[geos-commits] r2645 - trunk/tests/xmltester/tests
svn_geos at osgeo.org svn_geos at osgeo.org
Thu Oct 1 03:24:19 EDT 2009
Author: strk
Date: 2009-10-01 03:24:19 -0400 (Thu, 01 Oct 2009)
New Revision: 2645
   trunk/tests/xmltester/tests/singlesidedbuffer.xml
Re-enable the now succeeding test for sharp edges line single sided buffering
Modified: trunk/tests/xmltester/tests/singlesidedbuffer.xml
--- trunk/tests/xmltester/tests/singlesidedbuffer.xml	2009-10-01 07:23:07 UTC (rev 2644)
+++ trunk/tests/xmltester/tests/singlesidedbuffer.xml	2009-10-01 07:24:19 UTC (rev 2645)
@@ -71,13 +71,11 @@
 <a>
 LINESTRING (5 5,1 1,1.5 3)
 </a>
-<!-- right-side returns with empty geometry !
 <test>
 <op name="buffersinglesided" arg1="a" arg2="1.6" arg3="4" arg4="right">
 MULTILINESTRING ((0.889806640162438 3.15254833995939,3.86862915010152 6.13137084989848))
 </op>
 </test>
 <test>
 <op name="buffersinglesided" arg1="a" arg2="1.6" arg3="4" arg4="left">
 MULTILINESTRING ((6.13137084989848 3.86862915010152,2.13137084989848 -0.131370849898476,1.64334932914975 -0.464957897238882,1.06750928729122 -0.598575145599803,0.482454087349093 -0.513983562756987,-0.0319550194114402 -0.222730075655103,-0.405500120335007 0.235428609129087,-0.58719153245376 0.797952878498393,-0.552228000232531 1.38805700005813,-0.052228000232531 3.38805700005813))
More information about the geos-commits mailing list
