[geos-commits] r3071 - in trunk/php: . test
svn_geos at osgeo.org svn_geos at osgeo.org
Thu Jun 24 05:41:10 EDT 2010
Author: strk
Date: 2010-06-24 09:41:10 +0000 (Thu, 24 Jun 2010)
New Revision: 3071
   trunk/php/geos.c
   trunk/php/test/test.php
WKBReader: construct and readHEX; improve WKTReader test to include 'Z' label
Modified: trunk/php/geos.c
--- trunk/php/geos.c	2010-06-24 09:20:36 UTC (rev 3070)
+++ trunk/php/geos.c	2010-06-24 09:41:10 UTC (rev 3071)
@@ -2014,7 +2014,80 @@
     GEOSWKBWriter_setIncludeSRID(writer, inc);
+/* -- class GEOSWKBReader -------------------- */
+PHP_METHOD(WKBReader, __construct);
+PHP_METHOD(WKBReader, readHEX);
+static function_entry WKBReader_methods[] = {
+    PHP_ME(WKBReader, __construct, NULL, 0)
+    PHP_ME(WKBReader, readHEX, NULL, 0)
+    {NULL, NULL, NULL}
+static zend_class_entry *WKBReader_ce_ptr;
+static zend_object_handlers WKBReader_object_handlers;
+static void
+WKBReader_dtor (void *object TSRMLS_DC)
+    Proxy *obj = (Proxy *)object;
+    GEOSWKBReader_destroy((GEOSWKBReader*)obj->relay);
+    zend_hash_destroy(obj->std.properties);
+    FREE_HASHTABLE(obj->std.properties);
+    efree(obj);
+static zend_object_value
+WKBReader_create_obj (zend_class_entry *type TSRMLS_DC)
+    return Gen_create_obj(type, WKBReader_dtor, &WKBReader_object_handlers);
+    GEOSWKBReader* obj;
+    zval *object = getThis();
+    obj = GEOSWKBReader_create();
+    if ( ! obj ) {
+        php_error_docref(NULL TSRMLS_CC, E_ERROR,
+                "GEOSWKBReader_create() failed (didn't initGEOS?)");
+    setRelay(object, obj);
+    GEOSWKBReader *reader;
+    GEOSGeometry *geom;
+    unsigned char* wkb;
+    int wkblen;
+    reader = (GEOSWKBReader*)getRelay(getThis(), WKBReader_ce_ptr);
+    if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "s",
+        &wkb, &wkblen) == FAILURE)
+        RETURN_NULL();
+    geom = GEOSWKBReader_readHEX(reader, wkb, wkblen);
+    /* we'll probably get an exception if geom is null */
+    if ( ! geom ) RETURN_NULL();
+    /* return_value is a zval */
+    object_init_ex(return_value, Geometry_ce_ptr);
+    setRelay(return_value, geom);
 /* -- Free functions ------------------------- */
@@ -2164,7 +2237,15 @@
         zend_get_std_object_handlers(), sizeof(zend_object_handlers));
     WKBWriter_object_handlers.clone_obj = NULL;
+    /* WKBReader */
+    INIT_CLASS_ENTRY(ce, "GEOSWKBReader", WKBReader_methods);
+    WKBReader_ce_ptr = zend_register_internal_class(&ce TSRMLS_CC);
+    WKBReader_ce_ptr->create_object = WKBReader_create_obj;
+    memcpy(&WKBReader_object_handlers,
+        zend_get_std_object_handlers(), sizeof(zend_object_handlers));
+    WKBReader_object_handlers.clone_obj = NULL;
     /* Constants */
     REGISTER_LONG_CONSTANT("GEOSBUF_CAP_ROUND",  GEOSBUF_CAP_ROUND,
         CONST_CS|CONST_PERSISTENT);
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php	2010-06-24 09:20:36 UTC (rev 3070)
+++ trunk/php/test/test.php	2010-06-24 09:41:10 UTC (rev 3071)
@@ -48,10 +48,16 @@
         /* Good WKT */
         $geom = $reader->read('POINT(0 0)');
         $this->assertNotNull($geom);
+        $geom = $reader->read('POINT(0 0 0)');
+        $this->assertNotNull($geom);
+        $geom = $reader->read('POINT Z (0 0 0)');
         $geom = $reader->read('POINT EMPTY');
         $geom = $reader->read('MULTIPOINT(0 0 1, 2 3 4)');
+        $geom = $reader->read('MULTIPOINT Z (0 0 1, 2 3 4)');
         $geom = $reader->read('MULTIPOINT((0 0), (2 3))');
         $geom = $reader->read('MULTIPOINT EMPTY');
@@ -63,6 +69,9 @@
         $geom = $reader->read('MULTILINESTRING((0 0 1, 2 3 4),
                                                (10 10 2, 3 4 5))');
+        $geom = $reader->read('MULTILINESTRING Z ((0 0 1, 2 3 4),
+                                               (10 10 2, 3 4 5))');
         $geom = $reader->read('POLYGON((0 0, 1 0, 1 1, 0 1, 0 0))');
         $geom = $reader->read('POLYGON EMPTY');
@@ -1896,4 +1905,70 @@
           $writer->writeHEX($g));
         $writer->setIncludeSRID(FALSE);
+    public function testWKBReader__construct()
+        $reader = new GEOSWKBReader();
+        $this->assertNotNull($reader);
+    public function testWKBReader_readHEX()
+        $writer = new GEOSWKTWriter();
+        $writer->setTrim(TRUE);
+        $writer->setOutputDimension(3);
+        // 2D LITTLE endian
+        $g = $reader->readHEX(
+            '010100000000000000000018400000000000001C40'
+        $this->assertEquals('POINT (6 7)', $writer->write($g));
+        $this->assertEquals(0, $g->getSRID());
+        // 2D BIG endian
+            '00000000014018000000000000401C000000000000'
+        // 2D LITTLE endian + SRID
+            '01010000202B00000000000000000018400000000000001C40'
+        $this->assertEquals(43, $g->getSRID());
+        // 2D BIG endian + SRID
+            '00200000010000002B4018000000000000401C000000000000'
+        // 3D LITTLE endian
+            '010100008000000000000018400000000000001C400000000000002040'
+        $this->assertEquals('POINT Z (6 7 8)', $writer->write($g));
+        // 3D BIG endian
+            '00800000014018000000000000401C0000000000004020000000000000'
+        // 3D BIG endian + SRID
+          '00A0000001000000354018000000000000401C0000000000004020000000000000'
+        $this->assertEquals(53, $g->getSRID());
More information about the geos-commits mailing list
