[geos-commits] r3290 - in trunk/tests/xmltester: . tests tests/ticket
svn_geos at osgeo.org svn_geos at osgeo.org
Wed Apr 20 11:55:53 EDT 2011
Author: strk
Date: 2011-04-20 08:55:53 -0700 (Wed, 20 Apr 2011)
New Revision: 3290
Added:
   trunk/tests/xmltester/tests/ticket/
   trunk/tests/xmltester/tests/ticket/bug176.xml
   trunk/tests/xmltester/tests/ticket/bug188.xml
   trunk/tests/xmltester/tests/ticket/bug244.xml
   trunk/tests/xmltester/tests/ticket/bug275.xml
   trunk/tests/xmltester/tests/ticket/bug344.xml
   trunk/tests/xmltester/tests/ticket/bug350.xml
   trunk/tests/xmltester/tests/ticket/bug356.xml
   trunk/tests/xmltester/tests/ticket/bug358.xml
   trunk/tests/xmltester/tests/ticket/bug360.xml
   trunk/tests/xmltester/tests/ticket/bug366.xml
   trunk/tests/xmltester/tests/ticket/bug398.xml
Removed:
   trunk/tests/xmltester/tests/bug176.xml
   trunk/tests/xmltester/tests/bug188.xml
   trunk/tests/xmltester/tests/bug244.xml
   trunk/tests/xmltester/tests/bug275.xml
   trunk/tests/xmltester/tests/bug344.xml
   trunk/tests/xmltester/tests/bug350.xml
   trunk/tests/xmltester/tests/bug356.xml
   trunk/tests/xmltester/tests/bug358.xml
   trunk/tests/xmltester/tests/bug360.xml
   trunk/tests/xmltester/tests/bug366.xml
   trunk/tests/xmltester/tests/bug398.xml
   trunk/tests/xmltester/Makefile.am
Move per-ticket testcases under their own directory
Modified: trunk/tests/xmltester/Makefile.am
--- trunk/tests/xmltester/Makefile.am	2011-04-20 15:42:03 UTC (rev 3289)
+++ trunk/tests/xmltester/Makefile.am	2011-04-20 15:55:53 UTC (rev 3290)
@@ -21,15 +21,15 @@
 	$(srcdir)/tests/robustness.xml \
 	$(srcdir)/tests/buffer.xml \
 	$(srcdir)/tests/singlesidedbuffer.xml \
-	$(srcdir)/tests/bug176.xml \
-	$(srcdir)/tests/bug188.xml \
-	$(srcdir)/tests/bug244.xml \
-	$(srcdir)/tests/bug275.xml \
-	$(srcdir)/tests/bug356.xml \
-	$(srcdir)/tests/bug358.xml \
-	$(srcdir)/tests/bug360.xml \
-	$(srcdir)/tests/bug366.xml \
-	$(srcdir)/tests/bug398.xml \
+	$(srcdir)/tests/ticket/bug176.xml \
+	$(srcdir)/tests/ticket/bug188.xml \
+	$(srcdir)/tests/ticket/bug244.xml \
+	$(srcdir)/tests/ticket/bug275.xml \
+	$(srcdir)/tests/ticket/bug356.xml \
+	$(srcdir)/tests/ticket/bug358.xml \
+	$(srcdir)/tests/ticket/bug360.xml \
+	$(srcdir)/tests/ticket/bug366.xml \
+	$(srcdir)/tests/ticket/bug398.xml \
 	$(srcdir)/tests/general/TestBoundary.xml \
 	$(srcdir)/tests/general/TestBuffer.xml \
 	$(srcdir)/tests/general/TestBufferMitredJoin.xml \
Deleted: trunk/tests/xmltester/tests/bug176.xml
--- trunk/tests/xmltester/tests/bug176.xml	2011-04-20 15:42:03 UTC (rev 3289)
+++ trunk/tests/xmltester/tests/bug176.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -1,40 +0,0 @@
-<run>
-  <desc>
-  http://trac.osgeo.org/geos/ticket/176
-  </desc>
-  <precisionModel type="FLOATING" />
-  <resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
-<case>
-  <desc>
-	Polygon 1
-  </desc>
-  <a>
-POLYGON ((413.3999999999999773 243.0999999999999943, 607.2999999999999545 244.1999999999999886, 607.0000000000000000 294.8999999999999773, 697.8999999999999773 295.3999999999999773, 699.2000000000000455 241.8000000000000114, 416.8999999999999773 240.9000000000000057, 416.6999999999999886 162.3000000000000114, 413.1999999999999886 162.3000000000000114, 413.3999999999999773 243.0999999999999943))
-  </a>
-<test>
-  <op name='buffer' arg1='A' arg2='-2.0'>
-POLYGON ((609.1722610376851890 243.5129929302678704, 609.2638333893902427 243.8213729820575395, 609.2999649881396635 244.2118341123558309, 609.0118040315680901 292.9110357729544489, 695.9481804295313623 293.3892336629322699, 697.1510625643339836 243.7934779510754595, 609.1722610376851890 243.5129929302678704))
-  </op>
-</test>
-</case>
-<case>
-  <desc>
-	Polygon 2
-  </desc>
-  <a>
-POLYGON ((513.3999999999999773 343.1000000000000227, 707.2999999999999545 344.1999999999999886, 707.0000000000000000 394.8999999999999773, 797.8999999999999773 395.3999999999999773, 799.2000000000000455 341.8000000000000114, 516.8999999999999773 340.8999999999999773, 516.7000000000000455 262.3000000000000114, 513.2000000000000455 262.3000000000000114, 513.3999999999999773 343.1000000000000227))
-  </a>
-<test>
-POLYGON ((709.1722610376851890 343.5129929302678988, 709.2638333893902427 343.8213729820575963, 709.2999649881396635 344.2118341123558594, 709.0118040315680901 392.9110357729544489, 795.9481804295313623 393.3892336629322699, 797.1510625643339836 343.7934779510754879, 709.1722610376851890 343.5129929302678988))
-  </op>
-</test>
-</case>
-</run>
Deleted: trunk/tests/xmltester/tests/bug188.xml
--- trunk/tests/xmltester/tests/bug188.xml	2011-04-20 15:42:03 UTC (rev 3289)
+++ trunk/tests/xmltester/tests/bug188.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -1,22 +0,0 @@
-<run>
-  <desc>
-http://trac.osgeo.org/geos/ticket/188
-  </desc>
-<case>
-  <desc>
-  Caused crash in RightmostEdgeFinder creating BufferSubgraphs
-  </desc>
-  <a>
-0103000000010000000B000000713D0AD7C3F9C3403D0AD7A3E8B01441295C8FC255FBC340C3F5285C0BB1144153BB8CF8AD01C44092DD2F29FEB0144148E17A14AE01C4408FC2F528FEB0144148E17A146E01C440A4703D0AF0B014411F85EB517801C44085EB51B8EFB014419A999999B9FFC34066666666CBB0144133333333F3FCC340CDCCCCCCC9B01441295C8FC2F5FBC3408FC2F528CAB014413D0AD7A3F0FBC340CDCCCCCCC9B01441713D0AD7C3F9C3403D0AD7A3E8B01441
-  </a>
-<test>
-  <op name='buffer' arg1='A' arg2='-5.0000000000000004e-006' arg3='3'>
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
-  </op>
-</test>
-</case>
-</run>
Deleted: trunk/tests/xmltester/tests/bug244.xml
--- trunk/tests/xmltester/tests/bug244.xml	2011-04-20 15:42:03 UTC (rev 3289)
+++ trunk/tests/xmltester/tests/bug244.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -1,23 +0,0 @@
-<run>
-  <desc>
-http://trac.osgeo.org/geos/ticket/244
-  </desc>
-<case>
-  <desc>
-  </desc>
-  <a>
- MULTIPOLYGON(((144.520538330078 -1.12083339691162,144.516387939453 -1.12083339691162,144.514434814453 -1.11611104011536,144.514984130859 -1.10305547714233,144.517211914062 -1.09833335876465,144.521362304688 -1.09972214698792,144.522491455078 -1.10527777671814,144.523315429688 -1.11138892173767,144.522491455078 -1.11611104011536,144.520538330078 -1.12083339691162)),((149.731903076172 -1.60333347320557,149.715515136719 -1.57861113548279,149.7099609375 -1.57027792930603,149.703308105469 -1.56361126899719,149.699127197266 -1.56083345413208,149.681915283203 -1.55722236633301,149.680541992188 -1.56277775764465,149.681915283203 -1.57527780532837,149.681365966797 -1.5813889503479,149.678588867188 -1.58555555343628,149.673034667969 -1.58694458007812,149.663299560547 -1.58277773857117,149.659423828125 -1.58000016212463,149.558013916016 -1.50055575370789,149.533325195312 -1.469722032547,149.530548095703 -1.46555542945862,149.527770996094 -1.45444440841675,149.528594970703 -1.448333263
 39722,149.542755126953 -1.41472220420837,149.544982910156 -1.41000008583069,149.564147949219 -1.37027788162231,149.579956054688 -1.35527777671814,149.622467041016 -1.35944437980652,149.627166748047 -1.36138892173767,149.663299560547 -1.38666677474976,149.710784912109 -1.42166662216187,149.716918945312 -1.42916655540466,149.719696044922 -1.43333315849304,149.790252685547 -1.57666683197021,149.790802001953 -1.5813889503479,149.731903076172 -1.60333347320557)),((144.517761230469 -1.39833331108093,144.506103515625 -1.38944435119629,144.503326416016 -1.38555550575256,144.505554199219 -1.38055562973022,144.516387939453 -1.38194441795349,144.519989013672 -1.38555550575256,144.521911621094 -1.39555549621582,144.517761230469 -1.39833331108093)),((142.818298339844 -1.73333311080933,142.813598632812 -1.73277759552002,142.812194824219 -1.72722220420837,142.812744140625 -1.72111105918884,142.818298339844 -1.69972205162048,142.821075439453 -1.69583320617676,142.832183837891 -1.69361114501
 953,142.863006591797 -1.69444441795349,142.866363525391 -1.69777774810791,142.866912841797 -1.70944428443909,142.864410400391 -1.71361112594604,142.859405517578 -1.71555542945862,142.852752685547 -1.70861101150513,142.847198486328 -1.70722222328186,142.841644287109 -1.70861101150513,142.837463378906 -1.71138882637024,142.818298339844 -1.73333311080933)),((147.391937255859 -1.96083331108093,147.399993896484 -1.96638870239258,147.430816650391 -1.9902777671814,147.434417724609 -1.99361109733582,147.44580078125 -2.00944471359253,147.448028564453 -2.01416683197021,147.447204589844 -2.0188889503479,147.439697265625 -2.06083345413208,147.437744140625 -2.06555557250977,147.426086425781 -2.06777811050415,147.275268554688 -2.1211109161377,147.255554199219 -2.14916658401489,147.239135742188 -2.16694450378418,147.22802734375 -2.17638874053955,147.212188720703 -2.18805551528931,147.207458496094 -2.19027757644653,147.201904296875 -2.19166660308838,146.980529785156 -2.1991662979126,146.893
 035888672 -2.18944406509399,146.8388671875 -2.18194437026978,146.798309326172 -2.16888904571533,146.793579101562 -2.16694450378418,146.726348876953 -2.16083335876465,146.571624755859 -2.23472213745117,146.568023681641 -2.23666667938232,146.563293457031 -2.23472213745117,146.5283203125 -2.20111131668091,146.524993896484 -2.19083309173584,146.518035888672 -2.1497220993042,146.518859863281 -2.14361143112183,146.578308105469 -2.00194454193115,146.580535888672 -1.99722218513489,146.583862304688 -1.99361109733582,146.638580322266 -1.97861099243164,146.844970703125 -1.95055556297302,146.857177734375 -1.94916653633118,146.869689941406 -1.94916653633118,147.093566894531 -1.96638870239258,147.099975585938 -1.96694445610046,147.118286132812 -1.96888875961304,147.164428710938 -1.98333311080933,147.203308105469 -2.003333568573,147.300811767578 -2.02527761459351,147.417755126953 -2.05055570602417,147.419982910156 -2.04583358764648,147.422760009766 -2.03472232818604,147.422760009766 -2.029
 16669845581,147.420532226562 -2.01083374023438,147.418579101562 -2.00583362579346,147.391937255859 -1.96083331108093)),((147.756927490234 -2.35249996185303,147.766662597656 -2.32388925552368,147.795532226562 -2.26500034332275,147.815246582031 -2.24361133575439,147.832458496094 -2.24555540084839,147.877746582031 -2.28944444656372,147.879119873047 -2.29361152648926,147.856353759766 -2.3313889503479,147.848297119141 -2.33666658401489,147.829132080078 -2.34555530548096,147.824127197266 -2.34777784347534,147.81884765625 -2.34916639328003,147.812469482422 -2.34972190856934,147.756927490234 -2.35249996185303)),((150.367736816406 -2.68666648864746,150.356353759766 -2.66805553436279,150.347473144531 -2.66333341598511,150.341064453125 -2.66249990463257,150.273315429688 -2.67277765274048,150.257476806641 -2.6777777671814,150.242462158203 -2.68305540084839,150.190521240234 -2.68583297729492,150.184143066406 -2.68527746200562,150.109405517578 -2.625,149.972473144531 -2.50111150741577,149
 .965789794922 -2.4941668510437,149.949127197266 -2.47638845443726,149.948577880859 -2.47166633605957,149.951354980469 -2.46749973297119,149.960784912109 -2.46000003814697,150.079956054688 -2.41416645050049,150.189697265625 -2.37722206115723,150.206085205078 -2.37444448471069,150.216369628906 -2.37777757644653,150.248016357422 -2.39000034332275,150.417205810547 -2.46055555343628,150.443298339844 -2.47583293914795,150.446075439453 -2.47972202301025,150.467193603516 -2.54472255706787,150.468017578125 -2.55777788162231,150.459686279297 -2.64833354949951,150.458312988281 -2.6536111831665,150.448852539062 -2.66472196578979,150.443298339844 -2.66611099243164,150.41943359375 -2.66249990463257,150.406921386719 -2.66388893127441,150.4013671875 -2.6652774810791,150.371887207031 -2.68388891220093,150.367736816406 -2.68666648864746)),((152.659423828125 -3.84277772903442,152.670837402344 -3.85989284515381,152.701080322266 -3.88305521011353,152.739685058594 -3.89611101150513,152.7697143554
 69 -3.90027761459351,152.919128417969 -4.0041675567627,152.989685058594 -4.07583332061768,153.006927490234 -4.09361171722412,153.118560791016 -4.23916625976562,153.12939453125 -4.25555610656738,153.131622314453 -4.26027870178223,153.134429931641 -4.27138900756836,153.132171630859 -4.37861061096191,153.130798339844 -4.39083385467529,153.128021240234 -4.39500045776367,153.121337890625 -4.40194416046143,153.108856201172 -4.40999984741211,153.092468261719 -4.42083358764648,153.080810546875 -4.43000030517578,153.066375732422 -4.44277763366699,153.063018798828 -4.44638824462891,153.0546875 -4.45861148834229,153.04052734375 -4.48527717590332,153.039154052734 -4.49749946594238,153.039703369141 -4.50361156463623,153.041076660156 -4.5091667175293,153.043304443359 -4.51388931274414,153.046630859375 -4.51722240447998,153.059692382812 -4.52555561065674,153.066375732422 -4.53222274780273,153.077453613281 -4.54861068725586,153.079406738281 -4.58916664123535,153.077453613281 -4.600555419921
 88,152.980255126953 -4.7605562210083,152.974670410156 -4.76666641235352,152.910247802734 -4.82333374023438,152.891662597656 -4.82250022888184,152.743560791016 -4.67305564880371,152.735504150391 -4.66083335876465,152.733306884766 -4.6561107635498,152.693023681641 -4.55833339691162,152.681365966797 -4.5222225189209,152.664978027344 -4.4688892364502,152.662750244141 -4.4572229385376,152.666381835938 -4.45388889312744,152.678588867188 -4.44555473327637,152.681365966797 -4.44138813018799,152.692199707031 -4.39361190795898,152.69775390625 -4.36499977111816,152.69775390625 -4.35805511474609,152.694427490234 -4.19138813018799,152.693572998047 -4.18527698516846,152.691650390625 -4.18055534362793,152.603302001953 -4.00611114501953,152.581909179688 -3.96583318710327,152.538726806641 -3.90009546279907,152.512176513672 -3.8687310218811,152.491577148438 -3.85225462913513,152.374969482422 -3.7277774810791,152.359954833984 -3.70472240447998,152.357177734375 -3.69361114501953,152.35662841796
 9 -3.6875,152.358001708984 -3.66166639328003,152.355224609375 -3.65055561065674,152.349700927734 -3.64249992370605,152.289428710938 -3.57944440841675,152.282470703125 -3.57277774810791,152.190521240234 -3.50888919830322,152.182464599609 -3.50361156463623,152.156372070312 -3.48861122131348,152.151641845703 -3.48638868331909,152.146087646484 -3.4850001335144,152.136657714844 -3.48916673660278,152.131072998047 -3.49055576324463,152.124969482422 -3.49000024795532,151.984405517578 -3.46444463729858,151.956359863281 -3.45833349227905,151.934967041016 -3.44555521011353,151.758331298828 -3.32444477081299,151.708862304688 -3.28055572509766,151.688293457031 -3.25305557250977,151.620513916016 -3.17722225189209,151.6171875 -3.17388916015625,151.608306884766 -3.16916656494141,151.574676513672 -3.1594443321228,151.532745361328 -3.14499998092651,151.493011474609 -3.13000011444092,151.483581542969 -3.12583303451538,151.462188720703 -3.11305570602417,151.455535888672 -3.1061110496521,151.452
 758789062 -3.10194444656372,151.450531005859 -3.09722232818604,151.449981689453 -3.08416652679443,151.448577880859 -3.07888889312744,151.44384765625 -3.06972217559814,151.438293457031 -3.06361103057861,151.417205810547 -3.05055570602417,151.369689941406 -3.02250003814697,151.281372070312 -2.97416639328003,151.237457275391 -2.95361137390137,151.214965820312 -2.94194412231445,151.150543212891 -2.89527797698975,151.122467041016 -2.86861085891724,151.119689941406 -2.86444473266602,151.113586425781 -2.8502779006958,151.110778808594 -2.84611082077026,151.106628417969 -2.84333324432373,151.004425048828 -2.78916692733765,150.999694824219 -2.78722238540649,150.930541992188 -2.76861095428467,150.923583984375 -2.76861095428467,150.903045654297 -2.77138900756836,150.876342773438 -2.77611112594604,150.861907958984 -2.78249979019165,150.832458496094 -2.78722238540649,150.819427490234 -2.7877779006958,150.754425048828 -2.77083349227905,150.750274658203 -2.76805543899536,150.729675292969 -2
 .74055576324463,150.730529785156 -2.7344446182251,150.733856201172 -2.7311110496521,150.747467041016 -2.71749973297119,150.752471923828 -2.71527767181396,150.763305664062 -2.7180552482605,150.824401855469 -2.71527767181396,150.874969482422 -2.71250009536743,150.88720703125 -2.71111106872559,150.891357421875 -2.70833349227905,150.894989013672 -2.70499992370605,150.896942138672 -2.70027780532837,150.885650634766 -2.6851110458374,150.884307861328 -2.67811107635498,150.876983642578 -2.65594434738159,150.875640869141 -2.65294456481934,150.873641967773 -2.65094447135925,150.867797851562 -2.64844417572021,150.861633300781 -2.64977788925171,150.856292724609 -2.65261125564575,150.853134155273 -2.65344452857971,150.838012695312 -2.64277791976929,150.831909179688 -2.64222240447998,150.822204589844 -2.6380558013916,150.792755126953 -2.61666631698608,150.805816650391 -2.56666660308838,150.807739257812 -2.56333351135254,150.811370849609 -2.55999994277954,150.817474365234 -2.559166431427,1
 50.834686279297 -2.57083368301392,150.838012695312 -2.57416677474976,150.906524658203 -2.63594436645508,150.964691162109 -2.68722200393677,150.968841552734 -2.69000005722046,151.086639404297 -2.75027799606323,151.190246582031 -2.82611131668091,151.280822753906 -2.87083339691162,151.311370849609 -2.86999988555908,151.419128417969 -2.89805555343628,151.427185058594 -2.9036111831665,151.464416503906 -2.93499994277954,151.598022460938 -3.02750015258789,151.641937255859 -3.04805564880371,151.717742919922 -3.11555576324463,151.72607421875 -3.12805557250977,151.815246582031 -3.19777774810791,151.820526123047 -3.1991662979126,151.825531005859 -3.1972222328186,151.833587646484 -3.19166660308838,151.855529785156 -3.18611097335815,151.861907958984 -3.18694448471069,151.921905517578 -3.20333337783813,151.948852539062 -3.21083354949951,152.055816650391 -3.24777793884277,152.054412841797 -3.26000022888184,152.054412841797 -3.27361106872559,152.057739257812 -3.28388929367065,152.1647033691
 41 -3.41111087799072,152.204406738281 -3.45444440841675,152.210510253906 -3.46055555343628,152.238006591797 -3.47833299636841,152.252471923828 -3.4844446182251,152.277191162109 -3.49472236633301,152.306640625 -3.50638914108276,152.327178955078 -3.51999998092651,152.355224609375 -3.54000043869019,152.361907958984 -3.54666709899902,152.367462158203 -3.55499982833862,152.392211914062 -3.59861087799072,152.411926269531 -3.63361120223999,152.488006591797 -3.64916658401489,152.493011474609 -3.64861106872559,152.496917724609 -3.65138864517212,152.503051757812 -3.6588888168335,152.511383056641 -3.67111110687256,152.553314208984 -3.74583339691162,152.556640625 -3.756667137146,152.555816650391 -3.76944446563721,152.549713134766 -3.78388929367065,152.546356201172 -3.79416704177856,152.549133300781 -3.79833364486694,152.573852539062 -3.8216667175293,152.577758789062 -3.82444477081299,152.582733154297 -3.82638883590698,152.603302001953 -3.83305549621582,152.659423828125 -3.84277772903442
 )),((149.6640625 -10.3398141860962,149.639434814453 -10.3413887023926,149.572204589844 -10.3413887023926,149.566925048828 -10.3413887023926,149.536651611328 -10.361665725708,149.335784912109 -10.307222366333,149.224975585938 -10.2761116027832,149.186645507812 -10.2600002288818,149.176361083984 -10.2563896179199,149.161102294922 -10.2511119842529,149.139984130859 -10.2449989318848,149.093292236328 -10.2341651916504,149.049407958984 -10.2424983978271,149.03857421875 -10.2449989318848,148.993835449219 -10.2605571746826,148.981628417969 -10.268611907959,148.934967041016 -10.2672233581543,148.79443359375 -10.2391662597656,148.723297119141 -10.1869449615479,148.680267333984 -10.1494445800781,148.677459716797 -10.1533336639404,148.642486572266 -10.1863880157471,148.637481689453 -10.1883344650269,148.468292236328 -10.2038879394531,148.462738037109 -10.2038879394531,148.4033203125 -10.2005558013916,148.372467041016 -10.1919441223145,148.3369140625 -10.1797218322754,148.332733154297 -
 10.176944732666,148.327178955078 -10.1688899993896,148.322479248047 -10.1599998474121,148.314971923828 -10.1405563354492,148.312194824219 -10.1363887786865,148.3046875 -10.130277633667,148.157562255859 -10.0737085342407,148.154418945312 -10.0791664123535,148.150543212891 -10.0952777862549,148.148315429688 -10.0999984741211,148.115509033203 -10.1216659545898,148.10302734375 -10.1297206878662,148.0888671875 -10.1358337402344,148.083312988281 -10.1372222900391,148.055236816406 -10.1433334350586,147.999694824219 -10.1519451141357,147.952453613281 -10.1458339691162,147.940795898438 -10.1211109161377,147.923034667969 -10.0980548858643,147.872192382812 -10.0475006103516,147.86328125 -10.0427780151367,147.857727050781 -10.0427780151367,147.781097412109 -10.0508327484131,147.775543212891 -10.0522232055664,147.766082763672 -10.0561103820801,147.619964599609 -9.9908332824707,147.612457275391 -9.98472213745117,147.601348876953 -9.97527694702148,147.574127197266 -9.94833374023438,147.510
 25390625 -9.87861061096191,147.504150390625 -9.87138748168945,147.501373291016 -9.86722183227539,147.499389648438 -9.85583305358887,147.501373291016 -9.85111045837402,147.503601074219 -9.83944320678711,147.503601074219 -9.8125,147.499389648438 -9.79638862609863,147.490509033203 -9.77138900756836,147.48828125 -9.76666641235352,147.386932373047 -9.63555717468262,147.316375732422 -9.55527877807617,147.296600341797 -9.53412532806396,147.248565673828 -9.50583457946777,147.12939453125 -9.44361114501953,147.080001831055 -9.43415546417236,147.099975585938 -9.44972229003906,147.102752685547 -9.45388793945312,147.102752685547 -9.48361015319824,147.101348876953 -9.48888778686523,147.09912109375 -9.49110984802246,147.094421386719 -9.49305534362793,147.0888671875 -9.49166679382324,147.062194824219 -9.47333335876465,147.055236816406 -9.46666526794434,147.008026123047 -9.39833450317383,147.001922607422 -9.3841667175293,146.926635742188 -9.28277778625488,146.91748046875 -9.28750038146973,14
 6.911376953125 -9.28694534301758,146.901092529297 -9.28333282470703,146.896942138672 -9.28083419799805,146.893585205078 -9.27722358703613,146.891662597656 -9.27250099182129,146.888885498047 -9.1833324432373,146.905044555664 -9.13727760314941,146.905868530273 -9.13410949707031,146.907043457031 -9.13127708435059,146.909881591797 -9.13077735900879,146.915374755859 -9.13361072540283,146.918548583984 -9.13444423675537,146.969696044922 -9.09138870239258,146.977172851562 -9.07444381713867,146.981353759766 -9.05944442749023,146.981048583984 -9.05097389221191,146.974395751953 -9.03388977050781,146.972473144531 -9.02916717529297,146.969116210938 -9.02833366394043,146.951080322266 -9.03388977050781,146.94580078125 -9.04194450378418,146.944427490234 -9.04722213745117,146.94580078125 -9.05277824401855,146.951904296875 -9.06027793884277,146.954681396484 -9.06833267211914,146.953308105469 -9.07361030578613,146.925262451172 -9.09999847412109,146.91748046875 -9.10610961914062,146.84460449218
 8 -9.09577751159668,146.840911865234 -9.09627723693848,146.83757019043 -9.09544467926025,146.630523681641 -9.0302791595459,146.621612548828 -9.02555656433105,146.586639404297 -8.99916648864746,146.578308105469 -8.9869441986084,146.55859375 -8.9416675567627,146.545532226562 -8.90250015258789,146.546081542969 -8.89777946472168,146.555816650391 -8.85972213745117,146.559143066406 -8.85638809204102,146.567474365234 -8.8075008392334,146.541351318359 -8.76361274719238,146.517486572266 -8.72500038146973,146.441345214844 -8.62472152709961,146.431915283203 -8.61388778686523,146.419982910156 -8.60499954223633,146.403594970703 -8.59444427490234,146.379104614258 -8.58470821380615,146.372192382812 -8.57805633544922,146.351623535156 -8.55777740478516,146.318572998047 -8.50889015197754,146.275543212891 -8.44305610656738,146.269439697266 -8.42888832092285,146.268035888672 -8.42361068725586,146.263305664062 -8.38750076293945,146.264709472656 -8.37527656555176,146.264709472656 -8.3686103820800
 8,146.262481689453 -8.35972213745117,146.243286132812 -8.29472351074219,146.238555908203 -8.28583335876465,146.229675292969 -8.27444458007812,146.218566894531 -8.26472282409668,146.111083984375 -8.16388893127441,146.110229492188 -8.13472366333008,146.089691162109 -8.09111022949219,145.998016357422 -8.05444526672363,145.987731933594 -8.05111122131348,145.930816650391 -8.04111099243164,145.918579101562 -8.03972244262695,145.898590087891 -8.03888893127441,145.880798339844 -8.04166793823242,145.835510253906 -8.02805709838867,145.797760009766 -8.00777816772461,145.786376953125 -7.99888896942139,145.718292236328 -7.96777820587158,145.649993896484 -7.9597225189209,145.630798339844 -7.94472217559814,145.616912841797 -7.93777751922607,145.528045654297 -7.93777751922607,145.502471923828 -7.9399995803833,145.484130859375 -7.94861030578613,145.465515136719 -7.95083332061768,145.443572998047 -7.94944381713867,145.432739257812 -7.94805526733398,145.422485351562 -7.94472217559814,145.24411
 0107422 -7.86861038208008,145.19807434082 -7.82955169677734,145.182723999023 -7.81383991241455,145.168106079102 -7.81822443008423,145.162994384766 -7.82626342773438,145.164459228516 -7.83649444580078,145.161529541016 -7.84489870071411,145.155685424805 -7.84599494934082,145.044967651367 -7.82041692733765,144.995513916016 -7.81555557250977,144.879669189453 -7.78250026702881,144.844696044922 -7.75722312927246,144.838562011719 -7.74972152709961,144.840515136719 -7.74499988555908,144.850250244141 -7.74111080169678,144.871337890625 -7.70777797698975,144.873565673828 -7.7030553817749,144.874114990234 -7.69694423675537,144.874114990234 -7.6899995803833,144.862457275391 -7.61055564880371,144.844696044922 -7.60777759552002,144.833862304688 -7.67722225189209,144.831085205078 -7.68111133575439,144.824127197266 -7.68805503845215,144.819427490234 -7.6899995803833,144.787750244141 -7.69138813018799,144.783599853516 -7.69138813018799,144.599395751953 -7.6602783203125,144.588287353516 -7.657
 50026702881,144.584411621094 -7.65472221374512,144.552185058594 -7.6119441986084,144.547210693359 -7.60305500030518,144.547210693359 -7.5963888168335,144.545806884766 -7.57472229003906,144.536376953125 -7.52694511413574,144.534973144531 -7.52166652679443,144.530822753906 -7.51222229003906,144.525268554688 -7.5038890838623,144.520538330078 -7.50194454193115,144.514984130859 -7.50194454193115,144.51025390625 -7.5038890838623,144.508880615234 -7.50944519042969,144.508331298828 -7.61472225189209,144.508331298828 -7.62138843536377,144.424682617188 -7.53305530548096,144.418579101562 -7.52583312988281,144.410247802734 -7.52027797698975,144.406921386719 -7.51944446563721,144.412200927734 -7.56583309173584,144.435516357422 -7.68000030517578,144.467742919922 -7.74305534362793,144.395812988281 -7.75583362579346,144.378021240234 -7.75333404541016,144.363006591797 -7.74777793884277,144.358856201172 -7.74499988555908,144.356628417969 -7.74027729034424,144.354125976562 -7.72944450378418,14
 4.354125976562 -7.72277736663818,144.356628417969 -7.70499992370605,144.359680175781 -7.69416618347168,144.360229492188 -7.68249988555908,144.319122314453 -7.62083339691162,144.315795898438 -7.61749935150146,144.310791015625 -7.61666584014893,144.260803222656 -7.63777828216553,144.250549316406 -7.65472221374512,144.243560791016 -7.66694450378418,144.255249023438 -7.73416614532471,144.263031005859 -7.74027729034424,144.272491455078 -7.76749992370605,144.271911621094 -7.77361106872559,144.268310546875 -7.77694511413574,144.224395751953 -7.79333305358887,144.219116210938 -7.79472255706787,144.213012695312 -7.79527759552002,144.147216796875 -7.77888870239258,144.121612548828 -7.77166652679443,143.911926269531 -7.69694423675537,143.899719238281 -7.68861103057861,143.848037719727 -7.63533353805542,143.838531494141 -7.62833404541016,143.829193115234 -7.61733341217041,143.822525024414 -7.60766696929932,143.812713623047 -7.58883380889893,143.810211181641 -7.58316707611084,143.8065490
 72266 -7.57049989700317,143.773040771484 -7.51555633544922,143.768310546875 -7.506667137146,143.758605957031 -7.50250053405762,143.664825439453 -7.46764850616455,143.691345214844 -7.51222229003906,143.755126953125 -7.58950042724609,143.839416503906 -7.71527767181396,143.845520019531 -7.73611068725586,143.852447509766 -7.77027797698975,143.85302734375 -7.78305530548096,143.851898193359 -7.79527759552002,143.85302734375 -7.80749988555908,143.854400634766 -7.81305503845215,143.896362304688 -7.88027763366699,143.901641845703 -7.88833332061768,143.9580078125 -7.97862243652344,143.957183837891 -7.98472213745117,143.955230712891 -7.9894437789917,143.893585205078 -8.03694534301758,143.889434814453 -8.03972244262695,143.884704589844 -8.04166793823242,143.847747802734 -8.04583358764648,143.833862304688 -8.04583358764648,143.755249023438 -8.04111099243164,143.750274658203 -8.03888893127441,143.743560791016 -8.03222274780273,143.738006591797 -8.02416801452637,143.724395751953 -8.0105571
 7468262,143.719421386719 -8.00833511352539,143.661376953125 -7.99138832092285,143.631896972656 -7.98666667938232,143.618835449219 -7.98611068725586,143.597473144531 -7.99222183227539,143.588562011719 -7.99694442749023,143.568908691406 -8.0041675567627,143.56575012207 -8.00483322143555,143.546081542969 -8.00638961791992,143.501647949219 -7.9961109161377,143.485778808594 -7.99138832092285,143.481628417969 -7.98888874053955,143.474975585938 -7.98194408416748,143.473571777344 -7.97305583953857,143.460510253906 -7.93861103057861,143.454406738281 -7.92416667938232,143.444122314453 -7.91333389282227,143.439971923828 -7.91055583953857,143.435241699219 -7.90861129760742,143.424133300781 -7.90722274780273,143.362457275391 -7.8997220993042,143.358306884766 -7.90250015258789,143.356903076172 -7.90805530548096,143.356903076172 -7.91333389282227,143.360504150391 -7.91694450378418,143.446624755859 -7.98055553436279,143.538635253906 -8.05216693878174,143.541458129883 -8.05333423614502,143.5
 43975830078 -8.05500030517578,143.547958374023 -8.05900001525879,143.628295898438 -8.19361114501953,143.630523681641 -8.19833374023438,143.632446289062 -8.20999908447266,143.631896972656 -8.21611022949219,143.629669189453 -8.22749900817871,143.625518798828 -8.2369441986084,143.622192382812 -8.24055480957031,143.611907958984 -8.24388885498047,143.56884765625 -8.24722099304199,143.554962158203 -8.24722099304199,143.512481689453 -8.2458324432373,143.469421386719 -8.24527740478516,143.382446289062 -8.25,143.373565673828 -8.25055694580078,143.338562011719 -8.2538890838623,143.234954833984 -8.27500152587891,143.178039550781 -8.28666687011719,143.080810546875 -8.30833435058594,143.069976806641 -8.31083297729492,143.049407958984 -8.31777763366699,143.034149169922 -8.32305526733398,143.023864746094 -8.3266658782959,143 -8.33666610717773,142.991058349609 -8.34138870239258,142.979949951172 -8.34416580200195,142.973297119141 -8.34416580200195,142.967193603516 -8.3436107635498,142.961639
 404297 -8.34222221374512,142.94580078125 -8.33749961853027,142.941070556641 -8.33527755737305,142.908874511719 -8.31916618347168,142.882171630859 -8.30500030517578,142.865509033203 -8.29416656494141,142.845794677734 -8.28666687011719,142.799987792969 -8.27500152587891,142.776641845703 -8.27083396911621,142.696350097656 -8.26749992370605,142.654693603516 -8.27361106872559,142.638031005859 -8.27777862548828,142.595794677734 -8.29000091552734,142.575256347656 -8.29666709899902,142.565521240234 -8.30083274841309,142.548309326172 -8.31083297729492,142.540802001953 -8.31694412231445,142.533874511719 -8.32388877868652,142.529968261719 -8.3266658782959,142.521087646484 -8.33138847351074,142.511383056641 -8.33527755737305,142.505828857422 -8.33666610717773,142.485229492188 -8.33666610717773,142.466918945312 -8.33611106872559,142.442749023438 -8.33277702331543,142.437469482422 -8.33138847351074,142.427764892578 -8.32722282409668,142.419708251953 -8.32194519042969,142.411926269531 -8.3
 1583404541016,142.403213500977 -8.28638935089111,142.396194458008 -8.26155567169189,142.395050048828 -8.25055599212646,142.394195556641 -8.23922157287598,142.39453125 -8.23155498504639,142.394195556641 -8.2278881072998,142.386657714844 -8.19361114501953,142.383880615234 -8.18972206115723,142.379943847656 -8.18694496154785,142.338562011719 -8.16638946533203,142.327758789062 -8.16388893127441,142.316925048828 -8.16388893127441,142.221618652344 -8.1733341217041,142.2119140625 -8.17722320556641,142.140808105469 -8.22222137451172,142.13720703125 -8.22555541992188,142.13525390625 -8.23027801513672,142.135803222656 -8.23638725280762,142.144714355469 -8.23916625976562,142.155822753906 -8.24055480957031,142.163879394531 -8.23638725280762,142.172210693359 -8.23083305358887,142.182464599609 -8.22083282470703,142.186645507812 -8.21805572509766,142.195526123047 -8.21333312988281,142.223571777344 -8.20027732849121,142.228302001953 -8.19833374023438,142.309143066406 -8.18083381652832,142.3
 14147949219 -8.18000030517578,142.324401855469 -8.1833324432373,142.338012695312 -8.19027709960938,142.355224609375 -8.19916725158691,142.361358642578 -8.20638847351074,142.374572753906 -8.26111125946045,142.377410888672 -8.2746114730835,142.377075195312 -8.28644466400146,142.377410888672 -8.29327774047852,142.382446289062 -8.31916618347168,142.388031005859 -8.32722282409668,142.408599853516 -8.34749984741211,142.439422607422 -8.37138748168945,142.44970703125 -8.37472152709961,142.466918945312 -8.37805557250977,142.473022460938 -8.37888717651367,142.486633300781 -8.37888717651367,142.493011474609 -8.37805557250977,142.512756347656 -8.37194442749023,142.522491455078 -8.36805534362793,142.5263671875 -8.36527633666992,142.540252685547 -8.35166549682617,142.548309326172 -8.34611129760742,142.556640625 -8.34083366394043,142.590240478516 -8.3266658782959,142.619689941406 -8.31500053405762,142.635528564453 -8.31027793884277,142.641662597656 -8.31083297729492,142.734680175781 -8.322
 50022888184,142.771636962891 -8.33194351196289,142.776641845703 -8.33388900756836,142.783325195312 -8.34083366394043,142.788879394531 -8.3488883972168,142.799133300781 -8.35916519165039,142.807464599609 -8.36444473266602,142.906097412109 -8.42361068725586,142.917205810547 -8.42611122131348,142.9580078125 -8.43166732788086,143.01025390625 -8.44111061096191,143.04443359375 -8.44777870178223,143.049987792969 -8.44916725158691,143.086364746094 -8.45999908447266,143.096618652344 -8.4636116027832,143.110229492188 -8.47027778625488,143.213012695312 -8.5494441986084,143.220520019531 -8.55555534362793,143.239135742188 -8.57138824462891,143.246063232422 -8.57805633544922,143.249389648438 -8.58138847351074,143.281646728516 -8.61861038208008,143.374664306641 -8.741943359375,143.392761230469 -8.77027893066406,143.395263671875 -8.7813892364502,143.406921386719 -8.96194458007812,143.405548095703 -8.96749877929688,143.403045654297 -8.97138786315918,143.384429931641 -8.99388885498047,143.367
 1875 -9.01083374023438,143.363006591797 -9.01361274719238,143.331634521484 -9.02833366394043,143.321899414062 -9.03250122070312,143.316650390625 -9.03388977050781,143.310241699219 -9.03305625915527,143.299407958984 -9.02361106872559,143.289154052734 -9.02027893066406,143.283050537109 -9.01972198486328,143.269989013672 -9.02027893066406,143.248016357422 -9.02555656433105,143.232177734375 -9.0302791595459,143.174133300781 -9.04861068725586,143.047210693359 -9.09000015258789,143.04248046875 -9.09194374084473,143.039154052734 -9.09527778625488,143.030822753906 -9.10750007629395,143.023864746094 -9.11416625976562,142.902770996094 -9.19750022888184,142.842468261719 -9.2327766418457,142.807464599609 -9.25222396850586,142.797760009766 -9.25638961791992,142.788299560547 -9.26027870178223,142.769134521484 -9.2672233581543,142.752471923828 -9.27138900756836,142.723846435547 -9.28333282470703,142.66552734375 -9.32055473327637,142.654693603516 -9.32999992370605,142.638885498047 -9.334722
 5189209,142.625244140625 -9.3347225189209,142.582733154297 -9.33083343505859,142.571624755859 -9.32805633544922,142.543029785156 -9.30916595458984,142.532470703125 -9.29888916015625,142.5244140625 -9.28694534301758,142.521087646484 -9.28333282470703,142.517486572266 -9.28000068664551,142.497741699219 -9.26527786254883,142.477172851562 -9.25166702270508,142.425811767578 -9.22805595397949,142.2099609375 -9.16500091552734,142.203033447266 -9.16500091552734,142.054412841797 -9.18722152709961,141.944702148438 -9.20694351196289,141.721343994141 -9.21444511413574,141.615783691406 -9.23611068725586,141.608856201172 -9.23611068725586,141.522491455078 -9.22111129760742,141.509429931641 -9.21388816833496,141.501922607422 -9.20777702331543,141.495788574219 -9.20027732849121,141.48828125 -9.19416618347168,141.460784912109 -9.17388916015625,141.448577880859 -9.16583442687988,141.429412841797 -9.15750122070312,141.388305664062 -9.14416694641113,141.375244140625 -9.14333343505859,141.323028
 564453 -9.14999961853027,141.312194824219 -9.15277862548828,141.307464599609 -9.15500068664551,141.294982910156 -9.16305541992188,141.284698486328 -9.17305564880371,141.266387939453 -9.18888854980469,141.226623535156 -9.21722221374512,141.213592529297 -9.22472190856934,141.176361083984 -9.23388862609863,141.160797119141 -9.23749923706055,141.122467041016 -9.23194313049316,141.117462158203 -9.22999954223633,141.109405517578 -9.22472190856934,141.090789794922 -9.20916557312012,141.033874511719 -9.15694427490234,141.013305664062 -9.13666725158691,141.007019042969 -9.12846755981445,141.006134033203 -6.90478563308716,141.006134033203 -6.89328384399414,140.998565673828 -6.89388942718506,140.990509033203 -6.89944458007812,140.983581542969 -6.9061107635498,140.978851318359 -6.90694427490234,140.949401855469 -6.9036111831665,140.902770996094 -6.85583305358887,140.875244140625 -6.79611110687256,140.871063232422 -6.7863883972168,140.859405517578 -6.72861099243164,140.858856201172 -6.67
 83332824707,140.863006591797 -6.63138866424561,140.891082763672 -6.60333347320557,140.895263671875 -6.60055541992188,140.898040771484 -6.59666728973389,140.947204589844 -6.5,140.951354980469 -6.48361110687256,140.950805664062 -6.47749996185303,140.948577880859 -6.47277736663818,140.94580078125 -6.4686107635498,140.928039550781 -6.45083332061768,140.932189941406 -6.43444442749023,140.963592529297 -6.3386116027832,140.967742919922 -6.33583354949951,140.973297119141 -6.33444499969482,140.985504150391 -6.33305549621582,141.006134033203 -6.33292484283447,141.006103515625 -6,141.006103515625 -4.90555477142334,141.006103515625 -2.61388921737671,141.002471923828 -2.60708522796631,141.029968261719 -2.59277772903442,141.034698486328 -2.59083318710327,141.039428710938 -2.59000015258789,141.046356201172 -2.59000015258789,141.199127197266 -2.61805534362793,141.204681396484 -2.61944437026978,141.214141845703 -2.62222194671631,141.270538330078 -2.64555549621582,141.273864746094 -2.65583324
 432373,141.278045654297 -2.6652774810791,141.284149169922 -2.67277765274048,141.345794677734 -2.70777797698975,141.369689941406 -2.7180552482605,141.380798339844 -2.72083330154419,141.410797119141 -2.72499990463257,141.426635742188 -2.72972202301025,141.436370849609 -2.73388910293579,141.568572998047 -2.79388904571533,141.608856201172 -2.8125,141.704132080078 -2.86250019073486,141.840515136719 -2.93694448471069,141.881622314453 -2.96444463729858,141.889984130859 -2.96999979019165,141.894714355469 -2.9719443321228,141.913879394531 -2.9719443321228,141.931091308594 -2.9686107635498,141.935791015625 -2.96638870239258,141.962463378906 -2.95888900756836,141.973571777344 -2.95611095428467,141.991912841797 -2.95416688919067,142.003601074219 -2.95611095428467,142.011932373047 -2.96166658401489,142.066070556641 -3.00833368301392,142.076904296875 -3.01777791976929,142.077758789062 -3.02055549621582,142.124969482422 -3.05944442749023,142.252471923828 -3.10472249984741,142.551910400391
 -3.21833324432373,142.663604736328 -3.24777793884277,142.946624755859 -3.33249998092651,142.992462158203 -3.34833335876465,143.032745361328 -3.36277770996094,143.041076660156 -3.36416673660278,143.073181152344 -3.36020636558533,143.087738037109 -3.35583353042603,143.093841552734 -3.35500001907349,143.106079101562 -3.35388898849487,143.123840332031 -3.35388898849487,143.172760009766 -3.35722255706787,143.194702148438 -3.3600001335144,143.209686279297 -3.3652777671814,143.2138671875 -3.36805534362793,143.229400634766 -3.37972211837769,143.23828125 -3.38444471359253,143.255554199219 -3.3880558013916,143.336364746094 -3.40166664123535,143.346069335938 -3.40166664123535,143.370788574219 -3.40166664123535,143.384429931641 -3.40305519104004,143.408325195312 -3.40638875961304,143.442749023438 -3.41194438934326,143.516082763672 -3.43444442749023,143.520812988281 -3.43666648864746,143.529144287109 -3.44194412231445,143.536651611328 -3.44805526733398,143.569427490234 -3.47555541992188,
