[geos-commits] r2724 - in trunk/source: headers/geos/index/strtree index/strtree
svn_geos at osgeo.org svn_geos at osgeo.org
Thu Nov 19 13:52:50 EST 2009
Author: strk
Date: 2009-11-19 13:52:45 -0500 (Thu, 19 Nov 2009)
New Revision: 2724
   trunk/source/headers/geos/index/strtree/AbstractNode.h
   trunk/source/index/strtree/AbstractNode.cpp
Don not allocate the container of STRtree node childs on the heap
Modified: trunk/source/headers/geos/index/strtree/AbstractNode.h
--- trunk/source/headers/geos/index/strtree/AbstractNode.h	2009-11-19 16:40:29 UTC (rev 2723)
+++ trunk/source/headers/geos/index/strtree/AbstractNode.h	2009-11-19 18:52:45 UTC (rev 2724)
@@ -37,17 +37,22 @@
 class GEOS_DLL AbstractNode: public Boundable {
 private:
-	std::vector<Boundable*> *childBoundables;
+	std::vector<Boundable*> childBoundables;
 	int level;
 public:
 	AbstractNode(int newLevel, int capacity=10);
 	virtual	~AbstractNode();
+	// TODO: change signature to return by ref,
+	// document ownership of the return
 	inline std::vector<Boundable*>* getChildBoundables() {
-		return childBoundables;
+		return &childBoundables;
 	inline const std::vector<Boundable*>* getChildBoundables() const {
Modified: trunk/source/index/strtree/AbstractNode.cpp
--- trunk/source/index/strtree/AbstractNode.cpp	2009-11-19 16:40:29 UTC (rev 2723)
+++ trunk/source/index/strtree/AbstractNode.cpp	2009-11-19 18:52:45 UTC (rev 2724)
@@ -31,24 +31,14 @@
  * the root node will have the highest level
 AbstractNode::AbstractNode(int newLevel, int capacity) {
-	childBoundables=new std::vector<Boundable*>();
-	childBoundables->reserve(capacity);
+	childBoundables.reserve(capacity);
 	bounds=NULL;
 	level=newLevel;
 AbstractNode::~AbstractNode() {
-	delete childBoundables;
-* Returns either child AbstractNodes, or if this is a leaf node, real data (wrapped
-* in ItemBoundables).
-//vector<Boundable*>* AbstractNode::getChildBoundables() {
-	//return childBoundables;
 const void *
 AbstractNode::getBounds() const
@@ -72,7 +62,7 @@
 void AbstractNode::addChildBoundable(Boundable *childBoundable) {
 	assert(bounds==NULL);
-	childBoundables->push_back(childBoundable);
+	childBoundables.push_back(childBoundable);
 } // namespace geos.index.strtree
More information about the geos-commits mailing list
