[geos-commits] r3119 - in trunk/tests/xmltester/tests: . rt
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Nov 29 04:32:08 EST 2010
Author: strk
Date: 2010-11-29 01:32:08 -0800 (Mon, 29 Nov 2010)
New Revision: 3119
Added:
   trunk/tests/xmltester/tests/rt/
   trunk/tests/xmltester/tests/rt/TestSameDirection.xml
stub tet for SameDirection predicate
Added: trunk/tests/xmltester/tests/rt/TestSameDirection.xml
--- trunk/tests/xmltester/tests/rt/TestSameDirection.xml	                        (rev 0)
+++ trunk/tests/xmltester/tests/rt/TestSameDirection.xml	2010-11-29 09:32:08 UTC (rev 3119)
@@ -0,0 +1,123 @@
+<run>
+  <precisionModel type="FLOATING" />
+   <case>
+      <desc>equal lines</desc>
+      <a>
+LINESTRING(0 0, 10 0)
+      </a>
+      <b>
+      </b>
+      <test>
+         <op name="sameDirection" arg1="A" arg2="B">true</op>
+      </test>
+   </case>
+   <case>
+      <desc>disjoint lines</desc>
+      <a>
+      </a>
+      <b>
+LINESTRING(0 1, 10 1)
+      </b>
+      <test>
+         <op name="sameDirection" arg1="A" arg2="B">false</op>
+      </test>
+   </case>
+   <case>
+      <desc>overlapping lines, sharing vertices</desc>
+      <a>
+LINESTRING(0 0, 5 0, 10 0)
+      </a>
+      <b>
+LINESTRING(5 0, 10 0, 15 0)
+      </b>
+      <test>
+      </test>
+   </case>
+   <case>
+      <desc>overlapping lines, no shared vertices</desc>
+      <a>
+      </a>
+      <b>
+LINESTRING(5 0, 15 0)
+      </b>
+      <test>
+      </test>
+   </case>
+   <case>
+      <desc>equal lines, opposite direction</desc>
+      <a>
+      </a>
+      <b>
+LINESTRING(10 0, 0 0)
+      </b>
+      <test>
+      </test>
+   </case>
+   <case>
+      <desc>overlapping lines, sharing vertices, opposite direction</desc>
+      <a>
+      </a>
+      <b>
+LINESTRING(15 0, 10 0, 5 0)
+      </b>
+      <test>
+      </test>
+   </case>
+   <case>
+      <desc>overlapping lines, no shared vertices opposite direction</desc>
+      <a>
+      </a>
+      <b>
+LINESTRING(15 0, 5 0)
+      </b>
+      <test>
+      </test>
+   </case>
+   <case>
+      <desc>multiple overlaps all same direction</desc>
+      <a>
+LINESTRING(0 0, 30 0)
+      </a>
+      <b>
+LINESTRING(0 0, 10 0, 10 10, 20 10, 20 0, 30 0)
+      </b>
+      <test>
+      </test>
+   </case>
+   <case>
+      <desc>multiple overlaps mixed direction</desc>
+      <a>
+      </a>
+      <b>
+LINESTRING(0 0, 10 0, 10 10, 30 10, 30 0, 20 0)
+      </b>
+      <test>
+      </test>
+   </case>
+ <!-- TODO: multipart geoms -->
+</run>
More information about the geos-commits mailing list