 143.598846435547 -3.51444482803345,143.602172851562 -3.5247220993042,143.605804443359 -3.54194450378418,143.609130859375 -3.54527807235718,143.61328125 -3.54805564880371,143.648864746094 -3.56722259521484,143.731079101562 -3.60416698455811,143.768310546875 -3.61083364486694,143.790802001953 -3.61083364486694,143.794982910156 -3.61222219467163,143.798858642578 -3.61500024795532,143.949127197266 -3.73333311080933,143.955230712891 -3.73944425582886,143.9580078125 -3.74361133575439,143.964691162109 -3.7572226524353,143.966064453125 -3.76277780532837,143.976348876953 -3.77972221374512,143.981903076172 -3.78805589675903,143.988861083984 -3.79500007629395,143.993011474609 -3.79777812957764,144.016937255859 -3.81055545806885,144.243011474609 -3.87277746200562,144.249114990234 -3.87361097335815,144.253875732422 -3.87138891220093,144.255249023438 -3.86611127853394,144.253875732422 -3.86194467544556,144.253875732422 -3.85500001907349,144.258026123047 -3.84555530548096,144.275268554688
 -3.809166431427,144.278594970703 -3.80583333969116,144.284973144531 -3.80527782440186,144.338287353516 -3.80249977111816,144.375244140625 -3.80249977111816,144.511657714844 -3.82083368301392,144.515808105469 -3.82361125946045,144.532196044922 -3.84611082077026,144.534973144531 -3.8502779006958,144.549987792969 -3.87611103057861,144.552185058594 -3.88111114501953,144.547210693359 -3.8938889503479,144.545257568359 -3.90416669845581,144.54248046875 -3.93444442749023,144.543853759766 -3.95361137390137,144.547210693359 -3.96388912200928,144.551361083984 -3.9719443321228,144.571350097656 -3.99194431304932,144.591064453125 -4.00611114501953,144.608306884766 -4.0130558013916,144.613861083984 -4.01444530487061,144.653594970703 -4.0130558013916,144.673309326172 -4.01361179351807,144.678863525391 -4.01500034332275,144.729675292969 -4.0313892364502,144.766662597656 -4.04638862609863,144.850250244141 -4.09305572509766,144.858306884766 -4.09833335876465,144.876342773438 -4.11361122131348,
 144.978302001953 -4.22277736663818,144.981628417969 -4.22638893127441,144.986633300781 -4.23499965667725,144.991333007812 -4.24388885498047,144.994689941406 -4.25277805328369,144.996063232422 -4.26250076293945,145.004974365234 -4.28166675567627,145.033050537109 -4.33555603027344,145.036651611328 -4.33888912200928,145.054962158203 -4.35194396972656,145.089965820312 -4.37166595458984,145.094696044922 -4.37388896942139,145.157196044922 -4.38277721405029,145.228576660156 -4.3880558013916,145.253051757812 -4.37861061096191,145.293579101562 -4.37666606903076,145.305236816406 -4.37722206115723,145.333862304688 -4.38944435119629,145.338012695312 -4.39222240447998,145.451080322266 -4.49416637420654,145.459411621094 -4.50444507598877,145.527191162109 -4.59249973297119,145.614135742188 -4.70027828216553,145.620513916016 -4.70777797698975,145.675811767578 -4.76194477081299,145.679412841797 -4.76527786254883,145.69384765625 -4.77694511413574,145.735504150391 -4.80277729034424,145.7808227
 53906 -4.92777729034424,145.813598632812 -5.06555557250977,145.813598632812 -5.07250022888184,145.786926269531 -5.23138904571533,145.765808105469 -5.26361179351807,145.738861083984 -5.30527782440186,145.724395751953 -5.41222190856934,145.723846435547 -5.42527770996094,145.725250244141 -5.430832862854,145.734130859375 -5.4491662979126,145.747741699219 -5.46972179412842,145.754699707031 -5.47638893127441,145.766387939453 -5.48527717590332,145.782745361328 -5.4894437789917,145.787750244141 -5.48999977111816,145.793029785156 -5.48999977111816,145.872467041016 -5.48611068725586,145.930816650391 -5.47722244262695,145.935516357422 -5.47638893127441,145.963592529297 -5.47305583953857,145.976623535156 -5.47638893127441,146.082183837891 -5.51250076293945,146.174682617188 -5.55138874053955,146.194702148438 -5.55888843536377,146.289154052734 -5.58888912200928,146.376342773438 -5.59916687011719,146.439971923828 -5.59861087799072,146.445526123047 -5.59861087799072,146.465240478516 -5.6047
 2202301025,146.47021484375 -5.60666751861572,146.474090576172 -5.60944557189941,146.531188964844 -5.65468120574951,146.580535888672 -5.69472217559814,146.605224609375 -5.71777820587158,146.640808105469 -5.74388885498047,146.653045654297 -5.75194454193115,146.662750244141 -5.75611114501953,146.688873291016 -5.76416683197021,146.714691162109 -5.76972198486328,146.770782470703 -5.79138946533203,146.775787353516 -5.79361248016357,146.783843994141 -5.79889011383057,146.786071777344 -5.80388927459717,146.796310424805 -5.83441781997681,146.875213623047 -5.82555675506592,146.894958496094 -5.82888984680176,146.923004150391 -5.84194564819336,146.930511474609 -5.84805679321289,146.946319580078 -5.86638927459717,146.953826904297 -5.88611221313477,146.956604003906 -5.89027881622314,146.962707519531 -5.897780418396,146.992156982422 -5.91611289978027,147.014129638672 -5.92833518981934,147.041625976562 -5.94222354888916,147.046325683594 -5.94416904449463,147.102722167969 -5.96611404418945,1
 47.112152099609 -5.96667003631592,147.228820800781 -5.97223472595215,147.234924316406 -5.97140216827393,147.24658203125 -5.96251487731934,147.269683837891 -5.93807125091553,147.274658203125 -5.93612670898438,147.284942626953 -5.93529415130615,147.423278808594 -5.96058177947998,147.466613769531 -5.97085952758789,147.476867675781 -5.97419261932373,147.484375 -5.98030376434326,147.573303222656 -6.05527782440186,147.590515136719 -6.07222270965576,147.641937255859 -6.13694477081299,147.786651611328 -6.30249977111816,147.826354980469 -6.3372220993042,147.830261230469 -6.34694480895996,147.850250244141 -6.41166687011719,147.863861083984 -6.45916652679443,147.866638183594 -6.47000026702881,147.869964599609 -6.65472221374512,147.869415283203 -6.66083335876465,147.866058349609 -6.67083358764648,147.845520019531 -6.69138813018799,147.838562011719 -6.69805526733398,147.819427490234 -6.71305561065674,147.810516357422 -6.71777820587158,147.770812988281 -6.72611141204834,147.759155273438 -
 6.72805595397949,147.568023681641 -6.75194454193115,147.416381835938 -6.73499965667725,147.305541992188 -6.74583339691162,147.219696044922 -6.74638843536377,147.199981689453 -6.74583339691162,147.188873291016 -6.74305534362793,147.180816650391 -6.74027729034424,147.174682617188 -6.73555564880371,147.166381835938 -6.72333335876465,147.160247802734 -6.71722221374512,147.149993896484 -6.71388912200928,147.0888671875 -6.71444511413574,146.971069335938 -6.74305534362793,146.961364746094 -6.74722194671631,146.948577880859 -6.79805564880371,146.944976806641 -6.81527709960938,146.943023681641 -6.84027767181396,146.941650390625 -6.90444469451904,146.944976806641 -6.95388889312744,146.946350097656 -6.95944499969482,146.948577880859 -6.96416664123535,146.955230712891 -6.97111129760742,147.0244140625 -7.03694438934326,147.037475585938 -7.04444408416748,147.130798339844 -7.20361137390137,147.140258789062 -7.22111129760742,147.144439697266 -7.23083305358887,147.146362304688 -7.24916648864
 746,147.145812988281 -7.26194477081299,147.141662597656 -7.27166652679443,147.140258789062 -7.27694511413574,147.137481689453 -7.29472255706787,147.139709472656 -7.32527828216553,147.1533203125 -7.38305473327637,147.154693603516 -7.38861179351807,147.178588867188 -7.46388912200928,147.210784912109 -7.49027729034424,147.216369628906 -7.49166679382324,147.297210693359 -7.5038890838623,147.303314208984 -7.50472259521484,147.320526123047 -7.50527858734131,147.332183837891 -7.50333404541016,147.3369140625 -7.50527858734131,147.418579101562 -7.56722259521484,147.457733154297 -7.5977783203125,147.641357421875 -7.77555561065674,147.666656494141 -7.79111099243164,147.670806884766 -7.79388904571533,147.693298339844 -7.82583332061768,147.696075439453 -7.83527755737305,147.701629638672 -7.87055492401123,147.701629638672 -7.8841667175293,147.700805664062 -7.89027786254883,147.701629638672 -7.90333366394043,147.703033447266 -7.90861129760742,147.710510253906 -7.92166614532471,147.71524047
 8516 -7.92916679382324,147.718566894531 -7.93249988555908,147.731628417969 -7.9399995803833,147.741333007812 -7.94388866424561,147.756927490234 -7.94861030578613,147.776916503906 -7.93638801574707,147.782470703125 -7.93527698516846,147.804412841797 -7.93527698516846,147.854949951172 -7.93527698516846,147.866638183594 -7.93722152709961,147.876342773438 -7.94111061096191,147.888031005859 -7.94999980926514,147.911926269531 -7.96722221374512,147.935791015625 -7.98277759552002,147.939422607422 -7.98472213745117,147.974395751953 -7.99610900878906,147.979675292969 -8.03694534301758,147.982452392578 -8.04777908325195,147.985229492188 -8.05194473266602,147.9921875 -8.0586109161377,148.004425048828 -8.06666564941406,148.009979248047 -8.06666564941406,148.0263671875 -8.06277847290039,148.114685058594 -8.05527877807617,148.13525390625 -8.06611061096191,148.194976806641 -8.25194549560547,148.19970703125 -8.26749992370605,148.205810546875 -8.29527854919434,148.206634521484 -8.301389694213
 87,148.207183837891 -8.31083297729492,148.207183837891 -8.32055473327637,148.206634521484 -8.34000015258789,148.210784912109 -8.39305686950684,148.220245361328 -8.51027870178223,148.222198486328 -8.53388977050781,148.230529785156 -8.55972290039062,148.235229492188 -8.56861114501953,148.2421875 -8.57527732849121,148.271087646484 -8.59444427490234,148.300537109375 -8.61138916015625,148.318298339844 -8.60861015319824,148.327178955078 -8.60638809204102,148.331359863281 -8.60638809204102,148.347198486328 -8.61138916015625,148.351898193359 -8.61333274841309,148.376617431641 -8.62944412231445,148.443023681641 -8.67500114440918,148.44580078125 -8.67888832092285,148.478576660156 -8.73305511474609,148.479949951172 -8.73861122131348,148.479949951172 -8.75889015197754,148.489685058594 -8.84027671813965,148.494415283203 -8.86666488647461,148.530822753906 -8.99305534362793,148.534698486328 -9.00277900695801,148.536926269531 -9.00750160217285,148.5888671875 -9.07027816772461,148.6041259765
 62 -9.08250045776367,148.614410400391 -9.0858325958252,148.695251464844 -9.10222244262695,148.719970703125 -9.10472106933594,148.725250244141 -9.10472106933594,148.753601074219 -9.10416603088379,148.782196044922 -9.10138893127441,148.842468261719 -9.09055519104004,149.067199707031 -9.04111099243164,149.071350097656 -9.03861236572266,149.137756347656 -9.00666809082031,149.221343994141 -8.99860954284668,149.255828857422 -8.99777793884277,149.259979248047 -8.99916648864746,149.309967041016 -9.01694488525391,149.314697265625 -9.01889038085938,149.316650390625 -9.02166748046875,149.322204589844 -9.03777885437012,149.338012695312 -9.12972068786621,149.328308105469 -9.15277862548828,149.325531005859 -9.15694427490234,149.316070556641 -9.16777801513672,149.311920166016 -9.17055511474609,149.291351318359 -9.18388938903809,149.181640625 -9.34916687011719,149.1796875 -9.35361099243164,149.178863525391 -9.35972213745117,149.178863525391 -9.37333297729492,149.181091308594 -9.385000228881
 84,149.184417724609 -9.39500045776367,149.208312988281 -9.45249938964844,149.219970703125 -9.47472190856934,149.227752685547 -9.48749923706055,149.231079101562 -9.49110984802246,149.234405517578 -9.49444389343262,149.243286132812 -9.49916648864746,149.266662597656 -9.51000022888184,149.271636962891 -9.5119457244873,149.2783203125 -9.5119457244873,149.28857421875 -9.50861167907715,149.301635742188 -9.50777816772461,149.307189941406 -9.5091667175293,149.348846435547 -9.52194595336914,149.437469482422 -9.57138824462891,149.439422607422 -9.59111022949219,149.440795898438 -9.59638786315918,149.444122314453 -9.59972190856934,149.454406738281 -9.60305404663086,149.662200927734 -9.60722160339355,149.739410400391 -9.60166549682617,149.746337890625 -9.60166549682617,149.758026123047 -9.6038875579834,149.764984130859 -9.60916519165039,149.771087646484 -9.61666488647461,149.775268554688 -9.61944389343262,149.780548095703 -9.6208324432373,149.874389648438 -9.6422233581543,149.88079833984
 4 -9.64305686950684,149.9033203125 -9.64361190795898,149.910247802734 -9.64361190795898,149.94580078125 -9.6422233581543,149.956634521484 -9.63972282409668,149.960784912109 -9.6369457244873,149.982727050781 -9.63138771057129,150.008880615234 -9.63138771057129,150.049133300781 -9.67944526672363,150.051361083984 -9.68416595458984,150.053314208984 -9.68888854980469,150.056915283203 -9.70999908447266,150.056915283203 -9.71527671813965,150.055541992188 -9.72055435180664,150.051910400391 -9.72416687011719,149.988861083984 -9.75111198425293,149.926635742188 -9.76944541931152,149.863586425781 -9.78222274780273,149.857452392578 -9.78277778625488,149.852752685547 -9.78222274780273,149.841644287109 -9.77944564819336,149.835510253906 -9.77888870239258,149.808013916016 -9.7813892364502,149.769714355469 -9.7902774810791,149.764984130859 -9.79222297668457,149.739410400391 -9.80777740478516,149.727172851562 -9.81583404541016,149.720245361328 -9.82277679443359,149.717468261719 -9.82666587829
 59,149.716369628906 -9.83222198486328,149.717468261719 -9.83749961853027,149.721069335938 -9.84749984741211,149.723022460938 -9.85249900817871,149.76220703125 -9.90166664123535,149.873840332031 -10.0169448852539,149.914154052734 -10.0488891601562,149.926635742188 -10.0569438934326,149.935516357422 -10.0616655349731,149.982727050781 -10.081111907959,149.98828125 -10.0825004577637,149.994415283203 -10.0819444656372,150.003326416016 -10.0772228240967,150.013610839844 -10.0736103057861,150.019714355469 -10.073055267334,150.184143066406 -10.0933322906494,150.189147949219 -10.0952777862549,150.236358642578 -10.1283321380615,150.259704589844 -10.1527786254883,150.29052734375 -10.1830558776855,150.298583984375 -10.1883344650269,150.308319091797 -10.1924991607666,150.352752685547 -10.1999988555908,150.382171630859 -10.2047214508057,150.400268554688 -10.2072219848633,150.579681396484 -10.2411098480225,150.61328125 -10.2755565643311,150.618011474609 -10.2775001525879,150.63525390625 -1
 0.280834197998,150.641357421875 -10.2813892364502,150.647491455078 -10.280834197998,150.775543212891 -10.2613906860352,150.780548095703 -10.2591667175293,150.803588867188 -10.2486095428467,150.815521240234 -10.2397212982178,150.81884765625 -10.2363872528076,150.824981689453 -10.2316665649414,150.829681396484 -10.2294454574585,150.844116210938 -10.2247219085693,150.862731933594 -10.2227764129639,150.869415283203 -10.2227764129639,150.877746582031 -10.2283334732056,150.878295898438 -10.2316665649414,150.870788574219 -10.2377777099609,150.861907958984 -10.2424983978271,150.727752685547 -10.3125,150.641937255859 -10.3494434356689,150.636383056641 -10.3508319854736,150.631072998047 -10.3508319854736,150.602172851562 -10.3502769470215,150.596069335938 -10.3494434356689,150.547485351562 -10.3355560302734,150.496063232422 -10.3186111450195,150.438568115234 -10.3036117553711,150.421905517578 -10.3011112213135,150.415802001953 -10.3002777099609,150.406372070312 -10.3044452667236,150.3
 69110107422 -10.3219451904297,150.358306884766 -10.3313884735107,150.356353759766 -10.3361110687256,150.348571777344 -10.3758316040039,150.346618652344 -10.3875007629395,150.352172851562 -10.3952789306641,150.356903076172 -10.3975009918213,150.568572998047 -10.4627780914307,150.6494140625 -10.4755554199219,150.657745361328 -10.4811115264893,150.663299560547 -10.4891662597656,150.689971923828 -10.5502777099609,150.691925048828 -10.5550003051758,150.691345214844 -10.5611114501953,150.688568115234 -10.5652770996094,150.680267333984 -10.5774993896484,150.675537109375 -10.5794448852539,150.568023681641 -10.6219444274902,150.556365966797 -10.6238880157471,150.522766113281 -10.6191654205322,150.492736816406 -10.6191654205322,150.481628417969 -10.6219444274902,150.477447509766 -10.6244430541992,150.47412109375 -10.6277770996094,150.44384765625 -10.6588897705078,150.428314208984 -10.6877784729004,150.424133300781 -10.6905555725098,150.369964599609 -10.6872215270996,150.268585205078 -
 10.6886119842529,150.209686279297 -10.7005558013916,150.113006591797 -10.6674995422363,150.099975585938 -10.6575012207031,150.059417724609 -10.6258316040039,150.028045654297 -10.5894432067871,150.016937255859 -10.5733337402344,150.013031005859 -10.5705547332764,150.007476806641 -10.5691661834717,149.91552734375 -10.5577774047852,149.898590087891 -10.5597229003906,149.896362304688 -10.5625,149.893585205078 -10.5633344650269,149.888305664062 -10.5619449615479,149.862182617188 -10.5544452667236,149.852752685547 -10.5502777099609,149.850524902344 -10.5469455718994,149.875244140625 -10.5100002288818,149.878570556641 -10.5066680908203,149.883331298828 -10.5044460296631,149.901916503906 -10.5025005340576,149.942474365234 -10.5025005340576,149.964416503906 -10.5025005340576,149.968292236328 -10.5052795410156,149.971069335938 -10.5094451904297,149.97802734375 -10.5161113739014,149.989685058594 -10.5180568695068,150.016937255859 -10.5113906860352,150.022491455078 -10.5100002288818,150
 .031372070312 -10.5052795410156,150.039703369141 -10.5,150.078857421875 -10.4627780914307,150.064422607422 -10.4561100006104,149.990234375 -10.4372215270996,149.866363525391 -10.3980560302734,149.806091308594 -10.3677768707275,149.785522460938 -10.3583335876465,149.758026123047 -10.3461112976074,149.747741699219 -10.3427772521973,149.723846435547 -10.3394432067871,149.683868408203 -10.3380546569824,149.6640625 -10.3398141860962)),((152.004425048828 -2.67000007629395,151.972747802734 -2.66888904571533,151.961090087891 -2.66805553436279,151.957733154297 -2.66472196578979,151.955535888672 -2.65999984741211,151.953582763672 -2.64833354949951,151.954406738281 -2.64222240447998,151.958312988281 -2.63249969482422,151.972747802734 -2.60583353042603,151.979675292969 -2.59888887405396,151.983856201172 -2.59611082077026,151.995239257812 -2.59555530548096,152.000823974609 -2.5969443321228,152.010528564453 -2.60111141204834,152.018585205078 -2.60638904571533,152.022216796875 -2.610000133
 5144,152.035247802734 -2.63111114501953,152.037200927734 -2.63583326339722,152.038024902344 -2.64222240447998,152.029693603516 -2.66111087799072,152.026916503906 -2.6652774810791,152.022216796875 -2.66750001907349,152.004425048828 -2.67000007629395)),((151.959136962891 -2.84611082077026,151.946624755859 -2.84472227096558,151.941345214844 -2.84333324432373,151.937194824219 -2.8405556678772,151.931640625 -2.83249998092651,151.921905517578 -2.80777788162231,151.920806884766 -2.80222225189209,151.928863525391 -2.7186107635498,151.9296875 -2.71250009536743,151.932464599609 -2.70833349227905,151.939147949219 -2.70833349227905,151.944702148438 -2.70972204208374,151.985778808594 -2.72499990463257,151.989959716797 -2.72749996185303,151.996612548828 -2.7344446182251,152.006378173828 -2.74555540084839,152.009155273438 -2.74944448471069,152.009704589844 -2.75583362579346,152.011932373047 -2.79055595397949,152.011932373047 -2.81805562973022,152.009704589844 -2.82277774810791,152.00219726
 5625 -2.82888889312744,151.959136962891 -2.84611082077026)),((152.063873291016 -3.00222253799438,152.059143066406 -3,152.035247802734 -2.98277759552002,152.0283203125 -2.97555541992188,151.960510253906 -2.88722229003906,151.959686279297 -2.8808331489563,151.959686279297 -2.86861085891724,151.960510253906 -2.86250019073486,151.963287353516 -2.85833358764648,151.973571777344 -2.84805536270142,151.978302001953 -2.84611082077026,151.984954833984 -2.84611082077026,152.072204589844 -2.92138910293579,152.078857421875 -2.9283332824707,152.083862304688 -2.93694448471069,152.087188720703 -2.9472222328186,152.089141845703 -2.95888900756836,152.088562011719 -2.96527767181396,152.086639404297 -2.96999979019165,152.073577880859 -2.99805545806885,152.069976806641 -3.00138902664185,152.063873291016 -3.00222253799438)),((150.773590087891 -2.98555564880371,150.768035888672 -2.9844446182251,150.766082763672 -2.97944402694702,150.773040771484 -2.97249984741211,150.788024902344 -2.96027803421021
 ,150.795532226562 -2.95416688919067,150.870788574219 -2.91249990463257,150.879119873047 -2.9088888168335,150.903045654297 -2.90833330154419,150.908599853516 -2.90833330154419,150.913299560547 -2.91027784347534,150.941345214844 -2.9219446182251,151.021087646484 -2.96305561065674,151.023590087891 -2.96722221374512,151.021636962891 -2.9719443321228,151.003875732422 -2.98166656494141,150.999114990234 -2.98361110687256,150.992736816406 -2.9844446182251,150.882446289062 -2.9686107635498,150.872192382812 -2.96527767181396,150.855804443359 -2.9622220993042,150.838012695312 -2.95972204208374,150.831909179688 -2.96027803421021,150.773590087891 -2.98555564880371)),((152.640808105469 -3.23000001907349,152.636108398438 -3.2277774810791,152.605224609375 -3.20388889312744,152.577178955078 -3.17722225189209,152.538879394531 -3.1061110496521,152.537475585938 -3.10055589675903,152.537475585938 -3.09499979019165,152.539428710938 -3.09027767181396,152.553863525391 -3.07055568695068,152.55801391
 6016 -3.06777811050415,152.590240478516 -3.05194425582886,152.599700927734 -3.04805564880371,152.606079101562 -3.04722261428833,152.640258789062 -3.04305553436279,152.644989013672 -3.04527807235718,152.648590087891 -3.04861116409302,152.667755126953 -3.12944412231445,152.668853759766 -3.14861106872559,152.668853759766 -3.15527772903442,152.667755126953 -3.16083335876465,152.654693603516 -3.21638870239258,152.6533203125 -3.22166633605957,152.646362304688 -3.22861099243164,152.640808105469 -3.23000001907349)),((153.343292236328 -3.41666650772095,153.265258789062 -3.40722227096558,153.262481689453 -3.40444421768188,153.263885498047 -3.39888906478882,153.269989013672 -3.39277791976929,153.301635742188 -3.36944437026978,153.333587646484 -3.37138891220093,153.337188720703 -3.375,153.346069335938 -3.38666677474976,153.348022460938 -3.39138889312744,153.347473144531 -3.39750003814697,153.345245361328 -3.41194438934326,153.343292236328 -3.41666650772095)),((154.818572998047 -3.530277
 72903442,154.795257568359 -3.44138860702515,154.794708251953 -3.43249988555908,154.796081542969 -3.4283332824707,154.799407958984 -3.42500019073486,154.825531005859 -3.4713888168335,154.830261230469 -3.48027753829956,154.833862304688 -3.50416707992554,154.833038330078 -3.51027822494507,154.818572998047 -3.53027772903442)),((153.242462158203 -3.49944448471069,153.237182617188 -3.49805545806885,153.211090087891 -3.48861122131348,153.206909179688 -3.48583316802979,153.192474365234 -3.47277736663818,153.19384765625 -3.4686107635498,153.197204589844 -3.46527767181396,153.220520019531 -3.44888877868652,153.22412109375 -3.4466667175293,153.22802734375 -3.44555521011353,153.233581542969 -3.4466667175293,153.239959716797 -3.45444440841675,153.255554199219 -3.47972202301025,153.259704589844 -3.48916673660278,153.26025390625 -3.49527788162231,153.258331298828 -3.49888896942139,153.242462158203 -3.49944448471069)),((153.639434814453 -4.14083385467529,153.634429931641 -4.13861179351807,1
 53.588012695312 -4.10583305358887,153.585235595703 -4.10194396972656,153.584411621094 -4.09583377838135,153.585235595703 -4.08944416046143,153.587188720703 -4.0847225189209,153.602172851562 -4.05888843536377,153.629669189453 -4.0313892364502,153.633880615234 -4.0286111831665,153.653045654297 -4.02055549621582,153.658599853516 -4.01916694641113,153.662750244141 -4.02194499969482,153.664703369141 -4.02666664123535,153.671630859375 -4.08000087738037,153.672210693359 -4.08611106872559,153.671630859375 -4.10472202301025,153.670257568359 -4.10999965667725,153.650268554688 -4.1380558013916,153.645538330078 -4.14027786254883,153.639434814453 -4.14083385467529)),((145.057739257812 -4.13527774810791,145.050811767578 -4.13527774810791,145.041351318359 -4.13249969482422,145.037200927734 -4.13000011444092,145.031646728516 -4.12166595458984,145.027770996094 -4.11222171783447,145.0263671875 -4.10666656494141,145.022216796875 -4.07666683197021,145.0263671875 -4.06694507598877,145.0316467285
 16 -4.05888843536377,145.036651611328 -4.05666637420654,145.06884765625 -4.04500007629395,145.079132080078 -4.04777812957764,145.095520019531 -4.05888843536377,145.101623535156 -4.06638813018799,145.107177734375 -4.07527828216553,145.110504150391 -4.09222221374512,145.109954833984 -4.09833335876465,145.094696044922 -4.12444400787354,145.092193603516 -4.12833309173584,145.088012695312 -4.13138866424561,145.083312988281 -4.13333320617676,145.057739257812 -4.13527774810791)),((150.74609375 -6.13554954528809,150.729675292969 -6.14666748046875,150.724975585938 -6.14861106872559,150.707183837891 -6.15555572509766,150.668853759766 -6.16833305358887,150.663879394531 -6.16916656494141,150.661102294922 -6.16499996185303,150.659149169922 -6.15333366394043,150.657196044922 -6.14861106872559,150.652191162109 -6.14666748046875,150.63525390625 -6.14861106872559,150.509704589844 -6.23499965667725,150.484954833984 -6.25833415985107,150.480255126953 -6.26722240447998,150.473571777344 -6.27388
 954162598,150.468566894531 -6.2761116027832,150.406372070312 -6.29305553436279,150.400268554688 -6.29361152648926,150.222747802734 -6.28833293914795,150.211639404297 -6.2761116027832,150.188293457031 -6.25833415985107,150.184143066406 -6.25555610656738,150.180816650391 -6.25500011444092,150.170532226562 -6.25694465637207,150.080810546875 -6.28000068664551,150.038879394531 -6.29916667938232,150.018310546875 -6.32361125946045,150.016387939453 -6.30388832092285,150.014434814453 -6.29916667938232,150.010803222656 -6.29583358764648,149.98828125 -6.27722263336182,149.984130859375 -6.2747220993042,149.978576660156 -6.27333354949951,149.972473144531 -6.27388954162598,149.894989013672 -6.29249954223633,149.889709472656 -6.29249954223633,149.847198486328 -6.29249954223633,149.844421386719 -6.29249954223633,149.842193603516 -6.29249954223633,149.686645507812 -6.30527782440186,149.634704589844 -6.30805492401123,149.609405517578 -6.29249954223633,149.605224609375 -6.28972244262695,149.57
 4981689453 -6.26500034332275,149.571624755859 -6.26166725158691,149.555236816406 -6.22694492340088,149.539428710938 -6.19777774810791,149.510803222656 -6.15277767181396,149.489410400391 -6.12611103057861,149.482452392578 -6.11944389343262,149.467468261719 -6.10972213745117,149.444976806641 -6.09805583953857,149.341339111328 -6.06083297729492,149.335784912109 -6.05944442749023,149.311920166016 -6.05722236633301,149.289978027344 -6.06277751922607,149.163879394531 -6.11250019073486,149.138580322266 -6.14861106872559,149.131072998047 -6.15472221374512,149.119415283203 -6.15694427490234,149.069427490234 -6.16416645050049,149.063018798828 -6.16499996185303,149.056915283203 -6.16416645050049,149.052185058594 -6.16222190856934,149.049407958984 -6.15805530548096,149.048034667969 -6.15277767181396,149.048034667969 -6.14583396911621,149.050262451172 -6.14111137390137,149.054962158203 -6.13916683197021,149.061096191406 -6.13833332061768,149.067199707031 -6.14583396911621,149.07135009765
 6 -6.14861106872559,149.075531005859 -6.14583396911621,149.079681396484 -6.13638877868652,149.078857421875 -6.11944389343262,149.071899414062 -6.09277820587158,149.055541992188 -6.04444408416748,149.039978027344 -6.03694438934326,148.983032226562 -6.01972198486328,148.942474365234 -6.00833415985107,148.920654296875 -6.00002384185791,148.882995605469 -5.98166465759277,148.878814697266 -5.94748497009277,148.876068115234 -5.9436616897583,148.764434814453 -5.86499118804932,148.704650878906 -5.84858131408691,148.699554443359 -5.84745788574219,148.589721679688 -5.82837104797363,148.528045654297 -5.82837104797363,148.401672363281 -5.78336238861084,148.391967773438 -5.77940940856934,148.3876953125 -5.77660369873047,148.366607666016 -5.75592136383057,148.359771728516 -5.74921321868896,148.339324951172 -5.7143726348877,148.330780029297 -5.69515228271484,148.323089599609 -5.67537689208984,148.321655273438 -5.66980838775635,148.316467285156 -5.62802600860596,148.354675292969 -5.50166702
 270508,148.358001708984 -5.49277782440186,148.359954833984 -5.48805522918701,148.370239257812 -5.4777774810791,148.378570556641 -5.47249984741211,148.428588867188 -5.45111179351807,148.450531005859 -5.45527839660645,148.504699707031 -5.48333263397217,148.511657714844 -5.48999977111816,148.519714355469 -5.50250053405762,148.618286132812 -5.50500011444092,148.883605957031 -5.49694442749023,148.961639404297 -5.47361087799072,148.973297119141 -5.47166633605957,148.985778808594 -5.47305583953857,149.000823974609 -5.47833347320557,149.122192382812 -5.52416706085205,149.126892089844 -5.5261116027832,149.189147949219 -5.55833339691162,149.209686279297 -5.57194519042969,149.2138671875 -5.57472229003906,149.216064453125 -5.57944488525391,149.220764160156 -5.60611152648926,149.270812988281 -5.59444427490234,149.310516357422 -5.58611106872559,149.425537109375 -5.56722259521484,149.549133300781 -5.53861141204834,149.566925048828 -5.52888870239258,149.581909179688 -5.52333354949951,149.61
 1358642578 -5.51861095428467,149.668304443359 -5.51944446563721,149.680541992188 -5.55416679382324,149.680541992188 -5.561110496521,149.685516357422 -5.56305503845215,149.692199707031 -5.56305503845215,149.710784912109 -5.5625,149.875244140625 -5.5363883972168,149.880798339844 -5.53499984741211,149.887481689453 -5.53166675567627,149.916381835938 -5.51194477081299,149.928588867188 -5.50361156463623,149.956085205078 -5.47638893127441,149.964416503906 -5.46416664123535,149.981353759766 -5.4333324432373,149.984130859375 -5.42249965667725,149.983581542969 -5.41638851165771,149.981353759766 -5.41166687011719,149.97802734375 -5.40833377838135,149.973297119141 -5.4061107635498,149.954132080078 -5.40472221374512,149.950531005859 -5.40138912200928,149.923034667969 -5.36055564880371,149.917755126953 -5.35222244262695,149.918304443359 -5.34611129760742,149.928588867188 -5.31527709960938,149.934692382812 -5.30722236633301,150.002777099609 -5.16944408416748,150.015533447266 -5.05749988555
 908,150.019714355469 -5.04777812957764,150.029968261719 -5.03083324432373,150.034149169922 -5.02805614471436,150.0888671875 -5.00777816772461,150.095794677734 -5.00777816772461,150.121337890625 -5.00972270965576,150.126617431641 -5.01111125946045,150.154693603516 -5.02388954162598,150.181640625 -5.03888893127441,150.19384765625 -5.04722213745117,150.199401855469 -5.05527782440186,150.203582763672 -5.0649995803833,150.204956054688 -5.07055568695068,150.203582763672 -5.07583332061768,150.184143066406 -5.09833335876465,150.180816650391 -5.10194396972656,150.164428710938 -5.11277770996094,150.154693603516 -5.11694431304932,150.132720947266 -5.12222194671631,150.101348876953 -5.13194370269775,150.091644287109 -5.13583374023438,150.082733154297 -5.14138889312744,150.072479248047 -5.15166664123535,150.064422607422 -5.16388893127441,150.061645507812 -5.17472171783447,150.04248046875 -5.3086109161377,150.062194824219 -5.36388874053955,150.121337890625 -5.51250076293945,150.1232910156
 25 -5.51722240447998,150.143859863281 -5.5377779006958,150.164428710938 -5.55138874053955,150.178863525391 -5.55749988555908,150.184143066406 -5.55888843536377,150.282196044922 -5.57055568695068,150.291076660156 -5.57055568695068,150.296630859375 -5.569167137146,150.300811767578 -5.56638813018799,150.306915283203 -5.55888843536377,150.318023681641 -5.54194450378418,150.319976806641 -5.53722190856934,150.323303222656 -5.53361129760742,150.326904296875 -5.53027820587158,150.345245361328 -5.51472282409668,150.412475585938 -5.45861148834229,150.422760009766 -5.45527839660645,150.488555908203 -5.44694423675537,150.511108398438 -5.4505558013916,150.574127197266 -5.47638893127441,150.578308105469 -5.47916698455811,150.595520019531 -5.4961109161377,150.601623535156 -5.51722240447998,150.611083984375 -5.54194450378418,150.61328125 -5.54666709899902,150.616058349609 -5.55083274841309,150.624114990234 -5.55611038208008,150.644134521484 -5.55694389343262,150.677917480469 -5.551299095153
 81,150.693298339844 -5.54749965667725,150.698852539062 -5.54611110687256,150.914154052734 -5.4908332824707,150.924407958984 -5.48722171783447,150.979125976562 -5.44499969482422,151.003051757812 -5.42111110687256,151.011383056641 -5.4088888168335,151.015533447266 -5.39944458007812,151.018859863281 -5.38916683197021,151.023040771484 -5.37277698516846,151.023040771484 -5.3658332824707,151.018310546875 -5.34333324432373,151.018310546875 -5.33666706085205,151.018859863281 -5.33027839660645,151.0244140625 -5.28805541992188,151.028594970703 -5.27166652679443,151.038879394531 -5.24111080169678,151.046936035156 -5.22194480895996,151.066070556641 -5.18583297729492,151.071075439453 -5.17694473266602,151.084686279297 -5.1563892364502,151.096923828125 -5.14277839660645,151.26220703125 -4.98638820648193,151.266387939453 -4.98388862609863,151.357452392578 -4.94749927520752,151.441070556641 -4.93666648864746,151.513610839844 -4.93805503845215,151.604675292969 -4.96805572509766,151.608856201
 172 -4.97083377838135,151.614959716797 -4.97000026702881,151.641082763672 -4.95499992370605,151.648590087891 -4.94888877868652,151.654144287109 -4.94083309173584,151.676086425781 -4.90805530548096,151.684417724609 -4.88890266418457,151.687744140625 -4.86499977111816,151.682189941406 -4.81444454193115,151.658325195312 -4.61638832092285,151.630798339844 -4.50638961791992,151.62744140625 -4.49749946594238,151.598022460938 -4.43805503845215,151.592468261719 -4.43000030517578,151.588287353516 -4.42722225189209,151.547210693359 -4.35999965667725,151.501373291016 -4.23916625976562,151.5 -4.23388862609863,151.5 -4.22694492340088,151.503326416016 -4.21666622161865,151.508331298828 -4.20777797698975,151.511657714844 -4.20444488525391,151.536926269531 -4.18194389343262,151.783050537109 -4.20583343505859,151.841918945312 -4.22472190856934,151.852172851562 -4.22833347320557,151.857727050781 -4.23638820648193,151.859680175781 -4.24111080169678,151.861083984375 -4.24666690826416,151.863861
 083984 -4.27138900756836,151.869964599609 -4.28555583953857,151.878295898438 -4.29805564880371,151.884429931641 -4.30555534362793,151.895263671875 -4.3149995803833,151.904144287109 -4.32000064849854,151.9638671875 -4.33555603027344,151.969421386719 -4.33694458007812,151.974975585938 -4.33694458007812,151.984405517578 -4.33277797698975,151.991912841797 -4.32666683197021,152.138580322266 -4.20444488525391,152.141357421875 -4.20027828216553,152.145538330078 -4.19083309173584,152.150817871094 -4.17555522918701,152.153594970703 -4.16472244262695,152.153594970703 -4.15777778625488,152.156372070312 -4.15388870239258,152.161926269531 -4.14833354949951,152.166076660156 -4.14555549621582,152.171356201172 -4.14416694641113,152.177764892578 -4.14500045776367,152.185241699219 -4.14888954162598,152.214691162109 -4.16611099243164,152.235229492188 -4.2072229385376,152.239410400391 -4.21666622161865,152.2421875 -4.2344446182251,152.2421875 -4.24111080169678,152.240783691406 -4.24666690826416
 ,152.238006591797 -4.24805545806885,152.226898193359 -4.25083351135254,152.202453613281 -4.24666690826416,152.198303222656 -4.24388885498047,152.195526123047 -4.23999977111816,152.194122314453 -4.2344446182251,152.194122314453 -4.22749996185303,152.192749023438 -4.22222232818604,152.189971923828 -4.21805572509766,152.186645507812 -4.21472263336182,152.181640625 -4.21527767181396,152.176910400391 -4.21749973297119,152.172760009766 -4.22694492340088,152.16943359375 -4.24388885498047,152.170806884766 -4.28222274780273,152.171356201172 -4.28833293914795,152.172210693359 -4.29333305358887,152.174133300781 -4.29666709899902,152.1796875 -4.30472183227539,152.186645507812 -4.31166648864746,152.190521240234 -4.31444454193115,152.195526123047 -4.31638813018799,152.263885498047 -4.33500003814697,152.286651611328 -4.33972263336182,152.305236816406 -4.34166717529297,152.355804443359 -4.34305572509766,152.401641845703 -4.61083316802979,152.403045654297 -4.62305545806885,152.405242919922 -
 4.66888904571533,152.405822753906 -4.68888854980469,152.394989013672 -4.76111125946045,152.389434814453 -4.78305530548096,152.386108398438 -4.79333305358887,152.336090087891 -4.87527751922607,152.333312988281 -4.87916660308838,152.294128417969 -4.92916679382324,152.268035888672 -4.95777797698975,152.241333007812 -4.9844446182251,152.233306884766 -4.98999977111816,152.161102294922 -5.00694465637207,152.157196044922 -5.00694465637207,152.123565673828 -4.99944400787354,152.112457275391 -4.99666690826416,152.088562011719 -4.98638820648193,152.083038330078 -4.98499965667725,152.050262451172 -4.97972202301025,151.996612548828 -4.97277736663818,151.990509033203 -4.97222232818604,151.984954833984 -4.97361087799072,151.978302001953 -4.98027801513672,151.974975585938 -4.98388862609863,151.970794677734 -4.993332862854,151.968017578125 -5.0041675567627,151.966644287109 -5.02333354949951,151.964691162109 -5.10472202301025,151.969970703125 -5.14833354949951,151.97412109375 -5.157777786254
 88,151.979675292969 -5.16583347320557,151.993286132812 -5.17555522918701,152.069427490234 -5.23499965667725,152.07275390625 -5.23833274841309,152.118011474609 -5.29222202301025,152.124114990234 -5.29972171783447,152.129669189453 -5.30777740478516,152.144134521484 -5.34138870239258,152.145538330078 -5.34666728973389,152.147491455078 -5.36388874053955,152.144134521484 -5.37416648864746,152.131072998047 -5.40222263336182,152.123565673828 -5.41638851165771,152.096069335938 -5.4572229385376,151.972747802734 -5.53111171722412,151.968566894531 -5.53361129760742,151.841918945312 -5.59722232818604,151.825531005859 -5.60111141204834,151.818572998047 -5.60111141204834,151.808319091797 -5.5977783203125,151.779418945312 -5.58555603027344,151.771362304688 -5.58000087738037,151.759155273438 -5.55138874053955,151.752777099609 -5.54388904571533,151.748565673828 -5.54111099243164,151.705535888672 -5.53111171722412,151.699401855469 -5.53027820587158,151.491638183594 -5.52833366394043,151.47329
 7119141 -5.53027820587158,151.467742919922 -5.53166675567627,151.459411621094 -5.53583335876465,151.454132080078 -5.54111099243164,151.44384765625 -5.58555603027344,151.444427490234 -5.59166717529297,151.402770996094 -5.75137805938721,151.384704589844 -5.80720043182373,151.317779541016 -5.84993076324463,151.165649414062 -5.95807075500488,151.003051757812 -6.02250003814697,150.940795898438 -6.0286111831665,150.855804443359 -6.04083347320557,150.811920166016 -6.07638931274414,150.812744140625 -6.08944416046143,150.793304443359 -6.11805534362793,150.775543212891 -6.13916683197021,150.771636962891 -6.14166736602783,150.74609375 -6.13554954528809)),((154.153869628906 -4.44222164154053,154.128570556641 -4.3841667175293,154.126617431641 -4.37944412231445,154.128021240234 -4.37388896942139,154.132720947266 -4.37166595458984,154.140808105469 -4.37055492401123,154.150543212891 -4.37444400787354,154.152770996094 -4.37944412231445,154.1533203125 -4.3855562210083,154.155242919922 -4.4380
 5503845215,154.153869628906 -4.44222164154053)),((145.951354980469 -4.76444530487061,145.944427490234 -4.76444530487061,145.93359375 -4.76194477081299,145.918579101562 -4.75638961791992,145.898590087891 -4.74194431304932,145.891662597656 -4.73527717590332,145.875244140625 -4.69694423675537,145.873840332031 -4.69138813018799,145.872467041016 -4.67249965667725,145.873840332031 -4.66694450378418,145.892486572266 -4.6094446182251,145.8994140625 -4.59583377838135,145.904693603516 -4.58777809143066,145.914978027344 -4.57750034332275,145.966369628906 -4.53305530548096,145.970520019531 -4.53027820587158,145.975250244141 -4.52833366394043,145.981628417969 -4.52750015258789,146.011657714844 -4.5494441986084,146.026916503906 -4.56166648864746,146.053588867188 -4.5963888168335,146.055541992188 -4.60138893127441,146.054138183594 -4.66138935089111,146.04052734375 -4.70916652679443,146.037750244141 -4.71333408355713,146.027465820312 -4.72361087799072,146.019989013672 -4.72972202301025,145.
