[geos-commits] r2513 - trunk
svn_geos at osgeo.org svn_geos at osgeo.org
Thu May 21 05:56:04 EDT 2009
Author: strk
Date: 2009-05-21 05:56:03 -0400 (Thu, 21 May 2009)
New Revision: 2513
Added:
   trunk/ChangeLog.svn
   trunk/authors.svn
   trunk/Makefile.am
Add a rule to generate a ChangeLog using svn2cl. The authors.svn file will be used to map usernames and full names: please expand your own nick. The generated ChangeLog is added to repository to show you how it looks. If everybody agree we could rename this to ChangeLog and stop requiring manual edits (+1 from me:)
Added: trunk/ChangeLog.svn
--- trunk/ChangeLog.svn	                        (rev 0)
+++ trunk/ChangeLog.svn	2009-05-21 09:56:03 UTC (rev 2513)
@@ -0,0 +1,18903 @@
+2009-05-13 11:29  Frank Warmerdam <warmerdam at pobox.com>
+	* [r2508] capi/geos_c.h.in: refer to GEOSFree() instead of free()
+2009-05-13 11:26  Frank Warmerdam <warmerdam at pobox.com>
+	* [r2507] capi/geos_c.cpp, capi/geos_ts_c.cpp: forward GEOSFree to
+	  GEOSFree_r, use std:: prefix on free() (#249)
+2009-05-13 04:14  Frank Warmerdam <warmerdam at pobox.com>
+	* [r2506] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in,
+	  capi/geos_ts_c.cpp: Added GEOSFree() and GEOSFree_r() (#249)
+2009-05-12 17:47  Sandro Santilli <strk at keybit.net>
+	* [r2505] NEWS: Add note about single-sided buffer
+2009-05-12 16:49  Sandro Santilli <strk at keybit.net>
+	* [r2504] tests/xmltester/Makefile.am,
+	  tests/xmltester/tests/bug244.xml: Never fail bug #244 again
+	  (regression testcase added)
+2009-05-12 16:48  Sandro Santilli <strk at keybit.net>
+	* [r2503] source/operation/buffer/SubgraphDepthLocater.cpp: Have
+	  DepthSegment hold a real LineSegment, not a reference.
+	  SubgraphDepthLocater was passing the same LineSegment reference
+	  to multiple DepthSegments, messing everything up. This fixes bug
+	  #244.
+2009-05-12 15:38  Sandro Santilli <strk at keybit.net>
+	* [r2502] source/geomgraph/DirectedEdge.cpp,
+	  source/headers/geos/geomgraph/DirectedEdge.h,
+	  source/headers/geos/geomgraph/DirectedEdge.inl: Port info
+2009-05-08 16:30  Sandro Santilli <strk at keybit.net>
+	* [r2501] source/headers/geos/operation/overlay/PolygonBuilder.h,
+	  source/operation/overlay/PolygonBuilder.cpp: Update port info
+2009-05-08 12:47  Sandro Santilli <strk at keybit.net>
+	* [r2500] capi/geos_c.h.in: When included in a C++ environment,
+	  include <cstddef> and use std::size_t. Patch by Mateusz Loskot,
+	  ticket #252.
+2009-05-08 12:46  Sandro Santilli <strk at keybit.net>
+	* [r2499] source/operation/distance/DistanceOp.cpp: Oops, forgot to
+	  update the static closedPoints signature..
+2009-05-08 12:29  Sandro Santilli <strk at keybit.net>
+	* [r2498] NEWS: Note the withinDistance addition to DistanceOp
+2009-05-08 12:27  Sandro Santilli <strk at keybit.net>
+	* [r2497] tests/unit/operation/distance/DistanceOpTest.cpp: Add the
+	  complete set of tests for closedPoints
+2009-05-08 12:11  Sandro Santilli <strk at keybit.net>
+	* [r2496] source/headers/geos/operation/distance/DistanceOp.h:
+	  Document semantic of a null return from closestPoints
+2009-05-08 12:09  Sandro Santilli <strk at keybit.net>
+	* [r2495] source/headers/geos/operation/distance/DistanceOp.h,
+	  source/operation/distance/DistanceOp.cpp: Don't wipe out closest
+	  locations after computing them (doh). Fixes bug #236. Takes the
+	  chance to make the GeometryLocation retrival function private as
+	  we don't install GeometryLocation.h header anyway (for future
+	  cleanups), and to rename a function to follow current JTS naming
+	  (more renames to come for proper sync)
+2009-05-08 10:10  Sandro Santilli <strk at keybit.net>
+	* [r2494] source/headers/geos/operation/distance/DistanceOp.h,
+	  source/operation/distance/DistanceOp.cpp: Add isWithinDistance()
+	  to DistanceOp, reaching rev 1.17 of JTS
+2009-05-08 09:39  Sandro Santilli <strk at keybit.net>
+	* [r2493] source/headers/geos/operation/distance/DistanceOp.h,
+	  source/operation/distance/DistanceOp.cpp: Port info for
+	  DistanceOp
+2009-05-08 08:44  Sandro Santilli <strk at keybit.net>
+	* [r2492] capi/geos_c.h.in: Always include stddef.h. Closes bug
+	  #213
+2009-05-07 16:15  Sandro Santilli <strk at keybit.net>
+	* [r2491] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
+	  Add "thread-safe" version of GEOSGeom_setSRID. Closes bug #242.
+2009-05-07 16:00  Sandro Santilli <strk at keybit.net>
+	* [r2490] tests/bigtest/bug234.cpp: minor debug output improvement
+2009-05-07 15:57  Sandro Santilli <strk at keybit.net>
+	* [r2489] source/geomgraph/GeometryGraph.cpp,
+	  tests/bigtest/Makefile.am, tests/bigtest/README,
+	  tests/bigtest/bug234.cpp: Skip empty components when building
+	  GeometryGraph. Fixes bug #234. Add non-automated test for it, and
+	  README file in the directory containing it...
+2009-05-07 15:36  Sandro Santilli <strk at keybit.net>
+	* [r2488] tests/xmltester/Makefile.am,
+	  tests/xmltester/tests/bug188.xml: Add XML testcase for bug 188
+	* [r2487] tests/xmltester/XMLTester.cpp: remove code duplication on
+	  buffer result validation
+2009-05-07 08:52  Sandro Santilli <strk at keybit.net>
+	* [r2486] source/geom/CoordinateSequenceFactory.cpp,
+	  source/headers/geos/geom/CoordinateSequenceFactory.h: Port info,
+	  doxygen cleanups
+2009-05-07 08:45  Sandro Santilli <strk at keybit.net>
+	* [r2485] tests/unit/capi/GEOSCoordSeqTest.cpp: Add test for
+	  creating a CoordinateSequence with at least 2 dimension
+2009-05-06 20:47  Sandro Santilli <strk at keybit.net>
+	* [r2484] capi/geos_c.h.in, capi/geos_ts_c.cpp: Fix bug #135, give
+	  an hint about GEOSGeom_getDimensions being related to
+	  GEOSCoordSeq_getDimensions, fix signed vs. unsigned compiler
+	  warning.
+2009-05-06 20:22  Sandro Santilli <strk at keybit.net>
+	* [r2483] tests/xmltester/markup/MarkupSTL.cpp: Fix compilation
+	  warnings thrown by GCC 4.3.x. Patch by Mateus, closes bug #92.
+2009-05-06 20:12  mloskot
+	* [r2482] source/headers/geos/operation/overlay/snap: Updated
+	  svn:ignore property.
+2009-05-06 17:54  Sandro Santilli <strk at keybit.net>
+	* [r2481] source/headers/geos/noding/SegmentNodeList.h,
+	  source/noding/SegmentNodeList.cpp:
+	  findCollapsesFromExistingVertices: don't choke on sets of < 2
+	  points. Fixes bug #219.
+2009-05-06 17:52  Sandro Santilli <strk at keybit.net>
+	* [r2480] source/operation/buffer/BufferBuilder.cpp: minor
+	  indentation thing
+2009-05-06 17:42  Sandro Santilli <strk at keybit.net>
+	* [r2479] source/headers/geos/geom/Makefile.am,
+	  source/headers/geos/index/chain/MonotoneChain.h,
+	  source/headers/geos/index/chain/MonotoneChainOverlapAction.h,
+	  source/headers/geos/noding/MCIndexNoder.h,
+	  source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h,
+	  source/index/chain/MonotoneChain.cpp,
+	  source/index/chain/MonotoneChainOverlapAction.cpp,
+	  source/noding/MCIndexNoder.cpp,
+	  source/noding/MCIndexSegmentSetMutualIntersector.cpp: Cleanup
+	  MonotoneChainOverlapAction, reduce heap allocations. Cascade
+	  changes.
+2009-05-06 17:14  Sandro Santilli <strk at keybit.net>
+	* [r2478]
+	  source/index/chain/MonotoneChainOverlapAction.cpp: Port info (to
+	  be worked on for heap allocations reduction)
+2009-05-06 17:10  Sandro Santilli <strk at keybit.net>
+	* [r2477] source/algorithm/MCPointInRing.cpp,
+	  source/headers/geos/algorithm/MCPointInRing.h,
+	  source/headers/geos/index/chain/MonotoneChainSelectAction.h,
+	  source/index/chain/MonotoneChainSelectAction.cpp,
+	  source/noding/snapround/MCIndexPointSnapper.cpp:
+	  MonotoneChainSelectAction port review, heap allocation reduced,
+	  const-corrected.
+2009-05-06 16:44  Sandro Santilli <strk at keybit.net>
+	* [r2476] source/algorithm/MCPointInRing.cpp,
+	  source/headers/geos/index/SpatialIndex.h,
+	  source/headers/geos/index/bintree/Bintree.h,
+	  source/headers/geos/index/bintree/Root.h,
+	  source/index/bintree/Bintree.cpp,
+	  source/index/chain/MonotoneChainBuilder.cpp,
+	  MonotoneChain const-correctness and interface cleanups, cascaded
+	  changes. Possibly discovered a leak in MCPointInRing algorithm,
+	  needs some unit testing.
+2009-05-06 16:36  Sandro Santilli <strk at keybit.net>
+	* [r2475] source/headers/geos/index/bintree/Interval.h,
+	  source/index/bintree/Interval.cpp: Const-correctness for bintree
+	  Interval
+2009-05-06 15:47  Sandro Santilli <strk at keybit.net>
+	* [r2474] source/headers/geos/index/chain/MonotoneChain.h,
+	  source/index/chain/MonotoneChain.cpp: Port MonotoneChain up to
+	  JTS-1.10, plus minor dox improvement (memory-oriented)
+2009-05-06 15:31  Sandro Santilli <strk at keybit.net>
+	* [r2473] source/headers/geos/index/chain/MonotoneChainBuilder.h,
+	  source/index/chain/MonotoneChainBuilder.cpp: Port
+	  MonotoneChainBuilder up to JTS-1.10. Tweak some signatures to use
+	  stricter signedness.
+2009-05-06 14:55  Sandro Santilli <strk at keybit.net>
+	* [r2472] source/headers/geos/index/chain/MonotoneChainBuilder.h,
+	  source/index/chain/MonotoneChainBuilder.cpp: Port to 1.9, fixing
+	  an out of boundary access in findEdgeEnd
+2009-05-06 14:42  Sandro Santilli <strk at keybit.net>
+	* [r2471] source/headers/geos/index/chain/MonotoneChainBuilder.h,
+	  source/index/chain/MonotoneChainBuilder.cpp: Add port info. We're
+	  4 revision old (catching up next)
+2009-05-05 14:28  Sandro Santilli <strk at keybit.net>
+	* [r2470] source/geom/Envelope.cpp,
+	  source/headers/geos/geom/Envelope.h,
+	  source/headers/geos/geom/Envelope.inl: Sync Envelope to JTS-1.10
+2009-05-05 10:30  Sandro Santilli <strk at keybit.net>
+	* [r2469] tests/xmltester/XMLTester.cpp: Add compile-time support
+	  to skip use of BinaryOp thus engaging SnapIfNeededOverlayOp used
+	  by Geometry methods. Shows that BinaryOp (GEOS-specific original
+	  work) gives better numerical stability.
+2009-05-05 10:14  Sandro Santilli <strk at keybit.net>
+	* [r2468] configure.in, source/headers/geos/geom/BinaryOp.h,
+	  source/headers/geos/operation/overlay/Makefile.am,
+	  source/headers/geos/operation/overlay/snap/GeometrySnapper.h,
+	  source/headers/geos/operation/overlay/snap/LineStringSnapper.h,
+	  source/headers/geos/operation/overlay/snap/Makefile.am,
+	  source/headers/geos/precision/GeometrySnapper.h,
+	  source/headers/geos/precision/LineStringSnapper.h,
+	  source/headers/geos/precision/Makefile.am,
+	  source/operation/overlay/snap/GeometrySnapper.cpp,
+	  source/operation/overlay/snap/LineStringSnapper.cpp,
+	  source/operation/overlay/snap/SnapOverlayOp.cpp,
+	  source/precision/GeometrySnapper.cpp,
+	  source/precision/LineStringSnapper.cpp,
+	  source/precision/Makefile.am, tests/unit/Makefile.am,
+	  tests/unit/operation/overlay/snap,
+	  tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp,
+	  tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp,
+	  tests/unit/precision/GeometrySnapperTest.cpp,
+	  tests/unit/precision/LineStringSnapperTest.cpp: Found old
+	  GeometrySnapper/LineStringSnapper classes in an unexpected
+	  directory. Move them where they belong, sync with JTS-1.10.
+2009-05-05 00:04  Sandro Santilli <strk at keybit.net>
+	* [r2467] source/geom/util/GeometryTransformer.cpp: Fix memory leak
+	  on exception
+2009-05-04 23:43  Sandro Santilli <strk at keybit.net>
+	* [r2466] source/operation/IsSimpleOp.cpp: Fix memory bug
+2009-05-04 23:23  Sandro Santilli <strk at keybit.net>
+	* [r2465] source/geom/Geometry.cpp,
+	  source/headers/geos/geom/Geometry.h,
+	  source/headers/geos/geom/Geometry.inl: Geometry up to 1.112 with
+	  a minor bugfix and performance improvement in Geometry::covers
+2009-05-04 23:04  Sandro Santilli <strk at keybit.net>
+	* [r2464] source/geom/Geometry.cpp,
+	  source/headers/geos/geom/Geometry.inl: Bring Geometry port up a
+	  revision by having it use SnapIfNeededOp for overlay operations.
+	  Note that currently this doesn't affect the C-API nor the
+	  XMLTester codes, both using the BinaryOp original class (not
+	  JTS-ported) doing about the same thing as the SnapIfNeededOp
+	  class.
+2009-05-04 22:03  Sandro Santilli <strk at keybit.net>
+	* [r2463] source/headers/geos/operation/overlay/Makefile.am,
+	  source/headers/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h,
+	  source/headers/geos/operation/overlay/snap/SnapOverlayOp.h,
+	  source/operation/overlay/Makefile.am,
+	  source/operation/overlay/snap/SnapIfNeededOverlayOp.cpp: Port
+	  SnapIfNeededOverlayOp
+2009-05-04 21:28  Sandro Santilli <strk at keybit.net>
+	* [r2462]
+	  source/headers/geos/operation/overlay/FuzzyPointLocator.h,
+	  source/headers/geos/operation/overlay/OffsetPointGenerator.h,
+	  source/headers/geos/operation/overlay/OverlayResultValidator.h,
+	  source/headers/geos/operation/overlay/validate,
+	  source/headers/geos/operation/overlay/validate/FuzzyPointLocator.h,
+	  source/headers/geos/operation/overlay/validate/OffsetPointGenerator.h,
+	  source/headers/geos/operation/overlay/validate/OverlayResultValidator.h,
+	  source/operation/overlay/FuzzyPointLocator.cpp,
+	  source/operation/overlay/OffsetPointGenerator.cpp,
+	  source/operation/overlay/OverlayOp.cpp,
+	  source/operation/overlay/OverlayResultValidator.cpp,
+	  source/operation/overlay/validate,
+	  source/operation/overlay/validate/FuzzyPointLocator.cpp,
+	  source/operation/overlay/validate/OffsetPointGenerator.cpp,
+	  source/operation/overlay/validate/OverlayResultValidator.cpp,
+	  tests/unit/Makefile.am,
+	  tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp,
+	  tests/unit/operation/overlay/OffsetPointGeneratorTest.cpp,
+	  tests/unit/operation/overlay/OverlayResultValidatorTest.cpp,
+	  tests/unit/operation/overlay/validate,
+	  tests/unit/operation/overlay/validate/FuzzyPointLocatorTest.cpp,
+	  tests/unit/operation/overlay/validate/OffsetPointGeneratorTest.cpp,
+	  tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp:
+	  Move overlay.validate package files where they belong
+2009-05-04 21:02  Sandro Santilli <strk at keybit.net>
+	* [r2461] source/headers/geos/operation/overlay/Makefile.am,
+	  source/operation/overlay/snap/SnapOverlayOp.cpp: Port
+	  overlay.snap.SnapOverlayOp, update GeometrySnapper to be more
+	  useful
+2009-05-04 19:54  Sandro Santilli <strk at keybit.net>
+	* [r2460] source/headers/geos/operation/overlay/Makefile.am,
+	  source/operation/overlay/snap/GeometrySnapper.cpp: Port
+	  overlay.snap.GeometrySnapper
+2009-05-04 19:51  Sandro Santilli <strk at keybit.net>
+	* [r2459]
+	  source/operation/overlay/snap/LineStringSnapper.cpp: Extend to
+	  accept a vector of const Coordinate pointers for snap pointers,
+	  fix typo making it clone snap points rather than source points on
+	  snapping...
+2009-05-02 11:01  Sandro Santilli <strk at keybit.net>
+	* [r2458] source/headers/geos/operation/overlay/Makefile.am,
+	  source/headers/geos/operation/overlay/snap,
+	  source/operation/overlay/snap,
+	  source/operation/overlay/snap/LineStringSnapper.cpp: Port
+	  overlay.snap.LineStringSnapper from JTS-1.10
+2009-05-02 10:59  Sandro Santilli <strk at keybit.net>
+	* [r2457] source/geom/CoordinateArraySequence.cpp,
+	  source/headers/geos/geom/CoordinateArraySequence.h,
+	  source/headers/geos/geom/CoordinateSequence.h,
+	  tests/unit/geom/CoordinateArraySequenceTest.cpp: Add an
+	  insert-like virtual method to CoordinateSequence. This comes from
+	  CoordinateList of JTS, historically bound to CoordinateSequence
+	  in GEOS. Add test for that interface.
+2009-05-02 09:44  Sandro Santilli <strk at keybit.net>
+	* [r2456] tests/xmltester/Makefile.am,
+	  tests/xmltester/tests/general/MISSING,
+	  tests/xmltester/tests/general/TestRectanglePredicate.xml: Copy
+	  last portable JTS general test, add a file with info about what's
+	  missing
+2009-05-02 09:42  Sandro Santilli <strk at keybit.net>
+	* [r2455] tests/xmltester/tests/testLeaksBig.xml: Drop test also
+	  found in TestFunctionPLPrec.xml
+2009-05-02 09:40  Sandro Santilli <strk at keybit.net>
+	* [r2454] tests/xmltester/XMLTester.cpp: Add support for testing
+	  within, covers and coveredby. Properly use 'arg1' and 'arg2' for
+	  these tests.
+2009-05-02 09:25  Sandro Santilli <strk at keybit.net>
+	* [r2453] tests/xmltester/Makefile.am,
+	  tests/xmltester/tests/general/TestWithinDistance.xml,
+	  tests/xmltester/tests/testLeaksBig.xml: Copy
+	  TestWithinDistance.xml test, drop duplicates from
+	  testLeaksBig.xml
+2009-05-02 09:20  Sandro Santilli <strk at keybit.net>
+	* [r2452] tests/xmltester/Makefile.am,
+	  tests/xmltester/tests/general/TestFunctionAA.xml,
+	  tests/xmltester/tests/general/TestFunctionAAPrec.xml,
+	  tests/xmltester/tests/general/TestFunctionLA.xml,
+	  tests/xmltester/tests/general/TestFunctionLAPrec.xml,
+	  tests/xmltester/tests/general/TestFunctionLL.xml,
+	  tests/xmltester/tests/general/TestFunctionLLPrec.xml,
+	  tests/xmltester/tests/general/TestFunctionPA.xml,
+	  tests/xmltester/tests/general/TestFunctionPL.xml,
+	  tests/xmltester/tests/general/TestFunctionPLPrec.xml,
+	  tests/xmltester/tests/general/TestFunctionPP.xml: More tests from
+	  JTS (TestFunction*)
+2009-05-02 09:17  Sandro Santilli <strk at keybit.net>
+	* [r2451] tests/xmltester/Makefile.am,
+	  tests/xmltester/tests/general/TestBoundary.xml: Boundary test
+2009-05-02 09:16  Sandro Santilli <strk at keybit.net>
+	* [r2450] tests/xmltester/Makefile.am,
+	  tests/xmltester/tests/general/TestConvexHull-big.xml,
+	  tests/xmltester/tests/general/TestConvexHull.xml: ConvexHull
+	  tests
+2009-05-02 09:11  Sandro Santilli <strk at keybit.net>
+	* [r2449] tests/xmltester/Makefile.am,
+	  tests/xmltester/XMLTester.cpp,
+	  tests/xmltester/tests/general/TestRelateAA.xml,
+	  tests/xmltester/tests/general/TestRelateAC.xml,
+	  tests/xmltester/tests/general/TestRelateLA.xml,
+	  tests/xmltester/tests/general/TestRelateLC.xml,
+	  tests/xmltester/tests/general/TestRelateLL.xml,
+	  tests/xmltester/tests/general/TestRelatePA.xml,
+	  tests/xmltester/tests/general/TestRelatePL.xml,
+	  tests/xmltester/tests/general/TestRelatePP.xml: Add support for
+	  testing 'contains' in XMLTester, add all Relate tests from JTS
+2009-05-02 09:01  Sandro Santilli <strk at keybit.net>
+	* [r2448] tests/xmltester/Makefile.am,
+	  tests/xmltester/tests/TestBuffer.xml,
+	  tests/xmltester/tests/TestBufferMitredJoin.xml,
+	  tests/xmltester/tests/TestCentroid.xml,
+	  tests/xmltester/tests/TestInteriorPoint.xml,
+	  tests/xmltester/tests/TestSimple.xml,
+	  tests/xmltester/tests/TestValid.xml,
+	  tests/xmltester/tests/TestValid2-big.xml,
+	  tests/xmltester/tests/TestValid2.xml,
+	  tests/xmltester/tests/general,
+	  tests/xmltester/tests/general/TestBuffer.xml,
+	  tests/xmltester/tests/general/TestBufferMitredJoin.xml,
+	  tests/xmltester/tests/general/TestCentroid.xml,
+	  tests/xmltester/tests/general/TestInteriorPoint.xml,
+	  tests/xmltester/tests/general/TestSimple.xml,
+	  tests/xmltester/tests/general/TestValid.xml,
+	  tests/xmltester/tests/general/TestValid2-big.xml,
+	  tests/xmltester/tests/general/TestValid2.xml: More organization
+	  of xml tests: 'general' subdir following JTS
+2009-05-02 08:44  Sandro Santilli <strk at keybit.net>
+	* [r2447] tests/xmltester/Makefile.am, tests/xmltester/tests/stmlf,
+	  tests/xmltester/tests/stmlf-cases-20061020.xml,
+	  tests/xmltester/tests/stmlf-cases-20070119.xml,
+	  tests/xmltester/tests/stmlf/stmlf-cases-20061020.xml,
+	  tests/xmltester/tests/stmlf/stmlf-cases-20070119.xml: Put stml
+	  testcases under their own dir (like in JTS)
+2009-05-02 08:37  Sandro Santilli <strk at keybit.net>
+	* [r2446] tests/xmltester/Makefile.am,
+	  tests/xmltester/tests/TestRobustOverlayFixed.xml,
+	  tests/xmltester/tests/robust,
+	  tests/xmltester/tests/robust/TestRobustOverlayFixed.xml,
+	  tests/xmltester/tests/robust/TestRobustRelate.xml,
+	  tests/xmltester/tests/split.xml: Add a 'split.xml' testcase to
+	  confirm 'difference' may be used to split linestrings; add
+	  TestRobustRelate.xml from JTS, organize robust-related tests as
+	  in JTS repository.
+2009-04-30 12:42  Sandro Santilli <strk at keybit.net>
+	* [r2444] source/headers/geos/noding/snapround/SimpleSnapRounder.h:
+	  drop duplicated (and old) port info
+2009-04-30 12:33  Sandro Santilli <strk at keybit.net>
+	* [r2443] NEWS, source/geom/Geometry.cpp,
+	  source/headers/geos/geom/Geometry.inl: Update port info
+2009-04-30 12:17  Sandro Santilli <strk at keybit.net>
+	* [r2442] source/geom/Point.cpp, source/headers/geos/geom/Point.h:
+	  Point full up to JTS-1.0 (rev 1.37) : adds reverse()
+2009-04-30 12:07  Sandro Santilli <strk at keybit.net>
+	* [r2441] source/geom/LineString.cpp,
+	  source/headers/geos/geom/LineString.h: LineString to rev 1.46 :
+	  don't override isSimple, always return MultiPoint as bondary
+2009-04-30 11:47  Sandro Santilli <strk at keybit.net>
+	* [r2440] source/geom/Polygon.cpp,
+	  source/headers/geos/geom/Polygon.h: Polygon to rev 1.50
+	  (getBoundary always return MultiLineString)
+2009-04-30 11:42  Sandro Santilli <strk at keybit.net>
+	* [r2439] source/geom/MultiPoint.cpp,
+	  source/headers/geos/geom/MultiPoint.h: MultiPoint up to rev 1.30
+	  (drop isSimple override)
+2009-04-30 11:36  Sandro Santilli <strk at keybit.net>
+	* [r2438] source/geom/MultiLineString.cpp,
+	  source/headers/geos/geom/MultiLineString.h,
+	  source/headers/geos/geom/MultiLineString.inl: MultiLineString
+	  port info and sync to 1.40 (don't override isSimple)
+2009-04-30 11:29  Sandro Santilli <strk at keybit.net>
+	* [r2437] source/geom/MultiPolygon.cpp,
+	  source/headers/geos/geom/MultiPolygon.h,
+	  source/headers/geos/geom/MultiPolygon.inl: MultiPolygon up to rev
+	  1.34 (getBoundary always returns a MultiLineString now)
+2009-04-30 11:19  Sandro Santilli <strk at keybit.net>
+	* [r2436] source/geom/GeometryCollection.cpp,
+	  source/headers/geos/geom/GeometryCollection.h: Oops, *now* we're
+	  at 1.14 (drop isSimple, rely on the one in base class)
+2009-04-30 11:15  Sandro Santilli <strk at keybit.net>
+	* [r2435] source/geom/GeometryCollection.cpp,
+	  source/headers/geos/geom/GeometryCollection.h,
+	  source/headers/geos/geom/GeometryCollection.inl: Port info. It's
+	  at 1.41 now, JTS is at 1.42
+2009-04-30 11:03  Sandro Santilli <strk at keybit.net>
+	* [r2434] source/geom/Geometry.cpp,
+	  source/headers/geos/geom/Geometry.inl: Geometry class up to JTS
+	  rev 1.104 (need reach 1.127...)
+2009-04-30 10:59  Sandro Santilli <strk at keybit.net>
+	* [r2433] NEWS: Add some info about things changed (might have
+	  missed something)
+2009-04-30 10:51  Sandro Santilli <strk at keybit.net>
+	* [r2432] source/headers/geos/operation/IsSimpleOp.h,
+	  source/operation/IsSimpleOp.cpp: Sync to rev 1.22 (JTS-1.10)
+2009-04-30 10:47  Sandro Santilli <strk at keybit.net>
+	* [r2431] source/headers/geos/operation.h: EndpointInfo.h header is
+	  gone (it's always been private in JTS)
+2009-04-30 10:46  Sandro Santilli <strk at keybit.net>
+	* [r2430] source/headers/geos/operation/EndpointInfo.h,
+	  source/headers/geos/operation/IsSimpleOp.h,
+	  source/headers/geos/operation/Makefile.am,
+	  source/operation/IsSimpleOp.cpp: Port revision 1.9 of IsSimplOp :
+	  allow inspecting non-simple location coordinate.
+2009-04-30 10:43  Sandro Santilli <strk at keybit.net>
+	* [r2429] source/geomgraph/EdgeIntersection.cpp,
+	  source/headers/geos/geomgraph/EdgeIntersection.h: Sync to
+	  revision 1.5 (JTS-1.10) : add accessors
+2009-04-30 09:54  Sandro Santilli <strk at keybit.net>
+	* [r2428] source/headers/geos/operation/IsSimpleOp.h,
+	  source/operation/IsSimpleOp.cpp: port to rev 1.8 (use of
+	  BoundaryNodeRule)
+2009-04-30 09:49  Sandro Santilli <strk at keybit.net>
+	* [r2427] tests/xmltester/Makefile.am,
+	  tests/xmltester/tests/testLeaksBig.xml: Import TestSimple.xml
+	  from JTS, drop duplicated tests from testLeaksBig.xml
+2009-04-30 09:26  Sandro Santilli <strk at keybit.net>
+	* [r2426] source/algorithm/BoundaryNodeRule.cpp,
+	  source/algorithm/Makefile.am,
+	  source/headers/geos/algorithm/BoundaryNodeRule.h,
+	  source/headers/geos/algorithm/Makefile.am: Port
+	  algorithm::BoundaryNodeRule from JTS-1.10 (needed for IsSimpleOp
+	  sync)
+2009-04-30 08:33  Sandro Santilli <strk at keybit.net>
+	* [r2425] source/headers/geos/operation/IsSimpleOp.h,
+	  source/operation/IsSimpleOp.cpp: Port info, and sync from 1.14 to
+	  1.17 (more to do, need more classes)
+2009-04-29 23:52  mloskot
+	* [r2424] tests/unit/capi/GEOSContainsTest.cpp,
+	  tests/unit/capi/GEOSCoordSeqTest.cpp,
+	  tests/unit/capi/GEOSGeomFromWKBTest.cpp,
+	  tests/unit/capi/GEOSGeomToWKTTest.cpp,
+	  tests/unit/capi/GEOSPolygonizer_getCutEdgesTest.cpp,
+	  tests/unit/capi/GEOSPreparedGeometryTest.cpp,
+	  tests/unit/capi/GEOSSimplifyTest.cpp,
+	  tests/unit/capi/GEOSWithinTest.cpp: test/unit/capi: re-tab all
+	  .cpp files to use spaces.
+2009-04-29 23:46  mloskot
+	* [r2423] tests/unit/capi/GEOSContainsTest.cpp,
+	  tests/unit/capi/GEOSWithinTest.cpp: Removed unused <memory>
+	  header from C API tests.
+2009-04-29 23:44  mloskot
+	* [r2422] tests/unit/Makefile.am,
+	  tests/unit/capi/GEOSContainsTest.cpp,
+	  tests/unit/capi/GEOSWithinTest.cpp: Added new unit tests for C
+	  API: GEOSWithinTest and GEOSContainsTest. This is check and
+	  response for problems reporting in Ticket #250. Running the new
+	  tests does not reproduce the problem, so it likely has been fixed
+	  or the bug is somewhere else (i.e. Django layers).
+2009-04-29 09:44  Sandro Santilli <strk at keybit.net>
+	* [r2421] source/headers/geos/util/GeometricShapeFactory.h,
+	  source/util/GeometricShapeFactory.cpp: Sync GeometricShapeFactory
+	  to JTS-1.10 (createArcPolygon added)
+2009-04-29 08:56  Sandro Santilli <strk at keybit.net>
+	* [r2420] source/geom/prep/AbstractPreparedPolygonContains.cpp,
+	  source/geom/prep/PreparedPolygonContainsProperly.cpp,
+	  source/geom/prep/PreparedPolygonCovers.cpp,
+	  source/geom/prep/PreparedPolygonIntersects.cpp,
+	  source/geom/prep/PreparedPolygonPredicate.cpp,
+	  source/headers/geos/geom/prep/AbstractPreparedPolygonContains.h,
+	  source/headers/geos/geom/prep/PreparedPolygonContainsProperly.h,
+	  source/headers/geos/geom/prep/PreparedPolygonCovers.h,
+	  source/headers/geos/geom/prep/PreparedPolygonIntersects.h,
+	  source/headers/geos/geom/prep/PreparedPolygonPredicate.h: Bring
+	  all geom::prep package in sync with JTS-1.10
+2009-04-29 08:22  Sandro Santilli <strk at keybit.net>
+	* [r2419] source/geom/prep/BasicPreparedGeometry.cpp,
+	  source/headers/geos/geom/prep/BasicPreparedGeometry.h: Sync
+	  BasicPreparedGeometry to JTS-1.10 (short-circuit in
+	  containsProperly)
+2009-04-29 08:15  Sandro Santilli <strk at keybit.net>
+	* [r2418] source/geom/prep/AbstractPreparedPolygonContains.cpp,
+	  source/geom/prep/BasicPreparedGeometry.cpp,
+	  source/geom/prep/PreparedGeometry.cpp,
+	  source/geom/prep/PreparedGeometryFactory.cpp,
+	  source/geom/prep/PreparedLineString.cpp,
+	  source/geom/prep/PreparedLineStringIntersects.cpp,
+	  source/geom/prep/PreparedPoint.cpp,
+	  source/geom/prep/PreparedPolygon.cpp,
+	  source/geom/prep/PreparedPolygonContains.cpp,
+	  source/headers/geos/geom/prep/BasicPreparedGeometry.h,
+	  source/headers/geos/geom/prep/PreparedGeometry.h,
+	  source/headers/geos/geom/prep/PreparedGeometryFactory.h,
+	  source/headers/geos/geom/prep/PreparedLineString.h,
+	  source/headers/geos/geom/prep/PreparedLineStringIntersects.h,
+	  source/headers/geos/geom/prep/PreparedPoint.h,
+	  source/headers/geos/geom/prep/PreparedPolygon.h,
+	  source/headers/geos/geom/prep/PreparedPolygonContains.h,
+	  source/headers/geos/geom/prep/PreparedPolygonPredicate.h: Add
+	  port information for geom::prep package. Next stop: sync to
+	  JTS-1.10.
+2009-04-27 19:47  Sandro Santilli <strk at keybit.net>
+	* [r2417] tests/unit/capi/GEOSGeomToWKTTest.cpp: Plug last one. All
+	  heap blocks were freed -- no leaks are possible.
+2009-04-27 19:42  Sandro Santilli <strk at keybit.net>
+	* [r2416] tests/unit/algorithm/RobustLineIntersectorTest.cpp: Fix
+	  leak in testcase
+2009-04-27 19:38  Sandro Santilli <strk at keybit.net>
+	* [r2415] source/headers/geos/index/quadtree/Node.h,
+	  source/headers/geos/index/quadtree/Root.h,
+	  source/index/quadtree/Node.cpp, source/index/quadtree/Root.cpp:
+	  Refactor signatures to make ownership transfers more explicit.
+	  Fixed another leak in Node::insertNode.
+2009-04-27 19:22  Sandro Santilli <strk at keybit.net>
+	* [r2414] source/index/quadtree/NodeBase.cpp: Fix memory leak in
+	  NodeBase::remove, exposed by unit testing
+2009-04-27 15:52  Sandro Santilli <strk at keybit.net>
+	* [r2413] source/headers/geos/index/quadtree/Root.h,
+	  source/index/quadtree/Root.cpp: Port info for quadtree::root
+2009-04-27 15:47  Sandro Santilli <strk at keybit.net>
+	* [r2412] source/headers/geos/index/quadtree/Node.h,
+	  source/index/quadtree/Node.cpp: Port info for quadtree::Node
+2009-04-27 15:39  Sandro Santilli <strk at keybit.net>
+	* [r2411] source/headers/geos/index/quadtree/IntervalSize.h,
+	  source/index/quadtree/IntervalSize.cpp: Port info and check,
+	  doxygen.
+2009-04-27 15:30  Sandro Santilli <strk at keybit.net>
+	* [r2410] source/headers/geos/index/quadtree/Quadtree.h,
+	  source/index/quadtree/Quadtree.cpp: Sync to JTS-1.10, reduce heap
+	  allocations and pointers usage. Includes a bugfix in
+	  collectStats.
+2009-04-27 15:00  Sandro Santilli <strk at keybit.net>
+	* [r2409] source/headers/geos/index/quadtree/DoubleBits.h,
+	  source/index/quadtree/DoubleBits.cpp: DoubleBits didn't change in
+	  JTS, update port info accordingly
+2009-04-27 14:58  Sandro Santilli <strk at keybit.net>
+	* [r2408] source/headers/geos/index/quadtree/Node.h,
+	  source/headers/geos/index/quadtree/NodeBase.h,
+	  source/index/quadtree/NodeBase.cpp,
+	  source/index/quadtree/Quadtree.cpp: Quadtree's NodeBase: check
+	  port sync, add port info, drop unneeded pointers and virtuals,
+	  document objects ownership.
+2009-04-25 00:23  Sandro Santilli <strk at keybit.net>
+	* [r2407] source/headers/geos/index/SpatialIndex.h,
+	  source/headers/geos/index/quadtree/Key.h,
+	  source/headers/geos/index/quadtree/Node.h,
+	  source/index/quadtree/Key.cpp, source/index/quadtree/Node.cpp,
+	  source/index/quadtree/Root.cpp: Const-correctness, reduced heap
+	  allocations and port info for quadtree::Key class, a few more
+	  cleanups in user classes, to be continued.
+2009-04-24 23:44  Sandro Santilli <strk at keybit.net>
+	* [r2406] source/index/quadtree/Quadtree.cpp: Fix memory leak in
+	  Quadtree::remove
+2009-04-23 15:26  Sandro Santilli <strk at keybit.net>
+	* [r2405] source/headers/geos/operation/buffer/BufferBuilder.h,
+	  source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
+	  source/operation/buffer/BufferBuilder.cpp,
+	  source/operation/buffer/OffsetCurveBuilder.cpp,
+	  source/operation/buffer/OffsetCurveVertexList.h: Apply
+	  Single-sided buffer patch, issue #215. UNTESTED.
+2009-04-21 16:11  Sandro Santilli <strk at keybit.net>
+	* [r2404] tests/unit/Makefile.am,
+	  tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp:
+	  Port ValidSelfTouchingRingFormingHoleTest
+2009-04-21 15:30  Sandro Santilli <strk at keybit.net>
+	* [r2403] tests/unit/Makefile.am,
+	  tests/unit/operation/valid/ValidClosedRingTest.cpp: Port
+	  ValidClosedRingTest
+2009-04-21 15:13  Sandro Santilli <strk at keybit.net>
+	* [r2402] source/geom/LineString.cpp,
+	  source/headers/geos/geom/LineString.h: ::reverse returns a
+	  Geometry now (to be available up in base class)
+2009-04-21 15:12  Sandro Santilli <strk at keybit.net>
+	* [r2401] source/geom/LinearRing.cpp,
+	  source/headers/geos/geom/LinearRing.h,
+	  tests/unit/geom/LinearRingTest.cpp: Sync LinearRing to JTS-1.10
+	  (fixing a bug in isClosed)
+2009-04-21 14:03  Sandro Santilli <strk at keybit.net>
+	* [r2400] tests/unit/Makefile.am, tests/unit/operation/valid,
+	  tests/unit/operation/valid/IsValidTest.cpp: Port IsValidOp unit
+	  test
+2009-04-21 11:14  Sandro Santilli <strk at keybit.net>
+	* [r2399] configure.in: Configure for CXX, not C. Should fix
+	  unknown tag and link issues on telascience.
+2009-04-21 09:06  Sandro Santilli <strk at keybit.net>
+	* [r2398] configure.in: Add an AC_LIBTOOL_LANG_C_CONFIG call right
+	  before the AC_LIBTOOL_COMPILER_OPTION calls. Seems to fix
+	  compiler selection on telascience (whereas AC_LANG and
+	  AC_LANG_PUSH didn't work)
+2009-04-20 20:32  Sandro Santilli <strk at keybit.net>
+	* [r2397] tests/xmltester/BufferResultMatcher.cpp,
+	  tests/xmltester/BufferResultMatcher.h: Use JTS heuristic for
+	  distance-0 buffer checking
+2009-04-20 11:04  mloskot
+	* [r2396] tests/perf, tests/perf/operation,
+	  tests/perf/operation/buffer: Updated svn:ignore patterns.
+2009-04-20 10:37  Sandro Santilli <strk at keybit.net>
+	* [r2395] configure.in, tests/Makefile.am, tests/perf,
+	  tests/perf/Makefile.am, tests/perf/operation,
+	  tests/perf/operation/Makefile.am, tests/perf/operation/buffer,
+	  tests/perf/operation/buffer/IteratedBufferStressTest.cpp,
+	  tests/perf/operation/buffer/Makefile.am: Port
+	  IteratedBufferStessTest
+2009-04-20 09:37  Sandro Santilli <strk at keybit.net>
+	* [r2394] source/geomgraph/Quadrant.cpp,
+	  source/headers/geos/geomgraph/Quadrant.h: Add named constants,
+	  sync to JTS-1.10
+2009-04-20 09:24  mloskot
+	* [r2393] source/algorithm/distance,
+	  source/headers/geos/algorithm/distance: Updated svn:ignore
+	  patterns.
+2009-04-18 07:55  Sandro Santilli <strk at keybit.net>
+	* [r2392] tests/xmltester/XMLTester.cpp: Use BufferResultMatcher
+	  for buffer operations. No failures.
+2009-04-18 07:49  Sandro Santilli <strk at keybit.net>
+	* [r2391] tests/xmltester/tests/TestBigNastyBuffer.xml: Imported
+	  cleaned-up version of fme.xml -- this one fails (the one we have
+	  is actually expecting a wrong result)
+2009-04-18 07:46  Sandro Santilli <strk at keybit.net>
+	* [r2390] tests/xmltester/BufferResultMatcher.cpp: Don't densify
+	  coordinates if buffer distance is 0
+2009-04-17 16:50  Sandro Santilli <strk at keybit.net>
+	* [r2389]
+	  tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp:
+	  comment out debugging lines
+2009-04-17 16:49  Sandro Santilli <strk at keybit.net>
+	* [r2388] tests/unit/Makefile.am, tests/unit/algorithm/distance,
+	  Port DiscreteHausdorffDistance unit test
+2009-04-17 16:47  Sandro Santilli <strk at keybit.net>
+	* [r2387] source/algorithm/distance/DiscreteHausdorffDistance.cpp,
+	  source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h:
+	  Offline some more
+2009-04-17 16:46  Sandro Santilli <strk at keybit.net>
+	* [r2386]
+	  source/headers/geos/algorithm/distance/PointPairDistance.h: Fix
+	  typo
+2009-04-17 16:26  Sandro Santilli <strk at keybit.net>
+	* [r2385] source/algorithm/distance/DiscreteHausdorffDistance.cpp,
+	  Add missing implementation bits
+2009-04-17 15:47  Sandro Santilli <strk at keybit.net>
+	* [r2384] tests/xmltester/BufferResultMatcher.cpp,
+	  tests/xmltester/BufferResultMatcher.h,
+	  tests/xmltester/XMLTester.cpp: Port BufferResultMatcher. Gives 31
+	  new failures !!
+2009-04-17 15:37  Sandro Santilli <strk at keybit.net>
+	* [r2383] source/headers/geos/geom/BinaryOp.h,
+	  tests/xmltester/Makefile.am, tests/xmltester/XMLTester.cpp:
+	  proper inline check_valid source/headers/geos/geom/BinaryOp.h
+2009-04-17 15:34  Sandro Santilli <strk at keybit.net>
+	* [r2382] source/headers/geos/geom/BinaryOp.h: Header guard
+2009-04-17 13:59  Sandro Santilli <strk at keybit.net>
+	* [r2381] source/algorithm/LineIntersector.cpp,
+	  source/headers/geos/algorithm/LineIntersector.h,
+	  tests/unit/algorithm/RobustLineIntersectorTest.cpp: renamed
+	  intersection constants
+2009-04-17 09:56  Sandro Santilli <strk at keybit.net>
+	* [r2380] configure.in: Add debugging output of variables used by
+	  AC_LIBTOOL_COMPILER_OPTION. Surprisingly, the buildbots try to
+	  use a fortran compiler there
+2009-04-17 07:50  Sandro Santilli <strk at keybit.net>
+	* [r2379] configure.in: Differentiate variable used in
+	  AC_LIBTOOL_COMPILE_OPTION for proper use of configuration cache
+2009-04-16 18:05  Sandro Santilli <strk at keybit.net>
+	* [r2378] configure.in: Use -ffloat-store flag when available. See
+	  http://lists.osgeo.org/pipermail/geos-devel/2009-April/004089.html
+2009-04-16 12:56  Sandro Santilli <strk at keybit.net>
+	* [r2377] source/headers/geos/algorithm/LineIntersector.h: Make
+	  enum values explicit, as JTS tests rely on those..
+2009-04-16 12:54  Sandro Santilli <strk at keybit.net>
+	* [r2376] tests/unit/Makefile.am,
+	  tests/unit/algorithm/RobustLineIntersectorTest.cpp: Port
+	  RobustLineIntersectorTest from JTS
+2009-04-16 12:08  Sandro Santilli <strk at keybit.net>
+	* [r2375] tests/unit/algorithm/RobustLineIntersectionTest.cpp:
+	  better isolation of test-specific functions
+2009-04-16 10:48  Sandro Santilli <strk at keybit.net>
+	* [r2374] tests/unit/Makefile.am,
+	  tests/unit/algorithm/RobustLineIntersectionTest.cpp: Port
+	  RobustLineIntersectionTest (mostly failing, but reported by
+	  Martin Davis to be expected)
+2009-04-15 15:58  Sandro Santilli <strk at keybit.net>
+	* [r2373] source/algorithm/distance/DiscreteHausdorffDistance.cpp,
+	  source/algorithm/distance/DistanceToPoint.cpp,
+	  source/algorithm/distance/EuclideanDistanceToPoint.cpp,
+	  source/algorithm/distance/Makefile.am,
+	  source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h,
+	  source/headers/geos/algorithm/distance/DistanceToPoint.h,
+	  source/headers/geos/algorithm/distance/EuclideanDistanceToPoint.h,
+	  source/headers/geos/algorithm/distance/Makefile.am: New class
+	  rename, following JTS
+2009-04-15 12:56  Sandro Santilli <strk at keybit.net>
+	* [r2372] source/algorithm/HCoordinate.cpp: typo in disabled
+	  section
+2009-04-15 11:17  Sandro Santilli <strk at keybit.net>
+	* [r2371] source/headers/geos/index/quadtree/Key.h,
+	  source/index/quadtree/Key.cpp: Few more docs about memory
+	  management in quadtree indexing; fix a potential leak in
+	  quadtree::Key
+2009-04-15 10:43  Sandro Santilli <strk at keybit.net>
+	* [r2370] source/headers/geos/index/quadtree/NodeBase.h: Document
+	  ownership of quadtree::NodeBase subnodes
+2009-04-15 10:18  Sandro Santilli <strk at keybit.net>
+	* [r2369] tests/unit/util/UniqueCoordinateArrayFilterTest.cpp: Fix
+	  memory leak in unit test
+2009-04-15 10:02  Sandro Santilli <strk at keybit.net>
+	* [r2368] source/headers/geos/geom/CoordinateSequence.h,
+	  source/headers/geos/geom/util/CoordinateOperation.h,
+	  source/precision/SimpleGeometryPrecisionReducer.cpp: Fix leak in
+	  SimpleGeometryPrecisionReducer, improve memory management docs
+	  where topic.
+2009-04-15 09:29  Sandro Santilli <strk at keybit.net>
+	* [r2367] source/headers/geos/operation/distance/DistanceOp.h,
+	  tests/unit/operation/distance/DistanceOpTest.cpp: Document
+	  ownership of DistanceOp::closestPoints return, fix leak in unit
+	  test.
+2009-04-15 09:25  Sandro Santilli <strk at keybit.net>
+	* [r2366] source/geomgraph/EdgeRing.cpp,
+	  source/headers/geos/geomgraph/EdgeRing.h,
+	  source/headers/geos/operation/overlay/MaximalEdgeRing.h,
+	  source/headers/geos/operation/overlay/PolygonBuilder.h,
+	  source/operation/overlay/MaximalEdgeRing.cpp,
+	  source/operation/overlay/PolygonBuilder.cpp: Fix leak in
+	  PolygonBuilder (overlay operation). The leak was exposed by the
+	  stmlf-cases-20061020.xml testcase. This commit also adds some
+	  doc-only throw specs related to the bug.
+2009-04-15 07:52  Sandro Santilli <strk at keybit.net>
+	* [r2365] source/operation/valid/IndexedNestedRingTester.cpp: Fix
+	  memory leaks in IsValid operation
+2009-04-15 00:27  Sandro Santilli <strk at keybit.net>
+	* [r2364] source/algorithm/HCoordinate.cpp: Explain why unrolled
+	  computation is turned off, and keep it off
+2009-04-15 00:14  Sandro Santilli <strk at keybit.net>
+	* [r2363] source/operation/buffer/BufferInputLineSimplifier.cpp:
+	  Fix typo in computing angleOrientation
+2009-04-14 19:11  Sandro Santilli <strk at keybit.net>
+	* [r2362] source/algorithm/HCoordinate.cpp,
+	  tests/xmltester/tests/TestBufferMitredJoin.xml: Temporarly revert
+	  the unrolled computation in HCoordinate::intersection. Added
+	  mitred join buffer test from JTS (failed with the unrolled comp,
+	  to be further inspected).
+2009-04-14 16:43  Sandro Santilli <strk at keybit.net>
+	* [r2361] configure.in, source/algorithm/Makefile.am,
+	  source/algorithm/distance,
+	  source/algorithm/distance/DiscreteHausdorffDistance.cpp,
+	  source/headers/geos/algorithm/Makefile.am,
+	  source/headers/geos/algorithm/distance,
+	  source/headers/geos/algorithm/distance/Makefile.am,
+	  source/headers/geos/algorithm/distance/PointPairDistance.h,
+	  source/headers/geos/geom/CoordinateSequenceFilter.h: Port the
+	  algorithm::distance package from JTS 1.9
+2009-04-14 15:25  Sandro Santilli <strk at keybit.net>
+	* [r2360] source/geom/Geometry.cpp,
+	  source/geom/GeometryCollection.cpp,
+	  source/geom/GeometryComponentFilter.cpp,
+	  source/geom/LineString.cpp, source/geom/Point.cpp,
+	  source/geom/Polygon.cpp,
+	  source/headers/geos/geom/CoordinateSequenceFilter.h,
+	  source/headers/geos/geom/LineString.h,
+	  source/headers/geos/geom/Makefile.am,
+	  source/headers/geos/geom/Point.h,
+	  source/headers/geos/geom/Polygon.h: Add CoordinateSequenceFilter
+	  support, fix default GeometryComponentFilter moving the logic to
+	  the correct place (a Geometry private class).
+2009-04-14 13:35  Sandro Santilli <strk at keybit.net>
+	* [r2359] source/algorithm/LineIntersector.cpp,
+	  source/headers/geos/algorithm/LineIntersector.h: Sync
+	  (Robust)LineIntersector to JTS-1.9
+2009-04-14 13:23  Sandro Santilli <strk at keybit.net>
+	* [r2358] source/algorithm/CGAlgorithms.cpp,
+	  source/headers/geos/algorithm/CGAlgorithms.h: Sync CGAlgorithms
+	  with JTS-1.9
+2009-04-14 12:55  Sandro Santilli <strk at keybit.net>
+	* [r2357] source/algorithm/RayCrossingCounter.cpp,
+	  source/algorithm/locate/IndexedPointInAreaLocator.cpp,
+	  source/headers/geos/algorithm/RayCrossingCounter.h: Fix memory
+	  leak in RayCrossingCounter; update signatures to avoid pointers
+	  when unneeded; add a locatePointInRing taking a vector of
+	  coordinate pointers, for use by CGAlgorithms
+2009-04-14 12:42  Sandro Santilli <strk at keybit.net>
+	* [r2356] source/algorithm/RayCrossingCounter.cpp,
+	  source/headers/geos/algorithm/RayCrossingCounter.h: Update port
+	  info, checked against JTS-1.9
+2009-04-14 11:03  Sandro Santilli <strk at keybit.net>
+	* [r2355] tests/xmltester/Makefile.am,
+	  tests/xmltester/TestBuffer.xml,
+	  tests/xmltester/TestBufferExternal.xml,
+	  tests/xmltester/TestBufferExternal2.xml,
+	  tests/xmltester/TestCentroid.xml,
+	  tests/xmltester/TestInteriorPoint.xml,
+	  tests/xmltester/TestIsValid.xml,
+	  tests/xmltester/TestRobustOverlayFixed.xml,
+	  tests/xmltester/TestValid.xml,
+	  tests/xmltester/TestValid2-big.xml,
+	  tests/xmltester/TestValid2.xml, tests/xmltester/badguy3.xml,
+	  tests/xmltester/buffer.xml, tests/xmltester/buffer_snapround.xml,
+	  tests/xmltester/fme.xml, tests/xmltester/heisenbugs.xml,
+	  tests/xmltester/hexwkb.xml, tests/xmltester/hole_from_shell.xml,
+	  tests/xmltester/hole_red.xml, tests/xmltester/linemerge.xml,
+	  tests/xmltester/robustness.xml,
+	  tests/xmltester/stmlf-cases-20061020.xml,
+	  tests/xmltester/stmlf-cases-20070119.xml,
+	  tests/xmltester/test.xml, tests/xmltester/testLeaksBig.xml,
+	  tests/xmltester/tests, tests/xmltester/tests/TestBuffer.xml,
+	  tests/xmltester/tests/TestBufferExternal.xml,
+	  tests/xmltester/tests/TestBufferExternal2.xml,
+	  tests/xmltester/tests/TestIsValid.xml,
+	  tests/xmltester/tests/badguy3.xml,
+	  tests/xmltester/tests/buffer.xml,
+	  tests/xmltester/tests/buffer_snapround.xml,
+	  tests/xmltester/tests/fme.xml,
+	  tests/xmltester/tests/heisenbugs.xml,
+	  tests/xmltester/tests/hexwkb.xml,
+	  tests/xmltester/tests/hole_from_shell.xml,
+	  tests/xmltester/tests/hole_red.xml,
+	  tests/xmltester/tests/linemerge.xml,
+	  tests/xmltester/tests/robustness.xml,
+	  tests/xmltester/tests/test.xml,
+	  tests/xmltester/tests/testLeaksBig.xml: Move XML tests under
+	  their own directory
+2009-04-14 10:50  Sandro Santilli <strk at keybit.net>
+	* [r2354] source/operation/buffer/BufferBuilder.cpp: Fix memory
+	  leak in BufferBuilder (due to just-ported short-circuit)
+2009-04-14 10:27  Sandro Santilli <strk at keybit.net>
+	* [r2353] tests/xmltester/XMLTester.cpp: Add support for
+	  bufferMitredJoin tests
+2009-04-14 09:53  Sandro Santilli <strk at keybit.net>
+	* [r2352] tests/xmltester/Makefile.am,
+	  tests/xmltester/XMLTester.cpp, tests/xmltester/badguy3.xml,
+	  tests/xmltester/fme.xml, tests/xmltester/testLeaksBig.xml: Fix
+	  XML for Buffer testing to match jts layout (arg2 for distance,
+	  arg3 for quadrant segments); copy buffer-related tests from jts:
+	  they succeed w/out editing.
+2009-04-14 09:22  Sandro Santilli <strk at keybit.net>
+	* [r2351]
+	  source/headers/geos/operation/buffer/SubgraphDepthLocater.h,
+	  source/operation/buffer/SubgraphDepthLocater.cpp: Update port
+	  info of SubgraphDepthLocater
+2009-04-14 09:19  Sandro Santilli <strk at keybit.net>
+	* [r2350]
+	  source/headers/geos/operation/buffer/RightmostEdgeFinder.h,
+	  source/operation/buffer/RightmostEdgeFinder.cpp: Update port info
+	  for RightmostEdgeFinder (checked)
+2009-04-14 09:14  Sandro Santilli <strk at keybit.net>
+	* [r2349] source/headers/geos/operation/buffer/BufferSubgraph.h,
+	  source/operation/buffer/BufferSubgraph.cpp: Sync BufferSubgraph
+	  to JTS-1.9
+2009-04-14 08:52  Sandro Santilli <strk at keybit.net>
+	* [r2348]
+	  source/operation/buffer/OffsetCurveBuilder.cpp: Port
+	  OffsetCurveBuilder from JTS-1.9. Twenty time faster completion of
+	  fme.xml testcase !
+2009-04-10 20:22  Sandro Santilli <strk at keybit.net>
+	* [r2347] source/operation/buffer/BufferInputLineSimplifier.cpp,
+	  source/operation/buffer/BufferInputLineSimplifier.h,
+	  source/operation/buffer/Makefile.am: Port
+	  BufferInputLineSimplifier from JTS 1.9
+2009-04-10 15:15  mloskot
+	* [r2346] configure.in: Do not generate Makefile for
+	  tests/unit/tut. Fixed bug reported as #247.
+2009-04-10 12:08  Sandro Santilli <strk at keybit.net>
+	* [r2345] source/geom/LineSegment.cpp,
+	  source/headers/geos/geom/LineSegment.h,
+	  source/headers/geos/geom/LineSegment.inl: Sync LineSegment with
+	  JTS-1.9
+2009-04-09 21:46  mloskot
+	* [r2344] tests/unit/Makefile.am,
+	  tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp,
+	  tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp,
+	  tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp,
+	  tests/unit/algorithm/ConvexHullTest.cpp,
+	  tests/unit/algorithm/PointLocatorTest.cpp,
+	  tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp,
+	  tests/unit/geom/CoordinateArraySequenceTest.cpp,
+	  tests/unit/geom/CoordinateListTest.cpp,
+	  tests/unit/geom/CoordinateTest.cpp,
+	  tests/unit/geom/DimensionTest.cpp,
+	  tests/unit/geom/EnvelopeTest.cpp,
+	  tests/unit/geom/Geometry/coversTest.cpp,
+	  tests/unit/geom/Geometry/isRectangleTest.cpp,
+	  tests/unit/geom/GeometryFactoryTest.cpp,
+	  tests/unit/geom/IntersectionMatrixTest.cpp,
+	  tests/unit/geom/LineSegmentTest.cpp,
+	  tests/unit/geom/LineStringTest.cpp,
+	  tests/unit/geom/LinearRingTest.cpp,
+	  tests/unit/geom/LocationTest.cpp,
+	  tests/unit/geom/MultiLineStringTest.cpp,
+	  tests/unit/geom/MultiPointTest.cpp,
+	  tests/unit/geom/MultiPolygonTest.cpp,
+	  tests/unit/geom/PointTest.cpp, tests/unit/geom/PolygonTest.cpp,
+	  tests/unit/geom/TriangleTest.cpp,
+	  tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp,
+	  tests/unit/geos_unit.cpp,
+	  tests/unit/index/quadtree/DoubleBitsTest.cpp,
+	  tests/unit/io/ByteOrderValuesTest.cpp,
+	  tests/unit/io/WKBReaderTest.cpp,
+	  tests/unit/noding/BasicSegmentStringTest.cpp,
+	  tests/unit/noding/NodedSegmentStringTest.cpp,
+	  tests/unit/noding/SegmentNodeTest.cpp,
+	  tests/unit/noding/SegmentPointComparatorTest.cpp,
+	  tests/unit/operation/IsSimpleOpTest.cpp,
+	  tests/unit/operation/distance/DistanceOpTest.cpp,
+	  tests/unit/operation/union/CascadedPolygonUnionTest.cpp,
+	  tests/unit/precision/LineStringSnapperTest.cpp,
+	  tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp,
+	  tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp,
+	  tests/unit/simplify/TopologyPreservingSimplifierTest.cpp,
+	  tests/unit/tut/Makefile.am, tests/unit/tut/tut.h,
+	  tests/unit/tut/tut.hpp, tests/unit/tut/tut_assert.hpp,
+	  tests/unit/tut/tut_exception.hpp, tests/unit/tut/tut_posix.hpp,
+	  tests/unit/tut/tut_reporter.h, tests/unit/tut/tut_reporter.hpp,
+	  tests/unit/tut/tut_restartable.h,
+	  tests/unit/tut/tut_restartable.hpp,
+	  tests/unit/tut/tut_result.hpp, tests/unit/tut/tut_runner.hpp,
+	  tests/unit/util/UniqueCoordinateArrayFilterTest.cpp,
+	  tests/unit/utility.h: Updated tests/unit package with latest
+	  relase of C++ TUT Framework from 2008-11-30.
+2009-04-09 19:39  mloskot
+	* [r2343] configure.in, tests/Makefile.am, tests/tut,
+	  tests/unit/Makefile.am, tests/unit/tut,
+	  tests/unit/tut/tut_reporter.h, tests/unit/tut/tut_restartable.h:
+	  Moved tests/tut to tests/unit/tut. Preparing for update to latest
+	  version of C++ TUT Framework.
+2009-04-09 16:22  Sandro Santilli <strk at keybit.net>
+	* [r2342] source/algorithm/Angle.cpp, source/algorithm/Makefile.am,
+	  source/headers/geos/algorithm/Angle.h,
+	  source/headers/geos/algorithm/Makefile.am: Port algorithm.Angle
+	  from JTS-1.9
+2009-04-09 11:45  Sandro Santilli <strk at keybit.net>
+	* [r2341] source/headers/geos/operation/buffer/BufferBuilder.h,
+	  source/headers/geos/operation/buffer/BufferOp.h,
+	  source/operation/buffer/BufferOp.cpp,
+	  source/operation/buffer/OffsetCurveBuilder.cpp: Sync
+	  BufferBuilder and BufferOp classes to JTS-1.9. Adapt
+	  OffsetCurveBuilder to use of BufferParameter (needs more work for
+	  JTS-sync).
+2009-04-09 10:21  Sandro Santilli <strk at keybit.net>
+	* [r2340] source/headers/geos/operation/buffer/BufferParameters.h:
+	  typo
+2009-04-09 09:45  Sandro Santilli <strk at keybit.net>
+	* [r2339] source/headers/geos/operation/buffer/BufferParameters.h,
+	  source/headers/geos/operation/buffer/Makefile.am,
+	  source/operation/buffer/BufferParameters.cpp,
+	  source/operation/buffer/Makefile.am: Port BufferParameters from
+	  JTS-1.9
+2009-04-09 08:54  Sandro Santilli <strk at keybit.net>
+	* [r2338] source/operation/buffer/OffsetCurveBuilder.cpp,
+	  source/operation/buffer/OffsetCurveVertexList.h: Sync port of
+	  OffsetCurveVertexList to JTS-1.9, improve memory management
+	  documentation (would need some refactoring/love)
+2009-04-08 16:52  Sandro Santilli <strk at keybit.net>
+	* [r2337] source/geomgraph/EdgeList.cpp,
+	  source/headers/geos/geomgraph/EdgeList.h,
+	  source/headers/geos/noding/OrientedCoordinateArray.h: Improve
+	  duplicate edge detection performance (JTS-1.9 sync) - fme.xml
+	  runs 3 times as fast now.
+2009-04-08 16:17  Sandro Santilli <strk at keybit.net>
+	* [r2332] source/noding/OrientedCoordinateArray.cpp: const
+	  correctness
+2009-04-08 15:38  Sandro Santilli <strk at keybit.net>
+	* [r2329] capi/geos_c.h.in: Fix documentation for GEOSPrepare,
+	  GEOSPrepare_r
+2009-04-08 14:54  Sandro Santilli <strk at keybit.net>
+	* [r2328] source/headers/geos/noding/Makefile.am,
+	  source/headers/geos/noding/OrientedCoordinateArray.h,
+	  source/noding/Makefile.am,
+	  source/noding/OrientedCoordinateArray.cpp:
+	  OrientedCoordinateArray ported from JTS
+2009-04-08 14:41  Sandro Santilli <strk at keybit.net>
+	* [r2327] source/geom/CoordinateSequence.cpp,
+	  source/headers/geos/geom/CoordinateSequence.h: Add
+	  increasingDirection static method, from JTS's CoordinateArray
+	  (GEOS puts all of them in CoordinateSequence for historical
+	  reasons)
+2009-04-08 13:16  Sandro Santilli <strk at keybit.net>
+	* [r2326] source/headers/geos/noding/snapround/SimpleSnapRounder.h,
+	  source/noding/snapround/SimpleSnapRounder.cpp: Complete porting
+	  of SimpleSnapRounder (refactoring for adding snapped nodes)
+2009-04-08 13:02  Sandro Santilli <strk at keybit.net>
+	* [r2325] source/headers/geos/noding/SegmentStringUtil.h: Improve
+	  documentation about memory usage for SegmentStringUtil class
+2009-04-08 12:58  Sandro Santilli <strk at keybit.net>
+	* [r2324] tests/unit/Makefile.am,
+	  tests/unit/capi/GEOSPreparedGeometryTest.cpp: Stub initial unit
+	  tests for C-API's GEOSPreparedGeometry operations. Helped fixing
+	  issue 147 of postgis
+2009-04-08 12:55  Sandro Santilli <strk at keybit.net>
+	* [r2323] source/geom/prep/PreparedPolygonContainsProperly.cpp:
+	  Don't access deleted memory. Fixes issue 147.
+2009-04-08 10:53  Sandro Santilli <strk at keybit.net>
+	* [r2322] source/noding/snapround/HotPixel.cpp: Fix typo
+2009-04-08 10:06  Sandro Santilli <strk at keybit.net>
+	* [r2321] tests/unit/noding/SegmentNodeTest.cpp: Add a couple more
+	  tests to SegmentNode unit test
+2009-04-08 09:42  Sandro Santilli <strk at keybit.net>
+	* [r2320] source/headers/geos/noding/NodableSegmentString.h,
+	  source/headers/geos/noding/NodedSegmentString.h,
+	  source/headers/geos/noding/SegmentNode.h,
+	  source/headers/geos/noding/SegmentNodeList.h,
+	  source/noding/SegmentNode.cpp, source/noding/SegmentNodeList.cpp,
+	  tests/unit/noding/SegmentPointComparatorTest.cpp: Port
+	  SegmentNode to JTS-1.9
+2009-04-07 19:00  Sandro Santilli <strk at keybit.net>
+	* [r2319] source/geomgraph/EdgeNodingValidator.cpp,
+	  source/headers/geos/geomgraph/EdgeNodingValidator.h,
+	  source/headers/geos/noding/BasicSegmentString.h,
+	  source/headers/geos/noding/IntersectionAdder.h,
+	  source/headers/geos/noding/IntersectionFinderAdder.h,
+	  source/headers/geos/noding/IteratedNoder.h,
+	  source/headers/geos/noding/MCIndexNoder.inl,
+	  source/headers/geos/noding/Makefile.am,
+	  source/headers/geos/noding/NodableSegmentString.h,
+	  source/headers/geos/noding/SegmentString.h,
+	  source/headers/geos/noding/SegmentString.inl,
+	  source/headers/geos/noding/SimpleNoder.h,
+	  source/headers/geos/noding/snapround/MCIndexPointSnapper.h,
+	  source/headers/geos/noding/snapround/MCIndexSnapRounder.h,
+	  source/headers/geos/noding/snapround/MCIndexSnapRounder.inl,
+	  source/headers/geos/noding/snapround/SimpleSnapRounder.h,
+	  source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h,
+	  source/noding/BasicSegmentString.cpp,
+	  source/noding/IntersectionAdder.cpp,
+	  source/noding/IntersectionFinderAdder.cpp,
+	  source/noding/IteratedNoder.cpp, source/noding/MCIndexNoder.cpp,
+	  source/noding/Makefile.am, source/noding/NodedSegmentString.cpp,
+	  source/noding/ScaledNoder.cpp, source/noding/SegmentNodeList.cpp,
+	  source/noding/SegmentString.cpp, source/noding/SimpleNoder.cpp,
+	  source/noding/snapround/MCIndexPointSnapper.cpp,
+	  source/noding/snapround/MCIndexSnapRounder.cpp,
+	  source/noding/snapround/SimpleSnapRounder.cpp,
+	  source/operation/buffer/OffsetCurveSetBuilder.cpp,
+	  tests/unit/noding/SegmentStringTest.cpp: Refactor SegmentString
+	  to be an abstract class, to be in sync with JTS-1.9.
+2009-04-07 12:36  Sandro Santilli <strk at keybit.net>
+	* [r2318] source/operation/valid/IndexedNestedRingTester.cpp,
+	  source/operation/valid/IndexedNestedRingTester.h: update
+	  copyright notice
+2009-04-07 11:11  Sandro Santilli <strk at keybit.net>
+	* [r2317] source/headers/geos/noding/snapround/HotPixel.h,
+	  source/headers/geos/noding/snapround/HotPixel.inl,
+	  source/noding/snapround/HotPixel.cpp: Sync HotPixel to JTS-1.9
+	  (rev 1.3); fix a few bugs and use standard algorithms for min/max
+2009-04-07 10:48  Sandro Santilli <strk at keybit.net>
+	* [r2316] source/headers/geos/noding/NodedSegmentString.h: Fix
+	  signed vs. unsigned compiler warning
+2009-04-07 10:18  Sandro Santilli <strk at keybit.net>
+	* [r2315] source/headers/geos/operation/valid/IsValidOp.h: Port
+	  info, indenting
+2009-04-07 09:56  Sandro Santilli <strk at keybit.net>
+	* [r2314] source/operation/valid/IndexedNestedRingTester.cpp,
+	  source/operation/valid/IndexedNestedRingTester.h,
+	  source/operation/valid/IsValidOp.cpp,
+	  source/operation/valid/Makefile.am: Port IndexedNestedRingTester
+	  and have IsValidOp use it, syncing the operation to JTS-1.9
+2009-04-07 09:55  Sandro Santilli <strk at keybit.net>
+	* [r2313] source/headers/geos/noding/SegmentStringUtil.h: Update
+	  port info, minor tweaks to doxygen comments
+2009-04-07 08:14  Sandro Santilli <strk at keybit.net>
+	* [r2312] source/algorithm/HCoordinate.cpp,
+	  source/headers/geos/algorithm/HCoordinate.h: Sync HCoordinate
+	  class to JTS-1.9 (rev 1.18)
+2009-04-03 15:27  mloskot
+	* [r2311] nmake.opt: Added _NMAKE_VER 9.00.21022.08 to nmake.opt.
+	  Fixed bug with using BUILD_DEBUG instead of BUILD_BATCH in
+	  nmake.opt.
+2009-03-27 02:39  mloskot
+	* [r2310] build/msvc80/geos.sln,
+	  build/msvc80/geos_lib/geos_lib.vcproj: Updated build/msvc80.
+2009-03-27 02:38  mloskot
+	* [r2309] nmake.opt, source/Makefile.vc: Forgotten nmake.opt in
+	  last commit.
+2009-03-26 21:52  mloskot
+	* [r2308] build/msvc90/geos.sln,
+	  build/msvc90/geos_lib/geos_lib.vcproj, makefile.vc,
+	  source/Makefile.vc, source/dirlist.mk: Refactored NMAKE
+	  makefiles. Added nmake.opt file - GDAL style. Added some
+	  auto-magic to determine version of Visual C++ compiler and set
+	  version specific compilation flags. No need to specify Visual C++
+	  version in cmd line, but just run: nmake -f makefile.vc in root
+	  dir of the tree.
+2009-03-26 21:07  mloskot
+	* [r2307] source/operation/union/CascadedPolygonUnion.cpp:
+	  CascadedPolygonUnion.cpp: added missing std headers.
+2009-03-26 01:53  mloskot
+	* [r2306] TODO: Dummy commit - testing buildbot resurection.
+2009-03-24 16:49  mloskot
+	* [r2304] capi/geos_ts_c.cpp: Fixed bug introduced in recent
+	  refactoring work (r2281). This is the reason of PostGIS
+	  regression test failing (Issue 143)
+2009-03-24 15:58  pramsey
+	* [r2303] autogen.sh: Allow version test to work in glibtoolize
+2009-03-24 00:48  mloskot
+	* [r2302] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
+	  capi/geos_ts_c.cpp: refactoring, assert() to test against nullptr
+	  where it is forbidden.
+2009-03-24 00:30  mloskot
+	* [r2301] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
+	  REVERTED r2299: Fixed GEOSSetSRID_r missing, GEOSSetSRID
+	  duplicated (Ticket #242). A little of refactoring.
+2009-03-24 00:19  mloskot
+	* [r2300] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
+	  Fixed GEOSSetSRID_r missing, GEOSSetSRID duplicated (Ticket
+	  #242). A little of refactoring.
+2009-03-23 23:50  mloskot
+	* [r2299] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring, use
+	  single return expression per function, added assert() to test
+	  against nullptr where it is forbidden.
+2009-03-23 23:29  mloskot
+	* [r2298] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring, use
+	  against nullptr where it is forbidden, addd some comments.
+2009-03-23 22:19  mloskot
+	* [r2297] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring, use
+2009-03-23 21:07  mloskot
+	* [r2296] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring,
+	  replace manual strdup with gstrdup, use single return expression
+	  per function, added some comments.
+2009-03-23 20:31  mloskot
+	* [r2295] autogen.sh: dummy commit
+2009-03-23 20:03  mloskot
+	* [r2294] autogen.sh: autogen.sh: Fixed typo in tab character.
+2009-03-23 17:08  mloskot
+	* [r2293] autogen.sh: autogen.sh: be more verbose about versions,
+	  check for autoconf, check if ./configure is really generated.
+2009-03-23 16:28  mloskot
+	* [r2292] configure.in: configure.in: mloskot made a stupid
+	  mistake, mloskot has fixed it.
+2009-03-23 14:38  mloskot
+	* [r2291] configure.in: configure.in: wrap macro arguments with
+	  proper M4 quote characters.
+2009-03-23 14:08  mloskot
+	* [r2290] autogen.sh: autogen.sh: Call libtool *before* aclocal and
+	  automake (see Automake manual,8.3.9.1).
+2009-03-23 14:01  mloskot
+	* [r2289] autogen.sh: autogen.sh: verbose check if autotools
+	  versions.
+2009-03-22 20:29  pramsey
+	* [r2288] autogen.sh: Show what versions of things we're running
+2009-03-21 02:17  mloskot
+	* [r2287] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring -
+	  removed redundant return expressions, replaced bloated use of
+	  malloc + memcpy with single call to gstrdup, use of C++ cast
+	  operators, removed unnecessary allocation of std::string objects.
+2009-03-21 01:37  mloskot
+	* [r2286] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: added gstrdup and
+	  gstrdup_s helper functions to get rid of bloated code in future.
+	  Started eliminating redundant return expressions.
+2009-03-21 01:10  mloskot
+	* [r2285] macros: macros: Updated svn:ignore property.
+2009-03-21 01:08  mloskot
+	* [r2284] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: Use of spaces
+	  instead of tabs applied.
+2009-03-21 01:05  mloskot
+	* [r2283] source/operation/polygonize/EdgeRing.cpp:
+	  source/operation/polygonize/edgering.cpp: cleaned compiler
+	  warnings about mixed integral types.
+2009-03-21 01:01  mloskot
+	* [r2282] capi/geos_ts_c.cpp: Fixed deprecated conversion from
+	  string constant to char* in GEOSisValidReason_r. Small
+	  refactoring.
+2009-03-21 00:47  mloskot
+	* [r2281] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring, use
+	  c++ cast operators.
+2009-03-20 23:37  mloskot
+	* [r2280] source/operation/union: Updated svn:ignore property.
+2009-03-20 23:35  mloskot
+	* [r2279] build/msvc80/geos_unit/geos_unit.vcproj: Updated
+	  build/msvc80 project.
+2009-03-19 16:45  pramsey
+	* [r2278] autogen.sh: Fix spellingn mistake.
+2009-03-19 16:19  mloskot
+	* [r2277] build/msvc90/geos_unit/geos_unit.vcproj,
+	  tests/unit/capi/GEOSGeomFromWKBTest.cpp, tests/unit/utility.h: *
+	  tests/unit/capi: added GEOSGeomFromWKBTest with test cases (see
+	  comment) reported as a bug (See
+	  http://postgis.refractions.net/pipermail/postgis-devel/2009-March/005199.html).
+	  TODO: Reproduce and ask the reporter to submit a ticket if
+	  necessary.
+	  * test/unit/utility.h: Added helper class wkb_hex_decoder.
+	  * Updated build/msvc90 projects.
+2009-03-11 12:51  mloskot
+	* [r2276] source/operation/distance/DistanceOp.cpp,
+	  tests/unit/operation/distance/DistanceOpTest.cpp: BUG in
+	  DistanceOp:
+	  * Test case and explanation of existing bug in
+	  DistanceOp::closestPoints() recently reported by Aya (Ticket
+	  #236).
+	  * Refactored closestPoints() method to clearly present where is
+	  the bug. Again, chain calls are evil! Bless clear code!
+	  * tests/unit/operation/distance/DistanceOpTest.cpp: see test case
+	  test<17>, read FIXME comments. Uncomment closestPoints() to run
+	  and reproduce the bug.
+	  * A dirty fix: if loc0 or loc1 are nullptr, return nullptr
+	  CoordinatesSequence from closestPoints().
+2009-03-11 12:18  mloskot
+	* [r2275] source/geom/CoordinateArraySequence.cpp: Number of
+	  assertions in CoordinateArraySequence class.
+2009-03-10 17:29  pramsey
+	* [r2274] build/msvc90/geos_c_dll, build/msvc90/geos_lib,
+	  build/msvc90/geos_python, build/msvc90/geos_ruby,
+	  build/msvc90/geos_unit: svn:ignore
+2009-03-10 17:28  pramsey
+	* [r2273] build/msvc90, build/msvc90/geos_c_dll,
+	  build/msvc90/geos_lib, build/msvc90/geos_python,
+	  build/msvc90/geos_ruby, build/msvc90/geos_unit: svn:ignore
+2009-03-10 17:18  pramsey
+	* [r2272] NEWS: Update NEWS for 3.1.0
+2009-03-10 16:23  pramsey
+	* [r2271] ChangeLog: Update ChangeLog for 3.1.0 release
+2009-02-07 23:29  pramsey
+	* [r2269] source/headers/geos/precision/Makefile.am: Include
+	  GeometrySnapper.h in distribution package.
+2009-02-02 22:58  sgillies
+	* [r2268] swig/python/README.txt: Note lack of Python support since
+	  3.0
+2009-02-02 22:53  sgillies
+	* [r2267] README: Notes on state of scripting language bindings
+2009-01-30 20:01  pramsey
+	* [r2266] configure.in: Add new msvc targets to build
+2009-01-29 19:22  mloskot
+	* [r2265] build/Makefile.am, build/msvc90,
+	  build/msvc90/Makefile.am, build/msvc90/README,
+	  build/msvc90/geos.sln, build/msvc90/geos.vsprops,
+	  build/msvc90/geos_c_dll, build/msvc90/geos_c_dll/Makefile.am,
+	  build/msvc90/geos_c_dll/geos_c_dll.vcproj, build/msvc90/geos_lib,
+	  build/msvc90/geos_lib/Makefile.am,
+	  build/msvc90/geos_lib/geos_lib.vcproj, build/msvc90/geos_python,
+	  build/msvc90/geos_python/Makefile.am,
+	  build/msvc90/geos_python/geos_python.vcproj,
+	  build/msvc90/geos_ruby, build/msvc90/geos_ruby/Makefile.am,
+	  build/msvc90/geos_ruby/geos_ruby.vcproj, build/msvc90/geos_unit,
+	  build/msvc90/geos_unit/Makefile.am,
+	  build/msvc90/geos_unit/geos_unit.vcproj: Added build/msvc90 with
+	  solution and project files for Microsoft Visual C++ 2009 (9.0).
+	  Successfully built and tested GEOS with Visual C++ 9.0.
+2009-01-29 19:02  pramsey
+	* [r2264] README: update autogen.bat ref
+2009-01-29 18:56  mloskot
+	* [r2263] source/headers/geos/algorithm/RayCrossingCounter.h,
+	  source/headers/geos/algorithm/locate/IndexedPointInAreaLocator.h,
+	  source/headers/geos/algorithm/locate/PointOnGeometryLocator.h,
+	  source/headers/geos/geom/util/ComponentCoordinateExtracter.h,
+	  source/headers/geos/index/intervalrtree/IntervalRTreeBranchNode.h,
+	  source/headers/geos/index/intervalrtree/IntervalRTreeLeafNode.h,
+	  source/headers/geos/index/intervalrtree/IntervalRTreeNode.h,
+	  source/headers/geos/index/intervalrtree/SortedPackedIntervalRTree.h,
+	  source/headers/geos/noding/FastSegmentSetIntersectionFinder.h,
+	  source/headers/geos/noding/SegmentIntersectionDetector.h,
+	  source/headers/geos/noding/SegmentStringUtil.h: Fixed broken
+	  svn:keyword Id
+2009-01-29 18:51  mloskot
+	* [r2262] autogen.bat, bootstrap.bat: Renamed bootstrap.bat to
+	  autogen.bat for easier guass of the script purpose. Wiki updated.
+2009-01-28 01:06  pramsey
+	* [r2261] README: Add to win32 instructions
+2009-01-27 18:10  pramsey
+	* [r2260] source/headers/geos/geom/util/Makefile.am: Add
+	  GeometryCombiner.h to include dist
+2009-01-27 00:18  pramsey
+	* [r2259] build/msvc80/geos_c_dll/geos_c_dll.vcproj: Revert some
+	  junk from an old commit, per issue #220
+2009-01-26 20:44  Frank Warmerdam <warmerdam at pobox.com>
+	* [r2258] source/Makefile.vc: added two new files related to
+	  cascaded polygon union (#226)
+2009-01-24 05:03  pramsey
+	* [r2257] HOWTO_RELEASE: Update
+2009-01-24 05:02  pramsey
+	* [r2256] ChangeLog: Update changelog
+2009-01-24 01:33  mloskot
+	* [r2255] capi/geos_ts_c.cpp: Fixed mixed signed/unsigned integral
+	  types in geos_ts_c.cpp, so no compilers should flood with
+	  warnings now.
+2009-01-24 01:30  mloskot
+	* [r2254] build/msvc80/geos_c_dll/geos_c_dll.vcproj,
+	  build/msvc80/geos_lib/geos_lib.vcproj,
+	  build/msvc80/geos_unit/geos_unit.vcproj: Updated projects for
+	  Visual Studio 2005 adding new .h/.cpp files.
+2009-01-23 23:58  mloskot
+	* [r2253] capi/geos_ts_c.cpp,
+	  source/geom/util/GeometryCombiner.cpp,
+	  source/headers/geos/geom/util/GeometryCombiner.h,
+	  source/headers/geos/io/CLocalizer.h,
+	  source/headers/geos/operation/union/CascadedPolygonUnion.h,
+	  source/io/CLocalizer.cpp,
+	  source/operation/union/CascadedPolygonUnion.cpp,
+	  tests/unit/capi/badthreadtest.c, tests/unit/capi/threadtest.c,
+	  tests/unit/operation/union/CascadedPolygonUnionTest.cpp: Updated
+	  svn:keywords property on C/C++ files.
+2009-01-21 22:18  pramsey
+	* [r2252] source/geom/Geometry.cpp: Remove geometryCollection
+	  protection from Union/Relate/Intersection/Difference.
+2009-01-20 01:01  pramsey
+	* [r2251] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
+	  source/operation/union/CascadedPolygonUnion.cpp: Add
+	  GEOSUnionCascaded(*GEOSGeometry) to CAPI in preparation for
+	  PostGIS hook-up.
+2009-01-19 23:55  pramsey
+	* [r2250] capi/geos_c.cpp, capi/geos_ts_c.cpp: Formatting changes
+	  to function decls.
+2009-01-19 20:41  hobu
+	* [r2249] source/Makefile.vc: fixes to allow building in msvc 2003
+2009-01-19 20:00  pramsey
+	* [r2248] configure.in: Make warning flags conditional behind a
+	  compiler test... fix to bug #192 ?
+2009-01-19 16:44  pramsey
+	* [r2247]
+	  source/operation/union/CascadedPolygonUnion.cpp: Added patch from
+	  hkaiser to allow cascadedunion to be run directly on a
+	  multipolygon.
+2009-01-19 00:12  pramsey
+	* [r2246] autogen.sh: Fix error left behind from testing.
+2009-01-18 23:28  pramsey
+	* [r2245] autogen.sh: Add some more info on missing tools.
+2009-01-18 23:07  pramsey
+	* [r2244] HOWTO_RELEASE, Makefile.am, build, build/Makefile.am,
+	  build/msvc80, build/msvc80/Makefile.am, build/msvc80/geos_c_dll,
+	  build/msvc80/geos_c_dll/Makefile.am, build/msvc80/geos_lib,
+	  build/msvc80/geos_lib/Makefile.am, build/msvc80/geos_python,
+	  build/msvc80/geos_python/Makefile.am, build/msvc80/geos_ruby,
+	  build/msvc80/geos_ruby/Makefile.am, build/msvc80/geos_unit,
+	  build/msvc80/geos_unit/Makefile.am, configure.in,
+	  source/Makefile.vc, source/headers/geos/Makefile.am: Add msvc
+	  files to distribution target, and update release notes to include
+	  updating
+	  version in .vc headers.
+2009-01-18 22:35  pramsey
+	* [r2243] configure.in: Add a couple extra program checks.
+2009-01-18 21:30  pramsey
+	* [r2241] autogen.sh: Add version test for aclocal and automake to
+	  allow OpenSolaris to work.
+2009-01-18 20:34  pramsey
+	* [r2240] configure.in, source/geom/Envelope.cpp,
+	  source/geom/util/Makefile.am,
+	  source/headers/geos/index/strtree/AbstractSTRtree.h,
+	  source/headers/geos/noding/MCIndexNoder.h,
+	  source/headers/geos/operation/union,
+	  source/headers/geos/operation/union/Makefile.am,
+	  source/index/strtree/AbstractSTRtree.cpp,
+	  source/operation/Makefile.am, source/operation/union,
+	  source/operation/union/Makefile.am, tests/unit,
+	  tests/unit/Makefile.am, tests/unit/operation/union,
+	  tests/unit/operation/union/CascadedPolygonUnionTest.cpp: Apply
+	  cascaded union patch, for issue #225
+2009-01-15 01:00  pramsey
+	* [r2239] tests/xmltester/Makefile.am: Remove XMLTester from list
+	  of installed programs.
+2009-01-14 20:25  pramsey
+	* [r2238] capi/geos_ts_c.cpp: Remove strdup use from code for
+	  compilation in mingw
+2009-01-13 20:59  pramsey
+	* [r2237] configure.in: Add [macros] include to configure.in
+	  directly. Seems to make more recent aclocals happy
+2009-01-13 20:43  pramsey
+	* [r2236] configure.in: Change AC_SUBST to one-per-line instead of
+	  one-line-for-all. Seems to make more recent autoconf's happier.
+2009-01-13 19:23  pramsey
+	* [r2235] capi/geos_ts_c.cpp: Change return values for
+	  GEOSWKBWriter_getIncludeSRID_r to match function signature.
+2009-01-13 17:04  pramsey
+	* [r2234] tests/unit/capi/badthreadtest.c,
+	  tests/unit/capi/brokengrammar, tests/unit/capi/threadtest.c: More
+	  files missing from commit.
+2009-01-13 15:47  pramsey
+	* [r2233] capi/geos_ts_c.cpp: Add missing file to SVN.
+2009-01-13 01:21  pramsey
+	* [r2232] capi/Makefile.am, capi/geos_c.cpp, capi/geos_c.h.in,
+	  capi/geostest.c, capi/test.expected, capi/test.wkt,
+	  capi/testrunner.sh, tests/unit/Makefile.am,
+	  tests/unit/capi/geostest.c, tests/unit/capi/test.expected,
+	  tests/unit/capi/test.wkt, tests/unit/capi/testrunner.sh: Apply
+	  patch for issue #210 (thread safe c-api) submitted by Chuck
+	  Thibert.
+2009-01-05 23:42  swongu
+	* [r2231] source/operation/buffer/BufferBuilder.cpp,
+	  source/operation/buffer/OffsetCurveVertexList.h,
+	  source/operation/linemerge/LineMerger.cpp: Fixed memory leak in
+	  BufferBuilder (#218); added read-only coordinates function in
+	  OffsetCurveVertexList; explicity pass ownership in LineMerger.
+2008-11-26 19:41  pramsey
+	* [r2229] source/headers/geos/noding/Octant.h,
+	  tests/unit/noding/SegmentStringTest.cpp: Octant.h error (#185)
+	  from Denise Macleod.
