[geos-commits] r2875 - trunk
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Jan 18 19:03:59 EST 2010
Author: mloskot
Date: 2010-01-18 19:03:58 -0500 (Mon, 18 Jan 2010)
New Revision: 2875
   trunk/CMakeLists.txt
#317: Added CXX flags specific to Visual C++ compiler. Added ENABLE_MSVC_MP option to allow setting Visual C++ /MP flag that enables multi-process compilation.
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt	2010-01-18 21:15:43 UTC (rev 2874)
+++ trunk/CMakeLists.txt	2010-01-19 00:03:58 UTC (rev 2875)
@@ -47,10 +47,37 @@
 if(CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
-  set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -pedantic -Wall -Wno-long-long -ansi")
-  set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -fPIC")
+  list(APPEND CMAKE_CXX_FLAGS "-pedantic -ansi")
+  list(APPEND CMAKE_CXX_FLAGS "-Wall -Wno-long-long")
+  list(APPEND CMAKE_CXX_FLAGS "-fPIC")
+elseif(MSVC)
+  # Set pedantic mode by default
+  set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /W4")
+  if(MSVC80 OR MSVC90 OR MSVC10)
+    # Option is to enable the /MP switch for Visual Studio 2005 or later
+    option(ENABLE_MSVC_MP
+      "Set to ON to build GEOS with the /MP option (Visual Studio 2005 and above)." OFF)
+    mark_as_advanced(ENABLE_MSVC_MP)
+    if(ENABLE_MSVC_MP)
+      set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /MP")
+    endif()
+    message(STATUS "Setting Visual Studio 2005+ option /MP to ${ENABLE_MSVC_MP}")
+    # Disable C4996: 'function': was declared deprecated
+    add_definitions(-D_SCL_SECURE_NO_WARNINGS)
+    add_definitions(-D_CRT_SECURE_NO_WARNINGS)
+  endif()
 endif()
+# DEBUG
+#message(STATUS "XXX: CMAKE_CXX_FLAGS=${CMAKE_CXX_FLAGS}")
 # Setup C/C++ library features
More information about the geos-commits mailing list
