[geos-commits] r3091 - trunk/include/geos/geom
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Aug 23 11:10:59 EDT 2010
Author: strk
Date: 2010-08-23 15:10:59 +0000 (Mon, 23 Aug 2010)
New Revision: 3091
   trunk/include/geos/geom/BinaryOp.h
Add more debugging calls (for bug #358)
Modified: trunk/include/geos/geom/BinaryOp.h
--- trunk/include/geos/geom/BinaryOp.h	2010-08-23 13:38:33 UTC (rev 3090)
+++ trunk/include/geos/geom/BinaryOp.h	2010-08-23 15:10:59 UTC (rev 3091)
@@ -116,7 +116,7 @@
 	operation::valid::IsValidOp ivo(&g);
 	if ( ! ivo.isValid() )
-		std::cerr << label << ": is invalid!"
+		std::cerr << label << " is INVALID: "
 			<< ivo.getValidationError()->toString() << std::endl;
 		return false;
@@ -184,7 +184,7 @@
 	GeomPtr result( _Op(snapG0.get(), snapG1.get()) );
 #if GEOS_DEBUG_BINARYOP
-	check_valid(*result, "Op result (before common-bits addition");
+	check_valid(*result, "SNAP: result (before common-bits addition");
 #endif
 #if CBR_BEFORE_SNAPPING
@@ -193,7 +193,7 @@
 #endif
-	check_valid(*result, "Op result (after common-bits addition");
+	check_valid(*result, "SNAP: result (after common-bits addition");
 #endif
 	return result;
@@ -237,7 +237,7 @@
 		precision::CommonBitsRemover cbr;
-		std::cerr << "Trying with Common bits remover." << std::endl;
+		std::cerr << "Trying with Common Bits Remover (CBR)" << std::endl;
 #endif
 		cbr.add(g0);
@@ -247,21 +247,22 @@
 		rG1.reset( cbr.removeCommonBits(g1->clone()) );
-		if ( ! rG0->isValid() )
-			std::cerr << " CBR: geom 0 is invalid!" << std::endl;
-		if ( ! rG1->isValid() )
-			std::cerr << " CBR: geom 1 is invalid!" << std::endl;
+		check_valid(*rG0, "CBR: geom 0 (after common-bits removal)");
+		check_valid(*rG1, "CBR: geom 1 (after common-bits removal)");
 #endif
 		ret.reset( _Op(rG0.get(), rG1.get()) );
+#if GEOS_DEBUG_BINARYOP
+		check_valid(*ret, "CBR: result (before common-bits addition)");
+#endif
 		cbr.addCommonBits( ret.get() );
+		check_valid(*ret, "CBR: result (after common-bits addition)");
+#endif
 		return ret;
 	catch (const util::TopologyException& ex)
More information about the geos-commits mailing list