+2008-11-26 19:27  pramsey
+	* [r2228] source/io/WKBWriter.cpp: Allow proper writing out of z
+	  ordinates. From Justin Bronn (#216)
+2008-11-26 19:25  pramsey
+	* [r2227] source/io/WKBReader.cpp: Allow readpoint to look at input
+	  dimension and fill higher ordinates. (#217)
+2008-11-26 19:06  pramsey
+	* [r2226] capi/geos_c.cpp, capi/geos_c.h.in: Expose
+	  GEOSIsValidReason to CAPI
+2008-11-18 03:09  pramsey
+	* [r2221] source/inlines.cpp: Cygwin build fix from MCA
+2008-11-11 17:32  pramsey
+	* [r2220] source/geomgraph/EdgeList.cpp,
+	  source/operation/overlay/OverlayOp.cpp: Memory leak on invalid
+	  polygons in intersection(). (#170) from Denise MacLeod.
+2008-11-05 20:52  pramsey
+	* [r2218] source/geom/prep/PreparedLineStringIntersects.cpp:
+	  Another minor memory leak removed.
+2008-10-28 15:47  pramsey
+	* [r2217] source/inlines.cpp: Cygwin/Mingw patch from Mark
+	  Cave-Ayland
+2008-10-23 17:33  Frank Warmerdam <warmerdam at pobox.com>
+	* [r2210] source/operation/valid/IsValidOp.cpp: set isChecked flag
+	  after checking to fix memory leak (#169)
+2008-10-16 00:40  pramsey
+	* [r2203] HOWTO_RELEASE: change info to point to osgeo.org
+2008-10-14 15:01  pramsey
+	* [r2200] capi/geos_c.cpp, capi/geos_c.h.in: Consistent const
+	  declarations in c-api ($#209)
+2008-10-13 22:40  pramsey
+	* [r2199] source/headers/geos/io/Makefile.am: Add CLocalizer.h to
+	  build so it gets packaged in make dist
+2008-10-10 17:46  pramsey
+	* [r2198] source/geom/prep/PreparedPolygonContainsProperly.cpp: One
+	  last memory leak fix.
+2008-10-09 16:39  pramsey
+	* [r2197] source/geom/prep/PreparedPolygonIntersects.cpp: Memory
+	  leak fix for for prepared intersects. (#207)
+2008-10-04 18:14  pramsey
+	* [r2196]
+	  source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h,
+	  source/noding/MCIndexSegmentSetMutualIntersector.cpp: Memory leak
+	  fix for prepared geometry, from Hartmut Kaiser. (#207)
+2008-09-29 19:24  pramsey
+	* [r2195] capi/geos_c.cpp: Put function sig on one line
+2008-09-23 23:01  mloskot
+	* [r2194] source/geom/prep/AbstractPreparedPolygonContains.cpp,
+	  source/headers/geos/index/SpatialIndex.h,
+	  source/headers/geos/index/chain/MonotoneChain.h,
+	  source/headers/geos/index/strtree/ItemBoundable.h,
+	  source/headers/geos/noding/SegmentSetMutualIntersector.h,
+	  source/index/chain/MonotoneChain.cpp,
+	  source/index/chain/MonotoneChainBuilder.cpp,
+	  source/index/strtree/ItemBoundable.cpp: Moved some ctor/dctor
+	  bodies from headers to translation units. Improved source code
+	  readability. TODO: We need to run a beast like AStyle on all GEOS
+	  code because many places are very hard to read.
+2008-09-23 22:55  mloskot
+	* [r2193] source/noding/MCIndexSegmentSetMutualIntersector.cpp:
+	  MCIndexSegmentSetMutualIntersector::addToIndex: Completed BWJ's
+	  comment on memory leaks with important observations about objects
+	  relation & lifetime. The note is a diagnosis of roots of the
+	  problem. Improved source code readability.
+2008-09-22 21:48  mloskot
+	* [r2192] source/headers/geos/io/WKBWriter.h: Use conditional
+	  operators instead of cast bool to int.
+2008-09-22 20:16  mloskot
+	* [r2191] source/simplify/TopologyPreservingSimplifier.cpp: Removed
+	  unnecessary std::endl from debug messages in
+	  TopologyPreservingSimplifier.cpp.
+2008-09-21 21:32  mloskot
+	* [r2190] source/Makefile.vc: Patched NMAKE makefiles: replaced
+	  lib.exe with link.exe /lib command to enabled compilation using
+	  Microsoft Visual C++ Toolkit 2003
+2008-09-16 21:09  mloskot
+	* [r2189] source/operation/predicate/SegmentIntersectionTester.cpp,
+	  source/util/math.cpp: Patch fixing build problems on Solaris
+	  (Ticket #205).
+2008-09-16 21:01  mloskot
+	* [r2188] tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp:
+	  Fixed EOL to LF.
+2008-09-16 20:58  mloskot
+	* [r2187] source/geom/prep/PreparedGeometryFactory.cpp,
+	  tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp: Fixed crash
+	  of Prepared Geometry construction with nullptr to Geometry object
+	  (Ticket #197).
+2008-09-16 20:55  mloskot
+	* [r2186] build/msvc80/geos_unit/geos_unit.vcproj: Added
+	  PreparedGeometryFactoryTest to geos_unit.vcproj.
+2008-09-16 20:15  mloskot
+	* [r2185] build/msvc80/geos_lib/geos_lib.vcproj: Added CLocalizer
+	  to geos_lib.vcproj project for Visual C++ 2005/2008.
+2008-09-16 20:13  mloskot
+	* [r2184] tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp:
+	  Include missing <cassert> in isPointInRingTest.cpp
+2008-09-16 20:05  mloskot
+	* [r2183] source/Makefile.vc, source/io/CLocalizer.cpp: Fixed
+	  undeclared std::locale in CLocalizer when building using Visual
+	  C++ (Ticket #201)
+2008-08-31 20:28  mloskot
+	* [r2182] tests/unit/geos_unit.cpp: Replaced incorrect <cmath> with
+	  <cstdlib> in geos_unit.cpp.
+2008-08-31 20:23  mloskot
+	* [r2181] tests/unit/geos_unit.cpp: Added missing include <cmath>
+	  in geos_unit.cpp.
+2008-08-31 19:54  mloskot
+	* [r2180] source/headers/geos/io/CLocalizer.h,
+	  source/io/CLocalizer.cpp: Removed use of strdup function to fix
+	  compilation with GCC 4.3.1 (Ticket #204).
+2008-08-29 18:17  mloskot
+	* [r2179] capi/geos_c.cpp: Removed redundant return expressions
+	  from geos_c.cpp. Testing changes notifications for buildbot.
+2008-08-29 00:30  mloskot
+	* [r2176] capi/geos_c.cpp: Fixed execution paths and removed
+	  redundant return expr in some C API calls.
+2008-08-29 00:29  mloskot
+	* [r2175] source/headers/geos/io/WKBWriter.h,
+	  source/io/WKBWriter.cpp: Added missing virtual destructor to
+	  WKBWriter class.
+2008-08-28 22:20  sgillies
+	* [r2174] capi/geos_c.cpp, source/headers/geos/io.h,
+	  source/headers/geos/io/CLocalizer.h, source/io/CLocalizer.cpp,
+	  source/io/Makefile.am: Added CLocalizer class that switches to C
+	  locale and restores to the outer context's locale when deleted
+	  (#201)
+2008-08-28 21:35  mloskot
+	* [r2173] tests/unit/Makefile.am,
+	  tests/unit/capi/GEOSGeomToWKTTest.cpp: tests/unit: added
+	  GEOSGeomToWKTTest.
+2008-08-28 19:16  sgillies
+	* [r2172] capi/geos_c.cpp: Switch to C locale while reading and
+	  writing WKT and restore to the original context's locale
+	  afterward (#201)
+2008-08-22 17:25  Frank Warmerdam <warmerdam at pobox.com>
+	* [r2171] source/operation/buffer/BufferOp.cpp: include cmath for
+	  std::pow() and std:log() on MSVC7.1 (#199)
+2008-08-22 16:10  mloskot
+	* [r2170] build/bjam/README: Added build/bjam/README with status
+	  note.
+2008-08-19 17:02  mloskot
+	* [r2169] tests/unit/geom/LineStringTest.cpp: LineStringTest: fixed
+	  memory leak.
+2008-08-19 17:00  mloskot
+	* [r2168] source/geom/util/CoordinateOperation.cpp,
+	  source/geom/util/GeometryEditor.cpp: geos/geom/util: Prefer
+	  strict static_cast than C-style cast. Commented ownership
+	  transfer of coordinates object.
+2008-08-19 00:18  mloskot
+	* [r2167] tests/unit/algorithm/ConvexHullTest.cpp:
+	  tests/unit/algorithm/ConvexHullTest.cpp: Fixed memory leaks.
+2008-08-19 00:05  mloskot
+	* [r2166] tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp:
+	  tests/unit/algorithm/CGAlgorithms: Fixed memory leaks.
+2008-08-18 23:45  mloskot
+	* [r2165] tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp:
+	  tests/unit/algorithm/CGAlgorithms: Fixed number of memory leaks.
+2008-08-18 23:30  mloskot
+	* [r2164] tests/unit/capi/GEOSCoordSeqTest.cpp,
+	  tests/unit/capi/GEOSSimplifyTest.cpp: tests/unit/capi: Fixed
+	  number of memory leaks.
+2008-08-18 16:32  mloskot
+	* [r2163] tests/bigtest/GeometryTestFactory.cpp,
+	  tests/bigtest/TestSweepLineSpeed.cpp: tests/bigtest: Pointed out
+	  number of memory leaks but not fixing them, waiting for comments.
+2008-08-18 16:30  mloskot
+	* [r2162] tests/unit/algorithm/ConvexHullTest.cpp,
+	  tests/unit/geom/PolygonTest.cpp,
+	  tests/unit/utility.h: tests/unit: added tests cases to
+	  PreparedGeometryFactoryTest, refactored casting utils and
+	  geometry comparators, small cleanup.
+2008-08-18 16:29  mloskot
+	* [r2161] source/algorithm/RayCrossingCounter.cpp,
+	  source/algorithm/locate/PointOnGeometryLocator.cpp,
+	  source/geom/util/ComponentCoordinateExtracter.cpp,
+	  source/index/intervalrtree/IntervalRTreeBranchNode.cpp,
+	  source/index/intervalrtree/IntervalRTreeLeafNode.cpp,
+	  source/index/intervalrtree/IntervalRTreeNode.cpp,
+	  source/index/intervalrtree/SortedPackedIntervalRTree.cpp,
+	  source/noding/FastSegmentSetIntersectionFinder.cpp,
+	  source/noding/MCIndexSegmentSetMutualIntersector.cpp,
+	  source/noding/NodedSegmentString.cpp,
+	  source/noding/SegmentIntersectionDetector.cpp,
+	  source/noding/SegmentStringUtil.cpp: Fixed svn:keywords.
+2008-08-18 16:27  mloskot
+	* [r2160] source/headers/geos/util.h: Fixed UNREFERENCED_PARAMETER
+	  macro.
+	* [r2159]
+	  source/headers/geos/geom/prep/PreparedPolygonPredicate.h: Fixed
+	  svn:keywords.
+2008-08-18 16:24  mloskot
+	* [r2158] source/geom/prep/AbstractPreparedPolygonContains.cpp,
+	  source/geom/prep/PreparedPolygonPredicate.cpp: geom/prep:
+	  Refactored kamikaze casts to more readable form. Fixed
+	  svn:keywords.
+2008-08-12 00:25  mloskot
+	* [r2157] source/headers/geos/geomPrep.h: Fixed Id keywords.
+2008-08-12 00:23  mloskot
+	* [r2156]
+	  tests/unit/operation/IsSimpleOpTest.cpp: Fixed EOL to LF in
+	  trunk/tests.
+2008-08-12 00:09  mloskot
+	* [r2155] source/headers/geos/geom/prep/PreparedGeometryFactory.h:
+	  Updated svn:keywords property.
+2008-08-12 00:03  mloskot
+	* [r2154] tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp:
+2008-08-11 23:54  mloskot
+	* [r2153] tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp:
+	  Refactored tabs vs spaces in PreparedGeometryFactoryTest.
+2008-08-11 23:52  mloskot
+	* [r2152] source/headers/geos/geom/prep/PreparedGeometryFactory.h:
+	  PreparedGeometry must be a complete type where it is destroyed by
+	  the factory (Ticket #198).
+2008-08-11 23:42  mloskot
+	* [r2151] source/headers/geos/geom/prep/PreparedGeometryFactory.h,
+	  tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp: Completed
+	  PreparedGeometryFactory class with missing named destructor for
+	  PreparedGeometry (Ticket #198)
+2008-08-11 23:35  mloskot
+	* [r2150]
+	  tests/unit/geom/prep/.PreparedGeometryFactoryTest.cpp.swp:
+	  Removed .PreparedGeometryFactoryTest.cpp.swp that must sneaked
+	  accidentally.
+2008-08-11 22:48  mloskot
+	* [r2149] tests/unit/Makefile.am, tests/unit/geom/prep,
+	  tests/unit/geom/prep/.PreparedGeometryFactoryTest.cpp.swp,
+	  tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp: Added
+	  PreparedGeometryFactoryTest with first test cases included.
+	  FIXME: The test causes memory leak because we don't know how to
+	  destroy PreparedGeometry objects returned by the factory,
+	  discussing on the geos-devel list now.
+2008-08-07 16:59  pramsey
+	* [r2148] source/algorithm/RobustDeterminant.cpp: Added original
+	  author to main copyright block.
+2008-08-07 16:57  pramsey
+	* [r2147] source/headers/geos/timeval.h: Change to standard header,
+	  with (c) credit to author.
+2008-08-01 23:23  mloskot
+	* [r2146] ChangeLog: Updated ChangeLog with latest submissions.
+	  Hmm, should we stil maintain the ChangeLog file?
+2008-07-31 17:08  mloskot
+	* [r2145] tests/unit/capi/GEOSPolygonizer_getCutEdgesTest.cpp:
+	  Fixed tabs, hopefully. Updated svn:keywords property.
+2008-07-31 17:01  mloskot
+	* [r2144] capi/geos_c.cpp, capi/geos_c.h.in,
+	  tests/unit/capi/GEOSPolygonizer_getCutEdgesTest.cpp: Patch
+	  completing C API interface with wrapper on
+	  Polygonizer::getCutEdges (Ticket #195). Unit test included in
+	  tests/unit/capi/GEOSPolygonizer_getCutEdgeTest.cpp. Thanks to
+	  Jurgen E. Fischer for this patch.
+2008-07-26 23:06  mloskot
+	* [r2143] doc/example.cpp, source/geomgraph/GeometryGraph.cpp,
+	  source/headers/geos/noding/FastNodingValidator.h,
+	  source/index/quadtree/DoubleBits.cpp,
+	  source/io/StringTokenizer.cpp,
+	  tests/bigtest/TestSweepLineSpeed.cpp: Number of fixes enabling
+	  GEOS compilation with GCC 4.3 (Ticket #167).
+2008-07-26 21:00  mloskot
+	* [r2142] capi/geos_c.h.in: Guarded version macros with #ifndef
+	  conditions to avoid redefinition errors (Ticket #167).
+2008-07-26 20:47  mloskot
+	* [r2141] source/headers/geos/version.h.in,
+	  source/headers/geos/version.h.vc: Guarded version macros with
+	  #ifndef conditions to avoid redefinition errors (Ticket #167).
+2008-07-26 20:24  mloskot
+	* [r2140] macros/ac_python_devel.m4: Fixed problems with finding
+	  libpython on Mac Darwin (Ticket #191).
+2008-07-26 19:57  mloskot
+	* [r2139] autogen.sh: Updated svn:keywords property.
+2008-07-26 19:56  mloskot
+	* [r2138] autogen.sh: Fixed autogen.sh for OpenSolaris (Ticket
+	  #192).
+2008-07-25 21:00  mloskot
+	* [r2137] build/README, build/msvc80/README, macros/geos.m4,
+	  source/headers/geos/algorithm/CentralEndpointIntersector.h,
+	  source/headers/geos/geomPrep.h,
+	  source/headers/geos/indexIntervalRTree.h,
+	  source/headers/geos/noding/SingleInteriorIntersectionFinder.h,
+	  source/noding/FastNodingValidator.cpp,
+	  source/noding/SingleInteriorIntersectionFinder.cpp,
+	  swig/python/tests/TESTING.txt: Updated svn:keywords property
+2008-07-25 20:56  mloskot
+	* [r2136] tests/unit/operation/IsSimpleOpTest.cpp,
+	  tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp:
+2008-07-19 19:11  Frank Warmerdam <warmerdam at pobox.com>
+	* [r2135] source/Makefile.vc: added manifest handling for DLLs
+	  (#193)
+2008-07-19 19:07  Frank Warmerdam <warmerdam at pobox.com>
+	* [r2134] source/Makefile.vc: added rules to create platform.h,
+	  version.h and geos_c.h from templates on win32
+2008-07-15 22:04  mloskot
+	* [r2131] ChangeLog, capi/geos_c.cpp,
+	  source/algorithm/ConvexHull.cpp,
+	  source/algorithm/RobustDeterminant.cpp,
+	  source/geomgraph/EdgeEnd.cpp, source/geomgraph/GeometryGraph.cpp,
+	  source/headers/geos/geom/Coordinate.inl,
+	  source/headers/geos/geom/LineSegment.inl,
+	  source/headers/geos/io/WKBReader.h,
+	  source/index/bintree/Key.cpp, source/index/quadtree/Key.cpp,
+	  source/io/ByteOrderValues.cpp, source/noding/Octant.cpp,
+	  source/operation/distance/ConnectedElementPointFilter.cpp,
+	  source/planargraph/DirectedEdge.cpp,
+	  source/precision/SimpleGeometryPrecisionReducer.cpp,
+	  source/util/math.cpp, tests/xmltester/XMLTester.cpp,
+	  tests/xmltester/markup/MarkupSTL.h: Fixed compilation on with Sun
+	  Studio compiler on Solaris x86 and Sparc (Ticket #189). Thanks to
+	  Magne Mahre for the patch.
+2008-07-15 13:35  mloskot
+	* [r2130] source/Makefile.vc: For building with Visual C++, added
+	  new flag DEBUG=1 (see GEOS building instructions on GEOS Wiki).
+	  Added missing flags for Visual C++ compiler, in release and debug
+	  configuration.
+2008-05-20 21:34  mloskot
+	* [r2129] source/dirlist.mk: Added missing subdirs to
+	  source/dirlist.mk
+2008-05-20 21:31  mloskot
+	* [r2128] source/geom/prep: Updated svn:ignore patterns.
+2008-05-20 21:25  mloskot
+	* [r2127] ChangeLog, bootstrap.bat, build/msvc80/geos.sln,
+	  source/geom/PrecisionModel.cpp,
+	  source/geom/util/GeometryTransformer.cpp,
+	  source/headers/geos/geom/BinaryOp.h,
+	  source/headers/geos/noding/Octant.h,
+	  source/headers/geos/noding/ScaledNoder.h,
+	  source/headers/geos/operation/overlay/PointBuilder.h,
+	  source/headers/geos/util.h, source/index/quadtree/NodeBase.cpp,
+	  source/noding/ScaledNoder.cpp, source/noding/SegmentString.cpp,
+	  source/operation/overlay/FuzzyPointLocator.cpp,
+	  source/operation/overlay/OverlayOp.cpp,
+	  source/precision/CommonBitsRemover.cpp,
+	  source/precision/GeometrySnapper.cpp,
+	  source/simplify/DouglasPeuckerSimplifier.cpp,
+	  tests/unit/geom/DimensionTest.cpp: * source\headers\geos\util.h:
+	  Add UNREFERENCED_PARAMETER macro.
+	  * source\geom\PrecisionModel.cpp,
+	  source\geom\GeometryComponentFilter.cpp,
+	  source\geom\util\GeometryTransformer.cpp,
+	  source\precision\GeometrySnapper.cpp,
+	  source\precision\CommonBitsRemover.cpp,
+	  source\simplify\DouglasPeuckerSimplifier.cpp,
+	  source\operation\overlay\OverlayOp.cpp,
+	  source\operation\overlay\FuzzyPointLocator.cpp,
+	  source\index\quadtree\NodeBase.cpp,
+	  source\headers\geos\geom\BinaryOp.h,
+	  source\headers\geos\operation\overlay\PointBuilder.h,
+	  source\headers\geos\noding\MCIndexNoder.h,
+	  source\headers\geos\noding\ScaledNoder.h,
+	  source\headers\geos\noding\Octant.h,
+	  source\noding\ScaledNoder.cpp,
+	  source\noding\snapround\MCIndexPointSnapper.cpp,
+	  source\noding\SegmentString.cpp,
+	  tests\unit\geom\DimensionTest.cpp: Use UNREFERENCED_PARAMETER
+	  macro to get rid of C4100 warning when building with Visual C++.
+	  * build\msvc80\geos_lib\geos_lib.vcproj: Remove non-existing
+	  source files.
+2008-05-20 20:45  mloskot
+	* [r2126] ChangeLog, source/Makefile.vc: source/makefile.vc:
+	  Removed non-existing file entry:
+	  PreparedPolygonLineIntersects.obj.
+2008-05-20 20:33  mloskot
+	* [r2125] ChangeLog, bootstrap.bat, source/Makefile.vc: *
+	  bootstrap.bat: Added script generating headers for use with
+	  Visual C++ compiler. DO NOT include this script in GEOS source
+	  distribution. * source/makefile.vc: Do not make copies of 3
+	  dynamic headers but let users to use bootstrap.bat instead.
+2008-02-07 22:59  Frank Warmerdam <warmerdam at pobox.com>
+	* [r2123] Makefile.am: make sure makefile.vc gets distributed
+2008-02-06 22:17  Frank Warmerdam <warmerdam at pobox.com>
+	* [r2122] source/Makefile.am, source/Makefile.vc,
+	  source/headers/geos/noding/Makefile.am: try to fix up the files
+	  include in distribution, and remove unused files from Makefile.vc
+	  (#175)
+2008-01-30 22:34  benjubb
+	* [r2120] source/headers/geos/algorithm/RayCrossingCounter.h,
+	  source/headers/geos/algorithm/locate/SimplePointInAreaLocator.h,
+	  source/headers/geos/geom/prep/AbstractPreparedPolygonContains.h,
+	  source/headers/geos/geom/prep/BasicPreparedGeometry.h,
+	  source/headers/geos/geom/prep/PreparedGeometry.h,
+	  source/headers/geos/geom/prep/PreparedGeometryFactory.h,
+	  source/headers/geos/geom/prep/PreparedLineString.h,
+	  source/headers/geos/geom/prep/PreparedLineStringIntersects.h,
+	  source/headers/geos/geom/prep/PreparedPoint.h,
+	  source/headers/geos/geom/prep/PreparedPolygon.h,
+	  source/headers/geos/geom/prep/PreparedPolygonContains.h,
+	  source/headers/geos/geom/prep/PreparedPolygonContainsProperly.h,
+	  source/headers/geos/geom/prep/PreparedPolygonCovers.h,
+	  source/headers/geos/geom/prep/PreparedPolygonIntersects.h,
+	  source/headers/geos/geom/prep/PreparedPolygonPredicate.h,
+	  source/headers/geos/geomUtil.h,
+	  source/headers/geos/geosAlgorithm.h,
+	  source/headers/geos/noding/SegmentStringUtil.h: Added
+	  documentation, for benefit of doxygen.
+2008-01-30 22:30  benjubb
+	* [r2119] source/geom/prep/PreparedPolygonIntersects.cpp: deleted
+	  out-commented line.
+2008-01-30 22:29  benjubb
+	* [r2118] source/geom/prep/PreparedPolygon.cpp: removed ref to
+	  PreparedPolygonLineIntersection
+2008-01-30 22:18  benjubb
+	* [r2117] source/geom/prep/Makefile.am,
+	  source/headers/geos/geom/prep/Makefile.am: Removed refs to
+	  PreparedPolygonLineIntersection.
+2008-01-30 22:17  benjubb
+	* [r2116] source/geom/prep/PreparedPolygonLineIntersection.cpp,
+	  source/headers/geos/geom/prep/PreparedPolygonLineIntersection.h:
+	  Deleted. not used, not needed.
+2008-01-30 19:09  benjubb
+	* [r2115] source/headers/geos/geomPrep.h: Added for benefit of
+	  doxygen.
+2008-01-29 17:55  benjubb
+	* [r2114] source/geom/prep/AbstractPreparedPolygonContains.cpp,
+	  source/geom/prep/PreparedLineString.cpp,
+	  source/geom/prep/PreparedPolygon.cpp,
+	  source/headers/geos/noding/SegmentIntersector.h,
+	  source/noding/SegmentIntersectionDetector.cpp: Some small changes
+	  to improve the memory management. These changes plug a few leaks,
+	  but not all.
+2008-01-29 17:49  benjubb
+	* [r2113] source/operation/predicate/RectangleContains.cpp: Fix a
+	  bug in the shortcut test for containment in a rectangle. This
+	  test wasn't correctly testing for case of a point on the
+	  boundary.
+	  Was also a bug in JTS (now fixed).
+2008-01-29 17:37  benjubb
+	* [r2112] source/geom/Geometry.cpp: Patch to fix bug in ticket #171
+2008-01-22 19:34  benjubb
+	* [r2111] capi/geos_c.h.in, source/headers/geos/version.h.vc:
+	  Updated for VC to give correct version (3.1.0-CAPI-1.5.0).
+2008-01-18 00:37  benjubb
+	* [r2110] configure.in: Added to CAPI interface, cleared
+	  CAPI_INTERFACE_REV, bumped AGE & CURRENT
+2008-01-18 00:35  benjubb
+	* [r2109] source/index/chain/MonotoneChainBuilder.cpp: Fixed a bug
+	  in the handling of line strings with repeated points.
+	  -This line, and those below, will be ignored--
+	  M MonotoneChainBuilder.cpp
+2008-01-17 19:15  benjubb
+	* [r2108] capi/geos_c.cpp: Fixed a misspelling,
+	  GEOSPreparedContainsProperty => GEOSPreparedContainsProperly
+2008-01-16 18:36  Frank Warmerdam <warmerdam at pobox.com>
+	* [r2107] source/Makefile.vc: updated to include post 3.0 classes
+2008-01-09 23:49  benjubb
+	* [r2106] capi/geos_c.cpp, capi/geos_c.h.in: Added support for
+	  prepared geometry
+2008-01-09 23:48  benjubb
+	* [r2105] source/headers/geos/geom/prep/PreparedGeometryFactory.h:
+	  removed extraneous 'using namespace'
+2008-01-03 21:11  benjubb
+	* [r2104] source/noding/MCIndexSegmentSetMutualIntersector.cpp:
+	  commented out some delete's in
+	  MCIndexSegmentSetMutualIntersector::addToIndex, to fix a bug in
+	  prepared contains() predicate.
+2008-01-02 23:23  sgillies
+	* [r2102] swig/Makefile.am: Conditionally add swig/python,ruby to
+	  SUBDIRS
+2007-12-22 00:04  mloskot
+	* [r2101] build/bjam/geos/Jamfile, build/bjam/geos_c,
+	  build/bjam/geos_unit: Updated configuration of experimental
+	  builder based on Boost.Build. GEOS compiles with bjam
+	  successfully as static library.
+2007-12-21 23:50  mloskot
+	* [r2100] source/Makefile.vc, source/algorithm/locate,
+	  source/index/intervalrtree: Updated Visual C++ makefiles with new
+	  submissions from Ben. Now, new GEOS features compiles with NMAKE
+	  too.
+2007-12-21 23:31  mloskot
+	* [r2099] source/headers/geos/algorithm/Makefile.am: Removed
+	  SimplePointInAreaLocator.h from algorithm/Makefile.am (header
+	  migrated to algorithm/locate).
+2007-12-21 23:26  mloskot
+	* [r2098] source/algorithm/Makefile.am: Added comment about
+	  deprecated translation units in source/algorithm.
+2007-12-21 23:26  pramsey
+	* [r2097] source/geom/util/Makefile.am: remove trailing backslash
+2007-12-21 23:21  mloskot
+	* [r2096] ., source/headers/geos/algorithm,
+	  source/headers/geos/algorithm/locate, tests/unit: Updated
+	  svn:ignore property.
+2007-12-21 23:18  mloskot
+	* [r2095] source/geom/prep/PreparedPolygonContainsProperly.cpp:
+	  Fixed extra qualifications in
+	  /geom/prep/PreparedPolygonContainsProperly.
+2007-12-21 23:12  mloskot
+	* [r2094] source/geom/prep/AbstractPreparedPolygonContains.cpp,
+	  source/geom/prep/PreparedGeometryFactory.cpp,
+	  source/headers/geos/geom/prep/PreparedGeometryFactory.h: Fixed
+	  extra qualifications in PreparedGeometryFactory class.
+2007-12-21 22:57  mloskot
+	* [r2093]
+	  source/headers/geos/geom/util/ComponentCoordinateExtracter.h:
+	  Fixed GeometryTypeId misused in
+	  geos/geom/util/ComponentCoordinateExtracter.h.
+2007-12-21 22:49  pramsey
+	* [r2092] source/geom/util/Makefile.am: remove .cpp files that
+	  weren't there before
+2007-12-21 22:49  mloskot
+	* [r2091] source/geom/CoordinateArraySequence.cpp,
+	  source/geom/CoordinateSequence.cpp, source/geom/LineString.cpp:
+	  Reverted changes appled in r2089 to three files from source/geom.
+2007-12-21 22:47  pramsey
+	* [r2090] source/algorithm/Makefile.am: type subdir typo
+2007-12-21 22:43  mloskot
+	* [r2089] source/geom/CoordinateArraySequence.cpp,
+	  source/geom/CoordinateSequence.cpp, source/geom/LineString.cpp,
+	  source/geom/prep, source/headers/geos/geom/prep,
+	  source/headers/geos/index/intervalrtree,
+	  source/index/intervalrtree: Updated svn:ignore property.
+2007-12-21 22:41  mloskot
+	* [r2088] source/examples/CustomPointCoordinateSequence.cpp: Added
+	  missing <iostream> header to CustomPointCoordinateSequence.cpp.
+2007-12-21 22:40  mloskot
+	* [r2087] source/algorithm/Makefile.am,
+	  source/algorithm/SimplePointInAreaLocator.cpp,
+	  source/algorithm/locate: Removed unused
+	  SimplePointInAreaLocator.cpp. This unit migrated to
+	  algorithm/locate module.
+2007-12-21 22:21  pramsey
+	* [r2086] configure.in: Updated configure.in with new locations.
+2007-12-21 22:14  mloskot
+	* [r2085] configure.in: Updated configure.in with new locations.
+2007-12-21 22:12  mloskot
+	* [r2084] configure.in: Updated configure.in with new locations.
+2007-12-21 22:09  mloskot
+	* [r2083] configure.in: Updated configure.in with new locations.
+2007-12-21 22:07  mloskot
+	* [r2082] configure.in: Updated configure.in with new locations.
+2007-12-21 22:02  pramsey
+	* [r2081] source/headers/geos/algorithm/Makefile.am,
+	  source/headers/geos/algorithm/locate/Makefile.am,
+	  source/headers/geos/noding/Makefile.am: Add
+	  headers/geos/algorithm/locate to automake
+2007-12-21 22:01  pramsey
+	* [r2080] source/noding/Makefile.am: Add files to automake
+2007-12-21 21:57  pramsey
+	* [r2079] source/headers/geos/index/Makefile.am,
+	  source/headers/geos/index/intervalrtree/Makefile.am: Added
+	  headers/index/intervalrtree to automake
+2007-12-21 21:55  pramsey
+	* [r2078] source/headers/geos/geom/Makefile.am,
+	  source/headers/geos/geom/prep/Makefile.am,
+	  source/headers/geos/geom/util/Makefile.am: Added
+	  headers/geom/prep headers/geom/util to automake
+2007-12-21 21:47  pramsey
+	* [r2077] source/index/Makefile.am,
+	  source/index/intervalrtree/Makefile.am: Added index/intervalrtree
+	  to automake
+2007-12-21 21:43  pramsey
+	* [r2076] source/geom/util/Makefile.am: added
+	  geom/util/ComponentCoordinateExtracter.h
+2007-12-21 21:40  pramsey
+	* [r2075] source/geom/Makefile.am, source/geom/prep/Makefile.am:
+	  Add geom/prep to automake
+2007-12-21 21:36  pramsey
+	* [r2074] source/algorithm/Makefile.am,
+	  source/algorithm/locate/Makefile.am: Add algorithm/location to
+	  automake
+2007-12-21 21:31  pramsey
+	* [r2073] source/algorithm/Makefile.am: Added new files
+2007-12-21 20:50  benjubb
+	* [r2072] source/algorithm/RayCrossingCounter.cpp:
+2007-12-21 20:48  benjubb
+	* [r2071] build/msvc80/geos_lib/geos_lib.vcproj:
+2007-12-21 20:47  benjubb
+	* [r2070] source/headers/geos/index/intervalrtree,
+	  source/headers/geos/index/intervalrtree/SortedPackedIntervalRTree.h:
+	  Added from JTS 1.9 to support prepared geometry
+	* [r2069] source/algorithm/locate,
+	  source/algorithm/locate/SimplePointInAreaLocator.cpp: Added from
+	  JTS 1.9 to support prepared geometry
+2007-12-21 20:44  benjubb
+	* [r2068] source/geom/util/ComponentCoordinateExtracter.cpp: Added
+	  from JTS 1.9 to support prepared geometry
+	* [r2067]
+2007-12-21 20:42  benjubb
+	* [r2066] source/operation/predicate/RectangleIntersects.cpp:
+	  modified because SimplePointInAreaLocator.h moved
+2007-12-21 20:41  benjubb
+	* [r2065] source/noding/FastSegmentSetIntersectionFinder.cpp,
+	  source/noding/SegmentStringUtil.cpp: Added from JTS 1.9 to
+	  support prepared geometry
+	* [r2064] source/index/intervalrtree,
+	  source/index/intervalrtree/SortedPackedIntervalRTree.cpp: Added
+2007-12-21 20:40  benjubb
+	* [r2063] source/geom/prep,
+	  source/geom/prep/AbstractPreparedPolygonContains.cpp,
+	  source/geom/prep/BasicPreparedGeometry.cpp,
+	  source/geom/prep/PreparedGeometry.cpp,
+	  source/geom/prep/PreparedLineStringIntersects.cpp,
+	  source/geom/prep/PreparedPoint.cpp,
+	  source/geom/prep/PreparedPolygonContains.cpp,
+	  source/geom/prep/PreparedPolygonContainsProperly.cpp,
+	  source/geom/prep/PreparedPolygonCovers.cpp,
+	  source/geom/prep/PreparedPolygonIntersects.cpp,
+	  source/geom/prep/PreparedPolygonLineIntersection.cpp,
+	  source/geom/prep/PreparedPolygonPredicate.cpp: Added from JTS 1.9
+	  to support prepared geometry
+2007-12-21 20:39  benjubb
+	* [r2062] source/geomgraph/EdgeEndStar.cpp: modified because
+	  SimplePointInAreaLocator.h moved
+2007-12-21 20:38  benjubb
+	* [r2061] source/headers/geos/algorithm/SimplePointInAreaLocator.h:
+	  Moved into geos::algorithm::locate
+2007-12-21 20:37  benjubb
+	* [r2060] source/headers/geos/algorithm/RayCrossingCounter.h: Added
+2007-12-21 20:35  benjubb
+	* [r2059] source/headers/geos/geom/prep,
+	  source/headers/geos/geom/prep/PreparedPolygonLineIntersection.h,
+	  source/headers/geos/geom/prep/PreparedPolygonPredicate.h: Added
+2007-12-21 20:34  benjubb
+	* [r2058]
+	  source/headers/geos/noding/SegmentStringUtil.h: Added from JTS
+	  1.9 to support prepared geometry
+2007-12-21 20:33  benjubb
+	* [r2057] source/headers/geos/noding/SegmentString.h: changed
+	  destructor to be virtual
+2007-12-21 20:31  benjubb
+	* [r2056] source/headers/geos/geom/Envelope.h: Added a covers()
+	  predicate, from JTS 1.9, to support prepared geometry
+2007-12-21 20:30  benjubb
+	* [r2055] source/headers/geos/geom/Geometry.h: changed IsRectangle
+	  to be public
+2007-12-21 20:03  benjubb
+	* [r2054] source/headers/geos/geom/Envelope.inl: Added a covers()
+2007-12-21 20:00  benjubb
+	* [r2053]
+	  source/headers/geos/algorithm/locate/SimplePointInAreaLocator.h:
+	  Moved from geos::algorithm as in JTS 1.9
+2007-12-21 19:55  benjubb
+	* [r2052] source/headers/geos/algorithm/locate,
+	  source/headers/geos/algorithm/locate/PointOnGeometryLocator.h:
+	  New namaspace geos::algorithm::locate, as in JTS 1.9..
+2007-12-21 19:52  benjubb
+	* [r2051] source/headers/geos/algorithm/SimplePointInAreaLocator.h:
+	  Added a public constructor, and a method to bring in line with
+	  JTS 1.9. Changed namespace to geos::algorithm::locate
+2007-12-21 18:44  pramsey
+	* [r2050] configure.in: version numbering for next release (3.1.0)
+2007-12-21 18:41  pramsey
+	* [r2046] ChangeLog, configure.in: 3.0.0 release
+2007-12-19 20:18  mloskot
+	* [r2045] ChangeLog, source/headers/geos/geom.h,
+	  source/headers/geos/io.h: Improved warning message about using
+	  DEPRECATED headers
+2007-12-17 23:09  mloskot
+	* [r2044] tests/xmltester/XMLTester.cpp: Fixed std::tolower usage
+	  in XMLTester.cpp (Ticket #163).
+2007-12-17 23:05  mloskot
+	* [r2043] source/algorithm/HCoordinate.cpp: Replaced finite
+	  function with std::numeric_limits (Ticket #162).
+2007-12-17 21:52  mloskot
+	* [r2042] ChangeLog, source/Makefile.vc: source\Makefile.vc: Fixed
+	  MSVC_VER condition for Microsoft Visual C++ 2008 (9.0).
+2007-12-13 16:11  mloskot
+	* [r2041] ChangeLog: Added Id keyword at the top of ChangeLog file.
+2007-12-13 16:09  mloskot
+	* [r2040] ChangeLog, build/msvc80/geos_unit/geos_unit.vcproj,
+	  source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
+	  tests/unit/geom/GeometryFactoryTest.cpp: *
+	  build\msvc80\geos_unit\geos_unit.vcproj: fixed post-build event
+	  * source\geom\GeometryCollection.cpp: removed unreachable code,
+	  shorten exception message.
+	  * source\geom\Geometry.cpp: purified condition based on
+	  dynamic_cast
+	  * tests\unit\geom\GeometryFactoryTest.cpp: use std::size_t
+	  instead of
+	  int where unsigned integral type required.
+2007-12-09 00:02  mloskot
+	* [r2038] ChangeLog, tests/unit/Makefile.am,
+	  Added test suite for class
+	  geos::precision::SimpleGeometryPrecisionReducer.
+2007-12-08 22:59  mloskot
+	* [r2037] .: Updated svn:keyword property.
+2007-11-26 16:26  mloskot
+	* [r2036] build/msvc80/geos.vsprops: Added geos.vsprops - property
+	  sheet for Visual C++ projects.
+2007-11-26 15:19  mloskot
+	* [r2035] ChangeLog, build/msvc80/geos_python/geos_python.vcproj,
+	  build/msvc80/geos_ruby/geos_ruby.vcproj,
+	  swig/python/geos_wrap.cxx: Added common Property Sheet for Visual
+	  C++ projects where Python and Ruby macros/locations are defined.
+	  Fixed include of Python.h, see Ticket #164 for details.
+2007-11-26 06:21  mloskot
+	* [r2034] source/algorithm: Updated svn:ignore patterns.
+2007-11-26 06:16  mloskot
+	* [r2033] ChangeLog, source/Makefile.vc,
+	  source/headers/geos/version.h.vc: Enabled target copying
+	  version.h.vc and geos_c.h.vc to headers used by Visual C++. Added
+	  test if version.h.vc is used with Visual C++.
+2007-11-23 02:33  mloskot
+	* [r2032] ChangeLog, source/headers/geos/io/WKBWriter.h: A bit of
+	  purification with explicit casting int to bool type.
+2007-11-02 22:41  pramsey
+	* [r2031] web/index.html: urls updated to point to osgeo locations
+2007-11-02 22:17  pramsey
+	* [r2030] web, web/index.html, web/style.css: add the web site
+	  content to svn for collaborative management
+2007-09-21 17:42  csavage
+	* [r2029] configure.in: Update the CAPI and GEOS version numbers
+	  based on Reader/Writer additions to the CAPI and EWKB support for
+	  the C++ api.
+2007-09-21 17:40  csavage
+	* [r2028] swig/geos.i.in, swig/ruby/geos_wrap.cxx,
+	  swig/ruby/ruby.i, swig/ruby/test/test_buffer.rb,
+	  swig/ruby/test/test_helper.rb, swig/ruby/test/test_io.rb,
+	  swig/ruby/test/test_operations.rb, swig/ruby/test/test_srid.rb,
+	  swig/ruby/test/test_version.rb: Updated the SWIG bindings and
+	  tests to use the new Reader/Writer classes exposed in the CAPI.
+	* [r2027] capi/geos_c.cpp, capi/geos_c.h.in: Update the CAPI to
+	  expose WKTReader/WBTWriter and WKBReader/WBKWriter in the CAPI.
+	  This is an improvement over the existing API since it avoids the
+	  use of the static variable used to control byte order and # of
+	  dimenions, and gives clients more control over the
+	  creation/destruction of readers and writers. Finally, exposed the
+	  ability to output the EWKB format (set SRID to true in the
+	  WKBWriter).
+2007-09-21 17:35  csavage
+	* [r2026] source/index/strtree/STRtree.cpp: Switched back to using
+	  < because the fuzzy comparison now in use trips assertion errors
+	  in VC++. See comments in code for more information. Note this
+	  change may cause problems. Strk left a note in the code saying
+	  that the '<' comparison sometimes gives unstable results. But
+	  that seems better than an assertion failure.
+2007-09-21 17:32  csavage
+	* [r2025] source/headers/geos/io/WKBWriter.h,
+	  source/io/WKBWriter.cpp: Updated the WKBWriter so it can output
+	  EWKB format similar to PostGIS. Also added a few getter/setter
+	  methods that allow clients to specify the reader's number of
+	  dimensions, byte order and whether srid values should be output.
+	  These getters/setters make it easier to wrap the reader in the
+	  CAPI.
+2007-09-14 15:34  csavage
+	* [r2024] build/msvc80/geos_c_dll/geos_c_dll.vcproj,
+	  build/msvc80/geos_ruby, build/msvc80/geos_ruby/geos_ruby.vcproj:
+	* [r2023] build/msvc80/geos_python: Told SVN to ignore MSCV++
+	  Python swig build directories.
+2007-09-14 15:25  csavage
+	* [r2022] source/io/WKBReader.cpp: Set unknown SRID values to 0
+	  instead of -1 to be more consistent with the rest of GEOS (srid
+	  values are initialized to 0 by default).
+2007-09-11 02:02  csavage
+	* [r2021] source/headers/geos/profiler.h: Don't include config.h
+	  for MSVC++ builds.
+2007-09-07 17:32  csavage
+	* [r2020] configure.in: The test for SWIG was incorrect. Fixed by
+	  patch from Mark Cave-Ayland.
+2007-09-06 23:24  csavage
+	* [r2019] source/headers/geos/profiler.h: Applied patch from Mark
+	  Cave-Ayland's to make older versions of MingW that don't have
+	  struct timezone defined compile again. Also fixed issues with
+	  more recent versions of MingW that don't correctly compile with
+	  the -ansi compiler switch.
+2007-09-06 23:22  csavage
+	* [r2018] configure.in, macros/ruby.m4: Applied patches from Mark
+	  Cave-Ayland's that reorganize/improve the SWIG support in the
+	  generated configure file.\
+2007-08-31 20:44  csavage
+	* [r2017] capi/geos_c.cpp, capi/geos_c.h.in: For MSVC++ builds the
+	  CAPI version was set in geos_c.cpp instead of geos_c.h and it was
+	  set incorrectly. This patch fixes the MSVC++ version number and
+	  centralizes the various versoin #defines in the geos_c.h.
+2007-08-31 20:18  csavage
+	* [r2016] swig/python/Makefile.am, swig/ruby/Makefile.am: Update
+	  swig makefiles to make the wrappers dependent on the SWIG
+	  interface files even if SWIG is disabled. Doing this means that
+	  Make will correctly recognize that a user has modified an I file,
+	  but that the .cxx wrapper cannot be regenerated since SWIG is not
+	  available.
+2007-08-30 20:06  csavage
+	* [r2015] source/headers/geos/profiler.h,
+	  source/headers/geos/timeval.h: MingW now includes the
+	  gettimeofday function - so reworked includes to only use custom
+	  version when building with VC++.
+2007-08-30 17:00  csavage
+	* [r2014] macros/ruby.m4, swig/ruby/Makefile.am: Added RUBY_BIN_DIR
+	  to autoconf macros - simplified auto make input file for ruby
+	  bindings.
+2007-08-30 06:19  csavage
+	* [r2013] macros/ac_pkg_swig.m4: The last attempt to fix this file
+	  failed - instead keep the code that queries the swig libraries
+	  but use sed to merge multiple lines together. If this is not
+	  done, then the swig output causes ./configure to blow up on msys.
+2007-08-30 05:31  csavage
+	* [r2012] macros/ac_pkg_swig.m4: Fixes sed issue with swig on msys.
+	  For more info see:
+	  http://lists.refractions.net/pipermail/geos-devel/2007-August/002956.html
+2007-08-30 03:18  csavage
+	* [r2011] swig/geos.i.in: Changed from dos to unix line feeds.
+2007-08-29 01:41  csavage
+	* [r2010] build/msvc80/geos.sln, build/msvc80/geos_python,
+	  build/msvc80/geos_python/geos_python.vcproj,
+	  build/msvc80/geos_ruby/geos_ruby.vcproj: New VC++ project for the
+	  python SWIG bindings.
+2007-08-29 01:29  csavage
+	* [r2009] build/msvc80/geos_ruby/geos_ruby.vcproj, swig/geos.i.in,
+	  swig/python/python.i, swig/ruby/geos_wrap.cxx, swig/ruby/ruby.i:
+	  Ruby SWIG bindings - mapped eql? to == so that you can do point
+	  == point2 in ruby. Removed a hard-coded path from VC++ project.
+	  Updated out-of-date copyright notices for no particularly good
+	  reason.
+2007-08-28 21:29  csavage
+	* [r2008] build/msvc80: Added release as an ignored directory for
+	  VC++, similar to the debug directory.
+2007-08-28 21:28  csavage
+	* [r2007] build/msvc80/geos_ruby: Added new ruby VC++ project to
+	  solution file.
+2007-08-28 21:27  csavage
+	* [r2006] capi/geos_c.h.in: Fixed c api include for VC++ - it
+	  should be #include <geos/version.h> instead of #include
+	  <version.h>.
+	* [r2005] build/msvc80/geos.sln: Added new ruby VC++ project to
+	  solution file.
+2007-08-28 21:26  csavage
+	* [r2004] build/msvc80/geos_c_dll/geos_c_dll.vcproj: Follow lead of
+	  geos_lib project - copy geos/geos_c.h.in to geos/geos_c.h when
+	  building with VC++.
+2007-08-28 21:25  csavage
+	* [r2003] build/msvc80/geos_ruby,
+	  build/msvc80/geos_ruby/geos_ruby.vcproj: Added new vc++ project
+	  for building ruby bindings. Its not perfect since it hard-codes
+	  the path to Ruby, but its enough to get one started.
+2007-08-28 21:22  csavage
+	* [r2002] swig/python/geos.py, swig/python/geos_wrap.cxx,
+	  swig/ruby/geos_wrap.cxx: Updated SWIG wrappers based on changed
+	  interface file. Also generated with SWIG 1.3.31
+2007-08-28 20:42  csavage
+	* [r2001] swig/ruby/test/geos_tests.rb,
+	  swig/ruby/test/test_buffer.rb,
+	  swig/ruby/test/test_combinations.rb,
+	  swig/ruby/test/test_coordinate_sequence.rb,
+	  swig/ruby/test/test_envelope.rb, swig/ruby/test/test_geometry.rb,
+	  swig/ruby/test/test_io.rb, swig/ruby/test/test_operations.rb,
+	  swig/ruby/test/test_relations.rb, swig/ruby/test/test_srid.rb,
+	  swig/ruby/test/test_version.rb: SWIG bindings - updated Ruby
+	  tests based on name changes.
+2007-08-28 20:41  csavage
+	* [r2000] swig/ruby/ruby.i: Updated Ruby swig bindings to more
+	  closely match Ruby style names. So eql? instead of equals,
+	  dimensions instead of get_dimensions, etc.
+2007-08-28 20:40  csavage
+	* [r1999] swig/geos.i.in: Exposed Geometry::Clone method in SWIG
+	  bindings. Added check for NULL string in geomFromWKT wrapper.
+2007-08-23 20:35  pramsey
+	* [r1998] source/operation/buffer/BufferBuilder.cpp,
+	  source/operation/buffer/OffsetCurveVertexList.h: Memory leak
+	  patches from Robert Coup
+2007-08-22 23:45  mloskot
+	* [r1997] source/headers/geos/io/ByteOrderDataInStream.inl,
+	  source/operation/overlay/ElevationMatrix.cpp,
+	  source/operation/polygonize/Polygonizer.cpp: Cleaned compilation
+	  warnings from VC++.
+2007-06-11 07:43  mloskot
+	* [r1996] ChangeLog, source/operation/IsSimpleOp.cpp: Replaced
+	  post-increment operators with pre-increment operators where
+	  standard iterators are incremented in loops. NOTE: Prefer
+	  pre-incr. over post-inc. when working with standard iterators.
+2007-06-11 07:39  mloskot
+	* [r1995] tests/unit/Makefile.am,
+	  tests/unit/operation/IsSimpleOpTest.cpp: Added unit test for
+	  geos::operation::IsSimpleOp class.
+2007-06-10 13:03  mloskot
+	* [r1994] ., ChangeLog, tests/unit/Makefile.am: Updated
+	  tests/unit/Makefile.am with new files.
+2007-06-10 11:53  mloskot
+	* [r1993] ChangeLog, build/msvc80/geos.sln,
+	  build/msvc80/geos_unit/geos_unit.vcproj,
+	  tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp,
+	  tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp,
+	  tests/unit/algorithm/ConvexHullTest.cpp: Added unit test for
+	  geos::algorithm::CGAlgorithms::computeOrientation() function.
+2007-06-10 11:29  mloskot
+	* [r1992] ., capi, source, source/geom, source/geom/util,
+	  source/geomgraph, source/geomgraph/index, source/index/bintree,
+	  source/index/chain, source/index/quadtree, source/index/strtree,
+	  source/index/sweepline, source/io, source/noding,
+	  source/noding/snapround, source/operation,
+	  source/operation/buffer, source/operation/distance,
+	  source/operation/linemerge, source/operation/overlay,
+	  source/operation/polygonize, source/operation/predicate,
+	  source/operation/relate, source/operation/valid,
+	  source/planargraph, source/planargraph/algorithm,
+	  source/precision, source/simplify, source/util: Updated
+	  svn:ignore property for the whole tree adding VC++ and Windows
+	  specific patterns.
+2007-06-10 11:18  mloskot
+	* [r1991] ChangeLog, build/msvc80/geos_unit/geos_unit.vcproj,
+	  tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp: Added unit test
+	  for CGAlgorithms::isCCW() function.
+2007-06-10 11:08  mloskot
+	* [r1990] tests/unit/algorithm/ConvexHullTest.cpp,
+	  tests/unit/geom/LineStringTest.cpp: Added unit test for
+	  geos::algorithm::ConvexHull.
+2007-06-10 11:03  mloskot
+	* [r1989] tests/unit/utility.h: Added custom operators for static
+	  and dynamic casts of pointers wrapped with std::auto_ptr<T> type.
+2007-06-08 17:13  mloskot
+	* [r1988] tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp:
+	  Identified test case failing because of
+	  geos::index::strtree::yComparator() instability.
+2007-06-08 17:10  mloskot
+	* [r1987] ChangeLog, source/index/strtree/STRtree.cpp: Analysis of
+	  instability of the yComparator, there are some new important
+	  questions to answer.
+2007-06-08 15:27  mloskot
+	* [r1986] ChangeLog, build/msvc80/geos_lib/geos_lib.vcproj,
+	  source/algorithm/CGAlgorithms.cpp,
+	  source/algorithm/CentroidArea.cpp,
+	  source/algorithm/CentroidLine.cpp,
+	  source/algorithm/CentroidPoint.cpp,
+	  source/algorithm/HCoordinate.cpp,
+	  source/algorithm/InteriorPointArea.cpp,
+	  source/algorithm/InteriorPointLine.cpp,
+	  source/algorithm/InteriorPointPoint.cpp,
+	  source/algorithm/MinimumDiameter.cpp,
+	  source/algorithm/PointLocator.cpp,
+	  source/algorithm/SIRtreePointInRing.cpp,
+	  source/geom/CoordinateSequence.cpp, source/geomgraph/Edge.cpp,
+	  source/geomgraph/EdgeList.cpp,
+	  source/headers/geos/geom/CoordinateFilter.h,
+	  source/headers/geos/geomgraph/Edge.h,
+	  source/headers/geos/geomgraph/Node.h,
+	  source/headers/geos/index/bintree/Root.h,
+	  source/headers/geos/index/chain/MonotoneChainOverlapAction.h,
+	  source/index/strtree/SIRtree.cpp,
+	  source/index/strtree/STRtree.cpp,
+	  source/index/sweepline/SweepLineIndex.cpp,
+	  source/operation/buffer/BufferSubgraph.cpp: Cleaned
+	  signed/unsigned types mixtures, got rid from annoying compiler
+	  warnings.
+2007-06-08 14:50  mloskot
+	* [r1985] ChangeLog: Applied Konstantin Baumann's suggestion about
+	  including version.h in C API header for Visual C++.
+	* [r1984] capi/geos_c.h.in: Applied Konstantin Baumann's suggestion
+	  about including version.h in C API header for Visual C++.
+2007-06-01 13:53  mloskot
+	* [r1983] ChangeLog, build/bjam, build/bjam/Jamroot,
+	  build/bjam/geos, build/bjam/geos/Jamfile, build/bjam/geos_c,
+	  build/bjam/geos_c/Jamfile, build/bjam/geos_unit,
+	  build/bjam/geos_unit/Jamfile: Added Boost.Build configuration for
+	  GEOS (experimental). The idea is to enable users to build GEOS
+	  with bjam tool from Boost.Build package.
+2007-06-01 13:43  mloskot
+	* [r1982] source/headers/geos/platform.h.vc,
+	  source/headers/geos/version.h.vc,
+	  tests/unit/operation/distance/DistanceOpTest.cpp,
+	  tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp,
+	  tests/unit/operation/overlay/OffsetPointGeneratorTest.cpp,
+	  tests/unit/operation/overlay/OverlayResultValidatorTest.cpp: Set
+	  missing svn:keywords property.
+2007-06-01 13:06  mloskot
+	* [r1981] ChangeLog, build/msvc80/geos_lib/geos_lib.vcproj: Applied
+	  patch with pre-build events generating platform.h and version.h
+	  headers. Thanks to Konstantin Baumann for this patch.
+2007-05-06 02:42  mloskot
+	* [r1980] build/msvc80, build/msvc80/geos_c_dll,
+	  build/msvc80/geos_lib, build/msvc80/geos_unit: Updated svn:ignore
+	  property for build\msvc80.
+2007-05-06 02:40  mloskot
+	* [r1979] ChangeLog, source/headers/geos/version.h.vc: Added
+	  source/headers/geos/version.h.vc file for Visual C++ compiler.
+2007-04-22 04:44  mloskot
+	* [r1978] ., ChangeLog, capi,
+	  source/geom/CoordinateArraySequence.cpp, swig,
+	  tests/unit/capi/GEOSCoordSeqTest.cpp: Added assertion validating
+	  ordinateIndex in setOrdinate() function. Extended
+	  GEOSCoordSeqTest with swapped and non-swapped calls of
+	  coordiantes assignment functions.
+2007-04-15 18:02  mloskot
+	* [r1977] ChangeLog, autogen.sh: Added detection of glibtoolize
+	  under Mac OS X.
+2007-03-05 09:58  Sandro Santilli <strk at keybit.net>
+	* [r1976] ChangeLog, tests/xmltester/Makefile.am,
+	  tests/xmltester/hole_from_shell.xml,
+	  tests/xmltester/hole_red.xml: Add new testcases by Carl Anderson
+2007-02-26 10:46  Sandro Santilli <strk at keybit.net>
+	* [r1975] ChangeLog, source/inlines.cpp: Patch by Tom Elwertowski:
+	  * source/inlines.cpp: fix for MingW32 builds.
+2007-02-21 10:14  Sandro Santilli <strk at keybit.net>
+	* [r1974] ChangeLog,
+	  source/operation/buffer/SubgraphDepthLocater.cpp: Patch by Carl
+	  Anderson:
+	  * source/operation/buffer/SubgraphDepthLocater.cpp
+	  (findStabbedSegments):
+	  Implement short-circuit to avoid inner defective
+	  logic.
+	  Fixes badguy3.xml
+2007-02-21 10:12  Sandro Santilli <strk at keybit.net>
+	* [r1973] ChangeLog, tests/xmltester/Makefile.am,
+	  tests/xmltester/badguy3.xml: * tests/xmltester/: Makefile.am,
+	  badguy3.xml:
+	  Added simplified version of nasty buffer bug test.
+2007-02-08 23:33  Sandro Santilli <strk at keybit.net>
+	* [r1972] ChangeLog, configure.in: Patch by Mark Cave-Ayland:
+	  * configure.in: Allow configure to continue with use_python
+	  set to false if a python binary is not found, as per
+	  http://sources.redhat.com/automake/automake.html#Python.
+2007-02-07 00:34  Sandro Santilli <strk at keybit.net>
+	* [r1971] ChangeLog,
+	  source/headers/geos/index/strtree/AbstractNode.h,
+	  source/headers/geos/index/strtree/Boundable.h,
+	  source/headers/geos/index/strtree/SIRtree.h,
+	  source/headers/geos/index/strtree/STRtree.h,
+	  source/index/strtree/AbstractNode.cpp,
+	  source/index/strtree/ItemBoundable.cpp,
+	  source/index/strtree/STRtree.cpp: General refactoring aimed at
+	  making the code cleaner
+	  to read and maintain; use iterators rather then random
+	  accessing containers to allow easy future switch to std::list
+	  from std::vector; use a tolerance-based strict weak ordering
+	  operator for sorting child boundables in STRtree, this
+	  fixes the heisenbug when building with inlines disabled.
+2007-02-06 02:05  Sandro Santilli <strk at keybit.net>
+	* [r1970] ChangeLog,
+	  tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp: *
+	  Expect result of POLYGON simplification to always be
+	  a polygon, even if collapsed to the empty geom.
+2007-02-06 01:57  Sandro Santilli <strk at keybit.net>
+	* [r1969] ChangeLog,
+	  source/headers/geos/operation/buffer/BufferBuilder.h,
+	  source/headers/geos/operation/buffer/BufferOp.h,
+	  source/operation/buffer/BufferBuilder.cpp,
+	  source/operation/buffer/BufferOp.cpp: *
+	  operation::buffer::BufferBuilder,
+	  operation::buffer::BufferOp:
+	  Fixed buffer operation to always return polygonal
+	  geometry
+2007-02-03 02:18  pramsey
+	* [r1967] ChangeLog, configure.in: 3.0.0rc4 tagging
+2007-02-01 11:11  Sandro Santilli <strk at keybit.net>
+	* [r1966] ChangeLog,
+	  operation::buffer::BufferOp: set MAX_PRECISION_DIGITS
+	  so to match JTS.
+2007-01-26 01:19  Sandro Santilli <strk at keybit.net>
+	* [r1965] ChangeLog, tests/xmltester/Makefile.am,
+	  tests/xmltester/stmlf-cases-20070119.xml: * tests/xmltester/:
+	  Makefile.am, stmlf-cases-20070119.xml:
+	  New overlay test.
+2007-01-26 00:57  Sandro Santilli <strk at keybit.net>
+	* [r1964] ChangeLog, source/operation/buffer/BufferBuilder.cpp,
+	  tests/xmltester/XMLTester.cpp: * tests/xmltester/XMLTester.cpp:
+	  improved buffer
+	  result validator.
+	  * source/operation/buffer/BufferBuilder.cpp (computeNodedEdges):
+	  remove repeated points from noded SegmentStrings, skip collapsed
+	  edges.
+2007-01-17 11:59  Sandro Santilli <strk at keybit.net>
+	* [r1963] ChangeLog, tests/xmltester/Makefile.am,
+	  tests/xmltester/heisenbugs.xml: New testcase for bug fixed by
+	  previous commit.
+2007-01-17 01:05  Sandro Santilli <strk at keybit.net>
+	* [r1962] ChangeLog, source/index/strtree/STRtree.cpp: *
+	  source/index/strtree/STRtree.cpp (yComparator):
+	  Use static_cast<> and make code more readable.
+	  A side effect seems to be fixing a segfault :!
+2007-01-17 00:45  Sandro Santilli <strk at keybit.net>
+	* [r1961] ChangeLog, source/headers/geos/index/strtree/STRtree.h: *
+	  source/headers/geos/index/strtree/STRtree.h (centreY):
+	  const-corrected.
+2007-01-16 14:12  Sandro Santilli <strk at keybit.net>
+	* [r1960] ChangeLog, tests/xmltester/XMLTester.cpp,
+	  tests/xmltester/XMLTester.h: * tests/xmltester/XMLTester.cpp:
+	  don't include catch-all headers.
+2007-01-09 17:34  Sandro Santilli <strk at keybit.net>
+	* [r1959] ChangeLog,
+	  source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
+	  source/operation/buffer/Makefile.am,
+	  source/operation/buffer/OffsetCurveBuilder.cpp,
+	  tests/xmltester/Makefile.am,
+	  tests/xmltester/TestBufferExternal.xml,
+	  tests/xmltester/XMLTester.cpp: * source/operation/buffer/:
+	  Makefile.am, OffsetCurveVertexList.h:
+	  New helper class for OffsetCurveBuilder
+	  * operation::buffer::OffsetCurveBuilder:
+	  Move vertexlist management to external class.
+	  * tests/xmltester/: Makefile.am, TestBufferExternal.xml:
+	  added test for above changes (imported from JTS and
+	  modified to work with GEOS).
+	  * tests/xmltester/XMLTester.cpp: change buffer
+	  validator again: check area of topological
+	  difference between expected and obtained result
+	  to be smaller then 1/1000 of expected geometry
+	  area.
+2007-01-09 15:08  Sandro Santilli <strk at keybit.net>
+	* [r1958] ChangeLog, source/geom/CoordinateArraySequence.cpp,
+	  source/headers/geos/geom/CoordinateArraySequence.h,
+	  source/headers/geos/geom/CoordinateSequence.h: *
+	  source/headers/geos/geom/CoordinateSequence.h,
+	  source/headers/geos/geom/CoordinateArraySequence.h:
+	  add(Coordinate, bool) made a virtual method and overrridden
+	  for CoordinateArraySequence, for better performance
+	  (single virtual call vs. multiple); added front() and
+	  back() methods.
+2007-01-09 10:27  Sandro Santilli <strk at keybit.net>
+	* [r1957] ChangeLog, tests/xmltester/XMLTester.cpp: *
+	  tests/xmltester/XMLTester.cpp: add areatest to buffer test
+	  handler.
+2007-01-05 01:01  Sandro Santilli <strk at keybit.net>
+	* [r1956] ChangeLog, configure.in: * configure.in: prepared for
+	  version to 3.0.0rc4,
+	  fixed swig python errors as suggested by hint
+	  (AM_PATH_PYTHON).
+2007-01-04 22:43  Sandro Santilli <strk at keybit.net>
+	* [r1955] ChangeLog, configure.in, swig/geos.i, swig/geos.i.in: *
+	  configure.in, swig/geos.i.in, swig/geos.i:
+	  geos.i generated at configure time from geos.i.in
+	  (so we don't have to manually update versions there).
+2007-01-04 22:38  Sandro Santilli <strk at keybit.net>
+	* [r1954] ChangeLog, swig/geos.i: Patch by dev-zero at gentoo dot
+	  org:
+	  * swig/geos.i: use unsigned int when CAPI signatures
+	  expect unsigned int (not size_t).
+2007-01-03 20:11  Sandro Santilli <strk at keybit.net>
+	* [r1953] ChangeLog, tests/xmltester/Makefile.am,
+	  tests/xmltester/fme.xml: * tests/xmltester/: fme.xml,
+	  Makefile.am: added buffer testcase.
+2007-01-03 20:06  Sandro Santilli <strk at keybit.net>
+	* [r1952] ChangeLog, tests/xmltester/XMLTester.cpp: *
+	  tests/xmltester/XMLTester.cpp: use a tolerance of 10E-6
+	  for buffer validation (~10cm at worst when using latlong
+	  projections); create sql tables with oid to work around a
+	  bug in qgis 0.7.4.
+2007-01-03 19:18  Sandro Santilli <strk at keybit.net>
+	* [r1951] ChangeLog, source/algorithm/HCoordinate.cpp,
+	  source/inlines.cpp: Applied patch by Mark Cave-Ayland
+	  <mark.cave-ayland at ilande.co.uk>:
+	  * source/inlines.cpp, source/algorithm/HCoordinate.cpp:
+	  Fixes for MingW builds. See geos-devel/2007-January/002766.html.
+2007-01-03 14:56  Sandro Santilli <strk at keybit.net>
+	* [r1950] ChangeLog, source/operation/buffer/BufferOp.cpp: *
+	  source/operation/buffer/BufferOp.cpp (bufferReducedPrecision):
+	  Fixed computation of reduced PrecisionModel scale.
+2006-12-18 20:04  Sandro Santilli <strk at keybit.net>
+	* [r1949] ChangeLog, tests/xmltester/robustness.xml: *
+	  tests/xmltester/robustness.xml: added
+	  testcase reported to fail with 2.2.3 on
+	  postgis-users/2006-November/014013.html.
+2006-12-18 18:44  Sandro Santilli <strk at keybit.net>
+	* [r1948] ChangeLog, source/headers/geos/geom/BinaryOp.h,
+	  source/headers/geos/precision/GeometrySnapper.h,
+	  source/precision/GeometrySnapper.cpp: Geometry snapping synced
+	  with JTS.
+2006-12-18 14:27  Sandro Santilli <strk at keybit.net>
+	* [r1947] ChangeLog, HOWTO_RELEASE: * HOWTO_RELEASE: add
+	  ChangeLog's release mark step.
+2006-12-18 14:19  Sandro Santilli <strk at keybit.net>
+	* [r1946] ChangeLog, source/precision/GeometrySnapper.cpp,
+	  tests/xmltester/TestRobustOverlayFixed.xml: *
+	  source/precision/GeometrySnapper.cpp (computeSnapTolerance):
+	  properly compute snap tolerance for fixed precision geometries.
+	  * tests/xmltester/: Makefile.am, TestRobustOverlayFixed.xml:
+	  new test for fixed precision snapping.
+2006-12-15 10:50  Sandro Santilli <strk at keybit.net>
+	* [r1945] ChangeLog: release 3.0.0rc3 marked
+2006-12-14 19:12  pramsey
+	* [r1943] configure.in: bumped version numbers for 3.0.0rc3
+2006-12-13 11:05  mloskot
+	* [r1942] ChangeLog, build/msvc80/geos_lib/geos_lib.vcproj,
+	  source/Makefile.vc: Updated makefile and project files for Visual
+	  C++.
+2006-12-13 10:55  Sandro Santilli <strk at keybit.net>
+	* [r1941] ChangeLog,
+	  source/headers/geos/operation/overlay/FuzzyPointLocator.h,
+	  source/headers/geos/operation/overlay/OffsetPointGenerator.h,
+	  source/headers/geos/operation/overlay/OverlayResultValidator.h,
+	  source/operation/overlay/OffsetPointGenerator.cpp,
+	  source/operation/overlay/OverlayResultValidator.cpp: Updated port
+	  information.
+2006-12-13 10:51  Sandro Santilli <strk at keybit.net>
+	* [r1940] ChangeLog,
+	  source/headers/geos/precision/LineStringSnapper.h,
+	  source/precision/LineStringSnapper.cpp: *
+	  precision::GeometrySnapper, precision::LineStringSnapper:
+	  Updated port information.
+2006-12-11 17:42  Sandro Santilli <strk at keybit.net>
+	* [r1939] ChangeLog,
+	  source/headers/geos/geomgraph/EdgeNodingValidator.h,
+	  source/headers/geos/noding/Makefile.am,
+	  source/noding/MCIndexNoder.cpp, source/noding/Makefile.am,
+	  source/noding/SingleInteriorIntersectionFinder.cpp: *
+	  source/headers/geos/noding/SegmentIntersector.h: added virtual
+	  isDone() function, always returning false by default.
+	  * source/noding/MCIndexNoder.cpp (intersectChains):
+	  short-circuit from JTS-1.8, based on the new
+	  SegmentIntersector::isDone() method.
+	  * source/noding/Makefile.am,
+	  source/headers/geos/noding/SingleInteriorIntersectionFinder.h:
+	  New ports from JTS-1.8-cvs.
+	  * source/headers/geos/geomgraph/EdgeNodingValidator.h:
+	  use a FastNodingValidator rather then a simple NodingValidator.
+2006-12-07 10:45  Sandro Santilli <strk at keybit.net>
+	* [r1938] ChangeLog, source/algorithm/LineIntersector.cpp,
+	  source/headers/geos/algorithm/LineIntersector.h,
+	  source/headers/geos/algorithm/Makefile.am: *
+	  source/headers/geos/algorithm/: CentralEndpointIntersector.h,
+	  Makefile.am: new port from JTS-1.8.
+	  * algorithm::LineIntersector: robustness improvements
+	  from JTS-1.8.
+2006-12-05 11:22  mloskot
+	* [r1937] tests/unit/capi/GEOSCoordSeqTest.cpp,
+	  tests/unit/capi/GEOSSimplifyTest.cpp: Fixed indentantion in
+	  tests/unit/capi.
+2006-12-05 11:10  mloskot
+	* [r1936] ChangeLog: Fixed typos in changelog.
+2006-12-05 11:05  mloskot
+	* [r1935] tests/unit/capi/GEOSCoordSeqTest.cpp,
+	  tests/unit/capi/GEOSSimplifyTest.cpp: Set svn:keyword property on
+	  CAPI tests.
+2006-12-05 11:02  mloskot
+	* [r1934] ChangeLog, tests/unit/capi/GEOSCoordSeqTest.cpp,
+	  tests/unit/capi/GEOSSimplifyTest.cpp,
+	  tests/unit/util/UniqueCoordinateArrayFilterTest.cpp: Purifying
+	  CAPI unit tests.
+2006-12-05 10:59  mloskot
+	* [r1933] build/msvc80/geos_unit/geos_unit.vcproj: Added CAPI tests
+	  to VC++ project.
+2006-12-05 10:42  Sandro Santilli <strk at keybit.net>
+	* [r1932] ChangeLog, source/headers/geos/geom/BinaryOp.h,
+	  source/operation/overlay/OverlayOp.cpp: *
+	  source/operation/overlay/OverlayOp.cpp: Use EdgeNodingValidator
+	  instead of OverlayResultValidator (faster and more effective).
+	  Note that compile-time defines can select use of either or both
+	  ones.
+	  * source/headers/geos/geom/BinaryOp.h: be quiet if not in DEBUG
+	  mode.
+2006-12-05 09:59  Sandro Santilli <strk at keybit.net>
+	* [r1931] ChangeLog, source/headers/geos/noding/NodingValidator.h,
+	  source/noding/NodingValidator.cpp: * noding::NodingValidator.h:
+	  throw TopologyException
+	  rather then a generic GEOSException.
+2006-12-04 12:41  Sandro Santilli <strk at keybit.net>
+	* [r1930] ChangeLog,
+	  source/headers/geos/geomgraph/EdgeNodingValidator.h: *
+	  fix members initialization order.
+2006-12-04 11:38  Sandro Santilli <strk at keybit.net>
+	* [r1929] ChangeLog, source/geomgraph/EdgeNodingValidator.cpp,
+	  geomgraph::EdgeNodingValidator: minor cleanup
+	  to use references args instead of pointers for
+	  method that doesn't handle NULLs anyway.
+2006-12-04 10:31  Sandro Santilli <strk at keybit.net>
+	* [r1928] ChangeLog,
+	  source/simplify/DouglasPeuckerLineSimplifier.cpp,
+	  tests/unit/Makefile.am, tests/unit/capi/GEOSCoordSeq.cpp,
+	  tests/unit/capi/GEOSCoordSeqTest.cpp,
+	  tests/unit/capi/GEOSSimplifyTest.cpp: * tests/unit/capi/:
+	  GEOSCoordSeq.cpp => GEOSCoordSeqTest.cpp
+	  * tests/unit/capi/GEOSSimplifyTest.cpp: new test
+	  for GEOSSimplify (just a test for bug #134).
+	  * source/simplify/DouglasPeuckerLineSimplifier.cpp (simplify):
+	  don't try to simplify empty coordinate lists. Fixes bug #134.
+2006-12-04 10:14  Sandro Santilli <strk at keybit.net>
+	* [r1927] ChangeLog, tests/unit/capi/GEOSCoordSeq.cpp: Other tests
+	  using setOrdinate instead of set{X,Y,Z}
+2006-12-04 10:12  Sandro Santilli <strk at keybit.net>
+	* [r1926] ChangeLog, source/geom/CoordinateArraySequence.cpp: *
+	  source/geom/CoordinateArraySequence.cpp (setOrdinate): fix bug
+	  #133.
+2006-12-04 10:00  Sandro Santilli <strk at keybit.net>
+	* [r1925] ChangeLog, tests/unit/capi/GEOSCoordSeq.cpp: *
+	  tests/unit/capi/GEOSCoordSeq.cpp: add test for bug #133
+	  (failing).
+2006-12-04 09:57  Sandro Santilli <strk at keybit.net>
+	* [r1924] ChangeLog,
+	  tests/unit/geom/CoordinateArraySequenceTest.cpp: *
+	  tests/unit/geom/CoordinateArraySequenceTest.cpp: added tests for
+	  setOrdinate()
+2006-11-30 14:49  Sandro Santilli <strk at keybit.net>
+	* [r1923] ChangeLog, capi/geos_c.cpp, tests/unit/Makefile.am,
+	  tests/unit/capi, tests/unit/capi/GEOSCoordSeq.cpp: * tests/unit/:
+	  Makefile.am, capi/GEOSCoordSeq.cpp:
+	  new experimental test for C-API GEOSCoordSeq.
+	  * capi/geos_c.cpp (GEOSCoordSeq_create): removed
+	  suspicious static cast.
+2006-11-28 19:13  mloskot
+	* [r1922] build, build/README, build/msvc80, build/msvc80/README,
+	  build/msvc80/geos.sln, build/msvc80/geos_c_dll,
+	  build/msvc80/geos_c_dll/geos_c_dll.vcproj, build/msvc80/geos_lib,
+	  build/msvc80/geos_lib/geos_lib.vcproj, build/msvc80/geos_unit,
+	  build/msvc80/geos_unit/geos_unit.vcproj: Added Visual C++ 2005
+	  project files.
+2006-11-23 20:17  Sandro Santilli <strk at keybit.net>
+	* [r1921] ChangeLog, source/geom/Point.cpp: * source/geom/Point.cpp
+	  (equalsExact): don't segfault on empty points. Fixes bug #132.
+2006-11-23 12:25  Sandro Santilli <strk at keybit.net>
+	* [r1920] tests/xmltester/stmlf-cases-20061020.xml: Added short
+	  descripion of testcases provenience
+2006-11-22 20:29  Sandro Santilli <strk at keybit.net>
+	* [r1919] ChangeLog, tests/xmltester/Makefile.am,
+	  tests/xmltester/stmlf-cases-20061020.xml: * tests/xmltester/:
+	  stmlf-cases-20061020.xml, Makefile.am: add more robustness
+	  testcases.
+2006-11-22 12:26  Sandro Santilli <strk at keybit.net>
+	* [r1918] ChangeLog, autogen.sh: Patch by dron at ak4719.spb.edu:
+	  * autogen.sh: call 'autoheader' after 'aclocal'.
+	  Fixes bug #131
+2006-11-18 15:30  mloskot
+	* [r1917] source/Makefile.vc: Fixed path to geos_c.h in
+	  source/makefile.vc.
+2006-11-15 18:26  Sandro Santilli <strk at keybit.net>
+	* [r1916] ChangeLog, capi/Makefile.am, capi/geos_c.h.vc.in,
+	  configure.in, source/Makefile.vc,
+	  source/headers/geos/Makefile.am,
+	  source/headers/geos/version.h.vc: * configure.in: don't generate
+	  geos_c.h.vc
+	  * source/Makefile.vc: don't generate geos_c.h and version.h
+	  * source/headers/geos/version.h.vc, capi/geos_c.h.vc.in:
+	  removed, will NOT be needed by Makefile.vc
+	  * source/headers/geos/Makefile.am: distribute version.h
+	  * capi/Makefile.am: distribute geos_c.h
+2006-11-15 14:42  Sandro Santilli <strk at keybit.net>
+	* [r1915] ChangeLog, capi/geos_c.h.in: * capi/geos_c.h.in:
+	  hopefully fixed GEOS_DLL use.
+2006-11-15 11:28  Sandro Santilli <strk at keybit.net>
+	* [r1914] ChangeLog, capi/geos_c.cpp: * capi/geos_c.cpp
+	  (GEOSGeom_getDimensions): Fix a segfault on empty geometry input
+	  (fix bug #126).
+2006-11-11 05:32  pramsey
+	* [r1913] capi/geos_c.h.vc.in: Retreived original .vc file and put
+	  in MACRO substitutions. Somehow GNU version replaced .vc version
+	  during file shuffles to get macros in.
+2006-11-10 18:24  Sandro Santilli <strk at keybit.net>
+	* [r1912] ChangeLog: fixed timewarp
+2006-11-10 17:56  pramsey
+	* [r1911] ChangeLog: noted .vc change
+2006-11-10 17:55  pramsey
+	* [r1910] capi/Makefile.am: Made sure geos_c.h.vc is part of 'make
+	  dist' since VC users won't have .configure
+2006-11-10 17:38  pramsey
+	* [r1909] capi/Makefile.am, capi/geos_c.h.vc, capi/geos_c.h.vc.in:
+	  Added substitution strings to .in files for .vc generation.
+2006-11-10 17:35  pramsey
+	* [r1908] configure.in: Changes for capi .vc generation
+2006-11-10 14:50  hobu
+	* [r1907] capi/geos_c.h.vc: update
+2006-11-09 09:10  Sandro Santilli <strk at keybit.net>
+	* [r1906] ChangeLog, tests/xmltester/XMLTester.cpp: *
+	  test/xmltester/XMLTester.cpp: improved 'testarea' test.
+2006-11-08 11:54  Sandro Santilli <strk at keybit.net>
+	* [r1905] ChangeLog: added 'release-separator' tag
+2006-11-08 11:51  Sandro Santilli <strk at keybit.net>
+	* [r1904] ChangeLog, tests/xmltester/Makefile.am,
+	  tests/xmltester/robustness.xml: * tests/xmltester/robustness.xml:
+	  made test safe to
+	  run by using the new 'areatest' operation; added
+	  new testcases just raised on the mailing list.
+	  * tests/xmltester/Makefile.am: robustness.xml is now safe
+	  to run, so run it on make check.
+2006-11-08 10:40  Sandro Santilli <strk at keybit.net>
+	* [r1903] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
+	  source/headers/geos/geom/BinaryOp.h: enable
+	  COMMONBITS-removal heuristic so it is attempted
+	  before geometry snapping.
+2006-11-05 20:34  Sandro Santilli <strk at keybit.net>
+	* [r1900] ChangeLog, capi/Makefile.am: * capi/Makefile.am:
+	  distribute files needed for testing, proper cleanup (make
+	  distcheck works now)
+2006-11-05 00:24  csavage
+	* [r1899] swig/ruby/geos_wrap.cxx: Updated ruby swig wrapper for
+	  changes in header files.
+	* [r1898] swig/python/geos_wrap.cxx: Updated python swig wrapper
+	  for changes in header files.
+2006-11-05 00:23  csavage
+	* [r1897] swig/geos.i: Fixes for changes in header files.
+2006-11-03 12:35  Sandro Santilli <strk at keybit.net>
+	* [r1896] capi/testrunner.sh: redirect 'diff' output to stderr
+2006-11-03 10:54  Sandro Santilli <strk at keybit.net>
+	* [r1895] ChangeLog, capi/testrunner.sh: hopefully fixed proper
+	  quoting
+2006-11-03 10:30  Sandro Santilli <strk at keybit.net>
+	* [r1894] ChangeLog, capi/testrunner.sh: Report non-zero return
+	  from ./geostest run
+2006-11-02 10:08  Sandro Santilli <strk at keybit.net>
+	* [r1893] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
+	  source/headers/geos/geom/BinaryOp.h: disable debugging output by
+	  default.
+2006-11-02 10:02  Sandro Santilli <strk at keybit.net>
+	* [r1892] ChangeLog, capi/geostest.c: * capi/geostest.c: updated to
+	  use the new GEOSGeometry typedef, so to build w/out warnings and
+	  fully respecting current const specification.
+2006-11-02 09:48  Sandro Santilli <strk at keybit.net>
+	* [r1891] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: *
+	  capi/geos_c.cpp, capi/geos_c.h.in: const-corrected and documented
+	  GEOSPolygonize function.
+2006-11-02 09:38  Sandro Santilli <strk at keybit.net>
+	* [r1890] ChangeLog, capi/test.expected, capi/testrunner.sh: *
+	  capi/test.expected: updated expected version
+	  * capi/testrunner.sh: be happy with geostest running w/out
+	  segfaulting, still run diff for reference.
+2006-11-02 09:33  Sandro Santilli <strk at keybit.net>
+	* [r1889] ChangeLog, configure.in: * configure.in: updated versions
+	  to 3.0.0rc2 / CAPI-1.3.0
+2006-11-02 08:32  Sandro Santilli <strk at keybit.net>
+	* [r1888] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: Patch by
+	  Markus Schaber <schabi at logix-tt.com>:
+	  * capi/geos_c.h.in: add GEOSGeometry and GEOSCoordSequence
+	  typedef, to unhide the pointer type and allow fine-grained
+	  const specification, use the new typedefs in function signatures
+	  (fix some const-specifications accordingly)
+	  * capi/geos_c.cpp: define GEOSGeometry and GEOSCoordSequence
+	  for cross-checking of types in header.
+2006-10-30 15:14  Sandro Santilli <strk at keybit.net>
+	* [r1887] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: Patch by
+	  * capi/geos_c.cpp: more focused 'using' directives.
+	  * capi/geos_c.h.in: let the enum visible by geos_c.cpp
+	  now that there are no more name clashes.
+2006-10-30 13:20  Sandro Santilli <strk at keybit.net>
+	* [r1886] capi/geos_c.cpp: removed useless GEOSGeomTypes define
+2006-10-30 13:00  Sandro Santilli <strk at keybit.net>
+	* [r1885] ChangeLog, source/operation/overlay/OverlayOp.cpp: reduce
+	  default verbosity
+2006-10-30 12:49  Sandro Santilli <strk at keybit.net>
+	* [r1884] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: *
+	  capi/geos_c.cpp:
+	  Remove a typedef which is also included via Header;
+	  Use dynamic_cast instead of C cast in 2 cases to allow the RTTI
+	  type check;
+	  Replace "geoms" temp vector in polygonizer function with a loop,
+	  this saves us at least one of the two vector copies;
+	  Drop 2 unneded const_cast occurences;
+	  Allow calling getNumGeometries against non-collections;
+	  2 comment / whitespace cleanups.
+	  Added a comment explaining ou #ifndef magic;
+	  Unified the two #ifndef into a single one.
+2006-10-30 10:29  Sandro Santilli <strk at keybit.net>
+	* [r1883] ChangeLog, capi/Makefile.am, capi/test.expected,
+	  capi/testrunner.sh: * capi/: test.expected, testrunner.sh,
+	  Makefile.am: Added a run of ./geostest as part of 'make check'
+2006-10-30 10:15  Sandro Santilli <strk at keybit.net>
+	* [r1882] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: Patch
+	  submitted by Markus Schaber <schabi at logix-tt.com> ( reviewed and
+	  fixed )
+	  * capi/: geos_c.cpp, geos_c.h.in:
+	  Changed the C-API implementation to actually include the header
+	  that's included by the clients, this allows the compiler to check
+	  declarations and implementation for consistency, fixed geos_c.cpp
+	  accordingly (const-correctness, mainly).
+2006-10-30 09:49  Sandro Santilli <strk at keybit.net>
+	* [r1881] ChangeLog, capi/geostest.c: * capi/geostest.c: added some
+	  checks of return from CAPI functions returning GEOSGeom (not all,
+	  just a few)
+2006-10-27 11:54  Sandro Santilli <strk at keybit.net>
+	* [r1880] ChangeLog, source/algorithm/InteriorPointLine.cpp,
+	  source/headers/geos/algorithm/InteriorPointLine.h,
+	  source/headers/geos/geom/Geometry.h,
+	  source/headers/geos/operation/polygonize/Polygonizer.h,
+	  source/operation/polygonize/Polygonizer.cpp: Patch by Markus
+	  Schaber <schabi at logix-tt.com>
+	  * algorithm::InteriorPointLine (ctor): take Geometry by
+	  const-pointer.
+	  * geom::Geometry (getInteriorPoint): made a const-method
+	  * operation::polygonize::Polygonizer: implement filter_ro rather
+	  then filter_rw, as it doesn't change the Geometry, propagated
+	  change to internal interfaces (add methods)
+2006-10-26 09:22  Sandro Santilli <strk at keybit.net>
+	* [r1879] ChangeLog, capi/geos_c.h.in: * capi/geos_c.h.in: reverted
+	  all changes of 'int' types
+	  to 'size_t' types (the lib never changed, and still expects
+	  ints)
+2006-10-24 16:54  Sandro Santilli <strk at keybit.net>
+	* [r1878] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
+	  source/headers/geos/geom/BinaryOp.h: try original geoms first by
+	  default.
+2006-10-24 16:53  Sandro Santilli <strk at keybit.net>
+	* [r1877] ChangeLog,
+	  source/operation/overlay/OverlayResultValidator.cpp: *
+	  operation::overlay::OverlayResultValidator.cpp (isValid): run the
+	  test even if inputs and output are not areal.
+2006-10-24 16:49  Sandro Santilli <strk at keybit.net>
+	* [r1876] ChangeLog,
+	  source/operation/overlay/FuzzyPointLocator.cpp: *
+	  operation::overlay::FuzzyPointLocator: eliminate non-polygonal
+	  components from consideration when testing the location of
+	  points.
+2006-10-24 10:16  Sandro Santilli <strk at keybit.net>
+	* [r1875] ChangeLog,
+	  source/precision/GeometrySnapper.cpp: *
+	  precision::GeometrySnapper: snapPrecisionFactor augmented from
+	  10e-12 to 10e-10.
+2006-10-24 09:49  Sandro Santilli <strk at keybit.net>
+	* [r1874] ChangeLog,
+	  precision::LineStringSnapper (findSegmentToSnap):
+	  return the *closest* segment, don't snap if the closest
+	  segment *intersects* the snap points, consider a distance
+	  of exactly snapTolerance as non-tolerated (got in sync with JTS)
+2006-10-23 10:23  Sandro Santilli <strk at keybit.net>
+	* [r1873] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
+	  source/headers/geos/geom/BinaryOp.h (SnapOp): document and add
+	  optional CBR step (snap after applying common bits removal - this
+	  is the default); (check_valid): add validity checker function.
+2006-10-20 11:18  Sandro Santilli <strk at keybit.net>
+	* [r1872] ChangeLog, source/headers/geos/noding/SegmentString.h,
+	  source/noding/ScaledNoder.cpp, source/noding/SegmentString.cpp: *
+	  noding::SegmentString: added notifyCoordinatesChange method.
+	  * noding::ScaledNoder: notify possible coordinates change to
+	  SegmentString after removing repeated points.
