[geos-commits] r2964 - tags/3.2.1
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Mar 29 12:24:17 EDT 2010
Author: strk
Date: 2010-03-29 12:24:17 -0400 (Mon, 29 Mar 2010)
New Revision: 2964
   tags/3.2.1/ChangeLog
Update ChangeLog
Modified: tags/3.2.1/ChangeLog
--- tags/3.2.1/ChangeLog	2010-03-29 16:21:43 UTC (rev 2963)
+++ tags/3.2.1/ChangeLog	2010-03-29 16:24:17 UTC (rev 2964)
@@ -1,359 +1,279 @@
+2010-03-26 12:35  Mateusz Loskot <mateusz at loskot.net>
+	* [r2956] source/headers/geos/platform.h.vc: platform.h.vc: disable
+	  min/max macros substitution (ported from trunk)
+2010-03-26 12:03  Mateusz Loskot <mateusz at loskot.net>
+	* [r2953]
+	  source/headers/geos/operation/union/CascadedPolygonUnion.h: Added
+	  GEOS_DLL with Microsoft-specific __declspec attribute missing
+	  from CascadedPolygonUnion class
+2010-03-26 12:00  Mateusz Loskot <mateusz at loskot.net>
+	* [r2951] source/geom/GeometryList.cpp: geom\GeoemtryList.cpp:
+	  missing implementation of GeometryList::size() function.
+2010-03-26 11:57  Mateusz Loskot <mateusz at loskot.net>
+	* [r2949] source/Makefile.vc: source\Makefile.vc: added missing
+	  geom\GeometryList.cpp
+2010-03-26 11:52  Mateusz Loskot <mateusz at loskot.net>
+	* [r2947] nmake.opt: nmake.opt: Added missing GEOS_DLL_EXPORT to
+	  CPPFLAGS
+2010-03-19 15:09  Sandro Santilli <strk at keybit.net>
+	* [r2945] NEWS, capi/geos_ts_c.cpp: Improve formatting for
+	  GEOSisValidReason_r (issue #329)
+2010-03-18 18:28  Sandro Santilli <strk at keybit.net>
+	* [r2943] NEWS: Add bugfix item
+2010-03-18 18:26  Sandro Santilli <strk at keybit.net>
+	* [r2942] source/headers/geos/operation/valid/IsValidOp.h,
+	  source/operation/valid/IsValidOp.cpp,
+	  tests/xmltester/tests/general/TestValid.xml: Fix false-positive
+	  return from IsValidOp. This is done better than in trunk, so will
+	  backport later.
+2009-12-30 17:55  Mateusz Loskot <mateusz at loskot.net>
+	* [r2836] source/Makefile.vc: Ported fix for missing
+	  CoordinateSequenceFactory?.cpp from makefile.vc (Ticket #313)
+2009-12-14 19:21  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r2830] capi/geos_c.h.in, configure.in,
+	  source/headers/geos/version.h.vc: Back up the versions to 3.2.1
+	  for 3.2 branch
+2009-12-14 19:19  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r2829] .: Branch 3.2
+2009-12-14 19:18  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r2828] Update version numbers on trunk to 3.3 series
+2009-12-14 19:06  Sandro Santilli <strk at keybit.net>
+	* [r2826] Updated
+2009-12-14 18:58  Sandro Santilli <strk at keybit.net>
+	* [r2825] Don't mention 'troubles' in documentation (some like it
+	  not)
 2009-12-14 15:23  Mateusz Loskot <mateusz at loskot.net>
-	* [r2824] source/headers/geos/util/TopologyException.h,
-	  source/io/WKTWriter.cpp: * Fixed bug in WKTWriter that was
-	  dropping geometry tag in string representation of geometry
+	* [r2824] * Fixed bug in WKTWriter that was dropping geometry tag
+	  in string representation of geometry
 	  * Improved message carried by TopologyException
 2009-12-11 13:17  Sandro Santilli <strk at keybit.net>
-	* [r2823] ChangeLog: Updated
+	* [r2823] Updated
 2009-12-11 13:10  Sandro Santilli <strk at keybit.net>
-	* [r2822] source/geom/prep/BasicPreparedGeometry.cpp: Fix memory
-	  leak in BasicPreparedGeometry::isAnyTargetComponentInTest (issue
-	  #308) and drop Coordinate copies from it.
+	* [r2822] Fix memory leak in
+	  BasicPreparedGeometry::isAnyTargetComponentInTest (issue #308)
+	  and drop Coordinate copies from it.
 2009-12-09 11:10  Mateusz Loskot <mateusz at loskot.net>
-	* [r2821] build/msvc10/geos_lib/geos_lib.vcxproj: Fixed generation
-	  of platform.h as pre-build step of GEOS lib project for Visual
-	  C++
+	* [r2821] Fixed generation of platform.h as pre-build step of GEOS
+	  lib project for Visual C++
 2009-12-09 11:05  Mateusz Loskot <mateusz at loskot.net>
-	* [r2820] build/msvc80/geos_lib/geos_lib.vcproj,
-	  build/msvc90/geos_lib/geos_lib.vcproj: * Fixed generation of
-	  platform.h as pre-build step of GEOS lib project for Visual C++
-	  2005 and 2008
+	* [r2820] * Fixed generation of platform.h as pre-build step of
+	  GEOS lib project for Visual C++ 2005 and 2008
 	  * Added missing headers.
 2009-12-08 22:47  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2817] ChangeLog, INSTALL, configure.in: Prepare for RC4
-	  release.
+	* [r2817] Prepare for RC4 release.
 2009-12-08 21:40  Mateusz Loskot <mateusz at loskot.net>
-	* [r2816] tests/geostest, tests/thread: Updated svn:ignore patterns
+	* [r2816] Updated svn:ignore patterns
 2009-12-08 21:39  Mateusz Loskot <mateusz at loskot.net>
-	* [r2815] build/msvc10/Makefile.am: build/msvc10: fixed list of
-	  EXTRA_DIST files
+	* [r2815] build/msvc10: fixed list of EXTRA_DIST files
 2009-12-08 17:51  Sandro Santilli <strk at keybit.net>
-	* [r2814] tests/geostest/.deps/geostest.Po: This shouldn't be in
-	  the repository !
+	* [r2814] This shouldn't be in the repository !
 2009-12-08 17:50  Sandro Santilli <strk at keybit.net>
-	* [r2813] source/algorithm/NonRobustLineIntersector.cpp,
-	  source/algorithm/RobustLineIntersector.cpp: Remove
-	  deprecated/unused files
+	* [r2813] Remove deprecated/unused files
 2009-12-08 17:42  Sandro Santilli <strk at keybit.net>
-	* [r2812]
-	  source/headers/geos/geom/prep/PreparedLineStringIntersects.h:
-	  Drop useless (and leaking) heap allocation exposed by the new
-	  prepared linestring intersection test
+	* [r2812] Drop useless (and leaking) heap allocation exposed by the
+	  new prepared linestring intersection test
-	* [r2811] source/geom/prep/PreparedLineString.cpp,
-	  source/headers/geos/geom/prep/PreparedLineString.h: Add missing
-	  destructor of PreparedLineString (closes ticket #305)
+	* [r2811] Add missing destructor of PreparedLineString (closes
+	  ticket #305)
 2009-12-08 17:39  Sandro Santilli <strk at keybit.net>
-	* [r2810] tests/unit/capi/GEOSPreparedGeometryTest.cpp: Add test
-	  with Prepared linestrings, for the sake of testing the leak
-	  reported in ticket #305
+	* [r2810] Add test with Prepared linestrings, for the sake of
+	  testing the leak reported in ticket #305
 2009-12-06 01:05  Mateusz Loskot <mateusz at loskot.net>
-	* [r2809] source/algorithm/Angle.cpp,
-	  source/algorithm/BoundaryNodeRule.cpp,
-	  source/algorithm/distance/DiscreteHausdorffDistance.cpp,
-	  source/algorithm/distance/DistanceToPoint.cpp,
-	  source/headers/geos/algorithm/Angle.h,
-	  source/headers/geos/algorithm/BoundaryNodeRule.h,
-	  source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h,
-	  source/headers/geos/algorithm/distance/DistanceToPoint.h,
-	  source/headers/geos/algorithm/distance/PointPairDistance.h,
-	  source/headers/geos/export.h,
-	  source/headers/geos/geom/CoordinateSequenceFilter.h,
-	  source/headers/geos/linearref/ExtractLineByLocation.h,
-	  source/headers/geos/linearref/LengthIndexOfPoint.h,
-	  source/headers/geos/linearref/LengthIndexedLine.h,
-	  source/headers/geos/linearref/LengthLocationMap.h,
-	  source/headers/geos/linearref/LinearGeometryBuilder.h,
-	  source/headers/geos/linearref/LinearIterator.h,
-	  source/headers/geos/linearref/LinearLocation.h,
-	  source/headers/geos/linearref/LocationIndexOfLine.h,
-	  source/headers/geos/linearref/LocationIndexOfPoint.h,
-	  source/headers/geos/noding/BasicSegmentString.h,
-	  source/headers/geos/noding/OrientedCoordinateArray.h,
-	  source/headers/geos/operation/buffer/BufferParameters.h,
-	  source/headers/geos/operation/overlay/snap/GeometrySnapper.h,
-	  source/headers/geos/operation/overlay/snap/LineStringSnapper.h,
-	  source/headers/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h,
-	  source/headers/geos/operation/overlay/snap/SnapOverlayOp.h,
-	  source/linearref/ExtractLineByLocation.cpp,
-	  source/linearref/LengthIndexOfPoint.cpp,
-	  source/linearref/LengthIndexedLine.cpp,
-	  source/linearref/LengthLocationMap.cpp,
-	  source/linearref/LinearGeometryBuilder.cpp,
-	  source/linearref/LinearIterator.cpp,
-	  source/linearref/LinearLocation.cpp,
-	  source/linearref/LocationIndexOfLine.cpp,
-	  source/linearref/LocationIndexOfPoint.cpp,
-	  source/noding/BasicSegmentString.cpp,
-	  source/noding/OrientedCoordinateArray.cpp,
-	  source/operation/buffer/BufferInputLineSimplifier.cpp,
-	  source/operation/buffer/BufferInputLineSimplifier.h,
-	  source/operation/buffer/BufferParameters.cpp,
-	  source/operation/overlay/snap/GeometrySnapper.cpp,
-	  source/operation/overlay/snap/LineStringSnapper.cpp,
-	  source/operation/overlay/snap/SnapIfNeededOverlayOp.cpp,
-	  source/operation/overlay/snap/SnapOverlayOp.cpp,
-	  source/operation/valid/IndexedNestedRingTester.cpp,
-	  source/operation/valid/IndexedNestedRingTester.h,
-	  tests/bigtest/bug234.cpp, tests/geostest/geostest.c,
-	  tests/perf/operation/buffer/IteratedBufferStressTest.cpp,
-	  tests/thread/badthreadtest.c, tests/thread/threadtest.c,
-	  tests/unit/algorithm/RobustLineIntersectionTest.cpp,
-	  tests/unit/algorithm/RobustLineIntersectorTest.cpp,
-	  tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp,
-	  tests/unit/capi/GEOSBufferTest.cpp,
-	  tests/unit/capi/GEOSGeomFromWKBTest.cpp,
-	  tests/unit/capi/GEOSPreparedGeometryTest.cpp,
-	  tests/unit/linearref/LengthIndexedLineTest.cpp,
-	  tests/unit/noding/NodedSegmentStringTest.cpp,
-	  tests/unit/operation/buffer/BufferOpTest.cpp,
-	  tests/unit/operation/valid/IsValidTest.cpp,
-	  tests/unit/operation/valid/ValidClosedRingTest.cpp,
-	  tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp,
-	  tests/unit/tut/tut.hpp, tests/unit/tut/tut_assert.hpp,
-	  tests/unit/tut/tut_console_reporter.hpp,
-	  tests/unit/tut/tut_exception.hpp, tests/unit/tut/tut_posix.hpp,
-	  tests/unit/tut/tut_reporter.hpp,
-	  tests/unit/tut/tut_restartable.hpp,
-	  tests/unit/tut/tut_result.hpp, tests/unit/tut/tut_runner.hpp,
-	  tests/xmltester/BufferResultMatcher.cpp,
-	  tests/xmltester/BufferResultMatcher.h,
-	  tests/xmltester/SingleSidedBufferResultMatcher.cpp,
-	  tests/xmltester/SingleSidedBufferResultMatcher.h,
-	  tests/xmltester/tinyxml/tinystr.cpp,
-	  tests/xmltester/tinyxml/tinystr.h,
-	  tests/xmltester/tinyxml/tinyxml.cpp,
-	  tests/xmltester/tinyxml/tinyxml.h,
-	  tests/xmltester/tinyxml/tinyxmlerror.cpp,
-	  tests/xmltester/tinyxml/tinyxmlparser.cpp: Updated source code
-	  files with svn:keywords property.
+	* [r2809] Updated source code files with svn:keywords property.
 2009-12-06 01:01  Mateusz Loskot <mateusz at loskot.net>
-	* [r2808] build/msvc90/geos_xmltester, source: Updated svn:ignore
-	  patterns
+	* [r2808] Updated svn:ignore patterns
 2009-12-06 00:56  Mateusz Loskot <mateusz at loskot.net>
-	* [r2807] build/msvc10, build/msvc10/geos_c_dll,
-	  build/msvc10/geos_lib, build/msvc10/geos_unit,
-	  build/msvc10/geos_xmltester, build/msvc80/geos_xmltester: Updated
-	  svn:ignore patterns
+	* [r2807] Updated svn:ignore patterns
 2009-12-06 00:51  Mateusz Loskot <mateusz at loskot.net>
-	* [r2806] configure.in: Updated configure.in after moved non-unit
-	  tests programs out of tests/unit (Tickets #240).
+	* [r2806] Updated configure.in after moved non-unit tests programs
+	  out of tests/unit (Tickets #240).
 2009-12-06 00:47  Mateusz Loskot <mateusz at loskot.net>
-	* [r2805] tests/Makefile.am, tests/geostest, tests/geostest/.deps,
-	  tests/geostest/.deps/geostest.Po, tests/geostest/Makefile.am,
-	  tests/geostest/brokengrammar, tests/geostest/geostest.c,
-	  tests/geostest/test.expected, tests/geostest/test.wkt,
-	  tests/geostest/testrunner.sh, tests/thread,
-	  tests/thread/Makefile.am, tests/thread/badthreadtest.c,
-	  tests/thread/threadtest.c, tests/unit/Makefile.am,
-	  tests/unit/capi/badthreadtest.c, tests/unit/capi/brokengrammar,
-	  tests/unit/capi/geostest.c, tests/unit/capi/test.expected,
-	  tests/unit/capi/test.wkt, tests/unit/capi/testrunner.sh,
-	  tests/unit/capi/threadtest.c: Moved non-unit tests programs out
-	  of tests/unit: geostest -> tests/geostest, threadtest ->
-	  tests/thread, badthreadtest -> tests/thread (Ticket #240).
+	* [r2805] Moved non-unit tests programs out of tests/unit: geostest
+	  -> tests/geostest, threadtest -> tests/thread, badthreadtest ->
+	  tests/thread (Ticket #240).
 2009-12-05 21:59  Mateusz Loskot <mateusz at loskot.net>
-	* [r2804] configure.in: Added build/msvc80/geos_xmltester to
-	  configure.in
+	* [r2804] Added build/msvc80/geos_xmltester to configure.in
 2009-12-05 21:28  Mateusz Loskot <mateusz at loskot.net>
-	* [r2803] build/msvc80/Makefile.am, build/msvc80/geos.sln,
-	  build/msvc80/geos_xmltester,
-	  build/msvc80/geos_xmltester/Makefile.am,
-	  build/msvc80/geos_xmltester/geos_xmltester.vcproj: Added
-	  geos_xmltester.vcproj project to build/msvc80
+	* [r2803] Added geos_xmltester.vcproj project to build/msvc80
 2009-12-05 21:20  Mateusz Loskot <mateusz at loskot.net>
-	* [r2802] build/msvc80/geos_c_dll/geos_c_dll.vcproj: Added
-	  GEOS_DLL_EXPORT to preprocessor definitions in
+	* [r2802] Added GEOS_DLL_EXPORT to preprocessor definitions in
 2009-12-05 20:30  Mateusz Loskot <mateusz at loskot.net>
-	* [r2801] source/linearref/ExtractLineByLocation.cpp: small cleanup
+	* [r2801] small cleanup
 2009-12-05 20:23  Mateusz Loskot <mateusz at loskot.net>
-	* [r2800] build/msvc80/geos.sln,
-	  build/msvc80/geos_c_dll/geos_c_dll.vcproj,
-	  build/msvc80/geos_lib/geos_lib.vcproj,
-	  build/msvc80/geos_unit/geos_unit.vcproj: Updated solution for
-	  Visual C++ 8.0 (Visual Studio 2005) (Ticket #303)
+	* [r2800] Updated solution for Visual C++ 8.0 (Visual Studio 2005)
+	  (Ticket #303)
 2009-12-05 20:21  Mateusz Loskot <mateusz at loskot.net>
-	* [r2799] build/README: Updated information in README about
-	  build/msvcXY solutions
+	* [r2799] Updated information in README about build/msvcXY
+	  solutions
 2009-12-04 17:38  Mateusz Loskot <mateusz at loskot.net>
-	* [r2798] configure.in: Updated configure.in with msvc10
+	* [r2798] Updated configure.in with msvc10
 2009-12-04 17:05  Mateusz Loskot <mateusz at loskot.net>
-	* [r2797] build/Makefile.am, build/msvc10,
-	  build/msvc10/Makefile.am, build/msvc10/README,
-	  build/msvc10/geos.sln, build/msvc10/geos_c_dll,
-	  build/msvc10/geos_c_dll/Makefile.am,
-	  build/msvc10/geos_c_dll/geos_c_dll.vcxproj,
-	  build/msvc10/geos_c_dll/geos_c_dll.vcxproj.filters,
-	  build/msvc10/geos_lib, build/msvc10/geos_lib/Makefile.am,
-	  build/msvc10/geos_lib/geos_lib.vcxproj,
-	  build/msvc10/geos_lib/geos_lib.vcxproj.filters,
-	  build/msvc10/geos_unit, build/msvc10/geos_unit/Makefile.am,
-	  build/msvc10/geos_unit/geos_unit.vcxproj,
-	  build/msvc10/geos_unit/geos_unit.vcxproj.filters,
-	  build/msvc10/geos_xmltester/Makefile.am,
-	  build/msvc10/geos_xmltester/geos_xmltester.vcxproj,
-	  build/msvc10/geos_xmltester/geos_xmltester.vcxproj.filters: Added
-	  solution and projects for Visual Studio 2010 (note msvc90 denotes
-	  9.0 however msvc10 is 10 not 1.0)
+	* [r2797] Added solution and projects for Visual Studio 2010 (note
+	  msvc90 denotes 9.0 however msvc10 is 10 not 1.0)
 2009-12-04 15:58  Mateusz Loskot <mateusz at loskot.net>
-	* [r2796] tests/unit/geos_unit.cpp: Missing svn keywords
+	* [r2796] Missing svn keywords
 2009-12-04 15:30  Mateusz Loskot <mateusz at loskot.net>
-	* [r2795] tests/unit/tut/tut_exception.hpp: Small fixes to TUT.
+	* [r2795] Small fixes to TUT.
 2009-12-04 15:20  Mateusz Loskot <mateusz at loskot.net>
-	* [r2794] source/io/WKBReader.cpp: Replaced long with
-	  std::streampos
+	* [r2794] Replaced long with std::streampos
 2009-12-04 15:07  Mateusz Loskot <mateusz at loskot.net>
-	* [r2793] source/geom/CoordinateSequence.cpp: std::back_inserter
-	  requires <iterator> in geom/CoordinateSequence.cpp
+	* [r2793] std::back_inserter requires <iterator> in
+	  geom/CoordinateSequence.cpp
 2009-12-04 13:57  Mateusz Loskot <mateusz at loskot.net>
-	* [r2792] build/msvc90/geos_lib/geos_lib.vcproj: Updated Visual C++
-	  9.0 project
+	* [r2792] Updated Visual C++ 9.0 project
 2009-12-03 22:51  Mateusz Loskot <mateusz at loskot.net>
-	* [r2791] source/headers/geos/export.h: Yet another try to fix EOL
-	  in geos/export.h
+	* [r2791] Yet another try to fix EOL in geos/export.h
 2009-12-03 20:29  Mateusz Loskot <mateusz at loskot.net>
-	* [r2790] source/headers/geos/export.h: Removed mysterious extra
-	  tokens (blanks) from geos/export.h
+	* [r2790] Removed mysterious extra tokens (blanks) from
+	  geos/export.h
 2009-12-03 20:16  Mateusz Loskot <mateusz at loskot.net>
-	* [r2789] source/headers/geos/export.h: Removed mysterious extra
+	* [r2789] Removed mysterious extra tokens (blanks) from
+	  geos/export.h
 2009-12-03 20:01  Mateusz Loskot <mateusz at loskot.net>
-	* [r2788] build/msvc90/geos_unit/geos_unit.vcproj: Updated Visual
-	  C++ project geos_unit.vcproj
+	* [r2788] Updated Visual C++ project geos_unit.vcproj
 2009-12-03 19:59  Mateusz Loskot <mateusz at loskot.net>
-	* [r2787] source/headers/geos/platform.h.vc,
-	  source/headers/geos/timeval.h: Part 26 of larger changeset -
-	  source/headers:
+	* [r2787] Part 26 of larger changeset - source/headers:
 	  * Refine FINITE macro - pseudo-POSIX layer in Visual C++ does not
 	  offer long double version of finite()
 	  * Tidy up.
 2009-12-03 19:57  Mateusz Loskot <mateusz at loskot.net>
-	* [r2786] source/headers/geos/util/UniqueCoordinateArrayFilter.h:
-	  Part 25 of larger changeset - source/headers/geos/util:
+	* [r2786] Part 25 of larger changeset - source/headers/geos/util:
 	  * Declare noncopyable types as such explicitly (Ticket #304).
 	  * Tidy up.
 2009-12-03 19:55  Mateusz Loskot <mateusz at loskot.net>
-	* [r2785]
-	  source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h,
-	  source/headers/geos/simplify/DouglasPeuckerSimplifier.h,
-	  source/headers/geos/simplify/LineSegmentIndex.h,
-	  source/headers/geos/simplify/TaggedLineSegment.h,
-	  source/headers/geos/simplify/TaggedLineString.h,
-	  source/headers/geos/simplify/TaggedLineStringSimplifier.h,
-	  source/headers/geos/simplify/TaggedLinesSimplifier.h,
-	  source/headers/geos/simplify/TopologyPreservingSimplifier.h: Part
-	  24 of larger changeset - source/headers/geos/simplify:
+	* [r2785] Part 24 of larger changeset -
+	  source/headers/geos/simplify:
 	  * Tidy up.
 2009-12-03 19:52  Mateusz Loskot <mateusz at loskot.net>
-	* [r2784] source/headers/geos/planargraph/Subgraph.h: Part 23 of
-	  larger changeset - source/headers/geos/planargraph
+	* [r2784] Part 23 of larger changeset -
+	  source/headers/geos/planargraph
 	  * Tidy up.
 2009-12-03 19:51  Mateusz Loskot <mateusz at loskot.net>
-	* [r2783]
-	  source/headers/geos/planargraph/algorithm/ConnectedSubgraphFinder.h:
-	  Part 22 of larger changeset -
+	* [r2783] Part 22 of larger changeset -
 	  source/headers/geos/planargraph/algorithm:
 	  * Tidy up.
 2009-12-03 19:50  Mateusz Loskot <mateusz at loskot.net>
-	* [r2782]
-	  source/headers/geos/operation/valid/ConnectedInteriorTester.h:
-	  Part 21 of larger changeset -
+	* [r2782] Part 21 of larger changeset -
 	  source/headers/geos/operation/valid:
 	  * Tidy up.
 2009-12-03 19:48  Mateusz Loskot <mateusz at loskot.net>
-	* [r2781]
-	  source/headers/geos/operation/predicate/RectangleContains.h,
-	  source/headers/geos/operation/predicate/RectangleIntersects.h:
-	  Part 20 of larger changeset -
+	* [r2781] Part 20 of larger changeset -
 	  source/headers/geos/operation/overlay:
 	  * Unified EOL and style.
@@ -361,15 +281,7 @@
 2009-12-03 19:46  Mateusz Loskot <mateusz at loskot.net>
-	* [r2780] source/headers/geos/operation/overlay/ElevationMatrix.h,
-	  source/headers/geos/operation/overlay/validate/FuzzyPointLocator.h,
-	  source/headers/geos/operation/overlay/validate/OffsetPointGenerator.h,
-	  source/headers/geos/operation/overlay/validate/OverlayResultValidator.h:
-	  Part 19 of larger changeset -
+	* [r2780] Part 19 of larger changeset -
 	  * Tidy up.
@@ -377,10 +289,7 @@
 2009-12-03 19:45  Mateusz Loskot <mateusz at loskot.net>
-	* [r2779] source/headers/geos/operation/buffer/BufferBuilder.h,
-	  source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
-	  source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h:
-	  Part 18of larger changeset -
+	* [r2779] Part 18of larger changeset -
 	  source/headers/geos/operation/buffer:
 	  * Tidy up.
@@ -388,20 +297,7 @@
 2009-12-03 19:44  Mateusz Loskot <mateusz at loskot.net>
-	* [r2778] source/headers/geos/noding/FastNodingValidator.h,
-	  source/headers/geos/noding/IntersectionAdder.h,
-	  source/headers/geos/noding/IntersectionFinderAdder.h,
-	  source/headers/geos/noding/MCIndexNoder.h,
-	  source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h,
-	  source/headers/geos/noding/NodedSegmentString.h,
-	  source/headers/geos/noding/NodingValidator.h,
-	  source/headers/geos/noding/ScaledNoder.h,
-	  source/headers/geos/noding/SegmentNode.h,
-	  source/headers/geos/noding/SegmentNodeList.h,
-	  source/headers/geos/noding/SegmentString.h,
-	  source/headers/geos/noding/SingleInteriorIntersectionFinder.h:
-	  Part 17 of larger changeset -
+	* [r2778] Part 17 of larger changeset -
 	  source/headers/geos/noding/snapround:
 	  * Added Visual C++ pragmas.
@@ -410,11 +306,8 @@
 2009-12-03 19:41  Mateusz Loskot <mateusz at loskot.net>
-	* [r2777] source/headers/geos/noding/snapround/HotPixel.h,
-	  source/headers/geos/noding/snapround/MCIndexPointSnapper.h,
-	  source/headers/geos/noding/snapround/MCIndexSnapRounder.h,
-	  source/headers/geos/noding/snapround/SimpleSnapRounder.h: Part 16
-	  of larger changeset - source/headers/geos/noding/snapround:
+	* [r2777] Part 16 of larger changeset -
+	  source/headers/geos/noding/snapround:
 	  * Tidy up.
@@ -422,1899 +315,1029 @@
 2009-12-03 19:39  Mateusz Loskot <mateusz at loskot.net>
-	* [r2776] source/headers/geos/linearref/LinearIterator.h: Part 15
-	  of larger changeset - source/headers/geos/linearref:
+	* [r2776] Part 15 of larger changeset -
+	  source/headers/geos/linearref:
 	  * Tidy up.
 2009-12-03 19:38  Mateusz Loskot <mateusz at loskot.net>
-	* [r2775] source/headers/geos/io/StringTokenizer.h,
-	  source/headers/geos/io/WKBReader.h: Part 14 of larger changeset -
-	  source/headers/geos/io:
+	* [r2775] Part 14 of larger changeset - source/headers/geos/io:
 	  * Tidy up.
 2009-12-03 19:36  Mateusz Loskot <mateusz at loskot.net>
-	* [r2774] source/headers/geos/index/chain/MonotoneChain.h: Part 13
-	  of larger changeset - source/headers/geos/index/chain:
+	* [r2774] Part 13 of larger changeset -
+	  source/headers/geos/index/chain:
 	  * Tidy up.
-	* [r2773] source/headers/geos/geomgraph/GeometryGraph.h,
-	  source/headers/geos/geomgraph/NodeMap.h: Part 12 of larger
-	  changeset - source/headers/geos/geomgraph:
+	* [r2773] Part 12 of larger changeset -
+	  source/headers/geos/geomgraph:
 	  * Tidy up.
 2009-12-03 19:30  Mateusz Loskot <mateusz at loskot.net>
-	* [r2772]
-	  source/headers/geos/geom/util/ComponentCoordinateExtracter.h,
-	  source/headers/geos/geom/util/GeometryCombiner.h,
-	  source/headers/geos/geom/util/GeometryTransformer.h,
-	  source/headers/geos/geom/util/LinearComponentExtracter.h,
-	  source/headers/geos/geom/util/PointExtracter.h,
-	  source/headers/geos/geom/util/PolygonExtracter.h: Part 11 of
-	  larger changeset - source/headers/geos/geom/util:
+	* [r2772] Part 11 of larger changeset -
+	  source/headers/geos/geom/util:
 	  * Tidy up.
 2009-12-03 19:29  Mateusz Loskot <mateusz at loskot.net>
-	* [r2771]
-	  source/headers/geos/geom/prep/PreparedLineStringIntersects.h,
-	  source/headers/geos/geom/prep/PreparedPolygonPredicate.h: Part
-	  10of larger changeset - source/headers/geos/geom/prep:
+	* [r2771] Part 10of larger changeset -
+	  source/headers/geos/geom/prep:
 	  * Tidy up.
 2009-12-03 19:27  Mateusz Loskot <mateusz at loskot.net>
-	* [r2770] source/headers/geos/algorithm/RayCrossingCounter.h,
-	  source/headers/geos/algorithm/locate/IndexedPointInAreaLocator.h:
-	  Part 9 of larger changeset - source/headers/geos/algorithm:
+	* [r2770] Part 9 of larger changeset -
+	  source/headers/geos/algorithm:
 	  * Tidy up.
 2009-12-03 19:24  Mateusz Loskot <mateusz at loskot.net>
-	* [r2769] source/geomgraph/PlanarGraph.cpp: Part 7 of larger
-	  changeset - source/geomgraph:
+	* [r2769] Part 7 of larger changeset - source/geomgraph:
 	  * Fixed incorrect int to string conversion.
 2009-12-03 19:23  Mateusz Loskot <mateusz at loskot.net>
-	* [r2768] source/index/intervalrtree/SortedPackedIntervalRTree.cpp:
-	  Part 7 of larger changeset - source/index/intervalrtree:
+	* [r2768] Part 7 of larger changeset - source/index/intervalrtree:
 	  * Tidy up.
 2009-12-03 19:22  Mateusz Loskot <mateusz at loskot.net>
-	* [r2767] source/noding/ScaledNoder.cpp: Refined changeset r2766 -
-	  fix for nested classes required by GCC.
+	* [r2767] Refined changeset r2766 - fix for nested classes required
+	  by GCC.
 2009-12-03 19:14  Mateusz Loskot <mateusz at loskot.net>
-	* [r2766] source/noding/OrientedCoordinateArray.cpp,
-	  source/noding/ScaledNoder.cpp: Part 6 of larger changeset -
-	  source/noding:
+	* [r2766] Part 6 of larger changeset - source/noding:
 	  * Tidy up.
 2009-12-03 19:11  Mateusz Loskot <mateusz at loskot.net>
-	* [r2765] source/noding/snapround/MCIndexPointSnapper.cpp: Part 5
-	  of larger changeset - source/noding/snapround:
+	* [r2765] Part 5 of larger changeset - source/noding/snapround:
 	  * Tidy up.
 2009-12-03 19:03  Mateusz Loskot <mateusz at loskot.net>
-	* [r2764] source/algorithm/RobustDeterminant.cpp: Part 4 of larger
-	  changeset - source/algorithm:
+	* [r2764] Part 4 of larger changeset - source/algorithm:
 	  * Tidy up.
 2009-12-03 19:02  Mateusz Loskot <mateusz at loskot.net>
-	* [r2763] source/operation/buffer/BufferInputLineSimplifier.h,
-	  source/operation/buffer/OffsetCurveBuilder.cpp,
-	  source/operation/linemerge/LineSequencer.cpp,
-	  source/operation/overlay/OverlayOp.cpp,
-	  source/operation/overlay/PolygonBuilder.cpp,
-	  source/operation/predicate/RectangleIntersects.cpp,
-	  source/operation/valid/IsValidOp.cpp: Part 3 of larger changeset
-	  - source/operation:
+	* [r2763] Part 3 of larger changeset - source/operation:
 	  * Tidy up.
 2009-12-03 19:01  Mateusz Loskot <mateusz at loskot.net>
-	* [r2762] source/simplify/TopologyPreservingSimplifier.cpp: Part 2
-	  of larger changeset - source/simplify:
+	* [r2762] Part 2 of larger changeset - source/simplify:
 	  * Cleanup.
 	  * Unified EOL to LF.
 2009-12-03 18:56  Mateusz Loskot <mateusz at loskot.net>
-	* [r2761] tests/unit/algorithm/RobustLineIntersectionTest.cpp,
-	  tests/unit/geom/CoordinateTest.cpp,
-	  tests/unit/geom/GeometryFactoryTest.cpp,
-	  tests/unit/geom/IntersectionMatrixTest.cpp,
-	  tests/unit/geom/LinearRingTest.cpp,
-	  tests/unit/geom/MultiPointTest.cpp,
-	  tests/unit/geom/PolygonTest.cpp,
-	  tests/unit/geom/TriangleTest.cpp,
-	  tests/unit/io/ByteOrderValuesTest.cpp,
-	  tests/unit/noding/BasicSegmentStringTest.cpp,
-	  tests/unit/noding/NodedSegmentStringTest.cpp: Part 1 of larger
-	  changeset - tests/unit:
+	* [r2761] Part 1 of larger changeset - tests/unit:
 	  * Cleanup.
 2009-12-03 14:48  Mateusz Loskot <mateusz at loskot.net>
-	* [r2760] tests/unit/operation/valid/IsValidTest.cpp,
-	  tests/xmltester/XMLTester.cpp: * Added Visual C++ pragmas.
+	* [r2760] * Added Visual C++ pragmas.
 	  * Fixed implicit pointer tests for 0 (save typing is a myth, be
 	  explicit is bless).
 2009-12-03 13:25  Mateusz Loskot <mateusz at loskot.net>
-	* [r2759] tests/unit/geos_unit.cpp,
-	  tests/unit/tut/tut_restartable.hpp, tests/xmltester/XMLTester.h:
-	  Updated C++ TUT framework.
+	* [r2759] Updated C++ TUT framework.
 2009-12-01 16:16  Mateusz Loskot <mateusz at loskot.net>
-	* [r2758] source/geom/util/CoordinateOperation.cpp,
-	  source/io/WKBReader.cpp,
-	  source/operation/distance/DistanceOp.cpp,
-	  tests/unit/geos_unit.cpp: Improved WKBReader::readHEX to read WKB
-	  encoded with lower-case hex digits, useful if combined with SQL
+	* [r2758] Improved WKBReader::readHEX to read WKB encoded with
+	  lower-case hex digits, useful if combined with SQL
 	  encode(geometry, 'hex')
 2009-12-01 15:39  Mateusz Loskot <mateusz at loskot.net>
-	* [r2757] build/msvc90/geos_lib/geos_lib.vcproj,
-	  capi/geos_ts_c.cpp, source/geom/GeometryComponentFilter.cpp,
-	  source/geom/PrecisionModel.cpp,
-	  source/geom/util/GeometryTransformer.cpp,
-	  source/headers/geos/geom/BinaryOp.h,
-	  source/headers/geos/geom/Geometry.h,
-	  source/headers/geos/noding/Octant.h,
-	  source/headers/geos/operation/overlay/PointBuilder.h,
-	  source/headers/geos/util.h, source/index/quadtree/NodeBase.cpp,
-	  source/noding/NodedSegmentString.cpp,
-	  source/noding/ScaledNoder.cpp,
-	  source/noding/snapround/MCIndexPointSnapper.cpp,
-	  source/operation/overlay/validate/FuzzyPointLocator.cpp,
-	  source/precision/CommonBitsRemover.cpp,
-	  source/simplify/DouglasPeuckerSimplifier.cpp,
-	  tests/unit/geom/DimensionTest.cpp,
-	  tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp,
-	  tests/unit/operation/buffer/BufferOpTest.cpp: * More fixes for
-	  incompleteness of types required by std::auto_ptr
+	* [r2757] * More fixes for incompleteness of types required by
+	  std::auto_ptr
 	  * Replaced utility macros with disappearing ignorance template
 	  trick.
 2009-12-01 13:05  Mateusz Loskot <mateusz at loskot.net>
-	* [r2756] build/msvc90/geos_c_dll/geos_c_dll.vcproj,
-	  build/msvc90/geos_lib/geos_lib.vcproj,
-	  build/msvc90/geos_unit/geos_unit.vcproj,
-	  build/msvc90/geos_xmltester/geos_xmltester.vcproj: Tweaked
-	  projects for Visual Studio 2008
+	* [r2756] Tweaked projects for Visual Studio 2008
 2009-11-30 17:29  Mateusz Loskot <mateusz at loskot.net>
-	* [r2755] capi/geos_ts_c.cpp, source/geomgraph/EdgeEnd.cpp,
-	  source/precision/EnhancedPrecisionOp.cpp: * GEOSFree_r should
-	  check context handle even if its not used - nullptr may indicate
-	  logic error.
+	* [r2755] * GEOSFree_r should check context handle even if its not
+	  used - nullptr may indicate logic error.
 2009-11-30 13:55  Mateusz Loskot <mateusz at loskot.net>
-	* [r2754] build/msvc90/geos_c_dll/geos_c_dll.vcproj,
-	  build/msvc90/geos_xmltester/geos_xmltester.vcproj,
-	  source/geom/GeometryCollection.cpp,
-	  source/headers/geos/simplify/TopologyPreservingSimplifier.h,
-	  source/io/WKTReader.cpp,
-	  source/linearref/ExtractLineByLocation.cpp: * Fixed incomplete
-	  types Geometry and TaggedLinesSimplifier in
-	  TopologyPreservingSimplifier.h - required by std::auto_ptr
+	* [r2754] * Fixed incomplete types Geometry and
+	  TaggedLinesSimplifier in TopologyPreservingSimplifier.h -
+	  required by std::auto_ptr
 	  * Removed unreachable code.
 	  * Removed /Wp64 option from Visual Studio 2008 projects.
 2009-11-30 12:25  Mateusz Loskot <mateusz at loskot.net>
-	* [r2753] ChangeLog: Missing log.
+	* [r2753] Missing log.
 2009-11-30 10:48  Mateusz Loskot <mateusz at loskot.net>
-	* [r2752] build/msvc90/geos_unit/geos_unit.vcproj,
-	  tests/unit/linearref/LengthIndexedLineTest.cpp: * Added missing
-	  tests to Visual Studio 2008 project
+	* [r2752] * Added missing tests to Visual Studio 2008 project
 	  * Replaced call to isnan() missing in Visual C++ with ISNAN macro
 2009-11-29 10:09  Sandro Santilli <strk at keybit.net>
-	* [r2749] ChangeLog: updated
+	* [r2749] updated
 2009-11-26 21:42  Sandro Santilli <strk at keybit.net>
-	* [r2748] source/headers/geos/platform.h.in: Add ISNAN support in
-	  platform.h.in
+	* [r2748] Add ISNAN support in platform.h.in
 2009-11-26 21:34  Sandro Santilli <strk at keybit.net>
-	* [r2747] source/geom/util/LinearComponentExtracter.cpp,
-	  source/geom/util/Makefile.am,
-	  source/geom/util/PointExtracter.cpp,
-	  source/geom/util/PolygonExtracter.cpp,
-	  source/util/AssertionFailedException.cpp,
-	  source/util/IllegalArgumentException.cpp,
-	  source/util/Makefile.am,
-	  source/util/UnsupportedOperationException.cpp: Remove
-	  unreferenced files from the repository
+	* [r2747] Remove unreferenced files from the repository
 2009-11-26 21:28  Sandro Santilli <strk at keybit.net>
-	* [r2746] build/msvc90/geos_lib/geos_lib.vcproj: Remove reference
-	  to files not needing to go in the dll
+	* [r2746] Remove reference to files not needing to go in the dll
 2009-11-26 21:21  Sandro Santilli <strk at keybit.net>
-	* [r2745] source/geom/CoordinateSequenceFactory.cpp,
-	  source/geom/Makefile.am,
-	  source/headers/geos/geom/CoordinateSequenceFactory.h: Put
-	  destructor of the CoordinateSequenceFactory in an implementation
-	  file, hopefully reducing linker confusion about RTTI (see ticket
-	  #299)
+	* [r2745] Put destructor of the CoordinateSequenceFactory in an
+	  implementation file, hopefully reducing linker confusion about
+	  RTTI (see ticket #299)
 2009-11-26 19:49  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2744] configure.in: Add magic flags for OS/X Snow Leopard only.
-	  (#299)
+	* [r2744] Add magic flags for OS/X Snow Leopard only. (#299)
 2009-11-26 19:46  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2743] configure.in: Add vc90 xmltester target to Makefile build
+	* [r2743] Add vc90 xmltester target to Makefile build
 2009-11-26 18:29  Frank Warmerdam <warmerdam at pobox.com>
-	* [r2742] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
-	  clarify ownership of returned buffer from wkbwriter
+	* [r2742] clarify ownership of returned buffer from wkbwriter
 2009-11-26 16:32  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2741] Makefile.am, build/msvc90/Makefile.am,
-	  build/msvc90/geos_xmltester/Makefile.am: Fix missing components
-	  in tarball (#300)
+	* [r2741] Fix missing components in tarball (#300)
 2009-11-24 18:05  Sandro Santilli <strk at keybit.net>
-	* [r2736] ChangeLog: updated
+	* [r2736] updated
 2009-11-23 18:17  Sandro Santilli <strk at keybit.net>
-	* [r2735] tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp:
-	  Coordiante->Coordinate
+	* [r2735] Coordiante->Coordinate
 2009-11-23 18:06  Sandro Santilli <strk at keybit.net>
-	* [r2734] source/geom/Geometry.cpp: Avoid reallocations in Union
-	  short-circuit
+	* [r2734] Avoid reallocations in Union short-circuit
 2009-11-20 19:58  Sandro Santilli <strk at keybit.net>
-	* [r2733] source/headers/geos/planargraph/NodeMap.h,
-	  source/headers/geos/planargraph/PlanarGraph.h,
-	  source/operation/linemerge/LineMerger.cpp,
-	  source/operation/polygonize/PolygonizeGraph.cpp,
-	  source/planargraph/NodeMap.cpp: Don't force heap allocation of
-	  vectors for getting nodes of a NodeMap
+	* [r2733] Don't force heap allocation of vectors for getting nodes
+	  of a NodeMap
 2009-11-19 21:30  Sandro Santilli <strk at keybit.net>
-	* [r2732]
-	  source/noding/MCIndexSegmentSetMutualIntersector.cpp: Don't
-	  heap-allocate std::vector in MCIndexSegmentSetMutualIntersector
+	* [r2732] Don't heap-allocate std::vector in
+	  MCIndexSegmentSetMutualIntersector
 2009-11-19 21:06  Sandro Santilli <strk at keybit.net>
-	* [r2731] source/headers/geos/operation/overlay/MaximalEdgeRing.h,
-	  source/headers/geos/operation/valid/ConnectedInteriorTester.h,
-	  source/operation/overlay/MaximalEdgeRing.cpp,
-	  source/operation/valid/ConnectedInteriorTester.cpp: Don't force
-	  heap allocation when building edge rings for isValidOp
+	* [r2731] Don't force heap allocation when building edge rings for
+	  isValidOp
 2009-11-19 20:29  Sandro Santilli <strk at keybit.net>
-	* [r2730]
-	  source/headers/geos/operation/polygonize/PolygonizeGraph.h,
-	  source/operation/polygonize/Polygonizer.cpp: Don't force heap
-	  allocation of std::vector in PolygonizeGraph when deleting
-	  dangles (moved allocation higher, in Polygonizer, so needs a
-	  second pass)
+	* [r2730] Don't force heap allocation of std::vector in
+	  PolygonizeGraph when deleting dangles (moved allocation higher,
+	  in Polygonizer, so needs a second pass)
 2009-11-19 20:20  Sandro Santilli <strk at keybit.net>
-	* [r2729]
-	  source/operation/polygonize/PolygonizeGraph.cpp: don't
-	  heap-allocate vectors in findLabeledEdgeRings
+	* [r2729] don't heap-allocate vectors in findLabeledEdgeRings
 2009-11-19 19:57  Sandro Santilli <strk at keybit.net>
-	* [r2728]
-	  source/headers/geos/operation/polygonize/Polygonizer.h,
-	  source/operation/polygonize/Polygonizer.cpp: Move heap-allocation
-	  of vector used for 'cut-lines' containment out of PolygonizeGraph
-	  (but into Polygonizer)
+	* [r2728] Move heap-allocation of vector used for 'cut-lines'
+	  containment out of PolygonizeGraph (but into Polygonizer)
 2009-11-19 19:31  Sandro Santilli <strk at keybit.net>
-	* [r2727]
-	  source/operation/polygonize/PolygonizeGraph.cpp: Don't force
-	  heap-allocation of vectors for finding/labeling edge rings
+	* [r2727] Don't force heap-allocation of vectors for
+	  finding/labeling edge rings
 2009-11-19 19:19  Sandro Santilli <strk at keybit.net>
-	* [r2726]
-	  source/operation/polygonize/Polygonizer.cpp: Change
-	  PolygonizeGraph::getEdgeRings signature so not to force heap
-	  allocation of std::vector, update Polygonizer accordingly
+	* [r2726] Change PolygonizeGraph::getEdgeRings signature so not to
+	  force heap allocation of std::vector, update Polygonizer
+	  accordingly
 2009-11-19 19:06  Sandro Santilli <strk at keybit.net>
-	* [r2725]
-	  source/operation/polygonize/PolygonizeGraph.cpp: Do not
-	  heap-allocate vector of Node when finding intersections
+	* [r2725] Do not heap-allocate vector of Node when finding
+	  intersections
 2009-11-19 18:52  Sandro Santilli <strk at keybit.net>
-	* [r2724] source/headers/geos/index/strtree/AbstractNode.h,
-	  source/index/strtree/AbstractNode.cpp: Don not allocate the
-	  container of STRtree node childs on the heap
+	* [r2724] Don not allocate the container of STRtree node childs on
+	  the heap
 2009-11-19 16:40  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2723] source/geomgraph/index/SegmentIntersector.cpp,
-	  tests/xmltester/XMLTester.cpp: Apply patch for --disable-cassert
-	  compilation (#291)
+	* [r2723] Apply patch for --disable-cassert compilation (#291)
 2009-11-18 18:57  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2720] HOWTO_RELEASE: Reverse the upgrade process a bit, bump up
-	  revision numbers *after* release so that the repo version is
-	  always one higher than the release version. (#287)
+	* [r2720] Reverse the upgrade process a bit, bump up revision
+	  numbers *after* release so that the repo version is always one
+	  higher than the release version. (#287)
 2009-11-18 01:28  Mateusz Loskot <mateusz at loskot.net>
-	* [r2717] ChangeLog, capi/geos_c.cpp, capi/geos_ts_c.cpp: Silent
-	  warning thrown by Visual C++ about mixed class and struct keyword
-	  (#269)
+	* [r2717] Silent warning thrown by Visual C++ about mixed class and
+	  struct keyword (#269)
 2009-11-17 20:29  Sandro Santilli <strk at keybit.net>
-	* [r2716] tests/unit/Makefile.am: Include capi::GEOSGeomFromWKB
-	  test in geos_unit build (should also distribute as side-effect)
+	* [r2716] Include capi::GEOSGeomFromWKB test in geos_unit build
+	  (should also distribute as side-effect)
 2009-11-11 23:05  Sandro Santilli <strk at keybit.net>
-	* [r2713] HOWTO_RELEASE, Makefile.am: Change ChangeLog generation
-	  rule so it doesn't mess with make dist. Reflect in HOW_TO_RELEASE
+	* [r2713] Change ChangeLog generation rule so it doesn't mess with
+	  make dist. Reflect in HOW_TO_RELEASE
 2009-11-10 23:54  Sandro Santilli <strk at keybit.net>
-	* [r2712] HOWTO_RELEASE, Makefile.am: Make ChangeLog target
-	  non-phony to keep 'distcheck' happy. Reorganize HOW_TO_RELEASE
-	  steps.
+	* [r2712] Make ChangeLog target non-phony to keep 'distcheck'
+	  happy. Reorganize HOW_TO_RELEASE steps.
 2009-11-10 22:58  Sandro Santilli <strk at keybit.net>
-	* [r2711] ChangeLog, HOWTO_RELEASE, NEWS: Package stuff for release
+	* [r2711] Package stuff for release
 2009-10-29 21:06  Mateusz Loskot <mateusz at loskot.net>
-	* [r2710] tests/unit/operation/buffer/BufferOpTest.cpp: Testing
-	  linker problem with DEFAULT_QUADRANT_SEGMENT constant
+	* [r2710] Testing linker problem with DEFAULT_QUADRANT_SEGMENT
+	  constant
 2009-10-29 20:58  Mateusz Loskot <mateusz at loskot.net>
-	* [r2709] tests/unit/operation/buffer/BufferOpTest.cpp: Testing
+	* [r2709] Testing linker problem with DEFAULT_QUADRANT_SEGMENT
+	  constant
 2009-10-29 20:55  Mateusz Loskot <mateusz at loskot.net>
-	* [r2708] tests/unit/operation/buffer/BufferOpTest.cpp: Fixed CRLF
-	  to LF in BufferOpTest.cpp
+	* [r2708] Fixed CRLF to LF in BufferOpTest.cpp
 2009-10-29 20:47  Mateusz Loskot <mateusz at loskot.net>
-	* [r2707] ChangeLog, tests/unit/operation/buffer/BufferOpTest.cpp:
-	  Missing include of BufferParameters.h header in BufferOpTest.cpp
-	  unit suite
+	* [r2707] Missing include of BufferParameters.h header in
+	  BufferOpTest.cpp unit suite
 2009-10-29 16:20  Mateusz Loskot <mateusz at loskot.net>
-	* [r2706] ChangeLog, tests/unit/operation/buffer/BufferOpTest.cpp:
-	  Added more test cases for buffer calculation based on A (input)
-	  geometries from XMLTester's buffer.xml and
+	* [r2706] Added more test cases for buffer calculation based on A
+	  (input) geometries from XMLTester's buffer.xml and
 	  TestBufferExternal2.xml tests.
 2009-10-29 15:11  Mateusz Loskot <mateusz at loskot.net>
-	* [r2705] ChangeLog, tests/unit/operation/buffer/BufferOpTest.cpp:
-	  Added test case for buffer of multipolygon from XMLTester's
-	  buffer.xml, case #25 but with custom quadrant segments
+	* [r2705] Added test case for buffer of multipolygon from
+	  XMLTester's buffer.xml, case #25 but with custom quadrant
+	  segments
 2009-10-29 14:24  Mateusz Loskot <mateusz at loskot.net>
-	* [r2704] ChangeLog, tests/unit/operation/buffer/BufferOpTest.cpp:
-	  Added test case for buffer of POINT(0 0) with distance 1.0 and 32
-	  quadrant segments.
+	* [r2704] Added test case for buffer of POINT(0 0) with distance
+	  1.0 and 32 quadrant segments.
 2009-10-29 12:33  Mateusz Loskot <mateusz at loskot.net>
-	* [r2703] ChangeLog, build/msvc90/geos_unit/geos_unit.vcproj,
-	  tests/unit/Makefile.am, tests/unit/operation/buffer,
-	  tests/unit/operation/buffer: added unit test case for BufferOp,
+	* [r2703] * tests/unit/operation/buffer: added unit test case for
+	  BufferOp,
 	  * tests/unit/Makefile.am: added new test case source to Makefile,
 	  * build/msvc90/geos_unit/geos_unit.vcproj: updated Visual C++
 	  project.
 2009-10-28 12:09  Mateusz Loskot <mateusz at loskot.net>
-	* [r2702] ChangeLog, build/msvc90/geos.sln,
-	  tests/xmltester/XMLTester.cpp: tests/xmltester/XMLTester.cpp:
-	  declare checkBufferSuccess function to take geometries by
-	  refernece to const
+	* [r2702] tests/xmltester/XMLTester.cpp: declare checkBufferSuccess
+	  function to take geometries by refernece to const
 2009-10-25 18:48  Mateusz Loskot <mateusz at loskot.net>
-	* [r2701] ChangeLog, source/headers/geos/geom/Geometry.h: Fixed
-	  typo in getCentroid function comment in Geometry.h.
+	* [r2701] Fixed typo in getCentroid function comment in Geometry.h.
 2009-10-23 13:04  Sandro Santilli <strk at keybit.net>
-	* [r2700] source/headers/geos/linearref/LinearLocation.h,
-	  source/linearref/LinearLocation.cpp: Have
-	  LinearLocation::getSegment return by auto_ptr to encode ownership
-	  transfer. Fixes leak reported in #296.
+	* [r2700] Have LinearLocation::getSegment return by auto_ptr to
+	  encode ownership transfer. Fixes leak reported in #296.
 2009-10-23 12:58  Sandro Santilli <strk at keybit.net>
-	* [r2699] source/headers/geos/linearref/LinearLocation.h,
-	  source/linearref/LinearLocation.cpp: Fix port info, add standard
-	  protection notes
+	* [r2699] Fix port info, add standard protection notes
 2009-10-23 10:21  Sandro Santilli <strk at keybit.net>
-	* [r2698] source/headers/geos/linearref/LinearGeometryBuilder.h,
-	  source/linearref/LinearGeometryBuilder.cpp: Add destructor to
-	  LinearGeometryBuilder fixing memory leaks there.
+	* [r2698] Add destructor to LinearGeometryBuilder fixing memory
+	  leaks there.
 2009-10-23 10:13  Sandro Santilli <strk at keybit.net>
-	* [r2697] source/linearref/LinearGeometryBuilder.cpp: Fix memory
-	  access error (#283)
+	* [r2697] Fix memory access error (#283)
 2009-10-23 10:03  Sandro Santilli <strk at keybit.net>
-	* [r2696] source/headers/geos/linearref/LinearGeometryBuilder.h,
-	  source/linearref/LinearGeometryBuilder.cpp: Fix port info for
+	* [r2696] Fix port info for LinearGeometryBuilder
 2009-10-23 09:53  Sandro Santilli <strk at keybit.net>
-	* [r2695] source/headers/geos/linearref/LinearGeometryBuilder.h,
-	  source/linearref/LinearGeometryBuilder.cpp: Cleanup
-	  LinearGeometrybuilder defs and impl to match common code style,
-	  add note about suspicious things (not written but noted that the
-	  class seems to lack a destructor..)
+	* [r2695] Cleanup LinearGeometrybuilder defs and impl to match
+	  common code style, add note about suspicious things (not written
+	  but noted that the class seems to lack a destructor..)
 2009-10-23 09:43  Sandro Santilli <strk at keybit.net>
-	* [r2694] source/headers/geos/linearref/LocationIndexOfLine.h,
-	  tests/unit/linearref/LengthIndexedLineTest.cpp: Document
-	  ownership of return from LocationIndexOfLine::indicesOf, fix
-	  mismatch delete/delete[] in core and unit test
+	* [r2694] Document ownership of return from
+	  LocationIndexOfLine::indicesOf, fix mismatch delete/delete[] in
+	  core and unit test
 2009-10-23 09:34  Sandro Santilli <strk at keybit.net>
-	* [r2693] source/headers/geos/algorithm/BoundaryNodeRule.h: Add
-	  virtual dtor to virtual class
+	* [r2693] Add virtual dtor to virtual class
 2009-10-23 09:33  Sandro Santilli <strk at keybit.net>
-	* [r2692] tests/xmltester/tinyxml/tinyxmlparser.cpp: add some
-	  parens to hush gcc warning
+	* [r2692] add some parens to hush gcc warning
 2009-10-23 09:00  Sandro Santilli <strk at keybit.net>
-	* [r2691] tests/unit/Makefile.am: Fix static building of C-api
-	  demo/tests
+	* [r2691] Fix static building of C-api demo/tests
 2009-10-23 08:34  Sandro Santilli <strk at keybit.net>
-	* [r2690] tests/xmltester/Makefile.am: Run the last
-	  available-but-no-automatically-run test: test.xml
+	* [r2690] Run the last available-but-no-automatically-run test:
+	  test.xml
 2009-10-22 18:18  Sandro Santilli <strk at keybit.net>
-	* [r2689] tests/xmltester/tests/buffer.xml,
-	  tests/xmltester/tests/buffer_snapround.xml: Merge
-	  buffer_snapround.xml into buffer.xml
+	* [r2689] Merge buffer_snapround.xml into buffer.xml
 2009-10-22 17:13  Sandro Santilli <strk at keybit.net>
-	* [r2688] tests/xmltester/Makefile.am: A quick check reveals that
-	  the tests in buffer.xml are not really duplicated elsewhere so we
-	  run that test too now as part of make check
+	* [r2688] A quick check reveals that the tests in buffer.xml are
+	  not really duplicated elsewhere so we run that test too now as
+	  part of make check
 2009-10-22 17:07  Sandro Santilli <strk at keybit.net>
-	* [r2687] tests/xmltester/tests/buffer.xml: Give buffer.xml cases a
-	  somewhat more helpful description, fix 4 expected results after
-	  eye-checking. This is still not automatically run case it might
-	  contain duplicated tests from elsewhere (to be checked).
+	* [r2687] Give buffer.xml cases a somewhat more helpful
+	  description, fix 4 expected results after eye-checking. This is
+	  still not automatically run case it might contain duplicated
+	  tests from elsewhere (to be checked).
 2009-10-22 16:30  Sandro Santilli <strk at keybit.net>
-	* [r2686] tests/xmltester/XMLTester.cpp: Don't segfault on EOF
-	  inside <op> tag
+	* [r2686] Don't segfault on EOF inside <op> tag
 2009-10-20 16:59  Sandro Santilli <strk at keybit.net>
-	* [r2685] source/headers/geos/index/strtree/AbstractSTRtree.h,
-	  source/index/strtree/STRtree.cpp: Commit MingW bug workaround
-	  provided by sanak in ticket #293
+	* [r2685] Commit MingW bug workaround provided by sanak in ticket
+	  #293
 2009-10-19 13:38  Mateusz Loskot <mateusz at loskot.net>
-	* [r2684] ChangeLog,
-	  tests/xmltester/tests/buffer_snapround.xml: not well-formed XML,
-	  fixed missing attribute.
+	* [r2684] tests/xmltester/tests/buffer_snapround.xml: not
+	  well-formed XML, fixed missing attribute.
 2009-10-17 14:47  Sandro Santilli <strk at keybit.net>
-	* [r2683] ChangeLog: updated
+	* [r2683] updated
 2009-10-17 14:43  Sandro Santilli <strk at keybit.net>
-	* [r2682] NEWS: updated
+	* [r2682] updated
 2009-10-17 14:35  Sandro Santilli <strk at keybit.net>
-	* [r2681] source/algorithm/distance/DistanceToPoint.cpp: Half the
-	  calls to the virtual CoordinateSequence::getAt when computing
-	  line distances
+	* [r2681] Half the calls to the virtual CoordinateSequence::getAt
+	  when computing line distances
 2009-10-17 13:40  Sandro Santilli <strk at keybit.net>
-	* [r2680] source/geom/CoordinateArraySequence.cpp: Drop pointless
-	  asserts. We'd abort anyway if vector is null. For the
-	  out-of-range case the GNU c++ lib helps debugging with an
-	  environment variable
+	* [r2680] Drop pointless asserts. We'd abort anyway if vector is
+	  null. For the out-of-range case the GNU c++ lib helps debugging
+	  with an environment variable
 2009-10-17 13:04  Sandro Santilli <strk at keybit.net>
-	* [r2679] source/noding/OrientedCoordinateArray.cpp: Add note of
-	  private/static nature of implemented methods
+	* [r2679] Add note of private/static nature of implemented methods
 2009-10-17 12:28  Sandro Santilli <strk at keybit.net>
-	* [r2678] source/geom/CoordinateArraySequence.cpp,
-	  source/geom/Polygon.cpp,
-	  source/headers/geos/geom/CoordinateArraySequence.h,
-	  source/headers/geos/geom/CoordinateSequence.h: Expose a usable
-	  toVector method for CoordinateSequence (ie: no memory management
-	  issues). Use it from Polygon::getCoordinates.
+	* [r2678] Expose a usable toVector method for CoordinateSequence
+	  (ie: no memory management issues). Use it from
+	  Polygon::getCoordinates.
 2009-10-17 12:02  Sandro Santilli <strk at keybit.net>
-	* [r2677] source/geom/Polygon.cpp: Don't allocate too much space
-	  for polygon points vector. Fixes bug #294.
+	* [r2677] Don't allocate too much space for polygon points vector.
+	  Fixes bug #294.
 2009-10-16 15:27  Mateusz Loskot <mateusz at loskot.net>
-	* [r2676] tests/xmltester/tests/fme.xml: xmltester/tests: missing
-	  double quotes around XML attribute value in fme.xml.
+	* [r2676] xmltester/tests: missing double quotes around XML
+	  attribute value in fme.xml.
 2009-10-14 20:42  Sandro Santilli <strk at keybit.net>
-	* [r2675] ChangeLog: regenerate ChangeLog
+	* [r2675] regenerate ChangeLog
 2009-10-14 15:32  Mateusz Loskot <mateusz at loskot.net>
-	* [r2674] build/msvc90/geos_unit/geos_unit.vcproj,
-	  tests/xmltester/XMLTester.cpp, tests/xmltester/makefile.vc: *
-	  Optional use of GEOS_DEBUG_MSVC_USE_VLD in XMLTester.cpp
+	* [r2674] * Optional use of GEOS_DEBUG_MSVC_USE_VLD in
+	  XMLTester.cpp
 	  * Added xmltester/makefile.vc as port of testrunner.sh for
 	  Windows to be able to run all tests in batch:
 	  ** nmake /f makefile.vc XMLTESTER=C:\path\to\xmltester.exe
 2009-10-14 12:05  Mateusz Loskot <mateusz at loskot.net>
-	* [r2673] build/msvc90/geos.sln, build/msvc90/geos_xmltester,
-	  build/msvc90/geos_xmltester/geos_xmltester.vcproj: Added
-	  msvc90/geos_xmltester to solution for Visual Studio 2008.
+	* [r2673] Added msvc90/geos_xmltester to solution for Visual Studio
+	  2008.
 2009-10-14 12:03  Mateusz Loskot <mateusz at loskot.net>
-	* [r2672] tests/xmltester/XMLTester.cpp: Enable use of Stalkwalker
-	  only if building with Visual C++ and GEOS_TEST_USE_STACKWALKER is
-	  defined.
+	* [r2672] Enable use of Stalkwalker only if building with Visual
+	  C++ and GEOS_TEST_USE_STACKWALKER is defined.
 2009-10-13 16:25  Mateusz Loskot <mateusz at loskot.net>
-	* [r2671] build/msvc90/geos_lib/geos_lib.vcproj: build/msvc90:
-	  added missing sources of linearref package. Builds with Visual
-	  C++ 9.0 (using both project and makefiles).
+	* [r2671] build/msvc90: added missing sources of linearref package.
+	  Builds with Visual C++ 9.0 (using both project and makefiles).
 2009-10-13 14:20  Frank Warmerdam <warmerdam at pobox.com>
-	* [r2670] ChangeLog, capi/geos_c.h.in, nmake.opt,
-	  source/Makefile.vc: fix nmake dll export, and link test programs
-	  (#288)
+	* [r2670] fix nmake dll export, and link test programs (#288)
 2009-10-08 12:51  Frank Warmerdam <warmerdam at pobox.com>
-	* [r2669] source/Makefile.vc, source/dirlist.mk: add new
-	  directories and source (#288)
+	* [r2669] add new directories and source (#288)
 2009-10-08 08:56  Sandro Santilli <strk at keybit.net>
-	* [r2668] ChangeLog: regenerate ChangeLog now that we have all
-	  names in
+	* [r2668] regenerate ChangeLog now that we have all names in
 2009-10-08 08:47  Sandro Santilli <strk at keybit.net>
-	* [r2667] authors.svn: Add other missing names/addresses
+	* [r2667] Add other missing names/addresses
 2009-10-08 08:40  Sandro Santilli <strk at keybit.net>
-	* [r2666] ChangeLog, ChangeLog.svn, Makefile.am: Automatically
-	  generate the ChangeLog file, forget ChangeLog.svn.
+	* [r2666] Automatically generate the ChangeLog file, forget
+	  ChangeLog.svn.
 2009-10-08 08:38  Sandro Santilli <strk at keybit.net>
-	* [r2665] source/operation/overlay/snap/SnapIfNeededOverlayOp.cpp:
-	  Don't signal topology exception when it triggers snapping
+	* [r2665] Don't signal topology exception when it triggers snapping
 2009-10-08 08:37  Sandro Santilli <strk at keybit.net>
-	* [r2664] authors.svn: Add yury, fernando and sean
+	* [r2664] Add yury, fernando and sean
 2009-10-08 08:17  Sandro Santilli <strk at keybit.net>
-	* [r2663] tests/unit/Makefile.am: Distribute all of TUT
+	* [r2663] Distribute all of TUT
 2009-10-08 07:56  Sandro Santilli <strk at keybit.net>
-	* [r2662] capi/geos_c.h.in, source/headers/geos/version.h.vc:
-	  Properly set version for win target
+	* [r2662] Properly set version for win target
 2009-10-07 07:53  Sandro Santilli <strk at keybit.net>
-	* [r2661] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
-	  tests/unit/capi/GEOSBufferTest.cpp: Expose single-sided buffering
-	  in C-API (see ticket #258)
+	* [r2661] Expose single-sided buffering in C-API (see ticket #258)
 2009-10-05 21:36  Sandro Santilli <strk at keybit.net>
-	* [r2659] source/algorithm/distance/DistanceToPoint.cpp,
-	  source/headers/geos/algorithm/distance/DistanceToPoint.h: Drop
-	  use of static data in DistanceToPoint class (for thread-safety)
+	* [r2659] Drop use of static data in DistanceToPoint class (for
+	  thread-safety)
 2009-10-05 19:29  Sandro Santilli <strk at keybit.net>
-	* [r2658] source/operation/buffer/BufferBuilder.cpp: release memory
-	  earlier, and closer to allocation
+	* [r2658] release memory earlier, and closer to allocation
 2009-10-05 19:04  Sandro Santilli <strk at keybit.net>
-	* [r2657] source/operation/buffer/BufferBuilder.cpp: Finish
-	  plugging leaks. Make check runs with no leaks.
+	* [r2657] Finish plugging leaks. Make check runs with no leaks.
 2009-10-05 18:42  Sandro Santilli <strk at keybit.net>
-	* [r2656]
-	  source/headers/geos/operation/buffer/OffsetCurveBuilder.h:
-	  another memory management doc
+	* [r2656] another memory management doc
 2009-10-05 18:40  Sandro Santilli <strk at keybit.net>
-	* [r2655]
-	  source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp: Document more
-	  memory management issues
+	* [r2655] Document more memory management issues
 2009-10-05 17:20  Sandro Santilli <strk at keybit.net>
-	* [r2654] source/operation/buffer/BufferBuilder.cpp,
-	  source/operation/buffer/OffsetCurveBuilder.cpp: More memory leak
-	  fixes in single-sided buffering implementation
+	* [r2654] More memory leak fixes in single-sided buffering
+	  implementation
 2009-10-05 16:58  Sandro Santilli <strk at keybit.net>
-	* [r2653] source/operation/buffer/BufferBuilder.cpp: Plug some
-	  memory leaks in single sided buffering implementation
+	* [r2653] Plug some memory leaks in single sided buffering
+	  implementation
 2009-10-05 16:44  Sandro Santilli <strk at keybit.net>
-	* [r2652] source/headers/geos/operation/linemerge/LineMerger.h:
-	  Document ownership of return from
+	* [r2652] Document ownership of return from
 	  LineMerger::getMergedLineStrings
 2009-10-05 16:40  Sandro Santilli <strk at keybit.net>
-	* [r2651] .vimrc: Alright, there's no standard style yet so this
-	  file is made empty, but good to have for reference
+	* [r2651] Alright, there's no standard style yet so this file is
+	  made empty, but good to have for reference
 2009-10-01 10:30  Sandro Santilli <strk at keybit.net>
-	* [r2650] source/operation/buffer/BufferBuilder.cpp: Throw an
-	  exception rather than returning NULL if input to single-sided
-	  buffer code is invalid
+	* [r2650] Throw an exception rather than returning NULL if input to
+	  single-sided buffer code is invalid
 2009-10-01 09:10  Sandro Santilli <strk at keybit.net>
-	* [r2649] source/operation/buffer/BufferBuilder.cpp,
-	  tests/xmltester/Makefile.am, tests/xmltester/tests/safe,
-	  tests/xmltester/tests/safe/16595.xml,
-	  tests/xmltester/tests/safe/16596.xml,
-	  tests/xmltester/tests/singlesidedbuffer.xml: Have single-sided
-	  buffer constructor return a simple LINESTRING when appropriate
-	  rather than forcing a MULTI; import 2 tests from the SAFE
-	  testsuite
+	* [r2649] Have single-sided buffer constructor return a simple
+	  LINESTRING when appropriate rather than forcing a MULTI; import 2
+	  tests from the SAFE testsuite
 2009-10-01 09:01  Sandro Santilli <strk at keybit.net>
-	* [r2648] tests/xmltester/safe_to_xml.sh: Better parse style
-	  parameter
+	* [r2648] Better parse style parameter
 2009-10-01 08:46  Sandro Santilli <strk at keybit.net>
-	* [r2647] tests/xmltester/safe_to_xml.sh: Add utility script to
-	  import tests from SAFE software
+	* [r2647] Add utility script to import tests from SAFE software
 2009-10-01 08:42  Sandro Santilli <strk at keybit.net>
-	* [r2646] tests/xmltester/XMLTester.cpp: Don't segfault on xml
-	  tests missing precision model specification
+	* [r2646] Don't segfault on xml tests missing precision model
+	  specification
 2009-10-01 07:24  Sandro Santilli <strk at keybit.net>
-	* [r2645] tests/xmltester/tests/singlesidedbuffer.xml: Re-enable
-	  the now succeeding test for sharp edges line single sided
-	  buffering
+	* [r2645] Re-enable the now succeeding test for sharp edges line
+	  single sided buffering
 2009-10-01 07:23  Sandro Santilli <strk at keybit.net>
-	* [r2644] source/operation/buffer/BufferBuilder.cpp: Use FLAT/BUTT
-	  endcaps when doing single sided buffering
+	* [r2644] Use FLAT/BUTT endcaps when doing single sided buffering
 2009-10-01 07:06  Sandro Santilli <strk at keybit.net>
-	* [r2643] source/operation/buffer/OffsetCurveBuilder.cpp: Fix
-	  trimming of left/right curves (ie: don't include the endcap)
+	* [r2643] Fix trimming of left/right curves (ie: don't include the
+	  endcap)
 2009-10-01 06:33  Sandro Santilli <strk at keybit.net>
-	* [r2642] source/operation/buffer/BufferBuilder.cpp: Use snapped
-	  intersection between full buffer boundary and single-sided offset
-	  curves
+	* [r2642] Use snapped intersection between full buffer boundary and
+	  single-sided offset curves
 2009-09-30 22:18  Sandro Santilli <strk at keybit.net>
-	* [r2641] tests/xmltester/SingleSidedBufferResultMatcher.cpp: Check
-	  hausdorff distance in both directions, or an expected output line
-	  longer than the obtained one would be found as correct
+	* [r2641] Check hausdorff distance in both directions, or an
+	  expected output line longer than the obtained one would be found
+	  as correct
 2009-09-30 20:27  Sandro Santilli <strk at keybit.net>
-	* [r2640] source/operation/buffer/BufferBuilder.cpp: Some debugging
-	  for single sided buffers
+	* [r2640] Some debugging for single sided buffers
 2009-09-30 19:18  Sandro Santilli <strk at keybit.net>
-	* [r2639] tests/xmltester/tests/singlesidedbuffer.xml: Another
-	  simple test for single-sided buffer (horizontal line, both
-	  directions)
+	* [r2639] Another simple test for single-sided buffer (horizontal
+	  line, both directions)
 2009-09-30 19:07  Sandro Santilli <strk at keybit.net>
-	* [r2638] tests/xmltester/tests/singlesidedbuffer.xml: Another
-	  simple test for a vertical line, opposite direction from previous
+	* [r2638] Another simple test for a vertical line, opposite
+	  direction from previous
 2009-09-30 19:05  Sandro Santilli <strk at keybit.net>
-	* [r2637] tests/xmltester/tests/singlesidedbuffer.xml: Add test for
-	  single sided buffer on simple, vertical, line (this one succeeds
-	  both left and right)
+	* [r2637] Add test for single sided buffer on simple, vertical,
+	  line (this one succeeds both left and right)
 2009-09-30 18:57  Sandro Santilli <strk at keybit.net>
-	* [r2636] .vimrc: VIM setting for GEOS source code style (3-spaces
-	  tabs)
+	* [r2636] VIM setting for GEOS source code style (3-spaces tabs)
 2009-09-30 14:14  Sandro Santilli <strk at keybit.net>
-	* [r2635] autogen.sh: Don't use non-standard escape sequences with
-	  'echo'
+	* [r2635] Don't use non-standard escape sequences with 'echo'
 2009-09-28 10:35  Sandro Santilli <strk at keybit.net>
-	* [r2634] tests/xmltester/Makefile.am,
-	  tests/xmltester/XMLTester.cpp, tests/xmltester/XMLTester.h,
-	  tests/xmltester/markup, tests/xmltester/tinyxml,
-	  tests/xmltester/tinyxml/tinyxmlparser.cpp: Replace
-	  no-commercial-use licenced MarkupSTL with tinyXML
+	* [r2634] Replace no-commercial-use licenced MarkupSTL with tinyXML
 2009-09-28 10:34  Sandro Santilli <strk at keybit.net>
-	* [r2633] tests/xmltester/tests/singlesidedbuffer.xml: Temporarly
-	  disable failing single sided buffer test
+	* [r2633] Temporarly disable failing single sided buffer test
 2009-09-28 10:10  Sandro Santilli <strk at keybit.net>
-	* [r2632] tests/xmltester/SingleSidedBufferResultMatcher.cpp: Oops,
-	  it seems I just don't want a test to fail ;)
+	* [r2632] Oops, it seems I just don't want a test to fail ;)
 2009-09-28 10:09  Sandro Santilli <strk at keybit.net>
-	* [r2631] tests/xmltester/SingleSidedBufferResultMatcher.cpp: Don't
-	  give a false success if one of the expected/obtained geometry is
-	  empty
+	* [r2631] Don't give a false success if one of the
+	  expected/obtained geometry is empty
 2009-09-28 09:03  Sandro Santilli <strk at keybit.net>
-	* [r2630] source/geom/PrecisionModel.cpp: Add offsets to
-	  PrecisionModel text output
+	* [r2630] Add offsets to PrecisionModel text output
 2009-09-28 07:02  Sandro Santilli <strk at keybit.net>
-	* [r2629] tests/xmltester/Makefile.am,
-	  tests/xmltester/tests/singlesidedbuffer.xml: Add an hausdorff
-	  distance based result matcher for single-sided buffer tests.
-	  Enable the single sided buffer test provided by swong in ticket
-	  #215 with minor tweak (expect multilinestring).
+	* [r2629] Add an hausdorff distance based result matcher for
+	  single-sided buffer tests. Enable the single sided buffer test
+	  provided by swong in ticket #215 with minor tweak (expect
+	  multilinestring).
 2009-09-27 20:43  Sandro Santilli <strk at keybit.net>
-	* [r2628] source/headers/geos/operation/buffer/BufferBuilder.h,
-	  source/operation/buffer/BufferBuilder.cpp,
-	  source/operation/buffer/OffsetCurveVertexList.h,
-	  tests/xmltester/XMLTester.cpp: Re-introduce the singlesided
-	  buffer patch. Tests still need to be worked on.
+	* [r2628] Re-introduce the singlesided buffer patch. Tests still
+	  need to be worked on.
 2009-09-21 19:47  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2626] source/geom/Polygon.cpp: Polygon with empty ring causes a
-	  crash in WKBReader (from Tamas Szekeres) (#290)
+	* [r2626] Polygon with empty ring causes a crash in WKBReader (from
+	  Tamas Szekeres) (#290)
 2009-09-11 18:47  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2624] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
-	  Patch for #285, C api for project and interpolate, from David
-	  Turner (novalis)
+	* [r2624] Patch for #285, C api for project and interpolate, from
+	  David Turner (novalis)
 2009-08-21 09:54  Mateusz Loskot <mateusz at loskot.net>
-	* [r2623] source/headers/geos/linearref, source/linearref: Updated
-	  svn:ignore property
+	* [r2623] Updated svn:ignore property
 2009-08-21 09:50  Mateusz Loskot <mateusz at loskot.net>
-	* [r2622] source/headers/geos/export.h,
-	  tests/unit/geom/CoordinateArraySequenceTest.cpp,
-	  tests/unit/geos_unit.cpp: Cleaned compilation warnings in unit
-	  tests.
+	* [r2622] Cleaned compilation warnings in unit tests.
 2009-08-21 09:43  Mateusz Loskot <mateusz at loskot.net>
-	* [r2621] tests/unit/tut/tut.hpp, tests/unit/tut/tut_assert.hpp,
-	  tests/unit/tut/tut_result.hpp, tests/unit/tut/tut_runner.hpp:
-	  Updated C++ TUT Framework to latest revision (147) of its SVN
-	  trunk
+	* [r2621] Updated C++ TUT Framework to latest revision (147) of its
+	  SVN trunk
 2009-08-15 13:26  Sandro Santilli <strk at keybit.net>
-	* [r2620] source/headers/geos/linearref/ExtractLineByLocation.h,
-	  source/linearref/LocationIndexOfPoint.cpp: Const correctness of
-	  LenghtIndexedLine port, by novalis (issue #284)
+	* [r2620] Const correctness of LenghtIndexedLine port, by novalis
+	  (issue #284)
 2009-08-12 19:01  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2619] configure.in, source/Makefile.am,
-	  source/headers/geos/Makefile.am,
-	  source/headers/geos/geom/CoordinateList.h,
-	  source/headers/geos/linearref,
-	  source/headers/geos/linearref/Makefile.am, source/linearref,
-	  source/linearref/Makefile.am, tests/unit/Makefile.am,
-	  tests/unit/linearref,
-	  tests/unit/linearref/LengthIndexedLineTest.cpp: Port of JTS
-	  linear referencing (from David Turner) (#283)
+	* [r2619] Port of JTS linear referencing (from David Turner) (#283)
 2009-08-02 23:39  Mateusz Loskot <mateusz at loskot.net>
-	* [r2618] source/operation/overlay/PolygonBuilder.cpp: Removed
-	  incomplete GEOS_DEBUG message causing compilation error because
-	  Edge type is incomplete.
+	* [r2618] Removed incomplete GEOS_DEBUG message causing compilation
+	  error because Edge type is incomplete.
 2009-08-02 23:15  Mateusz Loskot <mateusz at loskot.net>
-	* [r2617] source/geom/GeometryFactory.cpp: Fixed broken escape
-	  sequence in debug msg.
+	* [r2617] Fixed broken escape sequence in debug msg.
 2009-07-17 22:23  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2616] source/headers/geos/io/WKBReader.h,
-	  source/io/WKBReader.cpp: Remove static string in WKB reader
-	  (#232)
+	* [r2616] Remove static string in WKB reader (#232)
 2009-07-15 18:56  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2613] swig/geos.i.in, swig/ruby/ruby.i: Add PreparedGeometry
-	  and STRtree support to SWIG (#279) Schuyler Erle
+	* [r2613] Add PreparedGeometry and STRtree support to SWIG (#279)
+	  Schuyler Erle
 2009-07-15 18:55  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2612] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
-	  Add STRtree support to the C API (#278) Schuyler Erle
+	* [r2612] Add STRtree support to the C API (#278) Schuyler Erle
 2009-07-15 18:53  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2611] source/headers/geos/index/strtree/AbstractSTRtree.h,
-	  source/index/strtree/AbstractSTRtree.cpp: Add
-	  geos::index::strtree::AbstractSTRtree::iterate (#277) Schuyler
-	  Erle
+	* [r2611] Add geos::index::strtree::AbstractSTRtree::iterate (#277)
+	  Schuyler Erle
 2009-07-06 17:35  Sandro Santilli <strk at keybit.net>
-	* [r2610] tests/xmltester/Makefile.am,
-	  tests/xmltester/tests/bug275.xml: Add automated XML test for
-	  issue #275. Succeeds here.
+	* [r2610] Add automated XML test for issue #275. Succeeds here.
 2009-07-05 15:58  Sandro Santilli <strk at keybit.net>
-	* [r2609] build/msvc90/geos_c_dll/geos_c_dll.vcproj,
-	  build/msvc90/geos_unit/geos_unit.vcproj: Apply
-	  fix-msvc90-only2.patch by Sanak from issue #273
+	* [r2609] Apply fix-msvc90-only2.patch by Sanak from issue #273
 2009-07-04 16:19  Sandro Santilli <strk at keybit.net>
-	* [r2608] source/headers/geos/export.h,
-	  source/headers/geos/platform.h.in: Apply fix-mingw.patch by Sanak
-	  (issue #273)
+	* [r2608] Apply fix-mingw.patch by Sanak (issue #273)
 2009-06-29 16:40  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2607] Makefile.am: Include nmake.opt in 'dist' target (#274)
+	* [r2607] Include nmake.opt in 'dist' target (#274)
 2009-06-26 21:59  Sandro Santilli <strk at keybit.net>
-	* [r2605] source/headers/geos/operation/buffer/BufferOp.h: Fix typo
-	  reported in ticket #272
+	* [r2605] Fix typo reported in ticket #272
 2009-06-24 21:43  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2604] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
-	  tests/unit/capi/geostest.c, tests/unit/capi/test.expected: Expose
-	  Hausdorf distance to CAPI (#264) from Vincent Picavet
+	* [r2604] Expose Hausdorf distance to CAPI (#264) from Vincent
+	  Picavet
 2009-06-24 21:30  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2603] source/headers/geos/platform.h.in: Fix stoopid syntax
-	  error.
+	* [r2603] Fix stoopid syntax error.
 2009-06-24 21:21  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2602] configure.in: Remove old logging noise.
+	* [r2602] Remove old logging noise.
 2009-06-24 21:19  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2601] configure.in, source/headers/geos/platform.h.in: Fix for
-	  #270, bad definition of isnan() in OS/X <cmath>. This needs to be
-	  tested on other operating systems to make sure it doesn't break
-	  them instead.
+	* [r2601] Fix for #270, bad definition of isnan() in OS/X <cmath>.
+	  This needs to be tested on other operating systems to make sure
+	  it doesn't break them instead.
 2009-06-23 22:20  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2599] source/Makefile.vc, source/dirlist.mk: Fix clean target
-	  for VC build (#267)
+	* [r2599] Fix clean target for VC build (#267)
 2009-06-23 18:22  Howard Butler <hobu.inc at gmail.com>
-	* [r2598] source/Makefile.vc: fix up syntax of the makefile related
-	  to the patch for #257
+	* [r2598] fix up syntax of the makefile related to the patch for
+	  #257
 2009-06-22 19:14  Sandro Santilli <strk at keybit.net>
-	* [r2597] tests/unit/capi/GEOSBufferTest.cpp: Add tests for limited
-	  mitre join (now working)
+	* [r2597] Add tests for limited mitre join (now working)
 2009-06-22 19:02  Sandro Santilli <strk at keybit.net>
-	* [r2596] source/headers/geos/operation/buffer/BufferParameters.h:
-	  Fix bug in BufferParameters::setMitreLimit
+	* [r2596] Fix bug in BufferParameters::setMitreLimit
 2009-06-20 21:29  Sandro Santilli <strk at keybit.net>
-	* [r2595] configure.in: Bump versions (core 3.2.0, capi 1.6.0, port
-	  1.10.0)
+	* [r2595] Bump versions (core 3.2.0, capi 1.6.0, port 1.10.0)
 2009-06-20 08:53  Sandro Santilli <strk at keybit.net>
-	* [r2594] tests/unit/Makefile.am,
-	  tests/unit/capi/GEOSBufferTest.cpp: Add tests for
-	  GEOSBufferWithStyle
+	* [r2594] Add tests for GEOSBufferWithStyle
 2009-06-19 22:32  Sandro Santilli <strk at keybit.net>
-	* [r2593] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
-	  Extend the C-API interface to expose a GEOSBufferWithStyle (and
-	  corresponding thread-safe version) and related enums.
+	* [r2593] Extend the C-API interface to expose a
+	  GEOSBufferWithStyle (and corresponding thread-safe version) and
+	  related enums.
 2009-06-16 15:49  Sandro Santilli <strk at keybit.net>
-	* [r2592] source/algorithm/RobustDeterminant.cpp,
-	  source/headers/geos/algorithm/RobustDeterminant.h: Sync
-	  RobustDeterminant to JTS-1.10 (r1.15 was just commented-out code)
+	* [r2592] Sync RobustDeterminant to JTS-1.10 (r1.15 was just
+	  commented-out code)
 2009-06-16 15:46  Sandro Santilli <strk at keybit.net>
-	* [r2591] source/algorithm/RobustDeterminant.cpp,
-	  RobustDeterminant to revision 1.14
+	* [r2591] Sync RobustDeterminant to revision 1.14
 2009-06-16 15:43  Sandro Santilli <strk at keybit.net>
-	* [r2590] source/algorithm/RobustDeterminant.cpp,
-	  source/headers/geos/algorithm/RobustDeterminant.h: Port info for
-	  RobustDeterminant
+	* [r2590] Port info for RobustDeterminant
 2009-06-16 15:33  Sandro Santilli <strk at keybit.net>
-	* [r2589] source/headers/geos/operation/buffer/BufferBuilder.h,
-	  tests/xmltester/XMLTester.cpp: Revert single-sided patch. Martin
-	  Davis is workin on it from the JTS side
+	* [r2589] Revert single-sided patch. Martin Davis is workin on it
+	  from the JTS side
 2009-06-16 00:00  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2581] HOWTO_RELEASE: add reminders on bump versions in various
-	  places
+	* [r2581] add reminders on bump versions in various places
 2009-06-15 14:57  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2580] source/headers/geos/Makefile.am: operation.h in
-	  Makefile.am twice. (#261)
+	* [r2580] operation.h in Makefile.am twice. (#261)
 2009-06-15 14:03  Sandro Santilli <strk at keybit.net>
-	* [r2579] source/headers/geos/io/ByteOrderDataInStream.h,
-	  source/headers/geos/io/ByteOrderDataInStream.inl,
-	  source/headers/geos/io/ByteOrderValues.h,
-	  source/headers/geos/io/CLocalizer.h,
-	  source/headers/geos/io/ParseException.h,
-	  source/headers/geos/io/StringTokenizer.h,
-	  source/headers/geos/io/WKBConstants.h,
-	  source/headers/geos/io/WKBReader.h,
-	  source/headers/geos/io/WKBWriter.h,
-	  source/headers/geos/io/WKTReader.h,
-	  source/headers/geos/io/WKTReader.inl,
-	  source/headers/geos/io/WKTWriter.h,
-	  source/headers/geos/io/Writer.h,
-	  source/io/ByteOrderDataInStream.cpp,
-	  source/io/ByteOrderValues.cpp, source/io/CLocalizer.cpp,
-	  source/io/ParseException.cpp, source/io/StringTokenizer.cpp,
-	  source/io/WKBReader.cpp, source/io/WKBWriter.cpp,
-	  source/io/WKTReader.cpp, source/io/WKTWriter.cpp,
-	  source/io/Writer.cpp: Port info in the geos::io namespace
+	* [r2579] Port info in the geos::io namespace
 2009-06-15 13:19  Sandro Santilli <strk at keybit.net>
-	* [r2578] source/io/WKTWriter.cpp: Put CLocalizer in the correct
-	  function. Fixes #260 for the writing part.
+	* [r2578] Put CLocalizer in the correct function. Fixes #260 for
+	  the writing part.
 2009-06-15 10:13  Sandro Santilli <strk at keybit.net>
-	* [r2577] capi/geos_ts_c.cpp: Stop explicitly using the CLocalizer
-	  now that it is done within WKTReader and WKTWriter (see bug
-	  #260). Some deep testing about this would be good. Make check
-	  worked for me with comma-using locale.
+	* [r2577] Stop explicitly using the CLocalizer now that it is done
+	  within WKTReader and WKTWriter (see bug #260). Some deep testing
+	  about this would be good. Make check worked for me with
+	  comma-using locale.
 2009-06-15 10:06  Sandro Santilli <strk at keybit.net>
-	* [r2576] source/io/WKTReader.cpp, source/io/WKTWriter.cpp: Use C
-	  locale while reading/writing WKT. Fixes bug #260.
+	* [r2576] Use C locale while reading/writing WKT. Fixes bug #260.
 2009-06-15 06:57  Sandro Santilli <strk at keybit.net>
-	* [r2575] tests/xmltester/Makefile.am,
-	  tests/xmltester/tests/bug176.xml: Add XML version of the testcase
-	  provided for bug #176
+	* [r2575] Add XML version of the testcase provided for bug #176
 2009-06-08 22:10  Sandro Santilli <strk at keybit.net>
-	* [r2572]
-	  source/headers/geos/operation/valid/IsValidOp.h,
-	  source/headers/geos/operation/valid/QuadtreeNestedRingTester.h,
-	  source/headers/geos/operation/valid/RepeatedPointTester.h,
-	  source/headers/geos/operation/valid/SimpleNestedRingTester.h,
-	  source/headers/geos/operation/valid/SweeplineNestedRingTester.h,
-	  source/headers/geos/operation/valid/TopologyValidationError.h,
-	  source/operation/valid/ConnectedInteriorTester.cpp,
-	  source/operation/valid/IndexedNestedRingTester.cpp,
-	  source/operation/valid/IndexedNestedRingTester.h,
-	  source/operation/valid/IsValidOp.cpp,
-	  source/operation/valid/QuadtreeNestedRingTester.cpp,
-	  source/operation/valid/RepeatedPointTester.cpp,
-	  source/operation/valid/SimpleNestedRingTester.cpp,
-	  source/operation/valid/SweeplineNestedRingTester.cpp,
-	  source/operation/valid/TopologyValidationError.cpp: JTS-1.10 port
-	  sync. The whole 'operation' namespace is complete on this.
+	* [r2572] JTS-1.10 port sync. The whole 'operation' namespace is
+	  complete on this.
 2009-06-08 21:53  Sandro Santilli <strk at keybit.net>
-	* [r2571]
-	  source/headers/geos/operation/union/CascadedPolygonUnion.h,
-	  source/operation/union/CascadedPolygonUnion.cpp: Port info for
-	  operation::union
+	* [r2571] Port info for operation::union
 2009-06-08 17:15  Sandro Santilli <strk at keybit.net>
-	* [r2570]
-	  source/headers/geos/operation/predicate/RectangleIntersects.h,
-	  source/headers/geos/operation/predicate/SegmentIntersectionTester.h,
-	  source/operation/predicate/SegmentIntersectionTester.cpp: Sync to
-	  JTS-1.10 (port info in SegmentIntersectionTester was wrong, btw)
+	* [r2570] Sync to JTS-1.10 (port info in SegmentIntersectionTester
+	  was wrong, btw)
 2009-06-08 17:12  Sandro Santilli <strk at keybit.net>
-	* [r2569]
-	  source/operation/predicate/RectangleContains.cpp: Sync
-	  RectangleContains to JTS-1.10
+	* [r2569] Sync RectangleContains to JTS-1.10
 2009-06-08 17:02  Sandro Santilli <strk at keybit.net>
-	* [r2568]
-	  source/operation/predicate/SegmentIntersectionTester.cpp: Port
-	  info for operation::predicate (we're at JTS-1.7 here)
+	* [r2568] Port info for operation::predicate (we're at JTS-1.7
+	  here)
 2009-06-08 16:58  Sandro Santilli <strk at keybit.net>
-	* [r2567] source/headers/geos/operation/polygonize/EdgeRing.h,
-	  source/headers/geos/operation/polygonize/PolygonizeDirectedEdge.h,
-	  source/headers/geos/operation/polygonize/PolygonizeEdge.h,
-	  source/operation/polygonize/EdgeRing.cpp,
-	  source/operation/polygonize/PolygonizeDirectedEdge.cpp,
-	  source/operation/polygonize/PolygonizeEdge.cpp,
-	  source/operation/polygonize/Polygonizer.cpp: Port info for
-	  polygonize operation
+	* [r2567] Port info for polygonize operation
 2009-06-08 16:46  Sandro Santilli <strk at keybit.net>
-	* [r2566]
-	  source/headers/geos/operation/overlay/validate/OverlayResultValidator.h,
-	  source/operation/overlay/validate/OffsetPointGenerator.cpp,
-	  source/operation/overlay/validate/OverlayResultValidator.cpp:
-	  Port info and sync for operation::overlay::validate
+	* [r2566] Port info and sync for operation::overlay::validate
 2009-06-08 16:26  Sandro Santilli <strk at keybit.net>
-	* [r2565] source/headers/geos/operation/overlay/LineBuilder.h,
-	  source/operation/overlay/LineBuilder.cpp: sync LineBuilder to
-	  JTS-1.10, completing overlay port
+	* [r2565] sync LineBuilder to JTS-1.10, completing overlay port
 2009-06-08 16:09  Sandro Santilli <strk at keybit.net>
-	* [r2564] source/headers/geos/operation/overlay/EdgeSetNoder.h,
-	  source/headers/geos/operation/overlay/ElevationMatrix.h,
-	  source/headers/geos/operation/overlay/ElevationMatrixCell.h,
-	  source/headers/geos/operation/overlay/LineBuilder.h,
-	  source/headers/geos/operation/overlay/MinimalEdgeRing.h,
-	  source/headers/geos/operation/overlay/MinimalEdgeRing.inl,
-	  source/headers/geos/operation/overlay/OverlayNodeFactory.h,
-	  source/operation/overlay/EdgeSetNoder.cpp,
-	  source/operation/overlay/ElevationMatrix.cpp,
-	  source/operation/overlay/ElevationMatrixCell.cpp,
-	  source/operation/overlay/LineBuilder.cpp,
-	  source/operation/overlay/MinimalEdgeRing.cpp,
-	  source/operation/overlay/OverlayNodeFactory.cpp,
-	  source/operation/overlay/PointBuilder.cpp: Complete port info in
-	  overlay package
+	* [r2564] Complete port info in overlay package
 2009-06-08 15:43  Sandro Santilli <strk at keybit.net>
-	* [r2563] source/headers/geos/operation/linemerge/LineMerger.h,
-	  source/headers/geos/planargraph/GraphComponent.h,
-	  source/operation/linemerge/LineMerger.cpp: Add missing setMarked
-	  static methods in GraphComponent and make use of them in
-	  LineMerger making it able to be called incrementally (JTS-1.10)
+	* [r2563] Add missing setMarked static methods in GraphComponent
+	  and make use of them in LineMerger making it able to be called
+	  incrementally (JTS-1.10)
 2009-06-08 15:28  Sandro Santilli <strk at keybit.net>
-	* [r2562] source/headers/geos/operation/linemerge/EdgeString.h,
-	  source/headers/geos/operation/linemerge/LineMergeDirectedEdge.h,
-	  source/headers/geos/operation/linemerge/LineMergeEdge.h,
-	  source/headers/geos/operation/linemerge/LineMergeGraph.h,
-	  source/headers/geos/operation/linemerge/LineMerger.h,
-	  source/headers/geos/operation/linemerge/LineSequencer.h,
-	  source/operation/linemerge/EdgeString.cpp,
-	  source/operation/linemerge/LineMergeDirectedEdge.cpp,
-	  source/operation/linemerge/LineMergeEdge.cpp,
-	  source/operation/linemerge/LineMergeGraph.cpp,
-	  source/operation/linemerge/LineSequencer.cpp: Port info in
-	  operation::linemerge (a single class is still at JTS-1.7, needs
-	  changes in GeometryGraphComponent.h to go up)
+	* [r2562] Port info in operation::linemerge (a single class is
+	  still at JTS-1.7, needs changes in GeometryGraphComponent.h to go
+	  up)
 2009-06-08 10:37  Sandro Santilli <strk at keybit.net>
-	* [r2561]
-	  source/headers/geos/operation/distance/GeometryLocation.h,
-	  source/operation/distance/GeometryLocation.cpp: GeometryLocation
-	  sync to JTS-1.10 (docs)
+	* [r2561] GeometryLocation sync to JTS-1.10 (docs)
 2009-06-08 10:29  Sandro Santilli <strk at keybit.net>
-	* [r2560] source/headers/geos/operation/distance/DistanceOp.h,
-	  source/operation/distance/DistanceOp.cpp: DistanceOp sync to
-	  JTS-1.10 (renames, docs...)
+	* [r2560] DistanceOp sync to JTS-1.10 (renames, docs...)
 2009-06-08 10:07  Sandro Santilli <strk at keybit.net>
-	* [r2559] source/headers/geos/operation/buffer/BufferBuilder.h,
-	  source/headers/geos/operation/buffer/BufferOp.h,
-	  source/headers/geos/operation/buffer/BufferParameters.h,
-	  source/headers/geos/operation/buffer/BufferSubgraph.h,
-	  source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
-	  source/headers/geos/operation/buffer/RightmostEdgeFinder.h,
-	  source/headers/geos/operation/buffer/SubgraphDepthLocater.h,
-	  source/operation/buffer/BufferInputLineSimplifier.cpp,
-	  source/operation/buffer/BufferInputLineSimplifier.h,
-	  source/operation/buffer/BufferOp.cpp,
-	  source/operation/buffer/BufferParameters.cpp,
-	  source/operation/buffer/BufferSubgraph.cpp,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp,
-	  source/operation/buffer/RightmostEdgeFinder.cpp,
-	  source/operation/buffer/SubgraphDepthLocater.cpp: Update port
-	  info for buffer package (it's really JTS-1.10)
+	* [r2559] Update port info for buffer package (it's really
+	  JTS-1.10)
 2009-06-08 09:40  Sandro Santilli <strk at keybit.net>
-	* [r2558] configure.in: Warn at configure time if 64bit integer
-	  type isn't found. See bug #202.
+	* [r2558] Warn at configure time if 64bit integer type isn't found.
+	  See bug #202.
 2009-06-08 09:30  Sandro Santilli <strk at keybit.net>
-	* [r2557] source/headers/geos/Makefile.am,
-	  source/headers/geos/algorithm/Makefile.am,
-	  source/headers/geos/algorithm/distance/Makefile.am,
-	  source/headers/geos/algorithm/locate/Makefile.am,
-	  source/headers/geos/geom/Makefile.am,
-	  source/headers/geos/geom/prep/Makefile.am,
-	  source/headers/geos/geom/util/Makefile.am,
-	  source/headers/geos/geomgraph/Depth.h,
-	  source/headers/geos/geomgraph/DirectedEdge.h,
-	  source/headers/geos/geomgraph/DirectedEdgeStar.h,
-	  source/headers/geos/geomgraph/Edge.h,
-	  source/headers/geos/geomgraph/EdgeEnd.h,
-	  source/headers/geos/geomgraph/EdgeEndStar.h,
-	  source/headers/geos/geomgraph/EdgeIntersection.h,
-	  source/headers/geos/geomgraph/EdgeIntersectionList.h,
-	  source/headers/geos/geomgraph/EdgeList.h,
-	  source/headers/geos/geomgraph/EdgeNodingValidator.h,
-	  source/headers/geos/geomgraph/EdgeRing.h,
-	  source/headers/geos/geomgraph/GeometryGraph.h,
-	  source/headers/geos/geomgraph/GeometryGraph.inl,
-	  source/headers/geos/geomgraph/GraphComponent.h,
-	  source/headers/geos/geomgraph/Label.h,
-	  source/headers/geos/geomgraph/Makefile.am,
-	  source/headers/geos/geomgraph/Node.h,
-	  source/headers/geos/geomgraph/NodeFactory.h,
-	  source/headers/geos/geomgraph/NodeMap.h,
-	  source/headers/geos/geomgraph/PlanarGraph.h,
-	  source/headers/geos/geomgraph/Position.h,
-	  source/headers/geos/geomgraph/Quadrant.h,
-	  source/headers/geos/geomgraph/TopologyLocation.h,
-	  source/headers/geos/geomgraph/index/Makefile.am,
-	  source/headers/geos/index/Makefile.am,
-	  source/headers/geos/index/bintree/Makefile.am,
-	  source/headers/geos/index/chain/Makefile.am,
-	  source/headers/geos/index/intervalrtree/Makefile.am,
-	  source/headers/geos/index/quadtree/Makefile.am,
-	  source/headers/geos/index/strtree/Makefile.am,
-	  source/headers/geos/index/sweepline/Makefile.am,
-	  source/headers/geos/io/Makefile.am,
-	  source/headers/geos/noding/Makefile.am,
-	  source/headers/geos/noding/snapround/Makefile.am,
-	  source/headers/geos/operation/Makefile.am,
-	  source/headers/geos/operation/buffer/Makefile.am,
-	  source/headers/geos/operation/distance/ConnectedElementLocationFilter.h,
-	  source/headers/geos/operation/distance/ConnectedElementPointFilter.h,
-	  source/headers/geos/operation/distance/DistanceOp.h,
-	  source/headers/geos/operation/distance/Makefile.am,
-	  source/headers/geos/operation/linemerge/Makefile.am,
-	  source/headers/geos/operation/overlay/Makefile.am,
-	  source/headers/geos/operation/overlay/MaximalEdgeRing.h,
-	  source/headers/geos/operation/overlay/OverlayOp.h,
-	  source/headers/geos/operation/overlay/snap/Makefile.am,
-	  source/headers/geos/operation/polygonize/Makefile.am,
-	  source/headers/geos/operation/predicate/Makefile.am,
-	  source/headers/geos/operation/relate/EdgeEndBuilder.h,
-	  source/headers/geos/operation/relate/EdgeEndBundle.h,
-	  source/headers/geos/operation/relate/EdgeEndBundleStar.h,
-	  source/headers/geos/operation/relate/Makefile.am,
-	  source/headers/geos/operation/relate/RelateComputer.h,
-	  source/headers/geos/operation/relate/RelateNode.h,
-	  source/headers/geos/operation/relate/RelateNodeFactory.h,
-	  source/headers/geos/operation/relate/RelateNodeGraph.h,
-	  source/headers/geos/operation/relate/RelateOp.h,
-	  source/headers/geos/operation/valid/ConsistentAreaTester.h,
-	  source/headers/geos/operation/valid/Makefile.am,
-	  source/headers/geos/planargraph/Makefile.am,
-	  source/headers/geos/planargraph/algorithm/Makefile.am,
-	  source/headers/geos/precision/Makefile.am,
-	  source/headers/geos/simplify/Makefile.am,
-	  source/headers/geos/util/Makefile.am, tests/unit/Makefile.am:
-	  Install all C++ headers to reduce maintainance costs. C++ API is
-	  documented as being unstable after all so let's give users the
-	  power to hurt themselves :)
+	* [r2557] Install all C++ headers to reduce maintainance costs. C++
+	  API is documented as being unstable after all so let's give users
+	  the power to hurt themselves :)
 2009-06-06 22:22  Sandro Santilli <strk at keybit.net>
-	* [r2556] build/msvc90/geos_c_dll/geos_c_dll.vcproj,
-	  build/msvc90/geos_unit/geos_unit.vcproj, capi/geos_c.cpp,
-	  capi/geos_c.h.in, capi/geos_ts_c.cpp,
-	  source/headers/geos/algorithm/CGAlgorithms.h,
-	  source/headers/geos/algorithm/CentroidArea.h,
-	  source/headers/geos/algorithm/CentroidLine.h,
-	  source/headers/geos/algorithm/CentroidPoint.h,
-	  source/headers/geos/algorithm/ConvexHull.h,
-	  source/headers/geos/algorithm/HCoordinate.h,
-	  source/headers/geos/algorithm/InteriorPointArea.h,
-	  source/headers/geos/algorithm/InteriorPointLine.h,
-	  source/headers/geos/algorithm/InteriorPointPoint.h,
-	  source/headers/geos/algorithm/LineIntersector.h,
-	  source/headers/geos/algorithm/MCPointInRing.h,
-	  source/headers/geos/algorithm/MinimumDiameter.h,
-	  source/headers/geos/algorithm/NotRepresentableException.h,
-	  source/headers/geos/algorithm/PointInRing.h,
-	  source/headers/geos/algorithm/PointLocator.h,
-	  source/headers/geos/algorithm/RayCrossingCounter.h,
-	  source/headers/geos/algorithm/RobustDeterminant.h,
-	  source/headers/geos/algorithm/SIRtreePointInRing.h,
-	  source/headers/geos/algorithm/SimplePointInRing.h,
-	  source/headers/geos/export.h,
-	  source/headers/geos/geom/Coordinate.h,
-	  source/headers/geos/geom/CoordinateArraySequenceFactory.h,
-	  source/headers/geos/geom/CoordinateFilter.h,
-	  source/headers/geos/geom/CoordinateSequence.h,
-	  source/headers/geos/geom/CoordinateSequenceFactory.h,
-	  source/headers/geos/geom/Dimension.h,
-	  source/headers/geos/geom/Envelope.h,
-	  source/headers/geos/geom/GeometryCollection.h,
-	  source/headers/geos/geom/GeometryComponentFilter.h,
-	  source/headers/geos/geom/GeometryFactory.h,
-	  source/headers/geos/geom/GeometryFilter.h,
-	  source/headers/geos/geom/GeometryList.h,
-	  source/headers/geos/geom/IntersectionMatrix.h,
-	  source/headers/geos/geom/LineSegment.h,
-	  source/headers/geos/geom/LineString.h,
-	  source/headers/geos/geom/LinearRing.h,
-	  source/headers/geos/geom/Location.h,
-	  source/headers/geos/geom/MultiLineString.h,
-	  source/headers/geos/geom/MultiPoint.h,
-	  source/headers/geos/geom/MultiPolygon.h,
-	  source/headers/geos/geom/Point.h,
-	  source/headers/geos/geom/Polygon.h,
-	  source/headers/geos/geom/PrecisionModel.h,
-	  source/headers/geos/geom/Triangle.h,
-	  source/headers/geos/geom/util/CoordinateOperation.h,
-	  source/headers/geos/geom/util/GeometryEditor.h,
-	  source/headers/geos/geom/util/GeometryEditorOperation.h,
-	  source/headers/geos/geom/util/GeometryTransformer.h,
-	  source/headers/geos/geom/util/LinearComponentExtracter.h,
-	  source/headers/geos/geom/util/PointExtracter.h,
-	  source/headers/geos/geom/util/PolygonExtracter.h,
-	  source/headers/geos/geom/util/ShortCircuitedGeometryVisitor.h,
-	  source/headers/geos/geomgraph/index/EdgeSetIntersector.h,
-	  source/headers/geos/geomgraph/index/MonotoneChain.h,
-	  source/headers/geos/geomgraph/index/MonotoneChainEdge.h,
-	  source/headers/geos/geomgraph/index/MonotoneChainIndexer.h,
-	  source/headers/geos/geomgraph/index/SegmentIntersector.h,
-	  source/headers/geos/geomgraph/index/SimpleEdgeSetIntersector.h,
-	  source/headers/geos/geomgraph/index/SimpleMCSweepLineIntersector.h,
-	  source/headers/geos/geomgraph/index/SimpleSweepLineIntersector.h,
-	  source/headers/geos/geomgraph/index/SweepLineEvent.h,
-	  source/headers/geos/geomgraph/index/SweepLineEventObj.h,
-	  source/headers/geos/geomgraph/index/SweepLineSegment.h,
-	  source/headers/geos/index/ItemVisitor.h,
-	  source/headers/geos/index/SpatialIndex.h,
-	  source/headers/geos/index/bintree/Bintree.h,
-	  source/headers/geos/index/bintree/Interval.h,
-	  source/headers/geos/index/bintree/Key.h,
-	  source/headers/geos/index/bintree/Node.h,
-	  source/headers/geos/index/bintree/NodeBase.h,
-	  source/headers/geos/index/bintree/Root.h,
-	  source/headers/geos/index/chain/MonotoneChain.h,
-	  source/headers/geos/index/chain/MonotoneChainBuilder.h,
-	  source/headers/geos/index/chain/MonotoneChainOverlapAction.h,
-	  source/headers/geos/index/chain/MonotoneChainSelectAction.h,
-	  source/headers/geos/index/quadtree/DoubleBits.h,
-	  source/headers/geos/index/quadtree/IntervalSize.h,
-	  source/headers/geos/index/quadtree/Key.h,
-	  source/headers/geos/index/quadtree/Node.h,
-	  source/headers/geos/index/quadtree/NodeBase.h,
-	  source/headers/geos/index/quadtree/Quadtree.h,
-	  source/headers/geos/index/quadtree/Root.h,
-	  source/headers/geos/index/strtree/AbstractNode.h,
-	  source/headers/geos/index/strtree/AbstractSTRtree.h,
-	  source/headers/geos/index/strtree/Boundable.h,
-	  source/headers/geos/index/strtree/Interval.h,
-	  source/headers/geos/index/strtree/ItemBoundable.h,
-	  source/headers/geos/index/strtree/SIRtree.h,
-	  source/headers/geos/index/strtree/STRtree.h,
-	  source/headers/geos/index/sweepline/SweepLineEvent.h,
-	  source/headers/geos/index/sweepline/SweepLineIndex.h,
-	  source/headers/geos/index/sweepline/SweepLineInterval.h,
-	  source/headers/geos/index/sweepline/SweepLineOverlapAction.h,
-	  source/headers/geos/inline.h,
-	  source/headers/geos/io/ByteOrderDataInStream.h,
-	  source/headers/geos/noding/IntersectionAdder.h,
-	  source/headers/geos/noding/IntersectionFinderAdder.h,
-	  source/headers/geos/noding/IteratedNoder.h,
-	  source/headers/geos/noding/MCIndexNoder.h,
-	  source/headers/geos/noding/Noder.h,
-	  source/headers/geos/noding/NodingValidator.h,
-	  source/headers/geos/noding/Octant.h,
-	  source/headers/geos/noding/OrientedCoordinateArray.h,
-	  source/headers/geos/noding/ScaledNoder.h,
-	  source/headers/geos/noding/SegmentIntersector.h,
-	  source/headers/geos/noding/SegmentNode.h,
-	  source/headers/geos/noding/SegmentNodeList.h,
-	  source/headers/geos/noding/SegmentString.h,
-	  source/headers/geos/noding/SimpleNoder.h,
-	  source/headers/geos/noding/SinglePassNoder.h,
-	  source/headers/geos/noding/snapround/HotPixel.h,
-	  source/headers/geos/noding/snapround/MCIndexPointSnapper.h,
-	  source/headers/geos/noding/snapround/MCIndexSnapRounder.h,
-	  source/headers/geos/noding/snapround/SimpleSnapRounder.h,
-	  source/headers/geos/operation/GeometryGraphOperation.h,
-	  source/headers/geos/operation/IsSimpleOp.h,
-	  source/headers/geos/operation/buffer/BufferBuilder.h,
-	  source/headers/geos/operation/linemerge/EdgeString.h,
-	  source/headers/geos/operation/overlay/EdgeSetNoder.h,
-	  source/headers/geos/operation/overlay/PointBuilder.h,
-	  source/headers/geos/operation/overlay/PolygonBuilder.h,
-	  source/headers/geos/operation/overlay/snap/GeometrySnapper.h,
-	  source/headers/geos/operation/overlay/snap/LineStringSnapper.h,
-	  source/headers/geos/operation/overlay/snap/SnapOverlayOp.h,
-	  source/headers/geos/operation/polygonize/EdgeRing.h,
-	  source/headers/geos/operation/predicate/RectangleContains.h,
-	  source/headers/geos/planargraph/DirectedEdge.h,
-	  source/headers/geos/planargraph/DirectedEdgeStar.h,
-	  source/headers/geos/planargraph/Edge.h,
-	  source/headers/geos/planargraph/Node.h,
-	  source/headers/geos/planargraph/NodeMap.h,
-	  source/headers/geos/planargraph/Subgraph.h,
-	  source/headers/geos/planargraph/algorithm/ConnectedSubgraphFinder.h,
-	  source/headers/geos/precision/CommonBits.h,
-	  source/headers/geos/precision/CommonBitsOp.h,
-	  source/headers/geos/precision/CommonBitsRemover.h,
-	  source/headers/geos/precision/EnhancedPrecisionOp.h,
-	  source/headers/geos/precision/SimpleGeometryPrecisionReducer.h,
-	  source/headers/geos/profiler.h,
-	  source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h,
-	  source/headers/geos/simplify/DouglasPeuckerSimplifier.h,
-	  source/headers/geos/simplify/LineSegmentIndex.h,
-	  source/headers/geos/simplify/TaggedLineSegment.h,
-	  source/headers/geos/simplify/TaggedLineString.h,
-	  source/headers/geos/simplify/TaggedLineStringSimplifier.h,
-	  source/headers/geos/simplify/TaggedLinesSimplifier.h,
-	  source/headers/geos/simplify/TopologyPreservingSimplifier.h,
-	  source/headers/geos/unload.h, source/headers/geos/util/Assert.h,
-	  source/headers/geos/util/AssertionFailedException.h,
-	  source/headers/geos/util/CoordinateArrayFilter.h,
-	  source/headers/geos/util/GEOSException.h,
-	  source/headers/geos/util/GeometricShapeFactory.h,
-	  source/headers/geos/util/IllegalArgumentException.h,
-	  source/headers/geos/util/TopologyException.h,
-	  source/headers/geos/util/UniqueCoordinateArrayFilter.h,
-	  source/headers/geos/util/UnsupportedOperationException.h,
-	  source/index/intervalrtree/SortedPackedIntervalRTree.cpp: Windows
-	  C++ exports by Ragi Y. Burhum. See
+	* [r2556] Windows C++ exports by Ragi Y. Burhum. See
 	  http://lists.osgeo.org/pipermail/geos-devel/2009-June/004190.html
 2009-06-06 22:17  Sandro Santilli <strk at keybit.net>
-	* [r2555] tests/xmltester/SimpleWKTTester.cpp: fix headers
-	  inclusion warnings
+	* [r2555] fix headers inclusion warnings
 2009-06-06 21:14  Sandro Santilli <strk at keybit.net>
-	* [r2554] build/msvc90/geos_lib/geos_lib.vcproj,
-	  capi/geos_ts_c.cpp, configure.in,
-	  source/algorithm/InteriorPointLine.cpp,
-	  source/algorithm/InteriorPointPoint.cpp,
-	  source/algorithm/MinimumDiameter.cpp, source/geom/Geometry.cpp,
-	  source/geom/GeometryFactory.cpp, source/geom/LineSegment.cpp,
-	  source/headers/geos/geom/Coordinate.inl,
-	  source/headers/geos/index/intervalrtree/IntervalRTreeNode.h,
-	  source/headers/geos/noding/SingleInteriorIntersectionFinder.h,
-	  source/headers/geos/platform.h.in,
-	  source/headers/geos/platform.h.vc,
-	  source/operation/distance/DistanceOp.cpp,
-	  source/util/GeometricShapeFactory.cpp,
-	  tests/unit/geom/CoordinateTest.cpp,
-	  tests/unit/geom/TriangleTest.cpp,
-	  tests/unit/operation/distance/DistanceOpTest.cpp: Use real NaNs
-	  rather than fake them. Applies patch in ticket #259. Adds
-	  autoconf checks for finite() and isfinite() and makes use of them
-	  for unix systems (platform.h)
+	* [r2554] Use real NaNs rather than fake them. Applies patch in
+	  ticket #259. Adds autoconf checks for finite() and isfinite() and
+	  makes use of them for unix systems (platform.h)
 2009-06-06 00:55  Sandro Santilli <strk at keybit.net>
-	* [r2553]
-	  source/operation/distance/ConnectedElementLocationFilter.cpp,
-	  source/operation/distance/ConnectedElementPointFilter.cpp,
-	  source/operation/distance/GeometryLocation.cpp: Complete port
-	  info and headers exposion for operation::distance package
+	* [r2553] Complete port info and headers exposion for
+	  operation::distance package
 2009-06-05 18:18  Sandro Santilli <strk at keybit.net>
-	* [r2552] source/headers/geos/operation/overlay/OverlayOp.h,
-	  source/operation/overlay/OverlayOp.cpp: JTS-1.10 OverlayOp
+	* [r2552] JTS-1.10 OverlayOp
 2009-06-05 18:12  Sandro Santilli <strk at keybit.net>
-	* [r2551] source/headers/geos/geomgraph/EdgeNodingValidator.h: Add
-	  missing static function
+	* [r2551] Add missing static function
 2009-06-05 18:02  Sandro Santilli <strk at keybit.net>
-	* [r2550] source/headers/geos/operation/overlay/MaximalEdgeRing.h,
-	  source/operation/overlay/MaximalEdgeRing.cpp: JTS-1.10 sync
+	* [r2550] JTS-1.10 sync
 2009-06-05 17:50  Sandro Santilli <strk at keybit.net>
-	* [r2549] source/headers/geos/operation/GeometryGraphOperation.h,
-	  source/operation/GeometryGraphOperation.cpp,
-	  source/operation/relate/RelateOp.cpp: Boundary Node Rule support
-	  in relateOp. JTS-1.10.
+	* [r2549] Boundary Node Rule support in relateOp. JTS-1.10.
 2009-06-05 13:44  Sandro Santilli <strk at keybit.net>
-	* [r2548] source/geomgraph/EdgeList.cpp, source/geomgraph/Node.cpp,
-	  source/headers/geos/geomgraph/Node.h: geomgraph package fully
-	  sync'ed to JTS-1.10 now
+	* [r2548] geomgraph package fully sync'ed to JTS-1.10 now
 2009-06-05 13:41  Sandro Santilli <strk at keybit.net>
-	* [r2547] source/geomgraph/EdgeEnd.cpp,
-	  source/geomgraph/EdgeEndStar.cpp,
-	  source/operation/relate/EdgeEndBundle.cpp,
-	  source/operation/valid/ConsistentAreaTester.cpp: added
-	  BoundaryNodeRule capability to EdgeEnds
+	* [r2547] added BoundaryNodeRule capability to EdgeEnds
 2009-06-05 12:42  Sandro Santilli <strk at keybit.net>
-	* [r2546] source/geomgraph/GeometryGraph.cpp,
-	  source/headers/geos/geomgraph/GeometryGraph.inl: Add support for
-	  custom BoundaryNodeRule bringing GeometryGraph to JTS-1.10
+	* [r2546] Add support for custom BoundaryNodeRule bringing
+	  GeometryGraph to JTS-1.10
 2009-06-05 12:07  Sandro Santilli <strk at keybit.net>
-	* [r2545] source/geomgraph/DirectedEdgeStar.cpp,
-	  source/geomgraph/Edge.cpp,
-	  source/geomgraph/EdgeIntersectionList.cpp,
-	  source/geomgraph/EdgeNodingValidator.cpp,
-	  source/geomgraph/EdgeRing.cpp, source/geomgraph/Label.cpp,
-	  source/geomgraph/NodeFactory.cpp, source/geomgraph/Position.cpp,
-	  source/geomgraph/TopologyLocation.cpp,
-	  source/headers/geos/geomgraph/TopologyLocation.h: Complete port
-	  info in geomgraph package
+	* [r2545] Complete port info in geomgraph package
 2009-06-05 11:03  Sandro Santilli <strk at keybit.net>
-	* [r2544] source/geomgraph/Depth.cpp,
-	  source/geomgraph/GeometryGraph.cpp,
-	  source/geomgraph/GraphComponent.cpp,
-	  source/geomgraph/NodeMap.cpp, source/geomgraph/PlanarGraph.cpp,
-	  source/headers/geos/geomgraph/PlanarGraph.h: Port info in the
-	  geomgraph package (unfinished); fix compiler warning in
-	  GeometryGraph and make code more readable;
+	* [r2544] Port info in the geomgraph package (unfinished); fix
+	  compiler warning in GeometryGraph and make code more readable;
 2009-06-05 10:23  Sandro Santilli <strk at keybit.net>
-	* [r2543] source/headers/geos/operation/relate/EdgeEndBuilder.h,
-	  source/operation/relate/EdgeEndBuilder.cpp,
-	  source/operation/relate/EdgeEndBundleStar.cpp,
-	  source/operation/relate/RelateComputer.cpp,
-	  source/operation/relate/RelateNode.cpp,
-	  source/operation/relate/RelateNodeFactory.cpp,
-	  source/operation/relate/RelateNodeGraph.cpp,
-	  source/operation/relate/RelateOp.cpp: Add port info and introduce
-	  header exposion info. Relate op results partially in JTS-1.7
-	  still.
+	* [r2543] Add port info and introduce header exposion info. Relate
+	  op results partially in JTS-1.7 still.
 2009-06-05 09:36  Sandro Santilli <strk at keybit.net>
-	* [r2542] source/headers/geos/geom.h: typo in doxygen index page
+	* [r2542] typo in doxygen index page
 2009-06-05 09:35  Sandro Santilli <strk at keybit.net>
-	* [r2541] source/headers/geos/geom.h: Fix doxygen link
+	* [r2541] Fix doxygen link
 2009-06-05 09:28  Sandro Santilli <strk at keybit.net>
-	* [r2540] source/algorithm/locate/IndexedPointInAreaLocator.cpp,
-	  source/headers/geos/algorithm/locate/IndexedPointInAreaLocator.h,
-	  source/headers/geos/index/intervalrtree/IntervalRTreeLeafNode.h,
-	  source/headers/geos/index/intervalrtree/SortedPackedIntervalRTree.h:
-	  Fix deletion of void pointer in IntervalRTreeLeafNode, document
-	  ownership, fix callers tracking allocations to avoid leaks. Fixes
-	  bug #227.
+	* [r2540] Fix deletion of void pointer in IntervalRTreeLeafNode,
+	  document ownership, fix callers tracking allocations to avoid
+	  leaks. Fixes bug #227.
 2009-06-05 09:15  Sandro Santilli <strk at keybit.net>
-	* [r2539] ChangeLog.svn, Makefile.am: Allow generating ChangeLog
-	  from external build tree
+	* [r2539] Allow generating ChangeLog from external build tree
 2009-06-04 15:01  Mateusz Loskot <mateusz at loskot.net>
-	* [r2538] build/msvc90/geos_c_dll/geos_c_dll.vcproj,
-	  build/msvc90/geos_lib/geos_lib.vcproj,
-	  build/msvc90/geos_unit/geos_unit.vcproj, source/Makefile.vc,
-	  source/geom/LinearRing.cpp,
-	  source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h,
-	  source/index/chain/MonotoneChainBuilder.cpp,
-	  tests/unit/operation/valid/IsValidTest.cpp: * Applied patch for
-	  ticket #257.
+	* [r2538] * Applied patch for ticket #257.
 	  * Noticed that unit tests fail:
 	  1>geos::util::UniqueCoordinateArrayFilter: .
 	  1>---> group: geos::operation::valid::IsValidOp, test: test<1>
@@ -2322,1750 +1345,1089 @@
 2009-06-04 14:59  Mateusz Loskot <mateusz at loskot.net>
-	* [r2537] source/operation/buffer/BufferBuilder.cpp: Fixed bug of
-	  inaccessible constructor of incomplete type NodedSegmentString -
-	  header missing.
+	* [r2537] Fixed bug of inaccessible constructor of incomplete type
+	  NodedSegmentString - header missing.
 2009-06-04 13:59  Sandro Santilli <strk at keybit.net>
-	* [r2536] tests/xmltester/XMLTester.cpp: Add support for testing
-	  single sided buffers
+	* [r2536] Add support for testing single sided buffers
 2009-06-01 03:34  Howard Butler <hobu.inc at gmail.com>
-	* [r2534] capi/geos_c.cpp: #256 finishGEOS called multiple times
-	  will segfault
+	* [r2534] #256 finishGEOS called multiple times will segfault
 2009-05-28 14:38  Mateusz Loskot <mateusz at loskot.net>
-	* [r2533] configure.in, tests/bigtest: Fixed aclocal warnings for
-	  mixing cache-id's in configure.in.
+	* [r2533] Fixed aclocal warnings for mixing cache-id's in
+	  configure.in.
 2009-05-27 16:57  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2516] NEWS: remove error
+	* [r2516] remove error
-	* [r2515] NEWS: Add single-sided item
+	* [r2515] Add single-sided item
 2009-05-21 10:08  Sandro Santilli <strk at keybit.net>
-	* [r2514] ChangeLog.svn, Makefile.am, authors.svn: Add Mat's and
-	  Paul's entries, make ChangeLog.svn rule phony
+	* [r2514] Add Mat's and Paul's entries, make ChangeLog.svn rule
+	  phony
 2009-05-21 09:56  Sandro Santilli <strk at keybit.net>
-	* [r2513] ChangeLog.svn, Makefile.am, authors.svn: Add a rule to
-	  generate a ChangeLog using svn2cl. The authors.svn file will be
-	  used to map usernames and full names: please expand your own
-	  nick. The generated ChangeLog is added to repository to show you
-	  how it looks. If everybody agree we could rename this to
-	  ChangeLog and stop requiring manual edits (+1 from me:)
+	* [r2513] Add a rule to generate a ChangeLog using svn2cl. The
+	  authors.svn file will be used to map usernames and full names:
+	  please expand your own nick. The generated ChangeLog is added to
+	  repository to show you how it looks. If everybody agree we could
+	  rename this to ChangeLog and stop requiring manual edits (+1 from
+	  me:)
 2009-05-13 11:29  Frank Warmerdam <warmerdam at pobox.com>
-	* [r2508] capi/geos_c.h.in: refer to GEOSFree() instead of free()
+	* [r2508] refer to GEOSFree() instead of free()
 2009-05-13 11:26  Frank Warmerdam <warmerdam at pobox.com>
-	* [r2507] capi/geos_c.cpp, capi/geos_ts_c.cpp: forward GEOSFree to
-	  GEOSFree_r, use std:: prefix on free() (#249)
+	* [r2507] forward GEOSFree to GEOSFree_r, use std:: prefix on
+	  free() (#249)
 2009-05-13 04:14  Frank Warmerdam <warmerdam at pobox.com>
-	* [r2506] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in,
-	  capi/geos_ts_c.cpp: Added GEOSFree() and GEOSFree_r() (#249)
+	* [r2506] Added GEOSFree() and GEOSFree_r() (#249)
 2009-05-12 17:47  Sandro Santilli <strk at keybit.net>
-	* [r2505] NEWS: Add note about single-sided buffer
+	* [r2505] Add note about single-sided buffer
 2009-05-12 16:49  Sandro Santilli <strk at keybit.net>
-	* [r2504] tests/xmltester/Makefile.am,
-	  tests/xmltester/tests/bug244.xml: Never fail bug #244 again
-	  (regression testcase added)
+	* [r2504] Never fail bug #244 again (regression testcase added)
 2009-05-12 16:48  Sandro Santilli <strk at keybit.net>
-	* [r2503] source/operation/buffer/SubgraphDepthLocater.cpp: Have
-	  DepthSegment hold a real LineSegment, not a reference.