 994415283203 -4.74555492401123,145.961639404297 -4.76111125946045,145.951354980469 -4.76444530487061)),((159.513305664062 -4.58166694641113,159.511383056641 -4.57666683197021,159.515533447266 -4.53972244262695,159.518859863281 -4.5363883972168,159.522216796875 -4.55083274841309,159.523040771484 -4.56388854980469,159.519714355469 -4.57388973236084,159.516937255859 -4.57805633544922,159.513305664062 -4.58166694641113)),((149.552459716797 -4.72083377838135,149.546356201172 -4.72027778625488,149.475799560547 -4.71138954162598,149.470245361328 -4.71000003814697,149.465515136719 -4.70777797698975,149.461364746094 -4.70527839660645,149.457733154297 -4.70166683197021,149.455810546875 -4.69694423675537,149.454406738281 -4.68472194671631,149.455810546875 -4.67916679382324,149.468017578125 -4.66416645050049,149.506652832031 -4.64777851104736,149.512756347656 -4.64694499969482,149.518859863281 -4.64777851104736,149.529968261719 -4.65055561065674,149.540252685547 -4.65388870239258,149.54
 3579101562 -4.65722274780273,149.549133300781 -4.66555595397949,149.559967041016 -4.68194389343262,149.563293457031 -4.69222164154053,149.564147949219 -4.70527839660645,149.562744140625 -4.71055603027344,149.560516357422 -4.71527767181396,149.557189941406 -4.7188892364502,149.552459716797 -4.72083377838135)),((146.240509033203 -4.85805511474609,146.234405517578 -4.85750007629395,146.215789794922 -4.85138893127441,146.2119140625 -4.84861087799072,146.201629638672 -4.83833312988281,146.199401855469 -4.83361148834229,146.198028564453 -4.82805633544922,146.200256347656 -4.81638813018799,146.202178955078 -4.81166648864746,146.215789794922 -4.79111099243164,146.219970703125 -4.78833293914795,146.232177734375 -4.78833293914795,146.238555908203 -4.79055595397949,146.241333007812 -4.79333305358887,146.256927490234 -4.81166648864746,146.262481689453 -4.81972217559814,146.263885498047 -4.82527828216553,146.263885498047 -4.83083343505859,146.261932373047 -4.83555603027344,146.2508239746
 09 -4.85472202301025,146.246612548828 -4.85750007629395,146.240509033203 -4.85805511474609)),((149.152191162109 -4.92361068725586,149.133026123047 -4.91555595397949,149.128845214844 -4.9127779006958,149.122741699219 -4.90527820587158,149.118560791016 -4.89555549621582,149.118011474609 -4.88944435119629,149.119415283203 -4.8841667175293,149.122192382812 -4.88138866424561,149.156921386719 -4.86694431304932,149.161926269531 -4.86638832092285,149.165802001953 -4.86777782440186,149.175537109375 -4.87805557250977,149.178314208984 -4.88194370269775,149.181640625 -4.89222240447998,149.178863525391 -4.89638900756836,149.156921386719 -4.92305564880371,149.152191162109 -4.92361068725586)),((154.63720703125 -5.45861148834229,154.618011474609 -5.43138885498047,154.5869140625 -5.34472274780273,154.565795898438 -5.27666664123535,154.5302734375 -5.13388919830322,154.532196044922 -5.12222194671631,154.541076660156 -5.10388851165771,154.546630859375 -5.09555530548096,154.558319091797 -5.08000
 087738037,154.598846435547 -5.03083324432373,154.605529785156 -5.02388954162598,154.620513916016 -5.01861095428467,154.63916015625 -5.01638889312744,154.646087646484 -5.01638889312744,154.6513671875 -5.01777839660645,154.658874511719 -5.02388954162598,154.665802001953 -5.03083324432373,154.671356201172 -5.03888893127441,154.726898193359 -5.19722175598145,154.728302001953 -5.20277786254883,154.728302001953 -5.21638870239258,154.69384765625 -5.41833305358887,154.692474365234 -5.42388916015625,154.687194824219 -5.43194389343262,154.675537109375 -5.44083309173584,154.63720703125 -5.45861148834229)),((147.135528564453 -5.45111179351807,147.121887207031 -5.44444370269775,147.009979248047 -5.35499954223633,147.008026123047 -5.3502779006958,147.002471923828 -5.30388832092285,147.008026123047 -5.25888919830322,147.009979248047 -5.24722194671631,147.013610839844 -5.23833274841309,147.017761230469 -5.23555564880371,147.109405517578 -5.19333267211914,147.121063232422 -5.19111061096191,1
 47.128570556641 -5.19194412231445,147.134979248047 -5.19527721405029,147.191070556641 -5.248610496521,147.211639404297 -5.26916694641113,147.228851318359 -5.36388874053955,147.229949951172 -5.42111110687256,147.224670410156 -5.42944431304932,147.220520019531 -5.43194389343262,147.158874511719 -5.44833278656006,147.1533203125 -5.44972133636475,147.135528564453 -5.45111179351807)),((147.596618652344 -5.36305522918701,147.591918945312 -5.36111068725586,147.567199707031 -5.33916664123535,147.563873291016 -5.33583354949951,147.561645507812 -5.33111190795898,147.560516357422 -5.31888961791992,147.561645507812 -5.31333351135254,147.563873291016 -5.3086109161377,147.57080078125 -5.30166625976562,147.583038330078 -5.29361152648926,147.591918945312 -5.2902774810791,147.602172851562 -5.28805541992188,147.609130859375 -5.28805541992188,147.620788574219 -5.2902774810791,147.625518798828 -5.29222202301025,147.628845214844 -5.29555511474609,147.640533447266 -5.31666660308838,147.6427612304
 69 -5.3216667175293,147.643310546875 -5.32777786254883,147.642761230469 -5.33388900756836,147.640533447266 -5.3386116027832,147.626892089844 -5.35222244262695,147.602172851562 -5.3619441986084,147.596618652344 -5.36305522918701)),((148.114685058594 -5.4688892364502,148.087463378906 -5.45527839660645,148.079132080078 -5.44972133636475,148.077178955078 -5.44499969482422,148.073028564453 -5.43000030517578,148.071624755859 -5.4244441986084,148.072204589844 -5.41833305358887,148.084686279297 -5.38972282409668,148.090789794922 -5.38222217559814,148.099700927734 -5.3774995803833,148.117462158203 -5.3841667175293,148.122192382812 -5.38638877868652,148.136657714844 -5.39944458007812,148.139434814453 -5.40333366394043,148.143585205078 -5.41305541992188,148.144989013672 -5.41833305358887,148.145538330078 -5.43833255767822,148.143585205078 -5.44972133636475,148.138031005859 -5.45805549621582,148.133880615234 -5.46083354949951,148.125793457031 -5.4661111831665,148.120788574219 -5.4683332
 4432373,148.114685058594 -5.4688892364502)),((155.404083251953 -6,155.41552734375 -6.07638931274414,155.418853759766 -6.08666706085205,155.428588867188 -6.11111068725586,155.430541992188 -6.1158332824707,155.432739257812 -6.12083339691162,155.477172851562 -6.16916656494141,155.490783691406 -6.18277740478516,155.499114990234 -6.18805503845215,155.562744140625 -6.21749973297119,155.577178955078 -6.22361087799072,155.582733154297 -6.22500038146973,155.5888671875 -6.22416687011719,155.614959716797 -6.22000026702881,155.767761230469 -6.35583305358887,155.772491455078 -6.35777759552002,155.795257568359 -6.36250019073486,155.809692382812 -6.36861038208008,155.813598632812 -6.37138843536377,155.832733154297 -6.39861106872559,155.909698486328 -6.51222229003906,155.917755126953 -6.52444458007812,155.921905517578 -6.53416633605957,155.965789794922 -6.70555591583252,155.967193603516 -6.71111106872559,155.967742919922 -6.71722221374512,155.966644287109 -6.72277736663818,155.948028564453
 -6.77583312988281,155.940521240234 -6.78861141204834,155.918579101562 -6.80777740478516,155.913024902344 -6.80916595458984,155.909698486328 -6.80555534362793,155.908874511719 -6.7994441986084,155.890533447266 -6.77972221374512,155.860778808594 -6.77500057220459,155.854675292969 -6.77444458007812,155.848571777344 -6.77500057220459,155.823852539062 -6.77777767181396,155.816375732422 -6.78055572509766,155.775268554688 -6.81444454193115,155.748565673828 -6.84249973297119,155.742462158203 -6.84999942779541,155.719696044922 -6.875,155.713012695312 -6.88194370269775,155.707458496094 -6.88333320617676,155.69384765625 -6.88333320617676,155.623840332031 -6.868332862854,155.558868408203 -6.85249996185303,155.4921875 -6.83027839660645,155.47802734375 -6.82416725158691,155.444976806641 -6.80916595458984,155.342742919922 -6.74361133575439,155.3388671875 -6.74111080169678,155.335235595703 -6.73750019073486,155.239959716797 -6.62249946594238,155.192749023438 -6.56055545806885,155.2016296386
 72 -6.53472232818604,155.207183837891 -6.53472232818604,155.2099609375 -6.53055572509766,155.216064453125 -6.51638889312744,155.224975585938 -6.47749996185303,155.232452392578 -6.44416618347168,155.233306884766 -6.43805503845215,155.233306884766 -6.4244441986084,155.230529785156 -6.36305522918701,155.226348876953 -6.34694480895996,155.218841552734 -6.32916736602783,155.214141845703 -6.32027816772461,155.204406738281 -6.3086109161377,155.190795898438 -6.29500007629395,155.187194824219 -6.29166698455811,155.174987792969 -6.28333282470703,155.127746582031 -6.2761116027832,155.101623535156 -6.27722263336182,155.063293457031 -6.25694561004639,154.994110107422 -6.21666622161865,154.981628417969 -6.20861148834229,154.972198486328 -6.19777774810791,154.969970703125 -6.19277763366699,154.888580322266 -6.07916736602783,154.880249023438 -6.07361125946045,154.823577880859 -6.02805614471436,154.755645751953 -5.95617389678955,154.746643066406 -5.94450378417969,154.744384765625 -5.93978023
 529053,154.700469970703 -5.78020095825195,154.698577880859 -5.76851844787598,154.699432373047 -5.7623987197876,154.71826171875 -5.6700611114502,154.753601074219 -5.51805591583252,154.79052734375 -5.47916698455811,154.794128417969 -5.48250007629395,154.882446289062 -5.54333305358887,154.920806884766 -5.54999923706055,154.961090087891 -5.54666709899902,154.967468261719 -5.54611110687256,155.073577880859 -5.56166648864746,155.162353515625 -5.73234081268311,155.216064453125 -5.86872386932373,155.268798828125 -5.88423919677734,155.277679443359 -5.88895511627197,155.365020751953 -5.95777797698975,155.371643066406 -5.96472263336182,155.400543212891 -5.99583339691162,155.404083251953 -6)),((147.990478515625 -5.85603713989258,147.983520507812 -5.82075119018555,147.982116699219 -5.81519317626953,147.974609375 -5.79546737670898,147.972381591797 -5.79074478149414,147.968475341797 -5.78796863555908,147.945220947266 -5.77992534637451,147.93359375 -5.7777099609375,147.927490234375 -5.77854
 824066162,147.922790527344 -5.78049659729004,147.865112304688 -5.74775314331055,147.802154541016 -5.67277145385742,147.793273925781 -5.66138458251953,147.769958496094 -5.62221908569336,147.766052246094 -5.61277484893799,147.765228271484 -5.60666275024414,147.761108398438 -5.52833366394043,147.761932373047 -5.5222225189209,147.7802734375 -5.49416637420654,147.783874511719 -5.4908332824707,147.814697265625 -5.48472213745117,147.841918945312 -5.48999977111816,147.852172851562 -5.49361133575439,148.008605957031 -5.57611179351807,148.020812988281 -5.58416652679443,148.040802001953 -5.59861087799072,148.044128417969 -5.60194396972656,148.065307617188 -5.62758445739746,148.074279785156 -5.64482402801514,148.078460693359 -5.65427875518799,148.080444335938 -5.66595458984375,148.078552246094 -5.69124603271484,148.076629638672 -5.70347595214844,148.072540283203 -5.72654151916504,148.067840576172 -5.74905109405518,148.061492919922 -5.77711772918701,148.057586669922 -5.78656482696533,148
 .017150878906 -5.84463882446289,148.000762939453 -5.85269927978516,147.990478515625 -5.85603713989258)),((149.048034667969 -6.09555530548096,149.043304443359 -6.09333324432373,149.043853759766 -6.0886116027832,149.045257568359 -6.0872220993042,149.054138183594 -6.08388900756836,149.058319091797 -6.08666706085205,149.057739257812 -6.09138870239258,149.053588867188 -6.09416675567627,149.048034667969 -6.09555530548096)),((143.994415283203 -7.82583332061768,143.984680175781 -7.8230562210083,143.943572998047 -7.80277729034424,143.934692382812 -7.79805564880371,143.923583984375 -7.78861141204834,143.91748046875 -7.78111171722412,143.914703369141 -7.77694511413574,143.877746582031 -7.7186107635498,143.875793457031 -7.71388912200928,143.877166748047 -7.7097225189209,143.88134765625 -7.70694446563721,143.886657714844 -7.70833396911621,143.959411621094 -7.74222183227539,143.966918945312 -7.74833297729492,143.979125976562 -7.76333427429199,144.000549316406 -7.78999996185303,144.0080261
 23047 -7.80277729034424,144.009429931641 -7.80833339691162,144.008605957031 -7.81416606903076,144.006652832031 -7.819167137146,143.999694824219 -7.82444477081299,143.994415283203 -7.82583332061768)),((145.193572998047 -7.86722183227539,145.186645507812 -7.86722183227539,145.182464599609 -7.86444473266602,145.180541992188 -7.86111068725586,145.177764892578 -7.83666706085205,145.178314208984 -7.83055591583252,145.182464599609 -7.82777786254883,145.185241699219 -7.83055591583252,145.191345214844 -7.84083366394043,145.197479248047 -7.85499954223633,145.198852539062 -7.86055564880371,145.197479248047 -7.86444473266602,145.193572998047 -7.86722183227539)),((143.727752685547 -8.10222244262695,143.697479248047 -8.08444404602051,143.683319091797 -8.07833290100098,143.661376953125 -8.07277679443359,143.618011474609 -8.07222175598145,143.599700927734 -8.07416725158691,143.588562011719 -8.0716667175293,143.582458496094 -8.06416702270508,143.569427490234 -8.04305648803711,143.56607055664
 1 -8.03277778625488,143.565246582031 -8.02000045776367,143.568023681641 -8.01583480834961,143.574127197266 -8.01388931274414,143.629669189453 -8.00638961791992,143.635803222656 -8.00583457946777,143.642761230469 -8.00583457946777,143.651092529297 -8.00833511352539,143.66943359375 -8.0172233581543,143.682464599609 -8.02472305297852,143.697479248047 -8.03694534301758,143.707733154297 -8.04722213745117,143.731079101562 -8.0716667175293,143.737182617188 -8.07888793945312,143.739959716797 -8.08305549621582,143.741333007812 -8.0886116027832,143.739410400391 -8.09333229064941,143.733306884766 -8.10083198547363,143.727752685547 -8.10222244262695)),((143.66552734375 -8.17611122131348,143.654968261719 -8.17250061035156,143.625518798828 -8.15416717529297,143.621612548828 -8.15166664123535,143.618835449219 -8.14750099182129,143.607727050781 -8.13055419921875,143.604949951172 -8.11972045898438,143.604400634766 -8.11361122131348,143.604949951172 -8.10888862609863,143.609130859375 -8.10610
 961914062,143.636657714844 -8.09249877929688,143.642211914062 -8.09055519104004,143.654968261719 -8.0897216796875,143.679138183594 -8.09333229064941,143.688568115234 -8.09722137451172,143.700256347656 -8.10610961914062,143.707183837891 -8.11277770996094,143.710510253906 -8.11638832092285,143.716064453125 -8.12444305419922,143.718841552734 -8.13527870178223,143.719421386719 -8.15500068664551,143.7119140625 -8.16111183166504,143.702453613281 -8.1652774810791,143.683319091797 -8.1733341217041,143.677764892578 -8.17472267150879,143.66552734375 -8.17611122131348)),((143.685791015625 -8.24722099304199,143.659973144531 -8.241943359375,143.654418945312 -8.24055480957031,143.650268554688 -8.23777770996094,143.648315429688 -8.23305511474609,143.648864746094 -8.22694396972656,143.651641845703 -8.19972229003906,143.666656494141 -8.19305610656738,143.726898193359 -8.17388916015625,143.733306884766 -8.17472267150879,143.737182617188 -8.17722320556641,143.755828857422 -8.20527839660645,143
 .756378173828 -8.20861053466797,143.755249023438 -8.21388816833496,143.752471923828 -8.21805572509766,143.7421875 -8.22833251953125,143.734680175781 -8.23444366455078,143.718841552734 -8.23916625976562,143.697479248047 -8.24527740478516,143.685791015625 -8.24722099304199)),((143.687194824219 -8.43972206115723,143.680541992188 -8.43972206115723,143.670257568359 -8.43638801574707,143.651641845703 -8.42749977111816,143.630523681641 -8.40722274780273,143.610504150391 -8.38611221313477,143.584411621094 -8.3577766418457,143.607177734375 -8.33277702331543,143.612731933594 -8.33388900756836,143.653045654297 -8.34222221374512,143.658599853516 -8.3436107635498,143.66552734375 -8.34749984741211,143.672210693359 -8.35444450378418,143.677764892578 -8.36249923706055,143.692199707031 -8.39583396911621,143.694976806641 -8.40666770935059,143.698303222656 -8.42361068725586,143.698303222656 -8.43027877807617,143.696929931641 -8.43555641174316,143.692749023438 -8.43833351135254,143.687194824219
  -8.43972206115723)),((143.57275390625 -8.49388885498047,143.559143066406 -8.49388885498047,143.509155273438 -8.48250007629395,143.498016357422 -8.47972106933594,143.493286132812 -8.4777774810791,143.354949951172 -8.41805648803711,143.318572998047 -8.39305686950684,143.315795898438 -8.38888931274414,143.314422607422 -8.38361167907715,143.314422607422 -8.37666511535645,143.319427490234 -8.36916542053223,143.326904296875 -8.3630542755127,143.331634521484 -8.36111068725586,143.339141845703 -8.35833358764648,143.342742919922 -8.3577766418457,143.356353759766 -8.3577766418457,143.494689941406 -8.3630542755127,143.573577880859 -8.37194442749023,143.578308105469 -8.37388801574707,143.581085205078 -8.37805557250977,143.616058349609 -8.46277809143066,143.616058349609 -8.4688892364502,143.613861083984 -8.47360992431641,143.610504150391 -8.47694396972656,143.583862304688 -8.49138832092285,143.578857421875 -8.49333190917969,143.57275390625 -8.49388885498047)),((143.632446289062 -8.73444
 366455078,143.60107421875 -8.6924991607666,143.585784912109 -8.67972183227539,143.487731933594 -8.62888717651367,143.3671875 -8.54472351074219,143.278869628906 -8.51027870178223,143.269989013672 -8.50555610656738,143.252777099609 -8.49527740478516,143.240509033203 -8.48722076416016,143.182189941406 -8.42972183227539,143.180816650391 -8.42416763305664,143.18359375 -8.42000007629395,143.211639404297 -8.4152774810791,143.217742919922 -8.41611099243164,143.227447509766 -8.42611122131348,143.233032226562 -8.43444442749023,143.251373291016 -8.45666694641113,143.261657714844 -8.46694374084473,143.274688720703 -8.47444343566895,143.324676513672 -8.48583221435547,143.371337890625 -8.49388885498047,143.422760009766 -8.51083374023438,143.467193603516 -8.52777862548828,143.644134521484 -8.66472244262695,143.647491455078 -8.66805648803711,143.651641845703 -8.67777824401855,143.653045654297 -8.68305587768555,143.653594970703 -8.68916702270508,143.653045654297 -8.7005558013916,143.64135742
 1875 -8.72972106933594,143.638031005859 -8.73305511474609,143.632446289062 -8.73444366455078)),((151.144439697266 -8.8305549621582,151.094970703125 -8.7711124420166,151.10107421875 -8.63888931274414,151.05859375 -8.55166625976562,151.052459716797 -8.55222320556641,151.034698486328 -8.55222320556641,151.029144287109 -8.55083274841309,151.003051757812 -8.54277801513672,150.999694824219 -8.53944396972656,150.997741699219 -8.53472328186035,150.996917724609 -8.52861213684082,150.997741699219 -8.52250099182129,151.024993896484 -8.46694374084473,151.033325195312 -8.45472145080566,151.054412841797 -8.43499946594238,151.062744140625 -8.42972183227539,151.076354980469 -8.42611122131348,151.118286132812 -8.42000007629395,151.124969482422 -8.42000007629395,151.124969482422 -8.42555618286133,151.123840332031 -8.62472152709961,151.103302001953 -8.72916603088379,151.102447509766 -8.741943359375,151.103851318359 -8.7541675567627,151.107177734375 -8.76444625854492,151.144439697266 -8.8305549
 621582)),((152.835510253906 -9.23555564880371,152.829956054688 -9.22333335876465,152.679962158203 -9.09055519104004,152.6533203125 -9.06972122192383,152.649139404297 -9.06694412231445,152.573028564453 -9.02027893066406,152.563598632812 -9.01611137390137,152.556640625 -9.01611137390137,152.540252685547 -9.02027893066406,152.499694824219 -9.02500152587891,152.497741699219 -9.02166748046875,152.5244140625 -8.99305534362793,152.527770996094 -8.98972129821777,152.532470703125 -8.98777770996094,152.619689941406 -8.96138954162598,152.625793457031 -8.96055603027344,152.647216796875 -8.96138954162598,152.8046875 -8.96944427490234,152.810241699219 -8.97083282470703,152.814971923828 -8.97277641296387,152.93359375 -9.04388999938965,152.937744140625 -9.04666709899902,152.952758789062 -9.05888938903809,153.017761230469 -9.11777687072754,153.020538330078 -9.12166595458984,153.019989013672 -9.12638854980469,153.002777099609 -9.16500091552734,152.997192382812 -9.17305564880371,152.9930114746
 09 -9.17583274841309,152.98828125 -9.17777824401855,152.982177734375 -9.17722320556641,152.835510253906 -9.23555564880371)),((150.334411621094 -9.52666664123535,150.310241699219 -9.5261116027832,150.193023681641 -9.45388793945312,150.180816650391 -9.44555473327637,150.173858642578 -9.43888854980469,150.110778808594 -9.37277603149414,150.108306884766 -9.36861038208008,150.103302001953 -9.33694458007812,150.102752685547 -9.33083343505859,150.104125976562 -9.31861114501953,150.106903076172 -9.30777740478516,150.123291015625 -9.2630558013916,150.126068115234 -9.26027870178223,150.143859863281 -9.24555397033691,150.189147949219 -9.21111106872559,150.198028564453 -9.20777702331543,150.206909179688 -9.2055549621582,150.2138671875 -9.2055549621582,150.232177734375 -9.20777702331543,150.326904296875 -9.26916694641113,150.330810546875 -9.27194595336914,150.333038330078 -9.27666664123535,150.376892089844 -9.38333320617676,150.37744140625 -9.38944435119629,150.363006591797 -9.4874992370
 6055,150.344696044922 -9.51666641235352,150.339141845703 -9.52472305297852,150.334411621094 -9.52666664123535)),((150.846923828125 -9.71805572509766,150.844116210938 -9.68555641174316,150.801635742188 -9.65861129760742,150.763305664062 -9.66250038146973,150.691345214844 -9.66333389282227,150.661102294922 -9.66333389282227,150.654968261719 -9.66250038146973,150.622741699219 -9.65388870239258,150.514434814453 -9.62333297729492,150.490509033203 -9.58361053466797,150.427459716797 -9.44083404541016,150.423309326172 -9.43138885498047,150.419982910156 -9.41472244262695,150.419982910156 -9.4011116027832,150.421905517578 -9.38944435119629,150.426086425781 -9.37666511535645,150.435791015625 -9.35916519165039,150.442474365234 -9.35499954223633,150.473571777344 -9.33888816833496,150.478851318359 -9.33749961853027,150.481628417969 -9.33694458007812,150.487731933594 -9.33749961853027,150.498840332031 -9.34027671813965,150.505554199219 -9.34222221374512,150.5302734375 -9.35166549682617,150
 .571350097656 -9.37055397033691,150.598022460938 -9.38500022888184,150.618011474609 -9.39777946472168,150.624969482422 -9.40444564819336,150.63525390625 -9.42194557189941,150.639434814453 -9.42472267150879,150.666656494141 -9.43833351135254,150.676910400391 -9.4416675567627,150.683044433594 -9.44083404541016,150.731903076172 -9.42805671691895,150.7421875 -9.42472267150879,150.746063232422 -9.42138862609863,150.748291015625 -9.41805648803711,150.754974365234 -9.40444564819336,150.760528564453 -9.40444564819336,150.765258789062 -9.4063892364502,150.777770996094 -9.41472244262695,150.804412841797 -9.43277740478516,150.828308105469 -9.45638847351074,150.885803222656 -9.52083396911621,150.888031005859 -9.52555656433105,150.931915283203 -9.64166831970215,150.932464599609 -9.64777946472168,150.930541992188 -9.65916633605957,150.921630859375 -9.67083358764648,150.906646728516 -9.68277740478516,150.901092529297 -9.68138885498047,150.896362304688 -9.67416763305664,150.893585205078 -9.
 67194557189941,150.888580322266 -9.67138862609863,150.876892089844 -9.67749977111816,150.873565673828 -9.68083381652832,150.846923828125 -9.71805572509766)),((151.229125976562 -10.2011108398438,151.19775390625 -10.1727771759033,151.190246582031 -10.1669454574585,151.148315429688 -10.1472234725952,151.143585205078 -10.1452789306641,151.086639404297 -10.1269435882568,151.075805664062 -10.1244430541992,151.025817871094 -10.1141662597656,151.001647949219 -10.1108322143555,150.994964599609 -10.1108322143555,150.983306884766 -10.1127777099609,150.970245361328 -10.1122207641602,150.958587646484 -10.1102771759033,150.94970703125 -10.1055545806885,150.91552734375 -10.0041675567627,150.877746582031 -9.92666625976562,150.826904296875 -9.83888816833496,150.762481689453 -9.80500030517578,150.758605957031 -9.80249977111816,150.750274658203 -9.74833297729492,150.748840332031 -9.73083305358887,150.757202148438 -9.71194458007812,150.759979248047 -9.70777702331543,150.763885498047 -9.70499992
 370605,150.769439697266 -9.70666694641113,150.788024902344 -9.71944427490234,150.803039550781 -9.73138809204102,150.821624755859 -9.74694442749023,150.900268554688 -9.81916618347168,150.931915283203 -9.8488883972168,150.938873291016 -9.85583305358887,150.962738037109 -9.89361190795898,151.030548095703 -9.98527717590332,151.039428710938 -9.99694442749023,151.059967041016 -10.0169448852539,151.073028564453 -10.0244445800781,151.111358642578 -10.0447244644165,151.116058349609 -10.046667098999,151.122467041016 -10.0475006103516,151.136657714844 -10.041389465332,151.147216796875 -10.0325012207031,151.149139404297 -10.0277786254883,151.149719238281 -10.0219459533691,151.147766113281 -10.0169448852539,151.143585205078 -10.0088901519775,151.140808105469 -10.0050010681152,151.136657714844 -10.0022239685059,151.134704589844 -9.99749946594238,151.134704589844 -9.9908332824707,151.138031005859 -9.98749923706055,151.184143066406 -9.94472312927246,151.192199707031 -9.93944358825684,151.20
 0531005859 -9.93666648864746,151.26416015625 -9.91972160339355,151.281372070312 -9.9233341217041,151.284149169922 -9.92722320556641,151.298583984375 -9.95083236694336,151.299133300781 -9.96249961853027,151.296356201172 -9.97305488586426,151.271087646484 -10.0616655349731,151.252471923828 -10.0974998474121,151.246337890625 -10.1047210693359,151.243560791016 -10.1088886260986,151.234130859375 -10.1330547332764,151.221618652344 -10.1708335876465,151.221618652344 -10.1816673278809,151.222473144531 -10.1877784729004,151.223846435547 -10.1930561065674,151.229125976562 -10.2011108398438)),((150.880523681641 -10.6527786254883,150.856353759766 -10.6494445800781,150.794128417969 -10.6394443511963,150.785247802734 -10.6347236633301,150.769439697266 -10.6111106872559,150.767486572266 -10.6075000762939,150.788024902344 -10.5463886260986,150.790802001953 -10.5422229766846,150.794708251953 -10.539722442627,150.798858642578 -10.5383338928223,150.868835449219 -10.5383338928223,150.8749694824
 22 -10.5388889312744,150.892211914062 -10.547779083252,150.900268554688 -10.5530548095703,150.904418945312 -10.5625,150.894989013672 -10.6466665267944,150.892211914062 -10.6508331298828,150.880523681641 -10.6527786254883)),((150.927185058594 -10.6838893890381,150.923034667969 -10.6825008392334,150.920257568359 -10.6783332824707,150.911926269531 -10.65944480896,150.909973144531 -10.6547222137451,150.909149169922 -10.6419448852539,150.909973144531 -10.6358337402344,150.91943359375 -10.6130542755127,150.922210693359 -10.6088886260986,150.9296875 -10.6030540466309,150.934692382812 -10.6008319854736,150.94970703125 -10.59694480896,151.016082763672 -10.5908336639404,151.064147949219 -10.5922222137451,151.066925048828 -10.5947227478027,151.06884765625 -10.5980548858643,151.069702148438 -10.6111106872559,151.063293457031 -10.6438903808594,151.049133300781 -10.6702785491943,151.042205810547 -10.676944732666,151.036651611328 -10.6783332824707,151.031372070312 -10.676944732666,151.0099
 79248047 -10.6683330535889,151.008026123047 -10.6636123657227,151.003875732422 -10.6472234725952,151.001647949219 -10.6427783966064,150.994110107422 -10.6366672515869,150.988861083984 -10.6352787017822,150.941345214844 -10.6347236633301,150.936096191406 -10.6347236633301,150.929138183594 -10.6547222137451,150.927185058594 -10.6838893890381)),((152.744415283203 -10.7166652679443,152.702453613281 -10.7066669464111,152.686920166016 -10.7019443511963,152.573852539062 -10.6569442749023,152.564971923828 -10.6522235870361,152.544982910156 -10.6380558013916,152.541656494141 -10.6338901519775,152.540802001953 -10.6305541992188,152.542205810547 -10.6277770996094,152.555236816406 -10.6230554580688,152.562194824219 -10.6230554580688,152.573852539062 -10.6252765655518,152.614959716797 -10.6386127471924,152.690246582031 -10.6627788543701,152.693023681641 -10.6627788543701,152.759429931641 -10.6372222900391,152.784973144531 -10.6211109161377,152.790252685547 -10.6197204589844,152.814971923
 828 -10.6291656494141,152.870513916016 -10.6580562591553,152.873291015625 -10.6622219085693,152.873840332031 -10.6683330535889,152.873291015625 -10.6730556488037,152.870513916016 -10.676944732666,152.863586425781 -10.6825008392334,152.844970703125 -10.6952781677246,152.814971923828 -10.6966667175293,152.744415283203 -10.7166652679443)),((153.210510253906 -11.2858333587646,153.181640625 -11.2522239685059,153.143859863281 -11.2247219085693,153.13916015625 -11.2227764129639,153.120513916016 -11.2166652679443,153.114959716797 -11.2152767181396,153.106079101562 -11.2147216796875,153.093292236328 -11.2019443511963,153.091064453125 -11.1972217559814,153.093841552734 -11.1930561065674,153.102172851562 -11.1888885498047,153.112457275391 -11.1844444274902,153.123840332031 -11.1849994659424,153.12939453125 -11.1863880157471,153.198028564453 -11.2172222137451,153.2138671875 -11.2247219085693,153.222747802734 -11.2294454574585,153.251373291016 -11.2469444274902,153.250579833984 -11.25,15
 3.25 -11.2522239685059,153.241058349609 -11.2688903808594,153.210510253906 -11.2858333587646)),((154.112182617188 -11.4397220611572,154.106628417969 -11.4397220611572,154.062744140625 -11.4330558776855,154.058013916016 -11.4308338165283,154.006652832031 -11.3872222900391,154.003326416016 -11.3838901519775,154.021087646484 -11.3488883972168,154.089691162109 -11.3152770996094,154.153869628906 -11.3141670227051,154.225250244141 -11.3194446563721,154.268310546875 -11.338888168335,154.276641845703 -11.344165802002,154.286376953125 -11.3605556488037,154.288299560547 -11.3649997711182,154.297760009766 -11.3919448852539,154.289703369141 -11.4108333587646,154.285522460938 -11.4136123657227,154.266387939453 -11.421667098999,154.263031005859 -11.4180555343628,154.26025390625 -11.4075012207031,154.256103515625 -11.4047222137451,154.250549316406 -11.4033336639404,154.190246582031 -11.3994445800781,154.137481689453 -11.3986110687256,154.134704589844 -11.4027786254883,154.112182617188 -11.