+2006-10-19 18:26  Sandro Santilli <strk at keybit.net>
+	* [r1871] ChangeLog, configure.in: * configure.in: use 'expr' for
+	  arithmetics (more portable)
+2006-10-18 19:21  mloskot
+	* [r1870] ChangeLog, makefile.vc, source/Makefile.vc: Refactored
+	  Visual C++ makefiles.
+2006-10-18 17:53  mloskot
+	* [r1869] source/Makefile.vc, source/dirlist.mk: Updated
+	  source\makefile.vc and source\dirlist.mk files.
+	* [r1868] makefile.vc: Added top-level makefile.vc.
+2006-10-18 14:28  Sandro Santilli <strk at keybit.net>
+	* [r1867] .: fixed svn:ignore property
+2006-10-18 12:08  Sandro Santilli <strk at keybit.net>
+	* [r1866] ChangeLog, source/operation/overlay/OverlayOp.cpp:
+	  disable non-JTS overlay result validators (to more closely track
+	  JTS at this stage)
+2006-10-17 14:26  Sandro Santilli <strk at keybit.net>
+	* [r1865] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
+	  source/headers/geos/geom/BinaryOp.h (SnapOp): fixed horrible
+	  bug applying overlay of first geom to itself :(
+2006-10-17 10:15  Sandro Santilli <strk at keybit.net>
+	* [r1864] capi/geos_c.h.in: really fixed 'extra tokens at end of
+	  #endif directive' warning
+2006-10-17 10:10  Sandro Santilli <strk at keybit.net>
+	* [r1863] capi/geos_c.h.in: fixed 'extra tokens at end of #endif
+	  directive' warning
+2006-10-17 08:44  Sandro Santilli <strk at keybit.net>
+	* [r1862] ChangeLog, capi/Makefile.am: * capi/Makefile.am: don't
+	  directly link geostest against
+	  both libgeos.so and libstdc++ (should be derived by
+	  libgeos_c.so).
+2006-10-12 15:33  Sandro Santilli <strk at keybit.net>
+	* [r1861] ChangeLog, tests/bigtest/GeometryTestFactory.cpp,
+	  tests/bigtest/TestSweepLineSpeed.cpp, tests/bigtest/bigtest.h: *
+	  tests/bigtest/GeometryTestFactory.cpp, tests/bigtest/bigtest.h,
+	  tests/bigtest/TestSweepLineSpeed.cpp: fixed header inclusion, to
+	  reduce compiler noise.
+2006-10-09 16:39  Sandro Santilli <strk at keybit.net>
+	* [r1860] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
+	  source/headers/geos/geom/BinaryOp.h: always snap geoms to
+	  each-other before applying an overlay (temp hack).
+2006-10-09 16:35  Sandro Santilli <strk at keybit.net>
+	* [r1859] ChangeLog, source/operation/overlay/OverlayOp.cpp: *
+	  source/operation/overlay/OverlayOp.cpp: enable all overlay result
+	  validators, make it disablable at compile time.
+2006-10-05 10:58  mloskot
+	* [r1858] ChangeLog, capi/geos_c.h.in, capi/geos_c.h.vc: Added
+	  inclusion guards to geos_c.h files.
+2006-10-05 09:46  Sandro Santilli <strk at keybit.net>
+	* [r1857] ChangeLog, tests/xmltester/XMLTester.cpp: increment
+	  areatest verbosity (needs -v -v)
+2006-10-02 18:53  hobu
+	* [r1856] ChangeLog, capi/geos_c.cpp: GEOSEnvelope wasn't in the
+	  PROTOTYPES section in geos_c.cpp
+2006-09-27 07:48  Sandro Santilli <strk at keybit.net>
+	* [r1855] HOWTO_RELEASE: updated tag item
+2006-09-27 07:43  Sandro Santilli <strk at keybit.net>
+	* [r1854] HOWTO_RELEASE: added info about svn tags
+2006-09-19 06:54  Sandro Santilli <strk at keybit.net>
+	* [r1853] source/operation/overlay/OffsetPointGenerator.cpp: Added
+	  <algorithm> include
+2006-09-08 23:13  pramsey
+	* [r1851] AUTHORS: Added information about funders of the 3.0.0
+	  series: Safe Software, Autodesk,
+	  Bavarian State Ministry of Agriculture and Forestry and the State
+	  Survey of Bavaria.
+2006-09-08 09:38  Sandro Santilli <strk at keybit.net>
+	* [r1850] TODO: updated
+2006-09-08 09:31  Sandro Santilli <strk at keybit.net>
+	* [r1849] source/operation/overlay/OverlayResultValidator.cpp: more
+	  debugging output
+2006-09-08 09:21  Sandro Santilli <strk at keybit.net>
+	* [r1848] tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp,
+	  tests/unit/operation/overlay/OverlayResultValidatorTest.cpp: More
+	  testcases
+2006-09-07 18:07  Sandro Santilli <strk at keybit.net>
+	* [r1847] tests/unit/Makefile.am,
+	  tests/unit/operation/overlay/OverlayResultValidatorTest.cpp: New
+	  unit test for OverlayResultValidator class
+	* [r1846] source/operation/overlay/OverlayResultValidator.cpp: more
+	  debugging output
+2006-09-07 17:52  Sandro Santilli <strk at keybit.net>
+	* [r1845]
+	  source/operation/overlay/OverlayResultValidator.cpp: Added
+	  addVertices private method (unused, as in JTS, but possibly
+	  useful in the future)
+2006-09-07 17:41  Sandro Santilli <strk at keybit.net>
+	* [r1844] source/operation/overlay/OverlayResultValidator.cpp:
+	  Added debugging code
+2006-09-07 17:35  Sandro Santilli <strk at keybit.net>
+	* [r1843]
+	  tests/unit/operation/overlay/OffsetPointGeneratorTest.cpp: more
+	  testcases (added test for max distance of offset points)
+2006-09-07 15:28  Sandro Santilli <strk at keybit.net>
+	* [r1842] tests/unit/algorithm/PointLocatorTest.cpp,
+	  tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp,
+	  tests/unit/geom/CoordinateArraySequenceTest.cpp,
+	  tests/unit/geom/CoordinateListTest.cpp,
+	  tests/unit/geom/CoordinateTest.cpp,
+	  tests/unit/geom/DimensionTest.cpp,
+	  tests/unit/geom/EnvelopeTest.cpp,
+	  tests/unit/geom/GeometryFactoryTest.cpp,
+	  tests/unit/geom/LineSegmentTest.cpp,
+	  tests/unit/geom/LineStringTest.cpp,
+	  tests/unit/geom/LinearRingTest.cpp,
+	  tests/unit/geom/LocationTest.cpp,
+	  tests/unit/geom/MultiLineStringTest.cpp,
+	  tests/unit/geom/MultiPointTest.cpp,
+	  tests/unit/geom/MultiPolygonTest.cpp,
+	  tests/unit/geom/PointTest.cpp, tests/unit/geom/PolygonTest.cpp,
+	  tests/unit/geom/TriangleTest.cpp,
+	  tests/unit/io/WKBReaderTest.cpp,
+	  tests/unit/noding/SegmentStringTest.cpp,
+	  tests/unit/precision/LineStringSnapperTest.cpp: removed
+	  svn:executable prop from all .cpp files
+2006-09-07 15:22  Sandro Santilli <strk at keybit.net>
+	* [r1841] tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp,
+	  removed svn:executable property
+2006-09-07 15:21  Sandro Santilli <strk at keybit.net>
+	* [r1840] tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp:
+	  testing execute bit state
+2006-09-07 12:17  mloskot
+	* [r1839] tests/unit/operation/distance/DistanceOpTest.cpp: Set
+	  svn:keyword for $ expansion.
+2006-09-07 11:34  Sandro Santilli <strk at keybit.net>
+	* [r1838] source/operation/overlay/OverlayOp.cpp: Cleaned up
+	  OverlayResultValidator call (still disabled due to bugs)
+2006-09-07 11:27  Sandro Santilli <strk at keybit.net>
+	* [r1837] source/operation/overlay/OverlayResultValidator.cpp:
+	  blindly return positive result if any input or output is not an
+	  area
+2006-09-07 11:08  Sandro Santilli <strk at keybit.net>
+	* [r1836] tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp:
+	  new test for FuzzyPointLocator
+2006-09-07 10:30  Sandro Santilli <strk at keybit.net>
+	* [r1835] source/headers/geos/geom/Location.h: Explicit values to
+	  LocationValue enum items. Removed CVS Log
+2006-09-07 09:33  Sandro Santilli <strk at keybit.net>
+	* [r1834] doc/example.cpp: Removed catch-all headers inclusion and
+	  use of obsoleted Unload class
+2006-09-07 09:24  Sandro Santilli <strk at keybit.net>
+	* [r1833] README: updated
+2006-09-07 09:23  Sandro Santilli <strk at keybit.net>
+	* [r1832]
+	  source/headers/geos/operation/overlay/OverlayResultValidator.h:
+	  comment cleanup
+2006-09-07 09:01  Sandro Santilli <strk at keybit.net>
+	* [r1831] source/headers/geos/operation/distance/DistanceOp.h:
+	  Comments about ownership (and lifetime) of returned objects
+2006-09-07 08:59  Sandro Santilli <strk at keybit.net>
+	* [r1830] tests/unit/Makefile.am, tests/unit/operation/distance,
+	  tests/unit/operation/distance/DistanceOpTest.cpp: New DistanceOp
+	  unit test
+2006-09-07 08:57  Sandro Santilli <strk at keybit.net>
+	* [r1829] ChangeLog, source/operation/distance/DistanceOp.cpp:
+	  (computeMinDistancePoints): fixed invalid reference.
+2006-09-07 08:23  Sandro Santilli <strk at keybit.net>
+	* [r1828] ChangeLog, autogen.sh: don't giveup on automake failures
+	  (testing)
+2006-09-06 18:44  Sandro Santilli <strk at keybit.net>
+	* [r1827] source/operation/overlay/OverlayOp.cpp: Ops, overlay
+	  result validation erroenously committed
+2006-09-06 18:41  Sandro Santilli <strk at keybit.net>
+	* [r1826] ChangeLog, tests/unit/Makefile.am,
+	  tests/unit/operation/overlay/OffsetPointGeneratorTest.cpp: new
+	  test for OffsetPointGenerator class
+2006-09-06 18:37  Sandro Santilli <strk at keybit.net>
+	* [r1825] source/operation/overlay/OffsetPointGenerator.cpp: Fixed
+	  uninitialized memory bug
+2006-09-06 17:59  Sandro Santilli <strk at keybit.net>
+	* [r1824] ChangeLog, source/operation/overlay/OverlayOp.cpp,
+	  tests/unit/Makefile.am, tests/unit/operation,
+	  tests/unit/operation/overlay,
+	  tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp: new test
+	  for FuzzyPointLocator class
+2006-09-06 17:48  Sandro Santilli <strk at keybit.net>
+	* [r1823] tests/unit/precision/GeometrySnapperTest.cpp: updated
+	  after GeometrySnapper interface change.
+2006-09-06 17:26  mloskot
+	* [r1822] ChangeLog,
+	  source/operation/overlay/OverlayResultValidator.cpp: Set $
+	  expansion for new files in 'overlay' module.
+2006-09-06 17:22  Sandro Santilli <strk at keybit.net>
+	* [r1821] ChangeLog,
+	  source/headers/geos/operation/overlay/Makefile.am,
+	  source/operation/overlay/FuzzyPointLocator.cpp,
+	  source/operation/overlay/Makefile.am,
+	  source/operation/overlay/OverlayResultValidator.cpp: Rest of
+	  Overlay validation classes.
+2006-09-06 16:54  mloskot
+	* [r1820] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in,
+	  capi/geos_c.h.vc, capi/geostest.c, configure.in, debian/watch,
+	  doc/Doxyfile.in, doc/example.cpp, source/Makefile.vc,
+	  source/algorithm/ConvexHull.cpp,
+	  source/algorithm/LineIntersector.cpp,
+	  source/algorithm/MCPointInRing.cpp,
+	  source/algorithm/NonRobustLineIntersector.cpp,
+	  source/algorithm/NotRepresentableException.cpp,
+	  source/algorithm/RobustDeterminant.cpp,
+	  source/algorithm/RobustLineIntersector.cpp,
+	  source/algorithm/SimplePointInRing.cpp, source/dirlist.mk,
+	  source/examples/CPCLException.cpp,
+	  source/examples/CoordinateSequencesExample.cpp,
+	  source/examples/CustomCoordinateSequenceExample.cpp,
+	  source/examples/CustomCoordinateSequenceExample.h,
+	  source/examples/CustomPointCoordinateSequence.cpp,
+	  source/geom/Coordinate.cpp,
+	  source/geom/CoordinateArraySequenceFactory.cpp,
+	  source/geom/CoordinateSequenceFactory.cpp,
+	  source/geom/Dimension.cpp, source/geom/Envelope.cpp,
+	  source/geom/GeometryComponentFilter.cpp,
+	  source/geom/GeometryFactory.cpp, source/geom/GeometryList.cpp,
+	  source/geom/IntersectionMatrix.cpp, source/geom/LineSegment.cpp,
+	  source/geom/LineString.cpp, source/geom/LinearRing.cpp,
+	  source/geom/Location.cpp, source/geom/MultiLineString.cpp,
+	  source/geom/MultiPoint.cpp, source/geom/MultiPolygon.cpp,
+	  source/geom/Point.cpp, source/geom/Polygon.cpp,
+	  source/geom/PrecisionModel.cpp, source/geom/Triangle.cpp,
+	  source/geom/util/CoordinateOperation.cpp,
+	  source/geom/util/GeometryEditor.cpp,
+	  source/geom/util/GeometryTransformer.cpp,
+	  source/geom/util/LinearComponentExtracter.cpp,
+	  source/geom/util/PointExtracter.cpp,
+	  source/geom/util/PolygonExtracter.cpp,
+	  source/geom/util/ShortCircuitedGeometryVisitor.cpp,
+	  source/geomgraph/Depth.cpp, source/geomgraph/DirectedEdge.cpp,
+	  source/geomgraph/DirectedEdgeStar.cpp, source/geomgraph/Edge.cpp,
+	  source/geomgraph/EdgeEnd.cpp, source/geomgraph/EdgeEndStar.cpp,
+	  source/geomgraph/EdgeIntersection.cpp,
+	  source/geomgraph/EdgeIntersectionList.cpp,
+	  source/geomgraph/EdgeNodingValidator.cpp,
+	  source/geomgraph/EdgeRing.cpp,
+	  source/geomgraph/GeometryGraph.cpp,
+	  source/geomgraph/GraphComponent.cpp, source/geomgraph/Label.cpp,
+	  source/geomgraph/Node.cpp, source/geomgraph/NodeFactory.cpp,
+	  source/geomgraph/NodeMap.cpp, source/geomgraph/PlanarGraph.cpp,
+	  source/geomgraph/Position.cpp, source/geomgraph/Quadrant.cpp,
+	  source/geomgraph/TopologyLocation.cpp,
+	  source/geomgraph/index/MonotoneChainEdge.cpp,
+	  source/geomgraph/index/MonotoneChainIndexer.cpp,
+	  source/geomgraph/index/SegmentIntersector.cpp,
+	  source/geomgraph/index/SimpleEdgeSetIntersector.cpp,
+	  source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
+	  source/geomgraph/index/SimpleSweepLineIntersector.cpp,
+	  source/geomgraph/index/SweepLineEvent.cpp,
+	  source/geomgraph/index/SweepLineSegment.cpp,
+	  source/headers/acconfig.h, source/headers/geos.h,
+	  source/headers/geos/algorithm/CGAlgorithms.h,
+	  source/headers/geos/algorithm/CentroidArea.h,
+	  source/headers/geos/algorithm/CentroidLine.h,
+	  source/headers/geos/algorithm/CentroidPoint.h,
+	  source/headers/geos/algorithm/ConvexHull.h,
+	  source/headers/geos/algorithm/ConvexHull.inl,
+	  source/headers/geos/algorithm/HCoordinate.h,
+	  source/headers/geos/algorithm/InteriorPointArea.h,
+	  source/headers/geos/algorithm/InteriorPointPoint.h,
+	  source/headers/geos/algorithm/MCPointInRing.h,
+	  source/headers/geos/algorithm/MinimumDiameter.h,
+	  source/headers/geos/algorithm/NotRepresentableException.h,
+	  source/headers/geos/algorithm/PointInRing.h,
+	  source/headers/geos/algorithm/PointLocator.h,
+	  source/headers/geos/algorithm/RobustDeterminant.h,
+	  source/headers/geos/algorithm/SIRtreePointInRing.h,
+	  source/headers/geos/algorithm/SimplePointInAreaLocator.h,
+	  source/headers/geos/algorithm/SimplePointInRing.h,
+	  source/headers/geos/geom.h, source/headers/geos/geom/BinaryOp.h,
+	  source/headers/geos/geom/Coordinate.h,
+	  source/headers/geos/geom/Coordinate.inl,
+	  source/headers/geos/geom/CoordinateArraySequenceFactory.h,
+	  source/headers/geos/geom/CoordinateArraySequenceFactory.inl,
+	  source/headers/geos/geom/CoordinateList.h,
+	  source/headers/geos/geom/CoordinateSequenceFactory.h,
+	  source/headers/geos/geom/Dimension.h,
+	  source/headers/geos/geom/Envelope.h,
+	  source/headers/geos/geom/Envelope.inl,
+	  source/headers/geos/geom/Geometry.inl,
+	  source/headers/geos/geom/GeometryCollection.h,
+	  source/headers/geos/geom/GeometryCollection.inl,
+	  source/headers/geos/geom/GeometryComponentFilter.h,
+	  source/headers/geos/geom/GeometryFactory.h,
+	  source/headers/geos/geom/GeometryFactory.inl,
+	  source/headers/geos/geom/GeometryFilter.h,
+	  source/headers/geos/geom/GeometryList.h,
+	  source/headers/geos/geom/IntersectionMatrix.h,
+	  source/headers/geos/geom/LineSegment.h,
+	  source/headers/geos/geom/LineSegment.inl,
+	  source/headers/geos/geom/LineString.h,
+	  source/headers/geos/geom/LinearRing.h,
+	  source/headers/geos/geom/Location.h,
+	  source/headers/geos/geom/MultiLineString.h,
+	  source/headers/geos/geom/MultiLineString.inl,
+	  source/headers/geos/geom/MultiPoint.h,
+	  source/headers/geos/geom/MultiPolygon.h,
+	  source/headers/geos/geom/MultiPolygon.inl,
+	  source/headers/geos/geom/Point.h,
+	  source/headers/geos/geom/Polygon.h,
+	  source/headers/geos/geom/PrecisionModel.h,
+	  source/headers/geos/geom/PrecisionModel.inl,
+	  source/headers/geos/geom/Triangle.h,
+	  source/headers/geos/geom/util/CoordinateOperation.h,
+	  source/headers/geos/geom/util/GeometryEditor.h,
+	  source/headers/geos/geom/util/GeometryEditorOperation.h,
+	  source/headers/geos/geom/util/GeometryTransformer.h,
+	  source/headers/geos/geom/util/LinearComponentExtracter.h,
+	  source/headers/geos/geom/util/PointExtracter.h,
+	  source/headers/geos/geom/util/PolygonExtracter.h,
+	  source/headers/geos/geom/util/ShortCircuitedGeometryVisitor.h,
+	  source/headers/geos/geomUtil.h, source/headers/geos/geomgraph.h,
+	  source/headers/geos/geomgraph/Depth.h,
+	  source/headers/geos/geomgraph/DirectedEdge.h,
+	  source/headers/geos/geomgraph/DirectedEdge.inl,
+	  source/headers/geos/geomgraph/DirectedEdgeStar.h,
+	  source/headers/geos/geomgraph/EdgeEnd.h,
+	  source/headers/geos/geomgraph/EdgeEndStar.h,
+	  source/headers/geos/geomgraph/EdgeIntersection.h,
+	  source/headers/geos/geomgraph/EdgeIntersectionList.h,
+	  source/headers/geos/geomgraph/EdgeList.h,
+	  source/headers/geos/geomgraph/EdgeRing.h,
+	  source/headers/geos/geomgraph/GeometryGraph.h,
+	  source/headers/geos/geomgraph/GeometryGraph.inl,
+	  source/headers/geos/geomgraph/GraphComponent.h,
+	  source/headers/geos/geomgraph/Label.h,
+	  source/headers/geos/geomgraph/NodeFactory.h,
+	  source/headers/geos/geomgraph/NodeMap.h,
+	  source/headers/geos/geomgraph/PlanarGraph.h,
+	  source/headers/geos/geomgraph/Position.h,
+	  source/headers/geos/geomgraph/Quadrant.h,
+	  source/headers/geos/geomgraph/TopologyLocation.h,
+	  source/headers/geos/geomgraph/index/EdgeSetIntersector.h,
+	  source/headers/geos/geomgraph/index/MonotoneChain.h,
+	  source/headers/geos/geomgraph/index/MonotoneChainEdge.h,
+	  source/headers/geos/geomgraph/index/MonotoneChainIndexer.h,
+	  source/headers/geos/geomgraph/index/SegmentIntersector.h,
+	  source/headers/geos/geomgraph/index/SimpleEdgeSetIntersector.h,
+	  source/headers/geos/geomgraph/index/SimpleMCSweepLineIntersector.h,
+	  source/headers/geos/geomgraph/index/SimpleSweepLineIntersector.h,
+	  source/headers/geos/geomgraph/index/SweepLineEvent.h,
+	  source/headers/geos/geomgraph/index/SweepLineEventObj.h,
+	  source/headers/geos/geomgraph/index/SweepLineSegment.h,
+	  source/headers/geos/geomgraphindex.h,
+	  source/headers/geos/geosAlgorithm.h,
+	  source/headers/geos/index/ItemVisitor.h,
+	  source/headers/geos/index/SpatialIndex.h,
+	  source/headers/geos/index/bintree/Bintree.h,
+	  source/headers/geos/index/bintree/Interval.h,
+	  source/headers/geos/index/bintree/Key.h,
+	  source/headers/geos/index/bintree/Node.h,
+	  source/headers/geos/index/bintree/NodeBase.h,
+	  source/headers/geos/index/chain/MonotoneChain.h,
+	  source/headers/geos/index/chain/MonotoneChainBuilder.h,
+	  source/headers/geos/index/chain/MonotoneChainSelectAction.h,
+	  source/headers/geos/index/quadtree/DoubleBits.h,
+	  source/headers/geos/index/quadtree/IntervalSize.h,
+	  source/headers/geos/index/quadtree/Key.h,
+	  source/headers/geos/index/quadtree/Node.h,
+	  source/headers/geos/index/quadtree/NodeBase.h,
+	  source/headers/geos/index/quadtree/Quadtree.h,
+	  source/headers/geos/index/quadtree/Root.h,
+	  source/headers/geos/index/strtree/AbstractSTRtree.h,
+	  source/headers/geos/index/strtree/Interval.h,
+	  source/headers/geos/index/strtree/ItemBoundable.h,
+	  source/headers/geos/index/sweepline/SweepLineEvent.h,
+	  source/headers/geos/index/sweepline/SweepLineIndex.h,
+	  source/headers/geos/index/sweepline/SweepLineInterval.h,
+	  source/headers/geos/index/sweepline/SweepLineOverlapAction.h,
+	  source/headers/geos/indexBintree.h,
+	  source/headers/geos/indexChain.h,
+	  source/headers/geos/indexQuadtree.h,
+	  source/headers/geos/indexStrtree.h,
+	  source/headers/geos/indexSweepline.h,
+	  source/headers/geos/inline.h, source/headers/geos/io.h,
+	  source/headers/geos/io/ByteOrderDataInStream.h,
+	  source/headers/geos/io/ByteOrderDataInStream.inl,
+	  source/headers/geos/io/ByteOrderValues.h,
+	  source/headers/geos/io/ParseException.h,
+	  source/headers/geos/io/StringTokenizer.h,
+	  source/headers/geos/io/WKBConstants.h,
+	  source/headers/geos/io/WKBReader.h,
+	  source/headers/geos/io/WKBWriter.h,
+	  source/headers/geos/io/WKTReader.h,
+	  source/headers/geos/io/WKTReader.inl,
+	  source/headers/geos/io/WKTWriter.h,
+	  source/headers/geos/io/Writer.h, source/headers/geos/noding.h,
+	  source/headers/geos/noding/IntersectionAdder.h,
+	  source/headers/geos/noding/IntersectionFinderAdder.h,
+	  source/headers/geos/noding/IteratedNoder.h,
+	  source/headers/geos/noding/MCIndexNoder.h,
+	  source/headers/geos/noding/MCIndexNoder.inl,
+	  source/headers/geos/noding/Noder.h,
+	  source/headers/geos/noding/NodingValidator.h,
+	  source/headers/geos/noding/Octant.h,
+	  source/headers/geos/noding/ScaledNoder.h,
+	  source/headers/geos/noding/SegmentIntersector.h,
+	  source/headers/geos/noding/SegmentNode.h,
+	  source/headers/geos/noding/SegmentNodeList.h,
+	  source/headers/geos/noding/SegmentString.h,
+	  source/headers/geos/noding/SegmentString.inl,
+	  source/headers/geos/noding/SimpleNoder.h,
+	  source/headers/geos/noding/SinglePassNoder.h,
+	  source/headers/geos/noding/snapround/HotPixel.h,
+	  source/headers/geos/noding/snapround/HotPixel.inl,
+	  source/headers/geos/noding/snapround/MCIndexPointSnapper.h,
+	  source/headers/geos/noding/snapround/MCIndexSnapRounder.h,
+	  source/headers/geos/noding/snapround/MCIndexSnapRounder.inl,
+	  source/headers/geos/noding/snapround/SimpleSnapRounder.h,
+	  source/headers/geos/nodingSnapround.h,
+	  source/headers/geos/opBuffer.h, source/headers/geos/opDistance.h,
+	  source/headers/geos/opLinemerge.h,
+	  source/headers/geos/opOverlay.h,
+	  source/headers/geos/opPolygonize.h,
+	  source/headers/geos/opPredicate.h,
+	  source/headers/geos/opRelate.h, source/headers/geos/opValid.h,
+	  source/headers/geos/operation.h,
+	  source/headers/geos/operation/EndpointInfo.h,
+	  source/headers/geos/operation/GeometryGraphOperation.h,
+	  source/headers/geos/operation/IsSimpleOp.h,
+	  source/headers/geos/operation/buffer/BufferSubgraph.h,
+	  source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h,
+	  source/headers/geos/operation/buffer/RightmostEdgeFinder.h,
+	  source/headers/geos/operation/buffer/SubgraphDepthLocater.h,
+	  source/headers/geos/operation/distance/ConnectedElementLocationFilter.h,
+	  source/headers/geos/operation/distance/ConnectedElementPointFilter.h,
+	  source/headers/geos/operation/distance/DistanceOp.h,
+	  source/headers/geos/operation/distance/GeometryLocation.h,
+	  source/headers/geos/operation/linemerge/EdgeString.h,
+	  source/headers/geos/operation/linemerge/LineMergeDirectedEdge.h,
+	  source/headers/geos/operation/linemerge/LineMergeEdge.h,
+	  source/headers/geos/operation/linemerge/LineMergeGraph.h,
+	  source/headers/geos/operation/linemerge/LineMerger.h,
+	  source/headers/geos/operation/linemerge/LineSequencer.h,
+	  source/headers/geos/operation/overlay/EdgeSetNoder.h,
+	  source/headers/geos/operation/overlay/ElevationMatrix.h,
+	  source/headers/geos/operation/overlay/ElevationMatrixCell.h,
+	  source/headers/geos/operation/overlay/LineBuilder.h,
+	  source/headers/geos/operation/overlay/MaximalEdgeRing.h,
+	  source/headers/geos/operation/overlay/MinimalEdgeRing.h,
+	  source/headers/geos/operation/overlay/MinimalEdgeRing.inl,
+	  source/headers/geos/operation/overlay/OverlayNodeFactory.h,
+	  source/headers/geos/operation/overlay/OverlayOp.h,
+	  source/headers/geos/operation/overlay/PointBuilder.h,
+	  source/headers/geos/operation/overlay/PolygonBuilder.h,
+	  source/headers/geos/operation/polygonize/EdgeRing.h,
+	  source/headers/geos/operation/polygonize/PolygonizeDirectedEdge.h,
+	  source/headers/geos/operation/polygonize/PolygonizeEdge.h,
+	  source/headers/geos/operation/polygonize/PolygonizeGraph.h,
+	  source/headers/geos/operation/predicate/RectangleContains.h,
+	  source/headers/geos/operation/predicate/RectangleIntersects.h,
+	  source/headers/geos/operation/predicate/SegmentIntersectionTester.h,
+	  source/headers/geos/operation/relate/EdgeEndBuilder.h,
+	  source/headers/geos/operation/relate/EdgeEndBundle.h,
+	  source/headers/geos/operation/relate/EdgeEndBundleStar.h,
+	  source/headers/geos/operation/relate/RelateComputer.h,
+	  source/headers/geos/operation/relate/RelateNode.h,
+	  source/headers/geos/operation/relate/RelateNodeFactory.h,
+	  source/headers/geos/operation/relate/RelateNodeGraph.h,
+	  source/headers/geos/operation/relate/RelateOp.h,
+	  source/headers/geos/operation/valid/ConnectedInteriorTester.h,
+	  source/headers/geos/operation/valid/ConsistentAreaTester.h,
+	  source/headers/geos/operation/valid/IsValidOp.h,
+	  source/headers/geos/operation/valid/QuadtreeNestedRingTester.h,
+	  source/headers/geos/operation/valid/RepeatedPointTester.h,
+	  source/headers/geos/operation/valid/SimpleNestedRingTester.h,
+	  source/headers/geos/operation/valid/SweeplineNestedRingTester.h,
+	  source/headers/geos/operation/valid/TopologyValidationError.h,
+	  source/headers/geos/planargraph.h,
+	  source/headers/geos/planargraph/DirectedEdge.h,
+	  source/headers/geos/planargraph/DirectedEdgeStar.h,
+	  source/headers/geos/planargraph/Edge.h,
+	  source/headers/geos/planargraph/GraphComponent.h,
+	  source/headers/geos/planargraph/Node.h,
+	  source/headers/geos/planargraph/NodeMap.h,
+	  source/headers/geos/planargraph/PlanarGraph.h,
+	  source/headers/geos/planargraph/Subgraph.h,
+	  source/headers/geos/planargraph/algorithm/ConnectedSubgraphFinder.h,
+	  source/headers/geos/platform.h.in,
+	  source/headers/geos/platform.h.vc,
+	  source/headers/geos/precision.h,
+	  source/headers/geos/precision/CommonBits.h,
+	  source/headers/geos/precision/CommonBitsOp.h,
+	  source/headers/geos/precision/CommonBitsRemover.h,
+	  source/headers/geos/precision/EnhancedPrecisionOp.h,
+	  source/headers/geos/precision/SimpleGeometryPrecisionReducer.h,
+	  source/headers/geos/profiler.h,
+	  source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h,
+	  source/headers/geos/simplify/DouglasPeuckerSimplifier.h,
+	  source/headers/geos/simplify/LineSegmentIndex.h,
+	  source/headers/geos/simplify/TaggedLineSegment.h,
+	  source/headers/geos/simplify/TaggedLineString.h,
+	  source/headers/geos/simplify/TaggedLineStringSimplifier.h,
+	  source/headers/geos/simplify/TaggedLinesSimplifier.h,
+	  source/headers/geos/simplify/TopologyPreservingSimplifier.h,
+	  source/headers/geos/spatialIndex.h,
+	  source/headers/geos/timeval.h, source/headers/geos/unload.h,
+	  source/headers/geos/util.h, source/headers/geos/util/Assert.h,
+	  source/headers/geos/util/AssertionFailedException.h,
+	  source/headers/geos/util/CoordinateArrayFilter.h,
+	  source/headers/geos/util/GEOSException.h,
+	  source/headers/geos/util/GeometricShapeFactory.h,
+	  source/headers/geos/util/IllegalArgumentException.h,
+	  source/headers/geos/util/TopologyException.h,
+	  source/headers/geos/util/UniqueCoordinateArrayFilter.h,
+	  source/headers/geos/util/UnsupportedOperationException.h,
+	  source/headers/geos/util/math.h,
+	  source/headers/geos/version.h.in,
+	  source/index/bintree/Bintree.cpp,
+	  source/index/bintree/Interval.cpp, source/index/bintree/Key.cpp,
+	  source/index/bintree/Node.cpp, source/index/bintree/NodeBase.cpp,
+	  source/index/bintree/Root.cpp,
+	  source/index/chain/MonotoneChain.cpp,
+	  source/index/chain/MonotoneChainBuilder.cpp,
+	  source/index/chain/MonotoneChainOverlapAction.cpp,
+	  source/index/chain/MonotoneChainSelectAction.cpp,
+	  source/index/quadtree/DoubleBits.cpp,
+	  source/index/quadtree/IntervalSize.cpp,
+	  source/index/quadtree/Key.cpp, source/index/quadtree/Node.cpp,
+	  source/index/quadtree/NodeBase.cpp,
+	  source/index/quadtree/Quadtree.cpp,
+	  source/index/quadtree/Root.cpp,
+	  source/index/strtree/AbstractSTRtree.cpp,
+	  source/index/strtree/Interval.cpp,
+	  source/index/sweepline/SweepLineEvent.cpp,
+	  source/index/sweepline/SweepLineInterval.cpp, source/inlines.cpp,
+	  source/io/ByteOrderDataInStream.cpp,
+	  source/io/ByteOrderValues.cpp, source/io/ParseException.cpp,
+	  source/io/StringTokenizer.cpp, source/io/Unload.cpp,
+	  source/io/WKBReader.cpp, source/io/WKBWriter.cpp,
+	  source/io/WKTReader.cpp, source/io/WKTWriter.cpp,
+	  source/io/Writer.cpp, source/noding/IntersectionAdder.cpp,
+	  source/noding/IntersectionFinderAdder.cpp,
+	  source/noding/IteratedNoder.cpp, source/noding/MCIndexNoder.cpp,
+	  source/noding/NodingValidator.cpp, source/noding/Octant.cpp,
+	  source/noding/ScaledNoder.cpp, source/noding/SegmentNode.cpp,
+	  source/noding/SegmentNodeList.cpp,
+	  source/noding/SegmentString.cpp, source/noding/SimpleNoder.cpp,
+	  source/noding/snapround/HotPixel.cpp,
+	  source/noding/snapround/MCIndexPointSnapper.cpp,
+	  source/noding/snapround/MCIndexSnapRounder.cpp,
+	  source/noding/snapround/SimpleSnapRounder.cpp,
+	  source/operation/GeometryGraphOperation.cpp,
+	  source/operation/IsSimpleOp.cpp,
+	  source/operation/buffer/BufferOp.cpp,
+	  source/operation/buffer/BufferSubgraph.cpp,
+	  source/operation/buffer/OffsetCurveSetBuilder.cpp,
+	  source/operation/buffer/RightmostEdgeFinder.cpp,
+	  source/operation/buffer/SubgraphDepthLocater.cpp,
+	  source/operation/distance/ConnectedElementLocationFilter.cpp,
+	  source/operation/distance/ConnectedElementPointFilter.cpp,
+	  source/operation/distance/DistanceOp.cpp,
+	  source/operation/distance/GeometryLocation.cpp,
+	  source/operation/linemerge/EdgeString.cpp,
+	  source/operation/linemerge/LineMergeDirectedEdge.cpp,
+	  source/operation/linemerge/LineMergeEdge.cpp,
+	  source/operation/linemerge/LineMergeGraph.cpp,
+	  source/operation/linemerge/LineMerger.cpp,
+	  source/operation/linemerge/LineSequencer.cpp,
+	  source/operation/overlay/EdgeSetNoder.cpp,
+	  source/operation/overlay/ElevationMatrixCell.cpp,
+	  source/operation/overlay/LineBuilder.cpp,
+	  source/operation/overlay/MaximalEdgeRing.cpp,
+	  source/operation/overlay/MinimalEdgeRing.cpp,
+	  source/operation/overlay/OverlayNodeFactory.cpp,
+	  source/operation/overlay/OverlayOp.cpp,
+	  source/operation/overlay/PointBuilder.cpp,
+	  source/operation/overlay/PolygonBuilder.cpp,
+	  source/operation/polygonize/EdgeRing.cpp,
+	  source/operation/polygonize/PolygonizeDirectedEdge.cpp,
+	  source/operation/polygonize/PolygonizeEdge.cpp,
+	  source/operation/polygonize/PolygonizeGraph.cpp,
+	  source/operation/polygonize/Polygonizer.cpp,
+	  source/operation/predicate/RectangleContains.cpp,
+	  source/operation/predicate/RectangleIntersects.cpp,
+	  source/operation/predicate/SegmentIntersectionTester.cpp,
+	  source/operation/relate/EdgeEndBuilder.cpp,
+	  source/operation/relate/EdgeEndBundle.cpp,
+	  source/operation/relate/EdgeEndBundleStar.cpp,
+	  source/operation/relate/RelateComputer.cpp,
+	  source/operation/relate/RelateNode.cpp,
+	  source/operation/relate/RelateNodeFactory.cpp,
+	  source/operation/relate/RelateNodeGraph.cpp,
+	  source/operation/relate/RelateOp.cpp,
+	  source/operation/valid/ConnectedInteriorTester.cpp,
+	  source/operation/valid/ConsistentAreaTester.cpp,
+	  source/operation/valid/IsValidOp.cpp,
+	  source/operation/valid/QuadtreeNestedRingTester.cpp,
+	  source/operation/valid/RepeatedPointTester.cpp,
+	  source/operation/valid/SimpleNestedRingTester.cpp,
+	  source/operation/valid/SweeplineNestedRingTester.cpp,
+	  source/operation/valid/TopologyValidationError.cpp,
+	  source/planargraph/DirectedEdge.cpp,
+	  source/planargraph/DirectedEdgeStar.cpp,
+	  source/planargraph/Edge.cpp, source/planargraph/Node.cpp,
+	  source/planargraph/NodeMap.cpp,
+	  source/planargraph/PlanarGraph.cpp,
+	  source/planargraph/Subgraph.cpp,
+	  source/planargraph/algorithm/ConnectedSubgraphFinder.cpp,
+	  source/precision/CommonBits.cpp,
+	  source/precision/CommonBitsOp.cpp,
+	  source/precision/CommonBitsRemover.cpp,
+	  source/precision/EnhancedPrecisionOp.cpp,
+	  source/precision/GeometrySnapper.cpp,
+	  source/precision/LineStringSnapper.cpp,
+	  source/precision/SimpleGeometryPrecisionReducer.cpp,
+	  source/simplify/DouglasPeuckerSimplifier.cpp,
+	  source/simplify/LineSegmentIndex.cpp,
+	  source/simplify/TaggedLineSegment.cpp,
+	  source/simplify/TaggedLineString.cpp,
+	  source/simplify/TaggedLineStringSimplifier.cpp,
+	  source/simplify/TaggedLinesSimplifier.cpp,
+	  source/simplify/TopologyPreservingSimplifier.cpp,
+	  source/util/Assert.cpp, source/util/AssertionFailedException.cpp,
+	  source/util/GeometricShapeFactory.cpp,
+	  source/util/IllegalArgumentException.cpp,
+	  source/util/Profiler.cpp,
+	  source/util/UnsupportedOperationException.cpp,
+	  source/util/math.cpp, swig/geos.i, swig/python/geos.py,
+	  swig/python/python.i, swig/python/tests/example.py,
+	  swig/python/tests/runtests.py,
+	  swig/python/tests/test_geometry.py, swig/ruby/ruby.i,
+	  tests/bigtest/TestSweepLineSpeed.cpp, tests/bigtest/bigtest.h,
+	  tests/tut/tut.h, tests/tut/tut_reporter.h,
+	  tests/tut/tut_restartable.h,
+	  tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp,
+	  tests/unit/algorithm/PointLocatorTest.cpp,
+	  tests/unit/geom/Geometry/coversTest.cpp,
+	  tests/unit/geom/Geometry/isRectangleTest.cpp,
+	  tests/unit/geom/IntersectionMatrixTest.cpp,
+	  tests/unit/geom/TriangleTest.cpp, tests/unit/geos_unit.cpp,
+	  tests/unit/index/quadtree/DoubleBitsTest.cpp,
+	  tests/unit/io/ByteOrderValuesTest.cpp,
+	  tests/unit/noding/SegmentNodeTest.cpp,
+	  tests/unit/noding/SegmentPointComparatorTest.cpp,
+	  tests/unit/precision/GeometrySnapperTest.cpp,
+	  tests/unit/precision/LineStringSnapperTest.cpp,
+	  tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp,
+	  tests/unit/simplify/TopologyPreservingSimplifierTest.cpp,
+	  tests/unit/util/UniqueCoordinateArrayFilterTest.cpp,
+	  tests/unit/utility.h, tests/xmltester/CTS.cpp,
+	  tests/xmltester/SimpleWKTTester.cpp,
+	  tests/xmltester/Stackwalker.cpp, tests/xmltester/Stackwalker.h,
+	  tests/xmltester/XMLTester.cpp, tests/xmltester/XMLTester.h,
+	  tests/xmltester/markup/MarkupSTL.cpp,
+	  tests/xmltester/markup/MarkupSTL.h, tools/geos-config.in: Set
+	  svn:keyword property for Id keyword expansion.
+2006-09-06 15:50  Sandro Santilli <strk at keybit.net>
+	* [r1819]
+	  source/operation/overlay/FuzzyPointLocator.cpp: Fixed comments
+	  and includes
+2006-09-06 15:33  Sandro Santilli <strk at keybit.net>
+	* [r1818] ChangeLog,
+	  source/operation/overlay/FuzzyPointLocator.cpp: new helper class
+	  for Overlay op validation.
+2006-09-06 15:21  Sandro Santilli <strk at keybit.net>
+	* [r1817] source/headers/geos/geom/Geometry.h: (getBoundary) memory
+	  allocations documented
+2006-09-05 16:18  Sandro Santilli <strk at keybit.net>
+	* [r1816] ChangeLog: updated (last commit log was bogus, refer to
+	  ChangeLog entry)
+2006-09-05 16:07  Sandro Santilli <strk at keybit.net>
+	* [r1815] source/headers/geos/geom/BinaryOp.h,
+	  (OverlayOp::checkObviouslyWrongResult): exceptions messages
+	  rewording
+2006-08-31 23:13  Sandro Santilli <strk at keybit.net>
+	* [r1814] ChangeLog, source/index/quadtree/Root.cpp:
+	  (insertContained): fixed bug reported in
+	  geos-devel/2006-August/002541.html
+2006-08-31 23:07  Sandro Santilli <strk at keybit.net>
+	* [r1813] ChangeLog, configure.in: Reverted last two commits.
+	  Darwin host on buildbot seems to have its own problems...
+2006-08-31 22:28  Sandro Santilli <strk at keybit.net>
+	* [r1812] configure.in: Ops, it was AM_CONFIG_HEADER the old
+	  version - still testing
+2006-08-31 22:21  Sandro Santilli <strk at keybit.net>
+	* [r1811] ChangeLog, configure.in: AC_CONFIG_HEADERS =>
+	  AM_CONFIG_HEADER (to support older automake versions)
+2006-08-04 20:30  hobu
+	* [r1810] capi/geos_c.h.vc: version should be 3.0.0 instead of
+	  3.3.0
+2006-08-04 20:29  hobu
+	* [r1809] source/headers/geos/version.h.vc: bump patch to rc1
+2006-08-04 20:23  hobu
+	* [r1808] source/Makefile.vc: give makefile.vc some love
+2006-08-04 16:40  csavage
+	* [r1807] swig/geos.i, swig/python/geos.py,
+	  swig/python/geos_wrap.cxx, swig/ruby/geos_wrap.cxx: Updated SWIG
+	  bindings to expose the equalsExact and normalize methods.
+2006-08-03 23:43  csavage
+	* [r1806] source/headers/geos/platform.h.in,
+	  source/headers/geos/timeval.h: Two changes needed to include the
+	  correct definitions for compiling geos using MingW/msys on
+	  Windows.
+2006-08-03 22:46  Sandro Santilli <strk at keybit.net>
+	* [r1805] ChangeLog: try to keep text within 80 cols
+2006-08-03 22:24  csavage
+	* [r1804] configure.in: Changed configure.in to use *nix line
+	  feeds.
+2006-08-03 22:17  csavage
+	* [r1803] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_c.h.vc:
+	  Mistakenly used Geometry* in C api headers instead of GEOSGeom.
+2006-08-03 22:13  csavage
+	* [r1802] configure.in: Removed native line endings for
+	  configure.in since CR/LF does not work on Windows under msys.
+2006-08-03 22:02  csavage
+	* [r1801] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in,
+	  capi/geos_c.h.vc: Added equalsExact and normalize to the c api as
+	  discussed on the mailing list
+	  (http://geos.refractions.net/pipermail/geos-devel/2006-July/002452.html).
+2006-08-03 21:34  csavage
+	* [r1800] ChangeLog, swig/python/Makefile.am,
+	  swig/ruby/Makefile.am: Updated build scripts so that
+	  ruby/geos_wrap.cxx, python/geos_wrap.cxx and python/geos.py are
+	  removed by make maintainer-clean but not make clean.
+2006-08-03 16:28  mloskot
+	* [r1799] ChangeLog, tests/unit/geos_unit.cpp: Fixed Bug #90
+2006-08-03 16:18  csavage
+	* [r1798] swig/python/geos.py, swig/python/geos_wrap.cxx,
+	  swig/ruby/geos_wrap.cxx: Added SWIG generated wrapper files for
+	  Ruby and Python
+2006-07-27 06:18  mloskot
+	* [r1797] .: Added svn:ignore property to ignore 'geos-3.0.0rc1'
+	  dir (testing commit access to SVN).
+2006-07-26 19:06  Sandro Santilli <strk at keybit.net>
+	* [r1795] .cvsignore, capi/.cvsignore, doc/.cvsignore,
+	  macros/.cvsignore, source/.cvsignore,
+	  source/algorithm/.cvsignore, source/examples/.cvsignore,
+	  source/geom/.cvsignore, source/geom/util/.cvsignore,
+	  source/geomgraph/.cvsignore, source/geomgraph/index/.cvsignore,
+	  source/headers/.cvsignore, source/headers/geos/.cvsignore,
+	  source/headers/geos/algorithm/.cvsignore,
+	  source/headers/geos/geom/.cvsignore,
+	  source/headers/geos/geom/util/.cvsignore,
+	  source/headers/geos/geomgraph/.cvsignore,
+	  source/headers/geos/geomgraph/index/.cvsignore,
+	  source/headers/geos/index/.cvsignore,
+	  source/headers/geos/index/bintree/.cvsignore,
+	  source/headers/geos/index/chain/.cvsignore,
+	  source/headers/geos/index/quadtree/.cvsignore,
+	  source/headers/geos/index/strtree/.cvsignore,
+	  source/headers/geos/index/sweepline/.cvsignore,
+	  source/headers/geos/io/.cvsignore,
+	  source/headers/geos/noding/.cvsignore,
+	  source/headers/geos/noding/snapround/.cvsignore,
+	  source/headers/geos/operation/.cvsignore,
+	  source/headers/geos/operation/buffer/.cvsignore,
+	  source/headers/geos/operation/distance/.cvsignore,
+	  source/headers/geos/operation/linemerge/.cvsignore,
+	  source/headers/geos/operation/overlay/.cvsignore,
+	  source/headers/geos/operation/polygonize/.cvsignore,
+	  source/headers/geos/operation/predicate/.cvsignore,
+	  source/headers/geos/operation/relate/.cvsignore,
+	  source/headers/geos/operation/valid/.cvsignore,
+	  source/headers/geos/planargraph/.cvsignore,
+	  source/headers/geos/planargraph/algorithm/.cvsignore,
+	  source/headers/geos/precision/.cvsignore,
+	  source/headers/geos/simplify/.cvsignore,
+	  source/headers/geos/util/.cvsignore, source/index/.cvsignore,
+	  source/index/bintree/.cvsignore, source/index/chain/.cvsignore,
+	  source/index/quadtree/.cvsignore,
+	  source/index/strtree/.cvsignore,
+	  source/index/sweepline/.cvsignore, source/io/.cvsignore,
+	  source/noding/.cvsignore, source/noding/snapround/.cvsignore,
+	  source/operation/.cvsignore, source/operation/buffer/.cvsignore,
+	  source/operation/distance/.cvsignore,
+	  source/operation/linemerge/.cvsignore,
+	  source/operation/overlay/.cvsignore,
+	  source/operation/polygonize/.cvsignore,
+	  source/operation/predicate/.cvsignore,
+	  source/operation/relate/.cvsignore,
+	  source/operation/valid/.cvsignore, source/planargraph/.cvsignore,
+	  source/precision/.cvsignore, source/simplify/.cvsignore,
+	  source/util/.cvsignore, swig/.cvsignore, swig/python/.cvsignore,
+	  swig/python/tests/.cvsignore, swig/ruby/.cvsignore,
+	  swig/ruby/test/.cvsignore, tests/.cvsignore,
+	  tests/bigtest/.cvsignore, tests/tut/.cvsignore,
+	  tests/unit/.cvsignore, tests/xmltester/.cvsignore,
+	  tools/.cvsignore: Removed .cvsignore files from repository
+2006-07-26 17:51  Sandro Santilli <strk at keybit.net>
+	* [r1794] ChangeLog, capi/Makefile.am,
+	  tests/xmltester/XMLTester.cpp: * capi/Makefile.am: forced link of
+	  geostest against stdc++ lib
+	  * tests/xmltester/XMLTester.cpp: added <cmath> include (for fabs
+	  use)
+2006-07-26 15:28  Sandro Santilli <strk at keybit.net>
+	* [r1776] ChangeLog, source/headers/geos/geom/BinaryOp.h: Added
+	  geometry snapping heuristic
+2006-07-25 20:45  Sandro Santilli <strk at keybit.net>
+	* [r1775] ChangeLog, autogen.sh: Made autogen.sh errors more
+	  visible
+2006-07-21 19:37  csavage
+	* [r1773] NEWS: Added note about inclusion of version.in.vc. See
+	  http://geos.refractions.net/pipermail/geos-devel/2006-July/002463.html
+	  for more info.
+2006-07-21 17:59  Sandro Santilli <strk at keybit.net>
+	* [r1772] ChangeLog, tests/unit/Makefile.am,
+	  tests/unit/precision/GeometrySnapperTest.cpp: Added test for
+	  GeometrySnapper
+	* [r1771] source/precision/LineStringSnapper.cpp: Fixed
+	  preprocessor directive use
+2006-07-21 17:09  Sandro Santilli <strk at keybit.net>
+	* [r1770] ChangeLog,
+	  source/headers/geos/precision/Makefile.am,
+	  source/precision/Makefile.am, tests/unit/Makefile.am,
+	  tests/unit/precision,
+	  tests/unit/precision/LineStringSnapperTest.cpp: Added new
+	  precision::LineStringSnapper class + test
+	  and precision::GeometrySnapper (w/out test)
+2006-07-21 17:05  Sandro Santilli <strk at keybit.net>
+	* [r1769] ChangeLog, source/headers/geos/geom/CoordinateList.h:
+	  added operator<< for CoordinateList class
+2006-07-21 17:00  Sandro Santilli <strk at keybit.net>
+	* [r1768] ChangeLog, tests/unit/geom/LineSegmentTest.cpp: Added
+	  another distance() test
+2006-07-21 16:45  mloskot
+	* [r1767] ChangeLog, source/headers/geos/geom.h,
+	  source/headers/geos/io.h: Wrapped FIXME message with #warning
+	  directive to shout about potential headers removal in future.
+2006-07-21 14:53  Sandro Santilli <strk at keybit.net>
+	* [r1766] ChangeLog, source/headers/geos/geom/CoordinateList.h,
+	  source/headers/geos/geom/Makefile.am, tests/unit/Makefile.am,
+	  tests/unit/geom/CoordinateListTest.cpp: CoordinateList class
+	  re-introduced, for list-based ops
+	  (not strictly mapped to JTS version, not yet at least)
+2006-07-21 14:49  Sandro Santilli <strk at keybit.net>
+	* [r1765] source/headers/geos/geom/LineSegment.h: Fixed typo in
+	  comment
+2006-07-21 08:33  Sandro Santilli <strk at keybit.net>
+	* [r1764] swig/ruby/test/Makefile.am: Removed blank space after
+	  backslash (automake complained)
+2006-07-19 02:43  csavage
+	* [r1763] source/headers/geos/Makefile.am: Added veresion.h.vc as
+	  EXTRA_DIST to ensure it is packaged when doing make dist.
+2006-07-15 19:36  csavage
+	* [r1762] configure.in: Removed python test/cases directory (tests
+	  are now just in tests directory).
+2006-07-13 08:02  csavage
+	* [r1761] ChangeLog: Updated ChangeLog to note additional SWIG
+	  tests and integration with the GEOS build system.
+2006-07-13 07:49  csavage
+	* [r1760] capi/geos_c.h.vc: Updated version number to
+	  3.0.0rc1-CAPI-1.1.1 to match the autoconf generated files.
+2006-07-13 07:38  csavage
+	* [r1759] swig/ruby/test/Makefile.am: Fixed spelling mistake in
+	  test task.
+2006-07-13 07:36  csavage
+	* [r1758] swig/Makefile.am: Removed dependency on README.txt since
+	  it has been removed.
+2006-07-13 07:35  csavage
+	* [r1757] swig/ruby/test/test_buffer.rb: New tests for the buffer
+	  operation.
+2006-07-13 07:29  csavage
+	* [r1756] configure.in: Added SWIG Python and Ruby bindings back
+	  into the main GEOS build system.
+2006-07-13 07:27  csavage
+	* [r1755] swig/python/tests/Makefile.am,
+	  swig/ruby/test/Makefile.am: Updated extra_dist for test
+	  directories.
+2006-07-13 07:20  csavage
+	* [r1754] swig/python/tests/Makefile.am: Remove the dependency on
+	  the cases subdirectory which is no longer needed.
+2006-07-13 07:19  csavage
+	* [r1753] swig/python/tests/runtests.py: Updated test suite to use
+	  the correct tests.
+2006-07-13 07:16  csavage
+	* [r1752] swig/python/tests/cases: Removed old tests cases which
+	  are no longer valid (worked using the C++ api).
+2006-07-13 07:14  csavage
+	* [r1751] swig/python/tests/test_geometry.py: New Python test case
+	  to ensure creating coordinate sequences and geometries works
+	  correctly.
+	* [r1750] swig/README.txt, swig/python/Makefile.am,
+	  swig/python/README.txt, swig/ruby/Makefile.am,
+	  swig/ruby/README.txt: Removed README.txt files which are no
+	  longer applicable now that the SWIG bindings have been
+	  intergrated into the GEOS build system.
+2006-07-13 07:13  csavage
+	* [r1749] swig/ruby/test/test_geometry.rb: Renamed test class.
+2006-07-13 07:09  csavage
+	* [r1748] swig/python/Makefile.am: Removed old, unused code.
+	* [r1747] swig/python/python.i: Added tyepmap to support creating
+	  polygons with holes.
+2006-07-13 07:08  csavage
+	* [r1746] swig/geos.i: Added default value for quadsegs parmeter in
+	  buffer operation.
+2006-07-13 04:47  csavage
+	* [r1745] swig/python/tests/example.py: Manually moved from parent
+	  directory.
+2006-07-13 04:46  csavage
+	* [r1744] swig/python/Makefile.am: Updated EXTRA_DIST to include
+	  python.i and geos.pth
+	* [r1743] swig/python/example.py: Moved file to tests subdirectory.
+2006-07-13 04:45  csavage
+	* [r1742] swig/python/setup.py: Installation is now done by
+	  autoconf macros instead of setup.py
+2006-07-13 04:39  csavage
+	* [r1741] swig/geos.i, swig/python/python.i, swig/ruby/ruby.i:
+	  Cleaned up ruby.i, added licenxe to python.i, commented back in
+	  python.i into geos.i.
+2006-07-13 04:09  csavage
+	* [r1740] swig/ruby/test/test_helper.rb: Added code to read xml
+	  test cases.
+2006-07-13 04:08  csavage
+	* [r1739] swig/geos.i: Added exception handling for results that
+	  return geometries. Added normalize and equalsExact, but for the
+	  moment they are commented out.
+2006-07-13 03:59  csavage
+	* [r1738] tests/xmltester/XMLTester.cpp: Changes to compile on VC++
+	  - fully qualified polygon name. Should also work on MingW, will
+	  test next.
+2006-07-12 23:17  csavage
+	* [r1737] swig/ruby/test/geos_tests.rb: Disabled
+	  test_combinations.rb for the moment since it fails.
+2006-07-12 23:16  csavage
+	* [r1736] swig/geos.i: Fixed serious bug in geom_to_hex and
+	  geom_to_wkb type maps. Was using temporary variable instead of
+	  passed in variable.
+2006-07-12 22:55  csavage
+	* [r1735] capi/geos_c.h.vc: Switched GeosBytesOrder to int in api
+	  signatures.
+2006-07-12 22:11  csavage
+	* [r1734] swig/geos.i: A number of changes to fix warning generated
+	  by gcc and to make sure the bindings compile for Python.
+	* [r1733] swig/python/Makefile.am: Updated Python SWIG makefile to
+	  build with the c api.
+2006-07-12 22:10  csavage
+	* [r1732] swig/ruby/ruby.i: Minor change to fix gcc warning.
+	* [r1731] swig/ruby/Makefile.am: Updated Ruby SWIG makefile to
+2006-07-12 21:03  csavage
+	* [r1730] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_c.h.vc:
+	  Fixed an error in the way GEOSByteOrder was declared. It is now
+	  an enum in geos_c.h
+2006-07-12 19:10  csavage
+	* [r1729] swig/geos.i: Added %rename directive so that GeomUnion is
+	  exposed as union is SWIG languages.
+2006-07-12 19:08  csavage
+	* [r1728] swig/ruby/test/geos_tests.rb,
+	  swig/ruby/test/test_combinations.rb,
+	  swig/ruby/test/test_operations.rb: Updated tests for combinatins
+	  (union, intersection, etc.) and operaptions (buffer, centroid,
+	  etc.).
+2006-07-12 19:07  csavage
+	* [r1727] swig/ruby/test/test_simple.rb: These tests are no longer
+	  needed.
+2006-07-12 17:51  csavage
+	* [r1726] swig/ruby/test/geos_tests.rb,
+	  swig/ruby/test/test_helper.rb, swig/ruby/test/test_relations.rb:
+	  Ported old tests for relations, such as intersects, touches,
+	  etc., to new swig bindings.
+2006-07-12 08:30  csavage
+	* [r1725] swig/ruby/ruby.i: Added type map needed to create
+	  polygons with holes. Unfortunately, this is Ruby specific. It
+	  needs to be ported to Python next.
+2006-07-12 08:29  csavage
+	* [r1724] swig/geos.i: Removed wrapper classes and replace them
+	  with SWIG "fake" classes. This makes the interface cleaner, and
+	  makes memory management much easier. Also added area, dimension,
+	  length, getExteriorRing, getInteriorRingN methods.
+2006-07-12 08:27  csavage
+	* [r1723] swig/ruby/test/test_srid.rb: Added test to read from wkb
+	  geometry - currently fails, needs more investigation.
+	* [r1722] swig/ruby/test/test_io.rb: Added tests for invalid
+	  geometries.
+	* [r1721] swig/ruby/test/geos_tests.rb: Updated ruby test suite.
+2006-07-12 08:24  csavage
+	* [r1720] swig/ruby/test/test_geometry.rb: New tests for area,
+	  length, distance.
+2006-07-12 05:21  csavage
+	* [r1719] swig/ruby/test/test_coordinate_sequence.rb,
+	  swig/ruby/test/test_version.rb: Converted line feeds to Unix
+	  style.
+	* [r1718] swig/ruby/test/test_geometry.rb: New tests for creating
+	  geometries and calling various functions such as numGeometries,
+	  isValid, etc.
+2006-07-12 05:20  csavage
+	* [r1717] swig/ruby/test/test_srid.rb: Tests for srid handling.
+	* [r1716] swig/ruby/test/test_io.rb: Merged tests from
+	  test_wkb_reader.rb
+2006-07-12 05:18  csavage
+	* [r1715] swig/ruby/test/test_wkb_reader.rb: Merging into
+	  test_io.rb
+2006-07-12 04:46  csavage
+	* [r1714] swig/ruby/test/test_version.rb: Tests to verify returned
+	  version numbers from C api.
+2006-07-11 18:48  csavage
+	* [r1713] swig/geos.i: Fixes for coordinate sequences. Fixed bug in
+	  range checking, chaned clone to be a method instead of copy
+	  constructor, marked clone as creating a new object.
+2006-07-11 18:44  csavage
+	* [r1712] swig/ruby/test/test_coordinate_sequence.rb: Tests for
+	  SWIG coordinate sequence class.
+2006-07-11 09:07  csavage
+	* [r1711] capi/geos_c.h.in, capi/geos_c.h.vc: Added reference to
+	  new enum called GEOSByteOrders. The enum has two values,
+	  GEOS_WKB_NDR and GEOS_WKB_XDR which signify big endian and little
+	  endian byte orders.
+2006-07-11 09:05  csavage
+	* [r1710] capi/geos_c.h.in, capi/geos_c.h.vc: Added 5 methods to
+	  the C API as documented in the changelong. The new methods are
+	  read/write WKB Hex values, read/write WKB byte order and read wkb
+	  output dimensions.
+2006-07-11 08:55  csavage
+	* [r1709] swig/ruby/test/test_wkb_reader.rb: Test cases for reading
+	  and writing geometries to WKT, WKB and hex encoded WKB formats
+	  via the SWIG bindings.
+2006-07-11 08:54  csavage
+	* [r1708] capi/geos_c.h.vc: Updated visual studio header file to
+	  match geos_c.h.in
+2006-07-11 08:53  csavage
+	* [r1707] capi/geos_c.cpp: Added 5 methods to the C API as
+	  documented in the changelong. The new methods are read/write WKB
+	  Hex values, read/write WKB byte order and read wkb output
+	  dimensions.
+2006-07-11 08:52  csavage
+	* [r1706] ChangeLog: Noted additions to the C API and porting of
+	  SWIG to use the C api.
+2006-07-11 08:44  csavage
+	* [r1705] swig/geos.i, swig/ruby/ruby.i: Ported SWIG bindings to
+	  use c-api.
+2006-07-10 22:29  Sandro Santilli <strk at keybit.net>
+	* [r1704] tests/tut, tests/tut/.cvsignore: Added .cvsignore file
+2006-07-10 21:51  Sandro Santilli <strk at keybit.net>
+	* [r1703] ChangeLog, capi/geos_c.cpp: don't use dynamic strings as
+	  format arg the formatted message callbacks.
+2006-07-10 10:16  Sandro Santilli <strk at keybit.net>
+	* [r1702] ChangeLog,
+	  source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h:
+	  changed vector<bool> to vector<short int> (see bug#101)
+2006-07-09 03:37  mloskot
+	* [r1701] tests/xmltester, tests/xmltester/.cvsignore: Added
+	  'testrunner' pattern to tests/xmltester/.cvsignore.
+2006-07-09 03:21  mloskot
+	* [r1700] ., .cvsignore: Added 'testrunner' to .cvsignore patterns.
+	* [r1699] ChangeLog: Updated ChangeLog with details about new unit
+	  tests.
+2006-07-09 03:16  mloskot
+	* [r1698] tests/unit/Makefile.am: Added new tests to
+	  tests/unit/Makefile.am.
+2006-07-09 03:15  mloskot
+	* [r1697] tests/unit/noding/SegmentNodeTest.cpp,
+	  tests/unit/noding/SegmentStringTest.cpp: Added new tests cases to
+	  tests/unit/noding. Removed zero-to-pointer casts.
+2006-07-09 00:24  Sandro Santilli <strk at keybit.net>
+	* [r1696] tests/xmltester/Makefile.am: Added testrunner to
+	  CLEANFILES. make distcheck now succeeds.
+2006-07-08 00:33  Sandro Santilli <strk at keybit.net>
+	* [r1693] ChangeLog, configure.in, source/geom/Geometry.cpp,
+	  source/geom/GeometryFactory.cpp, source/geomgraph/EdgeRing.cpp,
+	  source/headers/geos/platform.h.in: * configure.in: incremented
+	  CAPI minor version, to avoid falling behind any future version
+	  from the 2.2. branch.
+	  * source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
+	  source/headers/geos/geomgraph/EdgeRing.h:
+	  updated doxygen comments (sync with JTS head).
+	  * source/headers/geos/platform.h.in: include <inttypes.h>
+	  rather then <stdint.h>
+2006-07-07 20:02  mloskot
+	* [r1691] ChangeLog: Updated ChangeLog with version comparison fix
+	  in GEOS_UNIT.
+2006-07-07 20:00  mloskot
+	* [r1690] macros/geos.m4: Fixed versions comparison in the
+	  GEOS_UNIT macro.
+2006-07-07 19:33  Sandro Santilli <strk at keybit.net>
+	* [r1689] ChangeLog, acsite.m4, configure.in: * acsite.m4: include
+	  <inttypes.h> rather then <stdint.h>
+	  (the latter is not available on Solaris 9)
+	  * configure.in: make sure CFLAGS is set before compiling
+	  using the 64bit integer detection macro.
+2006-07-06 16:39  mloskot
+	* [r1688] ChangeLog, macros/geos.m4: Fixed version query regexp
+	  with escaped dots. Removed -lpq from GEOS_LIBS flags.
+2006-07-05 23:27  mloskot
+	* [r1687] ChangeLog, macros/geos.m4: Removed redundant -L and -I
+	  from GEOS_LIBS and GEOS_CFLAGS.
+2006-07-05 23:10  mloskot
+	* [r1686] ChangeLog, macros/geos.m4: Fixed GEOS_INIT to support
+	  full paths to geos-config passed to --with-geos. Fixed version
+	  decoding.
+2006-07-05 22:54  Sandro Santilli <strk at keybit.net>
+	* [r1685] ChangeLog, tests/unit/Makefile.am: distribute utility.h
+2006-07-05 22:19  Sandro Santilli <strk at keybit.net>
+	* [r1684] ChangeLog, configure.in, tests/Makefile.am,
+	  tests/tut/Makefile.am: distribute the TUT framework.
+2006-07-05 21:47  Sandro Santilli <strk at keybit.net>
+	* [r1683] ChangeLog, tests/xmltester/Makefile.am: Distribute XML
+	  tests and tester.
+2006-07-05 21:18  Sandro Santilli <strk at keybit.net>
+	* [r1682] ChangeLog, source/operation/valid/Makefile.am: Fixed
+	  missing SweeplineNestedRingTester.cpp file.
+2006-07-05 20:52  Sandro Santilli <strk at keybit.net>
+	* [r1681] ChangeLog,
+	  source/headers/geos/operation/linemerge/Makefile.am: Fixed
+	  missing backslash, dropping headers from distribution.
+2006-07-05 20:20  Sandro Santilli <strk at keybit.net>
+	* [r1680] TODO: updated
+2006-07-05 20:19  Sandro Santilli <strk at keybit.net>
+	* [r1679] ChangeLog,
+	  source/operation/overlay/OverlayOp.cpp: added checks for
+	  obviously wrong result of difference and intersection ops
+2006-06-27 15:59  Sandro Santilli <strk at keybit.net>
+	* [r1677] ChangeLog, source/algorithm/HCoordinate.cpp: *
+	  source/algorithm/HCoordinate.cpp: added support for MingW -ansi
+	  builds.
+2006-06-27 15:26  Sandro Santilli <strk at keybit.net>
+	* [r1676] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: *
+	  capi/geos_c.cpp: fixed forward declaration of
+	  GEOSCoordSeq_getOrdinate.
+	  * capi/geos_c.h.in: renamed GEOSGeomTypeId enum to GEOSGeomTypes,
+	  to make VC++ 2005 happy.
+2006-06-19 23:33  Sandro Santilli <strk at keybit.net>
+	* [r1675] ChangeLog, source/headers/geos/geom/CoordinateFilter.h,
+	  source/noding/ScaledNoder.cpp: Don't *require* CoordinateFilters
+	  to define both read-only and read-write methods.
+2006-06-19 22:52  Sandro Santilli <strk at keybit.net>
+	* [r1674] ChangeLog, source/geom/Polygon.cpp: optimized loops
+2006-06-19 21:20  Sandro Santilli <strk at keybit.net>
+	* [r1673] ChangeLog, source/geom/util/GeometryTransformer.cpp,
+	  source/headers/geos/geom/util/GeometryTransformer.h: updated port
+	  info
+2006-06-19 21:17  Sandro Santilli <strk at keybit.net>
+	* [r1672] ChangeLog, source/geom/GeometryFactory.cpp,
+	  source/headers/geos/geom/GeometryFactory.inl: port info and
+	  doxygen dox.
+2006-06-19 20:48  Sandro Santilli <strk at keybit.net>
+	* [r1671] ChangeLog, tests/xmltester/XMLTester.cpp: parseCase():
+	  make sure to exit the <case> tag before returning
+2006-06-14 19:27  Sandro Santilli <strk at keybit.net>
+	* [r1670] ChangeLog, source/geom/Coordinate.cpp,
+	  source/headers/geos/geom/Coordinate.inl: Let the compiler
+	  synthetize copy ctor and assignment op for Coordinate class to
+	  obtain better numerical stability.
+2006-06-14 19:19  Sandro Santilli <strk at keybit.net>
+	* [r1669] ChangeLog, tests/xmltester/XMLTester.cpp: Added support
+	  for "AreaTest" operations.
+2006-06-14 19:17  Sandro Santilli <strk at keybit.net>
+	* [r1668] ChangeLog, source/operation/overlay/PolygonBuilder.cpp:
+	  Fixed bug in findShell() needlessly erasing vector elements
+2006-06-14 15:38  Sandro Santilli <strk at keybit.net>
+	* [r1667] source/operation/overlay/OverlayOp.cpp: Fixed
+	  just-introduced bug
+2006-06-14 15:03  Sandro Santilli <strk at keybit.net>
+	* [r1666] ChangeLog, source/operation/overlay/OverlayOp.cpp: *
+	  source/operation/overlay/OverlayOp.cpp: use NodeMap::container
+	  and related typedefs, removed (int) casts, optimized loops.
+2006-06-14 14:32  Sandro Santilli <strk at keybit.net>
+	* [r1665] ChangeLog, source/geomgraph/EdgeEnd.cpp,
+	  source/headers/geos/geomgraph/EdgeEnd.h: EdgeEnd::getEdge() made
+	  non-virtual and inlined.
+2006-06-14 13:59  Sandro Santilli <strk at keybit.net>
+	* [r1664] ChangeLog, source/operation/overlay/PolygonBuilder.cpp:
+	  Fixed bug in PolygonBuilder::placePolygonHoles, performance
+	  improved as a side effect.
+2006-06-13 23:26  Sandro Santilli <strk at keybit.net>
+	* [r1663] ChangeLog,
+	  source/operation/overlay/PolygonBuilder.cpp: cleanups
+2006-06-13 22:50  Sandro Santilli <strk at keybit.net>
+	* [r1662] ChangeLog, source/headers/geos/io/WKTReader.inl: *
+	  source/headers/geos/io/WKTReader.inl: added missing include for
+	  GEOS_DEBUG set case, use stderr for debugging output.
+2006-06-13 22:19  Sandro Santilli <strk at keybit.net>
+	* [r1661] ChangeLog, source/operation/overlay/LineBuilder.cpp:
+	  fixed unused parameter warning
+2006-06-13 22:00  Sandro Santilli <strk at keybit.net>
+	* [r1660] ChangeLog, source/headers/geos/geomgraph/GeometryGraph.h:
+	  Changed GeometryGraph::lineEdgeMap set comparison function to be
+	  pointer-based. Should be safe and much faster. Available tests
+	  all succeed.
+2006-06-13 21:42  Sandro Santilli <strk at keybit.net>
+	* [r1659] source/operation/overlay/OverlayOp.cpp: trimmed cvs log,
+	  cleanups
+2006-06-13 21:40  Sandro Santilli <strk at keybit.net>
+	* [r1658] source/geomgraph/GeometryGraph.cpp: Cleanups and some
+	  more debugging lines
+2006-06-13 21:38  Sandro Santilli <strk at keybit.net>
+	* [r1657] ChangeLog, source/geom/Geometry.cpp: Added self
+	  comparison check in Geometry::compareTo().
+2006-06-13 19:16  Sandro Santilli <strk at keybit.net>
+	* [r1656] ChangeLog: fixed mis-assigned commit
+2006-06-12 17:18  Sandro Santilli <strk at keybit.net>
+	* [r1655] ChangeLog, source/simplify/LineSegmentIndex.cpp:
+	  LineSegmentIndex: explicitly initialized parent class in
+	  constructors.
+2006-06-12 17:15  Sandro Santilli <strk at keybit.net>
+	* [r1654] ChangeLog, source/headers/geos/index/quadtree/Root.h,
+	  source/headers/geos/operation/polygonize/Polygonizer.h: Removed
+	  unused parameters warning
+2006-06-12 17:14  Sandro Santilli <strk at keybit.net>
+	* [r1653] ChangeLog, source/headers/geos/geom/GeometryFilter.h:
+	  added assert(0) version of filter_ro() and filter_rw() to allow
+	  implementations to only defined the required one.
+2006-06-12 16:59  Sandro Santilli <strk at keybit.net>
+	* [r1652] tests/bigtest/TestSweepLineSpeed.cpp,
+	  tests/xmltester/SimpleWKTTester.cpp: Removed unused parameter
+	  warnings
+2006-06-12 16:57  Sandro Santilli <strk at keybit.net>
+	* [r1651] source/headers/geos/planargraph/Node.h: Added note about
+	  ownership of return from getEdgesBetween()
+2006-06-12 16:55  Sandro Santilli <strk at keybit.net>
+	* [r1650] ChangeLog, source/headers/geos/io/WKTWriter.h,
+	  source/io/WKTWriter.cpp: fixed compiler warnings, fixed some
+	  methods to omit unused parameters.
+2006-06-12 16:51  Sandro Santilli <strk at keybit.net>
+	* [r1649] ChangeLog, source/geom/CoordinateSequence.cpp,
+	  source/headers/geos/geom/CoordinateSequence.h,
+	  tests/unit/geom/CoordinateArraySequenceTest.cpp: Added equality
+	  and inequality operators and tests
+2006-06-12 16:36  Sandro Santilli <strk at keybit.net>
+	* [r1648] ChangeLog, source/geom/CoordinateSequence.cpp,
+	  source/headers/geos/geom/CoordinateSequence.h: indentation, notes
+	  about things to be fixed.
+2006-06-12 15:47  Sandro Santilli <strk at keybit.net>
+	* [r1647] ChangeLog, source/planargraph/Node.cpp: implemented
+	  missing getEdgesBetween() method (untested).
+2006-06-12 15:46  Sandro Santilli <strk at keybit.net>
+	* [r1646] source/headers/geos/planargraph/DirectedEdge.h,
+	  source/planargraph/DirectedEdge.cpp: provided a memory friendly
+	  version of toEdges() method.
+2006-06-12 15:07  Sandro Santilli <strk at keybit.net>
+	* [r1645] ChangeLog, source/geom/CoordinateArraySequence.cpp:
+	  explicitly invoked CoordinateSequence (copy) ctor - suggested by
+	  GCC warning.
+2006-06-12 15:06  Sandro Santilli <strk at keybit.net>
+	* [r1644] source/headers/geos/geom/CoordinateSequence.h: Added
+	  default ctor and copy ctor (protected)
+2006-06-12 13:57  Sandro Santilli <strk at keybit.net>
+	* [r1643] ChangeLog, acsite.m4, configure.in,
+	  source/headers/geos/platform.h.in: Check for int64_t type for
+	  int64 typedef.
+2006-06-12 11:29  Sandro Santilli <strk at keybit.net>
+	* [r1642] ChangeLog, source/algorithm/SimplePointInAreaLocator.cpp,
+	  source/geomgraph/PlanarGraph.cpp,
+	  source/index/sweepline/SweepLineIndex.cpp,
+	  source/operation/buffer/BufferBuilder.cpp,
+	  source/simplify/DouglasPeuckerLineSimplifier.cpp,
+	  source/simplify/TaggedLineString.cpp, source/util/Profiler.cpp:
+	  unsigned int => size_t
+2006-06-12 10:49  Sandro Santilli <strk at keybit.net>
+	* [r1641] ChangeLog, source/algorithm/ConvexHull.cpp,
+	  source/algorithm/PointLocator.cpp, source/geom/Envelope.cpp,
+	  source/headers/geos/index/strtree/SIRtree.h,
+	  source/headers/geos/index/strtree/STRtree.h,
+	  source/index/strtree/SIRtree.cpp,
+	  source/index/strtree/STRtree.cpp,
+	  source/planargraph/PlanarGraph.cpp: unsigned int => size_t
+2006-06-12 10:39  Sandro Santilli <strk at keybit.net>
+	* [r1640] ChangeLog, tests/xmltester/XMLTester.cpp: don't print
+	  test file precision model if verbosity level < 2.
+2006-06-12 10:10  Sandro Santilli <strk at keybit.net>
+	* [r1639] ChangeLog, NEWS, capi/geos_c.h.in,
+	  source/algorithm/CGAlgorithms.cpp,
+	  source/geom/CoordinateArraySequence.cpp,
+	  source/geom/CoordinateSequence.cpp, source/geom/Geometry.cpp,
+	  source/geom/GeometryCollection.cpp,
+	  source/geom/IntersectionMatrix.cpp, source/geom/LineString.cpp,
+	  source/geom/LinearRing.cpp, source/geom/MultiLineString.cpp,
+	  source/geom/MultiPolygon.cpp, source/geom/Polygon.cpp,
+	  source/headers/geos/geom/CoordinateArraySequence.h,
+	  source/headers/geos/geom/Geometry.h,
+	  source/headers/geos/util/UniqueCoordinateArrayFilter.h: Fixed
+	  getGeometryN() to take size_t rather then int, changed unsigned
+	  int parameters to size_t.
+2006-06-09 08:28  Sandro Santilli <strk at keybit.net>
+	* [r1638] tests/xmltester/SimpleWKTTester.cpp: Removed compiler
+	  warning
+2006-06-09 08:17  Sandro Santilli <strk at keybit.net>
+	* [r1637] ChangeLog, tests/unit/noding/SegmentStringTest.cpp:
+	  removed signed/unsigned comparison warnings.
+2006-06-09 08:09  Sandro Santilli <strk at keybit.net>
+	* [r1636] ChangeLog, tests/unit/geom/LinearRingTest.cpp,
+	  tests/unit/geom/PolygonTest.cpp: removed signed/unsigned
+	  comparison warnings.
+2006-06-09 08:02  Sandro Santilli <strk at keybit.net>
+	* [r1635] ChangeLog, tests/unit/geom/LineStringTest.cpp: Fixed
+	  signed/unsigned comparison tests
+2006-06-09 07:42  Sandro Santilli <strk at keybit.net>
+	* [r1634] ChangeLog, source/geomgraph/GeometryGraph.cpp,
+	  source/operation/valid/RepeatedPointTester.cpp: *
+	  source/operation/valid/RepeatedPointTester.cpp: Fixed warning
+	  after Polygon ring accessor methods changed to work with size_t.
+	  Small optimizations in loops.
+2006-06-09 06:41  Sandro Santilli <strk at keybit.net>
+	* [r1633] ChangeLog: Added missing log for mloskot change
+2006-06-08 18:50  mloskot
+	* [r1632] tests/unit/geom/DimensionTest.cpp: Fixed no-effect
+	  warning in test<1> from DimensionTest.cpp.
+2006-06-08 18:18  Sandro Santilli <strk at keybit.net>
+	* [r1631] ChangeLog, tests/unit/geom/GeometryFactoryTest.cpp: *
+	  tests/unit/geom/GeometryFactoryTest.cpp: fixed compiler warnings
+	  about signed/unsigned comparisons.
+2006-06-08 17:58  Sandro Santilli <strk at keybit.net>
+	* [r1630] ChangeLog, NEWS, source/algorithm/CentroidArea.cpp,
+	  source/geom/Polygon.cpp, source/geom/util/GeometryEditor.cpp,
+	  source/headers/geos/geom/Polygon.h, source/io/WKTWriter.cpp:
+	  Polygon::getNumInteriorRing() return size_t,
+	  Polygon::interiorRingN() takes size_t.
+2006-06-08 17:46  Sandro Santilli <strk at keybit.net>
+	* [r1629] ChangeLog,
+	  tests/unit/geom/CoordinateArraySequenceTest.cpp: *
+	  tests/unit/geom/CoordinateArraySequenceTest.cpp: fix
+	  signed/unsigned comparison warning.
+2006-06-08 15:55  Sandro Santilli <strk at keybit.net>
+	* [r1628] ChangeLog, tests/xmltester/markup/MarkupSTL.cpp: *
+	  tests/xmltester/markup/MarkupSTL.cpp: removed use of
+	  allocator<char>, which brings in some incompatibilities with
+	  libstdc++ 6.0.7 (gcc 4.0.2).
+2006-06-08 13:19  Sandro Santilli <strk at keybit.net>
+	* [r1627] configure.in: Commented out ruby and python detection
+2006-06-08 12:58  Sandro Santilli <strk at keybit.net>
+	* [r1626] tests/xmltester/Makefile.am,
+	  tests/xmltester/testrunner.sh: Fixed xml testrunner rule
+2006-06-08 12:16  Sandro Santilli <strk at keybit.net>
+	* [r1625] ChangeLog, tests/xmltester/Makefile.am,
+	  tests/xmltester/testrunner.sh: added XML tests run to the 'make
+	  check' rule.
+2006-06-08 11:20  Sandro Santilli <strk at keybit.net>
+	* [r1624] ChangeLog,
+	  source/headers/geos/index/sweepline/SweepLineOverlapAction.h:
+	  Added missing virtual destructor to abstract classes.
+2006-06-07 20:04  Sandro Santilli <strk at keybit.net>
+	* [r1623] ChangeLog, configure.in: * configure.in: enforce -Wall
+	  -ansi -pedantic -Wno-long-long to C and CXX flags.
+2006-06-07 19:45  Sandro Santilli <strk at keybit.net>
+	* [r1622] swig/ruby/test/Makefile.am: Renamed (reserved) TESTS
+	  variable to RUBY_TESTS
+2006-06-07 19:26  Sandro Santilli <strk at keybit.net>
+	* [r1621] Makefile.am: Fixed SUBDIRS order, and added a NOTE about
+	  maintaining it.
+2006-06-07 17:03  Sandro Santilli <strk at keybit.net>
+	* [r1620] ChangeLog, Makefile.am, configure.in,
+	  swig/python/Makefile.am, swig/ruby/Makefile.am,
+	  swig/ruby/test/Makefile.am: * Makefile.am, configure.in,
+	  swig/ruby/test/Makefile.am: swig removed from automatic build
+	  process.
+	  * configure.in: removed check for boost availability.
+2006-06-07 16:07  Sandro Santilli <strk at keybit.net>
+	* [r1619] configure.in: Set release version to 3.0.0rc1
+2006-06-07 14:10  mloskot
+	* [r1618] ChangeLog, tests/unit/Makefile.am: Update ChangeLog with
+	  info about new test case isPointInRingTest.cpp.
+2006-06-07 14:06  mloskot
+	* [r1617] tests/unit/algorithm/CGAlgorithms/isPointInRing.cpp,
+	  tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp: Renamed
+	  file isPointInRing.cpp to isPointInRingTest.cpp to follow GEOS
+	  Unit Test convention.
+2006-06-07 13:52  mloskot
+	* [r1616] tests/unit/Makefile.am,
+	  tests/unit/algorithm/CGAlgorithms,
+	  tests/unit/algorithm/CGAlgorithms/isPointInRing.cpp: Added new
+	  test: CGAlgorithms/isPointInRing.cpp.
+2006-06-07 13:10  Sandro Santilli <strk at keybit.net>
+	* [r1615] ChangeLog, source/headers/geos/geom.h: Removed Triangle.h
+	  include from geom.h
+2006-06-07 13:08  Sandro Santilli <strk at keybit.net>
+	* [r1614] ChangeLog, source/headers/geos/geom/Makefile.am: *
+	  source/headers/geos/geom/Makefile.am: removed Triangle.h from
+	  installed header set.
+2006-06-05 19:42  Sandro Santilli <strk at keybit.net>
+	* [r1613] ChangeLog, source/headers/geos/Makefile.am,
+	  source/headers/geos/algorithm/Makefile.am,
+	  source/headers/geos/geom/util/Makefile.am,
+	  source/headers/geos/geomgraph/Makefile.am,
+	  source/headers/geos/geomgraph/index/Makefile.am,
+	  source/headers/geos/index/Makefile.am,
+	  source/headers/geos/index/bintree/Makefile.am,
+	  source/headers/geos/index/chain/Makefile.am,
+	  source/headers/geos/index/quadtree/Makefile.am,
+	  source/headers/geos/index/strtree/Makefile.am,
+	  source/headers/geos/index/sweepline/Makefile.am,
+	  source/headers/geos/io/Makefile.am,
+	  source/headers/geos/noding/Makefile.am,
+	  source/headers/geos/noding/snapround/Makefile.am,
+	  source/headers/geos/opDistance.h,
+	  source/headers/geos/operation/Makefile.am,
+	  source/headers/geos/operation/buffer/Makefile.am,
+	  source/headers/geos/operation/distance/Makefile.am,
+	  source/headers/geos/operation/linemerge/Makefile.am,
+	  source/headers/geos/operation/polygonize/Makefile.am,
+	  source/headers/geos/operation/predicate/Makefile.am,
+	  source/headers/geos/operation/relate/Makefile.am,
+	  source/headers/geos/operation/valid/Makefile.am,
+	  source/headers/geos/planargraph/Makefile.am,
+	  source/headers/geos/planargraph/algorithm/Makefile.am,
+	  source/headers/geos/util.h, source/headers/geos/util/Makefile.am:
+	  Fixed noinst_geos_HEADERS => noinst_HEADERS.
+2006-06-05 15:36  Sandro Santilli <strk at keybit.net>
+	* [r1612] ChangeLog, NEWS, capi/geos_c.cpp,
+	  source/geom/Geometry.cpp, source/headers/geos/noding.h,
+	  tests/xmltester/XMLTester.cpp: Given OverlayOp funx code enum a
+	  name and renamed values to have a lowercase prefix. Drop all of
+	  noding headers from installed header set.
+2006-06-03 22:31  hobu
+	* [r1611] source/Makefile.vc: update to track latest removals
+2006-06-03 22:29  hobu
+	* [r1610] source/simplify/DouglasPeuckerLineSimplifier.cpp: Use a
+	  fully qualified namespace for LineSegment because we're inside of
+	  geos::simplify at the time
+2006-06-01 11:49  Sandro Santilli <strk at keybit.net>
+	* [r1609] ChangeLog, source/headers/geos/geomgraph.h,
+	  source/headers/geos/geomgraph/Node.h,
+	  source/headers/geos/io.h, source/headers/geos/io/Makefile.am,
+	  source/headers/geos/opValid.h,
+	  source/io/WKTWriter.cpp, source/io/Writer.cpp: Reduced installed
+	  headers form geomgraph namespace
+2006-06-01 10:28  Sandro Santilli <strk at keybit.net>
+	* [r1608] ChangeLog, source/headers/geos/index/bintree/Makefile.am,
+	  source/operation/valid/Makefile.am: Reduced number of installed
+	  headers for the geos::index namespace
+2006-05-25 18:44  Sandro Santilli <strk at keybit.net>
+	* [r1607] ChangeLog, tests/unit/geom/TriangleTest.cpp: *
+	  tests/unit/geom/TriangleTest.cpp: take floating-point rounding
+	  error into account.
+2006-05-25 16:11  mloskot
+	* [r1606] tests/tut/tut.h: Changed precision constant with
+	  epsilon() from std::numeric_limits.
+2006-05-25 15:54  mloskot
+	* [r1605] tests/tut/tut.h: Added specialization of ensure_equals
+	  for double type.
+2006-05-24 16:29  Sandro Santilli <strk at keybit.net>
+	* [r1604] ChangeLog, source/index/quadtree/DoubleBits.cpp: *
+	  source/index/quadtree/DoubleBits.cpp: handled negative or zero
+	  values in getExponent().
+2006-05-24 16:01  Sandro Santilli <strk at keybit.net>
+	* [r1603] ChangeLog, tests/unit/utility.h: * tests/unit/utility.h:
+	  fixed missing return from isSameStructure's specialization on
+	  GeometryCollection, also fixed a signed/unsigned mismatch warning
+	  there.
