[geos-commits] r3051 - in trunk/php: . test
svn_geos at osgeo.org svn_geos at osgeo.org
Sun Jun 20 21:39:50 EDT 2010
Author: strk
Date: 2010-06-21 01:39:50 +0000 (Mon, 21 Jun 2010)
New Revision: 3051
   trunk/php/geos.c
   trunk/php/test/test.php
exteriorRing
Modified: trunk/php/geos.c
--- trunk/php/geos.c	2010-06-21 01:36:53 UTC (rev 3050)
+++ trunk/php/geos.c	2010-06-21 01:39:50 UTC (rev 3051)
@@ -211,6 +211,7 @@
 PHP_METHOD(Geometry, getX);
 PHP_METHOD(Geometry, getY);
 PHP_METHOD(Geometry, interiorRingN);
+PHP_METHOD(Geometry, exteriorRing);
 static function_entry Geometry_methods[] = {
     PHP_ME(Geometry, __construct, NULL, 0)
@@ -256,6 +257,7 @@
     PHP_ME(Geometry, getX, NULL, 0)
     PHP_ME(Geometry, getY, NULL, 0)
     PHP_ME(Geometry, interiorRingN, NULL, 0)
+    PHP_ME(Geometry, exteriorRing, NULL, 0)
     {NULL, NULL, NULL}
@@ -1687,8 +1689,28 @@
     setRelay(return_value, cc);
+ * GEOSGeometry GEOSGeometry::exteriorRing()
+    GEOSGeometry *geom;
+    const GEOSGeometry *c;
+    GEOSGeometry *cc;
+    geom = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
+    c = GEOSGetExteriorRing(geom);
+    if ( ! c ) RETURN_NULL(); /* should get an exception first */
+    cc = GEOSGeom_clone(c);
+    if ( ! cc ) RETURN_NULL(); /* should get an exception first */
+    object_init_ex(return_value, Geometry_ce_ptr);
+    setRelay(return_value, cc);
 /* ------ Initialization / Deinitialization / Meta ------------------ */
 /* per-module initialization */
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php	2010-06-21 01:36:53 UTC (rev 3050)
+++ trunk/php/test/test.php	2010-06-21 01:39:50 UTC (rev 3051)
@@ -1465,4 +1465,27 @@
+    public function testGeometry_exteriorRing()
+        $reader = new GEOSWKTReader();
+        $writer = new GEOSWKTWriter();
+        $writer->setRoundingPrecision(0);
+        $g = $reader->read('POLYGON (
+            (10 10, 10 14, 14 14, 14 10, 10 10),
+                (11 11, 11 12, 12 12, 12 11, 11 11))');
+        $r = $g->exteriorRing();
+        $this->assertEquals('LINEARRING (10 10, 10 14, 14 14, 14 10, 10 10)',
+            $writer->write($r) );
+        $g = $reader->read('POINT (0 0)');
+        try {
+            $g->exteriorRing(0);
+            $this->assertTrue( FALSE );
+        } catch (Exception $e) {
+            $this->assertContains( 'Polygon', $e->getMessage() );
More information about the geos-commits mailing list
