[geos-commits] r3043 - in trunk/php: . test
svn_geos at osgeo.org
Sun Jun 20 20:01:46 EDT 2010
Author: strk
Date: 2010-06-21 00:01:46 +0000 (Mon, 21 Jun 2010)
New Revision: 3043
trunk/php/geos.c
trunk/php/test/test.php
getSRID, setSRID
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-06-20 23:53:46 UTC (rev 3042)
+++ trunk/php/geos.c 2010-06-21 00:01:46 UTC (rev 3043)
@@ -202,7 +202,8 @@
PHP_METHOD(Geometry, isClosed);
PHP_METHOD(Geometry, typeName);
PHP_METHOD(Geometry, typeId);
+PHP_METHOD(Geometry, getSRID);
+PHP_METHOD(Geometry, setSRID);
PHP_METHOD(Geometry, numGeometries);
static function_entry Geometry_methods[] = {
@@ -240,7 +241,8 @@
PHP_ME(Geometry, isClosed, NULL, 0)
PHP_ME(Geometry, typeName, NULL, 0)
PHP_ME(Geometry, typeId, NULL, 0)
+ PHP_ME(Geometry, getSRID, NULL, 0)
+ PHP_ME(Geometry, setSRID, NULL, 0)
PHP_ME(Geometry, numGeometries, NULL, 0)
{NULL, NULL, NULL}
@@ -339,19 +341,6 @@
RETURN_STRING(ret, 0);
-PHP_METHOD(Geometry, numGeometries)
- GEOSGeometry *geom;
- long int ret;
- geom = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
- ret = GEOSGetNumGeometries(geom);
- if ( ret == -1 ) RETURN_NULL(); /* should get an exception first */
- RETURN_LONG(ret);
PHP_METHOD(Geometry, project)
GEOSGeometry *this;
@@ -1519,7 +1508,57 @@
RETURN_LONG(typ);
+ * long GEOSGeometry::getSRID()
+ GEOSGeometry *geom;
+ long int ret;
+ geom = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
+ ret = GEOSGetSRID(geom);
+ RETURN_LONG(ret);
+ * void GEOSGeometry::setSRID(long)
+ long int srid;
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "l",
+ &srid) == FAILURE) {
+ RETURN_NULL();
+ GEOSSetSRID(geom, srid);
+ * long GEOSGeometry::numGeometries()
+PHP_METHOD(Geometry, numGeometries)
+ long int ret;
+ ret = GEOSGetNumGeometries(geom);
+ if ( ret == -1 ) RETURN_NULL(); /* should get an exception first */
+ RETURN_LONG(ret);
/* ------ Initialization / Deinitialization / Meta ------------------ */
/* per-module initialization */
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2010-06-20 23:53:46 UTC (rev 3042)
+++ trunk/php/test/test.php 2010-06-21 00:01:46 UTC (rev 3043)
@@ -1292,4 +1292,14 @@
$this->assertEquals(GEOS_GEOMETRYCOLLECTION, $g->typeId());
+ public function testGeometry_srid()
+ $reader = new GEOSWKTReader();
+ $g = $reader->read('POINT(0 0)');
+ $this->assertEquals(0, $g->getSRID());
+ $g->setSRID(2);
+ $this->assertEquals(2, $g->getSRID());
More information about the geos-commits
