[geos-commits] r3078 - in trunk: include/geos/operation/polygonize
	include/geos/planargraph php/test src/operation/polygonize
	src/planargraph
    svn_geos at osgeo.org
    Thu Jul  1 17:44:33 EDT 2010
Author: strk
Date: 2010-07-01 21:44:33 +0000 (Thu, 01 Jul 2010)
New Revision: 3078
   trunk/include/geos/operation/polygonize/EdgeRing.h
   trunk/include/geos/operation/polygonize/PolygonizeGraph.h
   trunk/include/geos/planargraph/PlanarGraph.h
   trunk/php/test/test.php
   trunk/src/operation/polygonize/EdgeRing.cpp
   trunk/src/operation/polygonize/PolygonizeGraph.cpp
   trunk/src/planargraph/PlanarGraph.cpp
Fix PolygonizeGraph::deleteDangles so it doesn't return duplicated LineStrings, as per JTS design. Fixes the Polygonizer Bug reported in list. This commit also takes the chance to reduce some heap allocations.
Modified: trunk/include/geos/operation/polygonize/EdgeRing.h
--- trunk/include/geos/operation/polygonize/EdgeRing.h	2010-07-01 20:49:03 UTC (rev 3077)
+++ trunk/include/geos/operation/polygonize/EdgeRing.h	2010-07-01 21:44:33 UTC (rev 3078)
@@ -14,7 +14,7 @@
- * Last port: operation/polygonize/EdgeRing.java rev. 109 (JTS-1.10)
+ * Last port: operation/polygonize/EdgeRing.java rev. 109/138 (JTS-1.10)
Modified: trunk/include/geos/operation/polygonize/PolygonizeGraph.h
--- trunk/include/geos/operation/polygonize/PolygonizeGraph.h	2010-07-01 20:49:03 UTC (rev 3077)
+++ trunk/include/geos/operation/polygonize/PolygonizeGraph.h	2010-07-01 21:44:33 UTC (rev 3078)
@@ -14,7 +14,7 @@
- * Last port: operation/polygonize/PolygonizeGraph.java rev. 1.6 (JTS-1.10)
+ * Last port: operation/polygonize/PolygonizeGraph.java rev. 6/138 (JTS-1.10)
Modified: trunk/include/geos/planargraph/PlanarGraph.h
--- trunk/include/geos/planargraph/PlanarGraph.h	2010-07-01 20:49:03 UTC (rev 3077)
+++ trunk/include/geos/planargraph/PlanarGraph.h	2010-07-01 21:44:33 UTC (rev 3078)
@@ -11,6 +11,10 @@
  * by the Free Software Foundation.
  * See the COPYING file for more information.
+ * Last port: planargraph/PlanarGraph.java rev. 107/138 (JTS-1.10)
 #ifndef GEOS_PLANARGRAPH_PLANARGRAPH_H
@@ -231,6 +235,14 @@
  	 * The return value is a newly allocated vector of existing nodes
 	std::vector<Node*>* findNodesOfDegree(std::size_t degree);
+	 * \brief
+	 * Get all Nodes with the given number of Edges around it.
+ 	 * Found nodes are pushed to the given vector
+	void findNodesOfDegree(std::size_t degree, std::vector<Node*>& to);
 } // namespace geos::planargraph
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php	2010-07-01 20:49:03 UTC (rev 3077)
+++ trunk/php/test/test.php	2010-07-01 21:44:33 UTC (rev 3078)
@@ -952,49 +952,64 @@
         $g2 = $reader->read('POINT(0 0)');
-        $g = $g->union($g2); /* Make sure linestrings are noded */
         $ret = GEOSPolygonize($g);
-         * NOTE: the following expected results are suspicious
-         *       due to the duplicated dangle and lack of a cut edge
-        //var_dump($ret);
         $this->assertEquals('array', gettype($ret));
         $this->assertEquals('array', gettype($ret['rings']));
         $this->assertEquals('array', gettype($ret['cut_edges']));
         $this->assertEquals('array', gettype($ret['dangles']));
         $this->assertEquals('array', gettype($ret['invalid_rings']));
-        $this->assertEquals(3, count($ret['rings']));
+        $this->assertEquals(2, count($ret['rings']));
-'POLYGON ((185 221, 132 146, 83 187, 185 221))'
+'POLYGON ((185 221, 88 275, 180 316, 292 281, 185 221))' # JTS-confirmed!
             , $writer->write($ret['rings'][0]));
-'POLYGON ((132 146, 185 221, 325 168, 189 98, 132 146))'
+'POLYGON ((189 98, 83 187, 185 221, 325 168, 189 98))' # JTS-confirmed !
             , $writer->write($ret['rings'][1]));
-'POLYGON ((185 221, 88 275, 180 316, 292 281, 185 221))'
-            , $writer->write($ret['rings'][2]));
         $this->assertEquals(0, count($ret['cut_edges']));
-        $this->assertEquals(3, count($ret['dangles']));
+        $this->assertEquals(0, count($ret['invalid_rings']));
+         * FIXME: the duplicated dangle (0 0, 10 10) is unexpected
+        $this->assertEquals(2, count($ret['dangles']));
+'LINESTRING (185 221, 100 100)' # JTS-confirmed !