+2006-05-24 15:42  Sandro Santilli <strk at keybit.net>
+	* [r1602] ChangeLog, source/util/CoordinateArrayFiter.cpp,
+	  source/util/GEOSException.cpp, source/util/Makefile.am,
+	  source/util/UniqueCoordinateArrayFilter.cpp: *
+	  source/util/Makefile.am, source/util/CoordinateArrayFiter.cpp,
+	  source/util/UniqueCoordinateArrayFilter.cpp: removed empty
+	  implementation files.
+2006-05-24 15:32  Sandro Santilli <strk at keybit.net>
+	* [r1601] ChangeLog,
+	  source/headers/geos/simplify/TaggedLinesSimplifier.h: *
+	  source/headers/geos/simplify/TaggedLinesSimplifier.h: added
+	  LineSegmentIndex.h include so that every use of the templated
+	  simplify() function get all the required definitions.
+2006-05-24 15:17  Sandro Santilli <strk at keybit.net>
+	* [r1600] ChangeLog, source/headers/geos/algorithm/Makefile.am,
+	  source/headers/geos/operation/overlay/Makefile.am,
+	  source/headers/geos/planargraph/Makefile.am: Reduced number of
+	  installed headers in geos/operation/ subdir
+2006-05-24 13:44  Sandro Santilli <strk at keybit.net>
+	* [r1599] NEWS: Added a note about unit tests being introduced
+2006-05-24 11:44  mloskot
+	* [r1598] ChangeLog: Added missing entries to ChangeLog.
+2006-05-24 11:41  Sandro Santilli <strk at keybit.net>
+	* [r1597] ChangeLog,
+	  source/simplify/TopologyPreservingSimplifier.cpp: *
+	  fixed bug in TopologyPreservingSimplifier failing to
+	  detect intersections, refactored TaggedLinesSimplifier
+	  class to more closely match JTS and use templated
+	  functions.
+2006-05-24 08:32  Sandro Santilli <strk at keybit.net>
+	* [r1596] ChangeLog, capi/geos_c.h.in: * capi/geos_c.h.in: #include
+	  <stddef.h> to get size_t definition (only #ifndef __cplusplus)
+2006-05-24 05:53  mloskot
+	* [r1595] tests/unit/Makefile.am,
+	  tests/unit/utility.h: Added new test:
+	  TopologyPreservingSimplifierTest.cpp. Added new utility.cpp
+	  helper for Unit Tests (implementes utils from JTS Unit Tests).
+2006-05-23 15:06  Sandro Santilli <strk at keybit.net>
+	* [r1594] ChangeLog, source/headers/geos/geom/Coordinate.h: *
+	  source/headers/geos/geom/Coordinate.h: added missing <string>
+	  include.
+2006-05-23 14:44  Sandro Santilli <strk at keybit.net>
+	* [r1593] ChangeLog, source/headers/geos/config.h: *
+	  source/headers/geos/config.h: removed file which is not supposed
+	  to be in the repository.
+2006-05-23 14:29  Sandro Santilli <strk at keybit.net>
+	* [r1592] ChangeLog,
+	  source/index/quadtree/DoubleBits.cpp: *
+	  source/index/quadtree/DoubleBits.cpp: const correctness and
+	  documentation.
+2006-05-23 13:21  Sandro Santilli <strk at keybit.net>
+	* [r1591] tests/unit/io/ByteOrderValuesTest.cpp: Added test for
+	  put/get Long values
+2006-05-23 13:16  Sandro Santilli <strk at keybit.net>
+	* [r1590] ChangeLog, source/io/WKBWriter.cpp: Fixed a bug in
+	  WKBWriter::writeByteOrder() failing to consider machine's byte
+	  order
+2006-05-23 12:57  Sandro Santilli <strk at keybit.net>
+	* [r1589] tests/unit/geom/CoordinateTest.cpp: Fixed small typo in
+	  label
+2006-05-23 12:33  Sandro Santilli <strk at keybit.net>
+	* [r1588] ChangeLog, source/io/ByteOrderValues.cpp: *
+	  source/io/ByteOrderValues.cpp: fixed bug in putLong() also
+	  affecting putDouble()
+2006-05-23 12:23  Sandro Santilli <strk at keybit.net>
+	* [r1587] ChangeLog, tests/unit/Makefile.am,
+	  tests/unit/io/ByteOrderValuesTest.cpp: * tests/unit/Makefile.am,
+	  tests/unit/io/ByteOrderValuesTest.cpp: unit test for
+	  ByteOrderValues class.
+2006-05-23 11:07  Sandro Santilli <strk at keybit.net>
+	* [r1586] ChangeLog, source/io/WKBWriter.cpp: *
+	  source/io/WKBWriter.cpp: fixed bug in ::writeInt missing to
+	  honour the requested byte order.
+2006-05-23 10:56  Sandro Santilli <strk at keybit.net>
+	* [r1585] tests/unit/io/WKBReaderTest.cpp: Fixed top comment
+2006-05-23 10:48  Sandro Santilli <strk at keybit.net>
+	* [r1584] ChangeLog, tests/unit/io/WKBReaderTest.cpp: *
+	  tests/unit/io/WKBReaderTest.cpp: cleaned up and added both XDR
+	  and NDR tests.
+2006-05-23 09:24  Sandro Santilli <strk at keybit.net>
+	* [r1583] ChangeLog, source/headers/geos/io/WKBConstants.h,
+	  source/io/ByteOrderValues.cpp: * source/io/ByteOrderValues.cpp:
+	  changed ENDIAN_BIG and ENDIAN_LITTLE values to match
+	  WKBConstants::XDR and WKBConstants::NDR respectively.
+	  * source/headers/geos/io/WKBConstants.h: added comments about
+	  meaning of XDR/NDR.
+2006-05-22 15:08  Sandro Santilli <strk at keybit.net>
+	* [r1582] source/headers/geos/util/GEOSException.h: Print colon
+	  after exception name (as it has always been)
+2006-05-19 17:44  Sandro Santilli <strk at keybit.net>
+	* [r1581] ChangeLog,
+	  removed friend specification in
+	  TopologyPreservingSimplifier helper class
+	  (no more needed)
+2006-05-19 17:39  Sandro Santilli <strk at keybit.net>
+	* [r1580] ChangeLog, tests/unit/geom/Geometry/coversTest.cpp: *
+	  tests/unit/geom/Geometry/coversTest.cpp:
+	  keep tests in 'tut' namespace.
+2006-05-19 16:38  Sandro Santilli <strk at keybit.net>
+	* [r1579] ChangeLog, tests/xmltester/XMLTester.cpp: *
+	  tests/xmltester/XMLTester.cpp: report
+	  error on load of requested tests.
+2006-05-18 10:19  Sandro Santilli <strk at keybit.net>
+	* [r1578] ChangeLog, source/headers/geos/geom.h: *
+	  source/headers/geos/geom.h: fixed doxygen header for mainpage.
+2006-05-18 10:16  Sandro Santilli <strk at keybit.net>
+	* [r1577] NEWS: Added note about the new BinaryOp class and its
+	  uses.
+2006-05-18 10:13  Sandro Santilli <strk at keybit.net>
+	* [r1576] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
+	  source/headers/geos/geom/BinaryOp.h: added compile-time defines
+	  to avoid precision-reduction and simplify based policies (default
+	  to enabled).
+2006-05-18 09:32  Sandro Santilli <strk at keybit.net>
+	* [r1575] NEWS: added note about new Geometry predicates
+2006-05-18 09:00  Sandro Santilli <strk at keybit.net>
+	* [r1574] ChangeLog, tests/unit/geom/Geometry/coversTest.cpp: Added
+	  tests for coveredBy(), fixed ChangeLog entry
+2006-05-18 08:56  Sandro Santilli <strk at keybit.net>
+	* [r1573] ChangeLog, source/geom/Geometry.cpp,
+	  source/headers/geos/geom/Geometry.h, tests/unit/Makefile.am,
+	  tests/unit/geom/Geometry/coversTest.cpp: *
+	  source/headers/geos/geom/Geometry.h: added
+	  covers() and isCoveredBy() predicates.
+	  * tests/unit/Makefile.am,
+	  added test for covers() predicates.
+2006-05-17 17:41  Sandro Santilli <strk at keybit.net>
+	* [r1572] source/geom/IntersectionMatrix.cpp,
+	  source/headers/geos/geom/IntersectionMatrix.h,
+	  tests/unit/geom/IntersectionMatrixTest.cpp: Added output operator
+	  + test
+2006-05-17 17:24  Sandro Santilli <strk at keybit.net>
+	* [r1571] ChangeLog, source/geom/IntersectionMatrix.cpp,
+	  source/headers/geos/geom/IntersectionMatrix.h: Added port info,
+	  fixed isCoveredBy() comment.
+2006-05-17 17:20  Sandro Santilli <strk at keybit.net>
+	* [r1570] ChangeLog, source/geom/IntersectionMatrix.cpp,
+	  tests/unit/geom/IntersectionMatrixTest.cpp: added isCovers() and
+	  isCoveredBy() public methods to IntersectionMatrix and associated
+	  tests.
+2006-05-17 08:40  Sandro Santilli <strk at keybit.net>
+	* [r1569] source/headers/geos/geom/BinaryOp.h: typo fixed to make
+	  description more clear
+2006-05-13 10:42  mloskot
+	* [r1563] tests/unit/algorithm/PointLocatorTest.cpp: Fixed
+	  line-ends in PointLocatorTest.cpp file.
+2006-05-13 08:26  mloskot
+	* [r1562] ., .cvsignore, tests/unit, tests/unit/.cvsignore,
+	  tests/unit/geom/Geometry/isRectangleTest.cpp: Fixed line-ends in
+	  isRectangleTest.cpp. Added new patterns to .cvsignore.
+2006-05-05 15:40  Sandro Santilli <strk at keybit.net>
+	* [r1561] ChangeLog,
+	  source/noding/snapround/SimpleSnapRounder.cpp: Had nodind
+	  validation error throw an exception for SimpleSnapRounder
+	  and MCIndexSnapRounder
+2006-05-05 14:34  Sandro Santilli <strk at keybit.net>
+	* [r1560] ChangeLog, tests/unit/Makefile.am, tests/unit/noding,
+	  tests/unit/noding/SegmentStringTest.cpp: New SegmentString unit
+	  test
+2006-05-05 14:25  Sandro Santilli <strk at keybit.net>
+	* [r1559] source/headers/geos/noding/SegmentString.h,
+	  source/noding/SegmentString.cpp: moved getSegmentOctant out of
+	  .inl into .cpp, renamed private eiList to nodeList as in JTS,
+	  added more assertion checking and fixed doxygen comments
+2006-05-05 10:19  Sandro Santilli <strk at keybit.net>
+	* [r1558] ChangeLog, source/headers/geos/noding/SegmentString.h,
+	  source/noding/SegmentNodeList.cpp: droppped
+	  SegmentString::getContext(), new name is getData() to reflect
+	  change in JTS
+2006-05-05 09:37  Sandro Santilli <strk at keybit.net>
+	* [r1557] ChangeLog, source/headers/geos/geom.h: *
+	  source/headers/geos/geom.h: fixed namespace qualification in
+	  doxygen page about C++ interface.
+2006-05-04 15:49  Sandro Santilli <strk at keybit.net>
+	* [r1556] ChangeLog, source/geom/GeometryCollection.cpp,
+	  source/geom/LineString.cpp, source/geom/MultiLineString.cpp,
+	  source/geom/MultiPoint.cpp, source/geom/MultiPolygon.cpp,
+	  source/geom/Point.cpp, source/geom/Polygon.cpp,
+	  source/headers/geos/geom/Dimension.h,
+	  source/headers/geos/geom/GeometryCollection.h,
+	  source/headers/geos/geom/LineString.h,
+	  source/headers/geos/geom/MultiLineString.h,
+	  source/headers/geos/geom/MultiPoint.h,
+	  source/headers/geos/geom/MultiPolygon.h,
+	  source/headers/geos/geom/Point.h,
+	  source/operation/buffer/BufferOp.cpp: updated all
+	  Geometry::getDimension() methods to return
+	  Dimension::DimensionType (closes bug#93)
+2006-05-04 14:05  Sandro Santilli <strk at keybit.net>
+	* [r1555] ChangeLog, source/geom/PrecisionModel.cpp,
+	  source/headers/geos/util/math.h, source/noding/ScaledNoder.cpp: *
+	  source/headers/geos/util/math.h: provided an util::round() method
+	  being an inline proxy to call appropriate default rounding
+	  function for the whole GEOS codebase. Currently pointing at
+	  util::java_math_round() being the last being used.
+2006-05-04 13:38  Sandro Santilli <strk at keybit.net>
+	* [r1554] source/headers/geos/geomgraph/DirectedEdge.h: doxygen
+	  comments cleanup
+2006-05-04 12:54  Sandro Santilli <strk at keybit.net>
+	* [r1553] ChangeLog, source/headers/geos/geomgraph/NodeMap.h: Added
+	  invariant tester for NodeMap class, fixed comment about ownership
+	  of NodeFactory
+2006-05-04 12:33  Sandro Santilli <strk at keybit.net>
+	* [r1552] source/operation/buffer/BufferSubgraph.cpp: Added some
+	  comments about RightmostEdgeFinder only considering forward
+	  DirectedEdge
+2006-05-04 12:19  Sandro Santilli <strk at keybit.net>
+	* [r1551]
+	  source/headers/geos/operation/buffer/RightmostEdgeFinder.h: Added
+	  note about findEdge() only scanning for forward DirectedEdges
+2006-05-04 12:17  Sandro Santilli <strk at keybit.net>
+	* [r1550] source/geomgraph/PlanarGraph.cpp: Added comment about
+	  management of newly created DirectedEdges
+2006-05-04 10:15  Sandro Santilli <strk at keybit.net>
+	* [r1549] ChangeLog,
+	  source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h:
+	  Doxygen comments
+2006-05-04 09:16  Sandro Santilli <strk at keybit.net>
+	* [r1548] source/operation/buffer/BufferBuilder.cpp: Added JTS
+	  debugging, for comparison with JTS
+2006-05-04 08:42  Sandro Santilli <strk at keybit.net>
+	* [r1547] ChangeLog, source/headers/geos/geom/CoordinateSequence.h:
+	  Added note about the CoordinateSequence::toVector() method.
+2006-05-04 08:35  Sandro Santilli <strk at keybit.net>
+	* [r1546] ChangeLog, source/noding/SegmentNodeList.cpp:
+	  noding/SegmentNodeList.cpp: cleanups, changed output operator to
+	  be more similar to JTS
+2006-05-04 08:30  Sandro Santilli <strk at keybit.net>
+	* [r1545] source/noding/ScaledNoder.cpp: removed use of
+	  SegmentString::setCoordinates() [dropped]
+2006-05-04 08:29  Sandro Santilli <strk at keybit.net>
+	* [r1544] ChangeLog, source/headers/geos/noding/SegmentString.h,
+	  source/headers/geos/noding/SegmentString.inl: *
+	  source/noding/ScaledNoder.cpp: removed use of
+	  SegmentString::setCoordinates().
+	  * source/headers/geos/noding/SegmentStrign.{h,inl}: removed new
+	  setCoordinates() interface.
+2006-05-04 07:43  Sandro Santilli <strk at keybit.net>
+	* [r1543] ChangeLog, source/headers/geos/noding/SegmentString.h,
+	  source/noding/SegmentString.cpp: output operator for
+	  SegmentString class
+2006-05-04 07:41  Sandro Santilli <strk at keybit.net>
+	* [r1542] ChangeLog, source/headers/geos/noding/SegmentNodeList.h:
+	  const-correct size() method for SegmentNodeList
+2006-05-04 06:36  Sandro Santilli <strk at keybit.net>
+	* [r1541] source/headers/geos/noding/ScaledNoder.h: Extended
+	  definition to take new CoordinateSequence tracking into account
+2006-05-03 20:05  Sandro Santilli <strk at keybit.net>
+	* [r1540] ChangeLog, source/noding/ScaledNoder.cpp: Added SQL
+	  debugging output
+2006-05-03 19:47  Sandro Santilli <strk at keybit.net>
+	* [r1539] ChangeLog, source/geom/CoordinateSequence.cpp,
+	  source/headers/geos/geom/CoordinateSequence.h: added operator<<
+	  for CoordinateSequence
+2006-05-03 18:04  Sandro Santilli <strk at keybit.net>
+	* [r1538] ChangeLog, source/headers/geos/noding/SegmentString.h,
+	  source/headers/geos/noding/SegmentString.inl: added
+	  SegmentString::setCoordinates() interface
+2006-05-03 17:54  Sandro Santilli <strk at keybit.net>
+	* [r1537] source/noding/snapround/SimpleSnapRounder.cpp:
+	  Uncommented correctness checker
+2006-05-03 17:51  Sandro Santilli <strk at keybit.net>
+	* [r1536] source/noding/snapround/HotPixel.cpp: system headers
+	  included after package headers
+2006-05-03 17:50  Sandro Santilli <strk at keybit.net>
+	* [r1535] ChangeLog,
+	  source/headers/geos/noding/snapround/HotPixel.h: Doxygen comments
+2006-05-03 17:48  Sandro Santilli <strk at keybit.net>
+	* [r1534] source/headers/geos/nodingSnapround.h: Forgot a slash
+	* [r1533] ChangeLog, source/headers/geos/nodingSnapround.h: Doxygen
+	  brief
+2006-05-03 16:22  hobu
+	* [r1532] source/Makefile.vc: tweak clean target
+2006-05-03 16:21  hobu
+	* [r1531] source/Makefile.vc: Build the C API and shared lib
+	  separate from the normal lib
+	  Add missing files
+2006-05-03 16:19  Sandro Santilli <strk at keybit.net>
+	* [r1530] source/headers/geos/noding/SegmentString.h: fit in 80
+	  columns
+2006-05-03 16:09  hobu
+	* [r1529] capi/geos_c.h.vc: Maintain a geos_c.h.vc until we come up
+	  with a better solution
+2006-05-03 15:50  hobu
+	* [r1528] ChangeLog: *** empty log message ***
+2006-05-03 15:49  Sandro Santilli <strk at keybit.net>
+	* [r1527] ChangeLog, source/noding/snapround/SimpleSnapRounder.cpp:
+	  fixed bug in SimpleSnapRounder::computeSnaps, trying to access
+	  out-of-bound vector element.
+2006-05-03 15:49  hobu
+	* [r1526] source/Makefile.vc: add additional files and change names
+	  where necessary
+2006-05-03 15:40  Sandro Santilli <strk at keybit.net>
+	* [r1525] source/noding/ScaledNoder.cpp: test SegmentString
+	  invariant before and after scaling
+2006-05-03 15:37  Sandro Santilli <strk at keybit.net>
+	* [r1524] ChangeLog: Tabs for indent
+2006-05-03 15:32  hobu
+	* [r1523] ChangeLog: *** empty log message ***
+2006-05-03 15:30  hobu
+	* [r1522] source/headers/geos/version.h.vc: Maintain a version.h.vc
+	  until we come up with a better solution
+2006-05-03 15:28  Sandro Santilli <strk at keybit.net>
+	* [r1521] ChangeLog, configure.in: updated JTS_PORT to 1.7.1
+2006-05-03 15:26  Sandro Santilli <strk at keybit.net>
+	* [r1520] ChangeLog, source/headers/geos/noding/SegmentString.h,
+	  source/headers/geos/noding/SegmentString.inl: testInvariant made
+	  public and always inlined
+2006-05-03 15:19  Sandro Santilli <strk at keybit.net>
+	* [r1519] ChangeLog,
+	  source/headers/geos/noding/snapround/HotPixel.inl: Changed
+	  sym_round() to java_math_round()
+2006-05-03 15:12  Sandro Santilli <strk at keybit.net>
+	* [r1518] source/noding/ScaledNoder.cpp: Oops, uninitialized value
+	  fix
+2006-05-03 15:06  Sandro Santilli <strk at keybit.net>
+	* [r1517] ChangeLog: Updated
+	* [r1516] source/headers/geos/noding/IntersectionFinderAdder.h:
+	  Better doxygen comment
+2006-05-03 15:05  Sandro Santilli <strk at keybit.net>
+	* [r1515] source/operation/buffer/RightmostEdgeFinder.cpp:
+	  Assertions checking
+2006-05-03 15:04  Sandro Santilli <strk at keybit.net>
+	* [r1514] source/headers/geos/noding/ScaledNoder.h: removed
+	  reduntant port info
+2006-05-03 15:02  Sandro Santilli <strk at keybit.net>
+	* [r1513] source/headers/geos/noding/snapround/SimpleSnapRounder.h,
+	  source/noding/snapround/SimpleSnapRounder.cpp: moved some
+	  implementations from header to .cpp file (taken out of inline)
+2006-05-03 15:00  Sandro Santilli <strk at keybit.net>
+	* [r1512] source/headers/geos/noding/ScaledNoder.h,
+	  source/noding/ScaledNoder.cpp: Fixed scale() function to remove
+	  repeated points *after* rounding. Added brief doxygen class
+	  description.
+2006-05-03 10:26  Sandro Santilli <strk at keybit.net>
+	* [r1511] ChangeLog, source/operation/buffer/BufferOp.cpp: Fixed
+	  misuse of precision model in noder (bufferFixedPrecision)
+2006-05-03 09:46  Sandro Santilli <strk at keybit.net>
+	* [r1510] ChangeLog: buffer headers reduction item
+2006-05-03 09:45  Sandro Santilli <strk at keybit.net>
+	* [r1509] source/headers/geos/opBuffer.h,
+	  source/headers/geos/operation/buffer/Makefile.am: Do not install
+	  following buffer headers: BufferBuilder.h,
+	  OffsetCurveSetBuilder.h, BufferSubgraph.h,
+	  SubgraphDepthLocater.h,
+	  RightmostEdgeFinder.h
+2006-05-03 09:14  Sandro Santilli <strk at keybit.net>
+	* [r1508] ChangeLog, source/headers/geos/noding/ScaledNoder.h,
+	  source/noding/ScaledNoder.cpp,
+	  source/operation/buffer/OffsetCurveSetBuilder.cpp: *
+	  source/operation/buffer/OffsetCurveSetBuilder.cpp: used auto_ptr
+	  to protect leaks of CoordinateSequence
+	  * source/noding/ScaledNoder.cpp,
+	  source/headers/geos/noding/ScaledNoder.h: ported JTS bugfix in
+	  scale method.
+2006-05-03 08:58  Sandro Santilli <strk at keybit.net>
+	* [r1507] ChangeLog, source/geom/CoordinateArraySequence.cpp,
+	  tests/unit/geom/CoordinateArraySequenceTest.cpp: added new
+	  non-static CoordinateSequence::removeRepeatedPoints() mutator.
+2006-05-02 16:22  Sandro Santilli <strk at keybit.net>
+	* [r1506] ChangeLog, source/noding/ScaledNoder.cpp: *
+	  source/noding/ScaledNoder.cpp: use java_math_round instead of
+	  sym_round.
+2006-05-02 14:51  Sandro Santilli <strk at keybit.net>
+	* [r1505] source/algorithm/CGAlgorithms.cpp,
+	  source/headers/geos/algorithm/CGAlgorithms.h: Added port info and
+	  fixed doxygen comments for CGAlgorithms class
+2006-05-02 14:32  Sandro Santilli <strk at keybit.net>
+	* [r1503] ChangeLog, source/headers/geos/opPolygonize.h,
+	  source/headers/geos/operation/polygonize/EdgeRing.h,
+	  source/operation/polygonize/EdgeRing.cpp: Added port info for
+	  polygonize/EdgeRing class, polygonize/EdgeRing.h header
+	  not installed.
+2006-05-02 14:22  Sandro Santilli <strk at keybit.net>
+	* [r1502] ChangeLog, source/operation/polygonize/EdgeRing.cpp,
+	  source/operation/polygonize/Makefile.am,
+	  source/operation/polygonize/polygonizeEdgeRing.cpp: *
+	  source/operation/polygonize/: polygonizeEdgeRing.cpp renamed to
+	  EdgeRing.cpp, to follow JTS naming.
+2006-05-02 14:01  Sandro Santilli <strk at keybit.net>
+	* [r1500] ChangeLog, source/io/WKBReader.cpp: *
+	  source/io/WKBReader.cpp: fixed reads of XDR WKB.
+2006-04-28 12:09  Sandro Santilli <strk at keybit.net>
+	* [r1497] tests/xmltester/Makefile.am: Added 'verbose-test' rule
+2006-04-28 12:08  Sandro Santilli <strk at keybit.net>
+	* [r1496] NEWS: Added note about Geometry constructors
+2006-04-28 11:56  Sandro Santilli <strk at keybit.net>
+	* [r1495] ChangeLog, source/geom/GeometryFactory.cpp,
+	  source/headers/geos/geom/GeometryFactory.h: *
+	  source/headers/geos/geom/GeometryFactory.h: added LineString copy
+	  constructor.
+	  * source/geom/Polygon.cpp: fixed getBoundary method to always
+	  return a geometry composed by LineStrings (not LinearRings)
+2006-04-28 11:12  Sandro Santilli <strk at keybit.net>
+	* [r1494] ChangeLog,
+	  source/headers/geos/operation/predicate/RectangleIntersects.h,
+	  source/operation/predicate/RectangleIntersects.cpp: removed
+	  warnings related to change in getNumPoints() return type.
+2006-04-28 10:55  Sandro Santilli <strk at keybit.net>
+	* [r1493] ChangeLog, source/geom/GeometryCollection.cpp,
+	  source/headers/geos/geom/Polygon.h: Geometry constructors made
+	  protected, to ensure all constructions use GeometryFactory,
+	  which has been made friend of all Geometry derivates.
+	  getNumPoints() changed to return
+	  size_t.
+2006-04-28 10:51  Sandro Santilli <strk at keybit.net>
+	* [r1492] ChangeLog, tests/unit/geom/LineStringTest.cpp,
+	  tests/unit/geom/MultiPointTest.cpp,
+	  tests/unit/geom/PointTest.cpp, tests/unit/geom/PolygonTest.cpp:
+	  Unit tests: only construct Geoms using GeometryFactory.
+2006-04-27 15:15  Sandro Santilli <strk at keybit.net>
+	* [r1491] ChangeLog, source/headers/geos/geomgraph/Node.h: Z check
+	  removed from invariant tester to avoid aborts due to differences
+	  in FP computations.
+2006-04-27 15:07  Sandro Santilli <strk at keybit.net>
+	* [r1490] source/geomgraph/PlanarGraph.cpp: use output operators in
+	  debugging lines
+2006-04-27 15:06  Sandro Santilli <strk at keybit.net>
+	* [r1489] ChangeLog, source/geomgraph/NodeMap.cpp: (addNode):
+	  always use the Node Coordinate as a key in the map to reduce
+	  likeliness of a premature deletion.
+2006-04-27 15:03  Sandro Santilli <strk at keybit.net>
+	* [r1488] source/geomgraph/Node.cpp: standard algorithm used in
+	  addZ() for vector seek
+2006-04-26 16:35  Sandro Santilli <strk at keybit.net>
+	* [r1485] ChangeLog, source/io/StringTokenizer.cpp,
+	  source/io/WKTReader.cpp, tests/xmltester/testLeaksBig.xml: Had
+	  WKTReader accept correct form for MultiPoint
+2006-04-26 10:39  Sandro Santilli <strk at keybit.net>
+	* [r1482] ChangeLog: Added mloskot item (bug#100)
+2006-04-26 10:26  Sandro Santilli <strk at keybit.net>
+	* [r1481] ChangeLog, tools/geos-config.in: tools/geos-config.in:
+	  fixed library path to use layout detected by autoconf
+2006-04-24 15:47  Sandro Santilli <strk at keybit.net>
+	* [r1480] source/simplify/TopologyPreservingSimplifier.cpp: Public
+	  constructors change made permanent
+2006-04-23 11:58  mloskot
+	* [r1479] ., .cvsignore,
+	  tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp: Small
+	  refactoring of DouglasPeuckerSimplifierTest (prefer to use ctor
+	  instead of operator= to create objects). Added new patterns to
+	  .cvsignore.
+2006-04-23 11:29  mloskot
+	* [r1478] ., .cvsignore: Added new patterns to .cvsignore file.
+2006-04-22 17:16  mloskot
+	* [r1477] source/simplify/TopologyPreservingSimplifier.cpp:
+	  Temporar fix of Bug #100. This report requires deeper analysis!.
+2006-04-21 17:04  Sandro Santilli <strk at keybit.net>
+	* [r1476] ChangeLog, source/geom/PrecisionModel.cpp: Fixed
+	  constructor by type to always initialize scale factor
+2006-04-20 16:21  Sandro Santilli <strk at keybit.net>
+	* [r1475] ChangeLog, source/headers/geos/geom/BinaryOp.h: Added
+	  missing debugging output
+2006-04-20 14:27  Sandro Santilli <strk at keybit.net>
+	* [r1474] ChangeLog, source/algorithm/HCoordinate.cpp,
+	  source/headers/geos/algorithm/HCoordinate.h: HCoordinate class
+	  changed to use long double types internally, in order to improve
+	  computation precision
+2006-04-20 14:16  Sandro Santilli <strk at keybit.net>
+	* [r1473] source/headers/geos/algorithm/LineIntersector.h: Added
+	  some more doxygen comments
+2006-04-20 11:11  Sandro Santilli <strk at keybit.net>
+	* [r1472] ChangeLog, source/algorithm/HCoordinate.cpp:
+	  source/algorithm/HCoordinate.cpp: added compile time define to
+	  force storage of intermediate computation values to variables (in
+	  order to make the -ffloat-store gcc switch effective). Disabled
+	  by default.
+2006-04-19 09:21  Sandro Santilli <strk at keybit.net>
+	* [r1471] TODO: Added snapround and simplify tests items
+2006-04-19 09:20  Sandro Santilli <strk at keybit.net>
+	* [r1470] NEWS: updated
+2006-04-14 15:34  Sandro Santilli <strk at keybit.net>
+	* [r1469] ChangeLog, capi/geos_c.cpp: Had CAPI use new BinaryOp
+	  class in an aim to reduce robustness problems
+2006-04-14 15:25  Sandro Santilli <strk at keybit.net>
+	* [r1468] TODO: updated, somehow
+2006-04-14 15:19  Sandro Santilli <strk at keybit.net>
+	* [r1467] ChangeLog, source/operation/overlay/OverlayOp.cpp:
+	  removed precision reduction code (use BinaryOp for that)
+2006-04-14 15:06  Sandro Santilli <strk at keybit.net>
+	* [r1466] source/headers/geos/geom/Makefile.am: Added BinaryOp.h
+	  header
+2006-04-14 15:04  Sandro Santilli <strk at keybit.net>
+	* [r1465] source/headers/geos/operation/overlay/OverlayOp.h: fixed
+	  missing namespace qualification in overlay::overlayOp
+2006-04-14 14:57  Sandro Santilli <strk at keybit.net>
+	* [r1464] ChangeLog, tests/xmltester/XMLTester.cpp: XMLTester
+	  binary ops invoked using the new BinaryOp template function.
+2006-04-14 14:38  Sandro Santilli <strk at keybit.net>
+	* [r1463] ChangeLog, source/headers/geos/geom/BinaryOp.h: new
+	  geos::Geom::BinaryOp template function implementing various
+	  heuristics aimed at making binary geometry ops work around
+	  robustness issues.
+2006-04-14 14:35  Sandro Santilli <strk at keybit.net>
+	* [r1462] ChangeLog,
+	  source/headers/geos/operation/overlay/OverlayOp.h: Added
+	  overlayOp() adapter for use in templates expecting binary ops
+2006-04-14 09:02  Sandro Santilli <strk at keybit.net>
+	* [r1461] ChangeLog, source/algorithm/HCoordinate.cpp,
+	  source/headers/geos/algorithm/HCoordinate.h: Hadded output
+	  operator and debugging prints for HCoordinate.
+2006-04-13 23:57  Sandro Santilli <strk at keybit.net>
+	* [r1460] source/operation/overlay/OverlayOp.cpp: Disables reduced
+	  precision overlayOp (is broken)
+2006-04-13 23:42  Sandro Santilli <strk at keybit.net>
+	* [r1459] source/operation/overlay/OverlayOp.cpp: Plugged
+	  CommonBitsOp attempts in overlay op, before brute force precision
+	  reduction (this is likely going to change)
+2006-04-13 23:28  Sandro Santilli <strk at keybit.net>
+	* [r1458] source/precision/CommonBitsOp.cpp: "always build before
+	  commit" (forgot a closing paren)
+2006-04-13 23:23  Sandro Santilli <strk at keybit.net>
+	* [r1457] ChangeLog, source/headers/geos/precision/CommonBitsOp.h,
+	  source/precision/CommonBitsOp.cpp: fixed bug in binary ops
+	  failing to consistently reduce operands.
+2006-04-13 21:53  Sandro Santilli <strk at keybit.net>
+	* [r1456] capi/geostest.c: fixed bug introduced by previous commit
+2006-04-13 21:52  Sandro Santilli <strk at keybit.net>
+	* [r1455] source/headers/geos/simplify/TaggedLineString.h,
+	  source/headers/geos/simplify/TaggedLineStringSimplifier.h,
+	  source/simplify/TaggedLineStringSimplifier.cpp,
+	  source/simplify/TopologyPreservingSimplifier.cpp: Many debugging
+	  lines and assertions added. Fixed bug in TaggedLineString class.
+2006-04-13 17:09  Sandro Santilli <strk at keybit.net>
+	* [r1454] ChangeLog, capi/geos_c.cpp: Use default GeometryFactory
+	  instance (finishGEOS() is a no-op now)
+2006-04-13 16:48  Sandro Santilli <strk at keybit.net>
+	* [r1453] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in,
+	  capi/geostest.c: Added GEOSSimplify and
+	  GEOSTopologyPreserveSimplify interfaces. Removed compiler
+	  warnings in geostest
+2006-04-13 16:44  Sandro Santilli <strk at keybit.net>
+	* [r1452] source/simplify/DouglasPeuckerSimplifier.cpp: Fixed a bug
+	  in DPTransformer handling of MultiPolygons
+2006-04-13 16:04  Sandro Santilli <strk at keybit.net>
+	* [r1451] source/headers/geos/simplify/TaggedLineString.h,
+	  source/headers/geos/simplify/TopologyPreservingSimplifier.h,
+	  source/simplify/Makefile.am,
+	  source/simplify/TopologyPreservingSimplifier.cpp: Made
+	  TopologyPreservingSimplifier implementation successfully build
+2006-04-13 14:51  Sandro Santilli <strk at keybit.net>
+	* [r1450] ChangeLog, tests/unit/io/WKBReaderTest.cpp: Forced NDR
+	  output (to not rely on architecture). Removed CRs endings.
+2006-04-13 14:25  Sandro Santilli <strk at keybit.net>
+	* [r1449] ChangeLog, source/geom/GeometryComponentFilter.cpp,
+	  source/headers/geos/geom/GeometryComponentFilter.h,
+	  source/headers/geos/geom/util/GeometryTransformer.h,
+	  source/headers/geos/simplify/TaggedLinesSimplifier.h,
+	  source/simplify/TaggedLinesSimplifier.cpp,
+	  TopologyPreservingSimplifier initial port
+2006-04-13 10:39  Sandro Santilli <strk at keybit.net>
+	* [r1448] ChangeLog,
+	  source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h,
+	  source/headers/geos/simplify/DouglasPeuckerSimplifier.h,
+	  source/headers/geos/simplify/Makefile.am,
+	  source/simplify/TopologyPreservingSimplifier.cpp: Initial
+	  implementation of TaggedLinesSimplifier class
+2006-04-13 09:28  mloskot
+	* [r1447] source/headers/geos/simplify/LineSegmentIndex.h,
+	  source/simplify/LineSegmentIndex.cpp: Removed definition of copy
+	  ctor and assignment operator for LineSegmentString class.
+2006-04-13 09:21  mloskot
+	* [r1446] source/headers/geos/simplify/TaggedLineString.h,
+	  source/simplify/TaggedLineString.cpp: Removed definition of copy
+	  ctor and assignment operator for TaggedLineString class.
+	  According to following rule: Declaring, but not defining, private
+	  copy operations has
+	  the effect of "turning off" copying for the class.
+2006-04-12 17:24  Sandro Santilli <strk at keybit.net>
+	* [r1445] ChangeLog: Added note about reduction of installed
+	  headers in simplify namespace
+2006-04-12 17:19  Sandro Santilli <strk at keybit.net>
+	* [r1444] ChangeLog, source/headers/geos/geom/LineSegment.h,
+	  source/headers/geos/simplify/TaggedLineSegment.h,
+	  source/headers/geos/simplify/TaggedLineString.h,
+	  source/simplify/TaggedLineSegment.cpp,
+	  source/simplify/TaggedLineStringSimplifier.cpp: Ported
+	  TaggedLineStringSimplifier class, made LineSegment class
+	  polymorphic to fix derivation of TaggedLineSegment
+2006-04-12 15:20  Sandro Santilli <strk at keybit.net>
+	* [r1443] ChangeLog,
+	  source/headers/geos/simplify/LineSegmentIndex.h,
+	  source/simplify/LineSegmentIndex.cpp,
+	  source/simplify/TaggedLineString.cpp: LineSegmentIndex class
+2006-04-12 14:22  Sandro Santilli <strk at keybit.net>
+	* [r1442] ChangeLog, source/headers/geos/simplify/Makefile.am,
+	  source/simplify/TaggedLineString.cpp: Initial implementation of
+	  TaggedLineSegment and TaggedLineString classes
+2006-04-12 12:20  Sandro Santilli <strk at keybit.net>
+	* [r1441] source/operation/overlay/OverlayOp.cpp: Added support for
+	  use of CommonBitsOp in reduced precision attempts
+	  (compile-time option)
+2006-04-12 11:57  Sandro Santilli <strk at keybit.net>
+	* [r1440] source/algorithm/LineIntersector.cpp: Fixed debugging
+	  line
+2006-04-12 11:39  Sandro Santilli <strk at keybit.net>
+	* [r1439] source/headers/geos/geom/GeometryFactory.h: Removed
+	  Geometry.h and CoordinateSequence.h includes.
+	  The former created a circular dependency.
+2006-04-12 11:17  Sandro Santilli <strk at keybit.net>
+	* [r1438] ChangeLog, source/io/WKBReader.cpp: Fixed exceptions
+	  constructors (were using operator+ with strings and const char*)
+2006-04-12 10:57  Sandro Santilli <strk at keybit.net>
+	* [r1437] ChangeLog, source/headers/geos/io/WKBReader.h,
+	  source/io/WKBReader.cpp: Added WKBReader default ctor using
+	  default GeometryFactory instance
+2006-04-11 16:04  Sandro Santilli <strk at keybit.net>
+	* [r1436] ChangeLog, source/geom/util/GeometryTransformer.cpp,
+	  source/simplify/DouglasPeuckerSimplifier.cpp,
+	  source/simplify/Makefile.am, tests/unit/Makefile.am,
+	  tests/unit/simplify,
+	  geos::simplify::DouglasPeukerSimplifier class + unit test
+2006-04-11 12:56  Sandro Santilli <strk at keybit.net>
+	* [r1435] source/headers/geos/geom/util/GeometryTransformer.h: used
+	  typedef for auto_ptr<CoordinateSequence>
+2006-04-11 12:21  Sandro Santilli <strk at keybit.net>
+	* [r1434] ChangeLog, source/geom/util/GeometryTransformer.cpp,
+	  source/geom/util/Makefile.am,
+	  source/headers/geos/geom/util/Makefile.am: GeometryTransformer
+	  class ported
+2006-04-11 11:55  Sandro Santilli <strk at keybit.net>
+	* [r1433] source/headers/geos/geom/CoordinateSequence.h: Added
+	  CoordinateSequence::AutoPtr typedef
+2006-04-11 11:16  Sandro Santilli <strk at keybit.net>
+	* [r1432] ChangeLog, source/geom/GeometryFactory.cpp,
+	  source/geom/LineString.cpp, source/geom/LinearRing.cpp,
+	  source/headers/geos/geom/GeometryFactory.h,
+	  source/headers/geos/geom/LinearRing.h: Added LineString and
+	  LinearRing constructors by auto_ptr
+2006-04-11 09:53  Sandro Santilli <strk at keybit.net>
+	* [r1431] source/headers/geos/geom/GeometryList.h: Added missing
+	  duplicated include sentinel
+2006-04-11 09:41  Sandro Santilli <strk at keybit.net>
+	* [r1430] source/geom/GeometryList.cpp, source/geom/Makefile.am,
+	  source/headers/geos/geom/GeometryList.h,
+	  source/headers/geos/geom/Makefile.am: Initial implementation of a
+	  GeometryList class, to be used to manage
+	  lists of Geometry pointers.
+2006-04-11 09:31  Sandro Santilli <strk at keybit.net>
+	* [r1429] source/headers/geos/geom/Geometry.h: Added
+	  Geometry::AutoPtr typedef
+2006-04-11 09:29  Sandro Santilli <strk at keybit.net>
+	* [r1428] source/geom/Geometry.cpp: Fixed initialization list
+	  (removed compiler warning)
+2006-04-10 18:15  Sandro Santilli <strk at keybit.net>
+	* [r1427] ChangeLog, source/geom/Geometry.cpp,
+	  source/geom/GeometryCollection.cpp, source/geom/LineString.cpp,
+	  source/headers/geos/geom/Envelope.h,
+	  source/headers/geos/geom/Polygon.h: Changed Geometry::envelope
+	  member to be of type auto_ptr<Envelope>.
+	  Changed computeEnvelopeInternal() signater to return
+	  auto_ptr<Envelope>
+2006-04-10 17:35  Sandro Santilli <strk at keybit.net>
+	* [r1426] ChangeLog, source/geom/LineString.cpp,
+	  source/geom/LinearRing.cpp, source/geom/Point.cpp,
+	  source/headers/geos/geom/LinearRing.h,
+	  tests/unit/geom/LineStringTest.cpp,
+	  tests/unit/geom/PointTest.cpp: Changed LineString::points and
+	  Point::coordinates to be wrapped
+	  in an auto_ptr<>. This should close bugs #86 and #89
+2006-04-10 15:11  Sandro Santilli <strk at keybit.net>
+	* [r1425] ChangeLog: First manual edit (will likely update later
+	  tonight... with changes grouped
+	  by date)
+2006-04-10 15:05  Sandro Santilli <strk at keybit.net>
+	* [r1424] tests/xmltester/TestInteriorPoint.xml: Re-synced with JTS
+	  version (so this actually *was* a bug :)
+	* [r1423] source/geom/Geometry.cpp: Fixed a bug introduced by
+	  previous commit in getCentroid()
+2006-04-10 14:18  Sandro Santilli <strk at keybit.net>
+	* [r1422] source/geom/Geometry.cpp: Fixed getCentroid(Coordinate&)
+	  to round using PrecisionModel
+	  all unit tests succeed.
+2006-04-10 13:40  Sandro Santilli <strk at keybit.net>
+	* [r1421] source/headers/geos/io/WKTReader.h,
+	  source/headers/geos/io/WKTReader.inl: Added default ctor for
+	  WKTReader (using GeometryFactory's default instance)
+2006-04-10 13:13  Sandro Santilli <strk at keybit.net>
+	* [r1420] tools/geos-config.in: Removed INLINE flags from
+	  geos-config --libs
+2006-04-10 13:09  Sandro Santilli <strk at keybit.net>
+	* [r1419] source/geom/Geometry.cpp,
+	  source/headers/geos/geom/GeometryFactory.h, source/io/Unload.cpp:
+	  Added GeometryFactory::defaultInstance()
+	  Made Geometry::INTERNAL_GEOMETRY_FACTORY an alias for it
+	  removed last deletion from Unload::Release class
+2006-04-10 12:05  Sandro Santilli <strk at keybit.net>
+	* [r1418] source/Makefile.am, source/geom/LineSegment.cpp,
+	  source/headers/geos/geom/LineSegment.inl,
+	  source/headers/geos/io/WKTReader.h,
+	  source/headers/geos/io/WKTReader.inl,
+	  source/headers/geos/noding/MCIndexNoder.inl,
+	  source/headers/geos/noding/SegmentString.inl,
+	  source/headers/geos/noding/snapround/HotPixel.inl,
+	  source/headers/geos/noding/snapround/MCIndexSnapRounder.inl,
+	  source/inlines.cpp, source/io/ByteOrderDataInStream.cpp,
+	  source/io/WKTReader.cpp, source/operation/overlay/OverlayOp.cpp:
+	  Added inline-replicator implementation files to make sure
+	  functions in .inl files are still available out-of-line.
+	  A side effect is this should fix MingW build.
+2006-04-10 11:34  Sandro Santilli <strk at keybit.net>
+	* [r1417] tests/unit/algorithm/PointLocatorTest.cpp: Uncommented
+	  required Geometry.h include (for use in auto_ptr)
+2006-04-10 09:21  mloskot
+	* [r1416] source/headers/geos/util/UniqueCoordinateArrayFilter.h,
+	  tests/unit/Makefile.am,
+	  tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp,
+	  tests/unit/geom/CoordinateArraySequenceTest.cpp,
+	  tests/unit/geom/GeometryFactoryTest.cpp,
+	  tests/unit/geom/LinearRingTest.cpp,
+	  tests/unit/geom/MultiPointTest.cpp, tests/unit/util,
+	  tests/unit/util/UniqueCoordinateArrayFilterTest.cpp: Added new
+	  test for UniqueCoordinateArrayFilter class. Small fixes related
+	  to signed/unsigned comparison.
+2006-04-09 11:07  mloskot
+	* [r1413] doc/example.cpp: Small fixes in doc/example.cpp.
+2006-04-09 04:56  mloskot
+	* [r1412] tests/xmltester/markup/MarkupSTL.cpp: Removed redundant
+	  semicolons from xmltester sources.
+2006-04-09 04:26  mloskot
+	* [r1411] tests/xmltester/markup/MarkupSTL.cpp: Removed redundant
+	  semicolon reported by g++ -pedantic.
+2006-04-09 04:09  mloskot
+	* [r1410] source/operation/valid/SweeplineNestedRingTester.cpp:
+	  Removed redundant semicolon reported by g++ -pedantic.
+2006-04-09 01:48  mloskot
+	* [r1409] tests/unit/Makefile.am,
+	  tests/unit/geom/IntersectionMatrixTest.cpp: Added Unit Test for
+	  IntersectionMatrix class.
+2006-04-09 01:46  mloskot
+	* [r1408] source/headers/geos/geom/IntersectionMatrix.h: [SORRY]
+	  Added comments for doxygen based on JTS docs. Added row/col
+	  dimension consts. Added asserts in functions to check if given
+	  row/col is in range.
+2006-04-09 01:41  mloskot
+	* [r1407] source/geom/IntersectionMatrix.cpp: Added comments for
+	  doxygen based on JTS docs. Added row/col dimension consts. Added
+	  asserts in functions to check if given row/col is in range.
+2006-04-08 15:57  mloskot
+	* [r1406] tests/tut/tut.h, tests/tut/tut_reporter.h,
+	  tests/tut/tut_restartable.h: Added copyright notice to TUT files.
+	  Small cleaning.
+2006-04-08 13:05  Sandro Santilli <strk at keybit.net>
+	* [r1405] source/geomgraph/EdgeEnd.cpp: Added assertion
+2006-04-08 13:00  Sandro Santilli <strk at keybit.net>
+	* [r1404] source/geomgraph/NodeMap.cpp: assertion checking,
+	  mergeLabel() call fix (bug#91)
+2006-04-07 16:52  Sandro Santilli <strk at keybit.net>
+	* [r1403] source/geomgraph/PlanarGraph.cpp,
+	  source/headers/geos/geomgraph/PlanarGraph.h: Port info, doxygen
+	  comments, assertion checking
+2006-04-07 16:01  Sandro Santilli <strk at keybit.net>
+	* [r1402] source/geomgraph/Node.cpp,
+	  source/headers/geos/geomgraph/Node.h: Port info, doxygen
+	  comments, testInvariant(), many assertionss, handling of
+	  the NULL EdgeEndStar member
+2006-04-07 13:26  Sandro Santilli <strk at keybit.net>
+	* [r1401] tests/xmltester/XMLTester.cpp,
+	  tests/xmltester/XMLTester.h: Use of auto_ptr<> to prevent
+	  confusing leaks in tester
+2006-04-07 13:14  mloskot
+	* [r1400] tests/tut/tut_reporter.h: Fixed annoying warnings from
+	  TUT.
+2006-04-07 13:01  mloskot
+	* [r1399] tests/unit/geos_unit.cpp: Fixed line-ends to LF.
+2006-04-07 12:55  mloskot
+	* [r1398] tests/unit/geom/PolygonTest.cpp: Uncommented test nr 38
+	  in PolygonTest.cpp.
+2006-04-07 12:37  mloskot
+	* [r1397] source/geom/PrecisionModel.cpp,
+	  source/headers/geos/util/math.h, source/util/math.cpp,
+	  tests/tut/tut_reporter.h,
+	  tests/unit/geom/MultiLineStringTest.cpp,
+	  tests/unit/geom/MultiPolygonTest.cpp,
+	  tests/unit/geom/PointTest.cpp, tests/unit/geom/PolygonTest.cpp,
+	  tests/unit/geos_unit.cpp: Added java_math_round() function for
+	  Asymmetric Arithmetic Rounding. Small fixes in Unit Tests.
+2006-04-07 10:42  mloskot
+	* [r1396] tests/unit/geom/GeometryFactoryTest.cpp,
+	  tests/unit/geom/PointTest.cpp: Added test nr 29 to PointTest (JTS
+	  conformance). Removed inform() calls from GeometryFactoryTest.
+2006-04-07 09:54  Sandro Santilli <strk at keybit.net>
+	* [r1395] source/algorithm/CentroidArea.cpp,
+	  source/algorithm/CentroidPoint.cpp,
+	  source/algorithm/InteriorPointArea.cpp,
+	  source/algorithm/PointLocator.cpp, source/geom/Geometry.cpp,
+	  source/geom/GeometryCollection.cpp, source/geom/MultiPolygon.cpp,
+	  source/geom/util/GeometryEditor.cpp,
+	  source/geomgraph/GeometryGraph.cpp,
+	  source/io/WKTWriter.cpp, source/operation/valid/IsValidOp.cpp,
+	  Geometry::getNumGeometries() changed to return 'unsigned int'
+	  rather then 'int'
+2006-04-07 09:12  Sandro Santilli <strk at keybit.net>
+	* [r1394] source/algorithm/LineIntersector.cpp: kept
+	  isInSegmentEnvelopes() check even when not debugging
+2006-04-07 08:31  Sandro Santilli <strk at keybit.net>
+	* [r1393] source/precision/EnhancedPrecisionOp.cpp: Debugging lines
+2006-04-07 08:30  Sandro Santilli <strk at keybit.net>
+	* [r1392] source/headers/geos/precision/CommonBitsRemover.h: made
+	  addCommonBits/removeCommonBits interface consistent, doxygen
+	  comments
+2006-04-07 08:28  Sandro Santilli <strk at keybit.net>
+	* [r1391] source/precision/CommonBitsRemover.cpp: debugging lines,
+	  assertions
+2006-04-07 08:27  Sandro Santilli <strk at keybit.net>
+	* [r1390] source/precision/CommonBitsOp.cpp: debugging blocks
+2006-04-07 07:21  mloskot
+	* [r1389] tests/unit/Makefile.am,
+	  tests/unit/geom/CoordinateTest.cpp: Add new-line at the EOF some
+	  files.
+2006-04-07 05:55  mloskot
+	* [r1388] ., .cvsignore: Added new objects to .cvsignore.
+2006-04-07 05:44  mloskot
+	* [r1387] source/headers/geos/geom/Dimension.h,
+	  tests/unit/geom/CoordinateTest.cpp,
+	  tests/unit/geom/DimensionTest.cpp,
+	  tests/unit/geom/EnvelopeTest.cpp,
+	  tests/unit/geom/LineSegmentTest.cpp,
+	  tests/unit/geom/LocationTest.cpp,
+	  tests/unit/geom/TriangleTest.cpp: Added name for anonymous enum
+	  in Dimension class (bug). Added missing new-line at the end of
+	  source files. Removed CR from line ends.
+2006-04-07 00:05  mloskot
+	* [r1386] tests/unit/geom/Geometry,
+	  tests/unit/geom/Geometry/isRectangleTest.cpp: Adding missing
+2006-04-06 23:50  mloskot
+	* [r1385] tests/unit/Makefile.am, tests/unit/geom,
+	  tests/unit/geom/TriangleTest.cpp, tests/unit/io,
+	  tests/unit/io/WKBReaderTest.cpp: Adding new Unit Tests.
+2006-04-06 23:35  Sandro Santilli <strk at keybit.net>
+	* [r1384] AUTHORS: Added Mateusz Loskot
+2006-04-06 23:31  mloskot
+	* [r1383] tests/unit/algorithm,
+	  tests/unit/algorithm/PointLocatorTest.cpp: [UT Files Renaming]
+	  Add PointLocatorTest.cpp
+2006-04-06 23:28  mloskot
+	* [r1382] tests/unit/io: [UT Files Renaming] Remove 'io' tests.
+2006-04-06 23:26  mloskot
+	* [r1381] tests/unit/geom: [UT Files Renaming] Remove 'geom' tests.
+2006-04-06 23:25  mloskot
+	* [r1380] tests/unit/algorithm: [UT Files Renaming] Remove file
+	  PointLocator.cpp
+2006-04-06 23:20  mloskot
+	* [r1379] tests/unit/geos_unit.cpp: New version of Unit Test
+	  runner. Now, it's more GNU style compatible
+2006-04-06 22:30  mloskot
+	* [r1378] tests/tut/tut.h, tests/tut/tut_reporter.h: Add inform()
+	  target in tut.h and new callbacks in tut_reporter.h
+2006-04-06 21:31  Sandro Santilli <strk at keybit.net>
+	* [r1377] source/algorithm/LineIntersector.cpp,
+	  source/headers/geos/algorithm/LineIntersector.h: Const
+	  correctness for debugging function
+2006-04-06 21:30  Sandro Santilli <strk at keybit.net>
+	* [r1376] source/headers/geos/util/math.h: Added missing rint_vc()
+	  forward declaration
+2006-04-06 17:33  Sandro Santilli <strk at keybit.net>
+	* [r1375] tests/unit/Makefile.am, tests/unit/index,
+	  tests/unit/index/quadtree,
+	  tests/unit/index/quadtree/DoubleBitsTest.cpp: Added unit test for
+	  DoubleBits
+2006-04-06 14:36  Sandro Santilli <strk at keybit.net>
+	* [r1374] source/headers/geos/precision/CommonBitsOp.h,
+	  source/headers/geos/precision/CommonBitsRemover.h,
+	  source/headers/geos/precision/EnhancedPrecisionOp.h,
+	  source/precision/CommonBitsOp.cpp,
+	  source/precision/CommonBitsRemover.cpp,
+	  source/precision/EnhancedPrecisionOp.cpp: Cleanup in
+	  geos::precision namespace (leaks plugged, auto_ptr use, ...)
+2006-04-06 12:58  Sandro Santilli <strk at keybit.net>
+	* [r1373] source/geomgraph/DirectedEdge.cpp: Added printing of
+	  EdgeRing if available
+2006-04-06 12:48  Sandro Santilli <strk at keybit.net>
+	* [r1372]
+	  source/headers/geos/operation/valid/ConnectedInteriorTester.h:
+	  Added private vector to keep track of allocated MaximalEdgeRings
+	  objects
+2006-04-06 12:47  Sandro Santilli <strk at keybit.net>
+	* [r1371] source/geomgraph/EdgeEnd.cpp: Fixed output function
+2006-04-06 12:45  Sandro Santilli <strk at keybit.net>
+	* [r1370] source/operation/valid/ConnectedInteriorTester.cpp:
+	  Delayed deletion of newly allocated MaximalEdgeRings.
+	  Existing 'valid' operation tests don't should instability with
+	  this patch.
+2006-04-06 12:36  Sandro Santilli <strk at keybit.net>
+	* [r1369] source/geom/PrecisionModel.cpp: removed spurious lines
+	  from previous commi
+2006-04-06 12:34  Sandro Santilli <strk at keybit.net>
+	* [r1368] source/geom/PrecisionModel.cpp,
+	  source/headers/geos/geom/PrecisionModel.h,
+	  source/headers/geos/geom/PrecisionModel.inl: Port info, more
+	  debugging lines, doxygen comments
+2006-04-06 12:33  Sandro Santilli <strk at keybit.net>
+	* [r1367] source/geom/GeometryFactory.cpp: More debugging lines
+2006-04-06 12:29  Sandro Santilli <strk at keybit.net>
+	* [r1366] source/io/WKBReader.cpp: Fixed bogus static
+	  PrecisionModel variable in ::readCoordinate().
+2006-04-06 09:41  Sandro Santilli <strk at keybit.net>
+	* [r1365] source/geomgraph/EdgeRing.cpp,
+	  source/headers/geos/geomgraph/EdgeRing.h: Added operator<<, added
+	  pts!=NULL assertion in testInvariant() function
+2006-04-06 09:39  Sandro Santilli <strk at keybit.net>
+	* [r1364] source/geomgraph/EdgeEnd.cpp,
+	  source/headers/geos/geomgraph/EdgeEnd.h: Added operator<<
+2006-04-06 09:01  Sandro Santilli <strk at keybit.net>
+	* [r1363] source/geomgraph/Label.cpp,
+	  source/geomgraph/TopologyLocation.cpp,
+	  source/headers/geos/geomgraph/Label.h,
+	  source/headers/geos/geomgraph/TopologyLocation.h: Doxygen
+	  comments, port info, operator<<, assertion checking
+2006-04-06 07:52  Sandro Santilli <strk at keybit.net>
+	* [r1362] source/geomgraph/DirectedEdge.cpp: Fixed bug in ::print()
+	  function
+2006-04-05 18:28  Sandro Santilli <strk at keybit.net>
+	* [r1361] source/headers/geos/geomgraph/Edge.h,
+	  source/headers/geos/geomgraph/EdgeRing.h: Moved testInvariant()
+	  methods from private to public, added
+	  some comments about them.
+2006-04-05 15:59  Sandro Santilli <strk at keybit.net>
+	* [r1360] source/operation/overlay/OverlayOp.cpp: Removed dead code
+2006-04-05 14:33  Sandro Santilli <strk at keybit.net>
+	* [r1359] tests/xmltester/markup/MarkupSTL.cpp,
+	  tests/xmltester/markup/MarkupSTL.h: Removed annoying warnings
+	  from external source
+2006-04-05 14:04  Sandro Santilli <strk at keybit.net>
+	* [r1358] source/geom/Envelope.cpp,
+	  source/headers/geos/geom/Envelope.inl: Fixed copy ctor to support
+	  "Null" Envelope copies.
+	  Drop init(Envelope&) method.
+	  Port info and various cleanups.
+2006-04-05 10:25  Sandro Santilli <strk at keybit.net>
+	* [r1357] source/geom/LineString.cpp,
+	  source/headers/geos/geom/LineString.h: Fixed LineString
+	  constructor to ensure deletion of CoordinateSequence
+	  argument on exception throw
+2006-04-05 09:34  Sandro Santilli <strk at keybit.net>
+	* [r1356] source/headers/geos/util/GEOSException.h: GEOSException
+	  derived from std::exception again, hopefully the correct way now
+2006-04-05 09:20  Sandro Santilli <strk at keybit.net>
+	* [r1355]
+	  source/headers/geos/operation/buffer/RightmostEdgeFinder.h,
+	  source/operation/buffer/RightmostEdgeFinder.cpp: Added port
+	  informations and many assertion checking.
+	  Fixed bug in getRightmostSide() method ( a "testing-only" corner
+	  case )
+2006-04-04 16:07  Sandro Santilli <strk at keybit.net>
+	* [r1353] source/geomgraph/DirectedEdgeStar.cpp: More assertion
+	  checking, less overhead when built with NDEBUG defined
+2006-04-04 13:35  Sandro Santilli <strk at keybit.net>
+	* [r1352] source/geomgraph/EdgeEndStar.cpp,
+	  source/headers/geos/geomgraph/EdgeEndStar.h: Port info, assertion
+	  checking, indentation
+2006-04-04 12:39  Sandro Santilli <strk at keybit.net>
+	* [r1351] source/algorithm/LineIntersector.cpp: Changed
+	  NotRepresentableCoordinate exception handler to throw
+	  a TopologyException. This allows further handling.
+2006-04-04 11:37  Sandro Santilli <strk at keybit.net>
+	* [r1350] source/algorithm/HCoordinate.cpp,
+	  source/headers/geos/algorithm/HCoordinate.h: Port information +
+	  initialization lists in ctors
+2006-04-04 11:28  Sandro Santilli <strk at keybit.net>
+	* [r1349] source/algorithm/HCoordinate.cpp: NotRepresentable
+	  condition detected using finite() from <cmath>
+	  rather then using FINITE() macro. Made ::intersection() body
+	  more readable.
+2006-04-04 09:53  Sandro Santilli <strk at keybit.net>
+	* [r1348] source/headers/geos/geom/CoordinateSequence.h: Fixed
+	  applyCoordinateFilter() templated function body
+2006-04-04 08:16  Sandro Santilli <strk at keybit.net>
+	* [r1345] NEWS, doc/example.cpp,
+	  source/algorithm/NotRepresentableException.cpp,
+	  source/examples/CPCLException.cpp,
+	  source/examples/CustomCoordinateSequenceExample.cpp,
+	  source/examples/CustomCoordinateSequenceExample.h,
+	  source/headers/geos/io/ParseException.h,
+	  source/headers/geos/util/GEOSException.h,
+	  source/headers/geos/util/IllegalArgumentException.h,
+	  source/io/ParseException.cpp,
+	  source/operation/overlay/ElevationMatrix.cpp,
+	  source/util/GEOSException.cpp: Changed GEOSException hierarchy to
+	  be derived from std::runtime_exception.
+	  Removed the GEOSException::toString redundant method (use
+	  ::what() instead)
+2006-04-04 01:54  hobu
+	* [r1344] source/Makefile.vc: Add in changes/missing from previous
+	  rearranging.
+2006-04-04 01:29  hobu
+	* [r1343] capi/geos_c.cpp: GEOS_JTS_PORT is in version.h not
+	  platform.h
+2006-04-04 01:28  hobu
+	* [r1342] source/Makefile.vc: remove objects that no longer exist
+	  default to MSVC_VER=1310
+2006-04-03 17:05  Sandro Santilli <strk at keybit.net>
+	* [r1341] source/geomgraph/DirectedEdge.cpp,
+	  source/geomgraph/EdgeEnd.cpp, source/geomgraph/Label.cpp,
+	  source/headers/geos/geomgraph/EdgeEnd.h: Assertion checking, port
+	  info, cleanups
+2006-04-03 15:54  Sandro Santilli <strk at keybit.net>
+	* [r1340] source/headers/geos/operation/GeometryGraphOperation.h,
+	  source/operation/GeometryGraphOperation.cpp: - getArgGeometry()
+	  parameter type changed from 'int' to 'unsigned int'
+	  - Added port informations
+	  - minor assertions checking
+	  - minor cleanups
+2006-04-03 14:07  Sandro Santilli <strk at keybit.net>
+	* [r1339] source/headers/geos/geom/PrecisionModel.h: Commented out
+	  obsoleted toInternal() method
+2006-04-03 13:58  Sandro Santilli <strk at keybit.net>
+	* [r1337] macros/ac_pkg_swig.m4, macros/ac_python_devel.m4,
+	  swig/geos.i, swig/python/Makefile.am, swig/python/python.i,
+	  swig/ruby/ruby.i, swig/ruby/test/geos_tests.rb,
+	  swig/ruby/test/test_helper.rb: Applied patch by Charlie Savage:
+	  - Fixes up the SWIG bindings to use the new GEOS namespaces
+	  - Fixes a bug in the Python m4 macro
+	  - Adds the -modern flag for SWIG when compiling a Python
+	  extension
+2006-04-03 13:56  Sandro Santilli <strk at keybit.net>
+	* [r1336]
+	  source/headers/geos/precision/SimpleGeometryPrecisionReducer.h,
+	  source/precision/SimpleGeometryPrecisionReducer.cpp: Made
+	  externally-owned PrecisionModel const
+2006-04-03 10:56  Sandro Santilli <strk at keybit.net>
+	* [r1334] source/geom/CoordinateSequenceFactory.cpp,
+	  source/geom/Makefile.am,
+	  source/geom/util/LinearComponentExtracter.cpp,
+	  source/geom/util/PointExtracter.cpp,
+	  source/geom/util/PolygonExtracter.cpp,
+	  source/util/AssertionFailedException.cpp,
+	  source/util/IllegalArgumentException.cpp,
+	  source/util/UnsupportedOperationException.cpp: Removed
+	  implementation files build spec for fully-inlined classes
+2006-04-03 10:44  Sandro Santilli <strk at keybit.net>
+	* [r1333] source/index/strtree/STRtree.cpp,
+	  source/noding/snapround/MCIndexSnapRounder.cpp: Added missing
+	  headers
+2006-04-03 10:16  Sandro Santilli <strk at keybit.net>
+	* [r1332] configure.in, source/Makefile.am,
+	  source/headers/geos/Makefile.am, source/headers/geos/simplify,
+	  source/headers/geos/simplify/.cvsignore,
+	  source/headers/geos/simplify/Makefile.am, source/simplify,
+	  source/simplify/.cvsignore,
+	  source/simplify/DouglasPeuckerLineSimplifier.cpp,
+	  source/simplify/Makefile.am: DouglasPeuckerLineSimplifier class
+	  port
+2006-04-03 08:43  Sandro Santilli <strk at keybit.net>
+	* [r1331] source/headers/geos/index/strtree/STRtree.h,
+	  source/index/strtree/STRtree.cpp: Added port info, minor cleanups
+2006-04-03 08:29  Sandro Santilli <strk at keybit.net>
+	* [r1330] source/headers/geos/index/quadtree/Quadtree.h,
+	  source/index/quadtree/Quadtree.cpp: Added port info, cleaned up
+	  log message, minor assertion checking.
+2006-03-31 17:51  Sandro Santilli <strk at keybit.net>
+	* [r1329] source/geom/GeometryFactory.cpp,
+	  source/headers/geos/geom/GeometryFactory.h: A few assertion
+	  checking, comments cleanup, use of initialization lists
+	  in constructors, handled NULL parameters.
+2006-03-31 16:55  Sandro Santilli <strk at keybit.net>
+	* [r1328] NEWS, source/geom/LineString.cpp,
+	  source/headers/geos/geom/LineString.h: Added many assertions
+	  checking in LineString implementation.
+	  Changed ::getCoordinate() to return NULL on empty geom.
+	  Changed ::get{Start,End}Point() to return NULL on empty geom.
+2006-03-31 16:53  Sandro Santilli <strk at keybit.net>
+	* [r1327] source/headers/geos/geom/Geometry.h: Added comment about
+	  possible NULL return from getCoordinate()
+2006-03-31 11:03  Sandro Santilli <strk at keybit.net>
+	* [r1325] source/geom/Geometry.cpp: Fixed NULL-GeometryFactory
+	  constructor to use INTERNAL_GEOMETRY_FACTORY
+	  (should fix bug #81)
+2006-03-30 09:26  Sandro Santilli <strk at keybit.net>
+	* [r1324] source/headers/geos/io/WKTReader.h: minor cleanup
+2006-03-29 15:48  Sandro Santilli <strk at keybit.net>
+	* [r1323] capi/geos_c.cpp: Added missing 'const' in catch
+	  std::exception statements
+2006-03-29 15:23  Sandro Santilli <strk at keybit.net>
+	* [r1322] source/geomgraph/DirectedEdge.cpp,
+	  source/headers/geos/geomgraph/GeometryGraph.h,
+	  source/headers/geos/geomgraph/GeometryGraph.inl,
+	  source/headers/geos/geomgraph/Makefile.am: Moved GeometryGraph
+	  inlines from .h to .inl file
+2006-03-29 14:34  Sandro Santilli <strk at keybit.net>
+	* [r1321] tests/xmltester/TestValid.xml: Sync'ed testfile with JTS
+	  head
+2006-03-29 14:31  Sandro Santilli <strk at keybit.net>
+	* [r1320] tests/unit/Makefile.am, tests/unit/algorithm,
+	  tests/unit/algorithm/PointLocator.cpp,
+	  tests/unit/io/WKBReader.cpp: Added PointLocator unit test
+2006-03-29 13:53  Sandro Santilli <strk at keybit.net>
+	* [r1319] source/geomgraph/EdgeRing.cpp,
+	  source/headers/geos/geomgraph/EdgeRing.h,
+	  source/headers/geos/operation/valid/IsValidOp.h,
+	  source/operation/valid/ConnectedInteriorTester.cpp,
+	  source/operation/valid/IsValidOp.cpp: EdgeRing equipped with
+	  Invariant testing function and lots of exceptional assertions.
+	  Removed useless heap allocations, and pointers usages.
+2006-03-29 11:52  Sandro Santilli <strk at keybit.net>
+	* [r1318] source/algorithm/MCPointInRing.cpp,
+	  source/headers/geos/algorithm/MCPointInRing.h: const correctness,
+	  useless heap allocations removal
+2006-03-29 11:48  Sandro Santilli <strk at keybit.net>
+	* [r1317]
+	  source/headers/geos/operation/valid/QuadtreeNestedRingTester.h,
+	  source/operation/valid/QuadtreeNestedRingTester.cpp: Removed
+	  useless heap allocations in construction, enforced const
+	  correctness
+2006-03-28 16:49  Sandro Santilli <strk at keybit.net>
+	* [r1316] source/io/WKBReader.cpp: Reintroduced rewind of input
+	  parameter in printHEX() [dropped by prev commit]
+2006-03-28 16:33  Sandro Santilli <strk at keybit.net>
+	* [r1315] source/headers/geos/geom/GeometryFactory.h: Added note
+	  about args responsibility in GeometryFactory constructor
+2006-03-28 16:11  Sandro Santilli <strk at keybit.net>
+	* [r1314] tests/unit/io/WKBReader.cpp: swapped assert_equals() args
+	  to get obtained/expected the right way.
+2006-03-28 15:27  Sandro Santilli <strk at keybit.net>
+	* [r1313] source/io/WKBReader.cpp: Simplified printHEX()
+	  implementation
+2006-03-28 15:19  Sandro Santilli <strk at keybit.net>
+	* [r1312] doc/example.cpp: Added macros for sections skip (useful
+	  in debugging)
+2006-03-28 14:45  Sandro Santilli <strk at keybit.net>
+	* [r1311] tests/unit/Makefile.am, tests/unit/io,
+	  tests/unit/io/WKBReader.cpp: Added simple test for WKB reader.
+2006-03-28 14:02  Sandro Santilli <strk at keybit.net>
+	* [r1310] source/io/WKBReader.cpp: added missing header for
+	  non-inlined builds
+2006-03-28 14:01  Sandro Santilli <strk at keybit.net>
+	* [r1309] source/io/ByteOrderDataInStream.cpp: forgot to add in
+	  previous commit
+2006-03-28 11:26  Sandro Santilli <strk at keybit.net>
+	* [r1308] source/headers/geos/io/ByteOrderDataInStream.h,
+	  source/headers/geos/io/ByteOrderDataInStream.inl,
+	  source/headers/geos/io/WKBWriter.h, source/io/Makefile.am:
+	  ByteOrderDataInStream inlines moved to .inl file, updated
+	  implementation files includes.
+2006-03-28 11:25  Sandro Santilli <strk at keybit.net>
+	* [r1307] source/io/WKBWriter.cpp: Assertion checking
+2006-03-28 09:14  Sandro Santilli <strk at keybit.net>
+	* [r1306] source/headers/geos/geom/LineSegment.h,
+	  source/headers/geos/geom/LineSegment.inl: Headers inclusion fix.
+2006-03-28 08:57  Sandro Santilli <strk at keybit.net>
+	* [r1305] source/headers/geos/geom/PrecisionModel.h,
+	  source/headers/geos/geom/PrecisionModel.inl: Comments cleanup,
+	  system headers included after project headers
+2006-03-28 08:40  Sandro Santilli <strk at keybit.net>
+	* [r1304] configure.in: C-API lib version bumped to 1.1.1 (release
+	  2.2.2 will ship 1.1.0)
+2006-03-27 17:59  Sandro Santilli <strk at keybit.net>
+	* [r1302] source/operation/buffer/OffsetCurveBuilder.cpp: Fixed
+	  small leak.
+2006-03-27 17:04  Sandro Santilli <strk at keybit.net>
+	* [r1301]
+	  source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
+	  source/operation/buffer/OffsetCurveBuilder.cpp,
+	  source/operation/buffer/OffsetCurveSetBuilder.cpp: Cleanups and
+	  explicit initializations
+2006-03-27 16:02  Sandro Santilli <strk at keybit.net>
+	* [r1300] source/geomgraph/EdgeRing.cpp,
+	  source/headers/geos/operation/overlay/MaximalEdgeRing.h,
+	  source/headers/geos/operation/overlay/MinimalEdgeRing.h,
+	  source/headers/geos/operation/overlay/MinimalEdgeRing.inl,
+	  source/operation/overlay/MaximalEdgeRing.cpp,
+	  source/operation/overlay/MinimalEdgeRing.cpp,
+	  source/operation/valid/ConnectedInteriorTester.cpp: Added INL
+	  file for MinimalEdgeRing, added many debugging blocks,
+	  fixed memory leak in ConnectedInteriorTester (bug #59)
+2006-03-27 15:57  Sandro Santilli <strk at keybit.net>
+	* [r1299] source/headers/geos/geom/Coordinate.h,
+	  source/headers/geos/geom/Coordinate.inl: Commented need for
+	  platform.h include
+2006-03-27 15:56  Sandro Santilli <strk at keybit.net>
+	* [r1298] source/geom/Coordinate.cpp: Added missing platform.h
+	  include (for ISNAN macro)
+2006-03-27 14:20  Sandro Santilli <strk at keybit.net>
+	* [r1297]
+	  source/headers/geos/operation/valid/ConnectedInteriorTester.h,
+	  paranoid assertion checking and a note in header about
+	  responsibility of return from buildMaximalEdgeRings()
+2006-03-27 10:37  Sandro Santilli <strk at keybit.net>
+	* [r1296]
+	  source/headers/geos/operation/valid/ConsistentAreaTester.h,
+	  source/operation/valid/ConsistentAreaTester.cpp: Reduced heap
+	  allocations and probability of error by making LineIntersector
+	  and RelateNodeGraph part of ConsistentAreaTester class .
+2006-03-27 10:36  Sandro Santilli <strk at keybit.net>
+	* [r1295] source/operation/valid/TopologyValidationError.cpp: added
+	  missing space in exception message
+2006-03-27 10:34  Sandro Santilli <strk at keybit.net>
+	* [r1294] source/headers/geos/geom/Coordinate.inl: moved external
+	  includes after internal ones
+2006-03-27 09:50  Sandro Santilli <strk at keybit.net>
+	* [r1293] tests/xmltester/Makefile.am,
+	  tests/xmltester/TestValid2-big.xml: Added final isValid test from
+	  JTS (floating version)
+2006-03-27 09:48  Sandro Santilli <strk at keybit.net>
+	* [r1292] tests/xmltester/Makefile.am,
+	  tests/xmltester/TestValid2.xml, tests/xmltester/testLeaksBig.xml:
+	  Extracted TestValid2.xml from testLeaksBig.xml (target file is
+	  taken from JTS source tree)
+2006-03-27 09:45  Sandro Santilli <strk at keybit.net>
+	* [r1291] tests/xmltester/Makefile.am,
+	  tests/xmltester/TestValid.xml, tests/xmltester/testLeaksBig.xml:
+	  Added TestValid.xml test, taken from JTS source tree, already
+	  present in testLeaksBig (from which tests were removed)
+2006-03-27 09:28  Sandro Santilli <strk at keybit.net>
+	* [r1290] NEWS: added namespaces use and headers split
+2006-03-27 09:05  Sandro Santilli <strk at keybit.net>
+	* [r1289] capi/geos_c.h.in: Added note about responsibility of
+	  return from GEOSGeomType()
+2006-03-27 09:00  Sandro Santilli <strk at keybit.net>
+	* [r1288] source/geom/CoordinateArraySequence.cpp: Bug #79 - Small
+	  fix in CoordinateArraySequence::toString()
+2006-03-24 11:42  Sandro Santilli <strk at keybit.net>
+	* [r1287] configure.in: reverted default of assertion checking
+2006-03-24 11:11  Sandro Santilli <strk at keybit.net>
+	* [r1286] TODO, configure.in, tools/geos-config.in: Inlining
+	  enabled by default, assertion checking disabled by default.
+	  Added --enable-cassert and --disable-inline configure switches.
+	  Had geos-config --cflags output appropriate inline flag if
+	  required (-DGEOS_INLINE)
+2006-03-24 11:04  Sandro Santilli <strk at keybit.net>
+	* [r1285] source/operation/linemerge/LineSequencer.cpp: Changed
+	  assert() with Assert::isTrue in addReverseSubpath
+2006-03-24 10:44  Sandro Santilli <strk at keybit.net>
+	* [r1284] source/operation/linemerge/LineSequencer.cpp: Fixed to
+	  build with -DNDEBUG
+2006-03-24 09:52  Sandro Santilli <strk at keybit.net>
+	* [r1283] TODO, capi/geos_c.cpp.bak,
+	  source/algorithm/ConvexHull.cpp, source/geom/Coordinate.cpp,
+	  source/geom/CoordinateArraySequenceFactory.cpp,
+	  source/geom/Envelope.cpp, source/geom/Geometry.cpp,
+	  source/geom/GeometryFactory.cpp, source/geom/LineSegment.cpp,
+	  source/geom/MultiLineString.cpp, source/geom/MultiPolygon.cpp,
+	  source/geom/PrecisionModel.cpp,
+	  source/geomgraph/DirectedEdge.cpp,
+	  source/headers/geos/algorithm/ConvexHull.h,
+	  source/headers/geos/geom/Coordinate.h,
+	  source/headers/geos/geom/CoordinateArraySequence.h,
+	  source/headers/geos/geom/CoordinateArraySequenceFactory.h,
+	  source/headers/geos/geom/CoordinateFilter.h,
+	  source/headers/geos/geom/CoordinateSequence.h,
+	  source/headers/geos/geom/CoordinateSequenceFactory.h,
+	  source/headers/geos/geom/GeometryFilter.h,
+	  source/headers/geos/geom/LineSegment.h,
+	  source/headers/geos/geom/Location.h,
+	  source/headers/geos/geom/Polygon.h,
+	  source/headers/geos/geom/Triangle.h,
+	  source/headers/geos/geom/util/CoordinateOperation.h,
+	  source/headers/geos/geom/util/GeometryEditor.h,
+	  source/headers/geos/geom/util/GeometryEditorOperation.h,
+	  source/headers/geos/geom/util/ShortCircuitedGeometryVisitor.h,
+	  source/headers/geos/geomgraph/Depth.h,
+	  source/headers/geos/geomgraph/DirectedEdge.h,
+	  source/headers/geos/geomgraph/DirectedEdgeStar.h,
+	  source/headers/geos/geomgraph/Edge.h,
+	  source/headers/geos/geomgraph/EdgeEnd.h,
+	  source/headers/geos/geomgraph/EdgeEndStar.h,
+	  source/headers/geos/geomgraph/EdgeIntersection.h,
+	  source/headers/geos/geomgraph/EdgeIntersectionList.h,
+	  source/headers/geos/geomgraph/EdgeList.h,
+	  source/headers/geos/geomgraph/EdgeNodingValidator.h,
+	  source/headers/geos/geomgraph/GraphComponent.h,
+	  source/headers/geos/geomgraph/Node.h,
+	  source/headers/geos/geomgraph/NodeFactory.h,
+	  source/headers/geos/geomgraph/NodeMap.h,
+	  source/headers/geos/geomgraph/PlanarGraph.h,
+	  source/headers/geos/geomgraph/Position.h,
+	  source/headers/geos/geomgraph/Quadrant.h,
+	  source/headers/geos/geomgraph/TopologyLocation.h,
+	  source/headers/geos/inline.h, source/headers/geos/io/WKTReader.h,
+	  source/headers/geos/noding/IntersectionAdder.h,
+	  source/headers/geos/noding/IntersectionFinderAdder.h,
+	  source/headers/geos/noding/IteratedNoder.h,
+	  source/headers/geos/noding/MCIndexNoder.h,
+	  source/headers/geos/noding/Noder.h,
+	  source/headers/geos/noding/NodingValidator.h,
+	  source/headers/geos/noding/Octant.h,
+	  source/headers/geos/noding/ScaledNoder.h,
+	  source/headers/geos/noding/SegmentIntersector.h,
+	  source/headers/geos/noding/SegmentNode.h,
+	  source/headers/geos/noding/SegmentNodeList.h,
+	  source/headers/geos/noding/SegmentString.h,
+	  source/headers/geos/noding/SimpleNoder.h,
+	  source/headers/geos/noding/SinglePassNoder.h,
+	  source/headers/geos/noding/snapround/HotPixel.h,
+	  source/headers/geos/noding/snapround/MCIndexPointSnapper.h,
+	  source/headers/geos/noding/snapround/MCIndexSnapRounder.h,
+	  source/headers/geos/noding/snapround/SimpleSnapRounder.h,
+	  source/io/WKTReader.cpp, source/noding/MCIndexNoder.cpp,
+	  source/noding/SegmentString.cpp,
+	  source/noding/snapround/HotPixel.cpp,
+	  source/noding/snapround/MCIndexSnapRounder.cpp,
+	  source/operation/distance/DistanceOp.cpp: USE_INLINE =>
+	  GEOS_INLINE
+2006-03-24 09:26  Sandro Santilli <strk at keybit.net>
+	* [r1282] capi/geos_c.cpp: Bug #77 - Missing platform.h
+2006-03-24 09:25  Sandro Santilli <strk at keybit.net>
+	* [r1281] source/noding/snapround/MCIndexPointSnapper.cpp,
+	  source/operation/buffer/BufferBuilder.cpp: Bugs #77 and #76:
+	  missing <algorithm>
+2006-03-24 09:23  Sandro Santilli <strk at keybit.net>
+	* [r1280] tests/unit/geos_unit.cpp: Bug #78 - Small fixes and
+	  cleaning
+2006-03-23 15:10  Sandro Santilli <strk at keybit.net>
+	* [r1278] source/geom/Coordinate.cpp,
+	  source/geomgraph/DirectedEdgeStar.cpp,
+	  source/geomgraph/EdgeEndStar.cpp, source/geomgraph/EdgeRing.cpp,
+	  source/headers/geos/geomgraph/DirectedEdge.inl,
+	  source/headers/geos/util/TopologyException.h,
+	  source/operation/overlay/OverlayOp.cpp: Dropped by-pointer
+	  TopologyException constructor, various small cleanups
+2006-03-23 13:31  Sandro Santilli <strk at keybit.net>
+	* [r1277] source/geomgraph/Edge.cpp,
+	  source/geomgraph/EdgeIntersectionList.cpp,
+	  source/geomgraph/index/SegmentIntersector.cpp,
+	  source/index/chain/MonotoneChainBuilder.cpp,
+	  source/index/quadtree/Node.cpp,
+	  source/index/quadtree/NodeBase.cpp,
+	  source/index/quadtree/Quadtree.cpp: Fixed to allow build with
+	  GEOS_DEBUG
+2006-03-23 12:12  Sandro Santilli <strk at keybit.net>
+	* [r1276] source/geom/Geometry.cpp,
+	  source/headers/geos/geom/Geometry.h,
+	  source/headers/geos/geom/Geometry.inl,
+	  source/headers/geos/geom/GeometryCollection.inl,
+	  source/headers/geos/geom/MultiLineString.inl,
+	  source/headers/geos/geom/MultiPolygon.inl,
+	  source/operation/distance/DistanceOp.cpp: Fixes to allow build
+	  with -DUSE_INLINE
+2006-03-23 10:55  Sandro Santilli <strk at keybit.net>
+	* [r1275] Makefile.am, configure.in: Temporarly excluded 'swig'
+	  extension from distribution, to allow for
+	  successufull 'dist' rule and distributed testing.
+2006-03-23 10:41  Sandro Santilli <strk at keybit.net>
+	* [r1274] source/headers/geos/Makefile.am,
+	  source/headers/geos/operation/relate/Makefile.am: Fixed automake
+	  files
+2006-03-23 10:09  Sandro Santilli <strk at keybit.net>
+	* [r1273] source/headers/geos/operation/predicate/Makefile.am:
+	  Fixed missing backslash
+2006-03-23 09:17  Sandro Santilli <strk at keybit.net>
+	* [r1272] configure.in, source/headers/geos/Makefile.am,
+	  source/headers/geos/precision, source/headers/geos/precision.h,
+	  source/headers/geos/precision/.cvsignore,
+	  source/headers/geos/precision/CommonBits.h,
+	  source/headers/geos/precision/CommonBitsOp.h,
+	  source/headers/geos/precision/Makefile.am,
+	  source/operation/buffer/BufferOp.cpp,
+	  source/operation/overlay/OverlayOp.cpp,
+	  source/precision/CommonBits.cpp,
+	  source/precision/EnhancedPrecisionOp.cpp,
+	  source/precision/SimpleGeometryPrecisionReducer.cpp: precision.h
+	  header split, minor optimizations
+2006-03-22 18:12  Sandro Santilli <strk at keybit.net>
+	* [r1271] configure.in, source/algorithm/MCPointInRing.cpp,
+	  source/geom/LineSegment.cpp,
+	  source/headers/geos/algorithm/MCPointInRing.h,
+	  source/headers/geos/index/Makefile.am,
+	  source/headers/geos/index/chain,
+	  source/headers/geos/index/chain/.cvsignore,
+	  source/headers/geos/index/chain/Makefile.am,
+	  source/headers/geos/index/chain/MonotoneChain.h,
+	  source/headers/geos/index/chain/MonotoneChainBuilder.h,
+	  source/headers/geos/index/chain/MonotoneChainOverlapAction.h,
+	  source/headers/geos/index/chain/MonotoneChainSelectAction.h,
+	  source/headers/geos/indexChain.h,
+	  source/index/bintree/NodeBase.cpp,
+	  source/index/chain/Makefile.am,
+	  source/index/chain/MonotoneChain.cpp,
+	  source/index/chain/MonotoneChainOverlapAction.cpp,
+	  source/index/chain/MonotoneChainSelectAction.cpp,
+	  source/index/chain/indexMonotoneChain.cpp,
+	  source/noding/MCIndexNoder.cpp,
+	  source/noding/snapround/MCIndexPointSnapper.cpp,
+	  source/operation/buffer/BufferBuilder.cpp,
+	  source/operation/valid/IsValidOp.cpp: indexChain.h header split.
+2006-03-22 16:59  Sandro Santilli <strk at keybit.net>
+	* [r1270] source/headers/geos/geosAlgorithm.h: cleaned up
+2006-03-22 16:58  Sandro Santilli <strk at keybit.net>
+	* [r1269] source/geom/CoordinateArraySequence.cpp,
+	  source/geom/CoordinateList.cpp,
+	  source/geom/CoordinateSequence.cpp, source/geom/Dimension.cpp,
+	  source/geom/GeometryCollectionIterator.cpp,
+	  source/geom/GeometryComponentFilter.cpp,
+	  source/geom/IntersectionMatrix.cpp, source/geom/LineSegment.cpp,
+	  source/geom/LineString.cpp, source/geom/Location.cpp,
+	  source/geom/Makefile.am, source/geom/MultiPoint.cpp,
+	  source/geom/MultiPolygon.cpp, source/geom/Point.cpp,
+	  source/geom/TopologyException.cpp, source/geom/Triangle.cpp,
+	  source/geom/util/ShortCircuitedGeometryVisitor.cpp,
+	  source/headers/geos/io/WKTWriter.h, source/io/WKBReader.cpp,
+	  source/io/WKBWriter.cpp, source/io/WKTReader.cpp,
+	  source/io/WKTWriter.cpp, source/util/CoordinateArrayFiter.cpp,
+	  source/util/GeometricShapeFactory.cpp,
+	  source/util/UniqueCoordinateArrayFilter.cpp: Removed (almost) all
+	  inclusions of geom.h.
+	  Removed obsoleted .cpp files.
+	  Fixed a bug in WKTReader not using the provided
+	  implementation, optimized out some memory allocations.
