[geos-commits] r2678 - in trunk/source: geom headers/geos/geom
svn_geos at osgeo.org svn_geos at osgeo.org
Sat Oct 17 08:28:41 EDT 2009
Author: strk
Date: 2009-10-17 08:28:41 -0400 (Sat, 17 Oct 2009)
New Revision: 2678
   trunk/source/geom/CoordinateArraySequence.cpp
   trunk/source/geom/Polygon.cpp
   trunk/source/headers/geos/geom/CoordinateArraySequence.h
   trunk/source/headers/geos/geom/CoordinateSequence.h
Expose a usable toVector method for CoordinateSequence (ie: no memory management issues). Use it from Polygon::getCoordinates.
Modified: trunk/source/geom/CoordinateArraySequence.cpp
--- trunk/source/geom/CoordinateArraySequence.cpp	2009-10-17 12:02:56 UTC (rev 2677)
+++ trunk/source/geom/CoordinateArraySequence.cpp	2009-10-17 12:28:41 UTC (rev 2678)
@@ -72,6 +72,14 @@
 	return vect; //new vector<Coordinate>(vect->begin(),vect->end());
+void
+CoordinateArraySequence::toVector(vector<Coordinate>& out) const
+	assert(0 != vect);
+	// TODO: can this be optimized ?
+	out.insert(out.end(), vect->begin(), vect->end());
 bool
 CoordinateArraySequence::isEmpty() const
Modified: trunk/source/geom/Polygon.cpp
--- trunk/source/geom/Polygon.cpp	2009-10-17 12:02:56 UTC (rev 2677)
+++ trunk/source/geom/Polygon.cpp	2009-10-17 12:28:41 UTC (rev 2678)
@@ -107,38 +107,21 @@
 		return getFactory()->getCoordinateSequenceFactory()->create(NULL);
-	size_t i, j, npts;
-	size_t nholes=holes->size();
 	vector<Coordinate> *cl = new vector<Coordinate>;
+	// reserve space in the vector for all the polygon points
+	cl->reserve(getNumPoints());
 	// Add shell points
 	const CoordinateSequence* shellCoords=shell->getCoordinatesRO();
-	npts=shellCoords->getSize();
+	shellCoords->toVector(*cl);
-	 * reserve space in the vector for all the polygon points
-	cl->reserve(getNumPoints());
-	for (j=0; j<npts; ++j)
+	// Add holes points
+	size_t nholes=holes->size();
+	for (size_t i=0; i<nholes; ++i)
-		// This can be optimized by having CoordinateSequence
-		// expose a method to push all coords to a vector
-		cl->push_back(shellCoords->getAt(j));
-	for (i=0; i<nholes; ++i)
-		// Add hole points
 		const CoordinateSequence* childCoords=((LinearRing *)(*holes)[i])->getCoordinatesRO();
-		npts=childCoords->getSize();
-			cl->push_back(childCoords->getAt(j));
+		childCoords->toVector(*cl);
 	return getFactory()->getCoordinateSequenceFactory()->create(cl);
Modified: trunk/source/headers/geos/geom/CoordinateArraySequence.h
--- trunk/source/headers/geos/geom/CoordinateArraySequence.h	2009-10-17 12:02:56 UTC (rev 2677)
+++ trunk/source/headers/geos/geom/CoordinateArraySequence.h	2009-10-17 12:28:41 UTC (rev 2678)
@@ -51,8 +51,13 @@
 	//int size() const;
 	size_t getSize() const;
+	// @deprecated
 	const std::vector<Coordinate>* toVector() const;
+	// See dox in CoordinateSequence.h
+	void toVector(std::vector<Coordinate>&) const;
 	/// Construct an empty sequence
 	CoordinateArraySequence();
Modified: trunk/source/headers/geos/geom/CoordinateSequence.h
--- trunk/source/headers/geos/geom/CoordinateSequence.h	2009-10-17 12:02:56 UTC (rev 2677)
+++ trunk/source/headers/geos/geom/CoordinateSequence.h	2009-10-17 12:28:41 UTC (rev 2678)
@@ -142,9 +142,17 @@
 	 * We opted for the second, so the returned object is a const, to
 	 * also ensure that returning an internal pointer doesn't make
 	 * the object mutable.
+	 * @deprecated use toVector(std::vector<Coordinate>&) instead
 	virtual	const std::vector<Coordinate>* toVector() const=0;
+	/// Pushes all Coordinates of this sequence onto the provided vector.
+	/// This method is a port of the toCoordinateArray() method of JTS.
+	virtual	void toVector(std::vector<Coordinate>& coords) const=0;
 	 * \brief Add an array of coordinates
 	 * @param vc The coordinates
More information about the geos-commits mailing list
