[geos-commits] r2897 - trunk
svn_geos at osgeo.org svn_geos at osgeo.org
Sat Jan 30 20:22:08 EST 2010
Author: mloskot
Date: 2010-01-30 20:22:07 -0500 (Sat, 30 Jan 2010)
New Revision: 2897
   trunk/CMakeLists.txt
A minor fix to order of enable_testing() and add_subdirectories(tests) - it is important to include the former macro first so the tests are caught in
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt	2010-01-30 23:45:09 UTC (rev 2896)
+++ trunk/CMakeLists.txt	2010-01-31 01:22:07 UTC (rev 2897)
@@ -219,23 +219,14 @@
   ${CMAKE_CURRENT_BINARY_DIR}/capi/geos_c.h @ONLY)
-# Configure subdirectories
-add_subdirectory(include)
-add_subdirectory(src)
-add_subdirectory(capi)
-add_subdirectory(tests)
-add_subdirectory(tools)
 # Configure tests
 if(GEOS_ENABLE_TESTS)
  # Include CTest support
-  enable_testing()
+ include(CTest)
+ enable_testing()
   # Define "make check" as alias for "make test"
   add_custom_target(check COMMAND ctest)
@@ -243,6 +234,16 @@
 endif()
+# Configure subdirectories
+add_subdirectory(include)
+add_subdirectory(src)
+add_subdirectory(capi)
+add_subdirectory(tests)
+add_subdirectory(tools)
 # Setup installation of common files not specific to any target
More information about the geos-commits mailing list
