[geos-commits] r3148 - in trunk/php: . test
svn_geos at osgeo.org
Thu Dec 2 11:48:24 EST 2010
Author: strk
Date: 2010-12-02 08:48:24 -0800 (Thu, 02 Dec 2010)
New Revision: 3148
trunk/php/geos.c
trunk/php/test/test.php
Expose GEOSSnap to PHP interface
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-12-02 16:44:03 UTC (rev 3147)
+++ trunk/php/geos.c 2010-12-02 16:48:24 UTC (rev 3148)
@@ -225,6 +225,7 @@
PHP_METHOD(Geometry, length);
PHP_METHOD(Geometry, distance);
PHP_METHOD(Geometry, hausdorffDistance);
+PHP_METHOD(Geometry, snapTo);
static function_entry Geometry_methods[] = {
PHP_ME(Geometry, __construct, NULL, 0)
@@ -281,6 +282,7 @@
PHP_ME(Geometry, length, NULL, 0)
PHP_ME(Geometry, distance, NULL, 0)
PHP_ME(Geometry, hausdorffDistance, NULL, 0)
+ PHP_ME(Geometry, snapTo, NULL, 0)
{NULL, NULL, NULL}
@@ -1680,7 +1682,32 @@
RETURN_DOUBLE(dist);
+ GEOSGeometry *this;
+ GEOSGeometry *other;
+ GEOSGeometry *ret;
+ double tolerance;
+ zval *zobj;
+ this = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "od", &zobj,
+ &tolerance) == FAILURE) {
+ RETURN_NULL();
+ other = getRelay(zobj, Geometry_ce_ptr);
+ ret = GEOSSnap(this, other, tolerance);
+ if ( ! ret ) RETURN_NULL(); /* should get an exception first */
+ /* return_value is a zval */
+ object_init_ex(return_value, Geometry_ce_ptr);
+ setRelay(return_value, ret);
/* -- class GEOSWKTReader -------------------- */
PHP_METHOD(WKTReader, __construct);
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2010-12-02 16:44:03 UTC (rev 3147)
+++ trunk/php/test/test.php 2010-12-02 16:48:24 UTC (rev 3148)
@@ -1778,6 +1778,25 @@
+ public function testGeometry_snapTo()
+ $reader = new GEOSWKTReader();
+ $writer = new GEOSWKTWriter();
+ $writer->setTrim(true);
+ $g = $reader->read('POLYGON ((0 0, 1 0, 1 1, 0 1, 0 0))');
+ $g2 = $reader->read('POINT(0.1 0)');
+ $snapped = $g->snapTo($g2, 0);
+ $this->assertEquals('POLYGON ((0 0, 1 0, 1 1, 0 1, 0 0))'
+ , $writer->write($snapped) );
+ $snapped = $g->snapTo($g2, 0.5);
+ $this->assertEquals('POLYGON ((0.1 0, 1 0, 1 1, 0 1, 0.1 0))'
public function testWKBWriter__construct()
$writer = new GEOSWKBWriter();
More information about the geos-commits
