[geos-commits] r3010 - trunk/php
svn_geos at osgeo.org
Fri Jun 18 12:12:21 EDT 2010
Author: strk
Date: 2010-06-18 16:12:21 +0000 (Fri, 18 Jun 2010)
New Revision: 3010
trunk/php/Makefile.am
Ubuntu 8.10 version of gcc needs -std=gnu99 to digest Zend headers :(
Modified: trunk/php/Makefile.am
--- trunk/php/Makefile.am 2010-06-18 15:09:21 UTC (rev 3009)
+++ trunk/php/Makefile.am 2010-06-18 16:12:21 UTC (rev 3010)
@@ -30,14 +30,29 @@
EXTRA_DIST = README
pkglib_LTLIBRARIES = geos.la
geos_la_SOURCES = geos.c php_geos.h
geos_la_LIBADD = $(top_builddir)/capi/libgeos_c.la
# TODO: check if -no-undefined should be added
geos_la_LDFLAGS = -module -avoid-version
+# -std is an attempt to fix interpretation
+# of Zend headers, failing with -ansi.
+# As of gcc (Ubuntu 4.3.2-1ubuntu12) 4.3.2
+# you need -std=gnu99
+# while on OpenSuse's plain gcc 4.3.2 -std=c99 is fine
+# (argh)
+geos_la_CFLAGS = $(AM_CFLAGS) -std=gnu99
# TODO: drop conditionals from geos.c and let it bound to current code
-geos_la_CFLAGS = $(AM_CFLAGS) `$(PHP_CONFIG) --includes` \
+geos_la_CPPFLAGS = $(AM_CPPFLAGS) \
+ `$(PHP_CONFIG) --includes` \
-DCOMPILE_DL_GEOS \
- -std=c99
+ -I../capi
install: all
$(INSTALL) -d "$(DESTDIR)"/`$(PHP_CONFIG) --extension-dir`
More information about the geos-commits