-	  SubgraphDepthLocater was passing the same LineSegment reference
-	  to multiple DepthSegments, messing everything up. This fixes bug
-	  #244.
+	* [r2503] Have DepthSegment hold a real LineSegment, not a
+	  reference. SubgraphDepthLocater was passing the same LineSegment
+	  reference to multiple DepthSegments, messing everything up. This
+	  fixes bug #244.
 2009-05-12 15:38  Sandro Santilli <strk at keybit.net>
-	* [r2502] source/geomgraph/DirectedEdge.cpp,
-	  source/headers/geos/geomgraph/DirectedEdge.inl: Port info
+	* [r2502] Port info
 2009-05-08 16:30  Sandro Santilli <strk at keybit.net>
-	* [r2501] source/headers/geos/operation/overlay/PolygonBuilder.h,
-	  source/operation/overlay/PolygonBuilder.cpp: Update port info
+	* [r2501] Update port info
 2009-05-08 12:47  Sandro Santilli <strk at keybit.net>
-	* [r2500] capi/geos_c.h.in: When included in a C++ environment,
-	  include <cstddef> and use std::size_t. Patch by Mateusz Loskot,
-	  ticket #252.
+	* [r2500] When included in a C++ environment, include <cstddef> and
+	  use std::size_t. Patch by Mateusz Loskot, ticket #252.
 2009-05-08 12:46  Sandro Santilli <strk at keybit.net>
-	* [r2499] source/operation/distance/DistanceOp.cpp: Oops, forgot to
-	  update the static closedPoints signature..
+	* [r2499] Oops, forgot to update the static closedPoints
+	  signature..
 2009-05-08 12:29  Sandro Santilli <strk at keybit.net>
-	* [r2498] NEWS: Note the withinDistance addition to DistanceOp
+	* [r2498] Note the withinDistance addition to DistanceOp
 2009-05-08 12:27  Sandro Santilli <strk at keybit.net>
-	* [r2497] tests/unit/operation/distance/DistanceOpTest.cpp: Add the
-	  complete set of tests for closedPoints
+	* [r2497] Add the complete set of tests for closedPoints
 2009-05-08 12:11  Sandro Santilli <strk at keybit.net>
-	* [r2496] source/headers/geos/operation/distance/DistanceOp.h:
-	  Document semantic of a null return from closestPoints
+	* [r2496] Document semantic of a null return from closestPoints
 2009-05-08 12:09  Sandro Santilli <strk at keybit.net>
-	* [r2495] source/headers/geos/operation/distance/DistanceOp.h,
-	  source/operation/distance/DistanceOp.cpp: Don't wipe out closest
-	  locations after computing them (doh). Fixes bug #236. Takes the
-	  chance to make the GeometryLocation retrival function private as
-	  we don't install GeometryLocation.h header anyway (for future
-	  cleanups), and to rename a function to follow current JTS naming
-	  (more renames to come for proper sync)
+	* [r2495] Don't wipe out closest locations after computing them
+	  (doh). Fixes bug #236. Takes the chance to make the
+	  GeometryLocation retrival function private as we don't install
+	  GeometryLocation.h header anyway (for future cleanups), and to
+	  rename a function to follow current JTS naming (more renames to
+	  come for proper sync)
 2009-05-08 10:10  Sandro Santilli <strk at keybit.net>
-	* [r2494] source/headers/geos/operation/distance/DistanceOp.h,
-	  source/operation/distance/DistanceOp.cpp: Add isWithinDistance()
-	  to DistanceOp, reaching rev 1.17 of JTS
+	* [r2494] Add isWithinDistance() to DistanceOp, reaching rev 1.17
+	  of JTS
 2009-05-08 09:39  Sandro Santilli <strk at keybit.net>
-	* [r2493] source/headers/geos/operation/distance/DistanceOp.h,
-	  source/operation/distance/DistanceOp.cpp: Port info for
-	  DistanceOp
+	* [r2493] Port info for DistanceOp
 2009-05-08 08:44  Sandro Santilli <strk at keybit.net>
-	* [r2492] capi/geos_c.h.in: Always include stddef.h. Closes bug
-	  #213
+	* [r2492] Always include stddef.h. Closes bug #213
 2009-05-07 16:15  Sandro Santilli <strk at keybit.net>
-	* [r2491] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
-	  Add "thread-safe" version of GEOSGeom_setSRID. Closes bug #242.
+	* [r2491] Add "thread-safe" version of GEOSGeom_setSRID. Closes bug
+	  #242.
 2009-05-07 16:00  Sandro Santilli <strk at keybit.net>
-	* [r2490] tests/bigtest/bug234.cpp: minor debug output improvement
+	* [r2490] minor debug output improvement
 2009-05-07 15:57  Sandro Santilli <strk at keybit.net>
-	* [r2489] source/geomgraph/GeometryGraph.cpp,
-	  tests/bigtest/Makefile.am, tests/bigtest/README,
-	  tests/bigtest/bug234.cpp: Skip empty components when building
-	  GeometryGraph. Fixes bug #234. Add non-automated test for it, and
-	  README file in the directory containing it...
+	* [r2489] Skip empty components when building GeometryGraph. Fixes
+	  bug #234. Add non-automated test for it, and README file in the
+	  directory containing it...
 2009-05-07 15:36  Sandro Santilli <strk at keybit.net>
-	* [r2488] tests/xmltester/Makefile.am,
-	  tests/xmltester/tests/bug188.xml: Add XML testcase for bug 188
+	* [r2488] Add XML testcase for bug 188
-	* [r2487] tests/xmltester/XMLTester.cpp: remove code duplication on
-	  buffer result validation
+	* [r2487] remove code duplication on buffer result validation
 2009-05-07 08:52  Sandro Santilli <strk at keybit.net>
-	* [r2486] source/geom/CoordinateSequenceFactory.cpp,
-	  source/headers/geos/geom/CoordinateSequenceFactory.h: Port info,
-	  doxygen cleanups
+	* [r2486] Port info, doxygen cleanups
 2009-05-07 08:45  Sandro Santilli <strk at keybit.net>
-	* [r2485] tests/unit/capi/GEOSCoordSeqTest.cpp: Add test for
-	  creating a CoordinateSequence with at least 2 dimension
+	* [r2485] Add test for creating a CoordinateSequence with at least
+	  2 dimension
 2009-05-06 20:47  Sandro Santilli <strk at keybit.net>
-	* [r2484] capi/geos_c.h.in, capi/geos_ts_c.cpp: Fix bug #135, give
-	  an hint about GEOSGeom_getDimensions being related to
-	  GEOSCoordSeq_getDimensions, fix signed vs. unsigned compiler
-	  warning.
+	* [r2484] Fix bug #135, give an hint about GEOSGeom_getDimensions
+	  being related to GEOSCoordSeq_getDimensions, fix signed vs.
+	  unsigned compiler warning.
 2009-05-06 20:22  Sandro Santilli <strk at keybit.net>
-	* [r2483] tests/xmltester/markup/MarkupSTL.cpp: Fix compilation
-	  warnings thrown by GCC 4.3.x. Patch by Mateus, closes bug #92.
+	* [r2483] Fix compilation warnings thrown by GCC 4.3.x. Patch by
+	  Mateus, closes bug #92.
 2009-05-06 20:12  Mateusz Loskot <mateusz at loskot.net>
-	* [r2482] source/headers/geos/operation/overlay/snap: Updated
-	  svn:ignore property.
+	* [r2482] Updated svn:ignore property.
 2009-05-06 17:54  Sandro Santilli <strk at keybit.net>
-	* [r2481] source/headers/geos/noding/SegmentNodeList.h,
-	  source/noding/SegmentNodeList.cpp:
-	  findCollapsesFromExistingVertices: don't choke on sets of < 2
-	  points. Fixes bug #219.
+	* [r2481] findCollapsesFromExistingVertices: don't choke on sets of
+	  < 2 points. Fixes bug #219.
 2009-05-06 17:52  Sandro Santilli <strk at keybit.net>
-	* [r2480] source/operation/buffer/BufferBuilder.cpp: minor
-	  indentation thing
+	* [r2480] minor indentation thing
 2009-05-06 17:42  Sandro Santilli <strk at keybit.net>
-	* [r2479] source/headers/geos/geom/Makefile.am,
-	  source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h,
-	  source/index/chain/MonotoneChain.cpp,
-	  source/index/chain/MonotoneChainOverlapAction.cpp,
-	  source/noding/MCIndexNoder.cpp,
-	  source/noding/MCIndexSegmentSetMutualIntersector.cpp: Cleanup
-	  MonotoneChainOverlapAction, reduce heap allocations. Cascade
-	  changes.
+	* [r2479] Cleanup MonotoneChainOverlapAction, reduce heap
+	  allocations. Cascade changes.
 2009-05-06 17:14  Sandro Santilli <strk at keybit.net>
-	* [r2478]
-	  source/index/chain/MonotoneChainOverlapAction.cpp: Port info (to
-	  be worked on for heap allocations reduction)
+	* [r2478] Port info (to be worked on for heap allocations
+	  reduction)
 2009-05-06 17:10  Sandro Santilli <strk at keybit.net>
-	* [r2477] source/algorithm/MCPointInRing.cpp,
-	  source/index/chain/MonotoneChainSelectAction.cpp,
-	  source/noding/snapround/MCIndexPointSnapper.cpp:
-	  MonotoneChainSelectAction port review, heap allocation reduced,
-	  const-corrected.
+	* [r2477] MonotoneChainSelectAction port review, heap allocation
+	  reduced, const-corrected.
 2009-05-06 16:44  Sandro Santilli <strk at keybit.net>
-	* [r2476] source/algorithm/MCPointInRing.cpp,
-	  source/index/bintree/Bintree.cpp,
-	  MonotoneChain const-correctness and interface cleanups, cascaded
-	  changes. Possibly discovered a leak in MCPointInRing algorithm,
-	  needs some unit testing.
+	* [r2476] MonotoneChain const-correctness and interface cleanups,
+	  cascaded changes. Possibly discovered a leak in MCPointInRing
+	  algorithm, needs some unit testing.
 2009-05-06 16:36  Sandro Santilli <strk at keybit.net>
-	* [r2475] source/headers/geos/index/bintree/Interval.h,
-	  source/index/bintree/Interval.cpp: Const-correctness for bintree
-	  Interval
+	* [r2475] Const-correctness for bintree Interval
 2009-05-06 15:47  Sandro Santilli <strk at keybit.net>
-	* [r2474] source/headers/geos/index/chain/MonotoneChain.h,
-	  source/index/chain/MonotoneChain.cpp: Port MonotoneChain up to
-	  JTS-1.10, plus minor dox improvement (memory-oriented)
+	* [r2474] Port MonotoneChain up to JTS-1.10, plus minor dox
+	  improvement (memory-oriented)
 2009-05-06 15:31  Sandro Santilli <strk at keybit.net>
-	* [r2473] source/headers/geos/index/chain/MonotoneChainBuilder.h,
-	  source/index/chain/MonotoneChainBuilder.cpp: Port
-	  MonotoneChainBuilder up to JTS-1.10. Tweak some signatures to use
-	  stricter signedness.
+	* [r2473] Port MonotoneChainBuilder up to JTS-1.10. Tweak some
+	  signatures to use stricter signedness.
 2009-05-06 14:55  Sandro Santilli <strk at keybit.net>
-	* [r2472] source/headers/geos/index/chain/MonotoneChainBuilder.h,
-	  source/index/chain/MonotoneChainBuilder.cpp: Port to 1.9, fixing
-	  an out of boundary access in findEdgeEnd
+	* [r2472] Port to 1.9, fixing an out of boundary access in
+	  findEdgeEnd
 2009-05-06 14:42  Sandro Santilli <strk at keybit.net>
-	* [r2471] source/headers/geos/index/chain/MonotoneChainBuilder.h,
-	  source/index/chain/MonotoneChainBuilder.cpp: Add port info. We're
-	  4 revision old (catching up next)
+	* [r2471] Add port info. We're 4 revision old (catching up next)
 2009-05-05 14:28  Sandro Santilli <strk at keybit.net>
-	* [r2470] source/geom/Envelope.cpp,
-	  source/headers/geos/geom/Envelope.inl: Sync Envelope to JTS-1.10
+	* [r2470] Sync Envelope to JTS-1.10
 2009-05-05 10:30  Sandro Santilli <strk at keybit.net>
-	* [r2469] tests/xmltester/XMLTester.cpp: Add compile-time support
-	  to skip use of BinaryOp thus engaging SnapIfNeededOverlayOp used
-	  by Geometry methods. Shows that BinaryOp (GEOS-specific original
-	  work) gives better numerical stability.
+	* [r2469] Add compile-time support to skip use of BinaryOp thus
+	  engaging SnapIfNeededOverlayOp used by Geometry methods. Shows
+	  that BinaryOp (GEOS-specific original work) gives better
+	  numerical stability.
 2009-05-05 10:14  Sandro Santilli <strk at keybit.net>
-	* [r2468] configure.in, source/headers/geos/geom/BinaryOp.h,
-	  source/headers/geos/precision/GeometrySnapper.h,
-	  source/headers/geos/precision/LineStringSnapper.h,
-	  source/operation/overlay/snap/GeometrySnapper.cpp,
-	  source/operation/overlay/snap/LineStringSnapper.cpp,
-	  source/operation/overlay/snap/SnapOverlayOp.cpp,
-	  source/precision/GeometrySnapper.cpp,
-	  source/precision/LineStringSnapper.cpp,
-	  source/precision/Makefile.am, tests/unit/Makefile.am,
-	  tests/unit/operation/overlay/snap,
-	  tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp,
-	  tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp,
-	  tests/unit/precision/GeometrySnapperTest.cpp,
-	  tests/unit/precision/LineStringSnapperTest.cpp: Found old
-	  GeometrySnapper/LineStringSnapper classes in an unexpected
-	  directory. Move them where they belong, sync with JTS-1.10.
+	* [r2468] Found old GeometrySnapper/LineStringSnapper classes in an
+	  unexpected directory. Move them where they belong, sync with
+	  JTS-1.10.
 2009-05-05 00:04  Sandro Santilli <strk at keybit.net>
-	* [r2467] source/geom/util/GeometryTransformer.cpp: Fix memory leak
-	  on exception
+	* [r2467] Fix memory leak on exception
 2009-05-04 23:43  Sandro Santilli <strk at keybit.net>
-	* [r2466] source/operation/IsSimpleOp.cpp: Fix memory bug
+	* [r2466] Fix memory bug
 2009-05-04 23:23  Sandro Santilli <strk at keybit.net>
-	* [r2465] source/geom/Geometry.cpp,
-	  source/headers/geos/geom/Geometry.h,
-	  source/headers/geos/geom/Geometry.inl: Geometry up to 1.112 with
-	  a minor bugfix and performance improvement in Geometry::covers
+	* [r2465] Geometry up to 1.112 with a minor bugfix and performance
+	  improvement in Geometry::covers
 2009-05-04 23:04  Sandro Santilli <strk at keybit.net>
-	* [r2464] source/geom/Geometry.cpp,
-	  source/headers/geos/geom/Geometry.inl: Bring Geometry port up a
-	  revision by having it use SnapIfNeededOp for overlay operations.
-	  Note that currently this doesn't affect the C-API nor the
-	  XMLTester codes, both using the BinaryOp original class (not
-	  JTS-ported) doing about the same thing as the SnapIfNeededOp
-	  class.
+	* [r2464] Bring Geometry port up a revision by having it use
+	  SnapIfNeededOp for overlay operations. Note that currently this
+	  doesn't affect the C-API nor the XMLTester codes, both using the
+	  BinaryOp original class (not JTS-ported) doing about the same
+	  thing as the SnapIfNeededOp class.
 2009-05-04 22:03  Sandro Santilli <strk at keybit.net>
-	* [r2463] source/headers/geos/operation/overlay/Makefile.am,
-	  source/headers/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h,
-	  source/operation/overlay/Makefile.am,
-	  source/operation/overlay/snap/SnapIfNeededOverlayOp.cpp: Port
-	  SnapIfNeededOverlayOp
+	* [r2463] Port SnapIfNeededOverlayOp
 2009-05-04 21:28  Sandro Santilli <strk at keybit.net>
-	* [r2462]
-	  source/headers/geos/operation/overlay/FuzzyPointLocator.h,
-	  source/headers/geos/operation/overlay/OffsetPointGenerator.h,
-	  source/headers/geos/operation/overlay/OverlayResultValidator.h,
-	  source/headers/geos/operation/overlay/validate,
-	  source/headers/geos/operation/overlay/validate/FuzzyPointLocator.h,
-	  source/headers/geos/operation/overlay/validate/OffsetPointGenerator.h,
-	  source/operation/overlay/FuzzyPointLocator.cpp,
-	  source/operation/overlay/OffsetPointGenerator.cpp,
-	  source/operation/overlay/OverlayOp.cpp,
-	  source/operation/overlay/OverlayResultValidator.cpp,
-	  source/operation/overlay/validate,
-	  source/operation/overlay/validate/FuzzyPointLocator.cpp,
-	  source/operation/overlay/validate/OverlayResultValidator.cpp,
-	  tests/unit/Makefile.am,
-	  tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp,
-	  tests/unit/operation/overlay/OffsetPointGeneratorTest.cpp,
-	  tests/unit/operation/overlay/OverlayResultValidatorTest.cpp,
-	  tests/unit/operation/overlay/validate,
-	  tests/unit/operation/overlay/validate/FuzzyPointLocatorTest.cpp,
-	  tests/unit/operation/overlay/validate/OffsetPointGeneratorTest.cpp,
-	  tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp:
-	  Move overlay.validate package files where they belong
+	* [r2462] Move overlay.validate package files where they belong
 2009-05-04 21:02  Sandro Santilli <strk at keybit.net>
-	* [r2461] source/headers/geos/operation/overlay/Makefile.am,
-	  source/operation/overlay/snap/SnapOverlayOp.cpp: Port
-	  overlay.snap.SnapOverlayOp, update GeometrySnapper to be more
-	  useful
+	* [r2461] Port overlay.snap.SnapOverlayOp, update GeometrySnapper
+	  to be more useful
 2009-05-04 19:54  Sandro Santilli <strk at keybit.net>
-	* [r2460] source/headers/geos/operation/overlay/Makefile.am,
-	  source/operation/overlay/snap/GeometrySnapper.cpp: Port
-	  overlay.snap.GeometrySnapper
+	* [r2460] Port overlay.snap.GeometrySnapper
 2009-05-04 19:51  Sandro Santilli <strk at keybit.net>
-	* [r2459]
-	  source/operation/overlay/snap/LineStringSnapper.cpp: Extend to
-	  accept a vector of const Coordinate pointers for snap pointers,
-	  fix typo making it clone snap points rather than source points on
-	  snapping...
+	* [r2459] Extend to accept a vector of const Coordinate pointers
+	  for snap pointers, fix typo making it clone snap points rather
+	  than source points on snapping...
 2009-05-02 11:01  Sandro Santilli <strk at keybit.net>
-	* [r2458] source/headers/geos/operation/overlay/Makefile.am,
-	  source/headers/geos/operation/overlay/snap,
-	  source/operation/overlay/snap,
-	  source/operation/overlay/snap/LineStringSnapper.cpp: Port
-	  overlay.snap.LineStringSnapper from JTS-1.10
+	* [r2458] Port overlay.snap.LineStringSnapper from JTS-1.10
 2009-05-02 10:59  Sandro Santilli <strk at keybit.net>
-	* [r2457] source/geom/CoordinateArraySequence.cpp,
-	  source/headers/geos/geom/CoordinateArraySequence.h,
-	  tests/unit/geom/CoordinateArraySequenceTest.cpp: Add an
-	  insert-like virtual method to CoordinateSequence. This comes from
-	  CoordinateList of JTS, historically bound to CoordinateSequence
-	  in GEOS. Add test for that interface.
+	* [r2457] Add an insert-like virtual method to CoordinateSequence.
+	  This comes from CoordinateList of JTS, historically bound to
+	  CoordinateSequence in GEOS. Add test for that interface.
 2009-05-02 09:44  Sandro Santilli <strk at keybit.net>
-	* [r2456] tests/xmltester/Makefile.am,
-	  tests/xmltester/tests/general/MISSING,
-	  tests/xmltester/tests/general/TestRectanglePredicate.xml: Copy
-	  last portable JTS general test, add a file with info about what's
-	  missing
+	* [r2456] Copy last portable JTS general test, add a file with info
+	  about what's missing
 2009-05-02 09:42  Sandro Santilli <strk at keybit.net>
-	* [r2455] tests/xmltester/tests/testLeaksBig.xml: Drop test also
-	  found in TestFunctionPLPrec.xml
+	* [r2455] Drop test also found in TestFunctionPLPrec.xml
 2009-05-02 09:40  Sandro Santilli <strk at keybit.net>
-	* [r2454] tests/xmltester/XMLTester.cpp: Add support for testing
-	  within, covers and coveredby. Properly use 'arg1' and 'arg2' for
-	  these tests.
+	* [r2454] Add support for testing within, covers and coveredby.
+	  Properly use 'arg1' and 'arg2' for these tests.
 2009-05-02 09:25  Sandro Santilli <strk at keybit.net>
-	* [r2453] tests/xmltester/Makefile.am,
-	  tests/xmltester/tests/general/TestWithinDistance.xml,
-	  tests/xmltester/tests/testLeaksBig.xml: Copy
-	  TestWithinDistance.xml test, drop duplicates from
+	* [r2453] Copy TestWithinDistance.xml test, drop duplicates from
 	  testLeaksBig.xml
 2009-05-02 09:20  Sandro Santilli <strk at keybit.net>
-	* [r2452] tests/xmltester/Makefile.am,
-	  tests/xmltester/tests/general/TestFunctionAA.xml,
-	  tests/xmltester/tests/general/TestFunctionAAPrec.xml,
-	  tests/xmltester/tests/general/TestFunctionLA.xml,
-	  tests/xmltester/tests/general/TestFunctionLAPrec.xml,
-	  tests/xmltester/tests/general/TestFunctionLL.xml,
-	  tests/xmltester/tests/general/TestFunctionLLPrec.xml,
-	  tests/xmltester/tests/general/TestFunctionPA.xml,
-	  tests/xmltester/tests/general/TestFunctionPL.xml,
-	  tests/xmltester/tests/general/TestFunctionPLPrec.xml,
-	  tests/xmltester/tests/general/TestFunctionPP.xml: More tests from
-	  JTS (TestFunction*)
+	* [r2452] More tests from JTS (TestFunction*)
 2009-05-02 09:17  Sandro Santilli <strk at keybit.net>
-	* [r2451] tests/xmltester/Makefile.am,
-	  tests/xmltester/tests/general/TestBoundary.xml: Boundary test
+	* [r2451] Boundary test
 2009-05-02 09:16  Sandro Santilli <strk at keybit.net>
-	* [r2450] tests/xmltester/Makefile.am,
-	  tests/xmltester/tests/general/TestConvexHull-big.xml,
-	  tests/xmltester/tests/general/TestConvexHull.xml: ConvexHull
-	  tests
+	* [r2450] ConvexHull tests
 2009-05-02 09:11  Sandro Santilli <strk at keybit.net>
-	* [r2449] tests/xmltester/Makefile.am,
-	  tests/xmltester/XMLTester.cpp,
-	  tests/xmltester/tests/general/TestRelateAA.xml,
-	  tests/xmltester/tests/general/TestRelateAC.xml,
-	  tests/xmltester/tests/general/TestRelateLA.xml,
-	  tests/xmltester/tests/general/TestRelateLC.xml,
-	  tests/xmltester/tests/general/TestRelateLL.xml,
-	  tests/xmltester/tests/general/TestRelatePA.xml,
-	  tests/xmltester/tests/general/TestRelatePL.xml,
-	  tests/xmltester/tests/general/TestRelatePP.xml: Add support for
-	  testing 'contains' in XMLTester, add all Relate tests from JTS
+	* [r2449] Add support for testing 'contains' in XMLTester, add all
+	  Relate tests from JTS
 2009-05-02 09:01  Sandro Santilli <strk at keybit.net>
-	* [r2448] tests/xmltester/Makefile.am,
-	  tests/xmltester/tests/TestBuffer.xml,
-	  tests/xmltester/tests/TestBufferMitredJoin.xml,
-	  tests/xmltester/tests/TestCentroid.xml,
-	  tests/xmltester/tests/TestInteriorPoint.xml,
-	  tests/xmltester/tests/TestSimple.xml,
-	  tests/xmltester/tests/TestValid.xml,
-	  tests/xmltester/tests/TestValid2-big.xml,
-	  tests/xmltester/tests/TestValid2.xml,
-	  tests/xmltester/tests/general,
-	  tests/xmltester/tests/general/TestBuffer.xml,
-	  tests/xmltester/tests/general/TestBufferMitredJoin.xml,
-	  tests/xmltester/tests/general/TestCentroid.xml,
-	  tests/xmltester/tests/general/TestInteriorPoint.xml,
-	  tests/xmltester/tests/general/TestSimple.xml,
-	  tests/xmltester/tests/general/TestValid.xml,
-	  tests/xmltester/tests/general/TestValid2-big.xml,
-	  tests/xmltester/tests/general/TestValid2.xml: More organization
-	  of xml tests: 'general' subdir following JTS
+	* [r2448] More organization of xml tests: 'general' subdir
+	  following JTS
 2009-05-02 08:44  Sandro Santilli <strk at keybit.net>
-	* [r2447] tests/xmltester/Makefile.am, tests/xmltester/tests/stmlf,
-	  tests/xmltester/tests/stmlf-cases-20061020.xml,
-	  tests/xmltester/tests/stmlf-cases-20070119.xml,
-	  tests/xmltester/tests/stmlf/stmlf-cases-20061020.xml,
-	  tests/xmltester/tests/stmlf/stmlf-cases-20070119.xml: Put stml
-	  testcases under their own dir (like in JTS)
+	* [r2447] Put stml testcases under their own dir (like in JTS)
 2009-05-02 08:37  Sandro Santilli <strk at keybit.net>
-	* [r2446] tests/xmltester/Makefile.am,
-	  tests/xmltester/tests/TestRobustOverlayFixed.xml,
-	  tests/xmltester/tests/robust,
-	  tests/xmltester/tests/robust/TestRobustOverlayFixed.xml,
-	  tests/xmltester/tests/robust/TestRobustRelate.xml,
-	  tests/xmltester/tests/split.xml: Add a 'split.xml' testcase to
-	  confirm 'difference' may be used to split linestrings; add
-	  TestRobustRelate.xml from JTS, organize robust-related tests as
-	  in JTS repository.
+	* [r2446] Add a 'split.xml' testcase to confirm 'difference' may be
+	  used to split linestrings; add TestRobustRelate.xml from JTS,
+	  organize robust-related tests as in JTS repository.
 2009-04-30 12:42  Sandro Santilli <strk at keybit.net>
-	* [r2444] source/headers/geos/noding/snapround/SimpleSnapRounder.h:
-	  drop duplicated (and old) port info
+	* [r2444] drop duplicated (and old) port info
 2009-04-30 12:33  Sandro Santilli <strk at keybit.net>
-	* [r2443] NEWS, source/geom/Geometry.cpp,
-	  source/headers/geos/geom/Geometry.inl: Update port info
+	* [r2443] Update port info
 2009-04-30 12:17  Sandro Santilli <strk at keybit.net>
-	* [r2442] source/geom/Point.cpp, source/headers/geos/geom/Point.h:
-	  Point full up to JTS-1.0 (rev 1.37) : adds reverse()
+	* [r2442] Point full up to JTS-1.0 (rev 1.37) : adds reverse()
 2009-04-30 12:07  Sandro Santilli <strk at keybit.net>
-	* [r2441] source/geom/LineString.cpp,
-	  source/headers/geos/geom/LineString.h: LineString to rev 1.46 :
-	  don't override isSimple, always return MultiPoint as bondary
+	* [r2441] LineString to rev 1.46 : don't override isSimple, always
+	  return MultiPoint as bondary
 2009-04-30 11:47  Sandro Santilli <strk at keybit.net>
-	* [r2440] source/geom/Polygon.cpp,
-	  source/headers/geos/geom/Polygon.h: Polygon to rev 1.50
-	  (getBoundary always return MultiLineString)
+	* [r2440] Polygon to rev 1.50 (getBoundary always return
+	  MultiLineString)
 2009-04-30 11:42  Sandro Santilli <strk at keybit.net>
-	* [r2439] source/geom/MultiPoint.cpp,
-	  source/headers/geos/geom/MultiPoint.h: MultiPoint up to rev 1.30
-	  (drop isSimple override)
+	* [r2439] MultiPoint up to rev 1.30 (drop isSimple override)
 2009-04-30 11:36  Sandro Santilli <strk at keybit.net>
-	* [r2438] source/geom/MultiLineString.cpp,
-	  source/headers/geos/geom/MultiLineString.inl: MultiLineString
-	  port info and sync to 1.40 (don't override isSimple)
+	* [r2438] MultiLineString port info and sync to 1.40 (don't
+	  override isSimple)
 2009-04-30 11:29  Sandro Santilli <strk at keybit.net>
-	* [r2437] source/geom/MultiPolygon.cpp,
-	  source/headers/geos/geom/MultiPolygon.inl: MultiPolygon up to rev
-	  1.34 (getBoundary always returns a MultiLineString now)
+	* [r2437] MultiPolygon up to rev 1.34 (getBoundary always returns a
+	  MultiLineString now)
 2009-04-30 11:19  Sandro Santilli <strk at keybit.net>
-	* [r2436] source/geom/GeometryCollection.cpp,
-	  source/headers/geos/geom/GeometryCollection.h: Oops, *now* we're
-	  at 1.14 (drop isSimple, rely on the one in base class)
+	* [r2436] Oops, *now* we're at 1.14 (drop isSimple, rely on the one
+	  in base class)
 2009-04-30 11:15  Sandro Santilli <strk at keybit.net>
-	* [r2435] source/geom/GeometryCollection.cpp,
-	  source/headers/geos/geom/GeometryCollection.inl: Port info. It's
-	  at 1.41 now, JTS is at 1.42
+	* [r2435] Port info. It's at 1.41 now, JTS is at 1.42
 2009-04-30 11:03  Sandro Santilli <strk at keybit.net>
-	* [r2434] source/geom/Geometry.cpp,
-	  source/headers/geos/geom/Geometry.inl: Geometry class up to JTS
-	  rev 1.104 (need reach 1.127...)
+	* [r2434] Geometry class up to JTS rev 1.104 (need reach 1.127...)
 2009-04-30 10:59  Sandro Santilli <strk at keybit.net>
-	* [r2433] NEWS: Add some info about things changed (might have
-	  missed something)
+	* [r2433] Add some info about things changed (might have missed
+	  something)
 2009-04-30 10:51  Sandro Santilli <strk at keybit.net>
-	* [r2432] source/headers/geos/operation/IsSimpleOp.h,
-	  source/operation/IsSimpleOp.cpp: Sync to rev 1.22 (JTS-1.10)
+	* [r2432] Sync to rev 1.22 (JTS-1.10)
 2009-04-30 10:47  Sandro Santilli <strk at keybit.net>
-	* [r2431] source/headers/geos/operation.h: EndpointInfo.h header is
-	  gone (it's always been private in JTS)
+	* [r2431] EndpointInfo.h header is gone (it's always been private
+	  in JTS)
 2009-04-30 10:46  Sandro Santilli <strk at keybit.net>
-	* [r2430] source/headers/geos/operation/EndpointInfo.h,
-	  source/operation/IsSimpleOp.cpp: Port revision 1.9 of IsSimplOp :
-	  allow inspecting non-simple location coordinate.
+	* [r2430] Port revision 1.9 of IsSimplOp : allow inspecting
+	  non-simple location coordinate.
 2009-04-30 10:43  Sandro Santilli <strk at keybit.net>
-	* [r2429] source/geomgraph/EdgeIntersection.cpp,
-	  source/headers/geos/geomgraph/EdgeIntersection.h: Sync to
-	  revision 1.5 (JTS-1.10) : add accessors
+	* [r2429] Sync to revision 1.5 (JTS-1.10) : add accessors
 2009-04-30 09:54  Sandro Santilli <strk at keybit.net>
-	* [r2428] source/headers/geos/operation/IsSimpleOp.h,
-	  source/operation/IsSimpleOp.cpp: port to rev 1.8 (use of
-	  BoundaryNodeRule)
+	* [r2428] port to rev 1.8 (use of BoundaryNodeRule)
 2009-04-30 09:49  Sandro Santilli <strk at keybit.net>
-	* [r2427] tests/xmltester/Makefile.am,
-	  tests/xmltester/tests/testLeaksBig.xml: Import TestSimple.xml
-	  from JTS, drop duplicated tests from testLeaksBig.xml
+	* [r2427] Import TestSimple.xml from JTS, drop duplicated tests
+	  from testLeaksBig.xml
 2009-04-30 09:26  Sandro Santilli <strk at keybit.net>
-	* [r2426] source/algorithm/BoundaryNodeRule.cpp,
-	  source/algorithm/Makefile.am,
-	  source/headers/geos/algorithm/BoundaryNodeRule.h,
-	  source/headers/geos/algorithm/Makefile.am: Port
-	  algorithm::BoundaryNodeRule from JTS-1.10 (needed for IsSimpleOp
-	  sync)
+	* [r2426] Port algorithm::BoundaryNodeRule from JTS-1.10 (needed
+	  for IsSimpleOp sync)
 2009-04-30 08:33  Sandro Santilli <strk at keybit.net>
-	* [r2425] source/headers/geos/operation/IsSimpleOp.h,
-	  source/operation/IsSimpleOp.cpp: Port info, and sync from 1.14 to
-	  1.17 (more to do, need more classes)
+	* [r2425] Port info, and sync from 1.14 to 1.17 (more to do, need
+	  more classes)
 2009-04-29 23:52  Mateusz Loskot <mateusz at loskot.net>
-	* [r2424] tests/unit/capi/GEOSContainsTest.cpp,
-	  tests/unit/capi/GEOSCoordSeqTest.cpp,
-	  tests/unit/capi/GEOSGeomFromWKBTest.cpp,
-	  tests/unit/capi/GEOSGeomToWKTTest.cpp,
-	  tests/unit/capi/GEOSPolygonizer_getCutEdgesTest.cpp,
-	  tests/unit/capi/GEOSPreparedGeometryTest.cpp,
-	  tests/unit/capi/GEOSSimplifyTest.cpp,
-	  tests/unit/capi/GEOSWithinTest.cpp: test/unit/capi: re-tab all
-	  .cpp files to use spaces.
+	* [r2424] test/unit/capi: re-tab all .cpp files to use spaces.
 2009-04-29 23:46  Mateusz Loskot <mateusz at loskot.net>
-	* [r2423] tests/unit/capi/GEOSContainsTest.cpp,
-	  tests/unit/capi/GEOSWithinTest.cpp: Removed unused <memory>
-	  header from C API tests.
+	* [r2423] Removed unused <memory> header from C API tests.
 2009-04-29 23:44  Mateusz Loskot <mateusz at loskot.net>
-	* [r2422] tests/unit/Makefile.am,
-	  tests/unit/capi/GEOSContainsTest.cpp,
-	  tests/unit/capi/GEOSWithinTest.cpp: Added new unit tests for C
-	  API: GEOSWithinTest and GEOSContainsTest. This is check and
-	  response for problems reporting in Ticket #250. Running the new
-	  tests does not reproduce the problem, so it likely has been fixed
-	  or the bug is somewhere else (i.e. Django layers).
+	* [r2422] Added new unit tests for C API: GEOSWithinTest and
+	  GEOSContainsTest. This is check and response for problems
+	  reporting in Ticket #250. Running the new tests does not
+	  reproduce the problem, so it likely has been fixed or the bug is
+	  somewhere else (i.e. Django layers).
 2009-04-29 09:44  Sandro Santilli <strk at keybit.net>
-	* [r2421] source/headers/geos/util/GeometricShapeFactory.h,
-	  source/util/GeometricShapeFactory.cpp: Sync GeometricShapeFactory
-	  to JTS-1.10 (createArcPolygon added)
+	* [r2421] Sync GeometricShapeFactory to JTS-1.10 (createArcPolygon
+	  added)
 2009-04-29 08:56  Sandro Santilli <strk at keybit.net>
-	* [r2420] source/geom/prep/AbstractPreparedPolygonContains.cpp,
-	  source/geom/prep/PreparedPolygonContainsProperly.cpp,
-	  source/geom/prep/PreparedPolygonCovers.cpp,
-	  source/geom/prep/PreparedPolygonIntersects.cpp,
-	  source/geom/prep/PreparedPolygonPredicate.cpp,
-	  source/headers/geos/geom/prep/AbstractPreparedPolygonContains.h,
-	  source/headers/geos/geom/prep/PreparedPolygonContainsProperly.h,
-	  source/headers/geos/geom/prep/PreparedPolygonCovers.h,
-	  source/headers/geos/geom/prep/PreparedPolygonIntersects.h,
-	  source/headers/geos/geom/prep/PreparedPolygonPredicate.h: Bring
-	  all geom::prep package in sync with JTS-1.10
+	* [r2420] Bring all geom::prep package in sync with JTS-1.10
 2009-04-29 08:22  Sandro Santilli <strk at keybit.net>
-	* [r2419] source/geom/prep/BasicPreparedGeometry.cpp,
-	  source/headers/geos/geom/prep/BasicPreparedGeometry.h: Sync
-	  BasicPreparedGeometry to JTS-1.10 (short-circuit in
+	* [r2419] Sync BasicPreparedGeometry to JTS-1.10 (short-circuit in
 	  containsProperly)
 2009-04-29 08:15  Sandro Santilli <strk at keybit.net>
-	* [r2418] source/geom/prep/AbstractPreparedPolygonContains.cpp,
-	  source/geom/prep/BasicPreparedGeometry.cpp,
-	  source/geom/prep/PreparedGeometry.cpp,
-	  source/geom/prep/PreparedGeometryFactory.cpp,
-	  source/geom/prep/PreparedLineString.cpp,
-	  source/geom/prep/PreparedLineStringIntersects.cpp,
-	  source/geom/prep/PreparedPoint.cpp,
-	  source/geom/prep/PreparedPolygon.cpp,
-	  source/geom/prep/PreparedPolygonContains.cpp,
-	  source/headers/geos/geom/prep/BasicPreparedGeometry.h,
-	  source/headers/geos/geom/prep/PreparedGeometry.h,
-	  source/headers/geos/geom/prep/PreparedGeometryFactory.h,
-	  source/headers/geos/geom/prep/PreparedLineString.h,
-	  source/headers/geos/geom/prep/PreparedLineStringIntersects.h,
-	  source/headers/geos/geom/prep/PreparedPoint.h,
-	  source/headers/geos/geom/prep/PreparedPolygon.h,
-	  source/headers/geos/geom/prep/PreparedPolygonContains.h,
-	  source/headers/geos/geom/prep/PreparedPolygonPredicate.h: Add
-	  port information for geom::prep package. Next stop: sync to
-	  JTS-1.10.
+	* [r2418] Add port information for geom::prep package. Next stop:
+	  sync to JTS-1.10.
 2009-04-27 19:47  Sandro Santilli <strk at keybit.net>
-	* [r2417] tests/unit/capi/GEOSGeomToWKTTest.cpp: Plug last one. All
-	  heap blocks were freed -- no leaks are possible.
+	* [r2417] Plug last one. All heap blocks were freed -- no leaks are
+	  possible.
 2009-04-27 19:42  Sandro Santilli <strk at keybit.net>
-	* [r2416] tests/unit/algorithm/RobustLineIntersectorTest.cpp: Fix
-	  leak in testcase
+	* [r2416] Fix leak in testcase
 2009-04-27 19:38  Sandro Santilli <strk at keybit.net>
-	* [r2415] source/headers/geos/index/quadtree/Node.h,
-	  source/index/quadtree/Node.cpp, source/index/quadtree/Root.cpp:
-	  Refactor signatures to make ownership transfers more explicit.
-	  Fixed another leak in Node::insertNode.
+	* [r2415] Refactor signatures to make ownership transfers more
+	  explicit. Fixed another leak in Node::insertNode.
 2009-04-27 19:22  Sandro Santilli <strk at keybit.net>
-	* [r2414] source/index/quadtree/NodeBase.cpp: Fix memory leak in
-	  NodeBase::remove, exposed by unit testing
+	* [r2414] Fix memory leak in NodeBase::remove, exposed by unit
+	  testing
 2009-04-27 15:52  Sandro Santilli <strk at keybit.net>
-	* [r2413] source/headers/geos/index/quadtree/Root.h,
-	  source/index/quadtree/Root.cpp: Port info for quadtree::root
+	* [r2413] Port info for quadtree::root
 2009-04-27 15:47  Sandro Santilli <strk at keybit.net>
-	* [r2412] source/headers/geos/index/quadtree/Node.h,
-	  source/index/quadtree/Node.cpp: Port info for quadtree::Node
+	* [r2412] Port info for quadtree::Node
 2009-04-27 15:39  Sandro Santilli <strk at keybit.net>
-	* [r2411] source/headers/geos/index/quadtree/IntervalSize.h,
-	  source/index/quadtree/IntervalSize.cpp: Port info and check,
-	  doxygen.
+	* [r2411] Port info and check, doxygen.
 2009-04-27 15:30  Sandro Santilli <strk at keybit.net>
-	* [r2410] source/headers/geos/index/quadtree/Quadtree.h,
-	  source/index/quadtree/Quadtree.cpp: Sync to JTS-1.10, reduce heap
-	  allocations and pointers usage. Includes a bugfix in
-	  collectStats.
+	* [r2410] Sync to JTS-1.10, reduce heap allocations and pointers
+	  usage. Includes a bugfix in collectStats.
 2009-04-27 15:00  Sandro Santilli <strk at keybit.net>
-	* [r2409] source/headers/geos/index/quadtree/DoubleBits.h,
-	  source/index/quadtree/DoubleBits.cpp: DoubleBits didn't change in
-	  JTS, update port info accordingly
+	* [r2409] DoubleBits didn't change in JTS, update port info
+	  accordingly
 2009-04-27 14:58  Sandro Santilli <strk at keybit.net>
-	* [r2408] source/headers/geos/index/quadtree/Node.h,
-	  source/index/quadtree/NodeBase.cpp,
-	  source/index/quadtree/Quadtree.cpp: Quadtree's NodeBase: check
-	  port sync, add port info, drop unneeded pointers and virtuals,
-	  document objects ownership.
+	* [r2408] Quadtree's NodeBase: check port sync, add port info, drop
+	  unneeded pointers and virtuals, document objects ownership.
 2009-04-25 00:23  Sandro Santilli <strk at keybit.net>
-	* [r2407] source/headers/geos/index/SpatialIndex.h,
-	  source/index/quadtree/Key.cpp, source/index/quadtree/Node.cpp,
-	  source/index/quadtree/Root.cpp: Const-correctness, reduced heap
-	  allocations and port info for quadtree::Key class, a few more
-	  cleanups in user classes, to be continued.
+	* [r2407] Const-correctness, reduced heap allocations and port info
+	  for quadtree::Key class, a few more cleanups in user classes, to
+	  be continued.
 2009-04-24 23:44  Sandro Santilli <strk at keybit.net>
-	* [r2406] source/index/quadtree/Quadtree.cpp: Fix memory leak in
-	  Quadtree::remove
+	* [r2406] Fix memory leak in Quadtree::remove
 2009-04-23 15:26  Sandro Santilli <strk at keybit.net>
-	* [r2405] source/headers/geos/operation/buffer/BufferBuilder.h,
-	  source/operation/buffer/BufferBuilder.cpp,
-	  source/operation/buffer/OffsetCurveBuilder.cpp,
-	  source/operation/buffer/OffsetCurveVertexList.h: Apply
-	  Single-sided buffer patch, issue #215. UNTESTED.
+	* [r2405] Apply Single-sided buffer patch, issue #215. UNTESTED.
 2009-04-21 16:11  Sandro Santilli <strk at keybit.net>
-	* [r2404] tests/unit/Makefile.am,
-	  tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp:
-	  Port ValidSelfTouchingRingFormingHoleTest
+	* [r2404] Port ValidSelfTouchingRingFormingHoleTest
 2009-04-21 15:30  Sandro Santilli <strk at keybit.net>
-	* [r2403] tests/unit/Makefile.am,
-	  tests/unit/operation/valid/ValidClosedRingTest.cpp: Port
-	  ValidClosedRingTest
+	* [r2403] Port ValidClosedRingTest
 2009-04-21 15:13  Sandro Santilli <strk at keybit.net>
-	* [r2402] source/geom/LineString.cpp,
-	  source/headers/geos/geom/LineString.h: ::reverse returns a
-	  Geometry now (to be available up in base class)
+	* [r2402] ::reverse returns a Geometry now (to be available up in
+	  base class)
 2009-04-21 15:12  Sandro Santilli <strk at keybit.net>
-	* [r2401] source/geom/LinearRing.cpp,
-	  tests/unit/geom/LinearRingTest.cpp: Sync LinearRing to JTS-1.10
-	  (fixing a bug in isClosed)
+	* [r2401] Sync LinearRing to JTS-1.10 (fixing a bug in isClosed)
 2009-04-21 14:03  Sandro Santilli <strk at keybit.net>
-	* [r2400] tests/unit/Makefile.am, tests/unit/operation/valid,
-	  tests/unit/operation/valid/IsValidTest.cpp: Port IsValidOp unit
-	  test
+	* [r2400] Port IsValidOp unit test
 2009-04-21 11:14  Sandro Santilli <strk at keybit.net>
-	* [r2399] configure.in: Configure for CXX, not C. Should fix
-	  unknown tag and link issues on telascience.
+	* [r2399] Configure for CXX, not C. Should fix unknown tag and link
+	  issues on telascience.
 2009-04-21 09:06  Sandro Santilli <strk at keybit.net>
-	* [r2398] configure.in: Add an AC_LIBTOOL_LANG_C_CONFIG call right
-	  before the AC_LIBTOOL_COMPILER_OPTION calls. Seems to fix
-	  compiler selection on telascience (whereas AC_LANG and
-	  AC_LANG_PUSH didn't work)
+	* [r2398] Add an AC_LIBTOOL_LANG_C_CONFIG call right before the
+	  AC_LIBTOOL_COMPILER_OPTION calls. Seems to fix compiler selection
+	  on telascience (whereas AC_LANG and AC_LANG_PUSH didn't work)
 2009-04-20 20:32  Sandro Santilli <strk at keybit.net>
-	* [r2397] tests/xmltester/BufferResultMatcher.cpp,
-	  tests/xmltester/BufferResultMatcher.h: Use JTS heuristic for
-	  distance-0 buffer checking
+	* [r2397] Use JTS heuristic for distance-0 buffer checking
 2009-04-20 11:04  Mateusz Loskot <mateusz at loskot.net>
-	* [r2396] tests/perf, tests/perf/operation,
-	  tests/perf/operation/buffer: Updated svn:ignore patterns.
+	* [r2396] Updated svn:ignore patterns.
 2009-04-20 10:37  Sandro Santilli <strk at keybit.net>
-	* [r2395] configure.in, tests/Makefile.am, tests/perf,
-	  tests/perf/Makefile.am, tests/perf/operation,
-	  tests/perf/operation/Makefile.am, tests/perf/operation/buffer,
-	  tests/perf/operation/buffer/IteratedBufferStressTest.cpp,
-	  tests/perf/operation/buffer/Makefile.am: Port
-	  IteratedBufferStessTest
+	* [r2395] Port IteratedBufferStessTest
 2009-04-20 09:37  Sandro Santilli <strk at keybit.net>
-	* [r2394] source/geomgraph/Quadrant.cpp,
-	  source/headers/geos/geomgraph/Quadrant.h: Add named constants,
-	  sync to JTS-1.10
+	* [r2394] Add named constants, sync to JTS-1.10
 2009-04-20 09:24  Mateusz Loskot <mateusz at loskot.net>
-	* [r2393] source/algorithm/distance,
-	  source/headers/geos/algorithm/distance: Updated svn:ignore
-	  patterns.
+	* [r2393] Updated svn:ignore patterns.
 2009-04-18 07:55  Sandro Santilli <strk at keybit.net>
-	* [r2392] tests/xmltester/XMLTester.cpp: Use BufferResultMatcher
-	  for buffer operations. No failures.
+	* [r2392] Use BufferResultMatcher for buffer operations. No
+	  failures.
 2009-04-18 07:49  Sandro Santilli <strk at keybit.net>
-	* [r2391] tests/xmltester/tests/TestBigNastyBuffer.xml: Imported
-	  cleaned-up version of fme.xml -- this one fails (the one we have
-	  is actually expecting a wrong result)
+	* [r2391] Imported cleaned-up version of fme.xml -- this one fails
+	  (the one we have is actually expecting a wrong result)
 2009-04-18 07:46  Sandro Santilli <strk at keybit.net>
-	* [r2390] tests/xmltester/BufferResultMatcher.cpp: Don't densify
-	  coordinates if buffer distance is 0
+	* [r2390] Don't densify coordinates if buffer distance is 0
 2009-04-17 16:50  Sandro Santilli <strk at keybit.net>
-	* [r2389]
-	  tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp:
-	  comment out debugging lines
+	* [r2389] comment out debugging lines
 2009-04-17 16:49  Sandro Santilli <strk at keybit.net>
-	* [r2388] tests/unit/Makefile.am, tests/unit/algorithm/distance,
-	  Port DiscreteHausdorffDistance unit test
+	* [r2388] Port DiscreteHausdorffDistance unit test
 2009-04-17 16:47  Sandro Santilli <strk at keybit.net>
-	* [r2387] source/algorithm/distance/DiscreteHausdorffDistance.cpp,
-	  source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h:
-	  Offline some more
+	* [r2387] Offline some more
 2009-04-17 16:46  Sandro Santilli <strk at keybit.net>
-	* [r2386]
-	  source/headers/geos/algorithm/distance/PointPairDistance.h: Fix
-	  typo
+	* [r2386] Fix typo
 2009-04-17 16:26  Sandro Santilli <strk at keybit.net>
-	* [r2385] source/algorithm/distance/DiscreteHausdorffDistance.cpp,
-	  Add missing implementation bits
+	* [r2385] Add missing implementation bits
 2009-04-17 15:47  Sandro Santilli <strk at keybit.net>
-	* [r2384] tests/xmltester/BufferResultMatcher.cpp,
-	  tests/xmltester/BufferResultMatcher.h,
-	  tests/xmltester/XMLTester.cpp: Port BufferResultMatcher. Gives 31
-	  new failures !!
+	* [r2384] Port BufferResultMatcher. Gives 31 new failures !!
 2009-04-17 15:37  Sandro Santilli <strk at keybit.net>
-	* [r2383] source/headers/geos/geom/BinaryOp.h,
-	  tests/xmltester/Makefile.am, tests/xmltester/XMLTester.cpp:
-	  proper inline check_valid source/headers/geos/geom/BinaryOp.h
+	* [r2383] proper inline check_valid
+	  source/headers/geos/geom/BinaryOp.h
 2009-04-17 15:34  Sandro Santilli <strk at keybit.net>
-	* [r2382] source/headers/geos/geom/BinaryOp.h: Header guard
+	* [r2382] Header guard
 2009-04-17 13:59  Sandro Santilli <strk at keybit.net>
-	* [r2381] source/algorithm/LineIntersector.cpp,
-	  tests/unit/algorithm/RobustLineIntersectorTest.cpp: renamed
-	  intersection constants
+	* [r2381] renamed intersection constants
 2009-04-17 09:56  Sandro Santilli <strk at keybit.net>
-	* [r2380] configure.in: Add debugging output of variables used by
+	* [r2380] Add debugging output of variables used by
 	  AC_LIBTOOL_COMPILER_OPTION. Surprisingly, the buildbots try to
 	  use a fortran compiler there
 2009-04-17 07:50  Sandro Santilli <strk at keybit.net>
-	* [r2379] configure.in: Differentiate variable used in
-	  AC_LIBTOOL_COMPILE_OPTION for proper use of configuration cache
+	* [r2379] Differentiate variable used in AC_LIBTOOL_COMPILE_OPTION
+	  for proper use of configuration cache
 2009-04-16 18:05  Sandro Santilli <strk at keybit.net>
-	* [r2378] configure.in: Use -ffloat-store flag when available. See
+	* [r2378] Use -ffloat-store flag when available. See
 	  http://lists.osgeo.org/pipermail/geos-devel/2009-April/004089.html
 2009-04-16 12:56  Sandro Santilli <strk at keybit.net>
-	* [r2377] source/headers/geos/algorithm/LineIntersector.h: Make
-	  enum values explicit, as JTS tests rely on those..
+	* [r2377] Make enum values explicit, as JTS tests rely on those..
 2009-04-16 12:54  Sandro Santilli <strk at keybit.net>
-	* [r2376] tests/unit/Makefile.am,
-	  tests/unit/algorithm/RobustLineIntersectorTest.cpp: Port
-	  RobustLineIntersectorTest from JTS
+	* [r2376] Port RobustLineIntersectorTest from JTS
 2009-04-16 12:08  Sandro Santilli <strk at keybit.net>
-	* [r2375] tests/unit/algorithm/RobustLineIntersectionTest.cpp:
-	  better isolation of test-specific functions
+	* [r2375] better isolation of test-specific functions
 2009-04-16 10:48  Sandro Santilli <strk at keybit.net>
-	* [r2374] tests/unit/Makefile.am,
-	  tests/unit/algorithm/RobustLineIntersectionTest.cpp: Port
-	  RobustLineIntersectionTest (mostly failing, but reported by
-	  Martin Davis to be expected)
+	* [r2374] Port RobustLineIntersectionTest (mostly failing, but
+	  reported by Martin Davis to be expected)
 2009-04-15 15:58  Sandro Santilli <strk at keybit.net>
-	* [r2373] source/algorithm/distance/DiscreteHausdorffDistance.cpp,
-	  source/algorithm/distance/DistanceToPoint.cpp,
-	  source/algorithm/distance/EuclideanDistanceToPoint.cpp,
-	  source/algorithm/distance/Makefile.am,
-	  source/headers/geos/algorithm/distance/DistanceToPoint.h,
-	  source/headers/geos/algorithm/distance/EuclideanDistanceToPoint.h,
-	  source/headers/geos/algorithm/distance/Makefile.am: New class
-	  rename, following JTS
+	* [r2373] New class rename, following JTS
 2009-04-15 12:56  Sandro Santilli <strk at keybit.net>
-	* [r2372] source/algorithm/HCoordinate.cpp: typo in disabled
-	  section
+	* [r2372] typo in disabled section
 2009-04-15 11:17  Sandro Santilli <strk at keybit.net>
-	* [r2371] source/headers/geos/index/quadtree/Key.h,
-	  source/index/quadtree/Key.cpp: Few more docs about memory
-	  management in quadtree indexing; fix a potential leak in
-	  quadtree::Key
+	* [r2371] Few more docs about memory management in quadtree
+	  indexing; fix a potential leak in quadtree::Key
 2009-04-15 10:43  Sandro Santilli <strk at keybit.net>
-	* [r2370] source/headers/geos/index/quadtree/NodeBase.h: Document
-	  ownership of quadtree::NodeBase subnodes
+	* [r2370] Document ownership of quadtree::NodeBase subnodes
 2009-04-15 10:18  Sandro Santilli <strk at keybit.net>
-	* [r2369] tests/unit/util/UniqueCoordinateArrayFilterTest.cpp: Fix
-	  memory leak in unit test
+	* [r2369] Fix memory leak in unit test
 2009-04-15 10:02  Sandro Santilli <strk at keybit.net>
-	* [r2368] source/headers/geos/geom/CoordinateSequence.h,
-	  source/headers/geos/geom/util/CoordinateOperation.h,
-	  source/precision/SimpleGeometryPrecisionReducer.cpp: Fix leak in
-	  SimpleGeometryPrecisionReducer, improve memory management docs
-	  where topic.
+	* [r2368] Fix leak in SimpleGeometryPrecisionReducer, improve
+	  memory management docs where topic.
 2009-04-15 09:29  Sandro Santilli <strk at keybit.net>
-	* [r2367] source/headers/geos/operation/distance/DistanceOp.h,
-	  tests/unit/operation/distance/DistanceOpTest.cpp: Document
-	  ownership of DistanceOp::closestPoints return, fix leak in unit
-	  test.
+	* [r2367] Document ownership of DistanceOp::closestPoints return,
+	  fix leak in unit test.
 2009-04-15 09:25  Sandro Santilli <strk at keybit.net>
-	* [r2366] source/geomgraph/EdgeRing.cpp,
-	  source/headers/geos/geomgraph/EdgeRing.h,
-	  source/headers/geos/operation/overlay/MaximalEdgeRing.h,
-	  source/operation/overlay/MaximalEdgeRing.cpp,
-	  source/operation/overlay/PolygonBuilder.cpp: Fix leak in
-	  PolygonBuilder (overlay operation). The leak was exposed by the
-	  stmlf-cases-20061020.xml testcase. This commit also adds some
-	  doc-only throw specs related to the bug.
+	* [r2366] Fix leak in PolygonBuilder (overlay operation). The leak
+	  was exposed by the stmlf-cases-20061020.xml testcase. This commit
+	  also adds some doc-only throw specs related to the bug.
 2009-04-15 07:52  Sandro Santilli <strk at keybit.net>
-	* [r2365] source/operation/valid/IndexedNestedRingTester.cpp: Fix
-	  memory leaks in IsValid operation
+	* [r2365] Fix memory leaks in IsValid operation
 2009-04-15 00:27  Sandro Santilli <strk at keybit.net>
-	* [r2364] source/algorithm/HCoordinate.cpp: Explain why unrolled
-	  computation is turned off, and keep it off
+	* [r2364] Explain why unrolled computation is turned off, and keep
+	  it off
 2009-04-15 00:14  Sandro Santilli <strk at keybit.net>
-	* [r2363] source/operation/buffer/BufferInputLineSimplifier.cpp:
-	  Fix typo in computing angleOrientation
+	* [r2363] Fix typo in computing angleOrientation
 2009-04-14 19:11  Sandro Santilli <strk at keybit.net>
-	* [r2362] source/algorithm/HCoordinate.cpp,
-	  tests/xmltester/tests/TestBufferMitredJoin.xml: Temporarly revert
-	  the unrolled computation in HCoordinate::intersection. Added
-	  mitred join buffer test from JTS (failed with the unrolled comp,
-	  to be further inspected).
+	* [r2362] Temporarly revert the unrolled computation in
+	  HCoordinate::intersection. Added mitred join buffer test from JTS
+	  (failed with the unrolled comp, to be further inspected).
 2009-04-14 16:43  Sandro Santilli <strk at keybit.net>
-	* [r2361] configure.in, source/algorithm/Makefile.am,
-	  source/algorithm/distance,
-	  source/algorithm/distance/DiscreteHausdorffDistance.cpp,
-	  source/headers/geos/algorithm/Makefile.am,
-	  source/headers/geos/algorithm/distance,
-	  source/headers/geos/algorithm/distance/Makefile.am,
-	  source/headers/geos/algorithm/distance/PointPairDistance.h,
-	  source/headers/geos/geom/CoordinateSequenceFilter.h: Port the
-	  algorithm::distance package from JTS 1.9
+	* [r2361] Port the algorithm::distance package from JTS 1.9
 2009-04-14 15:25  Sandro Santilli <strk at keybit.net>
-	* [r2360] source/geom/Geometry.cpp,
-	  source/geom/GeometryCollection.cpp,
-	  source/geom/GeometryComponentFilter.cpp,
-	  source/geom/LineString.cpp, source/geom/Point.cpp,
-	  source/geom/Polygon.cpp,
-	  source/headers/geos/geom/CoordinateSequenceFilter.h,
-	  source/headers/geos/geom/GeometryCollection.h,
-	  source/headers/geos/geom/LineString.h,
-	  source/headers/geos/geom/Makefile.am,
-	  source/headers/geos/geom/Point.h,
-	  source/headers/geos/geom/Polygon.h: Add CoordinateSequenceFilter
-	  support, fix default GeometryComponentFilter moving the logic to
-	  the correct place (a Geometry private class).
+	* [r2360] Add CoordinateSequenceFilter support, fix default
+	  GeometryComponentFilter moving the logic to the correct place (a
+	  Geometry private class).
 2009-04-14 13:35  Sandro Santilli <strk at keybit.net>
-	* [r2359] source/algorithm/LineIntersector.cpp,
-	  source/headers/geos/algorithm/LineIntersector.h: Sync
-	  (Robust)LineIntersector to JTS-1.9
+	* [r2359] Sync (Robust)LineIntersector to JTS-1.9
 2009-04-14 13:23  Sandro Santilli <strk at keybit.net>
-	* [r2358] source/algorithm/CGAlgorithms.cpp,
-	  source/headers/geos/algorithm/CGAlgorithms.h: Sync CGAlgorithms
-	  with JTS-1.9
+	* [r2358] Sync CGAlgorithms with JTS-1.9
 2009-04-14 12:55  Sandro Santilli <strk at keybit.net>
-	* [r2357] source/algorithm/RayCrossingCounter.cpp,
-	  source/algorithm/locate/IndexedPointInAreaLocator.cpp,
-	  source/headers/geos/algorithm/RayCrossingCounter.h: Fix memory
-	  leak in RayCrossingCounter; update signatures to avoid pointers
-	  when unneeded; add a locatePointInRing taking a vector of
-	  coordinate pointers, for use by CGAlgorithms
+	* [r2357] Fix memory leak in RayCrossingCounter; update signatures
+	  to avoid pointers when unneeded; add a locatePointInRing taking a
+	  vector of coordinate pointers, for use by CGAlgorithms
 2009-04-14 12:42  Sandro Santilli <strk at keybit.net>
-	* [r2356] source/algorithm/RayCrossingCounter.cpp,
-	  source/headers/geos/algorithm/RayCrossingCounter.h: Update port
-	  info, checked against JTS-1.9
+	* [r2356] Update port info, checked against JTS-1.9
 2009-04-14 11:03  Sandro Santilli <strk at keybit.net>
-	* [r2355] tests/xmltester/Makefile.am,
-	  tests/xmltester/TestBuffer.xml,
-	  tests/xmltester/TestBufferExternal.xml,
-	  tests/xmltester/TestBufferExternal2.xml,
-	  tests/xmltester/TestCentroid.xml,
-	  tests/xmltester/TestInteriorPoint.xml,
-	  tests/xmltester/TestIsValid.xml,
-	  tests/xmltester/TestRobustOverlayFixed.xml,
-	  tests/xmltester/TestValid.xml,
-	  tests/xmltester/TestValid2-big.xml,
-	  tests/xmltester/TestValid2.xml, tests/xmltester/badguy3.xml,
-	  tests/xmltester/buffer.xml, tests/xmltester/buffer_snapround.xml,
-	  tests/xmltester/fme.xml, tests/xmltester/heisenbugs.xml,
-	  tests/xmltester/hexwkb.xml, tests/xmltester/hole_from_shell.xml,
-	  tests/xmltester/hole_red.xml, tests/xmltester/linemerge.xml,
-	  tests/xmltester/robustness.xml,
-	  tests/xmltester/stmlf-cases-20061020.xml,
-	  tests/xmltester/stmlf-cases-20070119.xml,
-	  tests/xmltester/test.xml, tests/xmltester/testLeaksBig.xml,
-	  tests/xmltester/tests, tests/xmltester/tests/TestBuffer.xml,
-	  tests/xmltester/tests/TestBufferExternal.xml,
-	  tests/xmltester/tests/TestBufferExternal2.xml,
-	  tests/xmltester/tests/TestIsValid.xml,
-	  tests/xmltester/tests/badguy3.xml,
-	  tests/xmltester/tests/buffer.xml,
-	  tests/xmltester/tests/buffer_snapround.xml,
-	  tests/xmltester/tests/fme.xml,
-	  tests/xmltester/tests/heisenbugs.xml,
-	  tests/xmltester/tests/hexwkb.xml,
-	  tests/xmltester/tests/hole_from_shell.xml,
-	  tests/xmltester/tests/hole_red.xml,
-	  tests/xmltester/tests/linemerge.xml,
-	  tests/xmltester/tests/robustness.xml,
-	  tests/xmltester/tests/test.xml,
-	  tests/xmltester/tests/testLeaksBig.xml: Move XML tests under
-	  their own directory
+	* [r2355] Move XML tests under their own directory
 2009-04-14 10:50  Sandro Santilli <strk at keybit.net>
-	* [r2354] source/operation/buffer/BufferBuilder.cpp: Fix memory
-	  leak in BufferBuilder (due to just-ported short-circuit)
+	* [r2354] Fix memory leak in BufferBuilder (due to just-ported
+	  short-circuit)
 2009-04-14 10:27  Sandro Santilli <strk at keybit.net>
-	* [r2353] tests/xmltester/XMLTester.cpp: Add support for
-	  bufferMitredJoin tests
+	* [r2353] Add support for bufferMitredJoin tests
 2009-04-14 09:53  Sandro Santilli <strk at keybit.net>
-	* [r2352] tests/xmltester/Makefile.am,
-	  tests/xmltester/XMLTester.cpp, tests/xmltester/badguy3.xml,
-	  tests/xmltester/fme.xml, tests/xmltester/testLeaksBig.xml: Fix
-	  XML for Buffer testing to match jts layout (arg2 for distance,
-	  arg3 for quadrant segments); copy buffer-related tests from jts:
-	  they succeed w/out editing.
+	* [r2352] Fix XML for Buffer testing to match jts layout (arg2 for
+	  distance, arg3 for quadrant segments); copy buffer-related tests
+	  from jts: they succeed w/out editing.
 2009-04-14 09:22  Sandro Santilli <strk at keybit.net>
-	* [r2351]
-	  source/headers/geos/operation/buffer/SubgraphDepthLocater.h,
-	  source/operation/buffer/SubgraphDepthLocater.cpp: Update port
-	  info of SubgraphDepthLocater
+	* [r2351] Update port info of SubgraphDepthLocater
 2009-04-14 09:19  Sandro Santilli <strk at keybit.net>
-	* [r2350]
-	  source/headers/geos/operation/buffer/RightmostEdgeFinder.h,
-	  source/operation/buffer/RightmostEdgeFinder.cpp: Update port info
-	  for RightmostEdgeFinder (checked)
+	* [r2350] Update port info for RightmostEdgeFinder (checked)
 2009-04-14 09:14  Sandro Santilli <strk at keybit.net>
-	* [r2349] source/headers/geos/operation/buffer/BufferSubgraph.h,
-	  source/operation/buffer/BufferSubgraph.cpp: Sync BufferSubgraph
-	  to JTS-1.9
+	* [r2349] Sync BufferSubgraph to JTS-1.9
 2009-04-14 08:52  Sandro Santilli <strk at keybit.net>
-	* [r2348]
-	  source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
-	  source/operation/buffer/OffsetCurveBuilder.cpp: Port
-	  OffsetCurveBuilder from JTS-1.9. Twenty time faster completion of
-	  fme.xml testcase !
+	* [r2348] Port OffsetCurveBuilder from JTS-1.9. Twenty time faster
+	  completion of fme.xml testcase !
 2009-04-10 20:22  Sandro Santilli <strk at keybit.net>
-	* [r2347] source/operation/buffer/BufferInputLineSimplifier.cpp,
-	  source/operation/buffer/BufferInputLineSimplifier.h,
-	  source/operation/buffer/Makefile.am: Port
-	  BufferInputLineSimplifier from JTS 1.9
+	* [r2347] Port BufferInputLineSimplifier from JTS 1.9
 2009-04-10 15:15  Mateusz Loskot <mateusz at loskot.net>
-	* [r2346] configure.in: Do not generate Makefile for
-	  tests/unit/tut. Fixed bug reported as #247.
+	* [r2346] Do not generate Makefile for tests/unit/tut. Fixed bug
+	  reported as #247.
 2009-04-10 12:08  Sandro Santilli <strk at keybit.net>
-	* [r2345] source/geom/LineSegment.cpp,
-	  source/headers/geos/geom/LineSegment.h,
-	  source/headers/geos/geom/LineSegment.inl: Sync LineSegment with
-	  JTS-1.9
+	* [r2345] Sync LineSegment with JTS-1.9
 2009-04-09 21:46  Mateusz Loskot <mateusz at loskot.net>
-	* [r2344] tests/unit/Makefile.am,
-	  tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp,
-	  tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp,
-	  tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp,
-	  tests/unit/algorithm/ConvexHullTest.cpp,
-	  tests/unit/algorithm/PointLocatorTest.cpp,
-	  tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp,
-	  tests/unit/geom/CoordinateArraySequenceTest.cpp,
-	  tests/unit/geom/CoordinateListTest.cpp,
-	  tests/unit/geom/CoordinateTest.cpp,
-	  tests/unit/geom/DimensionTest.cpp,
-	  tests/unit/geom/EnvelopeTest.cpp,
-	  tests/unit/geom/Geometry/coversTest.cpp,
-	  tests/unit/geom/Geometry/isRectangleTest.cpp,
-	  tests/unit/geom/GeometryFactoryTest.cpp,
-	  tests/unit/geom/IntersectionMatrixTest.cpp,
-	  tests/unit/geom/LineSegmentTest.cpp,
-	  tests/unit/geom/LineStringTest.cpp,
-	  tests/unit/geom/LinearRingTest.cpp,
-	  tests/unit/geom/LocationTest.cpp,
-	  tests/unit/geom/MultiLineStringTest.cpp,
-	  tests/unit/geom/MultiPointTest.cpp,
-	  tests/unit/geom/MultiPolygonTest.cpp,
-	  tests/unit/geom/PointTest.cpp, tests/unit/geom/PolygonTest.cpp,
-	  tests/unit/geom/TriangleTest.cpp,
-	  tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp,
-	  tests/unit/geos_unit.cpp,
-	  tests/unit/index/quadtree/DoubleBitsTest.cpp,
-	  tests/unit/io/ByteOrderValuesTest.cpp,
-	  tests/unit/io/WKBReaderTest.cpp,
-	  tests/unit/noding/BasicSegmentStringTest.cpp,
-	  tests/unit/noding/NodedSegmentStringTest.cpp,
-	  tests/unit/noding/SegmentNodeTest.cpp,
-	  tests/unit/noding/SegmentPointComparatorTest.cpp,
-	  tests/unit/operation/IsSimpleOpTest.cpp,
-	  tests/unit/operation/distance/DistanceOpTest.cpp,
-	  tests/unit/operation/union/CascadedPolygonUnionTest.cpp,
-	  tests/unit/precision/LineStringSnapperTest.cpp,
-	  tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp,
-	  tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp,
-	  tests/unit/simplify/TopologyPreservingSimplifierTest.cpp,
-	  tests/unit/tut/Makefile.am, tests/unit/tut/tut.h,
-	  tests/unit/tut/tut.hpp, tests/unit/tut/tut_assert.hpp,
-	  tests/unit/tut/tut_exception.hpp, tests/unit/tut/tut_posix.hpp,
-	  tests/unit/tut/tut_reporter.h, tests/unit/tut/tut_reporter.hpp,
-	  tests/unit/tut/tut_restartable.h,
-	  tests/unit/tut/tut_restartable.hpp,
-	  tests/unit/tut/tut_result.hpp, tests/unit/tut/tut_runner.hpp,
-	  tests/unit/util/UniqueCoordinateArrayFilterTest.cpp,
-	  tests/unit/utility.h: Updated tests/unit package with latest
-	  relase of C++ TUT Framework from 2008-11-30.
+	* [r2344] Updated tests/unit package with latest relase of C++ TUT
+	  Framework from 2008-11-30.
 2009-04-09 19:39  Mateusz Loskot <mateusz at loskot.net>
-	* [r2343] configure.in, tests/Makefile.am, tests/tut,
-	  tests/unit/Makefile.am, tests/unit/tut,
-	  tests/unit/tut/tut_reporter.h, tests/unit/tut/tut_restartable.h:
-	  Moved tests/tut to tests/unit/tut. Preparing for update to latest
-	  version of C++ TUT Framework.
+	* [r2343] Moved tests/tut to tests/unit/tut. Preparing for update
+	  to latest version of C++ TUT Framework.
 2009-04-09 16:22  Sandro Santilli <strk at keybit.net>
-	* [r2342] source/algorithm/Angle.cpp, source/algorithm/Makefile.am,
-	  source/headers/geos/algorithm/Angle.h,
-	  source/headers/geos/algorithm/Makefile.am: Port algorithm.Angle
-	  from JTS-1.9
+	* [r2342] Port algorithm.Angle from JTS-1.9
 2009-04-09 11:45  Sandro Santilli <strk at keybit.net>
-	* [r2341] source/headers/geos/operation/buffer/BufferBuilder.h,
-	  source/headers/geos/operation/buffer/BufferOp.h,
-	  source/operation/buffer/BufferOp.cpp,
-	  source/operation/buffer/OffsetCurveBuilder.cpp: Sync
-	  BufferBuilder and BufferOp classes to JTS-1.9. Adapt
+	* [r2341] Sync BufferBuilder and BufferOp classes to JTS-1.9. Adapt
 	  OffsetCurveBuilder to use of BufferParameter (needs more work for
 	  JTS-sync).
 2009-04-09 10:21  Sandro Santilli <strk at keybit.net>
-	* [r2340] source/headers/geos/operation/buffer/BufferParameters.h:
-	  typo
+	* [r2340] typo
 2009-04-09 09:45  Sandro Santilli <strk at keybit.net>
-	* [r2339] source/headers/geos/operation/buffer/BufferParameters.h,
-	  source/headers/geos/operation/buffer/Makefile.am,
-	  source/operation/buffer/BufferParameters.cpp,
-	  source/operation/buffer/Makefile.am: Port BufferParameters from
-	  JTS-1.9
+	* [r2339] Port BufferParameters from JTS-1.9
 2009-04-09 08:54  Sandro Santilli <strk at keybit.net>
-	* [r2338] source/operation/buffer/OffsetCurveBuilder.cpp,
-	  source/operation/buffer/OffsetCurveVertexList.h: Sync port of
-	  OffsetCurveVertexList to JTS-1.9, improve memory management
-	  documentation (would need some refactoring/love)
+	* [r2338] Sync port of OffsetCurveVertexList to JTS-1.9, improve
+	  memory management documentation (would need some
+	  refactoring/love)
 2009-04-08 16:52  Sandro Santilli <strk at keybit.net>
-	* [r2337] source/geomgraph/EdgeList.cpp,
-	  source/headers/geos/geomgraph/EdgeList.h,
-	  source/headers/geos/noding/OrientedCoordinateArray.h: Improve
-	  duplicate edge detection performance (JTS-1.9 sync) - fme.xml
-	  runs 3 times as fast now.
+	* [r2337] Improve duplicate edge detection performance (JTS-1.9
+	  sync) - fme.xml runs 3 times as fast now.
 2009-04-08 16:17  Sandro Santilli <strk at keybit.net>
-	* [r2332] source/noding/OrientedCoordinateArray.cpp: const
-	  correctness
+	* [r2332] const correctness
 2009-04-08 15:38  Sandro Santilli <strk at keybit.net>
-	* [r2329] capi/geos_c.h.in: Fix documentation for GEOSPrepare,
-	  GEOSPrepare_r
+	* [r2329] Fix documentation for GEOSPrepare, GEOSPrepare_r
 2009-04-08 14:54  Sandro Santilli <strk at keybit.net>
-	* [r2328] source/headers/geos/noding/Makefile.am,
-	  source/headers/geos/noding/OrientedCoordinateArray.h,
-	  source/noding/Makefile.am,
-	  source/noding/OrientedCoordinateArray.cpp:
-	  OrientedCoordinateArray ported from JTS
+	* [r2328] OrientedCoordinateArray ported from JTS
 2009-04-08 14:41  Sandro Santilli <strk at keybit.net>
-	* [r2327] source/geom/CoordinateSequence.cpp,
-	  source/headers/geos/geom/CoordinateSequence.h: Add
-	  increasingDirection static method, from JTS's CoordinateArray
-	  (GEOS puts all of them in CoordinateSequence for historical
-	  reasons)
+	* [r2327] Add increasingDirection static method, from JTS's
+	  CoordinateArray (GEOS puts all of them in CoordinateSequence for
+	  historical reasons)
 2009-04-08 13:16  Sandro Santilli <strk at keybit.net>
-	* [r2326] source/headers/geos/noding/snapround/SimpleSnapRounder.h,
-	  source/noding/snapround/SimpleSnapRounder.cpp: Complete porting
-	  of SimpleSnapRounder (refactoring for adding snapped nodes)
+	* [r2326] Complete porting of SimpleSnapRounder (refactoring for
+	  adding snapped nodes)
 2009-04-08 13:02  Sandro Santilli <strk at keybit.net>
-	* [r2325] source/headers/geos/noding/SegmentStringUtil.h: Improve
-	  documentation about memory usage for SegmentStringUtil class
+	* [r2325] Improve documentation about memory usage for
+	  SegmentStringUtil class
 2009-04-08 12:58  Sandro Santilli <strk at keybit.net>
-	* [r2324] tests/unit/Makefile.am,
-	  tests/unit/capi/GEOSPreparedGeometryTest.cpp: Stub initial unit
-	  tests for C-API's GEOSPreparedGeometry operations. Helped fixing
-	  issue 147 of postgis
+	* [r2324] Stub initial unit tests for C-API's GEOSPreparedGeometry
+	  operations. Helped fixing issue 147 of postgis
 2009-04-08 12:55  Sandro Santilli <strk at keybit.net>
-	* [r2323] source/geom/prep/PreparedPolygonContainsProperly.cpp:
-	  Don't access deleted memory. Fixes issue 147.
+	* [r2323] Don't access deleted memory. Fixes issue 147.
 2009-04-08 10:53  Sandro Santilli <strk at keybit.net>
-	* [r2322] source/noding/snapround/HotPixel.cpp: Fix typo
+	* [r2322] Fix typo
 2009-04-08 10:06  Sandro Santilli <strk at keybit.net>
-	* [r2321] tests/unit/noding/SegmentNodeTest.cpp: Add a couple more
-	  tests to SegmentNode unit test
+	* [r2321] Add a couple more tests to SegmentNode unit test
 2009-04-08 09:42  Sandro Santilli <strk at keybit.net>
-	* [r2320] source/headers/geos/noding/NodableSegmentString.h,
-	  source/headers/geos/noding/NodedSegmentString.h,
-	  source/headers/geos/noding/SegmentNode.h,
-	  source/headers/geos/noding/SegmentNodeList.h,
-	  source/noding/SegmentNode.cpp, source/noding/SegmentNodeList.cpp,
-	  tests/unit/noding/SegmentPointComparatorTest.cpp: Port
-	  SegmentNode to JTS-1.9
+	* [r2320] Port SegmentNode to JTS-1.9
 2009-04-07 19:00  Sandro Santilli <strk at keybit.net>
-	* [r2319] source/geomgraph/EdgeNodingValidator.cpp,
-	  source/headers/geos/geomgraph/EdgeNodingValidator.h,
-	  source/headers/geos/noding/BasicSegmentString.h,
-	  source/headers/geos/noding/IntersectionAdder.h,
-	  source/headers/geos/noding/IntersectionFinderAdder.h,
-	  source/headers/geos/noding/IteratedNoder.h,
-	  source/headers/geos/noding/MCIndexNoder.h,
-	  source/headers/geos/noding/MCIndexNoder.inl,
-	  source/headers/geos/noding/Makefile.am,
-	  source/headers/geos/noding/NodableSegmentString.h,
-	  source/headers/geos/noding/SegmentString.h,
-	  source/headers/geos/noding/SegmentString.inl,
-	  source/headers/geos/noding/SimpleNoder.h,
-	  source/headers/geos/noding/snapround/MCIndexPointSnapper.h,
-	  source/headers/geos/noding/snapround/MCIndexSnapRounder.h,
-	  source/headers/geos/noding/snapround/MCIndexSnapRounder.inl,
-	  source/headers/geos/noding/snapround/SimpleSnapRounder.h,
-	  source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h,
-	  source/noding/BasicSegmentString.cpp,
-	  source/noding/IntersectionAdder.cpp,
-	  source/noding/IntersectionFinderAdder.cpp,
-	  source/noding/IteratedNoder.cpp, source/noding/MCIndexNoder.cpp,
-	  source/noding/Makefile.am, source/noding/NodedSegmentString.cpp,
-	  source/noding/ScaledNoder.cpp, source/noding/SegmentNodeList.cpp,
-	  source/noding/SegmentString.cpp, source/noding/SimpleNoder.cpp,
-	  source/noding/snapround/MCIndexPointSnapper.cpp,
-	  source/noding/snapround/MCIndexSnapRounder.cpp,
-	  source/noding/snapround/SimpleSnapRounder.cpp,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp,
-	  tests/unit/noding/SegmentStringTest.cpp: Refactor SegmentString
-	  to be an abstract class, to be in sync with JTS-1.9.
+	* [r2319] Refactor SegmentString to be an abstract class, to be in
+	  sync with JTS-1.9.
 2009-04-07 12:36  Sandro Santilli <strk at keybit.net>
-	* [r2318] source/operation/valid/IndexedNestedRingTester.cpp,
-	  source/operation/valid/IndexedNestedRingTester.h: update
-	  copyright notice
+	* [r2318] update copyright notice
 2009-04-07 11:11  Sandro Santilli <strk at keybit.net>
-	* [r2317] source/headers/geos/noding/snapround/HotPixel.h,
-	  source/headers/geos/noding/snapround/HotPixel.inl,
-	  source/noding/snapround/HotPixel.cpp: Sync HotPixel to JTS-1.9
-	  (rev 1.3); fix a few bugs and use standard algorithms for min/max
+	* [r2317] Sync HotPixel to JTS-1.9 (rev 1.3); fix a few bugs and
+	  use standard algorithms for min/max
 2009-04-07 10:48  Sandro Santilli <strk at keybit.net>
-	* [r2316] source/headers/geos/noding/NodedSegmentString.h: Fix
-	  signed vs. unsigned compiler warning
+	* [r2316] Fix signed vs. unsigned compiler warning
 2009-04-07 10:18  Sandro Santilli <strk at keybit.net>
-	* [r2315] source/headers/geos/operation/valid/IsValidOp.h: Port
-	  info, indenting
+	* [r2315] Port info, indenting
 2009-04-07 09:56  Sandro Santilli <strk at keybit.net>
-	* [r2314] source/operation/valid/IndexedNestedRingTester.cpp,
-	  source/operation/valid/IndexedNestedRingTester.h,
-	  source/operation/valid/IsValidOp.cpp,
-	  source/operation/valid/Makefile.am: Port IndexedNestedRingTester
-	  and have IsValidOp use it, syncing the operation to JTS-1.9
+	* [r2314] Port IndexedNestedRingTester and have IsValidOp use it,
+	  syncing the operation to JTS-1.9
 2009-04-07 09:55  Sandro Santilli <strk at keybit.net>
-	* [r2313] source/headers/geos/noding/SegmentStringUtil.h: Update
-	  port info, minor tweaks to doxygen comments
+	* [r2313] Update port info, minor tweaks to doxygen comments
 2009-04-07 08:14  Sandro Santilli <strk at keybit.net>
-	* [r2312] source/algorithm/HCoordinate.cpp,
-	  source/headers/geos/algorithm/HCoordinate.h: Sync HCoordinate
-	  class to JTS-1.9 (rev 1.18)
+	* [r2312] Sync HCoordinate class to JTS-1.9 (rev 1.18)
 2009-04-03 15:27  Mateusz Loskot <mateusz at loskot.net>
-	* [r2311] nmake.opt: Added _NMAKE_VER 9.00.21022.08 to nmake.opt.
-	  Fixed bug with using BUILD_DEBUG instead of BUILD_BATCH in
-	  nmake.opt.
+	* [r2311] Added _NMAKE_VER 9.00.21022.08 to nmake.opt. Fixed bug
+	  with using BUILD_DEBUG instead of BUILD_BATCH in nmake.opt.
 2009-03-27 02:39  Mateusz Loskot <mateusz at loskot.net>
-	* [r2310] build/msvc80/geos.sln,
-	  build/msvc80/geos_lib/geos_lib.vcproj: Updated build/msvc80.
+	* [r2310] Updated build/msvc80.
 2009-03-27 02:38  Mateusz Loskot <mateusz at loskot.net>
-	* [r2309] nmake.opt, source/Makefile.vc: Forgotten nmake.opt in
-	  last commit.
+	* [r2309] Forgotten nmake.opt in last commit.
 2009-03-26 21:52  Mateusz Loskot <mateusz at loskot.net>
-	* [r2308] build/msvc90/geos.sln,
-	  build/msvc90/geos_lib/geos_lib.vcproj, makefile.vc,
-	  source/Makefile.vc, source/dirlist.mk: Refactored NMAKE
-	  makefiles. Added nmake.opt file - GDAL style. Added some
-	  auto-magic to determine version of Visual C++ compiler and set
-	  version specific compilation flags. No need to specify Visual C++
-	  version in cmd line, but just run: nmake -f makefile.vc in root
-	  dir of the tree.
+	* [r2308] Refactored NMAKE makefiles. Added nmake.opt file - GDAL
+	  style. Added some auto-magic to determine version of Visual C++
+	  compiler and set version specific compilation flags. No need to
+	  specify Visual C++ version in cmd line, but just run: nmake -f
+	  makefile.vc in root dir of the tree.
 2009-03-26 21:07  Mateusz Loskot <mateusz at loskot.net>
-	* [r2307] source/operation/union/CascadedPolygonUnion.cpp:
-	  CascadedPolygonUnion.cpp: added missing std headers.
+	* [r2307] CascadedPolygonUnion.cpp: added missing std headers.
 2009-03-26 01:53  Mateusz Loskot <mateusz at loskot.net>
-	* [r2306] TODO: Dummy commit - testing buildbot resurection.
+	* [r2306] Dummy commit - testing buildbot resurection.
 2009-03-24 16:49  Mateusz Loskot <mateusz at loskot.net>
-	* [r2304] capi/geos_ts_c.cpp: Fixed bug introduced in recent
-	  refactoring work (r2281). This is the reason of PostGIS
-	  regression test failing (Issue 143)
+	* [r2304] Fixed bug introduced in recent refactoring work (r2281).
+	  This is the reason of PostGIS regression test failing (Issue 143)
 2009-03-24 15:58  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2303] autogen.sh: Allow version test to work in glibtoolize
+	* [r2303] Allow version test to work in glibtoolize
 2009-03-24 00:48  Mateusz Loskot <mateusz at loskot.net>
-	* [r2302] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
-	  capi/geos_ts_c.cpp: refactoring, assert() to test against nullptr
-	  where it is forbidden.
+	* [r2302] capi/geos_ts_c.cpp: refactoring, assert() to test against
+	  nullptr where it is forbidden.
 2009-03-24 00:30  Mateusz Loskot <mateusz at loskot.net>
-	* [r2301] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
-	  REVERTED r2299: Fixed GEOSSetSRID_r missing, GEOSSetSRID
+	* [r2301] REVERTED r2299: Fixed GEOSSetSRID_r missing, GEOSSetSRID
 	  duplicated (Ticket #242). A little of refactoring.
 2009-03-24 00:19  Mateusz Loskot <mateusz at loskot.net>
-	* [r2300] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
-	  Fixed GEOSSetSRID_r missing, GEOSSetSRID duplicated (Ticket
-	  #242). A little of refactoring.
+	* [r2300] Fixed GEOSSetSRID_r missing, GEOSSetSRID duplicated
+	  (Ticket #242). A little of refactoring.
 2009-03-23 23:50  Mateusz Loskot <mateusz at loskot.net>
-	* [r2299] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring, use
-	  single return expression per function, added assert() to test
-	  against nullptr where it is forbidden.
+	* [r2299] capi/geos_ts_c.cpp: refactoring, use single return
+	  expression per function, added assert() to test against nullptr
+	  where it is forbidden.
 2009-03-23 23:29  Mateusz Loskot <mateusz at loskot.net>
-	* [r2298] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring, use
-	  against nullptr where it is forbidden, addd some comments.
+	* [r2298] capi/geos_ts_c.cpp: refactoring, use single return
+	  where it is forbidden, addd some comments.
 2009-03-23 22:19  Mateusz Loskot <mateusz at loskot.net>
-	* [r2297] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring, use
+	* [r2297] capi/geos_ts_c.cpp: refactoring, use single return
 2009-03-23 21:07  Mateusz Loskot <mateusz at loskot.net>
-	* [r2296] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring,
-	  replace manual strdup with gstrdup, use single return expression
-	  per function, added some comments.
+	* [r2296] capi/geos_ts_c.cpp: refactoring, replace manual strdup
+	  with gstrdup, use single return expression per function, added
+	  some comments.
 2009-03-23 20:31  Mateusz Loskot <mateusz at loskot.net>
-	* [r2295] autogen.sh: dummy commit
+	* [r2295] dummy commit
 2009-03-23 20:03  Mateusz Loskot <mateusz at loskot.net>
-	* [r2294] autogen.sh: autogen.sh: Fixed typo in tab character.
+	* [r2294] autogen.sh: Fixed typo in tab character.
 2009-03-23 17:08  Mateusz Loskot <mateusz at loskot.net>
-	* [r2293] autogen.sh: autogen.sh: be more verbose about versions,
-	  check for autoconf, check if ./configure is really generated.
+	* [r2293] autogen.sh: be more verbose about versions, check for
+	  autoconf, check if ./configure is really generated.
 2009-03-23 16:28  Mateusz Loskot <mateusz at loskot.net>
-	* [r2292] configure.in: configure.in: mloskot made a stupid
-	  mistake, mloskot has fixed it.
+	* [r2292] configure.in: mloskot made a stupid mistake, mloskot has
+	  fixed it.
 2009-03-23 14:38  Mateusz Loskot <mateusz at loskot.net>
-	* [r2291] configure.in: configure.in: wrap macro arguments with
-	  proper M4 quote characters.
+	* [r2291] configure.in: wrap macro arguments with proper M4 quote
+	  characters.
 2009-03-23 14:08  Mateusz Loskot <mateusz at loskot.net>
-	* [r2290] autogen.sh: autogen.sh: Call libtool *before* aclocal and
-	  automake (see Automake manual,8.3.9.1).
+	* [r2290] autogen.sh: Call libtool *before* aclocal and automake
+	  (see Automake manual,8.3.9.1).
 2009-03-23 14:01  Mateusz Loskot <mateusz at loskot.net>
-	* [r2289] autogen.sh: autogen.sh: verbose check if autotools
-	  versions.
+	* [r2289] autogen.sh: verbose check if autotools versions.
 2009-03-22 20:29  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2288] autogen.sh: Show what versions of things we're running
+	* [r2288] Show what versions of things we're running
 2009-03-21 02:17  Mateusz Loskot <mateusz at loskot.net>
-	* [r2287] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring -
-	  removed redundant return expressions, replaced bloated use of
-	  malloc + memcpy with single call to gstrdup, use of C++ cast
-	  operators, removed unnecessary allocation of std::string objects.
+	* [r2287] capi/geos_ts_c.cpp: refactoring - removed redundant
+	  return expressions, replaced bloated use of malloc + memcpy with
+	  single call to gstrdup, use of C++ cast operators, removed
+	  unnecessary allocation of std::string objects.
 2009-03-21 01:37  Mateusz Loskot <mateusz at loskot.net>
-	* [r2286] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: added gstrdup and
-	  gstrdup_s helper functions to get rid of bloated code in future.
-	  Started eliminating redundant return expressions.
+	* [r2286] capi/geos_ts_c.cpp: added gstrdup and gstrdup_s helper
+	  functions to get rid of bloated code in future. Started
+	  eliminating redundant return expressions.
 2009-03-21 01:10  Mateusz Loskot <mateusz at loskot.net>
-	* [r2285] macros: macros: Updated svn:ignore property.
+	* [r2285] macros: Updated svn:ignore property.
 2009-03-21 01:08  Mateusz Loskot <mateusz at loskot.net>
-	* [r2284] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: Use of spaces
-	  instead of tabs applied.
+	* [r2284] capi/geos_ts_c.cpp: Use of spaces instead of tabs
+	  applied.
 2009-03-21 01:05  Mateusz Loskot <mateusz at loskot.net>
-	* [r2283] source/operation/polygonize/EdgeRing.cpp:
-	  source/operation/polygonize/edgering.cpp: cleaned compiler
-	  warnings about mixed integral types.
+	* [r2283] source/operation/polygonize/edgering.cpp: cleaned
+	  compiler warnings about mixed integral types.
 2009-03-21 01:01  Mateusz Loskot <mateusz at loskot.net>
-	* [r2282] capi/geos_ts_c.cpp: Fixed deprecated conversion from
-	  string constant to char* in GEOSisValidReason_r. Small
-	  refactoring.
+	* [r2282] Fixed deprecated conversion from string constant to char*
+	  in GEOSisValidReason_r. Small refactoring.
 2009-03-21 00:47  Mateusz Loskot <mateusz at loskot.net>
-	* [r2281] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring, use
-	  c++ cast operators.
+	* [r2281] capi/geos_ts_c.cpp: refactoring, use c++ cast operators.
 2009-03-20 23:37  Mateusz Loskot <mateusz at loskot.net>
-	* [r2280] source/operation/union: Updated svn:ignore property.
+	* [r2280] Updated svn:ignore property.
 2009-03-20 23:35  Mateusz Loskot <mateusz at loskot.net>
-	* [r2279] build/msvc80/geos_unit/geos_unit.vcproj: Updated
-	  build/msvc80 project.
+	* [r2279] Updated build/msvc80 project.
 2009-03-19 16:45  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2278] autogen.sh: Fix spellingn mistake.
+	* [r2278] Fix spellingn mistake.
 2009-03-19 16:19  Mateusz Loskot <mateusz at loskot.net>
-	* [r2277] build/msvc90/geos_unit/geos_unit.vcproj,
-	  tests/unit/capi/GEOSGeomFromWKBTest.cpp, tests/unit/utility.h: *
-	  tests/unit/capi: added GEOSGeomFromWKBTest with test cases (see
-	  comment) reported as a bug (See
+	* [r2277] * tests/unit/capi: added GEOSGeomFromWKBTest with test
+	  cases (see comment) reported as a bug (See
 	  http://postgis.refractions.net/pipermail/postgis-devel/2009-March/005199.html).
 	  TODO: Reproduce and ask the reporter to submit a ticket if
 	  necessary.
@@ -4074,9 +2436,7 @@
 2009-03-11 12:51  Mateusz Loskot <mateusz at loskot.net>
-	* [r2276] source/operation/distance/DistanceOp.cpp,
-	  tests/unit/operation/distance/DistanceOpTest.cpp: BUG in
-	  DistanceOp:
+	* [r2276] BUG in DistanceOp:
 	  * Test case and explanation of existing bug in
 	  DistanceOp::closestPoints() recently reported by Aya (Ticket
 	  #236).
@@ -4090,837 +2450,565 @@
 2009-03-11 12:18  Mateusz Loskot <mateusz at loskot.net>
-	* [r2275] source/geom/CoordinateArraySequence.cpp: Number of
-	  assertions in CoordinateArraySequence class.
+	* [r2275] Number of assertions in CoordinateArraySequence class.
 2009-03-10 17:29  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2274] build/msvc90/geos_c_dll, build/msvc90/geos_lib,
-	  build/msvc90/geos_python, build/msvc90/geos_ruby,
-	  build/msvc90/geos_unit: svn:ignore
+	* [r2274] svn:ignore
 2009-03-10 17:28  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2273] build/msvc90, build/msvc90/geos_c_dll,
-	  build/msvc90/geos_lib, build/msvc90/geos_python,
-	  build/msvc90/geos_ruby, build/msvc90/geos_unit: svn:ignore
+	* [r2273] svn:ignore
 2009-03-10 17:18  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2272] NEWS: Update NEWS for 3.1.0
+	* [r2272] Update NEWS for 3.1.0
 2009-03-10 16:23  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2271] ChangeLog: Update ChangeLog for 3.1.0 release
+	* [r2271] Update ChangeLog for 3.1.0 release
 2009-02-07 23:29  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2269] source/headers/geos/precision/Makefile.am: Include
-	  GeometrySnapper.h in distribution package.
+	* [r2269] Include GeometrySnapper.h in distribution package.
 2009-02-02 22:58  Sean Gillies <sgillies at frii.com>
-	* [r2268] swig/python/README.txt: Note lack of Python support since
-	  3.0
+	* [r2268] Note lack of Python support since 3.0
 2009-02-02 22:53  Sean Gillies <sgillies at frii.com>
-	* [r2267] README: Notes on state of scripting language bindings
+	* [r2267] Notes on state of scripting language bindings
 2009-01-30 20:01  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2266] configure.in: Add new msvc targets to build
+	* [r2266] Add new msvc targets to build
 2009-01-29 19:22  Mateusz Loskot <mateusz at loskot.net>
-	* [r2265] build/Makefile.am, build/msvc90,
-	  build/msvc90/Makefile.am, build/msvc90/README,
-	  build/msvc90/geos.sln, build/msvc90/geos.vsprops,
-	  build/msvc90/geos_c_dll, build/msvc90/geos_c_dll/Makefile.am,
-	  build/msvc90/geos_c_dll/geos_c_dll.vcproj, build/msvc90/geos_lib,
-	  build/msvc90/geos_lib/Makefile.am,
-	  build/msvc90/geos_lib/geos_lib.vcproj, build/msvc90/geos_python,
-	  build/msvc90/geos_python/Makefile.am,
-	  build/msvc90/geos_python/geos_python.vcproj,
-	  build/msvc90/geos_ruby, build/msvc90/geos_ruby/Makefile.am,
-	  build/msvc90/geos_ruby/geos_ruby.vcproj, build/msvc90/geos_unit,
-	  build/msvc90/geos_unit/Makefile.am,
-	  build/msvc90/geos_unit/geos_unit.vcproj: Added build/msvc90 with
-	  solution and project files for Microsoft Visual C++ 2009 (9.0).
-	  Successfully built and tested GEOS with Visual C++ 9.0.
+	* [r2265] Added build/msvc90 with solution and project files for
+	  Microsoft Visual C++ 2009 (9.0). Successfully built and tested
+	  GEOS with Visual C++ 9.0.
 2009-01-29 19:02  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2264] README: update autogen.bat ref
+	* [r2264] update autogen.bat ref
 2009-01-29 18:56  Mateusz Loskot <mateusz at loskot.net>
-	* [r2263] source/headers/geos/algorithm/RayCrossingCounter.h,
-	  source/headers/geos/algorithm/locate/IndexedPointInAreaLocator.h,
-	  source/headers/geos/algorithm/locate/PointOnGeometryLocator.h,
-	  source/headers/geos/geom/util/ComponentCoordinateExtracter.h,
-	  source/headers/geos/index/intervalrtree/IntervalRTreeBranchNode.h,
-	  source/headers/geos/index/intervalrtree/IntervalRTreeLeafNode.h,
-	  source/headers/geos/index/intervalrtree/IntervalRTreeNode.h,
-	  source/headers/geos/index/intervalrtree/SortedPackedIntervalRTree.h,
-	  source/headers/geos/noding/FastSegmentSetIntersectionFinder.h,
-	  source/headers/geos/noding/SegmentIntersectionDetector.h,
-	  source/headers/geos/noding/SegmentStringUtil.h: Fixed broken
-	  svn:keyword Id
+	* [r2263] Fixed broken svn:keyword Id
 2009-01-29 18:51  Mateusz Loskot <mateusz at loskot.net>
-	* [r2262] autogen.bat, bootstrap.bat: Renamed bootstrap.bat to
-	  autogen.bat for easier guass of the script purpose. Wiki updated.
+	* [r2262] Renamed bootstrap.bat to autogen.bat for easier guass of
+	  the script purpose. Wiki updated.
 2009-01-28 01:06  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2261] README: Add to win32 instructions
+	* [r2261] Add to win32 instructions
 2009-01-27 18:10  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2260] source/headers/geos/geom/util/Makefile.am: Add
-	  GeometryCombiner.h to include dist
+	* [r2260] Add GeometryCombiner.h to include dist
 2009-01-27 00:18  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2259] build/msvc80/geos_c_dll/geos_c_dll.vcproj: Revert some
-	  junk from an old commit, per issue #220
+	* [r2259] Revert some junk from an old commit, per issue #220
 2009-01-26 20:44  Frank Warmerdam <warmerdam at pobox.com>
-	* [r2258] source/Makefile.vc: added two new files related to
-	  cascaded polygon union (#226)
+	* [r2258] added two new files related to cascaded polygon union
+	  (#226)
 2009-01-24 05:03  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2257] HOWTO_RELEASE: Update
+	* [r2257] Update
 2009-01-24 05:02  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2256] ChangeLog: Update changelog
+	* [r2256] Update changelog
 2009-01-24 01:33  Mateusz Loskot <mateusz at loskot.net>
-	* [r2255] capi/geos_ts_c.cpp: Fixed mixed signed/unsigned integral
-	  types in geos_ts_c.cpp, so no compilers should flood with
-	  warnings now.
+	* [r2255] Fixed mixed signed/unsigned integral types in
+	  geos_ts_c.cpp, so no compilers should flood with warnings now.
 2009-01-24 01:30  Mateusz Loskot <mateusz at loskot.net>
-	* [r2254] build/msvc80/geos_c_dll/geos_c_dll.vcproj,
-	  build/msvc80/geos_lib/geos_lib.vcproj,
-	  build/msvc80/geos_unit/geos_unit.vcproj: Updated projects for
-	  Visual Studio 2005 adding new .h/.cpp files.
+	* [r2254] Updated projects for Visual Studio 2005 adding new
+	  .h/.cpp files.
 2009-01-23 23:58  Mateusz Loskot <mateusz at loskot.net>
-	* [r2253] capi/geos_ts_c.cpp,
-	  source/geom/util/GeometryCombiner.cpp,
-	  source/headers/geos/geom/util/GeometryCombiner.h,
-	  source/headers/geos/io/CLocalizer.h,
-	  source/headers/geos/operation/union/CascadedPolygonUnion.h,
-	  source/io/CLocalizer.cpp,
-	  source/operation/union/CascadedPolygonUnion.cpp,
-	  tests/unit/capi/badthreadtest.c, tests/unit/capi/threadtest.c,
-	  tests/unit/operation/union/CascadedPolygonUnionTest.cpp: Updated
-	  svn:keywords property on C/C++ files.
+	* [r2253] Updated svn:keywords property on C/C++ files.
 2009-01-21 22:18  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2252] source/geom/Geometry.cpp: Remove geometryCollection
-	  protection from Union/Relate/Intersection/Difference.
+	* [r2252] Remove geometryCollection protection from
+	  Union/Relate/Intersection/Difference.
 2009-01-20 01:01  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2251] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
-	  source/operation/union/CascadedPolygonUnion.cpp: Add
-	  GEOSUnionCascaded(*GEOSGeometry) to CAPI in preparation for
-	  PostGIS hook-up.
+	* [r2251] Add GEOSUnionCascaded(*GEOSGeometry) to CAPI in
+	  preparation for PostGIS hook-up.
 2009-01-19 23:55  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2250] capi/geos_c.cpp, capi/geos_ts_c.cpp: Formatting changes
-	  to function decls.
+	* [r2250] Formatting changes to function decls.
 2009-01-19 20:41  Howard Butler <hobu.inc at gmail.com>
-	* [r2249] source/Makefile.vc: fixes to allow building in msvc 2003
+	* [r2249] fixes to allow building in msvc 2003
 2009-01-19 20:00  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2248] configure.in: Make warning flags conditional behind a
-	  compiler test... fix to bug #192 ?
+	* [r2248] Make warning flags conditional behind a compiler test...
+	  fix to bug #192 ?
 2009-01-19 16:44  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2247]
-	  source/operation/union/CascadedPolygonUnion.cpp: Added patch from
-	  hkaiser to allow cascadedunion to be run directly on a
-	  multipolygon.
+	* [r2247] Added patch from hkaiser to allow cascadedunion to be run
+	  directly on a multipolygon.
 2009-01-19 00:12  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2246] autogen.sh: Fix error left behind from testing.
+	* [r2246] Fix error left behind from testing.
 2009-01-18 23:28  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2245] autogen.sh: Add some more info on missing tools.
+	* [r2245] Add some more info on missing tools.
 2009-01-18 23:07  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2244] HOWTO_RELEASE, Makefile.am, build, build/Makefile.am,
-	  build/msvc80, build/msvc80/Makefile.am, build/msvc80/geos_c_dll,
-	  build/msvc80/geos_c_dll/Makefile.am, build/msvc80/geos_lib,
-	  build/msvc80/geos_lib/Makefile.am, build/msvc80/geos_python,
-	  build/msvc80/geos_python/Makefile.am, build/msvc80/geos_ruby,
-	  build/msvc80/geos_ruby/Makefile.am, build/msvc80/geos_unit,
-	  build/msvc80/geos_unit/Makefile.am, configure.in,
-	  source/Makefile.vc, source/headers/geos/Makefile.am: Add msvc
-	  files to distribution target, and update release notes to include
-	  updating
+	* [r2244] Add msvc files to distribution target, and update release
+	  notes to include updating
 	  version in .vc headers.
 2009-01-18 22:35  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2243] configure.in: Add a couple extra program checks.
+	* [r2243] Add a couple extra program checks.
 2009-01-18 21:30  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2241] autogen.sh: Add version test for aclocal and automake to
-	  allow OpenSolaris to work.
+	* [r2241] Add version test for aclocal and automake to allow
+	  OpenSolaris to work.
 2009-01-18 20:34  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2240] configure.in, source/geom/Envelope.cpp,
-	  source/geom/util/Makefile.am,
-	  source/headers/geos/geom/Envelope.h,
-	  source/headers/geos/index/strtree/AbstractSTRtree.h,
-	  source/headers/geos/operation/Makefile.am,
-	  source/headers/geos/operation/union,
-	  source/headers/geos/operation/union/Makefile.am,
-	  source/index/strtree/AbstractSTRtree.cpp,
-	  source/operation/Makefile.am, source/operation/union,
-	  source/operation/union/Makefile.am, tests/unit,
-	  tests/unit/Makefile.am, tests/unit/operation/union,
-	  tests/unit/operation/union/CascadedPolygonUnionTest.cpp: Apply
-	  cascaded union patch, for issue #225
+	* [r2240] Apply cascaded union patch, for issue #225
 2009-01-15 01:00  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2239] tests/xmltester/Makefile.am: Remove XMLTester from list
-	  of installed programs.
+	* [r2239] Remove XMLTester from list of installed programs.
 2009-01-14 20:25  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2238] capi/geos_ts_c.cpp: Remove strdup use from code for
-	  compilation in mingw
+	* [r2238] Remove strdup use from code for compilation in mingw
 2009-01-13 20:59  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2237] configure.in: Add [macros] include to configure.in
-	  directly. Seems to make more recent aclocals happy
+	* [r2237] Add [macros] include to configure.in directly. Seems to
+	  make more recent aclocals happy
 2009-01-13 20:43  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2236] configure.in: Change AC_SUBST to one-per-line instead of
+	* [r2236] Change AC_SUBST to one-per-line instead of
 	  one-line-for-all. Seems to make more recent autoconf's happier.
 2009-01-13 19:23  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2235] capi/geos_ts_c.cpp: Change return values for
-	  GEOSWKBWriter_getIncludeSRID_r to match function signature.
+	* [r2235] Change return values for GEOSWKBWriter_getIncludeSRID_r
+	  to match function signature.
 2009-01-13 17:04  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2234] tests/unit/capi/badthreadtest.c,
-	  tests/unit/capi/brokengrammar, tests/unit/capi/threadtest.c: More
-	  files missing from commit.
+	* [r2234] More files missing from commit.
 2009-01-13 15:47  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2233] capi/geos_ts_c.cpp: Add missing file to SVN.
+	* [r2233] Add missing file to SVN.
 2009-01-13 01:21  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2232] capi/Makefile.am, capi/geos_c.cpp, capi/geos_c.h.in,
-	  capi/geostest.c, capi/test.expected, capi/test.wkt,
-	  capi/testrunner.sh, tests/unit/Makefile.am,
-	  tests/unit/capi/geostest.c, tests/unit/capi/test.expected,
-	  tests/unit/capi/test.wkt, tests/unit/capi/testrunner.sh: Apply
-	  patch for issue #210 (thread safe c-api) submitted by Chuck
-	  Thibert.
+	* [r2232] Apply patch for issue #210 (thread safe c-api) submitted
+	  by Chuck Thibert.
 2009-01-05 23:42  Stephen Wong <swongu at gmail.com>
-	* [r2231] source/operation/buffer/BufferBuilder.cpp,
-	  source/operation/buffer/OffsetCurveVertexList.h,
-	  source/operation/linemerge/LineMerger.cpp: Fixed memory leak in
-	  BufferBuilder (#218); added read-only coordinates function in
-	  OffsetCurveVertexList; explicity pass ownership in LineMerger.
+	* [r2231] Fixed memory leak in BufferBuilder (#218); added
+	  read-only coordinates function in OffsetCurveVertexList;
+	  explicity pass ownership in LineMerger.
 2008-11-26 19:41  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2229] source/headers/geos/noding/Octant.h,
-	  tests/unit/noding/SegmentStringTest.cpp: Octant.h error (#185)
-	  from Denise Macleod.
+	* [r2229] Octant.h error (#185) from Denise Macleod.
 2008-11-26 19:27  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2228] source/io/WKBWriter.cpp: Allow proper writing out of z
-	  ordinates. From Justin Bronn (#216)
+	* [r2228] Allow proper writing out of z ordinates. From Justin
+	  Bronn (#216)
 2008-11-26 19:25  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2227] source/io/WKBReader.cpp: Allow readpoint to look at input
-	  dimension and fill higher ordinates. (#217)
+	* [r2227] Allow readpoint to look at input dimension and fill
+	  higher ordinates. (#217)
 2008-11-26 19:06  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2226] capi/geos_c.cpp, capi/geos_c.h.in: Expose
-	  GEOSIsValidReason to CAPI
+	* [r2226] Expose GEOSIsValidReason to CAPI
 2008-11-18 03:09  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2221] source/inlines.cpp: Cygwin build fix from MCA
+	* [r2221] Cygwin build fix from MCA
 2008-11-11 17:32  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2220] source/geomgraph/EdgeList.cpp,
-	  source/operation/overlay/OverlayOp.cpp: Memory leak on invalid
-	  polygons in intersection(). (#170) from Denise MacLeod.
+	* [r2220] Memory leak on invalid polygons in intersection(). (#170)
+	  from Denise MacLeod.
 2008-11-05 20:52  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2218] source/geom/prep/PreparedLineStringIntersects.cpp:
-	  Another minor memory leak removed.
+	* [r2218] Another minor memory leak removed.
 2008-10-28 15:47  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2217] source/inlines.cpp: Cygwin/Mingw patch from Mark
-	  Cave-Ayland
+	* [r2217] Cygwin/Mingw patch from Mark Cave-Ayland
 2008-10-23 17:33  Frank Warmerdam <warmerdam at pobox.com>
-	* [r2210] source/operation/valid/IsValidOp.cpp: set isChecked flag
-	  after checking to fix memory leak (#169)
+	* [r2210] set isChecked flag after checking to fix memory leak
+	  (#169)
 2008-10-16 00:40  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2203] HOWTO_RELEASE: change info to point to osgeo.org
+	* [r2203] change info to point to osgeo.org
 2008-10-14 15:01  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2200] capi/geos_c.cpp, capi/geos_c.h.in: Consistent const
-	  declarations in c-api ($#209)
+	* [r2200] Consistent const declarations in c-api ($#209)
 2008-10-13 22:40  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2199] source/headers/geos/io/Makefile.am: Add CLocalizer.h to
-	  build so it gets packaged in make dist
+	* [r2199] Add CLocalizer.h to build so it gets packaged in make
+	  dist
 2008-10-10 17:46  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2198] source/geom/prep/PreparedPolygonContainsProperly.cpp: One
-	  last memory leak fix.
+	* [r2198] One last memory leak fix.
 2008-10-09 16:39  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2197] source/geom/prep/PreparedPolygonIntersects.cpp: Memory
-	  leak fix for for prepared intersects. (#207)
+	* [r2197] Memory leak fix for for prepared intersects. (#207)
 2008-10-04 18:14  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2196]
-	  source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h,
-	  source/noding/MCIndexSegmentSetMutualIntersector.cpp: Memory leak
-	  fix for prepared geometry, from Hartmut Kaiser. (#207)
+	* [r2196] Memory leak fix for prepared geometry, from Hartmut
+	  Kaiser. (#207)
 2008-09-29 19:24  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2195] capi/geos_c.cpp: Put function sig on one line
+	* [r2195] Put function sig on one line
 2008-09-23 23:01  Mateusz Loskot <mateusz at loskot.net>
-	* [r2194] source/geom/prep/AbstractPreparedPolygonContains.cpp,
-	  source/geom/prep/PreparedPolygon.cpp,
-	  source/geom/prep/PreparedPolygonContains.cpp,
-	  source/geom/prep/PreparedPolygonPredicate.cpp,
-	  source/headers/geos/geom/prep/PreparedPolygonContains.h,
-	  source/headers/geos/index/SpatialIndex.h,
-	  source/headers/geos/index/chain/MonotoneChain.h,
-	  source/headers/geos/index/strtree/ItemBoundable.h,
-	  source/headers/geos/noding/SegmentSetMutualIntersector.h,
-	  source/index/chain/MonotoneChain.cpp,
-	  source/index/chain/MonotoneChainBuilder.cpp,
-	  source/index/strtree/ItemBoundable.cpp: Moved some ctor/dctor
-	  bodies from headers to translation units. Improved source code
-	  readability. TODO: We need to run a beast like AStyle on all GEOS
-	  code because many places are very hard to read.
+	* [r2194] Moved some ctor/dctor bodies from headers to translation
+	  units. Improved source code readability. TODO: We need to run a
+	  beast like AStyle on all GEOS code because many places are very
+	  hard to read.
 2008-09-23 22:55  Mateusz Loskot <mateusz at loskot.net>
-	* [r2193] source/noding/MCIndexSegmentSetMutualIntersector.cpp:
-	  MCIndexSegmentSetMutualIntersector::addToIndex: Completed BWJ's
-	  comment on memory leaks with important observations about objects
-	  relation & lifetime. The note is a diagnosis of roots of the
-	  problem. Improved source code readability.
+	* [r2193] MCIndexSegmentSetMutualIntersector::addToIndex: Completed
+	  BWJ's comment on memory leaks with important observations about
+	  objects relation & lifetime. The note is a diagnosis of roots of
+	  the problem. Improved source code readability.
 2008-09-22 21:48  Mateusz Loskot <mateusz at loskot.net>
-	* [r2192] source/headers/geos/io/WKBWriter.h: Use conditional
-	  operators instead of cast bool to int.
+	* [r2192] Use conditional operators instead of cast bool to int.
 2008-09-22 20:16  Mateusz Loskot <mateusz at loskot.net>
-	* [r2191] source/simplify/TopologyPreservingSimplifier.cpp: Removed
-	  unnecessary std::endl from debug messages in
+	* [r2191] Removed unnecessary std::endl from debug messages in
 	  TopologyPreservingSimplifier.cpp.
 2008-09-21 21:32  Mateusz Loskot <mateusz at loskot.net>
-	* [r2190] source/Makefile.vc: Patched NMAKE makefiles: replaced
-	  lib.exe with link.exe /lib command to enabled compilation using
-	  Microsoft Visual C++ Toolkit 2003
+	* [r2190] Patched NMAKE makefiles: replaced lib.exe with link.exe
+	  /lib command to enabled compilation using Microsoft Visual C++
+	  Toolkit 2003
 2008-09-16 21:09  Mateusz Loskot <mateusz at loskot.net>
-	* [r2189] source/operation/predicate/SegmentIntersectionTester.cpp,
-	  source/util/math.cpp: Patch fixing build problems on Solaris
-	  (Ticket #205).
+	* [r2189] Patch fixing build problems on Solaris (Ticket #205).
 2008-09-16 21:01  Mateusz Loskot <mateusz at loskot.net>
-	* [r2188] tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp:
-	  Fixed EOL to LF.
+	* [r2188] Fixed EOL to LF.
 2008-09-16 20:58  Mateusz Loskot <mateusz at loskot.net>
-	* [r2187] source/geom/prep/PreparedGeometryFactory.cpp,
-	  tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp: Fixed crash
-	  of Prepared Geometry construction with nullptr to Geometry object
-	  (Ticket #197).
+	* [r2187] Fixed crash of Prepared Geometry construction with
+	  nullptr to Geometry object (Ticket #197).
 2008-09-16 20:55  Mateusz Loskot <mateusz at loskot.net>
-	* [r2186] build/msvc80/geos_unit/geos_unit.vcproj: Added
-	  PreparedGeometryFactoryTest to geos_unit.vcproj.
+	* [r2186] Added PreparedGeometryFactoryTest to geos_unit.vcproj.
 2008-09-16 20:15  Mateusz Loskot <mateusz at loskot.net>
-	* [r2185] build/msvc80/geos_lib/geos_lib.vcproj: Added CLocalizer
-	  to geos_lib.vcproj project for Visual C++ 2005/2008.
+	* [r2185] Added CLocalizer to geos_lib.vcproj project for Visual
+	  C++ 2005/2008.
 2008-09-16 20:13  Mateusz Loskot <mateusz at loskot.net>
-	* [r2184] tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp:
-	  Include missing <cassert> in isPointInRingTest.cpp
+	* [r2184] Include missing <cassert> in isPointInRingTest.cpp
 2008-09-16 20:05  Mateusz Loskot <mateusz at loskot.net>
-	* [r2183] source/Makefile.vc, source/io/CLocalizer.cpp: Fixed
-	  undeclared std::locale in CLocalizer when building using Visual
-	  C++ (Ticket #201)
+	* [r2183] Fixed undeclared std::locale in CLocalizer when building
+	  using Visual C++ (Ticket #201)
 2008-08-31 20:28  Mateusz Loskot <mateusz at loskot.net>
-	* [r2182] tests/unit/geos_unit.cpp: Replaced incorrect <cmath> with
-	  <cstdlib> in geos_unit.cpp.
+	* [r2182] Replaced incorrect <cmath> with <cstdlib> in
+	  geos_unit.cpp.
 2008-08-31 20:23  Mateusz Loskot <mateusz at loskot.net>
-	* [r2181] tests/unit/geos_unit.cpp: Added missing include <cmath>
-	  in geos_unit.cpp.
+	* [r2181] Added missing include <cmath> in geos_unit.cpp.
 2008-08-31 19:54  Mateusz Loskot <mateusz at loskot.net>
-	* [r2180] source/headers/geos/io/CLocalizer.h,
-	  source/io/CLocalizer.cpp: Removed use of strdup function to fix
-	  compilation with GCC 4.3.1 (Ticket #204).
+	* [r2180] Removed use of strdup function to fix compilation with
+	  GCC 4.3.1 (Ticket #204).
 2008-08-29 18:17  Mateusz Loskot <mateusz at loskot.net>
-	* [r2179] capi/geos_c.cpp: Removed redundant return expressions
-	  from geos_c.cpp. Testing changes notifications for buildbot.
+	* [r2179] Removed redundant return expressions from geos_c.cpp.
+	  Testing changes notifications for buildbot.
 2008-08-29 00:30  Mateusz Loskot <mateusz at loskot.net>
-	* [r2176] capi/geos_c.cpp: Fixed execution paths and removed
-	  redundant return expr in some C API calls.
+	* [r2176] Fixed execution paths and removed redundant return expr
+	  in some C API calls.
 2008-08-29 00:29  Mateusz Loskot <mateusz at loskot.net>
-	* [r2175] source/headers/geos/io/WKBWriter.h,
-	  source/io/WKBWriter.cpp: Added missing virtual destructor to
-	  WKBWriter class.
+	* [r2175] Added missing virtual destructor to WKBWriter class.
 2008-08-28 22:20  Sean Gillies <sgillies at frii.com>
-	* [r2174] capi/geos_c.cpp, source/headers/geos/io.h,
-	  source/headers/geos/io/CLocalizer.h, source/io/CLocalizer.cpp,
-	  source/io/Makefile.am: Added CLocalizer class that switches to C
-	  locale and restores to the outer context's locale when deleted
-	  (#201)
+	* [r2174] Added CLocalizer class that switches to C locale and
+	  restores to the outer context's locale when deleted (#201)
 2008-08-28 21:35  Mateusz Loskot <mateusz at loskot.net>
-	* [r2173] tests/unit/Makefile.am,
-	  tests/unit/capi/GEOSGeomToWKTTest.cpp: tests/unit: added
-	  GEOSGeomToWKTTest.
+	* [r2173] tests/unit: added GEOSGeomToWKTTest.
 2008-08-28 19:16  Sean Gillies <sgillies at frii.com>
-	* [r2172] capi/geos_c.cpp: Switch to C locale while reading and
-	  writing WKT and restore to the original context's locale
-	  afterward (#201)
+	* [r2172] Switch to C locale while reading and writing WKT and
+	  restore to the original context's locale afterward (#201)
 2008-08-22 17:25  Frank Warmerdam <warmerdam at pobox.com>
-	* [r2171] source/operation/buffer/BufferOp.cpp: include cmath for
-	  std::pow() and std:log() on MSVC7.1 (#199)
+	* [r2171] include cmath for std::pow() and std:log() on MSVC7.1
+	  (#199)
 2008-08-22 16:10  Mateusz Loskot <mateusz at loskot.net>
-	* [r2170] build/bjam/README: Added build/bjam/README with status
-	  note.
+	* [r2170] Added build/bjam/README with status note.
 2008-08-19 17:02  Mateusz Loskot <mateusz at loskot.net>
-	* [r2169] tests/unit/geom/LineStringTest.cpp: LineStringTest: fixed
-	  memory leak.
+	* [r2169] LineStringTest: fixed memory leak.
 2008-08-19 17:00  Mateusz Loskot <mateusz at loskot.net>
-	* [r2168] source/geom/util/CoordinateOperation.cpp,
-	  source/geom/util/GeometryEditor.cpp: geos/geom/util: Prefer
-	  strict static_cast than C-style cast. Commented ownership
-	  transfer of coordinates object.
+	* [r2168] geos/geom/util: Prefer strict static_cast than C-style
+	  cast. Commented ownership transfer of coordinates object.
 2008-08-19 00:18  Mateusz Loskot <mateusz at loskot.net>
-	* [r2167] tests/unit/algorithm/ConvexHullTest.cpp:
-	  tests/unit/algorithm/ConvexHullTest.cpp: Fixed memory leaks.
+	* [r2167] tests/unit/algorithm/ConvexHullTest.cpp: Fixed memory
+	  leaks.
 2008-08-19 00:05  Mateusz Loskot <mateusz at loskot.net>
-	* [r2166] tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp:
-	  tests/unit/algorithm/CGAlgorithms: Fixed memory leaks.
+	* [r2166] tests/unit/algorithm/CGAlgorithms: Fixed memory leaks.
 2008-08-18 23:45  Mateusz Loskot <mateusz at loskot.net>
-	* [r2165] tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp:
-	  tests/unit/algorithm/CGAlgorithms: Fixed number of memory leaks.
+	* [r2165] tests/unit/algorithm/CGAlgorithms: Fixed number of memory
+	  leaks.
 2008-08-18 23:30  Mateusz Loskot <mateusz at loskot.net>
-	* [r2164] tests/unit/capi/GEOSCoordSeqTest.cpp,
-	  tests/unit/capi/GEOSSimplifyTest.cpp: tests/unit/capi: Fixed
-	  number of memory leaks.
+	* [r2164] tests/unit/capi: Fixed number of memory leaks.
 2008-08-18 16:32  Mateusz Loskot <mateusz at loskot.net>
-	* [r2163] tests/bigtest/GeometryTestFactory.cpp,
-	  tests/bigtest/TestSweepLineSpeed.cpp: tests/bigtest: Pointed out
-	  number of memory leaks but not fixing them, waiting for comments.
+	* [r2163] tests/bigtest: Pointed out number of memory leaks but not
+	  fixing them, waiting for comments.
 2008-08-18 16:30  Mateusz Loskot <mateusz at loskot.net>
-	* [r2162] tests/unit/algorithm/ConvexHullTest.cpp,
-	  tests/unit/geom/PolygonTest.cpp,
-	  tests/unit/utility.h: tests/unit: added tests cases to
+	* [r2162] tests/unit: added tests cases to
 	  PreparedGeometryFactoryTest, refactored casting utils and
 	  geometry comparators, small cleanup.
 2008-08-18 16:29  Mateusz Loskot <mateusz at loskot.net>
-	* [r2161] source/algorithm/RayCrossingCounter.cpp,
-	  source/algorithm/locate/PointOnGeometryLocator.cpp,
-	  source/geom/util/ComponentCoordinateExtracter.cpp,
-	  source/index/intervalrtree/IntervalRTreeBranchNode.cpp,
-	  source/index/intervalrtree/IntervalRTreeLeafNode.cpp,
-	  source/index/intervalrtree/IntervalRTreeNode.cpp,
-	  source/index/intervalrtree/SortedPackedIntervalRTree.cpp,
-	  source/noding/FastSegmentSetIntersectionFinder.cpp,
-	  source/noding/MCIndexSegmentSetMutualIntersector.cpp,
-	  source/noding/NodedSegmentString.cpp,
-	  source/noding/SegmentIntersectionDetector.cpp,
-	  source/noding/SegmentStringUtil.cpp: Fixed svn:keywords.
+	* [r2161] Fixed svn:keywords.
 2008-08-18 16:27  Mateusz Loskot <mateusz at loskot.net>
-	* [r2160] source/headers/geos/util.h: Fixed UNREFERENCED_PARAMETER
-	  macro.
+	* [r2160] Fixed UNREFERENCED_PARAMETER macro.
-	* [r2159]
-	  source/headers/geos/geom/prep/AbstractPreparedPolygonContains.h,
-	  source/headers/geos/geom/prep/BasicPreparedGeometry.h,
-	  source/headers/geos/geom/prep/PreparedGeometry.h,
-	  source/headers/geos/geom/prep/PreparedLineString.h,
-	  source/headers/geos/geom/prep/PreparedLineStringIntersects.h,
-	  source/headers/geos/geom/prep/PreparedPoint.h,
-	  source/headers/geos/geom/prep/PreparedPolygon.h,
-	  source/headers/geos/geom/prep/PreparedPolygonContainsProperly.h,
-	  source/headers/geos/geom/prep/PreparedPolygonCovers.h,
-	  source/headers/geos/geom/prep/PreparedPolygonIntersects.h,
-	  source/headers/geos/geom/prep/PreparedPolygonPredicate.h: Fixed
-	  svn:keywords.