 4397220611572)),((153.566070556641 -11.6424999237061,153.522216796875 -11.602222442627,153.479125976562 -11.5733337402344,153.421356201172 -11.5686111450195,153.376068115234 -11.5672225952148,153.3671875 -11.557222366333,153.364410400391 -11.5530548095703,153.363861083984 -11.5472221374512,153.376068115234 -11.5269451141357,153.382446289062 -11.5197219848633,153.38720703125 -11.5108337402344,153.388580322266 -11.5055561065674,153.387756347656 -11.5008344650269,153.384429931641 -11.4974994659424,153.325531005859 -11.4752769470215,153.276916503906 -11.4624996185303,153.271911621094 -11.4605560302734,153.268585205078 -11.4572219848633,153.190521240234 -11.3730554580688,153.188293457031 -11.3683319091797,153.187194824219 -11.3536109924316,153.187194824219 -11.3497219085693,153.198028564453 -11.3241672515869,153.200805664062 -11.3199996948242,153.220520019531 -11.3274993896484,153.291931152344 -11.3569431304932,153.398040771484 -11.4047222137451,153.413879394531 -11.4161109924316
 ,153.426910400391 -11.4302787780762,153.437744140625 -11.4397220611572,153.507751464844 -11.4724998474121,153.559143066406 -11.491943359375,153.570251464844 -11.494722366333,153.576354980469 -11.4955539703369,153.645538330078 -11.5150012969971,153.686645507812 -11.5269451141357,153.751098632812 -11.5644445419312,153.754425048828 -11.5680561065674,153.7763671875 -11.5974998474121,153.777770996094 -11.6027765274048,153.7763671875 -11.6080551147461,153.7744140625 -11.6130542755127,153.770812988281 -11.6163883209229,153.676361083984 -11.6283321380615,153.670257568359 -11.6277770996094,153.605804443359 -11.6174983978271,153.598846435547 -11.6174983978271,153.582458496094 -11.6283321380615,153.566070556641 -11.6424999237061)))
-  </a>
-<test>
-  <op name='buffer' arg1='A' arg2='0.0' arg3='1'>
- MULTIPOLYGON(((144.520538330078 -1.12083339691162,144.516387939453 -1.12083339691162,144.514434814453 -1.11611104011536,144.514984130859 -1.10305547714233,144.517211914062 -1.09833335876465,144.521362304688 -1.09972214698792,144.522491455078 -1.10527777671814,144.523315429688 -1.11138892173767,144.522491455078 -1.11611104011536,144.520538330078 -1.12083339691162)),((149.731903076172 -1.60333347320557,149.715515136719 -1.57861113548279,149.7099609375 -1.57027792930603,149.703308105469 -1.56361126899719,149.699127197266 -1.56083345413208,149.681915283203 -1.55722236633301,149.680541992188 -1.56277775764465,149.681915283203 -1.57527780532837,149.681365966797 -1.5813889503479,149.678588867188 -1.58555555343628,149.673034667969 -1.58694458007812,149.663299560547 -1.58277773857117,149.659423828125 -1.58000016212463,149.558013916016 -1.50055575370789,149.533325195312 -1.469722032547,149.530548095703 -1.46555542945862,149.527770996094 -1.45444440841675,149.528594970703 -1.448333263
 39722,149.542755126953 -1.41472220420837,149.544982910156 -1.41000008583069,149.564147949219 -1.37027788162231,149.579956054688 -1.35527777671814,149.622467041016 -1.35944437980652,149.627166748047 -1.36138892173767,149.663299560547 -1.38666677474976,149.710784912109 -1.42166662216187,149.716918945312 -1.42916655540466,149.719696044922 -1.43333315849304,149.790252685547 -1.57666683197021,149.790802001953 -1.5813889503479,149.731903076172 -1.60333347320557)),((144.517761230469 -1.39833331108093,144.506103515625 -1.38944435119629,144.503326416016 -1.38555550575256,144.505554199219 -1.38055562973022,144.516387939453 -1.38194441795349,144.519989013672 -1.38555550575256,144.521911621094 -1.39555549621582,144.517761230469 -1.39833331108093)),((142.818298339844 -1.73333311080933,142.813598632812 -1.73277759552002,142.812194824219 -1.72722220420837,142.812744140625 -1.72111105918884,142.818298339844 -1.69972205162048,142.821075439453 -1.69583320617676,142.832183837891 -1.69361114501
 953,142.863006591797 -1.69444441795349,142.866363525391 -1.69777774810791,142.866912841797 -1.70944428443909,142.864410400391 -1.71361112594604,142.859405517578 -1.71555542945862,142.852752685547 -1.70861101150513,142.847198486328 -1.70722222328186,142.841644287109 -1.70861101150513,142.837463378906 -1.71138882637024,142.818298339844 -1.73333311080933)),((147.391937255859 -1.96083331108093,147.399993896484 -1.96638870239258,147.430816650391 -1.9902777671814,147.434417724609 -1.99361109733582,147.44580078125 -2.00944471359253,147.448028564453 -2.01416683197021,147.447204589844 -2.0188889503479,147.439697265625 -2.06083345413208,147.437744140625 -2.06555557250977,147.426086425781 -2.06777811050415,147.275268554688 -2.1211109161377,147.255554199219 -2.14916658401489,147.239135742188 -2.16694450378418,147.22802734375 -2.17638874053955,147.212188720703 -2.18805551528931,147.207458496094 -2.19027757644653,147.201904296875 -2.19166660308838,146.980529785156 -2.1991662979126,146.893
 035888672 -2.18944406509399,146.8388671875 -2.18194437026978,146.798309326172 -2.16888904571533,146.793579101562 -2.16694450378418,146.726348876953 -2.16083335876465,146.571624755859 -2.23472213745117,146.568023681641 -2.23666667938232,146.563293457031 -2.23472213745117,146.5283203125 -2.20111131668091,146.524993896484 -2.19083309173584,146.518035888672 -2.1497220993042,146.518859863281 -2.14361143112183,146.578308105469 -2.00194454193115,146.580535888672 -1.99722218513489,146.583862304688 -1.99361109733582,146.638580322266 -1.97861099243164,146.844970703125 -1.95055556297302,146.857177734375 -1.94916653633118,146.869689941406 -1.94916653633118,147.093566894531 -1.96638870239258,147.099975585938 -1.96694445610046,147.118286132812 -1.96888875961304,147.164428710938 -1.98333311080933,147.203308105469 -2.003333568573,147.300811767578 -2.02527761459351,147.417755126953 -2.05055570602417,147.419982910156 -2.04583358764648,147.422760009766 -2.03472232818604,147.422760009766 -2.029
 16669845581,147.420532226562 -2.01083374023438,147.418579101562 -2.00583362579346,147.391937255859 -1.96083331108093)),((147.756927490234 -2.35249996185303,147.766662597656 -2.32388925552368,147.795532226562 -2.26500034332275,147.815246582031 -2.24361133575439,147.832458496094 -2.24555540084839,147.877746582031 -2.28944444656372,147.879119873047 -2.29361152648926,147.856353759766 -2.3313889503479,147.848297119141 -2.33666658401489,147.829132080078 -2.34555530548096,147.824127197266 -2.34777784347534,147.81884765625 -2.34916639328003,147.812469482422 -2.34972190856934,147.756927490234 -2.35249996185303)),((150.367736816406 -2.68666648864746,150.356353759766 -2.66805553436279,150.347473144531 -2.66333341598511,150.341064453125 -2.66249990463257,150.273315429688 -2.67277765274048,150.257476806641 -2.6777777671814,150.242462158203 -2.68305540084839,150.190521240234 -2.68583297729492,150.184143066406 -2.68527746200562,150.109405517578 -2.625,149.972473144531 -2.50111150741577,149
 .965789794922 -2.4941668510437,149.949127197266 -2.47638845443726,149.948577880859 -2.47166633605957,149.951354980469 -2.46749973297119,149.960784912109 -2.46000003814697,150.079956054688 -2.41416645050049,150.189697265625 -2.37722206115723,150.206085205078 -2.37444448471069,150.216369628906 -2.37777757644653,150.248016357422 -2.39000034332275,150.417205810547 -2.46055555343628,150.443298339844 -2.47583293914795,150.446075439453 -2.47972202301025,150.467193603516 -2.54472255706787,150.468017578125 -2.55777788162231,150.459686279297 -2.64833354949951,150.458312988281 -2.6536111831665,150.448852539062 -2.66472196578979,150.443298339844 -2.66611099243164,150.41943359375 -2.66249990463257,150.406921386719 -2.66388893127441,150.4013671875 -2.6652774810791,150.371887207031 -2.68388891220093,150.367736816406 -2.68666648864746)),((152.659423828125 -3.84277772903442,152.670837402344 -3.85989284515381,152.701080322266 -3.88305521011353,152.739685058594 -3.89611101150513,152.7697143554
 69 -3.90027761459351,152.919128417969 -4.0041675567627,152.989685058594 -4.07583332061768,153.006927490234 -4.09361171722412,153.118560791016 -4.23916625976562,153.12939453125 -4.25555610656738,153.131622314453 -4.26027870178223,153.134429931641 -4.27138900756836,153.132171630859 -4.37861061096191,153.130798339844 -4.39083385467529,153.128021240234 -4.39500045776367,153.121337890625 -4.40194416046143,153.108856201172 -4.40999984741211,153.092468261719 -4.42083358764648,153.080810546875 -4.43000030517578,153.066375732422 -4.44277763366699,153.063018798828 -4.44638824462891,153.0546875 -4.45861148834229,153.04052734375 -4.48527717590332,153.039154052734 -4.49749946594238,153.039703369141 -4.50361156463623,153.041076660156 -4.5091667175293,153.043304443359 -4.51388931274414,153.046630859375 -4.51722240447998,153.059692382812 -4.52555561065674,153.066375732422 -4.53222274780273,153.077453613281 -4.54861068725586,153.079406738281 -4.58916664123535,153.077453613281 -4.600555419921
 88,152.980255126953 -4.7605562210083,152.974670410156 -4.76666641235352,152.910247802734 -4.82333374023438,152.891662597656 -4.82250022888184,152.743560791016 -4.67305564880371,152.735504150391 -4.66083335876465,152.733306884766 -4.6561107635498,152.693023681641 -4.55833339691162,152.681365966797 -4.5222225189209,152.664978027344 -4.4688892364502,152.662750244141 -4.4572229385376,152.666381835938 -4.45388889312744,152.678588867188 -4.44555473327637,152.681365966797 -4.44138813018799,152.692199707031 -4.39361190795898,152.69775390625 -4.36499977111816,152.69775390625 -4.35805511474609,152.694427490234 -4.19138813018799,152.693572998047 -4.18527698516846,152.691650390625 -4.18055534362793,152.603302001953 -4.00611114501953,152.581909179688 -3.96583318710327,152.538726806641 -3.90009546279907,152.512176513672 -3.8687310218811,152.491577148438 -3.85225462913513,152.374969482422 -3.7277774810791,152.359954833984 -3.70472240447998,152.357177734375 -3.69361114501953,152.35662841796
 9 -3.6875,152.358001708984 -3.66166639328003,152.355224609375 -3.65055561065674,152.349700927734 -3.64249992370605,152.289428710938 -3.57944440841675,152.282470703125 -3.57277774810791,152.190521240234 -3.50888919830322,152.182464599609 -3.50361156463623,152.156372070312 -3.48861122131348,152.151641845703 -3.48638868331909,152.146087646484 -3.4850001335144,152.136657714844 -3.48916673660278,152.131072998047 -3.49055576324463,152.124969482422 -3.49000024795532,151.984405517578 -3.46444463729858,151.956359863281 -3.45833349227905,151.934967041016 -3.44555521011353,151.758331298828 -3.32444477081299,151.708862304688 -3.28055572509766,151.688293457031 -3.25305557250977,151.620513916016 -3.17722225189209,151.6171875 -3.17388916015625,151.608306884766 -3.16916656494141,151.574676513672 -3.1594443321228,151.532745361328 -3.14499998092651,151.493011474609 -3.13000011444092,151.483581542969 -3.12583303451538,151.462188720703 -3.11305570602417,151.455535888672 -3.1061110496521,151.452
 758789062 -3.10194444656372,151.450531005859 -3.09722232818604,151.449981689453 -3.08416652679443,151.448577880859 -3.07888889312744,151.44384765625 -3.06972217559814,151.438293457031 -3.06361103057861,151.417205810547 -3.05055570602417,151.369689941406 -3.02250003814697,151.281372070312 -2.97416639328003,151.237457275391 -2.95361137390137,151.214965820312 -2.94194412231445,151.150543212891 -2.89527797698975,151.122467041016 -2.86861085891724,151.119689941406 -2.86444473266602,151.113586425781 -2.8502779006958,151.110778808594 -2.84611082077026,151.106628417969 -2.84333324432373,151.004425048828 -2.78916692733765,150.999694824219 -2.78722238540649,150.930541992188 -2.76861095428467,150.923583984375 -2.76861095428467,150.903045654297 -2.77138900756836,150.876342773438 -2.77611112594604,150.861907958984 -2.78249979019165,150.832458496094 -2.78722238540649,150.819427490234 -2.7877779006958,150.754425048828 -2.77083349227905,150.750274658203 -2.76805543899536,150.729675292969 -2
 .74055576324463,150.730529785156 -2.7344446182251,150.733856201172 -2.7311110496521,150.747467041016 -2.71749973297119,150.752471923828 -2.71527767181396,150.763305664062 -2.7180552482605,150.824401855469 -2.71527767181396,150.874969482422 -2.71250009536743,150.88720703125 -2.71111106872559,150.891357421875 -2.70833349227905,150.894989013672 -2.70499992370605,150.896942138672 -2.70027780532837,150.885650634766 -2.6851110458374,150.884307861328 -2.67811107635498,150.876983642578 -2.65594434738159,150.875640869141 -2.65294456481934,150.873641967773 -2.65094447135925,150.867797851562 -2.64844417572021,150.861633300781 -2.64977788925171,150.856292724609 -2.65261125564575,150.853134155273 -2.65344452857971,150.838012695312 -2.64277791976929,150.831909179688 -2.64222240447998,150.822204589844 -2.6380558013916,150.792755126953 -2.61666631698608,150.805816650391 -2.56666660308838,150.807739257812 -2.56333351135254,150.811370849609 -2.55999994277954,150.817474365234 -2.559166431427,1
 50.834686279297 -2.57083368301392,150.838012695312 -2.57416677474976,150.906524658203 -2.63594436645508,150.964691162109 -2.68722200393677,150.968841552734 -2.69000005722046,151.086639404297 -2.75027799606323,151.190246582031 -2.82611131668091,151.280822753906 -2.87083339691162,151.311370849609 -2.86999988555908,151.419128417969 -2.89805555343628,151.427185058594 -2.9036111831665,151.464416503906 -2.93499994277954,151.598022460938 -3.02750015258789,151.641937255859 -3.04805564880371,151.717742919922 -3.11555576324463,151.72607421875 -3.12805557250977,151.815246582031 -3.19777774810791,151.820526123047 -3.1991662979126,151.825531005859 -3.1972222328186,151.833587646484 -3.19166660308838,151.855529785156 -3.18611097335815,151.861907958984 -3.18694448471069,151.921905517578 -3.20333337783813,151.948852539062 -3.21083354949951,152.055816650391 -3.24777793884277,152.054412841797 -3.26000022888184,152.054412841797 -3.27361106872559,152.057739257812 -3.28388929367065,152.1647033691
 41 -3.41111087799072,152.204406738281 -3.45444440841675,152.210510253906 -3.46055555343628,152.238006591797 -3.47833299636841,152.252471923828 -3.4844446182251,152.277191162109 -3.49472236633301,152.306640625 -3.50638914108276,152.327178955078 -3.51999998092651,152.355224609375 -3.54000043869019,152.361907958984 -3.54666709899902,152.367462158203 -3.55499982833862,152.392211914062 -3.59861087799072,152.411926269531 -3.63361120223999,152.488006591797 -3.64916658401489,152.493011474609 -3.64861106872559,152.496917724609 -3.65138864517212,152.503051757812 -3.6588888168335,152.511383056641 -3.67111110687256,152.553314208984 -3.74583339691162,152.556640625 -3.756667137146,152.555816650391 -3.76944446563721,152.549713134766 -3.78388929367065,152.546356201172 -3.79416704177856,152.549133300781 -3.79833364486694,152.573852539062 -3.8216667175293,152.577758789062 -3.82444477081299,152.582733154297 -3.82638883590698,152.603302001953 -3.83305549621582,152.659423828125 -3.84277772903442
 )),((149.6640625 -10.3398141860962,149.639434814453 -10.3413887023926,149.572204589844 -10.3413887023926,149.566925048828 -10.3413887023926,149.536651611328 -10.361665725708,149.335784912109 -10.307222366333,149.224975585938 -10.2761116027832,149.186645507812 -10.2600002288818,149.176361083984 -10.2563896179199,149.161102294922 -10.2511119842529,149.139984130859 -10.2449989318848,149.093292236328 -10.2341651916504,149.049407958984 -10.2424983978271,149.03857421875 -10.2449989318848,148.993835449219 -10.2605571746826,148.981628417969 -10.268611907959,148.934967041016 -10.2672233581543,148.79443359375 -10.2391662597656,148.723297119141 -10.1869449615479,148.680267333984 -10.1494445800781,148.677459716797 -10.1533336639404,148.642486572266 -10.1863880157471,148.637481689453 -10.1883344650269,148.468292236328 -10.2038879394531,148.462738037109 -10.2038879394531,148.4033203125 -10.2005558013916,148.372467041016 -10.1919441223145,148.3369140625 -10.1797218322754,148.332733154297 -
 10.176944732666,148.327178955078 -10.1688899993896,148.322479248047 -10.1599998474121,148.314971923828 -10.1405563354492,148.312194824219 -10.1363887786865,148.3046875 -10.130277633667,148.157562255859 -10.0737085342407,148.154418945312 -10.0791664123535,148.150543212891 -10.0952777862549,148.148315429688 -10.0999984741211,148.115509033203 -10.1216659545898,148.10302734375 -10.1297206878662,148.0888671875 -10.1358337402344,148.083312988281 -10.1372222900391,148.055236816406 -10.1433334350586,147.999694824219 -10.1519451141357,147.952453613281 -10.1458339691162,147.940795898438 -10.1211109161377,147.923034667969 -10.0980548858643,147.872192382812 -10.0475006103516,147.86328125 -10.0427780151367,147.857727050781 -10.0427780151367,147.781097412109 -10.0508327484131,147.775543212891 -10.0522232055664,147.766082763672 -10.0561103820801,147.619964599609 -9.9908332824707,147.612457275391 -9.98472213745117,147.601348876953 -9.97527694702148,147.574127197266 -9.94833374023438,147.510
 25390625 -9.87861061096191,147.504150390625 -9.87138748168945,147.501373291016 -9.86722183227539,147.499389648438 -9.85583305358887,147.501373291016 -9.85111045837402,147.503601074219 -9.83944320678711,147.503601074219 -9.8125,147.499389648438 -9.79638862609863,147.490509033203 -9.77138900756836,147.48828125 -9.76666641235352,147.386932373047 -9.63555717468262,147.316375732422 -9.55527877807617,147.296600341797 -9.53412532806396,147.248565673828 -9.50583457946777,147.12939453125 -9.44361114501953,147.080001831055 -9.43415546417236,147.099975585938 -9.44972229003906,147.102752685547 -9.45388793945312,147.102752685547 -9.48361015319824,147.101348876953 -9.48888778686523,147.09912109375 -9.49110984802246,147.094421386719 -9.49305534362793,147.0888671875 -9.49166679382324,147.062194824219 -9.47333335876465,147.055236816406 -9.46666526794434,147.008026123047 -9.39833450317383,147.001922607422 -9.3841667175293,146.926635742188 -9.28277778625488,146.91748046875 -9.28750038146973,14
 6.911376953125 -9.28694534301758,146.901092529297 -9.28333282470703,146.896942138672 -9.28083419799805,146.893585205078 -9.27722358703613,146.891662597656 -9.27250099182129,146.888885498047 -9.1833324432373,146.905044555664 -9.13727760314941,146.905868530273 -9.13410949707031,146.907043457031 -9.13127708435059,146.909881591797 -9.13077735900879,146.915374755859 -9.13361072540283,146.918548583984 -9.13444423675537,146.969696044922 -9.09138870239258,146.977172851562 -9.07444381713867,146.981353759766 -9.05944442749023,146.981048583984 -9.05097389221191,146.974395751953 -9.03388977050781,146.972473144531 -9.02916717529297,146.969116210938 -9.02833366394043,146.951080322266 -9.03388977050781,146.94580078125 -9.04194450378418,146.944427490234 -9.04722213745117,146.94580078125 -9.05277824401855,146.951904296875 -9.06027793884277,146.954681396484 -9.06833267211914,146.953308105469 -9.07361030578613,146.925262451172 -9.09999847412109,146.91748046875 -9.10610961914062,146.84460449218
 8 -9.09577751159668,146.840911865234 -9.09627723693848,146.83757019043 -9.09544467926025,146.630523681641 -9.0302791595459,146.621612548828 -9.02555656433105,146.586639404297 -8.99916648864746,146.578308105469 -8.9869441986084,146.55859375 -8.9416675567627,146.545532226562 -8.90250015258789,146.546081542969 -8.89777946472168,146.555816650391 -8.85972213745117,146.559143066406 -8.85638809204102,146.567474365234 -8.8075008392334,146.541351318359 -8.76361274719238,146.517486572266 -8.72500038146973,146.441345214844 -8.62472152709961,146.431915283203 -8.61388778686523,146.419982910156 -8.60499954223633,146.403594970703 -8.59444427490234,146.379104614258 -8.58470821380615,146.372192382812 -8.57805633544922,146.351623535156 -8.55777740478516,146.318572998047 -8.50889015197754,146.275543212891 -8.44305610656738,146.269439697266 -8.42888832092285,146.268035888672 -8.42361068725586,146.263305664062 -8.38750076293945,146.264709472656 -8.37527656555176,146.264709472656 -8.3686103820800
 8,146.262481689453 -8.35972213745117,146.243286132812 -8.29472351074219,146.238555908203 -8.28583335876465,146.229675292969 -8.27444458007812,146.218566894531 -8.26472282409668,146.111083984375 -8.16388893127441,146.110229492188 -8.13472366333008,146.089691162109 -8.09111022949219,145.998016357422 -8.05444526672363,145.987731933594 -8.05111122131348,145.930816650391 -8.04111099243164,145.918579101562 -8.03972244262695,145.898590087891 -8.03888893127441,145.880798339844 -8.04166793823242,145.835510253906 -8.02805709838867,145.797760009766 -8.00777816772461,145.786376953125 -7.99888896942139,145.718292236328 -7.96777820587158,145.649993896484 -7.9597225189209,145.630798339844 -7.94472217559814,145.616912841797 -7.93777751922607,145.528045654297 -7.93777751922607,145.502471923828 -7.9399995803833,145.484130859375 -7.94861030578613,145.465515136719 -7.95083332061768,145.443572998047 -7.94944381713867,145.432739257812 -7.94805526733398,145.422485351562 -7.94472217559814,145.24411
 0107422 -7.86861038208008,145.19807434082 -7.82955169677734,145.182723999023 -7.81383991241455,145.168106079102 -7.81822443008423,145.162994384766 -7.82626342773438,145.164459228516 -7.83649444580078,145.161529541016 -7.84489870071411,145.155685424805 -7.84599494934082,145.044967651367 -7.82041692733765,144.995513916016 -7.81555557250977,144.879669189453 -7.78250026702881,144.844696044922 -7.75722312927246,144.838562011719 -7.74972152709961,144.840515136719 -7.74499988555908,144.850250244141 -7.74111080169678,144.871337890625 -7.70777797698975,144.873565673828 -7.7030553817749,144.874114990234 -7.69694423675537,144.874114990234 -7.6899995803833,144.862457275391 -7.61055564880371,144.844696044922 -7.60777759552002,144.833862304688 -7.67722225189209,144.831085205078 -7.68111133575439,144.824127197266 -7.68805503845215,144.819427490234 -7.6899995803833,144.787750244141 -7.69138813018799,144.783599853516 -7.69138813018799,144.599395751953 -7.6602783203125,144.588287353516 -7.657
 50026702881,144.584411621094 -7.65472221374512,144.552185058594 -7.6119441986084,144.547210693359 -7.60305500030518,144.547210693359 -7.5963888168335,144.545806884766 -7.57472229003906,144.536376953125 -7.52694511413574,144.534973144531 -7.52166652679443,144.530822753906 -7.51222229003906,144.525268554688 -7.5038890838623,144.520538330078 -7.50194454193115,144.514984130859 -7.50194454193115,144.51025390625 -7.5038890838623,144.508880615234 -7.50944519042969,144.508331298828 -7.61472225189209,144.508331298828 -7.62138843536377,144.424682617188 -7.53305530548096,144.418579101562 -7.52583312988281,144.410247802734 -7.52027797698975,144.406921386719 -7.51944446563721,144.412200927734 -7.56583309173584,144.435516357422 -7.68000030517578,144.467742919922 -7.74305534362793,144.395812988281 -7.75583362579346,144.378021240234 -7.75333404541016,144.363006591797 -7.74777793884277,144.358856201172 -7.74499988555908,144.356628417969 -7.74027729034424,144.354125976562 -7.72944450378418,14
 4.354125976562 -7.72277736663818,144.356628417969 -7.70499992370605,144.359680175781 -7.69416618347168,144.360229492188 -7.68249988555908,144.319122314453 -7.62083339691162,144.315795898438 -7.61749935150146,144.310791015625 -7.61666584014893,144.260803222656 -7.63777828216553,144.250549316406 -7.65472221374512,144.243560791016 -7.66694450378418,144.255249023438 -7.73416614532471,144.263031005859 -7.74027729034424,144.272491455078 -7.76749992370605,144.271911621094 -7.77361106872559,144.268310546875 -7.77694511413574,144.224395751953 -7.79333305358887,144.219116210938 -7.79472255706787,144.213012695312 -7.79527759552002,144.147216796875 -7.77888870239258,144.121612548828 -7.77166652679443,143.911926269531 -7.69694423675537,143.899719238281 -7.68861103057861,143.848037719727 -7.63533353805542,143.838531494141 -7.62833404541016,143.829193115234 -7.61733341217041,143.822525024414 -7.60766696929932,143.812713623047 -7.58883380889893,143.810211181641 -7.58316707611084,143.8065490
 72266 -7.57049989700317,143.773040771484 -7.51555633544922,143.768310546875 -7.506667137146,143.758605957031 -7.50250053405762,143.664825439453 -7.46764850616455,143.691345214844 -7.51222229003906,143.755126953125 -7.58950042724609,143.839416503906 -7.71527767181396,143.845520019531 -7.73611068725586,143.852447509766 -7.77027797698975,143.85302734375 -7.78305530548096,143.851898193359 -7.79527759552002,143.85302734375 -7.80749988555908,143.854400634766 -7.81305503845215,143.896362304688 -7.88027763366699,143.901641845703 -7.88833332061768,143.9580078125 -7.97862243652344,143.957183837891 -7.98472213745117,143.955230712891 -7.9894437789917,143.893585205078 -8.03694534301758,143.889434814453 -8.03972244262695,143.884704589844 -8.04166793823242,143.847747802734 -8.04583358764648,143.833862304688 -8.04583358764648,143.755249023438 -8.04111099243164,143.750274658203 -8.03888893127441,143.743560791016 -8.03222274780273,143.738006591797 -8.02416801452637,143.724395751953 -8.0105571
 7468262,143.719421386719 -8.00833511352539,143.661376953125 -7.99138832092285,143.631896972656 -7.98666667938232,143.618835449219 -7.98611068725586,143.597473144531 -7.99222183227539,143.588562011719 -7.99694442749023,143.568908691406 -8.0041675567627,143.56575012207 -8.00483322143555,143.546081542969 -8.00638961791992,143.501647949219 -7.9961109161377,143.485778808594 -7.99138832092285,143.481628417969 -7.98888874053955,143.474975585938 -7.98194408416748,143.473571777344 -7.97305583953857,143.460510253906 -7.93861103057861,143.454406738281 -7.92416667938232,143.444122314453 -7.91333389282227,143.439971923828 -7.91055583953857,143.435241699219 -7.90861129760742,143.424133300781 -7.90722274780273,143.362457275391 -7.8997220993042,143.358306884766 -7.90250015258789,143.356903076172 -7.90805530548096,143.356903076172 -7.91333389282227,143.360504150391 -7.91694450378418,143.446624755859 -7.98055553436279,143.538635253906 -8.05216693878174,143.541458129883 -8.05333423614502,143.5
 43975830078 -8.05500030517578,143.547958374023 -8.05900001525879,143.628295898438 -8.19361114501953,143.630523681641 -8.19833374023438,143.632446289062 -8.20999908447266,143.631896972656 -8.21611022949219,143.629669189453 -8.22749900817871,143.625518798828 -8.2369441986084,143.622192382812 -8.24055480957031,143.611907958984 -8.24388885498047,143.56884765625 -8.24722099304199,143.554962158203 -8.24722099304199,143.512481689453 -8.2458324432373,143.469421386719 -8.24527740478516,143.382446289062 -8.25,143.373565673828 -8.25055694580078,143.338562011719 -8.2538890838623,143.234954833984 -8.27500152587891,143.178039550781 -8.28666687011719,143.080810546875 -8.30833435058594,143.069976806641 -8.31083297729492,143.049407958984 -8.31777763366699,143.034149169922 -8.32305526733398,143.023864746094 -8.3266658782959,143 -8.33666610717773,142.991058349609 -8.34138870239258,142.979949951172 -8.34416580200195,142.973297119141 -8.34416580200195,142.967193603516 -8.3436107635498,142.961639
 404297 -8.34222221374512,142.94580078125 -8.33749961853027,142.941070556641 -8.33527755737305,142.908874511719 -8.31916618347168,142.882171630859 -8.30500030517578,142.865509033203 -8.29416656494141,142.845794677734 -8.28666687011719,142.799987792969 -8.27500152587891,142.776641845703 -8.27083396911621,142.696350097656 -8.26749992370605,142.654693603516 -8.27361106872559,142.638031005859 -8.27777862548828,142.595794677734 -8.29000091552734,142.575256347656 -8.29666709899902,142.565521240234 -8.30083274841309,142.548309326172 -8.31083297729492,142.540802001953 -8.31694412231445,142.533874511719 -8.32388877868652,142.529968261719 -8.3266658782959,142.521087646484 -8.33138847351074,142.511383056641 -8.33527755737305,142.505828857422 -8.33666610717773,142.485229492188 -8.33666610717773,142.466918945312 -8.33611106872559,142.442749023438 -8.33277702331543,142.437469482422 -8.33138847351074,142.427764892578 -8.32722282409668,142.419708251953 -8.32194519042969,142.411926269531 -8.3
 1583404541016,142.403213500977 -8.28638935089111,142.396194458008 -8.26155567169189,142.395050048828 -8.25055599212646,142.394195556641 -8.23922157287598,142.39453125 -8.23155498504639,142.394195556641 -8.2278881072998,142.386657714844 -8.19361114501953,142.383880615234 -8.18972206115723,142.379943847656 -8.18694496154785,142.338562011719 -8.16638946533203,142.327758789062 -8.16388893127441,142.316925048828 -8.16388893127441,142.221618652344 -8.1733341217041,142.2119140625 -8.17722320556641,142.140808105469 -8.22222137451172,142.13720703125 -8.22555541992188,142.13525390625 -8.23027801513672,142.135803222656 -8.23638725280762,142.144714355469 -8.23916625976562,142.155822753906 -8.24055480957031,142.163879394531 -8.23638725280762,142.172210693359 -8.23083305358887,142.182464599609 -8.22083282470703,142.186645507812 -8.21805572509766,142.195526123047 -8.21333312988281,142.223571777344 -8.20027732849121,142.228302001953 -8.19833374023438,142.309143066406 -8.18083381652832,142.3
 14147949219 -8.18000030517578,142.324401855469 -8.1833324432373,142.338012695312 -8.19027709960938,142.355224609375 -8.19916725158691,142.361358642578 -8.20638847351074,142.374572753906 -8.26111125946045,142.377410888672 -8.2746114730835,142.377075195312 -8.28644466400146,142.377410888672 -8.29327774047852,142.382446289062 -8.31916618347168,142.388031005859 -8.32722282409668,142.408599853516 -8.34749984741211,142.439422607422 -8.37138748168945,142.44970703125 -8.37472152709961,142.466918945312 -8.37805557250977,142.473022460938 -8.37888717651367,142.486633300781 -8.37888717651367,142.493011474609 -8.37805557250977,142.512756347656 -8.37194442749023,142.522491455078 -8.36805534362793,142.5263671875 -8.36527633666992,142.540252685547 -8.35166549682617,142.548309326172 -8.34611129760742,142.556640625 -8.34083366394043,142.590240478516 -8.3266658782959,142.619689941406 -8.31500053405762,142.635528564453 -8.31027793884277,142.641662597656 -8.31083297729492,142.734680175781 -8.322
 50022888184,142.771636962891 -8.33194351196289,142.776641845703 -8.33388900756836,142.783325195312 -8.34083366394043,142.788879394531 -8.3488883972168,142.799133300781 -8.35916519165039,142.807464599609 -8.36444473266602,142.906097412109 -8.42361068725586,142.917205810547 -8.42611122131348,142.9580078125 -8.43166732788086,143.01025390625 -8.44111061096191,143.04443359375 -8.44777870178223,143.049987792969 -8.44916725158691,143.086364746094 -8.45999908447266,143.096618652344 -8.4636116027832,143.110229492188 -8.47027778625488,143.213012695312 -8.5494441986084,143.220520019531 -8.55555534362793,143.239135742188 -8.57138824462891,143.246063232422 -8.57805633544922,143.249389648438 -8.58138847351074,143.281646728516 -8.61861038208008,143.374664306641 -8.741943359375,143.392761230469 -8.77027893066406,143.395263671875 -8.7813892364502,143.406921386719 -8.96194458007812,143.405548095703 -8.96749877929688,143.403045654297 -8.97138786315918,143.384429931641 -8.99388885498047,143.367
 1875 -9.01083374023438,143.363006591797 -9.01361274719238,143.331634521484 -9.02833366394043,143.321899414062 -9.03250122070312,143.316650390625 -9.03388977050781,143.310241699219 -9.03305625915527,143.299407958984 -9.02361106872559,143.289154052734 -9.02027893066406,143.283050537109 -9.01972198486328,143.269989013672 -9.02027893066406,143.248016357422 -9.02555656433105,143.232177734375 -9.0302791595459,143.174133300781 -9.04861068725586,143.047210693359 -9.09000015258789,143.04248046875 -9.09194374084473,143.039154052734 -9.09527778625488,143.030822753906 -9.10750007629395,143.023864746094 -9.11416625976562,142.902770996094 -9.19750022888184,142.842468261719 -9.2327766418457,142.807464599609 -9.25222396850586,142.797760009766 -9.25638961791992,142.788299560547 -9.26027870178223,142.769134521484 -9.2672233581543,142.752471923828 -9.27138900756836,142.723846435547 -9.28333282470703,142.66552734375 -9.32055473327637,142.654693603516 -9.32999992370605,142.638885498047 -9.334722
 5189209,142.625244140625 -9.3347225189209,142.582733154297 -9.33083343505859,142.571624755859 -9.32805633544922,142.543029785156 -9.30916595458984,142.532470703125 -9.29888916015625,142.5244140625 -9.28694534301758,142.521087646484 -9.28333282470703,142.517486572266 -9.28000068664551,142.497741699219 -9.26527786254883,142.477172851562 -9.25166702270508,142.425811767578 -9.22805595397949,142.2099609375 -9.16500091552734,142.203033447266 -9.16500091552734,142.054412841797 -9.18722152709961,141.944702148438 -9.20694351196289,141.721343994141 -9.21444511413574,141.615783691406 -9.23611068725586,141.608856201172 -9.23611068725586,141.522491455078 -9.22111129760742,141.509429931641 -9.21388816833496,141.501922607422 -9.20777702331543,141.495788574219 -9.20027732849121,141.48828125 -9.19416618347168,141.460784912109 -9.17388916015625,141.448577880859 -9.16583442687988,141.429412841797 -9.15750122070312,141.388305664062 -9.14416694641113,141.375244140625 -9.14333343505859,141.323028
 564453 -9.14999961853027,141.312194824219 -9.15277862548828,141.307464599609 -9.15500068664551,141.294982910156 -9.16305541992188,141.284698486328 -9.17305564880371,141.266387939453 -9.18888854980469,141.226623535156 -9.21722221374512,141.213592529297 -9.22472190856934,141.176361083984 -9.23388862609863,141.160797119141 -9.23749923706055,141.122467041016 -9.23194313049316,141.117462158203 -9.22999954223633,141.109405517578 -9.22472190856934,141.090789794922 -9.20916557312012,141.033874511719 -9.15694427490234,141.013305664062 -9.13666725158691,141.007019042969 -9.12846755981445,141.006134033203 -6.90478563308716,141.006134033203 -6.89328384399414,140.998565673828 -6.89388942718506,140.990509033203 -6.89944458007812,140.983581542969 -6.9061107635498,140.978851318359 -6.90694427490234,140.949401855469 -6.9036111831665,140.902770996094 -6.85583305358887,140.875244140625 -6.79611110687256,140.871063232422 -6.7863883972168,140.859405517578 -6.72861099243164,140.858856201172 -6.67
 83332824707,140.863006591797 -6.63138866424561,140.891082763672 -6.60333347320557,140.895263671875 -6.60055541992188,140.898040771484 -6.59666728973389,140.947204589844 -6.5,140.951354980469 -6.48361110687256,140.950805664062 -6.47749996185303,140.948577880859 -6.47277736663818,140.94580078125 -6.4686107635498,140.928039550781 -6.45083332061768,140.932189941406 -6.43444442749023,140.963592529297 -6.3386116027832,140.967742919922 -6.33583354949951,140.973297119141 -6.33444499969482,140.985504150391 -6.33305549621582,141.006134033203 -6.33292484283447,141.006103515625 -6,141.006103515625 -4.90555477142334,141.006103515625 -2.61388921737671,141.002471923828 -2.60708522796631,141.029968261719 -2.59277772903442,141.034698486328 -2.59083318710327,141.039428710938 -2.59000015258789,141.046356201172 -2.59000015258789,141.199127197266 -2.61805534362793,141.204681396484 -2.61944437026978,141.214141845703 -2.62222194671631,141.270538330078 -2.64555549621582,141.273864746094 -2.65583324
 432373,141.278045654297 -2.6652774810791,141.284149169922 -2.67277765274048,141.345794677734 -2.70777797698975,141.369689941406 -2.7180552482605,141.380798339844 -2.72083330154419,141.410797119141 -2.72499990463257,141.426635742188 -2.72972202301025,141.436370849609 -2.73388910293579,141.568572998047 -2.79388904571533,141.608856201172 -2.8125,141.704132080078 -2.86250019073486,141.840515136719 -2.93694448471069,141.881622314453 -2.96444463729858,141.889984130859 -2.96999979019165,141.894714355469 -2.9719443321228,141.913879394531 -2.9719443321228,141.931091308594 -2.9686107635498,141.935791015625 -2.96638870239258,141.962463378906 -2.95888900756836,141.973571777344 -2.95611095428467,141.991912841797 -2.95416688919067,142.003601074219 -2.95611095428467,142.011932373047 -2.96166658401489,142.066070556641 -3.00833368301392,142.076904296875 -3.01777791976929,142.077758789062 -3.02055549621582,142.124969482422 -3.05944442749023,142.252471923828 -3.10472249984741,142.551910400391
 -3.21833324432373,142.663604736328 -3.24777793884277,142.946624755859 -3.33249998092651,142.992462158203 -3.34833335876465,143.032745361328 -3.36277770996094,143.041076660156 -3.36416673660278,143.073181152344 -3.36020636558533,143.087738037109 -3.35583353042603,143.093841552734 -3.35500001907349,143.106079101562 -3.35388898849487,143.123840332031 -3.35388898849487,143.172760009766 -3.35722255706787,143.194702148438 -3.3600001335144,143.209686279297 -3.3652777671814,143.2138671875 -3.36805534362793,143.229400634766 -3.37972211837769,143.23828125 -3.38444471359253,143.255554199219 -3.3880558013916,143.336364746094 -3.40166664123535,143.346069335938 -3.40166664123535,143.370788574219 -3.40166664123535,143.384429931641 -3.40305519104004,143.408325195312 -3.40638875961304,143.442749023438 -3.41194438934326,143.516082763672 -3.43444442749023,143.520812988281 -3.43666648864746,143.529144287109 -3.44194412231445,143.536651611328 -3.44805526733398,143.569427490234 -3.47555541992188,
 143.598846435547 -3.51444482803345,143.602172851562 -3.5247220993042,143.605804443359 -3.54194450378418,143.609130859375 -3.54527807235718,143.61328125 -3.54805564880371,143.648864746094 -3.56722259521484,143.731079101562 -3.60416698455811,143.768310546875 -3.61083364486694,143.790802001953 -3.61083364486694,143.794982910156 -3.61222219467163,143.798858642578 -3.61500024795532,143.949127197266 -3.73333311080933,143.955230712891 -3.73944425582886,143.9580078125 -3.74361133575439,143.964691162109 -3.7572226524353,143.966064453125 -3.76277780532837,143.976348876953 -3.77972221374512,143.981903076172 -3.78805589675903,143.988861083984 -3.79500007629395,143.993011474609 -3.79777812957764,144.016937255859 -3.81055545806885,144.243011474609 -3.87277746200562,144.249114990234 -3.87361097335815,144.253875732422 -3.87138891220093,144.255249023438 -3.86611127853394,144.253875732422 -3.86194467544556,144.253875732422 -3.85500001907349,144.258026123047 -3.84555530548096,144.275268554688
 -3.809166431427,144.278594970703 -3.80583333969116,144.284973144531 -3.80527782440186,144.338287353516 -3.80249977111816,144.375244140625 -3.80249977111816,144.511657714844 -3.82083368301392,144.515808105469 -3.82361125946045,144.532196044922 -3.84611082077026,144.534973144531 -3.8502779006958,144.549987792969 -3.87611103057861,144.552185058594 -3.88111114501953,144.547210693359 -3.8938889503479,144.545257568359 -3.90416669845581,144.54248046875 -3.93444442749023,144.543853759766 -3.95361137390137,144.547210693359 -3.96388912200928,144.551361083984 -3.9719443321228,144.571350097656 -3.99194431304932,144.591064453125 -4.00611114501953,144.608306884766 -4.0130558013916,144.613861083984 -4.01444530487061,144.653594970703 -4.0130558013916,144.673309326172 -4.01361179351807,144.678863525391 -4.01500034332275,144.729675292969 -4.0313892364502,144.766662597656 -4.04638862609863,144.850250244141 -4.09305572509766,144.858306884766 -4.09833335876465,144.876342773438 -4.11361122131348,
 144.978302001953 -4.22277736663818,144.981628417969 -4.22638893127441,144.986633300781 -4.23499965667725,144.991333007812 -4.24388885498047,144.994689941406 -4.25277805328369,144.996063232422 -4.26250076293945,145.004974365234 -4.28166675567627,145.033050537109 -4.33555603027344,145.036651611328 -4.33888912200928,145.054962158203 -4.35194396972656,145.089965820312 -4.37166595458984,145.094696044922 -4.37388896942139,145.157196044922 -4.38277721405029,145.228576660156 -4.3880558013916,145.253051757812 -4.37861061096191,145.293579101562 -4.37666606903076,145.305236816406 -4.37722206115723,145.333862304688 -4.38944435119629,145.338012695312 -4.39222240447998,145.451080322266 -4.49416637420654,145.459411621094 -4.50444507598877,145.527191162109 -4.59249973297119,145.614135742188 -4.70027828216553,145.620513916016 -4.70777797698975,145.675811767578 -4.76194477081299,145.679412841797 -4.76527786254883,145.69384765625 -4.77694511413574,145.735504150391 -4.80277729034424,145.7808227
 53906 -4.92777729034424,145.813598632812 -5.06555557250977,145.813598632812 -5.07250022888184,145.786926269531 -5.23138904571533,145.765808105469 -5.26361179351807,145.738861083984 -5.30527782440186,145.724395751953 -5.41222190856934,145.723846435547 -5.42527770996094,145.725250244141 -5.430832862854,145.734130859375 -5.4491662979126,145.747741699219 -5.46972179412842,145.754699707031 -5.47638893127441,145.766387939453 -5.48527717590332,145.782745361328 -5.4894437789917,145.787750244141 -5.48999977111816,145.793029785156 -5.48999977111816,145.872467041016 -5.48611068725586,145.930816650391 -5.47722244262695,145.935516357422 -5.47638893127441,145.963592529297 -5.47305583953857,145.976623535156 -5.47638893127441,146.082183837891 -5.51250076293945,146.174682617188 -5.55138874053955,146.194702148438 -5.55888843536377,146.289154052734 -5.58888912200928,146.376342773438 -5.59916687011719,146.439971923828 -5.59861087799072,146.445526123047 -5.59861087799072,146.465240478516 -5.6047
 2202301025,146.47021484375 -5.60666751861572,146.474090576172 -5.60944557189941,146.531188964844 -5.65468120574951,146.580535888672 -5.69472217559814,146.605224609375 -5.71777820587158,146.640808105469 -5.74388885498047,146.653045654297 -5.75194454193115,146.662750244141 -5.75611114501953,146.688873291016 -5.76416683197021,146.714691162109 -5.76972198486328,146.770782470703 -5.79138946533203,146.775787353516 -5.79361248016357,146.783843994141 -5.79889011383057,146.786071777344 -5.80388927459717,146.796310424805 -5.83441781997681,146.875213623047 -5.82555675506592,146.894958496094 -5.82888984680176,146.923004150391 -5.84194564819336,146.930511474609 -5.84805679321289,146.946319580078 -5.86638927459717,146.953826904297 -5.88611221313477,146.956604003906 -5.89027881622314,146.962707519531 -5.897780418396,146.992156982422 -5.91611289978027,147.014129638672 -5.92833518981934,147.041625976562 -5.94222354888916,147.046325683594 -5.94416904449463,147.102722167969 -5.96611404418945,1
 47.112152099609 -5.96667003631592,147.228820800781 -5.97223472595215,147.234924316406 -5.97140216827393,147.24658203125 -5.96251487731934,147.269683837891 -5.93807125091553,147.274658203125 -5.93612670898438,147.284942626953 -5.93529415130615,147.423278808594 -5.96058177947998,147.466613769531 -5.97085952758789,147.476867675781 -5.97419261932373,147.484375 -5.98030376434326,147.573303222656 -6.05527782440186,147.590515136719 -6.07222270965576,147.641937255859 -6.13694477081299,147.786651611328 -6.30249977111816,147.826354980469 -6.3372220993042,147.830261230469 -6.34694480895996,147.850250244141 -6.41166687011719,147.863861083984 -6.45916652679443,147.866638183594 -6.47000026702881,147.869964599609 -6.65472221374512,147.869415283203 -6.66083335876465,147.866058349609 -6.67083358764648,147.845520019531 -6.69138813018799,147.838562011719 -6.69805526733398,147.819427490234 -6.71305561065674,147.810516357422 -6.71777820587158,147.770812988281 -6.72611141204834,147.759155273438 -
 6.72805595397949,147.568023681641 -6.75194454193115,147.416381835938 -6.73499965667725,147.305541992188 -6.74583339691162,147.219696044922 -6.74638843536377,147.199981689453 -6.74583339691162,147.188873291016 -6.74305534362793,147.180816650391 -6.74027729034424,147.174682617188 -6.73555564880371,147.166381835938 -6.72333335876465,147.160247802734 -6.71722221374512,147.149993896484 -6.71388912200928,147.0888671875 -6.71444511413574,146.971069335938 -6.74305534362793,146.961364746094 -6.74722194671631,146.948577880859 -6.79805564880371,146.944976806641 -6.81527709960938,146.943023681641 -6.84027767181396,146.941650390625 -6.90444469451904,146.944976806641 -6.95388889312744,146.946350097656 -6.95944499969482,146.948577880859 -6.96416664123535,146.955230712891 -6.97111129760742,147.0244140625 -7.03694438934326,147.037475585938 -7.04444408416748,147.130798339844 -7.20361137390137,147.140258789062 -7.22111129760742,147.144439697266 -7.23083305358887,147.146362304688 -7.24916648864
 746,147.145812988281 -7.26194477081299,147.141662597656 -7.27166652679443,147.140258789062 -7.27694511413574,147.137481689453 -7.29472255706787,147.139709472656 -7.32527828216553,147.1533203125 -7.38305473327637,147.154693603516 -7.38861179351807,147.178588867188 -7.46388912200928,147.210784912109 -7.49027729034424,147.216369628906 -7.49166679382324,147.297210693359 -7.5038890838623,147.303314208984 -7.50472259521484,147.320526123047 -7.50527858734131,147.332183837891 -7.50333404541016,147.3369140625 -7.50527858734131,147.418579101562 -7.56722259521484,147.457733154297 -7.5977783203125,147.641357421875 -7.77555561065674,147.666656494141 -7.79111099243164,147.670806884766 -7.79388904571533,147.693298339844 -7.82583332061768,147.696075439453 -7.83527755737305,147.701629638672 -7.87055492401123,147.701629638672 -7.8841667175293,147.700805664062 -7.89027786254883,147.701629638672 -7.90333366394043,147.703033447266 -7.90861129760742,147.710510253906 -7.92166614532471,147.71524047
 8516 -7.92916679382324,147.718566894531 -7.93249988555908,147.731628417969 -7.9399995803833,147.741333007812 -7.94388866424561,147.756927490234 -7.94861030578613,147.776916503906 -7.93638801574707,147.782470703125 -7.93527698516846,147.804412841797 -7.93527698516846,147.854949951172 -7.93527698516846,147.866638183594 -7.93722152709961,147.876342773438 -7.94111061096191,147.888031005859 -7.94999980926514,147.911926269531 -7.96722221374512,147.935791015625 -7.98277759552002,147.939422607422 -7.98472213745117,147.974395751953 -7.99610900878906,147.979675292969 -8.03694534301758,147.982452392578 -8.04777908325195,147.985229492188 -8.05194473266602,147.9921875 -8.0586109161377,148.004425048828 -8.06666564941406,148.009979248047 -8.06666564941406,148.0263671875 -8.06277847290039,148.114685058594 -8.05527877807617,148.13525390625 -8.06611061096191,148.194976806641 -8.25194549560547,148.19970703125 -8.26749992370605,148.205810546875 -8.29527854919434,148.206634521484 -8.301389694213
 87,148.207183837891 -8.31083297729492,148.207183837891 -8.32055473327637,148.206634521484 -8.34000015258789,148.210784912109 -8.39305686950684,148.220245361328 -8.51027870178223,148.222198486328 -8.53388977050781,148.230529785156 -8.55972290039062,148.235229492188 -8.56861114501953,148.2421875 -8.57527732849121,148.271087646484 -8.59444427490234,148.300537109375 -8.61138916015625,148.318298339844 -8.60861015319824,148.327178955078 -8.60638809204102,148.331359863281 -8.60638809204102,148.347198486328 -8.61138916015625,148.351898193359 -8.61333274841309,148.376617431641 -8.62944412231445,148.443023681641 -8.67500114440918,148.44580078125 -8.67888832092285,148.478576660156 -8.73305511474609,148.479949951172 -8.73861122131348,148.479949951172 -8.75889015197754,148.489685058594 -8.84027671813965,148.494415283203 -8.86666488647461,148.530822753906 -8.99305534362793,148.534698486328 -9.00277900695801,148.536926269531 -9.00750160217285,148.5888671875 -9.07027816772461,148.6041259765
 62 -9.08250045776367,148.614410400391 -9.0858325958252,148.695251464844 -9.10222244262695,148.719970703125 -9.10472106933594,148.725250244141 -9.10472106933594,148.753601074219 -9.10416603088379,148.782196044922 -9.10138893127441,148.842468261719 -9.09055519104004,149.067199707031 -9.04111099243164,149.071350097656 -9.03861236572266,149.137756347656 -9.00666809082031,149.221343994141 -8.99860954284668,149.255828857422 -8.99777793884277,149.259979248047 -8.99916648864746,149.309967041016 -9.01694488525391,149.314697265625 -9.01889038085938,149.316650390625 -9.02166748046875,149.322204589844 -9.03777885437012,149.338012695312 -9.12972068786621,149.328308105469 -9.15277862548828,149.325531005859 -9.15694427490234,149.316070556641 -9.16777801513672,149.311920166016 -9.17055511474609,149.291351318359 -9.18388938903809,149.181640625 -9.34916687011719,149.1796875 -9.35361099243164,149.178863525391 -9.35972213745117,149.178863525391 -9.37333297729492,149.181091308594 -9.385000228881
 84,149.184417724609 -9.39500045776367,149.208312988281 -9.45249938964844,149.219970703125 -9.47472190856934,149.227752685547 -9.48749923706055,149.231079101562 -9.49110984802246,149.234405517578 -9.49444389343262,149.243286132812 -9.49916648864746,149.266662597656 -9.51000022888184,149.271636962891 -9.5119457244873,149.2783203125 -9.5119457244873,149.28857421875 -9.50861167907715,149.301635742188 -9.50777816772461,149.307189941406 -9.5091667175293,149.348846435547 -9.52194595336914,149.437469482422 -9.57138824462891,149.439422607422 -9.59111022949219,149.440795898438 -9.59638786315918,149.444122314453 -9.59972190856934,149.454406738281 -9.60305404663086,149.662200927734 -9.60722160339355,149.739410400391 -9.60166549682617,149.746337890625 -9.60166549682617,149.758026123047 -9.6038875579834,149.764984130859 -9.60916519165039,149.771087646484 -9.61666488647461,149.775268554688 -9.61944389343262,149.780548095703 -9.6208324432373,149.874389648438 -9.6422233581543,149.88079833984
 4 -9.64305686950684,149.9033203125 -9.64361190795898,149.910247802734 -9.64361190795898,149.94580078125 -9.6422233581543,149.956634521484 -9.63972282409668,149.960784912109 -9.6369457244873,149.982727050781 -9.63138771057129,150.008880615234 -9.63138771057129,150.049133300781 -9.67944526672363,150.051361083984 -9.68416595458984,150.053314208984 -9.68888854980469,150.056915283203 -9.70999908447266,150.056915283203 -9.71527671813965,150.055541992188 -9.72055435180664,150.051910400391 -9.72416687011719,149.988861083984 -9.75111198425293,149.926635742188 -9.76944541931152,149.863586425781 -9.78222274780273,149.857452392578 -9.78277778625488,149.852752685547 -9.78222274780273,149.841644287109 -9.77944564819336,149.835510253906 -9.77888870239258,149.808013916016 -9.7813892364502,149.769714355469 -9.7902774810791,149.764984130859 -9.79222297668457,149.739410400391 -9.80777740478516,149.727172851562 -9.81583404541016,149.720245361328 -9.82277679443359,149.717468261719 -9.82666587829
