[geos-commits] r3029 - in trunk/php: . test
svn_geos at osgeo.org
Sat Jun 19 17:36:42 EDT 2010
Author: strk
Date: 2010-06-19 21:36:42 +0000 (Sat, 19 Jun 2010)
New Revision: 3029
trunk/php/geos.c
trunk/php/test/test.php
relate, relatePattern
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-06-19 18:27:12 UTC (rev 3028)
+++ trunk/php/geos.c 2010-06-19 21:36:42 UTC (rev 3029)
@@ -187,6 +187,7 @@
PHP_METHOD(Geometry, union); /* also does union cascaded */
PHP_METHOD(Geometry, pointOnSurface);
PHP_METHOD(Geometry, centroid);
+PHP_METHOD(Geometry, relate);
PHP_METHOD(Geometry, numGeometries);
@@ -204,6 +205,7 @@
PHP_ME(Geometry, union, NULL, 0)
PHP_ME(Geometry, pointOnSurface, NULL, 0)
PHP_ME(Geometry, centroid, NULL, 0)
+ PHP_ME(Geometry, relate, NULL, 0)
PHP_ME(Geometry, numGeometries, NULL, 0)
{NULL, NULL, NULL}
@@ -571,6 +573,47 @@
setRelay(return_value, ret);
+ * GEOSGeometry::relate(otherGeom)
+ * GEOSGeometry::relate(otherGeom, pattern)
+ GEOSGeometry *this;
+ GEOSGeometry *other;
+ zval *zobj;
+ char* pat = NULL;
+ int patlen;
+ int retInt;
+ zend_bool retBool;
+ char* retStr;
+ this = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "o|s",
+ &zobj, &pat, &patlen) == FAILURE)
+ RETURN_NULL();
+ other = getRelay(zobj, Geometry_ce_ptr);
+ if ( ! pat ) {
+ /* we'll compute it */
+ pat = GEOSRelate(this, other);
+ if ( ! pat ) RETURN_NULL(); /* should get an exception first */
+ retStr = estrdup(pat);
+ GEOSFree(pat);
+ RETURN_STRING(retStr, 0);
+ } else {
+ retInt = GEOSRelatePattern(this, other, pat);
+ if ( retInt == 2 ) RETURN_NULL(); /* should get an exception first */
+ retBool = retInt;
+ RETURN_BOOL(retBool);
/* -- class GEOSWKTReader -------------------- */
PHP_METHOD(WKTReader, __construct);
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2010-06-19 18:27:12 UTC (rev 3028)
+++ trunk/php/test/test.php 2010-06-19 21:36:42 UTC (rev 3029)
@@ -853,4 +853,45 @@
'POINT (5 4)'
, $writer->write($b));
+ public function testGeometry_relate()
+ $reader = new GEOSWKTReader();
+ $writer = new GEOSWKTWriter();
+ $writer->setRoundingPrecision(0);
+ $g = $reader->read('POINT(0 0)');
+ $g2 = $reader->read('POINT(0 0)');
+ $ret = $g->relate($g2);
+ $this->assertEquals('0FFFFFFF2', $ret);
+ $ret = $g->relate($g2, '0FFFFFFF2');
+ $this->assertEquals(TRUE, $ret);
+ $ret = $g->relate($g2, '0*******2');
+ $ret = $g->relate($g2, '0*******1');
+ $this->assertEquals(FALSE, $ret);
+ $g2 = $reader->read('POINT(1 0)');
+ $this->assertEquals('FF0FFF0F2', $ret);
+ $ret = $g->relate($g2, 'FF0FFF0F2');
+ $ret = $g->relate($g2, 'F*******2');
+ $ret = $g->relate($g2, 'T*******2');
+ $g = $reader->read('POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))');
+ $this->assertEquals('FF20F1FF2', $ret);
+ $ret = $g->relate($g2, 'FF20F1FF2');
More information about the geos-commits