+	* [r2159] Fixed svn:keywords.
 2008-08-18 16:24  Mateusz Loskot <mateusz at loskot.net>
-	* [r2158] source/geom/prep/AbstractPreparedPolygonContains.cpp,
-	  source/geom/prep/BasicPreparedGeometry.cpp,
-	  source/geom/prep/PreparedGeometry.cpp,
-	  source/geom/prep/PreparedGeometryFactory.cpp,
-	  source/geom/prep/PreparedLineString.cpp,
-	  source/geom/prep/PreparedLineStringIntersects.cpp,
-	  source/geom/prep/PreparedPoint.cpp,
-	  source/geom/prep/PreparedPolygonContainsProperly.cpp,
-	  source/geom/prep/PreparedPolygonCovers.cpp,
-	  source/geom/prep/PreparedPolygonIntersects.cpp,
-	  source/geom/prep/PreparedPolygonPredicate.cpp: geom/prep:
-	  Refactored kamikaze casts to more readable form. Fixed
-	  svn:keywords.
+	* [r2158] geom/prep: Refactored kamikaze casts to more readable
+	  form. Fixed svn:keywords.
 2008-08-12 00:25  Mateusz Loskot <mateusz at loskot.net>
-	* [r2157] source/headers/geos/geomPrep.h: Fixed Id keywords.
+	* [r2157] Fixed Id keywords.
 2008-08-12 00:23  Mateusz Loskot <mateusz at loskot.net>
-	* [r2156]
-	  tests/unit/operation/IsSimpleOpTest.cpp: Fixed EOL to LF in
-	  trunk/tests.
+	* [r2156] Fixed EOL to LF in trunk/tests.
 2008-08-12 00:09  Mateusz Loskot <mateusz at loskot.net>
-	* [r2155] source/headers/geos/geom/prep/PreparedGeometryFactory.h:
-	  Updated svn:keywords property.
+	* [r2155] Updated svn:keywords property.
 2008-08-12 00:03  Mateusz Loskot <mateusz at loskot.net>
-	* [r2154] tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp:
+	* [r2154] Updated svn:keywords property.
 2008-08-11 23:54  Mateusz Loskot <mateusz at loskot.net>
-	* [r2153] tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp:
-	  Refactored tabs vs spaces in PreparedGeometryFactoryTest.
+	* [r2153] Refactored tabs vs spaces in PreparedGeometryFactoryTest.
 2008-08-11 23:52  Mateusz Loskot <mateusz at loskot.net>
-	* [r2152] source/headers/geos/geom/prep/PreparedGeometryFactory.h:
-	  PreparedGeometry must be a complete type where it is destroyed by
-	  the factory (Ticket #198).
+	* [r2152] PreparedGeometry must be a complete type where it is
+	  destroyed by the factory (Ticket #198).
 2008-08-11 23:42  Mateusz Loskot <mateusz at loskot.net>
-	* [r2151] source/headers/geos/geom/prep/PreparedGeometryFactory.h,
-	  tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp: Completed
-	  PreparedGeometryFactory class with missing named destructor for
-	  PreparedGeometry (Ticket #198)
+	* [r2151] Completed PreparedGeometryFactory class with missing
+	  named destructor for PreparedGeometry (Ticket #198)
 2008-08-11 23:35  Mateusz Loskot <mateusz at loskot.net>
-	* [r2150]
-	  tests/unit/geom/prep/.PreparedGeometryFactoryTest.cpp.swp:
-	  Removed .PreparedGeometryFactoryTest.cpp.swp that must sneaked
-	  accidentally.
+	* [r2150] Removed .PreparedGeometryFactoryTest.cpp.swp that must
+	  sneaked accidentally.
 2008-08-11 22:48  Mateusz Loskot <mateusz at loskot.net>
-	* [r2149] tests/unit/Makefile.am, tests/unit/geom/prep,
-	  tests/unit/geom/prep/.PreparedGeometryFactoryTest.cpp.swp,
-	  tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp: Added
-	  PreparedGeometryFactoryTest with first test cases included.
-	  FIXME: The test causes memory leak because we don't know how to
-	  destroy PreparedGeometry objects returned by the factory,
-	  discussing on the geos-devel list now.
+	* [r2149] Added PreparedGeometryFactoryTest with first test cases
+	  included. FIXME: The test causes memory leak because we don't
+	  know how to destroy PreparedGeometry objects returned by the
+	  factory, discussing on the geos-devel list now.
 2008-08-07 16:59  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2148] source/algorithm/RobustDeterminant.cpp: Added original
-	  author to main copyright block.
+	* [r2148] Added original author to main copyright block.
 2008-08-07 16:57  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2147] source/headers/geos/timeval.h: Change to standard header,
-	  with (c) credit to author.
+	* [r2147] Change to standard header, with (c) credit to author.
 2008-08-01 23:23  Mateusz Loskot <mateusz at loskot.net>
-	* [r2146] ChangeLog: Updated ChangeLog with latest submissions.
-	  Hmm, should we stil maintain the ChangeLog file?
+	* [r2146] Updated ChangeLog with latest submissions. Hmm, should we
+	  stil maintain the ChangeLog file?
 2008-07-31 17:08  Mateusz Loskot <mateusz at loskot.net>
-	* [r2145] tests/unit/capi/GEOSPolygonizer_getCutEdgesTest.cpp:
-	  Fixed tabs, hopefully. Updated svn:keywords property.
+	* [r2145] Fixed tabs, hopefully. Updated svn:keywords property.
 2008-07-31 17:01  Mateusz Loskot <mateusz at loskot.net>
-	* [r2144] capi/geos_c.cpp, capi/geos_c.h.in,
-	  tests/unit/capi/GEOSPolygonizer_getCutEdgesTest.cpp: Patch
-	  completing C API interface with wrapper on
+	* [r2144] Patch completing C API interface with wrapper on
 	  Polygonizer::getCutEdges (Ticket #195). Unit test included in
 	  tests/unit/capi/GEOSPolygonizer_getCutEdgeTest.cpp. Thanks to
 	  Jurgen E. Fischer for this patch.
 2008-07-26 23:06  Mateusz Loskot <mateusz at loskot.net>
-	* [r2143] doc/example.cpp, source/geomgraph/GeometryGraph.cpp,
-	  source/headers/geos/noding/FastNodingValidator.h,
-	  source/index/quadtree/DoubleBits.cpp,
-	  source/io/StringTokenizer.cpp,
-	  tests/bigtest/TestSweepLineSpeed.cpp: Number of fixes enabling
-	  GEOS compilation with GCC 4.3 (Ticket #167).
+	* [r2143] Number of fixes enabling GEOS compilation with GCC 4.3
+	  (Ticket #167).
 2008-07-26 21:00  Mateusz Loskot <mateusz at loskot.net>
-	* [r2142] capi/geos_c.h.in: Guarded version macros with #ifndef
-	  conditions to avoid redefinition errors (Ticket #167).
+	* [r2142] Guarded version macros with #ifndef conditions to avoid
+	  redefinition errors (Ticket #167).
 2008-07-26 20:47  Mateusz Loskot <mateusz at loskot.net>
-	* [r2141] source/headers/geos/version.h.in,
-	  source/headers/geos/version.h.vc: Guarded version macros with
-	  #ifndef conditions to avoid redefinition errors (Ticket #167).
+	* [r2141] Guarded version macros with #ifndef conditions to avoid
 2008-07-26 20:24  Mateusz Loskot <mateusz at loskot.net>
-	* [r2140] macros/ac_python_devel.m4: Fixed problems with finding
-	  libpython on Mac Darwin (Ticket #191).
+	* [r2140] Fixed problems with finding libpython on Mac Darwin
+	  (Ticket #191).
 2008-07-26 19:57  Mateusz Loskot <mateusz at loskot.net>
-	* [r2139] autogen.sh: Updated svn:keywords property.
+	* [r2139] Updated svn:keywords property.
 2008-07-26 19:56  Mateusz Loskot <mateusz at loskot.net>
-	* [r2138] autogen.sh: Fixed autogen.sh for OpenSolaris (Ticket
-	  #192).
+	* [r2138] Fixed autogen.sh for OpenSolaris (Ticket #192).
 2008-07-25 21:00  Mateusz Loskot <mateusz at loskot.net>
-	* [r2137] build/README, build/msvc80/README, macros/geos.m4,
-	  source/headers/geos/algorithm/CentralEndpointIntersector.h,
-	  source/headers/geos/geomPrep.h,
-	  source/headers/geos/indexIntervalRTree.h,
-	  source/headers/geos/noding/SingleInteriorIntersectionFinder.h,
-	  source/noding/FastNodingValidator.cpp,
-	  source/noding/SingleInteriorIntersectionFinder.cpp,
-	  swig/python/tests/TESTING.txt: Updated svn:keywords property
+	* [r2137] Updated svn:keywords property
 2008-07-25 20:56  Mateusz Loskot <mateusz at loskot.net>
-	* [r2136] tests/unit/operation/IsSimpleOpTest.cpp,
-	  tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp:
+	* [r2136] Updated svn:keywords property
 2008-07-19 19:11  Frank Warmerdam <warmerdam at pobox.com>
-	* [r2135] source/Makefile.vc: added manifest handling for DLLs
-	  (#193)
+	* [r2135] added manifest handling for DLLs (#193)
 2008-07-19 19:07  Frank Warmerdam <warmerdam at pobox.com>
-	* [r2134] source/Makefile.vc: added rules to create platform.h,
-	  version.h and geos_c.h from templates on win32
+	* [r2134] added rules to create platform.h, version.h and geos_c.h
+	  from templates on win32
 2008-07-15 22:04  Mateusz Loskot <mateusz at loskot.net>
-	* [r2131] ChangeLog, capi/geos_c.cpp,
-	  source/algorithm/ConvexHull.cpp,
-	  source/algorithm/RobustDeterminant.cpp,
-	  source/algorithm/locate/IndexedPointInAreaLocator.cpp,
-	  source/geomgraph/EdgeEnd.cpp, source/geomgraph/GeometryGraph.cpp,
-	  source/headers/geos/geom/Coordinate.inl,
-	  source/headers/geos/geom/LineSegment.inl,
-	  source/headers/geos/io/WKBReader.h,
-	  source/index/bintree/Key.cpp, source/index/quadtree/Key.cpp,
-	  source/io/ByteOrderValues.cpp, source/noding/Octant.cpp,
-	  source/operation/buffer/BufferBuilder.cpp,
-	  source/operation/distance/ConnectedElementPointFilter.cpp,
-	  source/planargraph/DirectedEdge.cpp,
-	  source/precision/SimpleGeometryPrecisionReducer.cpp,
-	  source/util/math.cpp, tests/xmltester/XMLTester.cpp,
-	  tests/xmltester/markup/MarkupSTL.h: Fixed compilation on with Sun
-	  Studio compiler on Solaris x86 and Sparc (Ticket #189). Thanks to
-	  Magne Mahre for the patch.
+	* [r2131] Fixed compilation on with Sun Studio compiler on Solaris
+	  x86 and Sparc (Ticket #189). Thanks to Magne Mahre for the patch.
 2008-07-15 13:35  Mateusz Loskot <mateusz at loskot.net>
-	* [r2130] source/Makefile.vc: For building with Visual C++, added
-	  new flag DEBUG=1 (see GEOS building instructions on GEOS Wiki).
-	  Added missing flags for Visual C++ compiler, in release and debug
-	  configuration.
+	* [r2130] For building with Visual C++, added new flag DEBUG=1 (see
+	  GEOS building instructions on GEOS Wiki). Added missing flags for
+	  Visual C++ compiler, in release and debug configuration.
 2008-05-20 21:34  Mateusz Loskot <mateusz at loskot.net>
-	* [r2129] source/dirlist.mk: Added missing subdirs to
-	  source/dirlist.mk
+	* [r2129] Added missing subdirs to source/dirlist.mk
 2008-05-20 21:31  Mateusz Loskot <mateusz at loskot.net>
-	* [r2128] source/geom/prep: Updated svn:ignore patterns.
+	* [r2128] Updated svn:ignore patterns.
 2008-05-20 21:25  Mateusz Loskot <mateusz at loskot.net>
-	* [r2127] ChangeLog, bootstrap.bat, build/msvc80/geos.sln,
-	  source/geom/GeometryComponentFilter.cpp,
-	  source/geom/PrecisionModel.cpp,
-	  source/geom/util/GeometryTransformer.cpp,
-	  source/headers/geos/geom/BinaryOp.h,
-	  source/headers/geos/noding/Octant.h,
-	  source/headers/geos/noding/ScaledNoder.h,
-	  source/headers/geos/operation/overlay/PointBuilder.h,
-	  source/headers/geos/util.h, source/index/quadtree/NodeBase.cpp,
-	  source/noding/ScaledNoder.cpp, source/noding/SegmentString.cpp,
-	  source/operation/overlay/FuzzyPointLocator.cpp,
-	  source/operation/overlay/OverlayOp.cpp,
-	  source/precision/CommonBitsRemover.cpp,
-	  source/precision/GeometrySnapper.cpp,
-	  source/simplify/DouglasPeuckerSimplifier.cpp,
-	  tests/unit/geom/DimensionTest.cpp: * source\headers\geos\util.h:
-	  Add UNREFERENCED_PARAMETER macro.
+	* [r2127] * source\headers\geos\util.h: Add UNREFERENCED_PARAMETER
+	  macro.
 	  * source\geom\PrecisionModel.cpp,
 	  source\geom\GeometryComponentFilter.cpp,
 	  source\geom\util\GeometryTransformer.cpp,
@@ -4945,131 +3033,82 @@
 2008-05-20 20:45  Mateusz Loskot <mateusz at loskot.net>
-	* [r2126] ChangeLog, source/Makefile.vc: source/makefile.vc:
-	  Removed non-existing file entry:
+	* [r2126] source/makefile.vc: Removed non-existing file entry:
 	  PreparedPolygonLineIntersects.obj.
 2008-05-20 20:33  Mateusz Loskot <mateusz at loskot.net>
-	* [r2125] ChangeLog, bootstrap.bat, source/Makefile.vc: *
-	  bootstrap.bat: Added script generating headers for use with
-	  Visual C++ compiler. DO NOT include this script in GEOS source
-	  distribution. * source/makefile.vc: Do not make copies of 3
-	  dynamic headers but let users to use bootstrap.bat instead.
+	* [r2125] * bootstrap.bat: Added script generating headers for use
+	  with Visual C++ compiler. DO NOT include this script in GEOS
+	  source distribution. * source/makefile.vc: Do not make copies of
+	  3 dynamic headers but let users to use bootstrap.bat instead.
 2008-02-07 22:59  Frank Warmerdam <warmerdam at pobox.com>
-	* [r2123] Makefile.am: make sure makefile.vc gets distributed
+	* [r2123] make sure makefile.vc gets distributed
 2008-02-06 22:17  Frank Warmerdam <warmerdam at pobox.com>
-	* [r2122] source/Makefile.am, source/Makefile.vc,
-	  source/headers/geos/noding/Makefile.am: try to fix up the files
-	  include in distribution, and remove unused files from Makefile.vc
-	  (#175)
+	* [r2122] try to fix up the files include in distribution, and
+	  remove unused files from Makefile.vc (#175)
 2008-01-30 22:34  Ben Jubb <benjubb at refractions.net>
-	* [r2120] source/headers/geos/algorithm/RayCrossingCounter.h,
-	  source/headers/geos/algorithm/locate/SimplePointInAreaLocator.h,
-	  source/headers/geos/geom/prep/PreparedGeometryFactory.h,
-	  source/headers/geos/geom/prep/PreparedPolygonPredicate.h,
-	  source/headers/geos/geomUtil.h,
-	  source/headers/geos/geosAlgorithm.h,
-	  source/headers/geos/noding/SegmentStringUtil.h: Added
-	  documentation, for benefit of doxygen.
+	* [r2120] Added documentation, for benefit of doxygen.
 2008-01-30 22:30  Ben Jubb <benjubb at refractions.net>
-	* [r2119] source/geom/prep/PreparedPolygonIntersects.cpp: deleted
-	  out-commented line.
+	* [r2119] deleted out-commented line.
 2008-01-30 22:29  Ben Jubb <benjubb at refractions.net>
-	* [r2118] source/geom/prep/PreparedPolygon.cpp: removed ref to
-	  PreparedPolygonLineIntersection
+	* [r2118] removed ref to PreparedPolygonLineIntersection
 2008-01-30 22:18  Ben Jubb <benjubb at refractions.net>
-	* [r2117] source/geom/prep/Makefile.am,
-	  source/headers/geos/geom/prep/Makefile.am: Removed refs to
-	  PreparedPolygonLineIntersection.
+	* [r2117] Removed refs to PreparedPolygonLineIntersection.
 2008-01-30 22:17  Ben Jubb <benjubb at refractions.net>
-	* [r2116] source/geom/prep/PreparedPolygonLineIntersection.cpp,
-	  source/headers/geos/geom/prep/PreparedPolygonLineIntersection.h:
-	  Deleted. not used, not needed.
+	* [r2116] Deleted. not used, not needed.
 2008-01-30 19:09  Ben Jubb <benjubb at refractions.net>
-	* [r2115] source/headers/geos/geomPrep.h: Added for benefit of
-	  doxygen.
+	* [r2115] Added for benefit of doxygen.
 2008-01-29 17:55  Ben Jubb <benjubb at refractions.net>
-	* [r2114] source/geom/prep/AbstractPreparedPolygonContains.cpp,
-	  source/headers/geos/noding/SegmentIntersector.h,
-	  source/noding/SegmentIntersectionDetector.cpp: Some small changes
-	  to improve the memory management. These changes plug a few leaks,
-	  but not all.
+	* [r2114] Some small changes to improve the memory management.
+	  These changes plug a few leaks, but not all.
 2008-01-29 17:49  Ben Jubb <benjubb at refractions.net>
-	* [r2113] source/operation/predicate/RectangleContains.cpp: Fix a
-	  bug in the shortcut test for containment in a rectangle. This
-	  test wasn't correctly testing for case of a point on the
-	  boundary.
+	* [r2113] Fix a bug in the shortcut test for containment in a
+	  rectangle. This test wasn't correctly testing for case of a point
+	  on the boundary.
 	  Was also a bug in JTS (now fixed).
 2008-01-29 17:37  Ben Jubb <benjubb at refractions.net>
-	* [r2112] source/geom/Geometry.cpp: Patch to fix bug in ticket #171
+	* [r2112] Patch to fix bug in ticket #171
 2008-01-22 19:34  Ben Jubb <benjubb at refractions.net>
-	* [r2111] capi/geos_c.h.in, source/headers/geos/version.h.vc:
-	  Updated for VC to give correct version (3.1.0-CAPI-1.5.0).
+	* [r2111] Updated for VC to give correct version
+	  (3.1.0-CAPI-1.5.0).
 2008-01-18 00:37  Ben Jubb <benjubb at refractions.net>
-	* [r2110] configure.in: Added to CAPI interface, cleared
-	  CAPI_INTERFACE_REV, bumped AGE & CURRENT
+	* [r2110] Added to CAPI interface, cleared CAPI_INTERFACE_REV,
+	  bumped AGE & CURRENT
 2008-01-18 00:35  Ben Jubb <benjubb at refractions.net>
-	* [r2109] source/index/chain/MonotoneChainBuilder.cpp: Fixed a bug
-	  in the handling of line strings with repeated points.
+	* [r2109] Fixed a bug in the handling of line strings with repeated
+	  points.
 	  -This line, and those below, will be ignored--
@@ -5077,398 +3116,283 @@
 2008-01-17 19:15  Ben Jubb <benjubb at refractions.net>
-	* [r2108] capi/geos_c.cpp: Fixed a misspelling,
-	  GEOSPreparedContainsProperty => GEOSPreparedContainsProperly
+	* [r2108] Fixed a misspelling, GEOSPreparedContainsProperty =>
+	  GEOSPreparedContainsProperly
 2008-01-16 18:36  Frank Warmerdam <warmerdam at pobox.com>
-	* [r2107] source/Makefile.vc: updated to include post 3.0 classes
+	* [r2107] updated to include post 3.0 classes
 2008-01-09 23:49  Ben Jubb <benjubb at refractions.net>
-	* [r2106] capi/geos_c.cpp, capi/geos_c.h.in: Added support for
-	  prepared geometry
+	* [r2106] Added support for prepared geometry
 2008-01-09 23:48  Ben Jubb <benjubb at refractions.net>
-	* [r2105] source/headers/geos/geom/prep/PreparedGeometryFactory.h:
-	  removed extraneous 'using namespace'
+	* [r2105] removed extraneous 'using namespace'
 2008-01-03 21:11  Ben Jubb <benjubb at refractions.net>
-	* [r2104] source/noding/MCIndexSegmentSetMutualIntersector.cpp:
-	  commented out some delete's in
+	* [r2104] commented out some delete's in
 	  MCIndexSegmentSetMutualIntersector::addToIndex, to fix a bug in
 	  prepared contains() predicate.
 2008-01-02 23:23  Sean Gillies <sgillies at frii.com>
-	* [r2102] swig/Makefile.am: Conditionally add swig/python,ruby to
-	  SUBDIRS
+	* [r2102] Conditionally add swig/python,ruby to SUBDIRS
 2007-12-22 00:04  Mateusz Loskot <mateusz at loskot.net>
-	* [r2101] build/bjam/geos/Jamfile, build/bjam/geos_c,
-	  build/bjam/geos_unit: Updated configuration of experimental
-	  builder based on Boost.Build. GEOS compiles with bjam
-	  successfully as static library.
+	* [r2101] Updated configuration of experimental builder based on
+	  Boost.Build. GEOS compiles with bjam successfully as static
+	  library.
 2007-12-21 23:50  Mateusz Loskot <mateusz at loskot.net>
-	* [r2100] source/Makefile.vc, source/algorithm/locate,
-	  source/index/intervalrtree: Updated Visual C++ makefiles with new
-	  submissions from Ben. Now, new GEOS features compiles with NMAKE
-	  too.
+	* [r2100] Updated Visual C++ makefiles with new submissions from
+	  Ben. Now, new GEOS features compiles with NMAKE too.
 2007-12-21 23:31  Mateusz Loskot <mateusz at loskot.net>
-	* [r2099] source/headers/geos/algorithm/Makefile.am: Removed
-	  SimplePointInAreaLocator.h from algorithm/Makefile.am (header
-	  migrated to algorithm/locate).
+	* [r2099] Removed SimplePointInAreaLocator.h from
+	  algorithm/Makefile.am (header migrated to algorithm/locate).
 2007-12-21 23:26  Mateusz Loskot <mateusz at loskot.net>
-	* [r2098] source/algorithm/Makefile.am: Added comment about
-	  deprecated translation units in source/algorithm.
+	* [r2098] Added comment about deprecated translation units in
+	  source/algorithm.
 2007-12-21 23:26  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2097] source/geom/util/Makefile.am: remove trailing backslash
+	* [r2097] remove trailing backslash
 2007-12-21 23:21  Mateusz Loskot <mateusz at loskot.net>
-	* [r2096] ., source/headers/geos/algorithm,
-	  source/headers/geos/algorithm/locate, tests/unit: Updated
-	  svn:ignore property.
+	* [r2096] Updated svn:ignore property.
 2007-12-21 23:18  Mateusz Loskot <mateusz at loskot.net>
-	* [r2095] source/geom/prep/PreparedPolygonContainsProperly.cpp:
-	  Fixed extra qualifications in
+	* [r2095] Fixed extra qualifications in
 2007-12-21 23:12  Mateusz Loskot <mateusz at loskot.net>
-	* [r2094] source/geom/prep/AbstractPreparedPolygonContains.cpp,
-	  source/headers/geos/geom/prep/PreparedGeometryFactory.h: Fixed
-	  extra qualifications in PreparedGeometryFactory class.
+	* [r2094] Fixed extra qualifications in PreparedGeometryFactory
+	  class.
 2007-12-21 22:57  Mateusz Loskot <mateusz at loskot.net>
-	* [r2093]
-	  source/headers/geos/geom/util/ComponentCoordinateExtracter.h:
-	  Fixed GeometryTypeId misused in
+	* [r2093] Fixed GeometryTypeId misused in
 	  geos/geom/util/ComponentCoordinateExtracter.h.
 2007-12-21 22:49  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2092] source/geom/util/Makefile.am: remove .cpp files that
-	  weren't there before
+	* [r2092] remove .cpp files that weren't there before
 2007-12-21 22:49  Mateusz Loskot <mateusz at loskot.net>
-	* [r2091] source/geom/CoordinateArraySequence.cpp,
-	  source/geom/CoordinateSequence.cpp, source/geom/LineString.cpp:
-	  Reverted changes appled in r2089 to three files from source/geom.
+	* [r2091] Reverted changes appled in r2089 to three files from
+	  source/geom.
 2007-12-21 22:47  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2090] source/algorithm/Makefile.am: type subdir typo
+	* [r2090] type subdir typo
 2007-12-21 22:43  Mateusz Loskot <mateusz at loskot.net>
-	* [r2089] source/geom/CoordinateArraySequence.cpp,
-	  source/geom/CoordinateSequence.cpp, source/geom/LineString.cpp,
-	  source/geom/prep, source/headers/geos/geom/prep,
-	  source/headers/geos/index/intervalrtree,
-	  source/index/intervalrtree: Updated svn:ignore property.
+	* [r2089] Updated svn:ignore property.
 2007-12-21 22:41  Mateusz Loskot <mateusz at loskot.net>
-	* [r2088] source/examples/CustomPointCoordinateSequence.cpp: Added
-	  missing <iostream> header to CustomPointCoordinateSequence.cpp.
+	* [r2088] Added missing <iostream> header to
+	  CustomPointCoordinateSequence.cpp.
 2007-12-21 22:40  Mateusz Loskot <mateusz at loskot.net>
-	* [r2087] source/algorithm/Makefile.am,
-	  source/algorithm/SimplePointInAreaLocator.cpp,
-	  source/algorithm/locate: Removed unused
-	  SimplePointInAreaLocator.cpp. This unit migrated to
-	  algorithm/locate module.
+	* [r2087] Removed unused SimplePointInAreaLocator.cpp. This unit
+	  migrated to algorithm/locate module.
 2007-12-21 22:21  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2086] configure.in: Updated configure.in with new locations.
+	* [r2086] Updated configure.in with new locations.
 2007-12-21 22:14  Mateusz Loskot <mateusz at loskot.net>
-	* [r2085] configure.in: Updated configure.in with new locations.
+	* [r2085] Updated configure.in with new locations.
 2007-12-21 22:12  Mateusz Loskot <mateusz at loskot.net>
-	* [r2084] configure.in: Updated configure.in with new locations.
+	* [r2084] Updated configure.in with new locations.
 2007-12-21 22:09  Mateusz Loskot <mateusz at loskot.net>
-	* [r2083] configure.in: Updated configure.in with new locations.
+	* [r2083] Updated configure.in with new locations.
 2007-12-21 22:07  Mateusz Loskot <mateusz at loskot.net>
-	* [r2082] configure.in: Updated configure.in with new locations.
+	* [r2082] Updated configure.in with new locations.
 2007-12-21 22:02  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2081] source/headers/geos/algorithm/Makefile.am,
-	  source/headers/geos/algorithm/locate/Makefile.am,
-	  source/headers/geos/noding/Makefile.am: Add
-	  headers/geos/algorithm/locate to automake
+	* [r2081] Add headers/geos/algorithm/locate to automake
 2007-12-21 22:01  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2080] source/noding/Makefile.am: Add files to automake
+	* [r2080] Add files to automake
 2007-12-21 21:57  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2079] source/headers/geos/index/Makefile.am,
-	  source/headers/geos/index/intervalrtree/Makefile.am: Added
-	  headers/index/intervalrtree to automake
+	* [r2079] Added headers/index/intervalrtree to automake
 2007-12-21 21:55  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2078] source/headers/geos/geom/Makefile.am,
-	  source/headers/geos/geom/prep/Makefile.am,
-	  source/headers/geos/geom/util/Makefile.am: Added
-	  headers/geom/prep headers/geom/util to automake
+	* [r2078] Added headers/geom/prep headers/geom/util to automake
 2007-12-21 21:47  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2077] source/index/Makefile.am,
-	  source/index/intervalrtree/Makefile.am: Added index/intervalrtree
-	  to automake
+	* [r2077] Added index/intervalrtree to automake
 2007-12-21 21:43  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2076] source/geom/util/Makefile.am: added
-	  geom/util/ComponentCoordinateExtracter.h
+	* [r2076] added geom/util/ComponentCoordinateExtracter.h
 2007-12-21 21:40  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2075] source/geom/Makefile.am, source/geom/prep/Makefile.am:
-	  Add geom/prep to automake
+	* [r2075] Add geom/prep to automake
 2007-12-21 21:36  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2074] source/algorithm/Makefile.am,
-	  source/algorithm/locate/Makefile.am: Add algorithm/location to
-	  automake
+	* [r2074] Add algorithm/location to automake
 2007-12-21 21:31  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2073] source/algorithm/Makefile.am: Added new files
+	* [r2073] Added new files
 2007-12-21 20:50  Ben Jubb <benjubb at refractions.net>
-	* [r2072] source/algorithm/RayCrossingCounter.cpp:
+	* [r2072]
 2007-12-21 20:48  Ben Jubb <benjubb at refractions.net>
-	* [r2071] build/msvc80/geos_lib/geos_lib.vcproj:
+	* [r2071]
 2007-12-21 20:47  Ben Jubb <benjubb at refractions.net>
-	* [r2070] source/headers/geos/index/intervalrtree,
-	  source/headers/geos/index/intervalrtree/SortedPackedIntervalRTree.h:
-	  Added from JTS 1.9 to support prepared geometry
+	* [r2070] Added from JTS 1.9 to support prepared geometry
-	* [r2069] source/algorithm/locate,
-	  source/algorithm/locate/SimplePointInAreaLocator.cpp: Added from
-	  JTS 1.9 to support prepared geometry
+	* [r2069] Added from JTS 1.9 to support prepared geometry
 2007-12-21 20:44  Ben Jubb <benjubb at refractions.net>
-	* [r2068] source/geom/util/ComponentCoordinateExtracter.cpp: Added
-	  from JTS 1.9 to support prepared geometry
+	* [r2068] Added from JTS 1.9 to support prepared geometry
-	* [r2067]
+	* [r2067] Added from JTS 1.9 to support prepared geometry
 2007-12-21 20:42  Ben Jubb <benjubb at refractions.net>
-	* [r2066] source/operation/predicate/RectangleIntersects.cpp:
-	  modified because SimplePointInAreaLocator.h moved
+	* [r2066] modified because SimplePointInAreaLocator.h moved
 2007-12-21 20:41  Ben Jubb <benjubb at refractions.net>
-	* [r2065] source/noding/FastSegmentSetIntersectionFinder.cpp,
-	  source/noding/SegmentStringUtil.cpp: Added from JTS 1.9 to
-	  support prepared geometry
+	* [r2065] Added from JTS 1.9 to support prepared geometry
-	* [r2064] source/index/intervalrtree,
-	  source/index/intervalrtree/SortedPackedIntervalRTree.cpp: Added
+	* [r2064] Added from JTS 1.9 to support prepared geometry
 2007-12-21 20:40  Ben Jubb <benjubb at refractions.net>
-	* [r2063] source/geom/prep,
-	  source/geom/prep/AbstractPreparedPolygonContains.cpp,
-	  source/geom/prep/PreparedPolygonLineIntersection.cpp,
-	  source/geom/prep/PreparedPolygonPredicate.cpp: Added from JTS 1.9
-	  to support prepared geometry
+	* [r2063] Added from JTS 1.9 to support prepared geometry
 2007-12-21 20:39  Ben Jubb <benjubb at refractions.net>
-	* [r2062] source/geomgraph/EdgeEndStar.cpp: modified because
-	  SimplePointInAreaLocator.h moved
+	* [r2062] modified because SimplePointInAreaLocator.h moved
 2007-12-21 20:38  Ben Jubb <benjubb at refractions.net>
-	* [r2061] source/headers/geos/algorithm/SimplePointInAreaLocator.h:
-	  Moved into geos::algorithm::locate
+	* [r2061] Moved into geos::algorithm::locate
 2007-12-21 20:37  Ben Jubb <benjubb at refractions.net>
-	* [r2060] source/headers/geos/algorithm/RayCrossingCounter.h: Added
+	* [r2060] Added from JTS 1.9 to support prepared geometry
 2007-12-21 20:35  Ben Jubb <benjubb at refractions.net>
-	* [r2059] source/headers/geos/geom/prep,
-	  source/headers/geos/geom/prep/PreparedPolygonLineIntersection.h,
-	  source/headers/geos/geom/prep/PreparedPolygonPredicate.h: Added
+	* [r2059] Added from JTS 1.9 to support prepared geometry
 2007-12-21 20:34  Ben Jubb <benjubb at refractions.net>
-	* [r2058]
-	  source/headers/geos/noding/NodableSegmentString.h,
-	  source/headers/geos/noding/NodedSegmentString.h,
-	  source/headers/geos/noding/SegmentStringUtil.h: Added from JTS
-	  1.9 to support prepared geometry
+	* [r2058] Added from JTS 1.9 to support prepared geometry
 2007-12-21 20:33  Ben Jubb <benjubb at refractions.net>
-	* [r2057] source/headers/geos/noding/SegmentString.h: changed
-	  destructor to be virtual
+	* [r2057] changed destructor to be virtual
 2007-12-21 20:31  Ben Jubb <benjubb at refractions.net>
-	* [r2056] source/headers/geos/geom/Envelope.h: Added a covers()
-	  predicate, from JTS 1.9, to support prepared geometry
+	* [r2056] Added a covers() predicate, from JTS 1.9, to support
+	  prepared geometry
 2007-12-21 20:30  Ben Jubb <benjubb at refractions.net>
-	* [r2055] source/headers/geos/geom/Geometry.h: changed IsRectangle
-	  to be public
+	* [r2055] changed IsRectangle to be public
 2007-12-21 20:03  Ben Jubb <benjubb at refractions.net>
-	* [r2054] source/headers/geos/geom/Envelope.inl: Added a covers()
+	* [r2054] Added a covers() predicate, from JTS 1.9, to support
+	  prepared geometry
 2007-12-21 20:00  Ben Jubb <benjubb at refractions.net>
-	* [r2053]
-	  source/headers/geos/algorithm/locate/SimplePointInAreaLocator.h:
-	  Moved from geos::algorithm as in JTS 1.9
+	* [r2053] Moved from geos::algorithm as in JTS 1.9
 2007-12-21 19:55  Ben Jubb <benjubb at refractions.net>
-	* [r2052] source/headers/geos/algorithm/locate,
-	  source/headers/geos/algorithm/locate/PointOnGeometryLocator.h:
-	  New namaspace geos::algorithm::locate, as in JTS 1.9..
+	* [r2052] New namaspace geos::algorithm::locate, as in JTS 1.9..
 2007-12-21 19:52  Ben Jubb <benjubb at refractions.net>
-	* [r2051] source/headers/geos/algorithm/SimplePointInAreaLocator.h:
-	  Added a public constructor, and a method to bring in line with
-	  JTS 1.9. Changed namespace to geos::algorithm::locate
+	* [r2051] Added a public constructor, and a method to bring in line
+	  with JTS 1.9. Changed namespace to geos::algorithm::locate
 2007-12-21 18:44  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2050] configure.in: version numbering for next release (3.1.0)
+	* [r2050] version numbering for next release (3.1.0)
 2007-12-21 18:41  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2046] ChangeLog, configure.in: 3.0.0 release
+	* [r2046] 3.0.0 release
 2007-12-19 20:18  Mateusz Loskot <mateusz at loskot.net>
-	* [r2045] ChangeLog, source/headers/geos/geom.h,
-	  source/headers/geos/io.h: Improved warning message about using
-	  DEPRECATED headers
+	* [r2045] Improved warning message about using DEPRECATED headers
 2007-12-17 23:09  Mateusz Loskot <mateusz at loskot.net>
-	* [r2044] tests/xmltester/XMLTester.cpp: Fixed std::tolower usage
-	  in XMLTester.cpp (Ticket #163).
+	* [r2044] Fixed std::tolower usage in XMLTester.cpp (Ticket #163).
 2007-12-17 23:05  Mateusz Loskot <mateusz at loskot.net>
-	* [r2043] source/algorithm/HCoordinate.cpp: Replaced finite
-	  function with std::numeric_limits (Ticket #162).
+	* [r2043] Replaced finite function with std::numeric_limits (Ticket
+	  #162).
 2007-12-17 21:52  Mateusz Loskot <mateusz at loskot.net>
-	* [r2042] ChangeLog, source/Makefile.vc: source\Makefile.vc: Fixed
-	  MSVC_VER condition for Microsoft Visual C++ 2008 (9.0).
+	* [r2042] source\Makefile.vc: Fixed MSVC_VER condition for
+	  Microsoft Visual C++ 2008 (9.0).
 2007-12-13 16:11  Mateusz Loskot <mateusz at loskot.net>
-	* [r2041] ChangeLog: Added Id keyword at the top of ChangeLog file.
+	* [r2041] Added Id keyword at the top of ChangeLog file.
 2007-12-13 16:09  Mateusz Loskot <mateusz at loskot.net>
-	* [r2040] ChangeLog, build/msvc80/geos_unit/geos_unit.vcproj,
-	  source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
-	  tests/unit/geom/GeometryFactoryTest.cpp: *
-	  build\msvc80\geos_unit\geos_unit.vcproj: fixed post-build event
+	* [r2040] * build\msvc80\geos_unit\geos_unit.vcproj: fixed
+	  post-build event
 	  * source\geom\GeometryCollection.cpp: removed unreachable code,
 	  shorten exception message.
 	  * source\geom\Geometry.cpp: purified condition based on
@@ -5479,456 +3403,343 @@
 2007-12-09 00:02  Mateusz Loskot <mateusz at loskot.net>
-	* [r2038] ChangeLog, tests/unit/Makefile.am,
-	  Added test suite for class
+	* [r2038] Added test suite for class
 	  geos::precision::SimpleGeometryPrecisionReducer.
 2007-12-08 22:59  Mateusz Loskot <mateusz at loskot.net>
-	* [r2037] .: Updated svn:keyword property.
+	* [r2037] Updated svn:keyword property.
 2007-11-26 16:26  Mateusz Loskot <mateusz at loskot.net>
-	* [r2036] build/msvc80/geos.vsprops: Added geos.vsprops - property
-	  sheet for Visual C++ projects.
+	* [r2036] Added geos.vsprops - property sheet for Visual C++
+	  projects.
 2007-11-26 15:19  Mateusz Loskot <mateusz at loskot.net>
-	* [r2035] ChangeLog, build/msvc80/geos_python/geos_python.vcproj,
-	  build/msvc80/geos_ruby/geos_ruby.vcproj,
-	  swig/python/geos_wrap.cxx: Added common Property Sheet for Visual
-	  C++ projects where Python and Ruby macros/locations are defined.
-	  Fixed include of Python.h, see Ticket #164 for details.
+	* [r2035] Added common Property Sheet for Visual C++ projects where
+	  Python and Ruby macros/locations are defined. Fixed include of
+	  Python.h, see Ticket #164 for details.
 2007-11-26 06:21  Mateusz Loskot <mateusz at loskot.net>
-	* [r2034] source/algorithm: Updated svn:ignore patterns.
+	* [r2034] Updated svn:ignore patterns.
 2007-11-26 06:16  Mateusz Loskot <mateusz at loskot.net>
-	* [r2033] ChangeLog, source/Makefile.vc,
-	  source/headers/geos/version.h.vc: Enabled target copying
-	  version.h.vc and geos_c.h.vc to headers used by Visual C++. Added
-	  test if version.h.vc is used with Visual C++.
+	* [r2033] Enabled target copying version.h.vc and geos_c.h.vc to
+	  headers used by Visual C++. Added test if version.h.vc is used
+	  with Visual C++.
 2007-11-23 02:33  Mateusz Loskot <mateusz at loskot.net>
-	* [r2032] ChangeLog, source/headers/geos/io/WKBWriter.h: A bit of
-	  purification with explicit casting int to bool type.
+	* [r2032] A bit of purification with explicit casting int to bool
+	  type.
 2007-11-02 22:41  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2031] web/index.html: urls updated to point to osgeo locations
+	* [r2031] urls updated to point to osgeo locations
 2007-11-02 22:17  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2030] web, web/index.html, web/style.css: add the web site
-	  content to svn for collaborative management
+	* [r2030] add the web site content to svn for collaborative
+	  management
 2007-09-21 17:42  Charlie Savage <cfis at savagexi.com>
-	* [r2029] configure.in: Update the CAPI and GEOS version numbers
-	  based on Reader/Writer additions to the CAPI and EWKB support for
-	  the C++ api.
+	* [r2029] Update the CAPI and GEOS version numbers based on
+	  Reader/Writer additions to the CAPI and EWKB support for the C++
+	  api.
 2007-09-21 17:40  Charlie Savage <cfis at savagexi.com>
-	* [r2028] swig/geos.i.in, swig/ruby/geos_wrap.cxx,
-	  swig/ruby/ruby.i, swig/ruby/test/test_buffer.rb,
-	  swig/ruby/test/test_helper.rb, swig/ruby/test/test_io.rb,
-	  swig/ruby/test/test_operations.rb, swig/ruby/test/test_srid.rb,
-	  swig/ruby/test/test_version.rb: Updated the SWIG bindings and
-	  tests to use the new Reader/Writer classes exposed in the CAPI.
+	* [r2028] Updated the SWIG bindings and tests to use the new
+	  Reader/Writer classes exposed in the CAPI.
-	* [r2027] capi/geos_c.cpp, capi/geos_c.h.in: Update the CAPI to
-	  expose WKTReader/WBTWriter and WKBReader/WBKWriter in the CAPI.
-	  This is an improvement over the existing API since it avoids the
-	  use of the static variable used to control byte order and # of
-	  dimenions, and gives clients more control over the
-	  creation/destruction of readers and writers. Finally, exposed the
-	  ability to output the EWKB format (set SRID to true in the
-	  WKBWriter).
+	* [r2027] Update the CAPI to expose WKTReader/WBTWriter and
+	  WKBReader/WBKWriter in the CAPI. This is an improvement over the
+	  existing API since it avoids the use of the static variable used
+	  to control byte order and # of dimenions, and gives clients more
+	  control over the creation/destruction of readers and writers.
+	  Finally, exposed the ability to output the EWKB format (set SRID
+	  to true in the WKBWriter).
 2007-09-21 17:35  Charlie Savage <cfis at savagexi.com>
-	* [r2026] source/index/strtree/STRtree.cpp: Switched back to using
-	  < because the fuzzy comparison now in use trips assertion errors
-	  in VC++. See comments in code for more information. Note this
-	  change may cause problems. Strk left a note in the code saying
-	  that the '<' comparison sometimes gives unstable results. But
-	  that seems better than an assertion failure.
+	* [r2026] Switched back to using < because the fuzzy comparison now
+	  in use trips assertion errors in VC++. See comments in code for
+	  more information. Note this change may cause problems. Strk left
+	  a note in the code saying that the '<' comparison sometimes gives
+	  unstable results. But that seems better than an assertion
+	  failure.
 2007-09-21 17:32  Charlie Savage <cfis at savagexi.com>
-	* [r2025] source/headers/geos/io/WKBWriter.h,
-	  source/io/WKBWriter.cpp: Updated the WKBWriter so it can output
-	  EWKB format similar to PostGIS. Also added a few getter/setter
-	  methods that allow clients to specify the reader's number of
-	  dimensions, byte order and whether srid values should be output.
-	  These getters/setters make it easier to wrap the reader in the
-	  CAPI.
+	* [r2025] Updated the WKBWriter so it can output EWKB format
+	  similar to PostGIS. Also added a few getter/setter methods that
+	  allow clients to specify the reader's number of dimensions, byte
+	  order and whether srid values should be output. These
+	  getters/setters make it easier to wrap the reader in the CAPI.
 2007-09-14 15:34  Charlie Savage <cfis at savagexi.com>
-	* [r2024] build/msvc80/geos_c_dll/geos_c_dll.vcproj,
-	  build/msvc80/geos_ruby, build/msvc80/geos_ruby/geos_ruby.vcproj:
+	* [r2024]
-	* [r2023] build/msvc80/geos_python: Told SVN to ignore MSCV++
-	  Python swig build directories.
+	* [r2023] Told SVN to ignore MSCV++ Python swig build directories.
 2007-09-14 15:25  Charlie Savage <cfis at savagexi.com>
-	* [r2022] source/io/WKBReader.cpp: Set unknown SRID values to 0
-	  instead of -1 to be more consistent with the rest of GEOS (srid
-	  values are initialized to 0 by default).
+	* [r2022] Set unknown SRID values to 0 instead of -1 to be more
+	  consistent with the rest of GEOS (srid values are initialized to
+	  0 by default).
 2007-09-11 02:02  Charlie Savage <cfis at savagexi.com>
-	* [r2021] source/headers/geos/profiler.h: Don't include config.h
-	  for MSVC++ builds.
+	* [r2021] Don't include config.h for MSVC++ builds.
 2007-09-07 17:32  Charlie Savage <cfis at savagexi.com>
-	* [r2020] configure.in: The test for SWIG was incorrect. Fixed by
-	  patch from Mark Cave-Ayland.
+	* [r2020] The test for SWIG was incorrect. Fixed by patch from Mark
+	  Cave-Ayland.
 2007-09-06 23:24  Charlie Savage <cfis at savagexi.com>
-	* [r2019] source/headers/geos/profiler.h: Applied patch from Mark
-	  Cave-Ayland's to make older versions of MingW that don't have
-	  struct timezone defined compile again. Also fixed issues with
-	  more recent versions of MingW that don't correctly compile with
-	  the -ansi compiler switch.
+	* [r2019] Applied patch from Mark Cave-Ayland's to make older
+	  versions of MingW that don't have struct timezone defined compile
+	  again. Also fixed issues with more recent versions of MingW that
+	  don't correctly compile with the -ansi compiler switch.
 2007-09-06 23:22  Charlie Savage <cfis at savagexi.com>
-	* [r2018] configure.in, macros/ruby.m4: Applied patches from Mark
-	  Cave-Ayland's that reorganize/improve the SWIG support in the
-	  generated configure file.\
+	* [r2018] Applied patches from Mark Cave-Ayland's that
+	  reorganize/improve the SWIG support in the generated configure
+	  file.\
 2007-08-31 20:44  Charlie Savage <cfis at savagexi.com>
-	* [r2017] capi/geos_c.cpp, capi/geos_c.h.in: For MSVC++ builds the
-	  CAPI version was set in geos_c.cpp instead of geos_c.h and it was
-	  set incorrectly. This patch fixes the MSVC++ version number and
-	  centralizes the various versoin #defines in the geos_c.h.
+	* [r2017] For MSVC++ builds the CAPI version was set in geos_c.cpp
+	  instead of geos_c.h and it was set incorrectly. This patch fixes
+	  the MSVC++ version number and centralizes the various versoin
+	  #defines in the geos_c.h.
 2007-08-31 20:18  Charlie Savage <cfis at savagexi.com>
-	* [r2016] swig/python/Makefile.am, swig/ruby/Makefile.am: Update
-	  swig makefiles to make the wrappers dependent on the SWIG
-	  interface files even if SWIG is disabled. Doing this means that
-	  Make will correctly recognize that a user has modified an I file,
-	  but that the .cxx wrapper cannot be regenerated since SWIG is not
-	  available.
+	* [r2016] Update swig makefiles to make the wrappers dependent on
+	  the SWIG interface files even if SWIG is disabled. Doing this
+	  means that Make will correctly recognize that a user has modified
+	  an I file, but that the .cxx wrapper cannot be regenerated since
+	  SWIG is not available.
 2007-08-30 20:06  Charlie Savage <cfis at savagexi.com>
-	* [r2015] source/headers/geos/profiler.h,
-	  source/headers/geos/timeval.h: MingW now includes the
-	  gettimeofday function - so reworked includes to only use custom
-	  version when building with VC++.
+	* [r2015] MingW now includes the gettimeofday function - so
+	  reworked includes to only use custom version when building with
+	  VC++.
 2007-08-30 17:00  Charlie Savage <cfis at savagexi.com>
-	* [r2014] macros/ruby.m4, swig/ruby/Makefile.am: Added RUBY_BIN_DIR
-	  to autoconf macros - simplified auto make input file for ruby
-	  bindings.
+	* [r2014] Added RUBY_BIN_DIR to autoconf macros - simplified auto
+	  make input file for ruby bindings.
 2007-08-30 06:19  Charlie Savage <cfis at savagexi.com>
-	* [r2013] macros/ac_pkg_swig.m4: The last attempt to fix this file
-	  failed - instead keep the code that queries the swig libraries
-	  but use sed to merge multiple lines together. If this is not
-	  done, then the swig output causes ./configure to blow up on msys.
+	* [r2013] The last attempt to fix this file failed - instead keep
+	  the code that queries the swig libraries but use sed to merge
+	  multiple lines together. If this is not done, then the swig
+	  output causes ./configure to blow up on msys.
 2007-08-30 05:31  Charlie Savage <cfis at savagexi.com>
-	* [r2012] macros/ac_pkg_swig.m4: Fixes sed issue with swig on msys.
-	  For more info see:
+	* [r2012] Fixes sed issue with swig on msys. For more info see:
 	  http://lists.refractions.net/pipermail/geos-devel/2007-August/002956.html
 2007-08-30 03:18  Charlie Savage <cfis at savagexi.com>
-	* [r2011] swig/geos.i.in: Changed from dos to unix line feeds.
+	* [r2011] Changed from dos to unix line feeds.
 2007-08-29 01:41  Charlie Savage <cfis at savagexi.com>
-	* [r2010] build/msvc80/geos.sln, build/msvc80/geos_python,
-	  build/msvc80/geos_python/geos_python.vcproj,
-	  build/msvc80/geos_ruby/geos_ruby.vcproj: New VC++ project for the
-	  python SWIG bindings.
+	* [r2010] New VC++ project for the python SWIG bindings.
 2007-08-29 01:29  Charlie Savage <cfis at savagexi.com>
-	* [r2009] build/msvc80/geos_ruby/geos_ruby.vcproj, swig/geos.i.in,
-	  swig/python/python.i, swig/ruby/geos_wrap.cxx, swig/ruby/ruby.i:
-	  Ruby SWIG bindings - mapped eql? to == so that you can do point
-	  == point2 in ruby. Removed a hard-coded path from VC++ project.
-	  Updated out-of-date copyright notices for no particularly good
-	  reason.
+	* [r2009] Ruby SWIG bindings - mapped eql? to == so that you can do
+	  point == point2 in ruby. Removed a hard-coded path from VC++
+	  project. Updated out-of-date copyright notices for no
+	  particularly good reason.
 2007-08-28 21:29  Charlie Savage <cfis at savagexi.com>
-	* [r2008] build/msvc80: Added release as an ignored directory for
-	  VC++, similar to the debug directory.
+	* [r2008] Added release as an ignored directory for VC++, similar
+	  to the debug directory.
 2007-08-28 21:28  Charlie Savage <cfis at savagexi.com>
-	* [r2007] build/msvc80/geos_ruby: Added new ruby VC++ project to
-	  solution file.
+	* [r2007] Added new ruby VC++ project to solution file.
 2007-08-28 21:27  Charlie Savage <cfis at savagexi.com>
-	* [r2006] capi/geos_c.h.in: Fixed c api include for VC++ - it
-	  should be #include <geos/version.h> instead of #include
-	  <version.h>.
+	* [r2006] Fixed c api include for VC++ - it should be #include
+	  <geos/version.h> instead of #include <version.h>.
-	* [r2005] build/msvc80/geos.sln: Added new ruby VC++ project to
-	  solution file.
+	* [r2005] Added new ruby VC++ project to solution file.
 2007-08-28 21:26  Charlie Savage <cfis at savagexi.com>
-	* [r2004] build/msvc80/geos_c_dll/geos_c_dll.vcproj: Follow lead of
-	  geos_lib project - copy geos/geos_c.h.in to geos/geos_c.h when
-	  building with VC++.
+	* [r2004] Follow lead of geos_lib project - copy geos/geos_c.h.in
+	  to geos/geos_c.h when building with VC++.
 2007-08-28 21:25  Charlie Savage <cfis at savagexi.com>
-	* [r2003] build/msvc80/geos_ruby,
-	  build/msvc80/geos_ruby/geos_ruby.vcproj: Added new vc++ project
-	  for building ruby bindings. Its not perfect since it hard-codes
-	  the path to Ruby, but its enough to get one started.
+	* [r2003] Added new vc++ project for building ruby bindings. Its
+	  not perfect since it hard-codes the path to Ruby, but its enough
+	  to get one started.
 2007-08-28 21:22  Charlie Savage <cfis at savagexi.com>
-	* [r2002] swig/python/geos.py, swig/python/geos_wrap.cxx,
-	  swig/ruby/geos_wrap.cxx: Updated SWIG wrappers based on changed
-	  interface file. Also generated with SWIG 1.3.31
+	* [r2002] Updated SWIG wrappers based on changed interface file.
+	  Also generated with SWIG 1.3.31
 2007-08-28 20:42  Charlie Savage <cfis at savagexi.com>
-	* [r2001] swig/ruby/test/geos_tests.rb,
-	  swig/ruby/test/test_buffer.rb,
-	  swig/ruby/test/test_combinations.rb,
-	  swig/ruby/test/test_coordinate_sequence.rb,
-	  swig/ruby/test/test_envelope.rb, swig/ruby/test/test_geometry.rb,
-	  swig/ruby/test/test_io.rb, swig/ruby/test/test_operations.rb,
-	  swig/ruby/test/test_relations.rb, swig/ruby/test/test_srid.rb,
-	  swig/ruby/test/test_version.rb: SWIG bindings - updated Ruby
-	  tests based on name changes.
+	* [r2001] SWIG bindings - updated Ruby tests based on name changes.
 2007-08-28 20:41  Charlie Savage <cfis at savagexi.com>
-	* [r2000] swig/ruby/ruby.i: Updated Ruby swig bindings to more
-	  closely match Ruby style names. So eql? instead of equals,
-	  dimensions instead of get_dimensions, etc.
+	* [r2000] Updated Ruby swig bindings to more closely match Ruby
+	  style names. So eql? instead of equals, dimensions instead of
+	  get_dimensions, etc.
 2007-08-28 20:40  Charlie Savage <cfis at savagexi.com>
-	* [r1999] swig/geos.i.in: Exposed Geometry::Clone method in SWIG
-	  bindings. Added check for NULL string in geomFromWKT wrapper.
+	* [r1999] Exposed Geometry::Clone method in SWIG bindings. Added
+	  check for NULL string in geomFromWKT wrapper.
 2007-08-23 20:35  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r1998] source/operation/buffer/BufferBuilder.cpp,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp,
-	  source/operation/buffer/OffsetCurveVertexList.h: Memory leak
-	  patches from Robert Coup
+	* [r1998] Memory leak patches from Robert Coup
 2007-08-22 23:45  Mateusz Loskot <mateusz at loskot.net>
-	* [r1997] source/headers/geos/io/ByteOrderDataInStream.inl,
-	  source/operation/overlay/ElevationMatrix.cpp,
-	  source/operation/polygonize/Polygonizer.cpp: Cleaned compilation
-	  warnings from VC++.
+	* [r1997] Cleaned compilation warnings from VC++.
 2007-06-11 07:43  Mateusz Loskot <mateusz at loskot.net>
-	* [r1996] ChangeLog, source/operation/IsSimpleOp.cpp: Replaced
-	  post-increment operators with pre-increment operators where
-	  standard iterators are incremented in loops. NOTE: Prefer
-	  pre-incr. over post-inc. when working with standard iterators.
+	* [r1996] Replaced post-increment operators with pre-increment
+	  operators where standard iterators are incremented in loops.
+	  NOTE: Prefer pre-incr. over post-inc. when working with standard
+	  iterators.
 2007-06-11 07:39  Mateusz Loskot <mateusz at loskot.net>
-	* [r1995] tests/unit/Makefile.am,
-	  tests/unit/operation/IsSimpleOpTest.cpp: Added unit test for
-	  geos::operation::IsSimpleOp class.
+	* [r1995] Added unit test for geos::operation::IsSimpleOp class.
 2007-06-10 13:03  Mateusz Loskot <mateusz at loskot.net>
-	* [r1994] ., ChangeLog, tests/unit/Makefile.am: Updated
-	  tests/unit/Makefile.am with new files.
+	* [r1994] Updated tests/unit/Makefile.am with new files.
 2007-06-10 11:53  Mateusz Loskot <mateusz at loskot.net>
-	* [r1993] ChangeLog, build/msvc80/geos.sln,
-	  build/msvc80/geos_unit/geos_unit.vcproj,
-	  tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp,
-	  tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp,
-	  tests/unit/algorithm/ConvexHullTest.cpp: Added unit test for
+	* [r1993] Added unit test for
 	  geos::algorithm::CGAlgorithms::computeOrientation() function.
 2007-06-10 11:29  Mateusz Loskot <mateusz at loskot.net>
-	* [r1992] ., capi, source, source/geom, source/geom/util,
-	  source/geomgraph, source/geomgraph/index, source/index/bintree,
-	  source/index/chain, source/index/quadtree, source/index/strtree,
-	  source/index/sweepline, source/io, source/noding,
-	  source/noding/snapround, source/operation,
-	  source/operation/buffer, source/operation/distance,
-	  source/operation/linemerge, source/operation/overlay,
-	  source/operation/polygonize, source/operation/predicate,
-	  source/operation/relate, source/operation/valid,
-	  source/planargraph, source/planargraph/algorithm,
-	  source/precision, source/simplify, source/util: Updated
-	  svn:ignore property for the whole tree adding VC++ and Windows
-	  specific patterns.
+	* [r1992] Updated svn:ignore property for the whole tree adding
+	  VC++ and Windows specific patterns.
 2007-06-10 11:18  Mateusz Loskot <mateusz at loskot.net>
-	* [r1991] ChangeLog, build/msvc80/geos_unit/geos_unit.vcproj,
-	  tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp: Added unit test
-	  for CGAlgorithms::isCCW() function.
+	* [r1991] Added unit test for CGAlgorithms::isCCW() function.
 2007-06-10 11:08  Mateusz Loskot <mateusz at loskot.net>
-	* [r1990] tests/unit/algorithm/ConvexHullTest.cpp,
-	  tests/unit/geom/LineStringTest.cpp: Added unit test for
-	  geos::algorithm::ConvexHull.
+	* [r1990] Added unit test for geos::algorithm::ConvexHull.
 2007-06-10 11:03  Mateusz Loskot <mateusz at loskot.net>
-	* [r1989] tests/unit/utility.h: Added custom operators for static
-	  and dynamic casts of pointers wrapped with std::auto_ptr<T> type.
+	* [r1989] Added custom operators for static and dynamic casts of
+	  pointers wrapped with std::auto_ptr<T> type.
 2007-06-08 17:13  Mateusz Loskot <mateusz at loskot.net>
-	* [r1988] tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp:
-	  Identified test case failing because of
+	* [r1988] Identified test case failing because of
 	  geos::index::strtree::yComparator() instability.
 2007-06-08 17:10  Mateusz Loskot <mateusz at loskot.net>
-	* [r1987] ChangeLog, source/index/strtree/STRtree.cpp: Analysis of
-	  instability of the yComparator, there are some new important
-	  questions to answer.
+	* [r1987] Analysis of instability of the yComparator, there are
+	  some new important questions to answer.
 2007-06-08 15:27  Mateusz Loskot <mateusz at loskot.net>
-	* [r1986] ChangeLog, build/msvc80/geos_lib/geos_lib.vcproj,
-	  source/algorithm/CGAlgorithms.cpp,
-	  source/algorithm/CentroidArea.cpp,
-	  source/algorithm/CentroidLine.cpp,
-	  source/algorithm/CentroidPoint.cpp,
-	  source/algorithm/HCoordinate.cpp,
-	  source/algorithm/InteriorPointArea.cpp,
-	  source/algorithm/InteriorPointLine.cpp,
-	  source/algorithm/InteriorPointPoint.cpp,
-	  source/algorithm/MinimumDiameter.cpp,
-	  source/algorithm/PointLocator.cpp,
-	  source/algorithm/SIRtreePointInRing.cpp,
-	  source/geom/CoordinateSequence.cpp, source/geomgraph/Edge.cpp,
-	  source/geomgraph/EdgeList.cpp,
-	  source/headers/geos/geom/CoordinateFilter.h,
-	  source/headers/geos/geomgraph/Edge.h,
-	  source/headers/geos/geomgraph/Node.h,
-	  source/headers/geos/index/bintree/Root.h,
-	  source/headers/geos/index/chain/MonotoneChainOverlapAction.h,
-	  source/index/chain/MonotoneChainBuilder.cpp,
-	  source/index/strtree/SIRtree.cpp,
-	  source/index/strtree/STRtree.cpp,
-	  source/index/sweepline/SweepLineIndex.cpp,
-	  source/operation/buffer/BufferSubgraph.cpp: Cleaned
-	  signed/unsigned types mixtures, got rid from annoying compiler
-	  warnings.
+	* [r1986] Cleaned signed/unsigned types mixtures, got rid from
+	  annoying compiler warnings.
 2007-06-08 14:50  Mateusz Loskot <mateusz at loskot.net>
-	* [r1985] ChangeLog: Applied Konstantin Baumann's suggestion about
-	  including version.h in C API header for Visual C++.
+	* [r1985] Applied Konstantin Baumann's suggestion about including
+	  version.h in C API header for Visual C++.
-	* [r1984] capi/geos_c.h.in: Applied Konstantin Baumann's suggestion
-	  about including version.h in C API header for Visual C++.
+	* [r1984] Applied Konstantin Baumann's suggestion about including
 2007-06-01 13:53  Mateusz Loskot <mateusz at loskot.net>
-	* [r1983] ChangeLog, build/bjam, build/bjam/Jamroot,
-	  build/bjam/geos, build/bjam/geos/Jamfile, build/bjam/geos_c,
-	  build/bjam/geos_c/Jamfile, build/bjam/geos_unit,
-	  build/bjam/geos_unit/Jamfile: Added Boost.Build configuration for
-	  GEOS (experimental). The idea is to enable users to build GEOS
-	  with bjam tool from Boost.Build package.
+	* [r1983] Added Boost.Build configuration for GEOS (experimental).
+	  The idea is to enable users to build GEOS with bjam tool from
+	  Boost.Build package.
 2007-06-01 13:43  Mateusz Loskot <mateusz at loskot.net>
-	* [r1982] source/headers/geos/platform.h.vc,
-	  source/headers/geos/version.h.vc,
-	  tests/unit/operation/distance/DistanceOpTest.cpp,
-	  tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp,
-	  tests/unit/operation/overlay/OffsetPointGeneratorTest.cpp,
-	  tests/unit/operation/overlay/OverlayResultValidatorTest.cpp: Set
-	  missing svn:keywords property.
+	* [r1982] Set missing svn:keywords property.
 2007-06-01 13:06  Mateusz Loskot <mateusz at loskot.net>
-	* [r1981] ChangeLog, build/msvc80/geos_lib/geos_lib.vcproj: Applied
-	  patch with pre-build events generating platform.h and version.h
-	  headers. Thanks to Konstantin Baumann for this patch.
+	* [r1981] Applied patch with pre-build events generating platform.h
+	  and version.h headers. Thanks to Konstantin Baumann for this
+	  patch.
 2007-05-06 02:42  Mateusz Loskot <mateusz at loskot.net>
-	* [r1980] build/msvc80, build/msvc80/geos_c_dll,
-	  build/msvc80/geos_lib, build/msvc80/geos_unit: Updated svn:ignore
-	  property for build\msvc80.
+	* [r1980] Updated svn:ignore property for build\msvc80.
 2007-05-06 02:40  Mateusz Loskot <mateusz at loskot.net>
-	* [r1979] ChangeLog, source/headers/geos/version.h.vc: Added
-	  source/headers/geos/version.h.vc file for Visual C++ compiler.
+	* [r1979] Added source/headers/geos/version.h.vc file for Visual
+	  C++ compiler.
 2007-04-22 04:44  Mateusz Loskot <mateusz at loskot.net>
-	* [r1978] ., ChangeLog, capi,
-	  source/geom/CoordinateArraySequence.cpp, swig,
-	  tests/unit/capi/GEOSCoordSeqTest.cpp: Added assertion validating
-	  ordinateIndex in setOrdinate() function. Extended
-	  GEOSCoordSeqTest with swapped and non-swapped calls of
-	  coordiantes assignment functions.
+	* [r1978] Added assertion validating ordinateIndex in setOrdinate()
+	  function. Extended GEOSCoordSeqTest with swapped and non-swapped
+	  calls of coordiantes assignment functions.
 2007-04-15 18:02  Mateusz Loskot <mateusz at loskot.net>
-	* [r1977] ChangeLog, autogen.sh: Added detection of glibtoolize
-	  under Mac OS X.
+	* [r1977] Added detection of glibtoolize under Mac OS X.
 2007-03-05 09:58  Sandro Santilli <strk at keybit.net>
-	* [r1976] ChangeLog, tests/xmltester/Makefile.am,
-	  tests/xmltester/hole_from_shell.xml,
-	  tests/xmltester/hole_red.xml: Add new testcases by Carl Anderson
+	* [r1976] Add new testcases by Carl Anderson
 2007-02-26 10:46  Sandro Santilli <strk at keybit.net>
-	* [r1975] ChangeLog, source/inlines.cpp: Patch by Tom Elwertowski:
+	* [r1975] Patch by Tom Elwertowski:
 	  * source/inlines.cpp: fix for MingW32 builds.
 2007-02-21 10:14  Sandro Santilli <strk at keybit.net>
-	* [r1974] ChangeLog,
-	  source/operation/buffer/SubgraphDepthLocater.cpp: Patch by Carl
-	  Anderson:
+	* [r1974] Patch by Carl Anderson:
 	  * source/operation/buffer/SubgraphDepthLocater.cpp
 	  (findStabbedSegments):
@@ -5939,14 +3750,12 @@
 2007-02-21 10:12  Sandro Santilli <strk at keybit.net>
-	* [r1973] ChangeLog, tests/xmltester/Makefile.am,
-	  tests/xmltester/badguy3.xml: * tests/xmltester/: Makefile.am,
-	  badguy3.xml:
+	* [r1973] * tests/xmltester/: Makefile.am, badguy3.xml:
 	  Added simplified version of nasty buffer bug test.
 2007-02-08 23:33  Sandro Santilli <strk at keybit.net>
-	* [r1972] ChangeLog, configure.in: Patch by Mark Cave-Ayland:
+	* [r1972] Patch by Mark Cave-Ayland:
 	  * configure.in: Allow configure to continue with use_python
 	  set to false if a python binary is not found, as per
@@ -5954,19 +3763,7 @@
 2007-02-07 00:34  Sandro Santilli <strk at keybit.net>
-	* [r1971] ChangeLog,
-	  source/headers/geos/index/strtree/AbstractNode.h,
-	  source/headers/geos/index/strtree/AbstractSTRtree.h,
-	  source/headers/geos/index/strtree/Boundable.h,
-	  source/headers/geos/index/strtree/ItemBoundable.h,
-	  source/headers/geos/index/strtree/SIRtree.h,
-	  source/headers/geos/index/strtree/STRtree.h,
-	  source/index/strtree/AbstractNode.cpp,
-	  source/index/strtree/AbstractSTRtree.cpp,
-	  source/index/strtree/ItemBoundable.cpp,
-	  source/index/strtree/STRtree.cpp: General refactoring aimed at
-	  making the code cleaner
+	* [r1971] General refactoring aimed at making the code cleaner
 	  to read and maintain; use iterators rather then random
 	  accessing containers to allow easy future switch to std::list
 	  from std::vector; use a tolerance-based strict weak ordering
@@ -5975,48 +3772,35 @@
 2007-02-06 02:05  Sandro Santilli <strk at keybit.net>
-	* [r1970] ChangeLog,
-	  tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp: *
+	* [r1970] * tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp:
 	  Expect result of POLYGON simplification to always be
 	  a polygon, even if collapsed to the empty geom.
 2007-02-06 01:57  Sandro Santilli <strk at keybit.net>
-	* [r1969] ChangeLog,
-	  source/headers/geos/operation/buffer/BufferBuilder.h,
-	  source/headers/geos/operation/buffer/BufferOp.h,
-	  source/operation/buffer/BufferOp.cpp: *
-	  operation::buffer::BufferBuilder,
+	* [r1969] * operation::buffer::BufferBuilder,
 	  operation::buffer::BufferOp:
 	  Fixed buffer operation to always return polygonal
 	  geometry
 2007-02-03 02:18  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r1967] ChangeLog, configure.in: 3.0.0rc4 tagging
+	* [r1967] 3.0.0rc4 tagging
 2007-02-01 11:11  Sandro Santilli <strk at keybit.net>
-	* [r1966] ChangeLog,
-	  operation::buffer::BufferOp: set MAX_PRECISION_DIGITS
+	* [r1966] * operation::buffer::BufferOp: set MAX_PRECISION_DIGITS
 	  so to match JTS.
 2007-01-26 01:19  Sandro Santilli <strk at keybit.net>
-	* [r1965] ChangeLog, tests/xmltester/Makefile.am,
-	  tests/xmltester/stmlf-cases-20070119.xml: * tests/xmltester/:
-	  Makefile.am, stmlf-cases-20070119.xml:
+	* [r1965] * tests/xmltester/: Makefile.am,
+	  stmlf-cases-20070119.xml:
 	  New overlay test.
 2007-01-26 00:57  Sandro Santilli <strk at keybit.net>
-	* [r1964] ChangeLog, source/operation/buffer/BufferBuilder.cpp,
-	  tests/xmltester/XMLTester.cpp: * tests/xmltester/XMLTester.cpp:
-	  improved buffer
+	* [r1964] * tests/xmltester/XMLTester.cpp: improved buffer
 	  result validator.
 	  * source/operation/buffer/BufferBuilder.cpp (computeNodedEdges):
 	  remove repeated points from noded SegmentStrings, skip collapsed
@@ -6024,40 +3808,28 @@
 2007-01-17 11:59  Sandro Santilli <strk at keybit.net>
-	* [r1963] ChangeLog, tests/xmltester/Makefile.am,
-	  tests/xmltester/heisenbugs.xml: New testcase for bug fixed by
-	  previous commit.
+	* [r1963] New testcase for bug fixed by previous commit.
 2007-01-17 01:05  Sandro Santilli <strk at keybit.net>
-	* [r1962] ChangeLog, source/index/strtree/STRtree.cpp: *
-	  source/index/strtree/STRtree.cpp (yComparator):
+	* [r1962] * source/index/strtree/STRtree.cpp (yComparator):
 	  Use static_cast<> and make code more readable.
 	  A side effect seems to be fixing a segfault :!
 2007-01-17 00:45  Sandro Santilli <strk at keybit.net>
-	* [r1961] ChangeLog, source/headers/geos/index/strtree/STRtree.h: *
-	  source/headers/geos/index/strtree/STRtree.h (centreY):
+	* [r1961] * source/headers/geos/index/strtree/STRtree.h (centreY):
 	  const-corrected.
 2007-01-16 14:12  Sandro Santilli <strk at keybit.net>
-	* [r1960] ChangeLog, tests/xmltester/XMLTester.cpp,
-	  tests/xmltester/XMLTester.h: * tests/xmltester/XMLTester.cpp:
-	  don't include catch-all headers.
+	* [r1960] * tests/xmltester/XMLTester.cpp: don't include catch-all
+	  headers.
 2007-01-09 17:34  Sandro Santilli <strk at keybit.net>
-	* [r1959] ChangeLog,
-	  source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
-	  source/operation/buffer/Makefile.am,
-	  source/operation/buffer/OffsetCurveBuilder.cpp,
-	  source/operation/buffer/OffsetCurveVertexList.h,
-	  tests/xmltester/Makefile.am,
-	  tests/xmltester/TestBufferExternal.xml,
-	  tests/xmltester/XMLTester.cpp: * source/operation/buffer/:
-	  Makefile.am, OffsetCurveVertexList.h:
+	* [r1959] * source/operation/buffer/: Makefile.am,
+	  OffsetCurveVertexList.h:
 	  New helper class for OffsetCurveBuilder
 	  * operation::buffer::OffsetCurveBuilder:
 	  Move vertexlist management to external class.
@@ -6072,10 +3844,7 @@
 2007-01-09 15:08  Sandro Santilli <strk at keybit.net>
-	* [r1958] ChangeLog, source/geom/CoordinateArraySequence.cpp,
-	  source/headers/geos/geom/CoordinateArraySequence.h,
-	  source/headers/geos/geom/CoordinateSequence.h: *
+	* [r1958] * source/geom/CoordinateArraySequence.cpp,
 	  source/headers/geos/geom/CoordinateSequence.h,
 	  source/headers/geos/geom/CoordinateArraySequence.h:
 	  add(Coordinate, bool) made a virtual method and overrridden
@@ -6085,50 +3854,43 @@
 2007-01-09 10:27  Sandro Santilli <strk at keybit.net>
-	* [r1957] ChangeLog, tests/xmltester/XMLTester.cpp: *
-	  tests/xmltester/XMLTester.cpp: add areatest to buffer test
-	  handler.
+	* [r1957] * tests/xmltester/XMLTester.cpp: add areatest to buffer
+	  test handler.
 2007-01-05 01:01  Sandro Santilli <strk at keybit.net>
-	* [r1956] ChangeLog, configure.in: * configure.in: prepared for
-	  version to 3.0.0rc4,
+	* [r1956] * configure.in: prepared for version to 3.0.0rc4,
 	  fixed swig python errors as suggested by hint
 	  (AM_PATH_PYTHON).
 2007-01-04 22:43  Sandro Santilli <strk at keybit.net>
-	* [r1955] ChangeLog, configure.in, swig/geos.i, swig/geos.i.in: *
-	  configure.in, swig/geos.i.in, swig/geos.i:
+	* [r1955] * configure.in, swig/geos.i.in, swig/geos.i:
 	  geos.i generated at configure time from geos.i.in
 	  (so we don't have to manually update versions there).
 2007-01-04 22:38  Sandro Santilli <strk at keybit.net>
-	* [r1954] ChangeLog, swig/geos.i: Patch by dev-zero at gentoo dot
-	  org:
+	* [r1954] Patch by dev-zero at gentoo dot org:
 	  * swig/geos.i: use unsigned int when CAPI signatures
 	  expect unsigned int (not size_t).
 2007-01-03 20:11  Sandro Santilli <strk at keybit.net>
-	* [r1953] ChangeLog, tests/xmltester/Makefile.am,
-	  tests/xmltester/fme.xml: * tests/xmltester/: fme.xml,
-	  Makefile.am: added buffer testcase.
+	* [r1953] * tests/xmltester/: fme.xml, Makefile.am: added buffer
+	  testcase.
 2007-01-03 20:06  Sandro Santilli <strk at keybit.net>
-	* [r1952] ChangeLog, tests/xmltester/XMLTester.cpp: *
-	  tests/xmltester/XMLTester.cpp: use a tolerance of 10E-6
+	* [r1952] * tests/xmltester/XMLTester.cpp: use a tolerance of 10E-6
 	  for buffer validation (~10cm at worst when using latlong
 	  projections); create sql tables with oid to work around a
 	  bug in qgis 0.7.4.
 2007-01-03 19:18  Sandro Santilli <strk at keybit.net>
-	* [r1951] ChangeLog, source/algorithm/HCoordinate.cpp,
-	  source/inlines.cpp: Applied patch by Mark Cave-Ayland
+	* [r1951] Applied patch by Mark Cave-Ayland
 	  <mark.cave-ayland at ilande.co.uk>:
 	  * source/inlines.cpp, source/algorithm/HCoordinate.cpp:
@@ -6136,86 +3898,58 @@
 2007-01-03 14:56  Sandro Santilli <strk at keybit.net>
-	* [r1950] ChangeLog, source/operation/buffer/BufferOp.cpp: *
-	  source/operation/buffer/BufferOp.cpp (bufferReducedPrecision):
+	* [r1950] * source/operation/buffer/BufferOp.cpp
+	  (bufferReducedPrecision):
 	  Fixed computation of reduced PrecisionModel scale.
 2006-12-18 20:04  Sandro Santilli <strk at keybit.net>
-	* [r1949] ChangeLog, tests/xmltester/robustness.xml: *
-	  tests/xmltester/robustness.xml: added
+	* [r1949] * tests/xmltester/robustness.xml: added
 	  testcase reported to fail with 2.2.3 on
 	  postgis-users/2006-November/014013.html.
 2006-12-18 18:44  Sandro Santilli <strk at keybit.net>
-	* [r1948] ChangeLog, source/headers/geos/geom/BinaryOp.h,
-	  source/headers/geos/precision/GeometrySnapper.h,
-	  source/precision/GeometrySnapper.cpp: Geometry snapping synced
-	  with JTS.
+	* [r1948] Geometry snapping synced with JTS.
 2006-12-18 14:27  Sandro Santilli <strk at keybit.net>
-	* [r1947] ChangeLog, HOWTO_RELEASE: * HOWTO_RELEASE: add
-	  ChangeLog's release mark step.
+	* [r1947] * HOWTO_RELEASE: add ChangeLog's release mark step.
 2006-12-18 14:19  Sandro Santilli <strk at keybit.net>
-	* [r1946] ChangeLog, source/precision/GeometrySnapper.cpp,
-	  tests/xmltester/TestRobustOverlayFixed.xml: *
-	  source/precision/GeometrySnapper.cpp (computeSnapTolerance):
+	* [r1946] * source/precision/GeometrySnapper.cpp
+	  (computeSnapTolerance):
 	  properly compute snap tolerance for fixed precision geometries.
 	  * tests/xmltester/: Makefile.am, TestRobustOverlayFixed.xml:
 	  new test for fixed precision snapping.
 2006-12-15 10:50  Sandro Santilli <strk at keybit.net>
-	* [r1945] ChangeLog: release 3.0.0rc3 marked
+	* [r1945] release 3.0.0rc3 marked
 2006-12-14 19:12  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r1943] configure.in: bumped version numbers for 3.0.0rc3
+	* [r1943] bumped version numbers for 3.0.0rc3
 2006-12-13 11:05  Mateusz Loskot <mateusz at loskot.net>
-	* [r1942] ChangeLog, build/msvc80/geos_lib/geos_lib.vcproj,
-	  source/Makefile.vc: Updated makefile and project files for Visual
-	  C++.
+	* [r1942] Updated makefile and project files for Visual C++.
 2006-12-13 10:55  Sandro Santilli <strk at keybit.net>
-	* [r1941] ChangeLog,
-	  source/headers/geos/operation/overlay/FuzzyPointLocator.h,
-	  source/headers/geos/operation/overlay/OffsetPointGenerator.h,
-	  source/headers/geos/operation/overlay/OverlayResultValidator.h,
-	  source/operation/overlay/OffsetPointGenerator.cpp,
-	  source/operation/overlay/OverlayResultValidator.cpp: Updated port
-	  information.
+	* [r1941] Updated port information.
 2006-12-13 10:51  Sandro Santilli <strk at keybit.net>
-	* [r1940] ChangeLog,
-	  source/headers/geos/precision/LineStringSnapper.h,
-	  source/precision/LineStringSnapper.cpp: *
-	  precision::GeometrySnapper, precision::LineStringSnapper:
+	* [r1940] * precision::GeometrySnapper,
+	  precision::LineStringSnapper:
 2006-12-11 17:42  Sandro Santilli <strk at keybit.net>
-	* [r1939] ChangeLog,
-	  source/headers/geos/geomgraph/EdgeNodingValidator.h,
-	  source/headers/geos/noding/FastNodingValidator.h,
-	  source/headers/geos/noding/Makefile.am,
-	  source/noding/MCIndexNoder.cpp, source/noding/Makefile.am,
-	  source/noding/SingleInteriorIntersectionFinder.cpp: *
-	  source/headers/geos/noding/SegmentIntersector.h: added virtual
+	* [r1939] * source/headers/geos/noding/SegmentIntersector.h: added
+	  virtual
 	  isDone() function, always returning false by default.
 	  * source/noding/MCIndexNoder.cpp (intersectChains):
 	  short-circuit from JTS-1.8, based on the new
@@ -6232,48 +3966,36 @@
 2006-12-07 10:45  Sandro Santilli <strk at keybit.net>
-	* [r1938] ChangeLog, source/algorithm/LineIntersector.cpp,
-	  source/headers/geos/algorithm/CentralEndpointIntersector.h,
-	  source/headers/geos/algorithm/LineIntersector.h,
-	  source/headers/geos/algorithm/Makefile.am: *
-	  source/headers/geos/algorithm/: CentralEndpointIntersector.h,
+	* [r1938] * source/headers/geos/algorithm/:
+	  CentralEndpointIntersector.h,
 	  Makefile.am: new port from JTS-1.8.
 	  * algorithm::LineIntersector: robustness improvements
 	  from JTS-1.8.
 2006-12-05 11:22  Mateusz Loskot <mateusz at loskot.net>
-	* [r1937] tests/unit/capi/GEOSCoordSeqTest.cpp,
-	  tests/unit/capi/GEOSSimplifyTest.cpp: Fixed indentantion in
-	  tests/unit/capi.
+	* [r1937] Fixed indentantion in tests/unit/capi.
 2006-12-05 11:10  Mateusz Loskot <mateusz at loskot.net>
-	* [r1936] ChangeLog: Fixed typos in changelog.
+	* [r1936] Fixed typos in changelog.
 2006-12-05 11:05  Mateusz Loskot <mateusz at loskot.net>
-	* [r1935] tests/unit/capi/GEOSCoordSeqTest.cpp,
-	  tests/unit/capi/GEOSSimplifyTest.cpp: Set svn:keyword property on
-	  CAPI tests.
+	* [r1935] Set svn:keyword property on CAPI tests.
 2006-12-05 11:02  Mateusz Loskot <mateusz at loskot.net>
-	* [r1934] ChangeLog, tests/unit/capi/GEOSCoordSeqTest.cpp,
-	  tests/unit/capi/GEOSSimplifyTest.cpp,
-	  tests/unit/util/UniqueCoordinateArrayFilterTest.cpp: Purifying
-	  CAPI unit tests.
+	* [r1934] Purifying CAPI unit tests.
 2006-12-05 10:59  Mateusz Loskot <mateusz at loskot.net>
-	* [r1933] build/msvc80/geos_unit/geos_unit.vcproj: Added CAPI tests
-	  to VC++ project.
+	* [r1933] Added CAPI tests to VC++ project.
 2006-12-05 10:42  Sandro Santilli <strk at keybit.net>
-	* [r1932] ChangeLog, source/headers/geos/geom/BinaryOp.h,
-	  source/operation/overlay/OverlayOp.cpp: *
-	  source/operation/overlay/OverlayOp.cpp: Use EdgeNodingValidator
+	* [r1932] * source/operation/overlay/OverlayOp.cpp: Use
+	  EdgeNodingValidator
 	  instead of OverlayResultValidator (faster and more effective).
 	  Note that compile-time defines can select use of either or both
 	  ones.
@@ -6282,34 +4004,24 @@
 2006-12-05 09:59  Sandro Santilli <strk at keybit.net>
-	* [r1931] ChangeLog, source/headers/geos/noding/NodingValidator.h,
-	  source/noding/NodingValidator.cpp: * noding::NodingValidator.h:
-	  throw TopologyException
+	* [r1931] * noding::NodingValidator.h: throw TopologyException
 	  rather then a generic GEOSException.
 2006-12-04 12:41  Sandro Santilli <strk at keybit.net>
-	* [r1930] ChangeLog,
-	  source/headers/geos/geomgraph/EdgeNodingValidator.h: *
+	* [r1930] * source/headers/geos/geomgraph/EdgeNodingValidator.h:
 	  fix members initialization order.
 2006-12-04 11:38  Sandro Santilli <strk at keybit.net>
-	* [r1929] ChangeLog, source/geomgraph/EdgeNodingValidator.cpp,
-	  geomgraph::EdgeNodingValidator: minor cleanup
+	* [r1929] * geomgraph::EdgeNodingValidator: minor cleanup
 	  to use references args instead of pointers for
 	  method that doesn't handle NULLs anyway.
 2006-12-04 10:31  Sandro Santilli <strk at keybit.net>
-	* [r1928] ChangeLog,
-	  source/simplify/DouglasPeuckerLineSimplifier.cpp,
-	  tests/unit/Makefile.am, tests/unit/capi/GEOSCoordSeq.cpp,
-	  tests/unit/capi/GEOSCoordSeqTest.cpp,
-	  tests/unit/capi/GEOSSimplifyTest.cpp: * tests/unit/capi/:
-	  GEOSCoordSeq.cpp => GEOSCoordSeqTest.cpp
+	* [r1928] * tests/unit/capi/: GEOSCoordSeq.cpp =>
+	  GEOSCoordSeqTest.cpp
 	  * tests/unit/capi/GEOSSimplifyTest.cpp: new test
 	  for GEOSSimplify (just a test for bug #134).
 	  * source/simplify/DouglasPeuckerLineSimplifier.cpp (simplify):
@@ -6317,82 +4029,62 @@
 2006-12-04 10:14  Sandro Santilli <strk at keybit.net>
-	* [r1927] ChangeLog, tests/unit/capi/GEOSCoordSeq.cpp: Other tests
-	  using setOrdinate instead of set{X,Y,Z}
+	* [r1927] Other tests using setOrdinate instead of set{X,Y,Z}
 2006-12-04 10:12  Sandro Santilli <strk at keybit.net>
-	* [r1926] ChangeLog, source/geom/CoordinateArraySequence.cpp: *
-	  source/geom/CoordinateArraySequence.cpp (setOrdinate): fix bug
-	  #133.
+	* [r1926] * source/geom/CoordinateArraySequence.cpp (setOrdinate):
+	  fix bug #133.
 2006-12-04 10:00  Sandro Santilli <strk at keybit.net>
-	* [r1925] ChangeLog, tests/unit/capi/GEOSCoordSeq.cpp: *
-	  tests/unit/capi/GEOSCoordSeq.cpp: add test for bug #133
+	* [r1925] * tests/unit/capi/GEOSCoordSeq.cpp: add test for bug #133
 	  (failing).
 2006-12-04 09:57  Sandro Santilli <strk at keybit.net>
-	* [r1924] ChangeLog,
-	  tests/unit/geom/CoordinateArraySequenceTest.cpp: *
-	  tests/unit/geom/CoordinateArraySequenceTest.cpp: added tests for
-	  setOrdinate()
+	* [r1924] * tests/unit/geom/CoordinateArraySequenceTest.cpp: added
+	  tests for setOrdinate()
 2006-11-30 14:49  Sandro Santilli <strk at keybit.net>
-	* [r1923] ChangeLog, capi/geos_c.cpp, tests/unit/Makefile.am,
-	  tests/unit/capi, tests/unit/capi/GEOSCoordSeq.cpp: * tests/unit/:
-	  Makefile.am, capi/GEOSCoordSeq.cpp:
+	* [r1923] * tests/unit/: Makefile.am, capi/GEOSCoordSeq.cpp:
 	  new experimental test for C-API GEOSCoordSeq.
 	  * capi/geos_c.cpp (GEOSCoordSeq_create): removed
 	  suspicious static cast.
 2006-11-28 19:13  Mateusz Loskot <mateusz at loskot.net>
-	* [r1922] build, build/README, build/msvc80, build/msvc80/README,
-	  build/msvc80/geos.sln, build/msvc80/geos_c_dll,
-	  build/msvc80/geos_c_dll/geos_c_dll.vcproj, build/msvc80/geos_lib,
-	  build/msvc80/geos_lib/geos_lib.vcproj, build/msvc80/geos_unit,
-	  build/msvc80/geos_unit/geos_unit.vcproj: Added Visual C++ 2005
-	  project files.
+	* [r1922] Added Visual C++ 2005 project files.
 2006-11-23 20:17  Sandro Santilli <strk at keybit.net>
-	* [r1921] ChangeLog, source/geom/Point.cpp: * source/geom/Point.cpp
-	  (equalsExact): don't segfault on empty points. Fixes bug #132.
+	* [r1921] * source/geom/Point.cpp (equalsExact): don't segfault on
+	  empty points. Fixes bug #132.
 2006-11-23 12:25  Sandro Santilli <strk at keybit.net>
-	* [r1920] tests/xmltester/stmlf-cases-20061020.xml: Added short
-	  descripion of testcases provenience
+	* [r1920] Added short descripion of testcases provenience
 2006-11-22 20:29  Sandro Santilli <strk at keybit.net>
-	* [r1919] ChangeLog, tests/xmltester/Makefile.am,
-	  tests/xmltester/stmlf-cases-20061020.xml: * tests/xmltester/:
-	  stmlf-cases-20061020.xml, Makefile.am: add more robustness
-	  testcases.
+	* [r1919] * tests/xmltester/: stmlf-cases-20061020.xml,
+	  Makefile.am: add more robustness testcases.
 2006-11-22 12:26  Sandro Santilli <strk at keybit.net>
-	* [r1918] ChangeLog, autogen.sh: Patch by dron at ak4719.spb.edu:
+	* [r1918] Patch by dron at ak4719.spb.edu:
 	  * autogen.sh: call 'autoheader' after 'aclocal'.
 	  Fixes bug #131
 2006-11-18 15:30  Mateusz Loskot <mateusz at loskot.net>
-	* [r1917] source/Makefile.vc: Fixed path to geos_c.h in
-	  source/makefile.vc.
+	* [r1917] Fixed path to geos_c.h in source/makefile.vc.
 2006-11-15 18:26  Sandro Santilli <strk at keybit.net>
-	* [r1916] ChangeLog, capi/Makefile.am, capi/geos_c.h.vc.in,
-	  configure.in, source/Makefile.vc,
-	  source/headers/geos/Makefile.am,
-	  source/headers/geos/version.h.vc: * configure.in: don't generate
-	  geos_c.h.vc
+	* [r1916] * configure.in: don't generate geos_c.h.vc
 	  * source/Makefile.vc: don't generate geos_c.h and version.h
 	  * source/headers/geos/version.h.vc, capi/geos_c.h.vc.in:
 	  removed, will NOT be needed by Makefile.vc
@@ -6401,61 +4093,56 @@
 2006-11-15 14:42  Sandro Santilli <strk at keybit.net>
-	* [r1915] ChangeLog, capi/geos_c.h.in: * capi/geos_c.h.in:
-	  hopefully fixed GEOS_DLL use.
+	* [r1915] * capi/geos_c.h.in: hopefully fixed GEOS_DLL use.
 2006-11-15 11:28  Sandro Santilli <strk at keybit.net>
-	* [r1914] ChangeLog, capi/geos_c.cpp: * capi/geos_c.cpp
-	  (GEOSGeom_getDimensions): Fix a segfault on empty geometry input
-	  (fix bug #126).
+	* [r1914] * capi/geos_c.cpp (GEOSGeom_getDimensions): Fix a
+	  segfault on empty geometry input (fix bug #126).
 2006-11-11 05:32  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r1913] capi/geos_c.h.vc.in: Retreived original .vc file and put
-	  in MACRO substitutions. Somehow GNU version replaced .vc version
-	  during file shuffles to get macros in.
+	* [r1913] Retreived original .vc file and put in MACRO
+	  substitutions. Somehow GNU version replaced .vc version during
+	  file shuffles to get macros in.
 2006-11-10 18:24  Sandro Santilli <strk at keybit.net>
-	* [r1912] ChangeLog: fixed timewarp
+	* [r1912] fixed timewarp
 2006-11-10 17:56  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r1911] ChangeLog: noted .vc change
+	* [r1911] noted .vc change
 2006-11-10 17:55  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r1910] capi/Makefile.am: Made sure geos_c.h.vc is part of 'make
-	  dist' since VC users won't have .configure
+	* [r1910] Made sure geos_c.h.vc is part of 'make dist' since VC
+	  users won't have .configure
 2006-11-10 17:38  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r1909] capi/Makefile.am, capi/geos_c.h.vc, capi/geos_c.h.vc.in:
-	  Added substitution strings to .in files for .vc generation.
+	* [r1909] Added substitution strings to .in files for .vc
+	  generation.
 2006-11-10 17:35  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r1908] configure.in: Changes for capi .vc generation
+	* [r1908] Changes for capi .vc generation
 2006-11-10 14:50  Howard Butler <hobu.inc at gmail.com>
-	* [r1907] capi/geos_c.h.vc: update
+	* [r1907] update
 2006-11-09 09:10  Sandro Santilli <strk at keybit.net>
-	* [r1906] ChangeLog, tests/xmltester/XMLTester.cpp: *
-	  test/xmltester/XMLTester.cpp: improved 'testarea' test.
+	* [r1906] * test/xmltester/XMLTester.cpp: improved 'testarea' test.
 2006-11-08 11:54  Sandro Santilli <strk at keybit.net>
-	* [r1905] ChangeLog: added 'release-separator' tag
+	* [r1905] added 'release-separator' tag
 2006-11-08 11:51  Sandro Santilli <strk at keybit.net>
-	* [r1904] ChangeLog, tests/xmltester/Makefile.am,
-	  tests/xmltester/robustness.xml: * tests/xmltester/robustness.xml:
-	  made test safe to
+	* [r1904] * tests/xmltester/robustness.xml: made test safe to
 	  run by using the new 'areatest' operation; added
 	  new testcases just raised on the mailing list.
 	  * tests/xmltester/Makefile.am: robustness.xml is now safe
@@ -6463,79 +4150,68 @@
 2006-11-08 10:40  Sandro Santilli <strk at keybit.net>
-	* [r1903] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
-	  source/headers/geos/geom/BinaryOp.h: enable
+	* [r1903] * source/headers/geos/geom/BinaryOp.h: enable
 	  COMMONBITS-removal heuristic so it is attempted
 	  before geometry snapping.
 2006-11-05 20:34  Sandro Santilli <strk at keybit.net>
-	* [r1900] ChangeLog, capi/Makefile.am: * capi/Makefile.am:
-	  distribute files needed for testing, proper cleanup (make
-	  distcheck works now)
+	* [r1900] * capi/Makefile.am: distribute files needed for testing,
+	  proper cleanup (make distcheck works now)
 2006-11-05 00:24  Charlie Savage <cfis at savagexi.com>
-	* [r1899] swig/ruby/geos_wrap.cxx: Updated ruby swig wrapper for
-	  changes in header files.
+	* [r1899] Updated ruby swig wrapper for changes in header files.
-	* [r1898] swig/python/geos_wrap.cxx: Updated python swig wrapper
-	  for changes in header files.
+	* [r1898] Updated python swig wrapper for changes in header files.
 2006-11-05 00:23  Charlie Savage <cfis at savagexi.com>
-	* [r1897] swig/geos.i: Fixes for changes in header files.
+	* [r1897] Fixes for changes in header files.
 2006-11-03 12:35  Sandro Santilli <strk at keybit.net>
-	* [r1896] capi/testrunner.sh: redirect 'diff' output to stderr
+	* [r1896] redirect 'diff' output to stderr
 2006-11-03 10:54  Sandro Santilli <strk at keybit.net>
-	* [r1895] ChangeLog, capi/testrunner.sh: hopefully fixed proper
-	  quoting
+	* [r1895] hopefully fixed proper quoting
 2006-11-03 10:30  Sandro Santilli <strk at keybit.net>
-	* [r1894] ChangeLog, capi/testrunner.sh: Report non-zero return
-	  from ./geostest run
+	* [r1894] Report non-zero return from ./geostest run
 2006-11-02 10:08  Sandro Santilli <strk at keybit.net>
-	* [r1893] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
-	  source/headers/geos/geom/BinaryOp.h: disable debugging output by
-	  default.
+	* [r1893] * source/headers/geos/geom/BinaryOp.h: disable debugging
+	  output by default.
 2006-11-02 10:02  Sandro Santilli <strk at keybit.net>
-	* [r1892] ChangeLog, capi/geostest.c: * capi/geostest.c: updated to
-	  use the new GEOSGeometry typedef, so to build w/out warnings and
-	  fully respecting current const specification.
+	* [r1892] * capi/geostest.c: updated to use the new GEOSGeometry
+	  typedef, so to build w/out warnings and fully respecting current
+	  const specification.
 2006-11-02 09:48  Sandro Santilli <strk at keybit.net>
-	* [r1891] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: *
-	  capi/geos_c.cpp, capi/geos_c.h.in: const-corrected and documented
-	  GEOSPolygonize function.
+	* [r1891] * capi/geos_c.cpp, capi/geos_c.h.in: const-corrected and
+	  documented GEOSPolygonize function.
 2006-11-02 09:38  Sandro Santilli <strk at keybit.net>
-	* [r1890] ChangeLog, capi/test.expected, capi/testrunner.sh: *
-	  capi/test.expected: updated expected version
+	* [r1890] * capi/test.expected: updated expected version
 	  * capi/testrunner.sh: be happy with geostest running w/out
 	  segfaulting, still run diff for reference.
 2006-11-02 09:33  Sandro Santilli <strk at keybit.net>
-	* [r1889] ChangeLog, configure.in: * configure.in: updated versions
-	  to 3.0.0rc2 / CAPI-1.3.0
+	* [r1889] * configure.in: updated versions to 3.0.0rc2 / CAPI-1.3.0
 2006-11-02 08:32  Sandro Santilli <strk at keybit.net>
-	* [r1888] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: Patch by
-	  Markus Schaber <schabi at logix-tt.com>:
+	* [r1888] Patch by Markus Schaber <schabi at logix-tt.com>:
 	  * capi/geos_c.h.in: add GEOSGeometry and GEOSCoordSequence
 	  typedef, to unhide the pointer type and allow fine-grained
@@ -6546,8 +4222,7 @@
 2006-10-30 15:14  Sandro Santilli <strk at keybit.net>
-	* [r1887] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: Patch by
+	* [r1887] Patch by Markus Schaber <schabi at logix-tt.com>
 	  * capi/geos_c.cpp: more focused 'using' directives.
 	  * capi/geos_c.h.in: let the enum visible by geos_c.cpp
@@ -6555,17 +4230,15 @@
 2006-10-30 13:20  Sandro Santilli <strk at keybit.net>
-	* [r1886] capi/geos_c.cpp: removed useless GEOSGeomTypes define
+	* [r1886] removed useless GEOSGeomTypes define
 2006-10-30 13:00  Sandro Santilli <strk at keybit.net>
-	* [r1885] ChangeLog, source/operation/overlay/OverlayOp.cpp: reduce
-	  default verbosity
+	* [r1885] reduce default verbosity
 2006-10-30 12:49  Sandro Santilli <strk at keybit.net>
-	* [r1884] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: *
-	  capi/geos_c.cpp:
+	* [r1884] * capi/geos_c.cpp:
 	  Remove a typedef which is also included via Header;
 	  Use dynamic_cast instead of C cast in 2 cases to allow the RTTI
 	  type check;
@@ -6580,15 +4253,13 @@
 2006-10-30 10:29  Sandro Santilli <strk at keybit.net>
-	* [r1883] ChangeLog, capi/Makefile.am, capi/test.expected,
-	  capi/testrunner.sh: * capi/: test.expected, testrunner.sh,
-	  Makefile.am: Added a run of ./geostest as part of 'make check'
+	* [r1883] * capi/: test.expected, testrunner.sh, Makefile.am: Added
+	  a run of ./geostest as part of 'make check'
 2006-10-30 10:15  Sandro Santilli <strk at keybit.net>
-	* [r1882] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: Patch
-	  submitted by Markus Schaber <schabi at logix-tt.com> ( reviewed and
-	  fixed )
+	* [r1882] Patch submitted by Markus Schaber <schabi at logix-tt.com> (
+	  reviewed and fixed )
 	  * capi/: geos_c.cpp, geos_c.h.in:
 	  Changed the C-API implementation to actually include the header
@@ -6598,19 +4269,12 @@
 2006-10-30 09:49  Sandro Santilli <strk at keybit.net>
-	* [r1881] ChangeLog, capi/geostest.c: * capi/geostest.c: added some
-	  checks of return from CAPI functions returning GEOSGeom (not all,
-	  just a few)
+	* [r1881] * capi/geostest.c: added some checks of return from CAPI
+	  functions returning GEOSGeom (not all, just a few)
 2006-10-27 11:54  Sandro Santilli <strk at keybit.net>
-	* [r1880] ChangeLog, source/algorithm/InteriorPointLine.cpp,
-	  source/headers/geos/algorithm/InteriorPointLine.h,
-	  source/headers/geos/geom/Geometry.h,
-	  source/headers/geos/operation/polygonize/Polygonizer.h,
-	  source/operation/polygonize/Polygonizer.cpp: Patch by Markus
-	  Schaber <schabi at logix-tt.com>
+	* [r1880] Patch by Markus Schaber <schabi at logix-tt.com>
 	  * algorithm::InteriorPointLine (ctor): take Geometry by
 	  const-pointer.
@@ -6621,1533 +4285,769 @@
 2006-10-26 09:22  Sandro Santilli <strk at keybit.net>
-	* [r1879] ChangeLog, capi/geos_c.h.in: * capi/geos_c.h.in: reverted
-	  all changes of 'int' types
+	* [r1879] * capi/geos_c.h.in: reverted all changes of 'int' types
 	  to 'size_t' types (the lib never changed, and still expects
 	  ints)
 2006-10-24 16:54  Sandro Santilli <strk at keybit.net>
-	* [r1878] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
-	  source/headers/geos/geom/BinaryOp.h: try original geoms first by
-	  default.
+	* [r1878] * source/headers/geos/geom/BinaryOp.h: try original geoms
+	  first by default.
 2006-10-24 16:53  Sandro Santilli <strk at keybit.net>
-	* [r1877] ChangeLog,
-	  source/operation/overlay/OverlayResultValidator.cpp: *
-	  operation::overlay::OverlayResultValidator.cpp (isValid): run the
-	  test even if inputs and output are not areal.
+	* [r1877] * operation::overlay::OverlayResultValidator.cpp
+	  (isValid): run the test even if inputs and output are not areal.
 2006-10-24 16:49  Sandro Santilli <strk at keybit.net>
-	* [r1876] ChangeLog,
-	  source/operation/overlay/FuzzyPointLocator.cpp: *
-	  operation::overlay::FuzzyPointLocator: eliminate non-polygonal
-	  components from consideration when testing the location of
-	  points.
+	* [r1876] * operation::overlay::FuzzyPointLocator: eliminate
+	  non-polygonal components from consideration when testing the
+	  location of points.
 2006-10-24 10:16  Sandro Santilli <strk at keybit.net>
-	* [r1875] ChangeLog,
-	  source/precision/GeometrySnapper.cpp: *
-	  precision::GeometrySnapper: snapPrecisionFactor augmented from
-	  10e-12 to 10e-10.
+	* [r1875] * precision::GeometrySnapper: snapPrecisionFactor
+	  augmented from 10e-12 to 10e-10.
 2006-10-24 09:49  Sandro Santilli <strk at keybit.net>
-	* [r1874] ChangeLog,
-	  precision::LineStringSnapper (findSegmentToSnap):
+	* [r1874] * precision::LineStringSnapper (findSegmentToSnap):
 	  return the *closest* segment, don't snap if the closest
 	  segment *intersects* the snap points, consider a distance
 	  of exactly snapTolerance as non-tolerated (got in sync with JTS)
 2006-10-23 10:23  Sandro Santilli <strk at keybit.net>
-	* [r1873] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
-	  source/headers/geos/geom/BinaryOp.h (SnapOp): document and add
-	  optional CBR step (snap after applying common bits removal - this
-	  is the default); (check_valid): add validity checker function.
+	* [r1873] * source/headers/geos/geom/BinaryOp.h (SnapOp): document
+	  and add optional CBR step (snap after applying common bits
+	  removal - this is the default); (check_valid): add validity
+	  checker function.
 2006-10-20 11:18  Sandro Santilli <strk at keybit.net>
-	* [r1872] ChangeLog, source/headers/geos/noding/SegmentString.h,
-	  source/noding/ScaledNoder.cpp, source/noding/SegmentString.cpp: *
-	  noding::SegmentString: added notifyCoordinatesChange method.
+	* [r1872] * noding::SegmentString: added notifyCoordinatesChange
+	  method.
 	  * noding::ScaledNoder: notify possible coordinates change to
 	  SegmentString after removing repeated points.
 2006-10-19 18:26  Sandro Santilli <strk at keybit.net>
-	* [r1871] ChangeLog, configure.in: * configure.in: use 'expr' for
-	  arithmetics (more portable)
+	* [r1871] * configure.in: use 'expr' for arithmetics (more
+	  portable)
 2006-10-18 19:21  Mateusz Loskot <mateusz at loskot.net>
-	* [r1870] ChangeLog, makefile.vc, source/Makefile.vc: Refactored
-	  Visual C++ makefiles.
+	* [r1870] Refactored Visual C++ makefiles.
 2006-10-18 17:53  Mateusz Loskot <mateusz at loskot.net>
-	* [r1869] source/Makefile.vc, source/dirlist.mk: Updated
-	  source\makefile.vc and source\dirlist.mk files.
+	* [r1869] Updated source\makefile.vc and source\dirlist.mk files.
-	* [r1868] makefile.vc: Added top-level makefile.vc.
+	* [r1868] Added top-level makefile.vc.
 2006-10-18 14:28  Sandro Santilli <strk at keybit.net>
-	* [r1867] .: fixed svn:ignore property
+	* [r1867] fixed svn:ignore property
 2006-10-18 12:08  Sandro Santilli <strk at keybit.net>
-	* [r1866] ChangeLog, source/operation/overlay/OverlayOp.cpp:
-	  disable non-JTS overlay result validators (to more closely track
-	  JTS at this stage)
+	* [r1866] disable non-JTS overlay result validators (to more
+	  closely track JTS at this stage)
 2006-10-17 14:26  Sandro Santilli <strk at keybit.net>
-	* [r1865] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
-	  source/headers/geos/geom/BinaryOp.h (SnapOp): fixed horrible
+	* [r1865] * source/headers/geos/geom/BinaryOp.h (SnapOp): fixed
+	  horrible
 	  bug applying overlay of first geom to itself :(
 2006-10-17 10:15  Sandro Santilli <strk at keybit.net>
-	* [r1864] capi/geos_c.h.in: really fixed 'extra tokens at end of
-	  #endif directive' warning
+	* [r1864] really fixed 'extra tokens at end of #endif directive'
+	  warning
 2006-10-17 10:10  Sandro Santilli <strk at keybit.net>
-	* [r1863] capi/geos_c.h.in: fixed 'extra tokens at end of #endif
-	  directive' warning
+	* [r1863] fixed 'extra tokens at end of #endif directive' warning
 2006-10-17 08:44  Sandro Santilli <strk at keybit.net>
-	* [r1862] ChangeLog, capi/Makefile.am: * capi/Makefile.am: don't
-	  directly link geostest against
+	* [r1862] * capi/Makefile.am: don't directly link geostest against
 	  both libgeos.so and libstdc++ (should be derived by
 	  libgeos_c.so).
 2006-10-12 15:33  Sandro Santilli <strk at keybit.net>
-	* [r1861] ChangeLog, tests/bigtest/GeometryTestFactory.cpp,
-	  tests/bigtest/TestSweepLineSpeed.cpp, tests/bigtest/bigtest.h: *
-	  tests/bigtest/GeometryTestFactory.cpp, tests/bigtest/bigtest.h,
-	  tests/bigtest/TestSweepLineSpeed.cpp: fixed header inclusion, to
-	  reduce compiler noise.
+	* [r1861] * tests/bigtest/GeometryTestFactory.cpp,
+	  tests/bigtest/bigtest.h, tests/bigtest/TestSweepLineSpeed.cpp:
+	  fixed header inclusion, to reduce compiler noise.
 2006-10-09 16:39  Sandro Santilli <strk at keybit.net>
-	* [r1860] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
-	  source/headers/geos/geom/BinaryOp.h: always snap geoms to
-	  each-other before applying an overlay (temp hack).
+	* [r1860] * source/headers/geos/geom/BinaryOp.h: always snap geoms
+	  to each-other before applying an overlay (temp hack).
 2006-10-09 16:35  Sandro Santilli <strk at keybit.net>
-	* [r1859] ChangeLog, source/operation/overlay/OverlayOp.cpp: *
-	  source/operation/overlay/OverlayOp.cpp: enable all overlay result
-	  validators, make it disablable at compile time.
+	* [r1859] * source/operation/overlay/OverlayOp.cpp: enable all
+	  overlay result validators, make it disablable at compile time.
 2006-10-05 10:58  Mateusz Loskot <mateusz at loskot.net>
-	* [r1858] ChangeLog, capi/geos_c.h.in, capi/geos_c.h.vc: Added
-	  inclusion guards to geos_c.h files.
+	* [r1858] Added inclusion guards to geos_c.h files.
 2006-10-05 09:46  Sandro Santilli <strk at keybit.net>
-	* [r1857] ChangeLog, tests/xmltester/XMLTester.cpp: increment
-	  areatest verbosity (needs -v -v)
+	* [r1857] increment areatest verbosity (needs -v -v)
 2006-10-02 18:53  Howard Butler <hobu.inc at gmail.com>
-	* [r1856] ChangeLog, capi/geos_c.cpp: GEOSEnvelope wasn't in the
-	  PROTOTYPES section in geos_c.cpp
+	* [r1856] GEOSEnvelope wasn't in the PROTOTYPES section in
+	  geos_c.cpp
 2006-09-27 07:48  Sandro Santilli <strk at keybit.net>
-	* [r1855] HOWTO_RELEASE: updated tag item
+	* [r1855] updated tag item
 2006-09-27 07:43  Sandro Santilli <strk at keybit.net>
-	* [r1854] HOWTO_RELEASE: added info about svn tags
+	* [r1854] added info about svn tags
 2006-09-19 06:54  Sandro Santilli <strk at keybit.net>
-	* [r1853] source/operation/overlay/OffsetPointGenerator.cpp: Added
-	  <algorithm> include
+	* [r1853] Added <algorithm> include
 2006-09-08 23:13  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r1851] AUTHORS: Added information about funders of the 3.0.0
-	  series: Safe Software, Autodesk,
+	* [r1851] Added information about funders of the 3.0.0 series: Safe
+	  Software, Autodesk,
 	  Bavarian State Ministry of Agriculture and Forestry and the State
 	  Survey of Bavaria.
 2006-09-08 09:38  Sandro Santilli <strk at keybit.net>
-	* [r1850] TODO: updated
+	* [r1850] updated
 2006-09-08 09:31  Sandro Santilli <strk at keybit.net>
-	* [r1849] source/operation/overlay/OverlayResultValidator.cpp: more
-	  debugging output
+	* [r1849] more debugging output
 2006-09-08 09:21  Sandro Santilli <strk at keybit.net>
-	* [r1848] tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp,
-	  tests/unit/operation/overlay/OverlayResultValidatorTest.cpp: More
-	  testcases
+	* [r1848] More testcases
 2006-09-07 18:07  Sandro Santilli <strk at keybit.net>
-	* [r1847] tests/unit/Makefile.am,
-	  tests/unit/operation/overlay/OverlayResultValidatorTest.cpp: New
-	  unit test for OverlayResultValidator class
+	* [r1847] New unit test for OverlayResultValidator class
-	* [r1846] source/operation/overlay/OverlayResultValidator.cpp: more
-	  debugging output
+	* [r1846] more debugging output
 2006-09-07 17:52  Sandro Santilli <strk at keybit.net>
-	* [r1845]
-	  source/operation/overlay/OverlayResultValidator.cpp: Added
-	  addVertices private method (unused, as in JTS, but possibly
-	  useful in the future)
+	* [r1845] Added addVertices private method (unused, as in JTS, but
+	  possibly useful in the future)
 2006-09-07 17:41  Sandro Santilli <strk at keybit.net>
-	* [r1844] source/operation/overlay/OverlayResultValidator.cpp:
-	  Added debugging code
+	* [r1844] Added debugging code
 2006-09-07 17:35  Sandro Santilli <strk at keybit.net>
-	* [r1843]
-	  tests/unit/operation/overlay/OffsetPointGeneratorTest.cpp: more
-	  testcases (added test for max distance of offset points)
+	* [r1843] more testcases (added test for max distance of offset
+	  points)
 2006-09-07 15:28  Sandro Santilli <strk at keybit.net>
-	* [r1842] tests/unit/algorithm/PointLocatorTest.cpp,
-	  tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp,
-	  tests/unit/geom/CoordinateArraySequenceTest.cpp,
-	  tests/unit/geom/CoordinateListTest.cpp,
-	  tests/unit/geom/CoordinateTest.cpp,
-	  tests/unit/geom/DimensionTest.cpp,
-	  tests/unit/geom/EnvelopeTest.cpp,
-	  tests/unit/geom/GeometryFactoryTest.cpp,
-	  tests/unit/geom/LineSegmentTest.cpp,
-	  tests/unit/geom/LineStringTest.cpp,
-	  tests/unit/geom/LinearRingTest.cpp,
-	  tests/unit/geom/LocationTest.cpp,
-	  tests/unit/geom/MultiLineStringTest.cpp,
-	  tests/unit/geom/MultiPointTest.cpp,
-	  tests/unit/geom/MultiPolygonTest.cpp,
-	  tests/unit/geom/PointTest.cpp, tests/unit/geom/PolygonTest.cpp,
-	  tests/unit/geom/TriangleTest.cpp,
-	  tests/unit/io/WKBReaderTest.cpp,
-	  tests/unit/noding/SegmentStringTest.cpp,
-	  tests/unit/precision/LineStringSnapperTest.cpp: removed
-	  svn:executable prop from all .cpp files
+	* [r1842] removed svn:executable prop from all .cpp files
 2006-09-07 15:22  Sandro Santilli <strk at keybit.net>
-	* [r1841] tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp,
-	  removed svn:executable property
+	* [r1841] removed svn:executable property
 2006-09-07 15:21  Sandro Santilli <strk at keybit.net>
-	* [r1840] tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp:
-	  testing execute bit state
+	* [r1840] testing execute bit state
 2006-09-07 12:17  Mateusz Loskot <mateusz at loskot.net>
-	* [r1839] tests/unit/operation/distance/DistanceOpTest.cpp: Set
-	  svn:keyword for $ expansion.
+	* [r1839] Set svn:keyword for $ expansion.
 2006-09-07 11:34  Sandro Santilli <strk at keybit.net>
-	* [r1838] source/operation/overlay/OverlayOp.cpp: Cleaned up
-	  OverlayResultValidator call (still disabled due to bugs)
+	* [r1838] Cleaned up OverlayResultValidator call (still disabled
+	  due to bugs)
 2006-09-07 11:27  Sandro Santilli <strk at keybit.net>
-	* [r1837] source/operation/overlay/OverlayResultValidator.cpp:
-	  blindly return positive result if any input or output is not an
-	  area
+	* [r1837] blindly return positive result if any input or output is
+	  not an area
 2006-09-07 11:08  Sandro Santilli <strk at keybit.net>
-	* [r1836] tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp:
-	  new test for FuzzyPointLocator
+	* [r1836] new test for FuzzyPointLocator
 2006-09-07 10:30  Sandro Santilli <strk at keybit.net>
-	* [r1835] source/headers/geos/geom/Location.h: Explicit values to
-	  LocationValue enum items. Removed CVS Log
+	* [r1835] Explicit values to LocationValue enum items. Removed CVS
+	  Log
 2006-09-07 09:33  Sandro Santilli <strk at keybit.net>
-	* [r1834] doc/example.cpp: Removed catch-all headers inclusion and
-	  use of obsoleted Unload class
+	* [r1834] Removed catch-all headers inclusion and use of obsoleted
+	  Unload class
 2006-09-07 09:24  Sandro Santilli <strk at keybit.net>
-	* [r1833] README: updated
+	* [r1833] updated
 2006-09-07 09:23  Sandro Santilli <strk at keybit.net>
-	* [r1832]
-	  source/headers/geos/operation/overlay/OverlayResultValidator.h:
-	  comment cleanup
+	* [r1832] comment cleanup
 2006-09-07 09:01  Sandro Santilli <strk at keybit.net>
-	* [r1831] source/headers/geos/operation/distance/DistanceOp.h:
-	  Comments about ownership (and lifetime) of returned objects
+	* [r1831] Comments about ownership (and lifetime) of returned
+	  objects
 2006-09-07 08:59  Sandro Santilli <strk at keybit.net>
-	* [r1830] tests/unit/Makefile.am, tests/unit/operation/distance,
-	  tests/unit/operation/distance/DistanceOpTest.cpp: New DistanceOp
-	  unit test
+	* [r1830] New DistanceOp unit test
 2006-09-07 08:57  Sandro Santilli <strk at keybit.net>
-	* [r1829] ChangeLog, source/operation/distance/DistanceOp.cpp:
-	  (computeMinDistancePoints): fixed invalid reference.
+	* [r1829] (computeMinDistancePoints): fixed invalid reference.
 2006-09-07 08:23  Sandro Santilli <strk at keybit.net>
-	* [r1828] ChangeLog, autogen.sh: don't giveup on automake failures
-	  (testing)
+	* [r1828] don't giveup on automake failures (testing)
 2006-09-06 18:44  Sandro Santilli <strk at keybit.net>
-	* [r1827] source/operation/overlay/OverlayOp.cpp: Ops, overlay
-	  result validation erroenously committed
+	* [r1827] Ops, overlay result validation erroenously committed
 2006-09-06 18:41  Sandro Santilli <strk at keybit.net>
-	* [r1826] ChangeLog, tests/unit/Makefile.am,
-	  tests/unit/operation/overlay/OffsetPointGeneratorTest.cpp: new
-	  test for OffsetPointGenerator class
+	* [r1826] new test for OffsetPointGenerator class
 2006-09-06 18:37  Sandro Santilli <strk at keybit.net>
-	* [r1825] source/operation/overlay/OffsetPointGenerator.cpp: Fixed
-	  uninitialized memory bug
+	* [r1825] Fixed uninitialized memory bug
 2006-09-06 17:59  Sandro Santilli <strk at keybit.net>
-	* [r1824] ChangeLog, source/operation/overlay/OverlayOp.cpp,
-	  tests/unit/Makefile.am, tests/unit/operation,
-	  tests/unit/operation/overlay,
-	  tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp: new test
-	  for FuzzyPointLocator class
+	* [r1824] new test for FuzzyPointLocator class
 2006-09-06 17:48  Sandro Santilli <strk at keybit.net>
-	* [r1823] tests/unit/precision/GeometrySnapperTest.cpp: updated
-	  after GeometrySnapper interface change.
+	* [r1823] updated after GeometrySnapper interface change.
 2006-09-06 17:26  Mateusz Loskot <mateusz at loskot.net>
-	* [r1822] ChangeLog,
-	  source/operation/overlay/OverlayResultValidator.cpp: Set $
-	  expansion for new files in 'overlay' module.
+	* [r1822] Set $ expansion for new files in 'overlay' module.
 2006-09-06 17:22  Sandro Santilli <strk at keybit.net>
-	* [r1821] ChangeLog,
-	  source/headers/geos/operation/overlay/Makefile.am,
-	  source/operation/overlay/FuzzyPointLocator.cpp,
-	  source/operation/overlay/Makefile.am,
-	  source/operation/overlay/OverlayResultValidator.cpp: Rest of
-	  Overlay validation classes.
+	* [r1821] Rest of Overlay validation classes.
