[geos-commits] r3082 - trunk/php
svn_geos at osgeo.org svn_geos at osgeo.org
Wed Jul 14 04:38:50 EDT 2010
Author: strk
Date: 2010-07-14 08:38:50 +0000 (Wed, 14 Jul 2010)
New Revision: 3082
   trunk/php/TODO
   trunk/php/geos.c
Serialization/deserialization support for GEOSGeometry type
Modified: trunk/php/TODO
--- trunk/php/TODO	2010-07-13 11:03:49 UTC (rev 3081)
+++ trunk/php/TODO	2010-07-14 08:38:50 UTC (rev 3082)
@@ -1,9 +1,9 @@
 In order of priority
-- Implement serialization/deserialization for Geometry
+- Add phpunit test for serialization/deserialization
+- Find a way to have GEOSGeometry contents shown on var_dump
 - Documentation !! (doxygen-based?)
 - Add WKBReader::read and WKBWriter::write (binary strings required)
-- Find a way to have GEOSGeometry contents shown on var_dump
 - Use the re-entrant interface
 - Add interface for algorithms (Orientation Index) ?
 - Add interfaces for prepared geometries ?
Modified: trunk/php/geos.c
--- trunk/php/geos.c	2010-07-13 11:03:49 UTC (rev 3081)
+++ trunk/php/geos.c	2010-07-14 08:38:50 UTC (rev 3082)
@@ -34,6 +34,7 @@
 #include "php_geos.h"
 PHP_MINIT_FUNCTION(geos);
+PHP_MSHUTDOWN_FUNCTION(geos);
 PHP_RINIT_FUNCTION(geos);
 PHP_RSHUTDOWN_FUNCTION(geos);
 PHP_MINFO_FUNCTION(geos);
@@ -53,7 +54,7 @@
     PHP_GEOS_EXTNAME,
     geos_functions,
     PHP_MINIT(geos),              /* module init function */
-    NULL,                         /* module shutdown function */
+    PHP_MSHUTDOWN(geos),          /* module shutdown function */
     PHP_RINIT(geos),              /* request init function */
     PHP_RSHUTDOWN(geos),          /* request shutdown function */
     PHP_MINFO(geos),              /* module info function */
@@ -285,6 +286,100 @@
 static zend_object_handlers Geometry_object_handlers;
+/* Geometry serializer */
+static GEOSWKBWriter* Geometry_serializer = 0;
+static GEOSWKBWriter* getGeometrySerializer()
+    if ( ! Geometry_serializer ) {
+        Geometry_serializer = GEOSWKBWriter_create();
+        GEOSWKBWriter_setIncludeSRID(Geometry_serializer, 1);
+        GEOSWKBWriter_setOutputDimension(Geometry_serializer, 3);
+    return Geometry_serializer;
+static void delGeometrySerializer()
+    if ( Geometry_serializer ) {
+        GEOSWKBWriter_destroy(Geometry_serializer);
+/* Geometry deserializer */
+static GEOSWKBReader* Geometry_deserializer = 0;
+static GEOSWKBReader* getGeometryDeserializer()
+    if ( ! Geometry_deserializer ) {
+        Geometry_deserializer = GEOSWKBReader_create();
+    return Geometry_deserializer;
+static void delGeometryDeserializer()
+    if ( Geometry_deserializer ) {
+        GEOSWKBReader_destroy(Geometry_deserializer);
+/* Serializer function for GEOSGeometry */
+static int
+Geometry_serialize(zval *object, unsigned char **buffer, zend_uint *buf_len,
+        zend_serialize_data *data TSRMLS_DC)
+    GEOSWKBWriter *serializer;
+    GEOSGeometry *geom;
+    char* ret;
+    size_t retsize;
+    printf("Geometry_serialize called\n");
+    serializer = getGeometrySerializer();
+    geom = (GEOSGeometry*)getRelay(object, Geometry_ce_ptr);
+    /* NOTE: we might be fine using binary here */
+    ret = (char*)GEOSWKBWriter_writeHEX(serializer, geom, &retsize);
+    /* we'll probably get an exception if ret is null */
+    if ( ! ret ) return FAILURE;
+    *buffer = (unsigned char*)estrndup(ret, retsize);
+    GEOSFree(ret);
+    *buf_len = retsize;
+    return SUCCESS;
+static int
+Geometry_deserialize(zval **object, zend_class_entry *ce, const unsigned char *buf,
+        zend_uint buf_len, zend_unserialize_data *data TSRMLS_DC)
+    GEOSWKBReader* deserializer;
+    GEOSGeometry* geom;
+    printf("Geometry_deserialize called\n");
+    deserializer = getGeometryDeserializer();
+    geom = GEOSWKBReader_readHEX(deserializer, buf, buf_len);
+    /* TODO: check zend_class_entry being what we expect! */
+    if ( ce != Geometry_ce_ptr ) {
+        php_error_docref(NULL TSRMLS_CC, E_ERROR,
+                "Geometry_deserialize called with unexpected zend_class_entry");
+        return FAILURE;
+    object_init_ex(*object, ce);
+    setRelay(*object, geom);
+    return SUCCESS;
  * Push components of the given geometry
  * to the given array zval.
@@ -2248,6 +2343,9 @@
     memcpy(&Geometry_object_handlers,
         zend_get_std_object_handlers(), sizeof(zend_object_handlers));
     Geometry_object_handlers.clone_obj = NULL;
+    /* Geometry serialization */
+    Geometry_ce_ptr->serialize = Geometry_serialize;
+    Geometry_ce_ptr->unserialize = Geometry_deserialize;
     /* WKBWriter */
     INIT_CLASS_ENTRY(ce, "GEOSWKBWriter", WKBWriter_methods);
@@ -2300,6 +2398,14 @@
     return SUCCESS;
+/* per-module shutdown */
+    delGeometrySerializer();
+    delGeometryDeserializer();
+    return SUCCESS;
 /* per-request initialization */
More information about the geos-commits mailing list