 59,149.716369628906 -9.83222198486328,149.717468261719 -9.83749961853027,149.721069335938 -9.84749984741211,149.723022460938 -9.85249900817871,149.76220703125 -9.90166664123535,149.873840332031 -10.0169448852539,149.914154052734 -10.0488891601562,149.926635742188 -10.0569438934326,149.935516357422 -10.0616655349731,149.982727050781 -10.081111907959,149.98828125 -10.0825004577637,149.994415283203 -10.0819444656372,150.003326416016 -10.0772228240967,150.013610839844 -10.0736103057861,150.019714355469 -10.073055267334,150.184143066406 -10.0933322906494,150.189147949219 -10.0952777862549,150.236358642578 -10.1283321380615,150.259704589844 -10.1527786254883,150.29052734375 -10.1830558776855,150.298583984375 -10.1883344650269,150.308319091797 -10.1924991607666,150.352752685547 -10.1999988555908,150.382171630859 -10.2047214508057,150.400268554688 -10.2072219848633,150.579681396484 -10.2411098480225,150.61328125 -10.2755565643311,150.618011474609 -10.2775001525879,150.63525390625 -1
 0.280834197998,150.641357421875 -10.2813892364502,150.647491455078 -10.280834197998,150.775543212891 -10.2613906860352,150.780548095703 -10.2591667175293,150.803588867188 -10.2486095428467,150.815521240234 -10.2397212982178,150.81884765625 -10.2363872528076,150.824981689453 -10.2316665649414,150.829681396484 -10.2294454574585,150.844116210938 -10.2247219085693,150.862731933594 -10.2227764129639,150.869415283203 -10.2227764129639,150.877746582031 -10.2283334732056,150.878295898438 -10.2316665649414,150.870788574219 -10.2377777099609,150.861907958984 -10.2424983978271,150.727752685547 -10.3125,150.641937255859 -10.3494434356689,150.636383056641 -10.3508319854736,150.631072998047 -10.3508319854736,150.602172851562 -10.3502769470215,150.596069335938 -10.3494434356689,150.547485351562 -10.3355560302734,150.496063232422 -10.3186111450195,150.438568115234 -10.3036117553711,150.421905517578 -10.3011112213135,150.415802001953 -10.3002777099609,150.406372070312 -10.3044452667236,150.3
 69110107422 -10.3219451904297,150.358306884766 -10.3313884735107,150.356353759766 -10.3361110687256,150.348571777344 -10.3758316040039,150.346618652344 -10.3875007629395,150.352172851562 -10.3952789306641,150.356903076172 -10.3975009918213,150.568572998047 -10.4627780914307,150.6494140625 -10.4755554199219,150.657745361328 -10.4811115264893,150.663299560547 -10.4891662597656,150.689971923828 -10.5502777099609,150.691925048828 -10.5550003051758,150.691345214844 -10.5611114501953,150.688568115234 -10.5652770996094,150.680267333984 -10.5774993896484,150.675537109375 -10.5794448852539,150.568023681641 -10.6219444274902,150.556365966797 -10.6238880157471,150.522766113281 -10.6191654205322,150.492736816406 -10.6191654205322,150.481628417969 -10.6219444274902,150.477447509766 -10.6244430541992,150.47412109375 -10.6277770996094,150.44384765625 -10.6588897705078,150.428314208984 -10.6877784729004,150.424133300781 -10.6905555725098,150.369964599609 -10.6872215270996,150.268585205078 -
 10.6886119842529,150.209686279297 -10.7005558013916,150.113006591797 -10.6674995422363,150.099975585938 -10.6575012207031,150.059417724609 -10.6258316040039,150.028045654297 -10.5894432067871,150.016937255859 -10.5733337402344,150.013031005859 -10.5705547332764,150.007476806641 -10.5691661834717,149.91552734375 -10.5577774047852,149.898590087891 -10.5597229003906,149.896362304688 -10.5625,149.893585205078 -10.5633344650269,149.888305664062 -10.5619449615479,149.862182617188 -10.5544452667236,149.852752685547 -10.5502777099609,149.850524902344 -10.5469455718994,149.875244140625 -10.5100002288818,149.878570556641 -10.5066680908203,149.883331298828 -10.5044460296631,149.901916503906 -10.5025005340576,149.942474365234 -10.5025005340576,149.964416503906 -10.5025005340576,149.968292236328 -10.5052795410156,149.971069335938 -10.5094451904297,149.97802734375 -10.5161113739014,149.989685058594 -10.5180568695068,150.016937255859 -10.5113906860352,150.022491455078 -10.5100002288818,150
 .031372070312 -10.5052795410156,150.039703369141 -10.5,150.078857421875 -10.4627780914307,150.064422607422 -10.4561100006104,149.990234375 -10.4372215270996,149.866363525391 -10.3980560302734,149.806091308594 -10.3677768707275,149.785522460938 -10.3583335876465,149.758026123047 -10.3461112976074,149.747741699219 -10.3427772521973,149.723846435547 -10.3394432067871,149.683868408203 -10.3380546569824,149.6640625 -10.3398141860962)),((152.004425048828 -2.67000007629395,151.972747802734 -2.66888904571533,151.961090087891 -2.66805553436279,151.957733154297 -2.66472196578979,151.955535888672 -2.65999984741211,151.953582763672 -2.64833354949951,151.954406738281 -2.64222240447998,151.958312988281 -2.63249969482422,151.972747802734 -2.60583353042603,151.979675292969 -2.59888887405396,151.983856201172 -2.59611082077026,151.995239257812 -2.59555530548096,152.000823974609 -2.5969443321228,152.010528564453 -2.60111141204834,152.018585205078 -2.60638904571533,152.022216796875 -2.610000133
 5144,152.035247802734 -2.63111114501953,152.037200927734 -2.63583326339722,152.038024902344 -2.64222240447998,152.029693603516 -2.66111087799072,152.026916503906 -2.6652774810791,152.022216796875 -2.66750001907349,152.004425048828 -2.67000007629395)),((151.959136962891 -2.84611082077026,151.946624755859 -2.84472227096558,151.941345214844 -2.84333324432373,151.937194824219 -2.8405556678772,151.931640625 -2.83249998092651,151.921905517578 -2.80777788162231,151.920806884766 -2.80222225189209,151.928863525391 -2.7186107635498,151.9296875 -2.71250009536743,151.932464599609 -2.70833349227905,151.939147949219 -2.70833349227905,151.944702148438 -2.70972204208374,151.985778808594 -2.72499990463257,151.989959716797 -2.72749996185303,151.996612548828 -2.7344446182251,152.006378173828 -2.74555540084839,152.009155273438 -2.74944448471069,152.009704589844 -2.75583362579346,152.011932373047 -2.79055595397949,152.011932373047 -2.81805562973022,152.009704589844 -2.82277774810791,152.00219726
 5625 -2.82888889312744,151.959136962891 -2.84611082077026)),((152.063873291016 -3.00222253799438,152.059143066406 -3,152.035247802734 -2.98277759552002,152.0283203125 -2.97555541992188,151.960510253906 -2.88722229003906,151.959686279297 -2.8808331489563,151.959686279297 -2.86861085891724,151.960510253906 -2.86250019073486,151.963287353516 -2.85833358764648,151.973571777344 -2.84805536270142,151.978302001953 -2.84611082077026,151.984954833984 -2.84611082077026,152.072204589844 -2.92138910293579,152.078857421875 -2.9283332824707,152.083862304688 -2.93694448471069,152.087188720703 -2.9472222328186,152.089141845703 -2.95888900756836,152.088562011719 -2.96527767181396,152.086639404297 -2.96999979019165,152.073577880859 -2.99805545806885,152.069976806641 -3.00138902664185,152.063873291016 -3.00222253799438)),((150.773590087891 -2.98555564880371,150.768035888672 -2.9844446182251,150.766082763672 -2.97944402694702,150.773040771484 -2.97249984741211,150.788024902344 -2.96027803421021
 ,150.795532226562 -2.95416688919067,150.870788574219 -2.91249990463257,150.879119873047 -2.9088888168335,150.903045654297 -2.90833330154419,150.908599853516 -2.90833330154419,150.913299560547 -2.91027784347534,150.941345214844 -2.9219446182251,151.021087646484 -2.96305561065674,151.023590087891 -2.96722221374512,151.021636962891 -2.9719443321228,151.003875732422 -2.98166656494141,150.999114990234 -2.98361110687256,150.992736816406 -2.9844446182251,150.882446289062 -2.9686107635498,150.872192382812 -2.96527767181396,150.855804443359 -2.9622220993042,150.838012695312 -2.95972204208374,150.831909179688 -2.96027803421021,150.773590087891 -2.98555564880371)),((152.640808105469 -3.23000001907349,152.636108398438 -3.2277774810791,152.605224609375 -3.20388889312744,152.577178955078 -3.17722225189209,152.538879394531 -3.1061110496521,152.537475585938 -3.10055589675903,152.537475585938 -3.09499979019165,152.539428710938 -3.09027767181396,152.553863525391 -3.07055568695068,152.55801391
 6016 -3.06777811050415,152.590240478516 -3.05194425582886,152.599700927734 -3.04805564880371,152.606079101562 -3.04722261428833,152.640258789062 -3.04305553436279,152.644989013672 -3.04527807235718,152.648590087891 -3.04861116409302,152.667755126953 -3.12944412231445,152.668853759766 -3.14861106872559,152.668853759766 -3.15527772903442,152.667755126953 -3.16083335876465,152.654693603516 -3.21638870239258,152.6533203125 -3.22166633605957,152.646362304688 -3.22861099243164,152.640808105469 -3.23000001907349)),((153.343292236328 -3.41666650772095,153.265258789062 -3.40722227096558,153.262481689453 -3.40444421768188,153.263885498047 -3.39888906478882,153.269989013672 -3.39277791976929,153.301635742188 -3.36944437026978,153.333587646484 -3.37138891220093,153.337188720703 -3.375,153.346069335938 -3.38666677474976,153.348022460938 -3.39138889312744,153.347473144531 -3.39750003814697,153.345245361328 -3.41194438934326,153.343292236328 -3.41666650772095)),((154.818572998047 -3.530277
 72903442,154.795257568359 -3.44138860702515,154.794708251953 -3.43249988555908,154.796081542969 -3.4283332824707,154.799407958984 -3.42500019073486,154.825531005859 -3.4713888168335,154.830261230469 -3.48027753829956,154.833862304688 -3.50416707992554,154.833038330078 -3.51027822494507,154.818572998047 -3.53027772903442)),((153.242462158203 -3.49944448471069,153.237182617188 -3.49805545806885,153.211090087891 -3.48861122131348,153.206909179688 -3.48583316802979,153.192474365234 -3.47277736663818,153.19384765625 -3.4686107635498,153.197204589844 -3.46527767181396,153.220520019531 -3.44888877868652,153.22412109375 -3.4466667175293,153.22802734375 -3.44555521011353,153.233581542969 -3.4466667175293,153.239959716797 -3.45444440841675,153.255554199219 -3.47972202301025,153.259704589844 -3.48916673660278,153.26025390625 -3.49527788162231,153.258331298828 -3.49888896942139,153.242462158203 -3.49944448471069)),((153.639434814453 -4.14083385467529,153.634429931641 -4.13861179351807,1
 53.588012695312 -4.10583305358887,153.585235595703 -4.10194396972656,153.584411621094 -4.09583377838135,153.585235595703 -4.08944416046143,153.587188720703 -4.0847225189209,153.602172851562 -4.05888843536377,153.629669189453 -4.0313892364502,153.633880615234 -4.0286111831665,153.653045654297 -4.02055549621582,153.658599853516 -4.01916694641113,153.662750244141 -4.02194499969482,153.664703369141 -4.02666664123535,153.671630859375 -4.08000087738037,153.672210693359 -4.08611106872559,153.671630859375 -4.10472202301025,153.670257568359 -4.10999965667725,153.650268554688 -4.1380558013916,153.645538330078 -4.14027786254883,153.639434814453 -4.14083385467529)),((145.057739257812 -4.13527774810791,145.050811767578 -4.13527774810791,145.041351318359 -4.13249969482422,145.037200927734 -4.13000011444092,145.031646728516 -4.12166595458984,145.027770996094 -4.11222171783447,145.0263671875 -4.10666656494141,145.022216796875 -4.07666683197021,145.0263671875 -4.06694507598877,145.0316467285
 16 -4.05888843536377,145.036651611328 -4.05666637420654,145.06884765625 -4.04500007629395,145.079132080078 -4.04777812957764,145.095520019531 -4.05888843536377,145.101623535156 -4.06638813018799,145.107177734375 -4.07527828216553,145.110504150391 -4.09222221374512,145.109954833984 -4.09833335876465,145.094696044922 -4.12444400787354,145.092193603516 -4.12833309173584,145.088012695312 -4.13138866424561,145.083312988281 -4.13333320617676,145.057739257812 -4.13527774810791)),((150.74609375 -6.13554954528809,150.729675292969 -6.14666748046875,150.724975585938 -6.14861106872559,150.707183837891 -6.15555572509766,150.668853759766 -6.16833305358887,150.663879394531 -6.16916656494141,150.661102294922 -6.16499996185303,150.659149169922 -6.15333366394043,150.657196044922 -6.14861106872559,150.652191162109 -6.14666748046875,150.63525390625 -6.14861106872559,150.509704589844 -6.23499965667725,150.484954833984 -6.25833415985107,150.480255126953 -6.26722240447998,150.473571777344 -6.27388
 954162598,150.468566894531 -6.2761116027832,150.406372070312 -6.29305553436279,150.400268554688 -6.29361152648926,150.222747802734 -6.28833293914795,150.211639404297 -6.2761116027832,150.188293457031 -6.25833415985107,150.184143066406 -6.25555610656738,150.180816650391 -6.25500011444092,150.170532226562 -6.25694465637207,150.080810546875 -6.28000068664551,150.038879394531 -6.29916667938232,150.018310546875 -6.32361125946045,150.016387939453 -6.30388832092285,150.014434814453 -6.29916667938232,150.010803222656 -6.29583358764648,149.98828125 -6.27722263336182,149.984130859375 -6.2747220993042,149.978576660156 -6.27333354949951,149.972473144531 -6.27388954162598,149.894989013672 -6.29249954223633,149.889709472656 -6.29249954223633,149.847198486328 -6.29249954223633,149.844421386719 -6.29249954223633,149.842193603516 -6.29249954223633,149.686645507812 -6.30527782440186,149.634704589844 -6.30805492401123,149.609405517578 -6.29249954223633,149.605224609375 -6.28972244262695,149.57
 4981689453 -6.26500034332275,149.571624755859 -6.26166725158691,149.555236816406 -6.22694492340088,149.539428710938 -6.19777774810791,149.510803222656 -6.15277767181396,149.489410400391 -6.12611103057861,149.482452392578 -6.11944389343262,149.467468261719 -6.10972213745117,149.444976806641 -6.09805583953857,149.341339111328 -6.06083297729492,149.335784912109 -6.05944442749023,149.311920166016 -6.05722236633301,149.289978027344 -6.06277751922607,149.163879394531 -6.11250019073486,149.138580322266 -6.14861106872559,149.131072998047 -6.15472221374512,149.119415283203 -6.15694427490234,149.069427490234 -6.16416645050049,149.063018798828 -6.16499996185303,149.056915283203 -6.16416645050049,149.052185058594 -6.16222190856934,149.049407958984 -6.15805530548096,149.048034667969 -6.15277767181396,149.048034667969 -6.14583396911621,149.050262451172 -6.14111137390137,149.054962158203 -6.13916683197021,149.061096191406 -6.13833332061768,149.067199707031 -6.14583396911621,149.07135009765
 6 -6.14861106872559,149.075531005859 -6.14583396911621,149.079681396484 -6.13638877868652,149.078857421875 -6.11944389343262,149.071899414062 -6.09277820587158,149.055541992188 -6.04444408416748,149.039978027344 -6.03694438934326,148.983032226562 -6.01972198486328,148.942474365234 -6.00833415985107,148.920654296875 -6.00002384185791,148.882995605469 -5.98166465759277,148.878814697266 -5.94748497009277,148.876068115234 -5.9436616897583,148.764434814453 -5.86499118804932,148.704650878906 -5.84858131408691,148.699554443359 -5.84745788574219,148.589721679688 -5.82837104797363,148.528045654297 -5.82837104797363,148.401672363281 -5.78336238861084,148.391967773438 -5.77940940856934,148.3876953125 -5.77660369873047,148.366607666016 -5.75592136383057,148.359771728516 -5.74921321868896,148.339324951172 -5.7143726348877,148.330780029297 -5.69515228271484,148.323089599609 -5.67537689208984,148.321655273438 -5.66980838775635,148.316467285156 -5.62802600860596,148.354675292969 -5.50166702
 270508,148.358001708984 -5.49277782440186,148.359954833984 -5.48805522918701,148.370239257812 -5.4777774810791,148.378570556641 -5.47249984741211,148.428588867188 -5.45111179351807,148.450531005859 -5.45527839660645,148.504699707031 -5.48333263397217,148.511657714844 -5.48999977111816,148.519714355469 -5.50250053405762,148.618286132812 -5.50500011444092,148.883605957031 -5.49694442749023,148.961639404297 -5.47361087799072,148.973297119141 -5.47166633605957,148.985778808594 -5.47305583953857,149.000823974609 -5.47833347320557,149.122192382812 -5.52416706085205,149.126892089844 -5.5261116027832,149.189147949219 -5.55833339691162,149.209686279297 -5.57194519042969,149.2138671875 -5.57472229003906,149.216064453125 -5.57944488525391,149.220764160156 -5.60611152648926,149.270812988281 -5.59444427490234,149.310516357422 -5.58611106872559,149.425537109375 -5.56722259521484,149.549133300781 -5.53861141204834,149.566925048828 -5.52888870239258,149.581909179688 -5.52333354949951,149.61
 1358642578 -5.51861095428467,149.668304443359 -5.51944446563721,149.680541992188 -5.55416679382324,149.680541992188 -5.561110496521,149.685516357422 -5.56305503845215,149.692199707031 -5.56305503845215,149.710784912109 -5.5625,149.875244140625 -5.5363883972168,149.880798339844 -5.53499984741211,149.887481689453 -5.53166675567627,149.916381835938 -5.51194477081299,149.928588867188 -5.50361156463623,149.956085205078 -5.47638893127441,149.964416503906 -5.46416664123535,149.981353759766 -5.4333324432373,149.984130859375 -5.42249965667725,149.983581542969 -5.41638851165771,149.981353759766 -5.41166687011719,149.97802734375 -5.40833377838135,149.973297119141 -5.4061107635498,149.954132080078 -5.40472221374512,149.950531005859 -5.40138912200928,149.923034667969 -5.36055564880371,149.917755126953 -5.35222244262695,149.918304443359 -5.34611129760742,149.928588867188 -5.31527709960938,149.934692382812 -5.30722236633301,150.002777099609 -5.16944408416748,150.015533447266 -5.05749988555
 908,150.019714355469 -5.04777812957764,150.029968261719 -5.03083324432373,150.034149169922 -5.02805614471436,150.0888671875 -5.00777816772461,150.095794677734 -5.00777816772461,150.121337890625 -5.00972270965576,150.126617431641 -5.01111125946045,150.154693603516 -5.02388954162598,150.181640625 -5.03888893127441,150.19384765625 -5.04722213745117,150.199401855469 -5.05527782440186,150.203582763672 -5.0649995803833,150.204956054688 -5.07055568695068,150.203582763672 -5.07583332061768,150.184143066406 -5.09833335876465,150.180816650391 -5.10194396972656,150.164428710938 -5.11277770996094,150.154693603516 -5.11694431304932,150.132720947266 -5.12222194671631,150.101348876953 -5.13194370269775,150.091644287109 -5.13583374023438,150.082733154297 -5.14138889312744,150.072479248047 -5.15166664123535,150.064422607422 -5.16388893127441,150.061645507812 -5.17472171783447,150.04248046875 -5.3086109161377,150.062194824219 -5.36388874053955,150.121337890625 -5.51250076293945,150.1232910156
 25 -5.51722240447998,150.143859863281 -5.5377779006958,150.164428710938 -5.55138874053955,150.178863525391 -5.55749988555908,150.184143066406 -5.55888843536377,150.282196044922 -5.57055568695068,150.291076660156 -5.57055568695068,150.296630859375 -5.569167137146,150.300811767578 -5.56638813018799,150.306915283203 -5.55888843536377,150.318023681641 -5.54194450378418,150.319976806641 -5.53722190856934,150.323303222656 -5.53361129760742,150.326904296875 -5.53027820587158,150.345245361328 -5.51472282409668,150.412475585938 -5.45861148834229,150.422760009766 -5.45527839660645,150.488555908203 -5.44694423675537,150.511108398438 -5.4505558013916,150.574127197266 -5.47638893127441,150.578308105469 -5.47916698455811,150.595520019531 -5.4961109161377,150.601623535156 -5.51722240447998,150.611083984375 -5.54194450378418,150.61328125 -5.54666709899902,150.616058349609 -5.55083274841309,150.624114990234 -5.55611038208008,150.644134521484 -5.55694389343262,150.677917480469 -5.551299095153
 81,150.693298339844 -5.54749965667725,150.698852539062 -5.54611110687256,150.914154052734 -5.4908332824707,150.924407958984 -5.48722171783447,150.979125976562 -5.44499969482422,151.003051757812 -5.42111110687256,151.011383056641 -5.4088888168335,151.015533447266 -5.39944458007812,151.018859863281 -5.38916683197021,151.023040771484 -5.37277698516846,151.023040771484 -5.3658332824707,151.018310546875 -5.34333324432373,151.018310546875 -5.33666706085205,151.018859863281 -5.33027839660645,151.0244140625 -5.28805541992188,151.028594970703 -5.27166652679443,151.038879394531 -5.24111080169678,151.046936035156 -5.22194480895996,151.066070556641 -5.18583297729492,151.071075439453 -5.17694473266602,151.084686279297 -5.1563892364502,151.096923828125 -5.14277839660645,151.26220703125 -4.98638820648193,151.266387939453 -4.98388862609863,151.357452392578 -4.94749927520752,151.441070556641 -4.93666648864746,151.513610839844 -4.93805503845215,151.604675292969 -4.96805572509766,151.608856201
 172 -4.97083377838135,151.614959716797 -4.97000026702881,151.641082763672 -4.95499992370605,151.648590087891 -4.94888877868652,151.654144287109 -4.94083309173584,151.676086425781 -4.90805530548096,151.684417724609 -4.88890266418457,151.687744140625 -4.86499977111816,151.682189941406 -4.81444454193115,151.658325195312 -4.61638832092285,151.630798339844 -4.50638961791992,151.62744140625 -4.49749946594238,151.598022460938 -4.43805503845215,151.592468261719 -4.43000030517578,151.588287353516 -4.42722225189209,151.547210693359 -4.35999965667725,151.501373291016 -4.23916625976562,151.5 -4.23388862609863,151.5 -4.22694492340088,151.503326416016 -4.21666622161865,151.508331298828 -4.20777797698975,151.511657714844 -4.20444488525391,151.536926269531 -4.18194389343262,151.783050537109 -4.20583343505859,151.841918945312 -4.22472190856934,151.852172851562 -4.22833347320557,151.857727050781 -4.23638820648193,151.859680175781 -4.24111080169678,151.861083984375 -4.24666690826416,151.863861
 083984 -4.27138900756836,151.869964599609 -4.28555583953857,151.878295898438 -4.29805564880371,151.884429931641 -4.30555534362793,151.895263671875 -4.3149995803833,151.904144287109 -4.32000064849854,151.9638671875 -4.33555603027344,151.969421386719 -4.33694458007812,151.974975585938 -4.33694458007812,151.984405517578 -4.33277797698975,151.991912841797 -4.32666683197021,152.138580322266 -4.20444488525391,152.141357421875 -4.20027828216553,152.145538330078 -4.19083309173584,152.150817871094 -4.17555522918701,152.153594970703 -4.16472244262695,152.153594970703 -4.15777778625488,152.156372070312 -4.15388870239258,152.161926269531 -4.14833354949951,152.166076660156 -4.14555549621582,152.171356201172 -4.14416694641113,152.177764892578 -4.14500045776367,152.185241699219 -4.14888954162598,152.214691162109 -4.16611099243164,152.235229492188 -4.2072229385376,152.239410400391 -4.21666622161865,152.2421875 -4.2344446182251,152.2421875 -4.24111080169678,152.240783691406 -4.24666690826416
 ,152.238006591797 -4.24805545806885,152.226898193359 -4.25083351135254,152.202453613281 -4.24666690826416,152.198303222656 -4.24388885498047,152.195526123047 -4.23999977111816,152.194122314453 -4.2344446182251,152.194122314453 -4.22749996185303,152.192749023438 -4.22222232818604,152.189971923828 -4.21805572509766,152.186645507812 -4.21472263336182,152.181640625 -4.21527767181396,152.176910400391 -4.21749973297119,152.172760009766 -4.22694492340088,152.16943359375 -4.24388885498047,152.170806884766 -4.28222274780273,152.171356201172 -4.28833293914795,152.172210693359 -4.29333305358887,152.174133300781 -4.29666709899902,152.1796875 -4.30472183227539,152.186645507812 -4.31166648864746,152.190521240234 -4.31444454193115,152.195526123047 -4.31638813018799,152.263885498047 -4.33500003814697,152.286651611328 -4.33972263336182,152.305236816406 -4.34166717529297,152.355804443359 -4.34305572509766,152.401641845703 -4.61083316802979,152.403045654297 -4.62305545806885,152.405242919922 -
 4.66888904571533,152.405822753906 -4.68888854980469,152.394989013672 -4.76111125946045,152.389434814453 -4.78305530548096,152.386108398438 -4.79333305358887,152.336090087891 -4.87527751922607,152.333312988281 -4.87916660308838,152.294128417969 -4.92916679382324,152.268035888672 -4.95777797698975,152.241333007812 -4.9844446182251,152.233306884766 -4.98999977111816,152.161102294922 -5.00694465637207,152.157196044922 -5.00694465637207,152.123565673828 -4.99944400787354,152.112457275391 -4.99666690826416,152.088562011719 -4.98638820648193,152.083038330078 -4.98499965667725,152.050262451172 -4.97972202301025,151.996612548828 -4.97277736663818,151.990509033203 -4.97222232818604,151.984954833984 -4.97361087799072,151.978302001953 -4.98027801513672,151.974975585938 -4.98388862609863,151.970794677734 -4.993332862854,151.968017578125 -5.0041675567627,151.966644287109 -5.02333354949951,151.964691162109 -5.10472202301025,151.969970703125 -5.14833354949951,151.97412109375 -5.157777786254
 88,151.979675292969 -5.16583347320557,151.993286132812 -5.17555522918701,152.069427490234 -5.23499965667725,152.07275390625 -5.23833274841309,152.118011474609 -5.29222202301025,152.124114990234 -5.29972171783447,152.129669189453 -5.30777740478516,152.144134521484 -5.34138870239258,152.145538330078 -5.34666728973389,152.147491455078 -5.36388874053955,152.144134521484 -5.37416648864746,152.131072998047 -5.40222263336182,152.123565673828 -5.41638851165771,152.096069335938 -5.4572229385376,151.972747802734 -5.53111171722412,151.968566894531 -5.53361129760742,151.841918945312 -5.59722232818604,151.825531005859 -5.60111141204834,151.818572998047 -5.60111141204834,151.808319091797 -5.5977783203125,151.779418945312 -5.58555603027344,151.771362304688 -5.58000087738037,151.759155273438 -5.55138874053955,151.752777099609 -5.54388904571533,151.748565673828 -5.54111099243164,151.705535888672 -5.53111171722412,151.699401855469 -5.53027820587158,151.491638183594 -5.52833366394043,151.47329
 7119141 -5.53027820587158,151.467742919922 -5.53166675567627,151.459411621094 -5.53583335876465,151.454132080078 -5.54111099243164,151.44384765625 -5.58555603027344,151.444427490234 -5.59166717529297,151.402770996094 -5.75137805938721,151.384704589844 -5.80720043182373,151.317779541016 -5.84993076324463,151.165649414062 -5.95807075500488,151.003051757812 -6.02250003814697,150.940795898438 -6.0286111831665,150.855804443359 -6.04083347320557,150.811920166016 -6.07638931274414,150.812744140625 -6.08944416046143,150.793304443359 -6.11805534362793,150.775543212891 -6.13916683197021,150.771636962891 -6.14166736602783,150.74609375 -6.13554954528809)),((154.153869628906 -4.44222164154053,154.128570556641 -4.3841667175293,154.126617431641 -4.37944412231445,154.128021240234 -4.37388896942139,154.132720947266 -4.37166595458984,154.140808105469 -4.37055492401123,154.150543212891 -4.37444400787354,154.152770996094 -4.37944412231445,154.1533203125 -4.3855562210083,154.155242919922 -4.4380
 5503845215,154.153869628906 -4.44222164154053)),((145.951354980469 -4.76444530487061,145.944427490234 -4.76444530487061,145.93359375 -4.76194477081299,145.918579101562 -4.75638961791992,145.898590087891 -4.74194431304932,145.891662597656 -4.73527717590332,145.875244140625 -4.69694423675537,145.873840332031 -4.69138813018799,145.872467041016 -4.67249965667725,145.873840332031 -4.66694450378418,145.892486572266 -4.6094446182251,145.8994140625 -4.59583377838135,145.904693603516 -4.58777809143066,145.914978027344 -4.57750034332275,145.966369628906 -4.53305530548096,145.970520019531 -4.53027820587158,145.975250244141 -4.52833366394043,145.981628417969 -4.52750015258789,146.011657714844 -4.5494441986084,146.026916503906 -4.56166648864746,146.053588867188 -4.5963888168335,146.055541992188 -4.60138893127441,146.054138183594 -4.66138935089111,146.04052734375 -4.70916652679443,146.037750244141 -4.71333408355713,146.027465820312 -4.72361087799072,146.019989013672 -4.72972202301025,145.
 994415283203 -4.74555492401123,145.961639404297 -4.76111125946045,145.951354980469 -4.76444530487061)),((159.513305664062 -4.58166694641113,159.511383056641 -4.57666683197021,159.515533447266 -4.53972244262695,159.518859863281 -4.5363883972168,159.522216796875 -4.55083274841309,159.523040771484 -4.56388854980469,159.519714355469 -4.57388973236084,159.516937255859 -4.57805633544922,159.513305664062 -4.58166694641113)),((149.552459716797 -4.72083377838135,149.546356201172 -4.72027778625488,149.475799560547 -4.71138954162598,149.470245361328 -4.71000003814697,149.465515136719 -4.70777797698975,149.461364746094 -4.70527839660645,149.457733154297 -4.70166683197021,149.455810546875 -4.69694423675537,149.454406738281 -4.68472194671631,149.455810546875 -4.67916679382324,149.468017578125 -4.66416645050049,149.506652832031 -4.64777851104736,149.512756347656 -4.64694499969482,149.518859863281 -4.64777851104736,149.529968261719 -4.65055561065674,149.540252685547 -4.65388870239258,149.54
 3579101562 -4.65722274780273,149.549133300781 -4.66555595397949,149.559967041016 -4.68194389343262,149.563293457031 -4.69222164154053,149.564147949219 -4.70527839660645,149.562744140625 -4.71055603027344,149.560516357422 -4.71527767181396,149.557189941406 -4.7188892364502,149.552459716797 -4.72083377838135)),((146.240509033203 -4.85805511474609,146.234405517578 -4.85750007629395,146.215789794922 -4.85138893127441,146.2119140625 -4.84861087799072,146.201629638672 -4.83833312988281,146.199401855469 -4.83361148834229,146.198028564453 -4.82805633544922,146.200256347656 -4.81638813018799,146.202178955078 -4.81166648864746,146.215789794922 -4.79111099243164,146.219970703125 -4.78833293914795,146.232177734375 -4.78833293914795,146.238555908203 -4.79055595397949,146.241333007812 -4.79333305358887,146.256927490234 -4.81166648864746,146.262481689453 -4.81972217559814,146.263885498047 -4.82527828216553,146.263885498047 -4.83083343505859,146.261932373047 -4.83555603027344,146.2508239746
 09 -4.85472202301025,146.246612548828 -4.85750007629395,146.240509033203 -4.85805511474609)),((149.152191162109 -4.92361068725586,149.133026123047 -4.91555595397949,149.128845214844 -4.9127779006958,149.122741699219 -4.90527820587158,149.118560791016 -4.89555549621582,149.118011474609 -4.88944435119629,149.119415283203 -4.8841667175293,149.122192382812 -4.88138866424561,149.156921386719 -4.86694431304932,149.161926269531 -4.86638832092285,149.165802001953 -4.86777782440186,149.175537109375 -4.87805557250977,149.178314208984 -4.88194370269775,149.181640625 -4.89222240447998,149.178863525391 -4.89638900756836,149.156921386719 -4.92305564880371,149.152191162109 -4.92361068725586)),((154.63720703125 -5.45861148834229,154.618011474609 -5.43138885498047,154.5869140625 -5.34472274780273,154.565795898438 -5.27666664123535,154.5302734375 -5.13388919830322,154.532196044922 -5.12222194671631,154.541076660156 -5.10388851165771,154.546630859375 -5.09555530548096,154.558319091797 -5.08000
 087738037,154.598846435547 -5.03083324432373,154.605529785156 -5.02388954162598,154.620513916016 -5.01861095428467,154.63916015625 -5.01638889312744,154.646087646484 -5.01638889312744,154.6513671875 -5.01777839660645,154.658874511719 -5.02388954162598,154.665802001953 -5.03083324432373,154.671356201172 -5.03888893127441,154.726898193359 -5.19722175598145,154.728302001953 -5.20277786254883,154.728302001953 -5.21638870239258,154.69384765625 -5.41833305358887,154.692474365234 -5.42388916015625,154.687194824219 -5.43194389343262,154.675537109375 -5.44083309173584,154.63720703125 -5.45861148834229)),((147.135528564453 -5.45111179351807,147.121887207031 -5.44444370269775,147.009979248047 -5.35499954223633,147.008026123047 -5.3502779006958,147.002471923828 -5.30388832092285,147.008026123047 -5.25888919830322,147.009979248047 -5.24722194671631,147.013610839844 -5.23833274841309,147.017761230469 -5.23555564880371,147.109405517578 -5.19333267211914,147.121063232422 -5.19111061096191,1
 47.128570556641 -5.19194412231445,147.134979248047 -5.19527721405029,147.191070556641 -5.248610496521,147.211639404297 -5.26916694641113,147.228851318359 -5.36388874053955,147.229949951172 -5.42111110687256,147.224670410156 -5.42944431304932,147.220520019531 -5.43194389343262,147.158874511719 -5.44833278656006,147.1533203125 -5.44972133636475,147.135528564453 -5.45111179351807)),((147.596618652344 -5.36305522918701,147.591918945312 -5.36111068725586,147.567199707031 -5.33916664123535,147.563873291016 -5.33583354949951,147.561645507812 -5.33111190795898,147.560516357422 -5.31888961791992,147.561645507812 -5.31333351135254,147.563873291016 -5.3086109161377,147.57080078125 -5.30166625976562,147.583038330078 -5.29361152648926,147.591918945312 -5.2902774810791,147.602172851562 -5.28805541992188,147.609130859375 -5.28805541992188,147.620788574219 -5.2902774810791,147.625518798828 -5.29222202301025,147.628845214844 -5.29555511474609,147.640533447266 -5.31666660308838,147.6427612304
 69 -5.3216667175293,147.643310546875 -5.32777786254883,147.642761230469 -5.33388900756836,147.640533447266 -5.3386116027832,147.626892089844 -5.35222244262695,147.602172851562 -5.3619441986084,147.596618652344 -5.36305522918701)),((148.114685058594 -5.4688892364502,148.087463378906 -5.45527839660645,148.079132080078 -5.44972133636475,148.077178955078 -5.44499969482422,148.073028564453 -5.43000030517578,148.071624755859 -5.4244441986084,148.072204589844 -5.41833305358887,148.084686279297 -5.38972282409668,148.090789794922 -5.38222217559814,148.099700927734 -5.3774995803833,148.117462158203 -5.3841667175293,148.122192382812 -5.38638877868652,148.136657714844 -5.39944458007812,148.139434814453 -5.40333366394043,148.143585205078 -5.41305541992188,148.144989013672 -5.41833305358887,148.145538330078 -5.43833255767822,148.143585205078 -5.44972133636475,148.138031005859 -5.45805549621582,148.133880615234 -5.46083354949951,148.125793457031 -5.4661111831665,148.120788574219 -5.4683332
 4432373,148.114685058594 -5.4688892364502)),((155.404083251953 -6,155.41552734375 -6.07638931274414,155.418853759766 -6.08666706085205,155.428588867188 -6.11111068725586,155.430541992188 -6.1158332824707,155.432739257812 -6.12083339691162,155.477172851562 -6.16916656494141,155.490783691406 -6.18277740478516,155.499114990234 -6.18805503845215,155.562744140625 -6.21749973297119,155.577178955078 -6.22361087799072,155.582733154297 -6.22500038146973,155.5888671875 -6.22416687011719,155.614959716797 -6.22000026702881,155.767761230469 -6.35583305358887,155.772491455078 -6.35777759552002,155.795257568359 -6.36250019073486,155.809692382812 -6.36861038208008,155.813598632812 -6.37138843536377,155.832733154297 -6.39861106872559,155.909698486328 -6.51222229003906,155.917755126953 -6.52444458007812,155.921905517578 -6.53416633605957,155.965789794922 -6.70555591583252,155.967193603516 -6.71111106872559,155.967742919922 -6.71722221374512,155.966644287109 -6.72277736663818,155.948028564453
 -6.77583312988281,155.940521240234 -6.78861141204834,155.918579101562 -6.80777740478516,155.913024902344 -6.80916595458984,155.909698486328 -6.80555534362793,155.908874511719 -6.7994441986084,155.890533447266 -6.77972221374512,155.860778808594 -6.77500057220459,155.854675292969 -6.77444458007812,155.848571777344 -6.77500057220459,155.823852539062 -6.77777767181396,155.816375732422 -6.78055572509766,155.775268554688 -6.81444454193115,155.748565673828 -6.84249973297119,155.742462158203 -6.84999942779541,155.719696044922 -6.875,155.713012695312 -6.88194370269775,155.707458496094 -6.88333320617676,155.69384765625 -6.88333320617676,155.623840332031 -6.868332862854,155.558868408203 -6.85249996185303,155.4921875 -6.83027839660645,155.47802734375 -6.82416725158691,155.444976806641 -6.80916595458984,155.342742919922 -6.74361133575439,155.3388671875 -6.74111080169678,155.335235595703 -6.73750019073486,155.239959716797 -6.62249946594238,155.192749023438 -6.56055545806885,155.2016296386
 72 -6.53472232818604,155.207183837891 -6.53472232818604,155.2099609375 -6.53055572509766,155.216064453125 -6.51638889312744,155.224975585938 -6.47749996185303,155.232452392578 -6.44416618347168,155.233306884766 -6.43805503845215,155.233306884766 -6.4244441986084,155.230529785156 -6.36305522918701,155.226348876953 -6.34694480895996,155.218841552734 -6.32916736602783,155.214141845703 -6.32027816772461,155.204406738281 -6.3086109161377,155.190795898438 -6.29500007629395,155.187194824219 -6.29166698455811,155.174987792969 -6.28333282470703,155.127746582031 -6.2761116027832,155.101623535156 -6.27722263336182,155.063293457031 -6.25694561004639,154.994110107422 -6.21666622161865,154.981628417969 -6.20861148834229,154.972198486328 -6.19777774810791,154.969970703125 -6.19277763366699,154.888580322266 -6.07916736602783,154.880249023438 -6.07361125946045,154.823577880859 -6.02805614471436,154.755645751953 -5.95617389678955,154.746643066406 -5.94450378417969,154.744384765625 -5.93978023
 529053,154.700469970703 -5.78020095825195,154.698577880859 -5.76851844787598,154.699432373047 -5.7623987197876,154.71826171875 -5.6700611114502,154.753601074219 -5.51805591583252,154.79052734375 -5.47916698455811,154.794128417969 -5.48250007629395,154.882446289062 -5.54333305358887,154.920806884766 -5.54999923706055,154.961090087891 -5.54666709899902,154.967468261719 -5.54611110687256,155.073577880859 -5.56166648864746,155.162353515625 -5.73234081268311,155.216064453125 -5.86872386932373,155.268798828125 -5.88423919677734,155.277679443359 -5.88895511627197,155.365020751953 -5.95777797698975,155.371643066406 -5.96472263336182,155.400543212891 -5.99583339691162,155.404083251953 -6)),((147.990478515625 -5.85603713989258,147.983520507812 -5.82075119018555,147.982116699219 -5.81519317626953,147.974609375 -5.79546737670898,147.972381591797 -5.79074478149414,147.968475341797 -5.78796863555908,147.945220947266 -5.77992534637451,147.93359375 -5.7777099609375,147.927490234375 -5.77854
 824066162,147.922790527344 -5.78049659729004,147.865112304688 -5.74775314331055,147.802154541016 -5.67277145385742,147.793273925781 -5.66138458251953,147.769958496094 -5.62221908569336,147.766052246094 -5.61277484893799,147.765228271484 -5.60666275024414,147.761108398438 -5.52833366394043,147.761932373047 -5.5222225189209,147.7802734375 -5.49416637420654,147.783874511719 -5.4908332824707,147.814697265625 -5.48472213745117,147.841918945312 -5.48999977111816,147.852172851562 -5.49361133575439,148.008605957031 -5.57611179351807,148.020812988281 -5.58416652679443,148.040802001953 -5.59861087799072,148.044128417969 -5.60194396972656,148.065307617188 -5.62758445739746,148.074279785156 -5.64482402801514,148.078460693359 -5.65427875518799,148.080444335938 -5.66595458984375,148.078552246094 -5.69124603271484,148.076629638672 -5.70347595214844,148.072540283203 -5.72654151916504,148.067840576172 -5.74905109405518,148.061492919922 -5.77711772918701,148.057586669922 -5.78656482696533,148
 .017150878906 -5.84463882446289,148.000762939453 -5.85269927978516,147.990478515625 -5.85603713989258)),((149.048034667969 -6.09555530548096,149.043304443359 -6.09333324432373,149.043853759766 -6.0886116027832,149.045257568359 -6.0872220993042,149.054138183594 -6.08388900756836,149.058319091797 -6.08666706085205,149.057739257812 -6.09138870239258,149.053588867188 -6.09416675567627,149.048034667969 -6.09555530548096)),((143.994415283203 -7.82583332061768,143.984680175781 -7.8230562210083,143.943572998047 -7.80277729034424,143.934692382812 -7.79805564880371,143.923583984375 -7.78861141204834,143.91748046875 -7.78111171722412,143.914703369141 -7.77694511413574,143.877746582031 -7.7186107635498,143.875793457031 -7.71388912200928,143.877166748047 -7.7097225189209,143.88134765625 -7.70694446563721,143.886657714844 -7.70833396911621,143.959411621094 -7.74222183227539,143.966918945312 -7.74833297729492,143.979125976562 -7.76333427429199,144.000549316406 -7.78999996185303,144.0080261
 23047 -7.80277729034424,144.009429931641 -7.80833339691162,144.008605957031 -7.81416606903076,144.006652832031 -7.819167137146,143.999694824219 -7.82444477081299,143.994415283203 -7.82583332061768)),((145.193572998047 -7.86722183227539,145.186645507812 -7.86722183227539,145.182464599609 -7.86444473266602,145.180541992188 -7.86111068725586,145.177764892578 -7.83666706085205,145.178314208984 -7.83055591583252,145.182464599609 -7.82777786254883,145.185241699219 -7.83055591583252,145.191345214844 -7.84083366394043,145.197479248047 -7.85499954223633,145.198852539062 -7.86055564880371,145.197479248047 -7.86444473266602,145.193572998047 -7.86722183227539)),((143.727752685547 -8.10222244262695,143.697479248047 -8.08444404602051,143.683319091797 -8.07833290100098,143.661376953125 -8.07277679443359,143.618011474609 -8.07222175598145,143.599700927734 -8.07416725158691,143.588562011719 -8.0716667175293,143.582458496094 -8.06416702270508,143.569427490234 -8.04305648803711,143.56607055664
 1 -8.03277778625488,143.565246582031 -8.02000045776367,143.568023681641 -8.01583480834961,143.574127197266 -8.01388931274414,143.629669189453 -8.00638961791992,143.635803222656 -8.00583457946777,143.642761230469 -8.00583457946777,143.651092529297 -8.00833511352539,143.66943359375 -8.0172233581543,143.682464599609 -8.02472305297852,143.697479248047 -8.03694534301758,143.707733154297 -8.04722213745117,143.731079101562 -8.0716667175293,143.737182617188 -8.07888793945312,143.739959716797 -8.08305549621582,143.741333007812 -8.0886116027832,143.739410400391 -8.09333229064941,143.733306884766 -8.10083198547363,143.727752685547 -8.10222244262695)),((143.66552734375 -8.17611122131348,143.654968261719 -8.17250061035156,143.625518798828 -8.15416717529297,143.621612548828 -8.15166664123535,143.618835449219 -8.14750099182129,143.607727050781 -8.13055419921875,143.604949951172 -8.11972045898438,143.604400634766 -8.11361122131348,143.604949951172 -8.10888862609863,143.609130859375 -8.10610
 961914062,143.636657714844 -8.09249877929688,143.642211914062 -8.09055519104004,143.654968261719 -8.0897216796875,143.679138183594 -8.09333229064941,143.688568115234 -8.09722137451172,143.700256347656 -8.10610961914062,143.707183837891 -8.11277770996094,143.710510253906 -8.11638832092285,143.716064453125 -8.12444305419922,143.718841552734 -8.13527870178223,143.719421386719 -8.15500068664551,143.7119140625 -8.16111183166504,143.702453613281 -8.1652774810791,143.683319091797 -8.1733341217041,143.677764892578 -8.17472267150879,143.66552734375 -8.17611122131348)),((143.685791015625 -8.24722099304199,143.659973144531 -8.241943359375,143.654418945312 -8.24055480957031,143.650268554688 -8.23777770996094,143.648315429688 -8.23305511474609,143.648864746094 -8.22694396972656,143.651641845703 -8.19972229003906,143.666656494141 -8.19305610656738,143.726898193359 -8.17388916015625,143.733306884766 -8.17472267150879,143.737182617188 -8.17722320556641,143.755828857422 -8.20527839660645,143
 .756378173828 -8.20861053466797,143.755249023438 -8.21388816833496,143.752471923828 -8.21805572509766,143.7421875 -8.22833251953125,143.734680175781 -8.23444366455078,143.718841552734 -8.23916625976562,143.697479248047 -8.24527740478516,143.685791015625 -8.24722099304199)),((143.687194824219 -8.43972206115723,143.680541992188 -8.43972206115723,143.670257568359 -8.43638801574707,143.651641845703 -8.42749977111816,143.630523681641 -8.40722274780273,143.610504150391 -8.38611221313477,143.584411621094 -8.3577766418457,143.607177734375 -8.33277702331543,143.612731933594 -8.33388900756836,143.653045654297 -8.34222221374512,143.658599853516 -8.3436107635498,143.66552734375 -8.34749984741211,143.672210693359 -8.35444450378418,143.677764892578 -8.36249923706055,143.692199707031 -8.39583396911621,143.694976806641 -8.40666770935059,143.698303222656 -8.42361068725586,143.698303222656 -8.43027877807617,143.696929931641 -8.43555641174316,143.692749023438 -8.43833351135254,143.687194824219
  -8.43972206115723)),((143.57275390625 -8.49388885498047,143.559143066406 -8.49388885498047,143.509155273438 -8.48250007629395,143.498016357422 -8.47972106933594,143.493286132812 -8.4777774810791,143.354949951172 -8.41805648803711,143.318572998047 -8.39305686950684,143.315795898438 -8.38888931274414,143.314422607422 -8.38361167907715,143.314422607422 -8.37666511535645,143.319427490234 -8.36916542053223,143.326904296875 -8.3630542755127,143.331634521484 -8.36111068725586,143.339141845703 -8.35833358764648,143.342742919922 -8.3577766418457,143.356353759766 -8.3577766418457,143.494689941406 -8.3630542755127,143.573577880859 -8.37194442749023,143.578308105469 -8.37388801574707,143.581085205078 -8.37805557250977,143.616058349609 -8.46277809143066,143.616058349609 -8.4688892364502,143.613861083984 -8.47360992431641,143.610504150391 -8.47694396972656,143.583862304688 -8.49138832092285,143.578857421875 -8.49333190917969,143.57275390625 -8.49388885498047)),((143.632446289062 -8.73444
 366455078,143.60107421875 -8.6924991607666,143.585784912109 -8.67972183227539,143.487731933594 -8.62888717651367,143.3671875 -8.54472351074219,143.278869628906 -8.51027870178223,143.269989013672 -8.50555610656738,143.252777099609 -8.49527740478516,143.240509033203 -8.48722076416016,143.182189941406 -8.42972183227539,143.180816650391 -8.42416763305664,143.18359375 -8.42000007629395,143.211639404297 -8.4152774810791,143.217742919922 -8.41611099243164,143.227447509766 -8.42611122131348,143.233032226562 -8.43444442749023,143.251373291016 -8.45666694641113,143.261657714844 -8.46694374084473,143.274688720703 -8.47444343566895,143.324676513672 -8.48583221435547,143.371337890625 -8.49388885498047,143.422760009766 -8.51083374023438,143.467193603516 -8.52777862548828,143.644134521484 -8.66472244262695,143.647491455078 -8.66805648803711,143.651641845703 -8.67777824401855,143.653045654297 -8.68305587768555,143.653594970703 -8.68916702270508,143.653045654297 -8.7005558013916,143.64135742
 1875 -8.72972106933594,143.638031005859 -8.73305511474609,143.632446289062 -8.73444366455078)),((151.144439697266 -8.8305549621582,151.094970703125 -8.7711124420166,151.10107421875 -8.63888931274414,151.05859375 -8.55166625976562,151.052459716797 -8.55222320556641,151.034698486328 -8.55222320556641,151.029144287109 -8.55083274841309,151.003051757812 -8.54277801513672,150.999694824219 -8.53944396972656,150.997741699219 -8.53472328186035,150.996917724609 -8.52861213684082,150.997741699219 -8.52250099182129,151.024993896484 -8.46694374084473,151.033325195312 -8.45472145080566,151.054412841797 -8.43499946594238,151.062744140625 -8.42972183227539,151.076354980469 -8.42611122131348,151.118286132812 -8.42000007629395,151.124969482422 -8.42000007629395,151.124969482422 -8.42555618286133,151.123840332031 -8.62472152709961,151.103302001953 -8.72916603088379,151.102447509766 -8.741943359375,151.103851318359 -8.7541675567627,151.107177734375 -8.76444625854492,151.144439697266 -8.8305549
 621582)),((152.835510253906 -9.23555564880371,152.829956054688 -9.22333335876465,152.679962158203 -9.09055519104004,152.6533203125 -9.06972122192383,152.649139404297 -9.06694412231445,152.573028564453 -9.02027893066406,152.563598632812 -9.01611137390137,152.556640625 -9.01611137390137,152.540252685547 -9.02027893066406,152.499694824219 -9.02500152587891,152.497741699219 -9.02166748046875,152.5244140625 -8.99305534362793,152.527770996094 -8.98972129821777,152.532470703125 -8.98777770996094,152.619689941406 -8.96138954162598,152.625793457031 -8.96055603027344,152.647216796875 -8.96138954162598,152.8046875 -8.96944427490234,152.810241699219 -8.97083282470703,152.814971923828 -8.97277641296387,152.93359375 -9.04388999938965,152.937744140625 -9.04666709899902,152.952758789062 -9.05888938903809,153.017761230469 -9.11777687072754,153.020538330078 -9.12166595458984,153.019989013672 -9.12638854980469,153.002777099609 -9.16500091552734,152.997192382812 -9.17305564880371,152.9930114746
 09 -9.17583274841309,152.98828125 -9.17777824401855,152.982177734375 -9.17722320556641,152.835510253906 -9.23555564880371)),((150.334411621094 -9.52666664123535,150.310241699219 -9.5261116027832,150.193023681641 -9.45388793945312,150.180816650391 -9.44555473327637,150.173858642578 -9.43888854980469,150.110778808594 -9.37277603149414,150.108306884766 -9.36861038208008,150.103302001953 -9.33694458007812,150.102752685547 -9.33083343505859,150.104125976562 -9.31861114501953,150.106903076172 -9.30777740478516,150.123291015625 -9.2630558013916,150.126068115234 -9.26027870178223,150.143859863281 -9.24555397033691,150.189147949219 -9.21111106872559,150.198028564453 -9.20777702331543,150.206909179688 -9.2055549621582,150.2138671875 -9.2055549621582,150.232177734375 -9.20777702331543,150.326904296875 -9.26916694641113,150.330810546875 -9.27194595336914,150.333038330078 -9.27666664123535,150.376892089844 -9.38333320617676,150.37744140625 -9.38944435119629,150.363006591797 -9.4874992370
 6055,150.344696044922 -9.51666641235352,150.339141845703 -9.52472305297852,150.334411621094 -9.52666664123535)),((150.846923828125 -9.71805572509766,150.844116210938 -9.68555641174316,150.801635742188 -9.65861129760742,150.763305664062 -9.66250038146973,150.691345214844 -9.66333389282227,150.661102294922 -9.66333389282227,150.654968261719 -9.66250038146973,150.622741699219 -9.65388870239258,150.514434814453 -9.62333297729492,150.490509033203 -9.58361053466797,150.427459716797 -9.44083404541016,150.423309326172 -9.43138885498047,150.419982910156 -9.41472244262695,150.419982910156 -9.4011116027832,150.421905517578 -9.38944435119629,150.426086425781 -9.37666511535645,150.435791015625 -9.35916519165039,150.442474365234 -9.35499954223633,150.473571777344 -9.33888816833496,150.478851318359 -9.33749961853027,150.481628417969 -9.33694458007812,150.487731933594 -9.33749961853027,150.498840332031 -9.34027671813965,150.505554199219 -9.34222221374512,150.5302734375 -9.35166549682617,150
 .571350097656 -9.37055397033691,150.598022460938 -9.38500022888184,150.618011474609 -9.39777946472168,150.624969482422 -9.40444564819336,150.63525390625 -9.42194557189941,150.639434814453 -9.42472267150879,150.666656494141 -9.43833351135254,150.676910400391 -9.4416675567627,150.683044433594 -9.44083404541016,150.731903076172 -9.42805671691895,150.7421875 -9.42472267150879,150.746063232422 -9.42138862609863,150.748291015625 -9.41805648803711,150.754974365234 -9.40444564819336,150.760528564453 -9.40444564819336,150.765258789062 -9.4063892364502,150.777770996094 -9.41472244262695,150.804412841797 -9.43277740478516,150.828308105469 -9.45638847351074,150.885803222656 -9.52083396911621,150.888031005859 -9.52555656433105,150.931915283203 -9.64166831970215,150.932464599609 -9.64777946472168,150.930541992188 -9.65916633605957,150.921630859375 -9.67083358764648,150.906646728516 -9.68277740478516,150.901092529297 -9.68138885498047,150.896362304688 -9.67416763305664,150.893585205078 -9.