 2006-09-06 16:54  Mateusz Loskot <mateusz at loskot.net>
-	* [r1820] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in,
-	  capi/geos_c.h.vc, capi/geostest.c, configure.in, debian/watch,
-	  doc/Doxyfile.in, doc/example.cpp, source/Makefile.vc,
-	  source/algorithm/ConvexHull.cpp,
-	  source/algorithm/LineIntersector.cpp,
-	  source/algorithm/MCPointInRing.cpp,
-	  source/algorithm/NonRobustLineIntersector.cpp,
-	  source/algorithm/NotRepresentableException.cpp,
-	  source/algorithm/RobustDeterminant.cpp,
-	  source/algorithm/RobustLineIntersector.cpp,
-	  source/algorithm/SimplePointInAreaLocator.cpp,
-	  source/algorithm/SimplePointInRing.cpp, source/dirlist.mk,
-	  source/examples/CPCLException.cpp,
-	  source/examples/CoordinateSequencesExample.cpp,
-	  source/examples/CustomCoordinateSequenceExample.cpp,
-	  source/examples/CustomCoordinateSequenceExample.h,
-	  source/examples/CustomPointCoordinateSequence.cpp,
-	  source/geom/Coordinate.cpp,
-	  source/geom/CoordinateArraySequenceFactory.cpp,
-	  source/geom/CoordinateSequenceFactory.cpp,
-	  source/geom/Dimension.cpp, source/geom/Envelope.cpp,
-	  source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
-	  source/geom/GeometryComponentFilter.cpp,
-	  source/geom/GeometryFactory.cpp, source/geom/GeometryList.cpp,
-	  source/geom/IntersectionMatrix.cpp, source/geom/LineSegment.cpp,
-	  source/geom/LineString.cpp, source/geom/LinearRing.cpp,
-	  source/geom/Location.cpp, source/geom/MultiLineString.cpp,
-	  source/geom/MultiPoint.cpp, source/geom/MultiPolygon.cpp,
-	  source/geom/Point.cpp, source/geom/Polygon.cpp,
-	  source/geom/PrecisionModel.cpp, source/geom/Triangle.cpp,
-	  source/geom/util/CoordinateOperation.cpp,
-	  source/geom/util/GeometryEditor.cpp,
-	  source/geom/util/GeometryTransformer.cpp,
-	  source/geom/util/LinearComponentExtracter.cpp,
-	  source/geom/util/PointExtracter.cpp,
-	  source/geom/util/PolygonExtracter.cpp,
-	  source/geom/util/ShortCircuitedGeometryVisitor.cpp,
-	  source/geomgraph/Depth.cpp, source/geomgraph/DirectedEdge.cpp,
-	  source/geomgraph/DirectedEdgeStar.cpp, source/geomgraph/Edge.cpp,
-	  source/geomgraph/EdgeEnd.cpp, source/geomgraph/EdgeEndStar.cpp,
-	  source/geomgraph/EdgeIntersection.cpp,
-	  source/geomgraph/EdgeIntersectionList.cpp,
-	  source/geomgraph/EdgeNodingValidator.cpp,
-	  source/geomgraph/EdgeRing.cpp,
-	  source/geomgraph/GeometryGraph.cpp,
-	  source/geomgraph/GraphComponent.cpp, source/geomgraph/Label.cpp,
-	  source/geomgraph/Node.cpp, source/geomgraph/NodeFactory.cpp,
-	  source/geomgraph/NodeMap.cpp, source/geomgraph/PlanarGraph.cpp,
-	  source/geomgraph/Position.cpp, source/geomgraph/Quadrant.cpp,
-	  source/geomgraph/TopologyLocation.cpp,
-	  source/geomgraph/index/MonotoneChainEdge.cpp,
-	  source/geomgraph/index/MonotoneChainIndexer.cpp,
-	  source/geomgraph/index/SegmentIntersector.cpp,
-	  source/geomgraph/index/SimpleEdgeSetIntersector.cpp,
-	  source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
-	  source/geomgraph/index/SimpleSweepLineIntersector.cpp,
-	  source/geomgraph/index/SweepLineEvent.cpp,
-	  source/geomgraph/index/SweepLineSegment.cpp,
-	  source/headers/acconfig.h, source/headers/geos.h,
-	  source/headers/geos/algorithm/CGAlgorithms.h,
-	  source/headers/geos/algorithm/CentroidArea.h,
-	  source/headers/geos/algorithm/CentroidLine.h,
-	  source/headers/geos/algorithm/CentroidPoint.h,
-	  source/headers/geos/algorithm/ConvexHull.h,
-	  source/headers/geos/algorithm/ConvexHull.inl,
-	  source/headers/geos/algorithm/HCoordinate.h,
-	  source/headers/geos/algorithm/InteriorPointArea.h,
-	  source/headers/geos/algorithm/InteriorPointPoint.h,
-	  source/headers/geos/algorithm/MCPointInRing.h,
-	  source/headers/geos/algorithm/MinimumDiameter.h,
-	  source/headers/geos/algorithm/NotRepresentableException.h,
-	  source/headers/geos/algorithm/PointInRing.h,
-	  source/headers/geos/algorithm/PointLocator.h,
-	  source/headers/geos/algorithm/RobustDeterminant.h,
-	  source/headers/geos/algorithm/SIRtreePointInRing.h,
-	  source/headers/geos/algorithm/SimplePointInAreaLocator.h,
-	  source/headers/geos/algorithm/SimplePointInRing.h,
-	  source/headers/geos/geom.h, source/headers/geos/geom/BinaryOp.h,
-	  source/headers/geos/geom/Coordinate.h,
-	  source/headers/geos/geom/Coordinate.inl,
-	  source/headers/geos/geom/CoordinateArraySequenceFactory.h,
-	  source/headers/geos/geom/CoordinateArraySequenceFactory.inl,
-	  source/headers/geos/geom/CoordinateList.h,
-	  source/headers/geos/geom/CoordinateSequence.h,
-	  source/headers/geos/geom/CoordinateSequenceFactory.h,
-	  source/headers/geos/geom/Dimension.h,
-	  source/headers/geos/geom/Envelope.h,
-	  source/headers/geos/geom/Envelope.inl,
-	  source/headers/geos/geom/Geometry.inl,
-	  source/headers/geos/geom/GeometryCollection.h,
-	  source/headers/geos/geom/GeometryCollection.inl,
-	  source/headers/geos/geom/GeometryComponentFilter.h,
-	  source/headers/geos/geom/GeometryFactory.h,
-	  source/headers/geos/geom/GeometryFactory.inl,
-	  source/headers/geos/geom/GeometryFilter.h,
-	  source/headers/geos/geom/GeometryList.h,
-	  source/headers/geos/geom/IntersectionMatrix.h,
-	  source/headers/geos/geom/LineSegment.h,
-	  source/headers/geos/geom/LineSegment.inl,
-	  source/headers/geos/geom/LineString.h,
-	  source/headers/geos/geom/LinearRing.h,
-	  source/headers/geos/geom/Location.h,
-	  source/headers/geos/geom/MultiLineString.h,
-	  source/headers/geos/geom/MultiLineString.inl,
-	  source/headers/geos/geom/MultiPoint.h,
-	  source/headers/geos/geom/MultiPolygon.h,
-	  source/headers/geos/geom/MultiPolygon.inl,
-	  source/headers/geos/geom/Point.h,
-	  source/headers/geos/geom/Polygon.h,
-	  source/headers/geos/geom/PrecisionModel.h,
-	  source/headers/geos/geom/PrecisionModel.inl,
-	  source/headers/geos/geom/Triangle.h,
-	  source/headers/geos/geom/util/CoordinateOperation.h,
-	  source/headers/geos/geom/util/GeometryEditor.h,
-	  source/headers/geos/geom/util/GeometryEditorOperation.h,
-	  source/headers/geos/geom/util/GeometryTransformer.h,
-	  source/headers/geos/geom/util/LinearComponentExtracter.h,
-	  source/headers/geos/geom/util/PointExtracter.h,
-	  source/headers/geos/geom/util/PolygonExtracter.h,
-	  source/headers/geos/geom/util/ShortCircuitedGeometryVisitor.h,
-	  source/headers/geos/geomUtil.h, source/headers/geos/geomgraph.h,
-	  source/headers/geos/geomgraph/Depth.h,
-	  source/headers/geos/geomgraph/DirectedEdge.h,
-	  source/headers/geos/geomgraph/DirectedEdge.inl,
-	  source/headers/geos/geomgraph/DirectedEdgeStar.h,
-	  source/headers/geos/geomgraph/EdgeEnd.h,
-	  source/headers/geos/geomgraph/EdgeEndStar.h,
-	  source/headers/geos/geomgraph/EdgeIntersection.h,
-	  source/headers/geos/geomgraph/EdgeIntersectionList.h,
-	  source/headers/geos/geomgraph/EdgeList.h,
-	  source/headers/geos/geomgraph/EdgeRing.h,
-	  source/headers/geos/geomgraph/GeometryGraph.h,
-	  source/headers/geos/geomgraph/GeometryGraph.inl,
-	  source/headers/geos/geomgraph/GraphComponent.h,
-	  source/headers/geos/geomgraph/Label.h,
-	  source/headers/geos/geomgraph/NodeFactory.h,
-	  source/headers/geos/geomgraph/NodeMap.h,
-	  source/headers/geos/geomgraph/PlanarGraph.h,
-	  source/headers/geos/geomgraph/Position.h,
-	  source/headers/geos/geomgraph/Quadrant.h,
-	  source/headers/geos/geomgraph/TopologyLocation.h,
-	  source/headers/geos/geomgraph/index/EdgeSetIntersector.h,
-	  source/headers/geos/geomgraph/index/MonotoneChain.h,
-	  source/headers/geos/geomgraph/index/MonotoneChainEdge.h,
-	  source/headers/geos/geomgraph/index/MonotoneChainIndexer.h,
-	  source/headers/geos/geomgraph/index/SegmentIntersector.h,
-	  source/headers/geos/geomgraph/index/SimpleEdgeSetIntersector.h,
-	  source/headers/geos/geomgraph/index/SimpleMCSweepLineIntersector.h,
-	  source/headers/geos/geomgraph/index/SimpleSweepLineIntersector.h,
-	  source/headers/geos/geomgraph/index/SweepLineEvent.h,
-	  source/headers/geos/geomgraph/index/SweepLineEventObj.h,
-	  source/headers/geos/geomgraph/index/SweepLineSegment.h,
-	  source/headers/geos/geomgraphindex.h,
-	  source/headers/geos/geosAlgorithm.h,
-	  source/headers/geos/index/ItemVisitor.h,
-	  source/headers/geos/index/SpatialIndex.h,
-	  source/headers/geos/index/bintree/Bintree.h,
-	  source/headers/geos/index/bintree/Interval.h,
-	  source/headers/geos/index/bintree/Key.h,
-	  source/headers/geos/index/bintree/Node.h,
-	  source/headers/geos/index/bintree/NodeBase.h,
-	  source/headers/geos/index/chain/MonotoneChain.h,
-	  source/headers/geos/index/chain/MonotoneChainBuilder.h,
-	  source/headers/geos/index/chain/MonotoneChainSelectAction.h,
-	  source/headers/geos/index/quadtree/DoubleBits.h,
-	  source/headers/geos/index/quadtree/IntervalSize.h,
-	  source/headers/geos/index/quadtree/Key.h,
-	  source/headers/geos/index/quadtree/Node.h,
-	  source/headers/geos/index/quadtree/NodeBase.h,
-	  source/headers/geos/index/quadtree/Quadtree.h,
-	  source/headers/geos/index/quadtree/Root.h,
-	  source/headers/geos/index/strtree/Interval.h,
-	  source/headers/geos/index/sweepline/SweepLineEvent.h,
-	  source/headers/geos/index/sweepline/SweepLineIndex.h,
-	  source/headers/geos/index/sweepline/SweepLineInterval.h,
-	  source/headers/geos/index/sweepline/SweepLineOverlapAction.h,
-	  source/headers/geos/indexBintree.h,
-	  source/headers/geos/indexChain.h,
-	  source/headers/geos/indexQuadtree.h,
-	  source/headers/geos/indexStrtree.h,
-	  source/headers/geos/indexSweepline.h,
-	  source/headers/geos/inline.h, source/headers/geos/io.h,
-	  source/headers/geos/io/ByteOrderDataInStream.h,
-	  source/headers/geos/io/ByteOrderDataInStream.inl,
-	  source/headers/geos/io/ByteOrderValues.h,
-	  source/headers/geos/io/ParseException.h,
-	  source/headers/geos/io/StringTokenizer.h,
-	  source/headers/geos/io/WKBConstants.h,
-	  source/headers/geos/io/WKBReader.h,
-	  source/headers/geos/io/WKBWriter.h,
-	  source/headers/geos/io/WKTReader.h,
-	  source/headers/geos/io/WKTReader.inl,
-	  source/headers/geos/io/WKTWriter.h,
-	  source/headers/geos/io/Writer.h, source/headers/geos/noding.h,
-	  source/headers/geos/noding/IntersectionAdder.h,
-	  source/headers/geos/noding/IntersectionFinderAdder.h,
-	  source/headers/geos/noding/IteratedNoder.h,
-	  source/headers/geos/noding/MCIndexNoder.h,
-	  source/headers/geos/noding/MCIndexNoder.inl,
-	  source/headers/geos/noding/Noder.h,
-	  source/headers/geos/noding/NodingValidator.h,
-	  source/headers/geos/noding/Octant.h,
-	  source/headers/geos/noding/ScaledNoder.h,
-	  source/headers/geos/noding/SegmentIntersector.h,
-	  source/headers/geos/noding/SegmentNode.h,
-	  source/headers/geos/noding/SegmentNodeList.h,
-	  source/headers/geos/noding/SegmentString.h,
-	  source/headers/geos/noding/SegmentString.inl,
-	  source/headers/geos/noding/SimpleNoder.h,
-	  source/headers/geos/noding/SinglePassNoder.h,
-	  source/headers/geos/noding/snapround/HotPixel.h,
-	  source/headers/geos/noding/snapround/HotPixel.inl,
-	  source/headers/geos/noding/snapround/MCIndexPointSnapper.h,
-	  source/headers/geos/noding/snapround/MCIndexSnapRounder.h,
-	  source/headers/geos/noding/snapround/MCIndexSnapRounder.inl,
-	  source/headers/geos/noding/snapround/SimpleSnapRounder.h,
-	  source/headers/geos/nodingSnapround.h,
-	  source/headers/geos/opBuffer.h, source/headers/geos/opDistance.h,
-	  source/headers/geos/opLinemerge.h,
-	  source/headers/geos/opOverlay.h,
-	  source/headers/geos/opPolygonize.h,
-	  source/headers/geos/opPredicate.h,
-	  source/headers/geos/opRelate.h, source/headers/geos/opValid.h,
-	  source/headers/geos/operation.h,
-	  source/headers/geos/operation/EndpointInfo.h,
-	  source/headers/geos/operation/GeometryGraphOperation.h,
-	  source/headers/geos/operation/IsSimpleOp.h,
-	  source/headers/geos/operation/buffer/BufferSubgraph.h,
-	  source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h,
-	  source/headers/geos/operation/buffer/RightmostEdgeFinder.h,
-	  source/headers/geos/operation/buffer/SubgraphDepthLocater.h,
-	  source/headers/geos/operation/distance/ConnectedElementLocationFilter.h,
-	  source/headers/geos/operation/distance/ConnectedElementPointFilter.h,
-	  source/headers/geos/operation/distance/DistanceOp.h,
-	  source/headers/geos/operation/distance/GeometryLocation.h,
-	  source/headers/geos/operation/linemerge/EdgeString.h,
-	  source/headers/geos/operation/linemerge/LineMergeDirectedEdge.h,
-	  source/headers/geos/operation/linemerge/LineMergeEdge.h,
-	  source/headers/geos/operation/linemerge/LineMergeGraph.h,
-	  source/headers/geos/operation/linemerge/LineMerger.h,
-	  source/headers/geos/operation/linemerge/LineSequencer.h,
-	  source/headers/geos/operation/overlay/EdgeSetNoder.h,
-	  source/headers/geos/operation/overlay/ElevationMatrix.h,
-	  source/headers/geos/operation/overlay/ElevationMatrixCell.h,
-	  source/headers/geos/operation/overlay/LineBuilder.h,
-	  source/headers/geos/operation/overlay/MaximalEdgeRing.h,
-	  source/headers/geos/operation/overlay/MinimalEdgeRing.h,
-	  source/headers/geos/operation/overlay/MinimalEdgeRing.inl,
-	  source/headers/geos/operation/overlay/OverlayNodeFactory.h,
-	  source/headers/geos/operation/overlay/OverlayOp.h,
-	  source/headers/geos/operation/overlay/PointBuilder.h,
-	  source/headers/geos/operation/overlay/PolygonBuilder.h,
-	  source/headers/geos/operation/polygonize/EdgeRing.h,
-	  source/headers/geos/operation/polygonize/PolygonizeDirectedEdge.h,
-	  source/headers/geos/operation/polygonize/PolygonizeEdge.h,
-	  source/headers/geos/operation/polygonize/PolygonizeGraph.h,
-	  source/headers/geos/operation/predicate/RectangleContains.h,
-	  source/headers/geos/operation/predicate/RectangleIntersects.h,
-	  source/headers/geos/operation/predicate/SegmentIntersectionTester.h,
-	  source/headers/geos/operation/relate/EdgeEndBuilder.h,
-	  source/headers/geos/operation/relate/EdgeEndBundle.h,
-	  source/headers/geos/operation/relate/EdgeEndBundleStar.h,
-	  source/headers/geos/operation/relate/RelateComputer.h,
-	  source/headers/geos/operation/relate/RelateNode.h,
-	  source/headers/geos/operation/relate/RelateNodeFactory.h,
-	  source/headers/geos/operation/relate/RelateNodeGraph.h,
-	  source/headers/geos/operation/relate/RelateOp.h,
-	  source/headers/geos/operation/valid/ConnectedInteriorTester.h,
-	  source/headers/geos/operation/valid/ConsistentAreaTester.h,
-	  source/headers/geos/operation/valid/IsValidOp.h,
-	  source/headers/geos/operation/valid/QuadtreeNestedRingTester.h,
-	  source/headers/geos/operation/valid/RepeatedPointTester.h,
-	  source/headers/geos/operation/valid/SimpleNestedRingTester.h,
-	  source/headers/geos/operation/valid/SweeplineNestedRingTester.h,
-	  source/headers/geos/operation/valid/TopologyValidationError.h,
-	  source/headers/geos/planargraph.h,
-	  source/headers/geos/planargraph/DirectedEdge.h,
-	  source/headers/geos/planargraph/DirectedEdgeStar.h,
-	  source/headers/geos/planargraph/Edge.h,
-	  source/headers/geos/planargraph/GraphComponent.h,
-	  source/headers/geos/planargraph/Node.h,
-	  source/headers/geos/planargraph/NodeMap.h,
-	  source/headers/geos/planargraph/PlanarGraph.h,
-	  source/headers/geos/planargraph/Subgraph.h,
-	  source/headers/geos/planargraph/algorithm/ConnectedSubgraphFinder.h,
-	  source/headers/geos/platform.h.in,
-	  source/headers/geos/platform.h.vc,
-	  source/headers/geos/precision.h,
-	  source/headers/geos/precision/CommonBits.h,
-	  source/headers/geos/precision/CommonBitsOp.h,
-	  source/headers/geos/precision/CommonBitsRemover.h,
-	  source/headers/geos/precision/EnhancedPrecisionOp.h,
-	  source/headers/geos/precision/SimpleGeometryPrecisionReducer.h,
-	  source/headers/geos/profiler.h,
-	  source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h,
-	  source/headers/geos/simplify/DouglasPeuckerSimplifier.h,
-	  source/headers/geos/simplify/LineSegmentIndex.h,
-	  source/headers/geos/simplify/TaggedLineSegment.h,
-	  source/headers/geos/simplify/TaggedLineString.h,
-	  source/headers/geos/simplify/TaggedLineStringSimplifier.h,
-	  source/headers/geos/simplify/TaggedLinesSimplifier.h,
-	  source/headers/geos/simplify/TopologyPreservingSimplifier.h,
-	  source/headers/geos/spatialIndex.h,
-	  source/headers/geos/timeval.h, source/headers/geos/unload.h,
-	  source/headers/geos/util.h, source/headers/geos/util/Assert.h,
-	  source/headers/geos/util/AssertionFailedException.h,
-	  source/headers/geos/util/CoordinateArrayFilter.h,
-	  source/headers/geos/util/GEOSException.h,
-	  source/headers/geos/util/GeometricShapeFactory.h,
-	  source/headers/geos/util/IllegalArgumentException.h,
-	  source/headers/geos/util/TopologyException.h,
-	  source/headers/geos/util/UniqueCoordinateArrayFilter.h,
-	  source/headers/geos/util/UnsupportedOperationException.h,
-	  source/headers/geos/util/math.h,
-	  source/headers/geos/version.h.in,
-	  source/headers/geos/version.h.vc,
-	  source/index/bintree/Bintree.cpp,
-	  source/index/bintree/Interval.cpp, source/index/bintree/Key.cpp,
-	  source/index/bintree/Node.cpp, source/index/bintree/NodeBase.cpp,
-	  source/index/bintree/Root.cpp,
-	  source/index/chain/MonotoneChain.cpp,
-	  source/index/chain/MonotoneChainBuilder.cpp,
-	  source/index/chain/MonotoneChainOverlapAction.cpp,
-	  source/index/chain/MonotoneChainSelectAction.cpp,
-	  source/index/quadtree/DoubleBits.cpp,
-	  source/index/quadtree/IntervalSize.cpp,
-	  source/index/quadtree/Key.cpp, source/index/quadtree/Node.cpp,
-	  source/index/quadtree/NodeBase.cpp,
-	  source/index/quadtree/Quadtree.cpp,
-	  source/index/quadtree/Root.cpp,
-	  source/index/strtree/Interval.cpp,
-	  source/index/strtree/SIRtree.cpp,
-	  source/index/strtree/STRtree.cpp,
-	  source/index/sweepline/SweepLineEvent.cpp,
-	  source/index/sweepline/SweepLineIndex.cpp,
-	  source/index/sweepline/SweepLineInterval.cpp, source/inlines.cpp,
-	  source/io/ByteOrderDataInStream.cpp,
-	  source/io/ByteOrderValues.cpp, source/io/ParseException.cpp,
-	  source/io/StringTokenizer.cpp, source/io/Unload.cpp,
-	  source/io/WKBReader.cpp, source/io/WKBWriter.cpp,
-	  source/io/WKTReader.cpp, source/io/WKTWriter.cpp,
-	  source/io/Writer.cpp, source/noding/IntersectionAdder.cpp,
-	  source/noding/IntersectionFinderAdder.cpp,
-	  source/noding/IteratedNoder.cpp, source/noding/MCIndexNoder.cpp,
-	  source/noding/NodingValidator.cpp, source/noding/Octant.cpp,
-	  source/noding/ScaledNoder.cpp, source/noding/SegmentNode.cpp,
-	  source/noding/SegmentNodeList.cpp,
-	  source/noding/SegmentString.cpp, source/noding/SimpleNoder.cpp,
-	  source/noding/snapround/HotPixel.cpp,
-	  source/noding/snapround/MCIndexPointSnapper.cpp,
-	  source/noding/snapround/MCIndexSnapRounder.cpp,
-	  source/noding/snapround/SimpleSnapRounder.cpp,
-	  source/operation/GeometryGraphOperation.cpp,
-	  source/operation/IsSimpleOp.cpp,
-	  source/operation/buffer/BufferBuilder.cpp,
-	  source/operation/buffer/BufferOp.cpp,
-	  source/operation/buffer/BufferSubgraph.cpp,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp,
-	  source/operation/buffer/RightmostEdgeFinder.cpp,
-	  source/operation/buffer/SubgraphDepthLocater.cpp,
-	  source/operation/distance/ConnectedElementLocationFilter.cpp,
-	  source/operation/distance/ConnectedElementPointFilter.cpp,
-	  source/operation/distance/DistanceOp.cpp,
-	  source/operation/distance/GeometryLocation.cpp,
-	  source/operation/linemerge/EdgeString.cpp,
-	  source/operation/linemerge/LineMergeDirectedEdge.cpp,
-	  source/operation/linemerge/LineMergeEdge.cpp,
-	  source/operation/linemerge/LineMergeGraph.cpp,
-	  source/operation/linemerge/LineMerger.cpp,
-	  source/operation/linemerge/LineSequencer.cpp,
-	  source/operation/overlay/EdgeSetNoder.cpp,
-	  source/operation/overlay/ElevationMatrix.cpp,
-	  source/operation/overlay/ElevationMatrixCell.cpp,
-	  source/operation/overlay/LineBuilder.cpp,
-	  source/operation/overlay/MaximalEdgeRing.cpp,
-	  source/operation/overlay/MinimalEdgeRing.cpp,
-	  source/operation/overlay/OverlayNodeFactory.cpp,
-	  source/operation/overlay/OverlayOp.cpp,
-	  source/operation/overlay/PointBuilder.cpp,
-	  source/operation/overlay/PolygonBuilder.cpp,
-	  source/operation/polygonize/EdgeRing.cpp,
-	  source/operation/polygonize/PolygonizeDirectedEdge.cpp,
-	  source/operation/polygonize/PolygonizeEdge.cpp,
-	  source/operation/polygonize/PolygonizeGraph.cpp,
-	  source/operation/polygonize/Polygonizer.cpp,
-	  source/operation/predicate/RectangleContains.cpp,
-	  source/operation/predicate/RectangleIntersects.cpp,
-	  source/operation/predicate/SegmentIntersectionTester.cpp,
-	  source/operation/relate/EdgeEndBuilder.cpp,
-	  source/operation/relate/EdgeEndBundle.cpp,
-	  source/operation/relate/EdgeEndBundleStar.cpp,
-	  source/operation/relate/RelateComputer.cpp,
-	  source/operation/relate/RelateNode.cpp,
-	  source/operation/relate/RelateNodeFactory.cpp,
-	  source/operation/relate/RelateNodeGraph.cpp,
-	  source/operation/relate/RelateOp.cpp,
-	  source/operation/valid/ConnectedInteriorTester.cpp,
-	  source/operation/valid/ConsistentAreaTester.cpp,
-	  source/operation/valid/IsValidOp.cpp,
-	  source/operation/valid/QuadtreeNestedRingTester.cpp,
-	  source/operation/valid/RepeatedPointTester.cpp,
-	  source/operation/valid/SimpleNestedRingTester.cpp,
-	  source/operation/valid/SweeplineNestedRingTester.cpp,
-	  source/operation/valid/TopologyValidationError.cpp,
-	  source/planargraph/DirectedEdge.cpp,
-	  source/planargraph/DirectedEdgeStar.cpp,
-	  source/planargraph/Edge.cpp, source/planargraph/Node.cpp,
-	  source/planargraph/NodeMap.cpp,
-	  source/planargraph/PlanarGraph.cpp,
-	  source/planargraph/Subgraph.cpp,
-	  source/planargraph/algorithm/ConnectedSubgraphFinder.cpp,
-	  source/precision/CommonBits.cpp,
-	  source/precision/CommonBitsOp.cpp,
-	  source/precision/CommonBitsRemover.cpp,
-	  source/precision/EnhancedPrecisionOp.cpp,
-	  source/precision/GeometrySnapper.cpp,
-	  source/precision/LineStringSnapper.cpp,
-	  source/precision/SimpleGeometryPrecisionReducer.cpp,
-	  source/simplify/DouglasPeuckerSimplifier.cpp,
-	  source/simplify/LineSegmentIndex.cpp,
-	  source/simplify/TaggedLineSegment.cpp,
-	  source/simplify/TaggedLineString.cpp,
-	  source/simplify/TaggedLineStringSimplifier.cpp,
-	  source/simplify/TaggedLinesSimplifier.cpp,
-	  source/simplify/TopologyPreservingSimplifier.cpp,
-	  source/util/Assert.cpp, source/util/AssertionFailedException.cpp,
-	  source/util/GeometricShapeFactory.cpp,
-	  source/util/IllegalArgumentException.cpp,
-	  source/util/Profiler.cpp,
-	  source/util/UnsupportedOperationException.cpp,
-	  source/util/math.cpp, swig/geos.i, swig/python/geos.py,
-	  swig/python/python.i, swig/python/tests/example.py,
-	  swig/python/tests/runtests.py,
-	  swig/python/tests/test_geometry.py, swig/ruby/ruby.i,
-	  tests/bigtest/TestSweepLineSpeed.cpp, tests/bigtest/bigtest.h,
-	  tests/tut/tut.h, tests/tut/tut_reporter.h,
-	  tests/tut/tut_restartable.h,
-	  tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp,
-	  tests/unit/algorithm/PointLocatorTest.cpp,
-	  tests/unit/geom/Geometry/coversTest.cpp,
-	  tests/unit/geom/Geometry/isRectangleTest.cpp,
-	  tests/unit/geom/IntersectionMatrixTest.cpp,
-	  tests/unit/geom/TriangleTest.cpp, tests/unit/geos_unit.cpp,
-	  tests/unit/index/quadtree/DoubleBitsTest.cpp,
-	  tests/unit/io/ByteOrderValuesTest.cpp,
-	  tests/unit/noding/SegmentNodeTest.cpp,
-	  tests/unit/noding/SegmentPointComparatorTest.cpp,
-	  tests/unit/precision/GeometrySnapperTest.cpp,
-	  tests/unit/precision/LineStringSnapperTest.cpp,
-	  tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp,
-	  tests/unit/simplify/TopologyPreservingSimplifierTest.cpp,
-	  tests/unit/util/UniqueCoordinateArrayFilterTest.cpp,
-	  tests/unit/utility.h, tests/xmltester/CTS.cpp,
-	  tests/xmltester/SimpleWKTTester.cpp,
-	  tests/xmltester/Stackwalker.cpp, tests/xmltester/Stackwalker.h,
-	  tests/xmltester/XMLTester.cpp, tests/xmltester/XMLTester.h,
-	  tests/xmltester/markup/MarkupSTL.cpp,
-	  tests/xmltester/markup/MarkupSTL.h, tools/geos-config.in: Set
-	  svn:keyword property for Id keyword expansion.
+	* [r1820] Set svn:keyword property for Id keyword expansion.
 2006-09-06 15:50  Sandro Santilli <strk at keybit.net>
-	* [r1819]
-	  source/operation/overlay/FuzzyPointLocator.cpp: Fixed comments
-	  and includes
+	* [r1819] Fixed comments and includes
 2006-09-06 15:33  Sandro Santilli <strk at keybit.net>
-	* [r1818] ChangeLog,
-	  source/operation/overlay/FuzzyPointLocator.cpp: new helper class
-	  for Overlay op validation.
+	* [r1818] new helper class for Overlay op validation.
 2006-09-06 15:21  Sandro Santilli <strk at keybit.net>
-	* [r1817] source/headers/geos/geom/Geometry.h: (getBoundary) memory
-	  allocations documented
+	* [r1817] (getBoundary) memory allocations documented
 2006-09-05 16:18  Sandro Santilli <strk at keybit.net>
-	* [r1816] ChangeLog: updated (last commit log was bogus, refer to
-	  ChangeLog entry)
+	* [r1816] updated (last commit log was bogus, refer to ChangeLog
+	  entry)
 2006-09-05 16:07  Sandro Santilli <strk at keybit.net>
-	* [r1815] source/headers/geos/geom/BinaryOp.h,
-	  (OverlayOp::checkObviouslyWrongResult): exceptions messages
-	  rewording
+	* [r1815] (OverlayOp::checkObviouslyWrongResult): exceptions
+	  messages rewording
 2006-08-31 23:13  Sandro Santilli <strk at keybit.net>
-	* [r1814] ChangeLog, source/index/quadtree/Root.cpp:
-	  (insertContained): fixed bug reported in
+	* [r1814] (insertContained): fixed bug reported in
 	  geos-devel/2006-August/002541.html
 2006-08-31 23:07  Sandro Santilli <strk at keybit.net>
-	* [r1813] ChangeLog, configure.in: Reverted last two commits.
-	  Darwin host on buildbot seems to have its own problems...
+	* [r1813] Reverted last two commits. Darwin host on buildbot seems
+	  to have its own problems...
 2006-08-31 22:28  Sandro Santilli <strk at keybit.net>
-	* [r1812] configure.in: Ops, it was AM_CONFIG_HEADER the old
-	  version - still testing
+	* [r1812] Ops, it was AM_CONFIG_HEADER the old version - still
+	  testing
 2006-08-31 22:21  Sandro Santilli <strk at keybit.net>
-	* [r1811] ChangeLog, configure.in: AC_CONFIG_HEADERS =>
-	  AM_CONFIG_HEADER (to support older automake versions)
+	* [r1811] AC_CONFIG_HEADERS => AM_CONFIG_HEADER (to support older
+	  automake versions)
 2006-08-04 20:30  Howard Butler <hobu.inc at gmail.com>
-	* [r1810] capi/geos_c.h.vc: version should be 3.0.0 instead of
-	  3.3.0
+	* [r1810] version should be 3.0.0 instead of 3.3.0
 2006-08-04 20:29  Howard Butler <hobu.inc at gmail.com>
-	* [r1809] source/headers/geos/version.h.vc: bump patch to rc1
+	* [r1809] bump patch to rc1
 2006-08-04 20:23  Howard Butler <hobu.inc at gmail.com>
-	* [r1808] source/Makefile.vc: give makefile.vc some love
+	* [r1808] give makefile.vc some love
 2006-08-04 16:40  Charlie Savage <cfis at savagexi.com>
-	* [r1807] swig/geos.i, swig/python/geos.py,
-	  swig/python/geos_wrap.cxx, swig/ruby/geos_wrap.cxx: Updated SWIG
-	  bindings to expose the equalsExact and normalize methods.
+	* [r1807] Updated SWIG bindings to expose the equalsExact and
+	  normalize methods.
 2006-08-03 23:43  Charlie Savage <cfis at savagexi.com>
-	* [r1806] source/headers/geos/platform.h.in,
-	  source/headers/geos/timeval.h: Two changes needed to include the
-	  correct definitions for compiling geos using MingW/msys on
-	  Windows.
+	* [r1806] Two changes needed to include the correct definitions for
+	  compiling geos using MingW/msys on Windows.
 2006-08-03 22:46  Sandro Santilli <strk at keybit.net>
-	* [r1805] ChangeLog: try to keep text within 80 cols
+	* [r1805] try to keep text within 80 cols
 2006-08-03 22:24  Charlie Savage <cfis at savagexi.com>
-	* [r1804] configure.in: Changed configure.in to use *nix line
-	  feeds.
+	* [r1804] Changed configure.in to use *nix line feeds.
 2006-08-03 22:17  Charlie Savage <cfis at savagexi.com>
-	* [r1803] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_c.h.vc:
-	  Mistakenly used Geometry* in C api headers instead of GEOSGeom.
+	* [r1803] Mistakenly used Geometry* in C api headers instead of
+	  GEOSGeom.
 2006-08-03 22:13  Charlie Savage <cfis at savagexi.com>
-	* [r1802] configure.in: Removed native line endings for
-	  configure.in since CR/LF does not work on Windows under msys.
+	* [r1802] Removed native line endings for configure.in since CR/LF
+	  does not work on Windows under msys.
 2006-08-03 22:02  Charlie Savage <cfis at savagexi.com>
-	* [r1801] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in,
-	  capi/geos_c.h.vc: Added equalsExact and normalize to the c api as
-	  discussed on the mailing list
+	* [r1801] Added equalsExact and normalize to the c api as discussed
+	  on the mailing list
 	  (http://geos.refractions.net/pipermail/geos-devel/2006-July/002452.html).
 2006-08-03 21:34  Charlie Savage <cfis at savagexi.com>
-	* [r1800] ChangeLog, swig/python/Makefile.am,
-	  swig/ruby/Makefile.am: Updated build scripts so that
-	  ruby/geos_wrap.cxx, python/geos_wrap.cxx and python/geos.py are
-	  removed by make maintainer-clean but not make clean.
+	* [r1800] Updated build scripts so that ruby/geos_wrap.cxx,
+	  python/geos_wrap.cxx and python/geos.py are removed by make
+	  maintainer-clean but not make clean.
 2006-08-03 16:28  Mateusz Loskot <mateusz at loskot.net>
-	* [r1799] ChangeLog, tests/unit/geos_unit.cpp: Fixed Bug #90
+	* [r1799] Fixed Bug #90
 2006-08-03 16:18  Charlie Savage <cfis at savagexi.com>
-	* [r1798] swig/python/geos.py, swig/python/geos_wrap.cxx,
-	  swig/ruby/geos_wrap.cxx: Added SWIG generated wrapper files for
-	  Ruby and Python
+	* [r1798] Added SWIG generated wrapper files for Ruby and Python
 2006-07-27 06:18  Mateusz Loskot <mateusz at loskot.net>
-	* [r1797] .: Added svn:ignore property to ignore 'geos-3.0.0rc1'
-	  dir (testing commit access to SVN).
+	* [r1797] Added svn:ignore property to ignore 'geos-3.0.0rc1' dir
+	  (testing commit access to SVN).
 2006-07-26 19:06  Sandro Santilli <strk at keybit.net>
-	* [r1795] .cvsignore, capi/.cvsignore, doc/.cvsignore,
-	  macros/.cvsignore, source/.cvsignore,
-	  source/algorithm/.cvsignore, source/examples/.cvsignore,
-	  source/geom/.cvsignore, source/geom/util/.cvsignore,
-	  source/geomgraph/.cvsignore, source/geomgraph/index/.cvsignore,
-	  source/headers/.cvsignore, source/headers/geos/.cvsignore,
-	  source/headers/geos/algorithm/.cvsignore,
-	  source/headers/geos/geom/.cvsignore,
-	  source/headers/geos/geom/util/.cvsignore,
-	  source/headers/geos/geomgraph/.cvsignore,
-	  source/headers/geos/geomgraph/index/.cvsignore,
-	  source/headers/geos/index/.cvsignore,
-	  source/headers/geos/index/bintree/.cvsignore,
-	  source/headers/geos/index/chain/.cvsignore,
-	  source/headers/geos/index/quadtree/.cvsignore,
-	  source/headers/geos/index/strtree/.cvsignore,
-	  source/headers/geos/index/sweepline/.cvsignore,
-	  source/headers/geos/io/.cvsignore,
-	  source/headers/geos/noding/.cvsignore,
-	  source/headers/geos/noding/snapround/.cvsignore,
-	  source/headers/geos/operation/.cvsignore,
-	  source/headers/geos/operation/buffer/.cvsignore,
-	  source/headers/geos/operation/distance/.cvsignore,
-	  source/headers/geos/operation/linemerge/.cvsignore,
-	  source/headers/geos/operation/overlay/.cvsignore,
-	  source/headers/geos/operation/polygonize/.cvsignore,
-	  source/headers/geos/operation/predicate/.cvsignore,
-	  source/headers/geos/operation/relate/.cvsignore,
-	  source/headers/geos/operation/valid/.cvsignore,
-	  source/headers/geos/planargraph/.cvsignore,
-	  source/headers/geos/planargraph/algorithm/.cvsignore,
-	  source/headers/geos/precision/.cvsignore,
-	  source/headers/geos/simplify/.cvsignore,
-	  source/headers/geos/util/.cvsignore, source/index/.cvsignore,
-	  source/index/bintree/.cvsignore, source/index/chain/.cvsignore,
-	  source/index/quadtree/.cvsignore,
-	  source/index/strtree/.cvsignore,
-	  source/index/sweepline/.cvsignore, source/io/.cvsignore,
-	  source/noding/.cvsignore, source/noding/snapround/.cvsignore,
-	  source/operation/.cvsignore, source/operation/buffer/.cvsignore,
-	  source/operation/distance/.cvsignore,
-	  source/operation/linemerge/.cvsignore,
-	  source/operation/overlay/.cvsignore,
-	  source/operation/polygonize/.cvsignore,
-	  source/operation/predicate/.cvsignore,
-	  source/operation/relate/.cvsignore,
-	  source/operation/valid/.cvsignore, source/planargraph/.cvsignore,
-	  source/precision/.cvsignore, source/simplify/.cvsignore,
-	  source/util/.cvsignore, swig/.cvsignore, swig/python/.cvsignore,
-	  swig/python/tests/.cvsignore, swig/ruby/.cvsignore,
-	  swig/ruby/test/.cvsignore, tests/.cvsignore,
-	  tests/bigtest/.cvsignore, tests/tut/.cvsignore,
-	  tests/unit/.cvsignore, tests/xmltester/.cvsignore,
-	  tools/.cvsignore: Removed .cvsignore files from repository
+	* [r1795] Removed .cvsignore files from repository
 2006-07-26 17:51  Sandro Santilli <strk at keybit.net>
-	* [r1794] ChangeLog, capi/Makefile.am,
-	  tests/xmltester/XMLTester.cpp: * capi/Makefile.am: forced link of
-	  geostest against stdc++ lib
+	* [r1794] * capi/Makefile.am: forced link of geostest against
+	  stdc++ lib
 	  * tests/xmltester/XMLTester.cpp: added <cmath> include (for fabs
 	  use)
 2006-07-26 15:28  Sandro Santilli <strk at keybit.net>
-	* [r1776] ChangeLog, source/headers/geos/geom/BinaryOp.h: Added
-	  geometry snapping heuristic
+	* [r1776] Added geometry snapping heuristic
 2006-07-25 20:45  Sandro Santilli <strk at keybit.net>
-	* [r1775] ChangeLog, autogen.sh: Made autogen.sh errors more
-	  visible
+	* [r1775] Made autogen.sh errors more visible
 2006-07-21 19:37  Charlie Savage <cfis at savagexi.com>
-	* [r1773] NEWS: Added note about inclusion of version.in.vc. See
+	* [r1773] Added note about inclusion of version.in.vc. See
 	  http://geos.refractions.net/pipermail/geos-devel/2006-July/002463.html
 	  for more info.
 2006-07-21 17:59  Sandro Santilli <strk at keybit.net>
-	* [r1772] ChangeLog, tests/unit/Makefile.am,
-	  tests/unit/precision/GeometrySnapperTest.cpp: Added test for
-	  GeometrySnapper
+	* [r1772] Added test for GeometrySnapper
-	* [r1771] source/precision/LineStringSnapper.cpp: Fixed
-	  preprocessor directive use
+	* [r1771] Fixed preprocessor directive use
 2006-07-21 17:09  Sandro Santilli <strk at keybit.net>
-	* [r1770] ChangeLog,
-	  source/headers/geos/precision/GeometrySnapper.h,
-	  source/headers/geos/precision/LineStringSnapper.h,
-	  source/headers/geos/precision/Makefile.am,
-	  source/precision/Makefile.am, tests/unit/Makefile.am,
-	  tests/unit/precision,
-	  tests/unit/precision/LineStringSnapperTest.cpp: Added new
-	  precision::LineStringSnapper class + test
+	* [r1770] Added new precision::LineStringSnapper class + test
 	  and precision::GeometrySnapper (w/out test)
 2006-07-21 17:05  Sandro Santilli <strk at keybit.net>
-	* [r1769] ChangeLog, source/headers/geos/geom/CoordinateList.h:
-	  added operator<< for CoordinateList class
+	* [r1769] added operator<< for CoordinateList class
 2006-07-21 17:00  Sandro Santilli <strk at keybit.net>
-	* [r1768] ChangeLog, tests/unit/geom/LineSegmentTest.cpp: Added
-	  another distance() test
+	* [r1768] Added another distance() test
 2006-07-21 16:45  Mateusz Loskot <mateusz at loskot.net>
-	* [r1767] ChangeLog, source/headers/geos/geom.h,
-	  source/headers/geos/io.h: Wrapped FIXME message with #warning
-	  directive to shout about potential headers removal in future.
+	* [r1767] Wrapped FIXME message with #warning directive to shout
+	  about potential headers removal in future.
 2006-07-21 14:53  Sandro Santilli <strk at keybit.net>
-	* [r1766] ChangeLog, source/headers/geos/geom/CoordinateList.h,
-	  source/headers/geos/geom/Makefile.am, tests/unit/Makefile.am,
-	  tests/unit/geom/CoordinateListTest.cpp: CoordinateList class
-	  re-introduced, for list-based ops
+	* [r1766] CoordinateList class re-introduced, for list-based ops
 	  (not strictly mapped to JTS version, not yet at least)
 2006-07-21 14:49  Sandro Santilli <strk at keybit.net>
-	* [r1765] source/headers/geos/geom/LineSegment.h: Fixed typo in
-	  comment
+	* [r1765] Fixed typo in comment
 2006-07-21 08:33  Sandro Santilli <strk at keybit.net>
-	* [r1764] swig/ruby/test/Makefile.am: Removed blank space after
-	  backslash (automake complained)
+	* [r1764] Removed blank space after backslash (automake complained)
 2006-07-19 02:43  Charlie Savage <cfis at savagexi.com>
-	* [r1763] source/headers/geos/Makefile.am: Added veresion.h.vc as
-	  EXTRA_DIST to ensure it is packaged when doing make dist.
+	* [r1763] Added veresion.h.vc as EXTRA_DIST to ensure it is
+	  packaged when doing make dist.
 2006-07-15 19:36  Charlie Savage <cfis at savagexi.com>
-	* [r1762] configure.in: Removed python test/cases directory (tests
-	  are now just in tests directory).
+	* [r1762] Removed python test/cases directory (tests are now just
+	  in tests directory).
 2006-07-13 08:02  Charlie Savage <cfis at savagexi.com>
-	* [r1761] ChangeLog: Updated ChangeLog to note additional SWIG
-	  tests and integration with the GEOS build system.
+	* [r1761] Updated ChangeLog to note additional SWIG tests and
+	  integration with the GEOS build system.
 2006-07-13 07:49  Charlie Savage <cfis at savagexi.com>
-	* [r1760] capi/geos_c.h.vc: Updated version number to
-	  3.0.0rc1-CAPI-1.1.1 to match the autoconf generated files.
+	* [r1760] Updated version number to 3.0.0rc1-CAPI-1.1.1 to match
+	  the autoconf generated files.
 2006-07-13 07:38  Charlie Savage <cfis at savagexi.com>
-	* [r1759] swig/ruby/test/Makefile.am: Fixed spelling mistake in
-	  test task.
+	* [r1759] Fixed spelling mistake in test task.
 2006-07-13 07:36  Charlie Savage <cfis at savagexi.com>
-	* [r1758] swig/Makefile.am: Removed dependency on README.txt since
-	  it has been removed.
+	* [r1758] Removed dependency on README.txt since it has been
+	  removed.
 2006-07-13 07:35  Charlie Savage <cfis at savagexi.com>
-	* [r1757] swig/ruby/test/test_buffer.rb: New tests for the buffer
-	  operation.
+	* [r1757] New tests for the buffer operation.
 2006-07-13 07:29  Charlie Savage <cfis at savagexi.com>
-	* [r1756] configure.in: Added SWIG Python and Ruby bindings back
-	  into the main GEOS build system.
+	* [r1756] Added SWIG Python and Ruby bindings back into the main
+	  GEOS build system.
 2006-07-13 07:27  Charlie Savage <cfis at savagexi.com>
-	* [r1755] swig/python/tests/Makefile.am,
-	  swig/ruby/test/Makefile.am: Updated extra_dist for test
-	  directories.
+	* [r1755] Updated extra_dist for test directories.
 2006-07-13 07:20  Charlie Savage <cfis at savagexi.com>
-	* [r1754] swig/python/tests/Makefile.am: Remove the dependency on
-	  the cases subdirectory which is no longer needed.
+	* [r1754] Remove the dependency on the cases subdirectory which is
+	  no longer needed.
 2006-07-13 07:19  Charlie Savage <cfis at savagexi.com>
-	* [r1753] swig/python/tests/runtests.py: Updated test suite to use
-	  the correct tests.
+	* [r1753] Updated test suite to use the correct tests.
 2006-07-13 07:16  Charlie Savage <cfis at savagexi.com>
-	* [r1752] swig/python/tests/cases: Removed old tests cases which
-	  are no longer valid (worked using the C++ api).
+	* [r1752] Removed old tests cases which are no longer valid (worked
+	  using the C++ api).
 2006-07-13 07:14  Charlie Savage <cfis at savagexi.com>
-	* [r1751] swig/python/tests/test_geometry.py: New Python test case
-	  to ensure creating coordinate sequences and geometries works
-	  correctly.
+	* [r1751] New Python test case to ensure creating coordinate
+	  sequences and geometries works correctly.
-	* [r1750] swig/README.txt, swig/python/Makefile.am,
-	  swig/python/README.txt, swig/ruby/Makefile.am,
-	  swig/ruby/README.txt: Removed README.txt files which are no
-	  longer applicable now that the SWIG bindings have been
-	  intergrated into the GEOS build system.
+	* [r1750] Removed README.txt files which are no longer applicable
+	  now that the SWIG bindings have been intergrated into the GEOS
+	  build system.
 2006-07-13 07:13  Charlie Savage <cfis at savagexi.com>
-	* [r1749] swig/ruby/test/test_geometry.rb: Renamed test class.
+	* [r1749] Renamed test class.
 2006-07-13 07:09  Charlie Savage <cfis at savagexi.com>
-	* [r1748] swig/python/Makefile.am: Removed old, unused code.
+	* [r1748] Removed old, unused code.
-	* [r1747] swig/python/python.i: Added tyepmap to support creating
-	  polygons with holes.
+	* [r1747] Added tyepmap to support creating polygons with holes.
 2006-07-13 07:08  Charlie Savage <cfis at savagexi.com>
-	* [r1746] swig/geos.i: Added default value for quadsegs parmeter in
-	  buffer operation.
+	* [r1746] Added default value for quadsegs parmeter in buffer
+	  operation.
 2006-07-13 04:47  Charlie Savage <cfis at savagexi.com>
-	* [r1745] swig/python/tests/example.py: Manually moved from parent
-	  directory.
+	* [r1745] Manually moved from parent directory.
 2006-07-13 04:46  Charlie Savage <cfis at savagexi.com>
-	* [r1744] swig/python/Makefile.am: Updated EXTRA_DIST to include
-	  python.i and geos.pth
+	* [r1744] Updated EXTRA_DIST to include python.i and geos.pth
-	* [r1743] swig/python/example.py: Moved file to tests subdirectory.
+	* [r1743] Moved file to tests subdirectory.
 2006-07-13 04:45  Charlie Savage <cfis at savagexi.com>
-	* [r1742] swig/python/setup.py: Installation is now done by
-	  autoconf macros instead of setup.py
+	* [r1742] Installation is now done by autoconf macros instead of
+	  setup.py
 2006-07-13 04:39  Charlie Savage <cfis at savagexi.com>
-	* [r1741] swig/geos.i, swig/python/python.i, swig/ruby/ruby.i:
-	  Cleaned up ruby.i, added licenxe to python.i, commented back in
-	  python.i into geos.i.
+	* [r1741] Cleaned up ruby.i, added licenxe to python.i, commented
+	  back in python.i into geos.i.
 2006-07-13 04:09  Charlie Savage <cfis at savagexi.com>
-	* [r1740] swig/ruby/test/test_helper.rb: Added code to read xml
-	  test cases.
+	* [r1740] Added code to read xml test cases.
 2006-07-13 04:08  Charlie Savage <cfis at savagexi.com>
-	* [r1739] swig/geos.i: Added exception handling for results that
-	  return geometries. Added normalize and equalsExact, but for the
-	  moment they are commented out.
+	* [r1739] Added exception handling for results that return
+	  geometries. Added normalize and equalsExact, but for the moment
+	  they are commented out.
 2006-07-13 03:59  Charlie Savage <cfis at savagexi.com>
-	* [r1738] tests/xmltester/XMLTester.cpp: Changes to compile on VC++
-	  - fully qualified polygon name. Should also work on MingW, will
-	  test next.
+	* [r1738] Changes to compile on VC++ - fully qualified polygon
+	  name. Should also work on MingW, will test next.
 2006-07-12 23:17  Charlie Savage <cfis at savagexi.com>
-	* [r1737] swig/ruby/test/geos_tests.rb: Disabled
-	  test_combinations.rb for the moment since it fails.
+	* [r1737] Disabled test_combinations.rb for the moment since it
+	  fails.
 2006-07-12 23:16  Charlie Savage <cfis at savagexi.com>
-	* [r1736] swig/geos.i: Fixed serious bug in geom_to_hex and
-	  geom_to_wkb type maps. Was using temporary variable instead of
-	  passed in variable.
+	* [r1736] Fixed serious bug in geom_to_hex and geom_to_wkb type
+	  maps. Was using temporary variable instead of passed in variable.
 2006-07-12 22:55  Charlie Savage <cfis at savagexi.com>
-	* [r1735] capi/geos_c.h.vc: Switched GeosBytesOrder to int in api
-	  signatures.
+	* [r1735] Switched GeosBytesOrder to int in api signatures.
 2006-07-12 22:11  Charlie Savage <cfis at savagexi.com>
-	* [r1734] swig/geos.i: A number of changes to fix warning generated
-	  by gcc and to make sure the bindings compile for Python.
+	* [r1734] A number of changes to fix warning generated by gcc and
+	  to make sure the bindings compile for Python.
-	* [r1733] swig/python/Makefile.am: Updated Python SWIG makefile to
-	  build with the c api.
+	* [r1733] Updated Python SWIG makefile to build with the c api.
 2006-07-12 22:10  Charlie Savage <cfis at savagexi.com>
-	* [r1732] swig/ruby/ruby.i: Minor change to fix gcc warning.
+	* [r1732] Minor change to fix gcc warning.
-	* [r1731] swig/ruby/Makefile.am: Updated Ruby SWIG makefile to
+	* [r1731] Updated Ruby SWIG makefile to build with the c api.
 2006-07-12 21:03  Charlie Savage <cfis at savagexi.com>
-	* [r1730] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_c.h.vc:
-	  Fixed an error in the way GEOSByteOrder was declared. It is now
-	  an enum in geos_c.h
+	* [r1730] Fixed an error in the way GEOSByteOrder was declared. It
+	  is now an enum in geos_c.h
 2006-07-12 19:10  Charlie Savage <cfis at savagexi.com>
-	* [r1729] swig/geos.i: Added %rename directive so that GeomUnion is
-	  exposed as union is SWIG languages.
+	* [r1729] Added %rename directive so that GeomUnion is exposed as
+	  union is SWIG languages.
 2006-07-12 19:08  Charlie Savage <cfis at savagexi.com>
-	* [r1728] swig/ruby/test/geos_tests.rb,
-	  swig/ruby/test/test_combinations.rb,
-	  swig/ruby/test/test_operations.rb: Updated tests for combinatins
-	  (union, intersection, etc.) and operaptions (buffer, centroid,
-	  etc.).
+	* [r1728] Updated tests for combinatins (union, intersection, etc.)
+	  and operaptions (buffer, centroid, etc.).
 2006-07-12 19:07  Charlie Savage <cfis at savagexi.com>
-	* [r1727] swig/ruby/test/test_simple.rb: These tests are no longer
-	  needed.
+	* [r1727] These tests are no longer needed.
 2006-07-12 17:51  Charlie Savage <cfis at savagexi.com>
-	* [r1726] swig/ruby/test/geos_tests.rb,
-	  swig/ruby/test/test_helper.rb, swig/ruby/test/test_relations.rb:
-	  Ported old tests for relations, such as intersects, touches,
-	  etc., to new swig bindings.
+	* [r1726] Ported old tests for relations, such as intersects,
+	  touches, etc., to new swig bindings.
 2006-07-12 08:30  Charlie Savage <cfis at savagexi.com>
-	* [r1725] swig/ruby/ruby.i: Added type map needed to create
-	  polygons with holes. Unfortunately, this is Ruby specific. It
-	  needs to be ported to Python next.
+	* [r1725] Added type map needed to create polygons with holes.
+	  Unfortunately, this is Ruby specific. It needs to be ported to
+	  Python next.
 2006-07-12 08:29  Charlie Savage <cfis at savagexi.com>
-	* [r1724] swig/geos.i: Removed wrapper classes and replace them
-	  with SWIG "fake" classes. This makes the interface cleaner, and
-	  makes memory management much easier. Also added area, dimension,
-	  length, getExteriorRing, getInteriorRingN methods.
+	* [r1724] Removed wrapper classes and replace them with SWIG "fake"
+	  classes. This makes the interface cleaner, and makes memory
+	  management much easier. Also added area, dimension, length,
+	  getExteriorRing, getInteriorRingN methods.
 2006-07-12 08:27  Charlie Savage <cfis at savagexi.com>
-	* [r1723] swig/ruby/test/test_srid.rb: Added test to read from wkb
-	  geometry - currently fails, needs more investigation.
+	* [r1723] Added test to read from wkb geometry - currently fails,
+	  needs more investigation.
-	* [r1722] swig/ruby/test/test_io.rb: Added tests for invalid
-	  geometries.
+	* [r1722] Added tests for invalid geometries.
-	* [r1721] swig/ruby/test/geos_tests.rb: Updated ruby test suite.
+	* [r1721] Updated ruby test suite.
 2006-07-12 08:24  Charlie Savage <cfis at savagexi.com>
-	* [r1720] swig/ruby/test/test_geometry.rb: New tests for area,
-	  length, distance.
+	* [r1720] New tests for area, length, distance.
 2006-07-12 05:21  Charlie Savage <cfis at savagexi.com>
-	* [r1719] swig/ruby/test/test_coordinate_sequence.rb,
-	  swig/ruby/test/test_version.rb: Converted line feeds to Unix
-	  style.
+	* [r1719] Converted line feeds to Unix style.
-	* [r1718] swig/ruby/test/test_geometry.rb: New tests for creating
-	  geometries and calling various functions such as numGeometries,
-	  isValid, etc.
+	* [r1718] New tests for creating geometries and calling various
+	  functions such as numGeometries, isValid, etc.
 2006-07-12 05:20  Charlie Savage <cfis at savagexi.com>
-	* [r1717] swig/ruby/test/test_srid.rb: Tests for srid handling.
+	* [r1717] Tests for srid handling.
-	* [r1716] swig/ruby/test/test_io.rb: Merged tests from
-	  test_wkb_reader.rb
+	* [r1716] Merged tests from test_wkb_reader.rb
 2006-07-12 05:18  Charlie Savage <cfis at savagexi.com>
-	* [r1715] swig/ruby/test/test_wkb_reader.rb: Merging into
-	  test_io.rb
+	* [r1715] Merging into test_io.rb
 2006-07-12 04:46  Charlie Savage <cfis at savagexi.com>
-	* [r1714] swig/ruby/test/test_version.rb: Tests to verify returned
-	  version numbers from C api.
+	* [r1714] Tests to verify returned version numbers from C api.
 2006-07-11 18:48  Charlie Savage <cfis at savagexi.com>
-	* [r1713] swig/geos.i: Fixes for coordinate sequences. Fixed bug in
-	  range checking, chaned clone to be a method instead of copy
+	* [r1713] Fixes for coordinate sequences. Fixed bug in range
+	  checking, chaned clone to be a method instead of copy
 	  constructor, marked clone as creating a new object.
 2006-07-11 18:44  Charlie Savage <cfis at savagexi.com>
-	* [r1712] swig/ruby/test/test_coordinate_sequence.rb: Tests for
-	  SWIG coordinate sequence class.
+	* [r1712] Tests for SWIG coordinate sequence class.
 2006-07-11 09:07  Charlie Savage <cfis at savagexi.com>
-	* [r1711] capi/geos_c.h.in, capi/geos_c.h.vc: Added reference to
-	  new enum called GEOSByteOrders. The enum has two values,
-	  GEOS_WKB_NDR and GEOS_WKB_XDR which signify big endian and little
-	  endian byte orders.
+	* [r1711] Added reference to new enum called GEOSByteOrders. The
+	  enum has two values, GEOS_WKB_NDR and GEOS_WKB_XDR which signify
+	  big endian and little endian byte orders.
 2006-07-11 09:05  Charlie Savage <cfis at savagexi.com>
-	* [r1710] capi/geos_c.h.in, capi/geos_c.h.vc: Added 5 methods to
-	  the C API as documented in the changelong. The new methods are
-	  read/write WKB Hex values, read/write WKB byte order and read wkb
-	  output dimensions.
+	* [r1710] Added 5 methods to the C API as documented in the
+	  changelong. The new methods are read/write WKB Hex values,
+	  read/write WKB byte order and read wkb output dimensions.
 2006-07-11 08:55  Charlie Savage <cfis at savagexi.com>
-	* [r1709] swig/ruby/test/test_wkb_reader.rb: Test cases for reading
-	  and writing geometries to WKT, WKB and hex encoded WKB formats
-	  via the SWIG bindings.
+	* [r1709] Test cases for reading and writing geometries to WKT, WKB
+	  and hex encoded WKB formats via the SWIG bindings.
 2006-07-11 08:54  Charlie Savage <cfis at savagexi.com>
-	* [r1708] capi/geos_c.h.vc: Updated visual studio header file to
-	  match geos_c.h.in
+	* [r1708] Updated visual studio header file to match geos_c.h.in
 2006-07-11 08:53  Charlie Savage <cfis at savagexi.com>
-	* [r1707] capi/geos_c.cpp: Added 5 methods to the C API as
-	  documented in the changelong. The new methods are read/write WKB
-	  Hex values, read/write WKB byte order and read wkb output
-	  dimensions.
+	* [r1707] Added 5 methods to the C API as documented in the
 2006-07-11 08:52  Charlie Savage <cfis at savagexi.com>
-	* [r1706] ChangeLog: Noted additions to the C API and porting of
-	  SWIG to use the C api.
+	* [r1706] Noted additions to the C API and porting of SWIG to use
+	  the C api.
 2006-07-11 08:44  Charlie Savage <cfis at savagexi.com>
-	* [r1705] swig/geos.i, swig/ruby/ruby.i: Ported SWIG bindings to
-	  use c-api.
+	* [r1705] Ported SWIG bindings to use c-api.
 2006-07-10 22:29  Sandro Santilli <strk at keybit.net>
-	* [r1704] tests/tut, tests/tut/.cvsignore: Added .cvsignore file
+	* [r1704] Added .cvsignore file
 2006-07-10 21:51  Sandro Santilli <strk at keybit.net>
-	* [r1703] ChangeLog, capi/geos_c.cpp: don't use dynamic strings as
-	  format arg the formatted message callbacks.
+	* [r1703] don't use dynamic strings as format arg the formatted
+	  message callbacks.
 2006-07-10 10:16  Sandro Santilli <strk at keybit.net>
-	* [r1702] ChangeLog,
-	  source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h:
-	  changed vector<bool> to vector<short int> (see bug#101)
+	* [r1702] changed vector<bool> to vector<short int> (see bug#101)
 2006-07-09 03:37  Mateusz Loskot <mateusz at loskot.net>
-	* [r1701] tests/xmltester, tests/xmltester/.cvsignore: Added
-	  'testrunner' pattern to tests/xmltester/.cvsignore.
+	* [r1701] Added 'testrunner' pattern to tests/xmltester/.cvsignore.
 2006-07-09 03:21  Mateusz Loskot <mateusz at loskot.net>
-	* [r1700] ., .cvsignore: Added 'testrunner' to .cvsignore patterns.
+	* [r1700] Added 'testrunner' to .cvsignore patterns.
-	* [r1699] ChangeLog: Updated ChangeLog with details about new unit
-	  tests.
+	* [r1699] Updated ChangeLog with details about new unit tests.
 2006-07-09 03:16  Mateusz Loskot <mateusz at loskot.net>
-	* [r1698] tests/unit/Makefile.am: Added new tests to
-	  tests/unit/Makefile.am.
+	* [r1698] Added new tests to tests/unit/Makefile.am.
 2006-07-09 03:15  Mateusz Loskot <mateusz at loskot.net>
-	* [r1697] tests/unit/noding/SegmentNodeTest.cpp,
-	  tests/unit/noding/SegmentStringTest.cpp: Added new tests cases to
-	  tests/unit/noding. Removed zero-to-pointer casts.
+	* [r1697] Added new tests cases to tests/unit/noding. Removed
+	  zero-to-pointer casts.
 2006-07-09 00:24  Sandro Santilli <strk at keybit.net>
-	* [r1696] tests/xmltester/Makefile.am: Added testrunner to
-	  CLEANFILES. make distcheck now succeeds.
+	* [r1696] Added testrunner to CLEANFILES. make distcheck now
+	  succeeds.
 2006-07-08 00:33  Sandro Santilli <strk at keybit.net>
-	* [r1693] ChangeLog, configure.in, source/geom/Geometry.cpp,
-	  source/geom/GeometryFactory.cpp, source/geomgraph/EdgeRing.cpp,
-	  source/headers/geos/geom/Geometry.h,
-	  source/headers/geos/platform.h.in: * configure.in: incremented
-	  CAPI minor version, to avoid falling behind any future version
-	  from the 2.2. branch.
+	* [r1693] * configure.in: incremented CAPI minor version, to avoid
+	  falling behind any future version from the 2.2. branch.
 	  * source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
@@ -8160,712 +5060,445 @@
 2006-07-07 20:02  Mateusz Loskot <mateusz at loskot.net>
-	* [r1691] ChangeLog: Updated ChangeLog with version comparison fix
-	  in GEOS_UNIT.
+	* [r1691] Updated ChangeLog with version comparison fix in
+	  GEOS_UNIT.
 2006-07-07 20:00  Mateusz Loskot <mateusz at loskot.net>
-	* [r1690] macros/geos.m4: Fixed versions comparison in the
-	  GEOS_UNIT macro.
+	* [r1690] Fixed versions comparison in the GEOS_UNIT macro.
 2006-07-07 19:33  Sandro Santilli <strk at keybit.net>
-	* [r1689] ChangeLog, acsite.m4, configure.in: * acsite.m4: include
-	  <inttypes.h> rather then <stdint.h>
+	* [r1689] * acsite.m4: include <inttypes.h> rather then <stdint.h>
 	  (the latter is not available on Solaris 9)
 	  * configure.in: make sure CFLAGS is set before compiling
 	  using the 64bit integer detection macro.
 2006-07-06 16:39  Mateusz Loskot <mateusz at loskot.net>
-	* [r1688] ChangeLog, macros/geos.m4: Fixed version query regexp
-	  with escaped dots. Removed -lpq from GEOS_LIBS flags.
+	* [r1688] Fixed version query regexp with escaped dots. Removed
+	  -lpq from GEOS_LIBS flags.
 2006-07-05 23:27  Mateusz Loskot <mateusz at loskot.net>
-	* [r1687] ChangeLog, macros/geos.m4: Removed redundant -L and -I
-	  from GEOS_LIBS and GEOS_CFLAGS.
+	* [r1687] Removed redundant -L and -I from GEOS_LIBS and
+	  GEOS_CFLAGS.
 2006-07-05 23:10  Mateusz Loskot <mateusz at loskot.net>
-	* [r1686] ChangeLog, macros/geos.m4: Fixed GEOS_INIT to support
-	  full paths to geos-config passed to --with-geos. Fixed version
-	  decoding.
+	* [r1686] Fixed GEOS_INIT to support full paths to geos-config
+	  passed to --with-geos. Fixed version decoding.
 2006-07-05 22:54  Sandro Santilli <strk at keybit.net>
-	* [r1685] ChangeLog, tests/unit/Makefile.am: distribute utility.h
+	* [r1685] distribute utility.h
 2006-07-05 22:19  Sandro Santilli <strk at keybit.net>
-	* [r1684] ChangeLog, configure.in, tests/Makefile.am,
-	  tests/tut/Makefile.am: distribute the TUT framework.
+	* [r1684] distribute the TUT framework.
 2006-07-05 21:47  Sandro Santilli <strk at keybit.net>
-	* [r1683] ChangeLog, tests/xmltester/Makefile.am: Distribute XML
-	  tests and tester.
+	* [r1683] Distribute XML tests and tester.
 2006-07-05 21:18  Sandro Santilli <strk at keybit.net>
-	* [r1682] ChangeLog, source/operation/valid/Makefile.am: Fixed
-	  missing SweeplineNestedRingTester.cpp file.
+	* [r1682] Fixed missing SweeplineNestedRingTester.cpp file.
 2006-07-05 20:52  Sandro Santilli <strk at keybit.net>
-	* [r1681] ChangeLog,
-	  source/headers/geos/operation/linemerge/Makefile.am: Fixed
-	  missing backslash, dropping headers from distribution.
+	* [r1681] Fixed missing backslash, dropping headers from
+	  distribution.
 2006-07-05 20:20  Sandro Santilli <strk at keybit.net>
-	* [r1680] TODO: updated
+	* [r1680] updated
 2006-07-05 20:19  Sandro Santilli <strk at keybit.net>
-	* [r1679] ChangeLog,
-	  source/operation/overlay/OverlayOp.cpp: added checks for
-	  obviously wrong result of difference and intersection ops
+	* [r1679] added checks for obviously wrong result of difference and
+	  intersection ops
 2006-06-27 15:59  Sandro Santilli <strk at keybit.net>
-	* [r1677] ChangeLog, source/algorithm/HCoordinate.cpp: *
-	  source/algorithm/HCoordinate.cpp: added support for MingW -ansi
-	  builds.
+	* [r1677] * source/algorithm/HCoordinate.cpp: added support for
+	  MingW -ansi builds.
 2006-06-27 15:26  Sandro Santilli <strk at keybit.net>
-	* [r1676] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: *
-	  capi/geos_c.cpp: fixed forward declaration of
+	* [r1676] * capi/geos_c.cpp: fixed forward declaration of
 	  GEOSCoordSeq_getOrdinate.
 	  * capi/geos_c.h.in: renamed GEOSGeomTypeId enum to GEOSGeomTypes,
 	  to make VC++ 2005 happy.
 2006-06-19 23:33  Sandro Santilli <strk at keybit.net>
-	* [r1675] ChangeLog, source/headers/geos/geom/CoordinateFilter.h,
-	  source/noding/ScaledNoder.cpp: Don't *require* CoordinateFilters
-	  to define both read-only and read-write methods.
+	* [r1675] Don't *require* CoordinateFilters to define both
+	  read-only and read-write methods.
 2006-06-19 22:52  Sandro Santilli <strk at keybit.net>
-	* [r1674] ChangeLog, source/geom/Polygon.cpp: optimized loops
+	* [r1674] optimized loops
 2006-06-19 21:20  Sandro Santilli <strk at keybit.net>
-	* [r1673] ChangeLog, source/geom/util/GeometryTransformer.cpp,
-	  source/headers/geos/geom/util/GeometryTransformer.h: updated port
-	  info
+	* [r1673] updated port info
 2006-06-19 21:17  Sandro Santilli <strk at keybit.net>
-	* [r1672] ChangeLog, source/geom/GeometryFactory.cpp,
-	  source/headers/geos/geom/GeometryFactory.inl: port info and
-	  doxygen dox.
+	* [r1672] port info and doxygen dox.
 2006-06-19 20:48  Sandro Santilli <strk at keybit.net>
-	* [r1671] ChangeLog, tests/xmltester/XMLTester.cpp: parseCase():
-	  make sure to exit the <case> tag before returning
+	* [r1671] parseCase(): make sure to exit the <case> tag before
+	  returning
 2006-06-14 19:27  Sandro Santilli <strk at keybit.net>
-	* [r1670] ChangeLog, source/geom/Coordinate.cpp,
-	  source/headers/geos/geom/Coordinate.inl: Let the compiler
-	  synthetize copy ctor and assignment op for Coordinate class to
-	  obtain better numerical stability.
+	* [r1670] Let the compiler synthetize copy ctor and assignment op
+	  for Coordinate class to obtain better numerical stability.
 2006-06-14 19:19  Sandro Santilli <strk at keybit.net>
-	* [r1669] ChangeLog, tests/xmltester/XMLTester.cpp: Added support
-	  for "AreaTest" operations.
+	* [r1669] Added support for "AreaTest" operations.
 2006-06-14 19:17  Sandro Santilli <strk at keybit.net>
-	* [r1668] ChangeLog, source/operation/overlay/PolygonBuilder.cpp:
-	  Fixed bug in findShell() needlessly erasing vector elements
+	* [r1668] Fixed bug in findShell() needlessly erasing vector
+	  elements
 2006-06-14 15:38  Sandro Santilli <strk at keybit.net>
-	* [r1667] source/operation/overlay/OverlayOp.cpp: Fixed
-	  just-introduced bug
+	* [r1667] Fixed just-introduced bug
 2006-06-14 15:03  Sandro Santilli <strk at keybit.net>
-	* [r1666] ChangeLog, source/operation/overlay/OverlayOp.cpp: *
-	  source/operation/overlay/OverlayOp.cpp: use NodeMap::container
-	  and related typedefs, removed (int) casts, optimized loops.
+	* [r1666] * source/operation/overlay/OverlayOp.cpp: use
+	  NodeMap::container and related typedefs, removed (int) casts,
+	  optimized loops.
 2006-06-14 14:32  Sandro Santilli <strk at keybit.net>
-	* [r1665] ChangeLog, source/geomgraph/EdgeEnd.cpp,
-	  source/headers/geos/geomgraph/EdgeEnd.h: EdgeEnd::getEdge() made
-	  non-virtual and inlined.
+	* [r1665] EdgeEnd::getEdge() made non-virtual and inlined.
 2006-06-14 13:59  Sandro Santilli <strk at keybit.net>
-	* [r1664] ChangeLog, source/operation/overlay/PolygonBuilder.cpp:
-	  Fixed bug in PolygonBuilder::placePolygonHoles, performance
-	  improved as a side effect.
+	* [r1664] Fixed bug in PolygonBuilder::placePolygonHoles,
+	  performance improved as a side effect.
 2006-06-13 23:26  Sandro Santilli <strk at keybit.net>
-	* [r1663] ChangeLog,
-	  source/operation/overlay/PolygonBuilder.cpp: cleanups
+	* [r1663] cleanups
 2006-06-13 22:50  Sandro Santilli <strk at keybit.net>
-	* [r1662] ChangeLog, source/headers/geos/io/WKTReader.inl: *
-	  source/headers/geos/io/WKTReader.inl: added missing include for
-	  GEOS_DEBUG set case, use stderr for debugging output.
+	* [r1662] * source/headers/geos/io/WKTReader.inl: added missing
+	  include for GEOS_DEBUG set case, use stderr for debugging output.
 2006-06-13 22:19  Sandro Santilli <strk at keybit.net>
-	* [r1661] ChangeLog, source/operation/overlay/LineBuilder.cpp:
-	  fixed unused parameter warning
+	* [r1661] fixed unused parameter warning
 2006-06-13 22:00  Sandro Santilli <strk at keybit.net>
-	* [r1660] ChangeLog, source/headers/geos/geomgraph/GeometryGraph.h:
-	  Changed GeometryGraph::lineEdgeMap set comparison function to be
-	  pointer-based. Should be safe and much faster. Available tests
-	  all succeed.
+	* [r1660] Changed GeometryGraph::lineEdgeMap set comparison
+	  function to be pointer-based. Should be safe and much faster.
+	  Available tests all succeed.
 2006-06-13 21:42  Sandro Santilli <strk at keybit.net>
-	* [r1659] source/operation/overlay/OverlayOp.cpp: trimmed cvs log,
-	  cleanups
+	* [r1659] trimmed cvs log, cleanups
 2006-06-13 21:40  Sandro Santilli <strk at keybit.net>
-	* [r1658] source/geomgraph/GeometryGraph.cpp: Cleanups and some
-	  more debugging lines
+	* [r1658] Cleanups and some more debugging lines
 2006-06-13 21:38  Sandro Santilli <strk at keybit.net>
-	* [r1657] ChangeLog, source/geom/Geometry.cpp: Added self
-	  comparison check in Geometry::compareTo().
+	* [r1657] Added self comparison check in Geometry::compareTo().
 2006-06-13 19:16  Sandro Santilli <strk at keybit.net>
-	* [r1656] ChangeLog: fixed mis-assigned commit
+	* [r1656] fixed mis-assigned commit
 2006-06-12 17:18  Sandro Santilli <strk at keybit.net>
-	* [r1655] ChangeLog, source/simplify/LineSegmentIndex.cpp:
-	  LineSegmentIndex: explicitly initialized parent class in
+	* [r1655] LineSegmentIndex: explicitly initialized parent class in
 	  constructors.
 2006-06-12 17:15  Sandro Santilli <strk at keybit.net>
-	* [r1654] ChangeLog, source/headers/geos/index/quadtree/Root.h,
-	  source/headers/geos/operation/polygonize/Polygonizer.h: Removed
-	  unused parameters warning
+	* [r1654] Removed unused parameters warning
 2006-06-12 17:14  Sandro Santilli <strk at keybit.net>
-	* [r1653] ChangeLog, source/headers/geos/geom/GeometryFilter.h:
-	  added assert(0) version of filter_ro() and filter_rw() to allow
-	  implementations to only defined the required one.
+	* [r1653] added assert(0) version of filter_ro() and filter_rw() to
+	  allow implementations to only defined the required one.
 2006-06-12 16:59  Sandro Santilli <strk at keybit.net>
-	* [r1652] tests/bigtest/TestSweepLineSpeed.cpp,
-	  tests/xmltester/SimpleWKTTester.cpp: Removed unused parameter
-	  warnings
+	* [r1652] Removed unused parameter warnings
 2006-06-12 16:57  Sandro Santilli <strk at keybit.net>
-	* [r1651] source/headers/geos/planargraph/Node.h: Added note about
-	  ownership of return from getEdgesBetween()
+	* [r1651] Added note about ownership of return from
+	  getEdgesBetween()
 2006-06-12 16:55  Sandro Santilli <strk at keybit.net>
-	* [r1650] ChangeLog, source/headers/geos/io/WKTWriter.h,
-	  source/io/WKTWriter.cpp: fixed compiler warnings, fixed some
-	  methods to omit unused parameters.
+	* [r1650] fixed compiler warnings, fixed some methods to omit
+	  unused parameters.
 2006-06-12 16:51  Sandro Santilli <strk at keybit.net>
-	* [r1649] ChangeLog, source/geom/CoordinateSequence.cpp,
-	  tests/unit/geom/CoordinateArraySequenceTest.cpp: Added equality
-	  and inequality operators and tests
+	* [r1649] Added equality and inequality operators and tests
 2006-06-12 16:36  Sandro Santilli <strk at keybit.net>
-	* [r1648] ChangeLog, source/geom/CoordinateSequence.cpp,
-	  source/headers/geos/geom/CoordinateSequence.h: indentation, notes
-	  about things to be fixed.
+	* [r1648] indentation, notes about things to be fixed.
 2006-06-12 15:47  Sandro Santilli <strk at keybit.net>
-	* [r1647] ChangeLog, source/planargraph/Node.cpp: implemented
-	  missing getEdgesBetween() method (untested).
+	* [r1647] implemented missing getEdgesBetween() method (untested).
 2006-06-12 15:46  Sandro Santilli <strk at keybit.net>
-	* [r1646] source/headers/geos/planargraph/DirectedEdge.h,
-	  source/planargraph/DirectedEdge.cpp: provided a memory friendly
-	  version of toEdges() method.
+	* [r1646] provided a memory friendly version of toEdges() method.
 2006-06-12 15:07  Sandro Santilli <strk at keybit.net>
-	* [r1645] ChangeLog, source/geom/CoordinateArraySequence.cpp:
-	  explicitly invoked CoordinateSequence (copy) ctor - suggested by
-	  GCC warning.
+	* [r1645] explicitly invoked CoordinateSequence (copy) ctor -
+	  suggested by GCC warning.
 2006-06-12 15:06  Sandro Santilli <strk at keybit.net>
-	* [r1644] source/headers/geos/geom/CoordinateSequence.h: Added
-	  default ctor and copy ctor (protected)
+	* [r1644] Added default ctor and copy ctor (protected)
 2006-06-12 13:57  Sandro Santilli <strk at keybit.net>
-	* [r1643] ChangeLog, acsite.m4, configure.in,
-	  source/headers/geos/platform.h.in: Check for int64_t type for
-	  int64 typedef.
+	* [r1643] Check for int64_t type for int64 typedef.
 2006-06-12 11:29  Sandro Santilli <strk at keybit.net>
-	* [r1642] ChangeLog, source/algorithm/SimplePointInAreaLocator.cpp,
-	  source/geomgraph/EdgeNodingValidator.cpp,
-	  source/geomgraph/EdgeRing.cpp,
-	  source/geomgraph/GeometryGraph.cpp,
-	  source/geomgraph/PlanarGraph.cpp,
-	  source/geomgraph/TopologyLocation.cpp,
-	  source/geomgraph/index/MonotoneChainEdge.cpp,
-	  source/geomgraph/index/SimpleEdgeSetIntersector.cpp,
-	  source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
-	  source/headers/geos/geom/CoordinateArraySequenceFactory.h,
-	  source/headers/geos/geom/CoordinateArraySequenceFactory.inl,
-	  source/headers/geos/geom/LineSegment.inl,
-	  source/headers/geos/geom/Location.h,
-	  source/simplify/DouglasPeuckerLineSimplifier.cpp,
-	  source/simplify/TaggedLineString.cpp, source/util/Profiler.cpp:
-	  unsigned int => size_t
+	* [r1642] unsigned int => size_t
 2006-06-12 10:49  Sandro Santilli <strk at keybit.net>
-	* [r1641] ChangeLog, source/algorithm/ConvexHull.cpp,
-	  source/algorithm/PointLocator.cpp, source/geom/Envelope.cpp,
-	  source/geom/LineString.cpp,
-	  source/headers/geos/geom/LineString.h,
-	  source/headers/geos/index/strtree/AbstractSTRtree.h,
-	  source/headers/geos/index/strtree/SIRtree.h,
-	  source/headers/geos/index/strtree/STRtree.h,
-	  source/index/strtree/AbstractSTRtree.cpp,
-	  source/planargraph/PlanarGraph.cpp: unsigned int => size_t
+	* [r1641] unsigned int => size_t
 2006-06-12 10:39  Sandro Santilli <strk at keybit.net>
-	* [r1640] ChangeLog, tests/xmltester/XMLTester.cpp: don't print
-	  test file precision model if verbosity level < 2.
+	* [r1640] don't print test file precision model if verbosity level
+	  < 2.
 2006-06-12 10:10  Sandro Santilli <strk at keybit.net>
-	* [r1639] ChangeLog, NEWS, capi/geos_c.h.in,
-	  source/algorithm/CGAlgorithms.cpp,
-	  source/geom/CoordinateArraySequence.cpp,
-	  source/geom/CoordinateSequence.cpp, source/geom/Geometry.cpp,
-	  source/geom/GeometryCollection.cpp,
-	  source/geom/IntersectionMatrix.cpp, source/geom/LineString.cpp,
-	  source/geom/LinearRing.cpp, source/geom/MultiLineString.cpp,
-	  source/geom/MultiPolygon.cpp, source/geom/Polygon.cpp,
-	  source/headers/geos/geom/CoordinateArraySequence.h,
-	  source/headers/geos/geom/CoordinateSequence.h,
-	  source/headers/geos/geom/CoordinateSequenceFactory.h,
-	  source/headers/geos/geom/GeometryCollection.h,
-	  source/headers/geos/geom/LineSegment.h,
-	  source/headers/geos/util/UniqueCoordinateArrayFilter.h: Fixed
-	  getGeometryN() to take size_t rather then int, changed unsigned
-	  int parameters to size_t.
+	* [r1639] Fixed getGeometryN() to take size_t rather then int,
+	  changed unsigned int parameters to size_t.
 2006-06-09 08:28  Sandro Santilli <strk at keybit.net>
-	* [r1638] tests/xmltester/SimpleWKTTester.cpp: Removed compiler
-	  warning
+	* [r1638] Removed compiler warning
 2006-06-09 08:17  Sandro Santilli <strk at keybit.net>
-	* [r1637] ChangeLog, tests/unit/noding/SegmentStringTest.cpp:
-	  removed signed/unsigned comparison warnings.
+	* [r1637] removed signed/unsigned comparison warnings.
 2006-06-09 08:09  Sandro Santilli <strk at keybit.net>
-	* [r1636] ChangeLog, tests/unit/geom/LinearRingTest.cpp,
-	  tests/unit/geom/MultiPointTest.cpp,
-	  tests/unit/geom/PolygonTest.cpp: removed signed/unsigned
-	  comparison warnings.
+	* [r1636] removed signed/unsigned comparison warnings.
 2006-06-09 08:02  Sandro Santilli <strk at keybit.net>
-	* [r1635] ChangeLog, tests/unit/geom/LineStringTest.cpp: Fixed
-	  signed/unsigned comparison tests
+	* [r1635] Fixed signed/unsigned comparison tests
 2006-06-09 07:42  Sandro Santilli <strk at keybit.net>
-	* [r1634] ChangeLog, source/geomgraph/GeometryGraph.cpp,
+	* [r1634] * source/geomgraph/GeometryGraph.cpp,
-	  source/operation/valid/RepeatedPointTester.cpp: *
 	  source/operation/valid/RepeatedPointTester.cpp: Fixed warning
 	  after Polygon ring accessor methods changed to work with size_t.
 	  Small optimizations in loops.
 2006-06-09 06:41  Sandro Santilli <strk at keybit.net>
-	* [r1633] ChangeLog: Added missing log for mloskot change
+	* [r1633] Added missing log for mloskot change
 2006-06-08 18:50  Mateusz Loskot <mateusz at loskot.net>
-	* [r1632] tests/unit/geom/DimensionTest.cpp: Fixed no-effect
-	  warning in test<1> from DimensionTest.cpp.
+	* [r1632] Fixed no-effect warning in test<1> from
+	  DimensionTest.cpp.
 2006-06-08 18:18  Sandro Santilli <strk at keybit.net>
-	* [r1631] ChangeLog, tests/unit/geom/GeometryFactoryTest.cpp: *
-	  tests/unit/geom/GeometryFactoryTest.cpp: fixed compiler warnings
-	  about signed/unsigned comparisons.
+	* [r1631] * tests/unit/geom/GeometryFactoryTest.cpp: fixed compiler
+	  warnings about signed/unsigned comparisons.
 2006-06-08 17:58  Sandro Santilli <strk at keybit.net>
-	* [r1630] ChangeLog, NEWS, source/algorithm/CentroidArea.cpp,
-	  source/geom/Polygon.cpp, source/geom/util/GeometryEditor.cpp,
-	  source/headers/geos/geom/Polygon.h, source/io/WKTWriter.cpp:
-	  Polygon::getNumInteriorRing() return size_t,
+	* [r1630] Polygon::getNumInteriorRing() return size_t,
 	  Polygon::interiorRingN() takes size_t.
 2006-06-08 17:46  Sandro Santilli <strk at keybit.net>
-	* [r1629] ChangeLog,
-	  tests/unit/geom/CoordinateArraySequenceTest.cpp: *
-	  tests/unit/geom/CoordinateArraySequenceTest.cpp: fix
+	* [r1629] * tests/unit/geom/CoordinateArraySequenceTest.cpp: fix
 	  signed/unsigned comparison warning.
 2006-06-08 15:55  Sandro Santilli <strk at keybit.net>
-	* [r1628] ChangeLog, tests/xmltester/markup/MarkupSTL.cpp: *
-	  tests/xmltester/markup/MarkupSTL.cpp: removed use of
+	* [r1628] * tests/xmltester/markup/MarkupSTL.cpp: removed use of
 	  allocator<char>, which brings in some incompatibilities with
 	  libstdc++ 6.0.7 (gcc 4.0.2).
 2006-06-08 13:19  Sandro Santilli <strk at keybit.net>
-	* [r1627] configure.in: Commented out ruby and python detection
+	* [r1627] Commented out ruby and python detection
 2006-06-08 12:58  Sandro Santilli <strk at keybit.net>
-	* [r1626] tests/xmltester/Makefile.am,
-	  tests/xmltester/testrunner.sh: Fixed xml testrunner rule
+	* [r1626] Fixed xml testrunner rule
 2006-06-08 12:16  Sandro Santilli <strk at keybit.net>
-	* [r1625] ChangeLog, tests/xmltester/Makefile.am,
-	  tests/xmltester/testrunner.sh: added XML tests run to the 'make
-	  check' rule.
+	* [r1625] added XML tests run to the 'make check' rule.
 2006-06-08 11:20  Sandro Santilli <strk at keybit.net>
-	* [r1624] ChangeLog,
-	  source/headers/geos/geom/GeometryComponentFilter.h,
-	  source/headers/geos/geom/GeometryFilter.h,
-	  source/headers/geos/geom/util/CoordinateOperation.h,
-	  source/headers/geos/geom/util/GeometryEditorOperation.h,
-	  source/headers/geos/geom/util/ShortCircuitedGeometryVisitor.h,
-	  source/headers/geos/geomgraph/NodeFactory.h,
-	  source/headers/geos/index/ItemVisitor.h,
-	  source/headers/geos/index/sweepline/SweepLineOverlapAction.h:
-	  Added missing virtual destructor to abstract classes.
+	* [r1624] Added missing virtual destructor to abstract classes.
 2006-06-07 20:04  Sandro Santilli <strk at keybit.net>
-	* [r1623] ChangeLog, configure.in: * configure.in: enforce -Wall
-	  -ansi -pedantic -Wno-long-long to C and CXX flags.
+	* [r1623] * configure.in: enforce -Wall -ansi -pedantic
+	  -Wno-long-long to C and CXX flags.
 2006-06-07 19:45  Sandro Santilli <strk at keybit.net>
-	* [r1622] swig/ruby/test/Makefile.am: Renamed (reserved) TESTS
-	  variable to RUBY_TESTS
+	* [r1622] Renamed (reserved) TESTS variable to RUBY_TESTS
 2006-06-07 19:26  Sandro Santilli <strk at keybit.net>
-	* [r1621] Makefile.am: Fixed SUBDIRS order, and added a NOTE about
-	  maintaining it.
+	* [r1621] Fixed SUBDIRS order, and added a NOTE about maintaining
+	  it.
 2006-06-07 17:03  Sandro Santilli <strk at keybit.net>
-	* [r1620] ChangeLog, Makefile.am, configure.in,
-	  swig/python/Makefile.am, swig/ruby/Makefile.am,
-	  swig/ruby/test/Makefile.am: * Makefile.am, configure.in,
-	  swig/ruby/test/Makefile.am: swig removed from automatic build
-	  process.
+	* [r1620] * Makefile.am, configure.in, swig/python/Makefile.am,
+	  swig/ruby/Makefile.am, swig/ruby/test/Makefile.am: swig removed
+	  from automatic build process.
 	  * configure.in: removed check for boost availability.
 2006-06-07 16:07  Sandro Santilli <strk at keybit.net>
-	* [r1619] configure.in: Set release version to 3.0.0rc1
+	* [r1619] Set release version to 3.0.0rc1
 2006-06-07 14:10  Mateusz Loskot <mateusz at loskot.net>
-	* [r1618] ChangeLog, tests/unit/Makefile.am: Update ChangeLog with
-	  info about new test case isPointInRingTest.cpp.
+	* [r1618] Update ChangeLog with info about new test case
+	  isPointInRingTest.cpp.
 2006-06-07 14:06  Mateusz Loskot <mateusz at loskot.net>
-	* [r1617] tests/unit/algorithm/CGAlgorithms/isPointInRing.cpp,
-	  tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp: Renamed
-	  file isPointInRing.cpp to isPointInRingTest.cpp to follow GEOS
-	  Unit Test convention.
+	* [r1617] Renamed file isPointInRing.cpp to isPointInRingTest.cpp
+	  to follow GEOS Unit Test convention.
 2006-06-07 13:52  Mateusz Loskot <mateusz at loskot.net>
-	* [r1616] tests/unit/Makefile.am,
-	  tests/unit/algorithm/CGAlgorithms,
-	  tests/unit/algorithm/CGAlgorithms/isPointInRing.cpp: Added new
-	  test: CGAlgorithms/isPointInRing.cpp.
+	* [r1616] Added new test: CGAlgorithms/isPointInRing.cpp.
 2006-06-07 13:10  Sandro Santilli <strk at keybit.net>
-	* [r1615] ChangeLog, source/headers/geos/geom.h: Removed Triangle.h
-	  include from geom.h
+	* [r1615] Removed Triangle.h include from geom.h
 2006-06-07 13:08  Sandro Santilli <strk at keybit.net>
-	* [r1614] ChangeLog, source/headers/geos/geom/Makefile.am: *
-	  source/headers/geos/geom/Makefile.am: removed Triangle.h from
-	  installed header set.
+	* [r1614] * source/headers/geos/geom/Makefile.am: removed
+	  Triangle.h from installed header set.
 2006-06-05 19:42  Sandro Santilli <strk at keybit.net>
-	* [r1613] ChangeLog, source/headers/geos/Makefile.am,
-	  source/headers/geos/algorithm/Makefile.am,
-	  source/headers/geos/geom/util/Makefile.am,
-	  source/headers/geos/geomgraph/Makefile.am,
-	  source/headers/geos/geomgraph/index/Makefile.am,
-	  source/headers/geos/geosAlgorithm.h,
-	  source/headers/geos/index/Makefile.am,
-	  source/headers/geos/index/bintree/Makefile.am,
-	  source/headers/geos/index/chain/Makefile.am,
-	  source/headers/geos/index/quadtree/Makefile.am,
-	  source/headers/geos/index/strtree/Makefile.am,
-	  source/headers/geos/index/sweepline/Makefile.am,
-	  source/headers/geos/indexSweepline.h,
-	  source/headers/geos/io/Makefile.am,
-	  source/headers/geos/noding/Makefile.am,
-	  source/headers/geos/noding/snapround/Makefile.am,
-	  source/headers/geos/nodingSnapround.h,
-	  source/headers/geos/opDistance.h,
-	  source/headers/geos/opOverlay.h,
-	  source/headers/geos/opPolygonize.h,
-	  source/headers/geos/opPredicate.h,
-	  source/headers/geos/opRelate.h,
-	  source/headers/geos/operation/Makefile.am,
-	  source/headers/geos/operation/buffer/Makefile.am,
-	  source/headers/geos/operation/distance/Makefile.am,
-	  source/headers/geos/operation/linemerge/Makefile.am,
-	  source/headers/geos/operation/overlay/Makefile.am,
-	  source/headers/geos/operation/polygonize/Makefile.am,
-	  source/headers/geos/operation/predicate/Makefile.am,
-	  source/headers/geos/operation/relate/Makefile.am,
-	  source/headers/geos/operation/valid/Makefile.am,
-	  source/headers/geos/planargraph.h,
-	  source/headers/geos/planargraph/Makefile.am,
-	  source/headers/geos/planargraph/algorithm/Makefile.am,
-	  source/headers/geos/util.h, source/headers/geos/util/Makefile.am:
-	  Fixed noinst_geos_HEADERS => noinst_HEADERS.
+	* [r1613] Fixed noinst_geos_HEADERS => noinst_HEADERS.
 2006-06-05 15:36  Sandro Santilli <strk at keybit.net>
-	* [r1612] ChangeLog, NEWS, capi/geos_c.cpp,
-	  source/geom/Geometry.cpp, source/headers/geos/noding.h,
-	  source/headers/geos/operation/overlay/LineBuilder.h,
-	  source/headers/geos/operation/overlay/OverlayOp.h,
-	  source/headers/geos/operation/overlay/PointBuilder.h,
-	  tests/xmltester/XMLTester.cpp: Given OverlayOp funx code enum a
-	  name and renamed values to have a lowercase prefix. Drop all of
-	  noding headers from installed header set.
+	* [r1612] Given OverlayOp funx code enum a name and renamed values
+	  to have a lowercase prefix. Drop all of noding headers from
+	  installed header set.
 2006-06-03 22:31  Howard Butler <hobu.inc at gmail.com>
-	* [r1611] source/Makefile.vc: update to track latest removals
+	* [r1611] update to track latest removals
 2006-06-03 22:29  Howard Butler <hobu.inc at gmail.com>
-	* [r1610] source/simplify/DouglasPeuckerLineSimplifier.cpp: Use a
-	  fully qualified namespace for LineSegment because we're inside of
-	  geos::simplify at the time
+	* [r1610] Use a fully qualified namespace for LineSegment because
+	  we're inside of geos::simplify at the time
 2006-06-01 11:49  Sandro Santilli <strk at keybit.net>
-	* [r1609] ChangeLog, source/headers/geos/geomgraph.h,
-	  source/headers/geos/geomgraph/Node.h,
-	  source/headers/geos/geomgraph/PlanarGraph.h,
-	  source/headers/geos/io.h, source/headers/geos/io/Makefile.am,
-	  source/headers/geos/io/WKBReader.h,
-	  source/headers/geos/opValid.h,
-	  source/headers/geos/precision.h,
-	  source/io/WKTWriter.cpp, source/io/Writer.cpp: Reduced installed
-	  headers form geomgraph namespace
+	* [r1609] Reduced installed headers form geomgraph namespace
 2006-06-01 10:28  Sandro Santilli <strk at keybit.net>
-	* [r1608] ChangeLog, source/headers/geos/index/bintree/Makefile.am,
-	  source/headers/geos/indexBintree.h,
-	  source/headers/geos/indexChain.h,
-	  source/headers/geos/indexQuadtree.h,
-	  source/headers/geos/indexStrtree.h,
-	  source/headers/geos/operation/valid/SweeplineNestedRingTester.h,
-	  source/operation/valid/Makefile.am: Reduced number of installed
-	  headers for the geos::index namespace
+	* [r1608] Reduced number of installed headers for the geos::index
+	  namespace
 2006-05-25 18:44  Sandro Santilli <strk at keybit.net>
-	* [r1607] ChangeLog, tests/unit/geom/TriangleTest.cpp: *
-	  tests/unit/geom/TriangleTest.cpp: take floating-point rounding
-	  error into account.
+	* [r1607] * tests/unit/geom/TriangleTest.cpp: take floating-point
+	  rounding error into account.
 2006-05-25 16:11  Mateusz Loskot <mateusz at loskot.net>
-	* [r1606] tests/tut/tut.h: Changed precision constant with
-	  epsilon() from std::numeric_limits.
+	* [r1606] Changed precision constant with epsilon() from
+	  std::numeric_limits.
 2006-05-25 15:54  Mateusz Loskot <mateusz at loskot.net>
-	* [r1605] tests/tut/tut.h: Added specialization of ensure_equals
-	  for double type.
+	* [r1605] Added specialization of ensure_equals for double type.
 2006-05-24 16:29  Sandro Santilli <strk at keybit.net>
-	* [r1604] ChangeLog, source/index/quadtree/DoubleBits.cpp: *
-	  source/index/quadtree/DoubleBits.cpp: handled negative or zero
-	  values in getExponent().
+	* [r1604] * source/index/quadtree/DoubleBits.cpp: handled negative
+	  or zero values in getExponent().
 2006-05-24 16:01  Sandro Santilli <strk at keybit.net>
-	* [r1603] ChangeLog, tests/unit/utility.h: * tests/unit/utility.h:
-	  fixed missing return from isSameStructure's specialization on
-	  GeometryCollection, also fixed a signed/unsigned mismatch warning
-	  there.
+	* [r1603] * tests/unit/utility.h: fixed missing return from
+	  isSameStructure's specialization on GeometryCollection, also
+	  fixed a signed/unsigned mismatch warning there.
 2006-05-24 15:42  Sandro Santilli <strk at keybit.net>
-	* [r1602] ChangeLog, source/util/CoordinateArrayFiter.cpp,
-	  source/util/GEOSException.cpp, source/util/Makefile.am,
-	  source/util/UniqueCoordinateArrayFilter.cpp: *
-	  source/util/Makefile.am, source/util/CoordinateArrayFiter.cpp,
+	* [r1602] * source/util/Makefile.am,
+	  source/util/CoordinateArrayFiter.cpp,
 	  source/util/UniqueCoordinateArrayFilter.cpp: removed empty
 	  implementation files.
 2006-05-24 15:32  Sandro Santilli <strk at keybit.net>
-	* [r1601] ChangeLog,
-	  source/headers/geos/simplify/TaggedLinesSimplifier.h: *
-	  source/headers/geos/simplify/TaggedLinesSimplifier.h: added
-	  LineSegmentIndex.h include so that every use of the templated
-	  simplify() function get all the required definitions.
+	* [r1601] * source/headers/geos/simplify/TaggedLinesSimplifier.h:
+	  added LineSegmentIndex.h include so that every use of the
+	  templated simplify() function get all the required definitions.
 2006-05-24 15:17  Sandro Santilli <strk at keybit.net>
-	* [r1600] ChangeLog, source/headers/geos/algorithm/Makefile.am,
-	  source/headers/geos/opLinemerge.h,
-	  source/headers/geos/planargraph/Makefile.am: Reduced number of
-	  installed headers in geos/operation/ subdir
+	* [r1600] Reduced number of installed headers in geos/operation/
+	  subdir
 2006-05-24 13:44  Sandro Santilli <strk at keybit.net>
-	* [r1599] NEWS: Added a note about unit tests being introduced
+	* [r1599] Added a note about unit tests being introduced
 2006-05-24 11:44  Mateusz Loskot <mateusz at loskot.net>
-	* [r1598] ChangeLog: Added missing entries to ChangeLog.
+	* [r1598] Added missing entries to ChangeLog.
 2006-05-24 11:41  Sandro Santilli <strk at keybit.net>
-	* [r1597] ChangeLog,
-	  source/headers/geos/simplify/TaggedLinesSimplifier.h,
+	* [r1597] * source/headers/geos/simplify/TaggedLinesSimplifier.h,
 	  source/simplify/TaggedLinesSimplifier.cpp,
-	  source/simplify/TopologyPreservingSimplifier.cpp: *
-	  source/simplify/TaggedLinesSimplifier.cpp,
 	  fixed bug in TopologyPreservingSimplifier failing to
 	  detect intersections, refactored TaggedLinesSimplifier
@@ -8874,150 +5507,124 @@
 2006-05-24 08:32  Sandro Santilli <strk at keybit.net>
-	* [r1596] ChangeLog, capi/geos_c.h.in: * capi/geos_c.h.in: #include
-	  <stddef.h> to get size_t definition (only #ifndef __cplusplus)
+	* [r1596] * capi/geos_c.h.in: #include <stddef.h> to get size_t
+	  definition (only #ifndef __cplusplus)
 2006-05-24 05:53  Mateusz Loskot <mateusz at loskot.net>
-	* [r1595] tests/unit/Makefile.am,
-	  tests/unit/utility.h: Added new test:
-	  TopologyPreservingSimplifierTest.cpp. Added new utility.cpp
-	  helper for Unit Tests (implementes utils from JTS Unit Tests).
+	* [r1595] Added new test: TopologyPreservingSimplifierTest.cpp.
+	  Added new utility.cpp helper for Unit Tests (implementes utils
+	  from JTS Unit Tests).
 2006-05-23 15:06  Sandro Santilli <strk at keybit.net>
-	* [r1594] ChangeLog, source/headers/geos/geom/Coordinate.h: *
-	  source/headers/geos/geom/Coordinate.h: added missing <string>
-	  include.
+	* [r1594] * source/headers/geos/geom/Coordinate.h: added missing
+	  <string> include.
 2006-05-23 14:44  Sandro Santilli <strk at keybit.net>
-	* [r1593] ChangeLog, source/headers/geos/config.h: *
-	  source/headers/geos/config.h: removed file which is not supposed
-	  to be in the repository.
+	* [r1593] * source/headers/geos/config.h: removed file which is not
+	  supposed to be in the repository.
 2006-05-23 14:29  Sandro Santilli <strk at keybit.net>
-	* [r1592] ChangeLog,
-	  source/headers/geos/index/quadtree/DoubleBits.h,
-	  source/index/quadtree/DoubleBits.cpp: *
+	* [r1592] * source/headers/geos/index/quadtree/DoubleBits.h,
 	  source/index/quadtree/DoubleBits.cpp: const correctness and
 	  documentation.
 2006-05-23 13:21  Sandro Santilli <strk at keybit.net>
-	* [r1591] tests/unit/io/ByteOrderValuesTest.cpp: Added test for
-	  put/get Long values
+	* [r1591] Added test for put/get Long values
 2006-05-23 13:16  Sandro Santilli <strk at keybit.net>
-	* [r1590] ChangeLog, source/io/WKBWriter.cpp: Fixed a bug in
-	  WKBWriter::writeByteOrder() failing to consider machine's byte
-	  order
+	* [r1590] Fixed a bug in WKBWriter::writeByteOrder() failing to
+	  consider machine's byte order
 2006-05-23 12:57  Sandro Santilli <strk at keybit.net>
-	* [r1589] tests/unit/geom/CoordinateTest.cpp: Fixed small typo in
-	  label
+	* [r1589] Fixed small typo in label
 2006-05-23 12:33  Sandro Santilli <strk at keybit.net>
-	* [r1588] ChangeLog, source/io/ByteOrderValues.cpp: *
-	  source/io/ByteOrderValues.cpp: fixed bug in putLong() also
-	  affecting putDouble()
+	* [r1588] * source/io/ByteOrderValues.cpp: fixed bug in putLong()
+	  also affecting putDouble()
 2006-05-23 12:23  Sandro Santilli <strk at keybit.net>
-	* [r1587] ChangeLog, tests/unit/Makefile.am,
-	  tests/unit/io/ByteOrderValuesTest.cpp: * tests/unit/Makefile.am,
+	* [r1587] * tests/unit/Makefile.am,
 	  tests/unit/io/ByteOrderValuesTest.cpp: unit test for
 	  ByteOrderValues class.
 2006-05-23 11:07  Sandro Santilli <strk at keybit.net>
-	* [r1586] ChangeLog, source/io/WKBWriter.cpp: *
-	  source/io/WKBWriter.cpp: fixed bug in ::writeInt missing to
-	  honour the requested byte order.
+	* [r1586] * source/io/WKBWriter.cpp: fixed bug in ::writeInt
+	  missing to honour the requested byte order.
 2006-05-23 10:56  Sandro Santilli <strk at keybit.net>
-	* [r1585] tests/unit/io/WKBReaderTest.cpp: Fixed top comment
+	* [r1585] Fixed top comment
 2006-05-23 10:48  Sandro Santilli <strk at keybit.net>
-	* [r1584] ChangeLog, tests/unit/io/WKBReaderTest.cpp: *
-	  tests/unit/io/WKBReaderTest.cpp: cleaned up and added both XDR
-	  and NDR tests.
+	* [r1584] * tests/unit/io/WKBReaderTest.cpp: cleaned up and added
+	  both XDR and NDR tests.
 2006-05-23 09:24  Sandro Santilli <strk at keybit.net>
-	* [r1583] ChangeLog, source/headers/geos/io/WKBConstants.h,
-	  source/io/ByteOrderValues.cpp: * source/io/ByteOrderValues.cpp:
-	  changed ENDIAN_BIG and ENDIAN_LITTLE values to match
-	  WKBConstants::XDR and WKBConstants::NDR respectively.
+	* [r1583] * source/io/ByteOrderValues.cpp: changed ENDIAN_BIG and
+	  ENDIAN_LITTLE values to match WKBConstants::XDR and
+	  WKBConstants::NDR respectively.
 	  * source/headers/geos/io/WKBConstants.h: added comments about
 	  meaning of XDR/NDR.
 2006-05-22 15:08  Sandro Santilli <strk at keybit.net>
-	* [r1582] source/headers/geos/util/GEOSException.h: Print colon
-	  after exception name (as it has always been)
+	* [r1582] Print colon after exception name (as it has always been)
 2006-05-19 17:44  Sandro Santilli <strk at keybit.net>
-	* [r1581] ChangeLog,
+	* [r1581] * source/simplify/TopologyPreservingSimplifier.cpp:
 	  removed friend specification in
 	  TopologyPreservingSimplifier helper class
 	  (no more needed)
 2006-05-19 17:39  Sandro Santilli <strk at keybit.net>
-	* [r1580] ChangeLog, tests/unit/geom/Geometry/coversTest.cpp: *
-	  tests/unit/geom/Geometry/coversTest.cpp:
+	* [r1580] * tests/unit/geom/Geometry/coversTest.cpp:
 	  keep tests in 'tut' namespace.
 2006-05-19 16:38  Sandro Santilli <strk at keybit.net>
-	* [r1579] ChangeLog, tests/xmltester/XMLTester.cpp: *
-	  tests/xmltester/XMLTester.cpp: report
+	* [r1579] * tests/xmltester/XMLTester.cpp: report
 	  error on load of requested tests.
 2006-05-18 10:19  Sandro Santilli <strk at keybit.net>
-	* [r1578] ChangeLog, source/headers/geos/geom.h: *
-	  source/headers/geos/geom.h: fixed doxygen header for mainpage.
+	* [r1578] * source/headers/geos/geom.h: fixed doxygen header for
+	  mainpage.
 2006-05-18 10:16  Sandro Santilli <strk at keybit.net>
-	* [r1577] NEWS: Added note about the new BinaryOp class and its
-	  uses.
+	* [r1577] Added note about the new BinaryOp class and its uses.
 2006-05-18 10:13  Sandro Santilli <strk at keybit.net>
-	* [r1576] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
-	  source/headers/geos/geom/BinaryOp.h: added compile-time defines
-	  to avoid precision-reduction and simplify based policies (default
-	  to enabled).
+	* [r1576] * source/headers/geos/geom/BinaryOp.h: added compile-time
+	  defines to avoid precision-reduction and simplify based policies
+	  (default to enabled).
 2006-05-18 09:32  Sandro Santilli <strk at keybit.net>
-	* [r1575] NEWS: added note about new Geometry predicates
+	* [r1575] added note about new Geometry predicates
 2006-05-18 09:00  Sandro Santilli <strk at keybit.net>
-	* [r1574] ChangeLog, tests/unit/geom/Geometry/coversTest.cpp: Added
-	  tests for coveredBy(), fixed ChangeLog entry
+	* [r1574] Added tests for coveredBy(), fixed ChangeLog entry
 2006-05-18 08:56  Sandro Santilli <strk at keybit.net>
-	* [r1573] ChangeLog, source/geom/Geometry.cpp,
-	  source/headers/geos/geom/Geometry.h, tests/unit/Makefile.am,
-	  tests/unit/geom/Geometry/coversTest.cpp: *
+	* [r1573] * source/geom/Geometry.cpp,
 	  source/headers/geos/geom/Geometry.h: added
 	  covers() and isCoveredBy() predicates.
@@ -9026,418 +5633,322 @@
 2006-05-17 17:41  Sandro Santilli <strk at keybit.net>
-	* [r1572] source/geom/IntersectionMatrix.cpp,
-	  source/headers/geos/geom/IntersectionMatrix.h,
-	  tests/unit/geom/IntersectionMatrixTest.cpp: Added output operator
-	  + test
+	* [r1572] Added output operator + test
 2006-05-17 17:24  Sandro Santilli <strk at keybit.net>
-	* [r1571] ChangeLog, source/geom/IntersectionMatrix.cpp,
-	  source/headers/geos/geom/IntersectionMatrix.h: Added port info,
-	  fixed isCoveredBy() comment.
+	* [r1571] Added port info, fixed isCoveredBy() comment.
 2006-05-17 17:20  Sandro Santilli <strk at keybit.net>
-	* [r1570] ChangeLog, source/geom/IntersectionMatrix.cpp,
-	  tests/unit/geom/IntersectionMatrixTest.cpp: added isCovers() and
-	  isCoveredBy() public methods to IntersectionMatrix and associated
-	  tests.
+	* [r1570] added isCovers() and isCoveredBy() public methods to
+	  IntersectionMatrix and associated tests.
 2006-05-17 08:40  Sandro Santilli <strk at keybit.net>
-	* [r1569] source/headers/geos/geom/BinaryOp.h: typo fixed to make
-	  description more clear
+	* [r1569] typo fixed to make description more clear
 2006-05-13 10:42  Mateusz Loskot <mateusz at loskot.net>
-	* [r1563] tests/unit/algorithm/PointLocatorTest.cpp: Fixed
-	  line-ends in PointLocatorTest.cpp file.
+	* [r1563] Fixed line-ends in PointLocatorTest.cpp file.
 2006-05-13 08:26  Mateusz Loskot <mateusz at loskot.net>
-	* [r1562] ., .cvsignore, tests/unit, tests/unit/.cvsignore,
-	  tests/unit/geom/Geometry/isRectangleTest.cpp: Fixed line-ends in
-	  isRectangleTest.cpp. Added new patterns to .cvsignore.
+	* [r1562] Fixed line-ends in isRectangleTest.cpp. Added new
+	  patterns to .cvsignore.
 2006-05-05 15:40  Sandro Santilli <strk at keybit.net>
-	* [r1561] ChangeLog,
-	  source/noding/snapround/MCIndexSnapRounder.cpp,
-	  source/noding/snapround/SimpleSnapRounder.cpp: Had nodind
-	  validation error throw an exception for SimpleSnapRounder
+	* [r1561] Had nodind validation error throw an exception for
+	  SimpleSnapRounder
 	  and MCIndexSnapRounder
 2006-05-05 14:34  Sandro Santilli <strk at keybit.net>
-	* [r1560] ChangeLog, tests/unit/Makefile.am, tests/unit/noding,
-	  tests/unit/noding/SegmentStringTest.cpp: New SegmentString unit
-	  test
+	* [r1560] New SegmentString unit test
 2006-05-05 14:25  Sandro Santilli <strk at keybit.net>
-	* [r1559] source/headers/geos/noding/SegmentString.h,
-	  source/headers/geos/noding/SegmentString.inl,
-	  source/noding/SegmentString.cpp: moved getSegmentOctant out of
-	  .inl into .cpp, renamed private eiList to nodeList as in JTS,
-	  added more assertion checking and fixed doxygen comments
+	* [r1559] moved getSegmentOctant out of .inl into .cpp, renamed
+	  private eiList to nodeList as in JTS, added more assertion
+	  checking and fixed doxygen comments
 2006-05-05 10:19  Sandro Santilli <strk at keybit.net>
-	* [r1558] ChangeLog, source/headers/geos/noding/SegmentString.h,
-	  source/noding/SegmentNodeList.cpp: droppped
-	  SegmentString::getContext(), new name is getData() to reflect
-	  change in JTS
+	* [r1558] droppped SegmentString::getContext(), new name is
+	  getData() to reflect change in JTS
 2006-05-05 09:37  Sandro Santilli <strk at keybit.net>
-	* [r1557] ChangeLog, source/headers/geos/geom.h: *
-	  source/headers/geos/geom.h: fixed namespace qualification in
-	  doxygen page about C++ interface.
+	* [r1557] * source/headers/geos/geom.h: fixed namespace
+	  qualification in doxygen page about C++ interface.
 2006-05-04 15:49  Sandro Santilli <strk at keybit.net>
-	* [r1556] ChangeLog, source/geom/GeometryCollection.cpp,
-	  source/geom/LineString.cpp, source/geom/MultiLineString.cpp,
-	  source/geom/MultiPoint.cpp, source/geom/MultiPolygon.cpp,
-	  source/geom/Point.cpp, source/geom/Polygon.cpp,
-	  source/headers/geos/geom/Dimension.h,
-	  source/headers/geos/geom/MultiLineString.h,
-	  source/headers/geos/geom/MultiPoint.h,
-	  source/headers/geos/geom/MultiPolygon.h,
-	  source/headers/geos/geom/Point.h,
-	  source/operation/buffer/BufferOp.cpp: updated all
-	  Geometry::getDimension() methods to return
+	* [r1556] updated all Geometry::getDimension() methods to return
 	  Dimension::DimensionType (closes bug#93)
 2006-05-04 14:05  Sandro Santilli <strk at keybit.net>
-	* [r1555] ChangeLog, source/geom/PrecisionModel.cpp,
-	  source/headers/geos/noding/snapround/HotPixel.inl,
-	  source/headers/geos/util/math.h, source/noding/ScaledNoder.cpp: *
-	  source/headers/geos/util/math.h: provided an util::round() method
-	  being an inline proxy to call appropriate default rounding
-	  function for the whole GEOS codebase. Currently pointing at
-	  util::java_math_round() being the last being used.
+	* [r1555] * source/headers/geos/util/math.h: provided an
+	  util::round() method being an inline proxy to call appropriate
+	  default rounding function for the whole GEOS codebase. Currently
+	  pointing at util::java_math_round() being the last being used.
 2006-05-04 13:38  Sandro Santilli <strk at keybit.net>
-	* [r1554] source/headers/geos/geomgraph/DirectedEdge.h: doxygen
-	  comments cleanup
+	* [r1554] doxygen comments cleanup
 2006-05-04 12:54  Sandro Santilli <strk at keybit.net>
-	* [r1553] ChangeLog, source/headers/geos/geomgraph/NodeMap.h: Added
-	  invariant tester for NodeMap class, fixed comment about ownership
-	  of NodeFactory
+	* [r1553] Added invariant tester for NodeMap class, fixed comment
+	  about ownership of NodeFactory
 2006-05-04 12:33  Sandro Santilli <strk at keybit.net>
-	* [r1552] source/operation/buffer/BufferSubgraph.cpp: Added some
-	  comments about RightmostEdgeFinder only considering forward
-	  DirectedEdge
+	* [r1552] Added some comments about RightmostEdgeFinder only
+	  considering forward DirectedEdge
 2006-05-04 12:19  Sandro Santilli <strk at keybit.net>
-	* [r1551]
-	  source/headers/geos/operation/buffer/RightmostEdgeFinder.h: Added
-	  note about findEdge() only scanning for forward DirectedEdges
+	* [r1551] Added note about findEdge() only scanning for forward
+	  DirectedEdges
 2006-05-04 12:17  Sandro Santilli <strk at keybit.net>
-	* [r1550] source/geomgraph/PlanarGraph.cpp: Added comment about
-	  management of newly created DirectedEdges
+	* [r1550] Added comment about management of newly created
+	  DirectedEdges
 2006-05-04 10:15  Sandro Santilli <strk at keybit.net>
-	* [r1549] ChangeLog,
-	  source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h:
-	  Doxygen comments
+	* [r1549] Doxygen comments
 2006-05-04 09:16  Sandro Santilli <strk at keybit.net>
-	* [r1548] source/operation/buffer/BufferBuilder.cpp: Added JTS
-	  debugging, for comparison with JTS
+	* [r1548] Added JTS debugging, for comparison with JTS
 2006-05-04 08:42  Sandro Santilli <strk at keybit.net>
-	* [r1547] ChangeLog, source/headers/geos/geom/CoordinateSequence.h:
-	  Added note about the CoordinateSequence::toVector() method.
+	* [r1547] Added note about the CoordinateSequence::toVector()
+	  method.
 2006-05-04 08:35  Sandro Santilli <strk at keybit.net>
-	* [r1546] ChangeLog, source/noding/SegmentNodeList.cpp:
-	  noding/SegmentNodeList.cpp: cleanups, changed output operator to
-	  be more similar to JTS
+	* [r1546] noding/SegmentNodeList.cpp: cleanups, changed output
+	  operator to be more similar to JTS
 2006-05-04 08:30  Sandro Santilli <strk at keybit.net>
-	* [r1545] source/noding/ScaledNoder.cpp: removed use of
-	  SegmentString::setCoordinates() [dropped]
+	* [r1545] removed use of SegmentString::setCoordinates() [dropped]
 2006-05-04 08:29  Sandro Santilli <strk at keybit.net>
-	* [r1544] ChangeLog, source/headers/geos/noding/SegmentString.h,
-	  source/headers/geos/noding/SegmentString.inl: *
-	  source/noding/ScaledNoder.cpp: removed use of
+	* [r1544] * source/noding/ScaledNoder.cpp: removed use of
 	  SegmentString::setCoordinates().
 	  * source/headers/geos/noding/SegmentStrign.{h,inl}: removed new
 	  setCoordinates() interface.
 2006-05-04 07:43  Sandro Santilli <strk at keybit.net>
-	* [r1543] ChangeLog, source/headers/geos/noding/SegmentString.h,
-	  source/noding/SegmentString.cpp: output operator for
-	  SegmentString class
+	* [r1543] output operator for SegmentString class
 2006-05-04 07:41  Sandro Santilli <strk at keybit.net>
-	* [r1542] ChangeLog, source/headers/geos/noding/SegmentNodeList.h:
-	  const-correct size() method for SegmentNodeList
+	* [r1542] const-correct size() method for SegmentNodeList
 2006-05-04 06:36  Sandro Santilli <strk at keybit.net>
-	* [r1541] source/headers/geos/noding/ScaledNoder.h: Extended
-	  definition to take new CoordinateSequence tracking into account
+	* [r1541] Extended definition to take new CoordinateSequence
+	  tracking into account
 2006-05-03 20:05  Sandro Santilli <strk at keybit.net>
-	* [r1540] ChangeLog, source/noding/ScaledNoder.cpp: Added SQL
-	  debugging output
+	* [r1540] Added SQL debugging output
 2006-05-03 19:47  Sandro Santilli <strk at keybit.net>
-	* [r1539] ChangeLog, source/geom/CoordinateSequence.cpp,
-	  source/headers/geos/geom/CoordinateSequence.h: added operator<<
-	  for CoordinateSequence
+	* [r1539] added operator<< for CoordinateSequence
 2006-05-03 18:04  Sandro Santilli <strk at keybit.net>
-	* [r1538] ChangeLog, source/headers/geos/noding/SegmentString.h,
-	  source/headers/geos/noding/SegmentString.inl: added
-	  SegmentString::setCoordinates() interface
+	* [r1538] added SegmentString::setCoordinates() interface
 2006-05-03 17:54  Sandro Santilli <strk at keybit.net>
-	* [r1537] source/noding/snapround/SimpleSnapRounder.cpp:
-	  Uncommented correctness checker
+	* [r1537] Uncommented correctness checker
 2006-05-03 17:51  Sandro Santilli <strk at keybit.net>
-	* [r1536] source/noding/snapround/HotPixel.cpp: system headers
-	  included after package headers
+	* [r1536] system headers included after package headers
 2006-05-03 17:50  Sandro Santilli <strk at keybit.net>
-	* [r1535] ChangeLog,
-	  source/headers/geos/noding/snapround/HotPixel.h: Doxygen comments
+	* [r1535] Doxygen comments
 2006-05-03 17:48  Sandro Santilli <strk at keybit.net>
-	* [r1534] source/headers/geos/nodingSnapround.h: Forgot a slash
+	* [r1534] Forgot a slash
-	* [r1533] ChangeLog, source/headers/geos/nodingSnapround.h: Doxygen
-	  brief
+	* [r1533] Doxygen brief
 2006-05-03 16:22  Howard Butler <hobu.inc at gmail.com>
-	* [r1532] source/Makefile.vc: tweak clean target
+	* [r1532] tweak clean target
 2006-05-03 16:21  Howard Butler <hobu.inc at gmail.com>
-	* [r1531] source/Makefile.vc: Build the C API and shared lib
-	  separate from the normal lib
+	* [r1531] Build the C API and shared lib separate from the normal
+	  lib
 	  Add missing files
 2006-05-03 16:19  Sandro Santilli <strk at keybit.net>
-	* [r1530] source/headers/geos/noding/SegmentString.h: fit in 80
-	  columns
+	* [r1530] fit in 80 columns
 2006-05-03 16:09  Howard Butler <hobu.inc at gmail.com>
-	* [r1529] capi/geos_c.h.vc: Maintain a geos_c.h.vc until we come up
-	  with a better solution
+	* [r1529] Maintain a geos_c.h.vc until we come up with a better
+	  solution
 2006-05-03 15:50  Howard Butler <hobu.inc at gmail.com>
-	* [r1528] ChangeLog: *** empty log message ***
+	* [r1528] *** empty log message ***
 2006-05-03 15:49  Sandro Santilli <strk at keybit.net>
-	* [r1527] ChangeLog, source/noding/snapround/SimpleSnapRounder.cpp:
-	  fixed bug in SimpleSnapRounder::computeSnaps, trying to access
-	  out-of-bound vector element.
+	* [r1527] fixed bug in SimpleSnapRounder::computeSnaps, trying to
+	  access out-of-bound vector element.
 2006-05-03 15:49  Howard Butler <hobu.inc at gmail.com>
-	* [r1526] source/Makefile.vc: add additional files and change names
-	  where necessary
+	* [r1526] add additional files and change names where necessary
 2006-05-03 15:40  Sandro Santilli <strk at keybit.net>
-	* [r1525] source/noding/ScaledNoder.cpp: test SegmentString
-	  invariant before and after scaling
+	* [r1525] test SegmentString invariant before and after scaling
 2006-05-03 15:37  Sandro Santilli <strk at keybit.net>
-	* [r1524] ChangeLog: Tabs for indent
+	* [r1524] Tabs for indent
 2006-05-03 15:32  Howard Butler <hobu.inc at gmail.com>
-	* [r1523] ChangeLog: *** empty log message ***
+	* [r1523] *** empty log message ***
 2006-05-03 15:30  Howard Butler <hobu.inc at gmail.com>
-	* [r1522] source/headers/geos/version.h.vc: Maintain a version.h.vc
-	  until we come up with a better solution
+	* [r1522] Maintain a version.h.vc until we come up with a better
+	  solution
 2006-05-03 15:28  Sandro Santilli <strk at keybit.net>
-	* [r1521] ChangeLog, configure.in: updated JTS_PORT to 1.7.1
+	* [r1521] updated JTS_PORT to 1.7.1
 2006-05-03 15:26  Sandro Santilli <strk at keybit.net>
-	* [r1520] ChangeLog, source/headers/geos/noding/SegmentString.h,
-	  source/headers/geos/noding/SegmentString.inl: testInvariant made
-	  public and always inlined
+	* [r1520] testInvariant made public and always inlined
 2006-05-03 15:19  Sandro Santilli <strk at keybit.net>
-	* [r1519] ChangeLog,
-	  source/headers/geos/noding/snapround/HotPixel.inl: Changed
-	  sym_round() to java_math_round()
+	* [r1519] Changed sym_round() to java_math_round()
 2006-05-03 15:12  Sandro Santilli <strk at keybit.net>
-	* [r1518] source/noding/ScaledNoder.cpp: Oops, uninitialized value
-	  fix
+	* [r1518] Oops, uninitialized value fix
 2006-05-03 15:06  Sandro Santilli <strk at keybit.net>
-	* [r1517] ChangeLog: Updated
+	* [r1517] Updated
-	* [r1516] source/headers/geos/noding/IntersectionFinderAdder.h:
-	  Better doxygen comment
+	* [r1516] Better doxygen comment
 2006-05-03 15:05  Sandro Santilli <strk at keybit.net>
-	* [r1515] source/operation/buffer/RightmostEdgeFinder.cpp:
-	  Assertions checking
+	* [r1515] Assertions checking
 2006-05-03 15:04  Sandro Santilli <strk at keybit.net>
-	* [r1514] source/headers/geos/noding/ScaledNoder.h: removed
-	  reduntant port info
+	* [r1514] removed reduntant port info
 2006-05-03 15:02  Sandro Santilli <strk at keybit.net>
-	* [r1513] source/headers/geos/noding/snapround/SimpleSnapRounder.h,
-	  source/noding/snapround/SimpleSnapRounder.cpp: moved some
-	  implementations from header to .cpp file (taken out of inline)
+	* [r1513] moved some implementations from header to .cpp file
+	  (taken out of inline)
 2006-05-03 15:00  Sandro Santilli <strk at keybit.net>
-	* [r1512] source/headers/geos/noding/ScaledNoder.h,
-	  source/noding/ScaledNoder.cpp: Fixed scale() function to remove
-	  repeated points *after* rounding. Added brief doxygen class
-	  description.
+	* [r1512] Fixed scale() function to remove repeated points *after*
+	  rounding. Added brief doxygen class description.
 2006-05-03 10:26  Sandro Santilli <strk at keybit.net>
-	* [r1511] ChangeLog, source/operation/buffer/BufferOp.cpp: Fixed
-	  misuse of precision model in noder (bufferFixedPrecision)
+	* [r1511] Fixed misuse of precision model in noder
+	  (bufferFixedPrecision)
 2006-05-03 09:46  Sandro Santilli <strk at keybit.net>
-	* [r1510] ChangeLog: buffer headers reduction item
+	* [r1510] buffer headers reduction item
 2006-05-03 09:45  Sandro Santilli <strk at keybit.net>
-	* [r1509] source/headers/geos/opBuffer.h,
-	  source/headers/geos/operation/buffer/Makefile.am: Do not install
-	  following buffer headers: BufferBuilder.h,
+	* [r1509] Do not install following buffer headers: BufferBuilder.h,
 	  OffsetCurveSetBuilder.h, BufferSubgraph.h,
 	  SubgraphDepthLocater.h,
 2006-05-03 09:14  Sandro Santilli <strk at keybit.net>
-	* [r1508] ChangeLog, source/headers/geos/noding/ScaledNoder.h,
-	  source/noding/ScaledNoder.cpp,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp: *
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp: used auto_ptr
-	  to protect leaks of CoordinateSequence
+	* [r1508] * source/operation/buffer/OffsetCurveSetBuilder.cpp: used
+	  auto_ptr to protect leaks of CoordinateSequence
 	  * source/noding/ScaledNoder.cpp,
 	  source/headers/geos/noding/ScaledNoder.h: ported JTS bugfix in
 	  scale method.
 2006-05-03 08:58  Sandro Santilli <strk at keybit.net>
-	* [r1507] ChangeLog, source/geom/CoordinateArraySequence.cpp,
-	  tests/unit/geom/CoordinateArraySequenceTest.cpp: added new
-	  non-static CoordinateSequence::removeRepeatedPoints() mutator.
+	* [r1507] added new non-static
+	  CoordinateSequence::removeRepeatedPoints() mutator.
 2006-05-02 16:22  Sandro Santilli <strk at keybit.net>
-	* [r1506] ChangeLog, source/noding/ScaledNoder.cpp: *
-	  source/noding/ScaledNoder.cpp: use java_math_round instead of
-	  sym_round.
+	* [r1506] * source/noding/ScaledNoder.cpp: use java_math_round
+	  instead of sym_round.
 2006-05-02 14:51  Sandro Santilli <strk at keybit.net>
-	* [r1505] source/algorithm/CGAlgorithms.cpp,
-	  source/headers/geos/algorithm/CGAlgorithms.h: Added port info and
-	  fixed doxygen comments for CGAlgorithms class
+	* [r1505] Added port info and fixed doxygen comments for
+	  CGAlgorithms class
 2006-05-02 14:32  Sandro Santilli <strk at keybit.net>
-	* [r1503] ChangeLog, source/headers/geos/opPolygonize.h,
-	  source/headers/geos/operation/polygonize/EdgeRing.h,
-	  source/operation/polygonize/EdgeRing.cpp: Added port info for
-	  polygonize/EdgeRing class, polygonize/EdgeRing.h header
+	* [r1503] Added port info for polygonize/EdgeRing class,
+	  polygonize/EdgeRing.h header
 	  not installed.
 2006-05-02 14:22  Sandro Santilli <strk at keybit.net>
-	* [r1502] ChangeLog, source/operation/polygonize/EdgeRing.cpp,
-	  source/operation/polygonize/Makefile.am,
-	  source/operation/polygonize/polygonizeEdgeRing.cpp: *
-	  source/operation/polygonize/: polygonizeEdgeRing.cpp renamed to
-	  EdgeRing.cpp, to follow JTS naming.
+	* [r1502] * source/operation/polygonize/: polygonizeEdgeRing.cpp
+	  renamed to EdgeRing.cpp, to follow JTS naming.
 2006-05-02 14:01  Sandro Santilli <strk at keybit.net>
-	* [r1500] ChangeLog, source/io/WKBReader.cpp: *
-	  source/io/WKBReader.cpp: fixed reads of XDR WKB.
+	* [r1500] * source/io/WKBReader.cpp: fixed reads of XDR WKB.
 2006-04-28 12:09  Sandro Santilli <strk at keybit.net>
-	* [r1497] tests/xmltester/Makefile.am: Added 'verbose-test' rule
+	* [r1497] Added 'verbose-test' rule
 2006-04-28 12:08  Sandro Santilli <strk at keybit.net>
-	* [r1496] NEWS: Added note about Geometry constructors
+	* [r1496] Added note about Geometry constructors
 2006-04-28 11:56  Sandro Santilli <strk at keybit.net>
-	* [r1495] ChangeLog, source/geom/GeometryFactory.cpp,
-	  source/headers/geos/geom/GeometryFactory.h: *
+	* [r1495] * source/geom/GeometryFactory.cpp,
 	  source/headers/geos/geom/GeometryFactory.h: added LineString copy
 	  constructor.
 	  * source/geom/Polygon.cpp: fixed getBoundary method to always
@@ -9445,990 +5956,705 @@
 2006-04-28 11:12  Sandro Santilli <strk at keybit.net>
-	* [r1494] ChangeLog,
-	  source/headers/geos/operation/predicate/RectangleIntersects.h,
-	  source/operation/predicate/RectangleIntersects.cpp: removed
-	  warnings related to change in getNumPoints() return type.
+	* [r1494] removed warnings related to change in getNumPoints()
+	  return type.
 2006-04-28 10:55  Sandro Santilli <strk at keybit.net>
-	* [r1493] ChangeLog, source/geom/GeometryCollection.cpp,
-	  source/headers/geos/geom/Polygon.h: Geometry constructors made
-	  protected, to ensure all constructions use GeometryFactory,
+	* [r1493] Geometry constructors made protected, to ensure all
+	  constructions use GeometryFactory,
 	  which has been made friend of all Geometry derivates.
 	  getNumPoints() changed to return
 	  size_t.
 2006-04-28 10:51  Sandro Santilli <strk at keybit.net>
-	* [r1492] ChangeLog, tests/unit/geom/LineStringTest.cpp,
-	  tests/unit/geom/PointTest.cpp, tests/unit/geom/PolygonTest.cpp:
-	  Unit tests: only construct Geoms using GeometryFactory.
+	* [r1492] Unit tests: only construct Geoms using GeometryFactory.
 2006-04-27 15:15  Sandro Santilli <strk at keybit.net>
-	* [r1491] ChangeLog, source/headers/geos/geomgraph/Node.h: Z check
-	  removed from invariant tester to avoid aborts due to differences
-	  in FP computations.
+	* [r1491] Z check removed from invariant tester to avoid aborts due
+	  to differences in FP computations.
 2006-04-27 15:07  Sandro Santilli <strk at keybit.net>
-	* [r1490] source/geomgraph/PlanarGraph.cpp: use output operators in
-	  debugging lines
+	* [r1490] use output operators in debugging lines
 2006-04-27 15:06  Sandro Santilli <strk at keybit.net>
-	* [r1489] ChangeLog, source/geomgraph/NodeMap.cpp: (addNode):
-	  always use the Node Coordinate as a key in the map to reduce
-	  likeliness of a premature deletion.
+	* [r1489] (addNode): always use the Node Coordinate as a key in the
+	  map to reduce likeliness of a premature deletion.
