[geos-commits] r3076 - in trunk: include/geos/operation/polygonize
src/operation/polygonize
svn_geos at osgeo.org
Thu Jul 1 16:03:49 EDT 2010
Author: strk
Date: 2010-07-01 20:03:49 +0000 (Thu, 01 Jul 2010)
New Revision: 3076
trunk/include/geos/operation/polygonize/EdgeRing.h
trunk/src/operation/polygonize/EdgeRing.cpp
Drop useless heap-allocation in Polygonize op
Modified: trunk/include/geos/operation/polygonize/EdgeRing.h
--- trunk/include/geos/operation/polygonize/EdgeRing.h 2010-06-24 14:40:01 UTC (rev 3075)
+++ trunk/include/geos/operation/polygonize/EdgeRing.h 2010-07-01 20:03:49 UTC (rev 3076)
@@ -53,13 +53,17 @@
class GEOS_DLL EdgeRing {
private:
const geom::GeometryFactory *factory;
- std::vector<const planargraph::DirectedEdge*> *deList;
+ typedef std::vector<const planargraph::DirectedEdge*> DeList;
+ DeList deList;
// cache the following data for efficiency
geom::LinearRing *ring;
geom::CoordinateSequence *ringPts;
- std::vector<geom::Geometry*> *holes;
+ typedef std::vector<geom::Geometry*> GeomVect;
+ GeomVect *holes;
/** \brief
* Computes the list of coordinates which are contained in this ring.
* The coordinatea are computed once only and cached.
Modified: trunk/src/operation/polygonize/EdgeRing.cpp
--- trunk/src/operation/polygonize/EdgeRing.cpp 2010-06-24 14:40:01 UTC (rev 3075)
+++ trunk/src/operation/polygonize/EdgeRing.cpp 2010-07-01 20:03:49 UTC (rev 3076)
@@ -120,7 +120,6 @@
cerr<<"["<<this<<"] EdgeRing(factory)"<<endl;
#endif // DEBUG_ALLOC
- deList=new vector<const DirectedEdge*>();
ring=NULL;
ringPts=NULL;
@@ -133,10 +132,10 @@
#ifdef DEBUG_ALLOC
cerr<<"["<<this<<"] ~EdgeRing()"<<endl;
- delete deList;
if ( holes )
- for (int i=0; i<(int)holes->size(); i++) delete (*holes)[i];
+ for (GeomVect::size_type i=0, e=holes->size(); i<e; ++i)
+ delete (*holes)[i];
delete holes;
delete ring;
@@ -146,7 +145,7 @@
/*public*/
void
EdgeRing::add(const DirectedEdge *de){
- deList->push_back(de);
+ deList.push_back(de);
/*public*/
@@ -162,7 +161,7 @@
if (holes==NULL)
holes=new vector<Geometry*>();
- holes->push_back((Geometry *)hole);
+ holes->push_back(hole);
/*public*/
@@ -190,8 +189,8 @@
if (ringPts==NULL)
ringPts=factory->getCoordinateSequenceFactory()->create(NULL);
- for (int i=0;i<(int)deList->size();i++) {
- const DirectedEdge *de=(*deList)[i];
+ for (DeList::size_type i=0, e=deList.size(); i<e; ++i) {
+ const DirectedEdge *de=deList[i];
assert(dynamic_cast<PolygonizeEdge*>(de->getEdge()));
PolygonizeEdge *edge=static_cast<PolygonizeEdge*>(de->getEdge());
addEdge(edge->getLine()->getCoordinatesRO(),
More information about the geos-commits
