[geos-commits] r3157 - trunk/tests/unit/operation/overlay/snap
svn_geos at osgeo.org
Fri Dec 3 12:26:55 EST 2010
Author: strk
Date: 2010-12-03 09:26:55 -0800 (Fri, 03 Dec 2010)
New Revision: 3157
trunk/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp
Add test for src-vertex snapping allowance
Modified: trunk/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp
--- trunk/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp 2010-12-03 14:02:34 UTC (rev 3156)
+++ trunk/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp 2010-12-03 17:26:55 UTC (rev 3157)
@@ -245,5 +245,91 @@
+ // Test allow snapping to source vertices
+ template<>
+ template<>
+ void object::test<7>()
+ using geos::geom::Coordinate;
+ using geos::operation::overlay::snap::LineStringSnapper;
+ typedef std::auto_ptr<Coordinate::Vect> CoordsVectAptr;
+ // Source: (0 0, 10 0, 0 1)
+ Coordinate src_a(0, 0);
+ Coordinate src_b(10, 0);
+ Coordinate src_c(0, 1);
+ Coordinate::Vect srcCoords;
+ srcCoords.push_back(src_a);
+ srcCoords.push_back(src_b);
+ srcCoords.push_back(src_c);
+ // Snap: (0 0)
+ Coordinate snp_a(0, 0);
+ Coordinate::ConstVect snpCoords;
+ snpCoords.push_back( &snp_a );
+ // Snap with tolerance of 1
+ // (both first and second point could be snapped)
+ LineStringSnapper snapper(srcCoords, 1);
+ // Allow source-snapping, expect: (0 0, 5 0, 0 0, 10 0)
+ snapper.setAllowSnappingToSourceVertices(true);
+ CoordsVectAptr ret(snapper.snapTo(snpCoords));
+ ensure_equals(ret->size(), 4u);
+ ensure_equals(ret->operator[](0), src_a);
+ ensure_equals(ret->operator[](1), src_b);
+ ensure_equals(ret->operator[](2), snp_a);
+ ensure_equals(ret->operator[](3), src_c);
+ // Do not allow source-snapping, expect: (0 0, 5 0, 10 0)
+ snapper.setAllowSnappingToSourceVertices(false);
+ ret = snapper.snapTo(snpCoords);
+ ensure_equals(ret->size(), 3u);
+ ensure_equals(ret->operator[](2), src_c);
+ // Test two candidate vertices snaps
+/* The following one fails, I bet in JTS too.. but haven't tested
+ template<>
+ template<>
+ void object::test<8>()
+ // Source: (0 0, 1 0, 1 1)
+ Coordinate src_b(1, 0);
+ Coordinate src_c(1, 1);
+ // Snap: (0.5, 0)
+ Coordinate snp_a(0.5, 0);
+ // Expect: (0.5 0, 1 0, 1 1)
+ ensure_equals(ret->operator[](0), snp_a);
} // namespace tut
More information about the geos-commits
