[geos-commits] r3065 - in trunk: include/geos/io src/io
svn_geos at osgeo.org
Thu Jun 24 04:27:16 EDT 2010
Author: strk
Date: 2010-06-24 08:27:16 +0000 (Thu, 24 Jun 2010)
New Revision: 3065
trunk/include/geos/io/WKBWriter.h
trunk/include/geos/io/WKTWriter.h
trunk/src/io/WKBWriter.cpp
trunk/src/io/WKTWriter.cpp
Make WKTWriter::setOutputDimensions check parameter validity (must be 2 or 3) to be consistent with WKBWriter already doing so in constructor; make WKBWriter::setOutputDimensions perform the check as well (like the constructor); Drop virtual methods from WKTWriter class, which wasn't meant to be a virtual class (no virtual dtor anyway)
Modified: trunk/include/geos/io/WKBWriter.h
--- trunk/include/geos/io/WKBWriter.h 2010-06-23 09:48:03 UTC (rev 3064)
+++ trunk/include/geos/io/WKBWriter.h 2010-06-24 08:27:16 UTC (rev 3065)
@@ -106,7 +106,7 @@
* @param newOutputDimension Supported values are 2 or 3. Note that 3 indicates
* up to 3 dimensions will be written but 2D WKB is still produced for 2D geometries.
- virtual void setOutputDimension(int newOutputDimension) { defaultOutputDimension=newOutputDimension; }
+ virtual void setOutputDimension(int newOutputDimension);
* \brief
Modified: trunk/include/geos/io/WKTWriter.h
--- trunk/include/geos/io/WKTWriter.h 2010-06-23 09:48:03 UTC (rev 3064)
+++ trunk/include/geos/io/WKTWriter.h 2010-06-24 08:27:16 UTC (rev 3065)
@@ -141,11 +141,12 @@
* Enable old style 3D/4D WKT generation.
- * By default the WKBWriter produces new style 3D/4D WKT (ie. "POINT Z (10 20 30)")
- * but if this method is used to turn on old style WKT production then the WKT will
- * be formatted in the style "POINT (10 20 30)".
+ * By default the WKBWriter produces new style 3D/4D WKT
+ * (ie. "POINT Z (10 20 30)") but if this method is used
+ * to turn on old style WKT production then the WKT will
+ * be formatted in the style "POINT (10 20 30)".
* @param useOld3D true or false
void setOld3D(bool useOld3D ) { old3D = useOld3D; }
@@ -155,15 +156,16 @@
* Returns the output dimension used by the
* <code>WKBWriter</code>.
- virtual int getOutputDimension() const { return defaultOutputDimension; }
+ int getOutputDimension() const { return defaultOutputDimension; }
* Sets the output dimension used by the <code>WKBWriter</code>.
- * @param newOutputDimension Supported values are 2 or 3. Note that 3 indicates
- * up to 3 dimensions will be written but 2D WKB is still produced for 2D geometries.
+ * @param newOutputDimension Supported values are 2 or 3.
+ * Note that 3 indicates up to 3 dimensions will be
+ * written but 2D WKB is still produced for 2D geometries.
+ void setOutputDimension(int newOutputDimension);
protected:
Modified: trunk/src/io/WKBWriter.cpp
--- trunk/src/io/WKBWriter.cpp 2010-06-23 09:48:03 UTC (rev 3064)
+++ trunk/src/io/WKBWriter.cpp 2010-06-24 08:27:16 UTC (rev 3065)
@@ -53,6 +53,16 @@
outputDimension = defaultOutputDimension;
+/* public */
+void
+WKBWriter::setOutputDimension(int dims)
+ if ( dims < 2 || dims > 3 )
+ throw util::IllegalArgumentException("WKB output dimension must be 2 or 3");
+ defaultOutputDimension = dims;
WKBWriter::~WKBWriter()
Modified: trunk/src/io/WKTWriter.cpp
--- trunk/src/io/WKTWriter.cpp 2010-06-23 09:48:03 UTC (rev 3064)
+++ trunk/src/io/WKTWriter.cpp 2010-06-24 08:27:16 UTC (rev 3065)
@@ -31,6 +31,7 @@
#include <geos/geom/MultiPolygon.h>
#include <geos/geom/CoordinateSequence.h>
#include <geos/geom/PrecisionModel.h>
+#include <geos/util/IllegalArgumentException.h>
#include <typeinfo>
#include <cstdio> // should avoid this
@@ -45,16 +46,26 @@
namespace geos {
namespace io { // geos.io
-WKTWriter::WKTWriter() {
- isFormatted=false;
- roundingPrecision=-1;
- trim = false;
- level=0;
- formatter="%f";
- defaultOutputDimension = 2;
- old3D = false;
+WKTWriter::WKTWriter():
+ formatter("%f"),
+ isFormatted(false),
+ roundingPrecision(-1),
+ trim(false),
+ level(0),
+ defaultOutputDimension(2),
+ old3D(false)
+/* public */
+void
+WKTWriter::setOutputDimension(int dims)
+ throw util::IllegalArgumentException("WKT output dimension must be 2 or 3");
WKTWriter::~WKTWriter() {}
/*static*/
More information about the geos-commits
