[geos-commits] r3035 - in trunk/php: . test
svn_geos at osgeo.org
Sun Jun 20 13:00:29 EDT 2010
Author: strk
Date: 2010-06-20 17:00:29 +0000 (Sun, 20 Jun 2010)
New Revision: 3035
trunk/php/geos.c
trunk/php/test/Makefile.am
trunk/php/test/test.php
GEOSLineMerge
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-06-20 09:13:13 UTC (rev 3034)
+++ trunk/php/geos.c 2010-06-20 17:00:29 UTC (rev 3035)
@@ -39,10 +39,12 @@
PHP_MINFO_FUNCTION(geos);
PHP_FUNCTION(GEOSVersion);
PHP_FUNCTION(GEOSPolygonize);
+PHP_FUNCTION(GEOSLineMerge);
static function_entry geos_functions[] = {
PHP_FE(GEOSVersion, NULL)
PHP_FE(GEOSPolygonize, NULL)
+ PHP_FE(GEOSLineMerge, NULL)
{NULL, NULL, NULL}
@@ -210,18 +212,20 @@
static zend_object_handlers Geometry_object_handlers;
- * Return a newly created array zval containing
- * a clone of all components of given geometry
+ * Push components of the given geometry
+ * to the given array zval.
+ * Components geometries are cloned.
* NOTE: collection components are not descended into
-static zval*
-dumpGeometry(GEOSGeometry* g)
+static void
+dumpGeometry(GEOSGeometry* g, zval* array)
- zval *array;
int ngeoms, i;
MAKE_STD_ZVAL(array);
array_init(array);
ngeoms = GEOSGetNumGeometries(g);
for (i=0; i<ngeoms; ++i)
@@ -240,7 +244,7 @@
add_next_index_zval(array, tmp);
- return array;
+ //return array;
@@ -944,10 +948,7 @@
GEOSGeometry *cut_edges;
GEOSGeometry *dangles;
GEOSGeometry *invalid_rings;
- zval *rings_array;
- zval *cut_edges_array;
- zval *dangles_array;
- zval *invalid_rings_array;
+ zval *array_elem;
zval *zobj;
if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "o", &zobj)
@@ -963,20 +964,55 @@
/* return value should be an array */
array_init(return_value);
- rings_array = dumpGeometry(rings);
+ MAKE_STD_ZVAL(array_elem);
+ array_init(array_elem);
+ dumpGeometry(rings, array_elem);
GEOSGeom_destroy(rings);
- cut_edges_array = dumpGeometry(cut_edges);
+ add_assoc_zval(return_value, "rings", array_elem);
+ dumpGeometry(cut_edges, array_elem);
GEOSGeom_destroy(cut_edges);
- dangles_array = dumpGeometry(dangles);
+ add_assoc_zval(return_value, "cut_edges", array_elem);
+ dumpGeometry(dangles, array_elem);
GEOSGeom_destroy(dangles);
- invalid_rings_array = dumpGeometry(invalid_rings);
+ add_assoc_zval(return_value, "dangles", array_elem);
+ dumpGeometry(invalid_rings, array_elem);
GEOSGeom_destroy(invalid_rings);
+ add_assoc_zval(return_value, "invalid_rings", array_elem);
- add_assoc_zval(return_value, "rings", rings_array);
- add_assoc_zval(return_value, "cut_edges", cut_edges_array);
- add_assoc_zval(return_value, "dangles", dangles_array);
- add_assoc_zval(return_value, "invalid_rings", invalid_rings_array);
+ * array GEOSLineMerge(GEOSGeometry $geom)
+ GEOSGeometry *geom_in;
+ GEOSGeometry *geom_out;
+ zval *zobj;
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "o", &zobj)
+ == FAILURE)
+ RETURN_NULL();
+ geom_in = getRelay(zobj, Geometry_ce_ptr);
+ geom_out = GEOSLineMerge(geom_in);
+ if ( ! geom_out ) RETURN_NULL(); /* should get an exception first */
+ /* return value should be an array */
+ array_init(return_value);
+ dumpGeometry(geom_out, return_value);
+ GEOSGeom_destroy(geom_out);
Modified: trunk/php/test/Makefile.am
--- trunk/php/test/Makefile.am 2010-06-20 09:13:13 UTC (rev 3034)
+++ trunk/php/test/Makefile.am 2010-06-20 17:00:29 UTC (rev 3035)
@@ -39,7 +39,7 @@
chmod +x $@
crashtest:
- $(PHP) $(PHPOPTS) crashme.php
+ $(PHP) $(PHPOPTS) $(abs_srcdir)/crashme.php
clean-local:
rm -f phpunit
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2010-06-20 09:13:13 UTC (rev 3034)
+++ trunk/php/test/test.php 2010-06-20 17:00:29 UTC (rev 3035)
@@ -955,4 +955,30 @@
$this->assertEquals(0, count($ret['invalid_rings']));
+ public function testGeometry_lineMerge()
+ $reader = new GEOSWKTReader();
+ $writer = new GEOSWKTWriter();
+ $writer->setRoundingPrecision(0);
+ $g = $reader->read('MULTILINESTRING(
+ (0 0, 10 10),
+ (10 10, 10 0),
+ (5 0, 10 0),
+ (5 -5, 5 0)
+ $ret = GEOSLineMerge($g);
+ $this->assertEquals('array', gettype($ret));
+ $this->assertEquals('1', count($ret));
+'LINESTRING (0 0, 10 10, 10 0, 5 0, 5 -5)'
+ , $writer->write($ret[0]));
More information about the geos-commits