+2006-03-22 16:01  Sandro Santilli <strk at keybit.net>
+	* [r1268] configure.in, source/algorithm/MCPointInRing.cpp,
+	  source/headers/geos/index/bintree,
+	  source/headers/geos/index/bintree/.cvsignore,
+	  source/headers/geos/index/bintree/Bintree.h,
+	  source/headers/geos/index/bintree/Interval.h,
+	  source/headers/geos/index/bintree/Key.h,
+	  source/headers/geos/index/bintree/Makefile.am,
+	  source/headers/geos/index/bintree/Node.h,
+	  source/headers/geos/index/bintree/NodeBase.h,
+	  source/headers/geos/index/bintree/Root.h,
+	  source/headers/geos/indexBintree.h,
+	  source/index/bintree/BinTreeInterval.cpp,
+	  source/index/bintree/BinTreeNode.cpp,
+	  source/index/bintree/Bintree.cpp,
+	  source/index/bintree/Interval.cpp, source/index/bintree/Key.cpp,
+	  source/index/bintree/Makefile.am, source/index/bintree/Node.cpp,
+	  source/index/bintree/NodeBase.cpp, source/index/bintree/Root.cpp,
+	  tests/xmltester/XMLTester.cpp: indexBintree.h header split,
+	  classes renamed to match JTS
+2006-03-22 14:28  Sandro Santilli <strk at keybit.net>
+	* [r1267] source/index/quadtree/Key.cpp,
+	  source/index/quadtree/Makefile.am,
+	  source/index/quadtree/QuadTreeKey.cpp,
+	  source/index/quadtree/QuadTreeNode.cpp,
+	  source/index/quadtree/QuadTreeNodeBase.cpp,
+	  source/index/quadtree/QuadTreeRoot.cpp,
+	  source/index/quadtree/Root.cpp: Filenames renamed to match class
+	  names (matching JTS)
+2006-03-22 12:22  Sandro Santilli <strk at keybit.net>
+	* [r1266] configure.in, source/geomgraph/EdgeList.cpp,
+	  source/headers/geos/index/quadtree,
+	  source/headers/geos/index/quadtree/.cvsignore,
+	  source/headers/geos/index/quadtree/DoubleBits.h,
+	  source/headers/geos/index/quadtree/IntervalSize.h,
+	  source/headers/geos/index/quadtree/Key.h,
+	  source/headers/geos/index/quadtree/Makefile.am,
+	  source/headers/geos/index/quadtree/Node.h,
+	  source/headers/geos/index/quadtree/NodeBase.h,
+	  source/headers/geos/index/quadtree/Quadtree.h,
+	  source/headers/geos/index/quadtree/Root.h,
+	  source/headers/geos/indexQuadtree.h,
+	  source/index/bintree/Key.cpp, source/index/bintree/Root.cpp,
+	  source/index/quadtree/DoubleBits.cpp,
+	  source/index/quadtree/IntervalSize.cpp,
+	  source/index/quadtree/Quadtree.cpp,
+	  indexQuadtree.h split
+2006-03-22 11:19  Sandro Santilli <strk at keybit.net>
+	* [r1265] capi/geos_c.cpp, configure.in,
+	  source/headers/geos/opPolygonize.h,
+	  source/headers/geos/operation/Makefile.am,
+	  source/headers/geos/operation/polygonize,
+	  source/headers/geos/operation/polygonize/.cvsignore,
+	  source/headers/geos/operation/polygonize/Makefile.am,
+	  source/headers/geos/operation/polygonize/PolygonizeDirectedEdge.h,
+	  source/headers/geos/operation/polygonize/PolygonizeEdge.h,
+	  source/headers/geos/operation/polygonize/PolygonizeGraph.h,
+	  source/headers/geos/operation/polygonize/Polygonizer.h,
+	  source/operation/polygonize/PolygonizeDirectedEdge.cpp,
+	  source/operation/polygonize/PolygonizeEdge.cpp,
+	  source/operation/polygonize/PolygonizeGraph.cpp,
+	  source/operation/polygonize/Polygonizer.cpp,
+	  opPolygonize.h headers split.
+2006-03-22 11:18  Sandro Santilli <strk at keybit.net>
+	* [r1264] source/operation/buffer/BufferSubgraph.cpp,
+	  source/operation/buffer/OffsetCurveSetBuilder.cpp: Changed back
+	  'unable to find edge to compute depths' from assertion to
+	  TopologyException
+2006-03-22 10:13  Sandro Santilli <strk at keybit.net>
+	* [r1263] capi/geos_c.cpp, configure.in,
+	  source/headers/geos/opLinemerge.h,
+	  source/headers/geos/operation/linemerge,
+	  source/headers/geos/operation/linemerge/.cvsignore,
+	  source/headers/geos/operation/linemerge/EdgeString.h,
+	  source/headers/geos/operation/linemerge/LineMergeDirectedEdge.h,
+	  source/headers/geos/operation/linemerge/LineMergeEdge.h,
+	  source/headers/geos/operation/linemerge/LineMergeGraph.h,
+	  source/headers/geos/operation/linemerge/LineMerger.h,
+	  source/headers/geos/operation/linemerge/LineSequencer.h,
+	  source/headers/geos/operation/linemerge/Makefile.am,
+	  source/operation/linemerge/EdgeString.cpp,
+	  source/operation/linemerge/LineMergeDirectedEdge.cpp,
+	  source/operation/linemerge/LineMergeEdge.cpp,
+	  source/operation/linemerge/LineMergeGraph.cpp,
+	  source/operation/linemerge/LineMerger.cpp,
+	  source/operation/linemerge/LineSequencer.cpp: opLinemerge.h split
+2006-03-21 21:42  Sandro Santilli <strk at keybit.net>
+	* [r1262] configure.in, source/headers/geos/Makefile.am,
+	  source/headers/geos/planargraph,
+	  source/headers/geos/planargraph.h,
+	  source/headers/geos/planargraph/.cvsignore,
+	  source/headers/geos/planargraph/DirectedEdge.h,
+	  source/headers/geos/planargraph/DirectedEdgeStar.h,
+	  source/headers/geos/planargraph/Edge.h,
+	  source/headers/geos/planargraph/GraphComponent.h,
+	  source/headers/geos/planargraph/Makefile.am,
+	  source/headers/geos/planargraph/Node.h,
+	  source/headers/geos/planargraph/NodeMap.h,
+	  source/headers/geos/planargraph/PlanarGraph.h,
+	  source/headers/geos/planargraph/Subgraph.h,
+	  source/headers/geos/planargraph/algorithm,
+	  source/headers/geos/planargraph/algorithm/.cvsignore,
+	  source/headers/geos/planargraph/algorithm/ConnectedSubgraphFinder.h,
+	  source/headers/geos/planargraph/algorithm/Makefile.am,
+	  source/operation/GeometryGraphOperation.cpp,
+	  source/operation/IsSimpleOp.cpp,
+	  source/operation/linemerge/LineSequencer.cpp,
+	  source/operation/polygonize/polygonizeEdgeRing.cpp,
+	  source/planargraph/DirectedEdge.cpp,
+	  source/planargraph/DirectedEdgeStar.cpp,
+	  source/planargraph/Edge.cpp, source/planargraph/Makefile.am,
+	  source/planargraph/Node.cpp, source/planargraph/NodeMap.cpp,
+	  source/planargraph/PlanarGraph.cpp,
+	  source/planargraph/Subgraph.cpp,
+	  source/planargraph/algorithm/ConnectedSubgraphFinder.cpp,
+	  source/planargraph/planarDirectedEdge.cpp,
+	  source/planargraph/planarDirectedEdgeStar.cpp,
+	  source/planargraph/planarEdge.cpp,
+	  source/planargraph/planarGraphComponent.cpp,
+	  source/planargraph/planarNode.cpp,
+	  source/planargraph/planarNodeMap.cpp,
+	  source/planargraph/planarPlanarGraph.cpp,
+	  source/planargraph/planarSubgraph.cpp: planargraph.h header
+	  split, planargraph:: classes renamed to match JTS symbols
+2006-03-21 17:55  Sandro Santilli <strk at keybit.net>
+	* [r1261] configure.in, source/geom/Geometry.cpp,
+	  source/headers/geos/opDistance.h,
+	  source/headers/geos/opOverlay.h, source/headers/geos/opRelate.h,
+	  source/headers/geos/opValid.h, source/headers/geos/operation.h,
+	  source/headers/geos/operation/distance,
+	  source/headers/geos/operation/distance/.cvsignore,
+	  source/headers/geos/operation/distance/ConnectedElementLocationFilter.h,
+	  source/headers/geos/operation/distance/ConnectedElementPointFilter.h,
+	  source/headers/geos/operation/distance/DistanceOp.h,
+	  source/headers/geos/operation/distance/GeometryLocation.h,
+	  source/headers/geos/operation/distance/Makefile.am,
+	  source/operation/distance/ConnectedElementLocationFilter.cpp,
+	  source/operation/distance/ConnectedElementPointFilter.cpp,
+	  source/operation/distance/DistanceOp.cpp,
+	  source/operation/distance/GeometryLocation.cpp: opDistance.h
+	  header split
+2006-03-21 17:11  Sandro Santilli <strk at keybit.net>
+	* [r1260] configure.in, source/geom/Geometry.cpp,
+	  source/headers/geos/opPredicate.h,
+	  source/headers/geos/operation/predicate,
+	  source/headers/geos/operation/predicate/.cvsignore,
+	  source/headers/geos/operation/predicate/Makefile.am,
+	  source/headers/geos/operation/predicate/RectangleContains.h,
+	  source/headers/geos/operation/predicate/SegmentIntersectionTester.h,
+	  source/operation/predicate/RectangleContains.cpp,
+	  source/operation/predicate/RectangleIntersects.cpp,
+	  source/operation/predicate/SegmentIntersectionTester.cpp:
+	  opPredicate.h header split
+2006-03-21 13:11  Sandro Santilli <strk at keybit.net>
+	* [r1259] configure.in, source/geom/Geometry.cpp,
+	  source/headers/geos/opRelate.h,
+	  source/headers/geos/operation/relate,
+	  source/headers/geos/operation/relate/.cvsignore,
+	  source/headers/geos/operation/relate/EdgeEndBuilder.h,
+	  source/headers/geos/operation/relate/EdgeEndBundle.h,
+	  source/headers/geos/operation/relate/EdgeEndBundleStar.h,
+	  source/headers/geos/operation/relate/Makefile.am,
+	  source/headers/geos/operation/relate/RelateComputer.h,
+	  source/headers/geos/operation/relate/RelateNode.h,
+	  source/headers/geos/operation/relate/RelateNodeFactory.h,
+	  source/headers/geos/operation/relate/RelateNodeGraph.h,
+	  source/headers/geos/operation/relate/RelateOp.h,
+	  source/operation/relate/EdgeEndBuilder.cpp,
+	  source/operation/relate/EdgeEndBundle.cpp,
+	  source/operation/relate/EdgeEndBundleStar.cpp,
+	  source/operation/relate/RelateComputer.cpp,
+	  source/operation/relate/RelateNode.cpp,
+	  source/operation/relate/RelateNodeFactory.cpp,
+	  source/operation/relate/RelateNodeGraph.cpp,
+	  source/operation/relate/RelateOp.cpp,
+	  source/operation/valid/ConsistentAreaTester.cpp: opRelate.h
+	  header split
+2006-03-21 11:20  Sandro Santilli <strk at keybit.net>
+	* [r1258] tests/xmltester/TestInteriorPoint.xml: Changed expected
+	  result to the obtained one :)
+	  We're not cheating, it's a 2-vertex linestring for
+	  which an InteriorPoint is requested, both vertexes
+	  are correct answer (equidistant from centroid).
+2006-03-21 11:12  Sandro Santilli <strk at keybit.net>
+	* [r1257] source/algorithm/CGAlgorithms.cpp,
+	  source/algorithm/CentroidArea.cpp,
+	  source/algorithm/CentroidLine.cpp,
+	  source/algorithm/HCoordinate.cpp,
+	  source/algorithm/InteriorPointLine.cpp,
+	  source/algorithm/InteriorPointPoint.cpp,
+	  source/algorithm/LineIntersector.cpp,
+	  source/algorithm/MCPointInRing.cpp,
+	  source/algorithm/MinimumDiameter.cpp,
+	  source/algorithm/NonRobustLineIntersector.cpp,
+	  source/algorithm/RobustDeterminant.cpp,
+	  source/algorithm/RobustLineIntersector.cpp,
+	  source/algorithm/SIRtreePointInRing.cpp,
+	  source/algorithm/SimplePointInAreaLocator.cpp,
+	  source/algorithm/SimplePointInRing.cpp,
+	  source/headers/geos/algorithm/SIRtreePointInRing.h: Cleanups:
+	  headers inclusion and Log section
+2006-03-21 10:47  Sandro Santilli <strk at keybit.net>
+	* [r1256] configure.in, source/headers/geos/index/Makefile.am,
+	  source/headers/geos/index/strtree,
+	  source/headers/geos/index/strtree/.cvsignore,
+	  source/headers/geos/index/strtree/AbstractNode.h,
+	  source/headers/geos/index/strtree/AbstractSTRtree.h,
+	  source/headers/geos/index/strtree/Boundable.h,
+	  source/headers/geos/index/strtree/Interval.h,
+	  source/headers/geos/index/strtree/ItemBoundable.h,
+	  source/headers/geos/index/strtree/Makefile.am,
+	  source/headers/geos/index/strtree/SIRtree.h,
+	  source/headers/geos/index/strtree/STRtree.h,
+	  source/headers/geos/indexStrtree.h,
+	  source/index/strtree/AbstractNode.cpp,
+	  source/index/strtree/AbstractSTRtree.cpp,
+	  source/index/strtree/Interval.cpp,
+	  source/index/strtree/ItemBoundable.cpp,
+	  source/index/strtree/SIRtree.cpp,
+	  source/index/strtree/STRtree.cpp: indexStrtree.h split
+2006-03-21 10:46  Sandro Santilli <strk at keybit.net>
+	* [r1255] source/algorithm/RobustDeterminant.cpp: streamlined
+	  header inclusion, put original copyright on top
+2006-03-21 10:01  Sandro Santilli <strk at keybit.net>
+	* [r1254] configure.in, source/headers/geos/index/Makefile.am,
+	  source/headers/geos/index/sweepline,
+	  source/headers/geos/index/sweepline/.cvsignore,
+	  source/headers/geos/index/sweepline/Makefile.am,
+	  source/headers/geos/index/sweepline/SweepLineEvent.h,
+	  source/headers/geos/index/sweepline/SweepLineIndex.h,
+	  source/headers/geos/index/sweepline/SweepLineInterval.h,
+	  source/headers/geos/index/sweepline/SweepLineOverlapAction.h,
+	  source/headers/geos/indexSweepline.h,
+	  source/index/sweepline/Makefile.am,
+	  source/index/sweepline/SweepLineEvent.cpp,
+	  source/index/sweepline/SweepLineIndex.cpp,
+	  source/index/sweepline/SweepLineInterval.cpp,
+	  source/index/sweepline/indexSweepLineEvent.cpp,
+	  source/operation/valid/SweeplineNestedRingTester.cpp:
+	  indexSweepline.h header split
+2006-03-20 18:18  Sandro Santilli <strk at keybit.net>
+	* [r1253] capi/geos_c.cpp, configure.in,
+	  source/headers/geos/Makefile.am, source/headers/geos/io,
+	  source/headers/geos/io.h, source/headers/geos/io/.cvsignore,
+	  source/headers/geos/io/ByteOrderDataInStream.h,
+	  source/headers/geos/io/ByteOrderValues.h,
+	  source/headers/geos/io/Makefile.am,
+	  source/headers/geos/io/StringTokenizer.h,
+	  source/headers/geos/io/WKBConstants.h,
+	  source/headers/geos/io/WKBReader.h,
+	  source/headers/geos/io/Writer.h, source/io/ByteOrderValues.cpp,
+	  source/io/ParseException.cpp, source/io/StringTokenizer.cpp,
+	  source/io/WKBReader.cpp, source/io/WKBWriter.cpp,
+	  source/io/WKTReader.cpp, source/io/WKTWriter.cpp,
+	  source/io/Writer.cpp, source/operation/buffer/BufferSubgraph.cpp:
+	  io.h header split
+2006-03-20 17:40  Sandro Santilli <strk at keybit.net>
+	* [r1252] source/index/quadtree/DoubleBits.cpp: <cmath> included
+	  when appropriate
+2006-03-20 17:27  Sandro Santilli <strk at keybit.net>
+	* [r1251] source/headers/geos/geom/CoordinateSequence.h,
+	  source/headers/geos/geom/GeometryFactory.h: Bug #72 - Missing
+	  <vector> header
+2006-03-20 17:17  Sandro Santilli <strk at keybit.net>
+	* [r1250] source/headers/geos/geomgraph/index/Makefile.am,
+	  source/headers/geos/noding/snapround/Makefile.am,
+	  source/headers/geos/operation/buffer/Makefile.am,
+	  source/headers/geos/operation/overlay/Makefile.am,
+	  source/headers/geos/operation/valid/Makefile.am: Fixed geosdir
+2006-03-20 16:57  Sandro Santilli <strk at keybit.net>
+	* [r1249] configure.in, source/geom/Geometry.cpp,
+	  source/headers/geos/Makefile.am, source/headers/geos/index,
+	  source/headers/geos/index/.cvsignore,
+	  source/headers/geos/index/ItemVisitor.h,
+	  source/headers/geos/index/SpatialIndex.h,
+	  source/headers/geos/operation/valid,
+	  source/headers/geos/operation/valid/.cvsignore,
+	  source/headers/geos/operation/valid/Makefile.am,
+	  source/headers/geos/operation/valid/RepeatedPointTester.h,
+	  source/headers/geos/operation/valid/SimpleNestedRingTester.h,
+	  source/headers/geos/operation/valid/SweeplineNestedRingTester.h,
+	  source/headers/geos/operation/valid/TopologyValidationError.h,
+	  source/headers/geos/spatialIndex.h,
+	  source/index/strtree/STRtree.cpp, source/io/Unload.cpp,
+	  source/operation/overlay/LineBuilder.cpp,
+	  source/operation/overlay/PolygonBuilder.cpp,
+	  source/operation/valid/ConsistentAreaTester.cpp,
+	  source/operation/valid/IsValidOp.cpp,
+	  source/operation/valid/QuadtreeNestedRingTester.cpp,
+	  source/operation/valid/RepeatedPointTester.cpp,
+	  source/operation/valid/SimpleNestedRingTester.cpp,
+	  source/operation/valid/TopologyValidationError.cpp:
+	  spatialindex.h and opValid.h headers split
+2006-03-20 16:08  Sandro Santilli <strk at keybit.net>
+	* [r1248] macros/ac_python_devel.m4: redirected find stderr to
+	  /dev/null
+2006-03-20 13:20  Sandro Santilli <strk at keybit.net>
+	* [r1247] source/operation/overlay/PolygonBuilder.cpp: Changed
+	  assertion to TopologyException for the "orphaned" hole case
+	  in order to allow for reduced precision ops to catch the case.
+2006-03-20 12:33  Sandro Santilli <strk at keybit.net>
+	* [r1246] source/headers/geos/operation/overlay/PolygonBuilder.h,
+	  source/operation/overlay/PolygonBuilder.cpp: Simplified some
+	  privat methods to use refs instead of pointers, added
+	  debugging section for failiures of holes/shells associations
+2006-03-20 12:32  Sandro Santilli <strk at keybit.net>
+	* [r1245] source/headers/geos/geomgraph/EdgeRing.h: Added note
+	  about responsibility of return from ::toPolygon
+2006-03-20 12:03  Sandro Santilli <strk at keybit.net>
+	* [r1244] source/geom/Geometry.cpp,
+	  source/headers/geos/geom/Geometry.h: Added operator<< for
+	  Geometry, writing HEXWKB
+2006-03-20 11:42  Sandro Santilli <strk at keybit.net>
+	* [r1243] source/noding/Octant.cpp,
+	  source/operation/buffer/OffsetCurveSetBuilder.cpp: Added missing
+	  <cmath> include
+2006-03-20 10:42  Sandro Santilli <strk at keybit.net>
+	* [r1242] source/operation/predicate/RectangleContains.cpp,
+	  source/operation/predicate/RectangleIntersects.cpp: Bug #61 -
+	  Disambiguated geom::Polygon use
+2006-03-20 10:14  Sandro Santilli <strk at keybit.net>
+	* [r1241] source/headers/geos/timeval.h: Bug #69 - Check for macro
+	  WIN32_LEAN_AND_MEAN
+2006-03-20 10:13  Sandro Santilli <strk at keybit.net>
+	* [r1240] source/operation/buffer/SubgraphDepthLocater.cpp: Bug #71
+	  - Missing <algorithm>
+2006-03-20 10:12  Sandro Santilli <strk at keybit.net>
+	* [r1239] source/headers/geos/geom/Coordinate.h: Bug #70 - Small
+	  fix in fwd decl. of CoordinateLessThen
+2006-03-20 10:11  Sandro Santilli <strk at keybit.net>
+	* [r1238] source/geom/GeometryFactory.cpp: Bug #67 - Debugging
+	  helpers in GeometryFactory class
+2006-03-17 16:48  Sandro Santilli <strk at keybit.net>
+	* [r1237] source/headers/geos/opRelate.h,
+	  source/headers/geos/opValid.h, source/io/Unload.cpp,
+	  source/operation/valid/SimpleNestedRingTester.cpp:
+	  LineIntersector and PointLocator made complete components of
+	  RelateComputer
+	  (were statics const pointers before). Reduced inclusions from
+	  opRelate.h
+	  and opValid.h, updated .cpp files to allow build.
+2006-03-17 14:56  Sandro Santilli <strk at keybit.net>
+	* [r1236] tests/xmltester/XMLTester.cpp: Fixed filename normalizer
+	  for sql output
+2006-03-17 13:24  Sandro Santilli <strk at keybit.net>
+	* [r1235] configure.in, source/geom/Geometry.cpp,
+	  source/headers/geos/operation/overlay,
+	  source/headers/geos/operation/overlay/.cvsignore,
+	  source/headers/geos/operation/overlay/EdgeSetNoder.h,
+	  source/headers/geos/operation/overlay/ElevationMatrix.h,
+	  source/headers/geos/operation/overlay/ElevationMatrixCell.h,
+	  source/headers/geos/operation/overlay/LineBuilder.h,
+	  source/headers/geos/operation/overlay/OverlayNodeFactory.h,
+	  source/headers/geos/operation/overlay/OverlayOp.h,
+	  source/headers/geos/operation/overlay/PointBuilder.h,
+	  source/headers/geos/operation/overlay/PolygonBuilder.h,
+	  source/operation/buffer/BufferSubgraph.cpp,
+	  source/operation/buffer/SubgraphDepthLocater.cpp,
+	  source/operation/overlay/EdgeSetNoder.cpp,
+	  source/operation/overlay/ElevationMatrixCell.cpp,
+	  source/operation/overlay/ElevationMatrixFilter.cpp,
+	  source/operation/overlay/Makefile.am,
+	  source/operation/overlay/OverlayNodeFactory.cpp,
+	  source/operation/overlay/PointBuilder.cpp,
+	  source/operation/overlay/PolygonBuilder.cpp: opOverlay.h header
+	  splitted. Reduced header inclusions in operation/overlay
+	  implementation files. ElevationMatrixFilter code moved from own
+	  file to ElevationMatrix.cpp (ideally a class-private).
+2006-03-16 13:30  Sandro Santilli <strk at keybit.net>
+	* [r1234] tests/xmltester/linemerge.xml: Added missing testfile
+2006-03-16 13:29  Sandro Santilli <strk at keybit.net>
+	* [r1233] tests/unit/Makefile.am, tests/unit/geom/LineSegment.cpp:
+	  new unit test for LineSegment (adding tests would be helpful)
+2006-03-16 13:28  Sandro Santilli <strk at keybit.net>
+	* [r1232] source/geom/LineSegment.cpp,
+	  source/headers/geos/geom/LineSegment.inl: obsoleted
+	  getCoordinate(), replaced by operator[]
+2006-03-16 13:27  Sandro Santilli <strk at keybit.net>
+	* [r1231] README: Added notes about testing
+2006-03-16 10:47  Sandro Santilli <strk at keybit.net>
+	* [r1230] tests/tut/tut.h, tests/tut/tut_reporter.h,
+	  tests/tut/tut_restartable.h, tests/unit/geom/Envelope.cpp,
+	  tests/unit/geom/Geometry/isRectangle.cpp,
+	  tests/unit/geos_unit.cpp: Bug #65 - Command line changes and EOL
+	  fixes Unit Test
+2006-03-16 10:42  Sandro Santilli <strk at keybit.net>
+	* [r1229] source/geom/Geometry.cpp: Bug #64 - Not all control paths
+	  return a value in geos::geom::Geometry::getClassSortIndex
+2006-03-16 10:38  Sandro Santilli <strk at keybit.net>
+	* [r1228] source/algorithm/LineIntersector.cpp: Bug #63 - Remove
+	  unreferenced local variable warning
+2006-03-16 09:37  Sandro Santilli <strk at keybit.net>
+	* [r1227] tests/tut, tests/tut/tut.h, tests/tut/tut_reporter.h,
+	  tests/tut/tut_restartable.h, tests/unit/Makefile.am,
+	  tests/unit/envelope_class_test.cpp, tests/unit/geom,
+	  tests/unit/geom/Envelope.cpp, tests/unit/geom/Geometry,
+	  tests/unit/geos_unit.cpp: Initial unit tests
+2006-03-15 18:59  Sandro Santilli <strk at keybit.net>
+	* [r1226] source/headers/geos/operation/IsSimpleOp.h: Bug #62:
+	  'struct' CoordinateLessThen in forward declaration
+2006-03-15 18:57  Sandro Santilli <strk at keybit.net>
+	* [r1225] source/operation/buffer/SubgraphDepthLocater.cpp: small
+	  cleanup
+	* [r1224] source/operation/buffer/BufferBuilder.cpp: cleanups in
+	  DEBUG lines
+2006-03-15 18:56  Sandro Santilli <strk at keybit.net>
+	* [r1223] source/operation/buffer/BufferOp.cpp: Temporary hack to
+	  avoid snapround:: Noders (still using ScaledNoder wrapper)
+	  to allow for buffer_snapround.xml test to succeed
+2006-03-15 18:55  Sandro Santilli <strk at keybit.net>
+	* [r1222] tests/xmltester/buffer_snapround.xml: Added xml testfile
+	  showing bug in snapround:: noders
+2006-03-15 18:44  Sandro Santilli <strk at keybit.net>
+	* [r1221] doc/example.cpp, source/geom/Envelope.cpp,
+	  source/geom/LineSegment.cpp, source/geom/PrecisionModel.cpp,
+	  source/headers/geos/geom/Coordinate.inl,
+	  source/util/GeometricShapeFactory.cpp: Bug #60 - Missing <cmath>
+	  header in some files
+2006-03-15 17:33  Sandro Santilli <strk at keybit.net>
+	* [r1220] source/operation/buffer/BufferSubgraph.cpp: Changed
+	  operator<< to use operator<< for Nodes
+2006-03-15 17:17  Sandro Santilli <strk at keybit.net>
+	* [r1219] source/headers/geos/geomgraph/DirectedEdgeStar.h,
+	  source/headers/geos/geomgraph/index/SweepLineEvent.h: Added
+	  missing forward declarations
+2006-03-15 17:16  Sandro Santilli <strk at keybit.net>
+	* [r1218] source/geomgraph/Depth.cpp,
+	  source/geomgraph/DirectedEdgeStar.cpp, source/geomgraph/Edge.cpp,
+	  source/geomgraph/EdgeEnd.cpp, source/geomgraph/EdgeEndStar.cpp,
+	  source/geomgraph/EdgeIntersection.cpp,
+	  source/geomgraph/EdgeNodingValidator.cpp,
+	  source/geomgraph/EdgeRing.cpp,
+	  source/geomgraph/GraphComponent.cpp,
+	  source/geomgraph/NodeFactory.cpp,
+	  source/geomgraph/PlanarGraph.cpp, source/geomgraph/Position.cpp,
+	  source/geomgraph/Quadrant.cpp,
+	  source/geomgraph/index/MonotoneChainEdge.cpp,
+	  source/geomgraph/index/MonotoneChainIndexer.cpp,
+	  source/geomgraph/index/SimpleEdgeSetIntersector.cpp,
+	  source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
+	  source/geomgraph/index/SimpleSweepLineIntersector.cpp,
+	  source/geomgraph/index/SweepLineEvent.cpp,
+	  source/geomgraph/index/SweepLineSegment.cpp: streamlined headers
+	  inclusion
+2006-03-15 16:27  Sandro Santilli <strk at keybit.net>
+	* [r1217] source/geomgraph/Node.cpp,
+	  source/headers/geos/geomgraph/Node.h: operator<< for Node class
+2006-03-15 15:50  Sandro Santilli <strk at keybit.net>
+	* [r1216]
+	  source/headers/geos/operation/buffer/SubgraphDepthLocater.h,
+	  source/operation/buffer/SubgraphDepthLocater.cpp: const
+	  correctness, cleanups
+2006-03-15 15:27  Sandro Santilli <strk at keybit.net>
+	* [r1215] source/headers/geos/geomgraph/DirectedEdge.h,
+	  source/headers/geos/geomgraph/EdgeEnd.h: cleanups
+2006-03-15 15:26  Sandro Santilli <strk at keybit.net>
+	* [r1214] source/geomgraph/DirectedEdge.cpp,
+	  source/geomgraph/EdgeRing.cpp: Cleanups
+2006-03-15 13:03  Sandro Santilli <strk at keybit.net>
+	* [r1213] source/operation/buffer/BufferBuilder.cpp: removed
+	  leftover debugging line
+2006-03-15 12:54  Sandro Santilli <strk at keybit.net>
+	* [r1212] source/headers/geos/opBuffer.h: Removed DepthSegment.h
+	  include
+	* [r1211] source/headers/geos/operation/buffer/DepthSegment.h,
+	  source/headers/geos/operation/buffer/Makefile.am: Removed public
+	  DepthSegment definition (moved inside SubgraphDepthLocater
+	  implementation)
+2006-03-15 12:52  Sandro Santilli <strk at keybit.net>
+	* [r1210] source/operation/buffer/DepthSegment.cpp,
+	  source/operation/buffer/Makefile.am,
+	  source/operation/buffer/SubgraphDepthLocater.cpp: DepthSegment
+	  class moved inside SubgraphDepthLocator implementaion
+	  as it was private to this file in JTS. Also, changed to reduce
+	  copies of LineSegment copies.
+2006-03-15 11:45  Sandro Santilli <strk at keybit.net>
+	* [r1209] source/headers/geos/operation/buffer/BufferSubgraph.h:
+	  doxygen comments
+2006-03-15 11:44  Sandro Santilli <strk at keybit.net>
+	* [r1208] source/operation/overlay/PolygonBuilder.cpp: debug
+	  blocks, dumping SQL when GEOS_DEBUG > 1
+2006-03-15 11:42  Sandro Santilli <strk at keybit.net>
+	* [r1207] source/operation/buffer/BufferBuilder.cpp: more debugging
+	  lines, with two levels of debugging handled
+2006-03-15 11:39  Sandro Santilli <strk at keybit.net>
+	* [r1206] source/operation/buffer/BufferSubgraph.cpp: comments
+	  cleanup, changed computeDepths to use a list<> rather then a
+	  vector (performance related)
+2006-03-15 10:40  Sandro Santilli <strk at keybit.net>
+	* [r1205] doc/Doxyfile.in: Fixed to allow doxygen runs from
+	  external builddir
+2006-03-15 09:51  Sandro Santilli <strk at keybit.net>
+	* [r1204] source/headers/geos/noding/SegmentString.inl,
+	  source/headers/geos/noding/SimpleNoder.h: streamlined header
+	  usage
+	* [r1203] source/noding/IntersectionAdder.cpp,
+	  source/noding/IntersectionFinderAdder.cpp,
+	  source/noding/IteratedNoder.cpp, source/noding/MCIndexNoder.cpp,
+	  source/noding/NodingValidator.cpp, source/noding/Octant.cpp,
+	  source/noding/ScaledNoder.cpp, source/noding/SegmentNode.cpp,
+	  source/noding/SegmentNodeList.cpp,
+	  source/noding/SegmentString.cpp, source/noding/SimpleNoder.cpp,
+	  source/noding/snapround/SimpleSnapRounder.cpp: streamlined
+	  headers usage
+2006-03-15 09:13  Sandro Santilli <strk at keybit.net>
+	* [r1202] source/geom/Polygon.cpp: updated port info
+2006-03-15 09:12  Sandro Santilli <strk at keybit.net>
+	* [r1201] source/headers/geos/geom/Polygon.h: isSimple doc
+2006-03-14 17:46  Sandro Santilli <strk at keybit.net>
+	* [r1200] source/headers/geos/util/Assert.h: Removed unrequired
+	  include
+2006-03-14 17:10  Sandro Santilli <strk at keybit.net>
+	* [r1199] source/operation/buffer/BufferSubgraph.cpp: cleanups
+2006-03-14 17:08  Sandro Santilli <strk at keybit.net>
+	* [r1198] source/headers/geos/opOverlay.h,
+	  source/operation/overlay/MaximalEdgeRing.cpp: comments cleanup,
+	  integrity checks
+2006-03-14 16:55  Sandro Santilli <strk at keybit.net>
+	* [r1197] source/operation/overlay/PolygonBuilder.cpp: oops,
+	  GEOS_DEBUG default to 0
+	* [r1196] source/headers/geos/opOverlay.h,
+	  source/operation/overlay/PolygonBuilder.cpp: comments cleanup
+2006-03-14 16:53  Sandro Santilli <strk at keybit.net>
+	* [r1195] source/geomgraph/Edge.cpp: removed endline from printing
+	  funx
+2006-03-14 16:08  Sandro Santilli <strk at keybit.net>
+	* [r1194] source/headers/geos/operation/buffer/BufferBuilder.h,
+	  source/operation/buffer/BufferBuilder.cpp: changed buildSubgraphs
+	  signature to use refs rather then pointers, made it
+	  const-correct. Reduced heap allocations in createSubgraphs()
+2006-03-14 15:46  Sandro Santilli <strk at keybit.net>
+	* [r1193] source/geomgraph/PlanarGraph.cpp,
+	  source/headers/geos/geomgraph/PlanarGraph.h: Added
+	  PlanarGraph::getNodes(vector&) func, to reduce useless heap
+	  allocations
+2006-03-14 15:32  Sandro Santilli <strk at keybit.net>
+	* [r1192] source/geom/Coordinate.cpp,
+	  source/geom/CoordinateArraySequence.cpp,
+	  source/geomgraph/DirectedEdge.cpp, source/geomgraph/Edge.cpp,
+	  source/geomgraph/Node.cpp: Cleaned up toString funx (more WKT
+	  friendly)
+2006-03-14 14:16  Sandro Santilli <strk at keybit.net>
+	* [r1191] source/headers/geos/operation/buffer/BufferSubgraph.h,
+	  source/operation/overlay/PolygonBuilder.cpp: operator<< for
+	  BufferSubgraph, more debugging calls
+2006-03-14 12:55  Sandro Santilli <strk at keybit.net>
+	* [r1190] configure.in, source/geom/Geometry.cpp,
+	  source/geomgraph/Label.cpp, source/geomgraph/Node.cpp,
+	  source/geomgraph/NodeMap.cpp,
+	  source/headers/geos/geomgraph/Makefile.am,
+	  source/headers/geos/geomgraph/index,
+	  source/headers/geos/geomgraph/index/.cvsignore,
+	  source/headers/geos/geomgraph/index/EdgeSetIntersector.h,
+	  source/headers/geos/geomgraph/index/Makefile.am,
+	  source/headers/geos/geomgraph/index/MonotoneChain.h,
+	  source/headers/geos/geomgraph/index/MonotoneChainEdge.h,
+	  source/headers/geos/geomgraph/index/MonotoneChainIndexer.h,
+	  source/headers/geos/geomgraph/index/SegmentIntersector.h,
+	  source/headers/geos/geomgraph/index/SimpleEdgeSetIntersector.h,
+	  source/headers/geos/geomgraph/index/SimpleMCSweepLineIntersector.h,
+	  source/headers/geos/geomgraph/index/SimpleSweepLineIntersector.h,
+	  source/headers/geos/geomgraph/index/SweepLineEvent.h,
+	  source/headers/geos/geomgraph/index/SweepLineEventObj.h,
+	  source/headers/geos/geomgraph/index/SweepLineSegment.h,
+	  source/headers/geos/geomgraphindex.h,
+	  source/headers/geos/noding/MCIndexNoder.inl,
+	  source/headers/geos/noding/Makefile.am,
+	  source/headers/geos/noding/snapround,
+	  source/headers/geos/noding/snapround/.cvsignore,
+	  source/headers/geos/noding/snapround/HotPixel.inl,
+	  source/headers/geos/noding/snapround/MCIndexSnapRounder.inl,
+	  source/headers/geos/nodingSnapround.h,
+	  source/operation/buffer/BufferOp.cpp: Headers split:
+	  geomgraphindex.h, nodingSnapround.h
+2006-03-14 11:03  Sandro Santilli <strk at keybit.net>
+	* [r1189] source/geomgraph/Edge.cpp, source/geomgraph/EdgeList.cpp,
+	  source/headers/geos/geomgraph/EdgeList.h: Added operator<< for
+	  Edge and EdgeList
+2006-03-14 00:37  Sandro Santilli <strk at keybit.net>
+	* [r1188] source/headers/geos/operation/buffer/Makefile.am: Fixed
+	  include filenames
+2006-03-14 00:36  Sandro Santilli <strk at keybit.net>
+	* [r1187] source/operation/buffer/BufferOp.cpp: Reduced 'buffer'
+	  headers inclusion
+2006-03-14 00:19  Sandro Santilli <strk at keybit.net>
+	* [r1186] source/headers/geos/opBuffer.h,
+	  source/headers/geos/operation/buffer,
+	  source/headers/geos/operation/buffer/.cvsignore,
+	  source/headers/geos/operation/buffer/BufferBuilder.h,
+	  source/headers/geos/operation/buffer/BufferOp.h,
+	  source/headers/geos/operation/buffer/BufferSubgraph.h,
+	  source/headers/geos/operation/buffer/DepthSegment.h,
+	  source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h,
+	  source/operation/buffer/DepthSegment.cpp,
+	  source/operation/buffer/OffsetCurveSetBuilder.cpp,
+	  source/operation/buffer/RightmostEdgeFinder.cpp,
+	  source/operation/buffer/SubgraphDepthLocater.cpp: opBuffer.h
+	  split, streamlined headers in some (not all) files in
+	  operation/buffer/
+2006-03-13 22:33  Sandro Santilli <strk at keybit.net>
+	* [r1185] source/headers/geos/geom/LineSegment.h: Added missing
+	  forward declarations
+2006-03-13 21:54  Sandro Santilli <strk at keybit.net>
+	* [r1184] source/geom/Coordinate.cpp,
+	  source/geom/CoordinateSequenceFactory.cpp,
+	  source/geom/Geometry.cpp,
+	  source/geom/Triangle.cpp: Streamlined headers inclusion.
+2006-03-13 21:19  Sandro Santilli <strk at keybit.net>
+	* [r1183] source/headers/geos/noding/ScaledNoder.h,
+	  source/noding/ScaledNoder.cpp: Fixed bug in ScaledNoder scaling
+	  mechanism (hugly code, due to CoordinateSequence visitor pattern
+	  design). Tests are still failing so this possibly needs some
+	  other fix. Streamlined includes by implementation file.
+2006-03-13 21:14  Sandro Santilli <strk at keybit.net>
+	* [r1182] source/headers/geos/noding/SegmentString.h: Added missing
+2006-03-13 21:13  Sandro Santilli <strk at keybit.net>
+	* [r1181] source/headers/geos/geom/CoordinateFilter.h: Added
+	  comment about possible refactoring
+2006-03-11 16:58  Sandro Santilli <strk at keybit.net>
+	* [r1180] source/headers/geos/opBuffer.h,
+	  source/operation/buffer/OffsetCurveBuilder.cpp: Fixed bug in
+	  OffsetCurveBuilder::getCoordinates.
+2006-03-10 15:50  Sandro Santilli <strk at keybit.net>
+	* [r1179] source/geomgraph/EdgeRing.cpp: Changed 'found null
+	  Directed Edge' from an Assertion to a TopologyException, to give
+	  'precision-reducing' overlay operation a chance to handle it (it
+	  seems to work)
+2006-03-10 13:07  Sandro Santilli <strk at keybit.net>
+	* [r1178] source/geomgraph/EdgeRing.cpp: fine-tuned includes,
+	  reverted Assert=>assert due to user-input based failure
+2006-03-10 12:50  Sandro Santilli <strk at keybit.net>
+	* [r1177] configure.in, tests/unit/Makefile.am,
+	  tests/unit/envelope_class_test.cpp: boost detection code fix,
+	  first UTF source for testing purposes
+2006-03-10 12:43  Sandro Santilli <strk at keybit.net>
+	* [r1176] TODO: updated
+2006-03-10 12:09  Sandro Santilli <strk at keybit.net>
+	* [r1175] configure.in: Update configure script to work with new
+	  boost.m4 file
+2006-03-10 11:49  Sandro Santilli <strk at keybit.net>
+	* [r1174] macros/boost.m4: Updated boost detection macro
+2006-03-10 11:41  Sandro Santilli <strk at keybit.net>
+	* [r1173] source/index/quadtree/QuadTreeNodeBase.cpp: Added missing
+	  <algorithm> include (bug#56)
+2006-03-10 11:10  Sandro Santilli <strk at keybit.net>
+	* [r1172] configure.in, macros/boost.m4, tests/Makefile.am,
+	  tests/unit, tests/unit/.cvsignore, tests/unit/Makefile.am:
+	  Initial boost detection code
+2006-03-10 11:09  Sandro Santilli <strk at keybit.net>
+	* [r1171] source/operation/valid/ConnectedInteriorTester.cpp:
+	  Comments cleanup
+2006-03-10 10:48  Sandro Santilli <strk at keybit.net>
+	* [r1170] source/Makefile.vc: Bug #58 - Patch to makefile.vc after
+	  big refactoring commit
+2006-03-10 10:44  Sandro Santilli <strk at keybit.net>
+	* [r1169] source/operation/buffer/BufferBuilder.cpp,
+	  source/precision/EnhancedPrecisionOp.cpp: Unreferenced exception
+	  objects cleanup (#52)
+2006-03-10 10:37  Sandro Santilli <strk at keybit.net>
+	* [r1168] source/geomgraph/index/SimpleSweepLineIntersector.cpp:
+	  Added missing <algorithm> include (#55)
+2006-03-10 10:34  Sandro Santilli <strk at keybit.net>
+	* [r1167] source/geom/Polygon.cpp: Added missing <algorithm>
+	  include (#54)
+2006-03-09 18:22  Sandro Santilli <strk at keybit.net>
+	* [r1166] tests/xmltester/Makefile.am,
+	  tests/xmltester/TestIsValid.xml: Added isvalid test for latest
+	  validop patch
+2006-03-09 18:18  Sandro Santilli <strk at keybit.net>
+	* [r1165] source/headers/geos/opOverlay.h,
+	  memory-friendly MaximalEdgeRing::buildMinimalRings()
+	  implementation.
+	  Applied patch to IsValid operation from JTS-1.7.1
+2006-03-09 17:40  Sandro Santilli <strk at keybit.net>
+	* [r1164] source/headers/geos/opBuffer.h,
+	  source/operation/buffer/OffsetCurveBuilder.cpp: Fixed bug#33
+	  (hopefully)
+2006-03-09 16:46  Sandro Santilli <strk at keybit.net>
+	* [r1163] configure.in, source/algorithm/CGAlgorithms.cpp,
+	  source/algorithm/CentroidPoint.cpp,
+	  source/algorithm/InteriorPointArea.cpp,
+	  source/algorithm/PointLocator.cpp,
+	  source/geom/Coordinate.cpp,
+	  source/geom/Dimension.cpp, source/geom/Envelope.cpp,
+	  source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
+	  source/geom/LineString.cpp, source/geom/LinearRing.cpp,
+	  source/geom/Location.cpp, source/geom/MultiLineString.cpp,
+	  source/geom/MultiPoint.cpp, source/geom/MultiPolygon.cpp,
+	  source/geom/Point.cpp, source/geom/Polygon.cpp,
+	  source/geom/util/CoordinateOperation.cpp,
+	  source/geom/util/GeometryEditor.cpp,
+	  source/geom/util/Makefile.am, source/geomgraph/DirectedEdge.cpp,
+	  source/geomgraph/Edge.cpp, source/geomgraph/EdgeEnd.cpp,
+	  source/geomgraph/GeometryGraph.cpp,
+	  source/geomgraph/PlanarGraph.cpp, source/geomgraph/Quadrant.cpp,
+	  source/geomgraph/index/SweepLineSegment.cpp,
+	  source/headers/geos.h, source/headers/geos/Makefile.am,
+	  source/headers/geos/algorithm,
+	  source/headers/geos/algorithm/.cvsignore,
+	  source/headers/geos/algorithm/CGAlgorithms.h,
+	  source/headers/geos/algorithm/CentroidArea.h,
+	  source/headers/geos/algorithm/CentroidLine.h,
+	  source/headers/geos/algorithm/CentroidPoint.h,
+	  source/headers/geos/algorithm/ConvexHull.inl,
+	  source/headers/geos/algorithm/HCoordinate.h,
+	  source/headers/geos/algorithm/InteriorPointArea.h,
+	  source/headers/geos/algorithm/InteriorPointLine.h,
+	  source/headers/geos/algorithm/InteriorPointPoint.h,
+	  source/headers/geos/algorithm/LineIntersector.h,
+	  source/headers/geos/algorithm/Makefile.am,
+	  source/headers/geos/algorithm/MinimumDiameter.h,
+	  source/headers/geos/algorithm/NotRepresentableException.h,
+	  source/headers/geos/algorithm/PointInRing.h,
+	  source/headers/geos/algorithm/PointLocator.h,
+	  source/headers/geos/algorithm/RobustDeterminant.h,
+	  source/headers/geos/algorithm/SIRtreePointInRing.h,
+	  source/headers/geos/algorithm/SimplePointInAreaLocator.h,
+	  source/headers/geos/algorithm/SimplePointInRing.h,
+	  source/headers/geos/geom, source/headers/geos/geom.h,
+	  source/headers/geos/geom/.cvsignore,
+	  source/headers/geos/geom/CoordinateArraySequenceFactory.inl,
+	  source/headers/geos/geom/Dimension.h,
+	  source/headers/geos/geom/Envelope.h,
+	  source/headers/geos/geom/Envelope.inl,
+	  source/headers/geos/geom/GeometryCollection.h,
+	  source/headers/geos/geom/GeometryComponentFilter.h,
+	  source/headers/geos/geom/GeometryFactory.h,
+	  source/headers/geos/geom/GeometryFactory.inl,
+	  source/headers/geos/geom/IntersectionMatrix.h,
+	  source/headers/geos/geom/LineSegment.inl,
+	  source/headers/geos/geom/LineString.h,
+	  source/headers/geos/geom/LinearRing.h,
+	  source/headers/geos/geom/Makefile.am,
+	  source/headers/geos/geom/MultiLineString.h,
+	  source/headers/geos/geom/MultiPoint.h,
+	  source/headers/geos/geom/MultiPolygon.h,
+	  source/headers/geos/geom/Point.h,
+	  source/headers/geos/geom/PrecisionModel.h,
+	  source/headers/geos/geom/PrecisionModel.inl,
+	  source/headers/geos/geom/util,
+	  source/headers/geos/geom/util/.cvsignore,
+	  source/headers/geos/geom/util/LinearComponentExtracter.h,
+	  source/headers/geos/geom/util/Makefile.am,
+	  source/headers/geos/geom/util/PointExtracter.h,
+	  source/headers/geos/geom/util/PolygonExtracter.h,
+	  source/headers/geos/geomUtil.h, source/headers/geos/geomgraph,
+	  source/headers/geos/geomgraph.h,
+	  source/headers/geos/geomgraph/.cvsignore,
+	  source/headers/geos/geomgraph/Label.h,
+	  source/headers/geos/geosAlgorithm.h,
+	  source/headers/geos/indexStrtree.h, source/headers/geos/io.h,
+	  source/headers/geos/noding, source/headers/geos/noding.h,
+	  source/headers/geos/noding/.cvsignore,
+	  source/headers/geos/noding/SegmentString.inl,
+	  source/headers/geos/opBuffer.h, source/headers/geos/opDistance.h,
+	  source/headers/geos/opValid.h, source/headers/geos/operation,
+	  source/headers/geos/operation.h,
+	  source/headers/geos/operation/.cvsignore,
+	  source/headers/geos/operation/EndpointInfo.h,
+	  source/headers/geos/operation/GeometryGraphOperation.h,
+	  source/headers/geos/operation/IsSimpleOp.h,
+	  source/headers/geos/spatialIndex.h, source/headers/geos/util,
+	  source/headers/geos/util.h, source/headers/geos/util/.cvsignore,
+	  source/headers/geos/util/Assert.h,
+	  source/headers/geos/util/AssertionFailedException.h,
+	  source/headers/geos/util/CoordinateArrayFilter.h,
+	  source/headers/geos/util/GeometricShapeFactory.h,
+	  source/headers/geos/util/Makefile.am,
+	  source/headers/geos/util/UniqueCoordinateArrayFilter.h,
+	  source/headers/geos/util/UnsupportedOperationException.h,
+	  source/headers/geos/util/math.h, source/io/WKBReader.cpp,
+	  source/io/WKTWriter.cpp, source/noding/SegmentString.cpp,
+	  source/util/Assert.cpp, tests/xmltester/SimpleWKTTester.cpp,
+	  tests/xmltester/XMLTester.cpp, tests/xmltester/buffer.xml:
+	  geos::geom namespace definition, first pass at headers split
+2006-03-09 16:18  Sandro Santilli <strk at keybit.net>
+	* [r1162] tests/xmltester/Makefile.am: Fixed to allow tests from
+	  external build tree (thanks Norman:)
+2006-03-09 16:01  Sandro Santilli <strk at keybit.net>
+	* [r1161] source/geomgraph/Position.cpp,
+	  source/operation/overlay/ElevationMatrixFilter.cpp: Fixed
+	  debugging lines
+2006-03-09 15:50  Sandro Santilli <strk at keybit.net>
+	* [r1160] source/operation/overlay/OverlayOp.cpp: Fixed debugging
+	  lines, added missing header
+2006-03-09 15:47  Sandro Santilli <strk at keybit.net>
+	* [r1159] source/operation/linemerge/LineMergeGraph.cpp: Fixed
+	  debugging lines
+2006-03-09 15:39  Sandro Santilli <strk at keybit.net>
+	* [r1158] source/index/quadtree/QuadTreeKey.cpp,
+	  source/noding/SegmentNodeList.cpp: Fixed debugging lines
+2006-03-09 14:48  Sandro Santilli <strk at keybit.net>
+	* [r1157] capi/Makefile.am: Added missing INCLUDES line
+2006-03-07 14:21  Sandro Santilli <strk at keybit.net>
+	* [r1156] tests/xmltester/XMLTester.cpp: Leak plugged, tweeked
+	  output to be nice with --sql-output
+2006-03-07 14:20  Sandro Santilli <strk at keybit.net>
+	* [r1155] source/headers/geos/opBuffer.h,
+	  source/operation/buffer/OffsetCurveBuilder.cpp: Big deal of heap
+	  allocations reduction
+2006-03-07 14:18  Sandro Santilli <strk at keybit.net>
+	* [r1154] source/util/Profiler.cpp: Profiler singleton implemented
+	  with a function-static Profiler instance
+2006-03-07 12:42  Sandro Santilli <strk at keybit.net>
+	* [r1153] tests/xmltester/buffer.xml: addedvalidity test for a case
+	  with invalid input
+2006-03-07 12:41  Sandro Santilli <strk at keybit.net>
+	* [r1152] tests/xmltester/XMLTester.cpp,
+	  tests/xmltester/XMLTester.h: Added --wkb-output and made
+	  --sql-output compatible with -v
+2006-03-07 11:22  Sandro Santilli <strk at keybit.net>
+	* [r1151] tests/xmltester/XMLTester.cpp: table name for sqlOutput
+	  normalized
+2006-03-07 11:06  Sandro Santilli <strk at keybit.net>
+	* [r1150] tests/xmltester/XMLTester.cpp,
+	  tests/xmltester/XMLTester.h: Added --sql-output switch for
+	  debugging
+2006-03-07 10:46  Sandro Santilli <strk at keybit.net>
+	* [r1149] tests/xmltester/XMLTester.cpp: verbose validity errors
+2006-03-06 21:27  Sandro Santilli <strk at keybit.net>
+	* [r1148] doc/example.cpp, source/headers/geos/geom.h,
+	  source/headers/geos/opRelate.h, tests/xmltester/XMLTester.cpp:
+	  Cascading fixed after Unload definition moved to geos::io
+	  namespace
+2006-03-06 19:43  Sandro Santilli <strk at keybit.net>
+	* [r1147] source/headers/geos/unload.h: Fixed Unload class
+	  definition namespace (geos::io)
+2006-03-06 19:40  Sandro Santilli <strk at keybit.net>
+	* [r1146] capi/geos_c.cpp, doc/example.cpp,
+	  source/geom/Dimension.cpp, source/geom/Geometry.cpp,
+	  source/geom/GeometryCollection.cpp,
+	  source/geom/Location.cpp, source/geom/Makefile.am,
+	  source/headers/geos/LineSegment.inl,
+	  source/headers/geos/Makefile.am, source/headers/geos/geom,
+	  source/headers/geos/geom.h,
+	  source/headers/geos/geosAlgorithm.h, source/headers/geos/io.h,
+	  source/headers/geos/opBuffer.h, source/headers/geos/profiler.h,
+	  source/headers/geos/util.h, source/index/bintree/BinTreeNode.cpp,
+	  source/io/WKTWriter.cpp, source/noding/IteratedNoder.cpp,
+	  source/operation/overlay/ElevationMatrix.cpp,
+	  source/operation/valid/SweeplineNestedRingTester.cpp,
+	  source/precision/CommonBitsRemover.cpp,
+	  source/precision/EnhancedPrecisionOp.cpp, source/util/Assert.cpp,
+	  source/util/AssertionFailedException.cpp,
+	  source/util/CoordinateArrayFiter.cpp,
+	  source/util/GEOSException.cpp,
+	  source/util/IllegalArgumentException.cpp,
+	  source/util/Profiler.cpp,
+	  source/util/UniqueCoordinateArrayFilter.cpp,
+	  source/util/UnsupportedOperationException.cpp,
+	  tests/xmltester/SimpleWKTTester.cpp,
+	  tests/xmltester/XMLTester.cpp: geos::util namespace. New
+	  GeometryCollection::iterator interface, many cleanups.
+2006-03-06 15:23  Sandro Santilli <strk at keybit.net>
+	* [r1145] capi/geos_c.cpp, doc/example.cpp,
+	  source/geom/Geometry.cpp, source/headers/geos/io.h,
+	  source/io/ByteOrderValues.cpp, source/io/ParseException.cpp,
+	  source/io/StringTokenizer.cpp, source/io/Unload.cpp,
+	  source/io/Writer.cpp, tests/xmltester/SimpleWKTTester.cpp,
+	  tests/xmltester/XMLTester.cpp, tests/xmltester/XMLTester.h,
+	  tests/xmltester/buffer.xml: geos::io namespace
+2006-03-06 14:30  Sandro Santilli <strk at keybit.net>
+	* [r1143] capi/geos_c.cpp: Validity error include Coordinate
+2006-03-06 13:27  Sandro Santilli <strk at keybit.net>
+	* [r1142] source/geom/Polygon.cpp: Cleaned up equalsExact
+2006-03-06 13:26  Sandro Santilli <strk at keybit.net>
+	* [r1141] tests/xmltester/XMLTester.cpp: Fixed equalsExact check,
+	  and also reduced tolerance
+2006-03-06 12:47  Sandro Santilli <strk at keybit.net>
+	* [r1140] source/headers/geos/opValid.h,
+	  source/operation/valid/IsValidOp.cpp: TopologyValidationError
+	  error names (enum) renamed to avoid conflicts.
+2006-03-06 12:16  Sandro Santilli <strk at keybit.net>
+	* [r1139] tests/xmltester/robustness.xml: Added second case for
+	  Union
+2006-03-06 12:11  Sandro Santilli <strk at keybit.net>
+	* [r1138] source/operation/overlay/OverlayOp.cpp: precision.h =>
+	  geos/precision.h (#48)
+2006-03-06 11:39  Sandro Santilli <strk at keybit.net>
+	* [r1137] tests/xmltester/robustness.xml: Added test extracted from
+	  data provided by Guillaume Sueur
+2006-03-06 11:34  Sandro Santilli <strk at keybit.net>
+	* [r1136] source/headers/geos/geom.h: Dropped
+	  unused/unmaintained/platform-problematic serial version info for
+	  classes (#47)
+2006-03-06 11:17  Sandro Santilli <strk at keybit.net>
+	* [r1135] capi/geos_c.cpp: added a compile-time option to get
+	  VERBOSE_EXCEPTION (print args on exceptions)
+	* [r1134] source/operation/overlay/OverlayOp.cpp: precision
+	  reducing overlayOp made compile-time optional
+2006-03-06 11:05  Sandro Santilli <strk at keybit.net>
+	* [r1133] tests/xmltester/XMLTester.cpp,
+	  tests/xmltester/XMLTester.h: Added input and output validity test
+	  facilities
+2006-03-03 14:01  Sandro Santilli <strk at keybit.net>
+	* [r1132] source/operation/overlay/OverlayOp.cpp: Experimental
+	  precision-reducing overlayOp
+2006-03-03 13:50  Sandro Santilli <strk at keybit.net>
+	* [r1131] source/algorithm/InteriorPointLine.cpp,
+	  source/headers/geos/geom.h, source/headers/geos/geosAlgorithm.h:
+	  Cleaned up InteriorPointLine class
+2006-03-03 10:46  Sandro Santilli <strk at keybit.net>
+	* [r1130] capi/geos_c.cpp, doc/example.cpp,
+	  source/algorithm/CGAlgorithms.cpp,
+	  source/algorithm/NotRepresentableException.cpp,
+	  source/geom/util/GeometryEditor.cpp, source/geomgraph/Depth.cpp,
+	  source/geomgraph/EdgeList.cpp, source/geomgraph/EdgeRing.cpp,
+	  source/geomgraph/GeometryGraph.cpp, source/geomgraph/Label.cpp,
+	  source/geomgraph/Node.cpp, source/geomgraph/NodeMap.cpp,
+	  source/geomgraph/TopologyLocation.cpp,
+	  source/headers/geos/geom.h, source/headers/geos/geomUtil.h,
+	  source/headers/geos/noding.h,
+	  source/headers/geos/opRelate.h, source/headers/geos/opValid.h,
+	  source/headers/geos/profiler.h, source/headers/geos/util.h,
+	  source/index/strtree/STRtree.cpp, source/io/ByteOrderValues.cpp,
+	  source/io/Unload.cpp, source/io/WKBReader.cpp,
+	  source/io/WKTWriter.cpp, source/io/Writer.cpp,
+	  source/noding/SegmentNode.cpp, source/noding/SegmentNodeList.cpp,
+	  source/noding/snapround/SimpleSnapRounder.cpp,
+	  source/operation/valid/ConnectedInteriorTester.cpp,
+	  source/operation/valid/TopologyValidationError.cpp,
+	  source/planargraph/planarSubgraph.cpp,
+	  source/precision/CommonBitsOp.cpp,
+	  source/precision/SimpleGeometryPrecisionReducer.cpp,
+	  source/util/Assert.cpp, source/util/GEOSException.cpp,
+	  source/util/GeometricShapeFactory.cpp, source/util/Profiler.cpp,
+	  tests/xmltester/XMLTester.cpp, tests/xmltester/XMLTester.h:
+	  Removed 'using namespace' from headers, added missing headers in
+	  .cpp files, removed useless includes in headers (bug#46)
+2006-03-02 18:17  Sandro Santilli <strk at keybit.net>
+	* [r1129] tests/xmltester/Makefile.am,
+	  tests/xmltester/robustness.xml: Added robustness testcases
+2006-03-02 16:22  Sandro Santilli <strk at keybit.net>
+	* [r1128] tests/xmltester/XMLTester.cpp: Updated copyright notice
+2006-03-02 16:21  Sandro Santilli <strk at keybit.net>
+	* [r1127] source/geomgraph/PlanarGraph.cpp,
+	  source/headers/geos/geomUtil.h, source/headers/geos/precision.h,
+	  geos::precision namespace added
+2006-03-02 14:53  Sandro Santilli <strk at keybit.net>
+	* [r1126] source/geomgraph/index/SweepLineEvent.cpp,
+	  source/index/sweepline/indexSweepLineEvent.cpp:
+	  SweepLineEvent::DELETE=>DELETE_EVENT, INSERT=>INSERT_EVENT (#45)
+2006-03-02 14:34  Sandro Santilli <strk at keybit.net>
+	* [r1125] source/headers/geos/geomgraph.h,
+	  source/headers/geos/operation.h, source/io/Unload.cpp,
+	  GeometryGraphOperation::li made a non-static member, and not more
+	  a pointer
+2006-03-02 14:21  Sandro Santilli <strk at keybit.net>
+	* [r1124] capi/geos_c.cpp: DEBUG => GEOS_DEBUG [#44]
+2006-03-02 12:12  Sandro Santilli <strk at keybit.net>
+	* [r1123] source/algorithm/LineIntersector.cpp,
+	  source/geomgraph/GeometryGraph.cpp, source/geomgraph/Node.cpp,
+	  source/geomgraph/NodeMap.cpp, source/geomgraph/PlanarGraph.cpp,
+	  source/geomgraph/Position.cpp,
+	  source/operation/buffer/OffsetCurveBuilder.cpp,
+	  source/operation/polygonize/Polygonizer.cpp: Renamed DEBUG macros
+	  to GEOS_DEBUG, all wrapped in #ifndef block to allow global
+	  override (bug#43)
+2006-03-02 11:03  Sandro Santilli <strk at keybit.net>
+	* [r1122] tests/xmltester/XMLTester.cpp: Added assertion in relate
+	  test handler
+2006-03-02 11:00  Sandro Santilli <strk at keybit.net>
+	* [r1121] source/geom/IntersectionMatrix.cpp,
+	  source/headers/geos/geom.h: Changed IntersectionMatrix funx
+	  taking strings to take const string& instead
+2006-03-02 10:25  Sandro Santilli <strk at keybit.net>
+	* [r1120] tests/xmltester/XMLTester.cpp,
+	  tests/xmltester/buffer.xml: Added support for FLOATING_SINGLE
+	  precisionmodel in XML tests
+2006-03-02 10:03  Sandro Santilli <strk at keybit.net>
+	* [r1119] capi/Makefile.am, capi/geos_c.cpp: Removed use of strdup,
+	  changed GEOSjtsport() to return const char* instead of char* (is
+	  not advertised in headerfile, so no compatibility problems)
+2006-03-02 09:51  Sandro Santilli <strk at keybit.net>
+	* [r1118] source/operation/overlay/OverlayOp.cpp: Fixes in DEBUG
+	  lines (bug#42)
+2006-03-02 09:49  Sandro Santilli <strk at keybit.net>
+	* [r1117] source/headers/geos/LineSegment.inl: Changed LineSegment
+	  output to use 'LINESEGMENT' label rather then 'LINESTRING'
+	* [r1116] source/headers/geos/timeval.h: WINCE implmentation of
+	  gettimeofday (bug#40)
+2006-03-02 09:46  Sandro Santilli <strk at keybit.net>
+	* [r1115] source/operation/buffer/SubgraphDepthLocater.cpp: cleaned
+	  up debugging lines
+2006-03-01 18:44  Sandro Santilli <strk at keybit.net>
+	* [r1114] NEWS: added note about getInteriorPoint() possibly
+	  returning NULL
+2006-03-01 18:43  Sandro Santilli <strk at keybit.net>
+	* [r1113] capi/geos_c.cpp: Handled new NULL return from
+	  Geometry::getInteriorPoint()
+2006-03-01 18:37  Sandro Santilli <strk at keybit.net>
+	* [r1112] source/algorithm/InteriorPointLine.cpp,
+	  source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
+	  Geometry::createPointFromInternalCoord dropped (it's a
+	  duplication of GeometryFactory::createPointFromInternalCoord).
+	  Fixed bugs in InteriorPoint* and getCentroid() inserted by
+	  previous commits.
+2006-03-01 18:19  Sandro Santilli <strk at keybit.net>
+	* [r1111] tests/xmltester/Makefile.am,
+	  tests/xmltester/TestCentroid.xml,
+	  tests/xmltester/testLeaksBig.xml: getCentroid() test moved from
+	  testLeaksBig.xml to TestCentroid.xml (synced with JTS-1.7)
+2006-03-01 18:15  Sandro Santilli <strk at keybit.net>
+	* [r1110] tests/xmltester/Makefile.am,
+	  tests/xmltester/TestInteriorPoint.xml,
+	  tests/xmltester/testLeaksBig.xml: Extracted getInteriorPoint()
+	  tests out of testLeaksBig.xml and into TestInteriorPoint.xml
+	  (synced with JTS-1.7).
+2006-03-01 18:14  Sandro Santilli <strk at keybit.net>
+	* [r1109] tests/xmltester/XMLTester.cpp: Handled NULL return from
+2006-03-01 17:16  Sandro Santilli <strk at keybit.net>
+	* [r1108] source/algorithm/CentroidArea.cpp,
+	  source/algorithm/MinimumDiameter.cpp, source/geom/Geometry.cpp,
+	  source/geom/LineSegment.cpp, source/headers/geos/LineSegment.inl,
+	  source/headers/geos/Makefile.am, source/headers/geos/geom.h,
+	  source/headers/geos/inline.h, source/headers/geos/opBuffer.h,
+	  source/operation/distance/DistanceOp.cpp: LineSegment class made
+	  final and optionally (compile-time) inlined.
+	  Reduced heap allocations in Centroid{Area,Line,Point} and
+	  InteriorPoint{Area,Line,Point}.
+2006-03-01 16:42  Sandro Santilli <strk at keybit.net>
+	* [r1107] source/Makefile.vc: Fixed include name (Bug#41)
+2006-03-01 16:01  Sandro Santilli <strk at keybit.net>
+	* [r1106] source/noding/SegmentNodeList.cpp: Fixed const
+	  correctness of operator<<(ostream&, SegmentNodeList&) [bug#37]
+2006-03-01 13:49  Sandro Santilli <strk at keybit.net>
+	* [r1105] source/index/quadtree/Quadtree.cpp: Fixed debug lines
+	  (bug#36)
+2006-03-01 13:48  Sandro Santilli <strk at keybit.net>
+	* [r1104] tests/xmltester/Stackwalker.cpp: Fixed missing type
+	  specifier (bug#35)
+2006-03-01 13:06  Sandro Santilli <strk at keybit.net>
+	* [r1103] tests/xmltester/Makefile.am,
+	  tests/xmltester/XMLTester.cpp, tests/xmltester/buffer.xml: Used
+	  FLOATING precision model in buffer.xml test, added expected
+	  results,
+	  changed XMLTester.cpp to use a tolerance when comparing expected
+	  and obtained
+	  results from buffer operations.
+2006-03-01 12:12  Sandro Santilli <strk at keybit.net>
+	* [r1102] tests/xmltester/XMLTester.cpp: Fixed a bug in verbose
+	  output preventing geometry arg 'A' from being properly printed
+2006-03-01 11:47  Sandro Santilli <strk at keybit.net>
+	* [r1101] source/Makefile.vc: Applied patch by Mateusz Loskot (Bug
+	  #39)
+2006-03-01 10:48  Sandro Santilli <strk at keybit.net>
+	* [r1100] source/headers/geos/opValid.h,
+	  source/operation/valid/TopologyValidationError.cpp: Changed
+	  static TopologyValidationError::errMsg[] from 'string' to 'const
+	  char*'
+	  to reduce dynamic memory allocations.
+2006-03-01 10:39  Sandro Santilli <strk at keybit.net>
+	* [r1099] source/headers/geos/unload.h, source/io/Unload.cpp: ctor
+	  and dtor made private and inlined
+2006-03-01 09:56  Sandro Santilli <strk at keybit.net>
+	* [r1098] tests/xmltester/XMLTester.cpp: Case insensitive operation
+	  names and geometry arguments names (a/b)
+2006-03-01 09:43  Sandro Santilli <strk at keybit.net>
+	* [r1097] tests/xmltester/XMLTester.cpp: Unrecognized tests always
+	  printed (was only printed when verbose before)
+2006-03-01 08:52  Sandro Santilli <strk at keybit.net>
+	* [r1096] source/dirlist.mk: File to be included by Makefile.vc
+2006-02-28 19:22  Sandro Santilli <strk at keybit.net>
+	* [r1095] source/headers/geos/opBuffer.h,
+	  source/operation/buffer/OffsetCurveBuilder.cpp: Fixed in-place
+	  definition of static members in OffsetCurveBuilder (bug#33)
+2006-02-28 19:18  Sandro Santilli <strk at keybit.net>
+	* [r1094] tests/xmltester/XMLTester.cpp: Added cctype include (bug
+	  #34)
+2006-02-28 17:44  Sandro Santilli <strk at keybit.net>
+	* [r1093] source/geom/Coordinate.cpp, source/headers/geos/geom.h,
+	  source/headers/geos/noding.h, source/noding/SegmentNode.cpp,
+	  source/operation/buffer/BufferBuilder.cpp: Added a check in
+	  SegmentNode::addSplitEdge to prevent attempts
+	  to build SegmentString with less then 2 points.
+	  This is a temporary fix for the buffer.xml assertion failure,
+	  temporary
+	  as Martin Davis review would really be needed there.
+2006-02-28 15:34  Sandro Santilli <strk at keybit.net>
+	* [r1092] tests/xmltester/XMLTester.cpp: Fix for VC++ builds (Bug
+	  #32)
+2006-02-28 14:34  Sandro Santilli <strk at keybit.net>
+	* [r1091] source/geom/Coordinate.cpp,
+	  source/geom/PrecisionModel.cpp,
+	  source/geomgraph/EdgeEnd.cpp, source/geomgraph/EdgeList.cpp,
+	  source/headers/geos/geom.h, source/headers/geos/geomgraph.h,
+	  source/headers/geos/noding.h, source/headers/geos/opBuffer.h,
+	  source/noding/MCIndexNoder.cpp, source/noding/SegmentNode.cpp,
+	  tests/xmltester/buffer.xml: Added many assertions and debugging
+	  output hunting for a bug in BufferOp
+2006-02-28 14:05  Sandro Santilli <strk at keybit.net>
+	* [r1090] source/geomgraph/Edge.cpp: Fixed a bug in a debugging
+	  line
+2006-02-28 13:08  Sandro Santilli <strk at keybit.net>
+	* [r1089] source/headers/geos/noding.h: Added missing definition of
+	  IteratedNoder::MAX_ITER, moving it to private access level
+2006-02-28 11:15  Sandro Santilli <strk at keybit.net>
+	* [r1088] tests/xmltester/markup/MarkupSTL.cpp: Fixed strchr use
+	  (Bug #30)
+2006-02-28 11:11  Sandro Santilli <strk at keybit.net>
+	* [r1087] capi/geos_c.cpp: Fixed typo in GEOSLenght function
+2006-02-28 05:03  sgillies
+	* [r1085] NEWS, capi/geos_c.cpp, capi/geos_c.h.in: added
+	  GEOSLength(), GEOSEnvelope() to the C API
+2006-02-27 14:41  Sandro Santilli <strk at keybit.net>
+	* [r1076] tests/xmltester/XMLTester.cpp: More verbose handling of
+	  exceptions
+2006-02-27 11:53  Sandro Santilli <strk at keybit.net>
+	* [r1075] source/geomgraph/DirectedEdgeStar.cpp,
+	  source/headers/geos/geomgraph.h: DirectedEdgeStar made more safe
+	  trough assert(), use of standard iterator and
+	  dynamic casts substituting static ones.
+2006-02-27 09:05  Sandro Santilli <strk at keybit.net>
+	* [r1074] source/algorithm/LineIntersector.cpp,
+	  source/headers/geos/opOverlay.h, source/headers/geos/operation.h,
+	  source/operation/overlay/OverlayOp.cpp: Doxygen comments, a few
+	  inlines and general cleanups
+2006-02-24 16:20  Sandro Santilli <strk at keybit.net>
+	* [r1073] source/geom/PrecisionModel.cpp,
+	  source/headers/geos/util.h, source/util/Makefile.am,
+	  source/util/math.cpp, tests/xmltester/testLeaksBig.xml: Added
+	  Mateusz implementation of round() in a new math.cpp file
+	  named sym_round(). Changed use of rint_vc to sym_round in
+	  PrecisionModel.
+	  Moved rint_vc to math.cpp (geos::util namespace), to be renamed
+	  to something more meaningful
+2006-02-24 15:39  Sandro Santilli <strk at keybit.net>
+	* [r1072] source/geom/Coordinate.cpp, source/headers/geos/geom.h,
+	  source/planargraph/planarNode.cpp, tests/xmltester/Makefile.am: -
+	  operator>> for Coordinate, planarNode and planarEdge
+	  - Fixed bug in planarGraphComponent::setMarked
+	  - Added linemerge.xml test (single test, should grow a bit)
+2006-02-24 12:19  Sandro Santilli <strk at keybit.net>
+	* [r1071] doc/Doxyfile.in: Fixed typo in config file
+2006-02-23 23:17  Sandro Santilli <strk at keybit.net>
+	* [r1070] source/geom/Coordinate.cpp, source/geom/Envelope.cpp,
+	  source/geom/GeometryFactory.cpp, source/geom/LineSegment.cpp,
+	  source/geom/PrecisionModel.cpp, source/headers/geos/geom.h,
+	  source/util/GeometricShapeFactory.cpp: -
+	  Coordinate::nullCoordinate made private
+	  - Simplified Coordinate inline definitions
+	  - LMGeometryComponentFilter definition moved to LineMerger.cpp
+	  file
+	  - Misc cleanups
+2006-02-23 20:32  Sandro Santilli <strk at keybit.net>
+	* [r1069] tests/xmltester/XMLTester.cpp: Added support for
+	  LineMerge tests. Exception printed on stderr.
+2006-02-23 20:05  Sandro Santilli <strk at keybit.net>
+	* [r1068] source/headers/geos/noding.h,
+	  source/headers/geos/opBuffer.h, source/noding/MCIndexNoder.cpp,
+	  source/noding/SimpleNoder.cpp,
+	  source/operation/buffer/BufferOp.cpp: Fixed bug in MCIndexNoder
+	  constructor making memory checker go crazy, more
+	  doxygen-friendly comments, miscellaneous cleanups
+2006-02-23 20:03  Sandro Santilli <strk at keybit.net>
+	* [r1067] doc/Doxyfile.in: updated to also show undocumented
+	  methods
+2006-02-23 11:54  Sandro Santilli <strk at keybit.net>
+	* [r1066] source/geom/MultiLineString.cpp,
+	  source/geomgraph/Edge.cpp, source/geomgraph/EdgeList.cpp,
+	  source/geomgraph/GeometryGraph.cpp, source/geomgraph/NodeMap.cpp,
+	  source/geomgraph/index/SegmentIntersector.cpp,
+	  source/headers/geos/indexStrtree.h, source/headers/geos/noding.h,
+	  source/headers/geos/spatialIndex.h, source/headers/geos/util.h,
+	  source/noding/MCIndexNoder.cpp, source/noding/ScaledNoder.cpp,
+	  source/noding/snapround/MCIndexSnapRounder.cpp,
+	  source/operation/buffer/BufferBuilder.cpp,
+	  source/operation/buffer/BufferOp.cpp,
+	  source/util/Assert.cpp, source/util/AssertionFailedException.cpp,
+	  source/util/Makefile.am,
+	  tests/xmltester/buffer.xml: - MCIndexPointSnapper
+	  - MCIndexSnapRounder
+	  - SnapRounding BufferOp
+	  - ScaledNoder
+	  - GEOSException hierarchy cleanups
+	  - SpatialIndex memory-friendly query interface
+	  - GeometryGraph::getBoundaryNodes memory-friendly
+	  - NodeMap::getBoundaryNodes memory-friendly
+	  - Cleanups in geomgraph::Edge
+	  - Added an XML test for snaprounding buffer (shows leaks, working
+	  on it)
+2006-02-21 16:53  Sandro Santilli <strk at keybit.net>
+	* [r1065] source/algorithm/MCPointInRing.cpp,
+	  source/headers/geos/indexChain.h, source/headers/geos/noding.h,
+	  source/index/chain/MonotoneChainBuilder.cpp,
+	  source/index/chain/MonotoneChainSelectAction.cpp,
+	  source/index/chain/indexMonotoneChain.cpp,
+	  source/noding/snapround/HotPixel.cpp,
+	  source/noding/snapround/MCIndexPointSnapper.cpp,
+	  MCIndexPointSnapper, MCIndexSnapRounder
+2006-02-20 21:04  Sandro Santilli <strk at keybit.net>
+	* [r1064] source/headers/geos/geomgraph.h,
+	  source/index/strtree/STRtree.cpp: - namespace geos::index
+	  - SpatialIndex interface synced
+2006-02-20 10:14  Sandro Santilli <strk at keybit.net>
+	* [r1063] ChangeLog, doc/Doxyfile.in,
+	  source/geom/Geometry.cpp, source/geomgraph/EdgeList.cpp,
+	  source/headers/geos/indexBintree.h,
+	  source/headers/geos/indexSweepline.h, source/headers/geos/io.h,
+	  source/index/bintree/BinTreeInterval.cpp,
+	  source/index/bintree/BinTreeNode.cpp,
+	  source/index/bintree/Bintree.cpp, source/index/bintree/Key.cpp,
+	  source/index/bintree/NodeBase.cpp, source/index/bintree/Root.cpp,
+	  source/index/chain/MonotoneChainOverlapAction.cpp,
+	  source/io/Unload.cpp, source/noding/MCIndexNoder.cpp,
+	  source/operation/valid/SweeplineNestedRingTester.cpp: -
+	  namespaces geos::index::*
+	  - Doxygen documentation cleanup
+2006-02-19 19:46  Sandro Santilli <strk at keybit.net>
+	* [r1062] NEWS, capi/geos_c.cpp, configure.in, doc/example.cpp,
+	  source/algorithm/ConvexHull.cpp,
+	  source/geom/Coordinate.cpp, source/geom/Geometry.cpp,
+	  source/geom/LineSegment.cpp, source/geom/LineString.cpp,
+	  source/geom/MultiLineString.cpp, source/geom/MultiPoint.cpp,
+	  source/geom/Polygon.cpp, source/geomgraph/Depth.cpp,
+	  source/geomgraph/EdgeIntersectionList.cpp,
+	  source/geomgraph/GraphComponent.cpp, source/geomgraph/Label.cpp,
+	  source/geomgraph/Node.cpp, source/geomgraph/NodeFactory.cpp,
+	  source/geomgraph/Position.cpp, source/geomgraph/Quadrant.cpp,
+	  source/geomgraph/index/Makefile.am,
+	  source/geomgraph/index/MonotoneChain.cpp,
+	  source/headers/geos/planargraph.h, source/index/Makefile.am,
+	  source/index/bintree, source/index/bintree/.cvsignore,
+	  source/index/bintree/Makefile.am, source/index/chain,
+	  source/index/chain/.cvsignore, source/index/chain/Makefile.am,
+	  source/index/quadtree, source/index/quadtree/.cvsignore,
+	  source/index/quadtree/Makefile.am, source/index/strtree,
+	  source/index/strtree/.cvsignore,
+	  source/index/strtree/Makefile.am, source/index/sweepline,
+	  source/index/sweepline/.cvsignore,
+	  source/index/sweepline/Makefile.am, source/io/Unload.cpp,
+	  source/noding/IntersectionAdder.cpp,
+	  source/operation/distance/GeometryLocation.cpp,
+	  source/operation/overlay/MaximalEdgeRing.cpp,
+	  source/operation/overlay/MinimalEdgeRing.cpp,
+	  source/operation/overlay/OverlayOp.cpp,
+	  tests/xmltester/XMLTester.cpp: Packages <-> namespaces mapping
+	  for most GEOS internal code (uncomplete, but working). Dir-level
+	  libs for index/ subdirs.
+2006-02-18 21:08  Sandro Santilli <strk at keybit.net>
+	* [r1061] NEWS, source/geom/Geometry.cpp,
+	  source/noding/Makefile.am, source/noding/NodingValidator.cpp,
+	  source/noding/ScaledNoder.cpp, source/noding/SegmentNodeList.cpp,
+	  source/operation/buffer/OffsetCurveSetBuilder.cpp: - new
+	  CoordinateSequence::applyCoordinateFilter method (slow but
+	  useful)
+	  - SegmentString::getCoordinates() doesn't return a clone anymore.
+	  - SegmentString::getCoordinatesRO() obsoleted.
+	  - SegmentString constructor does not promises constness of passed
+	  CoordinateSequence anymore.
+	  - NEW ScaledNoder class
+	  - Stubs for MCIndexPointSnapper and MCIndexSnapRounder
+	  - Simplified internal interaces of OffsetCurveBuilder and
+	  OffsetCurveSetBuilder
+2006-02-16 08:41  Sandro Santilli <strk at keybit.net>
+	* [r1060] source/noding/NodingValidator.cpp: Fixed include:
+	  "util.h" => "geos/util.h"
+	* [r1059] source/headers/geos/nodingSnapround.h: added <cmath>
+	  include for round()
+2006-02-16 08:19  Sandro Santilli <strk at keybit.net>
+	* [r1058] source/noding/IntersectionAdder.cpp: Missed from last
+	  commit
+2006-02-15 22:48  sgillies
+	* [r1057] capi/geos_c.h.in: added GEOSGeomType
+2006-02-15 17:19  Sandro Santilli <strk at keybit.net>
+	* [r1056] NEWS, source/geomgraph/EdgeNodingValidator.cpp,
+	  source/headers/geos/noding.h, source/noding/NodingValidator.cpp,
+	  source/noding/snapround/SimpleSnapRounder.cpp: NodingValidator
+	  synced with JTS-1.7, added CoordinateSequence::operator[]
+	  and size() to easy port maintainance.
+2006-02-15 14:59  Sandro Santilli <strk at keybit.net>
+	* [r1055] source/headers/geos/noding.h,
+	  source/noding/SegmentString.cpp: JTS-1.7 sync for:
+	  noding/SegmentNode.cpp
+	  noding/SegmentNodeList.cpp
+	  noding/SegmentString.cpp
+2006-02-14 13:28  Sandro Santilli <strk at keybit.net>
+	* [r1054] NEWS, configure.in, source/algorithm/LineIntersector.cpp,
+	  source/noding/MCQuadtreeNoder.cpp, source/noding/Makefile.am,
+	  source/noding/Noder.cpp, source/noding/NodingValidator.cpp,
+	  source/noding/Octant.cpp, source/noding/SegmentNode.cpp,
+	  source/noding/nodingSegmentIntersector.cpp,
+	  source/noding/snapround, source/noding/snapround/.cvsignore,
+	  source/noding/snapround/Makefile.am,
+	  source/noding/snapround/SegmentSnapper.cpp,
+	  source/noding/snapround/SimpleSegmentStringsSnapper.cpp,
+	  source/noding/snapround/SnapRounder.cpp,
+	  tests/xmltester/XMLTester.cpp: New SnapRounding code ported from
+	  JTS-1.7 (not complete yet).
+	  Buffer op optimized by using new snaprounding code.
+	  Leaks fixed in XMLTester.
+2006-02-09 15:52  Sandro Santilli <strk at keybit.net>
+	* [r1053] capi/geos_c.cpp, capi/geos_c.cpp.bak, configure.in,
+	  doc/example.cpp, source/algorithm/CGAlgorithms.cpp,
+	  source/examples/CoordinateSequencesExample.cpp,
+	  source/examples/CustomCoordinateSequenceExample.cpp,
+	  source/examples/CustomPointCoordinateSequence.cpp,
+	  source/geom/GeometryCollectionIterator.cpp,
+	  source/geom/GeometryComponentFilter.cpp,
+	  source/geom/IntersectionMatrix.cpp, source/geom/LineString.cpp,
+	  source/geom/LinearRing.cpp, source/geom/Location.cpp,
+	  source/geom/TopologyException.cpp,
+	  source/geomgraph/EdgeEndStar.cpp, source/geomgraph/EdgeRing.cpp,
+	  source/headers/geos/opBuffer.h, source/headers/geos/util.h,
+	  source/index/quadtree/DoubleBits.cpp,
+	  source/io/ParseException.cpp, source/io/WKBReader.cpp,
+	  source/io/WKBWriter.cpp, source/io/WKTReader.cpp,
+	  tests/xmltester/CTS.cpp, tests/xmltester/SimpleWKTTester.cpp,
+	  tests/xmltester/XMLTester.cpp: GEOSException derived from
+	  std::exception; always thrown and cought by const ref.
+2006-02-09 15:41  sgillies
+	* [r1052] configure.in: incrementing C API patch level
+2006-02-09 14:49  sgillies
+	* [r1051] capi/geos_c.cpp, capi/geos_c.h.in, capi/geostest.c: added
+	  GEOSArea() to the C API
+2006-02-09 13:44  Sandro Santilli <strk at keybit.net>
+	* [r1050] source/geom/Geometry.cpp, source/headers/geos/geom.h,
+	  source/io/WKBReader.cpp: Added support for SRID in input WKB,
+	  undeprecated Geometry::setSRID
+	  and Geometry::getSRID
+2006-02-09 01:47  frank
+	* [r1049] source/io/WKBReader.cpp: Botched last fix. Hopefully this
+	  is better.
+2006-02-09 01:13  Sandro Santilli <strk at keybit.net>
+	* [r1048] ChangeLog, source/operation/linemerge/LineSequencer.cpp:
+	  Added missing <limits> include
+2006-02-09 00:06  frank
+	* [r1047] ChangeLog, source/io/WKBReader.cpp: Fixed support for
+	  consuming WKB for 'POLYGON EMPTY' with numRings==0.
+	  http://bugzilla.remotesensing.org/show_bug.cgi?id=1064
+2006-02-08 17:18  Sandro Santilli <strk at keybit.net>
+	* [r1046] NEWS, source/geom/Envelope.cpp, source/geom/Geometry.cpp,
+	  source/geom/LineString.cpp, source/geom/MultiLineString.cpp,
+	  source/geom/MultiPoint.cpp, source/headers/geos/geom.h,
+	  source/headers/geos/io.h, source/headers/geos/opBuffer.h,
+	  source/headers/geos/opValid.h, source/io/WKTWriter.cpp,
+	  source/operation/valid/IsValidOp.cpp: - New
+	  WKTWriter::toLineString and ::toPoint convenience methods
+	  - New IsValidOp::setSelfTouchingRingFormingHoleValid method
+	  - New Envelope::centre()
+	  - New Envelope::intersection(Envelope)
+	  - New Envelope::expandBy(distance, [ydistance])
+	  - New LineString::reverse()
+	  - New MultiLineString::reverse()
+	  - New Geometry::buffer(distance, quadSeg, endCapStyle)
+	  - Obsoleted toInternalGeometry/fromInternalGeometry
+	  - More const-correctness in Buffer "package"
+2006-02-08 13:07  Sandro Santilli <strk at keybit.net>
+	* [r1045] NEWS: Added note about new LineSequencer class
+2006-02-08 12:59  Sandro Santilli <strk at keybit.net>
+	* [r1044] source/headers/geos/geom.h,
+	  source/headers/geos/opLinemerge.h,
+	  source/operation/linemerge/LineSequencer.cpp,
+	  source/operation/linemerge/Makefile.am,
+	  source/planargraph/algorithm/ConnectedSubgraphFinder.cpp,
+	  source/planargraph/planarDirectedEdgeStar.cpp,
+	  source/planargraph/planarSubgraph.cpp: - NEW
+	  Geometry::applyComponentFilter() templated method
+	  - Changed Geometry::getGeometryN() to take unsigned int and
+	  getNumGeometries
+	  to return unsigned int.
+	  - Changed planarNode::getDegree() to return unsigned int.
+	  - Added Geometry::NonConstVect typedef
+	  - NEW LineSequencer class
+	  - Changed planarDirectedEdgeStar::outEdges from protected to
+	  private
+	  - added static templated setVisitedMap to change Visited flag
+	  for all values in a map
+	  - Added const versions of some planarDirectedEdgeStar methods.