 67194557189941,150.888580322266 -9.67138862609863,150.876892089844 -9.67749977111816,150.873565673828 -9.68083381652832,150.846923828125 -9.71805572509766)),((151.229125976562 -10.2011108398438,151.19775390625 -10.1727771759033,151.190246582031 -10.1669454574585,151.148315429688 -10.1472234725952,151.143585205078 -10.1452789306641,151.086639404297 -10.1269435882568,151.075805664062 -10.1244430541992,151.025817871094 -10.1141662597656,151.001647949219 -10.1108322143555,150.994964599609 -10.1108322143555,150.983306884766 -10.1127777099609,150.970245361328 -10.1122207641602,150.958587646484 -10.1102771759033,150.94970703125 -10.1055545806885,150.91552734375 -10.0041675567627,150.877746582031 -9.92666625976562,150.826904296875 -9.83888816833496,150.762481689453 -9.80500030517578,150.758605957031 -9.80249977111816,150.750274658203 -9.74833297729492,150.748840332031 -9.73083305358887,150.757202148438 -9.71194458007812,150.759979248047 -9.70777702331543,150.763885498047 -9.70499992
 370605,150.769439697266 -9.70666694641113,150.788024902344 -9.71944427490234,150.803039550781 -9.73138809204102,150.821624755859 -9.74694442749023,150.900268554688 -9.81916618347168,150.931915283203 -9.8488883972168,150.938873291016 -9.85583305358887,150.962738037109 -9.89361190795898,151.030548095703 -9.98527717590332,151.039428710938 -9.99694442749023,151.059967041016 -10.0169448852539,151.073028564453 -10.0244445800781,151.111358642578 -10.0447244644165,151.116058349609 -10.046667098999,151.122467041016 -10.0475006103516,151.136657714844 -10.041389465332,151.147216796875 -10.0325012207031,151.149139404297 -10.0277786254883,151.149719238281 -10.0219459533691,151.147766113281 -10.0169448852539,151.143585205078 -10.0088901519775,151.140808105469 -10.0050010681152,151.136657714844 -10.0022239685059,151.134704589844 -9.99749946594238,151.134704589844 -9.9908332824707,151.138031005859 -9.98749923706055,151.184143066406 -9.94472312927246,151.192199707031 -9.93944358825684,151.20
 0531005859 -9.93666648864746,151.26416015625 -9.91972160339355,151.281372070312 -9.9233341217041,151.284149169922 -9.92722320556641,151.298583984375 -9.95083236694336,151.299133300781 -9.96249961853027,151.296356201172 -9.97305488586426,151.271087646484 -10.0616655349731,151.252471923828 -10.0974998474121,151.246337890625 -10.1047210693359,151.243560791016 -10.1088886260986,151.234130859375 -10.1330547332764,151.221618652344 -10.1708335876465,151.221618652344 -10.1816673278809,151.222473144531 -10.1877784729004,151.223846435547 -10.1930561065674,151.229125976562 -10.2011108398438)),((150.880523681641 -10.6527786254883,150.856353759766 -10.6494445800781,150.794128417969 -10.6394443511963,150.785247802734 -10.6347236633301,150.769439697266 -10.6111106872559,150.767486572266 -10.6075000762939,150.788024902344 -10.5463886260986,150.790802001953 -10.5422229766846,150.794708251953 -10.539722442627,150.798858642578 -10.5383338928223,150.868835449219 -10.5383338928223,150.8749694824
 22 -10.5388889312744,150.892211914062 -10.547779083252,150.900268554688 -10.5530548095703,150.904418945312 -10.5625,150.894989013672 -10.6466665267944,150.892211914062 -10.6508331298828,150.880523681641 -10.6527786254883)),((150.927185058594 -10.6838893890381,150.923034667969 -10.6825008392334,150.920257568359 -10.6783332824707,150.911926269531 -10.65944480896,150.909973144531 -10.6547222137451,150.909149169922 -10.6419448852539,150.909973144531 -10.6358337402344,150.91943359375 -10.6130542755127,150.922210693359 -10.6088886260986,150.9296875 -10.6030540466309,150.934692382812 -10.6008319854736,150.94970703125 -10.59694480896,151.016082763672 -10.5908336639404,151.064147949219 -10.5922222137451,151.066925048828 -10.5947227478027,151.06884765625 -10.5980548858643,151.069702148438 -10.6111106872559,151.063293457031 -10.6438903808594,151.049133300781 -10.6702785491943,151.042205810547 -10.676944732666,151.036651611328 -10.6783332824707,151.031372070312 -10.676944732666,151.0099
 79248047 -10.6683330535889,151.008026123047 -10.6636123657227,151.003875732422 -10.6472234725952,151.001647949219 -10.6427783966064,150.994110107422 -10.6366672515869,150.988861083984 -10.6352787017822,150.941345214844 -10.6347236633301,150.936096191406 -10.6347236633301,150.929138183594 -10.6547222137451,150.927185058594 -10.6838893890381)),((152.744415283203 -10.7166652679443,152.702453613281 -10.7066669464111,152.686920166016 -10.7019443511963,152.573852539062 -10.6569442749023,152.564971923828 -10.6522235870361,152.544982910156 -10.6380558013916,152.541656494141 -10.6338901519775,152.540802001953 -10.6305541992188,152.542205810547 -10.6277770996094,152.555236816406 -10.6230554580688,152.562194824219 -10.6230554580688,152.573852539062 -10.6252765655518,152.614959716797 -10.6386127471924,152.690246582031 -10.6627788543701,152.693023681641 -10.6627788543701,152.759429931641 -10.6372222900391,152.784973144531 -10.6211109161377,152.790252685547 -10.6197204589844,152.814971923
 828 -10.6291656494141,152.870513916016 -10.6580562591553,152.873291015625 -10.6622219085693,152.873840332031 -10.6683330535889,152.873291015625 -10.6730556488037,152.870513916016 -10.676944732666,152.863586425781 -10.6825008392334,152.844970703125 -10.6952781677246,152.814971923828 -10.6966667175293,152.744415283203 -10.7166652679443)),((153.210510253906 -11.2858333587646,153.181640625 -11.2522239685059,153.143859863281 -11.2247219085693,153.13916015625 -11.2227764129639,153.120513916016 -11.2166652679443,153.114959716797 -11.2152767181396,153.106079101562 -11.2147216796875,153.093292236328 -11.2019443511963,153.091064453125 -11.1972217559814,153.093841552734 -11.1930561065674,153.102172851562 -11.1888885498047,153.112457275391 -11.1844444274902,153.123840332031 -11.1849994659424,153.12939453125 -11.1863880157471,153.198028564453 -11.2172222137451,153.2138671875 -11.2247219085693,153.222747802734 -11.2294454574585,153.251373291016 -11.2469444274902,153.250579833984 -11.25,15
 3.25 -11.2522239685059,153.241058349609 -11.2688903808594,153.210510253906 -11.2858333587646)),((154.112182617188 -11.4397220611572,154.106628417969 -11.4397220611572,154.062744140625 -11.4330558776855,154.058013916016 -11.4308338165283,154.006652832031 -11.3872222900391,154.003326416016 -11.3838901519775,154.021087646484 -11.3488883972168,154.089691162109 -11.3152770996094,154.153869628906 -11.3141670227051,154.225250244141 -11.3194446563721,154.268310546875 -11.338888168335,154.276641845703 -11.344165802002,154.286376953125 -11.3605556488037,154.288299560547 -11.3649997711182,154.297760009766 -11.3919448852539,154.289703369141 -11.4108333587646,154.285522460938 -11.4136123657227,154.266387939453 -11.421667098999,154.263031005859 -11.4180555343628,154.26025390625 -11.4075012207031,154.256103515625 -11.4047222137451,154.250549316406 -11.4033336639404,154.190246582031 -11.3994445800781,154.137481689453 -11.3986110687256,154.134704589844 -11.4027786254883,154.112182617188 -11.
 4397220611572)),((153.566070556641 -11.6424999237061,153.522216796875 -11.602222442627,153.479125976562 -11.5733337402344,153.421356201172 -11.5686111450195,153.376068115234 -11.5672225952148,153.3671875 -11.557222366333,153.364410400391 -11.5530548095703,153.363861083984 -11.5472221374512,153.376068115234 -11.5269451141357,153.382446289062 -11.5197219848633,153.38720703125 -11.5108337402344,153.388580322266 -11.5055561065674,153.387756347656 -11.5008344650269,153.384429931641 -11.4974994659424,153.325531005859 -11.4752769470215,153.276916503906 -11.4624996185303,153.271911621094 -11.4605560302734,153.268585205078 -11.4572219848633,153.190521240234 -11.3730554580688,153.188293457031 -11.3683319091797,153.187194824219 -11.3536109924316,153.187194824219 -11.3497219085693,153.198028564453 -11.3241672515869,153.200805664062 -11.3199996948242,153.220520019531 -11.3274993896484,153.291931152344 -11.3569431304932,153.398040771484 -11.4047222137451,153.413879394531 -11.4161109924316
 ,153.426910400391 -11.4302787780762,153.437744140625 -11.4397220611572,153.507751464844 -11.4724998474121,153.559143066406 -11.491943359375,153.570251464844 -11.494722366333,153.576354980469 -11.4955539703369,153.645538330078 -11.5150012969971,153.686645507812 -11.5269451141357,153.751098632812 -11.5644445419312,153.754425048828 -11.5680561065674,153.7763671875 -11.5974998474121,153.777770996094 -11.6027765274048,153.7763671875 -11.6080551147461,153.7744140625 -11.6130542755127,153.770812988281 -11.6163883209229,153.676361083984 -11.6283321380615,153.670257568359 -11.6277770996094,153.605804443359 -11.6174983978271,153.598846435547 -11.6174983978271,153.582458496094 -11.6283321380615,153.566070556641 -11.6424999237061)))
-  </op>
-</test>
-</case>
-</run>
Deleted: trunk/tests/xmltester/tests/bug275.xml
--- trunk/tests/xmltester/tests/bug275.xml	2011-04-20 15:42:03 UTC (rev 3289)
+++ trunk/tests/xmltester/tests/bug275.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -1,31 +0,0 @@
-<run>
-  <desc>
-http://trac.osgeo.org/geos/ticket/275
-  </desc>
-  <precisionModel type="FLOATING" />
-<case>
-  <desc>
-  </desc>
-  <a>
-MULTIPOLYGON (((97.4196581300587923 1391.7094503287939915, 1097.3929445351700451 1659.6432199333848985, 2097.6867783781326580 1391.5243492190379584, 2829.5979618286305595 659.3760732813996128, 3097.3929252677053228 -340.6343946513263745, 2829.3203546600025220 -1340.5704802618731719, 2566.4316545475776365 -1603.3983692935935323, 2589.9586987092807249 -1691.2539814346002913, 2550.3216026895242976 -1839.1041048139375107, 2582.0225141513105882 -1957.4828931887502677, 2523.0465473393464890 -2177.4688367911371643, 2361.9813735858801920 -2338.4967531528800464, 2141.9817920466971373 -2397.4218256316030420, 1921.9931199150225893 -2338.4560374338593647, 1915.5094890288899023 -2331.9715065100085667, 1790.8032356108271870 -2365.3730474120334293, 1773.3588004956532131 -2360.6972390794344392, 1755.9014460409671301 -2365.3730474120334293, 1535.9127739092928095 -2306.4072592142892972, 1470.0174606543544087 -2240.5027985744332000, 1267.8188705444704283 -2294.6600223925997852, 1145.5500718010
 853234 -2750.7342254735290226, 779.4928666591022193 -3116.7067547270667092, 279.4938285436001593 -3250.6273710942414255, -220.4804154644647269 -3116.6142190040254718, -276.8825358097809044 -3060.2042690896628301, -317.8708072633123720 -3042.4487397531365787, -317.0081043084857697 -3040.4572078632113517, -353.9188796380849453 -3025.9673133506230442, -481.8759722620623052 -2952.0780561800302166, -597.3916747239470624 -2859.9435764086629206, -697.8857092860117746 -2751.6218846962374300, -781.1133376604859677 -2629.5325659449085833, -845.2155017965442312 -2496.4027329581699632, -881.7734250743712892 -2377.8616075414415718, -883.2163026251768088 -2378.2274205979942963, -915.6765245378969666 -2250.1944686487954641, -958.6488338256679071 -2176.6893024190303549, -958.3104527203266798 -2176.4914793507796276, -961.3773376604859777 -2171.9925659449086197, -1025.4795017965443549 -2038.8627329581699996, -1069.0243497161841333 -1897.6661108397263433, -1091.0392188351402183 -1751.556612805
 9626863, -1091.0323623564322588 -1603.7978911310922285, -1089.6762878232161711 -1594.8034867385058533, -1104.6051239273215288 -1541.4387753320572756, -1142.1697554404233870 -1500.9481685832554376, -1144.1735018958338514 -1502.8286850026515822, -1237.9475018958337387 -1402.9096850026517131, -1235.9437554404232742 -1401.0291685832553412, -1283.8694719642787732 -1349.3704336840412452, -1284.3641704239839783 -1349.7723644815778243, -1285.2860836559341351 -1348.6376690100614724, -1338.3270735958196838 -1329.0603190321844522, -1337.4416005745254097 -1326.6613035542172838, -1425.0218796380850108 -1292.2803133506229187, -1552.9789722620623706 -1218.3910561800300911, -1668.4946747239471279 -1126.2565764086627951, -1679.3254791566805579 -1114.5821415641194108, -1680.0605373265407252 -1115.3491207030931491, -1702.7503708819851909 -1093.6036172334481762, -1770.9343685341837045 -1058.4171540195427497, -1770.1722772833329600 -1056.9403807575390601, -1874.5379722620623397 -996.674056180030
 1066, -1895.7478836933294133 -979.7571858838782646, -1896.7182978644157174 -981.0996960943623435, -2746.6499049371641377 -366.7388744659292570, -2763.2967822031337164 -362.2768436281256186, -2790.5987539714260492 -334.9710818839997160, -2790.5987539714260492 -334.9710818839996023, -2842.3952978644156246 -297.5306960943622698, -2841.4248836933293205 -296.1881858838783614, -2935.7306747239472315 -220.9705764086628506, -3036.2247092860116027 -112.6488846962375874, -3086.2207836436286925 -39.3080148699587753, -3129.2862482014747911 3.7634279033554208, -3145.0472131318642823 62.5968530737783055, -3145.0472131318642823 62.5968530737785258, -3183.5545017965441730 142.5702670418300499, -3227.0993497161844061 283.7668891602737631, -3249.1142188351404911 429.8763871940373633, -3249.1132358283407484 451.0604139114426516, -3263.2299989295852356 503.7562690975839246, -3249.1083453730552719 556.4508704679574294, -3249.1073623564325317 577.6351088689078779, -3227.0789334334317573 723.74256
 31523476568, -3183.5209817488726003 864.9351434214565870, -3145.0063950996932363 944.9047260716176879, -3129.2399803399048324 1003.7367132380807107, -3086.1705453954227778 1046.8041554447745511, -3036.1675038980588397 1120.1406209104106892, -2935.6634168207938274 1228.4529856651729460, -2820.1391641855243506 1320.5767444414277634, -2801.7930339334729979 1331.1685093202834196, -2763.2166432025555878 1369.7431151977043555, -2710.5214060758321466 1383.8623258961499687, -2692.1752147154593331 1394.4541260546511694, -2554.6299030180371119 1448.4349291985654418, -2410.5755828783944708 1481.3133830416004457, -2322.0627096881689795 1487.9463092123467050, -2263.2300000000000182 1503.7100000000000364, -2204.3990753125572155 1487.9409523895812981, -2115.7029639281322488 1481.2860169705504632, -1971.6547489328795564 1448.3808253636827885, -1834.1194591345197296 1394.3744929749309449, -1815.7587157038797159 1383.7697470828661608, -1763.0830830785189391 1369.6505646428263390, -1724.513755
 0381382425 1331.0687426030108327, -1706.1692244587284222 1320.4733608833789731, -1685.0325693031700212 1303.6117095115282609, -1684.0647021355841844 1304.9506960943622289, -798.3848875647835257 664.7497975144585780, -668.7086314658160973 597.8301540195427606, -669.4687336638634179 596.3572351253640136, -653.9962840476707697 587.4207017476531973, -634.6270161446395832 659.6966464095463607, 97.4196581300587923 1391.7094503287939915)))
-  </a>
-  <b>
-POLYGON ((-3138.9918179090095691 39.9929298181513317, -3195.9318721744207323 131.7765582775780331, -3194.3605115562841092 132.7513874532058367, -3212.0423376604862824 158.6894340550911124, -3276.1445017965443185 291.8192670418299599, -3319.6893497161845517 433.0158891602736730, -3341.7042188351406367 579.1253871940372164, -3341.7041685876552037 580.2082322725017320, -3341.7842797495400191 580.2023206768839145, -3358.7842797495400191 810.5783206768840046, -3358.7041685876552037 810.5842322725018221, -3358.6973623564326772 957.2601088689078779, -3336.6689334334319028 1103.3675631523476568, -3293.1109817488727458 1244.5601434214565870, -3260.5234971247000431 1312.2230153808816340, -3296.6374455479131029 1414.0631037763496352, -3294.8380822260414789 1414.7011836840215437, -3328.7143497161841879 1524.5468891602736221, -3349.7012648829327190 1663.8340056869151340, -3350.1912493926529351 1663.7938778131951949, -3510.7782493926529241 3624.6538778131953222, -3510.2882648829327081 362
 4.6940056869152613, -3511.3162188351402619 3631.5163871940371791, -3511.3093623564318477 3779.2751088689078642, -3489.2809334334315281 3925.3825631523477568, -3445.7229817488723711 4066.5751434214562323, -3381.6084625862131361 4199.6990267427599974, -3298.3695038980586105 4321.7806209104110167, -3197.8654168207931434 4430.0929856651728187, -3082.3411641855241214 4522.2167444414280908, -2954.3772147154591039 4596.0941260546514968, -2816.8319030180368827 4650.0749291985657692, -2672.7775828783942416 4682.9533830416003184, -2592.0441774584969608 4689.0033359847420797, -2592.2292272141212379 4691.7359415891232857, 464.5127727858784965 4898.7359415891232857, 464.6978225415029442 4896.0033359847420797, 531.3099999999999454 4900.9950805664066138, 678.8370360718679422 4889.9260169705503358, 822.8852510671204072 4857.0208253636828886, 832.4966505855577452 4853.2466926456381771, 832.7155347673275401 4853.9304792686480141, 3440.9455347673278993 4019.0204792686481596, 3440.7266505855582
 182 4018.3366926456378678, 3568.6505408654807070 3968.1044929749309631, 3696.6007755412720144 3894.2033608833789913, 3812.1079268348321420 3802.0581609104569907, 3912.5919080161379497 3693.7271431733465761, 3995.8082053600896870 3571.6301008898981308, 4059.8980139174327633 3438.4943193843760127, 4103.4297576971002854 3297.2936566327280161, 4111.9568486815251163 3240.6649172772094971, 4114.5449810944692217 3241.0993479430067055, 4438.8449810944684941 1309.0733479430066382, 4436.2568486815243887 1308.6389172772094298, 4449.7310668223972243 1219.1561161070862909, 4449.7104973863315536 1071.3973957048663124, 4427.6685088490185080 925.2919864301782127, 4384.0974537747060822 784.1034492265001745, 4319.9705801376658201 650.9855167172314623, 4236.7202918527709699 528.9116481847523801, 4136.2061531259496405 420.6086113205509491, 4020.6733513123099328 328.4955743328730478, 3892.7025460983149969 254.6300689133272499, 3755.1522252283625676 200.6620310892940324, 3611.0948543776285078 167
 .7969465530077287, 3463.7482473934069276 156.7689236912091246, 3316.4036898899316839 167.8242957839195242, 3172.3524217021254117 200.7161186505198884, 3034.8121203619148218 254.7096866493769767, 2920.2486381949101997 320.8647580300017808, 2829.5979618286305595 659.3760732813996128, 2485.1041348942267177 1003.9814942180254320, 2264.2788423241918281 2319.5541328332446938, 409.7273757065412383 2913.2071331414008455, -1458.2438853899545848 2786.7096887882385090, -1390.0104079583070416 1953.5395283355223910, -1308.4375544520867152 1723.5068962236503012, -1310.2333181418257482 1722.8700927968927772, -1276.3402423028999237 1612.9336566327281162, -1254.3389331776024846 1466.8221161070862308, -1254.3595026136681554 1319.0633957048662523, -1256.0639743336037100 1307.7652980846462469, -1255.2787938929561733 1307.6972329071288641, -1257.2316394637061876 1285.1697643588329356, -1227.2802423028999783 1188.0186566327281525, -1205.2789331776025392 1041.9071161070862672, -1205.29049195638299
 35 958.8756534762312640, -1684.0647021355841844 1304.9506960943622289, -1685.0325693031700212 1303.6117095115282609, -1706.1692244587284222 1320.4733608833789731, -1724.5137550381382425 1331.0687426030108327, -1763.0830830785189391 1369.6505646428263390, -1815.7587157038797159 1383.7697470828661608, -1834.1194591345197296 1394.3744929749309449, -1971.6547489328795564 1448.3808253636827885, -2115.7029639281322488 1481.2860169705504632, -2204.3990753125572155 1487.9409523895812981, -2263.2300000000000182 1503.7100000000000364, -2322.0627096881689795 1487.9463092123467050, -2410.5755828783944708 1481.3133830416004457, -2554.6299030180371119 1448.4349291985654418, -2692.1752147154593331 1394.4541260546511694, -2710.5214060758321466 1383.8623258961499687, -2763.2166432025555878 1369.7431151977043555, -2801.7930339334729979 1331.1685093202834196, -2820.1391641855243506 1320.5767444414277634, -2935.6634168207938274 1228.4529856651729460, -3036.1675038980588397 1120.1406209104106892
 , -3086.1705453954227778 1046.8041554447745511, -3129.2399803399048324 1003.7367132380807107, -3145.0063950996932363 944.9047260716176879, -3183.5209817488726003 864.9351434214565870, -3227.0789334334317573 723.7425631523476568, -3249.1073623564325317 577.6351088689078779, -3249.1083453730552719 556.4508704679574294, -3263.2299989295852356 503.7562690975839246, -3249.1132358283407484 451.0604139114426516, -3249.1142188351404911 429.8763871940373633, -3227.0993497161844061 283.7668891602737631, -3183.5545017965441730 142.5702670418300499, -3145.0472131318642823 62.5968530737785258, -3145.0472131318642823 62.5968530737783055, -3138.9918179090095691 39.9929298181513317))
-  </b>
-<test>
-  <op name="isValid" arg1="A">true</op>
-</test>
-<test>
-  <op name="isValid" arg1="B">true</op>
-</test>
-<test>
- <op name="union" arg1="A" arg2="B">
-	POLYGON ((-3511.3162188351402619 3631.5163871940371791, -3511.3093623564318477 3779.2751088689078642, -3489.2809334334315281 3925.3825631523477568, -3445.7229817488723711 4066.5751434214562323, -3381.6084625862131361 4199.6990267427599974, -3298.3695038980586105 4321.7806209104110167, -3197.8654168207931434 4430.0929856651728187, -3082.3411641855241214 4522.2167444414280908, -2954.3772147154591039 4596.0941260546514968, -2816.8319030180368827 4650.0749291985657692, -2672.7775828783942416 4682.9533830416003184, -2592.0441774584969608 4689.0033359847420797, -2592.2292272141212379 4691.7359415891232857, 464.5127727858784965 4898.7359415891232857, 464.6978225415029442 4896.0033359847420797, 531.3099999999999454 4900.9950805664066138, 678.8370360718679422 4889.9260169705503358, 822.8852510671204072 4857.0208253636828886, 832.4966505855577452 4853.2466926456381771, 832.7155347673275401 4853.9304792686480141, 3440.9455347673278993 4019.0204792686481596, 3440.7266505855582182 4018.
 3366926456378678, 3568.6505408654807070 3968.1044929749309631, 3696.6007755412720144 3894.2033608833789913, 3812.1079268348321420 3802.0581609104569907, 3912.5919080161379497 3693.7271431733465761, 3995.8082053600896870 3571.6301008898981308, 4059.8980139174327633 3438.4943193843760127, 4103.4297576971002854 3297.2936566327280161, 4111.9568486815251163 3240.6649172772094971, 4114.5449810944692217 3241.0993479430067055, 4438.8449810944684941 1309.0733479430066382, 4436.2568486815243887 1308.6389172772094298, 4449.7310668223972243 1219.1561161070862909, 4449.7104973863315536 1071.3973957048663124, 4427.6685088490185080 925.2919864301782127, 4384.0974537747060822 784.1034492265001745, 4319.9705801376658201 650.9855167172314623, 4236.7202918527709699 528.9116481847523801, 4136.2061531259496405 420.6086113205509491, 4020.6733513123099328 328.4955743328730478, 3892.7025460983149969 254.6300689133272499, 3755.1522252283625676 200.6620310892940324, 3611.0948543776285078 167.79694655
 30077287, 3463.7482473934069276 156.7689236912091246, 3316.4036898899316839 167.8242957839195242, 3172.3524217021254117 200.7161186505198884, 3034.8121203619148218 254.7096866493769767, 2920.2486381949101997 320.8647580300017808, 3097.3929252677053228 -340.6343946513263745, 2829.3203546600025220 -1340.5704802618731719, 2566.4316545475776365 -1603.3983692935935323, 2589.9586987092807249 -1691.2539814346002913, 2550.3216026895242976 -1839.1041048139375107, 2582.0225141513105882 -1957.4828931887502677, 2523.0465473393464890 -2177.4688367911371643, 2361.9813735858801920 -2338.4967531528800464, 2141.9817920466971373 -2397.4218256316030420, 1921.9931199150225893 -2338.4560374338593647, 1915.5094890288899023 -2331.9715065100085667, 1790.8032356108271870 -2365.3730474120334293, 1773.3588004956532131 -2360.6972390794344392, 1755.9014460409671301 -2365.3730474120334293, 1535.9127739092928095 -2306.4072592142892972, 1470.0174606543544087 -2240.5027985744332000, 1267.8188705444704283 -2
 294.6600223925997852, 1145.5500718010853234 -2750.7342254735290226, 779.4928666591022193 -3116.7067547270667092, 279.4938285436001593 -3250.6273710942414255, -220.4804154644647269 -3116.6142190040254718, -276.8825358097809044 -3060.2042690896628301, -317.8708072633123720 -3042.4487397531365787, -317.0081043084857697 -3040.4572078632113517, -353.9188796380849453 -3025.9673133506230442, -481.8759722620623052 -2952.0780561800302166, -597.3916747239470624 -2859.9435764086629206, -697.8857092860117746 -2751.6218846962374300, -781.1133376604859677 -2629.5325659449085833, -845.2155017965442312 -2496.4027329581699632, -881.7734250743712892 -2377.8616075414415718, -883.2163026251768088 -2378.2274205979942963, -915.6765245378969666 -2250.1944686487954641, -958.6488338256679071 -2176.6893024190303549, -958.3104527203266798 -2176.4914793507796276, -961.3773376604859777 -2171.9925659449086197, -1025.4795017965443549 -2038.8627329581699996, -1069.0243497161841333 -1897.6661108397263433, -
 1091.0392188351402183 -1751.5566128059626863, -1091.0323623564322588 -1603.7978911310922285, -1089.6762878232161711 -1594.8034867385058533, -1104.6051239273215288 -1541.4387753320572756, -1142.1697554404233870 -1500.9481685832554376, -1144.1735018958338514 -1502.8286850026515822, -1237.9475018958337387 -1402.9096850026517131, -1235.9437554404232742 -1401.0291685832553412, -1283.8694719642787732 -1349.3704336840412452, -1284.3641704239839783 -1349.7723644815778243, -1285.2860836559341351 -1348.6376690100614724, -1338.3270735958196838 -1329.0603190321844522, -1337.4416005745254097 -1326.6613035542172838, -1425.0218796380850108 -1292.2803133506229187, -1552.9789722620623706 -1218.3910561800300911, -1668.4946747239471279 -1126.2565764086627951, -1679.3254791566805579 -1114.5821415641194108, -1680.0605373265407252 -1115.3491207030931491, -1702.7503708819851909 -1093.6036172334481762, -1770.9343685341837045 -1058.4171540195427497, -1770.1722772833329600 -1056.9403807575390601, -18
 74.5379722620623397 -996.6740561800301066, -1895.7478836933294133 -979.7571858838782646, -1896.7182978644157174 -981.0996960943623435, -2746.6499049371641377 -366.7388744659292570, -2763.2967822031337164 -362.2768436281256186, -2790.5987539714260492 -334.9710818839997160, -2790.5987539714260492 -334.9710818839996023, -2842.3952978644156246 -297.5306960943622698, -2841.4248836933293205 -296.1881858838783614, -2935.7306747239472315 -220.9705764086628506, -3036.2247092860116027 -112.6488846962375874, -3086.2207836436286925 -39.3080148699587753, -3129.2862482014747911 3.7634279033554208, -3138.9918179090095691 39.9929298181513317, -3195.9318721744207323 131.7765582775780331, -3194.3605115562841092 132.7513874532058367, -3212.0423376604862824 158.6894340550911124, -3276.1445017965443185 291.8192670418299599, -3319.6893497161845517 433.0158891602736730, -3341.7042188351406367 579.1253871940372164, -3341.7041685876552037 580.2082322725017320, -3341.7842797495400191 580.202320676883
 9145, -3358.7842797495400191 810.5783206768840046, -3358.7041685876552037 810.5842322725018221, -3358.6973623564326772 957.2601088689078779, -3336.6689334334319028 1103.3675631523476568, -3293.1109817488727458 1244.5601434214565870, -3260.5234971247000431 1312.2230153808816340, -3296.6374455479131029 1414.0631037763496352, -3294.8380822260414789 1414.7011836840215437, -3328.7143497161841879 1524.5468891602736221, -3349.7012648829327190 1663.8340056869151340, -3350.1912493926529351 1663.7938778131951949, -3510.7782493926529241 3624.6538778131953222, -3510.2882648829327081 3624.6940056869152613, -3511.3162188351402619 3631.5163871940371791), (-1458.2438853899545848 2786.7096887882385090, -1390.0104079583070416 1953.5395283355223910, -1308.4375544520867152 1723.5068962236503012, -1310.2333181418257482 1722.8700927968927772, -1276.3402423028999237 1612.9336566327281162, -1254.3389331776024846 1466.8221161070862308, -1254.3595026136681554 1319.0633957048662523, -1256.063974333603
 7100 1307.7652980846462469, -1255.2787938929561733 1307.6972329071288641, -1257.2316394637061876 1285.1697643588329356, -1227.2802423028999783 1188.0186566327281525, -1205.2789331776025392 1041.9071161070862672, -1205.2904919563829935 958.8756534762312640, -798.3848875647835257 664.7497975144585780, -668.7086314658160973 597.8301540195427606, -669.4687336638634179 596.3572351253640136, -653.9962840476707697 587.4207017476531973, -634.6270161446395832 659.6966464095463607, 97.4196581300587923 1391.7094503287939915, 1097.3929445351700451 1659.6432199333848985, 2097.6867783781326580 1391.5243492190379584, 2485.1041348942267177 1003.9814942180254320, 2264.2788423241918281 2319.5541328332446938, 409.7273757065412383 2913.2071331414008455, -1458.2438853899545848 2786.7096887882385090))
- </op>
-</test>
-</case>
-</run>
Deleted: trunk/tests/xmltester/tests/bug344.xml
--- trunk/tests/xmltester/tests/bug344.xml	2011-04-20 15:42:03 UTC (rev 3289)
+++ trunk/tests/xmltester/tests/bug344.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -1,22 +0,0 @@
-<run>
-  <desc>
-    http://trac.osgeo.org/geos/ticket/344
-    Buffer operation uses a huge amount of memory
-  </desc>
-<case>
-  <desc>
-  </desc>
-  <a>
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
 0000050000008D0EA37BB1D751C0831035762E8540C0459E245DB3D751C07924B957418540C0CC199B67B6D751C0AA398ABD618540C06DFA5866B6D751C0CEB348C9618540C0CB9AFD26B9D751C043E4F4F57C8540C0010200000003000000CB9AFD26B9D751C043E4F4F57C8540C03B95C272BAD751C02D8C3E30918540C041AB8207BCD751C0FE8F5DB3A68540C0010200000002000000286F360C55D851C0B49BCF6F4E8540C08E57207A52D851C0600C40FE2D8540C00102000000030000008E57207A52D851C0600C40FE2D8540C006BF68EA50D851C03A18FBDC1A8540C0CCAF8B474ED851C0C4F24295F58440C0010200000002000000CCAF8B474ED851C0C4F24295F58440C05891D10149D851C0C36FF9FEBC8440C00102000000020000005891D10149D851C0C36FF9FEBC8440C0B818A83146D851C0CA518028988440C0010200000002000000B818A83146D851C0CA518028988440C09B4A500D45D851C0470EC7A98C8440C0010200000003000000060253BC00D751C0D97BF1457B8440C0700E322402D751C00787CDB6898440C04FACF82B09D751C0722B291CE68440C00102000000020000004FACF82B09D751C0722B291CE68440C053A813750BD751C0AC85A3F5018540C001020000000200000053A813750BD751C0AC85A3F5018540C0BECE97280CD751C
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
 088640C0373C180C09DD51C0A2D86553098640C0626B11AC05DD51C0367E97080A8640C058141B9801DD51C0CB23C9BD0A8640C01A51DA1BFCDC51C0CB23C9BD0A8640C0DB17D00BF7DC51C01360FD440A8640C0C7C5072CEFDC51C05A9C31CC098640C02FD16A92E9DC51C0D18A146F098640C0E9CB1CDCE7DC51C0A2D86553098640C0D537D5FFDEDC51C0C6F6FF16098640C061D4FF83D9DC51C0EA149ADA088640C0B86004E8D2DC51C0EA149ADA088640C0FC7BDFAECDDC51C0EA149ADA088640C0010200000006000000FC7BDFAECDDC51C0EA149ADA088640C044FD2E6CCDDC51C0EA149ADA088640C005961238C8DC51C00D33349E088640C0E107E753C7DC51C00D33349E088640C05CC6F253C1DC51C00D33349E088640C09EE9CA0CC0DC51C0D2A4B9BA088640C00102000000050000009EE9CA0CC0DC51C0D2A4B9BA088640C0BC7BDBA7BEDC51C0EA149ADA088640C0B2DC2D24BBDC51C0A2D86553098640C074EBDA83B5DC51C0EE27BE350B8640C0EC3EB61BB3DC51C0771F36470C8640C0010200000003000000EC3EB61BB3DC51C0771F36470C8640C08B3ED5D7A9DC51C045D1A865108640C075DA649EA6DC51C02656A1DC118640C001020000000400000075DA649EA6DC51C02656A1DC118640C07862D68BA1DC51C0732F302B148640C0ED0A22F799DC5
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
 51C058C51B99478740C00102000000020000009F4F2ED76CDC51C058C51B99478740C0F72CBE5763DC51C0BD8A8C0E488740C0010200000004000000F004B122D9DA51C01536035C908640C0565D2CB1D7DA51C0EBADDC66858640C015CD5E11D7DA51C0113A43CC808640C0C3EEE0CCD4DA51C07F130A11708640C001020000000A00000032EDF6B49EDA51C0D1D09A7A388740C0028063CF9EDA51C00AA359D93E8740C061B0766FA0DA51C0E5C63E12408740C09B66CB03A2DA51C00FD02280408740C0C4B12E6EA3DA51C0B5FAEAAA408740C076114B6FA4DA51C04A02791B408740C015CF8F75A7DA51C0C829954B3E8740C0B3DC88DDADDA51C06693B2FB448740C0E7A15B54B0DA51C0D5B2B5BE488740C0D533CEF0B0DA51C0863710374C8740C0010200000002000000D533CEF0B0DA51C0863710374C8740C0C8AA52C4B3DA51C0F70FD88B578740C0010200000004000000EE7893DFA2DA51C022C08EA4498740C0811255AEA6DA51C098EAB8D04B8740C0C564BB8CACDA51C0D7FBE82F4F8740C0D533CEF0B0DA51C0863710374C8740C001020000000200000049B5F40DF1DA51C000D6F4EA2D8640C07F55890DF1DA51C0CAFB389A238640C001020000000A0000002D6AE67F28DC51C0763980D9988540C0DFDDCA121DDC51C063D009A1838540C05DE2C80311D
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
 133C00559E151C0632E0494E18440C00585E6DF53E151C0BB873A62E38440C096F2B5C24FE151C061F48189E48440C0BC22F8DF4AE151C07978CF81E58440C065EFD64345E151C0DEFBC0FAE48440C05CC6F25341E151C026529ACDE38440C0529D0E643DE151C08D7F9F71E18440C0488ECFBF38E151C03B037EE8DD8440C0CA0116542FE151C0DF2CCA11D78440C04CBD135825E151C0A88E554ACF8440C06E6704C01DE151C0E15DD328C98440C0FAA70AFC17E151C04278B471C48440C051D8EA1711E151C05729988CBE8440C09EBDE94C10E151C0F8DEDFA0BD8440C0470B2B700DE151C07107454EBA8440C0DDEADE2F0BE151C043A9BD88B68440C072B0EDA309E151C0A5A9F985B28440C008D2206008E151C006C4DACEAD8440C0C69D770808E151C0688297CFA88440C0C6F99B5008E151C03A24100AA58440C0FBAD9D2809E151C04FD5F3249F8440C031067BB809E151C0FE58D29B9B8440C0665E58480AE151C0F418E599978440C066BA7C900AE151C0E5AB2EF1918440C066BA7C900AE151C047C60F3A8D8440C0665E58480AE151C0F00280BE888440C031D8689409E151C0E6C292BC848440C0FCF5549808E151C000A13F7E808440C091BB630C07E151C0AE241EF57C8440C027254E3805E151C0C8E8256B798440C087646DF802E151C00B123697768440
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
 BF48E09E78540C0C0F91E3F65D751C0BFF04A92E78540C0010200000003000000C0F91E3F65D751C0BFF04A92E78540C032AA0CE36ED751C0EEB66686E88540C0BCF5509179D751C0FA02C46EE98540C0010200000005000000BCF5509179D751C0FA02C46EE98540C03739D78B7CD751C0351B75BEE98540C0A44632F584D751C0054F2157EA8540C0FAC44B8196D751C0408FAC57EC8540C06204430CAAD751C027A3CA30EE8540C00102000000040000006204430CAAD751C027A3CA30EE8540C020ABA5CAC1D751C07925242DF08540C06DF24A48DAD751C09061BAB5F18540C00778D2C2E5D751C0D70D805DF28540C00102000000040000000778D2C2E5D751C0D70D805DF28540C0A7583508F3D751C0B9AC1D20F38540C089EC832C0BD851C04DC2E0F5F48540C023CB38FC24D851C052657330F68540C001020000000400000023CB38FC24D851C052657330F68540C0F2D654713ED851C0C3D89D49F68540C0AD20BC2C5CD851C0C91F0C3CF78540C0800239726ED851C04C885EEBF78540C0010200000002000000E3F1FE89DBDD51C0BD9580F33D8640C0D90AF54FCBDD51C04AD7A7774C8640C001020000000200000086AFAF75A9DD51C0A0EEF263828640C0A0658286A3DD51C0BFE2BA73728640C0010200000003000000A0658286A3DD51C0BFE2BA73728640
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