 2006-04-27 15:03  Sandro Santilli <strk at keybit.net>
-	* [r1488] source/geomgraph/Node.cpp: standard algorithm used in
-	  addZ() for vector seek
+	* [r1488] standard algorithm used in addZ() for vector seek
 2006-04-26 16:35  Sandro Santilli <strk at keybit.net>
-	* [r1485] ChangeLog, source/io/StringTokenizer.cpp,
-	  source/io/WKTReader.cpp, tests/xmltester/testLeaksBig.xml: Had
-	  WKTReader accept correct form for MultiPoint
+	* [r1485] Had WKTReader accept correct form for MultiPoint
 2006-04-26 10:39  Sandro Santilli <strk at keybit.net>
-	* [r1482] ChangeLog: Added mloskot item (bug#100)
+	* [r1482] Added mloskot item (bug#100)
 2006-04-26 10:26  Sandro Santilli <strk at keybit.net>
-	* [r1481] ChangeLog, tools/geos-config.in: tools/geos-config.in:
-	  fixed library path to use layout detected by autoconf
+	* [r1481] tools/geos-config.in: fixed library path to use layout
+	  detected by autoconf
 2006-04-24 15:47  Sandro Santilli <strk at keybit.net>
-	* [r1480] source/simplify/TopologyPreservingSimplifier.cpp: Public
-	  constructors change made permanent
+	* [r1480] Public constructors change made permanent
 2006-04-23 11:58  Mateusz Loskot <mateusz at loskot.net>
-	* [r1479] ., .cvsignore,
-	  tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp: Small
-	  refactoring of DouglasPeuckerSimplifierTest (prefer to use ctor
-	  instead of operator= to create objects). Added new patterns to
-	  .cvsignore.
+	* [r1479] Small refactoring of DouglasPeuckerSimplifierTest (prefer
+	  to use ctor instead of operator= to create objects). Added new
 2006-04-23 11:29  Mateusz Loskot <mateusz at loskot.net>
-	* [r1478] ., .cvsignore: Added new patterns to .cvsignore file.
+	* [r1478] Added new patterns to .cvsignore file.
 2006-04-22 17:16  Mateusz Loskot <mateusz at loskot.net>
-	* [r1477] source/simplify/TopologyPreservingSimplifier.cpp:
-	  Temporar fix of Bug #100. This report requires deeper analysis!.
+	* [r1477] Temporar fix of Bug #100. This report requires deeper
+	  analysis!.
 2006-04-21 17:04  Sandro Santilli <strk at keybit.net>
-	* [r1476] ChangeLog, source/geom/PrecisionModel.cpp: Fixed
-	  constructor by type to always initialize scale factor
+	* [r1476] Fixed constructor by type to always initialize scale
+	  factor
 2006-04-20 16:21  Sandro Santilli <strk at keybit.net>
-	* [r1475] ChangeLog, source/headers/geos/geom/BinaryOp.h: Added
-	  missing debugging output
+	* [r1475] Added missing debugging output
 2006-04-20 14:27  Sandro Santilli <strk at keybit.net>
-	* [r1474] ChangeLog, source/algorithm/HCoordinate.cpp,
-	  source/headers/geos/algorithm/HCoordinate.h: HCoordinate class
-	  changed to use long double types internally, in order to improve
-	  computation precision
+	* [r1474] HCoordinate class changed to use long double types
+	  internally, in order to improve computation precision
 2006-04-20 14:16  Sandro Santilli <strk at keybit.net>
-	* [r1473] source/headers/geos/algorithm/LineIntersector.h: Added
-	  some more doxygen comments
+	* [r1473] Added some more doxygen comments
 2006-04-20 11:11  Sandro Santilli <strk at keybit.net>
-	* [r1472] ChangeLog, source/algorithm/HCoordinate.cpp:
-	  source/algorithm/HCoordinate.cpp: added compile time define to
-	  force storage of intermediate computation values to variables (in
-	  order to make the -ffloat-store gcc switch effective). Disabled
-	  by default.
+	* [r1472] source/algorithm/HCoordinate.cpp: added compile time
+	  define to force storage of intermediate computation values to
+	  variables (in order to make the -ffloat-store gcc switch
+	  effective). Disabled by default.
 2006-04-19 09:21  Sandro Santilli <strk at keybit.net>
-	* [r1471] TODO: Added snapround and simplify tests items
+	* [r1471] Added snapround and simplify tests items
 2006-04-19 09:20  Sandro Santilli <strk at keybit.net>
-	* [r1470] NEWS: updated
+	* [r1470] updated
 2006-04-14 15:34  Sandro Santilli <strk at keybit.net>
-	* [r1469] ChangeLog, capi/geos_c.cpp: Had CAPI use new BinaryOp
-	  class in an aim to reduce robustness problems
+	* [r1469] Had CAPI use new BinaryOp class in an aim to reduce
+	  robustness problems
 2006-04-14 15:25  Sandro Santilli <strk at keybit.net>
-	* [r1468] TODO: updated, somehow
+	* [r1468] updated, somehow
 2006-04-14 15:19  Sandro Santilli <strk at keybit.net>
-	* [r1467] ChangeLog, source/operation/overlay/OverlayOp.cpp:
-	  removed precision reduction code (use BinaryOp for that)
+	* [r1467] removed precision reduction code (use BinaryOp for that)
 2006-04-14 15:06  Sandro Santilli <strk at keybit.net>
-	* [r1466] source/headers/geos/geom/Makefile.am: Added BinaryOp.h
-	  header
+	* [r1466] Added BinaryOp.h header
 2006-04-14 15:04  Sandro Santilli <strk at keybit.net>
-	* [r1465] source/headers/geos/operation/overlay/OverlayOp.h: fixed
-	  missing namespace qualification in overlay::overlayOp
+	* [r1465] fixed missing namespace qualification in
+	  overlay::overlayOp
 2006-04-14 14:57  Sandro Santilli <strk at keybit.net>
-	* [r1464] ChangeLog, tests/xmltester/XMLTester.cpp: XMLTester
-	  binary ops invoked using the new BinaryOp template function.
+	* [r1464] XMLTester binary ops invoked using the new BinaryOp
+	  template function.
 2006-04-14 14:38  Sandro Santilli <strk at keybit.net>
-	* [r1463] ChangeLog, source/headers/geos/geom/BinaryOp.h: new
-	  geos::Geom::BinaryOp template function implementing various
-	  heuristics aimed at making binary geometry ops work around
-	  robustness issues.
+	* [r1463] new geos::Geom::BinaryOp template function implementing
+	  various heuristics aimed at making binary geometry ops work
+	  around robustness issues.
 2006-04-14 14:35  Sandro Santilli <strk at keybit.net>
-	* [r1462] ChangeLog,
-	  source/headers/geos/operation/overlay/OverlayOp.h: Added
-	  overlayOp() adapter for use in templates expecting binary ops
+	* [r1462] Added overlayOp() adapter for use in templates expecting
+	  binary ops
 2006-04-14 09:02  Sandro Santilli <strk at keybit.net>
-	* [r1461] ChangeLog, source/algorithm/HCoordinate.cpp,
-	  source/headers/geos/algorithm/HCoordinate.h: Hadded output
-	  operator and debugging prints for HCoordinate.
+	* [r1461] Hadded output operator and debugging prints for
+	  HCoordinate.
 2006-04-13 23:57  Sandro Santilli <strk at keybit.net>
-	* [r1460] source/operation/overlay/OverlayOp.cpp: Disables reduced
-	  precision overlayOp (is broken)
+	* [r1460] Disables reduced precision overlayOp (is broken)
 2006-04-13 23:42  Sandro Santilli <strk at keybit.net>
-	* [r1459] source/operation/overlay/OverlayOp.cpp: Plugged
-	  CommonBitsOp attempts in overlay op, before brute force precision
+	* [r1459] Plugged CommonBitsOp attempts in overlay op, before brute
+	  force precision
 	  reduction (this is likely going to change)
 2006-04-13 23:28  Sandro Santilli <strk at keybit.net>
-	* [r1458] source/precision/CommonBitsOp.cpp: "always build before
-	  commit" (forgot a closing paren)
+	* [r1458] "always build before commit" (forgot a closing paren)
 2006-04-13 23:23  Sandro Santilli <strk at keybit.net>
-	* [r1457] ChangeLog, source/headers/geos/precision/CommonBitsOp.h,
-	  source/precision/CommonBitsOp.cpp: fixed bug in binary ops
-	  failing to consistently reduce operands.
+	* [r1457] fixed bug in binary ops failing to consistently reduce
+	  operands.
 2006-04-13 21:53  Sandro Santilli <strk at keybit.net>
-	* [r1456] capi/geostest.c: fixed bug introduced by previous commit
+	* [r1456] fixed bug introduced by previous commit
 2006-04-13 21:52  Sandro Santilli <strk at keybit.net>
-	* [r1455] source/headers/geos/simplify/TaggedLineString.h,
-	  source/headers/geos/simplify/TaggedLineStringSimplifier.h,
-	  source/simplify/TaggedLineStringSimplifier.cpp,
-	  source/simplify/TopologyPreservingSimplifier.cpp: Many debugging
-	  lines and assertions added. Fixed bug in TaggedLineString class.
+	* [r1455] Many debugging lines and assertions added. Fixed bug in
+	  TaggedLineString class.
 2006-04-13 17:09  Sandro Santilli <strk at keybit.net>
-	* [r1454] ChangeLog, capi/geos_c.cpp: Use default GeometryFactory
-	  instance (finishGEOS() is a no-op now)
+	* [r1454] Use default GeometryFactory instance (finishGEOS() is a
+	  no-op now)
 2006-04-13 16:48  Sandro Santilli <strk at keybit.net>
-	* [r1453] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in,
-	  capi/geostest.c: Added GEOSSimplify and
-	  GEOSTopologyPreserveSimplify interfaces. Removed compiler
-	  warnings in geostest
+	* [r1453] Added GEOSSimplify and GEOSTopologyPreserveSimplify
+	  interfaces. Removed compiler warnings in geostest
 2006-04-13 16:44  Sandro Santilli <strk at keybit.net>
-	* [r1452] source/simplify/DouglasPeuckerSimplifier.cpp: Fixed a bug
-	  in DPTransformer handling of MultiPolygons
+	* [r1452] Fixed a bug in DPTransformer handling of MultiPolygons
 2006-04-13 16:04  Sandro Santilli <strk at keybit.net>
-	* [r1451] source/headers/geos/simplify/TaggedLineString.h,
-	  source/headers/geos/simplify/TopologyPreservingSimplifier.h,
-	  source/simplify/Makefile.am,
-	  source/simplify/TopologyPreservingSimplifier.cpp: Made
-	  TopologyPreservingSimplifier implementation successfully build
+	* [r1451] Made TopologyPreservingSimplifier implementation
+	  successfully build
 2006-04-13 14:51  Sandro Santilli <strk at keybit.net>
-	* [r1450] ChangeLog, tests/unit/io/WKBReaderTest.cpp: Forced NDR
-	  output (to not rely on architecture). Removed CRs endings.
+	* [r1450] Forced NDR output (to not rely on architecture). Removed
+	  CRs endings.
 2006-04-13 14:25  Sandro Santilli <strk at keybit.net>
-	* [r1449] ChangeLog, source/geom/GeometryComponentFilter.cpp,
-	  source/headers/geos/geom/util/GeometryTransformer.h,
-	  TopologyPreservingSimplifier initial port
+	* [r1449] TopologyPreservingSimplifier initial port
 2006-04-13 10:39  Sandro Santilli <strk at keybit.net>
-	* [r1448] ChangeLog,
-	  source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h,
-	  source/headers/geos/simplify/DouglasPeuckerSimplifier.h,
-	  source/headers/geos/simplify/Makefile.am,
-	  source/simplify/TopologyPreservingSimplifier.cpp: Initial
-	  implementation of TaggedLinesSimplifier class
+	* [r1448] Initial implementation of TaggedLinesSimplifier class
 2006-04-13 09:28  Mateusz Loskot <mateusz at loskot.net>
-	* [r1447] source/headers/geos/simplify/LineSegmentIndex.h,
-	  source/simplify/LineSegmentIndex.cpp: Removed definition of copy
-	  ctor and assignment operator for LineSegmentString class.
+	* [r1447] Removed definition of copy ctor and assignment operator
+	  for LineSegmentString class.
 2006-04-13 09:21  Mateusz Loskot <mateusz at loskot.net>
-	* [r1446] source/headers/geos/simplify/TaggedLineString.h,
-	  source/simplify/TaggedLineString.cpp: Removed definition of copy
-	  ctor and assignment operator for TaggedLineString class.
+	* [r1446] Removed definition of copy ctor and assignment operator
+	  for TaggedLineString class.
 	  According to following rule: Declaring, but not defining, private
 	  copy operations has
 	  the effect of "turning off" copying for the class.
 2006-04-12 17:24  Sandro Santilli <strk at keybit.net>
-	* [r1445] ChangeLog: Added note about reduction of installed
-	  headers in simplify namespace
+	* [r1445] Added note about reduction of installed headers in
+	  simplify namespace
 2006-04-12 17:19  Sandro Santilli <strk at keybit.net>
-	* [r1444] ChangeLog, source/headers/geos/geom/LineSegment.h,
-	  source/headers/geos/simplify/TaggedLineSegment.h,
-	  source/headers/geos/simplify/TaggedLineString.h,
-	  source/simplify/TaggedLineSegment.cpp,
-	  source/simplify/TaggedLineStringSimplifier.cpp: Ported
-	  TaggedLineStringSimplifier class, made LineSegment class
+	* [r1444] Ported TaggedLineStringSimplifier class, made LineSegment
+	  class
 	  polymorphic to fix derivation of TaggedLineSegment
 2006-04-12 15:20  Sandro Santilli <strk at keybit.net>
-	* [r1443] ChangeLog,
-	  source/headers/geos/simplify/LineSegmentIndex.h,
-	  source/simplify/LineSegmentIndex.cpp,
-	  source/simplify/TaggedLineString.cpp: LineSegmentIndex class
+	* [r1443] LineSegmentIndex class
 2006-04-12 14:22  Sandro Santilli <strk at keybit.net>
-	* [r1442] ChangeLog, source/headers/geos/simplify/Makefile.am,
-	  source/simplify/TaggedLineString.cpp: Initial implementation of
-	  TaggedLineSegment and TaggedLineString classes
+	* [r1442] Initial implementation of TaggedLineSegment and
+	  TaggedLineString classes
 2006-04-12 12:20  Sandro Santilli <strk at keybit.net>
-	* [r1441] source/operation/overlay/OverlayOp.cpp: Added support for
-	  use of CommonBitsOp in reduced precision attempts
+	* [r1441] Added support for use of CommonBitsOp in reduced
+	  precision attempts
 	  (compile-time option)
 2006-04-12 11:57  Sandro Santilli <strk at keybit.net>
-	* [r1440] source/algorithm/LineIntersector.cpp: Fixed debugging
-	  line
+	* [r1440] Fixed debugging line
 2006-04-12 11:39  Sandro Santilli <strk at keybit.net>
-	* [r1439] source/headers/geos/geom/GeometryFactory.h: Removed
-	  Geometry.h and CoordinateSequence.h includes.
+	* [r1439] Removed Geometry.h and CoordinateSequence.h includes.
 	  The former created a circular dependency.
 2006-04-12 11:17  Sandro Santilli <strk at keybit.net>
-	* [r1438] ChangeLog, source/io/WKBReader.cpp: Fixed exceptions
-	  constructors (were using operator+ with strings and const char*)
+	* [r1438] Fixed exceptions constructors (were using operator+ with
+	  strings and const char*)
 2006-04-12 10:57  Sandro Santilli <strk at keybit.net>
-	* [r1437] ChangeLog, source/headers/geos/io/WKBReader.h,
-	  source/io/WKBReader.cpp: Added WKBReader default ctor using
-	  default GeometryFactory instance
+	* [r1437] Added WKBReader default ctor using default
+	  GeometryFactory instance
 2006-04-11 16:04  Sandro Santilli <strk at keybit.net>
-	* [r1436] ChangeLog, source/geom/util/GeometryTransformer.cpp,
-	  source/simplify/DouglasPeuckerSimplifier.cpp,
-	  source/simplify/Makefile.am, tests/unit/Makefile.am,
-	  tests/unit/simplify,
-	  geos::simplify::DouglasPeukerSimplifier class + unit test
+	* [r1436] geos::simplify::DouglasPeukerSimplifier class + unit test
 2006-04-11 12:56  Sandro Santilli <strk at keybit.net>
-	* [r1435] source/headers/geos/geom/util/GeometryTransformer.h: used
-	  typedef for auto_ptr<CoordinateSequence>
+	* [r1435] used typedef for auto_ptr<CoordinateSequence>
 2006-04-11 12:21  Sandro Santilli <strk at keybit.net>
-	* [r1434] ChangeLog, source/geom/util/GeometryTransformer.cpp,
-	  source/geom/util/Makefile.am,
-	  source/headers/geos/geom/util/Makefile.am: GeometryTransformer
-	  class ported
+	* [r1434] GeometryTransformer class ported
 2006-04-11 11:55  Sandro Santilli <strk at keybit.net>
-	* [r1433] source/headers/geos/geom/CoordinateSequence.h: Added
-	  CoordinateSequence::AutoPtr typedef
+	* [r1433] Added CoordinateSequence::AutoPtr typedef
 2006-04-11 11:16  Sandro Santilli <strk at keybit.net>
-	* [r1432] ChangeLog, source/geom/GeometryFactory.cpp,
-	  source/geom/LineString.cpp, source/geom/LinearRing.cpp,
-	  source/headers/geos/geom/GeometryFactory.h,
-	  source/headers/geos/geom/LinearRing.h: Added LineString and
-	  LinearRing constructors by auto_ptr
+	* [r1432] Added LineString and LinearRing constructors by auto_ptr
 2006-04-11 09:53  Sandro Santilli <strk at keybit.net>
-	* [r1431] source/headers/geos/geom/GeometryList.h: Added missing
-	  duplicated include sentinel
+	* [r1431] Added missing duplicated include sentinel
 2006-04-11 09:41  Sandro Santilli <strk at keybit.net>
-	* [r1430] source/geom/GeometryList.cpp, source/geom/Makefile.am,
-	  source/headers/geos/geom/GeometryList.h,
-	  source/headers/geos/geom/Makefile.am: Initial implementation of a
-	  GeometryList class, to be used to manage
+	* [r1430] Initial implementation of a GeometryList class, to be
+	  used to manage
 	  lists of Geometry pointers.
 2006-04-11 09:31  Sandro Santilli <strk at keybit.net>
-	* [r1429] source/headers/geos/geom/Geometry.h: Added
-	  Geometry::AutoPtr typedef
+	* [r1429] Added Geometry::AutoPtr typedef
 2006-04-11 09:29  Sandro Santilli <strk at keybit.net>
-	* [r1428] source/geom/Geometry.cpp: Fixed initialization list
-	  (removed compiler warning)
+	* [r1428] Fixed initialization list (removed compiler warning)
 2006-04-10 18:15  Sandro Santilli <strk at keybit.net>
-	* [r1427] ChangeLog, source/geom/Geometry.cpp,
-	  source/geom/GeometryCollection.cpp, source/geom/LineString.cpp,
-	  source/headers/geos/geom/Envelope.h,
-	  source/headers/geos/geom/Polygon.h: Changed Geometry::envelope
-	  member to be of type auto_ptr<Envelope>.
+	* [r1427] Changed Geometry::envelope member to be of type
+	  auto_ptr<Envelope>.
 	  Changed computeEnvelopeInternal() signater to return
 	  auto_ptr<Envelope>
 2006-04-10 17:35  Sandro Santilli <strk at keybit.net>
-	* [r1426] ChangeLog, source/geom/LineString.cpp,
-	  source/geom/LinearRing.cpp, source/geom/Point.cpp,
-	  source/headers/geos/geom/LinearRing.h,
-	  tests/unit/geom/LineStringTest.cpp,
-	  tests/unit/geom/PointTest.cpp: Changed LineString::points and
-	  Point::coordinates to be wrapped
+	* [r1426] Changed LineString::points and Point::coordinates to be
+	  wrapped
 	  in an auto_ptr<>. This should close bugs #86 and #89
 2006-04-10 15:11  Sandro Santilli <strk at keybit.net>
-	* [r1425] ChangeLog: First manual edit (will likely update later
-	  tonight... with changes grouped
+	* [r1425] First manual edit (will likely update later tonight...
+	  with changes grouped
 	  by date)
 2006-04-10 15:05  Sandro Santilli <strk at keybit.net>
-	* [r1424] tests/xmltester/TestInteriorPoint.xml: Re-synced with JTS
-	  version (so this actually *was* a bug :)
+	* [r1424] Re-synced with JTS version (so this actually *was* a bug
-	* [r1423] source/geom/Geometry.cpp: Fixed a bug introduced by
-	  previous commit in getCentroid()
+	* [r1423] Fixed a bug introduced by previous commit in
+	  getCentroid()
 2006-04-10 14:18  Sandro Santilli <strk at keybit.net>
-	* [r1422] source/geom/Geometry.cpp: Fixed getCentroid(Coordinate&)
-	  to round using PrecisionModel
+	* [r1422] Fixed getCentroid(Coordinate&) to round using
+	  PrecisionModel
 	  all unit tests succeed.
 2006-04-10 13:40  Sandro Santilli <strk at keybit.net>
-	* [r1421] source/headers/geos/io/WKTReader.h,
-	  source/headers/geos/io/WKTReader.inl: Added default ctor for
-	  WKTReader (using GeometryFactory's default instance)
+	* [r1421] Added default ctor for WKTReader (using GeometryFactory's
+	  default instance)
 2006-04-10 13:13  Sandro Santilli <strk at keybit.net>
-	* [r1420] tools/geos-config.in: Removed INLINE flags from
-	  geos-config --libs
+	* [r1420] Removed INLINE flags from geos-config --libs
 2006-04-10 13:09  Sandro Santilli <strk at keybit.net>
-	* [r1419] source/geom/Geometry.cpp,
-	  source/geom/GeometryFactory.cpp,
-	  source/headers/geos/geom/GeometryFactory.h, source/io/Unload.cpp:
-	  Added GeometryFactory::defaultInstance()
+	* [r1419] Added GeometryFactory::defaultInstance()
 	  Made Geometry::INTERNAL_GEOMETRY_FACTORY an alias for it
 	  removed last deletion from Unload::Release class
 2006-04-10 12:05  Sandro Santilli <strk at keybit.net>
-	* [r1418] source/Makefile.am, source/geom/LineSegment.cpp,
-	  source/headers/geos/geom/LineSegment.inl,
-	  source/headers/geos/io/WKTReader.h,
-	  source/headers/geos/io/WKTReader.inl,
-	  source/headers/geos/noding/MCIndexNoder.inl,
-	  source/headers/geos/noding/snapround/MCIndexSnapRounder.inl,
-	  source/inlines.cpp, source/io/ByteOrderDataInStream.cpp,
-	  source/io/WKTReader.cpp, source/operation/overlay/OverlayOp.cpp:
-	  Added inline-replicator implementation files to make sure
+	* [r1418] Added inline-replicator implementation files to make sure
 	  functions in .inl files are still available out-of-line.
 	  A side effect is this should fix MingW build.
 2006-04-10 11:34  Sandro Santilli <strk at keybit.net>
-	* [r1417] tests/unit/algorithm/PointLocatorTest.cpp: Uncommented
-	  required Geometry.h include (for use in auto_ptr)
+	* [r1417] Uncommented required Geometry.h include (for use in
+	  auto_ptr)
 2006-04-10 09:21  Mateusz Loskot <mateusz at loskot.net>
-	* [r1416] source/headers/geos/util/UniqueCoordinateArrayFilter.h,
-	  tests/unit/Makefile.am,
-	  tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp,
-	  tests/unit/geom/CoordinateArraySequenceTest.cpp,
-	  tests/unit/geom/GeometryFactoryTest.cpp,
-	  tests/unit/geom/LinearRingTest.cpp,
-	  tests/unit/geom/MultiPointTest.cpp, tests/unit/util,
-	  tests/unit/util/UniqueCoordinateArrayFilterTest.cpp: Added new
-	  test for UniqueCoordinateArrayFilter class. Small fixes related
-	  to signed/unsigned comparison.
+	* [r1416] Added new test for UniqueCoordinateArrayFilter class.
+	  Small fixes related to signed/unsigned comparison.
 2006-04-09 11:07  Mateusz Loskot <mateusz at loskot.net>
-	* [r1413] doc/example.cpp: Small fixes in doc/example.cpp.
+	* [r1413] Small fixes in doc/example.cpp.
 2006-04-09 04:56  Mateusz Loskot <mateusz at loskot.net>
-	* [r1412] tests/xmltester/markup/MarkupSTL.cpp: Removed redundant
-	  semicolons from xmltester sources.
+	* [r1412] Removed redundant semicolons from xmltester sources.
 2006-04-09 04:26  Mateusz Loskot <mateusz at loskot.net>
-	* [r1411] tests/xmltester/markup/MarkupSTL.cpp: Removed redundant
-	  semicolon reported by g++ -pedantic.
+	* [r1411] Removed redundant semicolon reported by g++ -pedantic.
 2006-04-09 04:09  Mateusz Loskot <mateusz at loskot.net>
-	* [r1410] source/operation/valid/SweeplineNestedRingTester.cpp:
-	  Removed redundant semicolon reported by g++ -pedantic.
+	* [r1410] Removed redundant semicolon reported by g++ -pedantic.
 2006-04-09 01:48  Mateusz Loskot <mateusz at loskot.net>
-	* [r1409] tests/unit/Makefile.am,
-	  tests/unit/geom/IntersectionMatrixTest.cpp: Added Unit Test for
-	  IntersectionMatrix class.
+	* [r1409] Added Unit Test for IntersectionMatrix class.
 2006-04-09 01:46  Mateusz Loskot <mateusz at loskot.net>
-	* [r1408] source/headers/geos/geom/IntersectionMatrix.h: [SORRY]
-	  Added comments for doxygen based on JTS docs. Added row/col
-	  dimension consts. Added asserts in functions to check if given
-	  row/col is in range.
+	* [r1408] [SORRY] Added comments for doxygen based on JTS docs.
+	  Added row/col dimension consts. Added asserts in functions to
+	  check if given row/col is in range.
 2006-04-09 01:41  Mateusz Loskot <mateusz at loskot.net>
-	* [r1407] source/geom/IntersectionMatrix.cpp: Added comments for
-	  doxygen based on JTS docs. Added row/col dimension consts. Added
-	  asserts in functions to check if given row/col is in range.
+	* [r1407] Added comments for doxygen based on JTS docs. Added
+	  row/col dimension consts. Added asserts in functions to check if
+	  given row/col is in range.
 2006-04-08 15:57  Mateusz Loskot <mateusz at loskot.net>
-	* [r1406] tests/tut/tut.h, tests/tut/tut_reporter.h,
-	  tests/tut/tut_restartable.h: Added copyright notice to TUT files.
-	  Small cleaning.
+	* [r1406] Added copyright notice to TUT files. Small cleaning.
 2006-04-08 13:05  Sandro Santilli <strk at keybit.net>
-	* [r1405] source/geomgraph/EdgeEnd.cpp: Added assertion
+	* [r1405] Added assertion
 2006-04-08 13:00  Sandro Santilli <strk at keybit.net>
-	* [r1404] source/geomgraph/NodeMap.cpp: assertion checking,
-	  mergeLabel() call fix (bug#91)
+	* [r1404] assertion checking, mergeLabel() call fix (bug#91)
 2006-04-07 16:52  Sandro Santilli <strk at keybit.net>
-	* [r1403] source/geomgraph/PlanarGraph.cpp,
-	  source/headers/geos/geomgraph/PlanarGraph.h: Port info, doxygen
-	  comments, assertion checking
+	* [r1403] Port info, doxygen comments, assertion checking
 2006-04-07 16:01  Sandro Santilli <strk at keybit.net>
-	* [r1402] source/geomgraph/Node.cpp,
-	  source/headers/geos/geomgraph/Node.h: Port info, doxygen
-	  comments, testInvariant(), many assertionss, handling of
+	* [r1402] Port info, doxygen comments, testInvariant(), many
+	  assertionss, handling of
 	  the NULL EdgeEndStar member
 2006-04-07 13:26  Sandro Santilli <strk at keybit.net>
-	* [r1401] tests/xmltester/XMLTester.cpp,
-	  tests/xmltester/XMLTester.h: Use of auto_ptr<> to prevent
-	  confusing leaks in tester
+	* [r1401] Use of auto_ptr<> to prevent confusing leaks in tester
 2006-04-07 13:14  Mateusz Loskot <mateusz at loskot.net>
-	* [r1400] tests/tut/tut_reporter.h: Fixed annoying warnings from
-	  TUT.
+	* [r1400] Fixed annoying warnings from TUT.
 2006-04-07 13:01  Mateusz Loskot <mateusz at loskot.net>
-	* [r1399] tests/unit/geos_unit.cpp: Fixed line-ends to LF.
+	* [r1399] Fixed line-ends to LF.
 2006-04-07 12:55  Mateusz Loskot <mateusz at loskot.net>
-	* [r1398] tests/unit/geom/PolygonTest.cpp: Uncommented test nr 38
-	  in PolygonTest.cpp.
+	* [r1398] Uncommented test nr 38 in PolygonTest.cpp.
 2006-04-07 12:37  Mateusz Loskot <mateusz at loskot.net>
-	* [r1397] source/geom/PrecisionModel.cpp,
-	  source/headers/geos/util/math.h, source/util/math.cpp,
-	  tests/tut/tut_reporter.h,
-	  tests/unit/geom/MultiLineStringTest.cpp,
-	  tests/unit/geom/MultiPolygonTest.cpp,
-	  tests/unit/geom/PointTest.cpp, tests/unit/geom/PolygonTest.cpp,
-	  tests/unit/geos_unit.cpp: Added java_math_round() function for
-	  Asymmetric Arithmetic Rounding. Small fixes in Unit Tests.
+	* [r1397] Added java_math_round() function for Asymmetric
+	  Arithmetic Rounding. Small fixes in Unit Tests.
 2006-04-07 10:42  Mateusz Loskot <mateusz at loskot.net>
-	* [r1396] tests/unit/geom/GeometryFactoryTest.cpp,
-	  tests/unit/geom/PointTest.cpp: Added test nr 29 to PointTest (JTS
-	  conformance). Removed inform() calls from GeometryFactoryTest.
+	* [r1396] Added test nr 29 to PointTest (JTS conformance). Removed
+	  inform() calls from GeometryFactoryTest.
 2006-04-07 09:54  Sandro Santilli <strk at keybit.net>
-	* [r1395] source/algorithm/CentroidArea.cpp,
-	  source/algorithm/CentroidPoint.cpp,
-	  source/algorithm/InteriorPointArea.cpp,
-	  source/algorithm/PointLocator.cpp, source/geom/Geometry.cpp,
-	  source/geom/GeometryCollection.cpp, source/geom/MultiPolygon.cpp,
-	  source/geom/util/GeometryEditor.cpp,
-	  source/geomgraph/GeometryGraph.cpp,
-	  source/headers/geos/geom/GeometryCollection.h,
-	  source/io/WKTWriter.cpp, source/operation/valid/IsValidOp.cpp,
-	  source/operation/valid/RepeatedPointTester.cpp:
-	  Geometry::getNumGeometries() changed to return 'unsigned int'
+	* [r1395] Geometry::getNumGeometries() changed to return 'unsigned
+	  int'
 	  rather then 'int'
 2006-04-07 09:12  Sandro Santilli <strk at keybit.net>
-	* [r1394] source/algorithm/LineIntersector.cpp: kept
-	  isInSegmentEnvelopes() check even when not debugging
+	* [r1394] kept isInSegmentEnvelopes() check even when not debugging
 2006-04-07 08:31  Sandro Santilli <strk at keybit.net>
-	* [r1393] source/precision/EnhancedPrecisionOp.cpp: Debugging lines
+	* [r1393] Debugging lines
 2006-04-07 08:30  Sandro Santilli <strk at keybit.net>
-	* [r1392] source/headers/geos/precision/CommonBitsRemover.h: made
-	  addCommonBits/removeCommonBits interface consistent, doxygen
-	  comments
+	* [r1392] made addCommonBits/removeCommonBits interface consistent,
+	  doxygen comments
 2006-04-07 08:28  Sandro Santilli <strk at keybit.net>
-	* [r1391] source/precision/CommonBitsRemover.cpp: debugging lines,
-	  assertions
+	* [r1391] debugging lines, assertions
 2006-04-07 08:27  Sandro Santilli <strk at keybit.net>
-	* [r1390] source/precision/CommonBitsOp.cpp: debugging blocks
+	* [r1390] debugging blocks
 2006-04-07 07:21  Mateusz Loskot <mateusz at loskot.net>
-	* [r1389] tests/unit/Makefile.am,
-	  tests/unit/geom/CoordinateTest.cpp: Add new-line at the EOF some
-	  files.
+	* [r1389] Add new-line at the EOF some files.
 2006-04-07 05:55  Mateusz Loskot <mateusz at loskot.net>
-	* [r1388] ., .cvsignore: Added new objects to .cvsignore.
+	* [r1388] Added new objects to .cvsignore.
 2006-04-07 05:44  Mateusz Loskot <mateusz at loskot.net>
-	* [r1387] source/headers/geos/geom/Dimension.h,
-	  tests/unit/geom/CoordinateTest.cpp,
-	  tests/unit/geom/DimensionTest.cpp,
-	  tests/unit/geom/EnvelopeTest.cpp,
-	  tests/unit/geom/LineSegmentTest.cpp,
-	  tests/unit/geom/LocationTest.cpp,
-	  tests/unit/geom/TriangleTest.cpp: Added name for anonymous enum
-	  in Dimension class (bug). Added missing new-line at the end of
-	  source files. Removed CR from line ends.
+	* [r1387] Added name for anonymous enum in Dimension class (bug).
+	  Added missing new-line at the end of source files. Removed CR
+	  from line ends.
 2006-04-07 00:05  Mateusz Loskot <mateusz at loskot.net>
-	* [r1386] tests/unit/geom/Geometry,
-	  tests/unit/geom/Geometry/isRectangleTest.cpp: Adding missing
+	* [r1386] Adding missing isRectangleTest.cpp
 2006-04-06 23:50  Mateusz Loskot <mateusz at loskot.net>
-	* [r1385] tests/unit/Makefile.am, tests/unit/geom,
-	  tests/unit/geom/TriangleTest.cpp, tests/unit/io,
-	  tests/unit/io/WKBReaderTest.cpp: Adding new Unit Tests.
+	* [r1385] Adding new Unit Tests.
 2006-04-06 23:35  Sandro Santilli <strk at keybit.net>
-	* [r1384] AUTHORS: Added Mateusz Loskot
+	* [r1384] Added Mateusz Loskot
 2006-04-06 23:31  Mateusz Loskot <mateusz at loskot.net>
-	* [r1383] tests/unit/algorithm,
-	  tests/unit/algorithm/PointLocatorTest.cpp: [UT Files Renaming]
-	  Add PointLocatorTest.cpp
+	* [r1383] [UT Files Renaming] Add PointLocatorTest.cpp
 2006-04-06 23:28  Mateusz Loskot <mateusz at loskot.net>
-	* [r1382] tests/unit/io: [UT Files Renaming] Remove 'io' tests.
+	* [r1382] [UT Files Renaming] Remove 'io' tests.
 2006-04-06 23:26  Mateusz Loskot <mateusz at loskot.net>
-	* [r1381] tests/unit/geom: [UT Files Renaming] Remove 'geom' tests.
+	* [r1381] [UT Files Renaming] Remove 'geom' tests.
 2006-04-06 23:25  Mateusz Loskot <mateusz at loskot.net>
-	* [r1380] tests/unit/algorithm: [UT Files Renaming] Remove file
-	  PointLocator.cpp
+	* [r1380] [UT Files Renaming] Remove file PointLocator.cpp
 2006-04-06 23:20  Mateusz Loskot <mateusz at loskot.net>
-	* [r1379] tests/unit/geos_unit.cpp: New version of Unit Test
-	  runner. Now, it's more GNU style compatible
+	* [r1379] New version of Unit Test runner. Now, it's more GNU style
+	  compatible
 2006-04-06 22:30  Mateusz Loskot <mateusz at loskot.net>
-	* [r1378] tests/tut/tut.h, tests/tut/tut_reporter.h: Add inform()
-	  target in tut.h and new callbacks in tut_reporter.h
+	* [r1378] Add inform() target in tut.h and new callbacks in
+	  tut_reporter.h
 2006-04-06 21:31  Sandro Santilli <strk at keybit.net>
-	* [r1377] source/algorithm/LineIntersector.cpp,
-	  source/headers/geos/algorithm/LineIntersector.h: Const
-	  correctness for debugging function
+	* [r1377] Const correctness for debugging function
 2006-04-06 21:30  Sandro Santilli <strk at keybit.net>
-	* [r1376] source/headers/geos/util/math.h: Added missing rint_vc()
-	  forward declaration
+	* [r1376] Added missing rint_vc() forward declaration
 2006-04-06 17:33  Sandro Santilli <strk at keybit.net>
-	* [r1375] tests/unit/Makefile.am, tests/unit/index,
-	  tests/unit/index/quadtree,
-	  tests/unit/index/quadtree/DoubleBitsTest.cpp: Added unit test for
-	  DoubleBits
+	* [r1375] Added unit test for DoubleBits
 2006-04-06 14:36  Sandro Santilli <strk at keybit.net>
-	* [r1374] source/headers/geos/precision/CommonBitsOp.h,
-	  source/headers/geos/precision/CommonBitsRemover.h,
-	  source/headers/geos/precision/EnhancedPrecisionOp.h,
-	  source/precision/CommonBitsOp.cpp,
-	  source/precision/CommonBitsRemover.cpp,
-	  source/precision/EnhancedPrecisionOp.cpp: Cleanup in
-	  geos::precision namespace (leaks plugged, auto_ptr use, ...)
+	* [r1374] Cleanup in geos::precision namespace (leaks plugged,
+	  auto_ptr use, ...)
 2006-04-06 12:58  Sandro Santilli <strk at keybit.net>
-	* [r1373] source/geomgraph/DirectedEdge.cpp: Added printing of
-	  EdgeRing if available
+	* [r1373] Added printing of EdgeRing if available
 2006-04-06 12:48  Sandro Santilli <strk at keybit.net>
-	* [r1372]
-	  source/headers/geos/operation/valid/ConnectedInteriorTester.h:
-	  Added private vector to keep track of allocated MaximalEdgeRings
-	  objects
+	* [r1372] Added private vector to keep track of allocated
+	  MaximalEdgeRings objects
 2006-04-06 12:47  Sandro Santilli <strk at keybit.net>
-	* [r1371] source/geomgraph/EdgeEnd.cpp: Fixed output function
+	* [r1371] Fixed output function
 2006-04-06 12:45  Sandro Santilli <strk at keybit.net>
-	* [r1370] source/operation/valid/ConnectedInteriorTester.cpp:
-	  Delayed deletion of newly allocated MaximalEdgeRings.
+	* [r1370] Delayed deletion of newly allocated MaximalEdgeRings.
 	  Existing 'valid' operation tests don't should instability with
 	  this patch.
 2006-04-06 12:36  Sandro Santilli <strk at keybit.net>
-	* [r1369] source/geom/PrecisionModel.cpp: removed spurious lines
-	  from previous commi
+	* [r1369] removed spurious lines from previous commi
 2006-04-06 12:34  Sandro Santilli <strk at keybit.net>
-	* [r1368] source/geom/PrecisionModel.cpp,
-	  source/headers/geos/geom/PrecisionModel.h,
-	  source/headers/geos/geom/PrecisionModel.inl: Port info, more
-	  debugging lines, doxygen comments
+	* [r1368] Port info, more debugging lines, doxygen comments
 2006-04-06 12:33  Sandro Santilli <strk at keybit.net>
-	* [r1367] source/geom/GeometryFactory.cpp: More debugging lines
+	* [r1367] More debugging lines
 2006-04-06 12:29  Sandro Santilli <strk at keybit.net>
-	* [r1366] source/io/WKBReader.cpp: Fixed bogus static
-	  PrecisionModel variable in ::readCoordinate().
+	* [r1366] Fixed bogus static PrecisionModel variable in
+	  ::readCoordinate().
 2006-04-06 09:41  Sandro Santilli <strk at keybit.net>
-	* [r1365] source/geomgraph/EdgeRing.cpp,
-	  source/headers/geos/geomgraph/EdgeRing.h: Added operator<<, added
-	  pts!=NULL assertion in testInvariant() function
+	* [r1365] Added operator<<, added pts!=NULL assertion in
+	  testInvariant() function
 2006-04-06 09:39  Sandro Santilli <strk at keybit.net>
-	* [r1364] source/geomgraph/EdgeEnd.cpp,
-	  source/headers/geos/geomgraph/EdgeEnd.h: Added operator<<
+	* [r1364] Added operator<<
 2006-04-06 09:01  Sandro Santilli <strk at keybit.net>
-	* [r1363] source/geomgraph/Label.cpp,
-	  source/geomgraph/TopologyLocation.cpp,
-	  source/headers/geos/geomgraph/Label.h,
-	  source/headers/geos/geomgraph/TopologyLocation.h: Doxygen
-	  comments, port info, operator<<, assertion checking
+	* [r1363] Doxygen comments, port info, operator<<, assertion
+	  checking
 2006-04-06 07:52  Sandro Santilli <strk at keybit.net>
-	* [r1362] source/geomgraph/DirectedEdge.cpp: Fixed bug in ::print()
-	  function
+	* [r1362] Fixed bug in ::print() function
 2006-04-05 18:28  Sandro Santilli <strk at keybit.net>
-	* [r1361] source/headers/geos/geomgraph/Edge.h,
-	  source/headers/geos/geomgraph/EdgeRing.h: Moved testInvariant()
-	  methods from private to public, added
+	* [r1361] Moved testInvariant() methods from private to public,
+	  added
 	  some comments about them.
 2006-04-05 15:59  Sandro Santilli <strk at keybit.net>
-	* [r1360] source/operation/overlay/OverlayOp.cpp: Removed dead code
+	* [r1360] Removed dead code
 2006-04-05 14:33  Sandro Santilli <strk at keybit.net>
-	* [r1359] tests/xmltester/markup/MarkupSTL.cpp,
-	  tests/xmltester/markup/MarkupSTL.h: Removed annoying warnings
-	  from external source
+	* [r1359] Removed annoying warnings from external source
 2006-04-05 14:04  Sandro Santilli <strk at keybit.net>
-	* [r1358] source/geom/Envelope.cpp,
-	  source/headers/geos/geom/Envelope.inl: Fixed copy ctor to support
-	  "Null" Envelope copies.
+	* [r1358] Fixed copy ctor to support "Null" Envelope copies.
 	  Drop init(Envelope&) method.
 	  Port info and various cleanups.
 2006-04-05 10:25  Sandro Santilli <strk at keybit.net>
-	* [r1357] source/geom/LineString.cpp,
-	  source/headers/geos/geom/LineString.h: Fixed LineString
-	  constructor to ensure deletion of CoordinateSequence
+	* [r1357] Fixed LineString constructor to ensure deletion of
 	  argument on exception throw
 2006-04-05 09:34  Sandro Santilli <strk at keybit.net>
-	* [r1356] source/headers/geos/util/GEOSException.h: GEOSException
-	  derived from std::exception again, hopefully the correct way now
+	* [r1356] GEOSException derived from std::exception again,
+	  hopefully the correct way now
 2006-04-05 09:20  Sandro Santilli <strk at keybit.net>
-	* [r1355]
-	  source/headers/geos/operation/buffer/RightmostEdgeFinder.h,
-	  source/operation/buffer/RightmostEdgeFinder.cpp: Added port
-	  informations and many assertion checking.
+	* [r1355] Added port informations and many assertion checking.
 	  Fixed bug in getRightmostSide() method ( a "testing-only" corner
 	  case )
 2006-04-04 16:07  Sandro Santilli <strk at keybit.net>
-	* [r1353] source/geomgraph/DirectedEdgeStar.cpp: More assertion
-	  checking, less overhead when built with NDEBUG defined
+	* [r1353] More assertion checking, less overhead when built with
+	  NDEBUG defined
 2006-04-04 13:35  Sandro Santilli <strk at keybit.net>
-	* [r1352] source/geomgraph/EdgeEndStar.cpp,
-	  source/headers/geos/geomgraph/EdgeEndStar.h: Port info, assertion
-	  checking, indentation
+	* [r1352] Port info, assertion checking, indentation
 2006-04-04 12:39  Sandro Santilli <strk at keybit.net>
-	* [r1351] source/algorithm/LineIntersector.cpp: Changed
-	  NotRepresentableCoordinate exception handler to throw
+	* [r1351] Changed NotRepresentableCoordinate exception handler to
+	  throw
 	  a TopologyException. This allows further handling.
 2006-04-04 11:37  Sandro Santilli <strk at keybit.net>
-	* [r1350] source/algorithm/HCoordinate.cpp,
-	  source/headers/geos/algorithm/HCoordinate.h: Port information +
-	  initialization lists in ctors
+	* [r1350] Port information + initialization lists in ctors
 2006-04-04 11:28  Sandro Santilli <strk at keybit.net>
-	* [r1349] source/algorithm/HCoordinate.cpp: NotRepresentable
-	  condition detected using finite() from <cmath>
+	* [r1349] NotRepresentable condition detected using finite() from
+	  <cmath>
 	  rather then using FINITE() macro. Made ::intersection() body
 	  more readable.
 2006-04-04 09:53  Sandro Santilli <strk at keybit.net>
-	* [r1348] source/headers/geos/geom/CoordinateSequence.h: Fixed
-	  applyCoordinateFilter() templated function body
+	* [r1348] Fixed applyCoordinateFilter() templated function body
 2006-04-04 08:16  Sandro Santilli <strk at keybit.net>
-	* [r1345] NEWS, doc/example.cpp,
-	  source/algorithm/NotRepresentableException.cpp,
-	  source/examples/CPCLException.cpp,
-	  source/examples/CustomCoordinateSequenceExample.cpp,
-	  source/examples/CustomCoordinateSequenceExample.h,
-	  source/headers/geos/io/ParseException.h,
-	  source/headers/geos/util/GEOSException.h,
-	  source/headers/geos/util/IllegalArgumentException.h,
-	  source/io/ParseException.cpp,
-	  source/operation/overlay/ElevationMatrix.cpp,
-	  source/util/GEOSException.cpp: Changed GEOSException hierarchy to
-	  be derived from std::runtime_exception.
+	* [r1345] Changed GEOSException hierarchy to be derived from
+	  std::runtime_exception.
 	  Removed the GEOSException::toString redundant method (use
 	  ::what() instead)
 2006-04-04 01:54  Howard Butler <hobu.inc at gmail.com>
-	* [r1344] source/Makefile.vc: Add in changes/missing from previous
-	  rearranging.
+	* [r1344] Add in changes/missing from previous rearranging.
 2006-04-04 01:29  Howard Butler <hobu.inc at gmail.com>
-	* [r1343] capi/geos_c.cpp: GEOS_JTS_PORT is in version.h not
-	  platform.h
+	* [r1343] GEOS_JTS_PORT is in version.h not platform.h
 2006-04-04 01:28  Howard Butler <hobu.inc at gmail.com>
-	* [r1342] source/Makefile.vc: remove objects that no longer exist
+	* [r1342] remove objects that no longer exist
 	  default to MSVC_VER=1310
 2006-04-03 17:05  Sandro Santilli <strk at keybit.net>
-	* [r1341] source/geomgraph/DirectedEdge.cpp,
-	  source/geomgraph/EdgeEnd.cpp, source/geomgraph/Label.cpp,
-	  source/headers/geos/geomgraph/EdgeEnd.h: Assertion checking, port
-	  info, cleanups
+	* [r1341] Assertion checking, port info, cleanups
 2006-04-03 15:54  Sandro Santilli <strk at keybit.net>
-	* [r1340] source/headers/geos/operation/GeometryGraphOperation.h,
-	  source/operation/GeometryGraphOperation.cpp: - getArgGeometry()
-	  parameter type changed from 'int' to 'unsigned int'
+	* [r1340] - getArgGeometry() parameter type changed from 'int' to
+	  'unsigned int'
 	  - Added port informations
 	  - minor assertions checking
 	  - minor cleanups
 2006-04-03 14:07  Sandro Santilli <strk at keybit.net>
-	* [r1339] source/headers/geos/geom/PrecisionModel.h: Commented out
-	  obsoleted toInternal() method
+	* [r1339] Commented out obsoleted toInternal() method
 2006-04-03 13:58  Sandro Santilli <strk at keybit.net>
-	* [r1337] macros/ac_pkg_swig.m4, macros/ac_python_devel.m4,
-	  swig/geos.i, swig/python/Makefile.am, swig/python/python.i,
-	  swig/ruby/ruby.i, swig/ruby/test/geos_tests.rb,
-	  swig/ruby/test/test_helper.rb: Applied patch by Charlie Savage:
+	* [r1337] Applied patch by Charlie Savage:
 	  - Fixes up the SWIG bindings to use the new GEOS namespaces
 	  - Fixes a bug in the Python m4 macro
 	  - Adds the -modern flag for SWIG when compiling a Python
@@ -10436,557 +6662,294 @@
 2006-04-03 13:56  Sandro Santilli <strk at keybit.net>
-	* [r1336]
-	  source/headers/geos/precision/SimpleGeometryPrecisionReducer.h,
-	  source/precision/SimpleGeometryPrecisionReducer.cpp: Made
-	  externally-owned PrecisionModel const
+	* [r1336] Made externally-owned PrecisionModel const
 2006-04-03 10:56  Sandro Santilli <strk at keybit.net>
-	* [r1334] source/geom/CoordinateSequenceFactory.cpp,
-	  source/geom/Makefile.am,
-	  source/geom/util/LinearComponentExtracter.cpp,
-	  source/geom/util/PointExtracter.cpp,
-	  source/geom/util/PolygonExtracter.cpp,
-	  source/util/AssertionFailedException.cpp,
-	  source/util/IllegalArgumentException.cpp,
-	  source/util/Makefile.am,
-	  source/util/UnsupportedOperationException.cpp: Removed
-	  implementation files build spec for fully-inlined classes
+	* [r1334] Removed implementation files build spec for fully-inlined
+	  classes
 2006-04-03 10:44  Sandro Santilli <strk at keybit.net>
-	* [r1333] source/index/strtree/STRtree.cpp,
-	  source/noding/snapround/MCIndexSnapRounder.cpp: Added missing
-	  headers
+	* [r1333] Added missing headers
 2006-04-03 10:16  Sandro Santilli <strk at keybit.net>
-	* [r1332] configure.in, source/Makefile.am,
-	  source/headers/geos/Makefile.am, source/headers/geos/simplify,
-	  source/headers/geos/simplify/.cvsignore,
-	  source/headers/geos/simplify/Makefile.am, source/simplify,
-	  source/simplify/.cvsignore,
-	  source/simplify/DouglasPeuckerLineSimplifier.cpp,
-	  source/simplify/Makefile.am: DouglasPeuckerLineSimplifier class
-	  port
+	* [r1332] DouglasPeuckerLineSimplifier class port
 2006-04-03 08:43  Sandro Santilli <strk at keybit.net>
-	* [r1331] source/headers/geos/index/strtree/STRtree.h,
-	  source/index/strtree/STRtree.cpp: Added port info, minor cleanups
+	* [r1331] Added port info, minor cleanups
 2006-04-03 08:29  Sandro Santilli <strk at keybit.net>
-	* [r1330] source/headers/geos/index/quadtree/Quadtree.h,
-	  source/index/quadtree/Quadtree.cpp: Added port info, cleaned up
-	  log message, minor assertion checking.
+	* [r1330] Added port info, cleaned up log message, minor assertion
+	  checking.
 2006-03-31 17:51  Sandro Santilli <strk at keybit.net>
-	* [r1329] source/geom/GeometryFactory.cpp,
-	  source/headers/geos/geom/GeometryFactory.h: A few assertion
-	  checking, comments cleanup, use of initialization lists
+	* [r1329] A few assertion checking, comments cleanup, use of
 	  in constructors, handled NULL parameters.
 2006-03-31 16:55  Sandro Santilli <strk at keybit.net>
-	* [r1328] NEWS, source/geom/LineString.cpp,
-	  source/headers/geos/geom/LineString.h: Added many assertions
-	  checking in LineString implementation.
+	* [r1328] Added many assertions checking in LineString
+	  implementation.
 	  Changed ::getCoordinate() to return NULL on empty geom.
 	  Changed ::get{Start,End}Point() to return NULL on empty geom.
 2006-03-31 16:53  Sandro Santilli <strk at keybit.net>
-	* [r1327] source/headers/geos/geom/Geometry.h: Added comment about
-	  possible NULL return from getCoordinate()
+	* [r1327] Added comment about possible NULL return from
+	  getCoordinate()
 2006-03-31 11:03  Sandro Santilli <strk at keybit.net>
-	* [r1325] source/geom/Geometry.cpp: Fixed NULL-GeometryFactory
-	  constructor to use INTERNAL_GEOMETRY_FACTORY
+	* [r1325] Fixed NULL-GeometryFactory constructor to use
+	  INTERNAL_GEOMETRY_FACTORY
 	  (should fix bug #81)
 2006-03-30 09:26  Sandro Santilli <strk at keybit.net>
-	* [r1324] source/headers/geos/io/WKTReader.h: minor cleanup
+	* [r1324] minor cleanup
 2006-03-29 15:48  Sandro Santilli <strk at keybit.net>
-	* [r1323] capi/geos_c.cpp: Added missing 'const' in catch
-	  std::exception statements
+	* [r1323] Added missing 'const' in catch std::exception statements
 2006-03-29 15:23  Sandro Santilli <strk at keybit.net>
-	* [r1322] source/geomgraph/DirectedEdge.cpp,
-	  source/headers/geos/geomgraph/GeometryGraph.h,
-	  source/headers/geos/geomgraph/GeometryGraph.inl,
-	  source/headers/geos/geomgraph/Makefile.am: Moved GeometryGraph
-	  inlines from .h to .inl file
+	* [r1322] Moved GeometryGraph inlines from .h to .inl file
 2006-03-29 14:34  Sandro Santilli <strk at keybit.net>
-	* [r1321] tests/xmltester/TestValid.xml: Sync'ed testfile with JTS
-	  head
+	* [r1321] Sync'ed testfile with JTS head
 2006-03-29 14:31  Sandro Santilli <strk at keybit.net>
-	* [r1320] tests/unit/Makefile.am, tests/unit/algorithm,
-	  tests/unit/algorithm/PointLocator.cpp,
-	  tests/unit/io/WKBReader.cpp: Added PointLocator unit test
+	* [r1320] Added PointLocator unit test
 2006-03-29 13:53  Sandro Santilli <strk at keybit.net>
-	* [r1319] source/geomgraph/EdgeRing.cpp,
-	  source/headers/geos/geomgraph/EdgeRing.h,
-	  source/headers/geos/operation/valid/IsValidOp.h,
-	  source/operation/valid/ConnectedInteriorTester.cpp,
-	  source/operation/valid/IsValidOp.cpp: EdgeRing equipped with
-	  Invariant testing function and lots of exceptional assertions.
-	  Removed useless heap allocations, and pointers usages.
+	* [r1319] EdgeRing equipped with Invariant testing function and
+	  lots of exceptional assertions. Removed useless heap allocations,
+	  and pointers usages.
 2006-03-29 11:52  Sandro Santilli <strk at keybit.net>
-	* [r1318] source/algorithm/MCPointInRing.cpp,
-	  source/headers/geos/algorithm/MCPointInRing.h: const correctness,
-	  useless heap allocations removal
+	* [r1318] const correctness, useless heap allocations removal
 2006-03-29 11:48  Sandro Santilli <strk at keybit.net>
-	* [r1317]
-	  source/headers/geos/operation/valid/QuadtreeNestedRingTester.h,
-	  source/operation/valid/QuadtreeNestedRingTester.cpp: Removed
-	  useless heap allocations in construction, enforced const
-	  correctness
+	* [r1317] Removed useless heap allocations in construction,
+	  enforced const correctness
 2006-03-28 16:49  Sandro Santilli <strk at keybit.net>
-	* [r1316] source/io/WKBReader.cpp: Reintroduced rewind of input
-	  parameter in printHEX() [dropped by prev commit]
+	* [r1316] Reintroduced rewind of input parameter in printHEX()
+	  [dropped by prev commit]
 2006-03-28 16:33  Sandro Santilli <strk at keybit.net>
-	* [r1315] source/headers/geos/geom/GeometryFactory.h: Added note
-	  about args responsibility in GeometryFactory constructor
+	* [r1315] Added note about args responsibility in GeometryFactory
+	  constructor
 2006-03-28 16:11  Sandro Santilli <strk at keybit.net>
-	* [r1314] tests/unit/io/WKBReader.cpp: swapped assert_equals() args
-	  to get obtained/expected the right way.
+	* [r1314] swapped assert_equals() args to get obtained/expected the
+	  right way.
 2006-03-28 15:27  Sandro Santilli <strk at keybit.net>
-	* [r1313] source/io/WKBReader.cpp: Simplified printHEX()
-	  implementation
+	* [r1313] Simplified printHEX() implementation
 2006-03-28 15:19  Sandro Santilli <strk at keybit.net>
-	* [r1312] doc/example.cpp: Added macros for sections skip (useful
-	  in debugging)
+	* [r1312] Added macros for sections skip (useful in debugging)
 2006-03-28 14:45  Sandro Santilli <strk at keybit.net>
-	* [r1311] tests/unit/Makefile.am, tests/unit/io,
-	  tests/unit/io/WKBReader.cpp: Added simple test for WKB reader.
+	* [r1311] Added simple test for WKB reader.
 2006-03-28 14:02  Sandro Santilli <strk at keybit.net>
-	* [r1310] source/io/WKBReader.cpp: added missing header for
-	  non-inlined builds
+	* [r1310] added missing header for non-inlined builds
 2006-03-28 14:01  Sandro Santilli <strk at keybit.net>
-	* [r1309] source/io/ByteOrderDataInStream.cpp: forgot to add in
-	  previous commit
+	* [r1309] forgot to add in previous commit
 2006-03-28 11:26  Sandro Santilli <strk at keybit.net>
-	* [r1308] source/headers/geos/io/ByteOrderDataInStream.h,
-	  source/headers/geos/io/ByteOrderDataInStream.inl,
-	  source/headers/geos/io/Makefile.am,
-	  source/headers/geos/io/WKBWriter.h, source/io/Makefile.am:
-	  ByteOrderDataInStream inlines moved to .inl file, updated
+	* [r1308] ByteOrderDataInStream inlines moved to .inl file, updated
 	  implementation files includes.
 2006-03-28 11:25  Sandro Santilli <strk at keybit.net>
-	* [r1307] source/io/WKBWriter.cpp: Assertion checking
+	* [r1307] Assertion checking
 2006-03-28 09:14  Sandro Santilli <strk at keybit.net>
-	* [r1306] source/headers/geos/geom/LineSegment.h,
-	  source/headers/geos/geom/LineSegment.inl: Headers inclusion fix.
+	* [r1306] Headers inclusion fix.
 2006-03-28 08:57  Sandro Santilli <strk at keybit.net>
-	* [r1305] source/headers/geos/geom/PrecisionModel.h,
-	  source/headers/geos/geom/PrecisionModel.inl: Comments cleanup,
-	  system headers included after project headers
+	* [r1305] Comments cleanup, system headers included after project
+	  headers
 2006-03-28 08:40  Sandro Santilli <strk at keybit.net>
-	* [r1304] configure.in: C-API lib version bumped to 1.1.1 (release
-	  2.2.2 will ship 1.1.0)
+	* [r1304] C-API lib version bumped to 1.1.1 (release 2.2.2 will
+	  ship 1.1.0)
 2006-03-27 17:59  Sandro Santilli <strk at keybit.net>
-	* [r1302] source/operation/buffer/OffsetCurveBuilder.cpp: Fixed
-	  small leak.
+	* [r1302] Fixed small leak.
 2006-03-27 17:04  Sandro Santilli <strk at keybit.net>
-	* [r1301]
-	  source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
-	  source/operation/buffer/OffsetCurveBuilder.cpp,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp: Cleanups and
-	  explicit initializations
+	* [r1301] Cleanups and explicit initializations
 2006-03-27 16:02  Sandro Santilli <strk at keybit.net>
-	* [r1300] source/geomgraph/EdgeRing.cpp,
-	  source/headers/geos/operation/overlay/Makefile.am,
-	  source/headers/geos/operation/overlay/MaximalEdgeRing.h,
-	  source/headers/geos/operation/overlay/MinimalEdgeRing.h,
-	  source/headers/geos/operation/overlay/MinimalEdgeRing.inl,
-	  source/operation/overlay/MaximalEdgeRing.cpp,
-	  source/operation/overlay/MinimalEdgeRing.cpp,
-	  source/operation/valid/ConnectedInteriorTester.cpp: Added INL
-	  file for MinimalEdgeRing, added many debugging blocks,
+	* [r1300] Added INL file for MinimalEdgeRing, added many debugging
+	  blocks,
 	  fixed memory leak in ConnectedInteriorTester (bug #59)
 2006-03-27 15:57  Sandro Santilli <strk at keybit.net>
-	* [r1299] source/headers/geos/geom/Coordinate.h,
-	  source/headers/geos/geom/Coordinate.inl: Commented need for
-	  platform.h include
+	* [r1299] Commented need for platform.h include
 2006-03-27 15:56  Sandro Santilli <strk at keybit.net>
-	* [r1298] source/geom/Coordinate.cpp: Added missing platform.h
-	  include (for ISNAN macro)
+	* [r1298] Added missing platform.h include (for ISNAN macro)
 2006-03-27 14:20  Sandro Santilli <strk at keybit.net>
-	* [r1297]
-	  source/headers/geos/operation/valid/ConnectedInteriorTester.h,
-	  paranoid assertion checking and a note in header about
-	  responsibility of return from buildMaximalEdgeRings()
+	* [r1297] Added paranoid assertion checking and a note in header
+	  about responsibility of return from buildMaximalEdgeRings()
 2006-03-27 10:37  Sandro Santilli <strk at keybit.net>
-	* [r1296]
-	  source/headers/geos/operation/valid/ConsistentAreaTester.h,
-	  source/operation/valid/ConsistentAreaTester.cpp: Reduced heap
-	  allocations and probability of error by making LineIntersector
+	* [r1296] Reduced heap allocations and probability of error by
+	  making LineIntersector
 	  and RelateNodeGraph part of ConsistentAreaTester class .
 2006-03-27 10:36  Sandro Santilli <strk at keybit.net>
-	* [r1295] source/operation/valid/TopologyValidationError.cpp: added
-	  missing space in exception message
+	* [r1295] added missing space in exception message
 2006-03-27 10:34  Sandro Santilli <strk at keybit.net>
-	* [r1294] source/headers/geos/geom/Coordinate.inl: moved external
-	  includes after internal ones
+	* [r1294] moved external includes after internal ones
 2006-03-27 09:50  Sandro Santilli <strk at keybit.net>
-	* [r1293] tests/xmltester/Makefile.am,
-	  tests/xmltester/TestValid2-big.xml: Added final isValid test from
-	  JTS (floating version)
+	* [r1293] Added final isValid test from JTS (floating version)
 2006-03-27 09:48  Sandro Santilli <strk at keybit.net>
-	* [r1292] tests/xmltester/Makefile.am,
-	  tests/xmltester/TestValid2.xml, tests/xmltester/testLeaksBig.xml:
-	  Extracted TestValid2.xml from testLeaksBig.xml (target file is
-	  taken from JTS source tree)
+	* [r1292] Extracted TestValid2.xml from testLeaksBig.xml (target
+	  file is taken from JTS source tree)
 2006-03-27 09:45  Sandro Santilli <strk at keybit.net>
-	* [r1291] tests/xmltester/Makefile.am,
-	  tests/xmltester/TestValid.xml, tests/xmltester/testLeaksBig.xml:
-	  Added TestValid.xml test, taken from JTS source tree, already
-	  present in testLeaksBig (from which tests were removed)
+	* [r1291] Added TestValid.xml test, taken from JTS source tree,
+	  already present in testLeaksBig (from which tests were removed)
 2006-03-27 09:28  Sandro Santilli <strk at keybit.net>
-	* [r1290] NEWS: added namespaces use and headers split
+	* [r1290] added namespaces use and headers split
 2006-03-27 09:05  Sandro Santilli <strk at keybit.net>
-	* [r1289] capi/geos_c.h.in: Added note about responsibility of
-	  return from GEOSGeomType()
+	* [r1289] Added note about responsibility of return from
+	  GEOSGeomType()
 2006-03-27 09:00  Sandro Santilli <strk at keybit.net>
-	* [r1288] source/geom/CoordinateArraySequence.cpp: Bug #79 - Small
-	  fix in CoordinateArraySequence::toString()
+	* [r1288] Bug #79 - Small fix in
+	  CoordinateArraySequence::toString()
 2006-03-24 11:42  Sandro Santilli <strk at keybit.net>
-	* [r1287] configure.in: reverted default of assertion checking
+	* [r1287] reverted default of assertion checking
 2006-03-24 11:11  Sandro Santilli <strk at keybit.net>
-	* [r1286] TODO, configure.in, tools/geos-config.in: Inlining
-	  enabled by default, assertion checking disabled by default.
+	* [r1286] Inlining enabled by default, assertion checking disabled
+	  by default.
 	  Added --enable-cassert and --disable-inline configure switches.
 	  Had geos-config --cflags output appropriate inline flag if
 	  required (-DGEOS_INLINE)
 2006-03-24 11:04  Sandro Santilli <strk at keybit.net>
-	* [r1285] source/operation/linemerge/LineSequencer.cpp: Changed
-	  assert() with Assert::isTrue in addReverseSubpath
+	* [r1285] Changed assert() with Assert::isTrue in addReverseSubpath
 2006-03-24 10:44  Sandro Santilli <strk at keybit.net>
-	* [r1284] source/operation/linemerge/LineSequencer.cpp: Fixed to
-	  build with -DNDEBUG
+	* [r1284] Fixed to build with -DNDEBUG
 2006-03-24 09:52  Sandro Santilli <strk at keybit.net>
-	* [r1283] TODO, capi/geos_c.cpp.bak,
-	  source/algorithm/ConvexHull.cpp, source/geom/Coordinate.cpp,
-	  source/geom/CoordinateArraySequenceFactory.cpp,
-	  source/geom/Envelope.cpp, source/geom/Geometry.cpp,
-	  source/geom/GeometryFactory.cpp, source/geom/LineSegment.cpp,
-	  source/geom/MultiLineString.cpp, source/geom/MultiPolygon.cpp,
-	  source/geom/PrecisionModel.cpp,
-	  source/geomgraph/DirectedEdge.cpp,
-	  source/headers/geos/algorithm/ConvexHull.h,
-	  source/headers/geos/geom/Coordinate.h,
-	  source/headers/geos/geom/CoordinateArraySequence.h,
-	  source/headers/geos/geom/CoordinateArraySequenceFactory.h,
-	  source/headers/geos/geom/CoordinateFilter.h,
-	  source/headers/geos/geom/CoordinateSequence.h,
-	  source/headers/geos/geom/CoordinateSequenceFactory.h,
-	  source/headers/geos/geom/Dimension.h,
-	  source/headers/geos/geom/Geometry.h,
-	  source/headers/geos/geom/GeometryComponentFilter.h,
-	  source/headers/geos/geom/GeometryFilter.h,
-	  source/headers/geos/geom/IntersectionMatrix.h,
-	  source/headers/geos/geom/LineSegment.h,
-	  source/headers/geos/geom/LineString.h,
-	  source/headers/geos/geom/Location.h,
-	  source/headers/geos/geom/MultiLineString.h,
-	  source/headers/geos/geom/MultiPoint.h,
-	  source/headers/geos/geom/MultiPolygon.h,
-	  source/headers/geos/geom/Point.h,
-	  source/headers/geos/geom/Polygon.h,
-	  source/headers/geos/geom/Triangle.h,
-	  source/headers/geos/geom/util/CoordinateOperation.h,
-	  source/headers/geos/geom/util/GeometryEditor.h,
-	  source/headers/geos/geom/util/GeometryEditorOperation.h,
-	  source/headers/geos/geom/util/ShortCircuitedGeometryVisitor.h,
-	  source/headers/geos/geomgraph/Depth.h,
-	  source/headers/geos/geomgraph/DirectedEdge.h,
-	  source/headers/geos/geomgraph/DirectedEdgeStar.h,
-	  source/headers/geos/geomgraph/Edge.h,
-	  source/headers/geos/geomgraph/EdgeEnd.h,
-	  source/headers/geos/geomgraph/EdgeEndStar.h,
-	  source/headers/geos/geomgraph/EdgeIntersection.h,
-	  source/headers/geos/geomgraph/EdgeIntersectionList.h,
-	  source/headers/geos/geomgraph/EdgeList.h,
-	  source/headers/geos/geomgraph/EdgeNodingValidator.h,
-	  source/headers/geos/geomgraph/GraphComponent.h,
-	  source/headers/geos/geomgraph/Node.h,
-	  source/headers/geos/geomgraph/NodeFactory.h,
-	  source/headers/geos/geomgraph/NodeMap.h,
-	  source/headers/geos/geomgraph/PlanarGraph.h,
-	  source/headers/geos/geomgraph/Position.h,
-	  source/headers/geos/geomgraph/Quadrant.h,
-	  source/headers/geos/geomgraph/TopologyLocation.h,
-	  source/headers/geos/inline.h, source/headers/geos/io/WKTReader.h,
-	  source/headers/geos/noding/IntersectionAdder.h,
-	  source/headers/geos/noding/IntersectionFinderAdder.h,
-	  source/headers/geos/noding/IteratedNoder.h,
-	  source/headers/geos/noding/MCIndexNoder.h,
-	  source/headers/geos/noding/Noder.h,
-	  source/headers/geos/noding/NodingValidator.h,
-	  source/headers/geos/noding/Octant.h,
-	  source/headers/geos/noding/ScaledNoder.h,
-	  source/headers/geos/noding/SegmentIntersector.h,
-	  source/headers/geos/noding/SegmentNode.h,
-	  source/headers/geos/noding/SegmentNodeList.h,
-	  source/headers/geos/noding/SegmentString.h,
-	  source/headers/geos/noding/SimpleNoder.h,
-	  source/headers/geos/noding/SinglePassNoder.h,
-	  source/headers/geos/noding/snapround/HotPixel.h,
-	  source/headers/geos/noding/snapround/MCIndexPointSnapper.h,
-	  source/headers/geos/noding/snapround/MCIndexSnapRounder.h,
-	  source/headers/geos/noding/snapround/SimpleSnapRounder.h,
-	  source/io/WKTReader.cpp, source/noding/MCIndexNoder.cpp,
-	  source/noding/SegmentString.cpp,
-	  source/noding/snapround/HotPixel.cpp,
-	  source/noding/snapround/MCIndexSnapRounder.cpp,
-	  source/operation/distance/DistanceOp.cpp: USE_INLINE =>
-	  GEOS_INLINE
+	* [r1283] USE_INLINE => GEOS_INLINE
 2006-03-24 09:26  Sandro Santilli <strk at keybit.net>
-	* [r1282] capi/geos_c.cpp: Bug #77 - Missing platform.h
+	* [r1282] Bug #77 - Missing platform.h
 2006-03-24 09:25  Sandro Santilli <strk at keybit.net>
-	* [r1281] source/noding/snapround/MCIndexPointSnapper.cpp,
-	  source/operation/buffer/BufferBuilder.cpp: Bugs #77 and #76:
-	  missing <algorithm>
+	* [r1281] Bugs #77 and #76: missing <algorithm>
 2006-03-24 09:23  Sandro Santilli <strk at keybit.net>
-	* [r1280] tests/unit/geos_unit.cpp: Bug #78 - Small fixes and
-	  cleaning
+	* [r1280] Bug #78 - Small fixes and cleaning
 2006-03-23 15:10  Sandro Santilli <strk at keybit.net>
-	* [r1278] source/geom/Coordinate.cpp,
-	  source/geomgraph/DirectedEdgeStar.cpp,
-	  source/geomgraph/EdgeEndStar.cpp, source/geomgraph/EdgeRing.cpp,
-	  source/headers/geos/geomgraph/DirectedEdge.inl,
-	  source/headers/geos/util/TopologyException.h,
-	  source/operation/overlay/OverlayOp.cpp: Dropped by-pointer
-	  TopologyException constructor, various small cleanups
+	* [r1278] Dropped by-pointer TopologyException constructor, various
+	  small cleanups
 2006-03-23 13:31  Sandro Santilli <strk at keybit.net>
-	* [r1277] source/geomgraph/Edge.cpp,
-	  source/geomgraph/EdgeIntersectionList.cpp,
-	  source/geomgraph/index/SegmentIntersector.cpp,
-	  source/index/chain/MonotoneChainBuilder.cpp,
-	  source/index/quadtree/Node.cpp,
-	  source/index/quadtree/NodeBase.cpp,
-	  source/index/quadtree/Quadtree.cpp: Fixed to allow build with
-	  GEOS_DEBUG
+	* [r1277] Fixed to allow build with GEOS_DEBUG
 2006-03-23 12:12  Sandro Santilli <strk at keybit.net>
-	* [r1276] source/geom/Geometry.cpp,
-	  source/headers/geos/geom/Geometry.inl,
-	  source/headers/geos/geom/GeometryCollection.inl,
-	  source/headers/geos/geom/MultiLineString.inl,
-	  source/headers/geos/geom/MultiPolygon.inl,
-	  source/operation/distance/DistanceOp.cpp: Fixes to allow build
-	  with -DUSE_INLINE
+	* [r1276] Fixes to allow build with -DUSE_INLINE
 2006-03-23 10:55  Sandro Santilli <strk at keybit.net>
-	* [r1275] Makefile.am, configure.in: Temporarly excluded 'swig'
-	  extension from distribution, to allow for
+	* [r1275] Temporarly excluded 'swig' extension from distribution,
+	  to allow for
 	  successufull 'dist' rule and distributed testing.
 2006-03-23 10:41  Sandro Santilli <strk at keybit.net>
-	* [r1274] source/headers/geos/Makefile.am,
-	  source/headers/geos/operation/relate/Makefile.am: Fixed automake
-	  files
+	* [r1274] Fixed automake files
 2006-03-23 10:09  Sandro Santilli <strk at keybit.net>
-	* [r1273] source/headers/geos/operation/predicate/Makefile.am:
-	  Fixed missing backslash
+	* [r1273] Fixed missing backslash
 2006-03-23 09:17  Sandro Santilli <strk at keybit.net>
-	* [r1272] configure.in, source/headers/geos/Makefile.am,
-	  source/headers/geos/precision, source/headers/geos/precision.h,
-	  source/headers/geos/precision/.cvsignore,
-	  source/headers/geos/precision/CommonBits.h,
-	  source/headers/geos/precision/CommonBitsOp.h,
-	  source/headers/geos/precision/Makefile.am,
-	  source/operation/buffer/BufferOp.cpp,
-	  source/operation/overlay/OverlayOp.cpp,
-	  source/precision/CommonBits.cpp,
-	  source/precision/EnhancedPrecisionOp.cpp,
-	  source/precision/SimpleGeometryPrecisionReducer.cpp: precision.h
-	  header split, minor optimizations
+	* [r1272] precision.h header split, minor optimizations
 2006-03-22 18:12  Sandro Santilli <strk at keybit.net>
-	* [r1271] configure.in, source/algorithm/MCPointInRing.cpp,
-	  source/geom/LineSegment.cpp,
-	  source/headers/geos/algorithm/MCPointInRing.h,
-	  source/headers/geos/index/Makefile.am,
-	  source/headers/geos/index/chain,
-	  source/headers/geos/index/chain/.cvsignore,
-	  source/headers/geos/index/chain/Makefile.am,
-	  source/headers/geos/index/chain/MonotoneChain.h,
-	  source/headers/geos/index/chain/MonotoneChainBuilder.h,
-	  source/headers/geos/index/chain/MonotoneChainOverlapAction.h,
-	  source/headers/geos/index/chain/MonotoneChainSelectAction.h,
-	  source/headers/geos/indexChain.h,
-	  source/index/bintree/NodeBase.cpp,
-	  source/index/chain/Makefile.am,
-	  source/index/chain/MonotoneChain.cpp,
-	  source/index/chain/MonotoneChainOverlapAction.cpp,
-	  source/index/chain/MonotoneChainSelectAction.cpp,
-	  source/index/chain/indexMonotoneChain.cpp,
-	  source/noding/MCIndexNoder.cpp,
-	  source/noding/snapround/MCIndexPointSnapper.cpp,
-	  source/operation/buffer/BufferBuilder.cpp,
-	  source/operation/valid/IsValidOp.cpp: indexChain.h header split.
+	* [r1271] indexChain.h header split.
 2006-03-22 16:59  Sandro Santilli <strk at keybit.net>
-	* [r1270] source/headers/geos/geosAlgorithm.h: cleaned up
+	* [r1270] cleaned up
 2006-03-22 16:58  Sandro Santilli <strk at keybit.net>
-	* [r1269] source/geom/CoordinateArraySequence.cpp,
-	  source/geom/CoordinateList.cpp,
-	  source/geom/CoordinateSequence.cpp, source/geom/Dimension.cpp,
-	  source/geom/GeometryCollectionIterator.cpp,
-	  source/geom/GeometryComponentFilter.cpp,
-	  source/geom/IntersectionMatrix.cpp, source/geom/LineSegment.cpp,
-	  source/geom/LineString.cpp, source/geom/Location.cpp,
-	  source/geom/Makefile.am, source/geom/MultiPoint.cpp,
-	  source/geom/MultiPolygon.cpp, source/geom/Point.cpp,
-	  source/geom/TopologyException.cpp, source/geom/Triangle.cpp,
-	  source/geom/util/ShortCircuitedGeometryVisitor.cpp,
-	  source/headers/geos/io/WKTWriter.h, source/io/WKBReader.cpp,
-	  source/io/WKBWriter.cpp, source/io/WKTReader.cpp,
-	  source/io/WKTWriter.cpp, source/util/CoordinateArrayFiter.cpp,
-	  source/util/GeometricShapeFactory.cpp,
-	  source/util/UniqueCoordinateArrayFilter.cpp: Removed (almost) all
-	  inclusions of geom.h.
+	* [r1269] Removed (almost) all inclusions of geom.h.
 	  Removed obsoleted .cpp files.
 	  Fixed a bug in WKTReader not using the provided
 	  CoordinateSequence
@@ -10994,1859 +6957,788 @@
 2006-03-22 16:01  Sandro Santilli <strk at keybit.net>
-	* [r1268] configure.in, source/algorithm/MCPointInRing.cpp,
-	  source/headers/geos/index/bintree,
-	  source/headers/geos/index/bintree/.cvsignore,
-	  source/headers/geos/index/bintree/Bintree.h,
-	  source/headers/geos/index/bintree/Interval.h,
-	  source/headers/geos/index/bintree/Key.h,
-	  source/headers/geos/index/bintree/Makefile.am,
-	  source/headers/geos/index/bintree/Node.h,
-	  source/headers/geos/index/bintree/NodeBase.h,
-	  source/headers/geos/index/bintree/Root.h,
-	  source/headers/geos/indexBintree.h,
-	  source/index/bintree/BinTreeInterval.cpp,
-	  source/index/bintree/BinTreeNode.cpp,
-	  source/index/bintree/Bintree.cpp,
-	  source/index/bintree/Interval.cpp, source/index/bintree/Key.cpp,
-	  source/index/bintree/Makefile.am, source/index/bintree/Node.cpp,
-	  source/index/bintree/NodeBase.cpp, source/index/bintree/Root.cpp,
-	  tests/xmltester/XMLTester.cpp: indexBintree.h header split,
-	  classes renamed to match JTS
+	* [r1268] indexBintree.h header split, classes renamed to match JTS
 2006-03-22 14:28  Sandro Santilli <strk at keybit.net>
-	* [r1267] source/index/quadtree/Key.cpp,
-	  source/index/quadtree/Makefile.am,
-	  source/index/quadtree/QuadTreeKey.cpp,
-	  source/index/quadtree/QuadTreeNode.cpp,
-	  source/index/quadtree/QuadTreeNodeBase.cpp,
-	  source/index/quadtree/QuadTreeRoot.cpp,
-	  source/index/quadtree/Root.cpp: Filenames renamed to match class
-	  names (matching JTS)
+	* [r1267] Filenames renamed to match class names (matching JTS)
 2006-03-22 12:22  Sandro Santilli <strk at keybit.net>
-	* [r1266] configure.in, source/geomgraph/EdgeList.cpp,
-	  source/headers/geos/index/quadtree,
-	  source/headers/geos/index/quadtree/.cvsignore,
-	  source/headers/geos/index/quadtree/DoubleBits.h,
-	  source/headers/geos/index/quadtree/IntervalSize.h,
-	  source/headers/geos/index/quadtree/Key.h,
-	  source/headers/geos/index/quadtree/Makefile.am,
-	  source/headers/geos/index/quadtree/Node.h,
-	  source/headers/geos/index/quadtree/NodeBase.h,
-	  source/headers/geos/index/quadtree/Quadtree.h,
-	  source/headers/geos/index/quadtree/Root.h,
-	  source/headers/geos/indexQuadtree.h,
-	  source/index/bintree/Key.cpp, source/index/bintree/Root.cpp,
-	  source/index/quadtree/DoubleBits.cpp,
-	  source/index/quadtree/IntervalSize.cpp,
-	  source/index/quadtree/Quadtree.cpp,
-	  indexQuadtree.h split
+	* [r1266] indexQuadtree.h split
 2006-03-22 11:19  Sandro Santilli <strk at keybit.net>
-	* [r1265] capi/geos_c.cpp, configure.in,
-	  source/headers/geos/opPolygonize.h,
-	  source/headers/geos/operation/Makefile.am,
-	  source/headers/geos/operation/polygonize,
-	  source/headers/geos/operation/polygonize/.cvsignore,
-	  source/headers/geos/operation/polygonize/EdgeRing.h,
-	  source/headers/geos/operation/polygonize/Makefile.am,
-	  source/headers/geos/operation/polygonize/PolygonizeDirectedEdge.h,
-	  source/headers/geos/operation/polygonize/PolygonizeEdge.h,
-	  source/headers/geos/operation/polygonize/PolygonizeGraph.h,
-	  source/headers/geos/operation/polygonize/Polygonizer.h,
-	  source/operation/polygonize/PolygonizeDirectedEdge.cpp,
-	  source/operation/polygonize/PolygonizeEdge.cpp,
-	  source/operation/polygonize/PolygonizeGraph.cpp,
-	  source/operation/polygonize/Polygonizer.cpp,
-	  source/operation/polygonize/polygonizeEdgeRing.cpp:
-	  opPolygonize.h headers split.
+	* [r1265] opPolygonize.h headers split.
 2006-03-22 11:18  Sandro Santilli <strk at keybit.net>
-	* [r1264] source/operation/buffer/BufferSubgraph.cpp,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp: Changed back
-	  'unable to find edge to compute depths' from assertion to
-	  TopologyException
+	* [r1264] Changed back 'unable to find edge to compute depths' from
+	  assertion to TopologyException
 2006-03-22 10:13  Sandro Santilli <strk at keybit.net>
-	* [r1263] capi/geos_c.cpp, configure.in,
-	  source/headers/geos/opLinemerge.h,
-	  source/headers/geos/operation/linemerge,
-	  source/headers/geos/operation/linemerge/.cvsignore,
-	  source/headers/geos/operation/linemerge/EdgeString.h,
-	  source/headers/geos/operation/linemerge/LineMergeDirectedEdge.h,
-	  source/headers/geos/operation/linemerge/LineMergeEdge.h,
-	  source/headers/geos/operation/linemerge/LineMergeGraph.h,
-	  source/headers/geos/operation/linemerge/LineMerger.h,
-	  source/headers/geos/operation/linemerge/LineSequencer.h,
-	  source/headers/geos/operation/linemerge/Makefile.am,
-	  source/operation/linemerge/EdgeString.cpp,
-	  source/operation/linemerge/LineMergeDirectedEdge.cpp,
-	  source/operation/linemerge/LineMergeEdge.cpp,
-	  source/operation/linemerge/LineMergeGraph.cpp,
-	  source/operation/linemerge/LineMerger.cpp,
-	  source/operation/linemerge/LineSequencer.cpp: opLinemerge.h split
+	* [r1263] opLinemerge.h split
 2006-03-21 21:42  Sandro Santilli <strk at keybit.net>
-	* [r1262] configure.in, source/headers/geos/Makefile.am,
-	  source/headers/geos/planargraph,
-	  source/headers/geos/planargraph.h,
-	  source/headers/geos/planargraph/.cvsignore,
-	  source/headers/geos/planargraph/DirectedEdge.h,
-	  source/headers/geos/planargraph/DirectedEdgeStar.h,
-	  source/headers/geos/planargraph/Edge.h,
-	  source/headers/geos/planargraph/GraphComponent.h,
-	  source/headers/geos/planargraph/Makefile.am,
-	  source/headers/geos/planargraph/Node.h,
-	  source/headers/geos/planargraph/NodeMap.h,
-	  source/headers/geos/planargraph/PlanarGraph.h,
-	  source/headers/geos/planargraph/Subgraph.h,
-	  source/headers/geos/planargraph/algorithm,
-	  source/headers/geos/planargraph/algorithm/.cvsignore,
-	  source/headers/geos/planargraph/algorithm/ConnectedSubgraphFinder.h,
-	  source/headers/geos/planargraph/algorithm/Makefile.am,
-	  source/operation/GeometryGraphOperation.cpp,
-	  source/operation/IsSimpleOp.cpp,
-	  source/operation/linemerge/LineSequencer.cpp,
-	  source/operation/polygonize/polygonizeEdgeRing.cpp,
-	  source/planargraph/DirectedEdge.cpp,
-	  source/planargraph/DirectedEdgeStar.cpp,
-	  source/planargraph/Edge.cpp, source/planargraph/Makefile.am,
-	  source/planargraph/Node.cpp, source/planargraph/NodeMap.cpp,
-	  source/planargraph/PlanarGraph.cpp,
-	  source/planargraph/Subgraph.cpp,
-	  source/planargraph/algorithm/ConnectedSubgraphFinder.cpp,
-	  source/planargraph/planarDirectedEdge.cpp,
-	  source/planargraph/planarDirectedEdgeStar.cpp,
-	  source/planargraph/planarEdge.cpp,
-	  source/planargraph/planarGraphComponent.cpp,
-	  source/planargraph/planarNode.cpp,
-	  source/planargraph/planarNodeMap.cpp,
-	  source/planargraph/planarPlanarGraph.cpp,
-	  source/planargraph/planarSubgraph.cpp: planargraph.h header
-	  split, planargraph:: classes renamed to match JTS symbols
+	* [r1262] planargraph.h header split, planargraph:: classes renamed
+	  to match JTS symbols
 2006-03-21 17:55  Sandro Santilli <strk at keybit.net>
-	* [r1261] configure.in, source/geom/Geometry.cpp,
-	  source/headers/geos/opDistance.h,
-	  source/headers/geos/opOverlay.h, source/headers/geos/opRelate.h,
-	  source/headers/geos/opValid.h, source/headers/geos/operation.h,
-	  source/headers/geos/operation/distance,
-	  source/headers/geos/operation/distance/.cvsignore,
-	  source/headers/geos/operation/distance/ConnectedElementLocationFilter.h,
-	  source/headers/geos/operation/distance/ConnectedElementPointFilter.h,
-	  source/headers/geos/operation/distance/DistanceOp.h,
-	  source/headers/geos/operation/distance/GeometryLocation.h,
-	  source/headers/geos/operation/distance/Makefile.am,
-	  source/operation/distance/ConnectedElementLocationFilter.cpp,
-	  source/operation/distance/ConnectedElementPointFilter.cpp,
-	  source/operation/distance/DistanceOp.cpp,
-	  source/operation/distance/GeometryLocation.cpp: opDistance.h
-	  header split
+	* [r1261] opDistance.h header split
 2006-03-21 17:11  Sandro Santilli <strk at keybit.net>
-	* [r1260] configure.in, source/geom/Geometry.cpp,
-	  source/headers/geos/opPredicate.h,
-	  source/headers/geos/operation/predicate,
-	  source/headers/geos/operation/predicate/.cvsignore,
-	  source/headers/geos/operation/predicate/Makefile.am,
-	  source/headers/geos/operation/predicate/RectangleContains.h,
-	  source/headers/geos/operation/predicate/RectangleIntersects.h,
-	  source/headers/geos/operation/predicate/SegmentIntersectionTester.h,
-	  source/operation/predicate/RectangleContains.cpp,
-	  source/operation/predicate/RectangleIntersects.cpp,
-	  source/operation/predicate/SegmentIntersectionTester.cpp:
-	  opPredicate.h header split
+	* [r1260] opPredicate.h header split
 2006-03-21 13:11  Sandro Santilli <strk at keybit.net>
-	* [r1259] configure.in, source/geom/Geometry.cpp,
-	  source/headers/geos/opRelate.h,
-	  source/headers/geos/operation/relate,
-	  source/headers/geos/operation/relate/.cvsignore,
-	  source/headers/geos/operation/relate/EdgeEndBuilder.h,
-	  source/headers/geos/operation/relate/EdgeEndBundle.h,
-	  source/headers/geos/operation/relate/EdgeEndBundleStar.h,
-	  source/headers/geos/operation/relate/Makefile.am,
-	  source/headers/geos/operation/relate/RelateComputer.h,
-	  source/headers/geos/operation/relate/RelateNode.h,
-	  source/headers/geos/operation/relate/RelateNodeFactory.h,
-	  source/headers/geos/operation/relate/RelateNodeGraph.h,
-	  source/headers/geos/operation/relate/RelateOp.h,
-	  source/operation/relate/EdgeEndBuilder.cpp,
-	  source/operation/relate/EdgeEndBundle.cpp,
-	  source/operation/relate/EdgeEndBundleStar.cpp,
-	  source/operation/relate/RelateComputer.cpp,
-	  source/operation/relate/RelateNode.cpp,
-	  source/operation/relate/RelateNodeFactory.cpp,
-	  source/operation/relate/RelateNodeGraph.cpp,
-	  source/operation/relate/RelateOp.cpp,
-	  source/operation/valid/ConsistentAreaTester.cpp: opRelate.h
-	  header split
+	* [r1259] opRelate.h header split
 2006-03-21 11:20  Sandro Santilli <strk at keybit.net>
-	* [r1258] tests/xmltester/TestInteriorPoint.xml: Changed expected
-	  result to the obtained one :)
+	* [r1258] Changed expected result to the obtained one :)
 	  We're not cheating, it's a 2-vertex linestring for
 	  which an InteriorPoint is requested, both vertexes
 	  are correct answer (equidistant from centroid).
 2006-03-21 11:12  Sandro Santilli <strk at keybit.net>
-	* [r1257] source/algorithm/CGAlgorithms.cpp,
-	  source/algorithm/CentroidArea.cpp,
-	  source/algorithm/CentroidLine.cpp,
-	  source/algorithm/HCoordinate.cpp,
-	  source/algorithm/InteriorPointLine.cpp,
-	  source/algorithm/InteriorPointPoint.cpp,
-	  source/algorithm/LineIntersector.cpp,
-	  source/algorithm/MCPointInRing.cpp,
-	  source/algorithm/MinimumDiameter.cpp,
-	  source/algorithm/NonRobustLineIntersector.cpp,
-	  source/algorithm/RobustDeterminant.cpp,
-	  source/algorithm/RobustLineIntersector.cpp,
-	  source/algorithm/SIRtreePointInRing.cpp,
-	  source/algorithm/SimplePointInAreaLocator.cpp,
-	  source/algorithm/SimplePointInRing.cpp,
-	  source/headers/geos/algorithm/SIRtreePointInRing.h: Cleanups:
-	  headers inclusion and Log section
+	* [r1257] Cleanups: headers inclusion and Log section
 2006-03-21 10:47  Sandro Santilli <strk at keybit.net>
-	* [r1256] configure.in, source/headers/geos/index/Makefile.am,
-	  source/headers/geos/index/strtree,
-	  source/headers/geos/index/strtree/.cvsignore,
-	  source/headers/geos/index/strtree/AbstractNode.h,
-	  source/headers/geos/index/strtree/AbstractSTRtree.h,
-	  source/headers/geos/index/strtree/Boundable.h,
-	  source/headers/geos/index/strtree/Interval.h,
-	  source/headers/geos/index/strtree/ItemBoundable.h,
-	  source/headers/geos/index/strtree/Makefile.am,
-	  source/headers/geos/index/strtree/SIRtree.h,
-	  source/headers/geos/index/strtree/STRtree.h,
-	  source/headers/geos/indexStrtree.h,
-	  source/index/strtree/AbstractNode.cpp,
-	  source/index/strtree/AbstractSTRtree.cpp,
-	  source/index/strtree/Interval.cpp,
-	  source/index/strtree/ItemBoundable.cpp,
-	  source/index/strtree/SIRtree.cpp,
-	  source/index/strtree/STRtree.cpp: indexStrtree.h split
+	* [r1256] indexStrtree.h split
 2006-03-21 10:46  Sandro Santilli <strk at keybit.net>
-	* [r1255] source/algorithm/RobustDeterminant.cpp: streamlined
-	  header inclusion, put original copyright on top
+	* [r1255] streamlined header inclusion, put original copyright on
+	  top
 2006-03-21 10:01  Sandro Santilli <strk at keybit.net>
-	* [r1254] configure.in, source/headers/geos/index/Makefile.am,
-	  source/headers/geos/index/sweepline,
-	  source/headers/geos/index/sweepline/.cvsignore,
-	  source/headers/geos/index/sweepline/Makefile.am,
-	  source/headers/geos/index/sweepline/SweepLineEvent.h,
-	  source/headers/geos/index/sweepline/SweepLineIndex.h,
-	  source/headers/geos/index/sweepline/SweepLineInterval.h,
-	  source/headers/geos/index/sweepline/SweepLineOverlapAction.h,
-	  source/headers/geos/indexSweepline.h,
-	  source/index/sweepline/Makefile.am,
-	  source/index/sweepline/SweepLineEvent.cpp,
-	  source/index/sweepline/SweepLineIndex.cpp,
-	  source/index/sweepline/SweepLineInterval.cpp,
-	  source/index/sweepline/indexSweepLineEvent.cpp,
-	  source/operation/valid/SweeplineNestedRingTester.cpp:
-	  indexSweepline.h header split
+	* [r1254] indexSweepline.h header split
 2006-03-20 18:18  Sandro Santilli <strk at keybit.net>
-	* [r1253] capi/geos_c.cpp, configure.in,
-	  source/headers/geos/Makefile.am, source/headers/geos/io,
-	  source/headers/geos/io.h, source/headers/geos/io/.cvsignore,
-	  source/headers/geos/io/ByteOrderDataInStream.h,
-	  source/headers/geos/io/ByteOrderValues.h,
-	  source/headers/geos/io/StringTokenizer.h,
-	  source/headers/geos/io/WKBConstants.h,
-	  source/headers/geos/io/WKBReader.h,
-	  source/headers/geos/io/Writer.h, source/io/ByteOrderValues.cpp,
-	  source/io/ParseException.cpp, source/io/StringTokenizer.cpp,
-	  source/io/WKBReader.cpp, source/io/WKBWriter.cpp,
-	  source/io/WKTReader.cpp, source/io/WKTWriter.cpp,
-	  source/io/Writer.cpp, source/operation/buffer/BufferSubgraph.cpp:
-	  io.h header split
+	* [r1253] io.h header split
 2006-03-20 17:40  Sandro Santilli <strk at keybit.net>
-	* [r1252] source/index/quadtree/DoubleBits.cpp: <cmath> included
-	  when appropriate
+	* [r1252] <cmath> included when appropriate
 2006-03-20 17:27  Sandro Santilli <strk at keybit.net>
-	* [r1251] source/headers/geos/geom/CoordinateSequence.h,
-	  source/headers/geos/geom/GeometryFactory.h: Bug #72 - Missing
-	  <vector> header
+	* [r1251] Bug #72 - Missing <vector> header
 2006-03-20 17:17  Sandro Santilli <strk at keybit.net>
-	* [r1250] source/headers/geos/geomgraph/index/Makefile.am,
-	  source/headers/geos/noding/snapround/Makefile.am,
-	  source/headers/geos/operation/buffer/Makefile.am,
-	  source/headers/geos/operation/valid/Makefile.am: Fixed geosdir
+	* [r1250] Fixed geosdir
 2006-03-20 16:57  Sandro Santilli <strk at keybit.net>
-	* [r1249] configure.in, source/geom/Geometry.cpp,
-	  source/headers/geos/Makefile.am, source/headers/geos/index,
-	  source/headers/geos/index/.cvsignore,
-	  source/headers/geos/index/ItemVisitor.h,
-	  source/headers/geos/index/SpatialIndex.h,
-	  source/headers/geos/operation/valid,
-	  source/headers/geos/operation/valid/.cvsignore,
-	  source/headers/geos/operation/valid/Makefile.am,
-	  source/headers/geos/operation/valid/RepeatedPointTester.h,
-	  source/headers/geos/operation/valid/SimpleNestedRingTester.h,
-	  source/headers/geos/operation/valid/SweeplineNestedRingTester.h,
-	  source/headers/geos/operation/valid/TopologyValidationError.h,
-	  source/headers/geos/spatialIndex.h,
-	  source/index/strtree/STRtree.cpp, source/io/Unload.cpp,
-	  source/operation/overlay/LineBuilder.cpp,
-	  source/operation/overlay/PolygonBuilder.cpp,
-	  source/operation/valid/ConsistentAreaTester.cpp,
-	  source/operation/valid/IsValidOp.cpp,
-	  source/operation/valid/QuadtreeNestedRingTester.cpp,
-	  source/operation/valid/RepeatedPointTester.cpp,
-	  source/operation/valid/SimpleNestedRingTester.cpp,
-	  source/operation/valid/TopologyValidationError.cpp:
-	  spatialindex.h and opValid.h headers split
+	* [r1249] spatialindex.h and opValid.h headers split
 2006-03-20 16:08  Sandro Santilli <strk at keybit.net>
-	* [r1248] macros/ac_python_devel.m4: redirected find stderr to
-	  /dev/null
+	* [r1248] redirected find stderr to /dev/null
 2006-03-20 13:20  Sandro Santilli <strk at keybit.net>
-	* [r1247] source/operation/overlay/PolygonBuilder.cpp: Changed
-	  assertion to TopologyException for the "orphaned" hole case
+	* [r1247] Changed assertion to TopologyException for the "orphaned"
+	  hole case
 	  in order to allow for reduced precision ops to catch the case.
 2006-03-20 12:33  Sandro Santilli <strk at keybit.net>
-	* [r1246] source/headers/geos/operation/overlay/PolygonBuilder.h,
-	  source/operation/overlay/PolygonBuilder.cpp: Simplified some
-	  privat methods to use refs instead of pointers, added
+	* [r1246] Simplified some privat methods to use refs instead of
+	  pointers, added
 	  debugging section for failiures of holes/shells associations
 2006-03-20 12:32  Sandro Santilli <strk at keybit.net>
-	* [r1245] source/headers/geos/geomgraph/EdgeRing.h: Added note
-	  about responsibility of return from ::toPolygon
+	* [r1245] Added note about responsibility of return from
+	  ::toPolygon
 2006-03-20 12:03  Sandro Santilli <strk at keybit.net>
-	* [r1244] source/geom/Geometry.cpp,
-	  source/headers/geos/geom/Geometry.h: Added operator<< for
-	  Geometry, writing HEXWKB
+	* [r1244] Added operator<< for Geometry, writing HEXWKB
 2006-03-20 11:42  Sandro Santilli <strk at keybit.net>
-	* [r1243] source/noding/Octant.cpp,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp: Added missing
-	  <cmath> include
+	* [r1243] Added missing <cmath> include
 2006-03-20 10:42  Sandro Santilli <strk at keybit.net>
-	* [r1242] source/operation/predicate/RectangleContains.cpp,
-	  source/operation/predicate/RectangleIntersects.cpp: Bug #61 -
-	  Disambiguated geom::Polygon use
+	* [r1242] Bug #61 - Disambiguated geom::Polygon use
 2006-03-20 10:14  Sandro Santilli <strk at keybit.net>
-	* [r1241] source/headers/geos/timeval.h: Bug #69 - Check for macro
-	  WIN32_LEAN_AND_MEAN
+	* [r1241] Bug #69 - Check for macro WIN32_LEAN_AND_MEAN
 2006-03-20 10:13  Sandro Santilli <strk at keybit.net>
-	* [r1240] source/operation/buffer/SubgraphDepthLocater.cpp: Bug #71
-	  - Missing <algorithm>
+	* [r1240] Bug #71 - Missing <algorithm>
 2006-03-20 10:12  Sandro Santilli <strk at keybit.net>
-	* [r1239] source/headers/geos/geom/Coordinate.h: Bug #70 - Small
-	  fix in fwd decl. of CoordinateLessThen
+	* [r1239] Bug #70 - Small fix in fwd decl. of CoordinateLessThen
 2006-03-20 10:11  Sandro Santilli <strk at keybit.net>
-	* [r1238] source/geom/GeometryFactory.cpp: Bug #67 - Debugging
-	  helpers in GeometryFactory class
+	* [r1238] Bug #67 - Debugging helpers in GeometryFactory class
 2006-03-17 16:48  Sandro Santilli <strk at keybit.net>
-	* [r1237] source/headers/geos/opRelate.h,
-	  source/headers/geos/opValid.h, source/io/Unload.cpp,
-	  source/operation/valid/SimpleNestedRingTester.cpp:
-	  LineIntersector and PointLocator made complete components of
-	  RelateComputer
+	* [r1237] LineIntersector and PointLocator made complete components
+	  of RelateComputer
 	  (were statics const pointers before). Reduced inclusions from
 	  opRelate.h
 	  and opValid.h, updated .cpp files to allow build.
 2006-03-17 14:56  Sandro Santilli <strk at keybit.net>
-	* [r1236] tests/xmltester/XMLTester.cpp: Fixed filename normalizer
-	  for sql output
+	* [r1236] Fixed filename normalizer for sql output
 2006-03-17 13:24  Sandro Santilli <strk at keybit.net>
-	* [r1235] configure.in, source/geom/Geometry.cpp,
-	  source/headers/geos/operation/overlay,
-	  source/headers/geos/operation/overlay/.cvsignore,
-	  source/headers/geos/operation/overlay/EdgeSetNoder.h,
-	  source/headers/geos/operation/overlay/ElevationMatrix.h,
-	  source/headers/geos/operation/overlay/ElevationMatrixCell.h,
-	  source/headers/geos/operation/overlay/LineBuilder.h,
-	  source/headers/geos/operation/overlay/OverlayNodeFactory.h,
-	  source/headers/geos/operation/overlay/OverlayOp.h,
-	  source/headers/geos/operation/overlay/PointBuilder.h,
-	  source/headers/geos/operation/overlay/PolygonBuilder.h,
-	  source/operation/buffer/BufferSubgraph.cpp,
-	  source/operation/buffer/SubgraphDepthLocater.cpp,
-	  source/operation/overlay/EdgeSetNoder.cpp,
-	  source/operation/overlay/ElevationMatrixCell.cpp,
-	  source/operation/overlay/ElevationMatrixFilter.cpp,
-	  source/operation/overlay/Makefile.am,
-	  source/operation/overlay/OverlayNodeFactory.cpp,
-	  source/operation/overlay/PointBuilder.cpp,
-	  source/operation/overlay/PolygonBuilder.cpp: opOverlay.h header
-	  splitted. Reduced header inclusions in operation/overlay
-	  implementation files. ElevationMatrixFilter code moved from own
-	  file to ElevationMatrix.cpp (ideally a class-private).
+	* [r1235] opOverlay.h header splitted. Reduced header inclusions in
+	  operation/overlay implementation files. ElevationMatrixFilter
+	  code moved from own file to ElevationMatrix.cpp (ideally a
+	  class-private).
 2006-03-16 13:30  Sandro Santilli <strk at keybit.net>
-	* [r1234] tests/xmltester/linemerge.xml: Added missing testfile
+	* [r1234] Added missing testfile
 2006-03-16 13:29  Sandro Santilli <strk at keybit.net>
-	* [r1233] tests/unit/Makefile.am, tests/unit/geom/LineSegment.cpp:
-	  new unit test for LineSegment (adding tests would be helpful)
+	* [r1233] new unit test for LineSegment (adding tests would be
+	  helpful)
 2006-03-16 13:28  Sandro Santilli <strk at keybit.net>
-	* [r1232] source/geom/LineSegment.cpp,
-	  source/headers/geos/geom/LineSegment.inl: obsoleted
-	  getCoordinate(), replaced by operator[]
+	* [r1232] obsoleted getCoordinate(), replaced by operator[]
 2006-03-16 13:27  Sandro Santilli <strk at keybit.net>
-	* [r1231] README: Added notes about testing
+	* [r1231] Added notes about testing
 2006-03-16 10:47  Sandro Santilli <strk at keybit.net>
-	* [r1230] tests/tut/tut.h, tests/tut/tut_reporter.h,
-	  tests/tut/tut_restartable.h, tests/unit/geom/Envelope.cpp,
-	  tests/unit/geom/Geometry/isRectangle.cpp,
-	  tests/unit/geos_unit.cpp: Bug #65 - Command line changes and EOL
-	  fixes Unit Test
+	* [r1230] Bug #65 - Command line changes and EOL fixes Unit Test
 2006-03-16 10:42  Sandro Santilli <strk at keybit.net>
-	* [r1229] source/geom/Geometry.cpp: Bug #64 - Not all control paths
-	  return a value in geos::geom::Geometry::getClassSortIndex
+	* [r1229] Bug #64 - Not all control paths return a value in
+	  geos::geom::Geometry::getClassSortIndex
 2006-03-16 10:38  Sandro Santilli <strk at keybit.net>
-	* [r1228] source/algorithm/LineIntersector.cpp: Bug #63 - Remove
-	  unreferenced local variable warning
+	* [r1228] Bug #63 - Remove unreferenced local variable warning
 2006-03-16 09:37  Sandro Santilli <strk at keybit.net>
-	* [r1227] tests/tut, tests/tut/tut.h, tests/tut/tut_reporter.h,
-	  tests/tut/tut_restartable.h, tests/unit/Makefile.am,
-	  tests/unit/envelope_class_test.cpp, tests/unit/geom,
-	  tests/unit/geom/Envelope.cpp, tests/unit/geom/Geometry,
-	  tests/unit/geos_unit.cpp: Initial unit tests
+	* [r1227] Initial unit tests
 2006-03-15 18:59  Sandro Santilli <strk at keybit.net>
-	* [r1226] source/headers/geos/operation/IsSimpleOp.h: Bug #62:
-	  'struct' CoordinateLessThen in forward declaration
+	* [r1226] Bug #62: 'struct' CoordinateLessThen in forward
+	  declaration
 2006-03-15 18:57  Sandro Santilli <strk at keybit.net>
-	* [r1225] source/operation/buffer/SubgraphDepthLocater.cpp: small
-	  cleanup
+	* [r1225] small cleanup
-	* [r1224] source/operation/buffer/BufferBuilder.cpp: cleanups in
-	  DEBUG lines
+	* [r1224] cleanups in DEBUG lines
 2006-03-15 18:56  Sandro Santilli <strk at keybit.net>
-	* [r1223] source/operation/buffer/BufferOp.cpp: Temporary hack to
-	  avoid snapround:: Noders (still using ScaledNoder wrapper)
+	* [r1223] Temporary hack to avoid snapround:: Noders (still using
+	  ScaledNoder wrapper)
 	  to allow for buffer_snapround.xml test to succeed
 2006-03-15 18:55  Sandro Santilli <strk at keybit.net>
-	* [r1222] tests/xmltester/buffer_snapround.xml: Added xml testfile
-	  showing bug in snapround:: noders
+	* [r1222] Added xml testfile showing bug in snapround:: noders
 2006-03-15 18:44  Sandro Santilli <strk at keybit.net>
-	* [r1221] doc/example.cpp, source/geom/Envelope.cpp,
-	  source/geom/LineSegment.cpp, source/geom/PrecisionModel.cpp,
-	  source/headers/geos/geom/Coordinate.inl,
-	  source/util/GeometricShapeFactory.cpp: Bug #60 - Missing <cmath>
-	  header in some files
+	* [r1221] Bug #60 - Missing <cmath> header in some files
 2006-03-15 17:33  Sandro Santilli <strk at keybit.net>
-	* [r1220] source/operation/buffer/BufferSubgraph.cpp: Changed
-	  operator<< to use operator<< for Nodes
+	* [r1220] Changed operator<< to use operator<< for Nodes
 2006-03-15 17:17  Sandro Santilli <strk at keybit.net>
-	* [r1219] source/headers/geos/geomgraph/DirectedEdgeStar.h,
-	  source/headers/geos/geomgraph/index/SweepLineEvent.h: Added
-	  missing forward declarations
+	* [r1219] Added missing forward declarations
 2006-03-15 17:16  Sandro Santilli <strk at keybit.net>
-	* [r1218] source/geomgraph/Depth.cpp,
-	  source/geomgraph/DirectedEdgeStar.cpp, source/geomgraph/Edge.cpp,
-	  source/geomgraph/EdgeEnd.cpp, source/geomgraph/EdgeEndStar.cpp,
-	  source/geomgraph/EdgeIntersection.cpp,
-	  source/geomgraph/EdgeNodingValidator.cpp,
-	  source/geomgraph/EdgeRing.cpp,
-	  source/geomgraph/GeometryGraph.cpp,
-	  source/geomgraph/GraphComponent.cpp,
-	  source/geomgraph/NodeFactory.cpp,
-	  source/geomgraph/PlanarGraph.cpp, source/geomgraph/Position.cpp,
-	  source/geomgraph/Quadrant.cpp,
-	  source/geomgraph/index/MonotoneChainEdge.cpp,
-	  source/geomgraph/index/MonotoneChainIndexer.cpp,
-	  source/geomgraph/index/SimpleEdgeSetIntersector.cpp,
-	  source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
-	  source/geomgraph/index/SimpleSweepLineIntersector.cpp,
-	  source/geomgraph/index/SweepLineEvent.cpp,
-	  source/geomgraph/index/SweepLineSegment.cpp: streamlined headers
-	  inclusion
+	* [r1218] streamlined headers inclusion
 2006-03-15 16:27  Sandro Santilli <strk at keybit.net>
-	* [r1217] source/geomgraph/Node.cpp,
-	  source/headers/geos/geomgraph/Node.h: operator<< for Node class
+	* [r1217] operator<< for Node class
 2006-03-15 15:50  Sandro Santilli <strk at keybit.net>
-	* [r1216]
-	  source/headers/geos/operation/buffer/SubgraphDepthLocater.h,
-	  source/operation/buffer/SubgraphDepthLocater.cpp: const
-	  correctness, cleanups
+	* [r1216] const correctness, cleanups
 2006-03-15 15:27  Sandro Santilli <strk at keybit.net>
-	* [r1215] source/headers/geos/geomgraph/DirectedEdge.h,
-	  source/headers/geos/geomgraph/EdgeEnd.h: cleanups
+	* [r1215] cleanups
 2006-03-15 15:26  Sandro Santilli <strk at keybit.net>
-	* [r1214] source/geomgraph/DirectedEdge.cpp,
-	  source/geomgraph/EdgeRing.cpp: Cleanups
+	* [r1214] Cleanups
 2006-03-15 13:03  Sandro Santilli <strk at keybit.net>
-	* [r1213] source/operation/buffer/BufferBuilder.cpp: removed
-	  leftover debugging line
+	* [r1213] removed leftover debugging line
 2006-03-15 12:54  Sandro Santilli <strk at keybit.net>
-	* [r1212] source/headers/geos/opBuffer.h: Removed DepthSegment.h
-	  include
+	* [r1212] Removed DepthSegment.h include
-	* [r1211] source/headers/geos/operation/buffer/DepthSegment.h,
-	  source/headers/geos/operation/buffer/Makefile.am: Removed public
-	  DepthSegment definition (moved inside SubgraphDepthLocater
-	  implementation)
+	* [r1211] Removed public DepthSegment definition (moved inside
+	  SubgraphDepthLocater implementation)
 2006-03-15 12:52  Sandro Santilli <strk at keybit.net>
-	* [r1210] source/operation/buffer/DepthSegment.cpp,
-	  source/operation/buffer/Makefile.am,
-	  source/operation/buffer/SubgraphDepthLocater.cpp: DepthSegment
-	  class moved inside SubgraphDepthLocator implementaion
+	* [r1210] DepthSegment class moved inside SubgraphDepthLocator
+	  implementaion
 	  as it was private to this file in JTS. Also, changed to reduce
 	  copies of LineSegment copies.
 2006-03-15 11:45  Sandro Santilli <strk at keybit.net>
-	* [r1209] source/headers/geos/operation/buffer/BufferSubgraph.h:
-	  doxygen comments
+	* [r1209] doxygen comments
 2006-03-15 11:44  Sandro Santilli <strk at keybit.net>
-	* [r1208] source/operation/overlay/PolygonBuilder.cpp: debug
-	  blocks, dumping SQL when GEOS_DEBUG > 1
+	* [r1208] debug blocks, dumping SQL when GEOS_DEBUG > 1
 2006-03-15 11:42  Sandro Santilli <strk at keybit.net>
-	* [r1207] source/operation/buffer/BufferBuilder.cpp: more debugging
-	  lines, with two levels of debugging handled
+	* [r1207] more debugging lines, with two levels of debugging
+	  handled
 2006-03-15 11:39  Sandro Santilli <strk at keybit.net>
-	* [r1206] source/operation/buffer/BufferSubgraph.cpp: comments
-	  cleanup, changed computeDepths to use a list<> rather then a
-	  vector (performance related)
+	* [r1206] comments cleanup, changed computeDepths to use a list<>
+	  rather then a vector (performance related)
 2006-03-15 10:40  Sandro Santilli <strk at keybit.net>
-	* [r1205] doc/Doxyfile.in: Fixed to allow doxygen runs from
-	  external builddir
+	* [r1205] Fixed to allow doxygen runs from external builddir
 2006-03-15 09:51  Sandro Santilli <strk at keybit.net>
-	* [r1204] source/headers/geos/noding/SegmentString.inl,
-	  source/headers/geos/noding/SimpleNoder.h: streamlined header
-	  usage
+	* [r1204] streamlined header usage
-	* [r1203] source/noding/IntersectionAdder.cpp,
-	  source/noding/IntersectionFinderAdder.cpp,
-	  source/noding/IteratedNoder.cpp, source/noding/MCIndexNoder.cpp,
-	  source/noding/NodingValidator.cpp, source/noding/Octant.cpp,
-	  source/noding/ScaledNoder.cpp, source/noding/SegmentNode.cpp,
-	  source/noding/SegmentNodeList.cpp,
-	  source/noding/SegmentString.cpp, source/noding/SimpleNoder.cpp,
-	  source/noding/snapround/SimpleSnapRounder.cpp: streamlined
-	  headers usage
+	* [r1203] streamlined headers usage
 2006-03-15 09:13  Sandro Santilli <strk at keybit.net>
-	* [r1202] source/geom/Polygon.cpp: updated port info
+	* [r1202] updated port info
 2006-03-15 09:12  Sandro Santilli <strk at keybit.net>
-	* [r1201] source/headers/geos/geom/Polygon.h: isSimple doc
+	* [r1201] isSimple doc
 2006-03-14 17:46  Sandro Santilli <strk at keybit.net>
-	* [r1200] source/headers/geos/util/Assert.h: Removed unrequired
-	  include
+	* [r1200] Removed unrequired include
 2006-03-14 17:10  Sandro Santilli <strk at keybit.net>
-	* [r1199] source/operation/buffer/BufferSubgraph.cpp: cleanups
+	* [r1199] cleanups
 2006-03-14 17:08  Sandro Santilli <strk at keybit.net>
-	* [r1198] source/headers/geos/opOverlay.h,
-	  source/operation/overlay/MaximalEdgeRing.cpp: comments cleanup,
-	  integrity checks
+	* [r1198] comments cleanup, integrity checks
 2006-03-14 16:55  Sandro Santilli <strk at keybit.net>
-	* [r1197] source/operation/overlay/PolygonBuilder.cpp: oops,
-	  GEOS_DEBUG default to 0
+	* [r1197] oops, GEOS_DEBUG default to 0
-	* [r1196] source/headers/geos/opOverlay.h,
-	  source/operation/overlay/PolygonBuilder.cpp: comments cleanup
+	* [r1196] comments cleanup
 2006-03-14 16:53  Sandro Santilli <strk at keybit.net>
-	* [r1195] source/geomgraph/Edge.cpp: removed endline from printing
-	  funx
+	* [r1195] removed endline from printing funx
 2006-03-14 16:08  Sandro Santilli <strk at keybit.net>
-	* [r1194] source/headers/geos/operation/buffer/BufferBuilder.h,
-	  source/operation/buffer/BufferBuilder.cpp: changed buildSubgraphs
-	  signature to use refs rather then pointers, made it
-	  const-correct. Reduced heap allocations in createSubgraphs()
+	* [r1194] changed buildSubgraphs signature to use refs rather then
+	  pointers, made it const-correct. Reduced heap allocations in
+	  createSubgraphs()
 2006-03-14 15:46  Sandro Santilli <strk at keybit.net>
-	* [r1193] source/geomgraph/PlanarGraph.cpp,
-	  source/headers/geos/geomgraph/PlanarGraph.h: Added
-	  PlanarGraph::getNodes(vector&) func, to reduce useless heap
-	  allocations
+	* [r1193] Added PlanarGraph::getNodes(vector&) func, to reduce
+	  useless heap allocations
 2006-03-14 15:32  Sandro Santilli <strk at keybit.net>
-	* [r1192] source/geom/Coordinate.cpp,
-	  source/geom/CoordinateArraySequence.cpp,
-	  source/geomgraph/DirectedEdge.cpp, source/geomgraph/Edge.cpp,
-	  source/geomgraph/Node.cpp: Cleaned up toString funx (more WKT
-	  friendly)
+	* [r1192] Cleaned up toString funx (more WKT friendly)
 2006-03-14 14:16  Sandro Santilli <strk at keybit.net>
-	* [r1191] source/headers/geos/operation/buffer/BufferSubgraph.h,
-	  source/operation/overlay/PolygonBuilder.cpp: operator<< for
-	  BufferSubgraph, more debugging calls
+	* [r1191] operator<< for BufferSubgraph, more debugging calls
 2006-03-14 12:55  Sandro Santilli <strk at keybit.net>
-	* [r1190] configure.in, source/geom/Geometry.cpp,
-	  source/geomgraph/Label.cpp, source/geomgraph/Node.cpp,
-	  source/geomgraph/NodeMap.cpp,
-	  source/headers/geos/geomgraph/Makefile.am,
-	  source/headers/geos/geomgraph/index,
-	  source/headers/geos/geomgraph/index/.cvsignore,
-	  source/headers/geos/geomgraph/index/EdgeSetIntersector.h,
-	  source/headers/geos/geomgraph/index/Makefile.am,
-	  source/headers/geos/geomgraph/index/MonotoneChain.h,
-	  source/headers/geos/geomgraph/index/MonotoneChainEdge.h,
-	  source/headers/geos/geomgraph/index/MonotoneChainIndexer.h,
-	  source/headers/geos/geomgraph/index/SegmentIntersector.h,
-	  source/headers/geos/geomgraph/index/SimpleEdgeSetIntersector.h,
-	  source/headers/geos/geomgraph/index/SimpleMCSweepLineIntersector.h,
-	  source/headers/geos/geomgraph/index/SimpleSweepLineIntersector.h,
-	  source/headers/geos/geomgraph/index/SweepLineEvent.h,
-	  source/headers/geos/geomgraph/index/SweepLineEventObj.h,
-	  source/headers/geos/geomgraph/index/SweepLineSegment.h,
-	  source/headers/geos/geomgraphindex.h,
-	  source/headers/geos/noding/MCIndexNoder.inl,
-	  source/headers/geos/noding/Makefile.am,
-	  source/headers/geos/noding/snapround,
-	  source/headers/geos/noding/snapround/.cvsignore,
-	  source/headers/geos/noding/snapround/HotPixel.inl,
-	  source/headers/geos/noding/snapround/MCIndexSnapRounder.inl,
-	  source/headers/geos/nodingSnapround.h,
-	  source/operation/buffer/BufferOp.cpp: Headers split:
-	  geomgraphindex.h, nodingSnapround.h
+	* [r1190] Headers split: geomgraphindex.h, nodingSnapround.h
 2006-03-14 11:03  Sandro Santilli <strk at keybit.net>
-	* [r1189] source/geomgraph/Edge.cpp, source/geomgraph/EdgeList.cpp,
-	  source/headers/geos/geomgraph/EdgeList.h: Added operator<< for
-	  Edge and EdgeList
+	* [r1189] Added operator<< for Edge and EdgeList
 2006-03-14 00:37  Sandro Santilli <strk at keybit.net>
-	* [r1188] source/headers/geos/operation/buffer/Makefile.am: Fixed
-	  include filenames
+	* [r1188] Fixed include filenames
 2006-03-14 00:36  Sandro Santilli <strk at keybit.net>
-	* [r1187] source/operation/buffer/BufferOp.cpp: Reduced 'buffer'
-	  headers inclusion
+	* [r1187] Reduced 'buffer' headers inclusion
 2006-03-14 00:19  Sandro Santilli <strk at keybit.net>
-	* [r1186] source/headers/geos/opBuffer.h,
-	  source/headers/geos/operation/buffer,
-	  source/headers/geos/operation/buffer/.cvsignore,
-	  source/headers/geos/operation/buffer/BufferBuilder.h,
-	  source/headers/geos/operation/buffer/BufferOp.h,
-	  source/headers/geos/operation/buffer/BufferSubgraph.h,
-	  source/headers/geos/operation/buffer/DepthSegment.h,
-	  source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h,
-	  source/headers/geos/operation/buffer/RightmostEdgeFinder.h,
-	  source/operation/buffer/DepthSegment.cpp,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp,
-	  source/operation/buffer/RightmostEdgeFinder.cpp,
-	  source/operation/buffer/SubgraphDepthLocater.cpp: opBuffer.h
-	  split, streamlined headers in some (not all) files in
-	  operation/buffer/
+	* [r1186] opBuffer.h split, streamlined headers in some (not all)
+	  files in operation/buffer/
 2006-03-13 22:33  Sandro Santilli <strk at keybit.net>
-	* [r1185] source/headers/geos/geom/LineSegment.h: Added missing
-	  forward declarations
+	* [r1185] Added missing forward declarations
 2006-03-13 21:54  Sandro Santilli <strk at keybit.net>
-	* [r1184] source/geom/Coordinate.cpp,
-	  source/geom/CoordinateSequenceFactory.cpp,
-	  source/geom/Geometry.cpp,
-	  source/geom/Triangle.cpp: Streamlined headers inclusion.
+	* [r1184] Streamlined headers inclusion.
 2006-03-13 21:19  Sandro Santilli <strk at keybit.net>
-	* [r1183] source/headers/geos/noding/ScaledNoder.h,
-	  source/noding/ScaledNoder.cpp: Fixed bug in ScaledNoder scaling
-	  mechanism (hugly code, due to CoordinateSequence visitor pattern
-	  design). Tests are still failing so this possibly needs some
-	  other fix. Streamlined includes by implementation file.
+	* [r1183] Fixed bug in ScaledNoder scaling mechanism (hugly code,
+	  due to CoordinateSequence visitor pattern design). Tests are
+	  still failing so this possibly needs some other fix. Streamlined
+	  includes by implementation file.
 2006-03-13 21:14  Sandro Santilli <strk at keybit.net>
-	* [r1182] source/headers/geos/noding/SegmentString.h: Added missing
+	* [r1182] Added missing forward declarations
 2006-03-13 21:13  Sandro Santilli <strk at keybit.net>
-	* [r1181] source/headers/geos/geom/CoordinateFilter.h: Added
-	  comment about possible refactoring
+	* [r1181] Added comment about possible refactoring
 2006-03-11 16:58  Sandro Santilli <strk at keybit.net>
-	* [r1180] source/headers/geos/opBuffer.h,
-	  source/operation/buffer/OffsetCurveBuilder.cpp: Fixed bug in
-	  OffsetCurveBuilder::getCoordinates.
+	* [r1180] Fixed bug in OffsetCurveBuilder::getCoordinates.
 2006-03-10 15:50  Sandro Santilli <strk at keybit.net>
-	* [r1179] source/geomgraph/EdgeRing.cpp: Changed 'found null
-	  Directed Edge' from an Assertion to a TopologyException, to give
-	  'precision-reducing' overlay operation a chance to handle it (it
-	  seems to work)
+	* [r1179] Changed 'found null Directed Edge' from an Assertion to a
+	  TopologyException, to give 'precision-reducing' overlay operation
+	  a chance to handle it (it seems to work)
 2006-03-10 13:07  Sandro Santilli <strk at keybit.net>
-	* [r1178] source/geomgraph/EdgeRing.cpp: fine-tuned includes,
-	  reverted Assert=>assert due to user-input based failure
+	* [r1178] fine-tuned includes, reverted Assert=>assert due to
+	  user-input based failure
 2006-03-10 12:50  Sandro Santilli <strk at keybit.net>
-	* [r1177] configure.in, tests/unit/Makefile.am,
-	  tests/unit/envelope_class_test.cpp: boost detection code fix,
-	  first UTF source for testing purposes
+	* [r1177] boost detection code fix, first UTF source for testing
+	  purposes
 2006-03-10 12:43  Sandro Santilli <strk at keybit.net>
-	* [r1176] TODO: updated
+	* [r1176] updated
 2006-03-10 12:09  Sandro Santilli <strk at keybit.net>
-	* [r1175] configure.in: Update configure script to work with new
-	  boost.m4 file
+	* [r1175] Update configure script to work with new boost.m4 file
 2006-03-10 11:49  Sandro Santilli <strk at keybit.net>
-	* [r1174] macros/boost.m4: Updated boost detection macro
+	* [r1174] Updated boost detection macro
 2006-03-10 11:41  Sandro Santilli <strk at keybit.net>
-	* [r1173] source/index/quadtree/QuadTreeNodeBase.cpp: Added missing
-	  <algorithm> include (bug#56)
+	* [r1173] Added missing <algorithm> include (bug#56)
 2006-03-10 11:10  Sandro Santilli <strk at keybit.net>
-	* [r1172] configure.in, macros/boost.m4, tests/Makefile.am,
-	  tests/unit, tests/unit/.cvsignore, tests/unit/Makefile.am:
-	  Initial boost detection code
+	* [r1172] Initial boost detection code
 2006-03-10 11:09  Sandro Santilli <strk at keybit.net>
-	* [r1171] source/operation/valid/ConnectedInteriorTester.cpp:
-	  Comments cleanup
+	* [r1171] Comments cleanup
 2006-03-10 10:48  Sandro Santilli <strk at keybit.net>
-	* [r1170] source/Makefile.vc: Bug #58 - Patch to makefile.vc after
-	  big refactoring commit
+	* [r1170] Bug #58 - Patch to makefile.vc after big refactoring
+	  commit
 2006-03-10 10:44  Sandro Santilli <strk at keybit.net>
-	* [r1169] source/operation/buffer/BufferBuilder.cpp,
-	  source/precision/EnhancedPrecisionOp.cpp: Unreferenced exception
-	  objects cleanup (#52)
+	* [r1169] Unreferenced exception objects cleanup (#52)
 2006-03-10 10:37  Sandro Santilli <strk at keybit.net>
-	* [r1168] source/geomgraph/index/SimpleSweepLineIntersector.cpp:
-	  Added missing <algorithm> include (#55)
+	* [r1168] Added missing <algorithm> include (#55)
 2006-03-10 10:34  Sandro Santilli <strk at keybit.net>
-	* [r1167] source/geom/Polygon.cpp: Added missing <algorithm>
-	  include (#54)
+	* [r1167] Added missing <algorithm> include (#54)
 2006-03-09 18:22  Sandro Santilli <strk at keybit.net>
-	* [r1166] tests/xmltester/Makefile.am,
-	  tests/xmltester/TestIsValid.xml: Added isvalid test for latest
-	  validop patch
+	* [r1166] Added isvalid test for latest validop patch
 2006-03-09 18:18  Sandro Santilli <strk at keybit.net>
-	* [r1165] source/headers/geos/opOverlay.h,
-	  memory-friendly MaximalEdgeRing::buildMinimalRings()
-	  implementation.