+	  - Added containers typedefs for planarDirectedEdgeStar
+2006-02-07 13:26  Sandro Santilli <strk at keybit.net>
+	* [r1043] source/Makefile.am: Added missing geomgraph SUBDIR
+2006-02-07 12:02  Sandro Santilli <strk at keybit.net>
+	* [r1042] tests/xmltester/Makefile.am: Removed TestConvexHull.xml
+	  file (already included in testLeaksBig.xml
+2006-02-06 11:27  Sandro Santilli <strk at keybit.net>
+	* [r1041] tests, tests/.cvsignore: new entry
+2006-02-05 17:14  Sandro Santilli <strk at keybit.net>
+	* [r1040] NEWS, source/headers/geos/planargraph.h,
+	  source/planargraph/Makefile.am, source/planargraph/algorithm,
+	  source/planargraph/planarNodeMap.cpp,
+	  source/planargraph/planarPlanarGraph.cpp: - New
+	  ConnectedSubgraphFinder class.
+	  - More iterators returning methods, inlining and cleanups
+	  in planargraph.
+2006-02-04 00:54  Sandro Santilli <strk at keybit.net>
+	* [r1039] ChangeLog, NEWS, source/headers/geos/geom.h,
+	  source/planargraph/planarSubgraph.cpp, swig/ruby/Makefile.am,
+	  tests/xmltester/Makefile.am: - Doxygen dox updated
+	  - LineStringLT struct moved from geomgraph.h to geom.h
+	  - New planarSubgraph class
+	  - Fixed ruby Makefiles to avoid running tests when disabled
+	  - Renamed TESTS variable to XMLTESTS to not confuse 'make check'
+	  rule
+2006-02-03 09:26  Sandro Santilli <strk at keybit.net>
+	* [r1038] source/geom/util/ShortCircuitedGeometryVisitor.cpp: Added
+	  missing file
+2006-02-02 02:20  Sandro Santilli <strk at keybit.net>
+	* [r1037] source/geom/Polygon.cpp: Fixed bug in isRectangle()
+	  failing to detect rectangles.
+2006-02-01 22:22  Sandro Santilli <strk at keybit.net>
+	* [r1036] NEWS: updated
+2006-02-01 22:21  Sandro Santilli <strk at keybit.net>
+	* [r1035] source/geom/Geometry.cpp, source/geom/Polygon.cpp,
+	  source/geom/util/Makefile.am, source/headers/geos/geom.h,
+	  source/headers/geos/opPredicate.h,
+	  source/headers/geos/planargraph.h, source/operation/Makefile.am,
+	  source/operation/predicate/Makefile.am,
+	  source/planargraph/planarGraphComponent.cpp: - Added
+	  rectangle-based optimizations of intersects() and contains() ops
+	  - Inlined all planarGraphComponent class
+2006-01-31 21:42  Sandro Santilli <strk at keybit.net>
+	* [r1034] source/Makefile.vc: Added DepthSegment object
+2006-01-31 21:36  Sandro Santilli <strk at keybit.net>
+	* [r1033] swig/geos.i: Fixes error in calling read_hex from
+	  scripting languages.
+2006-01-31 21:35  Sandro Santilli <strk at keybit.net>
+	* [r1032] capi/Makefile.in: Erroneusly ended in CVS
+2006-01-31 21:17  Sandro Santilli <strk at keybit.net>
+	* [r1031] source/operation/predicate/RectangleContains.cpp: Added
+	  missing file from last commits
+2006-01-31 19:11  Sandro Santilli <strk at keybit.net>
+	* [r1030] source/bigtest: Another left-over from cleanups
+2006-01-31 19:10  Sandro Santilli <strk at keybit.net>
+	* [r1029] source/capi, source/test: Removed leftover files in
+	  obsoleted dirs
+2006-01-31 19:07  Sandro Santilli <strk at keybit.net>
+	* [r1028] Makefile.am, NEWS, README, capi, capi/.cvsignore,
+	  capi/Makefile.am, capi/Makefile.in, capi/geos_c.cpp,
+	  capi/geos_c.cpp.bak, capi/geos_c.h.in, capi/geostest.c,
+	  capi/test.wkt, configure.in, doc/Doxyfile.in, doc/Makefile.am,
+	  doc/example.cpp, source, source/.cvsignore, source/Makefile.am,
+	  source/algorithm, source/algorithm/.cvsignore,
+	  source/algorithm/CentroidArea.cpp,
+	  source/algorithm/CentroidLine.cpp,
+	  source/algorithm/InteriorPointLine.cpp,
+	  source/algorithm/MCPointInRing.cpp, source/algorithm/Makefile.am,
+	  source/algorithm/SIRtreePointInRing.cpp,
+	  source/algorithm/SimplePointInAreaLocator.cpp,
+	  source/bigtest/GeometryTestFactory.cpp,
+	  source/bigtest/Makefile.am,
+	  source/bigtest/TestSweepLineSpeed.cpp, source/bigtest/bigtest.h,
+	  source/capi/Makefile.am, source/capi/geos_c.cpp,
+	  source/capi/geos_c.h.in, source/capi/geostest.c,
+	  source/capi/test.wkt, source/examples/CPCLException.cpp,
+	  source/geom/CoordinateArraySequenceFactory.cpp,
+	  source/geom/CoordinateList.cpp,
+	  source/geom/CoordinateSequence.cpp,
+	  source/geom/DefaultCoordinateSequence.cpp,
+	  source/geom/DefaultCoordinateSequenceFactory.cpp,
+	  source/geom/IntersectionMatrix.cpp, source/geom/LineSegment.cpp,
+	  source/geom/Makefile.am, source/geom/MultiLineString.cpp,
+	  source/geom/Point.cpp, source/geom/Polygon.cpp, source/geom/util,
+	  source/geom/util/.cvsignore, source/geom/util/GeometryEditor.cpp,
+	  source/geom/util/LinearComponentExtracter.cpp,
+	  source/geom/util/PointExtracter.cpp,
+	  source/geom/util/PolygonExtracter.cpp, source/geomgraph,
+	  source/geomgraph/.cvsignore, source/geomgraph/Edge.cpp,
+	  source/geomgraph/GeometryGraph.cpp, source/geomgraph/Makefile.am,
+	  source/geomgraph/PlanarGraph.cpp, source/geomgraph/index,
+	  source/geomgraph/index/.cvsignore,
+	  source/headers/geos/opDistance.h,
+	  source/headers/geos/precision.h, source/headers/geos/util.h,
+	  source/index, source/index/.cvsignore, source/index/Makefile.am,
+	  source/index/chain/indexMonotoneChain.cpp, source/io,
+	  source/io/.cvsignore, source/io/Makefile.am,
+	  source/io/Unload.cpp, source/io/WKTReader.cpp, source/io/markup,
+	  source/noding, source/noding/.cvsignore,
+	  source/operation, source/operation/.cvsignore,
+	  source/operation/Makefile.am, source/operation/buffer,
+	  source/operation/buffer/.cvsignore,
+	  source/operation/distance, source/operation/distance/.cvsignore,
+	  source/operation/distance/DistanceOp.cpp,
+	  source/operation/distance/Makefile.am,
+	  source/operation/linemerge,
+	  source/operation/linemerge/.cvsignore,
+	  source/operation/linemerge/EdgeString.cpp,
+	  source/operation/linemerge/LineMergeGraph.cpp,
+	  source/operation/linemerge/Makefile.am, source/operation/overlay,
+	  source/operation/overlay/.cvsignore,
+	  source/operation/overlay/PolygonBuilder.cpp,
+	  source/operation/polygonize,
+	  source/operation/polygonize/.cvsignore,
+	  source/operation/polygonize/Makefile.am,
+	  source/operation/polygonize/PolygonizeGraph.cpp,
+	  source/operation/polygonize/polygonizeEdgeRing.cpp,
+	  source/operation/predicate,
+	  source/operation/predicate/.cvsignore,
+	  source/operation/predicate/RectangleIntersects.cpp,
+	  source/operation/predicate/SegmentIntersectionTester.cpp,
+	  source/operation/relate, source/operation/relate/.cvsignore,
+	  source/operation/relate/Makefile.am, source/operation/valid,
+	  source/operation/valid/.cvsignore,
+	  source/operation/valid/IsValidOp.cpp,
+	  source/operation/valid/Makefile.am,
+	  source/operation/valid/QuadtreeNestedRingTester.cpp,
+	  source/operation/valid/RepeatedPointTester.cpp,
+	  source/operation/valid/SimpleNestedRingTester.cpp,
+	  source/planargraph, source/planargraph/.cvsignore,
+	  source/planargraph/Makefile.am, source/precision,
+	  source/precision/.cvsignore, source/precision/Makefile.am,
+	  source/test/CTS.cpp, source/test/Makefile.am,
+	  source/test/SimpleWKTTester.cpp, source/test/Stackwalker.cpp,
+	  source/test/Stackwalker.h, source/test/WKTIn, source/test/WKTOut,
+	  source/test/XMLTester.cpp, source/test/XMLTester.h,
+	  source/test/hexwkb.xml, source/test/test.xml,
+	  source/test/testLeaksBig.xml, source/util,
+	  source/util/.cvsignore, source/util/CoordinateArrayFiter.cpp,
+	  source/util/GeometricShapeFactory.cpp, source/util/Makefile.am,
+	  source/util/UniqueCoordinateArrayFilter.cpp, tests,
+	  tests/Makefile.am, tests/bigtest, tests/bigtest/.cvsignore,
+	  tests/bigtest/GeometryTestFactory.cpp, tests/bigtest/Makefile.am,
+	  tests/bigtest/TestSweepLineSpeed.cpp, tests/bigtest/bigtest.h,
+	  tests/xmltester, tests/xmltester/.cvsignore,
+	  tests/xmltester/CTS.cpp, tests/xmltester/Makefile.am,
+	  tests/xmltester/Stackwalker.cpp, tests/xmltester/Stackwalker.h,
+	  tests/xmltester/WKTIn, tests/xmltester/WKTOut,
+	  tests/xmltester/hexwkb.xml, tests/xmltester/markup,
+	  tests/xmltester/markup/MarkupSTL.cpp,
+	  tests/xmltester/markup/MarkupSTL.h, tests/xmltester/test.xml,
+	  tests/xmltester/testLeaksBig.xml: - Renamed
+	  DefaultCoordinateSequence to CoordinateArraySequence.
+	  - Moved GetNumGeometries() and GetGeometryN() interfaces
+	  from GeometryCollection to Geometry class.
+	  - Added getAt(int pos, Coordinate &to) funtion to
+	  CoordinateSequence class.
+	  - Reworked automake scripts to produce a static lib for each
+	  subdir and
+	  then link all subsystem's libs togheter
+	  - Moved C-API in it's own top-level dir capi/
+	  - Moved source/bigtest and source/test to tests/bigtest and
+	  test/xmltester
+	  - Fixed PointLocator handling of LinearRings
+	  - Changed CoordinateArrayFilter to reduce memory copies
+	  - Changed UniqueCoordinateArrayFilter to reduce memory copies
+	  - Added CGAlgorithms::isPointInRing() version working with
+	  Coordinate::ConstVect type (faster!)
+	  - Ported JTS-1.7 version of ConvexHull with big attention to
+	  memory usage optimizations.
+	  - Improved XMLTester output and user interface
+	  - geos::geom::util namespace used for geom/util stuff
+	  - Improved memory use in geos::geom::util::PolygonExtractor
+	  - New ShortCircuitedGeometryVisitor class
+	  - New operation/predicate package
+2006-01-30 21:59  frank
+	* [r1027] source/algorithm/LineIntersector.cpp: yikes! comment out
+	  debug define again
+2006-01-30 21:58  frank
+	* [r1026] ChangeLog, source/algorithm/LineIntersector.cpp: fixed up
+	  some debug messages
+2006-01-30 16:55  Sandro Santilli <strk at keybit.net>
+	* [r1025] macros/ac_python_devel.m4, swig/python/Makefile.am,
+	  swig/python/example.py, swig/python/geos.pth,
+	  swig/python/python.i, swig/ruby/test/geos_tests.rb: More patches
+	  from Charlie Savage
+2006-01-27 08:58  Sandro Santilli <strk at keybit.net>
+	* [r1024] configure.in: Python and Ruby build disable by default
+	  (until we've properly tested it)
+2006-01-27 08:25  Sandro Santilli <strk at keybit.net>
+	* [r1023] macros/ac_python_devel.m4, swig/python/Makefile.am,
+	  swig/ruby/ruby.i: * Ruby - removes dependency on renames.i file
+	  which is no longer deleted
+	  and was removed from CVS last week
+	  * Python - fixes autoconf search for Python include path
+	  * Python - fixes autoconf search for Python lib directory on
+	  MingW/windows
+	  * Python - adds python library to link line so that python
+	  extension can
+	  be built
+2006-01-22 22:48  Sandro Santilli <strk at keybit.net>
+	* [r1022] TODO: Added Safe's performance improvement idea for
+2006-01-21 16:11  Sandro Santilli <strk at keybit.net>
+	* [r1021] NEWS: updated
+2006-01-21 16:08  Sandro Santilli <strk at keybit.net>
+	* [r1020] source/io/ByteOrderValues.cpp: Fixed integer conversion
+	  bug (ported from JTS-1.7).
+	  Added last port information.
+2006-01-21 16:04  Sandro Santilli <strk at keybit.net>
+	* [r1019] source/test/hexwkb.xml: Added endian specification to
+	  case descriptions.
+	  All tests are Little Endian, should add the same
+	  tests with Big Endian format.
+2006-01-20 19:28  Sandro Santilli <strk at keybit.net>
+	* [r1018] source/operation/overlay/PolygonBuilder.cpp: Updated port
+	  information
+2006-01-20 19:21  Sandro Santilli <strk at keybit.net>
+	* [r1017] source/operation/overlay/PolygonBuilder.cpp: Fixed bug
+	  #13
+2006-01-20 19:11  Sandro Santilli <strk at keybit.net>
+	* [r1016] source/operation/valid/IsValidOp.cpp,
+	  source/operation/valid/TopologyValidationError.cpp: Updated last
+	  port info
+2006-01-20 17:20  Sandro Santilli <strk at keybit.net>
+	* [r1015] configure.in, macros/ruby.m4, swig/python/Makefile.am,
+	  swig/ruby/Makefile.am, swig/ruby/example.rb, swig/ruby/renames.i,
+	  swig/ruby/test/Makefile.am, swig/ruby/test/example.rb,
+	  swig/ruby/test/test_envelope.rb: More SWIG/python/ruby patches
+2006-01-20 00:59  Sandro Santilli <strk at keybit.net>
+	* [r1014] source/io/WKBReader.cpp: Better debugging
+	* [r1013] source/test/hexwkb.xml: PrecisionModel made FLOATING
+2006-01-18 17:49  Sandro Santilli <strk at keybit.net>
+	* [r1012] source/test/XMLTester.cpp, source/test/XMLTester.h:
+	  Reworked XMLTester to be quiet by default. Use -v switch to make
+	  it verbose.
+2006-01-18 17:47  Sandro Santilli <strk at keybit.net>
+	* [r1011] source/test/hexwkb.xml: Added GEOMETRYCOLLECTION test
+	* [r1010] source/test/Makefile.am: Added another local test to the
+	  test rule
+2006-01-18 17:46  Sandro Santilli <strk at keybit.net>
+	* [r1009] source/io/WKTWriter.cpp: Fixed leak in
+	  ::writeFormatted(Geometry *)
+2006-01-18 17:45  Sandro Santilli <strk at keybit.net>
+	* [r1008] source/io/WKBReader.cpp: more debugging lines
+2006-01-18 13:23  Sandro Santilli <strk at keybit.net>
+	* [r1007] source/io/WKBReader.cpp: Set binary flag for stringstream
+	  used in ::readHEX()
+2006-01-18 12:54  Sandro Santilli <strk at keybit.net>
+	* [r1006] source/test/Makefile.am, source/test/XMLTester.cpp,
+	  source/test/XMLTester.h, source/test/hexwkb.xml: Added HEXWKB
+	  support in XMLTester. Added a simple test in HEXWKB form
+	  and a 'test' rule running the locally-available tests and showing
+	  result summay.
+2006-01-18 10:02  Sandro Santilli <strk at keybit.net>
+	* [r1005] macros/ac_python_devel.m4: Added missing macro file
+2006-01-17 12:03  Sandro Santilli <strk at keybit.net>
+	* [r1004] configure.in, macros/ac_pkg_swig.m4: Modified
+	  AC_PROG_SWIG macro to set SWIG to the empty string
+	  on error (rather then making it echo an error and return false).
+	  SWIG version 1.3.28 or up required in order to build SWIG-based
+	  extensions.
+2006-01-16 18:34  Sandro Santilli <strk at keybit.net>
+	* [r1003] autogen.sh, configure.in, macros/ac_pkg_swig.m4,
+	  macros/python.m4, swig/python, swig/python/.cvsignore,
+	  swig/python/Makefile.am, swig/python/python.i,
+	  swig/ruby/Makefile.am: Added initial conditional build of python
+	  and ruby wrappers
+2006-01-15 23:01  Sandro Santilli <strk at keybit.net>
+	* [r1001] NEWS, configure.in, swig/Makefile.am, swig/geos.i,
+	  swig/ruby, swig/ruby/.cvsignore, swig/ruby/Makefile,
+	  swig/ruby/Makefile.am, swig/ruby/renames.i, swig/ruby/ruby.i,
+	  swig/ruby/test, swig/ruby/test/.cvsignore,
+	  swig/ruby/test/Makefile.am: Added bare build/install/dist scripts
+	  support for ruby interface
+2006-01-15 21:23  Sandro Santilli <strk at keybit.net>
+	* [r1000] swig/ruby/test, swig/ruby/test/geos_tests.rb,
+	  swig/ruby/test/test_combinations.rb,
+	  swig/ruby/test/test_helper.rb, swig/ruby/test/test_io.rb,
+	  swig/ruby/test/test_operations.rb,
+	  swig/ruby/test/test_relations.rb, swig/ruby/test/test_simple.rb:
+	  Initial import of ruby unit tests
+2006-01-15 21:22  Sandro Santilli <strk at keybit.net>
+	* [r999] source/geom/Envelope.cpp, source/headers/geos/geom.h:
+	  Added Envelope constructor by string (accepting what's returned
+	  by ::toString)
+2006-01-15 21:19  Sandro Santilli <strk at keybit.net>
+	* [r998] source/headers/geos/io.h, source/io/WKBReader.cpp,
+	  source/io/WKBWriter.cpp: Added WKBWriter::writeHEX() and
+	  WKBReader::readHEX()
+2006-01-12 11:44  Sandro Santilli <strk at keybit.net>
+	* [r997] NEWS: synced after 2.2.1 release
+	* [r996] source/capi/geos_c.cpp: Removed double call to ::isValid
+2006-01-08 15:39  Sandro Santilli <strk at keybit.net>
+	* [r994] source/capi/geos_c.cpp: Changed finite() function call
+	  with FINITE() macro.
+2006-01-08 15:24  Sandro Santilli <strk at keybit.net>
+	* [r993] source/geomgraph/EdgeIntersectionList.cpp,
+	  source/headers/geos/geomgraph.h, source/operation/IsSimpleOp.cpp,
+	  source/operation/relate/EdgeEndBuilder.cpp,
+	  source/operation/relate/RelateComputer.cpp,
+	  source/operation/relate/RelateNodeGraph.cpp,
+	  source/util/GeometricShapeFactory.cpp: Changed container-related
+	  typedef to class-scoped STL-like typedefs.
+	  Fixed const correctness of EdgeIntersectionList::begin() and
+	  ::end() consts;
+	  defined M_PI when undef as suggested by Charlie Savage.
+	  Removed <stdio.h> include from GeometricShapeFactory.cpp.
+2005-12-22 12:46  Sandro Santilli <strk at keybit.net>
+	* [r992] swig/README.txt, swig/geos.i, swig/ruby,
+	  swig/ruby/Makefile, swig/ruby/README.txt, swig/ruby/example.rb,
+	  swig/ruby/renames.i, swig/ruby/ruby.i: Imported Charlie Savage
+	  new ruby wrapper and swig changes
+2005-12-14 11:22  Sandro Santilli <strk at keybit.net>
+	* [r991] HOWTO_RELEASE: Added a note about the need to *always*
+	  increment CAPI version
+2005-12-14 02:32  Sandro Santilli <strk at keybit.net>
+	* [r990] HOWTO_RELEASE, source/algorithm/ConvexHull.cpp: New entry
+2005-12-13 23:59  Sandro Santilli <strk at keybit.net>
+	* [r989] source/capi/geos_c.h.in: Removed INTERFACE_* defines
+	  (obsoleted).
+	  Made GEOSCoordSeq_clone() arg const (won't change ABI, it's C
+	  world, lucky ;)
+2005-12-13 23:03  Sandro Santilli <strk at keybit.net>
+	* [r988] source/capi/geos_c.cpp: Removed conditional blocks based
+	  on GEOS version (we're always
+	  in sync). This fixed an annoying problem introduced since
+	  INTERFACE_LAST
+	  and INTERFACE_CURREN were taken off geos/version.h
+2005-12-12 09:32  Sandro Santilli <strk at keybit.net>
+	* [r987] configure.in, source/geom/Makefile.am,
+	  source/headers/geos/version.h.in: Switched to -release mode for
+	  C++ library versioning.
+	  Every release will be binary-incompatible with previous.
+	  Removed GEOS_FIRST_INTERFACE and GEOS_LAST_INTERFACE defines
+	  from geos/version.h.
+2005-12-11 10:41  Sandro Santilli <strk at keybit.net>
+	* [r984] source/operation/overlay/ElevationMatrix.cpp,
+	  premature initialization of average Z value in
+	  ElevationMatrixFilter
+2005-12-11 10:38  Sandro Santilli <strk at keybit.net>
+	* [r983] configure.in: Fixed mungled versions (1.0.0/3.0.1 =>
+	  1.0.1/3.0.0)
+2005-12-10 16:07  Sandro Santilli <strk at keybit.net>
+	* [r981] source/capi/geos_c.cpp: Unkown -> Unknown typo fix
+2005-12-09 13:24  Sandro Santilli <strk at keybit.net>
+	* [r980] configure.in: Capi lib version set to 1.0.1 (due to leak
+	  fix in GEOSHasZ)
+2005-12-09 11:36  Sandro Santilli <strk at keybit.net>
+	* [r977] NEWS, source/capi/geos_c.cpp,
+	  source/operation/polygonize/PolygonizeGraph.cpp: Small leak
+	  plugged in CAPI::GEOSHasZ() and in
+	  invalid input to PolygonizeGraph (again)
+2005-12-09 10:32  Sandro Santilli <strk at keybit.net>
+	* [r974] source/operation/polygonize/Polygonizer.cpp: Cleaned up
+	  debugging line left over from previous commit
+2005-12-09 10:03  Sandro Santilli <strk at keybit.net>
+	* [r972] NEWS, source/operation/polygonize/PolygonizeGraph.cpp,
+	  source/operation/polygonize/Polygonizer.cpp: Fixed a bug making
+	  PolygonizeGraph choking on invalid LineStrings.
+	  Minor optimizations in Polygonizer loops.
+2005-12-08 14:14  Sandro Santilli <strk at keybit.net>
+	* [r971] NEWS, source/geom/DefaultCoordinateSequence.cpp,
+	  source/geom/GeometryCollection.cpp, source/geom/LineString.cpp,
+	  source/headers/geos/geom.h, source/headers/geos/opOverlay.h,
+	  source/operation/overlay/ElevationMatrixFilter.cpp,
+	  source/util/UniqueCoordinateArrayFilter.cpp:
+	  ElevationMatrixFilter used for both elevation and Matrix fill,
+	  thus removing CoordinateSequence copy in
+	  ElevetaionMatrix::add(Geometry *).
+	  Changed CoordinateFilter::filter_rw to be a const method: updated
+	  all apply_rw() methods to take a const CoordinateFilter.
+2005-12-08 01:39  Sandro Santilli <strk at keybit.net>
+	* [r970] NEWS, source/headers/geos/noding.h,
+	  source/noding/Noder.cpp, source/noding/SegmentString.cpp:
+	  SegmentString::eiList made a real object rather then a pointer.
+	  Adde getter for const and non-const references of it (dropping
+	  get by pointer)
+2005-12-08 01:11  Sandro Santilli <strk at keybit.net>
+	* [r969] source/geomgraph/EdgeIntersectionList.cpp: minor
+	  optimizations in loops
+2005-12-08 00:24  Sandro Santilli <strk at keybit.net>
+	* [r968] source/geomgraph/EdgeIntersectionList.cpp: Reduced
+	  coordinate assignments in ::createSplitEdge
+2005-12-08 00:03  Sandro Santilli <strk at keybit.net>
+	* [r967] NEWS, source/headers/geos/opOverlay.h,
+	  source/operation/overlay/LineBuilder.cpp:
+	  LineBuilder::lineEdgesList made a real vector, rather then
+	  pointer (private member).
+	  Small optimizations in LineBuilder loops, cleanups in LineBuilder
+	  class dox.
+2005-12-07 23:36  Sandro Santilli <strk at keybit.net>
+	* [r966] source/geomgraph/EdgeIntersection.cpp: standard
+	  indentation
+2005-12-07 22:52  Sandro Santilli <strk at keybit.net>
+	* [r965] NEWS, source/geom/DefaultCoordinateSequence.cpp,
+	  source/geom/LineString.cpp, source/headers/geos/geom.h: Added
+	  CoordinateSequence::apply_rw(CoordinateFilter *) and
+	  CoordinateSequence::apply_ro(CoordinateFilter *) const
+	  to reduce coordinate copies on read-write CoordinateFilter
+	  applications (previously required getAt()/setAt() calls).
+	  Undefined PROFILE_COORDINATE_COPIES (erroneously left defined by
+	  previous commit)
+2005-12-07 21:55  Sandro Santilli <strk at keybit.net>
+	* [r964] source/geom/CoordinateSequence.cpp: Optimized memory
+	  allocations in ::removeRepeatedPoints
+2005-12-07 20:52  Sandro Santilli <strk at keybit.net>
+	* [r963] source/geomgraph/GeometryGraph.cpp: minor container
+	  methods call reduction
+2005-12-07 20:51  Sandro Santilli <strk at keybit.net>
+	* [r962] source/geomgraph/EdgeEndStar.cpp: removed dead code
+	* [r961] source/geomgraph/DirectedEdgeStar.cpp: minor cleanups
+2005-12-07 20:49  Sandro Santilli <strk at keybit.net>
+	* [r960] source/geomgraph/Edge.cpp: Oops, removed Coordinate copies
+	  introduced by recent code cleanups
+2005-12-07 19:18  Sandro Santilli <strk at keybit.net>
+	* [r959] NEWS, source/geomgraph/EdgeList.cpp,
+	  source/geomgraph/PlanarGraph.cpp, source/headers/geos/geom.h,
+	  source/operation/valid/ConnectedInteriorTester.cpp: Changed
+	  PlanarGraph::addEdges and EdgeList::addAll to take
+	  a const vector by reference rather then a non-const vector by
+	  pointer.
+	  Optimized polygon vector allocations in
+	  OverlayOp::computeOverlay.
+2005-12-06 10:24  Sandro Santilli <strk at keybit.net>
+	* [r958] Makefile.am, NEWS, configure.in, source/capi/Makefile.am,
+	  source/geom/Makefile.am: Added acsite.m4 to distribution.
+	  Added macros and flags required to build on mingw arch.
+2005-11-30 16:07  Sandro Santilli <strk at keybit.net>
+	* [r955] source/capi, source/capi/.cvsignore: Added geos_c.h
+2005-11-30 16:03  Sandro Santilli <strk at keybit.net>
+	* [r951] tools/geos-config.in: Added --ldflags
+2005-11-30 16:01  Sandro Santilli <strk at keybit.net>
+	* [r949] README: Updated with C-API usage
+2005-11-30 11:27  Sandro Santilli <strk at keybit.net>
+	* [r945] doc/example.cpp: catch std::exception by ref
+2005-11-30 11:25  Sandro Santilli <strk at keybit.net>
+	* [r944] doc/example.cpp: includes cleanup
+2005-11-29 23:01  Sandro Santilli <strk at keybit.net>
+	* [r942] NEWS: updated moving some items to 2.2.0
+2005-11-29 15:45  Sandro Santilli <strk at keybit.net>
+	* [r936] source/geomgraph/TopologyLocation.cpp,
+	  source/headers/geos/geomgraph.h: Fixed signedness of
+	  TopologyLocation methods, cleanups.
+2005-11-29 15:16  Sandro Santilli <strk at keybit.net>
+	* [r935] ChangeLog, source/algorithm/MinimumDiameter.cpp,
+	  source/headers/geos/geosAlgorithm.h: Fixed sign-related warnings
+	  and signatures.
+2005-11-29 14:49  Sandro Santilli <strk at keybit.net>
+	* [r934] NEWS: More info
+2005-11-29 14:44  Sandro Santilli <strk at keybit.net>
+	* [r933] NEWS: Updated
+2005-11-29 14:39  Sandro Santilli <strk at keybit.net>
+	* [r932] source/geomgraph/Edge.cpp,
+	  source/headers/geos/geomgraph.h: Removed number of points cache
+	  in Edge, replaced with local caches.
+	* [r931] source/geom/CoordinateSequence.cpp,
+	  source/geom/DefaultCoordinateSequence.cpp: More signed/unsigned
+	  fixes
+2005-11-29 13:39  Sandro Santilli <strk at keybit.net>
+	* [r930] source/headers/geos/geom.h, source/headers/geos/io.h:
+	  Moved byte typedef from geom.h to io.h.
+	  Removed useless commas at inlined funx end.
+	  Changed CoordinateSequenceFactory::create(siz,dims) to use
+	  unsigned for dims.
+2005-11-29 11:18  Sandro Santilli <strk at keybit.net>
+	* [r929] NEWS: organized changes info
+2005-11-29 00:48  Sandro Santilli <strk at keybit.net>
+	* [r928] source/geomgraph/DirectedEdgeStar.cpp,
+	  source/geomgraph/EdgeEndStar.cpp, source/geomgraph/Node.cpp,
+	  source/operation/buffer/BufferSubgraph.cpp,
+	  source/operation/relate/EdgeEndBundleStar.cpp,
+	  source/operation/valid/ConsistentAreaTester.cpp: Removed edgeList
+	  cache from EdgeEndRing. edgeMap is enough.
+	  Restructured iterated access by use of standard ::iterator
+	  abstraction
+	  with scoped typedefs.
+2005-11-28 18:37  Sandro Santilli <strk at keybit.net>
+	* [r927] source/geom/LineString.cpp: Minor warning removal
+2005-11-25 12:22  Sandro Santilli <strk at keybit.net>
+	* [r926] NEWS, source/test/XMLTester.cpp, source/test/XMLTester.h:
+	  Made XMLTester able to run multiple test files and keep overall
+	  counters.
+2005-11-25 11:40  Sandro Santilli <strk at keybit.net>
+	* [r925] source/precision/SimpleGeometryPrecisionReducer.cpp:
+	  Another getSize in for loop, another int-unsigned int warning
+2005-11-25 11:31  Sandro Santilli <strk at keybit.net>
+	* [r924] source/algorithm/InteriorPointArea.cpp,
+	  source/noding/NodingValidator.cpp, source/noding/SimpleNoder.cpp,
+	  source/operation/buffer/RightmostEdgeFinder.cpp,
+	  source/operation/valid/RepeatedPointTester.cpp: Removed all
+	  CoordinateSequence::getSize() calls embedded in for loops.
+2005-11-25 11:30  Sandro Santilli <strk at keybit.net>
+	* [r923] source/geomgraph/Edge.cpp: Fix in ::equals() - this
+	  finally passes testLeaksBig.xml tests
+2005-11-25 09:57  Sandro Santilli <strk at keybit.net>
+	* [r922] source/geom/GeometryCollection.cpp: Fixed bug in
+	  getCoordinates() [ introduced by previous commit ]
+2005-11-24 23:43  Sandro Santilli <strk at keybit.net>
+	* [r921] source/geomgraph/Edge.cpp,
+	  source/headers/geos/geomgraph.h: Yes another fix, sorry. Missing
+	  const-correctness.
+2005-11-24 23:24  Sandro Santilli <strk at keybit.net>
+	* [r920] source/geomgraph/Edge.cpp,
+	  source/headers/geos/geomgraph.h: Fixed equals() function [
+	  optimized in previous commit, but unchecked ]
+	* [r919] NEWS: Added note about CoordinateSequence signed->unsigned
+	  change in API
+2005-11-24 23:09  Sandro Santilli <strk at keybit.net>
+	* [r918] source/algorithm/CGAlgorithms.cpp,
+	  source/algorithm/PointLocator.cpp,
+	  source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
+	  source/geom/GeometryFactory.cpp, source/geom/LineString.cpp,
+	  source/geom/Polygon.cpp, source/geomgraph/Edge.cpp,
+	  source/geomgraph/EdgeRing.cpp,
+	  source/geomgraph/index/SimpleEdgeSetIntersector.cpp,
+	  source/noding/snapround/SimpleSegmentStringsSnapper.cpp:
+	  CoordinateSequence indexes switched from int to the more
+	  the correct unsigned int. Optimizations here and there
+	  to avoid calling getSize() in loops.
+	  Update of all callers is not complete yet.
+2005-11-24 23:07  Sandro Santilli <strk at keybit.net>
+	* [r917] source/algorithm/CentroidLine.cpp,
+	  source/headers/geos/geosAlgorithm.h: CentroidLine made concrete
+	  class (only destructor was virtual) - avoided heap allocation for
+	  owned Coordinate centSum
+2005-11-21 16:03  Sandro Santilli <strk at keybit.net>
+	* [r916] source/algorithm/CentroidArea.cpp,
+	  source/algorithm/HCoordinate.cpp,
+	  source/algorithm/LineIntersector.cpp, source/geom/Coordinate.cpp,
+	  source/geom/LineSegment.cpp, source/geom/Polygon.cpp,
+	  source/geomgraph/DirectedEdgeStar.cpp,
+	  source/geomgraph/EdgeEnd.cpp, source/geomgraph/EdgeEndStar.cpp,
+	  source/headers/geos/opOverlay.h, source/headers/geos/opRelate.h,
+	  source/headers/geos/opValid.h, source/headers/geos/operation.h,
+	  source/operation/GeometryGraphOperation.cpp,
+	  source/operation/IsSimpleOp.cpp,
+	  source/operation/overlay/OverlayNodeFactory.cpp,
+	  source/operation/relate/RelateNode.cpp,
+	  source/operation/relate/RelateNodeFactory.cpp,
+	  source/operation/relate/RelateOp.cpp,
+	  source/operation/valid/IsValidOp.cpp: Coordinate interface
+	  change:
+	  Removed setCoordinate call, use assignment operator
+	  instead. Provided a compile-time switch to
+	  make copy ctor and assignment operators non-inline
+	  to allow for more accurate profiling.
+	  Coordinate copies removal:
+	  NodeFactory::createNode() takes now a Coordinate reference
+	  rather then real value. This brings coordinate copies
+	  in the testLeaksBig.xml test from 654818 to 645991
+	  (tested in 2.1 branch). In the head branch Coordinate
+	  copies are 222198.
+	  Removed useless coordinate copies in ConvexHull
+	  operations
+	  STL containers heap allocations reduction:
+	  Converted many containers element from
+	  pointers to real objects.
+	  Made some use of .reserve() or size
+	  initialization when final container size is known
+	  in advance.
+	  Stateless classes allocations reduction:
+	  Provided ::instance() function for
+	  NodeFactories, to avoid allocating
+	  more then one (they are all
+	  stateless).
+	  HCoordinate improvements:
+	  Changed HCoordinate constructor by HCoordinates
+	  take reference rather then real objects.
+	  Changed HCoordinate::intersection to avoid
+	  a new allocation but rather return into a provided
+	  storage. LineIntersector changed to reflect
+	  the above change.
+2005-11-18 00:55  Sandro Santilli <strk at keybit.net>
+	* [r915] source/geomgraph/EdgeRing.cpp,
+	  source/headers/geos/geomgraph.h, source/headers/geos/opOverlay.h,
+	  source/operation/overlay/PolygonBuilder.cpp: Fixed a bug in
+	  EdgeRing::containsPoint().
+	  Changed EdgeRing::getLinearRing() to avoid LinearRing copy and
+	  updated
+	  usages from PolygonBuilder.
+	  Removed CoordinateSequence copy in EdgeRing (ownership is
+	  transferred
+	  to its LinearRing).
+	  Removed heap allocations for EdgeRing containers.
+	  Initialization lists and cleanups.
+2005-11-16 22:21  Sandro Santilli <strk at keybit.net>
+	* [r913] source/geomgraph/EdgeEnd.cpp,
+	  source/geomgraph/EdgeIntersection.cpp,
+	  source/operation/valid/IsValidOp.cpp: enforced const-correctness
+	  and use of initializer lists.
+2005-11-16 15:49  Sandro Santilli <strk at keybit.net>
+	* [r912] source/geomgraph/Edge.cpp,
+	  source/headers/geos/geomgraph.h, source/headers/geos/opValid.h,
+	  source/operation/overlay/EdgeSetNoder.cpp,
+	  source/operation/valid/IsValidOp.cpp: Reduced gratuitous heap
+	  allocations.
+2005-11-15 18:30  Sandro Santilli <strk at keybit.net>
+	* [r911] source/algorithm/LineIntersector.cpp,
+	  source/geomgraph/Label.cpp,
+	  source/headers/geos/geosAlgorithm.h: Removed dead code
+2005-11-15 12:14  Sandro Santilli <strk at keybit.net>
+	* [r909] source/headers/geos/opOverlay.h,
+	  source/headers/geos/opPolygonize.h,
+	  source/operation/linemerge/LineMergeDirectedEdge.cpp,
+	  source/operation/linemerge/LineMerger.cpp,
+	  source/operation/overlay/LineBuilder.cpp,
+	  source/operation/overlay/PointBuilder.cpp,
+	  source/planargraph/planarPlanarGraph.cpp: Reduced heap
+	  allocations, made use of references when appropriate,
+	  small optimizations here and there.
+2005-11-15 10:04  Sandro Santilli <strk at keybit.net>
+	* [r908] source/geomgraph/index/MonotoneChain.cpp,
+	  source/geomgraph/index/MonotoneChainEdge.cpp,
+	  source/geomgraph/index/MonotoneChainIndexer.cpp,
+	  source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
+	  source/geomgraph/index/SimpleSweepLineIntersector.cpp,
+	  source/geomgraph/index/SweepLineSegment.cpp,
+	  source/headers/geos/geomgraphindex.h: Reduced heap allocations
+	  (vectors, mostly).
+	  Enforced const-correctness, changed some interfaces
+	  to use references rather then pointers when appropriate.
+2005-11-15 10:02  Sandro Santilli <strk at keybit.net>
+	* [r907] source/geom/LineString.cpp: optimized envelope computation
+	  reducing virtual calls
+2005-11-14 18:14  Sandro Santilli <strk at keybit.net>
+	* [r906] source/geomgraph/Depth.cpp,
+	  source/geomgraph/DirectedEdge.cpp,
+	  source/geomgraph/DirectedEdgeStar.cpp, source/geomgraph/Edge.cpp,
+	  source/geomgraph/Node.cpp, source/geomgraph/TopologyLocation.cpp,
+	  source/operation/relate/EdgeEndBundle.cpp: Reduced heap
+	  allocations made by TopologyLocation and Label objects.
+	  Enforced const-correctness on GraphComponent.
+	  Cleanups.
+2005-11-10 16:26  Sandro Santilli <strk at keybit.net>
+	* [r904] source/io/WKBReader.cpp: Fixed printHEX (was printing one
+	  char past the WKB)
+2005-11-10 15:20  Sandro Santilli <strk at keybit.net>
+	* [r903] source/headers/geos/geomUtil.h,
+	  source/headers/geos/precision.h: Made virtual overloads explicit.
+2005-11-10 10:47  Sandro Santilli <strk at keybit.net>
+	* [r902] source/geom/MultiPoint.cpp, source/headers/geos/geom.h:
+	  Renamed MultiPoint::getCoordinate(int) to
+	  MultiPoint::getCoordinateN(int)
+	  to avoid hiding of Geometry::getCoordinate().
+2005-11-10 10:24  Sandro Santilli <strk at keybit.net>
+	* [r901] source/headers/geos/util.h,
+	  source/util/CoordinateArrayFiter.cpp: Fixed virtual overload of
+	  CoordinateArrayFilter::filter*
+2005-11-10 09:33  Sandro Santilli <strk at keybit.net>
+	* [r900] source/geom/LineString.cpp, source/headers/geos/geom.h:
+	  Removed virtual overloading LineString::compareTo(LineString *)
+2005-11-09 15:14  Sandro Santilli <strk at keybit.net>
+	* [r899] source/operation/buffer/DepthSegment.cpp: Forgot to add
+	  this
+2005-11-09 13:44  Sandro Santilli <strk at keybit.net>
+	* [r898] source/geomgraph/Node.cpp, source/geomgraph/NodeMap.cpp,
+	  source/headers/geos/geomgraph.h: Cleanups in Node and NodeMap.
+	  Optimization of EdgeIntersectionLessThen.
+2005-11-09 08:57  Sandro Santilli <strk at keybit.net>
+	* [r897] source/geom/IntersectionMatrix.cpp,
+	  source/headers/geos/geom.h: IntersectionMatrix made a concrete
+	  and final type.
+	  Cleanups in class definition.
+2005-11-08 20:12  Sandro Santilli <strk at keybit.net>
+	* [r896] NEWS, source/geom/Makefile.am, source/headers/geos/geom.h,
+	  source/operation/buffer/SubgraphDepthLocater.cpp: Memory overhead
+	  reductions in buffer operations.
+2005-11-08 12:32  Sandro Santilli <strk at keybit.net>
+	* [r895] source/geom/DefaultCoordinateSequence.cpp: Cleanups,
+	  ::setPoint small improvement
+2005-11-08 11:33  Sandro Santilli <strk at keybit.net>
+	* [r894] source/operation/overlay/OverlayOp.cpp: comments cleanup
+2005-11-08 10:26  Sandro Santilli <strk at keybit.net>
+	* [r893] configure.in: Library versioning took back to 3.0.0
+2005-11-08 10:03  Sandro Santilli <strk at keybit.net>
+	* [r892] configure.in, doc/Doxyfile.in, source/geom/Envelope.cpp,
+	  source/geom/Geometry.cpp, source/headers/geos/geom.h: Set library
+	  version to 2.2.0.
+	  Cleaned up Doxygen warnings.
+	  Inlined more Envelope methods.
+	  Dropped deprecated Envelope::overlaps methods.
+2005-11-07 18:07  Sandro Santilli <strk at keybit.net>
+	* [r890] configure.in: Removed VisualStudio knowledge from
+	  configure script
+2005-11-07 18:05  Sandro Santilli <strk at keybit.net>
+	* [r889] source/geomgraph/EdgeIntersectionList.cpp,
+	  source/headers/geos/noding.h, source/noding/SegmentNodeList.cpp:
+	  Reduced set<> lookups
+2005-11-07 13:17  frank
+	* [r888] VisualStudio: no longer used
+	* [r887] Makefile.am: removed VisualStudio, no longer distributed
+2005-11-07 13:16  frank
+	* [r886] VisualStudio/.cvsignore: obsolete
+2005-11-07 12:31  Sandro Santilli <strk at keybit.net>
+	* [r885] NEWS, source/geomgraph/Edge.cpp,
+	  source/geomgraph/index/SweepLineEvent.cpp,
+	  source/headers/geos/geomgraphindex.h,
+	  source/headers/geos/opValid.h, source/operation/IsSimpleOp.cpp,
+	  source/operation/valid/IsValidOp.cpp: Changed
+	  EdgeIntersectionList to use a set<> rathern then a vector<>, and
+	  to avoid dynamic allocation of initial header.
+	  Inlined short SweepLineEvent methods.
+2005-11-07 11:32  Sandro Santilli <strk at keybit.net>
+	* [r884] source/capi/geos_c.h.in: Added const qualifiers to
+	  function to reflect paradigm of immutable
+	  Geometry objects.
+2005-11-04 15:42  Sandro Santilli <strk at keybit.net>
+	* [r883] source/geomgraph/index/SweepLineEvent.cpp: Fixed bug in
+	  SweepLineEventLessThen functor
+	  (didn't conform to strict weak ordering).
+	  Note: this was introduced by previous commit.
+2005-11-04 11:06  Sandro Santilli <strk at keybit.net>
+	* [r882] NEWS: updated
+2005-11-04 11:04  Sandro Santilli <strk at keybit.net>
+	* [r881] source/headers/geos/opValid.h,
+	  source/operation/valid/SweeplineNestedRingTester.cpp,
+	  source/operation/valid/TopologyValidationError.cpp: Ported
+	  revision 1.38 of IsValidOp.java (adding closed Ring checks).
+	  Changed NestedRingTester classes to use Coorinate pointers
+	  rather then actual objects, to speedup NULL tests.
+	  Added JTS port revision when applicable.
+2005-11-04 08:28  Sandro Santilli <strk at keybit.net>
+	* [r880] NEWS, source/operation/overlay/OverlayOp.cpp: Ported
+	  speedup of OverlayOp::insertUniqueEdge() from JTS-1.7 (rev 1.23)
+	  Updated NEWS file.
+2005-11-03 21:28  Sandro Santilli <strk at keybit.net>
+	* [r878] source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
+	  source/geomgraph/index/SimpleSweepLineIntersector.cpp: Fixed
+	  constructors broke by previous commit
+2005-11-03 19:51  Sandro Santilli <strk at keybit.net>
+	* [r877] source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
+	  source/headers/geos/geomgraphindex.h: Indentation changes, small
+	  vector memory allocation optimization.
+2005-11-03 09:15  Sandro Santilli <strk at keybit.net>
+	* [r876] source/headers/geos/geom.h: Removed declaration of
+	  PointCoordinateSequence and PointCoordinateSequenceFactory
+2005-11-01 09:40  Sandro Santilli <strk at keybit.net>
+	* [r875] source/operation/valid/IsValidOp.cpp: Replaced finite()
+	  with FINITE() calls.
+2005-10-27 14:05  Sandro Santilli <strk at keybit.net>
+	* [r873] source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
+	  source/headers/geos/geomgraphindex.h: Added a
+	  SweepLineEventLessThen functor to be used by sort algorithm.
+2005-10-24 13:28  Sandro Santilli <strk at keybit.net>
+	* [r872] source/capi/geos_c.cpp, source/capi/geos_c.h.in,
+	  source/capi/geostest.c: Changed constructors to take ownership of
+	  GEOSGeom and GEOSCoordSeq objects.
+	  Changed inspectors to retain ownership of GEOSGeom and
+	  GEOSCoordSeq objects.
+	  Added GEOSGeom_clone() method.
+2005-10-21 15:13  Sandro Santilli <strk at keybit.net>
+	* [r871] source/capi/geos_c.cpp, source/capi/geos_c.h.in: Added
+	  GEOSGeom_clone() function
+2005-10-21 12:14  Sandro Santilli <strk at keybit.net>
+	* [r870] source/capi/geos_c.h.in: Added missing GEOS_DLL specifiers
+2005-10-21 12:07  Sandro Santilli <strk at keybit.net>
+	* [r869] source/capi/geos_c.cpp, source/capi/geos_c.h.in,
+	  source/capi/geostest.c: Added fine-grained geometry constructors
+	  and GEOSCoordSeq abstract data type.
+	  Renamed GEOSmakeCollection to GEOSGeom_createCollection
+2005-10-21 09:02  Sandro Santilli <strk at keybit.net>
+	* [r868] configure.in: typo fixed
+2005-10-21 02:46  frank
+	* [r867] AUTHORS: added myself to authors - isn't that cheeky!
+2005-10-21 02:45  frank
+	* [r866] README: added note on source\makefile.vc
+2005-10-21 02:44  frank
+	* [r865] source/Makefile.vc: added a wee readme
+2005-10-21 02:41  frank
+	* [r864] source/Makefile.vc: added DLL building, and geostest.exe
+	* [r863] source/capi/geos_c.h.in: need to DLL export C API
+2005-10-21 02:37  frank
+	* [r862] source/capi/geos_c.cpp: DLL Export functions
+	* [r861] source/capi/geostest.c: avoid non-portable vasprintf, make
+	  big buffer static
+2005-10-21 01:57  frank
+	* [r860] source/Makefile.vc: updated for 3.0.0 and added C API
+2005-10-20 20:37  frank
+	* [r859] source/headers/geos/platform.h.vc: added
+	  getMachineByteOrder(), convert to unix text mode
+2005-10-19 13:07  Sandro Santilli <strk at keybit.net>
+	* [r858] source/io/WKBReader.cpp: Added support for SRID flag in
+	  WKB (full EWKB is accepted now)
+2005-10-19 12:59  Sandro Santilli <strk at keybit.net>
+	* [r857] source/headers/geos/io.h: Added input stream checks in
+	  ByteOrderDataInStream, throwing ParseException on unexpected EOF
+2005-10-17 15:55  Sandro Santilli <strk at keybit.net>
+	* [r856] source/capi/geos_c.cpp, source/capi/geos_c.h.in: Added
+	  GetGeometryN, GetInteriorRingN, GetExteriorRing
+2005-10-17 14:37  Sandro Santilli <strk at keybit.net>
+	* [r855] source/capi/geos_c.h.in: Added comments on exception
+	  returns for Geometry info functions
+2005-10-17 14:33  Sandro Santilli <strk at keybit.net>
+	* [r854] source/capi/geos_c.cpp: Added missing exception handlers
+	  from previous commit.
+	  Fixed GEOSGeomTypeId signatures.
+2005-10-17 12:56  Sandro Santilli <strk at keybit.net>
+	* [r853] source/geom/Makefile.am: Removed GEOS_VERSION define
+	  (Geometry.cpp, the only file using this will use the one in
+	  version.h)
+2005-10-17 12:55  Sandro Santilli <strk at keybit.net>
+	* [r852] source/capi/geos_c.h.in: Fixed GEOSGeom typedef to be
+	  accepted by C++ compilers, added extern "C" namespace for
+	  inclusion by C++ code (really needed?)
+2005-10-17 09:38  Sandro Santilli <strk at keybit.net>
+	* [r851] source/capi/geos_c.cpp, source/capi/geos_c.h.in,
+	  source/capi/geostest.c: Added GEOSDistance() function.
+	  Trapped all exceptions and reported using ERROR_MESSAGE rather
+	  then NOTICE_MESSAGE.
+	  Changed WKB functions to use 'unsigned char' rather then 'char'
+	  Added missing GEOS_setWKBOutputDims() function in header file.
+2005-09-28 16:33  Sandro Santilli <strk at keybit.net>
+	* [r850] source/capi/geos_c.cpp: Added GEOS_setWKBOutputDims(int)
+	  function to specify coordinate
+	  dimension in WKB output.
+2005-09-28 10:15  Sandro Santilli <strk at keybit.net>
+	* [r849] source/headers/geos/io.h, source/io/WKBWriter.cpp:
+	  WKBWriter ctor out-lined (will require changes in the near
+	  future, for higher dimensions support), added support for 3d WKB
+	  output
+2005-09-28 09:36  Sandro Santilli <strk at keybit.net>
+	* [r848] source/io/WKBReader.cpp: Cleanups in the printHEX function
+2005-09-27 16:29  Sandro Santilli <strk at keybit.net>
+	* [r847] source/io/WKBReader.cpp: Ported JTS-1.7 use of
+	  PrecisionModel in WKBReader
+2005-09-27 16:20  Sandro Santilli <strk at keybit.net>
+	* [r846] doc/example.cpp, source/capi/geos_c.cpp,
+	  source/headers/geos/io.h, source/io/WKBReader.cpp: Reverted
+	  previous change, fixed the bug by turning WKBReader.factory
+	  into a reference rather then a real object. ABI still breaks, but
+	  API
+	  at least is safe (we didn't release any WKB-aware package so
+	  breaking
+	  ABI is not a big deal at this stage).
+2005-09-27 16:00  Sandro Santilli <strk at keybit.net>
+	* [r845] doc/example.cpp, source/capi/geos_c.cpp,
+	  source/headers/geos/io.h, source/io/WKBReader.cpp: Fixed bug in
+	  WKBReader destroying the GeometryFactory used in Geometry
+	  construction. Changed it's definition to *require* a
+	  GeometryFactory
+	  pointer parameter.
+2005-09-27 08:51  Sandro Santilli <strk at keybit.net>
+	* [r844] source/test/Makefile.am: Added XMLTester.h in
+	  XMLTester_SOURCES list
+2005-09-26 14:40  Sandro Santilli <strk at keybit.net>
+	* [r843] source/io/WKBReader.cpp: Fixed handling of higher
+	  dimensional WKB streams
+2005-09-26 13:46  Sandro Santilli <strk at keybit.net>
+	* [r842] source/capi/Makefile.am: Modified GEOS_CAPI_VERSION to
+	  include underlying GEOS version
+2005-09-26 13:42  Sandro Santilli <strk at keybit.net>
+	* [r841] configure.in, source/capi/Makefile.am,
+	  source/capi/geos_c.cpp, source/capi/geos_c.h,
+	  source/capi/geos_c.h.in: Moved C-api versioning to top-level
+	  configure.in
+	  Added version info in geos_c.h
+2005-09-26 12:25  Sandro Santilli <strk at keybit.net>
+	* [r840] source/capi/geos_c.cpp, source/capi/geos_c.h,
+	  source/capi/geostest.c: Changed LineMerge interface to accept a
+	  single Geometry and return the simpler Geometry obtainable with
+	  the set of merger LineStrings. Fixed leaks in geostest, fixed a
+	  leak in GEOSRelate().
+2005-09-26 12:23  Sandro Santilli <strk at keybit.net>
+	* [r839] source/geom/PrecisionModel.cpp: Initializzation lists in
+	  PrecisionModel ctors
+2005-09-26 11:04  Sandro Santilli <strk at keybit.net>
+	* [r838] NEWS: Added changes in LineMerger
+2005-09-26 11:01  Sandro Santilli <strk at keybit.net>
+	* [r837] source/headers/geos/opLinemerge.h,
+	  source/operation/linemerge/LineMergeEdge.cpp,
+	  source/operation/linemerge/LineMerger.cpp: Const correctness
+	  changes in LineMerger package, and a few speedups.
+2005-09-26 08:18  Sandro Santilli <strk at keybit.net>
+	* [r836] source/capi, source/capi/.cvsignore: Added .lo, .la and
+	  geostest
+2005-09-26 08:17  Sandro Santilli <strk at keybit.net>
+	* [r835] doc/example.cpp: Removed memory leak from WKB tester
+2005-09-23 17:20  Sandro Santilli <strk at keybit.net>
+	* [r834] source/headers/geos/opLinemerge.h,
+	  source/operation/linemerge/LineMerger.cpp: Made LineMerger graph
+	  be a real object (rather then a pointer to it)
+2005-09-23 16:07  Sandro Santilli <strk at keybit.net>
+	* [r833] source/capi/geos_c.cpp: Fixed export of GEOSPolygonize()
+	  and GEOSMakeCollection()
+2005-09-23 09:49  Sandro Santilli <strk at keybit.net>
+	* [r832] source/capi/geos_c.cpp, source/capi/geos_c.h: Added
+	  GEOSMakeCollection.
+	  Changed GEOSGetCentroid to return an EmptyGeometry when no
+	  Centroid can be
+	  computed (Empty input, for example).
+2005-09-19 08:16  Sandro Santilli <strk at keybit.net>
+	* [r831] NEWS: Added C api
+2005-09-14 15:11  Sandro Santilli <strk at keybit.net>
+	* [r830] source/capi/geos_c.h: Removed functions returning not-new
+	  GEOSGeom objects to avoid ambiguity
+	  whereas when to destroy returns. Added not about memory
+	  management.
+2005-09-14 14:55  Sandro Santilli <strk at keybit.net>
+	* [r829] source/capi/geos_c.cpp, source/capi/geos_c.h,
+	  source/capi/geostest.c: Added copyright notices and usage notes
+2005-09-14 14:28  Sandro Santilli <strk at keybit.net>
+	* [r828] source/io/WKBWriter.cpp: Fixed bug writing WKB for all
+	  Multi* geoms as Collections.
+2005-09-14 13:58  Sandro Santilli <strk at keybit.net>
+	* [r827] configure.in, source/Makefile.am, source/capi,
+	  source/capi/.cvsignore, source/capi/Makefile.am,
+	  source/capi/geostest.c, source/capi/test.wkt: Initial abstract C
+	  api.
+2005-09-14 13:56  Sandro Santilli <strk at keybit.net>
+	* [r826] source/io/WKBReader.cpp: Typo fixed
+2005-09-03 21:26  Sandro Santilli <strk at keybit.net>
+	* [r825] doc/example.cpp, source/geom/Makefile.am,
+	  source/headers/geos/ByteOrderDataInStreamT.h,
+	  source/headers/geos/Makefile.am,
+	  source/headers/geos/WKBReaderT.h,
+	  source/headers/geos/WKBWriterT.h, source/headers/geos/io.h,
+	  source/io/WKBReader.cpp, source/io/WKBWriter.cpp: Reworked WKB
+	  I/O to avoid use of templates and make better use of STL
+2005-08-22 13:34  Sandro Santilli <strk at keybit.net>
+	* [r822] NEWS: Added 2.1.4 section
+2005-08-22 13:31  Sandro Santilli <strk at keybit.net>
+	* [r821] source/geom/Geometry.cpp,
+	  source/planargraph/planarDirectedEdgeStar.cpp: Fixed comparator
+	  functions used with STL sort() algorithm to
+	  implement StrictWeakOrdering semantic.
+2005-07-12 14:33  Sandro Santilli <strk at keybit.net>
+	* [r819] NEWS: updated
+2005-07-11 16:21  Sandro Santilli <strk at keybit.net>
+	* [r818] source/headers/geos/ByteOrderDataInStreamT.h,
+	  source/headers/geos/WKBWriterT.h: Removed '_' prefix from header
+	  guards
+2005-07-11 12:17  Sandro Santilli <strk at keybit.net>
+	* [r817] source/headers/geos/io.h, source/headers/geos/opOverlay.h,
+	  source/headers/geos/platform.h.in: Cleaned up syntax
+	* [r816] doc/example.cpp: Commented out useless include
+2005-07-11 10:50  Sandro Santilli <strk at keybit.net>
+	* [r815] source/geom/Geometry.cpp: Added parens suggested by
+	  compiler
+2005-07-11 10:27  Sandro Santilli <strk at keybit.net>
+	* [r814] source/geomgraph/Edge.cpp,
+	  source/headers/geos/WKBReaderT.h: Cleaned up signed/unsigned
+	  mismatches
+	* [r813] source/geomgraph/DirectedEdge.cpp,
+	  source/operation/buffer/SubgraphDepthLocater.cpp: Fixed
+	  initializzazion lists
+2005-07-11 10:26  Sandro Santilli <strk at keybit.net>
+	* [r812] source/headers/geos/geom.h: Made
+	  CoordinateSequence::getDimension return unsigned int instead of
+	  int
+2005-07-11 10:23  Sandro Santilli <strk at keybit.net>
+	* [r811] source/geom/Geometry.cpp: removed useless assignment
+2005-06-30 18:31  Sandro Santilli <strk at keybit.net>
+	* [r807] source/headers/geos/opBuffer.h,
+	  source/operation/buffer/SubgraphDepthLocater.cpp: Ported
+	  SubgraphDepthLocator optimizations from JTS code
+2005-06-28 21:13  Sandro Santilli <strk at keybit.net>
+	* [r803] source/operation/buffer/SubgraphDepthLocater.cpp: Fixed a
+	  bug introduced by LineSegment skip - made LineSegment skip a
+	  compile-time optione
+2005-06-28 16:52  Sandro Santilli <strk at keybit.net>
+	* [r802] source/test/XMLTester.cpp: Added number of points count as
+	  a debugging aid
+2005-06-28 11:22  Sandro Santilli <strk at keybit.net>
+	* [r801] NEWS: Added DepthSegmentLT bugfix
+2005-06-28 01:07  Sandro Santilli <strk at keybit.net>
+	* [r796] source/headers/geos/opOverlay.h,
+	  source/operation/overlay/PointBuilder.cpp: improved extraction of
+	  result points in overlay op
+2005-06-28 00:04  Sandro Santilli <strk at keybit.net>
+	* [r794] source/geomgraph/Node.cpp: improved
+	  ::isIncidentEdgeInResult() method
+2005-06-27 21:58  Sandro Santilli <strk at keybit.net>
+	* [r793] source/operation/buffer/SubgraphDepthLocater.cpp: Bugfix
+	  in DepthSegmentLT as suggested by Graeme Hiebert
+2005-06-27 21:24  Sandro Santilli <strk at keybit.net>
+	* [r790] source/operation/buffer/SubgraphDepthLocater.cpp: Fixed
+	  bug just-introduced with optimization.
+2005-06-27 21:21  Sandro Santilli <strk at keybit.net>
+	* [r789] NEWS, source/operation/buffer/SubgraphDepthLocater.cpp:
+	  Reduced Coordinate copies due to LineSegment overuse
+2005-06-25 10:20  Sandro Santilli <strk at keybit.net>
+	* [r787] NEWS, source/geomgraph/Node.cpp,
+	  source/operation/overlay/PointBuilder.cpp: OverlayOp speedup (JTS
+	  port)
+2005-06-24 11:12  Sandro Santilli <strk at keybit.net>
+	* [r786] NEWS: Added LineIntersector concrete type note
+2005-06-24 11:09  Sandro Santilli <strk at keybit.net>
+	* [r785] source/algorithm/CGAlgorithms.cpp,
+	  source/algorithm/PointLocator.cpp, source/geom/LineSegment.cpp,
+	  source/geom/Makefile.am, source/geomgraph/PlanarGraph.cpp,
+	  source/headers/geos/geosAlgorithm.h,
+	  source/headers/geos/noding.h, source/noding/IteratedNoder.cpp,
+	  source/operation/buffer/OffsetCurveBuilder.cpp,
+	  source/operation/valid/ConsistentAreaTester.cpp,
+	  source/operation/valid/IsValidOp.cpp: Dropped
+	  RobustLineIntersector, made LineIntersector a concrete class.
+	  Added
+	  LineIntersector::hasIntersection(Coordinate&,Coordinate&,Coordinate&)
+	  to avoid computing intersection point (Z) when it's not
+	  necessary.
+2005-06-23 14:22  Sandro Santilli <strk at keybit.net>
+	* [r784] NEWS, source/geom/GeometryCollection.cpp,
+	  source/geom/LineString.cpp, source/geom/LinearRing.cpp,
+	  source/headers/geos/geom.h: Inlined and added missing ::clone()
+	  for Geometry subclasses
+2005-06-23 11:23  Sandro Santilli <strk at keybit.net>
+	* [r782] NEWS, source/algorithm/CGAlgorithms.cpp: performance
+	  improvement for CGAlgorithms::isOnLine()
+2005-06-22 00:46  Sandro Santilli <strk at keybit.net>
+	* [r779] NEWS, source/geom/Geometry.cpp: Shortcircuit tests for
+	  Union
+	* [r777] source/geom/GeometryFactory.cpp: Fixed bugus handling of
+	  collections in ::buildGeometry
+2005-06-21 12:22  Sandro Santilli <strk at keybit.net>
+	* [r773] NEWS, source/test/XMLTester.cpp, source/test/XMLTester.h:
+	  XMLTester code cleanups
+2005-06-20 10:23  Sandro Santilli <strk at keybit.net>
+	* [r772] NEWS, source/test/Makefile.am: XMLTester installed by
+	  default
+2005-06-17 15:17  Sandro Santilli <strk at keybit.net>
+	* [r770] ., .cvsignore, ltmain.sh: Removed ltmain.sh from
+	  repository, will be created by autogen.sh
+2005-06-17 15:08  Sandro Santilli <strk at keybit.net>
+	* [r766] NEWS, source/operation/polygonize/Polygonizer.cpp,
+	  source/operation/polygonize/polygonizeEdgeRing.cpp: Polygonizer
+	  segfault fix
+2005-06-17 14:58  Sandro Santilli <strk at keybit.net>
+	* [r764] source/geom/GeometryFactory.cpp: Fixed segfault in
+	  LinearRing and LineString constructors
+2005-06-14 11:57  Sandro Santilli <strk at keybit.net>
+	* [r761] NEWS, source/test/XMLTester.cpp: Added workaround for
+	  mingw Polygon name clash
+2005-06-10 14:04  Sandro Santilli <strk at keybit.net>
+	* [r760] autogen.sh: Added libtoolize call
+2005-06-10 13:24  Sandro Santilli <strk at keybit.net>
+	* [r758] source/test/XMLTester.cpp: Added use declaration to make
+	  MingW build work
+2005-06-08 09:38  Sandro Santilli <strk at keybit.net>
+	* [r754] INSTALL: Added GCC version requirement note
+2005-06-05 10:41  Sandro Santilli <strk at keybit.net>
+	* [r752] CHANGES, NEWS: Changes file renamed back to NEWS, automake
+	  insists on finding it.
+2005-05-30 16:20  autorun
+	* [r750] NEWS: Blank news file to molfify new versions of autoconf
+2005-05-24 08:42  Sandro Santilli <strk at keybit.net>
+	* [r749] NEWS: Info moved into CHANGES file
+	* [r748] CHANGES: Filled in section from 2.0.0 to 2.1.1
+2005-05-24 07:48  Sandro Santilli <strk at keybit.net>
+	* [r744] CHANGES: Initial import
+2005-05-23 16:42  Sandro Santilli <strk at keybit.net>
+	* [r728] source/geom/Point.cpp: Added Refractions copyright
+2005-05-23 15:13  Sandro Santilli <strk at keybit.net>
+	* [r717] source/operation/buffer/BufferSubgraph.cpp,
+	  source/operation/buffer/SubgraphDepthLocater.cpp: Added debugging
+	  output
+2005-05-23 15:04  Sandro Santilli <strk at keybit.net>
+	* [r716] source/geom/LineSegment.cpp: Fixed bug in ::reverse()
+2005-05-22 17:45  Sandro Santilli <strk at keybit.net>
+	* [r715] source/operation/buffer/BufferSubgraph.cpp: Fixed
+	  initialization list order
+2005-05-22 17:42  Sandro Santilli <strk at keybit.net>
+	* [r714] ChangeLog, source/headers/geos/Makefile.am: Added missing
+	  WKBWriterT.h
+2005-05-20 16:15  Sandro Santilli <strk at keybit.net>
+	* [r713] source/geomgraph/Position.cpp,
+	  source/operation/buffer/SubgraphDepthLocater.cpp: Code cleanups
+2005-05-20 16:14  Sandro Santilli <strk at keybit.net>
+	* [r712] source/operation/buffer/OffsetCurveSetBuilder.cpp: Fixed a
+	  bug in addPolygonRing setting wrong depths on Edges
+2005-05-19 10:29  Sandro Santilli <strk at keybit.net>
+	* [r711] source/algorithm/CentroidArea.cpp,
+	  source/geomgraph/DirectedEdge.cpp, source/geomgraph/EdgeEnd.cpp,
+	  source/geomgraph/EdgeRing.cpp, source/headers/geos/geomgraph.h,
+	  source/headers/geos/opBuffer.h, source/headers/geos/opOverlay.h,
+	  source/operation/buffer/BufferBuilder.cpp,
+	  source/operation/buffer/BufferOp.cpp,
+	  source/operation/buffer/OffsetCurveSetBuilder.cpp,
+	  source/operation/buffer/SubgraphDepthLocater.cpp,
+	  source/operation/overlay/MaximalEdgeRing.cpp,
+	  source/operation/overlay/MinimalEdgeRing.cpp,
+	  source/operation/overlay/PolygonBuilder.cpp: Removed some
+	  CGAlgorithms instances substituting them with direct calls
+	  to the static functions. Interfaces accepting CGAlgorithms
+	  pointers kept
+	  for backward compatibility but modified to make the argument
+	  optional.
+	  Fixed a small memory leak in OffsetCurveBuilder::getRingCurve.
+	  Inlined some smaller functions encountered during bug hunting.
+	  Updated Copyright notices in the touched files.
+2005-05-19 10:26  Sandro Santilli <strk at keybit.net>
+	* [r710] source/test/testLeaksBig.xml: Added bogus multipolygon
+	  buffering test
+2005-05-13 18:06  Sandro Santilli <strk at keybit.net>
+	* [r709] source/headers/geos/geom.h: Added default tolerance
+	  parameter for equalsExact
+2005-05-13 17:15  Sandro Santilli <strk at keybit.net>
+	* [r708] source/geom/Point.cpp: cleanups and indentations
+2005-05-13 17:14  Sandro Santilli <strk at keybit.net>
+	* [r707] source/geom/Geometry.cpp: Added comment about 2D-only
+	  comparison of ::equal(Coordinate, Coordinate, double)
+2005-05-09 21:17  Sandro Santilli <strk at keybit.net>
+	* [r706] source/headers/geos/WKBWriterT.h: Second argument to
+	  ::write made mandatory.
+2005-05-09 10:35  Sandro Santilli <strk at keybit.net>
+	* [r705] source/algorithm/RobustLineIntersector.cpp,
+	  source/headers/geos/geosAlgorithm.h: Ported JTS robustness
+	  patches made by Martin on suggestions by Kevin.
+2005-05-03 15:30  Sandro Santilli <strk at keybit.net>
+	* [r704] TODO: Added WKB TODOs
+2005-04-29 17:40  Sandro Santilli <strk at keybit.net>
+	* [r703] source/geom/Geometry.cpp, source/headers/geos.h,
+	  source/headers/geos/WKBWriterT.h, source/headers/geos/geom.h,
+	  source/headers/geos/io.h, source/headers/geos/opOverlay.h,
+	  source/io/ByteOrderValues.cpp,
+	  source/operation/overlay/OverlayOp.cpp: Updated Doxygen
+	  documentation and some Copyright headers.
+2005-04-29 16:36  Sandro Santilli <strk at keybit.net>
+	* [r702] source/headers/geos/io.h: Fixed biostringstream stream
+	  output.
+	* [r701] doc/example.cpp: Made WKBReader use global_factory, for
+	  having WKB reads produce
+	  same context of input geoms.
+2005-04-29 15:34  Sandro Santilli <strk at keybit.net>
+	* [r700] doc/example.cpp, source/headers/geos/WKBReaderT.h,
+	  source/io/ByteOrderValues.cpp: Typedef'ed biostringstream,
+	  preferred parameter for
+	  WKB parser templates.
+	  Added << operator for biostringstream.
+	  Typedef'ed WKBWriter and WKBReader to be parametrized by
+	  biostringstream.
+	  Added WKBtest in doc/example.cpp
+2005-04-29 11:52  Sandro Santilli <strk at keybit.net>
+	* [r699] source/geom/CoordinateSequence.cpp,
+	  source/geom/Makefile.am, source/geom/PointCoordinateSequence.cpp,
+	  source/geom/PointCoordinateSequenceFactory.cpp,
+	  source/headers/geos/io.h: Added new JTS interfaces for
+	  CoordinateSequence and factories,
+	  removed example implementations to reduce maintainance costs.
+	  Added first implementation of WKBWriter, made
+	  a template class.
+2005-04-29 11:50  Sandro Santilli <strk at keybit.net>
+	* [r698] source/headers/geos/platform.h.in: Added machine byte
+	  order extractor
+2005-04-21 15:13  Sandro Santilli <strk at keybit.net>
+	* [r697] configure.in: library version bumped to 3.0.0
+2005-04-21 13:43  Sandro Santilli <strk at keybit.net>
+	* [r696] ChangeLog, NEWS: Updated chage logs
+2005-04-21 11:16  Sandro Santilli <strk at keybit.net>
+	* [r695] source/operation/overlay/OverlayOp.cpp: Removed useless
+	  Coordinate copies in mergeZ() - patch by Safe Software
+2005-04-20 17:56  Sandro Santilli <strk at keybit.net>
+	* [r694] source/algorithm/NonRobustCGAlgorithms.cpp,
+	  source/algorithm/RobustCGAlgorithms.cpp, source/geom/Makefile.am:
+	  Removed NonRobustCGAlgorithms and RobustCGAlgorithms, already
+	  unused (CGAlgorithms replaces both with robust implementation).
+2005-04-20 17:22  Sandro Santilli <strk at keybit.net>
+	* [r693] source/geom/Makefile.am,
+	  source/headers/geos/WKBReaderT.h, source/headers/geos/geom.h,
+	  source/headers/geos/io.h, source/io/ByteOrderValues.cpp,
+	  source/io/WKBReader.cpp: Added initial implementation of
+	  WKBReaderT and ByteOrderDataInStreamT
+	  class templates and ByteOrderValues class.
+	  Work is unfinished as WKBReader requires new interface of
+	  taking higher dimensions into account.
+2005-04-20 17:18  Sandro Santilli <strk at keybit.net>
+	* [r692] source/headers/geos.h: Added standard copyright header
+2005-04-19 11:49  Sandro Santilli <strk at keybit.net>
+	* [r691] source/geom/Point.cpp: Fixed segfault in ::isEmpty
+2005-04-14 11:49  Sandro Santilli <strk at keybit.net>
+	* [r690] source/headers/geos/io.h, source/io/StringTokenizer.cpp,
+	  source/io/WKTReader.cpp: Applied slightly modified patch by Cheng
+	  Shan to speedup WKT parsing.
+2005-04-07 18:43  Sandro Santilli <strk at keybit.net>
+	* [r689] source/operation/valid/IsValidOp.cpp: Fixed bug throwing
+	  an exception when a result could be returned instead
+	  (ported JTS patch)
+2005-04-06 11:09  Sandro Santilli <strk at keybit.net>
+	* [r688] ChangeLog, ltmain.sh, source/algorithm/CGAlgorithms.cpp,
+	  source/algorithm/NonRobustLineIntersector.cpp,
+	  source/algorithm/RobustDeterminant.cpp,
+	  source/geomgraph/index/SegmentIntersector.cpp,
+	  source/headers/geos/platform.h.in,
+	  source/noding/snapround/SegmentSnapper.cpp,
+	  source/planargraph/planarDirectedEdge.cpp: Applied patch from Jon
+	  Schlueter (math.h => cmath; ieeefp.h in "C" block)
+2005-04-02 17:07  sgillies
+	* [r687] swig/python/setup.py: now supporting the win32 platform,
+	  thanks to Howard Butler
+2005-03-26 08:19  Sandro Santilli <strk at keybit.net>
+	* [r686] source/headers/geos/opPolygonize.h: Commented out
+	  Polygonizer::LineStringAdder friendship
+2005-03-10 17:27  Sandro Santilli <strk at keybit.net>
+	* [r685] source/io/WKBReader.cpp: ported from current JTS
+2005-03-04 07:48  Sandro Santilli <strk at keybit.net>
+	* [r684] source/algorithm/CGAlgorithms.cpp: Removed useless copy
+	  from ::isOnLine() - suggested by Dale Lutz
+2005-03-02 08:14  Sandro Santilli <strk at keybit.net>
+	* [r683] source/headers/Makefile.am: Removed commented line,
+	  cousing strange behaviours with autotools.
+2005-02-22 18:21  Sandro Santilli <strk at keybit.net>
+	* [r682] source/headers/geos/noding.h,
+	  source/index/strtree/STRtree.cpp, source/noding/SegmentNode.cpp,
+	  source/noding/SegmentNodeList.cpp,
+	  source/noding/SegmentString.cpp: Changed SegmentNode to contain a
+	  *real* Coordinate (not a pointer) to reduce
+	  construction costs.
+2005-02-22 17:10  Sandro Santilli <strk at keybit.net>
+	* [r681] source/geom/CoordinateSequence.cpp,
+	  source/geom/LineString.cpp, source/noding/MCQuadtreeNoder.cpp,
+	  source/operation/buffer/RightmostEdgeFinder.cpp: Reduced
+	  CoordinateSequence::getSize() calls.
+2005-02-22 16:24  Sandro Santilli <strk at keybit.net>
+	* [r680] source/geomgraph/Edge.cpp,
+	  source/headers/geos/geomgraph.h: cached number of points in Edge
+2005-02-22 16:23  Sandro Santilli <strk at keybit.net>
+	* [r679] source/headers/geos/noding.h,
+	  source/noding/SegmentString.cpp: Cached number of points in
+	  CoordinateSequence.
+2005-02-22 15:49  Sandro Santilli <strk at keybit.net>
+	* [r678] source/noding/SegmentString.cpp: Reduced calls to
+	  DefaultCoordinateSequence->getSize().
+2005-02-22 15:16  Sandro Santilli <strk at keybit.net>
+	* [r677] source/headers/geos/indexStrtree.h,
+	  source/index/strtree/STRtree.cpp: STRtree::avg() and
+	  STRtree::centreY() inlined.
+2005-02-22 10:55  Sandro Santilli <strk at keybit.net>
+	* [r676] source/geomgraph/Edge.cpp: Optimized Edge::equals(Edge *e)
+2005-02-18 08:20  Sandro Santilli <strk at keybit.net>
+	* [r675] source/test/XMLTester.cpp: Added support for
+	  point-per-quadrant argument in buffer tests (using arg2).
+2005-02-17 09:56  Sandro Santilli <strk at keybit.net>
+	* [r674] source/operation/buffer/OffsetCurveBuilder.cpp: Commented
+	  out unused variable.
+	* [r673] source/headers/geos/geom.h: Applied patch from Jon
+	  Schlueter using <cmath> instead of <math.h>
+2005-02-15 17:15  Sandro Santilli <strk at keybit.net>
+	* [r672] source/algorithm/RobustLineIntersector.cpp,
+	  source/geom/Envelope.cpp, source/geom/LineSegment.cpp,
+	  source/headers/geos/geom.h, source/headers/geos/indexChain.h,
+	  source/headers/geos/indexStrtree.h,
+	  source/index/chain/MonotoneChainBuilder.cpp,
+	  source/index/strtree/AbstractNode.cpp,
+	  source/index/strtree/AbstractSTRtree.cpp,
+	  source/index/strtree/SIRtree.cpp,
+	  source/noding/MCQuadtreeNoder.cpp: Inlined most Envelope methods,
+	  reserved() memory for some vectors when
+	  the usage was known a priori.
+2005-02-11 08:58  Sandro Santilli <strk at keybit.net>
+	* [r671] source/geom/Makefile.am, source/headers/Makefile.am,
+	  source/headers/geos/Makefile.am: Applied patch from Curtis
+	  Barrett handling --includedir and --libdir
+	  params for configure.
+2005-02-05 05:44  Sandro Santilli <strk at keybit.net>
+	* [r670] source/algorithm/CGAlgorithms.cpp,
+	  source/algorithm/RobustLineIntersector.cpp,
+	  source/geomgraph/EdgeIntersectionList.cpp,
+	  source/geomgraph/GeometryGraph.cpp, source/geomgraph/NodeMap.cpp,
+	  source/geomgraph/PlanarGraph.cpp, source/geomgraph/Quadrant.cpp,
+	  source/headers/geos/geom.h, source/headers/geos/geomgraph.h,
+	  source/headers/geos/opRelate.h, source/headers/geos/operation.h,
+	  source/noding/MCQuadtreeNoder.cpp,
+	  source/noding/SegmentString.cpp, source/operation/IsSimpleOp.cpp,
+	  source/operation/overlay/OverlayOp.cpp,
+	  source/operation/valid/IsValidOp.cpp: Changed geomgraph nodeMap
+	  to use Coordinate pointers as keys, reduces
+	  lots of other Coordinate copies.
+2005-02-04 23:55  Sandro Santilli <strk at keybit.net>
+	* [r669] source/headers/geos/geom.h: Envelope destructor made
+	  non-virtual to give compiler more static
+	  binding options.
+2005-02-04 18:49  Sandro Santilli <strk at keybit.net>
+	* [r668] source/headers/geos/opBuffer.h,
+	  source/operation/buffer/BufferSubgraph.cpp: Changed
+	  ::computeDepths to use a set instead of a vector for checking
+	  visited Edges.
+2005-02-04 14:49  Sandro Santilli <strk at keybit.net>
+	* [r667] source/test/Makefile.am: Added rule to build
+	  staticXMLTester (for profiling with gprof)
+2005-02-03 09:17  Sandro Santilli <strk at keybit.net>
+	* [r666] source/geom/CoordinateSequence.cpp: more profiling label
+2005-02-01 16:09  Sandro Santilli <strk at keybit.net>
+	* [r665] source/noding/MCQuadtreeNoder.cpp,
+	  source/noding/Noder.cpp: more profiling labels
+2005-02-01 16:06  Sandro Santilli <strk at keybit.net>
+	* [r664] source/geom/Envelope.cpp,
+	  source/index/chain/indexMonotoneChain.cpp: Small optimizations.
+2005-02-01 14:18  Sandro Santilli <strk at keybit.net>
+	* [r663] source/noding/SegmentNodeList.cpp,
+	  source/noding/SegmentString.cpp: More profiler labels
+	* [r662] source/headers/geos/profiler.h, source/util/Profiler.cpp:
+	  Made profiler start/stop inline
+2005-02-01 13:44  Sandro Santilli <strk at keybit.net>
+	* [r661] source/geom/LineSegment.cpp,
+	  source/geomgraph/EdgeList.cpp,
+	  source/index/chain/MonotoneChainOverlapAction.cpp,
+	  source/noding/IteratedNoder.cpp,
+	  source/util/Profiler.cpp: More profiling labels.
+2005-01-31 15:41  Sandro Santilli <strk at keybit.net>
+	* [r660] source/index/strtree/AbstractSTRtree.cpp,
+	  source/noding/MCQuadtreeNoder.cpp: Small optimizations.
+2005-01-28 10:01  Sandro Santilli <strk at keybit.net>
+	* [r659] source/io/ParseException.cpp: substituted sprintf calls
+	  with use of ostringstream
+2005-01-28 09:47  Sandro Santilli <strk at keybit.net>
+	* [r658] source/examples/CustomPointCoordinateSequence.cpp,
+	  source/geom/Dimension.cpp, source/geom/Envelope.cpp,
+	  source/geom/IntersectionMatrix.cpp, source/geom/LineSegment.cpp,
+	  source/geom/Location.cpp,
+	  source/geom/PointCoordinateSequence.cpp,
+	  source/geom/PrecisionModel.cpp, source/geomgraph/Depth.cpp,
+	  source/geomgraph/Quadrant.cpp,
+	  source/index/quadtree/QuadTreeNodeBase.cpp,
+	  source/noding/SegmentNode.cpp,
+	  source/planargraph/planarDirectedEdge.cpp: Replaced sprintf uses
+	  with ostringstream.
+2005-01-28 08:47  Sandro Santilli <strk at keybit.net>
+	* [r657] source/geom/Coordinate.cpp: Removed sprintf usage,
+	  replaced with sstream
+2005-01-28 07:58  Sandro Santilli <strk at keybit.net>
+	* [r656] source/geom/DefaultCoordinateSequence.cpp: removed sprintf
+	  usage, ad ::toString call Coordinate::toString
+2005-01-18 17:22  Sandro Santilli <strk at keybit.net>
+	* [r655] source/algorithm/LineIntersector.cpp: reverted previous
+	  change, sign was actually stored in zgap
+2005-01-18 17:09  Sandro Santilli <strk at keybit.net>
+	* [r654] source/algorithm/RobustLineIntersector.cpp: Fixed
+	  interpolateZ call using final intersection point instead of
+	  HCoordinate.
+2005-01-14 08:04  Sandro Santilli <strk at keybit.net>
+	* [r653] source/algorithm/LineIntersector.cpp: Fixed Z
+	  interpolation to use the correct sign
+2005-01-03 16:06  Sandro Santilli <strk at keybit.net>
+	* [r652] source/test/XMLTester.cpp: Changed polygonize op to return
+	  a GeometryCollection
+2005-01-03 15:56  Sandro Santilli <strk at keybit.net>
+	* [r651] source/test/XMLTester.cpp: Fixed memory leaks just
+	  introduced for Polygonizer test case.
+2005-01-03 15:49  Sandro Santilli <strk at keybit.net>
+	* [r650] source/test/XMLTester.cpp: Added Polygonize test handling
+2004-12-30 13:32  Sandro Santilli <strk at keybit.net>
+	* [r649] source/test/XMLTester.cpp: Handled NULL result from
+	  getCentroid()
+2004-12-30 13:31  Sandro Santilli <strk at keybit.net>
+	* [r648] source/geom/Geometry.cpp: Fixed a segfault on
+	  EMPTYGEOM->getCeontroid()
+2004-12-30 10:14  Sandro Santilli <strk at keybit.net>
+	* [r647] source/geom/Polygon.cpp: never return LinearRing or
+	  MultiLinearRing from getBoundary
+	* [r646] source/geom/GeometryFactory.cpp: input checking and class
+	  promoting in createMultiLineString()
+2004-12-22 09:42  Sandro Santilli <strk at keybit.net>
+	* [r645] source/geom/util/GeometryEditor.cpp: Fixed a premature
+	  Geometry destruction, Avoided CoordinateSequence copies
+	  when possible.
+2004-12-16 18:29  pramsey
+	* [r644] configure.in: Bumped minor version number for 2.1.1
+	  release.
+2004-12-16 16:27  Sandro Santilli <strk at keybit.net>
+	* [r643] source/geom/LinearRing.cpp, source/headers/geos/geom.h:
+	  Fixed LinearRing::clone() to return LinearRing instead of
+	  LineString
+2004-12-16 16:08  Sandro Santilli <strk at keybit.net>
+	* [r642] swig/geos.i, swig/python/example.py: New patches from Niki
+	  Spahiev <niki.spahiev at gmail.com>
+	  (still unstable)
+2004-12-16 09:05  Sandro Santilli <strk at keybit.net>
+	* [r641] swig/python/example.py: Added python example by Niki
+2004-12-16 08:56  Sandro Santilli <strk at keybit.net>
+	* [r640] swig/geos.i: Applyed patches by Niki Spahiev
+	  <niki.spahiev at gmail.com>
+2004-12-14 10:35  Sandro Santilli <strk at keybit.net>
+	* [r638] source/headers/geos/opPolygonize.h,
+	  source/headers/geos/planargraph.h,
+	  source/operation/polygonize/PolygonizeGraph.cpp,
+	  source/planargraph/planarDirectedEdge.cpp,
+	  source/planargraph/planarDirectedEdgeStar.cpp: Comments cleanup.
+	  PolygonizeGraph keeps track of generated CoordinateSequence
+	  for delayed destruction.
+2004-12-13 13:54  Sandro Santilli <strk at keybit.net>
+	* [r637] source/headers/geos/opPolygonize.h: Added a not about gcc
+	  2.95.4 required friendship
+2004-12-13 13:53  Sandro Santilli <strk at keybit.net>
+	* [r636] source/geom/TopologyException.cpp: Fixed uninitialized
+	  Coordinate.
+2004-12-12 17:22  Sandro Santilli <strk at keybit.net>
+	* [r635] source/headers/geos/Makefile.am: version.h and platform.h
+	  installed again (missed when removed from dist)
+2004-12-08 14:33  Sandro Santilli <strk at keybit.net>
+	* [r634] source/geom/MultiPolygon.cpp: Checked inner polys
+	  getBoundary return for the single LineString case.
+2004-12-08 14:32  Sandro Santilli <strk at keybit.net>
+	* [r633] source/geom/GeometryCollection.cpp: cleanups
+2004-12-08 14:31  Sandro Santilli <strk at keybit.net>
+	* [r632] source/test/testLeaksBig.xml: adjusted getBoundary
+	  expected returns to match OGC specs
+	* [r631] source/operation/overlay/OverlayOp.cpp: elevationMatrix
+	  deleted by destructor
+2004-12-08 14:30  Sandro Santilli <strk at keybit.net>
+	* [r630] source/io/Unload.cpp: Added default profiler instance
+	  cleanup
+2004-12-08 13:54  Sandro Santilli <strk at keybit.net>
+	* [r629] doc/example.cpp,
+	  source/bigtest/GeometryTestFactory.cpp, source/geom/Polygon.cpp,
+	  source/geom/util/GeometryEditor.cpp,
+	  source/geomgraph/Node.cpp, source/headers/geos/opBuffer.h,
+	  source/index/chain/MonotoneChainSelectAction.cpp,
+	  source/index/chain/indexMonotoneChain.cpp,
+	  source/index/quadtree/DoubleBits.cpp,
+	  source/index/quadtree/Quadtree.cpp,
+	  source/index/sweepline/SweepLineIndex.cpp,
+	  source/io/WKTReader.cpp, source/io/WKTWriter.cpp,
+	  source/operation/linemerge/LineMergeGraph.cpp,
+	  source/operation/overlay/ElevationMatrix.cpp,
+	  source/operation/polygonize/Polygonizer.cpp,
+	  source/operation/valid/IsValidOp.cpp, source/test/XMLTester.cpp,
+	  source/util/GeometricShapeFactory.cpp: gcc warnings checked and
+	  fixed, general cleanups.
