[geos-commits] r3140 - in trunk: include/geos/operation/overlay/snap src/operation/overlay/snap
svn_geos at osgeo.org svn_geos at osgeo.org
Thu Dec 2 04:36:16 EST 2010
Author: strk
Date: 2010-12-02 01:36:16 -0800 (Thu, 02 Dec 2010)
New Revision: 3140
   trunk/include/geos/operation/overlay/snap/GeometrySnapper.h
   trunk/src/operation/overlay/snap/GeometrySnapper.cpp
Take GeometrySnapper forward to r309 (JTS-1.11+): add self-snapping
Modified: trunk/include/geos/operation/overlay/snap/GeometrySnapper.h
--- trunk/include/geos/operation/overlay/snap/GeometrySnapper.h	2010-11-30 08:31:28 UTC (rev 3139)
+++ trunk/include/geos/operation/overlay/snap/GeometrySnapper.h	2010-12-02 09:36:16 UTC (rev 3140)
@@ -14,7 +14,7 @@
- * Last port: operation/overlay/snap/GeometrySnapper.java rev 1.8 (JTS-1.10)
+ * Last port: operation/overlay/snap/GeometrySnapper.java r309 (JTS-1.11+)
@@ -41,8 +41,19 @@
 namespace snap { // geos::operation::overlay::snap
 /** \brief
- * Snaps the vertices and segments of a geometry to another's vertices.
- * Should improve robustness for overlay operations.
+ * Snaps the vertices and segments of a {@link Geometry}
+ * to another Geometry's vertices.
+ * A snap distance tolerance is used to control where snapping is performed.
+ * Snapping one geometry to another can improve
+ * robustness for overlay operations by eliminating
+ * nearly-coincident edges
+ * (which cause problems during noding and intersection calculation).
+ * Too much snapping can result in invalid topology
+ * beging created, so the number and location of snapped vertices
+ * is decided using heuristics to determine when it
+ * is safe to snap.
+ * This can result in some potential snaps being omitted, however.
 class GEOS_DLL GeometrySnapper {
@@ -64,6 +75,9 @@
 	                        const geom::Geometry& g1,
 	                        double snapTolerance, GeomPtrPair& ret);
+	static GeomPtr snapToSelf(const geom::Geometry& g0,
+	                        double snapTolerance, bool cleanResult);
 	 * Creates a new snapper acting on the given geometry
@@ -88,6 +102,18 @@
 	                                     double snapTolerance);
 	/** \brief
+	 * Snaps the vertices in the component {@link LineString}s
+	 * of the source geometry to the vertices of itself
+	 * with a given snap tolerance and optionally cleaning the result.
+	 * @param snapTolerance
+	 * @param cleanResult clean the result
+	 * @return a new snapped Geometry
+	std::auto_ptr<geom::Geometry> snapToSelf(double snapTolerance,
+	                                         bool cleanResult);
+	/** \brief
 	 * Estimates the snap tolerance for a Geometry, taking into account
 	 * its precision model.
Modified: trunk/src/operation/overlay/snap/GeometrySnapper.cpp
--- trunk/src/operation/overlay/snap/GeometrySnapper.cpp	2010-11-30 08:31:28 UTC (rev 3139)
+++ trunk/src/operation/overlay/snap/GeometrySnapper.cpp	2010-12-02 09:36:16 UTC (rev 3140)
@@ -14,7 +14,7 @@
@@ -22,6 +22,8 @@
 #include <geos/operation/overlay/snap/LineStringSnapper.h>
 #include <geos/geom/util/GeometryTransformer.h> // inherit. of SnapTransformer
 #include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/MultiPolygon.h>
 #include <geos/geom/Coordinate.h>
 #include <geos/geom/GeometryFactory.h>
 #include <geos/geom/CoordinateSequenceFactory.h>
@@ -41,7 +43,7 @@
 namespace overlay { // geos.operation.overlay
 namespace snap { // geos.operation.overlay.snap
-const double GeometrySnapper::snapPrecisionFactor = 10e-10;
+const double GeometrySnapper::snapPrecisionFactor = 1e-9;
 class SnapTransformer: public geos::geom::util::GeometryTransformer {
@@ -115,6 +117,33 @@
 	return snapTrans->transform(&srcGeom);
+/*public*/
+std::auto_ptr<geom::Geometry>
+GeometrySnapper::snapToSelf(double snapTolerance, bool cleanResult)
+	using std::auto_ptr;
+	using geom::util::GeometryTransformer;
+	// Get snap points
+	auto_ptr<Coordinate::ConstVect> snapPts=extractTargetCoordinates(srcGeom);
+	// Apply a SnapTransformer to source geometry
+	// (we need a pointer for dynamic polymorphism)
+	auto_ptr<GeometryTransformer> snapTrans(new SnapTransformer(snapTolerance, *snapPts));
+	GeomPtr result = snapTrans->transform(&srcGeom);
+	if (cleanResult && ( dynamic_cast<const Polygon*>(result.get()) ||
+	                     dynamic_cast<const MultiPolygon*>(result.get()) ) )
+		// TODO: use better cleaning approach
+		result.reset(result->buffer(0));
+	return result;
 /*public static*/
 double
 GeometrySnapper::computeSizeBasedSnapTolerance(const geom::Geometry& g)
@@ -169,13 +198,12 @@
 	GeometrySnapper snapper0(g0);
 	snapGeom.first = snapper0.snapTo(g1, snapTolerance);
-	GeometrySnapper snapper1(g1);
 	 * Snap the second geometry to the snapped first geometry
 	 * (this strategy minimizes the number of possible different
 	 * points in the result)
+	GeometrySnapper snapper1(g1);
 	snapGeom.second = snapper1.snapTo(*snapGeom.first, snapTolerance);
 //	cout << *snapGeom.first << endl;
@@ -183,6 +211,15 @@
+/* public static */
+GeometrySnapper::GeomPtr
+GeometrySnapper::snapToSelf(const geom::Geometry& g,
+                      bool cleanResult)
+	GeometrySnapper snapper0(g);
+	return snapper0.snapToSelf(snapTolerance, cleanResult);
 } // namespace geos.operation.snap
 } // namespace geos.operation.overlay
More information about the geos-commits mailing list
