[geos-commits] r3143 - trunk/tests/unit/operation/overlay/snap
svn_geos at osgeo.org svn_geos at osgeo.org
Thu Dec 2 09:16:37 EST 2010
Author: strk
Date: 2010-12-02 06:16:37 -0800 (Thu, 02 Dec 2010)
New Revision: 3143
   trunk/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp
tab to 8 spaces
Modified: trunk/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp
--- trunk/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp	2010-12-02 10:32:06 UTC (rev 3142)
+++ trunk/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp	2010-12-02 14:16:37 UTC (rev 3143)
@@ -23,27 +23,27 @@
     // Common data used by tests
     struct test_geometrysnapper_data
-	typedef std::auto_ptr<geos::geom::Geometry> GeomAutoPtr;
+        typedef std::auto_ptr<geos::geom::Geometry> GeomAutoPtr;
-	geos::geom::GeometryFactory factory;
+        geos::geom::GeometryFactory factory;
-	geos::io::WKTReader reader;
+        geos::io::WKTReader reader;
-	GeomAutoPtr src;
+        GeomAutoPtr src;
-	geos::operation::overlay::snap::GeometrySnapper snapper;
+        geos::operation::overlay::snap::GeometrySnapper snapper;
         test_geometrysnapper_data()
-		factory(), // initialize before use!
-		reader(&factory),
-		src(reader.read(
-			"POLYGON ((0 0, 0 100, 100 100, 100 0, 0 0))"
-		snapper( *(src.get()) )
+                factory(), // initialize before use!
+                reader(&factory),
+                src(reader.read(
+                        "POLYGON ((0 0, 0 100, 100 100, 100 0, 0 0))"
+                snapper( *(src.get()) )
     typedef test_group<test_geometrysnapper_data> group;
@@ -60,17 +60,17 @@
     template<>
     void object::test<1>()
-	GeomAutoPtr snap(reader.read(
-		"MULTIPOINT ((0 0), (0 100.0000001), (100 100), (100 0))"
+        GeomAutoPtr snap(reader.read(
+                "MULTIPOINT ((0 0), (0 100.0000001), (100 100), (100 0))"
-	GeomAutoPtr expected(reader.read(
-		"POLYGON ((0 0, 0 100.0000001, 100 100, 100 0, 0 0))"
+        GeomAutoPtr expected(reader.read(
+                "POLYGON ((0 0, 0 100.0000001, 100 100, 100 0, 0 0))"
-	GeomAutoPtr ret(snapper.snapTo( *(snap.get()), 0.000001 ));
+        GeomAutoPtr ret(snapper.snapTo( *(snap.get()), 0.000001 ));
-	ensure( ret->equalsExact(expected.get(),0) );
+        ensure( ret->equalsExact(expected.get(),0) );
@@ -79,17 +79,17 @@
     template<>
     void object::test<2>()
-		"MULTIPOINT ((0.0000001 50))"
+                "MULTIPOINT ((0.0000001 50))"
-		"POLYGON ((0 0, 0.0000001 50, 0 100, 100 100, 100 0, 0 0))"
+                "POLYGON ((0 0, 0.0000001 50, 0 100, 100 100, 100 0, 0 0))"
More information about the geos-commits mailing list