+2004-12-06 10:54  Sandro Santilli <strk at keybit.net>
+	* [r628] source/headers/geos/Makefile.am: Added timeval.h in
+	  distribution.
+2004-12-05 10:54  Sandro Santilli <strk at keybit.net>
+	* [r627] VisualStudio, VisualStudio/.cvsignore: initial revision
+2004-12-05 10:50  Sandro Santilli <strk at keybit.net>
+	* [r626] VisualStudio/Makefile.am: forgot to add
+2004-12-05 10:48  Sandro Santilli <strk at keybit.net>
+	* [r625] debian/control, debian/libgeos-doc.doc-base, debian/rules:
+	  Modifications by Alex Bodnaru
+2004-12-05 10:44  Sandro Santilli <strk at keybit.net>
+	* [r624] configure.in, doc/Makefile.am, source/bigtest/Makefile.am,
+	  source/examples/Makefile.am, source/test/Makefile.am: Applied
+	  Norman Vine patches for cleaner win32 build.
+2004-12-04 15:56  Sandro Santilli <strk at keybit.net>
+	* [r623] source/Makefile.am, source/headers/geos/Makefile.am: Added
+	  source/Makefile.vc and source/headers/geos/platform.h.in in
+	  distribution
+2004-12-04 15:31  Sandro Santilli <strk at keybit.net>
+	* [r622] Makefile.am, configure.in,
+	  source/headers/geos/Makefile.am: Added VisualStudio dir in
+	  distribution, removed platform.h and version.h from it.
+2004-12-04 01:20  frank
+	* [r621] source/Makefile.vc: removed dll delete
+2004-12-03 22:52  Sandro Santilli <strk at keybit.net>
+	* [r620] source/geom/CoordinateSequence.cpp,
+	  source/geom/DefaultCoordinateSequence.cpp,
+	  source/headers/geos/geom.h, source/util/Profiler.cpp: enforced
+	  const return of CoordinateSequence::toVector() method to derivate
+	  classes.
+2004-12-03 16:26  frank
+	* [r619] source/headers/geos/platform.h.vc: added headers
+2004-12-03 16:25  frank
+	* [r618] source/Makefile.vc: New
+2004-12-03 16:22  frank
+	* [r617] source/headers/geos/geom.h: update to use I64 on MSVC for
+	  64 bit integer constants, also toVector chg.
+2004-12-03 16:21  frank
+	* [r616] source/headers/geos/profiler.h: dont try for sys/time.h
+	  with MSVC
+2004-12-03 16:19  frank
+	* [r615] source/headers/geos/platform.h.vc: New
+2004-11-30 16:44  Sandro Santilli <strk at keybit.net>
+	* [r614] source/headers/geos/profiler.h,
+	  source/headers/geos/timeval.h: Added gettimeofday implementation
+	  for win32, curtesy of Wu Yongwei.
+2004-11-30 13:05  Sandro Santilli <strk at keybit.net>
+	* [r613] source/headers/geos/platform.h.in: Removed inclusion of
+	  stdio.h, which should now be useless.
+2004-11-30 13:04  Sandro Santilli <strk at keybit.net>
+	* [r612] configure.in, source/headers/geos/platform.h.in: Added
+	  optional inclusion of ieeefp.h on platform providing it.
+2004-11-29 16:05  Sandro Santilli <strk at keybit.net>
+	* [r611] source/algorithm/HCoordinate.cpp,
+	  source/geom/Coordinate.cpp, source/geomgraph/Node.cpp,
+	  source/headers/geos/geom.h, source/headers/geos/platform.h.in,
+	  source/operation/overlay/ElevationMatrixCell.cpp,
+	  source/operation/overlay/OverlayOp.cpp: Fixed a bug in
+	  LineIntersector::interpolateZ causing NaN values
+	  to come out.
+	  Handled dimensional collapses in ElevationMatrix.
+	  Added ISNAN macro and changed ISNAN/FINITE macros to avoid
+	  dispendious isnan() and finite() calls.
+2004-11-27 11:36  Sandro Santilli <strk at keybit.net>
+	* [r610] debian/Makefile, debian/README.Debian, debian/changelog,
+	  debian/control, debian/libgeos-dev.install,
+	  debian/libgeos-dev.manpages, debian/rules, debian/shlibs.local:
+	  Updated scripts by Alex Bodnaru, added Makefile
+2004-11-26 09:53  Sandro Santilli <strk at keybit.net>
+	* [r609] source/algorithm/LineIntersector.cpp,
+	  source/geomgraph/Node.cpp, source/headers/geos/platform.h.in:
+	  Added more FINITE calls, and added inf and -inf to FINITE checks
+2004-11-26 09:22  Sandro Santilli <strk at keybit.net>
+	* [r608] source/headers/geos/platform.h.in,
+	  source/operation/overlay/OverlayOp.cpp: Added FINITE(x) macro and
+	  its use.
+	  Made input geoms average Z computation optional in OverlayOp.
+2004-11-24 18:10  Sandro Santilli <strk at keybit.net>
+	* [r607] source/operation/overlay/OverlayOp.cpp: Stricter handling
+	  of USE_ELEVATION_MATRIX define
+	* [r606] source/algorithm/LineIntersector.cpp: Cleanup of
+	  interpolateZ
+2004-11-24 12:29  Sandro Santilli <strk at keybit.net>
+	* [r605] source/operation/overlay/ElevationMatrix.cpp: Handled
+	  boundary cases in ::getCell
+2004-11-24 11:32  Sandro Santilli <strk at keybit.net>
+	* [r604] source/operation/overlay/LineBuilder.cpp: Re-enabled Z
+	  propagation in output lines.
+2004-11-23 19:53  Sandro Santilli <strk at keybit.net>
+	* [r603] source/algorithm/LineIntersector.cpp,
+	  source/geomgraph/Edge.cpp, source/geomgraph/EdgeEndStar.cpp,
+	  source/operation/overlay/OverlayOp.cpp: Had LineIntersector
+	  compute Z by interpolation.
+2004-11-23 16:22  Sandro Santilli <strk at keybit.net>
+	* [r602] source/geom/DefaultCoordinateSequence.cpp,
+	  source/geom/LineString.cpp, source/geom/Makefile.am,
+	  source/geom/Point.cpp, source/headers/geos/geom.h,
+	  source/operation/overlay/OverlayOp.cpp: Added ElevationMatrix
+	  class and components to do post-processing draping of overlayed
+	  geometries.
+2004-11-22 15:51  Sandro Santilli <strk at keybit.net>
+	* [r601] source/headers/geos/opOverlay.h,
+	  source/operation/overlay/OverlayOp.cpp: Added interpolation of
+	  containing geometry's average Z for point_in_poly case.
+2004-11-22 13:02  Sandro Santilli <strk at keybit.net>
+	* [r600] source/algorithm/RobustLineIntersector.cpp: Fixed a bug in
+	  Collinear intersection Z computation
+	* [r599] source/geomgraph/EdgeIntersectionList.cpp: Forced use if
+	  computed intersection point in ::createSplitEdge (for Z
+	  computation)
+2004-11-22 12:59  Sandro Santilli <strk at keybit.net>
+	* [r598] source/geomgraph/Edge.cpp: Added debugging lines
+2004-11-22 11:34  Sandro Santilli <strk at keybit.net>
+	* [r597] source/geomgraph/EdgeEndStar.cpp,
+	  source/operation/overlay/OverlayOp.cpp: More debugging lines and
+	  comments/indentation cleanups
+	* [r596] source/algorithm/RobustLineIntersector.cpp: Added Z
+	  computation for CollinearIntersections
+2004-11-20 18:54  Sandro Santilli <strk at keybit.net>
+	* [r595] debian/README.Debian, debian/control,
+	  debian/libgeos-dev.install, debian/rules: Scripts updates from
+	  Alex Bodnaru
+2004-11-20 18:17  Sandro Santilli <strk at keybit.net>
+	* [r594] source/headers/geos/opOverlay.h,
+	  source/operation/overlay/LineBuilder.cpp: Added Z propagation for
+	  overlay lines output.
+2004-11-20 17:16  Sandro Santilli <strk at keybit.net>
+	* [r593] source/headers/geos/opOverlay.h,
+	  source/operation/overlay/OverlayOp.cpp: Handled Z merging for
+	  point on polygon boundary case.
+2004-11-20 16:25  Sandro Santilli <strk at keybit.net>
+	* [r592] source/operation/overlay/OverlayOp.cpp: Added Z
+	  computation for point on line case.
+2004-11-20 15:46  Sandro Santilli <strk at keybit.net>
+	* [r591] source/headers/geos/geomgraph.h: Added composing Z
+	  management functions and elements for class Node
+2004-11-20 15:45  Sandro Santilli <strk at keybit.net>
+	* [r590] source/geomgraph/NodeMap.cpp: Fixed Z merging in
+	  addNode(Node *)
+2004-11-20 15:41  Sandro Santilli <strk at keybit.net>
+	* [r589] source/geomgraph/NodeMap.cpp: Added Z merging in ::addNode
+	* [r588] source/geomgraph/Node.cpp: Added management of vector of
+	  composing Z values.
+2004-11-20 15:40  Sandro Santilli <strk at keybit.net>
+	* [r587] source/algorithm/RobustLineIntersector.cpp: Added Z
+	  computation in point-segment intersection.
+2004-11-20 15:39  Sandro Santilli <strk at keybit.net>
+	* [r586] source/algorithm/CGAlgorithms.cpp: Reduced HEAP
+	  allocations.
+2004-11-19 16:35  Sandro Santilli <strk at keybit.net>
+	* [r585] debian, debian/changelog, debian/compat, debian/control,
+	  debian/copyright, debian/geos-config.1, debian/libgeos-dev.dirs,
+	  debian/libgeos-dev.docs, debian/libgeos-dev.install,
+	  debian/libgeos-doc.doc-base, debian/libgeos-doc.docs,
+	  debian/libgeos.dirs, debian/libgeos.docs, debian/libgeos.install,
+	  debian/makedoc, debian/rules, debian/shlibs.local, debian/watch:
+	  Added debian package builder scripts.
+2004-11-19 16:15  Sandro Santilli <strk at keybit.net>
+	* [r584] source/index/quadtree/QuadTreeNode.cpp: Completely removed
+	  sprintf usage, substituted by stringstream.
+2004-11-19 16:09  Sandro Santilli <strk at keybit.net>
+	* [r583] source/index/quadtree/QuadTreeNode.cpp: Added <stdio.h>
+	  include for sprintf recognition.
+2004-11-19 10:10  Sandro Santilli <strk at keybit.net>
+	* [r582] source/geomgraph/Node.cpp: COMPUTE_Z re-enabled by default
+2004-11-19 09:33  Sandro Santilli <strk at keybit.net>
+	* [r581] source/geomgraph/GeometryGraph.cpp: removed useless
+	  CoordinateSequence copy in ::addLineString
+2004-11-17 15:09  Sandro Santilli <strk at keybit.net>
+	* [r580] source/algorithm/RobustLineIntersector.cpp,
+	  source/operation/overlay/PointBuilder.cpp: Changed COMPUTE_Z
+	  defaults to be more conservative
+2004-11-17 08:41  Sandro Santilli <strk at keybit.net>
+	* [r579] source/algorithm/RobustLineIntersector.cpp,
+	  source/geomgraph/index/SegmentIntersector.cpp: Fixed a bug in Z
+	  computation and removed debugging output by default.
+2004-11-17 08:13  Sandro Santilli <strk at keybit.net>
+	* [r578] source/algorithm/PointLocator.cpp,
+	  source/geom/Geometry.cpp, source/geomgraph/EdgeEndStar.cpp,
+	  source/geomgraph/Label.cpp, source/geomgraph/Node.cpp,
+	  source/headers/geos/indexQuadtree.h,
+	  source/headers/geos/operation.h,
+	  source/operation/overlay/PointBuilder.cpp: Indentation changes.
+	  Some Z_COMPUTATION activated by default.
+2004-11-12 18:12  Sandro Santilli <strk at keybit.net>
+	* [r576] source/geom/Polygon.cpp: Changed ::getBoundary() to return
+	  LineString if polygon has no holes.
+	  (has required to pass OGC conformance test T20)
+2004-11-09 20:22  Sandro Santilli <strk at keybit.net>
+	* [r575] tools/geos-config.in: Removed -g -O2 from geos-config
+	  --cflags output
+2004-11-08 18:33  Sandro Santilli <strk at keybit.net>
+	* [r574] source/index/strtree/STRtree.cpp: Just another small
+	  improvement.
+2004-11-08 15:58  Sandro Santilli <strk at keybit.net>
+	* [r573] source/headers/geos/indexStrtree.h,
+	  source/operation/buffer/BufferOp.cpp: More performance tuning.
+2004-11-08 13:12  Sandro Santilli <strk at keybit.net>
+	* [r572] source/headers/geos/Makefile.am: Added profiler.h
+2004-11-08 12:15  Sandro Santilli <strk at keybit.net>
+	* [r571] source/util/Profiler.cpp: Added number of gathered timings
+	  in output.
+2004-11-08 11:19  Sandro Santilli <strk at keybit.net>
+	* [r570] source/util/Profiler.cpp: Profiler::get() always return a
+	  Profile (new if not existant).
+2004-11-08 10:58  Sandro Santilli <strk at keybit.net>
+	* [r569] source/geom/Envelope.cpp: Optimized the ::intersect
+	  function to avoid nested function calls.
+2004-11-08 10:57  Sandro Santilli <strk at keybit.net>
+	* [r568] source/headers/geos/geom.h: Moved Log lines at the bottom,
+	  and cut oldest
+2004-11-06 08:16  Sandro Santilli <strk at keybit.net>
+	* [r567] source/algorithm/CGAlgorithms.cpp,
+	  source/operation/valid/IsValidOp.cpp: Fixed CGAlgorithms::isCCW
+	  from JTS port.
+	  Code cleanup in IsValidOp.
+2004-11-05 12:18  Sandro Santilli <strk at keybit.net>
+	* [r566] TODO: updated
+2004-11-05 11:41  Sandro Santilli <strk at keybit.net>
+	* [r565] source/algorithm/CGAlgorithms.cpp,
+	  source/operation/valid/TopologyValidationError.cpp: Made
+	  IsValidOp handle IllegalArgumentException throw from
+	  GeometryGraph
+	  as a sign of invalidity (just for Polygon geometries).
+	  Removed leaks generated by this specific exception.
+2004-11-04 19:08  Sandro Santilli <strk at keybit.net>
+	* [r564] source/algorithm/MinimumDiameter.cpp,
+	  source/geom/CoordinateSequence.cpp,
+	  source/headers/geos/indexChain.h,
+	  source/headers/geos/indexStrtree.h, source/headers/geos/noding.h,
+	  source/noding/MCQuadtreeNoder.cpp, source/noding/Noder.cpp,
+	  source/test/XMLTester.cpp: Cleanups, initializers list,
+	  profiling.
+2004-11-04 08:49  Sandro Santilli <strk at keybit.net>
+	* [r563] source/headers/geos/indexQuadtree.h,
+	  source/headers/geos/profiler.h,
+	  source/index/quadtree/DoubleBits.cpp: Unlinked new documentation.
+2004-11-03 08:22  Sandro Santilli <strk at keybit.net>
+	* [r562] source/index/quadtree/DoubleBits.cpp: Slightly modified
+	  log/log2 based algo to better handle numbers in the
+	  range 0-1.
+2004-11-02 16:38  Sandro Santilli <strk at keybit.net>
+	* [r561] source/headers/geos/indexQuadtree.h: Fixed ieee-754
+	  detection switch
+2004-11-02 16:31  Sandro Santilli <strk at keybit.net>
+	* [r560] TODO: updated
+2004-11-02 16:05  Sandro Santilli <strk at keybit.net>
+	* [r559] source/headers/geos/indexQuadtree.h: Autodetect
+	  availability of IEEE-754 FP
+2004-11-02 15:49  Sandro Santilli <strk at keybit.net>
+	* [r558] source/headers/geos/indexQuadtree.h,
+	  source/index/quadtree/DoubleBits.cpp: Moved ASSUME_IEEE_DOUBLE
+	  define from DoubleBits.cpp to indexQuadtree.h.
+	  Fixed a bug in powerOf2(). Made the !IEEE version less prone to
+	  round-offs (still has approximation errors).
+2004-11-02 14:13  Sandro Santilli <strk at keybit.net>
+	* [r557] source/index/quadtree/DoubleBits.cpp: Fixed bug in
+	  IEEE-based exponent and PowerOf2 computation, but disabled
+	  at compile time.
+2004-11-02 14:11  Sandro Santilli <strk at keybit.net>
+	* [r556] source/noding/MCQuadtreeNoder.cpp: Added more profiling.
+2004-11-02 09:38  Sandro Santilli <strk at keybit.net>
+	* [r555] source/test/XMLTester.cpp: Added timer for buffer test.
+2004-11-01 16:43  Sandro Santilli <strk at keybit.net>
+	* [r554] source/geom/Coordinate.cpp, source/geom/Envelope.cpp,
+	  source/geom/Makefile.am, source/geomgraph/Edge.cpp,
+	  source/geomgraph/EdgeEndStar.cpp, source/geomgraph/EdgeList.cpp,
+	  source/headers/geos/noding.h, source/headers/geos/opBuffer.h,
+	  source/headers/geos/profiler.h, source/headers/geos/util.h,
+	  source/index/quadtree/QuadTreeKey.cpp,
+	  source/index/quadtree/QuadTreeNode.cpp,
+	  source/index/quadtree/QuadTreeRoot.cpp,
+	  source/noding/NodingValidator.cpp, source/noding/SegmentNode.cpp,
+	  source/noding/nodingSegmentIntersector.cpp,
+	  source/operation/buffer/BufferOp.cpp, source/util/Profiler.cpp:
+	  Added Profiler code.
+	  Temporarly patched a bug in DoubleBits (must check drawbacks).
+	  Various cleanups and speedups.
+2004-10-27 13:57  Sandro Santilli <strk at keybit.net>
+	* [r553] source/operation/polygonize/Polygonizer.cpp,
+	  source/operation/polygonize/polygonizeEdgeRing.cpp: Added some
+	  debugging lines (disabled by default)
+2004-10-27 11:05  Sandro Santilli <strk at keybit.net>
+	* [r552] TODO: updated
+2004-10-26 17:46  Sandro Santilli <strk at keybit.net>
+	* [r551] source/headers/geos/indexBintree.h,
+	  source/headers/geos/spatialIndex.h: Removed slash-stars in
+	  comments to remove annoying compiler warnings.
+2004-10-26 17:14  Sandro Santilli <strk at keybit.net>
+	* [r550] NEWS, configure.in: current:revision:age set to 3.0.1
+	  (will be release 2.1.0).
+	  added news.
+2004-10-26 16:22  Sandro Santilli <strk at keybit.net>
+	* [r549] TODO: updated
+2004-10-26 16:09  Sandro Santilli <strk at keybit.net>
+	* [r548] source/operation/polygonize/PolygonizeGraph.cpp,
+	  source/operation/polygonize/polygonizeEdgeRing.cpp: Some more
+	  intentation and envelope equality check fix.
+2004-10-21 22:29  Sandro Santilli <strk at keybit.net>
+	* [r547] source/algorithm/LineIntersector.cpp,
+	  source/geom/Coordinate.cpp, source/geomgraph/EdgeEnd.cpp,
+	  source/geomgraph/GeometryGraph.cpp, source/geomgraph/Node.cpp,
+	  source/geomgraph/NodeMap.cpp, source/geomgraph/PlanarGraph.cpp,
+	  source/headers/geos/opOverlay.h, source/io/WKTWriter.cpp,
+	  and some more COMPUTE_Z rules
+2004-10-21 17:13  Sandro Santilli <strk at keybit.net>
+	* [r546] source/io/WKTReader.cpp: Fixed bug introduced by previous
+	  patch.
+2004-10-21 07:03  Sandro Santilli <strk at keybit.net>
+	* [r545] source/io/WKTReader.cpp: Removed leak in ::readPolygonText
+	  reported by Carlos A. Rueda
+2004-10-20 17:32  Sandro Santilli <strk at keybit.net>
+	* [r544] source/algorithm/HCoordinate.cpp,
+	  source/algorithm/LineIntersector.cpp,
+	  source/geomgraph/index/MonotoneChain.cpp,
+	  source/io/WKTWriter.cpp,
+	  source/operation/overlay/PointBuilder.cpp: Initial approach to
+	  2.5d intersection()
+2004-10-19 21:04  Sandro Santilli <strk at keybit.net>
+	* [r543] TODO: updated
+2004-10-19 19:51  Sandro Santilli <strk at keybit.net>
+	* [r542] source/geomgraph/GeometryGraph.cpp,
+	  source/operation/polygonize/PolygonizeDirectedEdge.cpp,
+	  source/operation/polygonize/PolygonizeEdge.cpp,
+	  source/operation/polygonize/polygonizeEdgeRing.cpp,
+	  source/planargraph/planarNode.cpp,
+	  source/planargraph/planarNodeMap.cpp: Fixed many leaks and bugs
+	  in Polygonizer.
+	  Output still bogus.
+2004-10-18 12:43  Sandro Santilli <strk at keybit.net>
+	* [r541] Makefile.am, configure.in, swig, swig/.cvsignore,
+	  swig/Makefile.am, swig/python, swig/python/.cvsignore,
+	  swig/python/Makefile.am, swig/python/tests,
+	  swig/python/tests/.cvsignore, swig/python/tests/Makefile.am,
+	  swig/python/tests/cases, swig/python/tests/cases/.cvsignore,
+	  swig/python/tests/cases/Makefile.am: swig interface added to
+	  distribution.
+2004-10-13 10:03  Sandro Santilli <strk at keybit.net>
+	* [r540] doc/example.cpp, source/geom/CoordinateSequence.cpp,
+	  source/headers/geos/geom.h, source/headers/geos/opLinemerge.h,
+	  source/headers/geos/planargraph.h, source/io/Unload.cpp,
+	  source/operation/linemerge/EdgeString.cpp,
+	  source/planargraph/planarDirectedEdgeStar.cpp,
+	  source/planargraph/planarEdge.cpp,
+	  source/planargraph/planarGraphComponent.cpp,
+	  source/planargraph/planarNodeMap.cpp,
+	  source/planargraph/planarPlanarGraph.cpp: Added missing linemerge
+	  and polygonize operation.
+	  Bug fixes and leaks removal from the newly added modules and
+	  planargraph (used by them).
+	  Some comments and indentation changes.
+2004-09-23 21:36  Sandro Santilli <strk at keybit.net>
+	* [r539] source/geom/CoordinateSequence.cpp: Fixed a bug in
+	  ::reverse (thanks to Elliott Edwards)
+2004-09-23 21:28  pramsey
+	* [r538] configure.in: Back minor version back to 2.0.1
+2004-09-23 04:30  pramsey
+	* [r537] configure.in: Bumped minor version to 2.0.2 after 2.0.1
+	  release.
+2004-09-21 09:47  Sandro Santilli <strk at keybit.net>
+	* [r536] source/precision/SimpleGeometryPrecisionReducer.cpp: fixed
+	  a mis-initialization bug in ::reduce
+	* [r535] source/index/quadtree/DoubleBits.cpp: Removed useless
+	  auto_ptr usage in ::exponent
+2004-09-16 09:50  Sandro Santilli <strk at keybit.net>
+	* [r534] TODO: updated
+2004-09-16 09:48  Sandro Santilli <strk at keybit.net>
+	* [r533] source/geom/Geometry.cpp: Finer short-circuit tests for
+	  equals, within, contains.
+	* [r532] source/geom/Envelope.cpp, source/headers/geos/geom.h:
+	  Added Envelope::equals
+2004-09-16 07:32  Sandro Santilli <strk at keybit.net>
+	* [r531] TODO: updated
+	* [r530] source/geom/Geometry.cpp: Added short-circuit tests. Can
+	  be disabled at compile-time
+2004-09-13 12:50  Sandro Santilli <strk at keybit.net>
+	* [r529] source/operation/valid/IsValidOp.cpp: comments cleanup
+2004-09-13 12:40  Sandro Santilli <strk at keybit.net>
+	* [r528] TODO: updated
+	* [r527] configure.in: Updated version number
+2004-09-13 12:39  Sandro Santilli <strk at keybit.net>
+	* [r526] source/test/XMLTester.cpp: Added missing newline at end of
+	  output
+	* [r525] source/geom/MultiPoint.cpp, source/geom/Point.cpp,
+	  source/headers/geos/geom.h, source/headers/geos/opValid.h,
+	  source/operation/valid/IsValidOp.cpp: Made Point and MultiPoint
+	  subject to Validity tests.
+2004-09-13 10:14  Sandro Santilli <strk at keybit.net>
+	* [r524] source/operation/valid/TopologyValidationError.cpp: Added
+	  INVALID_COORDINATE code num and error message.
+2004-09-13 10:12  Sandro Santilli <strk at keybit.net>
+	* [r523] TODO, source/headers/geos/geosAlgorithm.h,
+	  source/operation/valid/IsValidOp.cpp: Added invalid coordinates
+	  checks in IsValidOp.
+	  Cleanups.
+2004-09-13 09:18  Sandro Santilli <strk at keybit.net>
+	* [r522] source/headers/geos/opValid.h,
+	  IsValidOp::isValid(Coordinate &)
+2004-09-13 09:07  Sandro Santilli <strk at keybit.net>
+	* [r521] source/geom/LineString.cpp: Ported fix in
+	  LineString::isCoordinate
+2004-09-12 03:51  pramsey
+	* [r520] source/geom/LineString.cpp,
+	  source/geom/MultiLineString.cpp, source/geom/MultiPoint.cpp:
+	  Casting changes to allow OS/X compilation.
+2004-09-07 08:29  Sandro Santilli <strk at keybit.net>
+	* [r519] source/headers/geos/geom.h: Fixed doxygen malformed
+	  comment for Coordinate class
+2004-08-20 03:20  pramsey
+	* [r517] source/bigtest/Makefile.am: Added reference to bigtest.h
+	  so 'make dist' includes it properly.
+2004-08-20 01:55  pramsey
+	* [r516] configure.in: Removed examples from build directories for
+	  release (they don't build now).
+2004-08-04 08:26  Sandro Santilli <strk at keybit.net>
+	* [r515] source/operation/relate/RelateComputer.cpp: comments lift,
+	  stack allocation reduced
+2004-07-27 16:35  Sandro Santilli <strk at keybit.net>
+	* [r514] source/algorithm/InteriorPointArea.cpp,
+	  source/algorithm/SIRtreePointInRing.cpp,
+	  source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
+	  source/geom/GeometryFactory.cpp, source/geom/Polygon.cpp,
+	  source/geomgraph/EdgeRing.cpp, source/headers/geos/geom.h,
+	  source/headers/geos/spatialIndex.h,
+	  source/index/strtree/ItemBoundable.cpp,
+	  source/operation/distance/DistanceOp.cpp,
+	  source/operation/overlay/PolygonBuilder.cpp,
+	  source/operation/relate/RelateComputer.cpp,
+	  source/operation/relate/RelateOp.cpp,
+	  source/operation/valid/QuadtreeNestedRingTester.cpp,
+	  source/operation/valid/SweeplineNestedRingTester.cpp:
+	  Geometry::getEnvelopeInternal() changed to return a const
+	  Envelope *.
+	  This should reduce object copies as once computed the envelope of
+	  a
+	  geometry remains the same.
+2004-07-26 19:28  sgillies
+	* [r513] AUTHORS: added to AUTHORS
+2004-07-26 18:53  sgillies
+	* [r512] swig/geos.i, swig/python/tests/cases/pointtest.py,
+	  swig/python/tests/cases/wkttest.py: added simple exception
+	  handling on all method calls
+2004-07-26 16:35  Sandro Santilli <strk at keybit.net>
+	* [r511] source/headers/geos/geom.h: Removed dangling
+	  MultiPoint::isClosed() method definition.
+2004-07-26 15:40  sgillies
+	* [r510] swig/geos.i, swig/python/setup.py,
+	  swig/python/tests/cases/wkttest.py,
+	  swig/python/tests/runtests.py: wrapped up WKT reader and writer
+	  and added two test cases to check that it works. found a bug
+	  where the WKT reader crashes the program in the case of poorly
+	  formatted WKT string.
+2004-07-25 23:45  sgillies
+	* [r509] swig, swig/README.txt, swig/geos.i, swig/python,
+	  swig/python/README.txt, swig/python/setup.py, swig/python/tests,
+	  swig/python/tests/TESTING.txt, swig/python/tests/cases,
+	  swig/python/tests/cases/__init__.py,
+	  swig/python/tests/cases/pointtest.py,
+	  swig/python/tests/cases/testing.py,
+	  swig/python/tests/runtests.py: SWIG interface for high level
+	  language modules, Python setup script, and beginning of a unit
+	  testing framework under swig/python/tests. The build works for
+	  today's CVS GEOS, and the test passes -- means that a module can
+	  be built, installed, and imported.
+2004-07-22 16:58  Sandro Santilli <strk at keybit.net>
+	* [r508] TODO, doc/example.cpp, source/geom/Geometry.cpp,
+	  source/headers/geos/geom.h: runtime version extractor functions
+	  split. geos::version() is now
+	  geos::geosversion() and geos::jtsport()
+2004-07-22 08:45  Sandro Santilli <strk at keybit.net>
+	* [r507] TODO, source/geom/GeometryCollection.cpp,
+	  source/geom/LineString.cpp, source/geom/MultiLineString.cpp,
+	  source/geom/MultiPoint.cpp, source/headers/geos/geom.h:
+	  Documentation updates, memory leaks fixed.
+2004-07-22 07:19  Sandro Santilli <strk at keybit.net>
+	* [r506] source/headers/geos/geom.h: Changed getCoordinatesRO
+	  description.
+2004-07-22 07:04  Sandro Santilli <strk at keybit.net>
+	* [r505] source/geom/Coordinate.cpp,
+	  source/geom/GeometryCollection.cpp, source/geom/Polygon.cpp,
+	  source/headers/geos/geom.h: Documented missing geometry
+	  functions.
+2004-07-21 09:55  Sandro Santilli <strk at keybit.net>
+	* [r504] source/geom/Coordinate.cpp,
+	  source/geom/CoordinateList.cpp,
+	  source/geom/CoordinateSequence.cpp, source/geom/Envelope.cpp,
+	  source/geom/Geometry.cpp, source/geom/LineSegment.cpp,
+	  source/geom/PrecisionModel.cpp, source/geomgraph/Edge.cpp,
+	  source/headers/geos.h, source/headers/geos/geom.h:
+	  CoordinateSequence::atLeastNCoordinatesOrNothing definition fix.
+	  Documentation fixes.
+2004-07-21 09:11  Sandro Santilli <strk at keybit.net>
+	* [r503] NEWS, README, TODO: Updated
+2004-07-20 08:35  Sandro Santilli <strk at keybit.net>
+	* [r502] doc/README: Updated doxygen rule
+2004-07-20 08:34  Sandro Santilli <strk at keybit.net>
+	* [r501] doc/Doxyfile.in, source/geom/CoordinateList.cpp,
+	  source/geom/Geometry.cpp, source/headers/geos/geom.h,
+	  source/headers/geos/opDistance.h: Fixed a bug in opDistance.h.
+	  Removed doxygen tags from obsoleted CoordinateList.cpp.
+	  Got doxygen to run with no warnings.
+2004-07-19 19:37  pramsey
+	* [r500] doc/Makefile.am: Changed doxygen target to be more "make
+	  dist" friendly. (and allow autogeneration of CVS snapshot to work
+	  again.)
+2004-07-19 13:19  Sandro Santilli <strk at keybit.net>
+	* [r499] doc/Doxyfile.in, source/geom/Envelope.cpp,
+	  source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
+	  source/geom/LineString.cpp, source/headers/geos/geom.h,
+	  source/headers/geos/geomUtil.h, source/headers/geos/geomgraph.h,
+	  source/headers/geos/geomgraphindex.h,
+	  source/headers/geos/indexBintree.h,
+	  source/headers/geos/indexSweepline.h,
+	  source/headers/geos/nodingSnapround.h,
+	  source/headers/geos/opBuffer.h, source/headers/geos/opDistance.h,
+	  source/headers/geos/opLinemerge.h,
+	  source/headers/geos/opPolygonize.h,
+	  source/headers/geos/opRelate.h, source/headers/geos/opValid.h,
+	  source/headers/geos/precision.h,
+	  source/headers/geos/spatialIndex.h, source/io/WKTWriter.cpp:
+2004-07-19 10:38  Sandro Santilli <strk at keybit.net>
+	* [r498] doc, doc/.cvsignore: Added Doxyfile
+	* [r497] TODO: updated
+2004-07-19 10:37  Sandro Santilli <strk at keybit.net>
+	* [r496] doc/Makefile.am: Doxygen doc added to default build rules
+	* [r495] source/geom/DefaultCoordinateSequenceFactory.cpp:
+	  defaultCoordinateSequenceFactory made module-static (use
+	  DefaultCoordinateSequenceFactory::instance() instead)
+2004-07-19 10:35  Sandro Santilli <strk at keybit.net>
+	* [r494] source/bigtest/GeometryTestFactory.cpp,
+	  source/bigtest/TestSweepLineSpeed.cpp, source/bigtest/bigtest.h,
+	  source/headers/geos/bigtest.h: bigtest.h moved to local dir
+2004-07-19 10:34  Sandro Santilli <strk at keybit.net>
+	* [r493] source/headers/geos/geom.h: removed doxygen documentation
+	  of removed feature
+2004-07-19 10:33  Sandro Santilli <strk at keybit.net>
+	* [r492] source/headers/geos/io.h: Class documentation changed to
+	  report geos.h as WKT writer/parser header file
+2004-07-19 10:30  Sandro Santilli <strk at keybit.net>
+	* [r491] source/headers/acconfig.h,
+	  source/headers/geos/Makefile.am, source/headers/geos/acconfig.h:
+	  acconfig.h moved one directory up
+2004-07-19 10:28  Sandro Santilli <strk at keybit.net>
+	* [r490] doc/Doxyfile.in: Excluded example and test dirs from input
+	  set
+2004-07-17 10:48  Sandro Santilli <strk at keybit.net>
+	* [r489] TODO: updated
+	* [r488] doc, doc/.cvsignore: added Doxyfile (generated)
+	* [r487] source/geom/Geometry.cpp: fixed typo in documentation
+2004-07-17 10:47  Sandro Santilli <strk at keybit.net>
+	* [r486] configure.in, doc/Doxyfile, doc/Doxyfile.in: Doxygen
+	  configuration created at ./configure time, for versioning.
+2004-07-17 09:19  Sandro Santilli <strk at keybit.net>
+	* [r485] doc/example.cpp: added GEOS version report
+2004-07-17 09:18  Sandro Santilli <strk at keybit.net>
+	* [r484] source/geom/Geometry.cpp, source/headers/geos/geom.h:
+	  Added geos::version()
+2004-07-17 09:07  Sandro Santilli <strk at keybit.net>
+	* [r483] tools/geos-config.in: Added --jtsport
+2004-07-17 09:06  Sandro Santilli <strk at keybit.net>
+	* [r482] source/headers/geos/version.h.in: Added
+	  GEOS_FIRST_INTERFACE, GEOS_LAST_INTERFACE and GEOS_JTS_PORT
+2004-07-17 09:05  Sandro Santilli <strk at keybit.net>
+	* [r481] configure.in: Added JTS_PORT variable.
+	  Simplified versioning settings: comments added,
+	  major/minor/patchlevel
+	  extracted by CURRENT,AGE,REVISION.
+2004-07-16 17:02  Sandro Santilli <strk at keybit.net>
+	* [r480] TODO: updated
+2004-07-16 16:20  Sandro Santilli <strk at keybit.net>
+	* [r479] configure.in, source/geom/Makefile.am: Libtool versioning
+	  scheme adopted.
+2004-07-16 16:09  Sandro Santilli <strk at keybit.net>
+	* [r478] doc/Makefile.am: removed useless Includedir
+2004-07-16 15:57  Sandro Santilli <strk at keybit.net>
+	* [r477] source/headers/geos.h: made includes use <>
+2004-07-16 13:27  Sandro Santilli <strk at keybit.net>
+	* [r476] TODO: updated
+2004-07-16 10:28  Sandro Santilli <strk at keybit.net>
+	* [r475] source/headers/geos/util.h,
+	  source/util/GeometricShapeFactory.cpp: Dimesions object allocated
+	  on the heap
+2004-07-16 10:00  Sandro Santilli <strk at keybit.net>
+	* [r474] doc/example.cpp: Bug fixed in GeometricShapeFactory
+	  examples.
+	  Added example of GeometricShapeFactory::createArc.
+2004-07-16 09:58  Sandro Santilli <strk at keybit.net>
+	* [r473] TODO: updated
+	* [r472] doc/example.tosql: Added LINEARRING to LINESTRING
+	  conversion
+2004-07-16 09:57  Sandro Santilli <strk at keybit.net>
+	* [r471] source/geom/Makefile.am: Modified library version to 1.4.0
+2004-07-15 13:41  Sandro Santilli <strk at keybit.net>
+	* [r470] doc/example.cpp: Added createRectangle example.
+2004-07-15 13:40  Sandro Santilli <strk at keybit.net>
+	* [r469] source/util/GeometricShapeFactory.cpp: Memory leaks fixed,
+	  CoordinateSequence use made JTS - compatible.
+2004-07-14 21:21  Sandro Santilli <strk at keybit.net>
+	* [r468] TODO: updated
+2004-07-14 21:20  Sandro Santilli <strk at keybit.net>
+	* [r467] source/geom/Geometry.cpp: Added GeometricShapeFactory note
+	  on doxygen mainpage
+	* [r466] source/headers/geos.h: added geos/io.h and geos/unload.h
+2004-07-14 21:19  Sandro Santilli <strk at keybit.net>
+	* [r465] source/headers/geos/util.h,
+	  source/util/GeometricShapeFactory.cpp: GeometricShapeFactory
+	  first pass of bug fixes
+2004-07-14 21:17  Sandro Santilli <strk at keybit.net>
+	* [r464] source/geom/Makefile.am: added missing
+	  GeometricShapeFactory.cpp
+	* [r463] source/geom/Coordinate.cpp, source/headers/geos/geom.h:
+	  added inequality operator for Coordinate
+2004-07-14 21:15  Sandro Santilli <strk at keybit.net>
+	* [r462] doc/example.cpp, doc/example.tosql: Added
+	  GeometricShapeFactory example: createCircle.
+	  Added simple filter to send example output to a postgis table.
+2004-07-13 08:33  Sandro Santilli <strk at keybit.net>
+	* [r461] source/geom/GeometryFactory.cpp, source/geom/Polygon.cpp,
+	  source/index/bintree/Bintree.cpp,
+	  source/planargraph/planarGraphComponent.cpp: Added missing
+	  virtual destructor to virtual classes.
+	  Fixed implicit unsigned int -> int casts
+2004-07-12 19:16  Sandro Santilli <strk at keybit.net>
+	* [r460] source/headers/geos/geom.h: Commented out CoordinateList
+	  class definition.
+2004-07-12 15:42  Sandro Santilli <strk at keybit.net>
+	* [r459] source/geom/PrecisionModel.cpp: Fixed maximumPreciseValue
+	  scope
+2004-07-09 08:01  Sandro Santilli <strk at keybit.net>
+	* [r458] TODO: updated
+2004-07-08 19:41  Sandro Santilli <strk at keybit.net>
+	* [r457] source/examples/CoordinateListsExample.cpp,
+	  source/examples/CoordinateSequencesExample.cpp,
+	  source/examples/CustomCoordinateListExample.cpp,
+	  source/examples/CustomCoordinateListExample.h,
+	  source/examples/CustomCoordinateSequenceExample.cpp,
+	  source/examples/CustomCoordinateSequenceExample.h,
+	  source/examples/CustomPointCoordinateList.cpp,
+	  source/examples/CustomPointCoordinateSequence.cpp: renamed to
+	  reflect JTS API.
+2004-07-08 19:38  Sandro Santilli <strk at keybit.net>
+	* [r456] source/geom/CoordinateSequence.cpp,
+	  source/geom/CoordinateSequenceFactory.cpp,
+	  source/geom/DefaultCoordinateSequenceFactory.cpp,
+	  source/geom/PointCoordinateSequenceFactory.cpp: renamed from
+	  *List* equivalents
+2004-07-08 19:37  Sandro Santilli <strk at keybit.net>
+	* [r455] source/geom/PointCoordinateList.cpp: Renamed to
+	  PointCoordinateSequence.cpp
+	* [r454] source/geom/CoordinateListFactory.cpp: Renamed to
+	  CoordinateSequenceFactory.cpp
+2004-07-08 19:36  Sandro Santilli <strk at keybit.net>
+	* [r453] source/geom/BasicCoordinateList.cpp: Renamed to
+	  DefaultCoordinateSequence.cpp
+2004-07-08 19:34  Sandro Santilli <strk at keybit.net>
+	* [r452] TODO, doc/example.cpp, source/Makefile.am,
+	  source/algorithm/CGAlgorithms.cpp,
+	  source/algorithm/CentroidArea.cpp,
+	  source/algorithm/CentroidLine.cpp,
+	  source/algorithm/ConvexHull.cpp,
+	  source/algorithm/InteriorPointArea.cpp,
+	  source/algorithm/InteriorPointLine.cpp,
+	  source/algorithm/MCPointInRing.cpp,
+	  source/algorithm/MinimumDiameter.cpp,
+	  source/algorithm/NonRobustCGAlgorithms.cpp,
+	  source/algorithm/SimplePointInAreaLocator.cpp,
+	  source/examples/CPCLException.cpp,
+	  source/examples/CoordinateListsExample.cpp,
+	  source/examples/Makefile.am, source/geom/CoordinateList.cpp,
+	  source/geom/GeometryFactory.cpp, source/geom/LineSegment.cpp,
+	  source/geom/Makefile.am, source/geom/MultiLineString.cpp,
+	  source/geom/MultiPoint.cpp, source/geom/MultiPolygon.cpp,
+	  source/geom/Point.cpp, source/geom/Polygon.cpp,
+	  source/geom/util/GeometryEditor.cpp, source/geomgraph/Edge.cpp,
+	  source/geomgraph/EdgeList.cpp, source/geomgraph/EdgeRing.cpp,
+	  source/geomgraph/index/MonotoneChainEdge.cpp,
+	  source/geomgraph/index/MonotoneChainIndexer.cpp,
+	  source/geomgraph/index/SimpleEdgeSetIntersector.cpp,
+	  source/geomgraph/index/SimpleSweepLineIntersector.cpp,
+	  source/headers/geos/bigtest.h, source/headers/geos/geom.h,
+	  source/headers/geos/indexChain.h, source/headers/geos/io.h,
+	  source/headers/geos/opDistance.h,
+	  source/headers/geos/opValid.h, source/headers/geos/precision.h,
+	  source/headers/geos/util.h,
+	  source/index/chain/indexMonotoneChain.cpp, source/io/Unload.cpp,
+	  source/io/WKTReader.cpp, source/noding/MCQuadtreeNoder.cpp,
+	  source/noding/SegmentString.cpp, source/noding/SimpleNoder.cpp,
+	  source/noding/snapround/SimpleSegmentStringsSnapper.cpp,
+	  source/operation/buffer/RightmostEdgeFinder.cpp,
+	  source/operation/valid/ConnectedInteriorTester.cpp,
+	  source/operation/valid/RepeatedPointTester.cpp,
+	  source/operation/valid/SimpleNestedRingTester.cpp,
+	  source/operation/valid/SweeplineNestedRingTester.cpp,
+	  source/precision/SimpleGeometryPrecisionReducer.cpp,
+	  source/util/CoordinateArrayFiter.cpp,
+	  source/util/GeometricShapeFactory.cpp,
+	  source/util/UniqueCoordinateArrayFilter.cpp: Mirrored JTS
+	  interface of CoordinateSequence, factory and
+	  default implementations.
+	  Added DefaultCoordinateSequenceFactory::instance() function.
+2004-07-07 18:54  Sandro Santilli <strk at keybit.net>
+	* [r451] TODO: updated
+2004-07-07 10:29  Sandro Santilli <strk at keybit.net>
+	* [r450] source/algorithm/NotRepresentableException.cpp,
+	  source/headers/geos/geosAlgorithm.h, source/headers/geos/io.h,
+	  source/headers/geos/util.h: Adjusted exceptions documentation.
+2004-07-07 09:38  Sandro Santilli <strk at keybit.net>
+	* [r449] NEWS, source/geom/Geometry.cpp,
+	  source/headers/geos/geom.h, source/headers/geos/geosAlgorithm.h,
+	  source/headers/geos/io.h, source/io/WKTReader.cpp,
+	  source/io/WKTWriter.cpp, source/test/XMLTester.cpp: Dropped
+	  WKTWriter::stringOfChars (implemented by std::string).
+	  Dropped WKTWriter default constructor (internally created
+	  GeometryFactory).
+	  Updated XMLTester to respect the changes.
+	  Main documentation page made nicer.
+2004-07-07 07:52  Sandro Santilli <strk at keybit.net>
+	* [r448] TODO, source/operation/buffer/BufferSubgraph.cpp: Removed
+	  note about required speedup in BufferSubgraph.
+	  I've made tests with 'sets' and there is actually a big slow
+	  down..
+2004-07-06 17:58  Sandro Santilli <strk at keybit.net>
+	* [r447] source/geom/Geometry.cpp,
+	  source/geom/GeometryCollection.cpp, source/geom/LineString.cpp,
+	  source/geom/LinearRing.cpp, source/geom/MultiLineString.cpp,
+	  source/headers/geos/geom.h, source/headers/geos/precision.h,
+	  source/precision/SimpleGeometryPrecisionReducer.cpp: Removed
+	  deprecated Geometry constructors based on PrecisionModel and
+	  SRID specification. Removed SimpleGeometryPrecisionReducer
+	  capability
+	  of changing Geometry's factory. Reverted Geometry::factory member
+	  to be a reference to external factory.
+2004-07-05 19:40  Sandro Santilli <strk at keybit.net>
+	* [r446] source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
+	  source/headers/geos/geom.h: Added
+	  GeometryFactory::destroyGeometry(Geometry *)
+2004-07-05 15:20  Sandro Santilli <strk at keybit.net>
+	* [r445] TODO, source/geom/Geometry.cpp,
+	  source/headers/geos/geom.h: Documentation again.
+2004-07-05 14:23  Sandro Santilli <strk at keybit.net>
+	* [r444] NEWS, source/geom/CoordinateList.cpp,
+	  source/geom/GeometryFactory.cpp, source/geom/LineString.cpp,
+	  source/geom/PrecisionModel.cpp, source/headers/geos/geom.h,
+	  source/headers/geos/util.h: More documentation cleanups.
+2004-07-05 11:50  Sandro Santilli <strk at keybit.net>
+	* [r443] doc/README: initial import
+2004-07-05 10:50  Sandro Santilli <strk at keybit.net>
+	* [r442] NEWS, doc/Doxyfile, source/geom/BasicCoordinateList.cpp,
+	  source/geom/Point.cpp, source/geom/PointCoordinateList.cpp,
+	  source/geom/Polygon.cpp, source/headers/geos.h,
+	  source/headers/geos/geom.h, source/headers/geos/util.h,
+	  source/io/WKTReader.cpp: deep-dopy construction taken out of
+	  Geometry and implemented only
+	  in GeometryFactory.
+	  Deep-copy geometry construction takes care of cleaning up copies
+	  on exception.
+	  Implemented clone() method for CoordinateList
+	  Changed createMultiPoint(CoordinateList) signature to reflect
+	  copy semantic (by-ref instead of by-pointer).
+	  Cleaned up documentation.
+2004-07-03 12:54  Sandro Santilli <strk at keybit.net>
+	* [r441] source/headers/geos, source/headers/geos/.cvsignore: more
+	  entries
+2004-07-03 12:51  Sandro Santilli <strk at keybit.net>
+	* [r440] source/algorithm/NotRepresentableException.cpp,
+	  source/geom/LineString.cpp, source/geom/PrecisionModel.cpp,
+	  source/headers/geos.h, source/headers/geos/geom.h: Documentation
+	  cleanups for DoxyGen.
+2004-07-02 17:22  Sandro Santilli <strk at keybit.net>
+	* [r439] doc/Doxyfile, doc/Makefile.am, doc/geosDoxygen.conf:
+	  Doxygen configuration file renamed.
+2004-07-02 14:27  Sandro Santilli <strk at keybit.net>
+	* [r438] source/geom/GeometryFactory.cpp, source/geom/Point.cpp,
+	  source/headers/geos/geom.h: Added deep-copy / take-ownerhship for
+	  Point type.
+2004-07-02 13:28  Sandro Santilli <strk at keybit.net>
+	* [r437] ChangeLog, README, configure.in, doc/Makefile.am,
+	  doc/example.cpp, source/algorithm/CGAlgorithms.cpp,
+	  source/algorithm/CentroidPoint.cpp,
+	  source/algorithm/HCoordinate.cpp,
+	  source/algorithm/InteriorPointPoint.cpp,
+	  source/algorithm/NotRepresentableException.cpp,
+	  source/algorithm/PointLocator.cpp,
+	  source/algorithm/SimplePointInRing.cpp,
+	  source/geom/BasicCoordinateList.cpp, source/geom/Coordinate.cpp,
+	  source/geom/CoordinateListFactory.cpp, source/geom/Dimension.cpp,
+	  source/geom/Envelope.cpp, source/geom/Geometry.cpp,
+	  source/geom/GeometryCollectionIterator.cpp,
+	  source/geom/GeometryComponentFilter.cpp,
+	  source/geom/LineString.cpp, source/geom/LinearRing.cpp,
+	  source/geom/Location.cpp, source/geom/MultiLineString.cpp,
+	  source/geom/Polygon.cpp, source/geom/PrecisionModel.cpp,
+	  source/geom/TopologyException.cpp, source/geom/Triangle.cpp,
+	  source/geom/util/LinearComponentExtracter.cpp,
+	  source/geom/util/PointExtracter.cpp,
+	  source/geom/util/PolygonExtracter.cpp,
+	  source/geomgraph/Depth.cpp, source/geomgraph/DirectedEdge.cpp,
+	  source/geomgraph/DirectedEdgeStar.cpp, source/geomgraph/Edge.cpp,
+	  source/geomgraph/EdgeEnd.cpp, source/geomgraph/EdgeEndStar.cpp,
+	  source/geomgraph/EdgeIntersection.cpp,
+	  source/geomgraph/EdgeNodingValidator.cpp,
+	  source/geomgraph/GraphComponent.cpp, source/geomgraph/Label.cpp,
+	  source/geomgraph/Node.cpp, source/geomgraph/NodeFactory.cpp,
+	  source/geomgraph/Position.cpp, source/geomgraph/Quadrant.cpp,
+	  source/geomgraph/TopologyLocation.cpp,
+	  source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
+	  source/geomgraph/index/SweepLineEvent.cpp,
+	  source/geomgraph/index/SweepLineSegment.cpp,
+	  source/index/bintree/BinTreeInterval.cpp,
+	  source/index/bintree/BinTreeNode.cpp,
+	  source/index/bintree/Bintree.cpp, source/index/bintree/Key.cpp,
+	  source/index/bintree/NodeBase.cpp, source/index/bintree/Root.cpp,
+	  source/index/quadtree/IntervalSize.cpp,
+	  source/index/strtree/Interval.cpp,
+	  source/index/sweepline/SweepLineInterval.cpp,
+	  source/index/sweepline/indexSweepLineEvent.cpp,
+	  source/io/ParseException.cpp, source/io/StringTokenizer.cpp,
+	  source/io/Unload.cpp, source/io/WKTReader.cpp,
+	  source/io/WKTWriter.cpp, source/io/Writer.cpp,
+	  source/io/markup/MarkupSTL.cpp, source/noding/IteratedNoder.cpp,
+	  source/noding/snapround/SnapRounder.cpp,
+	  source/operation/GeometryGraphOperation.cpp,
+	  source/operation/IsSimpleOp.cpp,
+	  source/operation/buffer/BufferSubgraph.cpp,
+	  source/operation/buffer/OffsetCurveBuilder.cpp,
+	  source/operation/distance/ConnectedElementLocationFilter.cpp,
+	  source/operation/distance/ConnectedElementPointFilter.cpp,
+	  source/operation/distance/GeometryLocation.cpp,
+	  source/operation/linemerge/LineMergeDirectedEdge.cpp,
+	  source/operation/linemerge/LineMergeEdge.cpp,
+	  source/operation/linemerge/LineMerger.cpp,
+	  source/operation/overlay/EdgeSetNoder.cpp,
+	  source/operation/overlay/LineBuilder.cpp,
+	  source/operation/overlay/OverlayNodeFactory.cpp,
+	  source/operation/overlay/PointBuilder.cpp,
+	  source/operation/relate/EdgeEndBuilder.cpp,
+	  source/operation/relate/EdgeEndBundle.cpp,
+	  source/operation/relate/EdgeEndBundleStar.cpp,
+	  source/operation/relate/RelateNode.cpp,
+	  source/operation/relate/RelateNodeFactory.cpp,
+	  source/operation/relate/RelateNodeGraph.cpp,
+	  source/operation/valid/ConsistentAreaTester.cpp,
+	  source/operation/valid/TopologyValidationError.cpp,
+	  source/planargraph/planarPlanarGraph.cpp,
+	  source/precision/CommonBits.cpp,
+	  source/precision/CommonBitsOp.cpp,
+	  source/precision/CommonBitsRemover.cpp,
+	  source/precision/EnhancedPrecisionOp.cpp,
+	  source/test/CTS.cpp, source/test/SimpleWKTTester.cpp,
+	  source/test/XMLTester.cpp, source/util/Assert.cpp,
+	  source/util/AssertionFailedException.cpp,
+	  source/util/GEOSException.cpp,
+	  source/util/IllegalArgumentException.cpp,
+	  source/util/UniqueCoordinateArrayFilter.cpp,
+	  source/util/UnsupportedOperationException.cpp: Fixed all #include
+	  lines to reflect headers layout change.
+	  Added client application build tips in README.
+2004-07-02 13:21  Sandro Santilli <strk at keybit.net>
+	* [r436] source/headers/geos_version.h.in: renamed to
+	  geos/version.h.in
+2004-07-02 13:20  Sandro Santilli <strk at keybit.net>
+	* [r435] source/headers, source/headers/.cvsignore,
+	  source/headers/Makefile.am, source/headers/acconfig.h,
+	  source/headers/bigtest.h, source/headers/geom.h,
+	  source/headers/geomUtil.h, source/headers/geomgraph.h,
+	  source/headers/geomgraphindex.h, source/headers/geos,
+	  source/headers/geos.h, source/headers/geos/.cvsignore,
+	  source/headers/geos/Makefile.am, source/headers/geos/acconfig.h,
+	  source/headers/geos/bigtest.h, source/headers/geos/config.h,
+	  source/headers/geos/geom.h, source/headers/geos/geomUtil.h,
+	  source/headers/geos/geomgraph.h,
+	  source/headers/geos/indexSweepline.h, source/headers/geos/io.h,
+	  source/headers/geos/spatialIndex.h, source/headers/geos/unload.h,
+	  source/headers/geos/util.h, source/headers/geos/version.h.in,
+	  source/headers/geosAlgorithm.h, source/headers/indexBintree.h,
+	  source/headers/indexChain.h, source/headers/indexQuadtree.h,
+	  source/headers/indexStrtree.h, source/headers/indexSweepline.h,
+	  source/headers/io.h, source/headers/noding.h,
+	  source/headers/nodingSnapround.h, source/headers/opBuffer.h,
+	  source/headers/opDistance.h, source/headers/opLinemerge.h,
+	  source/headers/opOverlay.h, source/headers/opPolygonize.h,
+	  source/headers/opRelate.h, source/headers/opValid.h,
+	  source/headers/operation.h, source/headers/planargraph.h,
+	  source/headers/platform.h.in, source/headers/precision.h,
+	  source/headers/spatialIndex.h, source/headers/unload.h,
+	  source/headers/util.h: Header files moved under geos/ dir.
+2004-07-01 17:34  Sandro Santilli <strk at keybit.net>
+	* [r434] source/geom/Geometry.cpp: GeometryFactory argument in
+	  Geometry constructor reverted
+	  to its copy-and-destroy semantic.
+2004-07-01 17:07  Sandro Santilli <strk at keybit.net>
+	* [r433] doc, doc/.cvsignore, doc/Makefile.am: Added doxygen_docs
+	  generation rule
+2004-07-01 16:49  Sandro Santilli <strk at keybit.net>
+	* [r432] doc/geosDoxygen.conf: re-generated with doxygen 1.2.15
+2004-07-01 15:47  cvs
+	* [r431] doc/geosDoxygen.conf: Added doxygen file for better doco
+	  generation.
+2004-07-01 14:12  Sandro Santilli <strk at keybit.net>
+	* [r430] ChangeLog, NEWS, TODO, doc/example.cpp,
+	  source/algorithm/InteriorPointArea.cpp, source/geom/Geometry.cpp,
+	  source/geomgraph/EdgeRing.cpp, source/headers/geom.h,
+	  source/headers/opBuffer.h, source/headers/opOverlay.h,
+	  source/io/WKTReader.cpp, source/noding/SegmentNodeList.cpp,
+	  source/operation/buffer/BufferBuilder.cpp,
+	  source/operation/buffer/OffsetCurveSetBuilder.cpp,
+	  source/util/GeometricShapeFactory.cpp: Geometry constructors come
+	  now in two flavors:
+	  - deep-copy args (pass-by-reference)
+	  - take-ownership of args (pass-by-pointer)
+	  Same functionality is available through GeometryFactory,
+	  including buildGeometry().
+2004-06-30 20:59  Sandro Santilli <strk at keybit.net>
+	* [r429] source/geom/Geometry.cpp,
+	  source/headers/geomgraph.h, source/headers/geosAlgorithm.h,
+	  source/operation/overlay/MaximalEdgeRing.cpp,
+	  source/operation/overlay/MinimalEdgeRing.cpp,
+	  source/operation/overlay/PolygonBuilder.cpp: Removed
+	  GeoemtryFactory copy from geometry constructors.
+	  Enforced const-correctness on GeometryFactory arguments.
+2004-06-28 21:58  Sandro Santilli <strk at keybit.net>
+	* [r428] source/geom/Polygon.cpp: Constructors speedup.
+2004-06-28 21:11  Sandro Santilli <strk at keybit.net>
+	* [r427] source/geom/GeometryCollection.cpp,
+	  source/geom/MultiLineString.cpp, source/geom/MultiPoint.cpp,
+	  source/geom/MultiPolygon.cpp, source/geom/Point.cpp,
+	  source/geom/Polygon.cpp, source/headers/geom.h: Moved
+	  getGeometryTypeId() definitions from geom.h to each geometry
+	  module.
+	  Added holes argument check in Polygon.cpp.
+2004-06-25 14:26  Sandro Santilli <strk at keybit.net>
+	* [r426] tools/geos-config.in: fixed --includes
+2004-06-22 16:57  Sandro Santilli <strk at keybit.net>
+	* [r425] NEWS: Written down some news
+2004-06-22 16:56  Sandro Santilli <strk at keybit.net>
+	* [r424] source/headers/Makefile.am, source/headers/geos.h: Added
+	  geos.h file.
+2004-06-21 22:14  Sandro Santilli <strk at keybit.net>
+	* [r423] source/headers, source/headers/.cvsignore: added
+	  geos_version.h
+2004-06-21 22:13  Sandro Santilli <strk at keybit.net>
+	* [r422] TODO: updated
+	* [r421] configure.in, source/headers/Makefile.am,
+	  source/headers/geos_version.h.in: Added VERSION defines
+2004-06-16 13:13  Sandro Santilli <strk at keybit.net>
+	* [r420] TODO, source/geom/BasicCoordinateList.cpp,
+	  source/geom/GeometryFactory.cpp, source/geom/MultiPolygon.cpp,
+	  source/geomgraph/Edge.cpp, source/headers/noding.h,
+	  source/noding/nodingSegmentIntersector.cpp: Changed interface of
+	  SegmentString, now copying CoordinateList argument.
+	  Fixed memory leaks associated with this and MultiGeometry
+	  constructors.
+	  Other associated fixes.
+2004-06-15 21:35  Sandro Santilli <strk at keybit.net>
+	* [r419] source/geom/GeometryFactory.cpp: fixed buildGeometry to
+	  always return a newly allocated geometry
+2004-06-15 20:42  Sandro Santilli <strk at keybit.net>
+	* [r418] doc/example.cpp, source/geom/LineString.cpp,
+	  source/geom/MultiPolygon.cpp, source/geom/Polygon.cpp: updated to
+	  respect deep-copy GeometryCollection interface
+2004-06-15 20:30  Sandro Santilli <strk at keybit.net>
+	* [r417] source/io/WKTReader.cpp: fixed a typo
+2004-06-15 20:20  Sandro Santilli <strk at keybit.net>
+	* [r416] source/geom/util/GeometryEditor.cpp,
+	  source/operation/overlay/OverlayOp.cpp: updated to respect
+	  deep-copy GeometryCollection interface
+2004-06-15 20:07  Sandro Santilli <strk at keybit.net>
+	* [r415] source/geom/GeometryCollection.cpp,
+	  source/geom/GeometryFactory.cpp, source/headers/geom.h:
+	  GeometryCollections constructors make a deep copy of Geometry
+	  vector argument.
+2004-06-15 20:01  Sandro Santilli <strk at keybit.net>
+	* [r414] source/operation/buffer/BufferBuilder.cpp: Empty geometry
+	  creation call made using NULL instead of newly created empty
+	  vector (will be faster)
+2004-06-15 19:24  Sandro Santilli <strk at keybit.net>
+	* [r413] tools/geos-config.in: Fixed a bug preventing geos-config
+	  from giving correct version info
+2004-06-15 07:40  Sandro Santilli <strk at keybit.net>
+	* [r412] source/noding/SegmentNode.cpp,
+	  source/planargraph/planarDirectedEdge.cpp: Added missing
+	  <stdio.h> include
+	* [r411] TODO: Updated
+2004-05-28 18:16  ybychkov
+	* [r410] source/geom/PrecisionModel.cpp: Changed rounding method to
+	  make compilable with VC++
+2004-05-27 12:09  Sandro Santilli <strk at keybit.net>
+	* [r409] source/test/testLeaksBig.xml: added one buffer test
+2004-05-27 10:27  Sandro Santilli <strk at keybit.net>
+	* [r408] source/noding/SegmentNodeList.cpp,
+	  source/noding/SegmentString.cpp: Memory leaks fixed.
+2004-05-27 10:26  Sandro Santilli <strk at keybit.net>
+	* [r407] source/noding/nodingSegmentIntersector.cpp: set (useless?)
+	  recordIsolated member in constructor
+2004-05-27 09:53  Sandro Santilli <strk at keybit.net>
+	* [r406] source/headers/indexChain.h:
+	  MonotoneChainOverlapAction::overlap(*) funx made virtual
+	  as they are supposed to be.
+2004-05-27 08:40  Sandro Santilli <strk at keybit.net>
+	* [r405] source/test/XMLTester.cpp: Fixed a memleak in buffer test.
+2004-05-27 08:37  Sandro Santilli <strk at keybit.net>
+	* [r404] source/headers/opBuffer.h,
+	  source/operation/buffer/OffsetCurveBuilder.cpp: Fixed a bug
+	  preventing OffsetCurveBuilder point list from being reset.
+2004-05-26 19:48  Sandro Santilli <strk at keybit.net>
+	* [r403] source/operation/buffer/OffsetCurveBuilder.cpp,
+	  source/operation/buffer/OffsetCurveSetBuilder.cpp: Changed abs()
+	  to fabs() when working with doubles.
+	  Used dynamic_cast<> instead of typeid() when JTS uses instanceof.
+2004-05-26 13:12  Sandro Santilli <strk at keybit.net>
+	* [r402] source/operation/buffer/BufferBuilder.cpp: Removed
+	  try/catch block from ::buildSubgraphs
+2004-05-26 09:50  Sandro Santilli <strk at keybit.net>
+	* [r401] source/headers/geomgraph.h: Added comments about
+	  OverlayNodeFactory() ownership in NodeMap and PlanarGraph
+	  constuctors
+2004-05-26 09:49  Sandro Santilli <strk at keybit.net>
+	* [r400] source/headers/opBuffer.h,
+	  source/operation/buffer/BufferBuilder.cpp: PlanarGraph made local
+	  to ::buffer instead of Class private.
+2004-05-21 14:17  Sandro Santilli <strk at keybit.net>
+	* [r399] TODO: updated
+2004-05-21 13:58  Sandro Santilli <strk at keybit.net>
+	* [r398] source/geom/Geometry.cpp: ::intersection missed to
+	  invalidate geometryCollection inputs
+2004-05-21 13:55  Sandro Santilli <strk at keybit.net>
+	* [r397] TODO: updated
+2004-05-21 13:39  Sandro Santilli <strk at keybit.net>
+	* [r396] source/geom/PrecisionModel.cpp: ::makePrecise make use of
+	  nearbyint() now, to be compatible with JTS
+2004-05-21 13:37  Sandro Santilli <strk at keybit.net>
+	* [r395] source/test/testLeaksBig.xml: first import
+2004-05-20 09:14  Sandro Santilli <strk at keybit.net>
+	* [r394] TODO: updated
+2004-05-19 19:39  ybychkov
+	* [r393] source/geom/PrecisionModel.cpp: Changed rounding method to
+2004-05-19 13:40  Sandro Santilli <strk at keybit.net>
+	* [r392] source/operation/buffer/OffsetCurveBuilder.cpp: Fixed bug
+	  in ::addCircle
+2004-05-19 13:18  Sandro Santilli <strk at keybit.net>
+	* [r391] source/geom/BasicCoordinateList.cpp,
+	  source/geom/PointCoordinateList.cpp, source/headers/geom.h: made
+	  CoordinateList::toString() a const member function
+2004-05-19 13:01  Sandro Santilli <strk at keybit.net>
+	* [r390] source/operation/buffer/BufferOp.cpp: avoided assignment
+	  operator calls for BufferBuilder
+2004-05-19 12:50  Sandro Santilli <strk at keybit.net>
+	* [r389] source/operation/buffer/BufferSubgraph.cpp: Removed all
+	  try/catch blocks transforming stack allocated-vectors to
+	  auto-heap-allocations
+2004-05-19 09:57  ybychkov
+	* [r388] source/operation/buffer/OffsetCurveSetBuilder.cpp: Bugfix
+	  in OffsetCurveSetBuilder::addPolygon (JTS 1.4.1)
+2004-05-18 13:49  Sandro Santilli <strk at keybit.net>
+	* [r387] source/test/XMLTester.cpp: Output made more neat (geometry
+	  B is not printed if not existent).
+	  Added support for buffer tests.
+2004-05-18 13:15  Sandro Santilli <strk at keybit.net>
+	* [r386] source/geom/CoordinateList.cpp: made ::scroll handle
+	  already scrolled vect and more readable
+2004-05-18 00:02  ybychkov
+	* [r385] source/headers/opValid.h,
+	  IsValidOp::checkShellNotNested() bugfix from JTS 1.4.1 (not
+	  released yet) has been added.
+2004-05-17 21:14  ybychkov
+	* [r384] source/geom/GeometryCollection.cpp, source/headers/geom.h:
+	  JavaDoc updated
+2004-05-17 21:09  ybychkov
+	* [r383] source/geom/BasicCoordinateList.cpp,
+	  source/geom/PointCoordinateList.cpp: toString() performance
+	  enhancement
+2004-05-17 21:03  ybychkov
+	* [r382] source/geom/CoordinateList.cpp, source/headers/geom.h:
+	  JavaDoc updated
+2004-05-17 12:54  Sandro Santilli <strk at keybit.net>
+	* [r381] source/io/markup/MarkupSTL.cpp: Added tab in list of blank
+	  chars
+2004-05-17 12:53  Sandro Santilli <strk at keybit.net>
+	* [r380] source/test/XMLTester.cpp: Expected result string trimmed
+	  for blanks
+2004-05-17 12:37  Sandro Santilli <strk at keybit.net>
+	* [r379] source/io/StringTokenizer.cpp: Added carriage returns and
+	  tabs in set of blanks chars
+2004-05-17 12:36  Sandro Santilli <strk at keybit.net>
+	* [r378] source/io/ParseException.cpp: ParseException message made
+	  more readable
+2004-05-17 10:45  Sandro Santilli <strk at keybit.net>
+	* [r377] source/geom/PrecisionModel.cpp: Fixed bogus FIXED
+	  coordinate rounding
+2004-05-17 08:34  Sandro Santilli <strk at keybit.net>
+	* [r376] source/operation/overlay/OverlayOp.cpp: reduced stack
+	  allocations, try/catch blocks in ::overlayOp
+2004-05-17 07:42  Sandro Santilli <strk at keybit.net>
+	* [r375] source/algorithm/CentroidArea.cpp: CentroidArea::add(const
+	  Geometry *geom) uses dynamic_cast
+2004-05-17 07:23  Sandro Santilli <strk at keybit.net>
+	* [r374] source/geom/Geometry.cpp: ::getCeontroid(): reduced
+	  dynamic allocations, added missing check for isEmpty
+2004-05-14 14:47  Sandro Santilli <strk at keybit.net>
+	* [r373]
+	  source/operation/distance/ConnectedElementLocationFilter.cpp:
+	  Added LinearRing support
+2004-05-14 14:45  Sandro Santilli <strk at keybit.net>
+	* [r372] source/headers/geomUtil.h: Fixed bogus inheritance of
+	  LinearComponentExtracter
+2004-05-14 13:42  Sandro Santilli <strk at keybit.net>
+	* [r371] source/geom/LineSegment.cpp,
+	  source/geom/util/PolygonExtracter.cpp, source/headers/geomUtil.h,
+	  source/operation/distance/DistanceOp.cpp: DistanceOp bug removed,
+	  cascading errors fixed.
+2004-05-14 12:14  Sandro Santilli <strk at keybit.net>
+	* [r370] source/geom/Geometry.cpp, source/headers/geom.h: const
+	  correctness
+2004-05-14 12:10  Sandro Santilli <strk at keybit.net>
+	* [r369] source/io/WKTReader.cpp: avoided leaks on malformed
+	  LinearRing
+2004-05-14 09:20  Sandro Santilli <strk at keybit.net>
+	* [r368] source/geom/util/LinearComponentExtracter.cpp,
+	  source/geom/util/PolygonExtracter.cpp: Mem leaks fixed
+2004-05-14 07:19  Sandro Santilli <strk at keybit.net>
+	* [r367] source/test/XMLTester.cpp: Changed the algorythm for
+	  finding precisionModel type (current way did
+	  not work): now if you specify a scale precisionModel will be
+	  FIXED,
+	  otherwise it will be FLOATING.
+2004-05-07 14:15  Sandro Santilli <strk at keybit.net>
+	* [r366] source/io/StringTokenizer.cpp: fixed peekNextToken to
+	  avoid incrementing string pointer
+2004-05-07 14:13  Sandro Santilli <strk at keybit.net>
+	* [r365] source/index/bintree/Bintree.cpp: Fixed segfault in
+	  ::insert
+2004-05-07 14:12  Sandro Santilli <strk at keybit.net>
+	* [r364] source/algorithm/InteriorPointArea.cpp: Fixed segfault in
+	  destructor
+2004-05-07 13:23  Sandro Santilli <strk at keybit.net>
+	* [r363] source/io/WKTReader.cpp, source/test/XMLTester.cpp: Memory
+	  leaks fixed.
+2004-05-07 13:04  Sandro Santilli <strk at keybit.net>
+	* [r362] source/geom/MultiLineString.cpp: leak removed in
+	  MultiLineString::getBoundary()
+2004-05-07 09:05  Sandro Santilli <strk at keybit.net>
+	* [r361] source/geom/Geometry.cpp,
+	  source/geom/MultiPolygon.cpp, source/headers/geom.h: Some const
+	  correctness added. Fixed bug in GeometryFactory::createMultiPoint
+	  to handle NULL CoordinateList.
+2004-05-07 07:57  Sandro Santilli <strk at keybit.net>
+	* [r360] source/geom/Makefile.am, source/headers/noding.h,
+	  source/headers/opBuffer.h, source/noding/SegmentString.cpp,
+	  source/operation/buffer/OffsetCurveSetBuilder.cpp: Added missing
+	  EdgeNodingValidator to build scripts.
+	  Changed SegmentString constructor back to its original form
+	  (takes const void *), implemented local tracking of "contexts"
+	  in caller objects for proper destruction.
+2004-05-06 16:30  Sandro Santilli <strk at keybit.net>
+	* [r359] source/headers/indexBintree.h,
+	  source/headers/indexQuadtree.h, source/index/bintree/Bintree.cpp,
+	  source/index/quadtree/Quadtree.cpp: Kept track of newly allocated
+	  objects by ensureExtent for Bintree and Quadtree,
+	  deleted at destruction time. doc/example.cpp runs with no leaks.
+2004-05-06 15:54  Sandro Santilli <strk at keybit.net>
+	* [r358] source/headers/noding.h,
+	  source/noding/SegmentNodeList.cpp,
+	  SegmentNodeList keeps track of created splitEdges for later
+	  destruction.
+	  SegmentString constructor copies given Label.
+	  Buffer operation does no more leaks for doc/example.cpp
+2004-05-06 15:00  Sandro Santilli <strk at keybit.net>
+	* [r357] source/headers/indexStrtree.h,
+	  source/index/strtree/AbstractSTRtree.cpp,
+	  source/index/strtree/SIRtree.cpp,
+	  source/index/strtree/STRtree.cpp: Boundable destructor made
+	  virtual.
+	  Added vector <AbstractNode *> *nodes member in AbstractSTRTree,
+	  used to keep track of created node to cleanly delete them at
+	  destruction time.
+2004-05-06 13:58  Sandro Santilli <strk at keybit.net>
+	* [r356] source/index/strtree/STRtree.cpp: leak removed from
+	  createParentBoundablesFromVerticalSlices
+2004-05-06 08:59  Sandro Santilli <strk at keybit.net>
+	* [r355] source/index/strtree/AbstractSTRtree.cpp: memory leak
+	  fixed
+2004-05-05 17:42  Sandro Santilli <strk at keybit.net>
+	* [r354] source/headers/indexStrtree.h,
+	  source/index/strtree/STRtree.cpp: AbstractNode destructor made
+	  virtual. AbstractNode::bounds made protected.
+	  SIRAbstractNode and STRAbstractNode destructors added to get rid
+	  of
+	  AbstractNode::bounds in the right way (is a void * casted to
+	  appropriate
+	  Class in the subClasses).
+2004-05-05 16:57  Sandro Santilli <strk at keybit.net>
+	* [r353] source/headers/opBuffer.h,
+	  source/operation/buffer/BufferBuilder.cpp: Rewritten static cga
+	  allocation to avoid copy constructor calls.
+2004-05-05 16:51  Sandro Santilli <strk at keybit.net>
+	* [r352] source/geom/Geometry.cpp: avoided copy constructor in
+	  Geometry::geometryChangedFilter initializzazion
+2004-05-05 16:39  Sandro Santilli <strk at keybit.net>
+	* [r351] source/noding/MCQuadtreeNoder.cpp: reduced explicit local
+	  objects allocation
+2004-05-05 16:36  Sandro Santilli <strk at keybit.net>
+	* [r350] source/operation/buffer/BufferBuilder.cpp: Avoid use of
+	  copy c'tors on local objects initializzation
+2004-05-05 15:51  Sandro Santilli <strk at keybit.net>
+	* [r349] source/noding/MCQuadtreeNoder.cpp: Fixed big leak in
+	  intersectChains()
+2004-05-05 13:08  Sandro Santilli <strk at keybit.net>
+	* [r348] source/algorithm/MinimumDiameter.cpp,
+	  source/operation/buffer/OffsetCurveSetBuilder.cpp: Leaks fixed,
+	  explicit allocations/deallocations reduced.
+2004-05-05 12:29  Sandro Santilli <strk at keybit.net>
+	* [r347] source/operation/buffer/SubgraphDepthLocater.cpp: memleak
+	  fixed in ::getDepth
+2004-05-05 12:20  Sandro Santilli <strk at keybit.net>
+	* [r346] source/geom/util/GeometryEditor.cpp: Memory leak plugged
+	  in editGeometryCollection
+2004-05-05 10:54  Sandro Santilli <strk at keybit.net>
+	* [r345] source/geom/Geometry.cpp, source/headers/geom.h,
+	  source/headers/opBuffer.h, source/io/Unload.cpp,
+	  source/operation/buffer/BufferBuilder.cpp: Removed some private
+	  static heap explicit allocation, less cleanup done by
+	  the unloader.
+2004-05-05 10:44  Sandro Santilli <strk at keybit.net>
+	* [r344] TODO: updated
+2004-05-05 10:22  Sandro Santilli <strk at keybit.net>
+	* [r343] source/operation/buffer/BufferOp.cpp: Removed dynamic
+	  allocations.
+2004-05-05 10:03  Sandro Santilli <strk at keybit.net>
+	* [r342] source/operation/buffer/BufferOp.cpp: Reduced dynamic
+	  allocations in bufferOriginalPrecision and bufferFixedPrecision.
+2004-05-03 22:56  Sandro Santilli <strk at keybit.net>
+	* [r341] source/geomgraph/EdgeList.cpp, source/headers/noding.h,
+	  source/noding/IteratedNoder.cpp,
+	  source/operation/buffer/SubgraphDepthLocater.cpp: leaks fixed,
+	  exception specification omitted.
+2004-05-03 20:49  Sandro Santilli <strk at keybit.net>
+	* [r340] source/geom/util/LinearComponentExtracter.cpp,
+	  source/noding/SegmentNodeList.cpp: Some more leaks fixed
+2004-05-03 17:15  Sandro Santilli <strk at keybit.net>
+	* [r339] source/geom/util/GeometryEditor.cpp,
+	  source/headers/precision.h, source/index/strtree/STRtree.cpp,
+	  source/precision/SimpleGeometryPrecisionReducer.cpp: leaks on
+	  exception fixed.
+2004-05-03 16:29  Sandro Santilli <strk at keybit.net>
+	* [r338] source/headers/indexStrtree.h,
+	  source/index/strtree/STRtree.cpp: Added sortBoundables(const
+	  vector<Boundable *>) pure virtual in AbstractSTRtree,
+	  implemented in SIRtree and STRtree. Comparator funx made static
+	  in STRtree.cpp
+	  and SIRtree.cpp.
+2004-05-03 13:17  Sandro Santilli <strk at keybit.net>
+	* [r337] source/headers/indexStrtree.h,
+	  source/index/strtree/AbstractSTRtree.cpp: Fixed comparator
+	  function to express StrictWeakOrdering.
+2004-05-03 12:09  Sandro Santilli <strk at keybit.net>
+	* [r336] source/noding/Noder.cpp, source/noding/SegmentNode.cpp,
+	  source/planargraph/planarNodeMap.cpp: newline added at end of
+	  file
+2004-05-03 10:43  Sandro Santilli <strk at keybit.net>
+	* [r335] source/geomgraph/DirectedEdgeStar.cpp,
+	  source/geomgraph/PlanarGraph.cpp, source/headers/geomgraph.h,
+	  source/operation/overlay/OverlayOp.cpp,
+	  source/planargraph/planarDirectedEdge.cpp: Exception
+	  specification considered harmful - left as comment.
+2004-04-30 09:15  Sandro Santilli <strk at keybit.net>
+	* [r334] source/geom/Geometry.cpp, source/headers/noding.h,
+	  source/headers/opBuffer.h, source/noding/IteratedNoder.cpp,
+	  source/operation/buffer/BufferBuilder.cpp: Enlarged exception
+	  specifications to allow for AssertionFailedException.
+	  Added missing initializers.
+2004-04-28 14:58  Sandro Santilli <strk at keybit.net>
+	* [r333] source/index/strtree/AbstractSTRtree.cpp: Made
+	  AbstractSTRtree::query use dynamic_cast<> to simulate java's
+	  instanceof. Previous typeid(*) use missed to catch an
+	  STRAbstractNode
+	  as a class derived from AbstractNode. Still have to check if this
+	  is the correct semantic with Martin, but at least lots of
+	  SIGABORT
+	  are no more raised.
+2004-04-26 22:00  pramsey
+	* [r332] configure.in: Bump version number to 1.4 to indicate new
+	  changes.
+2004-04-26 12:37  Sandro Santilli <strk at keybit.net>
+	* [r331] source/index/strtree/AbstractSTRtree.cpp,
+	  source/index/strtree/STRtree.cpp: Some leaks fixed.
+2004-04-23 00:02  Sandro Santilli <strk at keybit.net>
+	* [r330] source/headers/noding.h, source/headers/opBuffer.h,
+	  source/operation/buffer/BufferOp.cpp: const-correctness changes
+2004-04-21 14:14  Sandro Santilli <strk at keybit.net>
+	* [r329] source/geomgraph/DirectedEdgeStar.cpp: Fixed bug in
+	  computeDepths
+2004-04-20 13:24  Sandro Santilli <strk at keybit.net>
+	* [r328] source/algorithm/ConvexHull.cpp,
+	  source/algorithm/MinimumDiameter.cpp, source/geom/LineString.cpp,
+	  source/geom/LinearRing.cpp, source/geom/Polygon.cpp,
+	  source/operation/overlay/OverlayOp.cpp: More leaks removed.
+2004-04-20 12:47  Sandro Santilli <strk at keybit.net>
+	* [r327] source/algorithm/MinimumDiameter.cpp,
+	  source/headers/geosAlgorithm.h: MinimumDiameter leaks plugged.
+2004-04-20 10:58  Sandro Santilli <strk at keybit.net>
+	* [r326] source/headers/opBuffer.h,
+	  source/operation/buffer/OffsetCurveSetBuilder.cpp: More memory
+	  leaks removed.
+2004-04-20 10:14  Sandro Santilli <strk at keybit.net>
+	* [r325] source/algorithm/MinimumDiameter.cpp,
+	  source/geom/Geometry.cpp, source/geom/util/GeometryEditor.cpp,
+	  source/precision/SimpleGeometryPrecisionReducer.cpp: Memory leaks
+	  removed.
+2004-04-20 08:52  Sandro Santilli <strk at keybit.net>
+	* [r324] source/geom/GeometryCollection.cpp,
+	  source/geom/Polygon.cpp, source/geom/Triangle.cpp,
+	  source/geom/util/GeometryEditor.cpp, source/headers/geom.h,
+	  source/headers/geomUtil.h, source/headers/precision.h,
+	  GeometryFactory and Geometry const correctness.
+	  Memory leaks removed from SimpleGeometryPrecisionReducer
+	  and GeometryFactory.
+2004-04-19 16:14  Sandro Santilli <strk at keybit.net>
+	* [r323] source/headers/noding.h, source/noding/IteratedNoder.cpp,
+	  source/operation/buffer/OffsetCurveSetBuilder.cpp: Some memory
+	  leaks plugged in noding algorithms.
+2004-04-19 15:14  Sandro Santilli <strk at keybit.net>
+	* [r322] source/geomgraph/PlanarGraph.cpp,
+	  source/headers/indexQuadtree.h, source/headers/opBuffer.h,
+	  source/index/quadtree/Quadtree.cpp,
+	  virtual destructor in SpatialIndex class.
+	  Memory leaks fixes. Const and throw specifications added.
+2004-04-19 12:51  Sandro Santilli <strk at keybit.net>
+	* [r321] source/headers/noding.h, source/headers/opBuffer.h,
+	  source/operation/buffer/BufferOp.cpp: Memory leaks fixes. Throw
+	  specifications added.
+2004-04-16 14:12  Sandro Santilli <strk at keybit.net>
+	* [r320] source/geom/Point.cpp: Memory leak fix in copy constructor
+2004-04-16 14:09  Sandro Santilli <strk at keybit.net>
+	* [r319] source/operation/buffer/BufferOp.cpp: Leaks fixes
+2004-04-16 13:03  Sandro Santilli <strk at keybit.net>
+	* [r318] source/operation/buffer/OffsetCurveBuilder.cpp: More leaks
+	  fixed
+2004-04-16 12:48  Sandro Santilli <strk at keybit.net>
+	* [r317] source/noding/IteratedNoder.cpp,
+	  source/operation/buffer/OffsetCurveBuilder.cpp: Leak fixes.
+2004-04-16 11:04  Sandro Santilli <strk at keybit.net>
+	* [r316] source/operation/buffer/BufferOp.cpp: Memory leaks plugged
+	  on exception thrown
+2004-04-16 10:00  Sandro Santilli <strk at keybit.net>
+	* [r315] source/operation/buffer/BufferOp.cpp: Memory leak fixed.
+2004-04-16 09:01  Sandro Santilli <strk at keybit.net>
+	* [r314] source/algorithm/CGAlgorithms.cpp: Removed memory leak in
+	  CGAlgorithms::isOnline
+2004-04-16 08:52  Sandro Santilli <strk at keybit.net>
+	* [r313] source/headers/planargraph.h, source/io/Unload.cpp:
+	  Unload::Release final delete (static heap allocations should be
+	  gone now)
+2004-04-16 08:35  Sandro Santilli <strk at keybit.net>
+	* [r312] source/geom/GeometryFactory.cpp, source/geom/Point.cpp,
+	  source/headers/geom.h: Memory leaks fixed and const correctness
+	  applied for Point class.
+2004-04-16 07:42  Sandro Santilli <strk at keybit.net>
+	* [r311] source/geom/PrecisionModel.cpp, source/headers/geom.h,
+	  source/io/Unload.cpp: PrecisionModel::Type made an enum instead
+	  of a Type.
+2004-04-15 15:11  Sandro Santilli <strk at keybit.net>
+	* [r310] source/io/Unload.cpp: Commented out deletion that seems to
+	  cause segfaults
+2004-04-15 14:00  Sandro Santilli <strk at keybit.net>
+	* [r309] source/headers/geom.h, source/headers/opBuffer.h,
+	  source/io/Unload.cpp: Added new cleanup to Unload::Release
+2004-04-14 13:56  Sandro Santilli <strk at keybit.net>
+	* [r308] source/geom/Geometry.cpp, source/headers/geom.h: All
+	  geometries returned by {from,to}InternalGeometry calls are
+	  now deleted after use (unless NOT new).
+	  Some 'commented' throw specifications in geom.h
+2004-04-14 13:14  Sandro Santilli <strk at keybit.net>
+	* [r307] source/operation/overlay/OverlayOp.cpp: Removed deletion
+	  of externally pointed GeometryFactory from OverlayOp destructor
+2004-04-14 12:28  Sandro Santilli <strk at keybit.net>
+	* [r306] source/geom/GeometryCollection.cpp,
+	  source/index/strtree/AbstractSTRtree.cpp: shouldNeverReachHere
+	  exceptions made more verbose
+2004-04-14 11:05  Sandro Santilli <strk at keybit.net>
+	* [r305] source/geom/util/GeometryEditor.cpp: Added support for
+	  LinearRing in GeometryEditor
+2004-04-14 10:56  Sandro Santilli <strk at keybit.net>
+	* [r304] source/operation/distance/DistanceOp.cpp: Uncommented
+	  initializzazion and destruction of
+	  DistanceOp::minDistanceLocation
+2004-04-14 09:38  Sandro Santilli <strk at keybit.net>
+	* [r303] source/geom/PrecisionModel.cpp: PrecisionModel(double
+	  newScale) missed to set the scale
+2004-04-14 09:30  Sandro Santilli <strk at keybit.net>
+	* [r302] source/headers/noding.h, source/noding/IteratedNoder.cpp:
+	  Private iterated noding funx now use int* instead of vector to
+	  know
+	  when it's time to stop.
+2004-04-14 09:11  Sandro Santilli <strk at keybit.net>
+	* [r301] source/operation/buffer/BufferOp.cpp: endCapStyle was
+	  never set in BufferOp contructor
+2004-04-14 08:38  Sandro Santilli <strk at keybit.net>
+	* [r300] source/operation/buffer/BufferBuilder.cpp: BufferBuilder
+	  constructor missed to initialize workingPrecisionModel
+	* [r299] source/operation/buffer/BufferOp.cpp: BufferOp constructor
+	  missed to set argGeom
+2004-04-14 07:29  Sandro Santilli <strk at keybit.net>
+	* [r298] source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
+	  source/headers/geom.h: Fixed GeometryFactory constructors to copy
+	  given PrecisionModel. Added GeometryFactory copy constructor.
