[geos-commits] r3024 - in trunk/php: . test
svn_geos at osgeo.org svn_geos at osgeo.org
Sat Jun 19 09:17:49 EDT 2010
Author: strk
Date: 2010-06-19 13:17:49 +0000 (Sat, 19 Jun 2010)
New Revision: 3024
   trunk/php/geos.c
   trunk/php/test/test.php
Add second optional argument to Geometry->project and Geometry->interpolate to request normalization
Modified: trunk/php/geos.c
--- trunk/php/geos.c	2010-06-19 13:08:31 UTC (rev 3023)
+++ trunk/php/geos.c	2010-06-19 13:17:49 UTC (rev 3024)
@@ -210,17 +210,22 @@
     GEOSGeometry *this;
     GEOSGeometry *other;
     zval *zobj;
+    zend_bool normalized = 0;
     double ret;
     this = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
-    if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "o", &zobj)
-        == FAILURE) {
+    if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "o|b", &zobj,
+            &normalized) == FAILURE) {
         RETURN_NULL();
     other = getRelay(zobj, Geometry_ce_ptr);
-    ret = GEOSProject(this, other);
+    if ( normalized ) {
+        ret = GEOSProjectNormalized(this, other);
+    } else {
+        ret = GEOSProject(this, other);
     if ( ret < 0 ) RETURN_NULL(); /* should get an exception first */
     RETURN_DOUBLE(ret);
@@ -230,17 +235,21 @@
     GEOSGeometry *this;
     double dist;
-    zval *zobj;
     GEOSGeometry *ret;
-    if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "d", &dist)
-        == FAILURE) {
+    if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "d|b",
+            &dist, &normalized) == FAILURE) {
         RETURN_NULL();
-    ret = GEOSInterpolate(this, dist);
+        ret = GEOSInterpolateNormalized(this, dist);
+    } else {
+        ret = GEOSInterpolate(this, dist);
     if ( ! ret ) RETURN_NULL(); /* should get an exception first */
     /* return_value is a zval */
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php	2010-06-19 13:08:31 UTC (rev 3023)
+++ trunk/php/test/test.php	2010-06-19 13:17:49 UTC (rev 3024)
@@ -221,24 +221,34 @@
         $g2 = $reader->read('POINT(0 0)');
         $prj = $g->project($g2);
         $this->assertEquals(0, $prj);
+        $prj = $g->project($g2, TRUE);
+        $this->assertEquals(0, $prj);
         $g2 = $reader->read('POINT(10 0)');
         $this->assertEquals(10, $prj);
+        $this->assertEquals(1, $prj);
         $g2 = $reader->read('POINT(5 0)');
         $this->assertEquals(5, $prj);
+        $this->assertEquals(0.5, $prj);
-        $g = $reader->read('MULTILINESTRING((0 0, 10 0),(20 10, 20 30))');
+        $g = $reader->read('MULTILINESTRING((0 0, 10 0),(20 10, 20 20))');
         $g2 = $reader->read('POINT(20 0)');
         $g2 = $reader->read('POINT(20 5)');
@@ -263,15 +273,24 @@
         $prj = $g->interpolate(0);
         $this->assertNotNull($prj);
         $this->assertEquals('POINT (0 0)', $writer->write($prj));
+        $prj = $g->interpolate(0, TRUE);
+        $this->assertNotNull($prj);
+        $this->assertEquals('POINT (0 0)', $writer->write($prj));
         $prj = $g->interpolate(5);
         $this->assertEquals('POINT (5 0)', $writer->write($prj));
+        $prj = $g->interpolate(0.5, TRUE);
+        $this->assertEquals('POINT (5 0)', $writer->write($prj));
         /* return closest on longer distance */
         $prj = $g->interpolate(20);
         $this->assertEquals('POINT (10 0)', $writer->write($prj));
+        $prj = $g->interpolate(2, TRUE);
+        $this->assertEquals('POINT (10 0)', $writer->write($prj));
More information about the geos-commits mailing list