+	* [r1165] Added memory-friendly
+	  MaximalEdgeRing::buildMinimalRings() implementation.
 	  Applied patch to IsValid operation from JTS-1.7.1
 2006-03-09 17:40  Sandro Santilli <strk at keybit.net>
-	* [r1164] source/headers/geos/opBuffer.h,
-	  source/operation/buffer/OffsetCurveBuilder.cpp: Fixed bug#33
-	  (hopefully)
+	* [r1164] Fixed bug#33 (hopefully)
 2006-03-09 16:46  Sandro Santilli <strk at keybit.net>
-	* [r1163] configure.in, source/algorithm/CGAlgorithms.cpp,
-	  source/algorithm/CentroidPoint.cpp,
-	  source/algorithm/InteriorPointArea.cpp,
-	  source/algorithm/NotRepresentableException.cpp,
-	  source/algorithm/PointLocator.cpp,
-	  source/geom/Coordinate.cpp,
-	  source/geom/Dimension.cpp, source/geom/Envelope.cpp,
-	  source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
-	  source/geom/LineString.cpp, source/geom/LinearRing.cpp,
-	  source/geom/Location.cpp, source/geom/MultiLineString.cpp,
-	  source/geom/MultiPoint.cpp, source/geom/MultiPolygon.cpp,
-	  source/geom/Point.cpp, source/geom/Polygon.cpp,
-	  source/geom/util/CoordinateOperation.cpp,
-	  source/geom/util/GeometryEditor.cpp,
-	  source/geom/util/Makefile.am, source/geomgraph/DirectedEdge.cpp,
-	  source/geomgraph/Edge.cpp, source/geomgraph/EdgeEnd.cpp,
-	  source/geomgraph/PlanarGraph.cpp, source/geomgraph/Quadrant.cpp,
-	  source/geomgraph/index/SweepLineSegment.cpp,
-	  source/headers/geos.h, source/headers/geos/Makefile.am,
-	  source/headers/geos/algorithm,
-	  source/headers/geos/algorithm/.cvsignore,
-	  source/headers/geos/algorithm/CGAlgorithms.h,
-	  source/headers/geos/algorithm/CentroidArea.h,
-	  source/headers/geos/algorithm/CentroidLine.h,
-	  source/headers/geos/algorithm/CentroidPoint.h,
-	  source/headers/geos/algorithm/ConvexHull.inl,
-	  source/headers/geos/algorithm/HCoordinate.h,
-	  source/headers/geos/algorithm/InteriorPointArea.h,
-	  source/headers/geos/algorithm/InteriorPointLine.h,
-	  source/headers/geos/algorithm/InteriorPointPoint.h,
-	  source/headers/geos/algorithm/LineIntersector.h,
-	  source/headers/geos/algorithm/Makefile.am,
-	  source/headers/geos/algorithm/MinimumDiameter.h,
-	  source/headers/geos/algorithm/NotRepresentableException.h,
-	  source/headers/geos/algorithm/PointInRing.h,
-	  source/headers/geos/algorithm/PointLocator.h,
-	  source/headers/geos/algorithm/RobustDeterminant.h,
-	  source/headers/geos/algorithm/SIRtreePointInRing.h,
-	  source/headers/geos/algorithm/SimplePointInAreaLocator.h,
-	  source/headers/geos/algorithm/SimplePointInRing.h,
-	  source/headers/geos/geom, source/headers/geos/geom.h,
-	  source/headers/geos/geom/.cvsignore,
-	  source/headers/geos/geom/CoordinateArraySequenceFactory.inl,
-	  source/headers/geos/geom/Envelope.h,
-	  source/headers/geos/geom/Envelope.inl,
-	  source/headers/geos/geom/GeometryCollection.h,
-	  source/headers/geos/geom/GeometryFactory.h,
-	  source/headers/geos/geom/GeometryFactory.inl,
-	  source/headers/geos/geom/LineSegment.inl,
-	  source/headers/geos/geom/LinearRing.h,
-	  source/headers/geos/geom/Makefile.am,
-	  source/headers/geos/geom/PrecisionModel.h,
-	  source/headers/geos/geom/PrecisionModel.inl,
-	  source/headers/geos/geom/util,
-	  source/headers/geos/geom/util/.cvsignore,
-	  source/headers/geos/geom/util/LinearComponentExtracter.h,
-	  source/headers/geos/geom/util/Makefile.am,
-	  source/headers/geos/geom/util/PointExtracter.h,
-	  source/headers/geos/geom/util/PolygonExtracter.h,
-	  source/headers/geos/geomUtil.h, source/headers/geos/geomgraph,
-	  source/headers/geos/geomgraph.h,
-	  source/headers/geos/geomgraph/.cvsignore,
-	  source/headers/geos/geomgraph/EdgeRing.h,
-	  source/headers/geos/geomgraph/GeometryGraph.h,
-	  source/headers/geos/geomgraph/Label.h,
-	  source/headers/geos/geosAlgorithm.h,
-	  source/headers/geos/indexStrtree.h, source/headers/geos/io.h,
-	  source/headers/geos/noding, source/headers/geos/noding.h,
-	  source/headers/geos/noding/.cvsignore,
-	  source/headers/geos/noding/SegmentString.inl,
-	  source/headers/geos/opBuffer.h, source/headers/geos/opDistance.h,
-	  source/headers/geos/opValid.h, source/headers/geos/operation,
-	  source/headers/geos/operation.h,
-	  source/headers/geos/operation/.cvsignore,
-	  source/headers/geos/operation/EndpointInfo.h,
-	  source/headers/geos/operation/GeometryGraphOperation.h,
-	  source/headers/geos/operation/IsSimpleOp.h,
-	  source/headers/geos/spatialIndex.h, source/headers/geos/util,
-	  source/headers/geos/util.h, source/headers/geos/util/.cvsignore,
-	  source/headers/geos/util/Assert.h,
-	  source/headers/geos/util/AssertionFailedException.h,
-	  source/headers/geos/util/CoordinateArrayFilter.h,
-	  source/headers/geos/util/GEOSException.h,
-	  source/headers/geos/util/GeometricShapeFactory.h,
-	  source/headers/geos/util/IllegalArgumentException.h,
-	  source/headers/geos/util/Makefile.am,
-	  source/headers/geos/util/UniqueCoordinateArrayFilter.h,
-	  source/headers/geos/util/UnsupportedOperationException.h,
-	  source/headers/geos/util/math.h, source/io/WKBReader.cpp,
-	  source/io/WKTWriter.cpp, source/noding/SegmentString.cpp,
-	  source/operation/overlay/ElevationMatrix.cpp,
-	  source/util/Assert.cpp, tests/xmltester/SimpleWKTTester.cpp,
-	  tests/xmltester/XMLTester.cpp, tests/xmltester/buffer.xml:
-	  geos::geom namespace definition, first pass at headers split
+	* [r1163] geos::geom namespace definition, first pass at headers
+	  split
 2006-03-09 16:18  Sandro Santilli <strk at keybit.net>
-	* [r1162] tests/xmltester/Makefile.am: Fixed to allow tests from
-	  external build tree (thanks Norman:)
+	* [r1162] Fixed to allow tests from external build tree (thanks
+	  Norman:)
 2006-03-09 16:01  Sandro Santilli <strk at keybit.net>
-	* [r1161] source/geomgraph/Position.cpp,
-	  source/operation/overlay/ElevationMatrixFilter.cpp: Fixed
-	  debugging lines
+	* [r1161] Fixed debugging lines
 2006-03-09 15:50  Sandro Santilli <strk at keybit.net>
-	* [r1160] source/operation/overlay/OverlayOp.cpp: Fixed debugging
-	  lines, added missing header
+	* [r1160] Fixed debugging lines, added missing header
 2006-03-09 15:47  Sandro Santilli <strk at keybit.net>
-	* [r1159] source/operation/linemerge/LineMergeGraph.cpp: Fixed
-	  debugging lines
+	* [r1159] Fixed debugging lines
 2006-03-09 15:39  Sandro Santilli <strk at keybit.net>
-	* [r1158] source/index/quadtree/QuadTreeKey.cpp,
-	  source/noding/SegmentNodeList.cpp: Fixed debugging lines
+	* [r1158] Fixed debugging lines
 2006-03-09 14:48  Sandro Santilli <strk at keybit.net>
-	* [r1157] capi/Makefile.am: Added missing INCLUDES line
+	* [r1157] Added missing INCLUDES line
 2006-03-07 14:21  Sandro Santilli <strk at keybit.net>
-	* [r1156] tests/xmltester/XMLTester.cpp: Leak plugged, tweeked
-	  output to be nice with --sql-output
+	* [r1156] Leak plugged, tweeked output to be nice with --sql-output
 2006-03-07 14:20  Sandro Santilli <strk at keybit.net>
-	* [r1155] source/headers/geos/opBuffer.h,
-	  source/operation/buffer/OffsetCurveBuilder.cpp: Big deal of heap
-	  allocations reduction
+	* [r1155] Big deal of heap allocations reduction
 2006-03-07 14:18  Sandro Santilli <strk at keybit.net>
-	* [r1154] source/util/Profiler.cpp: Profiler singleton implemented
-	  with a function-static Profiler instance
+	* [r1154] Profiler singleton implemented with a function-static
+	  Profiler instance
 2006-03-07 12:42  Sandro Santilli <strk at keybit.net>
-	* [r1153] tests/xmltester/buffer.xml: addedvalidity test for a case
-	  with invalid input
+	* [r1153] addedvalidity test for a case with invalid input
 2006-03-07 12:41  Sandro Santilli <strk at keybit.net>
-	* [r1152] tests/xmltester/XMLTester.cpp,
-	  tests/xmltester/XMLTester.h: Added --wkb-output and made
-	  --sql-output compatible with -v
+	* [r1152] Added --wkb-output and made --sql-output compatible with
+	  -v
 2006-03-07 11:22  Sandro Santilli <strk at keybit.net>
-	* [r1151] tests/xmltester/XMLTester.cpp: table name for sqlOutput
-	  normalized
+	* [r1151] table name for sqlOutput normalized
 2006-03-07 11:06  Sandro Santilli <strk at keybit.net>
-	* [r1150] tests/xmltester/XMLTester.cpp,
-	  tests/xmltester/XMLTester.h: Added --sql-output switch for
-	  debugging
+	* [r1150] Added --sql-output switch for debugging
 2006-03-07 10:46  Sandro Santilli <strk at keybit.net>
-	* [r1149] tests/xmltester/XMLTester.cpp: verbose validity errors
+	* [r1149] verbose validity errors
 2006-03-06 21:27  Sandro Santilli <strk at keybit.net>
-	* [r1148] doc/example.cpp, source/headers/geos/geom.h,
-	  source/headers/geos/opRelate.h, tests/xmltester/XMLTester.cpp:
-	  Cascading fixed after Unload definition moved to geos::io
+	* [r1148] Cascading fixed after Unload definition moved to geos::io
 	  namespace
 2006-03-06 19:43  Sandro Santilli <strk at keybit.net>
-	* [r1147] source/headers/geos/unload.h: Fixed Unload class
-	  definition namespace (geos::io)
+	* [r1147] Fixed Unload class definition namespace (geos::io)
 2006-03-06 19:40  Sandro Santilli <strk at keybit.net>
-	* [r1146] capi/geos_c.cpp, doc/example.cpp,
-	  source/geom/Dimension.cpp, source/geom/Geometry.cpp,
-	  source/geom/GeometryCollection.cpp,
-	  source/geom/Location.cpp, source/geom/Makefile.am,
-	  source/headers/geos/LineSegment.inl,
-	  source/headers/geos/Makefile.am, source/headers/geos/geom,
-	  source/headers/geos/geom.h,
-	  source/headers/geos/geosAlgorithm.h, source/headers/geos/io.h,
-	  source/headers/geos/opBuffer.h, source/headers/geos/profiler.h,
-	  source/headers/geos/util.h, source/index/bintree/BinTreeNode.cpp,
-	  source/io/WKTWriter.cpp, source/noding/IteratedNoder.cpp,
-	  source/operation/valid/ConnectedInteriorTester.cpp,
-	  source/operation/valid/SweeplineNestedRingTester.cpp,
-	  source/precision/CommonBitsRemover.cpp,
-	  source/precision/EnhancedPrecisionOp.cpp, source/util/Assert.cpp,
-	  source/util/AssertionFailedException.cpp,
-	  source/util/CoordinateArrayFiter.cpp,
-	  source/util/GEOSException.cpp,
-	  source/util/IllegalArgumentException.cpp,
-	  source/util/Profiler.cpp,
-	  source/util/UniqueCoordinateArrayFilter.cpp,
-	  source/util/UnsupportedOperationException.cpp,
-	  tests/xmltester/SimpleWKTTester.cpp,
-	  tests/xmltester/XMLTester.cpp: geos::util namespace. New
-	  GeometryCollection::iterator interface, many cleanups.
+	* [r1146] geos::util namespace. New GeometryCollection::iterator
+	  interface, many cleanups.
 2006-03-06 15:23  Sandro Santilli <strk at keybit.net>
-	* [r1145] capi/geos_c.cpp, doc/example.cpp,
-	  source/geom/Geometry.cpp, source/headers/geos/io.h,
-	  source/io/ByteOrderValues.cpp, source/io/ParseException.cpp,
-	  source/io/StringTokenizer.cpp, source/io/Unload.cpp,
-	  source/io/Writer.cpp, tests/xmltester/SimpleWKTTester.cpp,
-	  tests/xmltester/XMLTester.cpp, tests/xmltester/XMLTester.h,
-	  tests/xmltester/buffer.xml: geos::io namespace
+	* [r1145] geos::io namespace
 2006-03-06 14:30  Sandro Santilli <strk at keybit.net>
-	* [r1143] capi/geos_c.cpp: Validity error include Coordinate
+	* [r1143] Validity error include Coordinate
 2006-03-06 13:27  Sandro Santilli <strk at keybit.net>
-	* [r1142] source/geom/Polygon.cpp: Cleaned up equalsExact
+	* [r1142] Cleaned up equalsExact
 2006-03-06 13:26  Sandro Santilli <strk at keybit.net>
-	* [r1141] tests/xmltester/XMLTester.cpp: Fixed equalsExact check,
-	  and also reduced tolerance
+	* [r1141] Fixed equalsExact check, and also reduced tolerance
 2006-03-06 12:47  Sandro Santilli <strk at keybit.net>
-	* [r1140] source/headers/geos/opValid.h,
-	  source/operation/valid/IsValidOp.cpp: TopologyValidationError
-	  error names (enum) renamed to avoid conflicts.
+	* [r1140] TopologyValidationError error names (enum) renamed to
+	  avoid conflicts.
 2006-03-06 12:16  Sandro Santilli <strk at keybit.net>
-	* [r1139] tests/xmltester/robustness.xml: Added second case for
-	  Union
+	* [r1139] Added second case for Union
 2006-03-06 12:11  Sandro Santilli <strk at keybit.net>
-	* [r1138] source/operation/overlay/OverlayOp.cpp: precision.h =>
-	  geos/precision.h (#48)
+	* [r1138] precision.h => geos/precision.h (#48)
 2006-03-06 11:39  Sandro Santilli <strk at keybit.net>
-	* [r1137] tests/xmltester/robustness.xml: Added test extracted from
-	  data provided by Guillaume Sueur
+	* [r1137] Added test extracted from data provided by Guillaume
+	  Sueur
 2006-03-06 11:34  Sandro Santilli <strk at keybit.net>
-	* [r1136] source/headers/geos/geom.h: Dropped
-	  unused/unmaintained/platform-problematic serial version info for
-	  classes (#47)
+	* [r1136] Dropped unused/unmaintained/platform-problematic serial
+	  version info for classes (#47)
 2006-03-06 11:17  Sandro Santilli <strk at keybit.net>
-	* [r1135] capi/geos_c.cpp: added a compile-time option to get
-	  VERBOSE_EXCEPTION (print args on exceptions)
+	* [r1135] added a compile-time option to get VERBOSE_EXCEPTION
+	  (print args on exceptions)
-	* [r1134] source/operation/overlay/OverlayOp.cpp: precision
-	  reducing overlayOp made compile-time optional
+	* [r1134] precision reducing overlayOp made compile-time optional
 2006-03-06 11:05  Sandro Santilli <strk at keybit.net>
-	* [r1133] tests/xmltester/XMLTester.cpp,
-	  tests/xmltester/XMLTester.h: Added input and output validity test
-	  facilities
+	* [r1133] Added input and output validity test facilities
 2006-03-03 14:01  Sandro Santilli <strk at keybit.net>
-	* [r1132] source/operation/overlay/OverlayOp.cpp: Experimental
-	  precision-reducing overlayOp
+	* [r1132] Experimental precision-reducing overlayOp
 2006-03-03 13:50  Sandro Santilli <strk at keybit.net>
-	* [r1131] source/algorithm/InteriorPointLine.cpp,
-	  source/headers/geos/geom.h, source/headers/geos/geosAlgorithm.h:
-	  Cleaned up InteriorPointLine class
+	* [r1131] Cleaned up InteriorPointLine class
 2006-03-03 10:46  Sandro Santilli <strk at keybit.net>
-	* [r1130] capi/geos_c.cpp, doc/example.cpp,
-	  source/algorithm/CGAlgorithms.cpp,
-	  source/geom/Envelope.cpp, source/geom/Geometry.cpp,
-	  source/geom/GeometryFactory.cpp,
-	  source/geom/PrecisionModel.cpp,
-	  source/geom/util/GeometryEditor.cpp, source/geomgraph/Depth.cpp,
-	  source/geomgraph/EdgeList.cpp, source/geomgraph/EdgeRing.cpp,
-	  source/geomgraph/GeometryGraph.cpp, source/geomgraph/Label.cpp,
-	  source/geomgraph/Node.cpp, source/geomgraph/NodeMap.cpp,
-	  source/geomgraph/TopologyLocation.cpp,
-	  source/headers/geos/geom.h, source/headers/geos/geomUtil.h,
-	  source/headers/geos/noding.h,
-	  source/headers/geos/opRelate.h, source/headers/geos/opValid.h,
-	  source/headers/geos/profiler.h, source/headers/geos/util.h,
-	  source/index/strtree/STRtree.cpp, source/io/ByteOrderValues.cpp,
-	  source/io/Unload.cpp, source/io/WKBReader.cpp,
-	  source/io/WKTWriter.cpp, source/io/Writer.cpp,
-	  source/noding/SegmentNode.cpp, source/noding/SegmentNodeList.cpp,
-	  source/noding/snapround/HotPixel.cpp,
-	  source/noding/snapround/MCIndexSnapRounder.cpp,
-	  source/noding/snapround/SimpleSnapRounder.cpp,
-	  source/operation/buffer/OffsetCurveBuilder.cpp,
-	  source/operation/valid/TopologyValidationError.cpp,
-	  source/planargraph/planarSubgraph.cpp,
-	  source/precision/CommonBitsOp.cpp,
-	  source/precision/SimpleGeometryPrecisionReducer.cpp,
-	  source/util/Assert.cpp, source/util/GEOSException.cpp,
-	  source/util/GeometricShapeFactory.cpp, source/util/Profiler.cpp,
-	  tests/xmltester/XMLTester.cpp, tests/xmltester/XMLTester.h:
-	  Removed 'using namespace' from headers, added missing headers in
-	  .cpp files, removed useless includes in headers (bug#46)
+	* [r1130] Removed 'using namespace' from headers, added missing
+	  headers in .cpp files, removed useless includes in headers
+	  (bug#46)
 2006-03-02 18:17  Sandro Santilli <strk at keybit.net>
-	* [r1129] tests/xmltester/Makefile.am,
-	  tests/xmltester/robustness.xml: Added robustness testcases
+	* [r1129] Added robustness testcases
 2006-03-02 16:22  Sandro Santilli <strk at keybit.net>
-	* [r1128] tests/xmltester/XMLTester.cpp: Updated copyright notice
+	* [r1128] Updated copyright notice
 2006-03-02 16:21  Sandro Santilli <strk at keybit.net>
-	* [r1127] source/geomgraph/PlanarGraph.cpp,
-	  source/headers/geos/geomUtil.h, source/headers/geos/precision.h,
-	  geos::precision namespace added
+	* [r1127] geos::precision namespace added
 2006-03-02 14:53  Sandro Santilli <strk at keybit.net>
-	* [r1126] source/geomgraph/index/SweepLineEvent.cpp,
-	  source/index/sweepline/indexSweepLineEvent.cpp:
-	  SweepLineEvent::DELETE=>DELETE_EVENT, INSERT=>INSERT_EVENT (#45)
+	* [r1126] SweepLineEvent::DELETE=>DELETE_EVENT,
+	  INSERT=>INSERT_EVENT (#45)
 2006-03-02 14:34  Sandro Santilli <strk at keybit.net>
-	* [r1125] source/headers/geos/geomgraph.h,
-	  source/headers/geos/operation.h, source/io/Unload.cpp,
-	  GeometryGraphOperation::li made a non-static member, and not more
-	  a pointer
+	* [r1125] GeometryGraphOperation::li made a non-static member, and
+	  not more a pointer
 2006-03-02 14:21  Sandro Santilli <strk at keybit.net>
-	* [r1124] capi/geos_c.cpp: DEBUG => GEOS_DEBUG [#44]
+	* [r1124] DEBUG => GEOS_DEBUG [#44]
 2006-03-02 12:12  Sandro Santilli <strk at keybit.net>
-	* [r1123] source/algorithm/LineIntersector.cpp,
-	  source/geomgraph/EdgeEndStar.cpp,
-	  source/geomgraph/EdgeIntersectionList.cpp,
-	  source/geomgraph/GeometryGraph.cpp, source/geomgraph/Node.cpp,
-	  source/geomgraph/NodeMap.cpp, source/geomgraph/PlanarGraph.cpp,
-	  source/geomgraph/Position.cpp,
-	  source/geomgraph/index/SegmentIntersector.cpp,
-	  source/index/chain/MonotoneChainBuilder.cpp,
-	  source/operation/polygonize/Polygonizer.cpp: Renamed DEBUG macros
-	  to GEOS_DEBUG, all wrapped in #ifndef block to allow global
-	  override (bug#43)
+	* [r1123] Renamed DEBUG macros to GEOS_DEBUG, all wrapped in
+	  #ifndef block to allow global override (bug#43)
 2006-03-02 11:03  Sandro Santilli <strk at keybit.net>
-	* [r1122] tests/xmltester/XMLTester.cpp: Added assertion in relate
-	  test handler
+	* [r1122] Added assertion in relate test handler
 2006-03-02 11:00  Sandro Santilli <strk at keybit.net>
-	* [r1121] source/geom/IntersectionMatrix.cpp,
-	  source/headers/geos/geom.h: Changed IntersectionMatrix funx
-	  taking strings to take const string& instead
+	* [r1121] Changed IntersectionMatrix funx taking strings to take
+	  const string& instead
 2006-03-02 10:25  Sandro Santilli <strk at keybit.net>
-	* [r1120] tests/xmltester/XMLTester.cpp,
-	  tests/xmltester/buffer.xml: Added support for FLOATING_SINGLE
-	  precisionmodel in XML tests
+	* [r1120] Added support for FLOATING_SINGLE precisionmodel in XML
+	  tests
 2006-03-02 10:03  Sandro Santilli <strk at keybit.net>
-	* [r1119] capi/Makefile.am, capi/geos_c.cpp: Removed use of strdup,
-	  changed GEOSjtsport() to return const char* instead of char* (is
-	  not advertised in headerfile, so no compatibility problems)
+	* [r1119] Removed use of strdup, changed GEOSjtsport() to return
+	  const char* instead of char* (is not advertised in headerfile, so
+	  no compatibility problems)
 2006-03-02 09:51  Sandro Santilli <strk at keybit.net>
-	* [r1118] source/operation/overlay/OverlayOp.cpp: Fixes in DEBUG
-	  lines (bug#42)
+	* [r1118] Fixes in DEBUG lines (bug#42)
 2006-03-02 09:49  Sandro Santilli <strk at keybit.net>
-	* [r1117] source/headers/geos/LineSegment.inl: Changed LineSegment
-	  output to use 'LINESEGMENT' label rather then 'LINESTRING'
+	* [r1117] Changed LineSegment output to use 'LINESEGMENT' label
+	  rather then 'LINESTRING'
-	* [r1116] source/headers/geos/timeval.h: WINCE implmentation of
-	  gettimeofday (bug#40)
+	* [r1116] WINCE implmentation of gettimeofday (bug#40)
 2006-03-02 09:46  Sandro Santilli <strk at keybit.net>
-	* [r1115] source/operation/buffer/SubgraphDepthLocater.cpp: cleaned
-	  up debugging lines
+	* [r1115] cleaned up debugging lines
 2006-03-01 18:44  Sandro Santilli <strk at keybit.net>
-	* [r1114] NEWS: added note about getInteriorPoint() possibly
-	  returning NULL
+	* [r1114] added note about getInteriorPoint() possibly returning
+	  NULL
 2006-03-01 18:43  Sandro Santilli <strk at keybit.net>
-	* [r1113] capi/geos_c.cpp: Handled new NULL return from
-	  Geometry::getInteriorPoint()
+	* [r1113] Handled new NULL return from Geometry::getInteriorPoint()
 2006-03-01 18:37  Sandro Santilli <strk at keybit.net>
-	* [r1112] source/algorithm/InteriorPointLine.cpp,
-	  source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
-	  Geometry::createPointFromInternalCoord dropped (it's a
+	* [r1112] Geometry::createPointFromInternalCoord dropped (it's a
 	  duplication of GeometryFactory::createPointFromInternalCoord).
 	  Fixed bugs in InteriorPoint* and getCentroid() inserted by
 	  previous commits.
 2006-03-01 18:19  Sandro Santilli <strk at keybit.net>
-	* [r1111] tests/xmltester/Makefile.am,
-	  tests/xmltester/TestCentroid.xml,
-	  tests/xmltester/testLeaksBig.xml: getCentroid() test moved from
-	  testLeaksBig.xml to TestCentroid.xml (synced with JTS-1.7)
+	* [r1111] getCentroid() test moved from testLeaksBig.xml to
+	  TestCentroid.xml (synced with JTS-1.7)
 2006-03-01 18:15  Sandro Santilli <strk at keybit.net>
-	* [r1110] tests/xmltester/Makefile.am,
-	  tests/xmltester/TestInteriorPoint.xml,
-	  tests/xmltester/testLeaksBig.xml: Extracted getInteriorPoint()
-	  tests out of testLeaksBig.xml and into TestInteriorPoint.xml
-	  (synced with JTS-1.7).
+	* [r1110] Extracted getInteriorPoint() tests out of
+	  testLeaksBig.xml and into TestInteriorPoint.xml (synced with
+	  JTS-1.7).
 2006-03-01 18:14  Sandro Santilli <strk at keybit.net>
-	* [r1109] tests/xmltester/XMLTester.cpp: Handled NULL return from
+	* [r1109] Handled NULL return from Geometry::getInteriorPoint()
 2006-03-01 17:16  Sandro Santilli <strk at keybit.net>
-	* [r1108] source/algorithm/CentroidArea.cpp,
-	  source/algorithm/MinimumDiameter.cpp, source/geom/Geometry.cpp,
-	  source/geom/LineSegment.cpp, source/headers/geos/LineSegment.inl,
-	  source/headers/geos/Makefile.am, source/headers/geos/geom.h,
-	  source/headers/geos/inline.h, source/headers/geos/opBuffer.h,
-	  source/operation/distance/DistanceOp.cpp: LineSegment class made
-	  final and optionally (compile-time) inlined.
+	* [r1108] LineSegment class made final and optionally
+	  (compile-time) inlined.
 	  Reduced heap allocations in Centroid{Area,Line,Point} and
 	  InteriorPoint{Area,Line,Point}.
 2006-03-01 16:42  Sandro Santilli <strk at keybit.net>
-	* [r1107] source/Makefile.vc: Fixed include name (Bug#41)
+	* [r1107] Fixed include name (Bug#41)
 2006-03-01 16:01  Sandro Santilli <strk at keybit.net>
-	* [r1106] source/noding/SegmentNodeList.cpp: Fixed const
-	  correctness of operator<<(ostream&, SegmentNodeList&) [bug#37]
+	* [r1106] Fixed const correctness of operator<<(ostream&,
+	  SegmentNodeList&) [bug#37]
 2006-03-01 13:49  Sandro Santilli <strk at keybit.net>
-	* [r1105] source/index/quadtree/Quadtree.cpp: Fixed debug lines
-	  (bug#36)
+	* [r1105] Fixed debug lines (bug#36)
 2006-03-01 13:48  Sandro Santilli <strk at keybit.net>
-	* [r1104] tests/xmltester/Stackwalker.cpp: Fixed missing type
-	  specifier (bug#35)
+	* [r1104] Fixed missing type specifier (bug#35)
 2006-03-01 13:06  Sandro Santilli <strk at keybit.net>
-	* [r1103] tests/xmltester/Makefile.am,
-	  tests/xmltester/XMLTester.cpp, tests/xmltester/buffer.xml: Used
-	  FLOATING precision model in buffer.xml test, added expected
-	  results,
+	* [r1103] Used FLOATING precision model in buffer.xml test, added
+	  expected results,
 	  changed XMLTester.cpp to use a tolerance when comparing expected
 	  and obtained
 	  results from buffer operations.
 2006-03-01 12:12  Sandro Santilli <strk at keybit.net>
-	* [r1102] tests/xmltester/XMLTester.cpp: Fixed a bug in verbose
-	  output preventing geometry arg 'A' from being properly printed
+	* [r1102] Fixed a bug in verbose output preventing geometry arg 'A'
+	  from being properly printed
 2006-03-01 11:47  Sandro Santilli <strk at keybit.net>
-	* [r1101] source/Makefile.vc: Applied patch by Mateusz Loskot (Bug
-	  #39)
+	* [r1101] Applied patch by Mateusz Loskot (Bug #39)
 2006-03-01 10:48  Sandro Santilli <strk at keybit.net>
-	* [r1100] source/headers/geos/opValid.h,
-	  source/operation/valid/TopologyValidationError.cpp: Changed
-	  static TopologyValidationError::errMsg[] from 'string' to 'const
-	  char*'
+	* [r1100] Changed static TopologyValidationError::errMsg[] from
+	  'string' to 'const char*'
 	  to reduce dynamic memory allocations.
 2006-03-01 10:39  Sandro Santilli <strk at keybit.net>
-	* [r1099] source/headers/geos/unload.h, source/io/Unload.cpp: ctor
-	  and dtor made private and inlined
+	* [r1099] ctor and dtor made private and inlined
 2006-03-01 09:56  Sandro Santilli <strk at keybit.net>
-	* [r1098] tests/xmltester/XMLTester.cpp: Case insensitive operation
-	  names and geometry arguments names (a/b)
+	* [r1098] Case insensitive operation names and geometry arguments
+	  names (a/b)
 2006-03-01 09:43  Sandro Santilli <strk at keybit.net>
-	* [r1097] tests/xmltester/XMLTester.cpp: Unrecognized tests always
-	  printed (was only printed when verbose before)
+	* [r1097] Unrecognized tests always printed (was only printed when
+	  verbose before)
 2006-03-01 08:52  Sandro Santilli <strk at keybit.net>
-	* [r1096] source/dirlist.mk: File to be included by Makefile.vc
+	* [r1096] File to be included by Makefile.vc
 2006-02-28 19:22  Sandro Santilli <strk at keybit.net>
-	* [r1095] source/headers/geos/opBuffer.h,
-	  source/operation/buffer/OffsetCurveBuilder.cpp: Fixed in-place
-	  definition of static members in OffsetCurveBuilder (bug#33)
+	* [r1095] Fixed in-place definition of static members in
+	  OffsetCurveBuilder (bug#33)
 2006-02-28 19:18  Sandro Santilli <strk at keybit.net>
-	* [r1094] tests/xmltester/XMLTester.cpp: Added cctype include (bug
-	  #34)
+	* [r1094] Added cctype include (bug #34)
 2006-02-28 17:44  Sandro Santilli <strk at keybit.net>
-	* [r1093] source/geom/Coordinate.cpp, source/headers/geos/geom.h,
-	  source/headers/geos/noding.h, source/noding/SegmentNode.cpp,
-	  source/operation/buffer/BufferBuilder.cpp: Added a check in
-	  SegmentNode::addSplitEdge to prevent attempts
+	* [r1093] Added a check in SegmentNode::addSplitEdge to prevent
+	  attempts
 	  to build SegmentString with less then 2 points.
 	  This is a temporary fix for the buffer.xml assertion failure,
 	  temporary
@@ -12854,84 +7746,52 @@
 2006-02-28 15:34  Sandro Santilli <strk at keybit.net>
-	* [r1092] tests/xmltester/XMLTester.cpp: Fix for VC++ builds (Bug
-	  #32)
+	* [r1092] Fix for VC++ builds (Bug #32)
 2006-02-28 14:34  Sandro Santilli <strk at keybit.net>
-	* [r1091] source/geom/Coordinate.cpp,
-	  source/geomgraph/EdgeEnd.cpp, source/geomgraph/EdgeList.cpp,
-	  source/headers/geos/geom.h, source/headers/geos/geomgraph.h,
-	  source/headers/geos/noding.h, source/headers/geos/opBuffer.h,
-	  source/noding/MCIndexNoder.cpp, source/noding/SegmentNode.cpp,
-	  source/operation/buffer/BufferBuilder.cpp,
-	  tests/xmltester/buffer.xml: Added many assertions and debugging
-	  output hunting for a bug in BufferOp
+	* [r1091] Added many assertions and debugging output hunting for a
+	  bug in BufferOp
 2006-02-28 14:05  Sandro Santilli <strk at keybit.net>
-	* [r1090] source/geomgraph/Edge.cpp: Fixed a bug in a debugging
-	  line
+	* [r1090] Fixed a bug in a debugging line
 2006-02-28 13:08  Sandro Santilli <strk at keybit.net>
-	* [r1089] source/headers/geos/noding.h: Added missing definition of
-	  IteratedNoder::MAX_ITER, moving it to private access level
+	* [r1089] Added missing definition of IteratedNoder::MAX_ITER,
+	  moving it to private access level
 2006-02-28 11:15  Sandro Santilli <strk at keybit.net>
-	* [r1088] tests/xmltester/markup/MarkupSTL.cpp: Fixed strchr use
-	  (Bug #30)
+	* [r1088] Fixed strchr use (Bug #30)
 2006-02-28 11:11  Sandro Santilli <strk at keybit.net>
-	* [r1087] capi/geos_c.cpp: Fixed typo in GEOSLenght function
+	* [r1087] Fixed typo in GEOSLenght function
 2006-02-28 05:03  Sean Gillies <sgillies at frii.com>
-	* [r1085] NEWS, capi/geos_c.cpp, capi/geos_c.h.in: added
-	  GEOSLength(), GEOSEnvelope() to the C API
+	* [r1085] added GEOSLength(), GEOSEnvelope() to the C API
 2006-02-27 14:41  Sandro Santilli <strk at keybit.net>
-	* [r1076] tests/xmltester/XMLTester.cpp: More verbose handling of
-	  exceptions
+	* [r1076] More verbose handling of exceptions
 2006-02-27 11:53  Sandro Santilli <strk at keybit.net>
-	* [r1075] source/geomgraph/DirectedEdgeStar.cpp,
-	  source/headers/geos/geomgraph.h: DirectedEdgeStar made more safe
-	  trough assert(), use of standard iterator and
+	* [r1075] DirectedEdgeStar made more safe trough assert(), use of
+	  standard iterator and
 	  dynamic casts substituting static ones.
 2006-02-27 09:05  Sandro Santilli <strk at keybit.net>
-	* [r1074] source/algorithm/LineIntersector.cpp,
-	  source/headers/geos/opOverlay.h, source/headers/geos/operation.h,
-	  source/operation/GeometryGraphOperation.cpp,
-	  source/operation/overlay/OverlayOp.cpp: Doxygen comments, a few
-	  inlines and general cleanups
+	* [r1074] Doxygen comments, a few inlines and general cleanups
 2006-02-24 16:20  Sandro Santilli <strk at keybit.net>
-	* [r1073] source/geom/PrecisionModel.cpp,
-	  source/headers/geos/util.h, source/util/Makefile.am,
-	  source/util/math.cpp, tests/xmltester/testLeaksBig.xml: Added
-	  Mateusz implementation of round() in a new math.cpp file
+	* [r1073] Added Mateusz implementation of round() in a new math.cpp
+	  file
 	  named sym_round(). Changed use of rint_vc to sym_round in
 	  PrecisionModel.
 	  Moved rint_vc to math.cpp (geos::util namespace), to be renamed
@@ -12939,37 +7799,17 @@
 2006-02-24 15:39  Sandro Santilli <strk at keybit.net>
-	* [r1072] source/geom/Coordinate.cpp, source/headers/geos/geom.h,
-	  source/headers/geos/opLinemerge.h,
-	  source/headers/geos/planargraph.h,
-	  source/operation/linemerge/LineMergeGraph.cpp,
-	  source/operation/linemerge/LineMerger.cpp,
-	  source/planargraph/planarEdge.cpp,
-	  source/planargraph/planarNode.cpp, tests/xmltester/Makefile.am: -
-	  operator>> for Coordinate, planarNode and planarEdge
+	* [r1072] - operator>> for Coordinate, planarNode and planarEdge
 	  - Fixed bug in planarGraphComponent::setMarked
 	  - Added linemerge.xml test (single test, should grow a bit)
 2006-02-24 12:19  Sandro Santilli <strk at keybit.net>
-	* [r1071] doc/Doxyfile.in: Fixed typo in config file
+	* [r1071] Fixed typo in config file
 2006-02-23 23:17  Sandro Santilli <strk at keybit.net>
-	* [r1070] source/geom/Coordinate.cpp, source/geom/Envelope.cpp,
-	  source/geom/GeometryFactory.cpp, source/geom/LineSegment.cpp,
-	  source/geom/PrecisionModel.cpp, source/headers/geos/geom.h,
-	  source/operation/polygonize/polygonizeEdgeRing.cpp,
-	  source/planargraph/planarDirectedEdgeStar.cpp,
-	  source/util/GeometricShapeFactory.cpp: -
-	  Coordinate::nullCoordinate made private
+	* [r1070] - Coordinate::nullCoordinate made private
 	  - Simplified Coordinate inline definitions
 	  - LMGeometryComponentFilter definition moved to LineMerger.cpp
 	  file
@@ -12977,61 +7817,22 @@
 2006-02-23 20:32  Sandro Santilli <strk at keybit.net>
-	* [r1069] tests/xmltester/XMLTester.cpp: Added support for
-	  LineMerge tests. Exception printed on stderr.
+	* [r1069] Added support for LineMerge tests. Exception printed on
+	  stderr.
 2006-02-23 20:05  Sandro Santilli <strk at keybit.net>
-	* [r1068] source/headers/geos/noding.h,
-	  source/headers/geos/opBuffer.h, source/noding/MCIndexNoder.cpp,
-	  source/noding/SimpleNoder.cpp,
-	  source/operation/buffer/BufferOp.cpp: Fixed bug in MCIndexNoder
-	  constructor making memory checker go crazy, more
+	* [r1068] Fixed bug in MCIndexNoder constructor making memory
+	  checker go crazy, more
 	  doxygen-friendly comments, miscellaneous cleanups
 2006-02-23 20:03  Sandro Santilli <strk at keybit.net>
-	* [r1067] doc/Doxyfile.in: updated to also show undocumented
-	  methods
+	* [r1067] updated to also show undocumented methods
 2006-02-23 11:54  Sandro Santilli <strk at keybit.net>
-	* [r1066] source/geom/MultiLineString.cpp,
-	  source/geom/TopologyException.cpp, source/geom/Triangle.cpp,
-	  source/geomgraph/Edge.cpp, source/geomgraph/EdgeList.cpp,
-	  source/geomgraph/GeometryGraph.cpp, source/geomgraph/NodeMap.cpp,
-	  source/headers/geos/indexQuadtree.h,
-	  source/headers/geos/indexStrtree.h, source/headers/geos/noding.h,
-	  source/headers/geos/spatialIndex.h, source/headers/geos/util.h,
-	  source/index/bintree/BinTreeNode.cpp,
-	  source/index/quadtree/QuadTreeNode.cpp,
-	  source/index/quadtree/QuadTreeNodeBase.cpp,
-	  source/index/quadtree/QuadTreeRoot.cpp,
-	  source/index/quadtree/Quadtree.cpp,
-	  source/index/strtree/AbstractSTRtree.cpp,
-	  source/index/strtree/SIRtree.cpp,
-	  source/noding/MCIndexNoder.cpp, source/noding/ScaledNoder.cpp,
-	  source/operation/buffer/BufferOp.cpp,
-	  source/operation/relate/RelateComputer.cpp,
-	  source/util/Assert.cpp, source/util/AssertionFailedException.cpp,
-	  source/util/Makefile.am,
-	  tests/xmltester/buffer.xml: - MCIndexPointSnapper
+	* [r1066] - MCIndexPointSnapper
 	  - MCIndexSnapRounder
 	  - SnapRounding BufferOp
 	  - ScaledNoder
@@ -13045,251 +7846,28 @@
 2006-02-21 16:53  Sandro Santilli <strk at keybit.net>
-	* [r1065] source/algorithm/MCPointInRing.cpp,
-	  source/headers/geos/indexChain.h, source/headers/geos/noding.h,
-	  source/index/chain/MonotoneChainSelectAction.cpp,
-	  source/index/chain/indexMonotoneChain.cpp,
-	  source/noding/snapround/MCIndexPointSnapper.cpp,
-	  MCIndexPointSnapper, MCIndexSnapRounder
+	* [r1065] MCIndexPointSnapper, MCIndexSnapRounder
 2006-02-20 21:04  Sandro Santilli <strk at keybit.net>
-	* [r1064] source/headers/geos/geomgraph.h,
-	  source/index/strtree/STRtree.cpp: - namespace geos::index
+	* [r1064] - namespace geos::index
 	  - SpatialIndex interface synced
 2006-02-20 10:14  Sandro Santilli <strk at keybit.net>
-	* [r1063] ChangeLog, doc/Doxyfile.in,
-	  source/algorithm/MCPointInRing.cpp,
-	  source/algorithm/SIRtreePointInRing.cpp,
-	  source/geom/Geometry.cpp, source/geomgraph/EdgeList.cpp,
-	  source/headers/geos/indexBintree.h,
-	  source/headers/geos/indexSweepline.h, source/headers/geos/io.h,
-	  source/headers/geos/opDistance.h,
-	  source/headers/geos/opOverlay.h, source/headers/geos/opRelate.h,
-	  source/headers/geos/opValid.h, source/headers/geos/operation.h,
-	  source/index/bintree/BinTreeInterval.cpp,
-	  source/index/bintree/Bintree.cpp, source/index/bintree/Key.cpp,
-	  source/index/bintree/NodeBase.cpp, source/index/bintree/Root.cpp,
-	  source/index/chain/MonotoneChainOverlapAction.cpp,
-	  source/index/quadtree/DoubleBits.cpp,
-	  source/index/quadtree/IntervalSize.cpp,
-	  source/index/quadtree/QuadTreeKey.cpp,
-	  source/index/strtree/AbstractNode.cpp,
-	  source/index/strtree/Interval.cpp,
-	  source/index/strtree/ItemBoundable.cpp,
-	  source/index/sweepline/SweepLineIndex.cpp,
-	  source/index/sweepline/SweepLineInterval.cpp,
-	  source/index/sweepline/indexSweepLineEvent.cpp,
-	  source/io/Unload.cpp, source/noding/MCIndexNoder.cpp,
-	  source/operation/valid/SweeplineNestedRingTester.cpp: -
-	  namespaces geos::index::*
+	* [r1063] - namespaces geos::index::*
 	  - Doxygen documentation cleanup
 2006-02-19 19:46  Sandro Santilli <strk at keybit.net>
-	* [r1062] NEWS, capi/geos_c.cpp, configure.in, doc/example.cpp,
-	  source/algorithm/CentroidArea.cpp,
-	  source/algorithm/CentroidLine.cpp,
-	  source/algorithm/ConvexHull.cpp,
-	  source/algorithm/HCoordinate.cpp,
-	  source/algorithm/InteriorPointLine.cpp,
-	  source/algorithm/InteriorPointPoint.cpp,
-	  source/algorithm/LineIntersector.cpp,
-	  source/algorithm/NonRobustLineIntersector.cpp,
-	  source/algorithm/RobustDeterminant.cpp,
-	  source/algorithm/RobustLineIntersector.cpp,
-	  source/algorithm/SimplePointInAreaLocator.cpp,
-	  source/algorithm/SimplePointInRing.cpp,
-	  source/geom/Coordinate.cpp, source/geom/Geometry.cpp,
-	  source/geom/LineSegment.cpp, source/geom/LineString.cpp,
-	  source/geom/MultiLineString.cpp, source/geom/MultiPoint.cpp,
-	  source/geom/Polygon.cpp, source/geomgraph/Depth.cpp,
-	  source/geomgraph/GraphComponent.cpp, source/geomgraph/Label.cpp,
-	  source/geomgraph/Node.cpp, source/geomgraph/NodeFactory.cpp,
-	  source/geomgraph/Position.cpp, source/geomgraph/Quadrant.cpp,
-	  source/geomgraph/index/Makefile.am,
-	  source/geomgraph/index/MonotoneChain.cpp,
-	  source/headers/geos/opPolygonize.h,
-	  source/headers/geos/opPredicate.h,
-	  source/headers/geos/planargraph.h, source/index/Makefile.am,
-	  source/index/bintree, source/index/bintree/.cvsignore,
-	  source/index/bintree/Makefile.am, source/index/chain,
-	  source/index/chain/.cvsignore, source/index/chain/Makefile.am,
-	  source/index/quadtree, source/index/quadtree/.cvsignore,
-	  source/index/quadtree/Makefile.am, source/index/strtree,
-	  source/index/strtree/.cvsignore,
-	  source/index/strtree/Makefile.am, source/index/sweepline,
-	  source/index/sweepline/.cvsignore,
-	  source/index/sweepline/Makefile.am, source/io/Unload.cpp,
-	  source/noding/IntersectionAdder.cpp,
-	  source/operation/IsSimpleOp.cpp,
-	  source/operation/distance/ConnectedElementLocationFilter.cpp,
-	  source/operation/distance/ConnectedElementPointFilter.cpp,
-	  source/operation/distance/DistanceOp.cpp,
-	  source/operation/distance/GeometryLocation.cpp,
-	  source/operation/linemerge/EdgeString.cpp,
-	  source/operation/linemerge/LineMergeDirectedEdge.cpp,
-	  source/operation/linemerge/LineMergeEdge.cpp,
-	  source/operation/linemerge/LineSequencer.cpp,
-	  source/operation/overlay/LineBuilder.cpp,
-	  source/operation/overlay/MaximalEdgeRing.cpp,
-	  source/operation/overlay/MinimalEdgeRing.cpp,
-	  source/operation/overlay/OverlayOp.cpp,
-	  source/operation/overlay/PolygonBuilder.cpp,
-	  source/operation/polygonize/PolygonizeDirectedEdge.cpp,
-	  source/operation/polygonize/PolygonizeEdge.cpp,
-	  source/operation/polygonize/PolygonizeGraph.cpp,
-	  source/operation/polygonize/Polygonizer.cpp,
-	  source/operation/predicate/RectangleIntersects.cpp,
-	  source/operation/relate/EdgeEndBuilder.cpp,
-	  source/operation/relate/EdgeEndBundle.cpp,
-	  source/operation/relate/EdgeEndBundleStar.cpp,
-	  source/operation/relate/RelateNode.cpp,
-	  source/operation/relate/RelateNodeFactory.cpp,
-	  source/operation/relate/RelateNodeGraph.cpp,
-	  source/operation/relate/RelateOp.cpp,
-	  source/operation/valid/ConsistentAreaTester.cpp,
-	  source/operation/valid/IsValidOp.cpp,
-	  source/operation/valid/QuadtreeNestedRingTester.cpp,
-	  source/operation/valid/RepeatedPointTester.cpp,
-	  source/operation/valid/SimpleNestedRingTester.cpp,
-	  source/planargraph/algorithm/ConnectedSubgraphFinder.cpp,
-	  source/planargraph/planarDirectedEdge.cpp,
-	  source/planargraph/planarGraphComponent.cpp,
-	  source/planargraph/planarNodeMap.cpp,
-	  source/planargraph/planarPlanarGraph.cpp,
-	  tests/xmltester/XMLTester.cpp: Packages <-> namespaces mapping
-	  for most GEOS internal code (uncomplete, but working). Dir-level
-	  libs for index/ subdirs.
+	* [r1062] Packages <-> namespaces mapping for most GEOS internal
+	  code (uncomplete, but working). Dir-level libs for index/
+	  subdirs.
 2006-02-18 21:08  Sandro Santilli <strk at keybit.net>
-	* [r1061] NEWS, source/geom/Geometry.cpp,
-	  source/noding/Makefile.am, source/noding/NodingValidator.cpp,
-	  source/noding/ScaledNoder.cpp, source/noding/SegmentNodeList.cpp,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp: - new
-	  CoordinateSequence::applyCoordinateFilter method (slow but
-	  useful)
+	* [r1061] - new CoordinateSequence::applyCoordinateFilter method
+	  (slow but useful)
 	  - SegmentString::getCoordinates() doesn't return a clone anymore.
 	  - SegmentString::getCoordinatesRO() obsoleted.
 	  - SegmentString constructor does not promises constness of passed
@@ -13301,168 +7879,77 @@
 2006-02-16 08:41  Sandro Santilli <strk at keybit.net>
-	* [r1060] source/noding/NodingValidator.cpp: Fixed include:
-	  "util.h" => "geos/util.h"
+	* [r1060] Fixed include: "util.h" => "geos/util.h"
-	* [r1059] source/headers/geos/nodingSnapround.h: added <cmath>
-	  include for round()
+	* [r1059] added <cmath> include for round()
 2006-02-16 08:19  Sandro Santilli <strk at keybit.net>
-	* [r1058] source/noding/IntersectionAdder.cpp: Missed from last
-	  commit
+	* [r1058] Missed from last commit
 2006-02-15 22:48  Sean Gillies <sgillies at frii.com>
-	* [r1057] capi/geos_c.h.in: added GEOSGeomType
+	* [r1057] added GEOSGeomType
 2006-02-15 17:19  Sandro Santilli <strk at keybit.net>
-	* [r1056] NEWS, source/geomgraph/EdgeNodingValidator.cpp,
-	  source/headers/geos/noding.h, source/noding/NodingValidator.cpp,
-	  source/noding/snapround/SimpleSnapRounder.cpp: NodingValidator
-	  synced with JTS-1.7, added CoordinateSequence::operator[]
+	* [r1056] NodingValidator synced with JTS-1.7, added
+	  CoordinateSequence::operator[]
 	  and size() to easy port maintainance.
 2006-02-15 14:59  Sandro Santilli <strk at keybit.net>
-	* [r1055] source/headers/geos/noding.h,
-	  source/noding/SegmentString.cpp: JTS-1.7 sync for:
+	* [r1055] JTS-1.7 sync for:
 2006-02-14 13:28  Sandro Santilli <strk at keybit.net>
-	* [r1054] NEWS, configure.in, source/algorithm/LineIntersector.cpp,
-	  source/noding/MCQuadtreeNoder.cpp, source/noding/Makefile.am,
-	  source/noding/Noder.cpp, source/noding/NodingValidator.cpp,
-	  source/noding/Octant.cpp, source/noding/SegmentNode.cpp,
-	  source/noding/nodingSegmentIntersector.cpp,
-	  source/noding/snapround, source/noding/snapround/.cvsignore,
-	  source/noding/snapround/Makefile.am,
-	  source/noding/snapround/SegmentSnapper.cpp,
-	  source/noding/snapround/SimpleSegmentStringsSnapper.cpp,
-	  source/noding/snapround/SnapRounder.cpp,
-	  tests/xmltester/XMLTester.cpp: New SnapRounding code ported from
-	  JTS-1.7 (not complete yet).
+	* [r1054] New SnapRounding code ported from JTS-1.7 (not complete
+	  yet).
 	  Buffer op optimized by using new snaprounding code.
 	  Leaks fixed in XMLTester.
 2006-02-09 15:52  Sandro Santilli <strk at keybit.net>
-	* [r1053] capi/geos_c.cpp, capi/geos_c.cpp.bak, configure.in,
-	  doc/example.cpp, source/algorithm/CGAlgorithms.cpp,
-	  source/examples/CoordinateSequencesExample.cpp,
-	  source/examples/CustomCoordinateSequenceExample.cpp,
-	  source/examples/CustomPointCoordinateSequence.cpp,
-	  source/geom/GeometryCollectionIterator.cpp,
-	  source/geom/GeometryComponentFilter.cpp,
-	  source/geom/IntersectionMatrix.cpp, source/geom/LineString.cpp,
-	  source/geom/LinearRing.cpp, source/geom/Location.cpp,
-	  source/geomgraph/EdgeEndStar.cpp, source/geomgraph/EdgeRing.cpp,
-	  source/headers/geos/opBuffer.h, source/headers/geos/util.h,
-	  source/io/ParseException.cpp, source/io/WKBReader.cpp,
-	  source/io/WKBWriter.cpp, source/io/WKTReader.cpp,
-	  source/operation/overlay/ElevationMatrixFilter.cpp,
-	  tests/xmltester/CTS.cpp, tests/xmltester/SimpleWKTTester.cpp,
-	  tests/xmltester/XMLTester.cpp: GEOSException derived from
-	  std::exception; always thrown and cought by const ref.
+	* [r1053] GEOSException derived from std::exception; always thrown
+	  and cought by const ref.
 2006-02-09 15:41  Sean Gillies <sgillies at frii.com>
-	* [r1052] configure.in: incrementing C API patch level
+	* [r1052] incrementing C API patch level
 2006-02-09 14:49  Sean Gillies <sgillies at frii.com>
-	* [r1051] capi/geos_c.cpp, capi/geos_c.h.in, capi/geostest.c: added
-	  GEOSArea() to the C API
+	* [r1051] added GEOSArea() to the C API
 2006-02-09 13:44  Sandro Santilli <strk at keybit.net>
-	* [r1050] source/geom/Geometry.cpp, source/headers/geos/geom.h,
-	  source/io/WKBReader.cpp: Added support for SRID in input WKB,
-	  undeprecated Geometry::setSRID
+	* [r1050] Added support for SRID in input WKB, undeprecated
+	  Geometry::setSRID
 	  and Geometry::getSRID
 2006-02-09 01:47  frank
-	* [r1049] source/io/WKBReader.cpp: Botched last fix. Hopefully this
-	  is better.
+	* [r1049] Botched last fix. Hopefully this is better.
 2006-02-09 01:13  Sandro Santilli <strk at keybit.net>
-	* [r1048] ChangeLog, source/operation/linemerge/LineSequencer.cpp:
-	  Added missing <limits> include
+	* [r1048] Added missing <limits> include
 2006-02-09 00:06  frank
-	* [r1047] ChangeLog, source/io/WKBReader.cpp: Fixed support for
-	  consuming WKB for 'POLYGON EMPTY' with numRings==0.
+	* [r1047] Fixed support for consuming WKB for 'POLYGON EMPTY' with
+	  numRings==0.
 	  http://bugzilla.remotesensing.org/show_bug.cgi?id=1064
 2006-02-08 17:18  Sandro Santilli <strk at keybit.net>
-	* [r1046] NEWS, source/geom/Envelope.cpp, source/geom/Geometry.cpp,
-	  source/geom/LineString.cpp, source/geom/MultiLineString.cpp,
-	  source/geom/MultiPoint.cpp, source/headers/geos/geom.h,
-	  source/headers/geos/io.h, source/headers/geos/opBuffer.h,
-	  source/headers/geos/opValid.h, source/io/WKTWriter.cpp,
-	  source/operation/valid/IsValidOp.cpp: - New
-	  WKTWriter::toLineString and ::toPoint convenience methods
+	* [r1046] - New WKTWriter::toLineString and ::toPoint convenience
+	  methods
 	  - New IsValidOp::setSelfTouchingRingFormingHoleValid method
 	  - New Envelope::centre()
 	  - New Envelope::intersection(Envelope)
@@ -13475,19 +7962,11 @@
 2006-02-08 13:07  Sandro Santilli <strk at keybit.net>
-	* [r1045] NEWS: Added note about new LineSequencer class
+	* [r1045] Added note about new LineSequencer class
 2006-02-08 12:59  Sandro Santilli <strk at keybit.net>
-	* [r1044] source/headers/geos/geom.h,
-	  source/operation/linemerge/Makefile.am,
-	  source/planargraph/planarSubgraph.cpp: - NEW
-	  Geometry::applyComponentFilter() templated method
+	* [r1044] - NEW Geometry::applyComponentFilter() templated method
 	  - Changed Geometry::getGeometryN() to take unsigned int and
 	  getNumGeometries
 	  to return unsigned int.
@@ -13503,37 +7982,26 @@
 2006-02-07 13:26  Sandro Santilli <strk at keybit.net>
-	* [r1043] source/Makefile.am: Added missing geomgraph SUBDIR
+	* [r1043] Added missing geomgraph SUBDIR
 2006-02-07 12:02  Sandro Santilli <strk at keybit.net>
-	* [r1042] tests/xmltester/Makefile.am: Removed TestConvexHull.xml
-	  file (already included in testLeaksBig.xml
+	* [r1042] Removed TestConvexHull.xml file (already included in
+	  testLeaksBig.xml
 2006-02-06 11:27  Sandro Santilli <strk at keybit.net>
-	* [r1041] tests, tests/.cvsignore: new entry
+	* [r1041] new entry
 2006-02-05 17:14  Sandro Santilli <strk at keybit.net>
-	* [r1040] NEWS, source/headers/geos/planargraph.h,
-	  source/planargraph/Makefile.am, source/planargraph/algorithm,
-	  source/planargraph/planarPlanarGraph.cpp: - New
-	  ConnectedSubgraphFinder class.
+	* [r1040] - New ConnectedSubgraphFinder class.
 	  - More iterators returning methods, inlining and cleanups
 	  in planargraph.
 2006-02-04 00:54  Sandro Santilli <strk at keybit.net>
-	* [r1039] ChangeLog, NEWS, source/headers/geos/geom.h,
-	  source/planargraph/planarSubgraph.cpp, swig/ruby/Makefile.am,
-	  tests/xmltester/Makefile.am: - Doxygen dox updated
+	* [r1039] - Doxygen dox updated
 	  - LineStringLT struct moved from geomgraph.h to geom.h
 	  - New planarSubgraph class
 	  - Fixed ruby Makefiles to avoid running tests when disabled
@@ -13542,199 +8010,50 @@
 2006-02-03 09:26  Sandro Santilli <strk at keybit.net>
-	* [r1038] source/geom/util/ShortCircuitedGeometryVisitor.cpp: Added
-	  missing file
+	* [r1038] Added missing file
 2006-02-02 02:20  Sandro Santilli <strk at keybit.net>
-	* [r1037] source/geom/Polygon.cpp: Fixed bug in isRectangle()
-	  failing to detect rectangles.
+	* [r1037] Fixed bug in isRectangle() failing to detect rectangles.
 2006-02-01 22:22  Sandro Santilli <strk at keybit.net>
-	* [r1036] NEWS: updated
+	* [r1036] updated
 2006-02-01 22:21  Sandro Santilli <strk at keybit.net>
-	* [r1035] source/geom/Geometry.cpp, source/geom/Polygon.cpp,
-	  source/geom/util/Makefile.am, source/headers/geos/geom.h,
-	  source/headers/geos/planargraph.h, source/operation/Makefile.am,
-	  source/operation/predicate/Makefile.am,
-	  source/planargraph/planarGraphComponent.cpp: - Added
-	  rectangle-based optimizations of intersects() and contains() ops
+	* [r1035] - Added rectangle-based optimizations of intersects() and
+	  contains() ops
 	  - Inlined all planarGraphComponent class
 2006-01-31 21:42  Sandro Santilli <strk at keybit.net>
-	* [r1034] source/Makefile.vc: Added DepthSegment object
+	* [r1034] Added DepthSegment object
 2006-01-31 21:36  Sandro Santilli <strk at keybit.net>
-	* [r1033] swig/geos.i: Fixes error in calling read_hex from
-	  scripting languages.
+	* [r1033] Fixes error in calling read_hex from scripting languages.
 2006-01-31 21:35  Sandro Santilli <strk at keybit.net>
-	* [r1032] capi/Makefile.in: Erroneusly ended in CVS
+	* [r1032] Erroneusly ended in CVS
 2006-01-31 21:17  Sandro Santilli <strk at keybit.net>
-	* [r1031] source/operation/predicate/RectangleContains.cpp: Added
-	  missing file from last commits
+	* [r1031] Added missing file from last commits
 2006-01-31 19:11  Sandro Santilli <strk at keybit.net>
-	* [r1030] source/bigtest: Another left-over from cleanups
+	* [r1030] Another left-over from cleanups
 2006-01-31 19:10  Sandro Santilli <strk at keybit.net>
-	* [r1029] source/capi, source/test: Removed leftover files in
-	  obsoleted dirs
+	* [r1029] Removed leftover files in obsoleted dirs
 2006-01-31 19:07  Sandro Santilli <strk at keybit.net>
-	* [r1028] Makefile.am, NEWS, README, capi, capi/.cvsignore,
-	  capi/Makefile.am, capi/Makefile.in, capi/geos_c.cpp,
-	  capi/geos_c.cpp.bak, capi/geos_c.h.in, capi/geostest.c,
-	  capi/test.wkt, configure.in, doc/Doxyfile.in, doc/Makefile.am,
-	  doc/example.cpp, source, source/.cvsignore, source/Makefile.am,
-	  source/algorithm, source/algorithm/.cvsignore,
-	  source/algorithm/MCPointInRing.cpp, source/algorithm/Makefile.am,
-	  source/bigtest/GeometryTestFactory.cpp,
-	  source/bigtest/Makefile.am,
-	  source/bigtest/TestSweepLineSpeed.cpp, source/bigtest/bigtest.h,
-	  source/capi/Makefile.am, source/capi/geos_c.cpp,
-	  source/capi/geos_c.h.in, source/capi/geostest.c,
-	  source/capi/test.wkt, source/examples/CPCLException.cpp,
-	  source/geom/CoordinateArraySequenceFactory.cpp,
-	  source/geom/CoordinateList.cpp,
-	  source/geom/CoordinateSequence.cpp,
-	  source/geom/DefaultCoordinateSequence.cpp,
-	  source/geom/DefaultCoordinateSequenceFactory.cpp,
-	  source/geom/IntersectionMatrix.cpp, source/geom/LineSegment.cpp,
-	  source/geom/Makefile.am, source/geom/MultiLineString.cpp,
-	  source/geom/Point.cpp, source/geom/Polygon.cpp, source/geom/util,
-	  source/geom/util/.cvsignore, source/geom/util/GeometryEditor.cpp,
-	  source/geom/util/LinearComponentExtracter.cpp,
-	  source/geom/util/PointExtracter.cpp,
-	  source/geom/util/PolygonExtracter.cpp, source/geomgraph,
-	  source/geomgraph/.cvsignore, source/geomgraph/Edge.cpp,
-	  source/geomgraph/GeometryGraph.cpp, source/geomgraph/Makefile.am,
-	  source/geomgraph/PlanarGraph.cpp, source/geomgraph/index,
-	  source/geomgraph/index/.cvsignore,
-	  source/geomgraph/index/MonotoneChainEdge.cpp,
-	  source/geomgraph/index/MonotoneChainIndexer.cpp,
-	  source/geomgraph/index/SimpleEdgeSetIntersector.cpp,
-	  source/geomgraph/index/SimpleSweepLineIntersector.cpp,
-	  source/headers/geos/precision.h, source/headers/geos/util.h,
-	  source/index, source/index/.cvsignore, source/index/Makefile.am,
-	  source/index/chain/indexMonotoneChain.cpp, source/io,
-	  source/io/.cvsignore, source/io/Makefile.am,
-	  source/io/Unload.cpp, source/io/WKTReader.cpp, source/io/markup,
-	  source/noding, source/noding/.cvsignore,
-	  source/noding/NodingValidator.cpp,
-	  source/noding/SegmentNodeList.cpp,
-	  source/noding/SegmentString.cpp, source/noding/SimpleNoder.cpp,
-	  source/operation, source/operation/.cvsignore,
-	  source/operation/Makefile.am, source/operation/buffer,
-	  source/operation/buffer/.cvsignore,
-	  source/operation/buffer/Makefile.am,
-	  source/operation/buffer/SubgraphDepthLocater.cpp,
-	  source/operation/distance, source/operation/distance/.cvsignore,
-	  source/operation/distance/Makefile.am,
-	  source/operation/linemerge,
-	  source/operation/linemerge/.cvsignore,
-	  source/operation/linemerge/Makefile.am, source/operation/overlay,
-	  source/operation/overlay/.cvsignore,
-	  source/operation/overlay/Makefile.am,
-	  source/operation/polygonize,
-	  source/operation/polygonize/.cvsignore,
-	  source/operation/polygonize/Makefile.am,
-	  source/operation/predicate,
-	  source/operation/predicate/.cvsignore,
-	  source/operation/predicate/SegmentIntersectionTester.cpp,
-	  source/operation/relate, source/operation/relate/.cvsignore,
-	  source/operation/relate/Makefile.am, source/operation/valid,
-	  source/operation/valid/.cvsignore,
-	  source/operation/valid/Makefile.am,
-	  source/planargraph, source/planargraph/.cvsignore,
-	  source/planargraph/Makefile.am, source/precision,
-	  source/precision/.cvsignore, source/precision/Makefile.am,
-	  source/test/CTS.cpp, source/test/Makefile.am,
-	  source/test/SimpleWKTTester.cpp, source/test/Stackwalker.cpp,
-	  source/test/Stackwalker.h, source/test/WKTIn, source/test/WKTOut,
-	  source/test/XMLTester.cpp, source/test/XMLTester.h,
-	  source/test/hexwkb.xml, source/test/test.xml,
-	  source/test/testLeaksBig.xml, source/util,
-	  source/util/.cvsignore, source/util/CoordinateArrayFiter.cpp,
-	  source/util/GeometricShapeFactory.cpp, source/util/Makefile.am,
-	  source/util/UniqueCoordinateArrayFilter.cpp, tests,
-	  tests/Makefile.am, tests/bigtest, tests/bigtest/.cvsignore,
-	  tests/bigtest/GeometryTestFactory.cpp, tests/bigtest/Makefile.am,
-	  tests/bigtest/TestSweepLineSpeed.cpp, tests/bigtest/bigtest.h,
-	  tests/xmltester, tests/xmltester/.cvsignore,
-	  tests/xmltester/CTS.cpp, tests/xmltester/Makefile.am,
-	  tests/xmltester/Stackwalker.cpp, tests/xmltester/Stackwalker.h,
-	  tests/xmltester/WKTIn, tests/xmltester/WKTOut,
-	  tests/xmltester/hexwkb.xml, tests/xmltester/markup,
-	  tests/xmltester/markup/MarkupSTL.cpp,
-	  tests/xmltester/markup/MarkupSTL.h, tests/xmltester/test.xml,
-	  tests/xmltester/testLeaksBig.xml: - Renamed
-	  DefaultCoordinateSequence to CoordinateArraySequence.
+	* [r1028] - Renamed DefaultCoordinateSequence to
+	  CoordinateArraySequence.
 	  - Moved GetNumGeometries() and GetGeometryN() interfaces
 	  from GeometryCollection to Geometry class.
 	  - Added getAt(int pos, Coordinate &to) funtion to
@@ -13760,31 +8079,25 @@
 2006-01-30 21:59  frank
-	* [r1027] source/algorithm/LineIntersector.cpp: yikes! comment out
-	  debug define again
+	* [r1027] yikes! comment out debug define again
 2006-01-30 21:58  frank
-	* [r1026] ChangeLog, source/algorithm/LineIntersector.cpp: fixed up
-	  some debug messages
+	* [r1026] fixed up some debug messages
 2006-01-30 16:55  Sandro Santilli <strk at keybit.net>
-	* [r1025] macros/ac_python_devel.m4, swig/python/Makefile.am,
-	  swig/python/example.py, swig/python/geos.pth,
-	  swig/python/python.i, swig/ruby/test/geos_tests.rb: More patches
-	  from Charlie Savage
+	* [r1025] More patches from Charlie Savage
 2006-01-27 08:58  Sandro Santilli <strk at keybit.net>
-	* [r1024] configure.in: Python and Ruby build disable by default
-	  (until we've properly tested it)
+	* [r1024] Python and Ruby build disable by default (until we've
+	  properly tested it)
 2006-01-27 08:25  Sandro Santilli <strk at keybit.net>
-	* [r1023] macros/ac_python_devel.m4, swig/python/Makefile.am,
-	  swig/ruby/ruby.i: * Ruby - removes dependency on renames.i file
-	  which is no longer deleted
+	* [r1023] * Ruby - removes dependency on renames.i file which is no
+	  longer deleted
 	  and was removed from CVS last week
 	  * Python - fixes autoconf search for Python include path
 	  * Python - fixes autoconf search for Python lib directory on
@@ -13795,169 +8108,131 @@
 2006-01-22 22:48  Sandro Santilli <strk at keybit.net>
-	* [r1022] TODO: Added Safe's performance improvement idea for
+	* [r1022] Added Safe's performance improvement idea for
 	  CoordinateSequence
 2006-01-21 16:11  Sandro Santilli <strk at keybit.net>
-	* [r1021] NEWS: updated
+	* [r1021] updated
 2006-01-21 16:08  Sandro Santilli <strk at keybit.net>
-	* [r1020] source/io/ByteOrderValues.cpp: Fixed integer conversion
-	  bug (ported from JTS-1.7).
+	* [r1020] Fixed integer conversion bug (ported from JTS-1.7).
 	  Added last port information.
 2006-01-21 16:04  Sandro Santilli <strk at keybit.net>
-	* [r1019] source/test/hexwkb.xml: Added endian specification to
-	  case descriptions.
+	* [r1019] Added endian specification to case descriptions.
 	  All tests are Little Endian, should add the same
 	  tests with Big Endian format.
 2006-01-20 19:28  Sandro Santilli <strk at keybit.net>
-	* [r1018] source/operation/overlay/PolygonBuilder.cpp: Updated port
-	  information
+	* [r1018] Updated port information
 2006-01-20 19:21  Sandro Santilli <strk at keybit.net>
-	* [r1017] source/operation/overlay/PolygonBuilder.cpp: Fixed bug
-	  #13
+	* [r1017] Fixed bug #13
 2006-01-20 19:11  Sandro Santilli <strk at keybit.net>
-	* [r1016] source/operation/valid/IsValidOp.cpp,
-	  source/operation/valid/TopologyValidationError.cpp: Updated last
-	  port info
+	* [r1016] Updated last port info
 2006-01-20 17:20  Sandro Santilli <strk at keybit.net>
-	* [r1015] configure.in, macros/ruby.m4, swig/python/Makefile.am,
-	  swig/ruby/Makefile.am, swig/ruby/example.rb, swig/ruby/renames.i,
-	  swig/ruby/test/Makefile.am, swig/ruby/test/example.rb,
-	  swig/ruby/test/test_envelope.rb: More SWIG/python/ruby patches
+	* [r1015] More SWIG/python/ruby patches
 2006-01-20 00:59  Sandro Santilli <strk at keybit.net>
-	* [r1014] source/io/WKBReader.cpp: Better debugging
+	* [r1014] Better debugging
-	* [r1013] source/test/hexwkb.xml: PrecisionModel made FLOATING
+	* [r1013] PrecisionModel made FLOATING
 2006-01-18 17:49  Sandro Santilli <strk at keybit.net>
-	* [r1012] source/test/XMLTester.cpp, source/test/XMLTester.h:
-	  Reworked XMLTester to be quiet by default. Use -v switch to make
-	  it verbose.
+	* [r1012] Reworked XMLTester to be quiet by default. Use -v switch
+	  to make it verbose.
 2006-01-18 17:47  Sandro Santilli <strk at keybit.net>
-	* [r1011] source/test/hexwkb.xml: Added GEOMETRYCOLLECTION test
+	* [r1011] Added GEOMETRYCOLLECTION test
-	* [r1010] source/test/Makefile.am: Added another local test to the
-	  test rule
+	* [r1010] Added another local test to the test rule
 2006-01-18 17:46  Sandro Santilli <strk at keybit.net>
-	* [r1009] source/io/WKTWriter.cpp: Fixed leak in
-	  ::writeFormatted(Geometry *)
+	* [r1009] Fixed leak in ::writeFormatted(Geometry *)
 2006-01-18 17:45  Sandro Santilli <strk at keybit.net>
-	* [r1008] source/io/WKBReader.cpp: more debugging lines
+	* [r1008] more debugging lines
 2006-01-18 13:23  Sandro Santilli <strk at keybit.net>
-	* [r1007] source/io/WKBReader.cpp: Set binary flag for stringstream
-	  used in ::readHEX()
+	* [r1007] Set binary flag for stringstream used in ::readHEX()
 2006-01-18 12:54  Sandro Santilli <strk at keybit.net>
-	* [r1006] source/test/Makefile.am, source/test/XMLTester.cpp,
-	  source/test/XMLTester.h, source/test/hexwkb.xml: Added HEXWKB
-	  support in XMLTester. Added a simple test in HEXWKB form
+	* [r1006] Added HEXWKB support in XMLTester. Added a simple test in
+	  HEXWKB form
 	  and a 'test' rule running the locally-available tests and showing
 	  result summay.
 2006-01-18 10:02  Sandro Santilli <strk at keybit.net>
-	* [r1005] macros/ac_python_devel.m4: Added missing macro file
+	* [r1005] Added missing macro file
 2006-01-17 12:03  Sandro Santilli <strk at keybit.net>
-	* [r1004] configure.in, macros/ac_pkg_swig.m4: Modified
-	  AC_PROG_SWIG macro to set SWIG to the empty string
+	* [r1004] Modified AC_PROG_SWIG macro to set SWIG to the empty
+	  string
 	  on error (rather then making it echo an error and return false).
 	  SWIG version 1.3.28 or up required in order to build SWIG-based
 	  extensions.
 2006-01-16 18:34  Sandro Santilli <strk at keybit.net>
-	* [r1003] autogen.sh, configure.in, macros/ac_pkg_swig.m4,
-	  macros/python.m4, swig/python, swig/python/.cvsignore,
-	  swig/python/Makefile.am, swig/python/python.i,
-	  swig/ruby/Makefile.am: Added initial conditional build of python
-	  and ruby wrappers
+	* [r1003] Added initial conditional build of python and ruby
+	  wrappers
 2006-01-15 23:01  Sandro Santilli <strk at keybit.net>
-	* [r1001] NEWS, configure.in, swig/Makefile.am, swig/geos.i,
-	  swig/ruby, swig/ruby/.cvsignore, swig/ruby/Makefile,
-	  swig/ruby/Makefile.am, swig/ruby/renames.i, swig/ruby/ruby.i,
-	  swig/ruby/test, swig/ruby/test/.cvsignore,
-	  swig/ruby/test/Makefile.am: Added bare build/install/dist scripts
-	  support for ruby interface
+	* [r1001] Added bare build/install/dist scripts support for ruby
+	  interface
 2006-01-15 21:23  Sandro Santilli <strk at keybit.net>
-	* [r1000] swig/ruby/test, swig/ruby/test/geos_tests.rb,
-	  swig/ruby/test/test_combinations.rb,
-	  swig/ruby/test/test_helper.rb, swig/ruby/test/test_io.rb,
-	  swig/ruby/test/test_operations.rb,
-	  swig/ruby/test/test_relations.rb, swig/ruby/test/test_simple.rb:
-	  Initial import of ruby unit tests
+	* [r1000] Initial import of ruby unit tests
 2006-01-15 21:22  Sandro Santilli <strk at keybit.net>
-	* [r999] source/geom/Envelope.cpp, source/headers/geos/geom.h:
-	  Added Envelope constructor by string (accepting what's returned
-	  by ::toString)
+	* [r999] Added Envelope constructor by string (accepting what's
+	  returned by ::toString)
 2006-01-15 21:19  Sandro Santilli <strk at keybit.net>
-	* [r998] source/headers/geos/io.h, source/io/WKBReader.cpp,
-	  source/io/WKBWriter.cpp: Added WKBWriter::writeHEX() and
-	  WKBReader::readHEX()
+	* [r998] Added WKBWriter::writeHEX() and WKBReader::readHEX()
 2006-01-12 11:44  Sandro Santilli <strk at keybit.net>
-	* [r997] NEWS: synced after 2.2.1 release
+	* [r997] synced after 2.2.1 release
-	* [r996] source/capi/geos_c.cpp: Removed double call to ::isValid
+	* [r996] Removed double call to ::isValid
 2006-01-08 15:39  Sandro Santilli <strk at keybit.net>
-	* [r994] source/capi/geos_c.cpp: Changed finite() function call
-	  with FINITE() macro.
+	* [r994] Changed finite() function call with FINITE() macro.
 2006-01-08 15:24  Sandro Santilli <strk at keybit.net>
-	* [r993] source/geomgraph/EdgeIntersectionList.cpp,
-	  source/headers/geos/geomgraph.h, source/operation/IsSimpleOp.cpp,
-	  source/util/GeometricShapeFactory.cpp: Changed container-related
-	  typedef to class-scoped STL-like typedefs.
+	* [r993] Changed container-related typedef to class-scoped STL-like
+	  typedefs.
 	  Fixed const correctness of EdgeIntersectionList::begin() and
 	  ::end() consts;
 	  defined M_PI when undef as suggested by Charlie Savage.
@@ -13965,97 +8240,75 @@
 2005-12-22 12:46  Sandro Santilli <strk at keybit.net>
-	* [r992] swig/README.txt, swig/geos.i, swig/ruby,
-	  swig/ruby/Makefile, swig/ruby/README.txt, swig/ruby/example.rb,
-	  swig/ruby/renames.i, swig/ruby/ruby.i: Imported Charlie Savage
-	  new ruby wrapper and swig changes
+	* [r992] Imported Charlie Savage new ruby wrapper and swig changes
 2005-12-14 11:22  Sandro Santilli <strk at keybit.net>
-	* [r991] HOWTO_RELEASE: Added a note about the need to *always*
-	  increment CAPI version
+	* [r991] Added a note about the need to *always* increment CAPI
+	  version
 2005-12-14 02:32  Sandro Santilli <strk at keybit.net>
-	* [r990] HOWTO_RELEASE, source/algorithm/ConvexHull.cpp: New entry
+	* [r990] New entry
 2005-12-13 23:59  Sandro Santilli <strk at keybit.net>
-	* [r989] source/capi/geos_c.h.in: Removed INTERFACE_* defines
-	  (obsoleted).
+	* [r989] Removed INTERFACE_* defines (obsoleted).
 	  Made GEOSCoordSeq_clone() arg const (won't change ABI, it's C
 	  world, lucky ;)
 2005-12-13 23:03  Sandro Santilli <strk at keybit.net>
-	* [r988] source/capi/geos_c.cpp: Removed conditional blocks based
-	  on GEOS version (we're always
+	* [r988] Removed conditional blocks based on GEOS version (we're
+	  always
 	  in sync). This fixed an annoying problem introduced since
 	  INTERFACE_LAST
 	  and INTERFACE_CURREN were taken off geos/version.h
 2005-12-12 09:32  Sandro Santilli <strk at keybit.net>
-	* [r987] configure.in, source/geom/Makefile.am,
-	  source/headers/geos/version.h.in: Switched to -release mode for
-	  C++ library versioning.
+	* [r987] Switched to -release mode for C++ library versioning.
 	  Every release will be binary-incompatible with previous.
 	  Removed GEOS_FIRST_INTERFACE and GEOS_LAST_INTERFACE defines
 	  from geos/version.h.
 2005-12-11 10:41  Sandro Santilli <strk at keybit.net>
-	* [r984] source/operation/overlay/ElevationMatrix.cpp,
-	  premature initialization of average Z value in
+	* [r984] Fixed premature initialization of average Z value in
 2005-12-11 10:38  Sandro Santilli <strk at keybit.net>
-	* [r983] configure.in: Fixed mungled versions (1.0.0/3.0.1 =>
-	  1.0.1/3.0.0)
+	* [r983] Fixed mungled versions (1.0.0/3.0.1 => 1.0.1/3.0.0)
 2005-12-10 16:07  Sandro Santilli <strk at keybit.net>
-	* [r981] source/capi/geos_c.cpp: Unkown -> Unknown typo fix
+	* [r981] Unkown -> Unknown typo fix
 2005-12-09 13:24  Sandro Santilli <strk at keybit.net>
-	* [r980] configure.in: Capi lib version set to 1.0.1 (due to leak
-	  fix in GEOSHasZ)
+	* [r980] Capi lib version set to 1.0.1 (due to leak fix in
+	  GEOSHasZ)
 2005-12-09 11:36  Sandro Santilli <strk at keybit.net>
-	* [r977] NEWS, source/capi/geos_c.cpp,
-	  source/operation/polygonize/PolygonizeGraph.cpp: Small leak
-	  plugged in CAPI::GEOSHasZ() and in
+	* [r977] Small leak plugged in CAPI::GEOSHasZ() and in
 	  invalid input to PolygonizeGraph (again)
 2005-12-09 10:32  Sandro Santilli <strk at keybit.net>
-	* [r974] source/operation/polygonize/Polygonizer.cpp: Cleaned up
-	  debugging line left over from previous commit
+	* [r974] Cleaned up debugging line left over from previous commit
 2005-12-09 10:03  Sandro Santilli <strk at keybit.net>
-	* [r972] NEWS, source/operation/polygonize/PolygonizeGraph.cpp,
-	  source/operation/polygonize/Polygonizer.cpp: Fixed a bug making
-	  PolygonizeGraph choking on invalid LineStrings.
+	* [r972] Fixed a bug making PolygonizeGraph choking on invalid
+	  LineStrings.
 	  Minor optimizations in Polygonizer loops.
 2005-12-08 14:14  Sandro Santilli <strk at keybit.net>
-	* [r971] NEWS, source/geom/DefaultCoordinateSequence.cpp,
-	  source/geom/GeometryCollection.cpp, source/geom/LineString.cpp,
-	  source/headers/geos/geom.h, source/headers/geos/opOverlay.h,
-	  source/util/UniqueCoordinateArrayFilter.cpp:
-	  ElevationMatrixFilter used for both elevation and Matrix fill,
+	* [r971] ElevationMatrixFilter used for both elevation and Matrix
+	  fill,
 	  thus removing CoordinateSequence copy in
 	  ElevetaionMatrix::add(Geometry *).
 	  Changed CoordinateFilter::filter_rw to be a const method: updated
@@ -14063,41 +8316,33 @@
 2005-12-08 01:39  Sandro Santilli <strk at keybit.net>
-	* [r970] NEWS, source/headers/geos/noding.h,
-	  source/noding/Noder.cpp, source/noding/SegmentString.cpp:
-	  SegmentString::eiList made a real object rather then a pointer.
+	* [r970] SegmentString::eiList made a real object rather then a
+	  pointer.
 	  Adde getter for const and non-const references of it (dropping
 	  get by pointer)
 2005-12-08 01:11  Sandro Santilli <strk at keybit.net>
-	* [r969] source/geomgraph/EdgeIntersectionList.cpp: minor
-	  optimizations in loops
+	* [r969] minor optimizations in loops
 2005-12-08 00:24  Sandro Santilli <strk at keybit.net>
-	* [r968] source/geomgraph/EdgeIntersectionList.cpp: Reduced
-	  coordinate assignments in ::createSplitEdge
+	* [r968] Reduced coordinate assignments in ::createSplitEdge
 2005-12-08 00:03  Sandro Santilli <strk at keybit.net>
-	* [r967] NEWS, source/headers/geos/opOverlay.h,
-	  source/operation/overlay/LineBuilder.cpp:
-	  LineBuilder::lineEdgesList made a real vector, rather then
+	* [r967] LineBuilder::lineEdgesList made a real vector, rather then
 	  pointer (private member).
 	  Small optimizations in LineBuilder loops, cleanups in LineBuilder
 	  class dox.
 2005-12-07 23:36  Sandro Santilli <strk at keybit.net>
-	* [r966] source/geomgraph/EdgeIntersection.cpp: standard
-	  indentation
+	* [r966] standard indentation
 2005-12-07 22:52  Sandro Santilli <strk at keybit.net>
-	* [r965] NEWS, source/geom/DefaultCoordinateSequence.cpp,
-	  source/geom/LineString.cpp, source/headers/geos/geom.h: Added
-	  CoordinateSequence::apply_rw(CoordinateFilter *) and
+	* [r965] Added CoordinateSequence::apply_rw(CoordinateFilter *) and
 	  CoordinateSequence::apply_ro(CoordinateFilter *) const
 	  to reduce coordinate copies on read-write CoordinateFilter
 	  applications (previously required getAt()/setAt() calls).
@@ -14106,35 +8351,28 @@
 2005-12-07 21:55  Sandro Santilli <strk at keybit.net>
-	* [r964] source/geom/CoordinateSequence.cpp: Optimized memory
-	  allocations in ::removeRepeatedPoints
+	* [r964] Optimized memory allocations in ::removeRepeatedPoints
 2005-12-07 20:52  Sandro Santilli <strk at keybit.net>
-	* [r963] source/geomgraph/GeometryGraph.cpp: minor container
-	  methods call reduction
+	* [r963] minor container methods call reduction
 2005-12-07 20:51  Sandro Santilli <strk at keybit.net>
-	* [r962] source/geomgraph/EdgeEndStar.cpp: removed dead code
+	* [r962] removed dead code
-	* [r961] source/geomgraph/DirectedEdgeStar.cpp: minor cleanups
+	* [r961] minor cleanups
 2005-12-07 20:49  Sandro Santilli <strk at keybit.net>
-	* [r960] source/geomgraph/Edge.cpp: Oops, removed Coordinate copies
-	  introduced by recent code cleanups
+	* [r960] Oops, removed Coordinate copies introduced by recent code
+	  cleanups
 2005-12-07 19:18  Sandro Santilli <strk at keybit.net>
-	* [r959] NEWS, source/geomgraph/EdgeList.cpp,
-	  source/geomgraph/PlanarGraph.cpp, source/headers/geos/geom.h,
-	  source/operation/valid/ConnectedInteriorTester.cpp: Changed
-	  PlanarGraph::addEdges and EdgeList::addAll to take
+	* [r959] Changed PlanarGraph::addEdges and EdgeList::addAll to take
 	  a const vector by reference rather then a non-const vector by
 	  pointer.
 	  Optimized polygon vector allocations in
@@ -14142,210 +8380,136 @@
 2005-12-06 10:24  Sandro Santilli <strk at keybit.net>
-	* [r958] Makefile.am, NEWS, configure.in, source/capi/Makefile.am,
-	  source/geom/Makefile.am: Added acsite.m4 to distribution.
+	* [r958] Added acsite.m4 to distribution.
 	  Added macros and flags required to build on mingw arch.
 2005-11-30 16:07  Sandro Santilli <strk at keybit.net>
-	* [r955] source/capi, source/capi/.cvsignore: Added geos_c.h
+	* [r955] Added geos_c.h
 2005-11-30 16:03  Sandro Santilli <strk at keybit.net>
-	* [r951] tools/geos-config.in: Added --ldflags
+	* [r951] Added --ldflags
 2005-11-30 16:01  Sandro Santilli <strk at keybit.net>
-	* [r949] README: Updated with C-API usage
+	* [r949] Updated with C-API usage
 2005-11-30 11:27  Sandro Santilli <strk at keybit.net>
-	* [r945] doc/example.cpp: catch std::exception by ref
+	* [r945] catch std::exception by ref
 2005-11-30 11:25  Sandro Santilli <strk at keybit.net>
-	* [r944] doc/example.cpp: includes cleanup
+	* [r944] includes cleanup
 2005-11-29 23:01  Sandro Santilli <strk at keybit.net>
-	* [r942] NEWS: updated moving some items to 2.2.0
+	* [r942] updated moving some items to 2.2.0
 2005-11-29 15:45  Sandro Santilli <strk at keybit.net>
-	* [r936] source/geomgraph/TopologyLocation.cpp,
-	  source/headers/geos/geomgraph.h: Fixed signedness of
-	  TopologyLocation methods, cleanups.
+	* [r936] Fixed signedness of TopologyLocation methods, cleanups.
 2005-11-29 15:16  Sandro Santilli <strk at keybit.net>
-	* [r935] ChangeLog, source/algorithm/MinimumDiameter.cpp,
-	  source/headers/geos/geosAlgorithm.h: Fixed sign-related warnings
-	  and signatures.
+	* [r935] Fixed sign-related warnings and signatures.
 2005-11-29 14:49  Sandro Santilli <strk at keybit.net>
-	* [r934] NEWS: More info
+	* [r934] More info
 2005-11-29 14:44  Sandro Santilli <strk at keybit.net>
-	* [r933] NEWS: Updated
+	* [r933] Updated
 2005-11-29 14:39  Sandro Santilli <strk at keybit.net>
-	* [r932] source/geomgraph/Edge.cpp,
-	  source/headers/geos/geomgraph.h: Removed number of points cache
-	  in Edge, replaced with local caches.
+	* [r932] Removed number of points cache in Edge, replaced with
+	  local caches.
-	* [r931] source/geom/CoordinateSequence.cpp,
-	  source/geom/DefaultCoordinateSequence.cpp: More signed/unsigned
-	  fixes
+	* [r931] More signed/unsigned fixes
 2005-11-29 13:39  Sandro Santilli <strk at keybit.net>
-	* [r930] source/headers/geos/geom.h, source/headers/geos/io.h:
-	  Moved byte typedef from geom.h to io.h.
+	* [r930] Moved byte typedef from geom.h to io.h.
 	  Removed useless commas at inlined funx end.
 	  Changed CoordinateSequenceFactory::create(siz,dims) to use
 	  unsigned for dims.
 2005-11-29 11:18  Sandro Santilli <strk at keybit.net>
-	* [r929] NEWS: organized changes info
+	* [r929] organized changes info
 2005-11-29 00:48  Sandro Santilli <strk at keybit.net>
-	* [r928] source/geomgraph/DirectedEdgeStar.cpp,
-	  source/geomgraph/EdgeEndStar.cpp, source/geomgraph/Node.cpp,
-	  source/operation/buffer/BufferSubgraph.cpp,
-	  source/operation/valid/ConsistentAreaTester.cpp: Removed edgeList
-	  cache from EdgeEndRing. edgeMap is enough.
+	* [r928] Removed edgeList cache from EdgeEndRing. edgeMap is
+	  enough.
 	  Restructured iterated access by use of standard ::iterator
 	  abstraction
 	  with scoped typedefs.
 2005-11-28 18:37  Sandro Santilli <strk at keybit.net>
-	* [r927] source/geom/LineString.cpp: Minor warning removal
+	* [r927] Minor warning removal
 2005-11-25 12:22  Sandro Santilli <strk at keybit.net>
-	* [r926] NEWS, source/test/XMLTester.cpp, source/test/XMLTester.h:
-	  Made XMLTester able to run multiple test files and keep overall
+	* [r926] Made XMLTester able to run multiple test files and keep
+	  overall
 	  counters.
 2005-11-25 11:40  Sandro Santilli <strk at keybit.net>
-	* [r925] source/precision/SimpleGeometryPrecisionReducer.cpp:
-	  Another getSize in for loop, another int-unsigned int warning
+	* [r925] Another getSize in for loop, another int-unsigned int
+	  warning
 2005-11-25 11:31  Sandro Santilli <strk at keybit.net>
-	* [r924] source/algorithm/InteriorPointArea.cpp,
-	  source/noding/NodingValidator.cpp, source/noding/SimpleNoder.cpp,
-	  source/operation/buffer/RightmostEdgeFinder.cpp,
-	  source/operation/valid/ConnectedInteriorTester.cpp,
-	  source/operation/valid/RepeatedPointTester.cpp: Removed all
-	  CoordinateSequence::getSize() calls embedded in for loops.
+	* [r924] Removed all CoordinateSequence::getSize() calls embedded
+	  in for loops.
 2005-11-25 11:30  Sandro Santilli <strk at keybit.net>
-	* [r923] source/geomgraph/Edge.cpp: Fix in ::equals() - this
-	  finally passes testLeaksBig.xml tests
+	* [r923] Fix in ::equals() - this finally passes testLeaksBig.xml
+	  tests
 2005-11-25 09:57  Sandro Santilli <strk at keybit.net>
-	* [r922] source/geom/GeometryCollection.cpp: Fixed bug in
-	  getCoordinates() [ introduced by previous commit ]
+	* [r922] Fixed bug in getCoordinates() [ introduced by previous
+	  commit ]
 2005-11-24 23:43  Sandro Santilli <strk at keybit.net>
-	* [r921] source/geomgraph/Edge.cpp,
-	  source/headers/geos/geomgraph.h: Yes another fix, sorry. Missing
-	  const-correctness.
+	* [r921] Yes another fix, sorry. Missing const-correctness.
 2005-11-24 23:24  Sandro Santilli <strk at keybit.net>
-	* [r920] source/geomgraph/Edge.cpp,
-	  source/headers/geos/geomgraph.h: Fixed equals() function [
-	  optimized in previous commit, but unchecked ]
+	* [r920] Fixed equals() function [ optimized in previous commit,
+	  but unchecked ]
-	* [r919] NEWS: Added note about CoordinateSequence signed->unsigned
+	* [r919] Added note about CoordinateSequence signed->unsigned
 	  change in API
 2005-11-24 23:09  Sandro Santilli <strk at keybit.net>
-	* [r918] source/algorithm/CGAlgorithms.cpp,
-	  source/algorithm/PointLocator.cpp,
-	  source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
-	  source/geom/GeometryFactory.cpp, source/geom/LineString.cpp,
-	  source/geom/Polygon.cpp, source/geomgraph/Edge.cpp,
-	  source/geomgraph/EdgeRing.cpp,
-	  source/noding/snapround/SimpleSegmentStringsSnapper.cpp:
-	  CoordinateSequence indexes switched from int to the more
+	* [r918] CoordinateSequence indexes switched from int to the more
 	  the correct unsigned int. Optimizations here and there
 	  to avoid calling getSize() in loops.
 	  Update of all callers is not complete yet.
 2005-11-24 23:07  Sandro Santilli <strk at keybit.net>
-	* [r917] source/algorithm/CentroidLine.cpp,
-	  source/headers/geos/geosAlgorithm.h: CentroidLine made concrete
-	  class (only destructor was virtual) - avoided heap allocation for
-	  owned Coordinate centSum
+	* [r917] CentroidLine made concrete class (only destructor was
+	  virtual) - avoided heap allocation for owned Coordinate centSum
 2005-11-21 16:03  Sandro Santilli <strk at keybit.net>
-	* [r916] source/algorithm/CentroidArea.cpp,
-	  source/algorithm/LineIntersector.cpp, source/geom/Coordinate.cpp,
-	  source/geom/LineSegment.cpp, source/geom/Polygon.cpp,
-	  source/geomgraph/DirectedEdgeStar.cpp,
-	  source/geomgraph/EdgeEnd.cpp, source/geomgraph/EdgeEndStar.cpp,
-	  source/headers/geos/geosAlgorithm.h,
-	  source/operation/overlay/OverlayNodeFactory.cpp,
-	  source/operation/valid/IsValidOp.cpp: Coordinate interface
-	  change:
+	* [r916] Coordinate interface change:
 	  Removed setCoordinate call, use assignment operator
 	  instead. Provided a compile-time switch to
 	  make copy ctor and assignment operators non-inline
@@ -14383,12 +8547,7 @@
 2005-11-18 00:55  Sandro Santilli <strk at keybit.net>
-	* [r915] source/geomgraph/EdgeRing.cpp,
-	  source/headers/geos/geomgraph.h, source/headers/geos/opOverlay.h,
-	  source/operation/overlay/PolygonBuilder.cpp: Fixed a bug in
-	  EdgeRing::containsPoint().
+	* [r915] Fixed a bug in EdgeRing::containsPoint().
 	  Changed EdgeRing::getLinearRing() to avoid LinearRing copy and
 	  updated
 	  usages from PolygonBuilder.
@@ -14400,389 +8559,279 @@
 2005-11-16 22:21  Sandro Santilli <strk at keybit.net>
-	* [r913] source/geomgraph/EdgeEnd.cpp,
-	  source/geomgraph/EdgeIntersection.cpp,
-	  source/operation/valid/IsValidOp.cpp: enforced const-correctness
-	  and use of initializer lists.
+	* [r913] enforced const-correctness and use of initializer lists.
 2005-11-16 15:49  Sandro Santilli <strk at keybit.net>
-	* [r912] source/geomgraph/Edge.cpp,
-	  source/headers/geos/geomgraph.h, source/headers/geos/opValid.h,
-	  source/operation/overlay/EdgeSetNoder.cpp,
-	  source/operation/valid/IsValidOp.cpp: Reduced gratuitous heap
-	  allocations.
+	* [r912] Reduced gratuitous heap allocations.
 2005-11-15 18:30  Sandro Santilli <strk at keybit.net>
-	* [r911] source/algorithm/LineIntersector.cpp,
-	  source/geomgraph/Label.cpp,
-	  source/geomgraph/TopologyLocation.cpp,
-	  source/headers/geos/geosAlgorithm.h: Removed dead code
+	* [r911] Removed dead code
 2005-11-15 12:14  Sandro Santilli <strk at keybit.net>
-	* [r909] source/headers/geos/opOverlay.h,
-	  source/operation/overlay/PointBuilder.cpp,
-	  source/planargraph/planarPlanarGraph.cpp: Reduced heap
-	  allocations, made use of references when appropriate,
+	* [r909] Reduced heap allocations, made use of references when
+	  appropriate,
 	  small optimizations here and there.
 2005-11-15 10:04  Sandro Santilli <strk at keybit.net>
-	* [r908] source/geomgraph/index/MonotoneChain.cpp,
-	  source/geomgraph/index/SegmentIntersector.cpp,
-	  source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
-	  source/geomgraph/index/SweepLineSegment.cpp,
-	  source/headers/geos/geomgraphindex.h: Reduced heap allocations
-	  (vectors, mostly).
+	* [r908] Reduced heap allocations (vectors, mostly).
 	  Enforced const-correctness, changed some interfaces
 	  to use references rather then pointers when appropriate.
 2005-11-15 10:02  Sandro Santilli <strk at keybit.net>
-	* [r907] source/geom/LineString.cpp: optimized envelope computation
-	  reducing virtual calls
+	* [r907] optimized envelope computation reducing virtual calls
 2005-11-14 18:14  Sandro Santilli <strk at keybit.net>
-	* [r906] source/geomgraph/Depth.cpp,
-	  source/geomgraph/DirectedEdge.cpp,
-	  source/geomgraph/DirectedEdgeStar.cpp, source/geomgraph/Edge.cpp,
-	  source/geomgraph/EdgeIntersectionList.cpp,
-	  source/geomgraph/Node.cpp, source/geomgraph/TopologyLocation.cpp,
-	  source/operation/relate/EdgeEndBundle.cpp: Reduced heap
-	  allocations made by TopologyLocation and Label objects.
+	* [r906] Reduced heap allocations made by TopologyLocation and
+	  Label objects.
 	  Enforced const-correctness on GraphComponent.
 	  Cleanups.
 2005-11-10 16:26  Sandro Santilli <strk at keybit.net>
-	* [r904] source/io/WKBReader.cpp: Fixed printHEX (was printing one
-	  char past the WKB)
+	* [r904] Fixed printHEX (was printing one char past the WKB)
 2005-11-10 15:20  Sandro Santilli <strk at keybit.net>
-	* [r903] source/headers/geos/geomUtil.h,
-	  source/headers/geos/precision.h: Made virtual overloads explicit.
+	* [r903] Made virtual overloads explicit.
 2005-11-10 10:47  Sandro Santilli <strk at keybit.net>
-	* [r902] source/geom/MultiPoint.cpp, source/headers/geos/geom.h:
-	  Renamed MultiPoint::getCoordinate(int) to
+	* [r902] Renamed MultiPoint::getCoordinate(int) to
 	  MultiPoint::getCoordinateN(int)
 	  to avoid hiding of Geometry::getCoordinate().
 2005-11-10 10:24  Sandro Santilli <strk at keybit.net>
-	* [r901] source/headers/geos/util.h,
-	  source/util/CoordinateArrayFiter.cpp: Fixed virtual overload of
-	  CoordinateArrayFilter::filter*
+	* [r901] Fixed virtual overload of CoordinateArrayFilter::filter*
 2005-11-10 09:33  Sandro Santilli <strk at keybit.net>
-	* [r900] source/geom/LineString.cpp, source/headers/geos/geom.h:
-	  Removed virtual overloading LineString::compareTo(LineString *)
+	* [r900] Removed virtual overloading
+	  LineString::compareTo(LineString *)
 2005-11-09 15:14  Sandro Santilli <strk at keybit.net>
-	* [r899] source/operation/buffer/DepthSegment.cpp: Forgot to add
-	  this
+	* [r899] Forgot to add this
 2005-11-09 13:44  Sandro Santilli <strk at keybit.net>
-	* [r898] source/geomgraph/Node.cpp, source/geomgraph/NodeMap.cpp,
-	  source/headers/geos/geomgraph.h: Cleanups in Node and NodeMap.
+	* [r898] Cleanups in Node and NodeMap.
 	  Optimization of EdgeIntersectionLessThen.
 2005-11-09 08:57  Sandro Santilli <strk at keybit.net>
-	* [r897] source/geom/IntersectionMatrix.cpp,
-	  source/headers/geos/geom.h: IntersectionMatrix made a concrete
-	  and final type.
+	* [r897] IntersectionMatrix made a concrete and final type.
 	  Cleanups in class definition.
 2005-11-08 20:12  Sandro Santilli <strk at keybit.net>
-	* [r896] NEWS, source/geom/Makefile.am, source/headers/geos/geom.h,
-	  source/operation/buffer/SubgraphDepthLocater.cpp: Memory overhead
-	  reductions in buffer operations.
+	* [r896] Memory overhead reductions in buffer operations.
 2005-11-08 12:32  Sandro Santilli <strk at keybit.net>
-	* [r895] source/geom/DefaultCoordinateSequence.cpp: Cleanups,
-	  ::setPoint small improvement
+	* [r895] Cleanups, ::setPoint small improvement
 2005-11-08 11:33  Sandro Santilli <strk at keybit.net>
-	* [r894] source/operation/overlay/OverlayOp.cpp: comments cleanup
+	* [r894] comments cleanup
 2005-11-08 10:26  Sandro Santilli <strk at keybit.net>
-	* [r893] configure.in: Library versioning took back to 3.0.0
+	* [r893] Library versioning took back to 3.0.0
 2005-11-08 10:03  Sandro Santilli <strk at keybit.net>
-	* [r892] configure.in, doc/Doxyfile.in, source/geom/Envelope.cpp,
-	  source/geom/Geometry.cpp, source/headers/geos/geom.h: Set library
-	  version to 2.2.0.
+	* [r892] Set library version to 2.2.0.
 	  Cleaned up Doxygen warnings.
 	  Inlined more Envelope methods.
 	  Dropped deprecated Envelope::overlaps methods.
 2005-11-07 18:07  Sandro Santilli <strk at keybit.net>
-	* [r890] configure.in: Removed VisualStudio knowledge from
-	  configure script
+	* [r890] Removed VisualStudio knowledge from configure script
 2005-11-07 18:05  Sandro Santilli <strk at keybit.net>
-	* [r889] source/geomgraph/EdgeIntersectionList.cpp,
-	  source/headers/geos/noding.h, source/noding/SegmentNodeList.cpp:
-	  Reduced set<> lookups
+	* [r889] Reduced set<> lookups
 2005-11-07 13:17  frank
-	* [r888] VisualStudio: no longer used
+	* [r888] no longer used
-	* [r887] Makefile.am: removed VisualStudio, no longer distributed
+	* [r887] removed VisualStudio, no longer distributed
 2005-11-07 13:16  frank
-	* [r886] VisualStudio/.cvsignore: obsolete
+	* [r886] obsolete
 2005-11-07 12:31  Sandro Santilli <strk at keybit.net>
-	* [r885] NEWS, source/geomgraph/Edge.cpp,
-	  source/geomgraph/index/SweepLineEvent.cpp,
-	  source/headers/geos/geomgraphindex.h,
-	  source/headers/geos/opValid.h, source/operation/IsSimpleOp.cpp,
-	  source/operation/valid/IsValidOp.cpp: Changed
-	  EdgeIntersectionList to use a set<> rathern then a vector<>, and
+	* [r885] Changed EdgeIntersectionList to use a set<> rathern then a
+	  vector<>, and
 	  to avoid dynamic allocation of initial header.
 	  Inlined short SweepLineEvent methods.
 2005-11-07 11:32  Sandro Santilli <strk at keybit.net>
-	* [r884] source/capi/geos_c.h.in: Added const qualifiers to
-	  function to reflect paradigm of immutable
+	* [r884] Added const qualifiers to function to reflect paradigm of
+	  immutable
 	  Geometry objects.
 2005-11-04 15:42  Sandro Santilli <strk at keybit.net>
-	* [r883] source/geomgraph/index/SweepLineEvent.cpp: Fixed bug in
-	  SweepLineEventLessThen functor
+	* [r883] Fixed bug in SweepLineEventLessThen functor
 	  (didn't conform to strict weak ordering).
 	  Note: this was introduced by previous commit.
 2005-11-04 11:06  Sandro Santilli <strk at keybit.net>
-	* [r882] NEWS: updated
+	* [r882] updated
 2005-11-04 11:04  Sandro Santilli <strk at keybit.net>
-	* [r881] source/headers/geos/opValid.h,
-	  source/operation/valid/SweeplineNestedRingTester.cpp,
-	  source/operation/valid/TopologyValidationError.cpp: Ported
-	  revision 1.38 of IsValidOp.java (adding closed Ring checks).
+	* [r881] Ported revision 1.38 of IsValidOp.java (adding closed Ring
+	  checks).
 	  Changed NestedRingTester classes to use Coorinate pointers
 	  rather then actual objects, to speedup NULL tests.
 	  Added JTS port revision when applicable.
 2005-11-04 08:28  Sandro Santilli <strk at keybit.net>
-	* [r880] NEWS, source/operation/overlay/OverlayOp.cpp: Ported
-	  speedup of OverlayOp::insertUniqueEdge() from JTS-1.7 (rev 1.23)
+	* [r880] Ported speedup of OverlayOp::insertUniqueEdge() from
+	  JTS-1.7 (rev 1.23)
 	  Updated NEWS file.
 2005-11-03 21:28  Sandro Santilli <strk at keybit.net>
-	* [r878] source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
-	  source/geomgraph/index/SimpleSweepLineIntersector.cpp: Fixed
-	  constructors broke by previous commit
+	* [r878] Fixed constructors broke by previous commit
 2005-11-03 19:51  Sandro Santilli <strk at keybit.net>
-	* [r877] source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
-	  source/headers/geos/geomgraphindex.h: Indentation changes, small
-	  vector memory allocation optimization.
+	* [r877] Indentation changes, small vector memory allocation
+	  optimization.
 2005-11-03 09:15  Sandro Santilli <strk at keybit.net>
-	* [r876] source/headers/geos/geom.h: Removed declaration of
-	  PointCoordinateSequence and PointCoordinateSequenceFactory
+	* [r876] Removed declaration of PointCoordinateSequence and
+	  PointCoordinateSequenceFactory
 2005-11-01 09:40  Sandro Santilli <strk at keybit.net>
-	* [r875] source/operation/valid/IsValidOp.cpp: Replaced finite()
-	  with FINITE() calls.
+	* [r875] Replaced finite() with FINITE() calls.
 2005-10-27 14:05  Sandro Santilli <strk at keybit.net>
-	* [r873] source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
-	  source/headers/geos/geomgraphindex.h: Added a
-	  SweepLineEventLessThen functor to be used by sort algorithm.
+	* [r873] Added a SweepLineEventLessThen functor to be used by sort
+	  algorithm.
 2005-10-24 13:28  Sandro Santilli <strk at keybit.net>
-	* [r872] source/capi/geos_c.cpp, source/capi/geos_c.h.in,
-	  source/capi/geostest.c: Changed constructors to take ownership of
-	  GEOSGeom and GEOSCoordSeq objects.
+	* [r872] Changed constructors to take ownership of GEOSGeom and
+	  GEOSCoordSeq objects.
 	  Changed inspectors to retain ownership of GEOSGeom and
 	  Added GEOSGeom_clone() method.
 2005-10-21 15:13  Sandro Santilli <strk at keybit.net>
-	* [r871] source/capi/geos_c.cpp, source/capi/geos_c.h.in: Added
-	  GEOSGeom_clone() function
+	* [r871] Added GEOSGeom_clone() function
 2005-10-21 12:14  Sandro Santilli <strk at keybit.net>
-	* [r870] source/capi/geos_c.h.in: Added missing GEOS_DLL specifiers
+	* [r870] Added missing GEOS_DLL specifiers
 2005-10-21 12:07  Sandro Santilli <strk at keybit.net>
-	* [r869] source/capi/geos_c.cpp, source/capi/geos_c.h.in,
-	  source/capi/geostest.c: Added fine-grained geometry constructors
-	  and GEOSCoordSeq abstract data type.
+	* [r869] Added fine-grained geometry constructors and GEOSCoordSeq
+	  abstract data type.
 	  Renamed GEOSmakeCollection to GEOSGeom_createCollection
 2005-10-21 09:02  Sandro Santilli <strk at keybit.net>
-	* [r868] configure.in: typo fixed
+	* [r868] typo fixed
 2005-10-21 02:46  frank
-	* [r867] AUTHORS: added myself to authors - isn't that cheeky!
+	* [r867] added myself to authors - isn't that cheeky!
 2005-10-21 02:45  frank
-	* [r866] README: added note on source\makefile.vc
+	* [r866] added note on source\makefile.vc
 2005-10-21 02:44  frank
-	* [r865] source/Makefile.vc: added a wee readme
+	* [r865] added a wee readme
 2005-10-21 02:41  frank
-	* [r864] source/Makefile.vc: added DLL building, and geostest.exe
+	* [r864] added DLL building, and geostest.exe
-	* [r863] source/capi/geos_c.h.in: need to DLL export C API
+	* [r863] need to DLL export C API
 2005-10-21 02:37  frank
-	* [r862] source/capi/geos_c.cpp: DLL Export functions
+	* [r862] DLL Export functions
-	* [r861] source/capi/geostest.c: avoid non-portable vasprintf, make
-	  big buffer static
+	* [r861] avoid non-portable vasprintf, make big buffer static
 2005-10-21 01:57  frank
-	* [r860] source/Makefile.vc: updated for 3.0.0 and added C API
+	* [r860] updated for 3.0.0 and added C API
 2005-10-20 20:37  frank
-	* [r859] source/headers/geos/platform.h.vc: added
-	  getMachineByteOrder(), convert to unix text mode
+	* [r859] added getMachineByteOrder(), convert to unix text mode
 2005-10-19 13:07  Sandro Santilli <strk at keybit.net>
-	* [r858] source/io/WKBReader.cpp: Added support for SRID flag in
-	  WKB (full EWKB is accepted now)
+	* [r858] Added support for SRID flag in WKB (full EWKB is accepted
+	  now)
 2005-10-19 12:59  Sandro Santilli <strk at keybit.net>
-	* [r857] source/headers/geos/io.h: Added input stream checks in
-	  ByteOrderDataInStream, throwing ParseException on unexpected EOF
+	* [r857] Added input stream checks in ByteOrderDataInStream,
+	  throwing ParseException on unexpected EOF
 2005-10-17 15:55  Sandro Santilli <strk at keybit.net>
-	* [r856] source/capi/geos_c.cpp, source/capi/geos_c.h.in: Added
-	  GetGeometryN, GetInteriorRingN, GetExteriorRing
+	* [r856] Added GetGeometryN, GetInteriorRingN, GetExteriorRing
 2005-10-17 14:37  Sandro Santilli <strk at keybit.net>
-	* [r855] source/capi/geos_c.h.in: Added comments on exception
-	  returns for Geometry info functions
+	* [r855] Added comments on exception returns for Geometry info
+	  functions
 2005-10-17 14:33  Sandro Santilli <strk at keybit.net>
-	* [r854] source/capi/geos_c.cpp: Added missing exception handlers
-	  from previous commit.
+	* [r854] Added missing exception handlers from previous commit.
 	  Fixed GEOSGeomTypeId signatures.
 2005-10-17 12:56  Sandro Santilli <strk at keybit.net>
-	* [r853] source/geom/Makefile.am: Removed GEOS_VERSION define
-	  (Geometry.cpp, the only file using this will use the one in
-	  version.h)
+	* [r853] Removed GEOS_VERSION define (Geometry.cpp, the only file
+	  using this will use the one in version.h)
 2005-10-17 12:55  Sandro Santilli <strk at keybit.net>
-	* [r852] source/capi/geos_c.h.in: Fixed GEOSGeom typedef to be
-	  accepted by C++ compilers, added extern "C" namespace for
-	  inclusion by C++ code (really needed?)
+	* [r852] Fixed GEOSGeom typedef to be accepted by C++ compilers,
+	  added extern "C" namespace for inclusion by C++ code (really
+	  needed?)
 2005-10-17 09:38  Sandro Santilli <strk at keybit.net>
-	* [r851] source/capi/geos_c.cpp, source/capi/geos_c.h.in,
-	  source/capi/geostest.c: Added GEOSDistance() function.
+	* [r851] Added GEOSDistance() function.
 	  Trapped all exceptions and reported using ERROR_MESSAGE rather
 	  then NOTICE_MESSAGE.
 	  Changed WKB functions to use 'unsigned char' rather then 'char'
@@ -14790,31 +8839,28 @@
 2005-09-28 16:33  Sandro Santilli <strk at keybit.net>
-	* [r850] source/capi/geos_c.cpp: Added GEOS_setWKBOutputDims(int)
-	  function to specify coordinate
+	* [r850] Added GEOS_setWKBOutputDims(int) function to specify
+	  coordinate
 	  dimension in WKB output.
 2005-09-28 10:15  Sandro Santilli <strk at keybit.net>
-	* [r849] source/headers/geos/io.h, source/io/WKBWriter.cpp:
-	  WKBWriter ctor out-lined (will require changes in the near
+	* [r849] WKBWriter ctor out-lined (will require changes in the near
 	  future, for higher dimensions support), added support for 3d WKB
 	  output
 2005-09-28 09:36  Sandro Santilli <strk at keybit.net>
-	* [r848] source/io/WKBReader.cpp: Cleanups in the printHEX function
+	* [r848] Cleanups in the printHEX function
 2005-09-27 16:29  Sandro Santilli <strk at keybit.net>
-	* [r847] source/io/WKBReader.cpp: Ported JTS-1.7 use of
-	  PrecisionModel in WKBReader
+	* [r847] Ported JTS-1.7 use of PrecisionModel in WKBReader
 2005-09-27 16:20  Sandro Santilli <strk at keybit.net>
-	* [r846] doc/example.cpp, source/capi/geos_c.cpp,
-	  source/headers/geos/io.h, source/io/WKBReader.cpp: Reverted
-	  previous change, fixed the bug by turning WKBReader.factory
+	* [r846] Reverted previous change, fixed the bug by turning
+	  WKBReader.factory
 	  into a reference rather then a real object. ABI still breaks, but
 	  API
 	  at least is safe (we didn't release any WKB-aware package so
@@ -14823,269 +8869,202 @@
 2005-09-27 16:00  Sandro Santilli <strk at keybit.net>
-	* [r845] doc/example.cpp, source/capi/geos_c.cpp,
-	  source/headers/geos/io.h, source/io/WKBReader.cpp: Fixed bug in
-	  WKBReader destroying the GeometryFactory used in Geometry
+	* [r845] Fixed bug in WKBReader destroying the GeometryFactory used
+	  in Geometry
 	  construction. Changed it's definition to *require* a
 	  GeometryFactory
 	  pointer parameter.
 2005-09-27 08:51  Sandro Santilli <strk at keybit.net>
-	* [r844] source/test/Makefile.am: Added XMLTester.h in
-	  XMLTester_SOURCES list
+	* [r844] Added XMLTester.h in XMLTester_SOURCES list
 2005-09-26 14:40  Sandro Santilli <strk at keybit.net>
-	* [r843] source/io/WKBReader.cpp: Fixed handling of higher
-	  dimensional WKB streams
+	* [r843] Fixed handling of higher dimensional WKB streams
 2005-09-26 13:46  Sandro Santilli <strk at keybit.net>
-	* [r842] source/capi/Makefile.am: Modified GEOS_CAPI_VERSION to
-	  include underlying GEOS version
+	* [r842] Modified GEOS_CAPI_VERSION to include underlying GEOS
+	  version
 2005-09-26 13:42  Sandro Santilli <strk at keybit.net>
-	* [r841] configure.in, source/capi/Makefile.am,
-	  source/capi/geos_c.cpp, source/capi/geos_c.h,
-	  source/capi/geos_c.h.in: Moved C-api versioning to top-level
-	  configure.in
+	* [r841] Moved C-api versioning to top-level configure.in
 	  Added version info in geos_c.h
 2005-09-26 12:25  Sandro Santilli <strk at keybit.net>
-	* [r840] source/capi/geos_c.cpp, source/capi/geos_c.h,
-	  source/capi/geostest.c: Changed LineMerge interface to accept a
-	  single Geometry and return the simpler Geometry obtainable with
-	  the set of merger LineStrings. Fixed leaks in geostest, fixed a
-	  leak in GEOSRelate().
+	* [r840] Changed LineMerge interface to accept a single Geometry
+	  and return the simpler Geometry obtainable with the set of merger
+	  LineStrings. Fixed leaks in geostest, fixed a leak in
+	  GEOSRelate().
 2005-09-26 12:23  Sandro Santilli <strk at keybit.net>
-	* [r839] source/geom/PrecisionModel.cpp: Initializzation lists in
-	  PrecisionModel ctors
+	* [r839] Initializzation lists in PrecisionModel ctors
 2005-09-26 11:04  Sandro Santilli <strk at keybit.net>
-	* [r838] NEWS: Added changes in LineMerger
+	* [r838] Added changes in LineMerger
 2005-09-26 11:01  Sandro Santilli <strk at keybit.net>
-	* [r837] source/headers/geos/opLinemerge.h,
-	  source/operation/linemerge/LineMergeGraph.cpp,
-	  source/operation/linemerge/LineMerger.cpp: Const correctness
-	  changes in LineMerger package, and a few speedups.
+	* [r837] Const correctness changes in LineMerger package, and a few
+	  speedups.
 2005-09-26 08:18  Sandro Santilli <strk at keybit.net>
-	* [r836] source/capi, source/capi/.cvsignore: Added .lo, .la and
-	  geostest
+	* [r836] Added .lo, .la and geostest
 2005-09-26 08:17  Sandro Santilli <strk at keybit.net>
-	* [r835] doc/example.cpp: Removed memory leak from WKB tester
+	* [r835] Removed memory leak from WKB tester
 2005-09-23 17:20  Sandro Santilli <strk at keybit.net>
-	* [r834] source/headers/geos/opLinemerge.h,
-	  source/operation/linemerge/LineMerger.cpp: Made LineMerger graph
-	  be a real object (rather then a pointer to it)
+	* [r834] Made LineMerger graph be a real object (rather then a
+	  pointer to it)
 2005-09-23 16:07  Sandro Santilli <strk at keybit.net>
-	* [r833] source/capi/geos_c.cpp: Fixed export of GEOSPolygonize()
-	  and GEOSMakeCollection()
+	* [r833] Fixed export of GEOSPolygonize() and GEOSMakeCollection()
 2005-09-23 09:49  Sandro Santilli <strk at keybit.net>
-	* [r832] source/capi/geos_c.cpp, source/capi/geos_c.h: Added
-	  GEOSMakeCollection.
+	* [r832] Added GEOSMakeCollection.
 	  Changed GEOSGetCentroid to return an EmptyGeometry when no
 	  Centroid can be
 	  computed (Empty input, for example).
 2005-09-19 08:16  Sandro Santilli <strk at keybit.net>
-	* [r831] NEWS: Added C api
+	* [r831] Added C api
 2005-09-14 15:11  Sandro Santilli <strk at keybit.net>
-	* [r830] source/capi/geos_c.h: Removed functions returning not-new
-	  GEOSGeom objects to avoid ambiguity
+	* [r830] Removed functions returning not-new GEOSGeom objects to
+	  avoid ambiguity
 	  whereas when to destroy returns. Added not about memory
 	  management.
 2005-09-14 14:55  Sandro Santilli <strk at keybit.net>
-	* [r829] source/capi/geos_c.cpp, source/capi/geos_c.h,
-	  source/capi/geostest.c: Added copyright notices and usage notes
+	* [r829] Added copyright notices and usage notes
 2005-09-14 14:28  Sandro Santilli <strk at keybit.net>
-	* [r828] source/io/WKBWriter.cpp: Fixed bug writing WKB for all
-	  Multi* geoms as Collections.
+	* [r828] Fixed bug writing WKB for all Multi* geoms as Collections.
 2005-09-14 13:58  Sandro Santilli <strk at keybit.net>
-	* [r827] configure.in, source/Makefile.am, source/capi,
-	  source/capi/.cvsignore, source/capi/Makefile.am,
-	  source/capi/geostest.c, source/capi/test.wkt: Initial abstract C
-	  api.
+	* [r827] Initial abstract C api.
 2005-09-14 13:56  Sandro Santilli <strk at keybit.net>
-	* [r826] source/io/WKBReader.cpp: Typo fixed
+	* [r826] Typo fixed
 2005-09-03 21:26  Sandro Santilli <strk at keybit.net>
-	* [r825] doc/example.cpp, source/geom/Makefile.am,
-	  source/headers/geos/ByteOrderDataInStreamT.h,
-	  source/headers/geos/Makefile.am,
-	  source/headers/geos/WKBReaderT.h,
-	  source/headers/geos/WKBWriterT.h, source/headers/geos/io.h,
-	  source/io/WKBReader.cpp, source/io/WKBWriter.cpp: Reworked WKB
-	  I/O to avoid use of templates and make better use of STL
+	* [r825] Reworked WKB I/O to avoid use of templates and make better
+	  use of STL
 2005-08-22 13:34  Sandro Santilli <strk at keybit.net>
-	* [r822] NEWS: Added 2.1.4 section
+	* [r822] Added 2.1.4 section
 2005-08-22 13:31  Sandro Santilli <strk at keybit.net>
-	* [r821] source/geom/Geometry.cpp,
-	  source/operation/buffer/BufferBuilder.cpp,
-	  source/planargraph/planarDirectedEdgeStar.cpp: Fixed comparator
-	  functions used with STL sort() algorithm to
+	* [r821] Fixed comparator functions used with STL sort() algorithm
+	  to
 	  implement StrictWeakOrdering semantic.
 2005-07-12 14:33  Sandro Santilli <strk at keybit.net>
-	* [r819] NEWS: updated
+	* [r819] updated
 2005-07-11 16:21  Sandro Santilli <strk at keybit.net>
-	* [r818] source/headers/geos/ByteOrderDataInStreamT.h,
-	  source/headers/geos/WKBWriterT.h: Removed '_' prefix from header
-	  guards
+	* [r818] Removed '_' prefix from header guards
 2005-07-11 12:17  Sandro Santilli <strk at keybit.net>
-	* [r817] source/headers/geos/io.h, source/headers/geos/opOverlay.h,
-	  source/headers/geos/platform.h.in: Cleaned up syntax
+	* [r817] Cleaned up syntax
-	* [r816] doc/example.cpp: Commented out useless include
+	* [r816] Commented out useless include
 2005-07-11 10:50  Sandro Santilli <strk at keybit.net>
-	* [r815] source/geom/Geometry.cpp: Added parens suggested by
-	  compiler
+	* [r815] Added parens suggested by compiler
 2005-07-11 10:27  Sandro Santilli <strk at keybit.net>
-	* [r814] source/geomgraph/Edge.cpp,
-	  source/headers/geos/WKBReaderT.h: Cleaned up signed/unsigned
-	  mismatches
+	* [r814] Cleaned up signed/unsigned mismatches
-	* [r813] source/geomgraph/DirectedEdge.cpp,
-	  source/operation/buffer/BufferOp.cpp,
-	  source/operation/buffer/SubgraphDepthLocater.cpp: Fixed
-	  initializzazion lists
+	* [r813] Fixed initializzazion lists
 2005-07-11 10:26  Sandro Santilli <strk at keybit.net>
-	* [r812] source/headers/geos/geom.h: Made
-	  CoordinateSequence::getDimension return unsigned int instead of
-	  int
+	* [r812] Made CoordinateSequence::getDimension return unsigned int
+	  instead of int
 2005-07-11 10:23  Sandro Santilli <strk at keybit.net>
-	* [r811] source/geom/Geometry.cpp: removed useless assignment
+	* [r811] removed useless assignment
 2005-06-30 18:31  Sandro Santilli <strk at keybit.net>
-	* [r807] source/headers/geos/opBuffer.h,
-	  source/operation/buffer/SubgraphDepthLocater.cpp: Ported
-	  SubgraphDepthLocator optimizations from JTS code
+	* [r807] Ported SubgraphDepthLocator optimizations from JTS code
 2005-06-28 21:13  Sandro Santilli <strk at keybit.net>
-	* [r803] source/operation/buffer/SubgraphDepthLocater.cpp: Fixed a
-	  bug introduced by LineSegment skip - made LineSegment skip a
-	  compile-time optione
+	* [r803] Fixed a bug introduced by LineSegment skip - made
+	  LineSegment skip a compile-time optione
 2005-06-28 16:52  Sandro Santilli <strk at keybit.net>
-	* [r802] source/test/XMLTester.cpp: Added number of points count as
-	  a debugging aid
+	* [r802] Added number of points count as a debugging aid
 2005-06-28 11:22  Sandro Santilli <strk at keybit.net>
-	* [r801] NEWS: Added DepthSegmentLT bugfix
+	* [r801] Added DepthSegmentLT bugfix
 2005-06-28 01:07  Sandro Santilli <strk at keybit.net>
-	* [r796] source/headers/geos/opOverlay.h,
-	  source/operation/overlay/PointBuilder.cpp: improved extraction of
-	  result points in overlay op
+	* [r796] improved extraction of result points in overlay op
 2005-06-28 00:04  Sandro Santilli <strk at keybit.net>
-	* [r794] source/geomgraph/Node.cpp: improved
-	  ::isIncidentEdgeInResult() method
+	* [r794] improved ::isIncidentEdgeInResult() method
 2005-06-27 21:58  Sandro Santilli <strk at keybit.net>
-	* [r793] source/operation/buffer/SubgraphDepthLocater.cpp: Bugfix
-	  in DepthSegmentLT as suggested by Graeme Hiebert
+	* [r793] Bugfix in DepthSegmentLT as suggested by Graeme Hiebert
 2005-06-27 21:24  Sandro Santilli <strk at keybit.net>
-	* [r790] source/operation/buffer/SubgraphDepthLocater.cpp: Fixed
-	  bug just-introduced with optimization.