+	  Fixed Geometry constructors to copy GeometryFactory.
+2004-04-14 06:04  ybychkov
+	* [r297] source/geomgraph/index,
+	  source/geomgraph/index/SegmentIntersector.cpp,
+	  source/geomgraph/index/SweepLineSegment.cpp: "geomgraph/index"
+	  committ problem fixed.
+2004-04-13 14:45  Sandro Santilli <strk at keybit.net>
+	* [r296] source/geom/Point.cpp: Removed faulty assert in
+	  constructor
+2004-04-13 14:33  Sandro Santilli <strk at keybit.net>
+	* [r295] source/geom/Makefile.am: Added more source files
+2004-04-13 14:28  Sandro Santilli <strk at keybit.net>
+	* [r294] doc/example.cpp: Removed spurious line
+2004-04-13 13:31  Sandro Santilli <strk at keybit.net>
+	* [r293] source/headers/precision.h: prototype mismatch fixed
+2004-04-13 12:29  Sandro Santilli <strk at keybit.net>
+	* [r292] source/headers/opDistance.h,
+	  source/operation/distance/GeometryLocation.cpp: GeometryLocation
+	  const-correctness.
+2004-04-13 11:04  Sandro Santilli <strk at keybit.net>
+	* [r291] source/headers/Makefile.am: Added lost opDistance.h
+2004-04-13 11:03  Sandro Santilli <strk at keybit.net>
+	* [r290] source/headers/Makefile.am: Added new header files
+2004-04-13 10:58  Sandro Santilli <strk at keybit.net>
+	* [r289] source/geom/Makefile.am: Added new source files
+2004-04-13 10:05  Sandro Santilli <strk at keybit.net>
+	* [r288] source/headers/opDistance.h,
+	  constructor made const-correct.
+	  Fixed erroneus down-casting in
+	  DistanceOp::computeMinDistancePoints.
+2004-04-13 08:15  Sandro Santilli <strk at keybit.net>
+	* [r287] source/headers/geom.h: Changed all 'long long' with int64.
+	  Changed all 'long long' constants to end with two Ls.
+2004-04-10 22:41  ybychkov
+	* [r286] VisualStudio/GEOS.vcproj, source/geom/LineString.cpp,
+	  source/geom/Point.cpp, source/headers/geom.h,
+	  source/headers/precision.h, source/headers/util.h,
+	  source/operation/buffer/BufferOp.cpp, source/precision,
+	  source/util/UniqueCoordinateArrayFilter.cpp: "precision" upgraded
+	  to JTS 1.4
+2004-04-10 08:40  ybychkov
+	* [r285] VisualStudio/GEOS.vcproj,
+	  source/operation/buffer/BufferEdgeBuilder.cpp,
+	  source/operation/buffer/BufferLineBuilder.cpp,
+	  source/operation/buffer/LoopFilter.cpp,
+	  source/operation/buffer/SubgraphDepthLocater.cpp,
+	  source/operation/overlay/PolygonBuilder.cpp: "operation/buffer"
+	  upgraded to JTS 1.4
+2004-04-08 04:53  ybychkov
+	* [r284] VisualStudio/GEOS.vcproj, source/headers/opPolygonize.h,
+	  source/operation/polygonize,
+	  source/operation/polygonize/PolygonizeGraph.cpp,
+	  source/operation/polygonize/Polygonizer.cpp,
+	  "operation/polygonize" ported from JTS 1.4
+2004-04-07 06:55  ybychkov
+	* [r283] VisualStudio/GEOS.vcproj, source/geom/CoordinateList.cpp,
+	  source/headers/geom.h, source/headers/opLinemerge.h,
+	  source/headers/planargraph.h, source/operation/linemerge,
+	  source/operation/linemerge/LineMergeGraph.cpp,
+	  source/planargraph/PlanarGraph.cpp,
+	  source/planargraph/planarPlanarGraph.cpp: "operation/linemerge"
+	  ported from JTS 1.4
+2004-04-05 06:35  ybychkov
+	* [r282] VisualStudio/GEOS.vcproj,
+	  source/algorithm/CGAlgorithms.cpp, source/geom/LineSegment.cpp,
+	  source/headers/indexStrtree.h, source/headers/opDistance.h,
+	  source/index/strtree/STRtree.cpp,
+	  source/operation/distance/LineExtracterFilter.cpp,
+	  source/operation/distance/PointExtracterFilter.cpp,
+	  source/operation/distance/PolygonExtracterFilter.cpp:
+	  "operation/distance" upgraded to JTS 1.4
+2004-04-04 06:29  ybychkov
+	* [r281] VisualStudio/GEOS.vcproj, source/geom/GeometryFactory.cpp,
+	  source/geom/util, source/geom/util/GeometryEditor.cpp,
+	  source/geom/util/PolygonExtracter.cpp, source/headers/geom.h,
+	  source/headers/geomgraphindex.h, source/headers/planargraph.h,
+	  source/planargraph, source/planargraph/PlanarGraph.cpp,
+	  source/planargraph/planarDirectedEdge.cpp,
+	  source/planargraph/planarNodeMap.cpp: "planargraph" and
+	  "geom/utill" upgraded to JTS 1.4
+2004-04-01 10:44  ybychkov
+	* [r280] source/geom/Geometry.cpp,
+	  source/geom/MultiPoint.cpp, source/geom/Polygon.cpp,
+	  source/headers/geom.h, source/io/Unload.cpp: All "geom" classes
+	  from JTS 1.3 upgraded to JTS 1.4
+2004-03-31 07:50  ybychkov
+	* [r279] source/geom/LineString.cpp, source/geom/MultiPoint.cpp,
+	  source/geomgraph/EdgeNodingValidator.cpp, source/headers/geom.h:
+	  "geom" partially upgraded to JTS 1.4
+2004-03-29 06:59  ybychkov
+	* [r278] VisualStudio/GEOS.vcproj, source/geom/LineSegment.cpp,
+	  source/headers/geom.h, source/headers/nodingSnapround.h,
+	  source/headers/opOverlay.h, source/headers/opRelate.h,
+	  source/headers/opValid.h, source/headers/operation.h,
+	  source/io/Unload.cpp, source/noding/snapround,
+	  source/noding/snapround/SegmentSnapper.cpp,
+	  source/operation/valid/IsValidOp.cpp,
+	  "noding/snapround" package ported (JTS 1.4);
+	  "operation", "operation/valid", "operation/relate" and
+	  "operation/overlay" upgraded to JTS 1.4;
+	  "geom" partially upgraded.
+2004-03-26 07:48  ybychkov
+	* [r277] VisualStudio/GEOS.vcproj, source/headers/noding.h,
+	  source/noding, source/noding/IteratedNoder.cpp,
+	  source/noding/MCQuadtreeNoder.cpp, source/noding/Noder.cpp,
+	  source/noding/NodingValidator.cpp, source/noding/SegmentNode.cpp,
+	  source/noding/nodingSegmentIntersector.cpp: "noding" package
+	  ported (JTS 1.4)
+2004-03-25 02:23  ybychkov
+	* [r276] source/algorithm/RobustLineIntersector.cpp, source/graph,
+	  source/headers/indexBintree.h, source/headers/indexChain.h,
+	  source/headers/indexQuadtree.h, source/headers/indexStrtree.h,
+	  source/index/chain/MonotoneChainBuilder.cpp,
+	  source/index/chain/MonotoneChainOverlapAction.cpp,
+	  source/index/chain/MonotoneChainSelectAction.cpp,
+	  source/index/strtree/AbstractNode.cpp,
+	  source/index/strtree/STRtree.cpp: All "index/*" packages upgraded
+	  to JTS 1.4
+2004-03-19 09:49  ybychkov
+	* [r275] VisualStudio/GEOS.vcproj,
+	  source/algorithm/PointLocator.cpp, source/geomgraph,
+	  source/geomgraph/EdgeIntersectionList.cpp,
+	  source/geomgraph/GeometryGraph.cpp,
+	  source/geomgraph/NodeMap.cpp, source/geomgraph/PlanarGraph.cpp,
+	  source/graph/index/MonotoneChain.cpp,
+	  source/graph/index/MonotoneChainEdge.cpp,
+	  source/graph/index/MonotoneChainIndexer.cpp,
+	  source/graph/index/SegmentIntersector.cpp,
+	  source/graph/index/SimpleEdgeSetIntersector.cpp,
+	  source/graph/index/SimpleMCSweepLineIntersector.cpp,
+	  source/graph/index/SimpleSweepLineIntersector.cpp,
+	  source/graph/index/SweepLineEvent.cpp,
+	  source/graph/index/SweepLineSegment.cpp,
+	  source/headers/geomgraph.h, source/headers/geomgraphindex.h,
+	  source/headers/graph.h, source/headers/graphindex.h,
+	  source/headers/noding.h, source/headers/opOverlay.h,
+	  source/headers/opRelate.h, source/headers/operation.h,
+	  source/io/Unload.cpp, source/operation/buffer/BufferOp.cpp,
+	  source/test/XMLTester.cpp: "geomgraph" and "geomgraph/indexl"
+2004-03-18 10:42  ybychkov
+	* [r274] VisualStudio/GEOS.vcproj, source/geom/Coordinate.cpp,
+	  source/geom/CoordinateList.cpp, source/geom/Envelope.cpp,
+	  source/geom/Triangle.cpp, source/headers/geom.h,
+	  source/headers/io.h, source/headers/util.h,
+	  source/io/StringTokenizer.cpp, source/io/WKTReader.cpp,
+	  source/io/WKTWriter.cpp, source/util/GeometricShapeFactory.cpp:
+	  "IO" and "Util" upgraded to JTS 1.4
+	  "Geometry" partially upgraded.
+2004-03-17 02:00  ybychkov
+	* [r273] VisualStudio/GEOS.sln, VisualStudio/GEOS.vcproj,
+	  source/algorithm/LineIntersector.cpp,
+	  source/algorithm/RobustCGAlgorithms.cpp,
+	  source/algorithm/RobustLineIntersector.cpp,
+	  source/algorithm/SimplePointInRing.cpp, source/geom/Geometry.cpp,
+	  source/headers/geom.h, source/headers/geosAlgorithm.h,
+	  source/test/Stackwalker.h: "Algorithm" upgraded to JTS 1.4
+2004-03-01 22:04  Sandro Santilli <strk at keybit.net>
+	* [r272] source/geom/Geometry.cpp, source/headers/geom.h,
+	  source/headers/opBuffer.h, source/headers/opRelate.h,
+	  source/operation/relate/RelateOp.cpp: applied const correctness
+	  changes by Manuel Prieto Villegas
+	  <ManuelPrietoVillegas at telefonica.net>
+2004-02-27 17:43  Sandro Santilli <strk at keybit.net>
+	* [r271] source/geom/Polygon.cpp: memory leak fix in
+	  Polygon::getArea() - reported by 'Manuel Prieto Villegas'
+	  <mprieto at dap.es>
+2004-02-27 17:42  Sandro Santilli <strk at keybit.net>
+	* [r270] source/algorithm/CGAlgorithms.cpp,
+	  source/headers/geosAlgorithm.h: made CGAlgorithms::signedArea()
+	  and CGAlgorithms::length() arguments const-correct
+2004-02-20 05:44  pramsey
+	* [r269] ltmain.sh: Changed to new version of ltmain, that matches
+	  the version of libtool
+	  on build box
+2004-01-20 05:51  pramsey
+	* [r268] configure.in: Change platform.h back to AM_CONFIG_HEADER.
+2004-01-20 05:10  pramsey
+	* [r267] configure.in: Change AM_CONFIG_HEADER to AC_CONFIG_HEADERS
+	  to allow autoheader to work
+	  its magic.
+2003-12-11 17:01  Sandro Santilli <strk at keybit.net>
+	* [r266] source/operation/buffer/BufferOp.cpp: made buffer(0) back
+	  to its *correct* semantic (empy collection)
+2003-12-11 16:01  Sandro Santilli <strk at keybit.net>
+	* [r265] source/operation/buffer/BufferOp.cpp: made buffer
+	  operation return a cloned input geom when called with 0 as
+	  distance
+2003-12-11 15:53  Sandro Santilli <strk at keybit.net>
+	* [r264] source/geom/GeometryCollection.cpp: Fixed bogus copy
+	  constructor (making clone bogus)
+2003-11-13 11:57  Sandro Santilli <strk at keybit.net>
+	* [r263] doc/example.cpp: bug fixed in relate call
+2003-11-12 22:03  Sandro Santilli <strk at keybit.net>
+	* [r262] doc/example.cpp: added relational operators
+2003-11-12 18:02  Sandro Santilli <strk at keybit.net>
+	* [r261] source/graph/PlanarGraph.cpp, source/headers/graph.h,
+	  source/operation/overlay/PolygonBuilder.cpp: Added throw
+	  specification. Fixed leaks on exceptions.
+2003-11-12 17:15  Sandro Santilli <strk at keybit.net>
+	* [r260] source/geom/PrecisionModel.cpp: made sure PrecisionModel
+	  scale is never 0
+2003-11-12 17:10  Sandro Santilli <strk at keybit.net>
+	* [r259] source/test/XMLTester.cpp: added missing initialization
+2003-11-12 16:14  Sandro Santilli <strk at keybit.net>
+	* [r258] source/headers/opOverlay.h,
+	  source/operation/overlay/OverlayOp.cpp: Added some more throw
+	  specifications and cleanup on exception (leaks removed).
+2003-11-12 15:43  Sandro Santilli <strk at keybit.net>
+	* [r257] source/graph/DirectedEdgeStar.cpp,
+	  source/graph/EdgeEndStar.cpp, source/graph/GeometryGraph.cpp,
+	  source/headers/graph.h: Added some more throw specifications
+2003-11-12 15:02  Sandro Santilli <strk at keybit.net>
+	* [r256] source/test/XMLTester.cpp: more cleanup on exception
+2003-11-12 11:08  Sandro Santilli <strk at keybit.net>
+	* [r255] doc/example.cpp: removed old changelog, moved comments in
+	  the nice standard frame
+2003-11-12 11:05  Sandro Santilli <strk at keybit.net>
+	* [r254] autogen.sh: added autoheader call
+2003-11-07 17:51  Sandro Santilli <strk at keybit.net>
+	* [r253] source/operation/buffer/BufferOp.cpp: Memory leak fix in
+	  insertEdge()
+2003-11-07 17:49  pramsey
+	* [r252] ChangeLog: Added current ChangeLog
+2003-11-07 17:45  Sandro Santilli <strk at keybit.net>
+	* [r251] source/headers/config.h.in: will be generated with
+	  ./autogen.sh
+2003-11-07 14:21  Sandro Santilli <strk at keybit.net>
+	* [r250] Makefile.am, configure.in, doc, doc/.cvsignore,
+	  doc/Makefile, doc/Makefile.am: Made doc/ directory part of
+	  distribution. Uniformed doc build script to
+	  autotools.
+2003-11-07 14:19  Sandro Santilli <strk at keybit.net>
+	* [r249] source/headers, source/headers/.cvsignore: added
+	  config.h.in (missed before)
+2003-11-07 14:18  Sandro Santilli <strk at keybit.net>
+	* [r248] source/headers, source/headers/.cvsignore: added
+	  config.h.in
+2003-11-07 01:58  pramsey
+	* [r247] AUTHORS: Added people!
+2003-11-07 01:23  pramsey
+	* [r245] doc/example.cpp, source/algorithm/CGAlgorithms.cpp,
+	  source/algorithm/NonRobustLineIntersector.cpp,
+	  source/algorithm/RobustDeterminant.cpp,
+	  source/algorithm/SIRtreePointInRing.cpp,
+	  source/bigtest/GeometryTestFactory.cpp,
+	  source/geom/IntersectionMatrix.cpp, source/geom/LineSegment.cpp,
+	  source/geom/TopologyException.cpp, source/graph/Depth.cpp,
+	  source/graph/DirectedEdge.cpp, source/graph/DirectedEdgeStar.cpp,
+	  source/graph/Edge.cpp, source/graph/EdgeEnd.cpp,
+	  source/graph/EdgeEndStar.cpp, source/graph/EdgeIntersection.cpp,
+	  source/graph/EdgeIntersectionList.cpp, source/graph/EdgeList.cpp,
+	  source/graph/EdgeRing.cpp, source/graph/GeometryGraph.cpp,
+	  source/graph/GraphComponent.cpp, source/graph/Label.cpp,
+	  source/graph/Node.cpp, source/graph/NodeFactory.cpp,
+	  source/graph/NodeMap.cpp, source/graph/PlanarGraph.cpp,
+	  source/graph/Position.cpp, source/graph/Quadrant.cpp,
+	  source/graph/TopologyLocation.cpp,
+	  source/headers/acconfig.h, source/headers/bigtest.h,
+	  source/headers/config.h.in, source/headers/geom.h,
+	  source/headers/geosAlgorithm.h, source/headers/graph.h,
+	  source/headers/graphindex.h, source/headers/indexBintree.h,
+	  source/headers/io.h, source/headers/opBuffer.h,
+	  source/headers/opDistance.h, source/headers/opOverlay.h,
+	  source/headers/operation.h, source/headers/spatialIndex.h,
+	  source/headers/unload.h, source/headers/util.h,
+	  source/index/quadtree/DoubleBits.cpp,
+	  source/index/quadtree/QuadTreeKey.cpp,
+	  source/index/quadtree/QuadTreeNode.cpp,
+	  source/index/quadtree/QuadTreeNodeBase.cpp,
+	  source/index/quadtree/QuadTreeRoot.cpp,
+	  source/index/strtree/ItemBoundable.cpp,
+	  source/index/sweepline/SweepLineIndex.cpp,
+	  source/io/markup/MarkupSTL.h,
+	  source/operation/distance/DistanceOp.cpp,
+	  source/operation/distance/PolygonExtracterFilter.cpp,
+	  source/operation/overlay/PolygonBuilder.cpp,
+	  source/operation/relate/RelateComputer.cpp,
+	  source/operation/relate/RelateOp.cpp,
+	  source/operation/valid/QuadtreeNestedRingTester.cpp,
+	  source/test/Stackwalker.h, source/test/XMLTester.cpp,
+	  source/util/Assert.cpp, source/util/AssertionFailedException.cpp,
+	  source/util/UnsupportedOperationException.cpp: Add standard CVS
+	  headers licence notices and copyrights to all cpp and h
+	  files.
+2003-11-06 19:04  Sandro Santilli <strk at keybit.net>
+	* [r244] source/graph/EdgeIntersectionList.cpp: removed useless
+	  Coordinate copy in ::createSplitEdge()
+2003-11-06 18:50  Sandro Santilli <strk at keybit.net>
+	* [r243] doc, doc/.cvsignore: first import
+2003-11-06 18:48  Sandro Santilli <strk at keybit.net>
+	* [r242] TODO: updated
+	* [r241] source/operation/overlay/PolygonBuilder.cpp: added throw
+	  information comment in PolygonBuilder
+2003-11-06 18:47  Sandro Santilli <strk at keybit.net>
+	* [r240] source/operation/buffer/BufferOp.cpp: Added throw
+	  specification for BufferOp's ::buildSubgraphs() and
+	  ::computeBuffer(). Cleanup on exception in computeBuffer().
+2003-11-06 18:46  Sandro Santilli <strk at keybit.net>
+	* [r239] source/headers/opBuffer.h: Added throw specification for
+	  BufferOp's ::buildSubgraphs() and ::computeBuffer()
+2003-11-06 18:45  Sandro Santilli <strk at keybit.net>
+	* [r238] source/graph/DirectedEdgeStar.cpp, source/headers/graph.h:
+	  Added throw specification for
+	  DirectEdgeStar::linkResultDirectedEdges()
+2003-11-06 18:00  Sandro Santilli <strk at keybit.net>
+	* [r237] source/operation/buffer/BufferOp.cpp: Cleanup on exception
+	  in ::bufferOp()
+2003-11-06 17:59  Sandro Santilli <strk at keybit.net>
+	* [r236] source/graph/EdgeRing.cpp: Memory leaks fixed in
+	  ::containsPoint()
+2003-11-06 17:48  Sandro Santilli <strk at keybit.net>
+	* [r235] source/operation/buffer/BufferLineBuilder.cpp: Fixed
+	  memory leaks in ::closePt() and ::addLineEndCap()
+2003-11-06 17:47  Sandro Santilli <strk at keybit.net>
+	* [r234] source/operation/buffer/BufferEdgeBuilder.cpp: Added
+	  support for LinearRing, removed memory leaks in ::addLineString
+2003-11-06 17:41  Sandro Santilli <strk at keybit.net>
+	* [r233] doc/example.cpp: Added Buffer,Intersection,Difference and
+	  Symdifference. Exception cleanup
+2003-11-06 17:33  pramsey
+	* [r232] INSTALL: Small addition of into about LD_LIBRARY_PATH
+2003-11-05 21:52  Sandro Santilli <strk at keybit.net>
+	* [r231] doc/Makefile, doc/example.cpp: Modified example.cpp to
+	  make use of vectors instead of Geometry * / int
+	  couples. Added LineString creation example. Added Makefile to
+	  compile it.
+2003-11-03 16:09  Sandro Santilli <strk at keybit.net>
+	* [r230] doc/example.cpp: Removed comments about segfaults, made
+	  the simple collection creation call
+	  cleaner by use of the clone() method.
+2003-10-31 16:36  Sandro Santilli <strk at keybit.net>
+	* [r229] source/geom/GeometryCollection.cpp,
+	  source/geom/LineString.cpp, source/geom/Point.cpp,
+	  source/geom/Polygon.cpp, source/headers/geom.h: Re-introduced
+	  clone() method. Copy constructor could not really replace it.
+2003-10-29 10:38  Sandro Santilli <strk at keybit.net>
+	* [r228] doc/example.cpp: Added centroid computation example
+	* [r227] source/algorithm/CentroidLine.cpp: Added support for
+	  LinearRing types (treated as LineString)
+2003-10-24 21:27  Sandro Santilli <strk at keybit.net>
+	* [r226] source/headers/geom.h: Added GeometryTypeId enum and
+	  getGeometryTypeId abstract Geometry method.
+2003-10-23 09:17  Sandro Santilli <strk at keybit.net>
+	* [r225] source/headers, source/headers/.cvsignore: Added stamp-h2
+	  and platform.h
+2003-10-23 09:12  Sandro Santilli <strk at keybit.net>
+	* [r224] source/headers/util.h: Made CoordinateArrayFilter
+	  destructor virtual.
+2003-10-22 23:58  Sandro Santilli <strk at keybit.net>
+	* [r223] configure.in, source/headers/platform.h,
+	  source/headers/platform.h.in: Made platform.h be created by
+	  configure. In this way we will not have
+	  problems of installed headers trying to include phantom config.h.
+2003-10-22 00:44  Sandro Santilli <strk at keybit.net>
+	* [r222] source/headers/indexQuadtree.h, source/headers/platform.h,
+	  source/index/quadtree/DoubleBits.cpp: Quadtree bitfield
+	  operations made using type int64. Type int64 typedef'ed based
+	  on autoconf detected int type (long or long long). If long is not
+	  64bits int64
+	  will be really 32 bits and INT64_IS_REALLY32 will be defined.
+2003-10-21 23:51  Sandro Santilli <strk at keybit.net>
+	* [r221] acsite.m4, configure.in, source/headers/acconfig.h,
+	  source/headers/config.h.in: Added macros to find 64bit integer.
+2003-10-21 16:16  Sandro Santilli <strk at keybit.net>
+	* [r220] doc/example.cpp: Uncommented point creation lines. Updated
+	  comments about segfaults.
+2003-10-21 05:35  pramsey
+	* [r219] source/test/Makefile.am: Added test.xml so it gets picked
+	  up by 'make dist'
+2003-10-21 05:09  pramsey
+	* [r218] INSTALL: Added simple installation directions.
+2003-10-21 04:55  pramsey
+	* [r217] source/examples/Makefile.am, source/geom/Makefile.am,
+	  source/test/Makefile.am: Fix up references to header files to
+	  'make dist' works.
+2003-10-20 17:50  Sandro Santilli <strk at keybit.net>
+	* [r216] doc/example.cpp: added Union example
+2003-10-20 15:41  Sandro Santilli <strk at keybit.net>
+	* [r215] source/geom/Geometry.cpp, source/headers/geom.h:
+	  Geometry::checkNotGeometryCollection made static and
+	  non-distructive.
+2003-10-20 14:02  Sandro Santilli <strk at keybit.net>
+	* [r214] source/graph/EdgeRing.cpp,
+	  source/operation/valid/ConnectedInteriorTester.cpp: more explicit
+	  exception thrown on null Directed Edge detection
+2003-10-20 13:56  Sandro Santilli <strk at keybit.net>
+	* [r213] source/util/AssertionFailedException.cpp: fixed typo
+2003-10-20 13:53  Sandro Santilli <strk at keybit.net>
+	* [r212] source/graph/GeometryGraph.cpp: LinearRing handled as a
+	  LineString in GeometryGraph::add(const Geometry *) - more
+	  explicit exception thrown for unknown geometries
+2003-10-17 05:51  ybychkov
+	* [r211] VisualStudio/GEOS.vcproj, source/geom/Polygon.cpp,
+	  source/index/quadtree/DoubleBits.cpp, source/test/XMLTester.cpp:
+	  Fixed a small memory leak.
+2003-10-16 17:41  Sandro Santilli <strk at keybit.net>
+	* [r210] source/util/GEOSException.cpp,
+	  source/util/UnsupportedOperationException.cpp: Fixed a bug in
+	  GEOSException that prevented print of the type of exception
+	  thrown.
+2003-10-16 17:33  Sandro Santilli <strk at keybit.net>
+	* [r209] source/operation/valid/RepeatedPointTester.cpp: dropped
+	  useless string() cast
+2003-10-16 17:05  Sandro Santilli <strk at keybit.net>
+	* [r208] source/geom/TopologyException.cpp, source/headers/geom.h,
+	  source/headers/util.h, source/util/IllegalArgumentException.cpp:
+	  Made TopologyException inherit from GEOSException. Adjusted
+	  IllegalArgumentException subclassing.
+2003-10-16 13:01  Sandro Santilli <strk at keybit.net>
+	* [r207] source/test/XMLTester.cpp: Added call to Unload::Release()
+2003-10-16 12:09  Sandro Santilli <strk at keybit.net>
+	* [r206] source/test/XMLTester.cpp: bug fixed in exception handling
+2003-10-16 08:50  Sandro Santilli <strk at keybit.net>
+	* [r205] source/algorithm/CentroidArea.cpp,
+	  source/geom/LineString.cpp, source/geom/MultiPolygon.cpp,
+	  source/geom/Polygon.cpp, source/headers/geosAlgorithm.h,
+	  source/operation/valid/QuadtreeNestedRingTester.cpp: Memory leak
+	  fixes. Improved performance by mean of more calls to new
+	  getCoordinatesRO() when applicable.
+2003-10-16 08:48  Sandro Santilli <strk at keybit.net>
+	* [r204] source/test/XMLTester.cpp: Exceptions handled
+2003-10-15 16:39  Sandro Santilli <strk at keybit.net>
+	* [r203] source/geom/GeometryFactory.cpp, source/graph/Edge.cpp,
+	  source/graph/EdgeList.cpp, source/graph/EdgeRing.cpp,
+	  source/graph/GeometryGraph.cpp, source/graph/PlanarGraph.cpp,
+	  source/headers/geom.h, source/headers/graph.h,
+	  source/operation/overlay/LineBuilder.cpp: Made
+	  Edge::getCoordinates() return a 'const' value. Adapted code set.
+2003-10-15 15:47  Sandro Santilli <strk at keybit.net>
+	* [r202] source/algorithm/MCPointInRing.cpp,
+	  source/algorithm/PointLocator.cpp: Adapted to new
+	  getCoordinatesRO() interface
+2003-10-15 15:30  Sandro Santilli <strk at keybit.net>
+	* [r201] source/graph/index/MonotoneChain.cpp,
+	  source/headers/graphindex.h: Declared a SweepLineEventOBJ from
+	  which MonotoneChain and SweepLineSegment
+	  derive to abstract SweepLineEvent object previously done on void
+	  * pointers.
+	  No more compiler warnings...
+2003-10-15 11:24  Sandro Santilli <strk at keybit.net>
+	* [r200] source/graph/GeometryGraph.cpp,
+	  source/operation/valid/IsValidOp.cpp: Use getCoordinatesRO()
+	  introduced.
+2003-10-15 11:23  Sandro Santilli <strk at keybit.net>
+	* [r199] source/geom/BasicCoordinateList.cpp,
+	  Formalized const nature of toVector() method and of first
+	  argument to static removeRepeatedPoints().
+2003-10-15 10:17  Sandro Santilli <strk at keybit.net>
+	* [r198] source/geom/BasicCoordinateList.cpp,
+	  source/geom/PointCoordinateList.cpp, source/headers/geom.h: Made
+	  setPoints() get a const vector<Coordinate>.
+2003-10-15 09:54  Sandro Santilli <strk at keybit.net>
+	* [r197] source/geom/LineString.cpp, source/headers/geom.h: Added
+	  getCoordinatesRO() public method.
+2003-10-15 08:52  Sandro Santilli <strk at keybit.net>
+	* [r196] source/io/WKTReader.cpp: Memory leaks fixed.
+2003-10-15 08:51  Sandro Santilli <strk at keybit.net>
+	* [r195] TODO: Initial import
+2003-10-15 08:08  Sandro Santilli <strk at keybit.net>
+	* [r194] source/geom/Polygon.cpp: Memory leaks fixed. Partially due
+	  to getCoordinates() and GeometryCollection()
+	  changes, partially old dated.
+2003-10-14 15:58  Sandro Santilli <strk at keybit.net>
+	* [r193] source/geom/GeometryFactory.cpp: Useless vector<Geometry
+	  *> leaking allocations removed
+2003-10-13 21:26  Sandro Santilli <strk at keybit.net>
+	* [r192] ., .cvsignore, macros, macros/.cvsignore, source/bigtest,
+	  source/bigtest/.cvsignore, source/examples,
+	  source/examples/.cvsignore, source/geom, source/geom/.cvsignore,
+	  source/headers, source/headers/.cvsignore, source/test,
+	  source/test/.cvsignore: Added build time created files to
+	  cvsignore lists
+2003-10-13 17:54  Sandro Santilli <strk at keybit.net>
+	* [r191] source/headers/opValid.h,
+	  source/operation/valid/IsValidOp.cpp: IsValidOp constructor used
+	  same name for the arg and a private element. Fixed.
+2003-10-13 17:47  Sandro Santilli <strk at keybit.net>
+	* [r190] source/operation/overlay/MaximalEdgeRing.cpp,
+	  source/operation/overlay/PolygonBuilder.cpp: delete statement
+	  removed
+2003-10-13 15:39  Sandro Santilli <strk at keybit.net>
+	* [r189] source/algorithm/CentroidArea.cpp,
+	  source/headers/geosAlgorithm.h: Fixed some leak or fault flips
+	  (forced copy of a single coordinate)
+2003-10-13 15:02  Sandro Santilli <strk at keybit.net>
+	* [r188] source/test/XMLTester.cpp: accept input file as first
+	  argument on cmdline
+2003-10-13 12:51  Sandro Santilli <strk at keybit.net>
+	* [r187] source/geom/Geometry.cpp, source/headers/geom.h: removed
+	  sortedClasses strings array from all geometries.
+2003-10-13 09:24  Sandro Santilli <strk at keybit.net>
+	* [r186] source/headers/indexQuadtree.h,
+	  source/index/quadtree/DoubleBits.cpp: long -> long long
+	  enlargement of types to allow for left/rigth shift of 53 bits
+2003-10-11 03:23  Sandro Santilli <strk at keybit.net>
+	* [r185] source/geom/LineString.cpp, source/geom/LinearRing.cpp:
+	  fixed spurious typos
+2003-10-11 01:56  Sandro Santilli <strk at keybit.net>
+	* [r184] source/algorithm/CGAlgorithms.cpp,
+	  source/algorithm/CentroidArea.cpp,
+	  source/algorithm/CentroidLine.cpp,
+	  source/algorithm/ConvexHull.cpp,
+	  source/algorithm/InteriorPointLine.cpp,
+	  source/algorithm/MCPointInRing.cpp,
+	  source/algorithm/NonRobustCGAlgorithms.cpp,
+	  source/algorithm/SimplePointInAreaLocator.cpp,
+	  source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
+	  source/geom/GeometryFactory.cpp, source/geom/LineSegment.cpp,
+	  source/geom/PointCoordinateList.cpp, source/geom/Polygon.cpp,
+	  source/geom/PrecisionModel.cpp, source/graph/Edge.cpp,
+	  source/graph/EdgeEnd.cpp, source/graph/EdgeIntersection.cpp,
+	  source/graph/EdgeIntersectionList.cpp, source/graph/EdgeRing.cpp,
+	  source/graph/GeometryGraph.cpp, source/graph/GraphComponent.cpp,
+	  source/graph/Label.cpp, source/graph/Node.cpp,
+	  source/graph/Quadrant.cpp, source/graph/TopologyLocation.cpp,
+	  source/graph/index/SweepLineEvent.cpp, source/headers/geom.h,
+	  source/headers/operation.h, source/headers/util.h,
+	  source/index/chain/indexMonotoneChain.cpp,
+	  source/operation/buffer/RightmostEdgeFinder.cpp,
+	  source/operation/valid/ConnectedInteriorTester.cpp,
+	  source/operation/valid/RepeatedPointTester.cpp,
+	  source/operation/valid/SimpleNestedRingTester.cpp,
+	  source/operation/valid/SweeplineNestedRingTester.cpp,
+	  source/util/Assert.cpp, source/util/CoordinateArrayFiter.cpp,
+	  source/util/UniqueCoordinateArrayFilter.cpp: Code base padded
+	  with 'const' keywords ;)
+2003-10-09 15:35  Sandro Santilli <strk at keybit.net>
+	* [r183] source/geom/GeometryFactory.cpp, source/headers/geom.h:
+	  added 'const' keyword to GeometryFactory constructor, Log on top
+	  of geom.h
+2003-10-09 11:20  Sandro Santilli <strk at keybit.net>
+	* [r182] doc/example.cpp: moved Log to a better place
+2003-10-09 11:19  Sandro Santilli <strk at keybit.net>
+	* [r181] doc/example.cpp: added convexHull and PrecisionModel
+2003-10-09 10:14  Sandro Santilli <strk at keybit.net>
+	* [r180] source/geom/GeometryFactory.cpp: just a style change in
+	  top Log comment.
+2003-10-09 10:10  Sandro Santilli <strk at keybit.net>
+	* [r179] source/geom/PrecisionModel.cpp: Throw an exception if
+	  scale is 0. Added Log entry.
+2003-10-09 09:42  Sandro Santilli <strk at keybit.net>
+	* [r178] source/geom/GeometryFactory.cpp: Tried to "formalize"
+	  constant nature of the first argument given to constructor by
+	  PrecisionModel and SRID specification. Added CVS Log on top.
+2003-10-09 08:58  Sandro Santilli <strk at keybit.net>
+	* [r177] doc/example.cpp, source/algorithm/ConvexHull.cpp: Added
+	  convexHull() call to example, fixed leaks in ConvexHull
+2003-10-09 00:11  Sandro Santilli <strk at keybit.net>
+	* [r176] doc, doc/example.cpp: First reference-by-example file.
+2003-10-08 16:51  Sandro Santilli <strk at keybit.net>
+	* [r175] source/geom/Makefile.am, source/headers/Makefile.am,
+	  source/headers/indexQuadtree.h, source/headers/opRelate.h,
+	  source/headers/unload.h, source/io/Unload.cpp: Added xie's Unload
+	  class with some fixes.
+2003-10-08 13:18  Sandro Santilli <strk at keybit.net>
+	* [r174] source/headers/io.h, source/io/WKTWriter.cpp: added
+	  missing LinearRing writing capabilities.
+2003-10-08 10:36  Sandro Santilli <strk at keybit.net>
+	* [r173] source/geom/GeometryCollection.cpp: Constructor by
+	  vector<Geometry *> * now makes a copy of the vector so that call
+	  ers can safely delete it when done.
+2003-10-07 21:47  Sandro Santilli <strk at keybit.net>
+	* [r172] source/algorithm/SimplePointInAreaLocator.cpp,
+	  source/geom/Polygon.cpp, source/graph/EdgeRing.cpp,
+	  source/operation/overlay/PolygonBuilder.cpp: had all
+	  getCoordinates() callers free returned value.
+2003-10-07 18:58  Sandro Santilli <strk at keybit.net>
+	* [r171] source/algorithm/PointLocator.cpp,
+	  source/geom/GeometryCollection.cpp, source/geom/LineString.cpp,
+	  source/graph/GeometryGraph.cpp, source/headers/config.h.in:
+	  LineString constructor now creates its own copy of given
+	  CoordinateList object, and returns a new copy with
+	  getCoordinates().
+	  will be easier to remove by anyone else.
+2003-10-03 01:20  ybychkov
+	* [r170] source/geom/MultiPolygon.cpp, source/test/XMLTester.cpp:
+	  Memory leak in Overlay fixed.
+2003-09-29 16:25  Sandro Santilli <strk at keybit.net>
+	* [r169] macros, macros/.cvsignore, source/bigtest,
+	  source/examples/.cvsignore, source/headers,
+	  source/headers/.cvsignore: Some more cvsignore files. Some
+	  entries should probably not be
+	  in the local copy
+2003-09-29 15:07  Sandro Santilli <strk at keybit.net>
+	* [r168] ., .cvsignore: Added config.sub, config.guess and
+	  autom4te.cache
+2003-09-29 13:15  Sandro Santilli <strk at keybit.net>
+	* [r167] tools, tools/.cvsignore: Don't wonder about Makefile.in,
+	  Makefile, gdal-config
+2003-09-26 17:31  Sandro Santilli <strk at keybit.net>
+	* [r166] source/algorithm/ConvexHull.cpp: getConvexHull() made
+	  check value returned by reduce() before deleting
+	  it (might be the untouched input).
+2003-09-26 09:17  ybychkov
+	* [r165] source/index/bintree/NodeBase.cpp,
+	  source/test/XMLTester.cpp: isValid segfault fixed. Overlay still
+	  leaks a bit.
+2003-09-24 02:16  ybychkov
+	* [r164] source/geom/MultiPolygon.cpp,
+	  source/graph/EdgeEndStar.cpp, source/index/bintree/NodeBase.cpp,
+	  source/index/bintree/Root.cpp,
+	  source/test/XMLTester.cpp: All reported bugs fiexd. Small leak in
+	  Overlay remains.
+2003-09-06 08:24  ybychkov
+	* [r163] source/geom/Geometry.cpp, source/headers/opDistance.h,
+	  source/test/XMLTester.cpp: isWithinDistance fixed and tested.
+2003-09-06 00:01  ybychkov
+	* [r162] source/algorithm/InteriorPointArea.cpp,
+	  source/algorithm/InteriorPointPoint.cpp,
+	  source/geom/Geometry.cpp, source/graph/DirectedEdge.cpp,
+	  source/graph/DirectedEdgeStar.cpp,
+	  source/test/XMLTester.cpp: getInteriorPoint bugs fixed.
+2003-09-01 06:32  ybychkov
+	* [r161] source/algorithm/ConvexHull.cpp, source/geom/Geometry.cpp,
+	  source/geom/Polygon.cpp, source/test/XMLTester.cpp: Some
+	  ConvexHull bugs fixed.
+2003-08-30 07:55  ybychkov
+	* [r160] source/algorithm/CentroidArea.cpp,
+	  source/geom/Polygon.cpp, source/graph/GeometryGraph.cpp,
+	  source/operation/IsSimpleOp.cpp, source/test/XMLTester.cpp: Some
+	  bugfixes. XMLTester expanded to accomodate getBoundary,
+	  getCentroid, isSimple.
+2003-08-18 23:40  pramsey
+	* [r159] source/algorithm/ConvexHull.java: Removed java source file
+	  from archive.
+2003-08-18 22:34  pramsey
+	* [r158] configure.in: Change it back :/
+2003-08-18 22:33  pramsey
+	* [r157] configure.in: Change version number.
+2003-08-18 20:42  pramsey
+	* [r156] ltmain.sh: Return ltmain to distro (oops)
+2003-08-18 20:36  pramsey
+	* [r155] mkinstalldirs: Remove more autoconf files
+2003-08-18 20:34  pramsey
+	* [r154] acinclude.m4, config.guess, config.sub, install-sh,
+	  ltmain.sh: Removed more autoconf files...
+2003-08-18 20:27  pramsey
+	* [r153] missing: Removed 'missing' script.
+2003-08-18 16:38  pramsey
+	* [r152] source/headers/Makefile.am: Fixed up to treat headers as
+	  headers.
+2003-08-17 18:40  pramsey
+	* [r151] Makefile.am, source/Makefile.am,
+	  source/algorithm/CentroidPoint.cpp,
+	  source/algorithm/HCoordinate.cpp,
+	  source/algorithm/NotRepresentableException.cpp,
+	  source/bigtest/Makefile.am,
+	  source/examples/CustomCoordinateListExample.h,
+	  source/examples/Makefile.am, source/geom/BasicCoordinateList.cpp,
+	  source/geom/Coordinate.cpp, source/geom/CoordinateList.cpp,
+	  source/geom/CoordinateListFactory.cpp, source/geom/Dimension.cpp,
+	  source/geom/Envelope.cpp, source/geom/Geometry.cpp,
+	  source/geom/GeometryCollectionIterator.cpp,
+	  source/geom/GeometryComponentFilter.cpp,
+	  source/geom/LineString.cpp, source/geom/LinearRing.cpp,
+	  source/geom/Location.cpp, source/geom/Makefile.am,
+	  source/headers/Makefile.am, source/headers/geom.h,
+	  source/index/bintree/BinTreeInterval.cpp,
+	  source/index/bintree/BinTreeNode.cpp,
+	  source/index/bintree/Bintree.cpp, source/index/bintree/Key.cpp,
+	  source/index/bintree/NodeBase.cpp, source/index/bintree/Root.cpp,
+	  source/index/quadtree/IntervalSize.cpp,
+	  source/index/strtree/Interval.cpp,
+	  source/index/sweepline/SweepLineInterval.cpp,
+	  source/index/sweepline/indexSweepLineEvent.cpp,
+	  source/io/ParseException.cpp, source/io/StringTokenizer.cpp,
+	  source/io/WKTReader.cpp, source/io/WKTWriter.cpp,
+	  source/io/Writer.cpp,
+	  source/operation/GeometryGraphOperation.cpp,
+	  source/operation/buffer/BufferSubgraph.cpp,
+	  source/operation/distance/ConnectedElementPointFilter.cpp,
+	  source/operation/overlay/EdgeSetNoder.cpp,
+	  source/operation/overlay/LineBuilder.cpp,
+	  source/operation/overlay/OverlayNodeFactory.cpp,
+	  source/operation/overlay/PointBuilder.cpp,
+	  source/operation/relate/EdgeEndBuilder.cpp,
+	  source/operation/relate/EdgeEndBundle.cpp,
+	  source/operation/relate/EdgeEndBundleStar.cpp,
+	  source/operation/relate/RelateNode.cpp,
+	  source/operation/relate/RelateNodeFactory.cpp,
+	  source/operation/relate/RelateNodeGraph.cpp,
+	  source/operation/valid/ConsistentAreaTester.cpp,
+	  source/operation/valid/TopologyValidationError.cpp,
+	  source/test/Makefile.am, source/test/XMLTester.cpp,
+	  source/util/CoordinateArrayFiter.cpp,
+	  source/util/GEOSException.cpp,
+	  source/util/IllegalArgumentException.cpp,
+	  source/util/UniqueCoordinateArrayFilter.cpp,
+	  source/util/UnsupportedOperationException.cpp: Norman's patch +
+	  global removal of "no newline" + small changes
+	  to make Norman's patch work in the linux build environment.
+2003-08-17 18:01  pramsey
+	* [r150] libtool: Removed more configuration files per Norman's
+	  request.
+2003-08-17 17:56  pramsey
+	* [r149] aclocal.m4, configure: Removed more configure files per
+	  Norman's request.
+2003-08-17 17:55  pramsey
+	* [r148] Makefile.in, macros/Makefile.in, source/Makefile.in,
+	  source/bigtest/Makefile.in, source/geom/Coordinate.cpp,
+	  source/geom/Makefile.in, source/headers/Makefile.in,
+	  source/test/Makefile.in, tools/Makefile.in: Removed Makefile.in
+	  files, per Norman's request.
+2003-08-16 06:33  ybychkov
+	* [r147] VisualStudio/GEOS.vcproj, source/algorithm/ConvexHull.cpp,
+	  source/bigtest/TestSweepLineSpeed.cpp,
+	  source/geom/BasicCoordinateList.cpp, source/geom/Coordinate.cpp,
+	  source/geom/CoordinateList.cpp, source/geom/Dimension.cpp,
+	  source/geom/IntersectionMatrix.cpp, source/geom/LineString.cpp,
+	  source/geom/LinearRing.cpp, source/geom/Location.cpp,
+	  source/geom/Point.cpp, source/geom/PointCoordinateList.cpp,
+	  source/geom/Polygon.cpp, source/geom/TopologyException.cpp,
+	  source/graph/Depth.cpp, source/graph/DirectedEdge.cpp,
+	  source/graph/DirectedEdgeStar.cpp, source/graph/Edge.cpp,
+	  source/graph/EdgeEnd.cpp, source/graph/EdgeEndStar.cpp,
+	  source/graph/EdgeIntersection.cpp,
+	  source/graph/Node.cpp, source/graph/NodeMap.cpp,
+	  source/graph/PlanarGraph.cpp, source/graph/TopologyLocation.cpp,
+	  source/graph/index/SweepLineEvent.cpp, source/headers/bigtest.h,
+	  source/headers/indexSweepline.h, source/headers/io.h,
+	  source/headers/opBuffer.h, source/headers/opDistance.h,
+	  source/headers/spatialIndex.h, source/headers/util.h,
+	  source/index/quadtree/QuadTreeRoot.cpp, source/io/WKTReader.cpp,
+	  source/operation/overlay/MaximalEdgeRing.cpp,
+	  source/operation/overlay/MinimalEdgeRing.cpp,
+	  source/test/Stackwalker.cpp, source/test/Stackwalker.h,
+	  source/test/XMLTester.cpp, source/util/CoordinateArrayFiter.cpp,
+	  source/util/UniqueCoordinateArrayFilter.cpp: Memory leak fixes.
+2003-06-21 22:17  pramsey
+	* [r146] source/geom/Makefile.am: GNU compile fixes from nvine.
+2003-06-19 20:54  ybychkov
+	* [r145] source/algorithm/CGAlgorithms.cpp,
+	  source/algorithm/InteriorPointArea.cpp,
+	  source/examples/CPCLException.cpp,
+	  source/examples/CoordinateListsExample.cpp,
+	  source/examples/CustomCoordinateListExample.cpp,
+	  source/examples/CustomPointCoordinateList.cpp,
+	  source/geom/Location.cpp, source/geom/MultiLineString.cpp,
+	  source/geom/MultiPoint.cpp, source/geom/MultiPolygon.cpp,
+	  source/geom/Polygon.cpp, source/geom/PrecisionModel.cpp,
+	  source/headers/bigtest.h, source/headers/geom.h,
+	  source/headers/indexChain.h, source/headers/indexQuadtree.h,
+	  source/headers/indexStrtree.h, source/headers/indexSweepline.h,
+	  source/headers/opRelate.h, source/headers/opValid.h,
+	  source/headers/util.h, source/index/bintree/BinTreeInterval.cpp,
+	  source/test/CTS.cpp, source/test/SimpleWKTTester.cpp,
+	  source/test/XMLTester.cpp, source/util/Assert.cpp,
+	  source/util/AssertionFailedException.cpp,
+	  source/util/UnsupportedOperationException.cpp: 'geos' namespace
+	  added.
+2003-06-18 20:08  ybychkov
+	* [r144] source/headers/opBuffer.h, source/operation/buffer,
+	  source/operation/buffer/RightmostEdgeFinder.cpp: Buffer is almost
+	  fully debugged.
+2003-05-29 00:05  pramsey
+	* [r143] source/bigtest/Makefile.am, source/geom/Makefile.am: Final
+	  GNU build adjustments.
+2003-05-28 23:55  pramsey
+	* [r142] source/examples/Makefile.am: Added new exception class.
+2003-05-28 23:39  pramsey
+	* [r141] source/headers/Makefile.am: Change reference to
+	  spatialIndex.h
+2003-05-28 23:22  pramsey
+	* [r140] source/geom/Makefile.am: Removed obsolete build entries
+	  for removed classes.
+2003-05-28 22:22  ybychkov
+	* [r139] source/headers/indexStrtree.h,
+	  source/index/strtree/Interval.cpp: Some bugfixes.
+2003-05-28 22:11  ybychkov
+	* [r138] source/index/bintree/Interval.cpp,
+	  source/index/bintree/Node.cpp, source/test/XMLTester.cpp: no
+	  message
+2003-05-28 05:02  pramsey
+	* [r137] source/index/strtree/Interval.cpp,
+	  source/index/strtree/SIRtree.cpp: Changed __max/__min to max/min
+2003-05-28 05:01  pramsey
+	* [r136] source/index/quadtree/IntervalSize.cpp: Change __max to
+	  max
+2003-05-27 23:56  pramsey
+	* [r135] source/geom/Makefile.am: Changed from mistaken cpp file
+	  names.
+2003-05-27 23:54  pramsey
+	* [r134] source/algorithm/CentroidArea.cpp: Added include for
+	  <typeinfo>
+2003-05-27 23:45  pramsey
+	* [r133] source/headers/indexStrtree.h: GNU build support
+2003-05-27 23:42  pramsey
+	* [r132] source/headers/indexQuadtree.h: Fix reference to
+	  spatialIndex header
+2003-05-27 23:41  pramsey
+	* [r131] source/headers/Makefile.in, source/headers/SpatialIndex.h,
+	  source/headers/geom.h, source/headers/indexStrtree.h,
+	  source/headers/spatialIndex.h: Build updates.
+2003-05-27 23:33  pramsey
+	* [r130] source/geom/Makefile.am: Add new files into build support
+2003-05-27 23:17  pramsey
+	* [r129] source/headers/Makefile.am: Add all new headers into the
+	  build process.
+2003-05-27 23:11  pramsey
+	* [r128] source/geom/Makefile.am, source/headers/Makefile.am: Some
+	  updates to synch build with devel.
+2003-05-21 23:28  ybychkov
+	* [r127] source/algorithm/MCPointInRing.cpp,
+	  source/geom/PrecisionModel.cpp, source/graph/GeometryGraph.cpp,
+	  source/index/bintree/Key.cpp,
+	  source/operation/relate/RelateOp.cpp: Several bugs fixed.
+2003-05-19 06:18  ybychkov
+	* [r126] source/algorithm/HCoordinate.cpp,
+	  source/geom/Point.cpp, source/geom/Polygon.cpp,
+	  source/graph/GeometryGraph.cpp, source/graph/Quadrant.cpp,
+	  source/io/ParseException.cpp, source/io/WKTReader.cpp,
+	  source/util/UnsupportedOperationException.cpp: All exceptions are
+	  now classes.
+2003-05-17 07:47  ybychkov
+	* [r125] source/algorithm/CentroidArea.cpp,
+	  source/index/quadtree/QuadTreeNodeBase.cpp: Last fix for CVS.
+2003-05-17 06:08  ybychkov
+	* [r124] source/algorithm/MCPointInRing.cpp,
+	  source/geom/GeometryFactory.cpp, source/graph/GeometryGraph.cpp,
+	  source/operation/valid/IsValidOp.cpp: Fixing CVS error.
+2003-05-17 00:27  ybychkov
+	* [r123] source/geom/GeometryCollection.cpp,
+	  source/headers/geosAlgorithm.h: Fixing a commit problem.
+2003-05-17 00:07  ybychkov
+	* [r122] source/algorithm/MCPointInRing.cpp,
+	  source/headers/graph.h, source/headers/opDistance.h,
+	  source/index/intervaltree, source/index/strtree/SIRtree.cpp,
+	  source/index/strtree/STRtree.cpp, source/operation/distance,
+	  source/operation/distance/PolygonExtracterFilter.cpp: SIRtree is
+	  done. Distance is done.
+2003-05-07 09:06  ybychkov
+	* [r121] source/algorithm/CentroidArea.cpp,
+	  source/algorithm/ConvexHull.java,
+	  source/algorithm/IntTreePointInRing.cpp,
+	  source/headers/SpatialIndex.h, source/headers/geosAlgorithm.h,
+	  source/headers/indexIntervaltree.h,
+	  source/index/bintree, source/index/bintree/BinTreeInterval.cpp,
+	  source/index/bintree/Interval.cpp, source/index/bintree/Key.cpp,
+	  source/index/bintree/Node.cpp, source/index/bintree/NodeBase.cpp,
+	  source/index/quadtree/Quad.cpp,
+	  source/index/quadtree/Quadtree.cpp, source/index/strtree,
+	  source/operation/valid/QuadtreeNestedRingTester.cpp: Closer to
+	  1.3
+2003-05-04 22:34  ybychkov
+	* [r120] source/algorithm/NonRobustCGAlgorithms.cpp,
+	  source/geom/PrecisionModel.cpp, source/graph/EdgeList.cpp,
+	  source/headers/graphindex.h, source/headers/opRelate.h,
+	  source/operation/valid/IsValidOp.cpp: Closer to JTS 1.3
+2003-04-28 06:01  ybychkov
+	* [r119] source/algorithm/CGAlgorithms.cpp,
+	  source/graph/index/SweepLineSegment.cpp, source/headers/geom.h,
+	  source/headers/graphindex.h, source/headers/opOverlay.h,
+	  source/index/intervaltree/IntervalNode.cpp,
+	  source/index/intervaltree/IntervalTree.cpp,
+	  source/util/Assert.cpp, source/util/AssertionFailedException.cpp:
+	  Partially upgraded to JTS 1.3
+2003-04-21 22:16  ybychkov
+	* [r118] VisualStudio, VisualStudio/GEOS.sln,
+	  VisualStudio/GEOS.vcproj: VisualStudio project added.
+2003-04-17 00:37  ybychkov
+	* [r117] source/geom/BasicCoordinateList.cpp,
+	  source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
+	  source/graph/GeometryGraph.cpp, source/io/WKTReader.cpp: Changed
+	  PrecisionModel to Value type. Removed bounds checking from *At
+	  methods in CoordinateLists.
+2003-04-12 04:31  ybychkov
+	* [r116] source/graph/EdgeRing.cpp,
+	  source/operation/overlay/OverlayOp.cpp: Overlay passes all tests
+	  (both precise and normal)
+2003-04-11 23:16  ybychkov
+	* [r115] source/geom/Geometry.cpp,
+	  source/geom/GeometryFactory.cpp, source/geom/LineString.cpp,
+	  source/headers/geom.h, source/io/WKTReader.cpp,
+	  source/test/XMLTester.cpp: Overlay almost works. Fails 2 tests.
+2003-04-10 04:34  ybychkov
+	* [r114] source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
+	  source/graph/Depth.cpp, source/graph/DirectedEdgeStar.cpp,
+	  source/test/XMLTester.cpp: Overlay passes all normal tests. Still
+	  fails on Precision tests.
+2003-04-09 21:52  pramsey
+	* [r113] source/headers/geom.h: Changed destructors to virtual to
+	  quiet GNU warnings
+2003-04-04 23:49  pramsey
+	* [r112] source/headers/Makefile.am: Install all headers at install
+	  time.
+2003-04-04 22:04  pramsey
+	* [r111] source/examples/CustomCoordinateListExample.cpp,
+	  source/examples/CustomPointCoordinateList.cpp: Newlines added to
+	  quiet gcc.
+2003-04-04 03:44  pramsey
+	* [r110] source/geom/Makefile.am: Build support
+2003-04-04 03:43  pramsey
+	* [r109] source/examples/Makefile.am: Build support.
+2003-04-04 03:28  pramsey
+	* [r108] source/geom/Makefile.am: Build support updates.
+2003-04-04 03:11  pramsey
+	* [r107] source/examples/Makefile.am: Build support for new example
+	  programs.
+2003-04-04 00:18  dblasby
+	* [r106] INSTALL: added comment about running ./autogen.sh
+2003-04-02 21:55  ybychkov
+	* [r105] source/examples/CustomCoordinateListExample.cpp,
+	  source/examples/CustomPointCoordinateList.cpp: Added example on
+	  how to wrap internal storage format with CoordinateLists.
+2003-04-02 08:02  ybychkov
+	* [r104] source/algorithm/MCPointInRing.cpp,
+	  source/geom/BasicCoordinateList.cpp, source/geom/LineString.cpp,
+	  source/graph/DirectedEdge.cpp, source/graph/EdgeEnd.cpp,
+	  source/graph/Node.cpp, source/headers/geom.h,
+	  source/headers/indexChain.h, source/headers/opOverlay.h,
+	  source/operation/valid/IsValidOp.cpp: isValid is debugged (passes
+	  all 805 tests).
+2003-03-24 19:23  pramsey
+	* [r103] source/headers/indexQuadtree.h,
+	  source/headers/indexSweepline.h: Added newlines to end to quiet
+	  gcc
+2003-03-24 19:21  pramsey
+	* [r102] Makefile.in, aclocal.m4, configure, configure.in, libtool,
+	  macros/Makefile.in, source/Makefile.am, source/Makefile.in,
+	  source/algorithm/Makefile.am, source/algorithm/Makefile.in,
+	  source/bigtest/Makefile.in, source/geom/Makefile.in,
+	  source/graph/Makefile.am, source/graph/Makefile.in,
+	  source/graph/index/Makefile.am, source/graph/index/Makefile.in,
+	  source/headers/Makefile.in, source/headers/config.h.in,
+	  source/headers/indexChain.h, source/headers/indexIntervaltree.h,
+	  source/io/Makefile.am, source/io/Makefile.in,
+	  source/io/markup/Makefile.am, source/io/markup/Makefile.in,
+	  source/operation/Makefile.am, source/operation/Makefile.in,
+	  source/operation/relate/Makefile.am,
+	  source/operation/relate/Makefile.in,
+	  source/operation/valid/Makefile.am, source/test/Makefile.in,
+	  source/util/Makefile.am, source/util/Makefile.in,
+	  tools/Makefile.in: Yet more GNU build fiddling. Removed
+	  extraneous build support from all
+	  non-geom library directories.
+2003-03-24 03:45  pramsey
+	* [r101] source/geom/Makefile.am: More GNU build support
+2003-03-24 03:07  pramsey
+	* [r100] Makefile.in, aclocal.m4, configure, configure.in, libtool,
+	  macros/Makefile.in, source/Makefile.in,
+	  source/algorithm/Makefile.in, source/bigtest/Makefile.in,
+	  source/geom/Makefile.am, source/geom/Makefile.in,
+	  source/graph/Makefile.in, source/graph/index/Makefile.in,
+	  source/headers/geosAlgorithm.h, source/headers/opValid.h,
+	  source/io/Makefile.in, source/io/markup/Makefile.in,
+	  source/operation/relate/Makefile.in, source/test/Makefile.in,
+	  source/test/XMLTester.cpp, source/util/Makefile.in,
+	  tools/Makefile.in: GNU build support on latest changes.
+2003-03-19 00:34  ybychkov
+	* [r99] source/algorithm/IntTreePointInRing.cpp,
+	  source/geom/Geometry.cpp, source/headers/geosAlgorithm.h,
+	  source/operation/overlay/OverlayOp.java: All Overlay classes are
+	  ported. Overlay and isValid have not been tested yet.
+2003-03-18 01:42  ybychkov
+	* [r98] source/geom/Geometry.cpp, source/graph/PlanarGraph.cpp,
+	  source/headers/opOverlay.h, source/headers/opValid.h,
+	  source/operation/overlay/OverlayOp.java,
+	  source/test/XMLTester.cpp: 90% of Overlay classes ported.
+2003-03-17 18:04  ybychkov
+	* [r97] source/algorithm/MCPointInRing.cpp,
+	  source/headers/geosAlgorithm.h, source/headers/indexChain.h,
+	  source/headers/indexIntervaltree.h, source/index/chain,
+	  source/index/intervaltree/IntervalTree.cpp: All 'index' packages
+	  and part of 'overlay' are done.
+2003-03-17 02:49  ybychkov
+	* [r96] source/algorithm/MCPointInRing.cpp,
+	  source/headers/geosAlgorithm.h, source/headers/opOverlay.h,
+	  source/headers/opValid.h, source/operation/overlay,
+	  source/operation/valid/IsValidOp.cpp: IsValid and supporting
+	  packages are ported (but NOT tested).
+2003-03-12 23:45  pramsey
+	* [r95] source/geom/Makefile.am, source/operation/Makefile.am,
+	  source/operation/valid/Makefile.am: Build support for valid.
+2003-03-10 10:18  ybychkov
+	* [r94] source/headers/indexQuadtree.h, source/headers/opOverlay.h,
+	  source/operation/valid/QuadtreeNestedRingTester.cpp: IsValid()
+	  and supporting index classes are ported, but don't work yet
+	  (external dependencies)
+2003-03-10 01:17  ybychkov
+	* [r93] source/headers/indexQuadtree.h,
+	  source/headers/indexSweepline.h, source/headers/opValid.h,
+	  source/index, source/index/quadtree,
+	  source/index/quadtree/Quadtree.cpp, source/index/sweepline,
+	  source/operation/valid,
+	  source/test/XMLTester.cpp: IsValid and supporting index classes
+	  are almost done.
+2003-03-05 17:04  pramsey
+	* [r92] configure.in, source/Makefile.am,
+	  source/examples/Makefile.am: Build support for new coordinateline
+	  examples.
+2003-03-05 08:02  ybychkov
+	* [r91] source/examples,
+	  CoordinateList interface example.
+2003-03-03 03:56  pramsey
+	* [r90] source/geom/Makefile.am: Remove PointInRing
+2003-03-03 03:35  pramsey
+	* [r89] source/algorithm/PointInRing.cpp: Removed unused file.
+2003-03-03 02:41  ybychkov
+	* [r88] source/algorithm/LineIntersector.cpp,
+	  source/graph/EdgeIntersectionList.cpp, source/io/WKTReader.cpp:
+	  Some Coordinate& related bugs fixed.
+2003-03-03 02:26  ybychkov
+	* [r87] source/geom/GeometryFactory.cpp: GeometryFactory bug fix.
+2003-03-03 00:46  ybychkov
+	* [r86] source/algorithm/CGAlgorithms.cpp,
+	  source/geom/LineSegment.cpp, source/geom/LineString.cpp,
+	  source/geom/PrecisionModel.cpp, source/graph/EdgeEndStar.cpp,
+	  source/graph/GeometryGraph.cpp, source/graph/Node.cpp,
+	  source/graph/index/SegmentIntersector.cpp, source/headers/geom.h,
+	  source/io/WKTReader.cpp, source/operation/IsSimpleOp.cpp,
+	  source/operation/relate/RelateNode.cpp, source/test/CTS.cpp,
+	  source/util/Assert.cpp: Second pass of code cleanup. Coordinate
+	  references and inlining.
+2003-03-02 03:47  ybychkov
+	* [r85] source/graph/Depth.cpp, source/graph/DirectedEdge.cpp,
+	  source/operation/relate/RelateNodeGraph.cpp: First pass of code
+	  cleanup completed over all packages.
+2003-03-01 06:10  pramsey
+	* [r84] source/headers/geosAlgorithm.h: Uncommented default
+	  constructor for PointInRing
+2003-03-01 06:08  pramsey
+	* [r83] source/test/SimpleWKTTester.cpp: Fixed call to geometry
+	  factory.
+2003-02-26 23:16  ybychkov
+	* [r82] source/algorithm/LineIntersector.cpp,
+	  source/headers/geosAlgorithm.h, source/headers/io.h,
+	  source/headers/util.h, source/io/StringTokenizer.cpp,
+	  source/io/Writer.cpp, source/test/XMLTester.cpp: All packages
+	  except 'graph' has been refactored.
+2003-02-20 03:32  pramsey
+	* [r81] source/test/SimpleWKTTester.cpp: Fixed small bug in call to
+	  GeometryFactory (instantiate PrecisionModel
+	  with new)
+2003-02-20 03:30  pramsey
+	* [r80] source/geom/CoordinateListFactory.cpp,
+	  source/geom/GeometryFactory.cpp: GFactory: Move i outside of for
+	  loop. Needed to compile GNU
+	  CListFactory: Add newline to end of file.
+2003-02-20 00:10  ybychkov
+	* [r79] source/geom/GeometryFactory.cpp, source/headers/opRelate.h,
+	  source/operation/relate/RelateOp.cpp: Geom and Operation
+	  (including Relate) packages are updated.
+2003-02-17 09:38  ybychkov
+	* [r78] source/geom/Envelope.cpp, source/geom/Geometry.cpp,
+	  source/graph/index/MonotoneChainEdge.cpp, source/headers/geom.h,
+	  source/headers/io.h, source/headers/opRelate.h,
+	  source/headers/operation.h, source/io/WKTWriter.cpp,
+	  source/operation/relate/RelateOp.cpp, source/test/XMLTester.cpp:
+	  GEOM package fully updated & bugs fixed.
+2003-02-17 00:40  ybychkov
+	* [r77] source/geom/Geometry.cpp, source/geom/MultiLineString.cpp,
+	  source/headers/geom.h, source/headers/io.h,
+	  source/io/WKTReader.cpp: GEOM package fully updated.
+2003-02-16 22:52  ybychkov
+	* [r76] source/bigtest/GeometryTestFactory.cpp,
+	  source/geom/LinearRing.cpp, source/geom/MultiLineString.cpp,
+	  source/graph/EdgeRing.cpp, source/headers/geom.h,
+	  source/io/WKTReader.cpp: GEOM package partially updated.
+2003-02-12 21:09  pramsey
+	* [r75] INSTALL, missing: Added two files required by autoconf
+	  build process.
+2003-02-12 20:51  pramsey
+	* [r74] configure, libtool, source/geom/Makefile.in,
+	  source/headers/Makefile.in, source/test/Makefile.in: Commit build
+	  support files.
+2003-02-12 19:11  pramsey
+	* [r73] source/headers/Makefile.am: Change header installation path
+	  to $(prefix)/include/geos.
+2003-02-12 06:50  pramsey
+	* [r72] source/algorithm/LineIntersector.cpp,
+	  source/operation/relate/EdgeEndBundle.cpp: Added newlines to
+	  quiet g++ warnings.
+2003-02-12 06:48  pramsey
+	* [r71] source/graph/Depth.cpp, source/graph/DirectedEdge.cpp,
+	  source/graph/DirectedEdgeStar.cpp, source/graph/EdgeEnd.cpp,
+	  source/graph/Label.cpp, source/graph/NodeFactory.cpp,
+	  source/graph/index/SweepLineEvent.cpp: Added newlines to ends of
+	  files to quiet g++ warnings.
+2003-02-12 06:27  pramsey
+	* [r70] source/test/XMLTester.cpp: Fix headers.
+2003-02-12 06:26  pramsey
+	* [r69] source/test/SimpleWKTTester.cpp: Changed headers.
+2003-02-12 06:24  pramsey
+	* [r68] source/bigtest/TestSweepLineSpeed.cpp: Added return value.
+	* [r67] source/bigtest/TestSweepLineSpeed.cpp, source/test/CTS.cpp,
+	  source/test/XMLTester.cpp: Changed headers.
+2003-02-12 06:19  pramsey
+	* [r66] source/test/XMLTester.cpp: Make path to test file relative.
+2003-02-12 06:18  pramsey
+	* [r65] source/bigtest/GeometryTestFactory.cpp: Change include
+	  reference syntax.
+2003-02-12 06:07  pramsey
+	* [r64] source/graph/EdgeEndStar.cpp: Remove NULL test.
+	* [r63] source/io/WKTWriter.cpp: Pass double to log().
+	* [r62] source/bigtest/TestSweepLineSpeed.cpp: Fixed main() return
+	  type.
+2003-02-12 06:04  pramsey
+	* [r61] source/test/Makefile.am: Remove old library references.
+2003-02-12 05:58  pramsey
+	* [r60] source/bigtest/TestSweepLineSpeed.cpp: Added stdio
+	  reference and newline at end.
+2003-02-12 00:58  pramsey
+	* [r59] source/test/test.xml: Added all JTS test cases to the file.
+2003-02-11 23:54  pramsey
+	* [r58] source/geom/Makefile.am: Added support for new cpp files.
+2003-02-11 23:33  ybychkov
+	* [r57] source/geom/CoordinateList.cpp, source/geom/Geometry.cpp,
+	  source/headers/geom.h: Some bugs fixed.
+2003-02-11 20:24  ybychkov
+	* [r56] source/geom/PointCoordinateList.cpp,
+	  source/graph/EdgeEndStar.cpp, source/headers/graph.h: Small
+	  changes in PointCoordinateList and EdgeEndStar.
+2003-02-11 19:01  mbdavis
+	* [r55] source/geom/Geometry.cpp: fixed duplicate for loop index
+2003-02-05 08:14  ybychkov
+	* [r54] source/bigtest/GeometryTestFactory.cpp,
+	  source/geom/CoordinateListFactory.cpp, source/geom/Geometry.cpp,
+	  source/geom/LinearRing.cpp, source/geom/MultiPoint.cpp,
+	  source/graph/Edge.cpp, source/graph/EdgeIntersectionList.cpp,
+	  Second pass of CoordinateList interface migration.
+2003-01-27 08:04  ybychkov
+	* [r53] source/algorithm/NonRobustCGAlgorithms.cpp,
+	  source/geom/BasicCoordinateList.cpp, source/geom/Envelope.cpp,
+	  source/geom/MultiLineString.cpp, source/geom/Point.cpp,
+	  source/headers/graphindex.h, source/headers/io.h,
+	  source/io/WKTReader.cpp: First pass of CoordinateList interface
+	  replacement.
+2003-01-27 07:56  ybychkov
+	* [r52] source/algorithm/CGAlgorithms.cpp: First pass of
+	  CoordinateList interface replacement.
+2003-01-27 07:26  ybychkov
+	* [r51] source/algorithm/CGAlgorithms.cpp: First pass of
+2002-12-02 09:48  ybychkov
+	* [r50] source/algorithm/CGAlgorithms.cpp,
+	  source/bigtest/TestSweepLineSpeed.cpp, source/geom/Geometry.cpp,
+	  source/geom/LinearRing.cpp, source/geom/Point.cpp,
+	  source/geom/Polygon.cpp, source/graph/Edge.cpp,
+	  source/headers/geosAlgorithm.h, source/headers/graph.h: More
+	  performance updates.
+2002-11-24 10:48  ybychkov
+	* [r49] source/algorithm/RobustLineIntersector.cpp,
+	  source/headers/geom.h, source/headers/graphindex.h: Some
+	  performance improvements.
+2002-11-14 23:43  pramsey
+	* [r48] configure.in, source/Makefile.am, source/Makefile.in,
+	  source/bigtest/Makefile.am, source/bigtest/Makefile.in,
+	  source/geom/Makefile.am, source/geom/Makefile.in: Build support
+	  for the bigtest programs.
+2002-11-08 19:49  ybychkov
+	* [r47] source/bigtest/TestSweepLineSpeed.cpp,
+	  source/geom/Coordinate.cpp, source/graph/Edge.cpp,
+	  source/headers/graph.h, source/headers/graphindex.h: Preformance
+	  is drastically improved
+2002-11-05 23:13  ybychkov
+	* [r46] source/bigtest, source/bigtest/GeometryTestFactory.cpp,
+	  source/operation/relate/RelateComputer.cpp: Code for generating
+	  large tests added.
+2002-10-31 07:37  ybychkov
+	* [r45] source/graph/index/SimpleMCSweepLineIntersector.cpp,
+	  source/io/StringTokenizer.cpp, source/test/XMLTester.cpp: XML
+	  tester is less fragile now.
+2002-10-30 21:59  pramsey
+	* [r44] config.guess, config.sub: Added configure support files for
+	  building w/o automake/autoconf
+2002-10-30 21:58  pramsey
+	* [r43] configure.in: Small changes to make autoconf happy.
+2002-10-30 20:04  pramsey
+	* [r42] source/test/test.xml: Edited test file to not crash
+	  XMLTester
+2002-10-30 19:54  pramsey
+	* [r41] Makefile.in, aclocal.m4, configure, configure.in, libtool,
+	  source/algorithm/Makefile.in, source/geom/Makefile.am,
+	  source/geom/Makefile.in, source/graph/Makefile.in,
+	  source/graph/index/Makefile.in, source/headers/Makefile.in,
+	  source/headers/config.h.in, source/headers/opRelate.h,
+	  source/operation/Makefile.in,
+	  source/operation/relate/Makefile.in, source/test/Makefile.am,
+	  source/test/Makefile.in, source/util/Makefile.in,
+	  tools/Makefile.in: New build changes necessary to build under
+	  Linux GNU.
+2002-10-23 02:21  nvine
+	* [r40] configure.in, source/Makefile.am, source/geom/Geometry.cpp,
+	  source/geom/GeometryCollection.cpp, source/geom/Makefile.am,
+	  source/geom/Polygon.cpp, source/graph/Depth.cpp,
+	  source/graph/PlanarGraph.cpp, source/graph/Quadrant.cpp,
+	  source/operation/relate/RelateComputer.cpp, source/test/CTS.cpp,
+	  source/test/SimpleWKTTester.cpp, source/test/XMLTester.cpp: GNU
+	  portability changes
+2002-10-17 07:12  ybychkov
+	* [r39] source/algorithm/SimplePointInAreaLocator.cpp,
+	  source/headers/graphindex.h, source/test/XMLTester.cpp: All test
+	  cases now work. Some are still too slow.
+2002-10-06 09:56  ybychkov
+	* [r38] source/algorithm/PointLocator.cpp,
+	  source/graph/DirectedEdgeStar.cpp, source/graph/EdgeEndStar.cpp,
+	  source/graph/GeometryGraph.cpp, source/graph/Label.cpp,
+	  source/graph/index/SweepLineEvent.cpp, source/headers/graph.h,
+	  source/test/XMLTester.cpp: Relate() is almost debugged.
+2002-09-12 14:08  fvilla
+	* [r37] Makefile.in, configure, configure.in, libtool,
+	  source/headers/Makefile.am, source/headers/Makefile.in,
+	  source/operation/relate/Makefile.in: Add makefile support for new
+	  files and dir
+2002-09-12 01:27  ybychkov
+	* [r36] source/geom/Geometry.cpp, source/geom/LineString.cpp,
+	  source/geom/MultiLineString.cpp, source/geom/MultiPoint.cpp,
+	  source/geom/Polygon.cpp, source/graph/DirectedEdgeStar.cpp,
+	  source/headers/graph.h, source/headers/opRelate.h,
+	  source/operation/relate,
+	  Relate is finished,but doesn't work yet.
+2002-09-10 13:46  fvilla
+	* [r35] configure, configure.in, libtool, source/Makefile.am,
+	  source/Makefile.in, source/geom/Makefile.am,
+	  source/geom/Makefile.in, source/operation/Makefile.am,
+	  source/operation/Makefile.in: Added operation/Makefiles
+2002-09-06 20:18  ybychkov
+	* [r34] source/algorithm/CGAlgorithms.cpp,
+	  source/algorithm/SimplePointInRing.cpp, source/geom/Envelope.cpp,
+	  source/graph/GeometryGraph.cpp, source/graph/NodeMap.cpp,
+	  source/headers/graph.h, source/headers/operation.h,
+	  source/operation, source/operation/GeometryGraphOperation.cpp,
+	  source/operation/IsSimpleOp.cpp: A lot of changes: Code is
+	  brought to version 1.2 of JTS. Compilable part of Operation
+	  added.
+2002-09-05 18:32  fvilla
+	* [r33] ChangeLog, Makefile.in, configure, configure.in, libtool,
+	  source/graph/index/Makefile.in, source/headers/Makefile.am,
+	  source/headers/Makefile.in, source/io/Makefile.in,
+	  source/io/markup/Makefile.in, source/test/Makefile.in,
+	  source/util/Makefile.in, tools/Makefile.in: Fixed version
+	  numbering. Whenever version numbers are bumped up the
+	  change should be reflected in the AC_INIT_AUTOMAKE macro in
+	  configure.in.
+	  I've put it at 0.0.1 - should be changed as appropriate. The
+	  version is
+	  #define'd for code being compiled as GEOS_VERSION.
+2002-09-03 16:04  pramsey
+	* [r32] source/test/Makefile.am: Changed reference to 'libgeom' to
+	  'libgeos'
+2002-09-03 13:53  fvilla
+	* [r31] Makefile.am, Makefile.in, acinclude.m4, aclocal.m4,
+	  configure, configure.in, install-sh, libtool, ltmain.sh, macros,
+	  macros/Makefile.am, macros/Makefile.in, macros/geos.m4,
+	  mkinstalldirs, source/Makefile.am, source/Makefile.in,
+	  source/headers/config.h.in, source/io/Makefile.am,
+	  source/io/Makefile.in, source/io/markup/Makefile.am,
+	  source/io/markup/Makefile.in, source/test/Makefile.am,
+	  source/test/Makefile.in, source/util/Makefile.am,
+	  source/util/Makefile.in, tools, tools/Makefile.am,
+	  tools/Makefile.in, tools/geos-config.in: * Add automake/autoconf
+	  support for one-lib compilation
+	  * add libtool support for shared libraries.
+	  --enable-shared={yes|no} and
+	  --enable-static={yes|no} control static and shared lib
+	  generation.
+	  * Makefile.in and configure files added to cvs (for users without
+	  automake)
+	  * add dir macros/ with a GEOS_INIT macro to be used in
+	  configure.in
+	  of other packages using geos (not used by geos itself)
+	  * add dir tools/ with geos-config script
+	  * the makefile in source/geom is the only one that generates a
+	  library - all others have the source files in EXTRA_DIST only
+	  * small glitch: 'make dist' will give errors trying to add the
+	  source files non local to source/geom to the archive using
+	  relative
+	  paths. Does not have consequences other than the error messages -
+	  will
+	  see if I can fix this. In general the one-lib, complex-tree
+	  solution is not
+	  easy to work with in automake.
+2002-09-01 18:08  pramsey
+	* [r30] source/algorithm/NotRepresentableException.cpp,
+	  source/algorithm/PointInRing.cpp,
+	  source/io/ParseException.cpp, source/io/WKTWriter.cpp,
+	  source/io/Writer.cpp, source/io/markup/MarkupSTL.cpp: Minor
+	  portability changes.
+2002-09-01 17:53  pramsey
+	* [r29] configure.in, source/Makefile.am,
+	  source/algorithm/Makefile.am: Changes to support algorithm
+	  directory in build structure.
+2002-09-01 17:51  pramsey
+	* [r28] source/geom/Coordinate.cpp, source/geom/CoordinateList.cpp,
+	  source/geom/Dimension.cpp, source/geom/Envelope.cpp,
+	  source/geom/LineString.cpp, source/geom/Location.cpp,
+	  source/geom/MultiPoint.cpp, source/geom/PrecisionModel.cpp: GNU
+	  compatibility fixes, changing __min/__max to min/max, adding
+	  stdio.h where needed, small syntax adjustments, newlines at
+	  end of files.
+2002-08-30 18:33  pramsey
+	* [r27] COPYING: Added LGPL licence text.
+2002-08-30 18:30  pramsey
+	* [r26] AUTHORS, Authors: Changed name of authors file as requested
+	  by autoconf.
+2002-08-30 18:28  pramsey
+	* [r25] autogen.sh: Removed --force-missing which did not work for
+	  my version of autoconf
+2002-08-30 18:16  pramsey
+	* [r24] ., .cvsignore, source, source/.cvsignore, source/geom,
+	  source/geom/.cvsignore, source/graph, source/graph/.cvsignore,
+	  source/graph/index, source/graph/index/.cvsignore, source/io,
+	  source/io/.cvsignore, source/io/markup,
+	  source/io/markup/.cvsignore, source/test, source/test/.cvsignore,
+	  source/util, source/util/.cvsignore: Added cvs ignore files.
+2002-08-30 18:15  pramsey
+	* [r23] source/test/CTS.cpp, source/test/SimpleWKTTester.cpp,
+	  source/test/WKTIn, source/test/WKTOut, source/test/XMLTester.cpp,
+	  source/test/test.xml: Added the testing files back into their new
+	  subdirectory.
+	* [r22] Authors, ChangeLog, Makefile.am, NEWS, README, autogen.sh,
+	  configure.in, source/CTS.cpp, source/Makefile.am,
+	  source/SimpleWKTTester.cpp, source/WKTIn, source/WKTOut,
+	  source/XMLTester.cpp, source/geom/Makefile.am,
+	  source/graph/Makefile.am, source/graph/index/Makefile.am,
+	  source/io/Makefile.am, source/io/markup/Makefile.am, source/test,
+	  source/test.xml, source/test/Makefile.am,
+	  source/util/Makefile.am: Added GNU autoconf support files
+	  submitted by Norman Vine. Moved test
+	  files to a new subdirectory.
+2002-08-30 15:52  ybychkov
+	* [r21] source/algorithm, source/algorithm/HCoordinate.cpp,
+	  source/headers/operation.h, source/headers/platform.h,
+	  source/headers/util.h, source/io/WKTWriter.cpp: 'algorithm' is
+	  almost complete
+2002-08-22 09:23  ybychkov
+	* [r20] source/graph/index, source/graph/index/MonotoneChain.cpp,
+	  source/headers/util.h: 'graph/index' finished. Some .h changes.
+2002-08-21 05:49  ybychkov
+	* [r19] source/graph/GeometryGraph.cpp, source/headers/graph.h,
+	  source/headers/graphindex.h: Some changes in 'graph'
+2002-08-20 21:08  ybychkov
+	* [r18] source/XMLTester.cpp, source/graph/Node.cpp,
+	  source/headers/graph.h, source/headers/io.h: Changed consts to
+	  enums
+2002-08-14 07:00  ybychkov
+	* [r17] Assert.cpp, AssertionFailedException.cpp, CTS.cpp,
+	  Coordinate.cpp, CoordinateList.cpp, Depth.cpp, Dimension.cpp,
+	  Envelope.cpp, Geometry.cpp, GeometryCollection.cpp,
+	  GeometryCollectionIterator.cpp, GeometryFactory.cpp,
+	  IntersectionMatrix.cpp, Label.cpp, LineSegment.cpp,
+	  LineString.cpp, LinearRing.cpp, Location.cpp, MarkupSTL.cpp,
+	  MarkupSTL.h, MultiLineString.cpp, MultiPoint.cpp,
+	  MultiPolygon.cpp, ParseException.cpp, Point.cpp, Polygon.cpp,
+	  Position.cpp, PrecisionModel.cpp, SimpleWKTTester.cpp,
+	  StringTokenizer.cpp, TopologyLocation.cpp, WKTIn, WKTOut,
+	  WKTReader.cpp, WKTWriter.cpp, Writer.cpp, XMLTester.cpp, geom.h,
+	  graph.h, io.h, operation.h, platform.h, source, source/CTS.cpp,
+	  source/XMLTester.cpp, source/geom, source/geom/Coordinate.cpp,
+	  source/geom/PrecisionModel.cpp, source/graph,
+	  source/graph/EdgeRing.cpp, source/graph/GraphComponent.cpp,
+	  source/graph/NodeFactory.cpp, source/graph/NodeMap.cpp,
+	  source/graph/TopologyLocation.cpp, source/headers,
+	  source/headers/io.h, source/headers/operation.h,
+	  source/headers/platform.h, source/headers/util.h, source/io,
+	  source/io/Writer.cpp, source/io/markup,
+	  source/io/markup/MarkupSTL.cpp, source/io/markup/MarkupSTL.h,
+	  source/test.xml, source/util, source/util/Assert.cpp,
+	  source/util/AssertionFailedException.cpp, test.xml, util.h: New
+	  structure of source.
+2002-07-11 07:57  ybychkov
+	* [r16] Assert.cpp, AssertionFailedException.cpp, Depth.cpp,
+	  Geometry.cpp, GeometryCollection.cpp, GeometryFactory.cpp,
+	  Label.cpp, Position.cpp, TopologyLocation.cpp, WKTReader.cpp,
+	  WKTWriter.cpp, XMLTester.cpp, graph.h, operation.h, test.xml,
+	  util.h: Assert and some graph classes
+2002-07-03 05:24  ybychkov
+	* [r15] MarkupSTL.cpp, MarkupSTL.h, XMLTester.cpp: started XML
+	  tester
+2002-07-02 06:41  ybychkov
+	* [r14] CTS.cpp, GeometryCollection.cpp,
+	  MultiPolygon.cpp, Polygon.cpp, SimpleWKTTester.cpp, WKTIn,
+	  WKTOut, WKTReader.cpp, WKTWriter.cpp, geom.h, io.h: 'io' and
+	  SimpleTester done
+2002-06-27 02:50  ybychkov
+	* [r13] CTS.cpp, StringTokenizer.cpp, WKTWriter.cpp, Writer.cpp,
+	  io.h: 'io' is almost done
+2002-06-26 09:10  ybychkov
+	* [r12] CTS.cpp, GeometryCollection.cpp, ParseException.cpp,
+	  Polygon.cpp, StringTokenizer.cpp, WKTReader.cpp, io.h: Some 'io'
+	  classes done.
+2002-06-21 07:13  ybychkov
+	* [r11] CTS.cpp, CoordinateList.cpp, Geometry.cpp,
+	  GeometryCollection.cpp, LineString.cpp, Point.cpp, Polygon.cpp,
+	  geom.h: 'geos': first pass done. Some external dependencies and
+	  polishing left.
+2002-06-20 08:58  ybychkov
+	* [r10] CTS.cpp, Geometry.cpp, GeometryCollection.cpp,
+	  GeometryCollectionIterator.cpp, GeometryFactory.cpp, geom.h: Only
+	  Geometry.java left
+2002-06-19 06:29  ybychkov
+	* [r9] CTS.cpp, CoordinateList.cpp, Geometry.cpp,
+	  GeometryCollection.cpp, LineString.cpp, LinearRing.cpp,
+	  MultiLineString.cpp, MultiPoint.cpp, MultiPolygon.cpp, Point.cpp,
+	  Polygon.cpp, geom.h: 'geom' mostly done.
+2002-06-14 07:46  ybychkov
+	* [r8] CTS.cpp, GeometryCollection.cpp, GeometryFactory.cpp,
+	  Polygon.cpp, geom.h: 'geom' almost done
+2002-06-12 01:47  ybychkov
+	* [r7] CoordinateList.cpp, LineString.cpp, geom.h: LineString is
+	  99% finished
+2002-06-11 23:43  ybychkov
+	* [r6] CTS.cpp, Coordinate.cpp, CoordinateList.cpp, Dimension.cpp,
+	  IntersectionMatrix.cpp, LineSegment.cpp, LineString.cpp,
+	  LinearRing.cpp, Location.cpp, Point.cpp, PrecisionModel.cpp,
+	  geom.h, operation.h, platform.h: 'geom' package 70% done
+2002-06-07 17:47  pramsey
+	* [r2] CTS.cpp, Coordinate.cpp, CoordinateList.cpp, Dimension.cpp,
+	  Envelope.cpp, LineSegment.cpp, Location.cpp, geom.h, platform.h:
+	  Initial revision
+2002-06-07 17:47  cvs
+	* [r1] .: New repository initialized by cvs2svn.
Modified: trunk/Makefile.am
--- trunk/Makefile.am	2009-05-14 19:31:45 UTC (rev 2512)
+++ trunk/Makefile.am	2009-05-21 09:56:03 UTC (rev 2513)
@@ -18,3 +18,6 @@
 EXTRA_DIST = acsite.m4 makefile.vc
 ACLOCAL_AMFLAGS = -I macros
+ChangeLog.svn:
+	svn2cl --authors=authors.svn -i -o ChangeLog.svn
Added: trunk/authors.svn
--- trunk/authors.svn	                        (rev 0)
+++ trunk/authors.svn	2009-05-21 09:56:03 UTC (rev 2513)
@@ -0,0 +1,11 @@
+strk:Sandro Santilli <strk at keybit.net>
+pramsey:
+warmerdam:Frank Warmerdam  <warmerdam at pobox.com>
+sgillies:
+mloskot:
+hobu:
+swongu:
+benjubb:
+csavage:
+ybychkov:
+fvilla:
More information about the geos-commits mailing list