 0102000000040000009E17DD3040DE51C0A05AD82EC88540C080BCB2663FDE51C0EEB5A0F7C68540C04BC395583EDE51C03CFDFBE7C48540C0FE9EB3603DDE51C07F3A79ECC28540C0010200000009000000DC5FE23469DE51C0DED8FD744D8540C04303B16C66DE51C0BF9F75E84F8540C0E3A9471A5CDE51C0BC2B71D3558540C08BDDE3F159DE51C027947483578540C0B06312E456DE51C0905264085B8540C06F18607A56DE51C0956BC0D65B8540C0B63D8BEF55DE51C036D318085D8540C034A7261C55DE51C0222EA5D35F8540C0930E208D54DE51C0D9D1938D628540C001020000000200000055E4C6E358DE51C06AC18BBE828540C02AEE2E0645DE51C03CC8A1348A8540C0010200000002000000BB7207FB40DE51C02471A0D1678540C089E711482EDE51C0C8E5E4EA6C8540C0010200000002000000938D075B6CDE51C09C1551137D8540C055E4C6E358DE51C06AC18BBE828540C0010200000002000000E184F87601DF51C052EFA99CF68440C0414BB26900DF51C0626B11AC058540C0010200000002000000DD88DD2DFFDE51C052859A7C0E8540C0C44373F8FFDE51C027AF84A4058540C0010200000005000000A2F14410E7DE51C0D7400466CF8440C0B4D59B07E6DE51C0E9BF6268D08440C0F077DE7CD9DE51C0E921BF23CF8440C01D291197D2DE5
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
 F148BC3C9D8440C060B6F86FB9DE51C0F7393E5A9C8440C047718E3ABADE51C0E059CC199B8440C07DF77DEEBADE51C0761FDB8D998440C0A6A1A1DABBDE51C0E2372ADC978440C04091DDBBBCDE51C024A3B904968440C0925852EEBEDE51C027874F3A918440C0010200000011000000925852EEBEDE51C027874F3A918440C097546D37C1DE51C0AC5D6E8B8D8440C01A19E42EC2DE51C0B83F72C68B8440C0EAA8B40FC3DE51C0A15F00868A8440C0B91EE0A4C4DE51C0313AC54F888440C07D451218C6DE51C009652B79868440C0B23E2F26C7DE51C05DC5E237858440C0CF7FB4A4C8DE51C09F307260838440C0F829D890C9DE51C046EBA86A828440C0156B5D0FCBDE51C09A1D4E05818440C0D9918F82CCDE51C0FA59D18B7F8440C0439E6EEACDDE51C0ADF0D35D7E8440C0547655FBCFDE51C0AEF60BD17C8440C0521F926BD4DE51C06E4100BA798440C079E51F22DADE51C082148612778440C04DFEDDF1DCDE51C094E1D3F7758440C07BC7DA0FDDDE51C02F3C45F1758440C00102000000050000007BC7DA0FDDDE51C02F3C45F1758440C0CD3AE3FBE2DE51C0474AC4A5748440C096DC723FF1DE51C025C2D034728440C0CBD58F4DF2DE51C0EF0A3323728440C01D52B1D6F5DE51C0A8A0EC77728440C001020000000C0000000BB6114FF6DE51C041B566D
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
 C9E369F9818440C0B3823A408BDE51C00B49C1AE818440C050E3DEFC86DE51C088500020828440C00102000000020000001D52B1D6F5DE51C0A8A0EC77728440C05B295F2BFCDE51C0CA709758748440C00102000000020000005B295F2BFCDE51C0CA709758748440C00137E6D0FDDE51C09BD88D88738440C001020000000200000065B3D947DDDE51C0E61B7684788440C07BC7DA0FDDDE51C02F3C45F1758440C00102000000100000007BC7DA0FDDDE51C02F3C45F1758440C077949405DDDE51C035215278758440C0612D8892DADE51C0A585CB2A6C8440C0D28C45D3D9DE51C0CB259F68688440C002171A3ED8DE51C0E6C704A1618440C027AB7D95D7DE51C05EBC1FB75F8440C0B03500C0D6DE51C0886F17505E8440C0D4E30863D5DE51C0D7B672405C8440C06AD729FBD3DE51C0BAEBB6555A8440C0A63DCA2DD2DE51C044AD1F51578440C0B3A6689BD1DE51C0E67C0CB1558440C030551FFED0DE51C082339D42538440C0489A8933D0DE51C06D3189C44E8440C0AD90A806D0DE51C0BD5C7AEA478440C06C2EED8ACFDE51C0958D1887448440C07F8BA94FCDDE51C00C11267B3A8440C00102000000070000007F8BA94FCDDE51C00C11267B3A8440C0C1525DC0CBDE51C02B4AAE07388440C09E7F16A6CADE51C05CC0159A358440C0F20DE088C9DE51C0A5C
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
 34F2798440C06AA4A5F276DE51C0F64CE5A37B8440C07B095FA978DE51C0FC372F4E7C8440C03E16ECD07ADE51C03ECB98277C8440C0B9FAB1497EDE51C0FD3D67C17A8440C0BE839F3880DE51C0032FE9DE798440C029907EA081DE51C00F0BB5A6798440C03AF5375783DE51C0626534F2798440C02123FB7B84DE51C0862172FA7A8440C0034CCFAA85DE51C00EFF44C07C8440C0CD04C3B986DE51C0FA59D18B7F8440C0010200000002000000CD04C3B986DE51C0FA59D18B7F8440C050E3DEFC86DE51C088500020828440C001020000000900000050E3DEFC86DE51C088500020828440C0C1B5C99786DE51C08D63247B848440C02739BB1086DE51C056D4601A868440C06312899D84DE51C05BE78475888440C000E65AB480DE51C076D4E29D8D8440C0D23F1C7F7DDE51C0B06A5A73918440C0984AE4277ADE51C0EF192E17968440C05DAE34DF77DE51C0CF64A4839A8440C0FF0AF4E475DE51C06D4AC33A9F8440C0010200000002000000FF0AF4E475DE51C06D4AC33A9F8440C066C5CB2E73DE51C0FD9D9218A98440C001020000000500000066C5CB2E73DE51C0FD9D9218A98440C01A34F44F70DE51C08E9B7521B18440C0AF9A42426FDE51C0CE226F14B48440C0860AC4A16DDE51C0D12F5BFCB78440C081F4030D6CDE51C089D349B6BA8440C0010200000
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
 014ABABA7FB8340C0010200000002000000F1CFB12811DA51C02EBAAB0D048440C018963FDF16DA51C0D46EAAA4048440C00102000000020000004997A36C36DA51C01D67E43D188440C0968796862BDA51C0CA0C65F2178440C0010200000002000000968796862BDA51C0CA0C65F2178440C03A3B191C25DA51C04D052681178440C00102000000020000003A3B191C25DA51C04D052681178440C0AEF199EC1FDA51C0FAAAA635178440C0010200000002000000AEF199EC1FDA51C0FAAAA635178440C0BDB1FBE91ADA51C03C10FEEA168440C0010200000002000000BDB1FBE91ADA51C03C10FEEA168440C0FAAD426F16DA51C007D561E0148440C0010200000004000000FAAD426F16DA51C007D561E0148440C04FC9DEF714DA51C0B46675BC138440C0A98D452E13DA51C02C27463B138440C00E36D0D707DA51C02536C41D148440C00102000000030000000E36D0D707DA51C02536C41D148440C070AF71A202DA51C019880A7A148440C076E8AA2F01DA51C0E4FE7E8C148440C0010200000002000000CB96F6170BDA51C060747973B88340C0486A46ABFFD951C0D277126CB78340C0010200000002000000009013260CDA51C085590D2EC28340C095A8CDEEFFD951C01A47F652C28340C00102000000020000004DCE9A690CDA51C06ECACB50CB8340C0E27327
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
 951C0960A2AAA7E8440C0010200000002000000C532A259FED951C0B674BB4D6E8440C0C5BF74FFFDD951C0960A2AAA7E8440C0010200000002000000CBE48A4116DA51C0E360808EA08440C03E33D29C06DA51C0EA5102AC9F8440C00102000000020000003E33D29C06DA51C0EA5102AC9F8440C0FA6AFDE3F3D951C013FFC1D19F8440C001020000000200000030DBA91416DA51C08B02D8DBC18440C0D9C9856F06DA51C0790DB045C18440C0010200000002000000D9C9856F06DA51C0790DB045C18440C02ADB2C03F3D951C08B02D8DBC18440C0010200000002000000F5543D4FF2D951C0514D49D6E18440C0F1F44A5906DA51C06242716CE28440C0010200000002000000F1F44A5906DA51C06242716CE28440C0E39C22D115DA51C0DF49B0DDE28440C0010200000002000000E39C22D115DA51C0DF49B0DDE28440C0A67B421B25DA51C04ACC58D9E38440C00102000000020000000D9AA784F1D951C075F6DF94038540C056783CD205DA51C045589E51048540C001020000000200000056783CD205DA51C045589E51048540C04820144A15DA51C0EC0C9DE8048540C00102000000020000008641F4FF05DA51C0501D064E118540C05C5A0D89FBD951C0501D064E118540C0010200000002000000A4B6C31506DA51C0F6A633411E8540C09CA223B9FCD951C0
 2260634D1B8540C001020000000200000025523F14F1D951C0B3F96EA9398540C0C05B2041F1D951C023D4B1EF2F8540C0010200000002000000C05B2041F1D951C023D4B1EF2F8540C0FC17AD48F1D951C05B5B785E2A8540C001020000000500000076E8AA2F01DA51C0E4FE7E8C148440C041D8840F00DA51C001182A5A148440C048F71851FFD951C07F81C586138440C0AD7A0ACAFED951C0E5AECA2A118440C0FBB8910DFFD951C0EF5B08CD098440C0010200000002000000FBB8910DFFD951C0EF5B08CD098440C095C2723AFFD951C089E30A39008440C001020000000200000095C2723AFFD951C089E30A39008440C09535A094FFD951C03460353BF78340C00102000000020000009535A094FFD951C03460353BF78340C0FA2BBF67FFD951C0F1A375AFEE8340C0010200000002000000FA2BBF67FFD951C0F1A375AFEE8340C09535A094FFD951C0F07A1FFDE58340C00102000000020000009535A094FFD951C0F07A1FFDE58340C09535A094FFD951C0DC5CA1B4DC8340C00102000000020000009535A094FFD951C0DC5CA1B4DC8340C0303F81C1FFD951C01D99A2B7D38340C0010200000002000000303F81C1FFD951C01D99A2B7D38340C0E27327D8FFD951C0C815CDB9CA8340C0010200000002000000E27327D8FFD951C0C815CDB9CA8340C095A8CDE
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
 015EB0E5D951C0E342D433738540C0D852F64CE5D951C0EC08F192498540C0010200000003000000D852F64CE5D951C0EC08F192498540C00850F811E4D951C0C35B316D498540C0D9E2642CE4D951C07D0E87003B8540C0010200000002000000C32EE5D7EAD951C083E563D23A8540C04CE4DDECEAD951C0541454F9438540C0010200000002000000552646E0D9D951C01E7695A4218540C0FF23D3A1D3D951C08AFE7513218540C0010200000002000000FF23D3A1D3D951C08AFE7513218540C0916C640DCDD951C07E3C4F97208540C0010200000002000000916C640DCDD951C07E3C4F97208540C00CBBDEECC5D951C02B5899DF1F8540C00102000000100000005F29CB10C7D951C04E8E4CD1DB8340C047713381C7D951C024777D8BF38340C0B1529CFEC7D951C082BBFD03F68340C07CF72235C8D951C00BB37515F78340C0FE2EC786C9D951C08CCDD8E1F98340C0981E0368CAD951C019BECF02FE8340C0CEA4F21BCBD951C081142B59048440C0EBFF1CE6CBD951C055890D71078440C09DA7F056CCD951C0F54C8AEA088440C0D8B6CDF9CED951C04CDCCFCE0E8440C0C4FA50B3D1D951C05CC5877E128440C0DD8D4F12DCD951C0BD2A61B7198440C0470D5CD4DDD951C0C23D85121C8440C09961A3ACDFD951C0D2263DC21F8440C0B6A2282BE1D951C0820
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
 2FE8340C03D1E447C71DA51C0FCF21318FC8340C01474209070DA51C0571C7343F88340C0089BF00170DA51C094E46F31F58340C00102000000050000002D55B31886DA51C0CF1F894D1A8440C00DE2033B7EDA51C090C1E50C208440C04268F3EE7EDA51C0D048DFFF228440C06616FC917DDA51C0F4041D08248440C00120DDBE7DDA51C06A66D24B318440C00102000000060000000120DDBE7DDA51C06A66D24B318440C07E41C17B7DDA51C03DFD56A1378440C0C0304F9D7DDA51C0F39A0DE83B8440C090C01F7E7EDA51C05CF7A0B1408440C06B85443580DA51C017A87B53478440C08E3EE60382DA51C0FCF1A8424D8440C0010200000002000000C15E173463DA51C0A9B1CE424C8440C051E0F8356DDA51C0E553B6FE4C8440C00102000000040000000BF379208DDA51C0C26F9E454A8440C02DE285BE85DA51C05C4299A14C8440C064BF380282DA51C0CD6D0C4B4D8440C049BBD1C77CDA51C019051C9D4E8440C001020000000400000049BBD1C77CDA51C019051C9D4E8440C069E0EC7B79DA51C0B4AF3C484F8440C02F5EE27E76DA51C0C49E2C6B518440C0837C1A4174DA51C06B532B02528440C001020000000600000049BBD1C77CDA51C019051C9D4E8440C08DDC894883DA51C03DE477E4598440C08689AB6F85DA51C05FC2572A5E8440C02D55B318
 86DA51C00399F8FE618440C008347D1B87DA51C08EA559EA6A8440C031DEA00788DA51C05E58480A768440C00102000000020000004ED1915C7EDA51C08B9EA575658440C0DD71D41B7FDA51C0BCB0355B798440C001020000000400000045D95BCA79DA51C0F239C148798440C003EACDA879DA51C03BE702F2808440C0D82725A971DA51C035FCB847808440C08A5CCBBF71DA51C0844314387E8440C00102000000020000008A5CCBBF71DA51C0844314387E8440C04D158C4A6ADA51C0A2009BBD7D8440C00102000000020000007EF32C5272DA51C003E4F0EE6D8440C08A5CCBBF71DA51C0844314387E8440C0010200000004000000D3799E897ADA51C0431ABA7E668440C0F211E79777DA51C0D0C5F0225D8440C0E1AC2DE175DA51C074733B45588440C05FEB522374DA51C0752387E3548440C001020000000200000031DEA00788DA51C05E58480A768440C0DD71D41B7FDA51C0BCB0355B798440C0010200000002000000DD71D41B7FDA51C0BCB0355B798440C045D95BCA79DA51C0F239C148798440C001020000000200000045D95BCA79DA51C0F239C148798440C017331D9576DA51C0753282D7788440C00102000000050000009FA97C748FDB51C0337C5578E18440C0B4D3C55C88DB51C0F7C54A71FA8440C0CC18309287DB51C01A828879FB8440C0756
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
 102000000060000000998AF81E3D851C0AE1DD665428740C0FD5FBF71E3D851C0C86B14483F8740C09721E92EE4D851C0B47570B0378740C01FFFBBF4E5D851C0164B917C258740C002D53F88E4D851C06508B600238740C0983E2AB4E2D851C0D162844B228740C0010200000002000000E22593AEF4D851C012989878518740C078BA4E7EE6D851C016574BF03C8740C0010200000004000000983E2AB4E2D851C0D162844B228740C091A9CCDEE3D851C05865F041198740C0BADD2637E5D851C05DE5643D108740C08E603EB4EAD851C011A4F732F68640C0010200000002000000994528B682D951C0D4145C07628640C041A43A7881D951C014BB6C2A418640C001020000000300000041A43A7881D951C014BB6C2A418640C00C94145880D951C091FEA897298640C0246651337FD951C094F36A25198640C0010200000004000000246651337FD951C094F36A25198640C0488787307ED951C0C43D3B85018640C00109D4AC7DD951C065BCF781F58540C049731A587DD951C0EFD00BD2E78540C001020000000200000051FC732C4AD951C0BBDB508C878640C04FCAA48636D951C047B2A2618C8640C001020000000200000089F1F51068D951C08EFE3CB25E8640C08830D9D369D951C0038294336F8640C0010200000002000000C4BE53B769D951C0A68E9FD7E985
 40C0F79FEBB163D951C09451C0D1E98540C0010200000002000000F79FEBB163D951C09451C0D1E98540C080F9BF7E63D951C09451C0D1E98540C001020000000200000080F9BF7E63D951C09451C0D1E98540C0E4B5B70059D951C06B1ACA3FE98540C0010200000003000000E4B5B70059D951C06B1ACA3FE98540C01C7FFD6B54D951C03B3A0900E98540C0F960BE6147D951C0D06FA994E88540C0010200000007000000F960BE6147D951C0D06FA994E88540C0789F3E5D38D951C0C5AD8218E88540C01B16FE6728D951C012EFA595E78540C0FF507AF024D951C0EF74E789E78540C0BFA9FEF716D951C0360D4059E78540C04B8EE0EB10D951C0A2670EA4E68540C0B20639390DD951C0D852F64CE58540C0010200000006000000B20639390DD951C0D852F64CE58540C0D6862FB80BD951C05518B6C1E48540C0BB0963B007D951C0B6FE4C73E18540C07C74345802D951C0D1F69E80DC8540C033B62110F9D851C0E07AB9F4D48540C066F6798CF2D851C0005E55ACD08540C001020000000500000066F6798CF2D851C0005E55ACD08540C0CC7C073FF1D851C0420B64D1CF8540C0FC790904F0D851C043C9E4D4CE8540C05334208CE9D851C0156B5D0FCB8540C05546C8E5E4D851C0A5CF5845C98540C00102000000090000005546C8E5E4D851C0A5CF5845C98
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
 08703D7CBA58540C0010200000003000000CCC86A04ACD751C08703D7CBA58540C07000474C9AD751C03BB47EE9A38540C07BD399208FD751C083AE3374A28540C00102000000030000007BD399208FD751C083AE3374A28540C096B77E5589D751C0CB8E43B3A18540C006A62E7480D751C013B70A62A08540C001020000000200000006A62E7480D751C013B70A62A08540C0B55D1AF67BD751C0EBBF39B89F8540C0010200000004000000B55D1AF67BD751C0EBBF39B89F8540C0AD2C76A073D751C008292E7D9E8540C0BB421F2C63D751C09E36F4609C8540C0E79F2AF05FD751C003160A229C8540C001020000000A0000002F3201BF46D951C05A79138DFF8540C0A3E8818F41D951C09E1331DB048640C0D9322ABA3FD951C0FD497CEE048640C0E6142EF53DD951C033011A00058640C04E79196A39D951C09EE51EB7048640C0037B4CA434D951C0210CF269048640C004988D2933D951C07B3D4E87048640C0C505FB0A2DD951C0C8C0F000058640C0E9995E622CD951C057F1A19F048640C0BC9D335827D951C0522635B4018640C0010200000002000000493C8F4072D951C015185701638640C0662728EA71D951C0DE23F664598640C001020000000200000027C0B0FC79D951C05E4C8E965E8640C03F332D5679D951C026299FD44D8640C001020000000400
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
 8840C04846185039D651C0F3B0AB240D8840C009DFFB1B34D651C0C13F0004078840C0FFE3295030D651C0B7FF1202038840C08B6CE7FB29D651C0CCCA9B68FC8740C00D28E5FF1FD651C090190346F28740C02F2EFAAF18D651C07C992842EA8740C01B52FB6310D651C0D48DC1D4E08740C0A708CB330AD651C055B31886D98740C03349D16F04D651C0FAF609FBD18740C0F423343800D651C0A367C416CC8740C04B9CCBC3F8D551C01A4D2EC6C08740C037781508F1D551C0B0236992B38740C0F83E0BF8EBD551C07472D06FA98740C0BAD7EEC3E6D551C0C739A05B9E8740C010EE2994E0D551C0AA937DA1918740C00669215CDCD551C0016E71E8888740C0924D0350D6D551C008E6E8F17B8740C0896CD6CFD1D551C084DE76FC728740C049192774CDD551C0FFD604076A8740C0751A0EF0C9D551C0F183F3A9638740C06B67F393C5D551C0B9E57EE25B8740C0619A33ECC1D551C0AB926D85558740C08D11E4FBBDD551C07821C2644F8740C0CAF38535BAD551C0FEE9AB50498740C07907D38BB5D551C0A29D2EE6428740C03AFCDA9FB0D551C0DB8651103C8740C0FBA82B44ACD551C0CC199B67368740C0F299EC9FA7D551C09AA8EF46308740C0B2182B20A3D551C08B3B399E2A8740C0A99322E89ED551C0C951256F258740C0FE16539F9AD551C0259529E
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
 F77018640C01FCA0688B8D751C022437D810F8640C0010200000002000000B2BD16F45ED751C0C6E2923E088640C02EC2B92B60D751C0FBF48E09E78540C00102000000030000007AA697184BD751C0495A3B9B9F8640C07B33C5773DD751C09DD497A59D8640C0C687D9CB36D751C0219F46109D8640C0010200000002000000C687D9CB36D751C0219F46109D8640C09B4C26B822D751C015F7C4DF9B8640C0010200000002000000B7555A9077D751C0B931E2A7168840C00ADEEBFF77D751C0273FF383048840C0010200000002000000ABDC555925DC51C086764EB3408540C0B5334C6D29DC51C0068200193A8540C0010200000005000000B5334C6D29DC51C0068200193A8540C0F49A68A12EDC51C0CEE38B51328540C0330285D533DC51C0DE67A6C52A8540C0D2C2651536DC51C0F8455387268540C0DE25CC0F37DC51C036429A0C228540C0010200000002000000DE25CC0F37DC51C036429A0C228540C0FB97FFEB37DC51C0DA0FC2ED1A8540C0010200000003000000FB97FFEB37DC51C0DA0FC2ED1A8540C0A7655A5139DC51C0E6F6819A108540C0DCCE08803BDC51C04E5BC8C8FE8440C0010200000003000000DCCE08803BDC51C04E5BC8C8FE8440C0B14687D13DDC51C0F3C98AE1EA8440C050AB43C93FDC51C07E463360DA8440C00102000000020000
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
 BBCE2B43C18540C00102000000030000009FCBD42478D651C0362F9809D08540C0FC3493147DD651C092CEC0C8CB8540C007AF02217ED651C04A0856D5CB8540C0010200000002000000760D446076D651C01BB80375CA8540C0107E3DBA6CD651C017AE580DD38540C0010200000002000000107E3DBA6CD651C017AE580DD38540C0EB1F443264D651C04FF0A88CDA8540C0010200000002000000EB1F443264D651C04FF0A88CDA8540C00150C58D5BD651C06EA873A0E28540C0010200000002000000E557BD0D7BD651C07F04B463D98540C0B43A394371D651C0FD344987E28540C0010200000002000000B43A394371D651C0FD344987E28540C024264D2869D651C06571FF91E98540C001020000000200000024264D2869D651C06571FF91E98540C09F63F66860D651C0D22236B3F18540C001020000000200000029FA8DC069D651C04820B990A28540C0760D446076D651C01BB80375CA8540C0010200000002000000760D446076D651C01BB80375CA8540C09FCBD42478D651C0362F9809D08540C00102000000020000009FCBD42478D651C0362F9809D08540C057BDB2C178D651C00C34E900D28540C001020000000200000057BDB2C178D651C00C34E900D28540C0E557BD0D7BD651C07F04B463D98540C0010200000002000000E557BD0D7BD651C07F04B
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
 C0C6D2D1BBC28540C08EB1135E02D651C0747396FECA8540C0010200000002000000FE55911B0FD651C0297EE772DE8540C08EB1135E02D651C0747396FECA8540C00102000000050000007B905495ECD551C0478C43A2758540C0A2E3B4F1F1D551C0D0C07E3E808540C0F4AA2924F4D551C04E6A1E76958540C046E5CBB0F6D551C03B5B9B21B08540C07A1DCC81F9D551C04EF85BF1C38540C001020000000200000076B0B44247D651C001A3CB9BC38440C0CA66B38F3AD651C04D45CFD2BA8440C0010200000002000000B43396FA43D651C01E8B6D52D18440C019F9612937D651C03476D377C88440C0010200000002000000033972EE40D651C00BA7BBA1DF8440C0B43396FA43D651C01E8B6D52D18440C0010200000002000000B43396FA43D651C01E8B6D52D18440C076B0B44247D651C001A3CB9BC38440C001020000000300000076B0B44247D651C001A3CB9BC38440C0A0FEB3E647D651C08B02D8DBC18440C0EC6415DB49D651C09E730179C08440C001020000000500000036E7E09950D651C06A28FFA4EB8440C05897AEBB54D651C0AE5406C4DA8440C01EA2766451D651C099582AB9D48440C0C03280014ED651C0A219D533CE8440C0EC6415DB49D651C09E730179C08440C0010200000003000000EC6415DB49D651C09E730179C08440C02A8F6E844
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
 00007000000807D1931D8D551C05B666C43208640C06C34CA44DBD551C0A9DBD9571E8640C08EFE3CB2DED551C01CBDD0121A8640C0164CA198E1D551C0D822B3C4148640C0021DF7F7E3D551C0938895760F8640C0D20550E7E5D551C059C40B7D0B8640C09CAAD61DE6D551C095F661180B8640C00102000000080000009CAAD61DE6D551C095F661180B8640C00767A66AF1D551C07008556AF68540C05E2A36E6F5D551C0D3009475EE8540C063B323D5F7D551C07B93F0CEEB8540C0B5EDC561FAD551C0057D337BEA8540C0BA76B350FCD551C0DBCF7355EA8540C0BFFFA03FFED551C017725B11EB8540C011C4793801D651C0F353C14DEB8540C001020000000400000011C4793801D651C0F353C14DEB8540C04BBC4DC903D651C093799A82EB8540C0E613C31F0FD651C005323B8BDE8540C08F2EDBF321D651C03A1966B2C98540C00102000000030000003892150D63D651C0F57C72B9668540C0B9BAAD3E68D651C0F844E8B1778540C04EED0C535BD651C0EBADDC66858540C00102000000040000004EED0C535BD651C0EBADDC66858540C0CCDA01324FD651C0FDEDFCEC918540C0614150244ED651C080E6BD7B918540C0EC6415DB49D651C09ABBF149828540C00102000000020000007A956BC056D651C01131CAD8758540C04EED0C535BD651C0EBADDC66
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
 B8540C01B39C1ED3FD751C0817DCFA33D8540C00102000000030000009709754735D751C0AC10A0F0238540C0C779A46634D751C029D9A0E52F8540C092C5A28E33D751C0BE2B27463B8540C001020000000300000092C5A28E33D751C0BE2B27463B8540C08DDA58E432D751C0128F1F85468540C0C9B08A3732D751C094E645DC528540C0010200000003000000893D59D622D751C0F53691F4C48440C0B5A679C729D751C030D978B0C58440C0F1C4628A28D751C0E8C2A3E8DC8440C0010200000003000000BECE97280CD751C02FFDA60B0C8540C08466D7BD15D751C014DCFE4B088540C06AD6BE2525D751C0184B47EF0A8540C0010200000002000000D6BA1E9617D751C0C5DF9B4B168540C0DB8B683B26D751C0DBB9D518198540C001020000000200000071AA5A7718D751C00ED8D5E4298540C0281DF68C0ED751C0194C0D7E2C8540C0010200000003000000DC34119175D851C072D014F0218540C0A6214F3775D851C00A7AB9991B8540C0F4797BC674D851C0233EC10F188540C0010200000002000000F4797BC674D851C0233EC10F188540C0EE601FF873D851C09B5775560B8540C0010200000002000000EE601FF873D851C09B5775560B8540C03C2F151B73D851C05418004FFF8440C00102000000020000003C2F151B73D851C05418004FFF8440C084
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
 E31096D751C05D84CE10338540C0D0C3BFBE8CD751C0703DAF1D318540C0BCDE477F79D751C0D66AB4C12E8540C0BCDE477F79D751C0831035762E8540C09016670C73D751C0CB1E57D92D8540C0B6042A2D6DD751C0A22F18B72C8540C0F651FCCE65D751C043893B832B8540C0010200000002000000F651FCCE65D751C043893B832B8540C0E6DBCC3255D751C01BBAD91F288540C00102000000040000006947BB1B55D751C00F4E9F78298540C02C5F3C284DD751C0B079B020288540C0D310FA3E41D751C06A013510268540C09709754735D751C0AC10A0F0238540C00102000000030000009709754735D751C0AC10A0F0238540C0AB3E575B31D751C07773A72A238540C02E5915E126D751C0F5C8D57E218540C00102000000020000002E5915E126D751C0F5C8D57E218540C089EFC4AC17D751C085A39A481F8540C0010200000002000000003219332ED851C013A4ADA5DB8440C060DE889320D851C004E44BA8E08440C001020000000600000060DE889320D851C004E44BA8E08440C04EA6C0B80AD851C06B065D67E88440C0FB3F87F9F2D751C0A3D2E352F08440C024DEF071DCD751C057D4BBD3F88440C02AF1CA3FC4D751C0BE384C8F018540C04AC851CAB5D751C0741882D2068540C001020000000400000071B66FA4A2D751C078634161508540C0666
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
 81073D951C0A4648396BF8540C001020000000200000078D4981073D951C0A4648396BF8540C03E4F4D9363D951C064535337BC8540C00102000000020000008B8DD4D663D951C08966F915C68540C07EC27EF472D951C087889B53C98540C0010200000002000000F02609D341D951C027AF84A4058540C0D584A39A48D951C05C0AFE6D058540C0010200000002000000D584A39A48D951C05C0AFE6D058540C0B7990AF148D951C09ECB796B058540C0010200000002000000B7990AF148D951C09ECB796B058540C0559396804ED951C0CE21043F058540C0010200000002000000559396804ED951C0CE21043F058540C090076C184FD951C051A4FB39058540C001020000000200000090076C184FD951C051A4FB39058540C0589DE62E53D951C0037D7D08058540C0010200000002000000589DE62E53D951C0037D7D08058540C016D3968455D951C0EC0C9DE8048540C001020000000200000016D3968455D951C0EC0C9DE8048540C00ED6A48059D951C04BE7C3B3048540C00102000000020000000ED6A48059D951C04BE7C3B3048540C048A066ED5BD951C09EB70C93048540C001020000000200000048A066ED5BD951C09EB70C93048540C0B292A0095ED951C06F055E77048540C0010200000002000000B292A0095ED951C06F055E77048540C07660EFB46B
 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
 288540C00102000000020000003201BF4612D951C0271D401AA98440C080CC183012D951C0F77EFED6A98440C001020000000300000080CC183012D951C0F77EFED6A98440C0E5C2370312D951C09A7741E9B08440C01BF09EA811D951C0BF34FBF2B88440C00102000000020000001BF09EA811D951C0BF34FBF2B88440C0E54F0AA911D951C0B5AF9701C28440C0010200000002000000E54F0AA911D951C0B5AF9701C28440C01BF09EA811D951C051F9D7F2CA8440C00102000000030000001BF09EA811D951C051F9D7F2CA8440C0FD7ACF9211D951C0837EF0EBD18440C021B0726811D951C07DDE9E31DD8440C0010200000005000000681481A012D951C0314DC752DA8440C08513872213D951C0950C0055DC8440C09D0D9EAE13D951C02F6F6990DD8440C0071A7D1615D951C034828DEBDF8440C0BE4A3E7617D951C0AB984A3FE18440C0010200000002000000719989D816D951C09E205624CB8440C01BF09EA811D951C051F9D7F2CA8440C0010200000003000000F49C3E4C0CD951C008A98020E58440C08F05E0FA0BD951C0F83D4569CA8440C01BF09EA811D951C051F9D7F2CA8440C0010200000002000000A605D44018D951C0EEFA16E7B98440C01BF09EA811D951C0BF34FBF2B88440C0010200000002000000C460FE0A19D951C031B7D672C28440C0E
 54F0AA911D951C0B5AF9701C28440C0010200000002000000E970BE2209D951C01AF043EF9E8440C080CC183012D951C0F77EFED6A98440C0010200000002000000DC18969A18D951C0E76388ADEA8440C09884B0BF11D951C0EE540ACBE98440C0010200000002000000F3435B8418D951C054CD075FF38440C0E56613BB11D951C0EF213C35F28440C0010200000003000000E56613BB11D951C0EF213C35F28440C024809BC50BD951C08A5CCBBFF18440C0D6B441DC0BD951C0AFF6668AEF8440C0010200000002000000F4D02D2A18D951C0EAE34636FC8440C0EB6B02B111D951C0CC4065FCFB8440C0010200000002000000EB6B02B111D951C0CC4065FCFB8440C0EE6CD96B0BD951C0029CDEC5FB8440C00102000000020000000C89C5B917D951C0EC0C9DE8048540C01BF09EA811D951C045B4C299048540C00102000000020000001BF09EA811D951C045B4C299048540C023F3C81F0CD951C045589E51048540C00102000000030000003C139A2416D951C0BD10BC6B1A8540C0D71C7B5116D951C0183A1B97168540C0EB54F99E11D951C0AD9DCD4F168540C0010200000002000000EB54F99E11D951C0AD9DCD4F168540C0BE897CF20BD951C072851C00168540C0010200000002000000410FB56D18D951C028D8DA560E8540C0C7F143A511D951C0C3B64599
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
 B187698D951C0D7C8096EFF8440C07F1475E69ED951C0D01F3FC0FF8440C00102000000020000007F1475E69ED951C0D01F3FC0FF8440C054EEF439ADD951C0FACCFEE5FF8440C001020000000200000054EEF439ADD951C0FACCFEE5FF8440C0543C8963B8D951C0FACCFEE5FF8440C0010200000004000000543C8963B8D951C0FACCFEE5FF8440C0FDC68D11BFD951C00CC2267C008540C039DF3E61BFD951C0F47F5880008540C00C48B192C5D951C0F4DB7CC8008540C00102000000020000000C48B192C5D951C0F4DB7CC8008540C07C0679E2DED951C0FFDF2241028540C00102000000020000007C0679E2DED951C0FFDF2241028540C00D9AA784F1D951C075F6DF94038540C0010200000005000000E92B483396D951C028E26366558440C06667D13B95D951C0536D814E528440C049B31E6393D951C0B35E0CE5448440C07AB0202892D951C03D484F91438440C0A5B107A48ED951C0D854CCF7428440C0010200000010000000A5B107A48ED951C0D854CCF7428440C0B357C4558AD951C092802C9F408440C03A57941282D951C0C80FF0FF3E8440C036CEA62380D951C08D6D08443E8440C0574A856778D951C09B2D6A41398440C0358012FA74D951C0025B6FE5368440C0D9A6C2E96ED951C0F34F15F82F8440C0E7D951416AD951C0624CFA7B298440C013
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
 51C0211DBBE8F18440C001020000000400000084AB1741DFD851C0211DBBE8F18440C0822271EADED851C0CC796B05F28440C01420AFACD9D851C0FA8106F6F38440C003C12D69D6D851C077894567F48440C001020000000300000003C12D69D6D851C077894567F48440C06A95AAFED2D851C0A136058DF48440C0FB1983F3CED851C0A72787AAF38440C00102000000020000000D36751E95D851C0CE9BD4E1328540C08A09C5B189D851C0C1B9D0A6348540C00102000000020000006DC83F3388D851C07048FEBB998540C0F669CB6F87D851C048A46DFC898540C00102000000020000006B8203B5F3D851C0BD4E8F12608540C0E8A04B38F4D851C0792B01E77B8540C0010200000008000000EDA7B51FDFD851C0C849BC97568340C0ED3488C5DED851C075EF3C4C568340C01E328A8ADDD851C0DB1C42F0538340C0E81EC830DDD851C0AD5C5E6F518340C07E2C8E14DBD851C0BB86CF8C348340C01DE4F560D2D851C0008BFCFA218340C0BC81B861CAD851C0468F29690F8340C03537F0B4C6D851C00EA9FD31088340C0010200000002000000119F854E19D951C06C81F398378540C029571DDE18D951C0E6176F754A8540C001020000000200000029571DDE18D951C0E6176F754A8540C0DB15FA6019D951C0E3DEFC86898540C0010200000002000000764710F
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
 B3ED951C032CDCF68068440C03453B5383ED951C0351F7CCD178440C00102000000020000003453B5383ED951C0351F7CCD178440C02E51627C3DD951C05D7B551D288440C00102000000030000002E51627C3DD951C05D7B551D288440C04C981F6E3DD951C0389F3A56298440C034E087DE3DD951C01E262BD0388440C001020000000300000034E087DE3DD951C01E262BD0388440C0E6875B4F3ED951C03E71A5434C8440C0630564543ED951C0A96917D34C8440C0010200000002000000630564543ED951C0A96917D34C8440C01B0E4B033FD951C0D0BFB8AF5E8440C00102000000030000001B0E4B033FD951C0D0BFB8AF5E8440C051210D5D3FD951C01E801EB4688440C0868D57C540D951C01FA97466718440C0010200000002000000868D57C540D951C01FA97466718440C06ED5BF3541D951C0F28AF1AB838440C00102000000020000006ED5BF3541D951C0F28AF1AB838440C0BBA0191F41D951C0307F85CC958440C0010200000002000000BBA0191F41D951C0307F85CC958440C0F06EC04241D951C03BA01111A38440C0010200000002000000F06EC04241D951C03BA01111A38440C056AAFA4B41D951C0CFAF9C73A68440C001020000000200000056AAFA4B41D951C0CFAF9C73A68440C0976B764941D951C05107C3CAB28440C00102000000020000
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
 1C04AD5D1CCEE8740C0010200000006000000977730BD58DB51C0A91D59541F8540C00A1AE9FB5FDB51C02D08E57D1C8540C08933750D69DB51C08E1C8E53198540C0DBBE47FD75DB51C05B913DE7138540C0242136FD7EDB51C009151C5E108540C098F1006086DB51C0525788580E8540C001020000001800000098F1006086DB51C0525788580E8540C0382B476D87DB51C04C24873E0E8540C0EB234B4192DB51C0DCB694980C8540C0333E82D19BDB51C0471163E30B8540C047489341A4DB51C0DCB694980C8540C0904E5DF9ACDB51C0E1C9B8F30E8540C0437573F1B7DB51C0EB234B41128540C056AD9685C0DB51C0F5633843168540C0D40B3ECDC9DB51C04BF37D271C8540C0FDF4447CCCDB51C0B55B81D71D8540C0527E52EDD3DB51C0EE056685228540C0C63D4CB1D9DB51C0F8455387268540C03A596ABDDFDB51C0730DD87A2B8540C044B060D1E3DB51C07D4DC57C2F8540C04E0757E5E7DB51C0F7144A70348540C01D4938E3EADB51C0782975C9388540C0588C5F1DECDB51C0BE45CC913A8540C096F37B51F1DB51C0F6E34059428540C0A0EE4D1DF5DB51C075D88EF3488540C075779D0DF9DB51C0F5CCDC8D4F8540C0B4F85E8DFDDB51C05089EB18578540C0BE4F55A101DC51C0882760E05E8540C032E13C4107DC51C0AB2E96D86B8540C0AE9D28
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
 61EB63CFDF51C038E04E7D7B8440C0B832F2C3D2DF51C0612BB2E77C8440C001020000000C000000B832F2C3D2DF51C0612BB2E77C8440C001FD1939E6DF51C05D555117848440C0325FB939F0DF51C03E5E4887878440C0A29BFD81F2DF51C06D52769F888440C03C889D29F4DF51C01F6D776A898440C07B939515F9DF51C071033E3F8C8440C04FC0C0BDFCDF51C052F8C7D68E8440C02463B5F9FFDF51C0A374E95F928440C02EBAAB0D04E051C04274AD62968440C06C4FDA6509E051C074E558839C8440C04137EAD70CE051C0FB2C85F6A08440C01695C3DD0FE051C01D250A88A48440C001020000000700000078C59D1CCFDA51C0B524F6BF128640C02FAEA70CD2DA51C0B8D2C66C248640C02FF3C242D2DA51C01715CCF33B8640C005B93077D2DA51C090EDC6CC4F8640C0C425C79DD2DA51C005B9D5BD5F8640C051BD35B0D5DA51C056C8A6A66E8640C06BCFD14FDDDA51C01C052DC9A68640C00102000000050000006BCFD14FDDDA51C01C052DC9A68640C0E9CEB815E7DA51C0B33918FBDC8640C0F261F6B2EDDA51C03469AE2E028740C0566C825EEEDA51C0A488B1F1058740C00DF6CBCCF1DA51C08AB03CA3088740C0010200000003000000B6EC5A8CCBDA51C04E8A45C2AD8540C0A422A9E0CBDA51C0D2B650E8AB8540C04A33CCBFCCDA51C0DA290C8
 0A78540C00102000000050000004A33CCBFCCDA51C0DA290C80A78540C061E52BDCCDDA51C0300CFDB8A28540C06C706C87D0DA51C009771D609C8540C0D06053E7D1DA51C0F9314168988540C041722145D3DA51C085831843948540C00102000000040000004A33CCBFCCDA51C0DA290C80A78540C0FC613A63CEDA51C083667C04A38540C07E99DEB4CFDA51C09048803FA18540C0183EC7ECD1DA51C043F3EFE9A08540C0010200000004000000183EC7ECD1DA51C043F3EFE9A08540C04D37E4FAD2DA51C0D798219FA18540C0457F0D2DD7DA51C04DD7B8A3A48540C01420AFACD9DA51C046E63686A58540C0010200000002000000D8D30E7FCDDA51C0EDE6F39BD38540C078C59D1CCFDA51C0B524F6BF128640C001020000000200000041722145D3DA51C085831843948540C0183EC7ECD1DA51C043F3EFE9A08540C0010200000002000000183EC7ECD1DA51C043F3EFE9A08540C05A8FB1C9D0DA51C0A8DB7E9EAB8540C0010200000003000000E2FAC10A81DC51C054138E6A228640C04605F3FC8EDC51C0CB619C64508640C025308CAA95DC51C013C42FAB668640C0010200000004000000FFB7EDD68DDC51C068C471851C8640C0343EDD8A8EDC51C049B9FB1C1F8640C087FDF9119ADC51C0363D2828458640C087E354C69ADC51C0881BA66C478640C00102
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
 0620097B6EEDC51C0B5EDC5617A8640C017957950F5DC51C0ADCE7BAD958640C00102000000030000001EA8531EDDDC51C08BD70638CE8640C0BECD2C53DDDC51C07313B534B78640C03016E181DCDC51C07F2EBF78AB8640C00102000000090000009EE9CA0CC0DC51C0D2A4B9BA088640C0142BFE4AC2DC51C0121B8755178640C048C2BE9DC4DC51C0518B1C7D278640C0048D3E8BCADC51C0834A010E468640C04E40B8A7D0DC51C04F102B92658640C098DC28B2D6DC51C06E162F16868640C0BB229D26D8DC51C04A2F206A918640C079A3A025D9DC51C0885CBA93998640C02515D742DADC51C071CD78B6A28640C00102000000020000002515D742DADC51C071CD78B6A28640C05523AAA6DADC51C0E13433E9A58640C00102000000030000005523AAA6DADC51C0E13433E9A58640C0960F9C8EDBDC51C06EB598E9A88640C03016E181DCDC51C07F2EBF78AB8640C00102000000020000007A7654907ADD51C023BB7779DF8540C077E2282F68DD51C0039FD5B8ED8540C001020000000200000077E2282F68DD51C0039FD5B8ED8540C02DD0EE9062DD51C01945C5EEF18540C00102000000020000002DD0EE9062DD51C01945C5EEF18540C0E7E4A0DF52DD51C049E647B2FD8540C0010200000006000000E7E4A0DF52DD51C049E647B2FD8540C020AE410441DD
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
 28E728540C01C38B1D183DB51C074B680D07A8540C00102000000020000001C38B1D183DB51C074B680D07A8540C0AA79330F85DB51C0D906EE409D8540C0010200000002000000AA79330F85DB51C0D906EE409D8540C0FD9F68C386DB51C01E26D016C68540C0010200000003000000FD9F68C386DB51C01E26D016C68540C03E192D5187DB51C0CD5C3BACCB8540C0B385D6798ADB51C06950D955ED8540C0010200000002000000B385D6798ADB51C06950D955ED8540C0E25F5F468CDB51C05E448078028640C0010200000005000000E25F5F468CDB51C05E448078028640C09906EA398EDB51C0ED52D966198640C0AA51FEA490DB51C0BBB4E1B0348640C0260B4E3393DB51C0D9E2BFE5568640C0549A835696DB51C0FEE77AEC788640C0010200000003000000549A835696DB51C0FEE77AEC788640C05820D50B99DB51C0E1A183899A8640C0D41E40D09BDB51C064DD89A3BC8640C0010200000004000000D41E40D09BDB51C064DD89A3BC8640C08B7D13549EDB51C05F7D3CF4DD8640C0CB01710DA2DB51C09DD9AED0078740C0CF59B09EA4DB51C02A0AAAFC218740C001020000000B000000CF59B09EA4DB51C02A0AAAFC218740C040999020A6DB51C0CF876709328740C0B455EEAAACDB51C045F69C4F788740C07D957CECAEDB51C093CDB0AC8F8740C08E
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
 1FDDE0179DB51C08E965EF6468840C0BFAE70DC73DB51C0D4EEFC474B8840C0010200000003000000AA85ED829CDC51C08DB38E4F6D8640C03E2B1F389DDC51C010C182458F8640C04A91216C9DDC51C0F9991F24B08640C00102000000050000004A91216C9DDC51C0F9991F24B08640C0F71CFDD49DDC51C0241A93B4D18640C02C30BF2E9EDC51C0068CE4E1F38640C038F2E5AA9EDC51C04DC6E704238740C0D29C06569FDC51C022533E04558740C0010200000004000000F6A6D887ABDE51C0BF8E49905B8540C04143A44BA4DE51C0D2FF722D5A8540C000E1E8CFA3DE51C081BADCBB618540C01221640FA3DE51C0AA5670896D8540C0010200000002000000A95615D0FADB51C07B50AB43C98440C08AC4A97B09DC51C0C3561A42DF8440C00102000000030000008AC4A97B09DC51C0C3561A42DF8440C094AB0E6F0CDC51C0F16CEA97E38440C01D3636E018DC51C05279E008F78440C00102000000020000001D3636E018DC51C05279E008F78440C0C2B92B6027DC51C0535DC0CB0C8540C0010200000002000000C2B92B6027DC51C0535DC0CB0C8540C0DE25CC0F37DC51C036429A0C228540C0010200000002000000DE25CC0F37DC51C036429A0C228540C03D1A3D6D43DC51C0C790AD78348540C00102000000020000003D1A3D6D43DC51C0C790AD783485
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
 1020000000400000015B7F461D8DB51C0DD6D93AE938440C068695D59D8DB51C04F1432A1938440C04EB91D75CFDB51C05C1BCF0C878440C0D8405F1FC2DB51C0015C7F01738440C00102000000050000001A1B159392DB51C0785CF9D1158440C0809E060C92DB51C0894BE9F4178440C04A18175891DB51C022043F051B8440C016DADE1390DB51C0BBBC94151E8440C0F984ECBC8DDB51C00EB5B7A51F8440C0010200000002000000EDD3F19881DB51C03035F8B1388440C00876FC1788DB51C04C56A0713C8440C001020000000700000052F8C7D68EDB51C0DEA2DD32F18340C01B35BADE91DB51C057C04EFBF78340C015BD9D8E91DB51C0BA5972CBFD8340C0CE6CFC2E91DB51C023BC3D08018440C0C2EFF0E890DB51C0930F8B62038440C08D3E8B4A8FDB51C0BE2D58AA0B8440C0E1E6F9788DDB51C06E3079A8128440C0010200000004000000F984ECBC8DDB51C00EB5B7A51F8440C0C48E6BE88BDB51C09EF419AB288440C0AE6C7AAB89DB51C01484E112368440C00876FC1788DB51C04C56A0713C8440C00102000000080000000876FC1788DB51C04C56A0713C8440C098ACE52986DB51C0FF09890F478440C08DAE772483DB51C05B56067A4D8440C0F73878CB7ADB51C074D59700578440C0055262D776DB51C06C62DC685B8440C036278AEB73DB51C006
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