+	* [r790] Fixed bug just-introduced with optimization.
 2005-06-27 21:21  Sandro Santilli <strk at keybit.net>
-	* [r789] NEWS, source/operation/buffer/SubgraphDepthLocater.cpp:
-	  Reduced Coordinate copies due to LineSegment overuse
+	* [r789] Reduced Coordinate copies due to LineSegment overuse
 2005-06-25 10:20  Sandro Santilli <strk at keybit.net>
-	* [r787] NEWS, source/geomgraph/Node.cpp,
-	  source/operation/overlay/PointBuilder.cpp: OverlayOp speedup (JTS
-	  port)
+	* [r787] OverlayOp speedup (JTS port)
 2005-06-24 11:12  Sandro Santilli <strk at keybit.net>
-	* [r786] NEWS: Added LineIntersector concrete type note
+	* [r786] Added LineIntersector concrete type note
 2005-06-24 11:09  Sandro Santilli <strk at keybit.net>
-	* [r785] source/algorithm/CGAlgorithms.cpp,
-	  source/algorithm/PointLocator.cpp, source/geom/LineSegment.cpp,
-	  source/geom/Makefile.am, source/geomgraph/PlanarGraph.cpp,
-	  source/headers/geos/noding.h, source/noding/IteratedNoder.cpp,
-	  source/operation/GeometryGraphOperation.cpp,
-	  source/operation/IsSimpleOp.cpp,
-	  source/operation/buffer/OffsetCurveBuilder.cpp,
-	  source/operation/overlay/OverlayOp.cpp,
-	  source/operation/relate/RelateComputer.cpp,
-	  source/operation/valid/ConsistentAreaTester.cpp,
-	  source/operation/valid/IsValidOp.cpp: Dropped
-	  RobustLineIntersector, made LineIntersector a concrete class.
+	* [r785] Dropped RobustLineIntersector, made LineIntersector a
+	  concrete class.
 	  Added
 	  LineIntersector::hasIntersection(Coordinate&,Coordinate&,Coordinate&)
 	  to avoid computing intersection point (Z) when it's not
@@ -15093,145 +9072,112 @@
 2005-06-23 14:22  Sandro Santilli <strk at keybit.net>
-	* [r784] NEWS, source/geom/GeometryCollection.cpp,
-	  source/geom/LineString.cpp, source/geom/LinearRing.cpp,
-	  source/headers/geos/geom.h: Inlined and added missing ::clone()
-	  for Geometry subclasses
+	* [r784] Inlined and added missing ::clone() for Geometry
+	  subclasses
 2005-06-23 11:23  Sandro Santilli <strk at keybit.net>
-	* [r782] NEWS, source/algorithm/CGAlgorithms.cpp: performance
-	  improvement for CGAlgorithms::isOnLine()
+	* [r782] performance improvement for CGAlgorithms::isOnLine()
 2005-06-22 00:46  Sandro Santilli <strk at keybit.net>
-	* [r779] NEWS, source/geom/Geometry.cpp: Shortcircuit tests for
-	  Union
+	* [r779] Shortcircuit tests for Union
-	* [r777] source/geom/GeometryFactory.cpp: Fixed bugus handling of
-	  collections in ::buildGeometry
+	* [r777] Fixed bugus handling of collections in ::buildGeometry
 2005-06-21 12:22  Sandro Santilli <strk at keybit.net>
-	* [r773] NEWS, source/test/XMLTester.cpp, source/test/XMLTester.h:
-	  XMLTester code cleanups
+	* [r773] XMLTester code cleanups
 2005-06-20 10:23  Sandro Santilli <strk at keybit.net>
-	* [r772] NEWS, source/test/Makefile.am: XMLTester installed by
-	  default
+	* [r772] XMLTester installed by default
 2005-06-17 15:17  Sandro Santilli <strk at keybit.net>
-	* [r770] ., .cvsignore, ltmain.sh: Removed ltmain.sh from
-	  repository, will be created by autogen.sh
+	* [r770] Removed ltmain.sh from repository, will be created by
+	  autogen.sh
 2005-06-17 15:08  Sandro Santilli <strk at keybit.net>
-	* [r766] NEWS, source/operation/polygonize/Polygonizer.cpp,
-	  source/operation/polygonize/polygonizeEdgeRing.cpp: Polygonizer
-	  segfault fix
+	* [r766] Polygonizer segfault fix
 2005-06-17 14:58  Sandro Santilli <strk at keybit.net>
-	* [r764] source/geom/GeometryFactory.cpp: Fixed segfault in
-	  LinearRing and LineString constructors
+	* [r764] Fixed segfault in LinearRing and LineString constructors
 2005-06-14 11:57  Sandro Santilli <strk at keybit.net>
-	* [r761] NEWS, source/test/XMLTester.cpp: Added workaround for
-	  mingw Polygon name clash
+	* [r761] Added workaround for mingw Polygon name clash
 2005-06-10 14:04  Sandro Santilli <strk at keybit.net>
-	* [r760] autogen.sh: Added libtoolize call
+	* [r760] Added libtoolize call
 2005-06-10 13:24  Sandro Santilli <strk at keybit.net>
-	* [r758] source/test/XMLTester.cpp: Added use declaration to make
-	  MingW build work
+	* [r758] Added use declaration to make MingW build work
 2005-06-08 09:38  Sandro Santilli <strk at keybit.net>
-	* [r754] INSTALL: Added GCC version requirement note
+	* [r754] Added GCC version requirement note
 2005-06-05 10:41  Sandro Santilli <strk at keybit.net>
-	* [r752] CHANGES, NEWS: Changes file renamed back to NEWS, automake
-	  insists on finding it.
+	* [r752] Changes file renamed back to NEWS, automake insists on
+	  finding it.
 2005-05-30 16:20  autorun
-	* [r750] NEWS: Blank news file to molfify new versions of autoconf
+	* [r750] Blank news file to molfify new versions of autoconf
 2005-05-24 08:42  Sandro Santilli <strk at keybit.net>
-	* [r749] NEWS: Info moved into CHANGES file
+	* [r749] Info moved into CHANGES file
-	* [r748] CHANGES: Filled in section from 2.0.0 to 2.1.1
+	* [r748] Filled in section from 2.0.0 to 2.1.1
 2005-05-24 07:48  Sandro Santilli <strk at keybit.net>
-	* [r744] CHANGES: Initial import
+	* [r744] Initial import
 2005-05-23 16:42  Sandro Santilli <strk at keybit.net>
-	* [r728] source/geom/Point.cpp: Added Refractions copyright
+	* [r728] Added Refractions copyright
 2005-05-23 15:13  Sandro Santilli <strk at keybit.net>
-	* [r717] source/operation/buffer/BufferSubgraph.cpp,
-	  source/operation/buffer/SubgraphDepthLocater.cpp: Added debugging
-	  output
+	* [r717] Added debugging output
 2005-05-23 15:04  Sandro Santilli <strk at keybit.net>
-	* [r716] source/geom/LineSegment.cpp: Fixed bug in ::reverse()
+	* [r716] Fixed bug in ::reverse()
 2005-05-22 17:45  Sandro Santilli <strk at keybit.net>
-	* [r715] source/operation/buffer/BufferSubgraph.cpp: Fixed
-	  initialization list order
+	* [r715] Fixed initialization list order
 2005-05-22 17:42  Sandro Santilli <strk at keybit.net>
-	* [r714] ChangeLog, source/headers/geos/Makefile.am: Added missing
-	  WKBWriterT.h
+	* [r714] Added missing WKBWriterT.h
 2005-05-20 16:15  Sandro Santilli <strk at keybit.net>
-	* [r713] source/geomgraph/Position.cpp,
-	  source/operation/buffer/SubgraphDepthLocater.cpp: Code cleanups
+	* [r713] Code cleanups
 2005-05-20 16:14  Sandro Santilli <strk at keybit.net>
-	* [r712] source/operation/buffer/OffsetCurveSetBuilder.cpp: Fixed a
-	  bug in addPolygonRing setting wrong depths on Edges
+	* [r712] Fixed a bug in addPolygonRing setting wrong depths on
+	  Edges
 2005-05-19 10:29  Sandro Santilli <strk at keybit.net>
-	* [r711] source/algorithm/CentroidArea.cpp,
-	  source/geomgraph/DirectedEdge.cpp, source/geomgraph/EdgeEnd.cpp,
-	  source/geomgraph/EdgeRing.cpp, source/headers/geos/geomgraph.h,
-	  source/headers/geos/opBuffer.h, source/headers/geos/opOverlay.h,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp,
-	  source/operation/overlay/MaximalEdgeRing.cpp,
-	  source/operation/overlay/MinimalEdgeRing.cpp,
-	  source/operation/overlay/PolygonBuilder.cpp: Removed some
-	  CGAlgorithms instances substituting them with direct calls
+	* [r711] Removed some CGAlgorithms instances substituting them with
+	  direct calls
 	  to the static functions. Interfaces accepting CGAlgorithms
 	  pointers kept
 	  for backward compatibility but modified to make the argument
@@ -15242,65 +9188,51 @@
 2005-05-19 10:26  Sandro Santilli <strk at keybit.net>
-	* [r710] source/test/testLeaksBig.xml: Added bogus multipolygon
-	  buffering test
+	* [r710] Added bogus multipolygon buffering test
 2005-05-13 18:06  Sandro Santilli <strk at keybit.net>
-	* [r709] source/headers/geos/geom.h: Added default tolerance
-	  parameter for equalsExact
+	* [r709] Added default tolerance parameter for equalsExact
 2005-05-13 17:15  Sandro Santilli <strk at keybit.net>
-	* [r708] source/geom/Point.cpp: cleanups and indentations
+	* [r708] cleanups and indentations
 2005-05-13 17:14  Sandro Santilli <strk at keybit.net>
-	* [r707] source/geom/Geometry.cpp: Added comment about 2D-only
-	  comparison of ::equal(Coordinate, Coordinate, double)
+	* [r707] Added comment about 2D-only comparison of
+	  ::equal(Coordinate, Coordinate, double)
 2005-05-09 21:17  Sandro Santilli <strk at keybit.net>
-	* [r706] source/headers/geos/WKBWriterT.h: Second argument to
-	  ::write made mandatory.
+	* [r706] Second argument to ::write made mandatory.
 2005-05-09 10:35  Sandro Santilli <strk at keybit.net>
-	* [r705] source/algorithm/RobustLineIntersector.cpp,
-	  source/headers/geos/geosAlgorithm.h: Ported JTS robustness
-	  patches made by Martin on suggestions by Kevin.
+	* [r705] Ported JTS robustness patches made by Martin on
+	  suggestions by Kevin.
 2005-05-03 15:30  Sandro Santilli <strk at keybit.net>
-	* [r704] TODO: Added WKB TODOs
+	* [r704] Added WKB TODOs
 2005-04-29 17:40  Sandro Santilli <strk at keybit.net>
-	* [r703] source/geom/Geometry.cpp, source/headers/geos.h,
-	  source/headers/geos/WKBWriterT.h, source/headers/geos/geom.h,
-	  source/headers/geos/io.h, source/headers/geos/opOverlay.h,
-	  source/io/ByteOrderValues.cpp,
-	  source/operation/overlay/OverlayOp.cpp: Updated Doxygen
-	  documentation and some Copyright headers.
+	* [r703] Updated Doxygen documentation and some Copyright headers.
 2005-04-29 16:36  Sandro Santilli <strk at keybit.net>
-	* [r702] source/headers/geos/io.h: Fixed biostringstream stream
-	  output.
+	* [r702] Fixed biostringstream stream output.
-	* [r701] doc/example.cpp: Made WKBReader use global_factory, for
-	  having WKB reads produce
+	* [r701] Made WKBReader use global_factory, for having WKB reads
+	  produce
 	  same context of input geoms.
 2005-04-29 15:34  Sandro Santilli <strk at keybit.net>
-	* [r700] doc/example.cpp, source/headers/geos/WKBReaderT.h,
-	  source/io/ByteOrderValues.cpp: Typedef'ed biostringstream,
-	  preferred parameter for
+	* [r700] Typedef'ed biostringstream, preferred parameter for
 	  WKB parser templates.
 	  Added << operator for biostringstream.
 	  Typedef'ed WKBWriter and WKBReader to be parametrized by
@@ -15309,16 +9241,8 @@
 2005-04-29 11:52  Sandro Santilli <strk at keybit.net>
-	* [r699] source/geom/CoordinateSequence.cpp,
-	  source/geom/DefaultCoordinateSequence.cpp,
-	  source/geom/DefaultCoordinateSequenceFactory.cpp,
-	  source/geom/Makefile.am, source/geom/PointCoordinateSequence.cpp,
-	  source/geom/PointCoordinateSequenceFactory.cpp,
-	  source/headers/geos/io.h: Added new JTS interfaces for
-	  CoordinateSequence and factories,
+	* [r699] Added new JTS interfaces for CoordinateSequence and
+	  factories,
 	  removed example implementations to reduce maintainance costs.
 	  Added first implementation of WKBWriter, made
@@ -15326,38 +9250,31 @@
 2005-04-29 11:50  Sandro Santilli <strk at keybit.net>
-	* [r698] source/headers/geos/platform.h.in: Added machine byte
-	  order extractor
+	* [r698] Added machine byte order extractor
 2005-04-21 15:13  Sandro Santilli <strk at keybit.net>
-	* [r697] configure.in: library version bumped to 3.0.0
+	* [r697] library version bumped to 3.0.0
 2005-04-21 13:43  Sandro Santilli <strk at keybit.net>
-	* [r696] ChangeLog, NEWS: Updated chage logs
+	* [r696] Updated chage logs
 2005-04-21 11:16  Sandro Santilli <strk at keybit.net>
-	* [r695] source/operation/overlay/OverlayOp.cpp: Removed useless
-	  Coordinate copies in mergeZ() - patch by Safe Software
+	* [r695] Removed useless Coordinate copies in mergeZ() - patch by
+	  Safe Software
 2005-04-20 17:56  Sandro Santilli <strk at keybit.net>
-	* [r694] source/algorithm/NonRobustCGAlgorithms.cpp,
-	  source/algorithm/RobustCGAlgorithms.cpp, source/geom/Makefile.am:
-	  Removed NonRobustCGAlgorithms and RobustCGAlgorithms, already
+	* [r694] Removed NonRobustCGAlgorithms and RobustCGAlgorithms,
+	  already
 	  unused (CGAlgorithms replaces both with robust implementation).
 2005-04-20 17:22  Sandro Santilli <strk at keybit.net>
-	* [r693] source/geom/Makefile.am,
-	  source/headers/geos/WKBReaderT.h, source/headers/geos/geom.h,
-	  source/headers/geos/io.h, source/io/ByteOrderValues.cpp,
-	  source/io/WKBReader.cpp: Added initial implementation of
-	  WKBReaderT and ByteOrderDataInStreamT
+	* [r693] Added initial implementation of WKBReaderT and
+	  ByteOrderDataInStreamT
 	  class templates and ByteOrderValues class.
 	  Work is unfinished as WKBReader requires new interface of
 	  CoordinateSequence
@@ -15365,533 +9282,369 @@
 2005-04-20 17:18  Sandro Santilli <strk at keybit.net>
-	* [r692] source/headers/geos.h: Added standard copyright header
+	* [r692] Added standard copyright header
 2005-04-19 11:49  Sandro Santilli <strk at keybit.net>
-	* [r691] source/geom/Point.cpp: Fixed segfault in ::isEmpty
+	* [r691] Fixed segfault in ::isEmpty
 2005-04-14 11:49  Sandro Santilli <strk at keybit.net>
-	* [r690] source/headers/geos/io.h, source/io/StringTokenizer.cpp,
-	  source/io/WKTReader.cpp: Applied slightly modified patch by Cheng
-	  Shan to speedup WKT parsing.
+	* [r690] Applied slightly modified patch by Cheng Shan to speedup
+	  WKT parsing.
 2005-04-07 18:43  Sandro Santilli <strk at keybit.net>
-	* [r689] source/operation/valid/IsValidOp.cpp: Fixed bug throwing
-	  an exception when a result could be returned instead
+	* [r689] Fixed bug throwing an exception when a result could be
+	  returned instead
 	  (ported JTS patch)
 2005-04-06 11:09  Sandro Santilli <strk at keybit.net>
-	* [r688] ChangeLog, ltmain.sh, source/algorithm/CGAlgorithms.cpp,
-	  source/algorithm/NonRobustLineIntersector.cpp,
-	  source/algorithm/RobustDeterminant.cpp,
-	  source/bigtest/GeometryTestFactory.cpp,
-	  source/headers/geos/platform.h.in,
-	  source/noding/snapround/SegmentSnapper.cpp,
-	  source/planargraph/planarDirectedEdge.cpp: Applied patch from Jon
-	  Schlueter (math.h => cmath; ieeefp.h in "C" block)
+	* [r688] Applied patch from Jon Schlueter (math.h => cmath;
+	  ieeefp.h in "C" block)
 2005-04-02 17:07  Sean Gillies <sgillies at frii.com>
-	* [r687] swig/python/setup.py: now supporting the win32 platform,
-	  thanks to Howard Butler
+	* [r687] now supporting the win32 platform, thanks to Howard Butler
 2005-03-26 08:19  Sandro Santilli <strk at keybit.net>
-	* [r686] source/headers/geos/opPolygonize.h: Commented out
-	  Polygonizer::LineStringAdder friendship
+	* [r686] Commented out Polygonizer::LineStringAdder friendship
 2005-03-10 17:27  Sandro Santilli <strk at keybit.net>
-	* [r685] source/io/WKBReader.cpp: ported from current JTS
+	* [r685] ported from current JTS
 2005-03-04 07:48  Sandro Santilli <strk at keybit.net>
-	* [r684] source/algorithm/CGAlgorithms.cpp: Removed useless copy
+	* [r684] Removed useless copy from ::isOnLine() - suggested by Dale
+	  Lutz
 2005-03-02 08:14  Sandro Santilli <strk at keybit.net>
-	* [r683] source/headers/Makefile.am: Removed commented line,
-	  cousing strange behaviours with autotools.
+	* [r683] Removed commented line, cousing strange behaviours with
+	  autotools.
 2005-02-22 18:21  Sandro Santilli <strk at keybit.net>
-	* [r682] source/headers/geos/noding.h,
-	  source/index/strtree/STRtree.cpp, source/noding/SegmentNode.cpp,
-	  source/noding/SegmentNodeList.cpp,
-	  source/noding/SegmentString.cpp: Changed SegmentNode to contain a
-	  *real* Coordinate (not a pointer) to reduce
+	* [r682] Changed SegmentNode to contain a *real* Coordinate (not a
+	  pointer) to reduce
 	  construction costs.
 2005-02-22 17:10  Sandro Santilli <strk at keybit.net>
-	* [r681] source/geom/CoordinateSequence.cpp,
-	  source/geom/LineString.cpp, source/noding/MCQuadtreeNoder.cpp,
-	  source/operation/buffer/RightmostEdgeFinder.cpp: Reduced
-	  CoordinateSequence::getSize() calls.
+	* [r681] Reduced CoordinateSequence::getSize() calls.
 2005-02-22 16:24  Sandro Santilli <strk at keybit.net>
-	* [r680] source/geomgraph/Edge.cpp,
-	  source/headers/geos/geomgraph.h: cached number of points in Edge
+	* [r680] cached number of points in Edge
 2005-02-22 16:23  Sandro Santilli <strk at keybit.net>
-	* [r679] source/headers/geos/noding.h,
-	  source/noding/SegmentString.cpp: Cached number of points in
-	  CoordinateSequence.
+	* [r679] Cached number of points in CoordinateSequence.
 2005-02-22 15:49  Sandro Santilli <strk at keybit.net>
-	* [r678] source/noding/SegmentString.cpp: Reduced calls to
-	  DefaultCoordinateSequence->getSize().
+	* [r678] Reduced calls to DefaultCoordinateSequence->getSize().
 2005-02-22 15:16  Sandro Santilli <strk at keybit.net>
-	* [r677] source/headers/geos/indexStrtree.h,
-	  source/index/strtree/STRtree.cpp: STRtree::avg() and
-	  STRtree::centreY() inlined.
+	* [r677] STRtree::avg() and STRtree::centreY() inlined.
 2005-02-22 10:55  Sandro Santilli <strk at keybit.net>
-	* [r676] source/geomgraph/Edge.cpp: Optimized Edge::equals(Edge *e)
+	* [r676] Optimized Edge::equals(Edge *e)
 2005-02-18 08:20  Sandro Santilli <strk at keybit.net>
-	* [r675] source/test/XMLTester.cpp: Added support for
-	  point-per-quadrant argument in buffer tests (using arg2).
+	* [r675] Added support for point-per-quadrant argument in buffer
+	  tests (using arg2).
 2005-02-17 09:56  Sandro Santilli <strk at keybit.net>
-	* [r674] source/operation/buffer/OffsetCurveBuilder.cpp: Commented
-	  out unused variable.
+	* [r674] Commented out unused variable.
-	* [r673] source/headers/geos/geom.h: Applied patch from Jon
-	  Schlueter using <cmath> instead of <math.h>
+	* [r673] Applied patch from Jon Schlueter using <cmath> instead of
+	  <math.h>
 2005-02-15 17:15  Sandro Santilli <strk at keybit.net>
-	* [r672] source/algorithm/RobustLineIntersector.cpp,
-	  source/geom/Envelope.cpp, source/geom/LineSegment.cpp,
-	  source/headers/geos/geom.h, source/headers/geos/indexChain.h,
-	  source/headers/geos/indexStrtree.h,
-	  source/index/chain/MonotoneChainBuilder.cpp,
-	  source/index/chain/indexMonotoneChain.cpp,
-	  source/index/strtree/AbstractNode.cpp,
-	  source/index/strtree/AbstractSTRtree.cpp,
-	  source/index/strtree/SIRtree.cpp,
-	  source/noding/MCQuadtreeNoder.cpp: Inlined most Envelope methods,
-	  reserved() memory for some vectors when
+	* [r672] Inlined most Envelope methods, reserved() memory for some
+	  vectors when
 	  the usage was known a priori.
 2005-02-11 08:58  Sandro Santilli <strk at keybit.net>
-	* [r671] source/geom/Makefile.am, source/headers/Makefile.am,
-	  source/headers/geos/Makefile.am: Applied patch from Curtis
-	  Barrett handling --includedir and --libdir
+	* [r671] Applied patch from Curtis Barrett handling --includedir
+	  and --libdir
 	  params for configure.
 2005-02-05 05:44  Sandro Santilli <strk at keybit.net>
-	* [r670] source/algorithm/CGAlgorithms.cpp,
-	  source/algorithm/RobustLineIntersector.cpp,
-	  source/geomgraph/GeometryGraph.cpp, source/geomgraph/NodeMap.cpp,
-	  source/geomgraph/PlanarGraph.cpp, source/geomgraph/Quadrant.cpp,
-	  source/headers/geos/geom.h, source/headers/geos/geomgraph.h,
-	  source/headers/geos/opRelate.h, source/headers/geos/operation.h,
-	  source/noding/MCQuadtreeNoder.cpp,
-	  source/noding/SegmentString.cpp, source/operation/IsSimpleOp.cpp,
-	  source/operation/overlay/LineBuilder.cpp,
-	  source/operation/overlay/PolygonBuilder.cpp,
-	  source/operation/relate/RelateNodeGraph.cpp,
-	  source/operation/valid/IsValidOp.cpp: Changed geomgraph nodeMap
-	  to use Coordinate pointers as keys, reduces
+	* [r670] Changed geomgraph nodeMap to use Coordinate pointers as
+	  keys, reduces
 	  lots of other Coordinate copies.
 2005-02-04 23:55  Sandro Santilli <strk at keybit.net>
-	* [r669] source/headers/geos/geom.h: Envelope destructor made
-	  non-virtual to give compiler more static
+	* [r669] Envelope destructor made non-virtual to give compiler more
+	  static
 	  binding options.
 2005-02-04 18:49  Sandro Santilli <strk at keybit.net>
-	* [r668] source/headers/geos/opBuffer.h,
-	  source/operation/buffer/BufferSubgraph.cpp: Changed
-	  ::computeDepths to use a set instead of a vector for checking
+	* [r668] Changed ::computeDepths to use a set instead of a vector
+	  for checking
 	  visited Edges.
 2005-02-04 14:49  Sandro Santilli <strk at keybit.net>
-	* [r667] source/test/Makefile.am: Added rule to build
-	  staticXMLTester (for profiling with gprof)
+	* [r667] Added rule to build staticXMLTester (for profiling with
+	  gprof)
 2005-02-03 09:17  Sandro Santilli <strk at keybit.net>
-	* [r666] source/geom/CoordinateSequence.cpp: more profiling label
+	* [r666] more profiling label
 2005-02-01 16:09  Sandro Santilli <strk at keybit.net>
-	* [r665] source/noding/MCQuadtreeNoder.cpp,
-	  source/noding/Noder.cpp: more profiling labels
+	* [r665] more profiling labels
 2005-02-01 16:06  Sandro Santilli <strk at keybit.net>
-	* [r664] source/geom/Envelope.cpp,
-	  source/index/chain/indexMonotoneChain.cpp: Small optimizations.
+	* [r664] Small optimizations.
 2005-02-01 14:18  Sandro Santilli <strk at keybit.net>
-	* [r663] source/noding/SegmentNodeList.cpp,
-	  source/noding/SegmentString.cpp: More profiler labels
+	* [r663] More profiler labels
-	* [r662] source/headers/geos/profiler.h, source/util/Profiler.cpp:
-	  Made profiler start/stop inline
+	* [r662] Made profiler start/stop inline
 2005-02-01 13:44  Sandro Santilli <strk at keybit.net>
-	* [r661] source/geom/LineSegment.cpp,
-	  source/geomgraph/EdgeList.cpp,
-	  source/index/chain/MonotoneChainOverlapAction.cpp,
-	  source/noding/IteratedNoder.cpp,
-	  source/util/Profiler.cpp: More profiling labels.
+	* [r661] More profiling labels.
 2005-01-31 15:41  Sandro Santilli <strk at keybit.net>
-	* [r660] source/index/strtree/AbstractSTRtree.cpp,
-	  source/noding/MCQuadtreeNoder.cpp: Small optimizations.
+	* [r660] Small optimizations.
 2005-01-28 10:01  Sandro Santilli <strk at keybit.net>
-	* [r659] source/io/ParseException.cpp: substituted sprintf calls
-	  with use of ostringstream
+	* [r659] substituted sprintf calls with use of ostringstream
 2005-01-28 09:47  Sandro Santilli <strk at keybit.net>
-	* [r658] source/examples/CustomPointCoordinateSequence.cpp,
-	  source/geom/Dimension.cpp, source/geom/Envelope.cpp,
-	  source/geom/IntersectionMatrix.cpp, source/geom/LineSegment.cpp,
-	  source/geom/Location.cpp,
-	  source/geom/PointCoordinateSequence.cpp,
-	  source/geom/PrecisionModel.cpp, source/geomgraph/Depth.cpp,
-	  source/geomgraph/Quadrant.cpp,
-	  source/index/quadtree/QuadTreeNodeBase.cpp,
-	  source/noding/SegmentNode.cpp,
-	  source/planargraph/planarDirectedEdge.cpp: Replaced sprintf uses
-	  with ostringstream.
+	* [r658] Replaced sprintf uses with ostringstream.
 2005-01-28 08:47  Sandro Santilli <strk at keybit.net>
-	* [r657] source/geom/Coordinate.cpp: Removed sprintf usage,
-	  replaced with sstream
+	* [r657] Removed sprintf usage, replaced with sstream
 2005-01-28 07:58  Sandro Santilli <strk at keybit.net>
-	* [r656] source/geom/DefaultCoordinateSequence.cpp: removed sprintf
-	  usage, ad ::toString call Coordinate::toString
+	* [r656] removed sprintf usage, ad ::toString call
+	  Coordinate::toString
 2005-01-18 17:22  Sandro Santilli <strk at keybit.net>
-	* [r655] source/algorithm/LineIntersector.cpp: reverted previous
-	  change, sign was actually stored in zgap
+	* [r655] reverted previous change, sign was actually stored in zgap
 2005-01-18 17:09  Sandro Santilli <strk at keybit.net>
-	* [r654] source/algorithm/RobustLineIntersector.cpp: Fixed
-	  interpolateZ call using final intersection point instead of
-	  HCoordinate.
+	* [r654] Fixed interpolateZ call using final intersection point
+	  instead of HCoordinate.
 2005-01-14 08:04  Sandro Santilli <strk at keybit.net>
-	* [r653] source/algorithm/LineIntersector.cpp: Fixed Z
-	  interpolation to use the correct sign
+	* [r653] Fixed Z interpolation to use the correct sign
 2005-01-03 16:06  Sandro Santilli <strk at keybit.net>
-	* [r652] source/test/XMLTester.cpp: Changed polygonize op to return
-	  a GeometryCollection
+	* [r652] Changed polygonize op to return a GeometryCollection
 2005-01-03 15:56  Sandro Santilli <strk at keybit.net>
-	* [r651] source/test/XMLTester.cpp: Fixed memory leaks just
-	  introduced for Polygonizer test case.
+	* [r651] Fixed memory leaks just introduced for Polygonizer test
+	  case.
 2005-01-03 15:49  Sandro Santilli <strk at keybit.net>
-	* [r650] source/test/XMLTester.cpp: Added Polygonize test handling
+	* [r650] Added Polygonize test handling
 2004-12-30 13:32  Sandro Santilli <strk at keybit.net>
-	* [r649] source/test/XMLTester.cpp: Handled NULL result from
-	  getCentroid()
+	* [r649] Handled NULL result from getCentroid()
 2004-12-30 13:31  Sandro Santilli <strk at keybit.net>
-	* [r648] source/geom/Geometry.cpp: Fixed a segfault on
-	  EMPTYGEOM->getCeontroid()
+	* [r648] Fixed a segfault on EMPTYGEOM->getCeontroid()
 2004-12-30 10:14  Sandro Santilli <strk at keybit.net>
-	* [r647] source/geom/Polygon.cpp: never return LinearRing or
-	  MultiLinearRing from getBoundary
+	* [r647] never return LinearRing or MultiLinearRing from
+	  getBoundary
-	* [r646] source/geom/GeometryFactory.cpp: input checking and class
-	  promoting in createMultiLineString()
+	* [r646] input checking and class promoting in
+	  createMultiLineString()
 2004-12-22 09:42  Sandro Santilli <strk at keybit.net>
-	* [r645] source/geom/util/GeometryEditor.cpp: Fixed a premature
-	  Geometry destruction, Avoided CoordinateSequence copies
+	* [r645] Fixed a premature Geometry destruction, Avoided
+	  CoordinateSequence copies
 	  when possible.
 2004-12-16 18:29  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r644] configure.in: Bumped minor version number for 2.1.1
-	  release.
+	* [r644] Bumped minor version number for 2.1.1 release.
 2004-12-16 16:27  Sandro Santilli <strk at keybit.net>
-	* [r643] source/geom/LinearRing.cpp, source/headers/geos/geom.h:
-	  Fixed LinearRing::clone() to return LinearRing instead of
+	* [r643] Fixed LinearRing::clone() to return LinearRing instead of
 	  LineString
 2004-12-16 16:08  Sandro Santilli <strk at keybit.net>
-	* [r642] swig/geos.i, swig/python/example.py: New patches from Niki
-	  Spahiev <niki.spahiev at gmail.com>
+	* [r642] New patches from Niki Spahiev <niki.spahiev at gmail.com>
 	  (still unstable)
 2004-12-16 09:05  Sandro Santilli <strk at keybit.net>
-	* [r641] swig/python/example.py: Added python example by Niki
+	* [r641] Added python example by Niki Spahiev
+	  <niki.spahiev at gmail.com>
 2004-12-16 08:56  Sandro Santilli <strk at keybit.net>
-	* [r640] swig/geos.i: Applyed patches by Niki Spahiev
-	  <niki.spahiev at gmail.com>
+	* [r640] Applyed patches by Niki Spahiev <niki.spahiev at gmail.com>
 2004-12-14 10:35  Sandro Santilli <strk at keybit.net>
-	* [r638] source/headers/geos/opPolygonize.h,
-	  source/headers/geos/planargraph.h,
-	  source/operation/polygonize/PolygonizeGraph.cpp,
-	  source/planargraph/planarDirectedEdge.cpp,
-	  source/planargraph/planarDirectedEdgeStar.cpp: Comments cleanup.
-	  PolygonizeGraph keeps track of generated CoordinateSequence
+	* [r638] Comments cleanup. PolygonizeGraph keeps track of generated
 	  for delayed destruction.
 2004-12-13 13:54  Sandro Santilli <strk at keybit.net>
-	* [r637] source/headers/geos/opPolygonize.h: Added a not about gcc
-	  2.95.4 required friendship
+	* [r637] Added a not about gcc 2.95.4 required friendship
 2004-12-13 13:53  Sandro Santilli <strk at keybit.net>
-	* [r636] source/geom/TopologyException.cpp: Fixed uninitialized
-	  Coordinate.
+	* [r636] Fixed uninitialized Coordinate.
 2004-12-12 17:22  Sandro Santilli <strk at keybit.net>
-	* [r635] source/headers/geos/Makefile.am: version.h and platform.h
-	  installed again (missed when removed from dist)
+	* [r635] version.h and platform.h installed again (missed when
+	  removed from dist)
 2004-12-08 14:33  Sandro Santilli <strk at keybit.net>
-	* [r634] source/geom/MultiPolygon.cpp: Checked inner polys
-	  getBoundary return for the single LineString case.
+	* [r634] Checked inner polys getBoundary return for the single
+	  LineString case.
 2004-12-08 14:32  Sandro Santilli <strk at keybit.net>
-	* [r633] source/geom/GeometryCollection.cpp: cleanups
+	* [r633] cleanups
 2004-12-08 14:31  Sandro Santilli <strk at keybit.net>
-	* [r632] source/test/testLeaksBig.xml: adjusted getBoundary
-	  expected returns to match OGC specs
+	* [r632] adjusted getBoundary expected returns to match OGC specs
-	* [r631] source/operation/overlay/OverlayOp.cpp: elevationMatrix
-	  deleted by destructor
+	* [r631] elevationMatrix deleted by destructor
 2004-12-08 14:30  Sandro Santilli <strk at keybit.net>
-	* [r630] source/io/Unload.cpp: Added default profiler instance
-	  cleanup
+	* [r630] Added default profiler instance cleanup
 2004-12-08 13:54  Sandro Santilli <strk at keybit.net>
-	* [r629] doc/example.cpp,
-	  source/bigtest/GeometryTestFactory.cpp, source/geom/Polygon.cpp,
-	  source/geom/util/GeometryEditor.cpp,
-	  source/geomgraph/Node.cpp, source/headers/geos/opBuffer.h,
-	  source/headers/geos/opOverlay.h,
-	  source/index/chain/MonotoneChainSelectAction.cpp,
-	  source/index/quadtree/DoubleBits.cpp,
-	  source/index/quadtree/Quadtree.cpp,
-	  source/index/sweepline/SweepLineIndex.cpp,
-	  source/io/WKTReader.cpp, source/io/WKTWriter.cpp,
-	  source/operation/linemerge/LineMerger.cpp,
-	  source/operation/overlay/ElevationMatrix.cpp,
-	  source/operation/polygonize/Polygonizer.cpp,
-	  source/operation/valid/IsValidOp.cpp, source/test/XMLTester.cpp,
-	  source/util/GeometricShapeFactory.cpp: gcc warnings checked and
-	  fixed, general cleanups.
+	* [r629] gcc warnings checked and fixed, general cleanups.
 2004-12-06 10:54  Sandro Santilli <strk at keybit.net>
-	* [r628] source/headers/geos/Makefile.am: Added timeval.h in
-	  distribution.
+	* [r628] Added timeval.h in distribution.
 2004-12-05 10:54  Sandro Santilli <strk at keybit.net>
-	* [r627] VisualStudio, VisualStudio/.cvsignore: initial revision
+	* [r627] initial revision
 2004-12-05 10:50  Sandro Santilli <strk at keybit.net>
-	* [r626] VisualStudio/Makefile.am: forgot to add
+	* [r626] forgot to add
 2004-12-05 10:48  Sandro Santilli <strk at keybit.net>
-	* [r625] debian/control, debian/libgeos-doc.doc-base, debian/rules:
-	  Modifications by Alex Bodnaru
+	* [r625] Modifications by Alex Bodnaru
 2004-12-05 10:44  Sandro Santilli <strk at keybit.net>
-	* [r624] configure.in, doc/Makefile.am, source/bigtest/Makefile.am,
-	  source/examples/Makefile.am, source/test/Makefile.am: Applied
-	  Norman Vine patches for cleaner win32 build.
+	* [r624] Applied Norman Vine patches for cleaner win32 build.
 2004-12-04 15:56  Sandro Santilli <strk at keybit.net>
-	* [r623] source/Makefile.am, source/headers/geos/Makefile.am: Added
-	  source/Makefile.vc and source/headers/geos/platform.h.in in
-	  distribution
+	* [r623] Added source/Makefile.vc and
+	  source/headers/geos/platform.h.in in distribution
 2004-12-04 15:31  Sandro Santilli <strk at keybit.net>
-	* [r622] Makefile.am, configure.in,
-	  source/headers/geos/Makefile.am: Added VisualStudio dir in
-	  distribution, removed platform.h and version.h from it.
+	* [r622] Added VisualStudio dir in distribution, removed platform.h
+	  and version.h from it.
 2004-12-04 01:20  frank
-	* [r621] source/Makefile.vc: removed dll delete
+	* [r621] removed dll delete
 2004-12-03 22:52  Sandro Santilli <strk at keybit.net>
-	* [r620] source/geom/CoordinateSequence.cpp,
-	  source/headers/geos/geom.h, source/util/Profiler.cpp: enforced
-	  const return of CoordinateSequence::toVector() method to derivate
-	  classes.
+	* [r620] enforced const return of CoordinateSequence::toVector()
+	  method to derivate classes.
 2004-12-03 16:26  frank
-	* [r619] source/headers/geos/platform.h.vc: added headers
+	* [r619] added headers
 2004-12-03 16:25  frank
-	* [r618] source/Makefile.vc: New
+	* [r618] New
 2004-12-03 16:22  frank
-	* [r617] source/headers/geos/geom.h: update to use I64 on MSVC for
-	  64 bit integer constants, also toVector chg.
+	* [r617] update to use I64 on MSVC for 64 bit integer constants,
+	  also toVector chg.
 2004-12-03 16:21  frank
-	* [r616] source/headers/geos/profiler.h: dont try for sys/time.h
-	  with MSVC
+	* [r616] dont try for sys/time.h with MSVC
 2004-12-03 16:19  frank
-	* [r615] source/headers/geos/platform.h.vc: New
+	* [r615] New
 2004-11-30 16:44  Sandro Santilli <strk at keybit.net>
-	* [r614] source/headers/geos/profiler.h,
-	  source/headers/geos/timeval.h: Added gettimeofday implementation
-	  for win32, curtesy of Wu Yongwei.
+	* [r614] Added gettimeofday implementation for win32, curtesy of Wu
+	  Yongwei.
 2004-11-30 13:05  Sandro Santilli <strk at keybit.net>
-	* [r613] source/headers/geos/platform.h.in: Removed inclusion of
-	  stdio.h, which should now be useless.
+	* [r613] Removed inclusion of stdio.h, which should now be useless.
 2004-11-30 13:04  Sandro Santilli <strk at keybit.net>
-	* [r612] configure.in, source/headers/geos/platform.h.in: Added
-	  optional inclusion of ieeefp.h on platform providing it.
+	* [r612] Added optional inclusion of ieeefp.h on platform providing
+	  it.
 2004-11-29 16:05  Sandro Santilli <strk at keybit.net>
-	* [r611] source/algorithm/HCoordinate.cpp,
-	  source/geom/Coordinate.cpp, source/geomgraph/Node.cpp,
-	  source/headers/geos/geom.h, source/headers/geos/platform.h.in,
-	  source/operation/overlay/ElevationMatrixCell.cpp,
-	  source/operation/overlay/ElevationMatrixFilter.cpp,
-	  source/operation/overlay/OverlayOp.cpp: Fixed a bug in
-	  LineIntersector::interpolateZ causing NaN values
+	* [r611] Fixed a bug in LineIntersector::interpolateZ causing NaN
+	  values
 	  to come out.
 	  Handled dimensional collapses in ElevationMatrix.
 	  Added ISNAN macro and changed ISNAN/FINITE macros to avoid
@@ -15899,681 +9652,419 @@
 2004-11-27 11:36  Sandro Santilli <strk at keybit.net>
-	* [r610] debian/Makefile, debian/README.Debian, debian/changelog,
-	  debian/control, debian/libgeos-dev.install,
-	  debian/libgeos-dev.manpages, debian/rules, debian/shlibs.local:
-	  Updated scripts by Alex Bodnaru, added Makefile
+	* [r610] Updated scripts by Alex Bodnaru, added Makefile
 2004-11-26 09:53  Sandro Santilli <strk at keybit.net>
-	* [r609] source/algorithm/LineIntersector.cpp,
-	  source/geomgraph/Node.cpp, source/headers/geos/platform.h.in:
-	  Added more FINITE calls, and added inf and -inf to FINITE checks
+	* [r609] Added more FINITE calls, and added inf and -inf to FINITE
+	  checks
 2004-11-26 09:22  Sandro Santilli <strk at keybit.net>
-	* [r608] source/headers/geos/platform.h.in,
-	  source/operation/overlay/OverlayOp.cpp: Added FINITE(x) macro and
-	  its use.
+	* [r608] Added FINITE(x) macro and its use.
 	  Made input geoms average Z computation optional in OverlayOp.
 2004-11-24 18:10  Sandro Santilli <strk at keybit.net>
-	* [r607] source/operation/overlay/OverlayOp.cpp: Stricter handling
-	  of USE_ELEVATION_MATRIX define
+	* [r607] Stricter handling of USE_ELEVATION_MATRIX define
-	* [r606] source/algorithm/LineIntersector.cpp: Cleanup of
-	  interpolateZ
+	* [r606] Cleanup of interpolateZ
 2004-11-24 12:29  Sandro Santilli <strk at keybit.net>
-	* [r605] source/operation/overlay/ElevationMatrix.cpp: Handled
-	  boundary cases in ::getCell
+	* [r605] Handled boundary cases in ::getCell
 2004-11-24 11:32  Sandro Santilli <strk at keybit.net>
-	* [r604] source/operation/overlay/LineBuilder.cpp: Re-enabled Z
-	  propagation in output lines.
+	* [r604] Re-enabled Z propagation in output lines.
 2004-11-23 19:53  Sandro Santilli <strk at keybit.net>
-	* [r603] source/algorithm/LineIntersector.cpp,
-	  source/geomgraph/Edge.cpp, source/geomgraph/EdgeEndStar.cpp,
-	  source/geomgraph/index/MonotoneChainEdge.cpp,
-	  source/headers/geos/geosAlgorithm.h,
-	  source/operation/overlay/OverlayOp.cpp: Had LineIntersector
-	  compute Z by interpolation.
+	* [r603] Had LineIntersector compute Z by interpolation.
 2004-11-23 16:22  Sandro Santilli <strk at keybit.net>
-	* [r602] source/geom/DefaultCoordinateSequence.cpp,
-	  source/geom/LineString.cpp, source/geom/Makefile.am,
-	  source/geom/Point.cpp, source/headers/geos/geom.h,
-	  source/operation/overlay/OverlayOp.cpp: Added ElevationMatrix
-	  class and components to do post-processing draping of overlayed
-	  geometries.
+	* [r602] Added ElevationMatrix class and components to do
+	  post-processing draping of overlayed geometries.
 2004-11-22 15:51  Sandro Santilli <strk at keybit.net>
-	* [r601] source/headers/geos/opOverlay.h,
-	  source/operation/overlay/OverlayOp.cpp: Added interpolation of
-	  containing geometry's average Z for point_in_poly case.
+	* [r601] Added interpolation of containing geometry's average Z for
+	  point_in_poly case.
 2004-11-22 13:02  Sandro Santilli <strk at keybit.net>
-	* [r600] source/algorithm/RobustLineIntersector.cpp: Fixed a bug in
-	  Collinear intersection Z computation
+	* [r600] Fixed a bug in Collinear intersection Z computation
-	* [r599] source/geomgraph/EdgeIntersectionList.cpp: Forced use if
-	  computed intersection point in ::createSplitEdge (for Z
-	  computation)
+	* [r599] Forced use if computed intersection point in
+	  ::createSplitEdge (for Z computation)
 2004-11-22 12:59  Sandro Santilli <strk at keybit.net>
-	* [r598] source/geomgraph/Edge.cpp: Added debugging lines
+	* [r598] Added debugging lines
 2004-11-22 11:34  Sandro Santilli <strk at keybit.net>
-	* [r597] source/geomgraph/EdgeEndStar.cpp,
-	  source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
-	  source/operation/overlay/OverlayOp.cpp: More debugging lines and
-	  comments/indentation cleanups
+	* [r597] More debugging lines and comments/indentation cleanups
-	* [r596] source/algorithm/RobustLineIntersector.cpp: Added Z
-	  computation for CollinearIntersections
+	* [r596] Added Z computation for CollinearIntersections
 2004-11-20 18:54  Sandro Santilli <strk at keybit.net>
-	* [r595] debian/README.Debian, debian/control,
-	  debian/libgeos-dev.install, debian/rules: Scripts updates from
-	  Alex Bodnaru
+	* [r595] Scripts updates from Alex Bodnaru
 2004-11-20 18:17  Sandro Santilli <strk at keybit.net>
-	* [r594] source/headers/geos/opOverlay.h,
-	  source/operation/overlay/LineBuilder.cpp: Added Z propagation for
-	  overlay lines output.
+	* [r594] Added Z propagation for overlay lines output.
 2004-11-20 17:16  Sandro Santilli <strk at keybit.net>
-	* [r593] source/headers/geos/opOverlay.h,
-	  source/operation/overlay/OverlayOp.cpp: Handled Z merging for
-	  point on polygon boundary case.
+	* [r593] Handled Z merging for point on polygon boundary case.
 2004-11-20 16:25  Sandro Santilli <strk at keybit.net>
-	* [r592] source/operation/overlay/OverlayOp.cpp: Added Z
-	  computation for point on line case.
+	* [r592] Added Z computation for point on line case.
 2004-11-20 15:46  Sandro Santilli <strk at keybit.net>
-	* [r591] source/headers/geos/geomgraph.h: Added composing Z
-	  management functions and elements for class Node
+	* [r591] Added composing Z management functions and elements for
+	  class Node
 2004-11-20 15:45  Sandro Santilli <strk at keybit.net>
-	* [r590] source/geomgraph/NodeMap.cpp: Fixed Z merging in
-	  addNode(Node *)
+	* [r590] Fixed Z merging in addNode(Node *)
 2004-11-20 15:41  Sandro Santilli <strk at keybit.net>
-	* [r589] source/geomgraph/NodeMap.cpp: Added Z merging in ::addNode
+	* [r589] Added Z merging in ::addNode
-	* [r588] source/geomgraph/Node.cpp: Added management of vector of
-	  composing Z values.
+	* [r588] Added management of vector of composing Z values.
 2004-11-20 15:40  Sandro Santilli <strk at keybit.net>
-	* [r587] source/algorithm/RobustLineIntersector.cpp: Added Z
-	  computation in point-segment intersection.
+	* [r587] Added Z computation in point-segment intersection.
 2004-11-20 15:39  Sandro Santilli <strk at keybit.net>
-	* [r586] source/algorithm/CGAlgorithms.cpp: Reduced HEAP
-	  allocations.
+	* [r586] Reduced HEAP allocations.
 2004-11-19 16:35  Sandro Santilli <strk at keybit.net>
-	* [r585] debian, debian/changelog, debian/compat, debian/control,
-	  debian/copyright, debian/geos-config.1, debian/libgeos-dev.dirs,
-	  debian/libgeos-dev.docs, debian/libgeos-dev.install,
-	  debian/libgeos-doc.doc-base, debian/libgeos-doc.docs,
-	  debian/libgeos.dirs, debian/libgeos.docs, debian/libgeos.install,
-	  debian/makedoc, debian/rules, debian/shlibs.local, debian/watch:
-	  Added debian package builder scripts.
+	* [r585] Added debian package builder scripts.
 2004-11-19 16:15  Sandro Santilli <strk at keybit.net>
-	* [r584] source/index/quadtree/QuadTreeNode.cpp: Completely removed
-	  sprintf usage, substituted by stringstream.
+	* [r584] Completely removed sprintf usage, substituted by
+	  stringstream.
 2004-11-19 16:09  Sandro Santilli <strk at keybit.net>
-	* [r583] source/index/quadtree/QuadTreeNode.cpp: Added <stdio.h>
-	  include for sprintf recognition.
+	* [r583] Added <stdio.h> include for sprintf recognition.
 2004-11-19 10:10  Sandro Santilli <strk at keybit.net>
-	* [r582] source/geomgraph/Node.cpp: COMPUTE_Z re-enabled by default
+	* [r582] COMPUTE_Z re-enabled by default
 2004-11-19 09:33  Sandro Santilli <strk at keybit.net>
-	* [r581] source/geomgraph/GeometryGraph.cpp: removed useless
-	  CoordinateSequence copy in ::addLineString
+	* [r581] removed useless CoordinateSequence copy in ::addLineString
 2004-11-17 15:09  Sandro Santilli <strk at keybit.net>
-	* [r580] source/algorithm/RobustLineIntersector.cpp,
-	  source/operation/overlay/PointBuilder.cpp: Changed COMPUTE_Z
-	  defaults to be more conservative
+	* [r580] Changed COMPUTE_Z defaults to be more conservative
 2004-11-17 08:41  Sandro Santilli <strk at keybit.net>
-	* [r579] source/algorithm/RobustLineIntersector.cpp,
-	  source/geomgraph/index/SegmentIntersector.cpp: Fixed a bug in Z
-	  computation and removed debugging output by default.
+	* [r579] Fixed a bug in Z computation and removed debugging output
+	  by default.
 2004-11-17 08:13  Sandro Santilli <strk at keybit.net>
-	* [r578] source/algorithm/PointLocator.cpp,
-	  source/geom/Geometry.cpp, source/geomgraph/EdgeEndStar.cpp,
-	  source/geomgraph/EdgeIntersectionList.cpp,
-	  source/geomgraph/Label.cpp, source/geomgraph/Node.cpp,
-	  source/geomgraph/index/SegmentIntersector.cpp,
-	  source/headers/geos/indexQuadtree.h,
-	  source/headers/geos/operation.h,
-	  source/operation/overlay/PointBuilder.cpp: Indentation changes.
+	* [r578] Indentation changes.
 	  Some Z_COMPUTATION activated by default.
 2004-11-12 18:12  Sandro Santilli <strk at keybit.net>
-	* [r576] source/geom/Polygon.cpp: Changed ::getBoundary() to return
-	  LineString if polygon has no holes.
+	* [r576] Changed ::getBoundary() to return LineString if polygon
+	  has no holes.
 	  (has required to pass OGC conformance test T20)
 2004-11-09 20:22  Sandro Santilli <strk at keybit.net>
-	* [r575] tools/geos-config.in: Removed -g -O2 from geos-config
-	  --cflags output
+	* [r575] Removed -g -O2 from geos-config --cflags output
 2004-11-08 18:33  Sandro Santilli <strk at keybit.net>
-	* [r574] source/index/strtree/STRtree.cpp: Just another small
-	  improvement.
+	* [r574] Just another small improvement.
 2004-11-08 15:58  Sandro Santilli <strk at keybit.net>
-	* [r573] source/headers/geos/indexStrtree.h,
-	  source/operation/buffer/BufferOp.cpp: More performance tuning.
+	* [r573] More performance tuning.
 2004-11-08 13:12  Sandro Santilli <strk at keybit.net>
-	* [r572] source/headers/geos/Makefile.am: Added profiler.h
+	* [r572] Added profiler.h
 2004-11-08 12:15  Sandro Santilli <strk at keybit.net>
-	* [r571] source/util/Profiler.cpp: Added number of gathered timings
-	  in output.
+	* [r571] Added number of gathered timings in output.
 2004-11-08 11:19  Sandro Santilli <strk at keybit.net>
-	* [r570] source/util/Profiler.cpp: Profiler::get() always return a
-	  Profile (new if not existant).
+	* [r570] Profiler::get() always return a Profile (new if not
+	  existant).
 2004-11-08 10:58  Sandro Santilli <strk at keybit.net>
-	* [r569] source/geom/Envelope.cpp: Optimized the ::intersect
-	  function to avoid nested function calls.
+	* [r569] Optimized the ::intersect function to avoid nested
+	  function calls.
 2004-11-08 10:57  Sandro Santilli <strk at keybit.net>
-	* [r568] source/headers/geos/geom.h: Moved Log lines at the bottom,
-	  and cut oldest
+	* [r568] Moved Log lines at the bottom, and cut oldest
 2004-11-06 08:16  Sandro Santilli <strk at keybit.net>
-	* [r567] source/algorithm/CGAlgorithms.cpp,
-	  source/operation/valid/IsValidOp.cpp: Fixed CGAlgorithms::isCCW
-	  from JTS port.
+	* [r567] Fixed CGAlgorithms::isCCW from JTS port.
 	  Code cleanup in IsValidOp.
 2004-11-05 12:18  Sandro Santilli <strk at keybit.net>
-	* [r566] TODO: updated
+	* [r566] updated
 2004-11-05 11:41  Sandro Santilli <strk at keybit.net>
-	* [r565] source/algorithm/CGAlgorithms.cpp,
-	  source/headers/geos/opValid.h,
-	  source/operation/valid/TopologyValidationError.cpp: Made
-	  IsValidOp handle IllegalArgumentException throw from
+	* [r565] Made IsValidOp handle IllegalArgumentException throw from
 	  GeometryGraph
 	  as a sign of invalidity (just for Polygon geometries).
 	  Removed leaks generated by this specific exception.
 2004-11-04 19:08  Sandro Santilli <strk at keybit.net>
-	* [r564] source/algorithm/MinimumDiameter.cpp,
-	  source/geom/CoordinateSequence.cpp,
-	  source/headers/geos/indexChain.h,
-	  source/headers/geos/indexStrtree.h, source/headers/geos/noding.h,
-	  source/noding/MCQuadtreeNoder.cpp, source/noding/Noder.cpp,
-	  source/test/XMLTester.cpp: Cleanups, initializers list,
-	  profiling.
+	* [r564] Cleanups, initializers list, profiling.
 2004-11-04 08:49  Sandro Santilli <strk at keybit.net>
-	* [r563] source/headers/geos/indexQuadtree.h,
-	  source/headers/geos/profiler.h,
-	  source/index/quadtree/DoubleBits.cpp: Unlinked new documentation.
+	* [r563] Unlinked new documentation.
 2004-11-03 08:22  Sandro Santilli <strk at keybit.net>
-	* [r562] source/index/quadtree/DoubleBits.cpp: Slightly modified
-	  log/log2 based algo to better handle numbers in the
+	* [r562] Slightly modified log/log2 based algo to better handle
+	  numbers in the
 	  range 0-1.
 2004-11-02 16:38  Sandro Santilli <strk at keybit.net>
-	* [r561] source/headers/geos/indexQuadtree.h: Fixed ieee-754
-	  detection switch
+	* [r561] Fixed ieee-754 detection switch
 2004-11-02 16:31  Sandro Santilli <strk at keybit.net>
-	* [r560] TODO: updated
+	* [r560] updated
 2004-11-02 16:05  Sandro Santilli <strk at keybit.net>
-	* [r559] source/headers/geos/indexQuadtree.h: Autodetect
-	  availability of IEEE-754 FP
+	* [r559] Autodetect availability of IEEE-754 FP
 2004-11-02 15:49  Sandro Santilli <strk at keybit.net>
-	* [r558] source/headers/geos/indexQuadtree.h,
-	  source/index/quadtree/DoubleBits.cpp: Moved ASSUME_IEEE_DOUBLE
-	  define from DoubleBits.cpp to indexQuadtree.h.
+	* [r558] Moved ASSUME_IEEE_DOUBLE define from DoubleBits.cpp to
+	  indexQuadtree.h.
 	  Fixed a bug in powerOf2(). Made the !IEEE version less prone to
 	  round-offs (still has approximation errors).
 2004-11-02 14:13  Sandro Santilli <strk at keybit.net>
-	* [r557] source/index/quadtree/DoubleBits.cpp: Fixed bug in
-	  IEEE-based exponent and PowerOf2 computation, but disabled
+	* [r557] Fixed bug in IEEE-based exponent and PowerOf2 computation,
+	  but disabled
 	  at compile time.
 2004-11-02 14:11  Sandro Santilli <strk at keybit.net>
-	* [r556] source/noding/MCQuadtreeNoder.cpp: Added more profiling.
+	* [r556] Added more profiling.
 2004-11-02 09:38  Sandro Santilli <strk at keybit.net>
-	* [r555] source/test/XMLTester.cpp: Added timer for buffer test.
+	* [r555] Added timer for buffer test.
 2004-11-01 16:43  Sandro Santilli <strk at keybit.net>
-	* [r554] source/geom/Coordinate.cpp, source/geom/Envelope.cpp,
-	  source/geom/Makefile.am, source/geomgraph/Edge.cpp,
-	  source/geomgraph/EdgeEndStar.cpp, source/geomgraph/EdgeList.cpp,
-	  source/headers/geos/noding.h, source/headers/geos/opBuffer.h,
-	  source/headers/geos/profiler.h, source/headers/geos/util.h,
-	  source/index/quadtree/QuadTreeKey.cpp,
-	  source/index/quadtree/QuadTreeNode.cpp,
-	  source/index/quadtree/QuadTreeRoot.cpp,
-	  source/noding/NodingValidator.cpp, source/noding/SegmentNode.cpp,
-	  source/noding/nodingSegmentIntersector.cpp,
-	  source/operation/buffer/BufferOp.cpp, source/util/Profiler.cpp:
-	  Added Profiler code.
+	* [r554] Added Profiler code.
 	  Temporarly patched a bug in DoubleBits (must check drawbacks).
 	  Various cleanups and speedups.
 2004-10-27 13:57  Sandro Santilli <strk at keybit.net>
-	* [r553] source/operation/polygonize/Polygonizer.cpp,
-	  source/operation/polygonize/polygonizeEdgeRing.cpp: Added some
-	  debugging lines (disabled by default)
+	* [r553] Added some debugging lines (disabled by default)
 2004-10-27 11:05  Sandro Santilli <strk at keybit.net>
-	* [r552] TODO: updated
+	* [r552] updated
 2004-10-26 17:46  Sandro Santilli <strk at keybit.net>
-	* [r551] source/headers/geos/indexBintree.h,
-	  source/headers/geos/spatialIndex.h: Removed slash-stars in
-	  comments to remove annoying compiler warnings.
+	* [r551] Removed slash-stars in comments to remove annoying
+	  compiler warnings.
 2004-10-26 17:14  Sandro Santilli <strk at keybit.net>
-	* [r550] NEWS, configure.in: current:revision:age set to 3.0.1
-	  (will be release 2.1.0).
+	* [r550] current:revision:age set to 3.0.1 (will be release 2.1.0).
 	  added news.
 2004-10-26 16:22  Sandro Santilli <strk at keybit.net>
-	* [r549] TODO: updated
+	* [r549] updated
 2004-10-26 16:09  Sandro Santilli <strk at keybit.net>
-	* [r548] source/operation/polygonize/PolygonizeGraph.cpp,
-	  source/operation/polygonize/polygonizeEdgeRing.cpp: Some more
-	  intentation and envelope equality check fix.
+	* [r548] Some more intentation and envelope equality check fix.
 2004-10-21 22:29  Sandro Santilli <strk at keybit.net>
-	* [r547] source/algorithm/LineIntersector.cpp,
-	  source/geom/Coordinate.cpp, source/geomgraph/EdgeEnd.cpp,
-	  source/geomgraph/GeometryGraph.cpp, source/geomgraph/Node.cpp,
-	  source/geomgraph/NodeMap.cpp, source/geomgraph/PlanarGraph.cpp,
-	  source/headers/geos/geomgraph.h,
-	  source/headers/geos/opOverlay.h, source/io/WKTWriter.cpp,
-	  and some more COMPUTE_Z rules
+	* [r547] Indentation changes and some more COMPUTE_Z rules
 2004-10-21 17:13  Sandro Santilli <strk at keybit.net>
-	* [r546] source/io/WKTReader.cpp: Fixed bug introduced by previous
-	  patch.
+	* [r546] Fixed bug introduced by previous patch.
 2004-10-21 07:03  Sandro Santilli <strk at keybit.net>
-	* [r545] source/io/WKTReader.cpp: Removed leak in ::readPolygonText
-	  reported by Carlos A. Rueda
+	* [r545] Removed leak in ::readPolygonText reported by Carlos A.
+	  Rueda
 2004-10-20 17:32  Sandro Santilli <strk at keybit.net>
-	* [r544] source/algorithm/HCoordinate.cpp,
-	  source/algorithm/LineIntersector.cpp,
-	  source/geomgraph/index/MonotoneChain.cpp,
-	  source/io/WKTWriter.cpp,
-	  source/operation/overlay/PointBuilder.cpp: Initial approach to
-	  2.5d intersection()
+	* [r544] Initial approach to 2.5d intersection()
 2004-10-19 21:04  Sandro Santilli <strk at keybit.net>
-	* [r543] TODO: updated
+	* [r543] updated
 2004-10-19 19:51  Sandro Santilli <strk at keybit.net>
-	* [r542] source/geomgraph/GeometryGraph.cpp,
-	  source/headers/geos/opPolygonize.h,
-	  source/operation/polygonize/PolygonizeDirectedEdge.cpp,
-	  source/operation/polygonize/PolygonizeEdge.cpp,
-	  source/operation/polygonize/polygonizeEdgeRing.cpp,
-	  source/planargraph/planarNode.cpp,
-	  source/planargraph/planarNodeMap.cpp: Fixed many leaks and bugs
-	  in Polygonizer.
+	* [r542] Fixed many leaks and bugs in Polygonizer.
 	  Output still bogus.
 2004-10-18 12:43  Sandro Santilli <strk at keybit.net>
-	* [r541] Makefile.am, configure.in, swig, swig/.cvsignore,
-	  swig/Makefile.am, swig/python, swig/python/.cvsignore,
-	  swig/python/Makefile.am, swig/python/tests,
-	  swig/python/tests/.cvsignore, swig/python/tests/Makefile.am,
-	  swig/python/tests/cases, swig/python/tests/cases/.cvsignore,
-	  swig/python/tests/cases/Makefile.am: swig interface added to
-	  distribution.
+	* [r541] swig interface added to distribution.
 2004-10-13 10:03  Sandro Santilli <strk at keybit.net>
-	* [r540] doc/example.cpp, source/geom/CoordinateSequence.cpp,
-	  source/headers/geos/geom.h, source/headers/geos/opLinemerge.h,
-	  source/headers/geos/planargraph.h, source/io/Unload.cpp,
-	  source/operation/linemerge/EdgeString.cpp,
-	  source/operation/linemerge/LineMergeDirectedEdge.cpp,
-	  source/operation/linemerge/LineMergeEdge.cpp,
-	  source/planargraph/planarDirectedEdgeStar.cpp,
-	  source/planargraph/planarEdge.cpp,
-	  source/planargraph/planarGraphComponent.cpp,
-	  source/planargraph/planarNodeMap.cpp,
-	  source/planargraph/planarPlanarGraph.cpp: Added missing linemerge
-	  and polygonize operation.
+	* [r540] Added missing linemerge and polygonize operation.
 	  Bug fixes and leaks removal from the newly added modules and
 	  planargraph (used by them).
 	  Some comments and indentation changes.
 2004-09-23 21:36  Sandro Santilli <strk at keybit.net>
-	* [r539] source/geom/CoordinateSequence.cpp: Fixed a bug in
-	  ::reverse (thanks to Elliott Edwards)
+	* [r539] Fixed a bug in ::reverse (thanks to Elliott Edwards)
 2004-09-23 21:28  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r538] configure.in: Back minor version back to 2.0.1
+	* [r538] Back minor version back to 2.0.1
 2004-09-23 04:30  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r537] configure.in: Bumped minor version to 2.0.2 after 2.0.1
-	  release.
+	* [r537] Bumped minor version to 2.0.2 after 2.0.1 release.
 2004-09-21 09:47  Sandro Santilli <strk at keybit.net>
-	* [r536] source/precision/SimpleGeometryPrecisionReducer.cpp: fixed
-	  a mis-initialization bug in ::reduce
+	* [r536] fixed a mis-initialization bug in ::reduce
-	* [r535] source/index/quadtree/DoubleBits.cpp: Removed useless
-	  auto_ptr usage in ::exponent
+	* [r535] Removed useless auto_ptr usage in ::exponent
 2004-09-16 09:50  Sandro Santilli <strk at keybit.net>
-	* [r534] TODO: updated
+	* [r534] updated
 2004-09-16 09:48  Sandro Santilli <strk at keybit.net>
-	* [r533] source/geom/Geometry.cpp: Finer short-circuit tests for
-	  equals, within, contains.
+	* [r533] Finer short-circuit tests for equals, within, contains.
-	* [r532] source/geom/Envelope.cpp, source/headers/geos/geom.h:
-	  Added Envelope::equals
+	* [r532] Added Envelope::equals
 2004-09-16 07:32  Sandro Santilli <strk at keybit.net>
-	* [r531] TODO: updated
+	* [r531] updated
-	* [r530] source/geom/Geometry.cpp: Added short-circuit tests. Can
-	  be disabled at compile-time
+	* [r530] Added short-circuit tests. Can be disabled at compile-time
 2004-09-13 12:50  Sandro Santilli <strk at keybit.net>
-	* [r529] source/operation/valid/IsValidOp.cpp: comments cleanup
+	* [r529] comments cleanup
 2004-09-13 12:40  Sandro Santilli <strk at keybit.net>
-	* [r528] TODO: updated
+	* [r528] updated
-	* [r527] configure.in: Updated version number
+	* [r527] Updated version number
 2004-09-13 12:39  Sandro Santilli <strk at keybit.net>
-	* [r526] source/test/XMLTester.cpp: Added missing newline at end of
-	  output
+	* [r526] Added missing newline at end of output
-	* [r525] source/geom/MultiPoint.cpp, source/geom/Point.cpp,
-	  source/headers/geos/geom.h, source/headers/geos/opValid.h,
-	  source/operation/valid/IsValidOp.cpp: Made Point and MultiPoint
-	  subject to Validity tests.
+	* [r525] Made Point and MultiPoint subject to Validity tests.
 2004-09-13 10:14  Sandro Santilli <strk at keybit.net>
-	* [r524] source/operation/valid/TopologyValidationError.cpp: Added
-	  INVALID_COORDINATE code num and error message.
+	* [r524] Added INVALID_COORDINATE code num and error message.
 2004-09-13 10:12  Sandro Santilli <strk at keybit.net>
-	* [r523] TODO, source/headers/geos/geosAlgorithm.h,
-	  source/operation/valid/IsValidOp.cpp: Added invalid coordinates
-	  checks in IsValidOp.
+	* [r523] Added invalid coordinates checks in IsValidOp.
 	  Cleanups.
 2004-09-13 09:18  Sandro Santilli <strk at keybit.net>
-	* [r522] source/headers/geos/opValid.h,
-	  IsValidOp::isValid(Coordinate &)
+	* [r522] Added IsValidOp::isValid(Coordinate &)
 2004-09-13 09:07  Sandro Santilli <strk at keybit.net>
-	* [r521] source/geom/LineString.cpp: Ported fix in
-	  LineString::isCoordinate
+	* [r521] Ported fix in LineString::isCoordinate
 2004-09-12 03:51  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r520] source/geom/LineString.cpp,
-	  source/geom/MultiLineString.cpp, source/geom/MultiPoint.cpp:
-	  Casting changes to allow OS/X compilation.
+	* [r520] Casting changes to allow OS/X compilation.
 2004-09-07 08:29  Sandro Santilli <strk at keybit.net>
-	* [r519] source/headers/geos/geom.h: Fixed doxygen malformed
-	  comment for Coordinate class
+	* [r519] Fixed doxygen malformed comment for Coordinate class
 2004-08-20 03:20  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r517] source/bigtest/Makefile.am: Added reference to bigtest.h
-	  so 'make dist' includes it properly.
+	* [r517] Added reference to bigtest.h so 'make dist' includes it
+	  properly.
 2004-08-20 01:55  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r516] configure.in: Removed examples from build directories for
-	  release (they don't build now).
+	* [r516] Removed examples from build directories for release (they
+	  don't build now).
 2004-08-04 08:26  Sandro Santilli <strk at keybit.net>
-	* [r515] source/operation/relate/RelateComputer.cpp: comments lift,
-	  stack allocation reduced
+	* [r515] comments lift, stack allocation reduced
 2004-07-27 16:35  Sandro Santilli <strk at keybit.net>
-	* [r514] source/algorithm/InteriorPointArea.cpp,
-	  source/algorithm/SIRtreePointInRing.cpp,
-	  source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
-	  source/geom/GeometryFactory.cpp, source/geom/Polygon.cpp,
-	  source/geomgraph/EdgeRing.cpp, source/headers/geos/geom.h,
-	  source/headers/geos/spatialIndex.h,
-	  source/index/strtree/ItemBoundable.cpp,
-	  source/operation/distance/DistanceOp.cpp,
-	  source/operation/relate/RelateOp.cpp,
-	  source/operation/valid/QuadtreeNestedRingTester.cpp,
-	  source/operation/valid/SweeplineNestedRingTester.cpp:
-	  Geometry::getEnvelopeInternal() changed to return a const
+	* [r514] Geometry::getEnvelopeInternal() changed to return a const
 	  Envelope *.
 	  This should reduce object copies as once computed the envelope of
 	  a
@@ -16581,473 +10072,290 @@
 2004-07-26 19:28  Sean Gillies <sgillies at frii.com>
-	* [r513] AUTHORS: added to AUTHORS
+	* [r513] added to AUTHORS
 2004-07-26 18:53  Sean Gillies <sgillies at frii.com>
-	* [r512] swig/geos.i, swig/python/tests/cases/pointtest.py,
-	  swig/python/tests/cases/wkttest.py: added simple exception
-	  handling on all method calls
+	* [r512] added simple exception handling on all method calls
 2004-07-26 16:35  Sandro Santilli <strk at keybit.net>
-	* [r511] source/headers/geos/geom.h: Removed dangling
-	  MultiPoint::isClosed() method definition.
+	* [r511] Removed dangling MultiPoint::isClosed() method definition.
 2004-07-26 15:40  Sean Gillies <sgillies at frii.com>
-	* [r510] swig/geos.i, swig/python/setup.py,
-	  swig/python/tests/cases/wkttest.py,
-	  swig/python/tests/runtests.py: wrapped up WKT reader and writer
-	  and added two test cases to check that it works. found a bug
-	  where the WKT reader crashes the program in the case of poorly
-	  formatted WKT string.
+	* [r510] wrapped up WKT reader and writer and added two test cases
+	  to check that it works. found a bug where the WKT reader crashes
+	  the program in the case of poorly formatted WKT string.
 2004-07-25 23:45  Sean Gillies <sgillies at frii.com>
-	* [r509] swig, swig/README.txt, swig/geos.i, swig/python,
-	  swig/python/README.txt, swig/python/setup.py, swig/python/tests,
-	  swig/python/tests/TESTING.txt, swig/python/tests/cases,
-	  swig/python/tests/cases/__init__.py,
-	  swig/python/tests/cases/pointtest.py,
-	  swig/python/tests/cases/testing.py,
-	  swig/python/tests/runtests.py: SWIG interface for high level
-	  language modules, Python setup script, and beginning of a unit
-	  testing framework under swig/python/tests. The build works for
-	  today's CVS GEOS, and the test passes -- means that a module can
-	  be built, installed, and imported.
+	* [r509] SWIG interface for high level language modules, Python
+	  setup script, and beginning of a unit testing framework under
+	  swig/python/tests. The build works for today's CVS GEOS, and the
+	  test passes -- means that a module can be built, installed, and
+	  imported.
 2004-07-22 16:58  Sandro Santilli <strk at keybit.net>
-	* [r508] TODO, doc/example.cpp, source/geom/Geometry.cpp,
-	  source/headers/geos/geom.h: runtime version extractor functions
-	  split. geos::version() is now
+	* [r508] runtime version extractor functions split. geos::version()
+	  is now
 	  geos::geosversion() and geos::jtsport()
 2004-07-22 08:45  Sandro Santilli <strk at keybit.net>
-	* [r507] TODO, source/geom/GeometryCollection.cpp,
-	  source/geom/LineString.cpp, source/geom/MultiLineString.cpp,
-	  source/geom/MultiPoint.cpp, source/headers/geos/geom.h:
-	  Documentation updates, memory leaks fixed.
+	* [r507] Documentation updates, memory leaks fixed.
 2004-07-22 07:19  Sandro Santilli <strk at keybit.net>
-	* [r506] source/headers/geos/geom.h: Changed getCoordinatesRO
-	  description.
+	* [r506] Changed getCoordinatesRO description.
 2004-07-22 07:04  Sandro Santilli <strk at keybit.net>
-	* [r505] source/geom/Coordinate.cpp,
-	  source/geom/GeometryCollection.cpp, source/geom/Polygon.cpp,
-	  source/headers/geos/geom.h: Documented missing geometry
-	  functions.
+	* [r505] Documented missing geometry functions.
 2004-07-21 09:55  Sandro Santilli <strk at keybit.net>
-	* [r504] source/geom/Coordinate.cpp,
-	  source/geom/CoordinateList.cpp,
-	  source/geom/CoordinateSequence.cpp, source/geom/Envelope.cpp,
-	  source/geom/Geometry.cpp, source/geom/LineSegment.cpp,
-	  source/geom/PrecisionModel.cpp, source/geomgraph/Edge.cpp,
-	  source/headers/geos.h, source/headers/geos/geom.h:
-	  CoordinateSequence::atLeastNCoordinatesOrNothing definition fix.
+	* [r504] CoordinateSequence::atLeastNCoordinatesOrNothing
+	  definition fix.
 	  Documentation fixes.
 2004-07-21 09:11  Sandro Santilli <strk at keybit.net>
-	* [r503] NEWS, README, TODO: Updated
+	* [r503] Updated
 2004-07-20 08:35  Sandro Santilli <strk at keybit.net>
-	* [r502] doc/README: Updated doxygen rule
+	* [r502] Updated doxygen rule
 2004-07-20 08:34  Sandro Santilli <strk at keybit.net>
-	* [r501] doc/Doxyfile.in, source/geom/CoordinateList.cpp,
-	  source/geom/Geometry.cpp, source/headers/geos/geom.h,
-	  source/headers/geos/opDistance.h: Fixed a bug in opDistance.h.
+	* [r501] Fixed a bug in opDistance.h.
 	  Removed doxygen tags from obsoleted CoordinateList.cpp.
 	  Got doxygen to run with no warnings.
 2004-07-19 19:37  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r500] doc/Makefile.am: Changed doxygen target to be more "make
-	  dist" friendly. (and allow autogeneration of CVS snapshot to work
-	  again.)
+	* [r500] Changed doxygen target to be more "make dist" friendly.
+	  (and allow autogeneration of CVS snapshot to work again.)
 2004-07-19 13:19  Sandro Santilli <strk at keybit.net>
-	* [r499] doc/Doxyfile.in, source/geom/Envelope.cpp,
-	  source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
-	  source/geom/LineString.cpp, source/headers/geos/geom.h,
-	  source/headers/geos/geomUtil.h, source/headers/geos/geomgraph.h,
-	  source/headers/geos/geomgraphindex.h,
-	  source/headers/geos/indexBintree.h,
-	  source/headers/geos/indexSweepline.h,
-	  source/headers/geos/nodingSnapround.h,
-	  source/headers/geos/opBuffer.h, source/headers/geos/opDistance.h,
-	  source/headers/geos/opLinemerge.h,
-	  source/headers/geos/opRelate.h, source/headers/geos/opValid.h,
-	  source/headers/geos/precision.h,
-	  source/headers/geos/spatialIndex.h, source/io/WKTWriter.cpp:
-	  Documentation fixes
+	* [r499] Documentation fixes
 2004-07-19 10:38  Sandro Santilli <strk at keybit.net>
-	* [r498] doc, doc/.cvsignore: Added Doxyfile
+	* [r498] Added Doxyfile
-	* [r497] TODO: updated
+	* [r497] updated
 2004-07-19 10:37  Sandro Santilli <strk at keybit.net>
-	* [r496] doc/Makefile.am: Doxygen doc added to default build rules
+	* [r496] Doxygen doc added to default build rules
-	* [r495] source/geom/DefaultCoordinateSequenceFactory.cpp:
-	  defaultCoordinateSequenceFactory made module-static (use
+	* [r495] defaultCoordinateSequenceFactory made module-static (use
 	  DefaultCoordinateSequenceFactory::instance() instead)
 2004-07-19 10:35  Sandro Santilli <strk at keybit.net>
-	* [r494] source/bigtest/GeometryTestFactory.cpp,
-	  source/bigtest/TestSweepLineSpeed.cpp, source/bigtest/bigtest.h,
-	  source/headers/geos/bigtest.h: bigtest.h moved to local dir
+	* [r494] bigtest.h moved to local dir
 2004-07-19 10:34  Sandro Santilli <strk at keybit.net>
-	* [r493] source/headers/geos/geom.h: removed doxygen documentation
-	  of removed feature
+	* [r493] removed doxygen documentation of removed feature
 2004-07-19 10:33  Sandro Santilli <strk at keybit.net>
-	* [r492] source/headers/geos/io.h: Class documentation changed to
-	  report geos.h as WKT writer/parser header file
+	* [r492] Class documentation changed to report geos.h as WKT
+	  writer/parser header file
 2004-07-19 10:30  Sandro Santilli <strk at keybit.net>
-	* [r491] source/headers/acconfig.h,
-	  source/headers/geos/Makefile.am, source/headers/geos/acconfig.h:
-	  acconfig.h moved one directory up
+	* [r491] acconfig.h moved one directory up
 2004-07-19 10:28  Sandro Santilli <strk at keybit.net>
-	* [r490] doc/Doxyfile.in: Excluded example and test dirs from input
-	  set
+	* [r490] Excluded example and test dirs from input set
 2004-07-17 10:48  Sandro Santilli <strk at keybit.net>
-	* [r489] TODO: updated
+	* [r489] updated
-	* [r488] doc, doc/.cvsignore: added Doxyfile (generated)
+	* [r488] added Doxyfile (generated)
-	* [r487] source/geom/Geometry.cpp: fixed typo in documentation
+	* [r487] fixed typo in documentation
 2004-07-17 10:47  Sandro Santilli <strk at keybit.net>
-	* [r486] configure.in, doc/Doxyfile, doc/Doxyfile.in: Doxygen
-	  configuration created at ./configure time, for versioning.
+	* [r486] Doxygen configuration created at ./configure time, for
+	  versioning.
 2004-07-17 09:19  Sandro Santilli <strk at keybit.net>
-	* [r485] doc/example.cpp: added GEOS version report
+	* [r485] added GEOS version report
 2004-07-17 09:18  Sandro Santilli <strk at keybit.net>
-	* [r484] source/geom/Geometry.cpp, source/headers/geos/geom.h:
-	  Added geos::version()
+	* [r484] Added geos::version()
 2004-07-17 09:07  Sandro Santilli <strk at keybit.net>
-	* [r483] tools/geos-config.in: Added --jtsport
+	* [r483] Added --jtsport
 2004-07-17 09:06  Sandro Santilli <strk at keybit.net>
-	* [r482] source/headers/geos/version.h.in: Added
-	  GEOS_FIRST_INTERFACE, GEOS_LAST_INTERFACE and GEOS_JTS_PORT
+	* [r482] Added GEOS_FIRST_INTERFACE, GEOS_LAST_INTERFACE and
+	  GEOS_JTS_PORT
 2004-07-17 09:05  Sandro Santilli <strk at keybit.net>
-	* [r481] configure.in: Added JTS_PORT variable.
+	* [r481] Added JTS_PORT variable.
 	  Simplified versioning settings: comments added,
 	  major/minor/patchlevel
 	  extracted by CURRENT,AGE,REVISION.
 2004-07-16 17:02  Sandro Santilli <strk at keybit.net>
-	* [r480] TODO: updated
+	* [r480] updated
 2004-07-16 16:20  Sandro Santilli <strk at keybit.net>
-	* [r479] configure.in, source/geom/Makefile.am: Libtool versioning
-	  scheme adopted.
+	* [r479] Libtool versioning scheme adopted.
 2004-07-16 16:09  Sandro Santilli <strk at keybit.net>
-	* [r478] doc/Makefile.am: removed useless Includedir
+	* [r478] removed useless Includedir
 2004-07-16 15:57  Sandro Santilli <strk at keybit.net>
-	* [r477] source/headers/geos.h: made includes use <>
+	* [r477] made includes use <>
 2004-07-16 13:27  Sandro Santilli <strk at keybit.net>
-	* [r476] TODO: updated
+	* [r476] updated
 2004-07-16 10:28  Sandro Santilli <strk at keybit.net>
-	* [r475] source/headers/geos/util.h,
-	  source/util/GeometricShapeFactory.cpp: Dimesions object allocated
-	  on the heap
+	* [r475] Dimesions object allocated on the heap
 2004-07-16 10:00  Sandro Santilli <strk at keybit.net>
-	* [r474] doc/example.cpp: Bug fixed in GeometricShapeFactory
-	  examples.
+	* [r474] Bug fixed in GeometricShapeFactory examples.
 	  Added example of GeometricShapeFactory::createArc.
 2004-07-16 09:58  Sandro Santilli <strk at keybit.net>
-	* [r473] TODO: updated
+	* [r473] updated
-	* [r472] doc/example.tosql: Added LINEARRING to LINESTRING
-	  conversion
+	* [r472] Added LINEARRING to LINESTRING conversion
 2004-07-16 09:57  Sandro Santilli <strk at keybit.net>
-	* [r471] source/geom/Makefile.am: Modified library version to 1.4.0
+	* [r471] Modified library version to 1.4.0
 2004-07-15 13:41  Sandro Santilli <strk at keybit.net>
-	* [r470] doc/example.cpp: Added createRectangle example.
+	* [r470] Added createRectangle example.
 2004-07-15 13:40  Sandro Santilli <strk at keybit.net>
-	* [r469] source/util/GeometricShapeFactory.cpp: Memory leaks fixed,
-	  CoordinateSequence use made JTS - compatible.
+	* [r469] Memory leaks fixed, CoordinateSequence use made JTS -
+	  compatible.
 2004-07-14 21:21  Sandro Santilli <strk at keybit.net>
-	* [r468] TODO: updated
+	* [r468] updated
 2004-07-14 21:20  Sandro Santilli <strk at keybit.net>
-	* [r467] source/geom/Geometry.cpp: Added GeometricShapeFactory note
-	  on doxygen mainpage
+	* [r467] Added GeometricShapeFactory note on doxygen mainpage
-	* [r466] source/headers/geos.h: added geos/io.h and geos/unload.h
+	* [r466] added geos/io.h and geos/unload.h
 2004-07-14 21:19  Sandro Santilli <strk at keybit.net>
-	* [r465] source/headers/geos/util.h,
-	  source/util/GeometricShapeFactory.cpp: GeometricShapeFactory
-	  first pass of bug fixes
+	* [r465] GeometricShapeFactory first pass of bug fixes
 2004-07-14 21:17  Sandro Santilli <strk at keybit.net>
-	* [r464] source/geom/Makefile.am: added missing
-	  GeometricShapeFactory.cpp
+	* [r464] added missing GeometricShapeFactory.cpp
-	* [r463] source/geom/Coordinate.cpp, source/headers/geos/geom.h:
-	  added inequality operator for Coordinate
+	* [r463] added inequality operator for Coordinate
 2004-07-14 21:15  Sandro Santilli <strk at keybit.net>
-	* [r462] doc/example.cpp, doc/example.tosql: Added
-	  GeometricShapeFactory example: createCircle.
+	* [r462] Added GeometricShapeFactory example: createCircle.
 	  Added simple filter to send example output to a postgis table.
 2004-07-13 08:33  Sandro Santilli <strk at keybit.net>
-	* [r461] source/geom/GeometryFactory.cpp, source/geom/Polygon.cpp,
-	  source/index/bintree/Bintree.cpp,
-	  source/operation/buffer/BufferBuilder.cpp,
-	  source/operation/buffer/OffsetCurveBuilder.cpp,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp,
-	  source/planargraph/planarGraphComponent.cpp: Added missing
-	  virtual destructor to virtual classes.
+	* [r461] Added missing virtual destructor to virtual classes.
 	  Fixed implicit unsigned int -> int casts
 2004-07-12 19:16  Sandro Santilli <strk at keybit.net>
-	* [r460] source/headers/geos/geom.h: Commented out CoordinateList
-	  class definition.
+	* [r460] Commented out CoordinateList class definition.
 2004-07-12 15:42  Sandro Santilli <strk at keybit.net>
-	* [r459] source/geom/PrecisionModel.cpp: Fixed maximumPreciseValue
-	  scope
+	* [r459] Fixed maximumPreciseValue scope
 2004-07-09 08:01  Sandro Santilli <strk at keybit.net>
-	* [r458] TODO: updated
+	* [r458] updated
 2004-07-08 19:41  Sandro Santilli <strk at keybit.net>
-	* [r457] source/examples/CoordinateListsExample.cpp,
-	  source/examples/CoordinateSequencesExample.cpp,
-	  source/examples/CustomCoordinateListExample.cpp,
-	  source/examples/CustomCoordinateListExample.h,
-	  source/examples/CustomCoordinateSequenceExample.cpp,
-	  source/examples/CustomCoordinateSequenceExample.h,
-	  source/examples/CustomPointCoordinateList.cpp,
-	  source/examples/CustomPointCoordinateSequence.cpp: renamed to
-	  reflect JTS API.
+	* [r457] renamed to reflect JTS API.
 2004-07-08 19:38  Sandro Santilli <strk at keybit.net>
-	* [r456] source/geom/CoordinateSequence.cpp,
-	  source/geom/CoordinateSequenceFactory.cpp,
-	  source/geom/DefaultCoordinateSequence.cpp,
-	  source/geom/DefaultCoordinateSequenceFactory.cpp,
-	  source/geom/PointCoordinateSequenceFactory.cpp: renamed from
-	  *List* equivalents
+	* [r456] renamed from *List* equivalents
 2004-07-08 19:37  Sandro Santilli <strk at keybit.net>
-	* [r455] source/geom/PointCoordinateList.cpp: Renamed to
-	  PointCoordinateSequence.cpp
+	* [r455] Renamed to PointCoordinateSequence.cpp
-	* [r454] source/geom/CoordinateListFactory.cpp: Renamed to
-	  CoordinateSequenceFactory.cpp
+	* [r454] Renamed to CoordinateSequenceFactory.cpp
 2004-07-08 19:36  Sandro Santilli <strk at keybit.net>
-	* [r453] source/geom/BasicCoordinateList.cpp: Renamed to
-	  DefaultCoordinateSequence.cpp
+	* [r453] Renamed to DefaultCoordinateSequence.cpp
 2004-07-08 19:34  Sandro Santilli <strk at keybit.net>
-	* [r452] TODO, doc/example.cpp, source/Makefile.am,
-	  source/algorithm/CGAlgorithms.cpp,
-	  source/algorithm/CentroidArea.cpp,
-	  source/algorithm/CentroidLine.cpp,
-	  source/algorithm/ConvexHull.cpp,
-	  source/algorithm/InteriorPointArea.cpp,
-	  source/algorithm/InteriorPointLine.cpp,
-	  source/algorithm/MCPointInRing.cpp,
-	  source/algorithm/MinimumDiameter.cpp,
-	  source/algorithm/NonRobustCGAlgorithms.cpp,
-	  source/algorithm/PointLocator.cpp,
-	  source/algorithm/SimplePointInAreaLocator.cpp,
-	  source/examples/CPCLException.cpp,
-	  source/examples/CoordinateListsExample.cpp,
-	  source/examples/Makefile.am, source/geom/CoordinateList.cpp,
-	  source/geom/GeometryFactory.cpp, source/geom/LineSegment.cpp,
-	  source/geom/LineString.cpp, source/geom/LinearRing.cpp,
-	  source/geom/Makefile.am, source/geom/MultiLineString.cpp,
-	  source/geom/MultiPoint.cpp, source/geom/MultiPolygon.cpp,
-	  source/geom/Point.cpp, source/geom/Polygon.cpp,
-	  source/geom/util/GeometryEditor.cpp, source/geomgraph/Edge.cpp,
-	  source/geomgraph/EdgeList.cpp, source/geomgraph/EdgeRing.cpp,
-	  source/geomgraph/index/MonotoneChainIndexer.cpp,
-	  source/geomgraph/index/SimpleEdgeSetIntersector.cpp,
-	  source/geomgraph/index/SimpleSweepLineIntersector.cpp,
-	  source/headers/geos/bigtest.h, source/headers/geos/geom.h,
-	  source/headers/geos/indexChain.h, source/headers/geos/io.h,
-	  source/headers/geos/opDistance.h,
-	  source/headers/geos/opValid.h, source/headers/geos/precision.h,
-	  source/headers/geos/util.h,
-	  source/index/chain/indexMonotoneChain.cpp, source/io/Unload.cpp,
-	  source/io/WKTReader.cpp, source/noding/MCQuadtreeNoder.cpp,
-	  source/noding/SegmentString.cpp, source/noding/SimpleNoder.cpp,
-	  source/noding/snapround/SimpleSegmentStringsSnapper.cpp,
-	  source/operation/buffer/RightmostEdgeFinder.cpp,
-	  source/operation/buffer/SubgraphDepthLocater.cpp,
-	  source/operation/linemerge/LineMergeGraph.cpp,
-	  source/operation/valid/ConnectedInteriorTester.cpp,
-	  source/operation/valid/RepeatedPointTester.cpp,
-	  source/operation/valid/SimpleNestedRingTester.cpp,
-	  source/operation/valid/SweeplineNestedRingTester.cpp,
-	  source/precision/SimpleGeometryPrecisionReducer.cpp,
-	  source/util/CoordinateArrayFiter.cpp,
-	  source/util/GeometricShapeFactory.cpp,
-	  source/util/UniqueCoordinateArrayFilter.cpp: Mirrored JTS
-	  interface of CoordinateSequence, factory and
+	* [r452] Mirrored JTS interface of CoordinateSequence, factory and
 	  default implementations.
 	  Added DefaultCoordinateSequenceFactory::instance() function.
 2004-07-07 18:54  Sandro Santilli <strk at keybit.net>
-	* [r451] TODO: updated
+	* [r451] updated
 2004-07-07 10:29  Sandro Santilli <strk at keybit.net>
-	* [r450] source/algorithm/NotRepresentableException.cpp,
-	  source/headers/geos/geosAlgorithm.h, source/headers/geos/io.h,
-	  source/headers/geos/util.h: Adjusted exceptions documentation.
+	* [r450] Adjusted exceptions documentation.
 2004-07-07 09:38  Sandro Santilli <strk at keybit.net>
-	* [r449] NEWS, source/geom/Geometry.cpp,
-	  source/headers/geos/geom.h, source/headers/geos/geosAlgorithm.h,
-	  source/headers/geos/io.h, source/io/WKTReader.cpp,
-	  source/io/WKTWriter.cpp, source/test/XMLTester.cpp: Dropped
-	  WKTWriter::stringOfChars (implemented by std::string).
+	* [r449] Dropped WKTWriter::stringOfChars (implemented by
+	  std::string).
 	  Dropped WKTWriter default constructor (internally created
 	  GeometryFactory).
 	  Updated XMLTester to respect the changes.
@@ -17055,22 +10363,14 @@
 2004-07-07 07:52  Sandro Santilli <strk at keybit.net>
-	* [r448] TODO, source/operation/buffer/BufferSubgraph.cpp: Removed
-	  note about required speedup in BufferSubgraph.
+	* [r448] Removed note about required speedup in BufferSubgraph.
 	  I've made tests with 'sets' and there is actually a big slow
 	  down..
 2004-07-06 17:58  Sandro Santilli <strk at keybit.net>
-	* [r447] source/geom/Geometry.cpp,
-	  source/geom/GeometryCollection.cpp, source/geom/LineString.cpp,
-	  source/geom/LinearRing.cpp, source/geom/MultiLineString.cpp,
-	  source/headers/geos/geom.h, source/headers/geos/precision.h,
-	  source/precision/SimpleGeometryPrecisionReducer.cpp: Removed
-	  deprecated Geometry constructors based on PrecisionModel and
+	* [r447] Removed deprecated Geometry constructors based on
+	  PrecisionModel and
 	  SRID specification. Removed SimpleGeometryPrecisionReducer
 	  capability
 	  of changing Geometry's factory. Reverted Geometry::factory member
@@ -17078,38 +10378,24 @@
 2004-07-05 19:40  Sandro Santilli <strk at keybit.net>
-	* [r446] source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
-	  source/headers/geos/geom.h: Added
-	  GeometryFactory::destroyGeometry(Geometry *)
+	* [r446] Added GeometryFactory::destroyGeometry(Geometry *)
 2004-07-05 15:20  Sandro Santilli <strk at keybit.net>
-	* [r445] TODO, source/geom/Geometry.cpp,
-	  source/headers/geos/geom.h: Documentation again.
+	* [r445] Documentation again.
 2004-07-05 14:23  Sandro Santilli <strk at keybit.net>
-	* [r444] NEWS, source/geom/CoordinateList.cpp,
-	  source/geom/GeometryFactory.cpp, source/geom/LineString.cpp,
-	  source/geom/PrecisionModel.cpp, source/headers/geos/geom.h,
-	  source/headers/geos/util.h: More documentation cleanups.
+	* [r444] More documentation cleanups.
 2004-07-05 11:50  Sandro Santilli <strk at keybit.net>
-	* [r443] doc/README: initial import
+	* [r443] initial import
 2004-07-05 10:50  Sandro Santilli <strk at keybit.net>
-	* [r442] NEWS, doc/Doxyfile, source/geom/BasicCoordinateList.cpp,
-	  source/geom/Point.cpp, source/geom/PointCoordinateList.cpp,
-	  source/geom/Polygon.cpp, source/headers/geos.h,
-	  source/headers/geos/geom.h, source/headers/geos/util.h,
-	  source/io/WKTReader.cpp: deep-dopy construction taken out of
-	  Geometry and implemented only
+	* [r442] deep-dopy construction taken out of Geometry and
+	  implemented only
 	  in GeometryFactory.
 	  Deep-copy geometry construction takes care of cleaning up copies
 	  on exception.
@@ -17120,303 +10406,53 @@
 2004-07-03 12:54  Sandro Santilli <strk at keybit.net>
-	* [r441] source/headers/geos, source/headers/geos/.cvsignore: more
-	  entries
+	* [r441] more entries
 2004-07-03 12:51  Sandro Santilli <strk at keybit.net>
-	* [r440] source/algorithm/NotRepresentableException.cpp,
-	  source/geom/LineString.cpp, source/geom/PrecisionModel.cpp,
-	  source/headers/geos.h, source/headers/geos/geom.h: Documentation
-	  cleanups for DoxyGen.
+	* [r440] Documentation cleanups for DoxyGen.
 2004-07-02 17:22  Sandro Santilli <strk at keybit.net>
-	* [r439] doc/Doxyfile, doc/Makefile.am, doc/geosDoxygen.conf:
-	  Doxygen configuration file renamed.
+	* [r439] Doxygen configuration file renamed.
 2004-07-02 14:27  Sandro Santilli <strk at keybit.net>
-	* [r438] source/geom/GeometryFactory.cpp, source/geom/Point.cpp,
-	  source/headers/geos/geom.h: Added deep-copy / take-ownerhship for
-	  Point type.
+	* [r438] Added deep-copy / take-ownerhship for Point type.
 2004-07-02 13:28  Sandro Santilli <strk at keybit.net>
-	* [r437] ChangeLog, README, configure.in, doc/Makefile.am,
-	  doc/example.cpp, source/algorithm/CGAlgorithms.cpp,
-	  source/algorithm/CentroidPoint.cpp,
-	  source/algorithm/HCoordinate.cpp,
-	  source/algorithm/InteriorPointPoint.cpp,
-	  source/algorithm/NonRobustLineIntersector.cpp,
-	  source/algorithm/NotRepresentableException.cpp,
-	  source/algorithm/RobustCGAlgorithms.cpp,
-	  source/algorithm/RobustDeterminant.cpp,
-	  source/algorithm/RobustLineIntersector.cpp,
-	  source/algorithm/SimplePointInRing.cpp,
-	  source/geom/BasicCoordinateList.cpp, source/geom/Coordinate.cpp,
-	  source/geom/CoordinateListFactory.cpp, source/geom/Dimension.cpp,
-	  source/geom/Envelope.cpp, source/geom/Geometry.cpp,
-	  source/geom/GeometryCollectionIterator.cpp,
-	  source/geom/GeometryComponentFilter.cpp,
-	  source/geom/Location.cpp, source/geom/MultiLineString.cpp,
-	  source/geom/Polygon.cpp, source/geom/PrecisionModel.cpp,
-	  source/geom/TopologyException.cpp, source/geom/Triangle.cpp,
-	  source/geom/util/LinearComponentExtracter.cpp,
-	  source/geom/util/PointExtracter.cpp,
-	  source/geom/util/PolygonExtracter.cpp,
-	  source/geomgraph/Depth.cpp, source/geomgraph/DirectedEdge.cpp,
-	  source/geomgraph/DirectedEdgeStar.cpp, source/geomgraph/Edge.cpp,
-	  source/geomgraph/EdgeEnd.cpp, source/geomgraph/EdgeEndStar.cpp,
-	  source/geomgraph/EdgeIntersection.cpp,
-	  source/geomgraph/EdgeNodingValidator.cpp,
-	  source/geomgraph/GraphComponent.cpp, source/geomgraph/Label.cpp,
-	  source/geomgraph/Node.cpp, source/geomgraph/NodeFactory.cpp,
-	  source/geomgraph/Position.cpp, source/geomgraph/Quadrant.cpp,
-	  source/geomgraph/TopologyLocation.cpp,
-	  source/geomgraph/index/SweepLineEvent.cpp,
-	  source/geomgraph/index/SweepLineSegment.cpp,
-	  source/index/bintree/BinTreeInterval.cpp,
-	  source/index/bintree/BinTreeNode.cpp,
-	  source/index/bintree/Bintree.cpp, source/index/bintree/Key.cpp,
-	  source/index/bintree/NodeBase.cpp, source/index/bintree/Root.cpp,
-	  source/index/chain/MonotoneChainBuilder.cpp,
-	  source/index/quadtree/IntervalSize.cpp,
-	  source/index/strtree/AbstractNode.cpp,
-	  source/index/strtree/AbstractSTRtree.cpp,
-	  source/index/strtree/Interval.cpp,
-	  source/index/strtree/SIRtree.cpp,
-	  source/index/strtree/STRtree.cpp,
-	  source/index/sweepline/SweepLineInterval.cpp,
-	  source/index/sweepline/indexSweepLineEvent.cpp,
-	  source/io/ParseException.cpp, source/io/StringTokenizer.cpp,
-	  source/io/Unload.cpp, source/io/WKTReader.cpp,
-	  source/io/WKTWriter.cpp, source/io/Writer.cpp,
-	  source/io/markup/MarkupSTL.cpp, source/noding/IteratedNoder.cpp,
-	  source/noding/SegmentNodeList.cpp,
-	  source/noding/snapround/SegmentSnapper.cpp,
-	  source/noding/snapround/SnapRounder.cpp,
-	  source/operation/GeometryGraphOperation.cpp,
-	  source/operation/IsSimpleOp.cpp,
-	  source/operation/buffer/BufferSubgraph.cpp,
-	  source/operation/distance/ConnectedElementLocationFilter.cpp,
-	  source/operation/distance/ConnectedElementPointFilter.cpp,
-	  source/operation/distance/GeometryLocation.cpp,
-	  source/operation/overlay/EdgeSetNoder.cpp,
-	  source/operation/overlay/LineBuilder.cpp,
-	  source/operation/overlay/MaximalEdgeRing.cpp,
-	  source/operation/overlay/MinimalEdgeRing.cpp,
-	  source/operation/overlay/OverlayNodeFactory.cpp,
-	  source/operation/overlay/OverlayOp.cpp,
-	  source/operation/overlay/PointBuilder.cpp,
-	  source/operation/overlay/PolygonBuilder.cpp,
-	  source/operation/relate/EdgeEndBuilder.cpp,
-	  source/operation/relate/EdgeEndBundle.cpp,
-	  source/operation/relate/EdgeEndBundleStar.cpp,
-	  source/operation/relate/RelateComputer.cpp,
-	  source/operation/relate/RelateNode.cpp,
-	  source/operation/relate/RelateNodeFactory.cpp,
-	  source/operation/relate/RelateNodeGraph.cpp,
-	  source/operation/valid/ConsistentAreaTester.cpp,
-	  source/operation/valid/TopologyValidationError.cpp,
-	  source/planargraph/planarPlanarGraph.cpp,
-	  source/precision/CommonBits.cpp,
-	  source/precision/CommonBitsOp.cpp,
-	  source/precision/CommonBitsRemover.cpp,
-	  source/precision/EnhancedPrecisionOp.cpp,
-	  source/test/CTS.cpp, source/test/SimpleWKTTester.cpp,
-	  source/test/XMLTester.cpp, source/util/Assert.cpp,
-	  source/util/AssertionFailedException.cpp,
-	  source/util/GEOSException.cpp,
-	  source/util/IllegalArgumentException.cpp,
-	  source/util/UniqueCoordinateArrayFilter.cpp,
-	  source/util/UnsupportedOperationException.cpp: Fixed all #include
-	  lines to reflect headers layout change.
+	* [r437] Fixed all #include lines to reflect headers layout change.
 	  Added client application build tips in README.
 2004-07-02 13:21  Sandro Santilli <strk at keybit.net>
-	* [r436] source/headers/geos_version.h.in: renamed to
-	  geos/version.h.in
+	* [r436] renamed to geos/version.h.in
 2004-07-02 13:20  Sandro Santilli <strk at keybit.net>
-	* [r435] source/headers, source/headers/.cvsignore,
-	  source/headers/Makefile.am, source/headers/acconfig.h,
-	  source/headers/bigtest.h, source/headers/geom.h,
-	  source/headers/geomUtil.h, source/headers/geomgraph.h,
-	  source/headers/geomgraphindex.h, source/headers/geos,
-	  source/headers/geos.h, source/headers/geos/.cvsignore,
-	  source/headers/geos/Makefile.am, source/headers/geos/acconfig.h,
-	  source/headers/geos/bigtest.h, source/headers/geos/config.h,
-	  source/headers/geos/geom.h, source/headers/geos/geomUtil.h,
-	  source/headers/geos/indexSweepline.h, source/headers/geos/io.h,
-	  source/headers/geos/platform.h.in,
-	  source/headers/geos/spatialIndex.h, source/headers/geos/unload.h,
-	  source/headers/geos/util.h, source/headers/geos/version.h.in,
-	  source/headers/geosAlgorithm.h, source/headers/indexBintree.h,
-	  source/headers/indexChain.h, source/headers/indexQuadtree.h,
-	  source/headers/indexStrtree.h, source/headers/indexSweepline.h,
-	  source/headers/io.h, source/headers/noding.h,
-	  source/headers/nodingSnapround.h, source/headers/opBuffer.h,
-	  source/headers/opDistance.h, source/headers/opLinemerge.h,
-	  source/headers/opOverlay.h, source/headers/opPolygonize.h,
-	  source/headers/opRelate.h, source/headers/opValid.h,
-	  source/headers/operation.h, source/headers/planargraph.h,
-	  source/headers/platform.h.in, source/headers/precision.h,
-	  source/headers/spatialIndex.h, source/headers/unload.h,
-	  source/headers/util.h: Header files moved under geos/ dir.
+	* [r435] Header files moved under geos/ dir.
 2004-07-01 17:34  Sandro Santilli <strk at keybit.net>
-	* [r434] source/geom/Geometry.cpp: GeometryFactory argument in
-	  Geometry constructor reverted
+	* [r434] GeometryFactory argument in Geometry constructor reverted
 	  to its copy-and-destroy semantic.
 2004-07-01 17:07  Sandro Santilli <strk at keybit.net>
-	* [r433] doc, doc/.cvsignore, doc/Makefile.am: Added doxygen_docs
-	  generation rule
+	* [r433] Added doxygen_docs generation rule
 2004-07-01 16:49  Sandro Santilli <strk at keybit.net>
-	* [r432] doc/geosDoxygen.conf: re-generated with doxygen 1.2.15
+	* [r432] re-generated with doxygen 1.2.15
 2004-07-01 15:47  cvs
-	* [r431] doc/geosDoxygen.conf: Added doxygen file for better doco
-	  generation.
+	* [r431] Added doxygen file for better doco generation.
 2004-07-01 14:12  Sandro Santilli <strk at keybit.net>
-	* [r430] ChangeLog, NEWS, TODO, doc/example.cpp,
-	  source/algorithm/InteriorPointArea.cpp, source/geom/Geometry.cpp,
-	  source/geomgraph/EdgeRing.cpp, source/headers/geom.h,
-	  source/headers/opBuffer.h, source/headers/opOverlay.h,
-	  source/io/WKTReader.cpp, source/noding/SegmentNodeList.cpp,
-	  source/util/GeometricShapeFactory.cpp: Geometry constructors come
-	  now in two flavors:
+	* [r430] Geometry constructors come now in two flavors:
 	  - deep-copy args (pass-by-reference)
 	  - take-ownership of args (pass-by-pointer)
 	  Same functionality is available through GeometryFactory,
@@ -17424,456 +10460,349 @@
 2004-06-30 20:59  Sandro Santilli <strk at keybit.net>
-	* [r429] source/geom/Geometry.cpp,
-	  source/headers/geomgraph.h, source/headers/geosAlgorithm.h,
-	  source/operation/overlay/PolygonBuilder.cpp: Removed
-	  GeoemtryFactory copy from geometry constructors.
+	* [r429] Removed GeoemtryFactory copy from geometry constructors.
 	  Enforced const-correctness on GeometryFactory arguments.
 2004-06-28 21:58  Sandro Santilli <strk at keybit.net>
-	* [r428] source/geom/Polygon.cpp: Constructors speedup.
+	* [r428] Constructors speedup.
 2004-06-28 21:11  Sandro Santilli <strk at keybit.net>
-	* [r427] source/geom/GeometryCollection.cpp,
-	  source/geom/MultiLineString.cpp, source/geom/MultiPoint.cpp,
-	  source/geom/MultiPolygon.cpp, source/geom/Point.cpp,
-	  source/geom/Polygon.cpp, source/headers/geom.h: Moved
-	  getGeometryTypeId() definitions from geom.h to each geometry
-	  module.
+	* [r427] Moved getGeometryTypeId() definitions from geom.h to each
+	  geometry module.
 	  Added holes argument check in Polygon.cpp.
 2004-06-25 14:26  Sandro Santilli <strk at keybit.net>
-	* [r426] tools/geos-config.in: fixed --includes
+	* [r426] fixed --includes
 2004-06-22 16:57  Sandro Santilli <strk at keybit.net>
-	* [r425] NEWS: Written down some news
+	* [r425] Written down some news
 2004-06-22 16:56  Sandro Santilli <strk at keybit.net>
-	* [r424] source/headers/Makefile.am, source/headers/geos.h: Added
-	  geos.h file.
+	* [r424] Added geos.h file.
 2004-06-21 22:14  Sandro Santilli <strk at keybit.net>
-	* [r423] source/headers, source/headers/.cvsignore: added
-	  geos_version.h
+	* [r423] added geos_version.h
 2004-06-21 22:13  Sandro Santilli <strk at keybit.net>
-	* [r422] TODO: updated
+	* [r422] updated
-	* [r421] configure.in, source/headers/Makefile.am,
-	  source/headers/geos_version.h.in: Added VERSION defines
+	* [r421] Added VERSION defines
 2004-06-16 13:13  Sandro Santilli <strk at keybit.net>
-	* [r420] TODO, source/geom/BasicCoordinateList.cpp,
-	  source/geom/GeometryFactory.cpp, source/geom/MultiPolygon.cpp,
-	  source/geomgraph/Edge.cpp, source/headers/noding.h,
-	  source/noding/nodingSegmentIntersector.cpp: Changed interface of
-	  SegmentString, now copying CoordinateList argument.
+	* [r420] Changed interface of SegmentString, now copying
+	  CoordinateList argument.
 	  Fixed memory leaks associated with this and MultiGeometry
 	  constructors.
 	  Other associated fixes.
 2004-06-15 21:35  Sandro Santilli <strk at keybit.net>
-	* [r419] source/geom/GeometryFactory.cpp: fixed buildGeometry to
-	  always return a newly allocated geometry
+	* [r419] fixed buildGeometry to always return a newly allocated
+	  geometry
 2004-06-15 20:42  Sandro Santilli <strk at keybit.net>
-	* [r418] doc/example.cpp, source/geom/LineString.cpp,
-	  source/geom/MultiPolygon.cpp, source/geom/Polygon.cpp: updated to
-	  respect deep-copy GeometryCollection interface
+	* [r418] updated to respect deep-copy GeometryCollection interface
 2004-06-15 20:30  Sandro Santilli <strk at keybit.net>
-	* [r417] source/io/WKTReader.cpp: fixed a typo
+	* [r417] fixed a typo
 2004-06-15 20:20  Sandro Santilli <strk at keybit.net>
-	* [r416] source/geom/util/GeometryEditor.cpp,
-	  source/operation/overlay/OverlayOp.cpp: updated to respect
-	  deep-copy GeometryCollection interface
+	* [r416] updated to respect deep-copy GeometryCollection interface
 2004-06-15 20:07  Sandro Santilli <strk at keybit.net>
-	* [r415] source/geom/GeometryCollection.cpp,
-	  source/geom/GeometryFactory.cpp, source/headers/geom.h:
-	  GeometryCollections constructors make a deep copy of Geometry
-	  vector argument.
+	* [r415] GeometryCollections constructors make a deep copy of
+	  Geometry vector argument.
 2004-06-15 20:01  Sandro Santilli <strk at keybit.net>
-	* [r414] source/operation/buffer/BufferBuilder.cpp: Empty geometry
-	  creation call made using NULL instead of newly created empty
-	  vector (will be faster)
+	* [r414] Empty geometry creation call made using NULL instead of
+	  newly created empty vector (will be faster)
 2004-06-15 19:24  Sandro Santilli <strk at keybit.net>
-	* [r413] tools/geos-config.in: Fixed a bug preventing geos-config
-	  from giving correct version info
+	* [r413] Fixed a bug preventing geos-config from giving correct
+	  version info
 2004-06-15 07:40  Sandro Santilli <strk at keybit.net>
-	* [r412] source/noding/SegmentNode.cpp,
-	  source/planargraph/planarDirectedEdge.cpp: Added missing
-	  <stdio.h> include
+	* [r412] Added missing <stdio.h> include
-	* [r411] TODO: Updated
+	* [r411] Updated
 2004-05-28 18:16  Yury Bychkov <me at yury.ca>
-	* [r410] source/geom/PrecisionModel.cpp: Changed rounding method to
-	  make compilable with VC++
+	* [r410] Changed rounding method to make compilable with VC++
 2004-05-27 12:09  Sandro Santilli <strk at keybit.net>
-	* [r409] source/test/testLeaksBig.xml: added one buffer test
+	* [r409] added one buffer test
 2004-05-27 10:27  Sandro Santilli <strk at keybit.net>
-	* [r408] source/noding/SegmentNodeList.cpp,
-	  source/noding/SegmentString.cpp: Memory leaks fixed.
+	* [r408] Memory leaks fixed.
 2004-05-27 10:26  Sandro Santilli <strk at keybit.net>
-	* [r407] source/noding/nodingSegmentIntersector.cpp: set (useless?)
-	  recordIsolated member in constructor
+	* [r407] set (useless?) recordIsolated member in constructor
 2004-05-27 09:53  Sandro Santilli <strk at keybit.net>
-	* [r406] source/headers/indexChain.h:
-	  MonotoneChainOverlapAction::overlap(*) funx made virtual
+	* [r406] MonotoneChainOverlapAction::overlap(*) funx made virtual
 	  as they are supposed to be.
 2004-05-27 08:40  Sandro Santilli <strk at keybit.net>
-	* [r405] source/test/XMLTester.cpp: Fixed a memleak in buffer test.
+	* [r405] Fixed a memleak in buffer test.
 2004-05-27 08:37  Sandro Santilli <strk at keybit.net>
-	* [r404] source/headers/opBuffer.h,
-	  source/operation/buffer/OffsetCurveBuilder.cpp: Fixed a bug
-	  preventing OffsetCurveBuilder point list from being reset.
+	* [r404] Fixed a bug preventing OffsetCurveBuilder point list from
+	  being reset.
 2004-05-26 19:48  Sandro Santilli <strk at keybit.net>
-	* [r403] source/operation/buffer/OffsetCurveBuilder.cpp,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp: Changed abs()
-	  to fabs() when working with doubles.
+	* [r403] Changed abs() to fabs() when working with doubles.
 	  Used dynamic_cast<> instead of typeid() when JTS uses instanceof.
 2004-05-26 13:12  Sandro Santilli <strk at keybit.net>
-	* [r402] source/operation/buffer/BufferBuilder.cpp: Removed
-	  try/catch block from ::buildSubgraphs
+	* [r402] Removed try/catch block from ::buildSubgraphs
 2004-05-26 09:50  Sandro Santilli <strk at keybit.net>
-	* [r401] source/headers/geomgraph.h: Added comments about
-	  OverlayNodeFactory() ownership in NodeMap and PlanarGraph
-	  constuctors
+	* [r401] Added comments about OverlayNodeFactory() ownership in
+	  NodeMap and PlanarGraph constuctors
 2004-05-26 09:49  Sandro Santilli <strk at keybit.net>
-	* [r400] source/headers/opBuffer.h,
-	  source/operation/buffer/BufferBuilder.cpp: PlanarGraph made local
-	  to ::buffer instead of Class private.
+	* [r400] PlanarGraph made local to ::buffer instead of Class
+	  private.
 2004-05-21 14:17  Sandro Santilli <strk at keybit.net>
-	* [r399] TODO: updated
+	* [r399] updated
 2004-05-21 13:58  Sandro Santilli <strk at keybit.net>
-	* [r398] source/geom/Geometry.cpp: ::intersection missed to
-	  invalidate geometryCollection inputs
+	* [r398] ::intersection missed to invalidate geometryCollection
+	  inputs
 2004-05-21 13:55  Sandro Santilli <strk at keybit.net>
-	* [r397] TODO: updated
+	* [r397] updated
 2004-05-21 13:39  Sandro Santilli <strk at keybit.net>
-	* [r396] source/geom/PrecisionModel.cpp: ::makePrecise make use of
-	  nearbyint() now, to be compatible with JTS
+	* [r396] ::makePrecise make use of nearbyint() now, to be
+	  compatible with JTS
 2004-05-21 13:37  Sandro Santilli <strk at keybit.net>
-	* [r395] source/test/testLeaksBig.xml: first import
+	* [r395] first import
 2004-05-20 09:14  Sandro Santilli <strk at keybit.net>
-	* [r394] TODO: updated
+	* [r394] updated
 2004-05-19 19:39  Yury Bychkov <me at yury.ca>
-	* [r393] source/geom/PrecisionModel.cpp: Changed rounding method to
+	* [r393] Changed rounding method to make compilable with VC++
 2004-05-19 13:40  Sandro Santilli <strk at keybit.net>
-	* [r392] source/operation/buffer/OffsetCurveBuilder.cpp: Fixed bug
-	  in ::addCircle
+	* [r392] Fixed bug in ::addCircle
 2004-05-19 13:18  Sandro Santilli <strk at keybit.net>
-	* [r391] source/geom/BasicCoordinateList.cpp,
-	  source/geom/PointCoordinateList.cpp, source/headers/geom.h: made
-	  CoordinateList::toString() a const member function
+	* [r391] made CoordinateList::toString() a const member function
 2004-05-19 13:01  Sandro Santilli <strk at keybit.net>
-	* [r390] source/operation/buffer/BufferOp.cpp: avoided assignment
-	  operator calls for BufferBuilder
+	* [r390] avoided assignment operator calls for BufferBuilder
 2004-05-19 12:50  Sandro Santilli <strk at keybit.net>
-	* [r389] source/operation/buffer/BufferSubgraph.cpp: Removed all
-	  try/catch blocks transforming stack allocated-vectors to
-	  auto-heap-allocations
+	* [r389] Removed all try/catch blocks transforming stack
+	  allocated-vectors to auto-heap-allocations
 2004-05-19 09:57  Yury Bychkov <me at yury.ca>
-	* [r388] source/operation/buffer/OffsetCurveSetBuilder.cpp: Bugfix
-	  in OffsetCurveSetBuilder::addPolygon (JTS 1.4.1)
+	* [r388] Bugfix in OffsetCurveSetBuilder::addPolygon (JTS 1.4.1)
 2004-05-18 13:49  Sandro Santilli <strk at keybit.net>
-	* [r387] source/test/XMLTester.cpp: Output made more neat (geometry
-	  B is not printed if not existent).
+	* [r387] Output made more neat (geometry B is not printed if not
+	  existent).
 	  Added support for buffer tests.
 2004-05-18 13:15  Sandro Santilli <strk at keybit.net>
-	* [r386] source/geom/CoordinateList.cpp: made ::scroll handle
-	  already scrolled vect and more readable
+	* [r386] made ::scroll handle already scrolled vect and more
+	  readable
 2004-05-18 00:02  Yury Bychkov <me at yury.ca>
-	* [r385] source/headers/opValid.h,
-	  IsValidOp::checkShellNotNested() bugfix from JTS 1.4.1 (not
-	  released yet) has been added.
+	* [r385] IsValidOp::checkShellNotNested() bugfix from JTS 1.4.1
+	  (not released yet) has been added.
 2004-05-17 21:14  Yury Bychkov <me at yury.ca>
-	* [r384] source/geom/GeometryCollection.cpp, source/headers/geom.h:
-	  JavaDoc updated
+	* [r384] JavaDoc updated
 2004-05-17 21:09  Yury Bychkov <me at yury.ca>
-	* [r383] source/geom/BasicCoordinateList.cpp,
-	  source/geom/PointCoordinateList.cpp: toString() performance
-	  enhancement
+	* [r383] toString() performance enhancement
 2004-05-17 21:03  Yury Bychkov <me at yury.ca>
-	* [r382] source/geom/CoordinateList.cpp, source/headers/geom.h:
-	  JavaDoc updated
+	* [r382] JavaDoc updated
 2004-05-17 12:54  Sandro Santilli <strk at keybit.net>
-	* [r381] source/io/markup/MarkupSTL.cpp: Added tab in list of blank
-	  chars
+	* [r381] Added tab in list of blank chars
 2004-05-17 12:53  Sandro Santilli <strk at keybit.net>
-	* [r380] source/test/XMLTester.cpp: Expected result string trimmed
-	  for blanks
+	* [r380] Expected result string trimmed for blanks
 2004-05-17 12:37  Sandro Santilli <strk at keybit.net>
-	* [r379] source/io/StringTokenizer.cpp: Added carriage returns and
-	  tabs in set of blanks chars
+	* [r379] Added carriage returns and tabs in set of blanks chars
 2004-05-17 12:36  Sandro Santilli <strk at keybit.net>
-	* [r378] source/io/ParseException.cpp: ParseException message made
-	  more readable
+	* [r378] ParseException message made more readable
 2004-05-17 10:45  Sandro Santilli <strk at keybit.net>
-	* [r377] source/geom/PrecisionModel.cpp: Fixed bogus FIXED
-	  coordinate rounding
+	* [r377] Fixed bogus FIXED coordinate rounding
 2004-05-17 08:34  Sandro Santilli <strk at keybit.net>
-	* [r376] source/operation/overlay/OverlayOp.cpp: reduced stack
-	  allocations, try/catch blocks in ::overlayOp
+	* [r376] reduced stack allocations, try/catch blocks in ::overlayOp
 2004-05-17 07:42  Sandro Santilli <strk at keybit.net>
-	* [r375] source/algorithm/CentroidArea.cpp: CentroidArea::add(const
-	  Geometry *geom) uses dynamic_cast
+	* [r375] CentroidArea::add(const Geometry *geom) uses dynamic_cast
 2004-05-17 07:23  Sandro Santilli <strk at keybit.net>
-	* [r374] source/geom/Geometry.cpp: ::getCeontroid(): reduced
-	  dynamic allocations, added missing check for isEmpty
+	* [r374] ::getCeontroid(): reduced dynamic allocations, added
+	  missing check for isEmpty
 2004-05-14 14:47  Sandro Santilli <strk at keybit.net>
-	* [r373]
-	  source/operation/distance/ConnectedElementLocationFilter.cpp:
-	  Added LinearRing support
+	* [r373] Added LinearRing support
 2004-05-14 14:45  Sandro Santilli <strk at keybit.net>
-	* [r372] source/headers/geomUtil.h: Fixed bogus inheritance of
-	  LinearComponentExtracter
+	* [r372] Fixed bogus inheritance of LinearComponentExtracter
 2004-05-14 13:42  Sandro Santilli <strk at keybit.net>
-	* [r371] source/geom/LineSegment.cpp,
-	  source/geom/util/PolygonExtracter.cpp, source/headers/geomUtil.h,
-	  source/operation/distance/DistanceOp.cpp: DistanceOp bug removed,
-	  cascading errors fixed.
+	* [r371] DistanceOp bug removed, cascading errors fixed.
 2004-05-14 12:14  Sandro Santilli <strk at keybit.net>
-	* [r370] source/geom/Geometry.cpp, source/headers/geom.h: const
-	  correctness
+	* [r370] const correctness
 2004-05-14 12:10  Sandro Santilli <strk at keybit.net>
-	* [r369] source/io/WKTReader.cpp: avoided leaks on malformed
-	  LinearRing
+	* [r369] avoided leaks on malformed LinearRing
 2004-05-14 09:20  Sandro Santilli <strk at keybit.net>
-	* [r368] source/geom/util/LinearComponentExtracter.cpp,
-	  source/geom/util/PolygonExtracter.cpp: Mem leaks fixed
+	* [r368] Mem leaks fixed
 2004-05-14 07:19  Sandro Santilli <strk at keybit.net>
-	* [r367] source/test/XMLTester.cpp: Changed the algorythm for
-	  finding precisionModel type (current way did
+	* [r367] Changed the algorythm for finding precisionModel type
+	  (current way did
 	  not work): now if you specify a scale precisionModel will be
 	  FIXED,
 	  otherwise it will be FLOATING.
 2004-05-07 14:15  Sandro Santilli <strk at keybit.net>
-	* [r366] source/io/StringTokenizer.cpp: fixed peekNextToken to
-	  avoid incrementing string pointer
+	* [r366] fixed peekNextToken to avoid incrementing string pointer
 2004-05-07 14:13  Sandro Santilli <strk at keybit.net>
-	* [r365] source/index/bintree/Bintree.cpp: Fixed segfault in
-	  ::insert
+	* [r365] Fixed segfault in ::insert
 2004-05-07 14:12  Sandro Santilli <strk at keybit.net>
-	* [r364] source/algorithm/InteriorPointArea.cpp: Fixed segfault in
-	  destructor
+	* [r364] Fixed segfault in destructor
 2004-05-07 13:23  Sandro Santilli <strk at keybit.net>
-	* [r363] source/io/WKTReader.cpp, source/test/XMLTester.cpp: Memory
-	  leaks fixed.
+	* [r363] Memory leaks fixed.
 2004-05-07 13:04  Sandro Santilli <strk at keybit.net>
-	* [r362] source/geom/MultiLineString.cpp: leak removed in
-	  MultiLineString::getBoundary()
+	* [r362] leak removed in MultiLineString::getBoundary()
 2004-05-07 09:05  Sandro Santilli <strk at keybit.net>
-	* [r361] source/geom/Geometry.cpp,
-	  source/geom/MultiPolygon.cpp, source/headers/geom.h: Some const
-	  correctness added. Fixed bug in GeometryFactory::createMultiPoint
+	* [r361] Some const correctness added. Fixed bug in
+	  GeometryFactory::createMultiPoint
 	  to handle NULL CoordinateList.
 2004-05-07 07:57  Sandro Santilli <strk at keybit.net>
-	* [r360] source/geom/Makefile.am, source/headers/noding.h,
-	  source/headers/opBuffer.h, source/noding/SegmentString.cpp,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp: Added missing
-	  EdgeNodingValidator to build scripts.
+	* [r360] Added missing EdgeNodingValidator to build scripts.
 	  Changed SegmentString constructor back to its original form
 	  (takes const void *), implemented local tracking of "contexts"
 	  in caller objects for proper destruction.