+            , $writer->write($ret['dangles'][0]));
+'LINESTRING (0 0, 10 10)' # JTS-confirmed !
+            , $writer->write($ret['dangles'][1]));
+        $g = $g->union($g2); /* Now make sure linestrings are noded */
+        $ret = GEOSPolygonize($g);
+        $this->assertEquals('array', gettype($ret));
+        $this->assertEquals('array', gettype($ret['rings']));
+        $this->assertEquals('array', gettype($ret['cut_edges']));
+        $this->assertEquals('array', gettype($ret['dangles']));
+        $this->assertEquals('array', gettype($ret['invalid_rings']));
 'LINESTRING (132 146, 100 100)'
-'LINESTRING (0 0, 10 10)'
-            , $writer->write($ret['dangles'][2]));
+	// TODO: test a polygonize run with cut lines and invalid_rings
     public function testGeometry_lineMerge()
Modified: trunk/src/operation/polygonize/EdgeRing.cpp
--- trunk/src/operation/polygonize/EdgeRing.cpp	2010-07-01 20:49:03 UTC (rev 3077)
+++ trunk/src/operation/polygonize/EdgeRing.cpp	2010-07-01 21:44:33 UTC (rev 3078)
@@ -14,7 +14,7 @@
Modified: trunk/src/operation/polygonize/PolygonizeGraph.cpp
--- trunk/src/operation/polygonize/PolygonizeGraph.cpp	2010-07-01 20:49:03 UTC (rev 3077)
+++ trunk/src/operation/polygonize/PolygonizeGraph.cpp	2010-07-01 21:44:33 UTC (rev 3078)
@@ -14,7 +14,7 @@
@@ -30,6 +30,7 @@
 #include <cassert>
 #include <vector>
+#include <set>
 //using namespace std;
 using namespace geos::planargraph;
@@ -444,14 +445,13 @@
 void
 PolygonizeGraph::deleteDangles(std::vector<const LineString*>& dangleLines)
-	std::vector<Node*> *nodesToRemove=findNodesOfDegree(1);
 	std::vector<Node*> nodeStack;
-	for(int i=0;i<(int)nodesToRemove->size();i++) {
-		nodeStack.push_back((*nodesToRemove)[i]);
-	delete nodesToRemove;
+	findNodesOfDegree(1, nodeStack);
+	std::set<const LineString*> uniqueDangles;
 	while (!nodeStack.empty()) {
-		Node *node=nodeStack[nodeStack.size()-1];
+		Node *node=nodeStack.back();
 		nodeStack.pop_back();
 		deleteAllEdges(node);
 		std::vector<DirectedEdge*> &nodeOutEdges=node->getOutEdges()->getEdges();
@@ -465,13 +465,17 @@
 				sym->setMarked(true);
 			// save the line as a dangle
 			PolygonizeEdge *e=(PolygonizeEdge*) de->getEdge();
-			dangleLines.push_back(e->getLine());
+			const LineString* ls = e->getLine();
+			if ( uniqueDangles.insert(ls).second )
+				dangleLines.push_back(ls);
 			Node *toNode=de->getToNode();
-			// add the toNode to the list to be processed, if it is now a dangle
+			// add the toNode to the list to be processed,
+			// if it is now a dangle
 			if (getDegreeNonDeleted(toNode)==1)
 				nodeStack.push_back(toNode);
 } // namespace geos.operation.polygonize
Modified: trunk/src/planargraph/PlanarGraph.cpp
--- trunk/src/planargraph/PlanarGraph.cpp	2010-07-01 20:49:03 UTC (rev 3077)
+++ trunk/src/planargraph/PlanarGraph.cpp	2010-07-01 21:44:33 UTC (rev 3078)
@@ -12,6 +12,10 @@
 #include <geos/planargraph/PlanarGraph.h>
@@ -126,16 +130,21 @@
 PlanarGraph::findNodesOfDegree(size_t degree)
 	vector<Node*> *nodesFound=new vector<Node*>();
+	findNodesOfDegree(degree, *nodesFound);
+	return nodesFound;
+/*public*/
+void
+PlanarGraph::findNodesOfDegree(size_t degree, vector<Node*>& nodesFound)
 	NodeMap::container &nm=nodeMap.getNodeMap();
-//	NodeMap::container::iterator it=nm.begin();
-//	for ( ; it!=nm.end(); ++it)
 	for (NodeMap::container::iterator it=nm.begin(), itEnd=nm.end();
 			it!=itEnd; ++it)
 		Node *node=it->second;
-		if (node->getDegree()==degree) nodesFound->push_back(node);
+		if (node->getDegree()==degree) nodesFound.push_back(node);
-	return nodesFound;
 } // namespace planargraph
More information about the geos-commits
