[geos-commits] r3022 - in trunk/php: . test
svn_geos at osgeo.org
Sat Jun 19 09:06:16 EDT 2010
Author: strk
Date: 2010-06-19 13:06:16 +0000 (Sat, 19 Jun 2010)
New Revision: 3022
trunk/php/geos.c
trunk/php/test/test.php
Add GEOSGeometry->interpolate()
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-06-19 12:42:43 UTC (rev 3021)
+++ trunk/php/geos.c 2010-06-19 13:06:16 UTC (rev 3022)
@@ -150,12 +150,14 @@
PHP_METHOD(Geometry, __construct);
PHP_METHOD(Geometry, project);
+PHP_METHOD(Geometry, interpolate);
PHP_METHOD(Geometry, numGeometries);
static function_entry Geometry_methods[] = {
PHP_ME(Geometry, __construct, NULL, 0)
PHP_ME(Geometry, project, NULL, 0)
+ PHP_ME(Geometry, interpolate, NULL, 0)
PHP_ME(Geometry, numGeometries, NULL, 0)
{NULL, NULL, NULL}
@@ -224,6 +226,28 @@
RETURN_DOUBLE(ret);
+ GEOSGeometry *this;
+ double dist;
+ zval *zobj;
+ GEOSGeometry *ret;
+ this = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "d", &dist)
+ == FAILURE) {
+ RETURN_NULL();
+ ret = GEOSInterpolate(this, dist);
+ if ( ! ret ) RETURN_NULL(); /* should get an exception first */
+ /* return_value is a zval */
+ object_init_ex(return_value, Geometry_ce_ptr);
+ setRelay(return_value, ret);
/* -- class GEOSWKTReader -------------------- */
PHP_METHOD(WKTReader, __construct);
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2010-06-19 12:42:43 UTC (rev 3021)
+++ trunk/php/test/test.php 2010-06-19 13:06:16 UTC (rev 3022)
@@ -242,4 +242,36 @@
+ public function testGeometry_interpolate()
+ $reader = new GEOSWKTReader();
+ $writer = new GEOSWKTWriter();
+ $writer->setTrim(TRUE);
+ /* The method only accept LineString geometries */
+ $g = $reader->read('POINT(1 2)');
+ try {
+ $prj = $g->interpolate(0);
+ $this->assertTrue(FALSE); # this is just to fail if we get here
+ } catch (Exception $e) {
+ $this->assertContains('LineString', $e->getMessage());
+ $g = $reader->read('LINESTRING(0 0, 10 0)');
+ $this->assertNotNull($prj);
+ $this->assertEquals('POINT (0 0)', $writer->write($prj));
+ $prj = $g->interpolate(5);
+ $this->assertEquals('POINT (5 0)', $writer->write($prj));
+ /* return closest on longer distance */
+ $prj = $g->interpolate(20);
+ $this->assertEquals('POINT (10 0)', $writer->write($prj));
More information about the geos-commits