 2004-05-06 16:30  Sandro Santilli <strk at keybit.net>
-	* [r359] source/headers/indexBintree.h,
-	  source/headers/indexQuadtree.h, source/index/bintree/Bintree.cpp,
-	  source/index/quadtree/Quadtree.cpp: Kept track of newly allocated
-	  objects by ensureExtent for Bintree and Quadtree,
+	* [r359] Kept track of newly allocated objects by ensureExtent for
+	  Bintree and Quadtree,
 	  deleted at destruction time. doc/example.cpp runs with no leaks.
 2004-05-06 15:54  Sandro Santilli <strk at keybit.net>
-	* [r358] source/headers/noding.h,
-	  SegmentNodeList keeps track of created splitEdges for later
-	  destruction.
+	* [r358] SegmentNodeList keeps track of created splitEdges for
+	  later destruction.
 	  SegmentString constructor copies given Label.
 	  Buffer operation does no more leaks for doc/example.cpp
 2004-05-06 15:00  Sandro Santilli <strk at keybit.net>
-	* [r357] source/headers/indexStrtree.h,
-	  source/index/strtree/STRtree.cpp: Boundable destructor made
-	  virtual.
+	* [r357] Boundable destructor made virtual.
 	  Added vector <AbstractNode *> *nodes member in AbstractSTRTree,
 	  used to keep track of created node to cleanly delete them at
 	  destruction time.
 2004-05-06 13:58  Sandro Santilli <strk at keybit.net>
-	* [r356] source/index/strtree/STRtree.cpp: leak removed from
-	  createParentBoundablesFromVerticalSlices
+	* [r356] leak removed from createParentBoundablesFromVerticalSlices
 2004-05-06 08:59  Sandro Santilli <strk at keybit.net>
-	* [r355] source/index/strtree/AbstractSTRtree.cpp: memory leak
-	  fixed
+	* [r355] memory leak fixed
 2004-05-05 17:42  Sandro Santilli <strk at keybit.net>
-	* [r354] source/headers/indexStrtree.h,
-	  source/index/strtree/STRtree.cpp: AbstractNode destructor made
-	  virtual. AbstractNode::bounds made protected.
+	* [r354] AbstractNode destructor made virtual. AbstractNode::bounds
+	  made protected.
 	  SIRAbstractNode and STRAbstractNode destructors added to get rid
 	  of
 	  AbstractNode::bounds in the right way (is a void * casted to
@@ -17882,148 +10811,100 @@
 2004-05-05 16:57  Sandro Santilli <strk at keybit.net>
-	* [r353] source/headers/opBuffer.h,
-	  source/operation/buffer/BufferBuilder.cpp: Rewritten static cga
-	  allocation to avoid copy constructor calls.
+	* [r353] Rewritten static cga allocation to avoid copy constructor
+	  calls.
 2004-05-05 16:51  Sandro Santilli <strk at keybit.net>
-	* [r352] source/geom/Geometry.cpp: avoided copy constructor in
+	* [r352] avoided copy constructor in
 	  Geometry::geometryChangedFilter initializzazion
 2004-05-05 16:39  Sandro Santilli <strk at keybit.net>
-	* [r351] source/noding/MCQuadtreeNoder.cpp: reduced explicit local
-	  objects allocation
+	* [r351] reduced explicit local objects allocation
 2004-05-05 16:36  Sandro Santilli <strk at keybit.net>
-	* [r350] source/operation/buffer/BufferBuilder.cpp: Avoid use of
-	  copy c'tors on local objects initializzation
+	* [r350] Avoid use of copy c'tors on local objects initializzation
 2004-05-05 15:51  Sandro Santilli <strk at keybit.net>
-	* [r349] source/noding/MCQuadtreeNoder.cpp: Fixed big leak in
-	  intersectChains()
+	* [r349] Fixed big leak in intersectChains()
 2004-05-05 13:08  Sandro Santilli <strk at keybit.net>
-	* [r348] source/algorithm/MinimumDiameter.cpp,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp: Leaks fixed,
-	  explicit allocations/deallocations reduced.
+	* [r348] Leaks fixed, explicit allocations/deallocations reduced.
 2004-05-05 12:29  Sandro Santilli <strk at keybit.net>
-	* [r347] source/operation/buffer/SubgraphDepthLocater.cpp: memleak
-	  fixed in ::getDepth
+	* [r347] memleak fixed in ::getDepth
 2004-05-05 12:20  Sandro Santilli <strk at keybit.net>
-	* [r346] source/geom/util/GeometryEditor.cpp: Memory leak plugged
-	  in editGeometryCollection
+	* [r346] Memory leak plugged in editGeometryCollection
 2004-05-05 10:54  Sandro Santilli <strk at keybit.net>
-	* [r345] source/geom/Geometry.cpp, source/headers/geom.h,
-	  source/headers/opBuffer.h, source/io/Unload.cpp,
-	  source/operation/buffer/BufferBuilder.cpp: Removed some private
-	  static heap explicit allocation, less cleanup done by
+	* [r345] Removed some private static heap explicit allocation, less
+	  cleanup done by
 	  the unloader.
 2004-05-05 10:44  Sandro Santilli <strk at keybit.net>
-	* [r344] TODO: updated
+	* [r344] updated
 2004-05-05 10:22  Sandro Santilli <strk at keybit.net>
-	* [r343] source/operation/buffer/BufferOp.cpp: Removed dynamic
-	  allocations.
+	* [r343] Removed dynamic allocations.
 2004-05-05 10:03  Sandro Santilli <strk at keybit.net>
-	* [r342] source/operation/buffer/BufferOp.cpp: Reduced dynamic
-	  allocations in bufferOriginalPrecision and bufferFixedPrecision.
+	* [r342] Reduced dynamic allocations in bufferOriginalPrecision and
+	  bufferFixedPrecision.
 2004-05-03 22:56  Sandro Santilli <strk at keybit.net>
-	* [r341] source/geomgraph/EdgeList.cpp, source/headers/noding.h,
-	  source/noding/IteratedNoder.cpp,
-	  source/noding/MCQuadtreeNoder.cpp, source/noding/Noder.cpp,
-	  source/operation/buffer/SubgraphDepthLocater.cpp: leaks fixed,
-	  exception specification omitted.
+	* [r341] leaks fixed, exception specification omitted.
 2004-05-03 20:49  Sandro Santilli <strk at keybit.net>
-	* [r340] source/geom/util/LinearComponentExtracter.cpp,
-	  source/noding/SegmentNodeList.cpp: Some more leaks fixed
+	* [r340] Some more leaks fixed
 2004-05-03 17:15  Sandro Santilli <strk at keybit.net>
-	* [r339] source/geom/util/GeometryEditor.cpp,
-	  source/headers/precision.h, source/index/strtree/STRtree.cpp,
-	  source/operation/buffer/BufferOp.cpp,
-	  source/precision/SimpleGeometryPrecisionReducer.cpp: leaks on
-	  exception fixed.
+	* [r339] leaks on exception fixed.
 2004-05-03 16:29  Sandro Santilli <strk at keybit.net>
-	* [r338] source/headers/indexStrtree.h,
-	  source/index/strtree/STRtree.cpp: Added sortBoundables(const
-	  vector<Boundable *>) pure virtual in AbstractSTRtree,
+	* [r338] Added sortBoundables(const vector<Boundable *>) pure
+	  virtual in AbstractSTRtree,
 	  implemented in SIRtree and STRtree. Comparator funx made static
 	  in STRtree.cpp
 	  and SIRtree.cpp.
 2004-05-03 13:17  Sandro Santilli <strk at keybit.net>
-	* [r337] source/headers/indexStrtree.h,
-	  source/index/strtree/AbstractSTRtree.cpp: Fixed comparator
-	  function to express StrictWeakOrdering.
+	* [r337] Fixed comparator function to express StrictWeakOrdering.
 2004-05-03 12:09  Sandro Santilli <strk at keybit.net>
-	* [r336] source/noding/Noder.cpp, source/noding/SegmentNode.cpp,
-	  source/noding/nodingSegmentIntersector.cpp,
-	  source/planargraph/planarNodeMap.cpp: newline added at end of
-	  file
+	* [r336] newline added at end of file
 2004-05-03 10:43  Sandro Santilli <strk at keybit.net>
-	* [r335] source/geomgraph/DirectedEdgeStar.cpp,
-	  source/geomgraph/EdgeEndStar.cpp,
-	  source/geomgraph/PlanarGraph.cpp, source/headers/geomgraph.h,
-	  source/planargraph/planarDirectedEdge.cpp: Exception
-	  specification considered harmful - left as comment.
+	* [r335] Exception specification considered harmful - left as
+	  comment.
 2004-04-30 09:15  Sandro Santilli <strk at keybit.net>
-	* [r334] source/geom/Geometry.cpp, source/headers/noding.h,
-	  source/headers/opBuffer.h, source/noding/IteratedNoder.cpp,
-	  source/operation/buffer/BufferBuilder.cpp: Enlarged exception
-	  specifications to allow for AssertionFailedException.
+	* [r334] Enlarged exception specifications to allow for
+	  AssertionFailedException.
 	  Added missing initializers.
 2004-04-28 14:58  Sandro Santilli <strk at keybit.net>
-	* [r333] source/index/strtree/AbstractSTRtree.cpp: Made
-	  AbstractSTRtree::query use dynamic_cast<> to simulate java's
+	* [r333] Made AbstractSTRtree::query use dynamic_cast<> to simulate
+	  java's
 	  instanceof. Previous typeid(*) use missed to catch an
 	  STRAbstractNode
 	  as a class derived from AbstractNode. Still have to check if this
@@ -18033,2931 +10914,1305 @@
 2004-04-26 22:00  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r332] configure.in: Bump version number to 1.4 to indicate new
-	  changes.
+	* [r332] Bump version number to 1.4 to indicate new changes.
 2004-04-26 12:37  Sandro Santilli <strk at keybit.net>
-	* [r331] source/index/strtree/AbstractSTRtree.cpp,
-	  source/index/strtree/STRtree.cpp: Some leaks fixed.
+	* [r331] Some leaks fixed.
 2004-04-23 00:02  Sandro Santilli <strk at keybit.net>
-	* [r330] source/headers/noding.h, source/headers/opBuffer.h,
-	  source/operation/buffer/BufferOp.cpp: const-correctness changes
+	* [r330] const-correctness changes
 2004-04-21 14:14  Sandro Santilli <strk at keybit.net>
-	* [r329] source/geomgraph/DirectedEdgeStar.cpp: Fixed bug in
-	  computeDepths
+	* [r329] Fixed bug in computeDepths
 2004-04-20 13:24  Sandro Santilli <strk at keybit.net>
-	* [r328] source/algorithm/ConvexHull.cpp,
-	  source/algorithm/MinimumDiameter.cpp, source/geom/LineString.cpp,
-	  source/geom/LinearRing.cpp, source/geom/Polygon.cpp,
-	  source/operation/overlay/OverlayOp.cpp: More leaks removed.
+	* [r328] More leaks removed.
 2004-04-20 12:47  Sandro Santilli <strk at keybit.net>
-	* [r327] source/algorithm/MinimumDiameter.cpp,
-	  source/headers/geosAlgorithm.h: MinimumDiameter leaks plugged.
+	* [r327] MinimumDiameter leaks plugged.
 2004-04-20 10:58  Sandro Santilli <strk at keybit.net>
-	* [r326] source/headers/opBuffer.h,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp: More memory
-	  leaks removed.
+	* [r326] More memory leaks removed.
 2004-04-20 10:14  Sandro Santilli <strk at keybit.net>
-	* [r325] source/algorithm/MinimumDiameter.cpp,
-	  source/geom/Geometry.cpp, source/geom/util/GeometryEditor.cpp,
-	  source/precision/SimpleGeometryPrecisionReducer.cpp: Memory leaks
-	  removed.
+	* [r325] Memory leaks removed.
 2004-04-20 08:52  Sandro Santilli <strk at keybit.net>
-	* [r324] source/geom/GeometryCollection.cpp,
-	  source/geom/Polygon.cpp, source/geom/Triangle.cpp,
-	  source/geom/util/GeometryEditor.cpp, source/headers/geom.h,
-	  source/headers/geomUtil.h, source/headers/precision.h,
-	  GeometryFactory and Geometry const correctness.
+	* [r324] GeometryFactory and Geometry const correctness.
 	  Memory leaks removed from SimpleGeometryPrecisionReducer
 	  and GeometryFactory.
 2004-04-19 16:14  Sandro Santilli <strk at keybit.net>
-	* [r323] source/headers/noding.h, source/noding/IteratedNoder.cpp,
-	  source/operation/buffer/OffsetCurveSetBuilder.cpp: Some memory
-	  leaks plugged in noding algorithms.
+	* [r323] Some memory leaks plugged in noding algorithms.
 2004-04-19 15:14  Sandro Santilli <strk at keybit.net>
-	* [r322] source/geomgraph/PlanarGraph.cpp,
-	  source/headers/indexQuadtree.h, source/headers/opBuffer.h,
-	  source/index/quadtree/Quadtree.cpp,
-	  virtual destructor in SpatialIndex class.
+	* [r322] Added missing virtual destructor in SpatialIndex class.
 	  Memory leaks fixes. Const and throw specifications added.
 2004-04-19 12:51  Sandro Santilli <strk at keybit.net>
-	* [r321] source/headers/noding.h, source/headers/opBuffer.h,
-	  source/operation/buffer/BufferOp.cpp: Memory leaks fixes. Throw
-	  specifications added.
+	* [r321] Memory leaks fixes. Throw specifications added.
 2004-04-16 14:12  Sandro Santilli <strk at keybit.net>
-	* [r320] source/geom/Point.cpp: Memory leak fix in copy constructor
+	* [r320] Memory leak fix in copy constructor
 2004-04-16 14:09  Sandro Santilli <strk at keybit.net>
-	* [r319] source/operation/buffer/BufferOp.cpp: Leaks fixes
+	* [r319] Leaks fixes
 2004-04-16 13:03  Sandro Santilli <strk at keybit.net>
-	* [r318] source/operation/buffer/OffsetCurveBuilder.cpp: More leaks
-	  fixed
+	* [r318] More leaks fixed
 2004-04-16 12:48  Sandro Santilli <strk at keybit.net>
-	* [r317] source/noding/IteratedNoder.cpp,
-	  source/operation/buffer/OffsetCurveBuilder.cpp: Leak fixes.
+	* [r317] Leak fixes.
 2004-04-16 11:04  Sandro Santilli <strk at keybit.net>
-	* [r316] source/operation/buffer/BufferOp.cpp: Memory leaks plugged
-	  on exception thrown
+	* [r316] Memory leaks plugged on exception thrown
 2004-04-16 10:00  Sandro Santilli <strk at keybit.net>
-	* [r315] source/operation/buffer/BufferOp.cpp: Memory leak fixed.
+	* [r315] Memory leak fixed.
 2004-04-16 09:01  Sandro Santilli <strk at keybit.net>
-	* [r314] source/algorithm/CGAlgorithms.cpp: Removed memory leak in
-	  CGAlgorithms::isOnline
+	* [r314] Removed memory leak in CGAlgorithms::isOnline
 2004-04-16 08:52  Sandro Santilli <strk at keybit.net>
-	* [r313] source/headers/planargraph.h, source/io/Unload.cpp:
-	  Unload::Release final delete (static heap allocations should be
-	  gone now)
+	* [r313] Unload::Release final delete (static heap allocations
+	  should be gone now)
 2004-04-16 08:35  Sandro Santilli <strk at keybit.net>
-	* [r312] source/geom/GeometryFactory.cpp, source/geom/Point.cpp,
-	  source/headers/geom.h: Memory leaks fixed and const correctness
-	  applied for Point class.
+	* [r312] Memory leaks fixed and const correctness applied for Point
+	  class.
 2004-04-16 07:42  Sandro Santilli <strk at keybit.net>
-	* [r311] source/geom/PrecisionModel.cpp, source/headers/geom.h,
-	  source/io/Unload.cpp: PrecisionModel::Type made an enum instead
-	  of a Type.
+	* [r311] PrecisionModel::Type made an enum instead of a Type.
 2004-04-15 15:11  Sandro Santilli <strk at keybit.net>
-	* [r310] source/io/Unload.cpp: Commented out deletion that seems to
-	  cause segfaults
+	* [r310] Commented out deletion that seems to cause segfaults
 2004-04-15 14:00  Sandro Santilli <strk at keybit.net>
-	* [r309] source/headers/geom.h, source/headers/opBuffer.h,
-	  source/io/Unload.cpp: Added new cleanup to Unload::Release
+	* [r309] Added new cleanup to Unload::Release
 2004-04-14 13:56  Sandro Santilli <strk at keybit.net>
-	* [r308] source/geom/Geometry.cpp, source/headers/geom.h: All
-	  geometries returned by {from,to}InternalGeometry calls are
+	* [r308] All geometries returned by {from,to}InternalGeometry calls
+	  are
 	  now deleted after use (unless NOT new).
 	  Some 'commented' throw specifications in geom.h
 2004-04-14 13:14  Sandro Santilli <strk at keybit.net>
-	* [r307] source/operation/overlay/OverlayOp.cpp: Removed deletion
-	  of externally pointed GeometryFactory from OverlayOp destructor
+	* [r307] Removed deletion of externally pointed GeometryFactory
+	  from OverlayOp destructor
 2004-04-14 12:28  Sandro Santilli <strk at keybit.net>
-	* [r306] source/geom/GeometryCollection.cpp,
-	  source/index/strtree/AbstractSTRtree.cpp: shouldNeverReachHere
-	  exceptions made more verbose
+	* [r306] shouldNeverReachHere exceptions made more verbose
 2004-04-14 11:05  Sandro Santilli <strk at keybit.net>
-	* [r305] source/geom/util/GeometryEditor.cpp: Added support for
-	  LinearRing in GeometryEditor
+	* [r305] Added support for LinearRing in GeometryEditor
 2004-04-14 10:56  Sandro Santilli <strk at keybit.net>
-	* [r304] source/operation/distance/DistanceOp.cpp: Uncommented
-	  initializzazion and destruction of
+	* [r304] Uncommented initializzazion and destruction of
 	  DistanceOp::minDistanceLocation
 2004-04-14 09:38  Sandro Santilli <strk at keybit.net>
-	* [r303] source/geom/PrecisionModel.cpp: PrecisionModel(double
-	  newScale) missed to set the scale
+	* [r303] PrecisionModel(double newScale) missed to set the scale
 2004-04-14 09:30  Sandro Santilli <strk at keybit.net>
-	* [r302] source/headers/noding.h, source/noding/IteratedNoder.cpp:
-	  Private iterated noding funx now use int* instead of vector to
-	  know
+	* [r302] Private iterated noding funx now use int* instead of
+	  vector to know
 	  when it's time to stop.
 2004-04-14 09:11  Sandro Santilli <strk at keybit.net>
-	* [r301] source/operation/buffer/BufferOp.cpp: endCapStyle was
-	  never set in BufferOp contructor
+	* [r301] endCapStyle was never set in BufferOp contructor
 2004-04-14 08:38  Sandro Santilli <strk at keybit.net>
-	* [r300] source/operation/buffer/BufferBuilder.cpp: BufferBuilder
-	  constructor missed to initialize workingPrecisionModel
+	* [r300] BufferBuilder constructor missed to initialize
+	  workingPrecisionModel
-	* [r299] source/operation/buffer/BufferOp.cpp: BufferOp constructor
-	  missed to set argGeom
+	* [r299] BufferOp constructor missed to set argGeom
 2004-04-14 07:29  Sandro Santilli <strk at keybit.net>
-	* [r298] source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
-	  source/headers/geom.h: Fixed GeometryFactory constructors to copy
-	  given PrecisionModel. Added GeometryFactory copy constructor.
-	  Fixed Geometry constructors to copy GeometryFactory.
+	* [r298] Fixed GeometryFactory constructors to copy given
+	  PrecisionModel. Added GeometryFactory copy constructor. Fixed
+	  Geometry constructors to copy GeometryFactory.
 2004-04-14 06:04  Yury Bychkov <me at yury.ca>
-	* [r297] source/geomgraph/index,
-	  source/geomgraph/index/MonotoneChain.cpp,
-	  source/geomgraph/index/MonotoneChainEdge.cpp,
-	  source/geomgraph/index/SegmentIntersector.cpp,
-	  source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
-	  source/geomgraph/index/SweepLineSegment.cpp: "geomgraph/index"
-	  committ problem fixed.
+	* [r297] "geomgraph/index" committ problem fixed.
 2004-04-13 14:45  Sandro Santilli <strk at keybit.net>
-	* [r296] source/geom/Point.cpp: Removed faulty assert in
-	  constructor
+	* [r296] Removed faulty assert in constructor
 2004-04-13 14:33  Sandro Santilli <strk at keybit.net>
-	* [r295] source/geom/Makefile.am: Added more source files
+	* [r295] Added more source files
 2004-04-13 14:28  Sandro Santilli <strk at keybit.net>
-	* [r294] doc/example.cpp: Removed spurious line
+	* [r294] Removed spurious line
 2004-04-13 13:31  Sandro Santilli <strk at keybit.net>
-	* [r293] source/headers/precision.h: prototype mismatch fixed
+	* [r293] prototype mismatch fixed
 2004-04-13 12:29  Sandro Santilli <strk at keybit.net>
-	* [r292] source/headers/opDistance.h,
-	  source/operation/distance/GeometryLocation.cpp: GeometryLocation
-	  const-correctness.
+	* [r292] GeometryLocation const-correctness.
 2004-04-13 11:04  Sandro Santilli <strk at keybit.net>
-	* [r291] source/headers/Makefile.am: Added lost opDistance.h
+	* [r291] Added lost opDistance.h
 2004-04-13 11:03  Sandro Santilli <strk at keybit.net>
-	* [r290] source/headers/Makefile.am: Added new header files
+	* [r290] Added new header files
 2004-04-13 10:58  Sandro Santilli <strk at keybit.net>
-	* [r289] source/geom/Makefile.am: Added new source files
+	* [r289] Added new source files
 2004-04-13 10:05  Sandro Santilli <strk at keybit.net>
-	* [r288] source/headers/opDistance.h,
-	  source/operation/distance/DistanceOp.cpp,
-	  constructor made const-correct.
+	* [r288] GeometryLocation constructor made const-correct.
 	  Fixed erroneus down-casting in
 	  DistanceOp::computeMinDistancePoints.
 2004-04-13 08:15  Sandro Santilli <strk at keybit.net>
-	* [r287] source/headers/geom.h: Changed all 'long long' with int64.
+	* [r287] Changed all 'long long' with int64.
 	  Changed all 'long long' constants to end with two Ls.
 2004-04-10 22:41  Yury Bychkov <me at yury.ca>
-	* [r286] VisualStudio/GEOS.vcproj, source/geom/LineString.cpp,
-	  source/geom/Point.cpp, source/headers/geom.h,
-	  source/headers/precision.h, source/headers/util.h,
-	  source/operation/buffer/BufferOp.cpp, source/precision,
-	  source/util/UniqueCoordinateArrayFilter.cpp: "precision" upgraded
-	  to JTS 1.4
+	* [r286] "precision" upgraded to JTS 1.4
 2004-04-10 08:40  Yury Bychkov <me at yury.ca>
-	* [r285] VisualStudio/GEOS.vcproj,
-	  source/operation/buffer/BufferEdgeBuilder.cpp,
-	  source/operation/buffer/BufferLineBuilder.cpp,
-	  source/operation/buffer/LoopFilter.cpp,
-	  source/operation/overlay/PolygonBuilder.cpp: "operation/buffer"
-	  upgraded to JTS 1.4
+	* [r285] "operation/buffer" upgraded to JTS 1.4
 2004-04-08 04:53  Yury Bychkov <me at yury.ca>
-	* [r284] VisualStudio/GEOS.vcproj, source/headers/opPolygonize.h,
-	  source/operation/polygonize,
-	  source/operation/polygonize/PolygonizeDirectedEdge.cpp,
-	  source/operation/polygonize/PolygonizeEdge.cpp,
-	  source/operation/polygonize/PolygonizeGraph.cpp,
-	  source/operation/polygonize/Polygonizer.cpp,
-	  source/operation/polygonize/polygonizeEdgeRing.cpp:
-	  "operation/polygonize" ported from JTS 1.4
+	* [r284] "operation/polygonize" ported from JTS 1.4
 2004-04-07 06:55  Yury Bychkov <me at yury.ca>
-	* [r283] VisualStudio/GEOS.vcproj, source/geom/CoordinateList.cpp,
-	  source/headers/geom.h, source/headers/opLinemerge.h,
-	  source/headers/planargraph.h, source/operation/linemerge,
-	  source/operation/linemerge/EdgeString.cpp,
-	  source/operation/linemerge/LineMergeDirectedEdge.cpp,
-	  source/operation/linemerge/LineMergeEdge.cpp,
-	  source/operation/linemerge/LineMerger.cpp,
-	  source/planargraph/PlanarGraph.cpp,
-	  source/planargraph/planarNodeMap.cpp,
-	  source/planargraph/planarPlanarGraph.cpp: "operation/linemerge"
-	  ported from JTS 1.4
+	* [r283] "operation/linemerge" ported from JTS 1.4
 2004-04-05 06:35  Yury Bychkov <me at yury.ca>
-	* [r282] VisualStudio/GEOS.vcproj,
-	  source/algorithm/CGAlgorithms.cpp, source/geom/LineSegment.cpp,
-	  source/headers/indexStrtree.h, source/headers/opDistance.h,
-	  source/operation/distance/LineExtracterFilter.cpp,
-	  source/operation/distance/PointExtracterFilter.cpp,
-	  source/operation/distance/PolygonExtracterFilter.cpp:
-	  "operation/distance" upgraded to JTS 1.4
+	* [r282] "operation/distance" upgraded to JTS 1.4
 2004-04-04 06:29  Yury Bychkov <me at yury.ca>
-	* [r281] VisualStudio/GEOS.vcproj, source/geom/GeometryFactory.cpp,
-	  source/geom/util, source/geom/util/GeometryEditor.cpp,
-	  source/geom/util/PolygonExtracter.cpp, source/headers/geom.h,
-	  source/headers/geomgraphindex.h, source/headers/planargraph.h,
-	  source/planargraph, source/planargraph/PlanarGraph.cpp,
-	  source/planargraph/planarDirectedEdge.cpp,
-	  source/planargraph/planarDirectedEdgeStar.cpp,
-	  source/planargraph/planarEdge.cpp,
-	  source/planargraph/planarGraphComponent.cpp,
-	  source/planargraph/planarNode.cpp,
-	  source/planargraph/planarNodeMap.cpp: "planargraph" and
-	  "geom/utill" upgraded to JTS 1.4
+	* [r281] "planargraph" and "geom/utill" upgraded to JTS 1.4
 2004-04-01 10:44  Yury Bychkov <me at yury.ca>
-	* [r280] source/geom/Geometry.cpp,
-	  source/geom/MultiPoint.cpp, source/geom/Polygon.cpp,
-	  source/headers/geom.h, source/io/Unload.cpp: All "geom" classes
-	  from JTS 1.3 upgraded to JTS 1.4
+	* [r280] All "geom" classes from JTS 1.3 upgraded to JTS 1.4
 2004-03-31 07:50  Yury Bychkov <me at yury.ca>
-	* [r279] source/geom/LineString.cpp, source/geom/MultiPoint.cpp,
-	  source/geomgraph/EdgeNodingValidator.cpp, source/headers/geom.h:
-	  "geom" partially upgraded to JTS 1.4
+	* [r279] "geom" partially upgraded to JTS 1.4
 2004-03-29 06:59  Yury Bychkov <me at yury.ca>
-	* [r278] VisualStudio/GEOS.vcproj, source/geom/LineSegment.cpp,
-	  source/headers/geom.h, source/headers/nodingSnapround.h,
-	  source/headers/opOverlay.h, source/headers/opRelate.h,
-	  source/headers/opValid.h, source/headers/operation.h,
-	  source/io/Unload.cpp, source/noding/snapround,
-	  source/operation/relate/RelateOp.cpp,
-	  source/operation/valid/IsValidOp.cpp,
-	  source/operation/valid/QuadtreeNestedRingTester.cpp,
-	  source/operation/valid/SweeplineNestedRingTester.cpp:
-	  "noding/snapround" package ported (JTS 1.4);
+	* [r278] "noding/snapround" package ported (JTS 1.4);
 	  "operation", "operation/valid", "operation/relate" and
 	  "operation/overlay" upgraded to JTS 1.4;
 	  "geom" partially upgraded.
 2004-03-26 07:48  Yury Bychkov <me at yury.ca>
-	* [r277] VisualStudio/GEOS.vcproj, source/headers/noding.h,
-	  source/noding, source/noding/IteratedNoder.cpp,
-	  source/noding/NodingValidator.cpp, source/noding/SegmentNode.cpp,
-	  source/noding/nodingSegmentIntersector.cpp: "noding" package
-	  ported (JTS 1.4)
+	* [r277] "noding" package ported (JTS 1.4)
 2004-03-25 02:23  Yury Bychkov <me at yury.ca>
-	* [r276] source/algorithm/RobustLineIntersector.cpp, source/graph,
-	  source/headers/indexBintree.h, source/headers/indexChain.h,
-	  source/headers/indexQuadtree.h, source/headers/indexStrtree.h,
-	  source/index/chain/MonotoneChainOverlapAction.cpp,
-	  source/index/chain/MonotoneChainSelectAction.cpp,
-	  source/index/strtree/STRtree.cpp: All "index/*" packages upgraded
-	  to JTS 1.4
+	* [r276] All "index/*" packages upgraded to JTS 1.4
 2004-03-19 09:49  Yury Bychkov <me at yury.ca>
-	* [r275] VisualStudio/GEOS.vcproj,
-	  source/algorithm/PointLocator.cpp, source/geomgraph,
-	  source/geomgraph/EdgeIntersectionList.cpp,
-	  source/geomgraph/GeometryGraph.cpp,
-	  source/geomgraph/NodeMap.cpp, source/geomgraph/PlanarGraph.cpp,
-	  source/graph/index/MonotoneChain.cpp,
-	  source/graph/index/MonotoneChainEdge.cpp,
-	  source/graph/index/MonotoneChainIndexer.cpp,
-	  source/graph/index/SegmentIntersector.cpp,
-	  source/graph/index/SimpleEdgeSetIntersector.cpp,
-	  source/graph/index/SimpleMCSweepLineIntersector.cpp,
-	  source/graph/index/SimpleSweepLineIntersector.cpp,
-	  source/graph/index/SweepLineEvent.cpp,
-	  source/graph/index/SweepLineSegment.cpp,
-	  source/headers/geomgraph.h, source/headers/geomgraphindex.h,
-	  source/headers/graph.h, source/headers/graphindex.h,
-	  source/headers/noding.h, source/headers/opOverlay.h,
-	  source/headers/opRelate.h, source/headers/operation.h,
-	  source/io/Unload.cpp, source/operation/buffer/BufferOp.cpp,
-	  source/test/XMLTester.cpp: "geomgraph" and "geomgraph/indexl"
+	* [r275] "geomgraph" and "geomgraph/indexl" upgraded to JTS 1.4
 2004-03-18 10:42  Yury Bychkov <me at yury.ca>
-	* [r274] VisualStudio/GEOS.vcproj, source/geom/Coordinate.cpp,
-	  source/geom/CoordinateList.cpp, source/geom/Envelope.cpp,
-	  source/geom/Triangle.cpp, source/headers/geom.h,
-	  source/headers/io.h, source/headers/util.h,
-	  source/io/StringTokenizer.cpp, source/io/WKTReader.cpp,
-	  source/io/WKTWriter.cpp, source/util/GeometricShapeFactory.cpp:
-	  "IO" and "Util" upgraded to JTS 1.4
+	* [r274] "IO" and "Util" upgraded to JTS 1.4
 	  "Geometry" partially upgraded.
 2004-03-17 02:00  Yury Bychkov <me at yury.ca>
-	* [r273] VisualStudio/GEOS.sln, VisualStudio/GEOS.vcproj,
-	  source/algorithm/LineIntersector.cpp,
-	  source/algorithm/SimplePointInRing.cpp, source/geom/Geometry.cpp,
-	  source/headers/geom.h, source/headers/geosAlgorithm.h,
-	  source/test/Stackwalker.h: "Algorithm" upgraded to JTS 1.4
+	* [r273] "Algorithm" upgraded to JTS 1.4
 2004-03-01 22:04  Sandro Santilli <strk at keybit.net>
-	* [r272] source/geom/Geometry.cpp, source/headers/geom.h,
-	  source/headers/opBuffer.h, source/headers/opRelate.h,
-	  source/operation/relate/RelateOp.cpp: applied const correctness
-	  changes by Manuel Prieto Villegas
-	  <ManuelPrietoVillegas at telefonica.net>
+	* [r272] applied const correctness changes by Manuel Prieto
+	  Villegas <ManuelPrietoVillegas at telefonica.net>
 2004-02-27 17:43  Sandro Santilli <strk at keybit.net>
-	* [r271] source/geom/Polygon.cpp: memory leak fix in
-	  Polygon::getArea() - reported by 'Manuel Prieto Villegas'
-	  <mprieto at dap.es>
+	* [r271] memory leak fix in Polygon::getArea() - reported by
+	  'Manuel Prieto Villegas' <mprieto at dap.es>
 2004-02-27 17:42  Sandro Santilli <strk at keybit.net>
-	* [r270] source/algorithm/CGAlgorithms.cpp,
-	  source/headers/geosAlgorithm.h: made CGAlgorithms::signedArea()
-	  and CGAlgorithms::length() arguments const-correct
+	* [r270] made CGAlgorithms::signedArea() and CGAlgorithms::length()
+	  arguments const-correct
 2004-02-20 05:44  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r269] ltmain.sh: Changed to new version of ltmain, that matches
-	  the version of libtool
+	* [r269] Changed to new version of ltmain, that matches the version
+	  of libtool
 	  on build box
 2004-01-20 05:51  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r268] configure.in: Change platform.h back to AM_CONFIG_HEADER.
+	* [r268] Change platform.h back to AM_CONFIG_HEADER.
 2004-01-20 05:10  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r267] configure.in: Change AM_CONFIG_HEADER to AC_CONFIG_HEADERS
-	  to allow autoheader to work
+	* [r267] Change AM_CONFIG_HEADER to AC_CONFIG_HEADERS to allow
+	  autoheader to work
 	  its magic.
 2003-12-11 17:01  Sandro Santilli <strk at keybit.net>
-	* [r266] source/operation/buffer/BufferOp.cpp: made buffer(0) back
-	  to its *correct* semantic (empy collection)
+	* [r266] made buffer(0) back to its *correct* semantic (empy
+	  collection)
 2003-12-11 16:01  Sandro Santilli <strk at keybit.net>
-	* [r265] source/operation/buffer/BufferOp.cpp: made buffer
-	  operation return a cloned input geom when called with 0 as
-	  distance
+	* [r265] made buffer operation return a cloned input geom when
+	  called with 0 as distance
 2003-12-11 15:53  Sandro Santilli <strk at keybit.net>
-	* [r264] source/geom/GeometryCollection.cpp: Fixed bogus copy
-	  constructor (making clone bogus)
+	* [r264] Fixed bogus copy constructor (making clone bogus)
 2003-11-13 11:57  Sandro Santilli <strk at keybit.net>
-	* [r263] doc/example.cpp: bug fixed in relate call
+	* [r263] bug fixed in relate call
 2003-11-12 22:03  Sandro Santilli <strk at keybit.net>
-	* [r262] doc/example.cpp: added relational operators
+	* [r262] added relational operators
 2003-11-12 18:02  Sandro Santilli <strk at keybit.net>
-	* [r261] source/graph/PlanarGraph.cpp, source/headers/graph.h,
-	  source/operation/overlay/PolygonBuilder.cpp: Added throw
-	  specification. Fixed leaks on exceptions.
+	* [r261] Added throw specification. Fixed leaks on exceptions.
 2003-11-12 17:15  Sandro Santilli <strk at keybit.net>
-	* [r260] source/geom/PrecisionModel.cpp: made sure PrecisionModel
-	  scale is never 0
+	* [r260] made sure PrecisionModel scale is never 0
 2003-11-12 17:10  Sandro Santilli <strk at keybit.net>
-	* [r259] source/test/XMLTester.cpp: added missing initialization
+	* [r259] added missing initialization
 2003-11-12 16:14  Sandro Santilli <strk at keybit.net>
-	* [r258] source/headers/opOverlay.h,
-	  source/operation/overlay/OverlayOp.cpp: Added some more throw
-	  specifications and cleanup on exception (leaks removed).
+	* [r258] Added some more throw specifications and cleanup on
+	  exception (leaks removed).
 2003-11-12 15:43  Sandro Santilli <strk at keybit.net>
-	* [r257] source/graph/DirectedEdgeStar.cpp,
-	  source/graph/EdgeEndStar.cpp, source/graph/GeometryGraph.cpp,
-	  source/headers/graph.h: Added some more throw specifications
+	* [r257] Added some more throw specifications
 2003-11-12 15:02  Sandro Santilli <strk at keybit.net>
-	* [r256] source/test/XMLTester.cpp: more cleanup on exception
+	* [r256] more cleanup on exception
 2003-11-12 11:08  Sandro Santilli <strk at keybit.net>
-	* [r255] doc/example.cpp: removed old changelog, moved comments in
-	  the nice standard frame
+	* [r255] removed old changelog, moved comments in the nice standard
+	  frame
 2003-11-12 11:05  Sandro Santilli <strk at keybit.net>
-	* [r254] autogen.sh: added autoheader call
+	* [r254] added autoheader call
 2003-11-07 17:51  Sandro Santilli <strk at keybit.net>
-	* [r253] source/operation/buffer/BufferOp.cpp: Memory leak fix in
-	  insertEdge()
+	* [r253] Memory leak fix in insertEdge()
 2003-11-07 17:49  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r252] ChangeLog: Added current ChangeLog
+	* [r252] Added current ChangeLog
 2003-11-07 17:45  Sandro Santilli <strk at keybit.net>
-	* [r251] source/headers/config.h.in: will be generated with
-	  ./autogen.sh
+	* [r251] will be generated with ./autogen.sh
 2003-11-07 14:21  Sandro Santilli <strk at keybit.net>
-	* [r250] Makefile.am, configure.in, doc, doc/.cvsignore,
-	  doc/Makefile, doc/Makefile.am: Made doc/ directory part of
-	  distribution. Uniformed doc build script to
+	* [r250] Made doc/ directory part of distribution. Uniformed doc
+	  build script to
 	  autotools.
 2003-11-07 14:19  Sandro Santilli <strk at keybit.net>
-	* [r249] source/headers, source/headers/.cvsignore: added
-	  config.h.in (missed before)
+	* [r249] added config.h.in (missed before)
 2003-11-07 14:18  Sandro Santilli <strk at keybit.net>
-	* [r248] source/headers, source/headers/.cvsignore: added
-	  config.h.in
+	* [r248] added config.h.in
 2003-11-07 01:58  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r247] AUTHORS: Added people!
+	* [r247] Added people!
 2003-11-07 01:23  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r245] doc/example.cpp, source/algorithm/CGAlgorithms.cpp,
-	  source/algorithm/CentroidArea.cpp,
-	  source/algorithm/CentroidLine.cpp,
-	  source/algorithm/ConvexHull.cpp,
-	  source/algorithm/InteriorPointLine.cpp,
-	  source/algorithm/MCPointInRing.cpp,
-	  source/algorithm/NonRobustCGAlgorithms.cpp,
-	  source/algorithm/SIRtreePointInRing.cpp,
-	  source/algorithm/SimplePointInAreaLocator.cpp,
-	  source/bigtest/GeometryTestFactory.cpp,
-	  source/bigtest/TestSweepLineSpeed.cpp,
-	  source/examples/CPCLException.cpp,
-	  source/examples/CoordinateListsExample.cpp,
-	  source/examples/CustomCoordinateListExample.cpp,
-	  source/examples/CustomCoordinateListExample.h,
-	  source/examples/CustomPointCoordinateList.cpp,
-	  source/geom/IntersectionMatrix.cpp, source/geom/LineSegment.cpp,
-	  source/geom/LineString.cpp, source/geom/LinearRing.cpp,
-	  source/geom/MultiPoint.cpp, source/geom/MultiPolygon.cpp,
-	  source/geom/TopologyException.cpp, source/graph/Depth.cpp,
-	  source/graph/DirectedEdge.cpp, source/graph/DirectedEdgeStar.cpp,
-	  source/graph/Edge.cpp, source/graph/EdgeEnd.cpp,
-	  source/graph/EdgeEndStar.cpp, source/graph/EdgeIntersection.cpp,
-	  source/graph/EdgeIntersectionList.cpp, source/graph/EdgeList.cpp,
-	  source/graph/EdgeRing.cpp, source/graph/GeometryGraph.cpp,
-	  source/graph/GraphComponent.cpp, source/graph/Label.cpp,
-	  source/graph/Node.cpp, source/graph/NodeFactory.cpp,
-	  source/graph/NodeMap.cpp, source/graph/PlanarGraph.cpp,
-	  source/graph/Position.cpp, source/graph/Quadrant.cpp,
-	  source/graph/TopologyLocation.cpp,
-	  source/headers/acconfig.h, source/headers/bigtest.h,
-	  source/headers/config.h.in, source/headers/geom.h,
-	  source/headers/geosAlgorithm.h, source/headers/graph.h,
-	  source/headers/graphindex.h, source/headers/indexBintree.h,
-	  source/headers/io.h, source/headers/opBuffer.h,
-	  source/headers/opDistance.h, source/headers/opOverlay.h,
-	  source/headers/operation.h, source/headers/spatialIndex.h,
-	  source/headers/unload.h, source/headers/util.h,
-	  source/index/chain/indexMonotoneChain.cpp,
-	  source/index/quadtree/DoubleBits.cpp,
-	  source/index/quadtree/QuadTreeKey.cpp,
-	  source/index/quadtree/QuadTreeNode.cpp,
-	  source/index/quadtree/QuadTreeNodeBase.cpp,
-	  source/index/quadtree/QuadTreeRoot.cpp,
-	  source/index/strtree/ItemBoundable.cpp,
-	  source/index/sweepline/SweepLineIndex.cpp,
-	  source/io/markup/MarkupSTL.h,
-	  source/operation/buffer/RightmostEdgeFinder.cpp,
-	  source/operation/distance/PolygonExtracterFilter.cpp,
-	  source/operation/valid/ConnectedInteriorTester.cpp,
-	  source/operation/valid/RepeatedPointTester.cpp,
-	  source/operation/valid/SimpleNestedRingTester.cpp,
-	  source/operation/valid/SweeplineNestedRingTester.cpp,
-	  source/test/Stackwalker.h, source/test/XMLTester.cpp,
-	  source/util/Assert.cpp, source/util/AssertionFailedException.cpp,
-	  source/util/CoordinateArrayFiter.cpp,
-	  source/util/UnsupportedOperationException.cpp: Add standard CVS
-	  headers licence notices and copyrights to all cpp and h
+	* [r245] Add standard CVS headers licence notices and copyrights to
+	  all cpp and h
 	  files.
 2003-11-06 19:04  Sandro Santilli <strk at keybit.net>
-	* [r244] source/graph/EdgeIntersectionList.cpp: removed useless
-	  Coordinate copy in ::createSplitEdge()
+	* [r244] removed useless Coordinate copy in ::createSplitEdge()
 2003-11-06 18:50  Sandro Santilli <strk at keybit.net>
-	* [r243] doc, doc/.cvsignore: first import
+	* [r243] first import
 2003-11-06 18:48  Sandro Santilli <strk at keybit.net>
-	* [r242] TODO: updated
+	* [r242] updated
-	* [r241] source/operation/overlay/PolygonBuilder.cpp: added throw
-	  information comment in PolygonBuilder
+	* [r241] added throw information comment in PolygonBuilder
 2003-11-06 18:47  Sandro Santilli <strk at keybit.net>
-	* [r240] source/operation/buffer/BufferOp.cpp: Added throw
-	  specification for BufferOp's ::buildSubgraphs() and
-	  ::computeBuffer(). Cleanup on exception in computeBuffer().
+	* [r240] Added throw specification for BufferOp's
+	  ::buildSubgraphs() and ::computeBuffer(). Cleanup on exception in
+	  computeBuffer().
 2003-11-06 18:46  Sandro Santilli <strk at keybit.net>
-	* [r239] source/headers/opBuffer.h: Added throw specification for
-	  BufferOp's ::buildSubgraphs() and ::computeBuffer()
+	* [r239] Added throw specification for BufferOp's
 2003-11-06 18:45  Sandro Santilli <strk at keybit.net>
-	* [r238] source/graph/DirectedEdgeStar.cpp, source/headers/graph.h:
-	  Added throw specification for
+	* [r238] Added throw specification for
 	  DirectEdgeStar::linkResultDirectedEdges()
 2003-11-06 18:00  Sandro Santilli <strk at keybit.net>
-	* [r237] source/operation/buffer/BufferOp.cpp: Cleanup on exception
-	  in ::bufferOp()
+	* [r237] Cleanup on exception in ::bufferOp()
 2003-11-06 17:59  Sandro Santilli <strk at keybit.net>
-	* [r236] source/graph/EdgeRing.cpp: Memory leaks fixed in
-	  ::containsPoint()
+	* [r236] Memory leaks fixed in ::containsPoint()
 2003-11-06 17:48  Sandro Santilli <strk at keybit.net>
-	* [r235] source/operation/buffer/BufferLineBuilder.cpp: Fixed
-	  memory leaks in ::closePt() and ::addLineEndCap()
+	* [r235] Fixed memory leaks in ::closePt() and ::addLineEndCap()
 2003-11-06 17:47  Sandro Santilli <strk at keybit.net>
-	* [r234] source/operation/buffer/BufferEdgeBuilder.cpp: Added
-	  support for LinearRing, removed memory leaks in ::addLineString
+	* [r234] Added support for LinearRing, removed memory leaks in
+	  ::addLineString
 2003-11-06 17:41  Sandro Santilli <strk at keybit.net>
-	* [r233] doc/example.cpp: Added Buffer,Intersection,Difference and
-	  Symdifference. Exception cleanup
+	* [r233] Added Buffer,Intersection,Difference and Symdifference.
+	  Exception cleanup
 2003-11-06 17:33  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r232] INSTALL: Small addition of into about LD_LIBRARY_PATH
+	* [r232] Small addition of into about LD_LIBRARY_PATH
 2003-11-05 21:52  Sandro Santilli <strk at keybit.net>
-	* [r231] doc/Makefile, doc/example.cpp: Modified example.cpp to
-	  make use of vectors instead of Geometry * / int
+	* [r231] Modified example.cpp to make use of vectors instead of
+	  Geometry * / int
 	  couples. Added LineString creation example. Added Makefile to
 	  compile it.
 2003-11-03 16:09  Sandro Santilli <strk at keybit.net>
-	* [r230] doc/example.cpp: Removed comments about segfaults, made
-	  the simple collection creation call
+	* [r230] Removed comments about segfaults, made the simple
+	  collection creation call
 	  cleaner by use of the clone() method.
 2003-10-31 16:36  Sandro Santilli <strk at keybit.net>
-	* [r229] source/geom/GeometryCollection.cpp,
-	  source/geom/LineString.cpp, source/geom/Point.cpp,
-	  source/geom/Polygon.cpp, source/headers/geom.h: Re-introduced
-	  clone() method. Copy constructor could not really replace it.
+	* [r229] Re-introduced clone() method. Copy constructor could not
+	  really replace it.
 2003-10-29 10:38  Sandro Santilli <strk at keybit.net>
-	* [r228] doc/example.cpp: Added centroid computation example
+	* [r228] Added centroid computation example
-	* [r227] source/algorithm/CentroidLine.cpp: Added support for
-	  LinearRing types (treated as LineString)
+	* [r227] Added support for LinearRing types (treated as LineString)
 2003-10-24 21:27  Sandro Santilli <strk at keybit.net>
-	* [r226] source/headers/geom.h: Added GeometryTypeId enum and
-	  getGeometryTypeId abstract Geometry method.
+	* [r226] Added GeometryTypeId enum and getGeometryTypeId abstract
+	  Geometry method.
 2003-10-23 09:17  Sandro Santilli <strk at keybit.net>
-	* [r225] source/headers, source/headers/.cvsignore: Added stamp-h2
-	  and platform.h
+	* [r225] Added stamp-h2 and platform.h
 2003-10-23 09:12  Sandro Santilli <strk at keybit.net>
-	* [r224] source/headers/util.h: Made CoordinateArrayFilter
-	  destructor virtual.
+	* [r224] Made CoordinateArrayFilter destructor virtual.
 2003-10-22 23:58  Sandro Santilli <strk at keybit.net>
-	* [r223] configure.in, source/headers/platform.h,
-	  source/headers/platform.h.in: Made platform.h be created by
-	  configure. In this way we will not have
+	* [r223] Made platform.h be created by configure. In this way we
+	  will not have
 	  problems of installed headers trying to include phantom config.h.
 2003-10-22 00:44  Sandro Santilli <strk at keybit.net>
-	* [r222] source/headers/indexQuadtree.h, source/headers/platform.h,
-	  source/index/quadtree/DoubleBits.cpp: Quadtree bitfield
-	  operations made using type int64. Type int64 typedef'ed based
+	* [r222] Quadtree bitfield operations made using type int64. Type
+	  int64 typedef'ed based
 	  on autoconf detected int type (long or long long). If long is not
 	  64bits int64
 	  will be really 32 bits and INT64_IS_REALLY32 will be defined.
 2003-10-21 23:51  Sandro Santilli <strk at keybit.net>
-	* [r221] acsite.m4, configure.in, source/headers/acconfig.h,
-	  source/headers/config.h.in: Added macros to find 64bit integer.
+	* [r221] Added macros to find 64bit integer.
 2003-10-21 16:16  Sandro Santilli <strk at keybit.net>
-	* [r220] doc/example.cpp: Uncommented point creation lines. Updated
-	  comments about segfaults.
+	* [r220] Uncommented point creation lines. Updated comments about
+	  segfaults.
 2003-10-21 05:35  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r219] source/test/Makefile.am: Added test.xml so it gets picked
-	  up by 'make dist'
+	* [r219] Added test.xml so it gets picked up by 'make dist'
 2003-10-21 05:09  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r218] INSTALL: Added simple installation directions.
+	* [r218] Added simple installation directions.
 2003-10-21 04:55  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r217] source/examples/Makefile.am, source/geom/Makefile.am,
-	  source/test/Makefile.am: Fix up references to header files to
-	  'make dist' works.
+	* [r217] Fix up references to header files to 'make dist' works.
 2003-10-20 17:50  Sandro Santilli <strk at keybit.net>
-	* [r216] doc/example.cpp: added Union example
+	* [r216] added Union example
 2003-10-20 15:41  Sandro Santilli <strk at keybit.net>
-	* [r215] source/geom/Geometry.cpp, source/headers/geom.h:
-	  Geometry::checkNotGeometryCollection made static and
+	* [r215] Geometry::checkNotGeometryCollection made static and
 	  non-distructive.
 2003-10-20 14:02  Sandro Santilli <strk at keybit.net>
-	* [r214] source/graph/EdgeRing.cpp,
-	  source/operation/valid/ConnectedInteriorTester.cpp: more explicit
-	  exception thrown on null Directed Edge detection
+	* [r214] more explicit exception thrown on null Directed Edge
+	  detection
 2003-10-20 13:56  Sandro Santilli <strk at keybit.net>
-	* [r213] source/util/AssertionFailedException.cpp: fixed typo
+	* [r213] fixed typo
 2003-10-20 13:53  Sandro Santilli <strk at keybit.net>
-	* [r212] source/graph/GeometryGraph.cpp: LinearRing handled as a
-	  LineString in GeometryGraph::add(const Geometry *) - more
-	  explicit exception thrown for unknown geometries
+	* [r212] LinearRing handled as a LineString in
+	  GeometryGraph::add(const Geometry *) - more explicit exception
+	  thrown for unknown geometries
 2003-10-17 05:51  Yury Bychkov <me at yury.ca>
-	* [r211] VisualStudio/GEOS.vcproj, source/geom/Polygon.cpp,
-	  source/index/quadtree/DoubleBits.cpp, source/test/XMLTester.cpp:
-	  Fixed a small memory leak.
+	* [r211] Fixed a small memory leak.
 2003-10-16 17:41  Sandro Santilli <strk at keybit.net>
-	* [r210] source/util/GEOSException.cpp,
-	  source/util/UnsupportedOperationException.cpp: Fixed a bug in
-	  GEOSException that prevented print of the type of exception
-	  thrown.
+	* [r210] Fixed a bug in GEOSException that prevented print of the
+	  type of exception thrown.
 2003-10-16 17:33  Sandro Santilli <strk at keybit.net>
-	* [r209] source/operation/valid/RepeatedPointTester.cpp: dropped
-	  useless string() cast
+	* [r209] dropped useless string() cast
 2003-10-16 17:05  Sandro Santilli <strk at keybit.net>
-	* [r208] source/geom/TopologyException.cpp, source/headers/geom.h,
-	  source/headers/util.h, source/util/IllegalArgumentException.cpp:
-	  Made TopologyException inherit from GEOSException. Adjusted
-	  IllegalArgumentException subclassing.
+	* [r208] Made TopologyException inherit from GEOSException.
+	  Adjusted IllegalArgumentException subclassing.
 2003-10-16 13:01  Sandro Santilli <strk at keybit.net>
-	* [r207] source/test/XMLTester.cpp: Added call to Unload::Release()
+	* [r207] Added call to Unload::Release()
 2003-10-16 12:09  Sandro Santilli <strk at keybit.net>
-	* [r206] source/test/XMLTester.cpp: bug fixed in exception handling
+	* [r206] bug fixed in exception handling
 2003-10-16 08:50  Sandro Santilli <strk at keybit.net>
-	* [r205] source/algorithm/CentroidArea.cpp,
-	  source/algorithm/InteriorPointArea.cpp,
-	  source/geom/LineString.cpp, source/geom/MultiPolygon.cpp,
-	  source/geom/Polygon.cpp, source/headers/geosAlgorithm.h,
-	  source/operation/overlay/LineBuilder.cpp,
-	  source/operation/valid/QuadtreeNestedRingTester.cpp: Memory leak
-	  fixes. Improved performance by mean of more calls to new
-	  getCoordinatesRO() when applicable.
+	* [r205] Memory leak fixes. Improved performance by mean of more
+	  calls to new getCoordinatesRO() when applicable.
 2003-10-16 08:48  Sandro Santilli <strk at keybit.net>
-	* [r204] source/test/XMLTester.cpp: Exceptions handled
+	* [r204] Exceptions handled
 2003-10-15 16:39  Sandro Santilli <strk at keybit.net>
-	* [r203] source/geom/GeometryFactory.cpp, source/graph/Edge.cpp,
-	  source/graph/EdgeList.cpp, source/graph/EdgeRing.cpp,
-	  source/graph/GeometryGraph.cpp, source/graph/PlanarGraph.cpp,
-	  source/headers/geom.h, source/headers/graph.h,
-	  source/operation/overlay/LineBuilder.cpp: Made
-	  Edge::getCoordinates() return a 'const' value. Adapted code set.
+	* [r203] Made Edge::getCoordinates() return a 'const' value.
+	  Adapted code set.
 2003-10-15 15:47  Sandro Santilli <strk at keybit.net>
-	* [r202] source/algorithm/MCPointInRing.cpp,
-	  source/algorithm/PointLocator.cpp: Adapted to new
-	  getCoordinatesRO() interface
+	* [r202] Adapted to new getCoordinatesRO() interface
 2003-10-15 15:30  Sandro Santilli <strk at keybit.net>
-	* [r201] source/graph/index/MonotoneChain.cpp,
-	  source/headers/graphindex.h: Declared a SweepLineEventOBJ from
-	  which MonotoneChain and SweepLineSegment
+	* [r201] Declared a SweepLineEventOBJ from which MonotoneChain and
+	  SweepLineSegment
 	  derive to abstract SweepLineEvent object previously done on void
 	  * pointers.
 	  No more compiler warnings...
 2003-10-15 11:24  Sandro Santilli <strk at keybit.net>
-	* [r200] source/graph/GeometryGraph.cpp,
-	  source/operation/valid/IsValidOp.cpp: Use getCoordinatesRO()
-	  introduced.
+	* [r200] Use getCoordinatesRO() introduced.
 2003-10-15 11:23  Sandro Santilli <strk at keybit.net>
-	* [r199] source/geom/BasicCoordinateList.cpp,
-	  Formalized const nature of toVector() method and of first
+	* [r199] Formalized const nature of toVector() method and of first
 	  argument to static removeRepeatedPoints().
 2003-10-15 10:17  Sandro Santilli <strk at keybit.net>
-	* [r198] source/geom/BasicCoordinateList.cpp,
-	  source/geom/PointCoordinateList.cpp, source/headers/geom.h: Made
-	  setPoints() get a const vector<Coordinate>.
+	* [r198] Made setPoints() get a const vector<Coordinate>.
 2003-10-15 09:54  Sandro Santilli <strk at keybit.net>
-	* [r197] source/geom/LineString.cpp, source/headers/geom.h: Added
-	  getCoordinatesRO() public method.
+	* [r197] Added getCoordinatesRO() public method.
 2003-10-15 08:52  Sandro Santilli <strk at keybit.net>
-	* [r196] source/io/WKTReader.cpp: Memory leaks fixed.
+	* [r196] Memory leaks fixed.
 2003-10-15 08:51  Sandro Santilli <strk at keybit.net>
-	* [r195] TODO: Initial import
+	* [r195] Initial import
 2003-10-15 08:08  Sandro Santilli <strk at keybit.net>
-	* [r194] source/geom/Polygon.cpp: Memory leaks fixed. Partially due
-	  to getCoordinates() and GeometryCollection()
+	* [r194] Memory leaks fixed. Partially due to getCoordinates() and
+	  GeometryCollection()
 	  changes, partially old dated.
 2003-10-14 15:58  Sandro Santilli <strk at keybit.net>
-	* [r193] source/geom/GeometryFactory.cpp: Useless vector<Geometry
-	  *> leaking allocations removed
+	* [r193] Useless vector<Geometry *> leaking allocations removed
 2003-10-13 21:26  Sandro Santilli <strk at keybit.net>
-	* [r192] ., .cvsignore, macros, macros/.cvsignore, source/bigtest,
-	  source/bigtest/.cvsignore, source/examples,
-	  source/examples/.cvsignore, source/geom, source/geom/.cvsignore,
-	  source/headers, source/headers/.cvsignore, source/test,
-	  source/test/.cvsignore: Added build time created files to
-	  cvsignore lists
+	* [r192] Added build time created files to cvsignore lists
 2003-10-13 17:54  Sandro Santilli <strk at keybit.net>
-	* [r191] source/headers/opValid.h,
-	  source/operation/valid/IsValidOp.cpp: IsValidOp constructor used
-	  same name for the arg and a private element. Fixed.
+	* [r191] IsValidOp constructor used same name for the arg and a
+	  private element. Fixed.
 2003-10-13 17:47  Sandro Santilli <strk at keybit.net>
-	* [r190] source/operation/overlay/MaximalEdgeRing.cpp,
-	  source/operation/overlay/PolygonBuilder.cpp: delete statement
-	  removed
+	* [r190] delete statement removed
 2003-10-13 15:39  Sandro Santilli <strk at keybit.net>
-	* [r189] source/algorithm/CentroidArea.cpp,
-	  source/algorithm/InteriorPointPoint.cpp,
-	  source/headers/geosAlgorithm.h: Fixed some leak or fault flips
-	  (forced copy of a single coordinate)
+	* [r189] Fixed some leak or fault flips (forced copy of a single
+	  coordinate)
 2003-10-13 15:02  Sandro Santilli <strk at keybit.net>
-	* [r188] source/test/XMLTester.cpp: accept input file as first
-	  argument on cmdline
+	* [r188] accept input file as first argument on cmdline
 2003-10-13 12:51  Sandro Santilli <strk at keybit.net>
-	* [r187] source/geom/Geometry.cpp, source/headers/geom.h: removed
-	  sortedClasses strings array from all geometries.
+	* [r187] removed sortedClasses strings array from all geometries.
 2003-10-13 09:24  Sandro Santilli <strk at keybit.net>
-	* [r186] source/headers/indexQuadtree.h,
-	  source/index/quadtree/DoubleBits.cpp: long -> long long
-	  enlargement of types to allow for left/rigth shift of 53 bits
+	* [r186] long -> long long enlargement of types to allow for
+	  left/rigth shift of 53 bits
 2003-10-11 03:23  Sandro Santilli <strk at keybit.net>
-	* [r185] source/geom/LineString.cpp, source/geom/LinearRing.cpp:
-	  fixed spurious typos
+	* [r185] fixed spurious typos
 2003-10-11 01:56  Sandro Santilli <strk at keybit.net>
-	* [r184] source/algorithm/CGAlgorithms.cpp,
-	  source/algorithm/CentroidPoint.cpp,
-	  source/algorithm/NonRobustLineIntersector.cpp,
-	  source/algorithm/RobustCGAlgorithms.cpp,
-	  source/algorithm/RobustLineIntersector.cpp,
-	  source/geom/BasicCoordinateList.cpp, source/geom/Coordinate.cpp,
-	  source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
-	  source/geom/GeometryCollectionIterator.cpp,
-	  source/geom/GeometryComponentFilter.cpp,
-	  source/geom/GeometryFactory.cpp, source/geom/LineSegment.cpp,
-	  source/geom/MultiLineString.cpp, source/geom/MultiPoint.cpp,
-	  source/geom/MultiPolygon.cpp, source/geom/Point.cpp,
-	  source/geom/PointCoordinateList.cpp, source/geom/Polygon.cpp,
-	  source/geom/PrecisionModel.cpp, source/graph/Edge.cpp,
-	  source/graph/EdgeEnd.cpp, source/graph/EdgeIntersection.cpp,
-	  source/graph/EdgeIntersectionList.cpp, source/graph/EdgeRing.cpp,
-	  source/graph/GeometryGraph.cpp, source/graph/GraphComponent.cpp,
-	  source/graph/Label.cpp, source/graph/Node.cpp,
-	  source/graph/Quadrant.cpp, source/graph/TopologyLocation.cpp,
-	  source/graph/index/SweepLineEvent.cpp, source/headers/geom.h,
-	  source/headers/opRelate.h, source/headers/opValid.h,
-	  source/headers/operation.h, source/headers/util.h,
-	  source/operation/GeometryGraphOperation.cpp,
-	  source/operation/IsSimpleOp.cpp,
-	  source/operation/distance/ConnectedElementPointFilter.cpp,
-	  source/operation/overlay/OverlayOp.cpp,
-	  source/operation/overlay/PointBuilder.cpp,
-	  source/operation/overlay/PolygonBuilder.cpp,
-	  source/operation/relate/RelateComputer.cpp,
-	  source/util/Assert.cpp, source/util/CoordinateArrayFiter.cpp,
-	  source/util/UniqueCoordinateArrayFilter.cpp: Code base padded
-	  with 'const' keywords ;)
+	* [r184] Code base padded with 'const' keywords ;)
 2003-10-09 15:35  Sandro Santilli <strk at keybit.net>
-	* [r183] source/geom/GeometryFactory.cpp, source/headers/geom.h:
-	  added 'const' keyword to GeometryFactory constructor, Log on top
-	  of geom.h
+	* [r183] added 'const' keyword to GeometryFactory constructor, Log
+	  on top of geom.h
 2003-10-09 11:20  Sandro Santilli <strk at keybit.net>
-	* [r182] doc/example.cpp: moved Log to a better place
+	* [r182] moved Log to a better place
 2003-10-09 11:19  Sandro Santilli <strk at keybit.net>
-	* [r181] doc/example.cpp: added convexHull and PrecisionModel
+	* [r181] added convexHull and PrecisionModel
 2003-10-09 10:14  Sandro Santilli <strk at keybit.net>
-	* [r180] source/geom/GeometryFactory.cpp: just a style change in
-	  top Log comment.
+	* [r180] just a style change in top Log comment.
 2003-10-09 10:10  Sandro Santilli <strk at keybit.net>
-	* [r179] source/geom/PrecisionModel.cpp: Throw an exception if
-	  scale is 0. Added Log entry.
+	* [r179] Throw an exception if scale is 0. Added Log entry.
 2003-10-09 09:42  Sandro Santilli <strk at keybit.net>
-	* [r178] source/geom/GeometryFactory.cpp: Tried to "formalize"
-	  constant nature of the first argument given to constructor by
-	  PrecisionModel and SRID specification. Added CVS Log on top.
+	* [r178] Tried to "formalize" constant nature of the first argument
+	  given to constructor by PrecisionModel and SRID specification.
+	  Added CVS Log on top.
 2003-10-09 08:58  Sandro Santilli <strk at keybit.net>
-	* [r177] doc/example.cpp, source/algorithm/ConvexHull.cpp: Added
-	  convexHull() call to example, fixed leaks in ConvexHull
+	* [r177] Added convexHull() call to example, fixed leaks in
+	  ConvexHull
 2003-10-09 00:11  Sandro Santilli <strk at keybit.net>
-	* [r176] doc, doc/example.cpp: First reference-by-example file.
+	* [r176] First reference-by-example file.
 2003-10-08 16:51  Sandro Santilli <strk at keybit.net>
-	* [r175] source/geom/Makefile.am, source/headers/Makefile.am,
-	  source/headers/indexQuadtree.h, source/headers/opRelate.h,
-	  source/headers/unload.h, source/io/Unload.cpp: Added xie's Unload
-	  class with some fixes.
+	* [r175] Added xie's Unload class with some fixes.
 2003-10-08 13:18  Sandro Santilli <strk at keybit.net>
-	* [r174] source/headers/io.h, source/io/WKTWriter.cpp: added
-	  missing LinearRing writing capabilities.
+	* [r174] added missing LinearRing writing capabilities.
 2003-10-08 10:36  Sandro Santilli <strk at keybit.net>
-	* [r173] source/geom/GeometryCollection.cpp: Constructor by
-	  vector<Geometry *> * now makes a copy of the vector so that call
+	* [r173] Constructor by vector<Geometry *> * now makes a copy of
+	  the vector so that call
 	  ers can safely delete it when done.
 2003-10-07 21:47  Sandro Santilli <strk at keybit.net>
-	* [r172] source/algorithm/SimplePointInAreaLocator.cpp,
-	  source/geom/Polygon.cpp, source/graph/EdgeRing.cpp,
-	  source/operation/overlay/PolygonBuilder.cpp: had all
-	  getCoordinates() callers free returned value.
+	* [r172] had all getCoordinates() callers free returned value.
 2003-10-07 18:58  Sandro Santilli <strk at keybit.net>
-	* [r171] source/algorithm/PointLocator.cpp,
-	  source/geom/GeometryCollection.cpp, source/geom/LineString.cpp,
-	  source/graph/GeometryGraph.cpp, source/headers/config.h.in:
-	  LineString constructor now creates its own copy of given
+	* [r171] LineString constructor now creates its own copy of given
 	  CoordinateList object, and returns a new copy with
 	  getCoordinates().
 	  will be easier to remove by anyone else.
 2003-10-03 01:20  Yury Bychkov <me at yury.ca>
-	* [r170] source/geom/MultiPolygon.cpp, source/test/XMLTester.cpp:
-	  Memory leak in Overlay fixed.
+	* [r170] Memory leak in Overlay fixed.
 2003-09-29 16:25  Sandro Santilli <strk at keybit.net>
-	* [r169] macros, macros/.cvsignore, source/bigtest,
-	  source/examples/.cvsignore, source/headers,
-	  source/headers/.cvsignore: Some more cvsignore files. Some
-	  entries should probably not be
+	* [r169] Some more cvsignore files. Some entries should probably
+	  not be
 	  in the local copy
 2003-09-29 15:07  Sandro Santilli <strk at keybit.net>
-	* [r168] ., .cvsignore: Added config.sub, config.guess and
-	  autom4te.cache
+	* [r168] Added config.sub, config.guess and autom4te.cache
 2003-09-29 13:15  Sandro Santilli <strk at keybit.net>
-	* [r167] tools, tools/.cvsignore: Don't wonder about Makefile.in,
-	  Makefile, gdal-config
+	* [r167] Don't wonder about Makefile.in, Makefile, gdal-config
 2003-09-26 17:31  Sandro Santilli <strk at keybit.net>
-	* [r166] source/algorithm/ConvexHull.cpp: getConvexHull() made
-	  check value returned by reduce() before deleting
+	* [r166] getConvexHull() made check value returned by reduce()
+	  before deleting
 	  it (might be the untouched input).
 2003-09-26 09:17  Yury Bychkov <me at yury.ca>
-	* [r165] source/index/bintree/NodeBase.cpp,
-	  source/test/XMLTester.cpp: isValid segfault fixed. Overlay still
-	  leaks a bit.
+	* [r165] isValid segfault fixed. Overlay still leaks a bit.
 2003-09-24 02:16  Yury Bychkov <me at yury.ca>
-	* [r164] source/geom/MultiPolygon.cpp,
-	  source/graph/EdgeEndStar.cpp, source/index/bintree/NodeBase.cpp,
-	  source/index/bintree/Root.cpp,
-	  source/test/XMLTester.cpp: All reported bugs fiexd. Small leak in
-	  Overlay remains.
+	* [r164] All reported bugs fiexd. Small leak in Overlay remains.
 2003-09-06 08:24  Yury Bychkov <me at yury.ca>
-	* [r163] source/geom/Geometry.cpp, source/headers/opDistance.h,
-	  source/test/XMLTester.cpp: isWithinDistance fixed and tested.
+	* [r163] isWithinDistance fixed and tested.
 2003-09-06 00:01  Yury Bychkov <me at yury.ca>
-	* [r162] source/algorithm/InteriorPointArea.cpp,
-	  source/geom/Geometry.cpp, source/graph/DirectedEdge.cpp,
-	  source/graph/DirectedEdgeStar.cpp,
-	  source/test/XMLTester.cpp: getInteriorPoint bugs fixed.
+	* [r162] getInteriorPoint bugs fixed.
 2003-09-01 06:32  Yury Bychkov <me at yury.ca>
-	* [r161] source/algorithm/ConvexHull.cpp, source/geom/Geometry.cpp,
-	  source/geom/Polygon.cpp, source/test/XMLTester.cpp: Some
-	  ConvexHull bugs fixed.
+	* [r161] Some ConvexHull bugs fixed.
 2003-08-30 07:55  Yury Bychkov <me at yury.ca>
-	* [r160] source/algorithm/CentroidArea.cpp,
-	  source/geom/Polygon.cpp, source/graph/GeometryGraph.cpp,
-	  source/operation/IsSimpleOp.cpp, source/test/XMLTester.cpp: Some
-	  bugfixes. XMLTester expanded to accomodate getBoundary,
-	  getCentroid, isSimple.
+	* [r160] Some bugfixes. XMLTester expanded to accomodate
+	  getBoundary, getCentroid, isSimple.
 2003-08-18 23:40  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r159] source/algorithm/ConvexHull.java: Removed java source file
-	  from archive.
+	* [r159] Removed java source file from archive.
 2003-08-18 22:34  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r158] configure.in: Change it back :/
+	* [r158] Change it back :/
 2003-08-18 22:33  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r157] configure.in: Change version number.
+	* [r157] Change version number.
 2003-08-18 20:42  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r156] ltmain.sh: Return ltmain to distro (oops)
+	* [r156] Return ltmain to distro (oops)
 2003-08-18 20:36  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r155] mkinstalldirs: Remove more autoconf files
+	* [r155] Remove more autoconf files
 2003-08-18 20:34  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r154] acinclude.m4, config.guess, config.sub, install-sh,
-	  ltmain.sh: Removed more autoconf files...
+	* [r154] Removed more autoconf files...
 2003-08-18 20:27  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r153] missing: Removed 'missing' script.
+	* [r153] Removed 'missing' script.
 2003-08-18 16:38  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r152] source/headers/Makefile.am: Fixed up to treat headers as
-	  headers.
+	* [r152] Fixed up to treat headers as headers.
 2003-08-17 18:40  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r151] Makefile.am, source/Makefile.am,
-	  source/algorithm/HCoordinate.cpp,
-	  source/algorithm/NotRepresentableException.cpp,
-	  source/algorithm/RobustDeterminant.cpp,
-	  source/bigtest/Makefile.am,
-	  source/examples/Makefile.am, source/geom/BasicCoordinateList.cpp,
-	  source/geom/Coordinate.cpp, source/geom/CoordinateList.cpp,
-	  source/geom/CoordinateListFactory.cpp, source/geom/Dimension.cpp,
-	  source/geom/Envelope.cpp, source/geom/Geometry.cpp,
-	  source/geom/Location.cpp, source/geom/Makefile.am,
-	  source/headers/Makefile.am, source/headers/geom.h,
-	  source/index/bintree/BinTreeInterval.cpp,
-	  source/index/bintree/BinTreeNode.cpp,
-	  source/index/bintree/Bintree.cpp, source/index/bintree/Key.cpp,
-	  source/index/bintree/NodeBase.cpp, source/index/bintree/Root.cpp,
-	  source/index/chain/MonotoneChainBuilder.cpp,
-	  source/index/quadtree/IntervalSize.cpp,
-	  source/index/strtree/AbstractNode.cpp,
-	  source/index/strtree/AbstractSTRtree.cpp,
-	  source/index/strtree/Interval.cpp,
-	  source/index/strtree/SIRtree.cpp,
-	  source/index/sweepline/SweepLineInterval.cpp,
-	  source/index/sweepline/indexSweepLineEvent.cpp,
-	  source/io/ParseException.cpp, source/io/StringTokenizer.cpp,
-	  source/io/WKTReader.cpp, source/io/WKTWriter.cpp,
-	  source/io/Writer.cpp,
-	  source/operation/buffer/BufferSubgraph.cpp,
-	  source/operation/overlay/EdgeSetNoder.cpp,
-	  source/operation/overlay/MaximalEdgeRing.cpp,
-	  source/operation/overlay/MinimalEdgeRing.cpp,
-	  source/operation/overlay/OverlayNodeFactory.cpp,
-	  source/operation/relate/EdgeEndBuilder.cpp,
-	  source/operation/relate/EdgeEndBundle.cpp,
-	  source/operation/relate/EdgeEndBundleStar.cpp,
-	  source/operation/relate/RelateNode.cpp,
-	  source/operation/relate/RelateNodeFactory.cpp,
-	  source/operation/relate/RelateNodeGraph.cpp,
-	  source/operation/valid/ConsistentAreaTester.cpp,
-	  source/operation/valid/TopologyValidationError.cpp,
-	  source/test/Makefile.am, source/test/XMLTester.cpp,
-	  source/util/GEOSException.cpp,
-	  source/util/IllegalArgumentException.cpp,
-	  source/util/UniqueCoordinateArrayFilter.cpp,
-	  source/util/UnsupportedOperationException.cpp: Norman's patch +
-	  global removal of "no newline" + small changes
+	* [r151] Norman's patch + global removal of "no newline" + small
+	  changes
 	  to make Norman's patch work in the linux build environment.
 2003-08-17 18:01  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r150] libtool: Removed more configuration files per Norman's
-	  request.
+	* [r150] Removed more configuration files per Norman's request.
 2003-08-17 17:56  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r149] aclocal.m4, configure: Removed more configure files per
-	  Norman's request.
+	* [r149] Removed more configure files per Norman's request.
 2003-08-17 17:55  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r148] Makefile.in, macros/Makefile.in, source/Makefile.in,
-	  source/bigtest/Makefile.in, source/geom/Coordinate.cpp,
-	  source/geom/Makefile.in, source/headers/Makefile.in,
-	  source/test/Makefile.in, tools/Makefile.in: Removed Makefile.in
-	  files, per Norman's request.
+	* [r148] Removed Makefile.in files, per Norman's request.
 2003-08-16 06:33  Yury Bychkov <me at yury.ca>
-	* [r147] VisualStudio/GEOS.vcproj, source/algorithm/ConvexHull.cpp,
-	  source/geom/CoordinateList.cpp, source/geom/Dimension.cpp,
-	  source/geom/IntersectionMatrix.cpp, source/geom/LineString.cpp,
-	  source/geom/LinearRing.cpp, source/geom/Location.cpp,
-	  source/geom/Point.cpp, source/geom/PointCoordinateList.cpp,
-	  source/geom/Polygon.cpp, source/geom/TopologyException.cpp,
-	  source/graph/Depth.cpp, source/graph/DirectedEdge.cpp,
-	  source/graph/DirectedEdgeStar.cpp, source/graph/Edge.cpp,
-	  source/graph/EdgeEnd.cpp, source/graph/EdgeEndStar.cpp,
-	  source/graph/EdgeIntersection.cpp,
-	  source/graph/Node.cpp, source/graph/NodeMap.cpp,
-	  source/graph/PlanarGraph.cpp, source/graph/TopologyLocation.cpp,
-	  source/graph/index/SweepLineEvent.cpp, source/headers/bigtest.h,
-	  source/headers/indexSweepline.h, source/headers/io.h,
-	  source/headers/opBuffer.h, source/headers/opDistance.h,
-	  source/headers/spatialIndex.h, source/headers/util.h,
-	  source/index/quadtree/QuadTreeRoot.cpp, source/io/WKTReader.cpp,
-	  source/test/Stackwalker.cpp, source/test/Stackwalker.h,
-	  source/test/XMLTester.cpp, source/util/CoordinateArrayFiter.cpp,
-	  source/util/UniqueCoordinateArrayFilter.cpp: Memory leak fixes.
+	* [r147] Memory leak fixes.
 2003-06-21 22:17  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r146] source/geom/Makefile.am: GNU compile fixes from nvine.
+	* [r146] GNU compile fixes from nvine.
 2003-06-19 20:54  Yury Bychkov <me at yury.ca>
-	* [r145] source/algorithm/CGAlgorithms.cpp,
-	  source/geom/Location.cpp, source/geom/MultiLineString.cpp,
-	  source/geom/Polygon.cpp, source/geom/PrecisionModel.cpp,
-	  source/headers/bigtest.h, source/headers/geom.h,
-	  source/headers/indexChain.h, source/headers/indexQuadtree.h,
-	  source/headers/indexStrtree.h, source/headers/indexSweepline.h,
-	  source/headers/util.h, source/index/bintree/BinTreeInterval.cpp,
-	  source/test/CTS.cpp, source/test/SimpleWKTTester.cpp,
-	  source/test/XMLTester.cpp, source/util/Assert.cpp,
-	  source/util/AssertionFailedException.cpp,
-	  source/util/UnsupportedOperationException.cpp: 'geos' namespace
-	  added.
+	* [r145] 'geos' namespace added.
 2003-06-18 20:08  Yury Bychkov <me at yury.ca>
-	* [r144] source/headers/opBuffer.h, source/operation/buffer,
-	  source/operation/buffer/RightmostEdgeFinder.cpp: Buffer is almost
-	  fully debugged.
+	* [r144] Buffer is almost fully debugged.
 2003-05-29 00:05  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r143] source/bigtest/Makefile.am, source/geom/Makefile.am: Final
-	  GNU build adjustments.
+	* [r143] Final GNU build adjustments.
 2003-05-28 23:55  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r142] source/examples/Makefile.am: Added new exception class.
+	* [r142] Added new exception class.
 2003-05-28 23:39  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r141] source/headers/Makefile.am: Change reference to
-	  spatialIndex.h
+	* [r141] Change reference to spatialIndex.h
 2003-05-28 23:22  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r140] source/geom/Makefile.am: Removed obsolete build entries
-	  for removed classes.
+	* [r140] Removed obsolete build entries for removed classes.
 2003-05-28 22:22  Yury Bychkov <me at yury.ca>
-	* [r139] source/headers/indexStrtree.h,
-	  source/index/strtree/Interval.cpp: Some bugfixes.
+	* [r139] Some bugfixes.
 2003-05-28 22:11  Yury Bychkov <me at yury.ca>
-	* [r138] source/index/bintree/Interval.cpp,
-	  source/index/bintree/Node.cpp, source/test/XMLTester.cpp: no
-	  message
+	* [r138] no message
 2003-05-28 05:02  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r137] source/index/strtree/Interval.cpp,
-	  source/index/strtree/SIRtree.cpp: Changed __max/__min to max/min
+	* [r137] Changed __max/__min to max/min
 2003-05-28 05:01  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r136] source/index/quadtree/IntervalSize.cpp: Change __max to
-	  max
+	* [r136] Change __max to max
 2003-05-27 23:56  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r135] source/geom/Makefile.am: Changed from mistaken cpp file
-	  names.
+	* [r135] Changed from mistaken cpp file names.
 2003-05-27 23:54  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r134] source/algorithm/CentroidArea.cpp: Added include for
-	  <typeinfo>
+	* [r134] Added include for <typeinfo>
 2003-05-27 23:45  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r133] source/headers/indexStrtree.h: GNU build support
+	* [r133] GNU build support
 2003-05-27 23:42  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r132] source/headers/indexQuadtree.h: Fix reference to
-	  spatialIndex header
+	* [r132] Fix reference to spatialIndex header
 2003-05-27 23:41  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r131] source/headers/Makefile.in, source/headers/SpatialIndex.h,
-	  source/headers/geom.h, source/headers/indexStrtree.h,
-	  source/headers/spatialIndex.h: Build updates.
+	* [r131] Build updates.
 2003-05-27 23:33  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r130] source/geom/Makefile.am: Add new files into build support
+	* [r130] Add new files into build support
 2003-05-27 23:17  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r129] source/headers/Makefile.am: Add all new headers into the
-	  build process.
+	* [r129] Add all new headers into the build process.
 2003-05-27 23:11  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r128] source/geom/Makefile.am, source/headers/Makefile.am: Some
-	  updates to synch build with devel.
+	* [r128] Some updates to synch build with devel.
 2003-05-21 23:28  Yury Bychkov <me at yury.ca>
-	* [r127] source/algorithm/MCPointInRing.cpp,
-	  source/geom/PrecisionModel.cpp, source/graph/GeometryGraph.cpp,
-	  source/index/bintree/Key.cpp,
-	  source/operation/relate/RelateOp.cpp: Several bugs fixed.
+	* [r127] Several bugs fixed.
 2003-05-19 06:18  Yury Bychkov <me at yury.ca>
-	* [r126] source/algorithm/HCoordinate.cpp,
-	  source/geom/Point.cpp, source/geom/Polygon.cpp,
-	  source/graph/GeometryGraph.cpp, source/graph/Quadrant.cpp,
-	  source/io/ParseException.cpp, source/io/WKTReader.cpp,
-	  source/util/UnsupportedOperationException.cpp: All exceptions are
-	  now classes.
+	* [r126] All exceptions are now classes.
 2003-05-17 07:47  Yury Bychkov <me at yury.ca>
-	* [r125] source/algorithm/CentroidArea.cpp,
-	  source/index/quadtree/QuadTreeNodeBase.cpp: Last fix for CVS.
+	* [r125] Last fix for CVS.
 2003-05-17 06:08  Yury Bychkov <me at yury.ca>
-	* [r124] source/algorithm/MCPointInRing.cpp,
-	  source/geom/GeometryFactory.cpp, source/graph/GeometryGraph.cpp,
-	  source/operation/valid/IsValidOp.cpp: Fixing CVS error.
+	* [r124] Fixing CVS error.
 2003-05-17 00:27  Yury Bychkov <me at yury.ca>
-	* [r123] source/geom/GeometryCollection.cpp,
-	  source/headers/geosAlgorithm.h: Fixing a commit problem.
+	* [r123] Fixing a commit problem.
 2003-05-17 00:07  Yury Bychkov <me at yury.ca>
-	* [r122] source/algorithm/MCPointInRing.cpp,
-	  source/headers/graph.h, source/headers/opDistance.h,
-	  source/index/intervaltree, source/index/strtree/SIRtree.cpp,
-	  source/index/strtree/STRtree.cpp, source/operation/distance,
-	  source/operation/distance/PolygonExtracterFilter.cpp: SIRtree is
-	  done. Distance is done.
+	* [r122] SIRtree is done. Distance is done.
 2003-05-07 09:06  Yury Bychkov <me at yury.ca>
-	* [r121] source/algorithm/CentroidArea.cpp,
-	  source/algorithm/ConvexHull.java,
-	  source/algorithm/IntTreePointInRing.cpp,
-	  source/headers/SpatialIndex.h, source/headers/geosAlgorithm.h,
-	  source/headers/indexIntervaltree.h,
-	  source/index/bintree, source/index/bintree/BinTreeInterval.cpp,
-	  source/index/bintree/Interval.cpp, source/index/bintree/Key.cpp,
-	  source/index/bintree/Node.cpp, source/index/bintree/NodeBase.cpp,
-	  source/index/quadtree/Quad.cpp,
-	  source/index/quadtree/Quadtree.cpp, source/index/strtree,
-	  source/operation/valid/QuadtreeNestedRingTester.cpp: Closer to
-	  1.3
+	* [r121] Closer to 1.3
 2003-05-04 22:34  Yury Bychkov <me at yury.ca>
-	* [r120] source/algorithm/NonRobustCGAlgorithms.cpp,
-	  source/geom/PrecisionModel.cpp, source/graph/EdgeList.cpp,
-	  source/headers/graphindex.h, source/headers/opRelate.h,
-	  source/operation/valid/IsValidOp.cpp: Closer to JTS 1.3
+	* [r120] Closer to JTS 1.3
 2003-04-28 06:01  Yury Bychkov <me at yury.ca>
-	* [r119] source/algorithm/CGAlgorithms.cpp,
-	  source/graph/index/SweepLineSegment.cpp, source/headers/geom.h,
-	  source/headers/graphindex.h, source/headers/opOverlay.h,
-	  source/index/intervaltree/IntervalNode.cpp,
-	  source/index/intervaltree/IntervalTree.cpp,
-	  source/util/Assert.cpp, source/util/AssertionFailedException.cpp:
-	  Partially upgraded to JTS 1.3
+	* [r119] Partially upgraded to JTS 1.3
 2003-04-21 22:16  Yury Bychkov <me at yury.ca>
-	* [r118] VisualStudio, VisualStudio/GEOS.sln,
-	  VisualStudio/GEOS.vcproj: VisualStudio project added.
+	* [r118] VisualStudio project added.
 2003-04-17 00:37  Yury Bychkov <me at yury.ca>
-	* [r117] source/geom/BasicCoordinateList.cpp,
-	  source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
-	  source/graph/GeometryGraph.cpp, source/io/WKTReader.cpp: Changed
-	  PrecisionModel to Value type. Removed bounds checking from *At
-	  methods in CoordinateLists.
+	* [r117] Changed PrecisionModel to Value type. Removed bounds
+	  checking from *At methods in CoordinateLists.
 2003-04-12 04:31  Yury Bychkov <me at yury.ca>
-	* [r116] source/graph/EdgeRing.cpp,
-	  source/operation/overlay/OverlayOp.cpp: Overlay passes all tests
-	  (both precise and normal)
+	* [r116] Overlay passes all tests (both precise and normal)
 2003-04-11 23:16  Yury Bychkov <me at yury.ca>
-	* [r115] source/geom/Geometry.cpp,
-	  source/geom/GeometryFactory.cpp, source/geom/LineString.cpp,
-	  source/headers/geom.h, source/io/WKTReader.cpp,
-	  source/test/XMLTester.cpp: Overlay almost works. Fails 2 tests.
+	* [r115] Overlay almost works. Fails 2 tests.
 2003-04-10 04:34  Yury Bychkov <me at yury.ca>
-	* [r114] source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
-	  source/graph/Depth.cpp, source/graph/DirectedEdgeStar.cpp,
-	  source/test/XMLTester.cpp: Overlay passes all normal tests. Still
-	  fails on Precision tests.
+	* [r114] Overlay passes all normal tests. Still fails on Precision
+	  tests.
 2003-04-09 21:52  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r113] source/headers/geom.h: Changed destructors to virtual to
-	  quiet GNU warnings
+	* [r113] Changed destructors to virtual to quiet GNU warnings
 2003-04-04 23:49  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r112] source/headers/Makefile.am: Install all headers at install
-	  time.
+	* [r112] Install all headers at install time.
 2003-04-04 22:04  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r111] source/examples/CustomCoordinateListExample.cpp,
-	  source/examples/CustomPointCoordinateList.cpp: Newlines added to
-	  quiet gcc.
+	* [r111] Newlines added to quiet gcc.
 2003-04-04 03:44  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r110] source/geom/Makefile.am: Build support
+	* [r110] Build support
 2003-04-04 03:43  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r109] source/examples/Makefile.am: Build support.
+	* [r109] Build support.
 2003-04-04 03:28  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r108] source/geom/Makefile.am: Build support updates.
+	* [r108] Build support updates.
 2003-04-04 03:11  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r107] source/examples/Makefile.am: Build support for new example
-	  programs.
+	* [r107] Build support for new example programs.
 2003-04-04 00:18  dblasby
-	* [r106] INSTALL: added comment about running ./autogen.sh
+	* [r106] added comment about running ./autogen.sh
 2003-04-02 21:55  Yury Bychkov <me at yury.ca>
-	* [r105] source/examples/CustomCoordinateListExample.cpp,
-	  source/examples/CustomPointCoordinateList.cpp: Added example on
-	  how to wrap internal storage format with CoordinateLists.
+	* [r105] Added example on how to wrap internal storage format with
+	  CoordinateLists.
 2003-04-02 08:02  Yury Bychkov <me at yury.ca>
-	* [r104] source/algorithm/MCPointInRing.cpp,
-	  source/geom/BasicCoordinateList.cpp, source/geom/LineString.cpp,
-	  source/graph/DirectedEdge.cpp, source/graph/EdgeEnd.cpp,
-	  source/graph/Node.cpp, source/headers/geom.h,
-	  source/headers/indexChain.h, source/headers/opOverlay.h,
-	  source/operation/valid/IsValidOp.cpp: isValid is debugged (passes
-	  all 805 tests).
+	* [r104] isValid is debugged (passes all 805 tests).
 2003-03-24 19:23  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r103] source/headers/indexQuadtree.h,
-	  source/headers/indexSweepline.h: Added newlines to end to quiet
-	  gcc
+	* [r103] Added newlines to end to quiet gcc
 2003-03-24 19:21  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r102] Makefile.in, aclocal.m4, configure, configure.in, libtool,
-	  macros/Makefile.in, source/Makefile.am, source/Makefile.in,
-	  source/algorithm/Makefile.am, source/algorithm/Makefile.in,
-	  source/bigtest/Makefile.in, source/geom/Makefile.in,
-	  source/graph/Makefile.am, source/graph/Makefile.in,
-	  source/graph/index/Makefile.am, source/graph/index/Makefile.in,
-	  source/headers/Makefile.in, source/headers/config.h.in,
-	  source/headers/indexChain.h, source/headers/indexIntervaltree.h,
-	  source/io/Makefile.am, source/io/Makefile.in,
-	  source/io/markup/Makefile.am, source/io/markup/Makefile.in,
-	  source/operation/Makefile.am, source/operation/Makefile.in,
-	  source/operation/relate/Makefile.am,
-	  source/operation/relate/Makefile.in,
-	  source/operation/valid/Makefile.am, source/test/Makefile.in,
-	  source/util/Makefile.am, source/util/Makefile.in,
-	  tools/Makefile.in: Yet more GNU build fiddling. Removed
-	  extraneous build support from all
+	* [r102] Yet more GNU build fiddling. Removed extraneous build
+	  support from all
 	  non-geom library directories.
 2003-03-24 03:45  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r101] source/geom/Makefile.am: More GNU build support
+	* [r101] More GNU build support
 2003-03-24 03:07  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r100] Makefile.in, aclocal.m4, configure, configure.in, libtool,
-	  macros/Makefile.in, source/Makefile.in,
-	  source/algorithm/Makefile.in, source/bigtest/Makefile.in,
-	  source/geom/Makefile.am, source/geom/Makefile.in,
-	  source/graph/Makefile.in, source/graph/index/Makefile.in,
-	  source/headers/geosAlgorithm.h, source/headers/opValid.h,
-	  source/io/Makefile.in, source/io/markup/Makefile.in,
-	  source/operation/relate/Makefile.in, source/test/Makefile.in,
-	  source/test/XMLTester.cpp, source/util/Makefile.in,
-	  tools/Makefile.in: GNU build support on latest changes.
+	* [r100] GNU build support on latest changes.
 2003-03-19 00:34  Yury Bychkov <me at yury.ca>
-	* [r99] source/algorithm/IntTreePointInRing.cpp,
-	  source/geom/Geometry.cpp, source/headers/geosAlgorithm.h,
-	  source/operation/overlay/OverlayOp.java: All Overlay classes are
-	  ported. Overlay and isValid have not been tested yet.
+	* [r99] All Overlay classes are ported. Overlay and isValid have
+	  not been tested yet.
 2003-03-18 01:42  Yury Bychkov <me at yury.ca>
-	* [r98] source/geom/Geometry.cpp, source/graph/PlanarGraph.cpp,
-	  source/headers/opOverlay.h, source/headers/opValid.h,
-	  source/operation/overlay/OverlayOp.java,
-	  source/test/XMLTester.cpp: 90% of Overlay classes ported.
+	* [r98] 90% of Overlay classes ported.
 2003-03-17 18:04  Yury Bychkov <me at yury.ca>
-	* [r97] source/algorithm/MCPointInRing.cpp,
-	  source/headers/geosAlgorithm.h, source/headers/indexChain.h,
-	  source/headers/indexIntervaltree.h, source/index/chain,
-	  source/index/intervaltree/IntervalTree.cpp: All 'index' packages
-	  and part of 'overlay' are done.
+	* [r97] All 'index' packages and part of 'overlay' are done.
 2003-03-17 02:49  Yury Bychkov <me at yury.ca>
-	* [r96] source/algorithm/MCPointInRing.cpp,
-	  source/headers/geosAlgorithm.h, source/headers/opOverlay.h,
-	  source/headers/opValid.h, source/operation/overlay,
-	  source/operation/valid/IsValidOp.cpp: IsValid and supporting
-	  packages are ported (but NOT tested).
+	* [r96] IsValid and supporting packages are ported (but NOT
+	  tested).
 2003-03-12 23:45  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r95] source/geom/Makefile.am, source/operation/Makefile.am,
-	  source/operation/valid/Makefile.am: Build support for valid.
+	* [r95] Build support for valid.
 2003-03-10 10:18  Yury Bychkov <me at yury.ca>
-	* [r94] source/headers/indexQuadtree.h, source/headers/opOverlay.h,
-	  source/operation/valid/QuadtreeNestedRingTester.cpp: IsValid()
-	  and supporting index classes are ported, but don't work yet
-	  (external dependencies)
+	* [r94] IsValid() and supporting index classes are ported, but
+	  don't work yet (external dependencies)
 2003-03-10 01:17  Yury Bychkov <me at yury.ca>
-	* [r93] source/headers/indexQuadtree.h,
-	  source/headers/indexSweepline.h, source/headers/opValid.h,
-	  source/index, source/index/quadtree,
-	  source/index/quadtree/Quadtree.cpp, source/index/sweepline,
-	  source/operation/valid,
-	  source/test/XMLTester.cpp: IsValid and supporting index classes
-	  are almost done.
+	* [r93] IsValid and supporting index classes are almost done.
 2003-03-05 17:04  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r92] configure.in, source/Makefile.am,
-	  source/examples/Makefile.am: Build support for new coordinateline
-	  examples.
+	* [r92] Build support for new coordinateline examples.
 2003-03-05 08:02  Yury Bychkov <me at yury.ca>
-	* [r91] source/examples,
-	  CoordinateList interface example.
+	* [r91] CoordinateList interface example.
 2003-03-03 03:56  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r90] source/geom/Makefile.am: Remove PointInRing
+	* [r90] Remove PointInRing
 2003-03-03 03:35  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r89] source/algorithm/PointInRing.cpp: Removed unused file.
+	* [r89] Removed unused file.
 2003-03-03 02:41  Yury Bychkov <me at yury.ca>
-	* [r88] source/algorithm/LineIntersector.cpp,
-	  source/graph/EdgeIntersectionList.cpp, source/io/WKTReader.cpp:
-	  Some Coordinate& related bugs fixed.
+	* [r88] Some Coordinate& related bugs fixed.
 2003-03-03 02:26  Yury Bychkov <me at yury.ca>
-	* [r87] source/geom/GeometryFactory.cpp: GeometryFactory bug fix.
+	* [r87] GeometryFactory bug fix.
 2003-03-03 00:46  Yury Bychkov <me at yury.ca>
-	* [r86] source/algorithm/CGAlgorithms.cpp,
-	  source/geom/LineSegment.cpp, source/geom/LineString.cpp,
-	  source/geom/PrecisionModel.cpp, source/graph/EdgeEndStar.cpp,
-	  source/graph/GeometryGraph.cpp, source/graph/Node.cpp,
-	  source/graph/index/SegmentIntersector.cpp, source/headers/geom.h,
-	  source/io/WKTReader.cpp, source/operation/IsSimpleOp.cpp,
-	  source/operation/relate/RelateNode.cpp, source/test/CTS.cpp,
-	  source/util/Assert.cpp: Second pass of code cleanup. Coordinate
-	  references and inlining.
+	* [r86] Second pass of code cleanup. Coordinate references and
+	  inlining.
 2003-03-02 03:47  Yury Bychkov <me at yury.ca>
-	* [r85] source/graph/Depth.cpp, source/graph/DirectedEdge.cpp,
-	  source/operation/relate/RelateNodeGraph.cpp: First pass of code
-	  cleanup completed over all packages.
+	* [r85] First pass of code cleanup completed over all packages.
 2003-03-01 06:10  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r84] source/headers/geosAlgorithm.h: Uncommented default
-	  constructor for PointInRing
+	* [r84] Uncommented default constructor for PointInRing
 2003-03-01 06:08  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r83] source/test/SimpleWKTTester.cpp: Fixed call to geometry
-	  factory.
+	* [r83] Fixed call to geometry factory.
 2003-02-26 23:16  Yury Bychkov <me at yury.ca>
-	* [r82] source/algorithm/LineIntersector.cpp,
-	  source/headers/geosAlgorithm.h, source/headers/io.h,
-	  source/headers/util.h, source/io/StringTokenizer.cpp,
-	  source/io/Writer.cpp, source/test/XMLTester.cpp: All packages
-	  except 'graph' has been refactored.
+	* [r82] All packages except 'graph' has been refactored.
 2003-02-20 03:32  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r81] source/test/SimpleWKTTester.cpp: Fixed small bug in call to
-	  GeometryFactory (instantiate PrecisionModel
+	* [r81] Fixed small bug in call to GeometryFactory (instantiate
+	  PrecisionModel
 	  with new)
 2003-02-20 03:30  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r80] source/geom/CoordinateListFactory.cpp,
-	  source/geom/GeometryFactory.cpp: GFactory: Move i outside of for
-	  loop. Needed to compile GNU
+	* [r80] GFactory: Move i outside of for loop. Needed to compile GNU
 	  CListFactory: Add newline to end of file.
 2003-02-20 00:10  Yury Bychkov <me at yury.ca>
-	* [r79] source/geom/GeometryFactory.cpp, source/headers/opRelate.h,
-	  source/operation/relate/RelateOp.cpp: Geom and Operation
-	  (including Relate) packages are updated.
+	* [r79] Geom and Operation (including Relate) packages are updated.
 2003-02-17 09:38  Yury Bychkov <me at yury.ca>
-	* [r78] source/geom/Envelope.cpp, source/geom/Geometry.cpp,
-	  source/graph/index/MonotoneChainEdge.cpp, source/headers/geom.h,
-	  source/headers/io.h, source/headers/opRelate.h,
-	  source/headers/operation.h, source/io/WKTWriter.cpp,
-	  source/operation/relate/RelateOp.cpp, source/test/XMLTester.cpp:
-	  GEOM package fully updated & bugs fixed.
+	* [r78] GEOM package fully updated & bugs fixed.
 2003-02-17 00:40  Yury Bychkov <me at yury.ca>
-	* [r77] source/geom/Geometry.cpp, source/geom/MultiLineString.cpp,
-	  source/headers/geom.h, source/headers/io.h,
-	  source/io/WKTReader.cpp: GEOM package fully updated.
+	* [r77] GEOM package fully updated.
 2003-02-16 22:52  Yury Bychkov <me at yury.ca>
-	* [r76] source/bigtest/GeometryTestFactory.cpp,
-	  source/geom/LinearRing.cpp, source/geom/MultiLineString.cpp,
-	  source/graph/EdgeRing.cpp, source/headers/geom.h,
-	  source/io/WKTReader.cpp: GEOM package partially updated.
+	* [r76] GEOM package partially updated.
 2003-02-12 21:09  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r75] INSTALL, missing: Added two files required by autoconf
-	  build process.
+	* [r75] Added two files required by autoconf build process.
 2003-02-12 20:51  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r74] configure, libtool, source/geom/Makefile.in,
-	  source/headers/Makefile.in, source/test/Makefile.in: Commit build
-	  support files.
+	* [r74] Commit build support files.
 2003-02-12 19:11  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r73] source/headers/Makefile.am: Change header installation path
-	  to $(prefix)/include/geos.
+	* [r73] Change header installation path to $(prefix)/include/geos.
 2003-02-12 06:50  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r72] source/algorithm/LineIntersector.cpp,
-	  source/operation/relate/EdgeEndBundle.cpp: Added newlines to
-	  quiet g++ warnings.
+	* [r72] Added newlines to quiet g++ warnings.
 2003-02-12 06:48  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r71] source/graph/Depth.cpp, source/graph/DirectedEdge.cpp,
-	  source/graph/DirectedEdgeStar.cpp, source/graph/EdgeEnd.cpp,
-	  source/graph/Label.cpp, source/graph/NodeFactory.cpp,
-	  source/graph/index/MonotoneChain.cpp,
-	  source/graph/index/SimpleMCSweepLineIntersector.cpp,
-	  source/graph/index/SweepLineEvent.cpp: Added newlines to ends of
-	  files to quiet g++ warnings.
+	* [r71] Added newlines to ends of files to quiet g++ warnings.
 2003-02-12 06:27  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r70] source/test/XMLTester.cpp: Fix headers.
+	* [r70] Fix headers.
 2003-02-12 06:26  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r69] source/test/SimpleWKTTester.cpp: Changed headers.
+	* [r69] Changed headers.
 2003-02-12 06:24  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r68] source/bigtest/TestSweepLineSpeed.cpp: Added return value.
+	* [r68] Added return value.
-	* [r67] source/bigtest/TestSweepLineSpeed.cpp, source/test/CTS.cpp,
-	  source/test/XMLTester.cpp: Changed headers.
+	* [r67] Changed headers.
 2003-02-12 06:19  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r66] source/test/XMLTester.cpp: Make path to test file relative.
+	* [r66] Make path to test file relative.
 2003-02-12 06:18  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r65] source/bigtest/GeometryTestFactory.cpp: Change include
-	  reference syntax.
+	* [r65] Change include reference syntax.
 2003-02-12 06:07  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r64] source/graph/EdgeEndStar.cpp: Remove NULL test.
+	* [r64] Remove NULL test.
-	* [r63] source/io/WKTWriter.cpp: Pass double to log().
+	* [r63] Pass double to log().
-	* [r62] source/bigtest/TestSweepLineSpeed.cpp: Fixed main() return
-	  type.
+	* [r62] Fixed main() return type.
 2003-02-12 06:04  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r61] source/test/Makefile.am: Remove old library references.
+	* [r61] Remove old library references.
 2003-02-12 05:58  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r60] source/bigtest/TestSweepLineSpeed.cpp: Added stdio
-	  reference and newline at end.
+	* [r60] Added stdio reference and newline at end.
 2003-02-12 00:58  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r59] source/test/test.xml: Added all JTS test cases to the file.
+	* [r59] Added all JTS test cases to the file.
 2003-02-11 23:54  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r58] source/geom/Makefile.am: Added support for new cpp files.
+	* [r58] Added support for new cpp files.
 2003-02-11 23:33  Yury Bychkov <me at yury.ca>
-	* [r57] source/geom/CoordinateList.cpp, source/geom/Geometry.cpp,
-	  source/headers/geom.h: Some bugs fixed.
+	* [r57] Some bugs fixed.
 2003-02-11 20:24  Yury Bychkov <me at yury.ca>
-	* [r56] source/geom/PointCoordinateList.cpp,
-	  source/graph/EdgeEndStar.cpp, source/headers/graph.h: Small
-	  changes in PointCoordinateList and EdgeEndStar.
+	* [r56] Small changes in PointCoordinateList and EdgeEndStar.
 2003-02-11 19:01  mbdavis
-	* [r55] source/geom/Geometry.cpp: fixed duplicate for loop index
+	* [r55] fixed duplicate for loop index
 2003-02-05 08:14  Yury Bychkov <me at yury.ca>
-	* [r54] source/bigtest/GeometryTestFactory.cpp,
-	  source/geom/CoordinateListFactory.cpp, source/geom/Geometry.cpp,
-	  source/geom/LinearRing.cpp, source/geom/MultiPoint.cpp,
-	  source/graph/Edge.cpp, source/graph/EdgeIntersectionList.cpp,
-	  Second pass of CoordinateList interface migration.
+	* [r54] Second pass of CoordinateList interface migration.
 2003-01-27 08:04  Yury Bychkov <me at yury.ca>
-	* [r53] source/algorithm/NonRobustCGAlgorithms.cpp,
-	  source/algorithm/PointLocator.cpp,
-	  source/algorithm/SimplePointInRing.cpp,
-	  source/geom/BasicCoordinateList.cpp, source/geom/Envelope.cpp,
-	  source/geom/MultiLineString.cpp, source/geom/Point.cpp,
-	  source/graph/index/MonotoneChainIndexer.cpp,
-	  source/headers/graphindex.h, source/headers/io.h,
-	  source/io/WKTReader.cpp: First pass of CoordinateList interface
-	  replacement.
+	* [r53] First pass of CoordinateList interface replacement.
 2003-01-27 07:56  Yury Bychkov <me at yury.ca>
-	* [r52] source/algorithm/CGAlgorithms.cpp: First pass of
-	  CoordinateList interface replacement.
+	* [r52] First pass of CoordinateList interface replacement.
 2003-01-27 07:26  Yury Bychkov <me at yury.ca>
-	* [r51] source/algorithm/CGAlgorithms.cpp: First pass of
+	* [r51] First pass of CoordinateList interface replacement.
 2002-12-02 09:48  Yury Bychkov <me at yury.ca>
-	* [r50] source/algorithm/CGAlgorithms.cpp,
-	  source/bigtest/TestSweepLineSpeed.cpp, source/geom/Geometry.cpp,
-	  source/geom/LinearRing.cpp, source/geom/Point.cpp,
-	  source/geom/Polygon.cpp, source/graph/Edge.cpp,
-	  source/headers/geosAlgorithm.h, source/headers/graph.h: More
-	  performance updates.
+	* [r50] More performance updates.
 2002-11-24 10:48  Yury Bychkov <me at yury.ca>
-	* [r49] source/algorithm/RobustLineIntersector.cpp,
-	  source/headers/geom.h, source/headers/graphindex.h: Some
-	  performance improvements.
+	* [r49] Some performance improvements.
 2002-11-14 23:43  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r48] configure.in, source/Makefile.am, source/Makefile.in,
-	  source/bigtest/Makefile.am, source/bigtest/Makefile.in,
-	  source/geom/Makefile.am, source/geom/Makefile.in: Build support
-	  for the bigtest programs.
+	* [r48] Build support for the bigtest programs.
 2002-11-08 19:49  Yury Bychkov <me at yury.ca>
-	* [r47] source/bigtest/TestSweepLineSpeed.cpp,
-	  source/geom/Coordinate.cpp, source/graph/Edge.cpp,
-	  source/headers/graph.h, source/headers/graphindex.h: Preformance
-	  is drastically improved
+	* [r47] Preformance is drastically improved
 2002-11-05 23:13  Yury Bychkov <me at yury.ca>
-	* [r46] source/bigtest, source/bigtest/GeometryTestFactory.cpp,
-	  source/operation/relate/RelateComputer.cpp: Code for generating
-	  large tests added.
+	* [r46] Code for generating large tests added.
 2002-10-31 07:37  Yury Bychkov <me at yury.ca>
-	* [r45] source/graph/index/SimpleMCSweepLineIntersector.cpp,
-	  source/io/StringTokenizer.cpp, source/test/XMLTester.cpp: XML
-	  tester is less fragile now.
+	* [r45] XML tester is less fragile now.
 2002-10-30 21:59  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r44] config.guess, config.sub: Added configure support files for
-	  building w/o automake/autoconf
+	* [r44] Added configure support files for building w/o
+	  automake/autoconf
 2002-10-30 21:58  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r43] configure.in: Small changes to make autoconf happy.
+	* [r43] Small changes to make autoconf happy.
 2002-10-30 20:04  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r42] source/test/test.xml: Edited test file to not crash
-	  XMLTester
+	* [r42] Edited test file to not crash XMLTester
 2002-10-30 19:54  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r41] Makefile.in, aclocal.m4, configure, configure.in, libtool,
-	  source/algorithm/Makefile.in, source/geom/Makefile.am,
-	  source/geom/Makefile.in, source/graph/Makefile.in,
-	  source/graph/index/Makefile.in, source/headers/Makefile.in,
-	  source/headers/config.h.in, source/headers/opRelate.h,
-	  source/operation/Makefile.in,
-	  source/operation/relate/Makefile.in, source/test/Makefile.am,
-	  source/test/Makefile.in, source/util/Makefile.in,
-	  tools/Makefile.in: New build changes necessary to build under
-	  Linux GNU.
+	* [r41] New build changes necessary to build under Linux GNU.
 2002-10-23 02:21  nvine
-	* [r40] configure.in, source/Makefile.am, source/geom/Geometry.cpp,
-	  source/geom/GeometryCollection.cpp, source/geom/Makefile.am,
-	  source/geom/Polygon.cpp, source/graph/Depth.cpp,
-	  source/graph/PlanarGraph.cpp, source/graph/Quadrant.cpp,
-	  source/operation/relate/RelateComputer.cpp, source/test/CTS.cpp,
-	  source/test/SimpleWKTTester.cpp, source/test/XMLTester.cpp: GNU
-	  portability changes
+	* [r40] GNU portability changes
 2002-10-17 07:12  Yury Bychkov <me at yury.ca>
-	* [r39] source/algorithm/SimplePointInAreaLocator.cpp,
-	  source/headers/graphindex.h, source/test/XMLTester.cpp: All test
-	  cases now work. Some are still too slow.
+	* [r39] All test cases now work. Some are still too slow.
 2002-10-06 09:56  Yury Bychkov <me at yury.ca>
-	* [r38] source/algorithm/PointLocator.cpp,
-	  source/graph/DirectedEdgeStar.cpp, source/graph/EdgeEndStar.cpp,
-	  source/graph/GeometryGraph.cpp, source/graph/Label.cpp,
-	  source/graph/index/SweepLineEvent.cpp, source/headers/graph.h,
-	  source/test/XMLTester.cpp: Relate() is almost debugged.
+	* [r38] Relate() is almost debugged.
 2002-09-12 14:08  Fernando Villa <fvilla at zoo.uvm.edu>
-	* [r37] Makefile.in, configure, configure.in, libtool,
-	  source/headers/Makefile.am, source/headers/Makefile.in,
-	  source/operation/relate/Makefile.in: Add makefile support for new
-	  files and dir
+	* [r37] Add makefile support for new files and dir
 2002-09-12 01:27  Yury Bychkov <me at yury.ca>
-	* [r36] source/geom/Geometry.cpp, source/geom/LineString.cpp,
-	  source/geom/Polygon.cpp, source/graph/DirectedEdgeStar.cpp,
-	  source/graph/Edge.cpp, source/graph/EdgeEnd.cpp,
-	  source/graph/EdgeIntersectionList.cpp, source/graph/EdgeList.cpp,
-	  source/graph/Node.cpp, source/graph/NodeFactory.cpp,
-	  source/graph/NodeMap.cpp, source/graph/PlanarGraph.cpp,
-	  source/headers/graph.h, source/headers/opRelate.h,
-	  source/operation/relate,
-	  Relate is finished,but doesn't work yet.
+	* [r36] Relate is finished,but doesn't work yet.
 2002-09-10 13:46  Fernando Villa <fvilla at zoo.uvm.edu>
-	* [r35] configure, configure.in, libtool, source/Makefile.am,
-	  source/Makefile.in, source/geom/Makefile.am,
-	  source/geom/Makefile.in, source/operation/Makefile.am,
-	  source/operation/Makefile.in: Added operation/Makefiles
+	* [r35] Added operation/Makefiles
 2002-09-06 20:18  Yury Bychkov <me at yury.ca>
-	* [r34] source/algorithm/CGAlgorithms.cpp,
-	  source/algorithm/NonRobustCGAlgorithms.cpp,
-	  source/algorithm/SimplePointInAreaLocator.cpp,
-	  source/algorithm/SimplePointInRing.cpp, source/geom/Envelope.cpp,
-	  source/graph/GeometryGraph.cpp, source/graph/NodeMap.cpp,
-	  source/headers/geom.h, source/headers/geosAlgorithm.h,
-	  source/headers/graph.h, source/headers/operation.h,
-	  source/operation, source/operation/GeometryGraphOperation.cpp,
-	  source/operation/IsSimpleOp.cpp: A lot of changes: Code is
-	  brought to version 1.2 of JTS. Compilable part of Operation
-	  added.
+	* [r34] A lot of changes: Code is brought to version 1.2 of JTS.
+	  Compilable part of Operation added.
 2002-09-05 18:32  Fernando Villa <fvilla at zoo.uvm.edu>
-	* [r33] ChangeLog, Makefile.in, configure, configure.in, libtool,
-	  source/graph/index/Makefile.in, source/headers/Makefile.am,
-	  source/headers/Makefile.in, source/io/Makefile.in,
-	  source/io/markup/Makefile.in, source/test/Makefile.in,
-	  source/util/Makefile.in, tools/Makefile.in: Fixed version
-	  numbering. Whenever version numbers are bumped up the
+	* [r33] Fixed version numbering. Whenever version numbers are
+	  bumped up the
 	  change should be reflected in the AC_INIT_AUTOMAKE macro in
 	  configure.in.
 	  I've put it at 0.0.1 - should be changed as appropriate. The
@@ -20966,27 +12221,11 @@
 2002-09-03 16:04  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r32] source/test/Makefile.am: Changed reference to 'libgeom' to
-	  'libgeos'
+	* [r32] Changed reference to 'libgeom' to 'libgeos'
 2002-09-03 13:53  Fernando Villa <fvilla at zoo.uvm.edu>
-	* [r31] Makefile.am, Makefile.in, acinclude.m4, aclocal.m4,
-	  configure, configure.in, install-sh, libtool, ltmain.sh, macros,
-	  macros/Makefile.am, macros/Makefile.in, macros/geos.m4,
-	  mkinstalldirs, source/Makefile.am, source/Makefile.in,
-	  source/headers/config.h.in, source/io/Makefile.am,
-	  source/io/Makefile.in, source/io/markup/Makefile.am,
-	  source/io/markup/Makefile.in, source/test/Makefile.am,
-	  source/test/Makefile.in, source/util/Makefile.am,
-	  source/util/Makefile.in, tools, tools/Makefile.am,
-	  tools/Makefile.in, tools/geos-config.in: * Add automake/autoconf
-	  support for one-lib compilation
+	* [r31] * Add automake/autoconf support for one-lib compilation
 	  * add libtool support for shared libraries.
 	  --enable-shared={yes|no} and
@@ -21016,253 +12255,116 @@
 2002-09-01 18:08  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r30] source/algorithm/NotRepresentableException.cpp,
-	  source/algorithm/PointInRing.cpp,
-	  source/io/ParseException.cpp, source/io/WKTWriter.cpp,
-	  source/io/Writer.cpp, source/io/markup/MarkupSTL.cpp: Minor
-	  portability changes.
+	* [r30] Minor portability changes.
 2002-09-01 17:53  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r29] configure.in, source/Makefile.am,
-	  source/algorithm/Makefile.am: Changes to support algorithm
-	  directory in build structure.
+	* [r29] Changes to support algorithm directory in build structure.
 2002-09-01 17:51  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r28] source/geom/Coordinate.cpp, source/geom/CoordinateList.cpp,
-	  source/geom/Dimension.cpp, source/geom/Envelope.cpp,
-	  source/geom/IntersectionMatrix.cpp, source/geom/LineSegment.cpp,
-	  source/geom/LineString.cpp, source/geom/Location.cpp,
-	  source/geom/MultiPoint.cpp, source/geom/PrecisionModel.cpp: GNU
-	  compatibility fixes, changing __min/__max to min/max, adding
+	* [r28] GNU compatibility fixes, changing __min/__max to min/max,
+	  adding
 	  stdio.h where needed, small syntax adjustments, newlines at
 	  end of files.
 2002-08-30 18:33  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r27] COPYING: Added LGPL licence text.
+	* [r27] Added LGPL licence text.
 2002-08-30 18:30  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r26] AUTHORS, Authors: Changed name of authors file as requested
-	  by autoconf.
+	* [r26] Changed name of authors file as requested by autoconf.
 2002-08-30 18:28  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r25] autogen.sh: Removed --force-missing which did not work for
-	  my version of autoconf
+	* [r25] Removed --force-missing which did not work for my version
+	  of autoconf
 2002-08-30 18:16  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r24] ., .cvsignore, source, source/.cvsignore, source/geom,
-	  source/geom/.cvsignore, source/graph, source/graph/.cvsignore,
-	  source/graph/index, source/graph/index/.cvsignore, source/io,
-	  source/io/.cvsignore, source/io/markup,
-	  source/io/markup/.cvsignore, source/test, source/test/.cvsignore,
-	  source/util, source/util/.cvsignore: Added cvs ignore files.
+	* [r24] Added cvs ignore files.
 2002-08-30 18:15  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r23] source/test/CTS.cpp, source/test/SimpleWKTTester.cpp,
-	  source/test/WKTIn, source/test/WKTOut, source/test/XMLTester.cpp,
-	  source/test/test.xml: Added the testing files back into their new
-	  subdirectory.
+	* [r23] Added the testing files back into their new subdirectory.
-	* [r22] Authors, ChangeLog, Makefile.am, NEWS, README, autogen.sh,
-	  configure.in, source/CTS.cpp, source/Makefile.am,
-	  source/SimpleWKTTester.cpp, source/WKTIn, source/WKTOut,
-	  source/XMLTester.cpp, source/geom/Makefile.am,
-	  source/graph/Makefile.am, source/graph/index/Makefile.am,
-	  source/io/Makefile.am, source/io/markup/Makefile.am, source/test,
-	  source/test.xml, source/test/Makefile.am,
-	  source/util/Makefile.am: Added GNU autoconf support files
-	  submitted by Norman Vine. Moved test
+	* [r22] Added GNU autoconf support files submitted by Norman Vine.
+	  Moved test
 	  files to a new subdirectory.
 2002-08-30 15:52  Yury Bychkov <me at yury.ca>
-	* [r21] source/algorithm, source/algorithm/HCoordinate.cpp,
-	  source/algorithm/LineIntersector.cpp,
-	  source/algorithm/SimplePointInRing.cpp, source/geom/Geometry.cpp,
-	  source/graph/EdgeEndStar.cpp, source/graph/GeometryGraph.cpp,
-	  source/headers/graph.h, source/headers/graphindex.h,
-	  source/headers/operation.h, source/headers/platform.h,
-	  source/headers/util.h, source/io/WKTWriter.cpp: 'algorithm' is
-	  almost complete
+	* [r21] 'algorithm' is almost complete
 2002-08-22 09:23  Yury Bychkov <me at yury.ca>
-	* [r20] source/graph/index, source/graph/index/MonotoneChain.cpp,
-	  source/headers/geosAlgorithm.h, source/headers/graph.h,
-	  source/headers/util.h: 'graph/index' finished. Some .h changes.
+	* [r20] 'graph/index' finished. Some .h changes.
 2002-08-21 05:49  Yury Bychkov <me at yury.ca>
-	* [r19] source/graph/GeometryGraph.cpp, source/headers/graph.h,
-	  source/headers/graphindex.h: Some changes in 'graph'
+	* [r19] Some changes in 'graph'
 2002-08-20 21:08  Yury Bychkov <me at yury.ca>
-	* [r18] source/XMLTester.cpp, source/graph/Node.cpp,
-	  source/headers/graph.h, source/headers/io.h: Changed consts to
-	  enums
+	* [r18] Changed consts to enums
 2002-08-14 07:00  Yury Bychkov <me at yury.ca>
-	* [r17] Assert.cpp, AssertionFailedException.cpp, CTS.cpp,
-	  Coordinate.cpp, CoordinateList.cpp, Depth.cpp, Dimension.cpp,
-	  Envelope.cpp, Geometry.cpp, GeometryCollection.cpp,
-	  GeometryCollectionIterator.cpp, GeometryFactory.cpp,
-	  IntersectionMatrix.cpp, Label.cpp, LineSegment.cpp,
-	  LineString.cpp, LinearRing.cpp, Location.cpp, MarkupSTL.cpp,
-	  MarkupSTL.h, MultiLineString.cpp, MultiPoint.cpp,
-	  MultiPolygon.cpp, ParseException.cpp, Point.cpp, Polygon.cpp,
-	  Position.cpp, PrecisionModel.cpp, SimpleWKTTester.cpp,
-	  StringTokenizer.cpp, TopologyLocation.cpp, WKTIn, WKTOut,
-	  WKTReader.cpp, WKTWriter.cpp, Writer.cpp, XMLTester.cpp, geom.h,
-	  graph.h, io.h, operation.h, platform.h, source, source/CTS.cpp,
-	  source/XMLTester.cpp, source/geom, source/geom/Coordinate.cpp,
-	  source/geom/LineString.cpp, source/geom/LinearRing.cpp,
-	  source/geom/MultiPoint.cpp, source/geom/MultiPolygon.cpp,
-	  source/geom/PrecisionModel.cpp, source/graph,
-	  source/graph/EdgeRing.cpp, source/graph/GraphComponent.cpp,
-	  source/graph/NodeFactory.cpp, source/graph/NodeMap.cpp,
-	  source/graph/Position.cpp, source/graph/Quadrant.cpp,
-	  source/graph/TopologyLocation.cpp, source/headers,
-	  source/headers/io.h, source/headers/operation.h,
-	  source/headers/platform.h, source/headers/util.h, source/io,
-	  source/io/Writer.cpp, source/io/markup,
-	  source/io/markup/MarkupSTL.cpp, source/io/markup/MarkupSTL.h,
-	  source/test.xml, source/util, source/util/Assert.cpp,
-	  source/util/AssertionFailedException.cpp, test.xml, util.h: New
-	  structure of source.
+	* [r17] New structure of source.
 2002-07-11 07:57  Yury Bychkov <me at yury.ca>
-	* [r16] Assert.cpp, AssertionFailedException.cpp, Depth.cpp,
-	  Geometry.cpp, GeometryCollection.cpp, GeometryFactory.cpp,
-	  Label.cpp, Position.cpp, TopologyLocation.cpp, WKTReader.cpp,
-	  WKTWriter.cpp, XMLTester.cpp, graph.h, operation.h, test.xml,
-	  util.h: Assert and some graph classes
+	* [r16] Assert and some graph classes
 2002-07-03 05:24  Yury Bychkov <me at yury.ca>
-	* [r15] MarkupSTL.cpp, MarkupSTL.h, XMLTester.cpp: started XML
-	  tester
+	* [r15] started XML tester
 2002-07-02 06:41  Yury Bychkov <me at yury.ca>
-	* [r14] CTS.cpp, GeometryCollection.cpp,
-	  MultiPolygon.cpp, Polygon.cpp, SimpleWKTTester.cpp, WKTIn,
-	  WKTOut, WKTReader.cpp, WKTWriter.cpp, geom.h, io.h: 'io' and
-	  SimpleTester done
+	* [r14] 'io' and SimpleTester done
 2002-06-27 02:50  Yury Bychkov <me at yury.ca>
-	* [r13] CTS.cpp, StringTokenizer.cpp, WKTWriter.cpp, Writer.cpp,
-	  io.h: 'io' is almost done
+	* [r13] 'io' is almost done
 2002-06-26 09:10  Yury Bychkov <me at yury.ca>
-	* [r12] CTS.cpp, GeometryCollection.cpp, ParseException.cpp,
-	  Polygon.cpp, StringTokenizer.cpp, WKTReader.cpp, io.h: Some 'io'
-	  classes done.
+	* [r12] Some 'io' classes done.
 2002-06-21 07:13  Yury Bychkov <me at yury.ca>
-	* [r11] CTS.cpp, CoordinateList.cpp, Geometry.cpp,
-	  GeometryCollection.cpp, LineString.cpp, Point.cpp, Polygon.cpp,
-	  geom.h: 'geos': first pass done. Some external dependencies and
+	* [r11] 'geos': first pass done. Some external dependencies and
 	  polishing left.
 2002-06-20 08:58  Yury Bychkov <me at yury.ca>
-	* [r10] CTS.cpp, Geometry.cpp, GeometryCollection.cpp,
-	  GeometryCollectionIterator.cpp, GeometryFactory.cpp, geom.h: Only
-	  Geometry.java left
+	* [r10] Only Geometry.java left
 2002-06-19 06:29  Yury Bychkov <me at yury.ca>
-	* [r9] CTS.cpp, CoordinateList.cpp, Geometry.cpp,
-	  GeometryCollection.cpp, LineString.cpp, LinearRing.cpp,
-	  MultiLineString.cpp, MultiPoint.cpp, MultiPolygon.cpp, Point.cpp,
-	  Polygon.cpp, geom.h: 'geom' mostly done.
+	* [r9] 'geom' mostly done.
 2002-06-14 07:46  Yury Bychkov <me at yury.ca>
-	* [r8] CTS.cpp, GeometryCollection.cpp, GeometryFactory.cpp,
-	  Polygon.cpp, geom.h: 'geom' almost done
+	* [r8] 'geom' almost done
 2002-06-12 01:47  Yury Bychkov <me at yury.ca>
-	* [r7] CoordinateList.cpp, LineString.cpp, geom.h: LineString is
-	  99% finished
+	* [r7] LineString is 99% finished
 2002-06-11 23:43  Yury Bychkov <me at yury.ca>
-	* [r6] CTS.cpp, Coordinate.cpp, CoordinateList.cpp, Dimension.cpp,
-	  IntersectionMatrix.cpp, LineSegment.cpp, LineString.cpp,
-	  LinearRing.cpp, Location.cpp, Point.cpp, PrecisionModel.cpp,
-	  geom.h, operation.h, platform.h: 'geom' package 70% done
+	* [r6] 'geom' package 70% done
 2002-06-07 17:47  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r2] CTS.cpp, Coordinate.cpp, CoordinateList.cpp, Dimension.cpp,
-	  Envelope.cpp, LineSegment.cpp, Location.cpp, geom.h, platform.h:
-	  Initial revision
+	* [r2] Initial revision
 2002-06-07 17:47  cvs
-	* [r1] .: New repository initialized by cvs2svn.
+	* [r1] New repository initialized by cvs2svn.
More information about the geos-commits mailing list