 0D40561133EDA51C0AF1B00BBE48440C0010200000002000000D40561133EDA51C0AF1B00BBE48440C05B8F673C36DA51C0E4A48BA8E48440C00102000000020000005B8F673C36DA51C0E4A48BA8E48440C0E04BE14133DA51C03EA8D5A1E48440C0010200000002000000E04BE14133DA51C03EA8D5A1E48440C0ECF99AE532DA51C0763B5684F68440C0010200000002000000ECF99AE532DA51C0763B5684F68440C0517D8C5E32DA51C09CBF0985088540C0010200000005000000517D8C5E32DA51C09CBF0985088540C0E0C4460F32DA51C0A9763C1C138540C0E16822C731DA51C08A6BC6B3158540C082BFA95931DA51C09E503EF3288540C087DBA16131DA51C0FBEAAA402D8540C001020000000200000087DBA16131DA51C0FBEAAA402D8540C0DB4FC6F830DA51C0E53C08A63F8540C0010200000002000000DB4FC6F830DA51C0E53C08A63F8540C0944440CF30DA51C0B2101D02478540C0010200000002000000944440CF30DA51C0B2101D02478540C04046E5CB30DA51C0F1BFF0A54B8540C0010200000006000000944440CF30DA51C0B2101D02478540C092A34ADE4ADA51C03A5B40683D8540C034C467A153DA51C031D9D369388540C0F86063A854DA51C01336F22F388540C0DAFC643156DA51C0C6E061DA378540C03930140B57DA51C03D597BE937
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
 000000F9AD8CFC30DA51C0B32B88DC678440C0DB21B4D430DA51C0A1DD7C7E738440C0010200000002000000DB21B4D430DA51C0A1DD7C7E738440C076B867A730DA51C04DC8BDAF808440C001020000000200000076B867A730DA51C04DC8BDAF808440C0F95404EE2FDA51C0484ECBB4A28440C0010200000002000000F95404EE2FDA51C0484ECBB4A28440C0F93DFBDB2FDA51C042131736B98440C0010200000003000000D745764A2CDA51C0065F3D93A28440C03386DE8728DA51C010A7DDF98F8440C05040C9D328DA51C05900AEBF808440C00102000000040000005040C9D328DA51C05900AEBF808440C0A9CD493929DA51C0F8E8C369778440C0795A7EE02ADA51C0D105F52D738440C0DB21B4D430DA51C0A1DD7C7E738440C001020000000200000007A74FBC14DA51C099CD8877258540C084526AE514DA51C09DD1FB6B1E8540C001020000000300000084526AE514DA51C09DD1FB6B1E8540C0AE16331D15DA51C078769E1D158540C04820144A15DA51C0EC0C9DE8048540C00102000000020000004820144A15DA51C0EC0C9DE8048540C0E39C22D115DA51C0DF49B0DDE28440C0010200000002000000E39C22D115DA51C0DF49B0DDE28440C030DBA91416DA51C08B02D8DBC18440C001020000000200000030DBA91416DA51C08B02D8DBC18440C0CBE
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
 2C1F93D6298640C066E6B809ADD551C0866A943F298640C00102000000020000004463377D87D551C071CCB227818640C00304183B86D551C0893952C7748640C001020000000300000008C14FC106D651C0418754AC758640C03C7A0D0BFFD551C05D386B4B788640C0C3D265D6F7D551C0D3BEB9BF7A8640C0010200000003000000C3D265D6F7D551C0D3BEB9BF7A8640C080BD1D3CEED551C0901FE0FF7D8640C063D8BC05EDD551C0D16A92697E8640C0010200000004000000AD6296E24FD651C0ECBA5C69BE8540C00788388C38D651C02D825A67D78540C06F7C92E032D651C012FA997ADD8540C07054B82F31D651C0AC144C46DF8540C00102000000060000007054B82F31D651C0AC144C46DF8540C03F34982B28D651C024CA28E0E88540C084F9861D21D651C044CAAA63F08540C0CF786C150ED651C092AD2EA7048640C0B3C414F6FED551C0C641F806158640C01BFE8980F9D551C043EAD1AF088640C00102000000020000004BABC6B71CD651C0BE840A0E2F8640C0B6FC1B0F11D651C07709980A3B8640C0010200000007000000B6FC1B0F11D651C07709980A3B8640C07098689002D651C0335992F2498640C09C5A6C49FDD551C0C05DF6EB4E8640C0C8A06EFBF9D551C042507F07508640C0132631ADF2D551C0E2557B7D528640C0463B133FEBD551C
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
 49D951C0707033260E8740C09D68B2DA57D951C0EB234B41128740C0010200000002000000E1534A1982D951C03629BB4F448740C0E778BB148DD951C09CF46338438740C0010200000005000000E778BB148DD951C09CF46338438740C0FB230C0396D951C0D89C8367428740C05B6CA4B69ED951C0D2B139BD418740C02600FF94AAD951C038352B36418740C0657330F6B9D951C0F1D01CFE3F8740C0010200000002000000579B5A1190D951C00D2B2680AC8640C0F1738DE090D951C0C4EBFA05BB8640C0010200000002000000F1738DE090D951C0C4EBFA05BB8640C003F6871C91D951C0C12F3F81C18640C001020000000200000003F6871C91D951C0C12F3F81C18640C021F58D9E91D951C0EC67B114C98640C001020000000200000021F58D9E91D951C0EC67B114C98640C0AF95D05D92D951C01F589FBCD98640C0010200000003000000AF95D05D92D951C01F589FBCD98640C0B5801A0893D951C096438B6CE78640C0CC7A319493D951C05BDE663BF08640C0010200000002000000CC7A319493D951C05BDE663BF08640C037B8BE5994D951C0718DCF64FF8640C0010200000002000000CC7A319493D951C05BDE663BF08640C09F28BFFB99D951C0CCA77D29F28640C0010200000002000000AF95D05D92D951C01F589FBCD98640C0BB8BE6B79ED951C02
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
 0C00102000000020000001A3625B440DA51C02AEDC330168640C09A78077852DA51C007E9CEB8158640C00102000000020000009A78077852DA51C007E9CEB8158640C0CA4A38995DDA51C0B48E4F6D158640C001020000000D000000CA4A38995DDA51C0B48E4F6D158640C075DE10F461DA51C05A5DF34F158640C08B76700B71DA51C04363DCC3148640C0AB1D6A8077DA51C09C381499148640C05D7D868178DA51C0F53B5E92148640C04B26023079DA51C0FC123B64148640C0ADA580B47FDA51C0732F302B148640C0B51E190687DA51C072B96697148640C0D47723988FDA51C0316EB42D148640C0B742588DA5DA51C0C07053A8138640C0D188E30AB9DA51C032FE220D138640C07CAFC67EBBDA51C0209331E3128640C078C59D1CCFDA51C0B524F6BF128640C001020000000B00000078C59D1CCFDA51C0B524F6BF128640C04242942FE8DA51C0AF0B9AF1118640C01BA26538F9DA51C0D98A47F3118640C068F45954FADA51C0E59425DF118640C087753E9704DB51C015BD9D8E118640C015BA5C0E05DB51C0C1BE428B118640C04F081D7409DB51C056500768118640C0877B1B5110DB51C0216B5732118640C0B7989F1B1ADB51C063A29CC3108640C0E86278912EDB51C0CE16105A0F8640C059F0EC3C3BDB51C0B7369E190E8640C0010200000002000000
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
 D5D8840C0A8E49CD843D951C00549449D5E8840C0
-  </a>
-<test>
-  <op name='buffer' arg1='A' arg2='0.005' arg3='1'>
-    GEOMETRYCOLLECTION EMPTY
-  </op>
-</test>
-</case>
-</run>
Deleted: trunk/tests/xmltester/tests/bug350.xml
--- trunk/tests/xmltester/tests/bug350.xml	2011-04-20 15:42:03 UTC (rev 3289)
+++ trunk/tests/xmltester/tests/bug350.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -1,29 +0,0 @@
-<run>
-  <precisionModel type="FLOATING" />
-<case>
-  <desc>
-http://trac.osgeo.org/geos/ticket/350
-TopologyException: found non-noded intersection between LINESTRING (-322379 830.734, -336712 -2708) and LINESTRING (-332496 -1667.09, -322379 830.734) at -332496 -1667.09
-  </desc>
-  <a>
-01060000000100000001030000000100000007000000000000005C3613C1000000000028A54000000000208D14C1000000000028A5C000000000A83F15C100000000C0A6D040981124BD63B414C1B82DC4EB7C969940CA5EE746E76814C120462E0E5B4A8A40323BFF843F4B14C1C77B5B2D590C9AC0000000005C3613C1000000000028A540
-  </a>
-  <b>
-01060000000100000001030000000100000005000000EF2CF4FC0ED315C1F4792E801F82B6C0477F50A83BA313C12242DCE0BE81B2C0203301B73FCE13C14FB2744AB1EBD24029062D840ECE15C161DDB50E8D6BD140EF2CF4FC0ED315C1F4792E801F82B6C0
-  </b>
-<test>
- <op name="union" arg1="A" arg2="B">
-POLYGON ((-314775 2708, -322378.6881546058 830.7344192302963, -321742.91436957236 -4737.74561859717, -357571.7470252057 -5762.123049645208, -357251.62907800317 17838.204022852125, -324495.928715514 19374.77016942418, -322378.6881546058 830.7344192302967, -314775 2708))
- </op>
-</test>
-<test>
- <op name="difference" arg1="A" arg2="B">
-POLYGON ((-314775 2708, -322378.6881546058 830.7344192302963, -322378.6881546058 830.7344192302967, -314775 2708))
- </op>
-</test>
-</case>
-</run>
Deleted: trunk/tests/xmltester/tests/bug356.xml
--- trunk/tests/xmltester/tests/bug356.xml	2011-04-20 15:42:03 UTC (rev 3289)
+++ trunk/tests/xmltester/tests/bug356.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -1,25 +0,0 @@
-<run>
-  <desc>
-http://trac.osgeo.org/geos/ticket/356
-  </desc>
-  <resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
-<case>
-  <desc>
-multilinestring buffer artifacts
-  </desc>
-  <a>
-MULTILINESTRING((1676339.95971128 4847443.67952346, 1676340.19 4847443.54, 1676338.44 4847440.65, 1676335.37 4847442.52, 1676337.12 4847445.4, 1676339.95971128 4847443.67952346))
-  </a>
-<test>
-  <op name='buffer' arg1='A' arg2='1.0' arg3='8'>
-POLYGON ((1676334.370908338 4847442.47738721, 1676334.381771572 4847442.672985536, 1676334.430559768 4847442.86271278, 1676334.515400594 4847443.039287834, 1676336.265400594 4847445.919287834, 1676336.383019845 4847446.075914382, 1676336.528914198 4847446.206608688, 1676336.697486246 4847446.306356514, 1676336.882268526 4847446.371330916, 1676337.07617165 4847446.399039078, 1676337.2717563 4847446.388417942, 1676337.461518643 4847446.339875002, 1676337.638178226 4847446.255272662, 1676340.477889498 4847444.534796128, 1676340.477889507 4847444.534796122, 1676340.708178227 4847444.395272662, 1676340.865054944 4847444.277767458, 1676340.995997551 4847444.13191887, 1676341.095975523 4847443.963330074, 1676341.16114793 4847443.778477878, 1676341.189010992 4847443.584463894, 1676341.178494273 4847443.388741704, 1676341.130001801 4847443.19883052, 1676341.04539655 4847443.022026312, 1676339.29539655 4847440.132026312, 1676339.177687757 4847439.974857962, 1676339.031535752 4847439.8
 43721232, 1676338.862575756 4847439.743672394, 1676338.6773224 4847439.678569058, 1676338.482918545 4847439.650921426, 1676338.286859869 4847439.661795518, 1676338.096705855 4847439.710772058, 1676337.91978832 4847439.795962644, 1676334.84978832 4847441.665962642, 1676334.693269131 4847441.783769514, 1676334.56272065 4847441.92983049, 1676334.463152898 4847442.098540236, 1676334.398386959 4847442.283424222, 1676334.370908338 4847442.47738721),
-(1676338.816753609 4847443.202781668, 1676337.455985112 4847444.027221212, 1676336.743325995 4847442.854387922, 1676338.10393518 4847442.025612946, 1676338.816753609 4847443.202781668))
-  </op>
-</test>
-</case>
-</run>
Deleted: trunk/tests/xmltester/tests/bug358.xml
--- trunk/tests/xmltester/tests/bug358.xml	2011-04-20 15:42:03 UTC (rev 3289)
+++ trunk/tests/xmltester/tests/bug358.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -1,26 +0,0 @@
-<run>
-  <desc>
-http://trac.osgeo.org/geos/ticket/358
-  </desc>
-<case>
-  <desc>
-Invalid result from union
-  </desc>
-  <a>
-010300000001000000D60500000AD7A3306B4D39418FC2F598DE4B52410AD7A3B0794D39418FC2F5F8DC4B52410AD7A3B08E4D39418FC2F5B8DB4B52410AD7A3B0A34D39418FC2F5F8D94B52410AD7A330B24D39418FC2F558DA4B52410AD7A3B0C34D39418FC2F518DB4B52410AD7A3B0D24D39418FC2F578DA4B52410AD7A3B0E54D39418FC2F558D84B52410AD7A3B0F34D39418FC2F5F8D64B52410AD7A330044E39418FC2F5F8D34B52410AD7A330134E39418FC2F5F8D14B52410AD7A330334E39418FC2F598D04B52410AD7A3304D4E39418FC2F578CD4B52410AD7A3B05D4E39418FC2F558CA4B52410AD7A3306E4E39418FC2F518C84B52410AD7A330844E39418FC2F578C54B52410AD7A3309C4E39418FC2F5B8C24B52410AD7A330C74E39418FC2F5D8BB4B52410AD7A3B0DE4E39418FC2F578B74B52410AD7A3B0F04E39418FC2F598B34B52410AD7A330FF4E39418FC2F518B14B52410AD7A3B0154F39418FC2F558AD4B52410AD7A3B01F4F39418FC2F5F8AB4B52410AD7A3B0374F39418FC2F5B8A84B52410AD7A3B04F4F39418FC2F5B8A64B52410AD7A3B0774F39418FC2F578A44B52410AD7A3B0AA4F39418FC2F5F8A34B52410AD7A3B0C54F39418FC2F558A24B52410AD7A330DD4F39418FC2F5389C4B52410AD7A330055039418FC2F5188F4B52410AD
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
 52413C4ED1510E5439417E6ABC645B4C5241D019516A0A543941388941745D4C5241F44A59660A5439415E4BC8735D4C5241A8A44E600A543941BA490C765D4C524198218E650A543941A067B3765D4C524174711BED06543941B2BFEC325F4C524188F4DBE706543941CAA145325F4C52414872F9CF065439413433333B5F4C524194D409D806543941D6C56D3C5F4C5241D4096812025439410EE02D30614C524140355E0A025439416A4DF32E614C524120B072D801543941C0CAA141614C5241341136DC01543941226C7842614C52411461C363FE5339413E79583C624C524100000060FE533941DCD7813B624C5241782D214FFE5339413C4ED141624C524170A301DCFD53394196B20C55624C5241E4361AE0FD53394140A4DF56624C5241A0D634EFF65339415CB1BF50634C52412C431CEBF6533941B2BFEC4E634C5241C07D1DB8F65339418E757157634C52418816D90EF653394188F4DB5F634C5241C09F1A0FF6533941923A0161634C524194B20CD1ED533941143FC67C634C52416029CBD0ED5339419C559F7B634C5241784F1EB6ED533941B27BF27C634C5241109C33F2EC533941A2D63473634C5241CCEEC9D3EC533941E4F21F6E634C524178E926D1EC53394120D26F6F634C5241C0172633DD533941EAB7AF7B614C52415C8FC235DD533941AED85F7A6
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
 B5239417A58A8A9644C5241489D80C6DB523941168C4A96644C524104560EBDDB523941C420B096644C5241643BDF6FDA5239418E06F0A2624C524164105879DA523941DE718AA2624C52411CA7E868DA52394166F7E48D624C52411CC9E58FDA5239411EA7E85C624C5241A8E848AEDA5239414C378951624C5241448B6CA7DA52394176029A50624C5241AC3E570BDD523941780B2438614C524140575BE1DD52394104780BE05D4C524140575BE1DD52394138F8C2B85B4C52413C795808DE523941F0A7C6875B4C5241ECC03923DE5239415817B77D5B4C524140E8D91CDE52394188D2DE7C5B4C52412C8716E9E5523941ECE236CE574C5241A4B437C8F3523941304CA6DE504C5241903177CDF3523941166A4DDF504C5241941804D6F3523941E2361ADC504C5241F4285CCFF3523941A2D634DB504C5241C854C1D8F6523941384547724F4C5241684469DFF65239417AA52C734F4C524194A98231F75239418E5374544F4C5241506B9AD7F75239415839B4384F4C52417C1D38F7F7523941E6D022374F4C5241DC8AFD55F8523941FCA9F10E4E4C5241E4C7987BF75239412653059B4B4C524164EE5A82F752394140A4DF9A4B4C5241482EFF81F752394120F46C9A4B4C5241D4E76A7BF7523941285C8F9A4B4C524144AD692EF652394102098AB3474C5241FCCBEE
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
 41E8482E63F94B5241943A011D9C543941DCD78163F94B52418451490D9C5439418204C54FF94B524170AC8B1B9C5439410022FD4EF94B52418C976EC297543941501E165EF44B5241AC8BDB3894543941BAB88DF6EE4B5241F853E34592543941029A086FE84B52415405A3129C543941645DDC8ED84B5241D49AE68DA554394190C2F5B8D34B52417C613245AC54394126530523D24B524184C95461B35439414C158C8ED04B524160BA495CB35439412EFF218DD04B52419C802682B3543941849ECD86D04B5241ECC03913B4543941BAFC8750D04B524154302A19B454394112363C51D04B5241283A92ABB75439415405A36ECE4B5241083D9BA5B7543941FCCBEE6DCE4B5241049A08BBB7543941B0E1E965CE4B5241C8293AD2B754394138F8C248CE4B524190E4F2DFB75439412CF69749CE4B5241D8CEF7D3BD543941A857CA22C84B5241588638C6BD543941B459F521C84B52413C7958E8BD543941986E12F7C74B5241FCD478E9BD543941986E12F7C74B524114FBCB4EBE5439411EA7E8B4BA4B5241482EFF11C154394166F7E431B44B524120F46C06C1543941BE529631B44B5241842F4C16C15439412E6EA31DB44B52414CF38EF3C0543941482EFFF1B34B5241B0726801C1543941C4D32BF1B34B5241ECEBC009BF543941F48E53E0B14B524180FB3A60B25
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
 465439416ABC74937B4B5241ECEBC039425439418E5374207C4B5241A01A2F3D3B54394134A2B45B7B4B524104A392FA3A5439413E9B551F7A4B5241480378CB3D54394188635DA0784B5241A045B6834254394174469476764B52418CB96B794254394132772D75764B5241703D0AA742543941C07D1D64764B52412C8716D9425439410EBE3025764B5241A8A44EE042543941F0F44A25764B5241B0E1E9454354394106F0165C744B524134C4B13E43543941925CFE5B744B5241E458174743543941D8A37051744B524198BB96204354394104560E21744B524120166A2D43543941C66D3420744B52419CE61D273E543941C07D1D646F4B5241701B0D10405439419EEFA7F2694B5241E895B23C445439412A1895A0664B5241B8F3FDC452543941DE938725604B5241C03923BA525439416EA30124604B5241C0EC9EEC52543941E4141D11604B5241E458172753543941E63FA4C75F4B52410868221C535439411C0DE0B95F4B5241E09C1125535439415817B7B95F4B5241182024C8525439411E143C7A5E4B52418838D6F56B5439414CC807655E4B5241CCAACFF56B543941C6DCB5645E4B52417C1D38776C543941CAA1455E5E4B5241FCD478796C543941F01648605E4B5241E81DA718835439418AB0E1C95C4B52416866661683543941643BDFC75C4B5241C8293
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
 64B52410AD7A3303E5039418FC2F578784B52410AD7A3B02A5039418FC2F5D87A4B52410AD7A3B0145039418FC2F5587E4B52410AD7A3B00B5039418FC2F538814B52410AD7A330FC4F39418FC2F598864B52410AD7A330F04F39418FC2F5388D4B52410AD7A330E24F39418FC2F5B8934B52410AD7A330D54F39418FC2F598974B52410AD7A3B0C24F39418FC2F5589A4B52410AD7A330AA4F39418FC2F5989D4B52410AD7A3B0894F39418FC2F5789F4B52410AD7A3305D4F39418FC2F598A14B52410AD7A3B02D4F39418FC2F5D8A44B52410AD7A330124F39418FC2F518A84B52410AD7A330FC4E39418FC2F578AB4B52410AD7A3B0E24E39418FC2F598AD4B52410AD7A330D84E39418FC2F558B14B52410AD7A3B0C44E39418FC2F538B54B52410AD7A330AB4E39418FC2F578BA4B52410AD7A3B08B4E39418FC2F5B8BE4B52410AD7A3B06A4E39418FC2F518C24B52410AD7A3305B4E39418FC2F578C34B52410AD7A3303F4E39418FC2F518C74B52410AD7A3302F4E39418FC2F558C84B52410AD7A3B0234E39418FC2F578C64B52410AD7A3301B4E39418FC2F5D8C14B52410AD7A330184E39418FC2F518BE4B52410AD7A3B0144E39418FC2F5F8B84B52410AD7A330F74D39418FC2F558B94B52410AD7A3B0FC4D39418FC2F5D8BF4B52410AD7A330F94D39418FC2F5
 98C44B52410AD7A3B0E74D39418FC2F5B8C74B52410AD7A3B0D64D39418FC2F5D8CA4B52410AD7A330BC4D39418FC2F558CC4B52410AD7A3B0A74D39418FC2F518CE4B52410AD7A3308B4D39418FC2F538D04B52410AD7A3B0754D39418FC2F5F8D14B52410AD7A330614D39418FC2F578D54B52410AD7A330484D39418FC2F5F8D84B52410AD7A330314D39418FC2F518DC4B52410AD7A3B0444D39418FC2F5B8E34B52410AD7A3306B4D39418FC2F598DE4B5241
-  </a>
-  <b>
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
 CDF6534C5241784F1E0662533941A067B3FA534C524178E92621625339413E575BF9534C5241B072682162533941948785FA534C52414CEA047482533941EA26318C534C524198DD93379A533941C0EC9E80544C5241C486A787AF533941423EE845574C5241B0506B0AC1533941D656EC275A4C5241F853E3A5DC53394176E09C61614C5241B4A679A7DC53394112363C61614C5241E07A14AEDC53394134A2B463614C52415C8FC235DD533941AED85F7A614C5241C0172633DD533941EAB7AF7B614C524178E926D1EC53394120D26F6F634C5241CCEEC9D3EC533941E4F21F6E634C5241109C33F2EC533941A2D63473634C5241784F1EB6ED533941B27BF27C634C52416029CBD0ED5339419C559F7B634C524194B20CD1ED533941143FC67C634C5241C09F1A0FF6533941923A0161634C52418816D90EF653394188F4DB5F634C5241C07D1DB8F65339418E757157634C52412C431CEBF6533941B2BFEC4E634C5241A0D634EFF65339415CB1BF50634C5241E4361AE0FD53394140A4DF56624C524170A301DCFD53394196B20C55624C5241782D214FFE5339413C4ED141624C524100000060FE533941DCD7813B624C52411461C363FE5339413E79583C624C5241341136DC01543941226C7842614C524120B072D801543941C0CAA141614C524140355E0A025439416
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
 8E5374B1533941CEF75367564C5241FC187377B15339413C4ED165564C52419CEFA7C69B533941FC87F493534C5241946588C39B53394190317795534C52418C1F639E9B5339418295438F534C52413455302A9B533941DA1B7C89534C5241C4FEB22B9B53394154742487534C5241E02D90E0825339413867448D524C52414C840DDF82533941BE0E9C8F524C52413C9B558F82533941E63FA48B524C52413C014D74825339414850FC8C524C524104780B748253394162C3D38B524C52413480B720625339417AC729FA524C52418048BF5D4153394150FC18AF514C5241A42C435C4153394168006FB1514C52411C0DE00D415339414C3789AD514C5241343333A340533941AACFD5B2514C5241C05B20A1405339418E5374B0514C5241ACCFD5A6365339415EDC463B524C52411CA7E8A8365339417A58A83D524C52417858A89536533941081B9E3E524C5241F8A0679336533941D6C56D3C524C524140A4DFBE1D533941684469D7534C524144AD69FE0E5339416C567D86534C52410022FD46035339412A189500534C524198999919FE52394136AB3E43524C52413C4ED181FB5239417EFB3AB0504C524130DD2456FC523941C6DCB5184E4C5241C876BE4FFC5239412A1895184E4C52415C4BC857FC5239414A9D800E4E4C52410412144FFC5239414EF38E034E4C524
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
 174D52415C2041F182533941CAA14512174D5241F441CF168F53394152499DD4174D524174F90F198F533941AED85FD2174D52416CC5FE928F533941B20C71D8174D52418C06F0569053394132C4B1CE174D5241
-  </b>
-<test>
- <op name="union" arg1="A" arg2="B">
- 010300000007000000020300000AD7A330314D39418FC2F518DC4B52410AD7A3B0444D39418FC2F5B8E34B52410AD7A3306B4D39418FC2F598DE4B52410AD7A3B0794D39418FC2F5F8DC4B52410AD7A3B08E4D39418FC2F5B8DB4B52410AD7A3B0A34D39418FC2F5F8D94B52410AD7A330B24D39418FC2F558DA4B52410AD7A3B0C34D39418FC2F518DB4B52410AD7A3B0D24D39418FC2F578DA4B52410AD7A3B0E54D39418FC2F558D84B52410AD7A3B0F34D39418FC2F5F8D64B52410AD7A330044E39418FC2F5F8D34B52410AD7A330134E39418FC2F5F8D14B52410AD7A330334E39418FC2F598D04B52410AD7A3304D4E39418FC2F578CD4B52410AD7A3B05D4E39418FC2F558CA4B52410AD7A3306E4E39418FC2F518C84B52410AD7A330844E39418FC2F578C54B52410AD7A3309C4E39418FC2F5B8C24B52410AD7A330C74E39418FC2F5D8BB4B52410AD7A3B0DE4E39418FC2F578B74B52410AD7A3B0F04E39418FC2F598B34B52410AD7A330FF4E39418FC2F518B14B52410AD7A3B0154F39418FC2F558AD4B52410AD7A3B01F4F39418FC2F5F8AB4B52410AD7A3B0374F39418FC2F5B8A84B52410AD7A3B04F4F39418FC2F5B8A64B52410AD7A3B0774F39418FC2F578A44B52410AD7A3B0AA4F39418FC2F5F8A34B52410AD7A3B0C54F39418FC2F558A24B52410A
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
 2410AD7A3305D4F39418FC2F598A14B52410AD7A3B02D4F39418FC2F5D8A44B52410AD7A330124F39418FC2F518A84B52410AD7A330FC4E39418FC2F578AB4B52410AD7A3B0E24E39418FC2F598AD4B52410AD7A330D84E39418FC2F558B14B52410AD7A3B0C44E39418FC2F538B54B52410AD7A330AB4E39418FC2F578BA4B52410AD7A3B08B4E39418FC2F5B8BE4B52410AD7A3B06A4E39418FC2F518C24B52410AD7A3305B4E39418FC2F578C34B52410AD7A3303F4E39418FC2F518C74B52410AD7A3302F4E39418FC2F558C84B52410AD7A3B0234E39418FC2F578C64B52410AD7A3301B4E39418FC2F5D8C14B52410AD7A330184E39418FC2F518BE4B52410AD7A3B0144E39418FC2F5F8B84B52410AD7A330F74D39418FC2F558B94B52410AD7A3B0FC4D39418FC2F5D8BF4B52410AD7A330F94D39418FC2F598C44B52410AD7A3B0E74D39418FC2F5B8C74B52410AD7A3B0D64D39418FC2F5D8CA4B52410AD7A330BC4D39418FC2F558CC4B52410AD7A3B0A74D39418FC2F518CE4B52410AD7A3308B4D39418FC2F538D04B52410AD7A3B0754D39418FC2F5F8D14B52410AD7A330614D39418FC2F578D54B52410AD7A330484D39418FC2F5F8D84B52410AD7A330314D39418FC2F518DC4B52412F000000C0EC9ECCF7523941226C78366A4C524140A4DFCEF75239415E
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
 96BF9835139418638D6C1044D524104000000A8C64B27735139419A081BA62C4C52412497FF109E5139419CA223852E4C5241D0B359D59A51394196B20C612E4C5241A8C64B27735139419A081BA62C4C5241
- </op>
-</test>
-</case>
-</run>
Deleted: trunk/tests/xmltester/tests/bug360.xml
--- trunk/tests/xmltester/tests/bug360.xml	2011-04-20 15:42:03 UTC (rev 3289)
+++ trunk/tests/xmltester/tests/bug360.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -1,22 +0,0 @@
-<run>
-  <desc>
-http://trac.osgeo.org/geos/ticket/360
-  </desc>
-  <precisionModel type="FLOATING" />
-<case>
-  <desc>
-Exception on CascadedUnion (JTS works!)
-  </desc>
-  <a>
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
 124A21B12F11D5241010300000001000000060000009C8CC751B8483A4118E57CB8FD1D52413551951AB9483A41DAABCF0F001E52417E74A8A5BA483A41C45FD389FF1D52415374A8A5BA483A41C45FD389FF1D52417E74A8A5BA483A41B95FD389FF1D52419C8CC751B8483A4118E57CB8FD1D5241</a>
-<test>
- <op name="union" arg1="A">
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
- </op>
-</test>
-</case>
-</run>
Deleted: trunk/tests/xmltester/tests/bug366.xml
--- trunk/tests/xmltester/tests/bug366.xml	2011-04-20 15:42:03 UTC (rev 3289)
+++ trunk/tests/xmltester/tests/bug366.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -1,23 +0,0 @@
-<run>
-  <desc>
-    http://trac.osgeo.org/geos/ticket/366
-    Unable to find edge to compute depths at at -200016 249553
-  </desc>
-  <resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
-<case>
-  <desc>
-  </desc>
-  <a>
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
 C114E940F9C7430F411530CCF5BF5406C19BAF9406E8630F4166203B26D81106C14D0D57E70F8F0F410EFB351CDE0006C1F3284448F9980F41BEEB2AF1DCF105C12DEF4FF6E67C0F41EBB1C54FEDCA05C1365D92168CFC0E410DD099A7C7BD05C10000000010770E41
-  </a>
-<test>
-  <op name='buffer' arg1='A' arg2='1'>
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
 780D41E99D0A581A090BC13FE1EC9691F10D4163B25DA61A090BC1446CB02093F10D411F9B894E40160BC188CF42370F770E41
-  </op>
-</test>
-</case>
-</run>
Deleted: trunk/tests/xmltester/tests/bug398.xml
--- trunk/tests/xmltester/tests/bug398.xml	2011-04-20 15:42:03 UTC (rev 3289)
+++ trunk/tests/xmltester/tests/bug398.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -1,48 +0,0 @@
-<run>
-  <desc>
-http://trac.osgeo.org/geos/ticket/398
-  </desc>
-<case>
-  <desc><![CDATA[
-Assertion `shellCount <= 1' failed.
-  ]]></desc>
-  <a>
-MULTIPOLYGON (((60.0 6.5105151320986412,
-44.0044859469790026 11.6931320480208569, 0.0 25.9507790663861222,
-0.0 26.8608278557796467, 0.0 29.8387923019253307, 60.0 10.3985283676378408,
-60.0 7.8021345594223774, 60.0000000000000000 6.6570998796460161, 60.0
-6.5105151320986412)), ((43.3161197496508308 0.0,
-0.0 0.0, 0.0 14.0346133423735822, 0.0 17.9226661292310787,
-0.0 21.5874865260243638, 34.0258524396557860
-6.8981402622972743, 55.3161197496508308 0.0,
-50.0044466166182886 0.0, 43.3161197496508308
-0.0)), ((13.4455725323347899 36.0,
-60.0 36.0, 60.0 16.7944518298098018, 60.0 16.3644011555093201,
-60.0 14.0439960304547569, 2.9187843276549756
-36.0, 11.8945390820010992 36.0, 13.4455725323347899 36.0)))
-  </a>
-  <b>
-POLYGON ((50.0044466166182886 0.0,
-0.0 21.5874865260243638, 0.0
-35.7392139719321804, 60.0 13.1838946818537934,
-60.0 0.0, 50.0044466166182886 0.0))
-  </b>
-<test>
-MULTIPOLYGON (((0.0 0.0, 0.0 14.0346133423735822, 0.0 17.9226661292310787,
-0.0 21.5874865260243638, 0.0 25.9507790663861222, 0.0 26.8608278557796467,
-0.0 29.8387923019253307, 0.0 35.7392139719321804, 60.0 13.1838946818537934,
-60.0 10.3985283676378408, 60.0 7.8021345594223774, 60.0 6.6570998796460161,
-60.0 6.5105151320986412, 60.0 0.0, 55.3161197496508308 0.0,
-50.0044466166182886 0.0, 43.3161197496508308 0.0, 0.0 0.0)),
-((2.9187843276549756 36.0, 11.8945390820010992 36.0, 13.4455725323347899
-36.0, 60.0 36.0, 60.0 16.7944518298098018, 60.0 16.3644011555093201,
-60.0 14.0439960304547569, 2.9187843276549756 36.0)))'
- </op>
-</test>
-</case>
-</run>
Copied: trunk/tests/xmltester/tests/ticket/bug176.xml (from rev 3289, trunk/tests/xmltester/tests/bug176.xml)
--- trunk/tests/xmltester/tests/ticket/bug176.xml	                        (rev 0)
+++ trunk/tests/xmltester/tests/ticket/bug176.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -0,0 +1,40 @@
+<run>
+  <desc>
+  http://trac.osgeo.org/geos/ticket/176
+  </desc>
+  <precisionModel type="FLOATING" />
+  <resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
+<case>
+  <desc>
+	Polygon 1
+  </desc>
+  <a>
+POLYGON ((413.3999999999999773 243.0999999999999943, 607.2999999999999545 244.1999999999999886, 607.0000000000000000 294.8999999999999773, 697.8999999999999773 295.3999999999999773, 699.2000000000000455 241.8000000000000114, 416.8999999999999773 240.9000000000000057, 416.6999999999999886 162.3000000000000114, 413.1999999999999886 162.3000000000000114, 413.3999999999999773 243.0999999999999943))
+  </a>
+<test>
+  <op name='buffer' arg1='A' arg2='-2.0'>
+POLYGON ((609.1722610376851890 243.5129929302678704, 609.2638333893902427 243.8213729820575395, 609.2999649881396635 244.2118341123558309, 609.0118040315680901 292.9110357729544489, 695.9481804295313623 293.3892336629322699, 697.1510625643339836 243.7934779510754595, 609.1722610376851890 243.5129929302678704))
+  </op>
+</test>
+</case>
+<case>
+  <desc>
+	Polygon 2
+  </desc>
+  <a>
+POLYGON ((513.3999999999999773 343.1000000000000227, 707.2999999999999545 344.1999999999999886, 707.0000000000000000 394.8999999999999773, 797.8999999999999773 395.3999999999999773, 799.2000000000000455 341.8000000000000114, 516.8999999999999773 340.8999999999999773, 516.7000000000000455 262.3000000000000114, 513.2000000000000455 262.3000000000000114, 513.3999999999999773 343.1000000000000227))
+  </a>
+<test>
+POLYGON ((709.1722610376851890 343.5129929302678988, 709.2638333893902427 343.8213729820575963, 709.2999649881396635 344.2118341123558594, 709.0118040315680901 392.9110357729544489, 795.9481804295313623 393.3892336629322699, 797.1510625643339836 343.7934779510754879, 709.1722610376851890 343.5129929302678988))
+  </op>
+</test>
+</case>
+</run>
Copied: trunk/tests/xmltester/tests/ticket/bug188.xml (from rev 3289, trunk/tests/xmltester/tests/bug188.xml)
--- trunk/tests/xmltester/tests/ticket/bug188.xml	                        (rev 0)
+++ trunk/tests/xmltester/tests/ticket/bug188.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -0,0 +1,22 @@
+<run>
+  <desc>
+http://trac.osgeo.org/geos/ticket/188
+  </desc>
+<case>
+  <desc>
+  Caused crash in RightmostEdgeFinder creating BufferSubgraphs
+  </desc>
+  <a>
+0103000000010000000B000000713D0AD7C3F9C3403D0AD7A3E8B01441295C8FC255FBC340C3F5285C0BB1144153BB8CF8AD01C44092DD2F29FEB0144148E17A14AE01C4408FC2F528FEB0144148E17A146E01C440A4703D0AF0B014411F85EB517801C44085EB51B8EFB014419A999999B9FFC34066666666CBB0144133333333F3FCC340CDCCCCCCC9B01441295C8FC2F5FBC3408FC2F528CAB014413D0AD7A3F0FBC340CDCCCCCCC9B01441713D0AD7C3F9C3403D0AD7A3E8B01441
+  </a>
+<test>
+  <op name='buffer' arg1='A' arg2='-5.0000000000000004e-006' arg3='3'>
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
+  </op>
+</test>
+</case>
+</run>
Copied: trunk/tests/xmltester/tests/ticket/bug244.xml (from rev 3289, trunk/tests/xmltester/tests/bug244.xml)
--- trunk/tests/xmltester/tests/ticket/bug244.xml	                        (rev 0)
+++ trunk/tests/xmltester/tests/ticket/bug244.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -0,0 +1,23 @@
+<run>
+  <desc>
+http://trac.osgeo.org/geos/ticket/244
+  </desc>
+<case>
+  <desc>
+  </desc>
+  <a>
+ MULTIPOLYGON(((144.520538330078 -1.12083339691162,144.516387939453 -1.12083339691162,144.514434814453 -1.11611104011536,144.514984130859 -1.10305547714233,144.517211914062 -1.09833335876465,144.521362304688 -1.09972214698792,144.522491455078 -1.10527777671814,144.523315429688 -1.11138892173767,144.522491455078 -1.11611104011536,144.520538330078 -1.12083339691162)),((149.731903076172 -1.60333347320557,149.715515136719 -1.57861113548279,149.7099609375 -1.57027792930603,149.703308105469 -1.56361126899719,149.699127197266 -1.56083345413208,149.681915283203 -1.55722236633301,149.680541992188 -1.56277775764465,149.681915283203 -1.57527780532837,149.681365966797 -1.5813889503479,149.678588867188 -1.58555555343628,149.673034667969 -1.58694458007812,149.663299560547 -1.58277773857117,149.659423828125 -1.58000016212463,149.558013916016 -1.50055575370789,149.533325195312 -1.469722032547,149.530548095703 -1.46555542945862,149.527770996094 -1.45444440841675,149.528594970703 -1.448333263
 39722,149.542755126953 -1.41472220420837,149.544982910156 -1.41000008583069,149.564147949219 -1.37027788162231,149.579956054688 -1.35527777671814,149.622467041016 -1.35944437980652,149.627166748047 -1.36138892173767,149.663299560547 -1.38666677474976,149.710784912109 -1.42166662216187,149.716918945312 -1.42916655540466,149.719696044922 -1.43333315849304,149.790252685547 -1.57666683197021,149.790802001953 -1.5813889503479,149.731903076172 -1.60333347320557)),((144.517761230469 -1.39833331108093,144.506103515625 -1.38944435119629,144.503326416016 -1.38555550575256,144.505554199219 -1.38055562973022,144.516387939453 -1.38194441795349,144.519989013672 -1.38555550575256,144.521911621094 -1.39555549621582,144.517761230469 -1.39833331108093)),((142.818298339844 -1.73333311080933,142.813598632812 -1.73277759552002,142.812194824219 -1.72722220420837,142.812744140625 -1.72111105918884,142.818298339844 -1.69972205162048,142.821075439453 -1.69583320617676,142.832183837891 -1.69361114501
 953,142.863006591797 -1.69444441795349,142.866363525391 -1.69777774810791,142.866912841797 -1.70944428443909,142.864410400391 -1.71361112594604,142.859405517578 -1.71555542945862,142.852752685547 -1.70861101150513,142.847198486328 -1.70722222328186,142.841644287109 -1.70861101150513,142.837463378906 -1.71138882637024,142.818298339844 -1.73333311080933)),((147.391937255859 -1.96083331108093,147.399993896484 -1.96638870239258,147.430816650391 -1.9902777671814,147.434417724609 -1.99361109733582,147.44580078125 -2.00944471359253,147.448028564453 -2.01416683197021,147.447204589844 -2.0188889503479,147.439697265625 -2.06083345413208,147.437744140625 -2.06555557250977,147.426086425781 -2.06777811050415,147.275268554688 -2.1211109161377,147.255554199219 -2.14916658401489,147.239135742188 -2.16694450378418,147.22802734375 -2.17638874053955,147.212188720703 -2.18805551528931,147.207458496094 -2.19027757644653,147.201904296875 -2.19166660308838,146.980529785156 -2.1991662979126,146.893
 035888672 -2.18944406509399,146.8388671875 -2.18194437026978,146.798309326172 -2.16888904571533,146.793579101562 -2.16694450378418,146.726348876953 -2.16083335876465,146.571624755859 -2.23472213745117,146.568023681641 -2.23666667938232,146.563293457031 -2.23472213745117,146.5283203125 -2.20111131668091,146.524993896484 -2.19083309173584,146.518035888672 -2.1497220993042,146.518859863281 -2.14361143112183,146.578308105469 -2.00194454193115,146.580535888672 -1.99722218513489,146.583862304688 -1.99361109733582,146.638580322266 -1.97861099243164,146.844970703125 -1.95055556297302,146.857177734375 -1.94916653633118,146.869689941406 -1.94916653633118,147.093566894531 -1.96638870239258,147.099975585938 -1.96694445610046,147.118286132812 -1.96888875961304,147.164428710938 -1.98333311080933,147.203308105469 -2.003333568573,147.300811767578 -2.02527761459351,147.417755126953 -2.05055570602417,147.419982910156 -2.04583358764648,147.422760009766 -2.03472232818604,147.422760009766 -2.029
 16669845581,147.420532226562 -2.01083374023438,147.418579101562 -2.00583362579346,147.391937255859 -1.96083331108093)),((147.756927490234 -2.35249996185303,147.766662597656 -2.32388925552368,147.795532226562 -2.26500034332275,147.815246582031 -2.24361133575439,147.832458496094 -2.24555540084839,147.877746582031 -2.28944444656372,147.879119873047 -2.29361152648926,147.856353759766 -2.3313889503479,147.848297119141 -2.33666658401489,147.829132080078 -2.34555530548096,147.824127197266 -2.34777784347534,147.81884765625 -2.34916639328003,147.812469482422 -2.34972190856934,147.756927490234 -2.35249996185303)),((150.367736816406 -2.68666648864746,150.356353759766 -2.66805553436279,150.347473144531 -2.66333341598511,150.341064453125 -2.66249990463257,150.273315429688 -2.67277765274048,150.257476806641 -2.6777777671814,150.242462158203 -2.68305540084839,150.190521240234 -2.68583297729492,150.184143066406 -2.68527746200562,150.109405517578 -2.625,149.972473144531 -2.50111150741577,149
 .965789794922 -2.4941668510437,149.949127197266 -2.47638845443726,149.948577880859 -2.47166633605957,149.951354980469 -2.46749973297119,149.960784912109 -2.46000003814697,150.079956054688 -2.41416645050049,150.189697265625 -2.37722206115723,150.206085205078 -2.37444448471069,150.216369628906 -2.37777757644653,150.248016357422 -2.39000034332275,150.417205810547 -2.46055555343628,150.443298339844 -2.47583293914795,150.446075439453 -2.47972202301025,150.467193603516 -2.54472255706787,150.468017578125 -2.55777788162231,150.459686279297 -2.64833354949951,150.458312988281 -2.6536111831665,150.448852539062 -2.66472196578979,150.443298339844 -2.66611099243164,150.41943359375 -2.66249990463257,150.406921386719 -2.66388893127441,150.4013671875 -2.6652774810791,150.371887207031 -2.68388891220093,150.367736816406 -2.68666648864746)),((152.659423828125 -3.84277772903442,152.670837402344 -3.85989284515381,152.701080322266 -3.88305521011353,152.739685058594 -3.89611101150513,152.7697143554
 69 -3.90027761459351,152.919128417969 -4.0041675567627,152.989685058594 -4.07583332061768,153.006927490234 -4.09361171722412,153.118560791016 -4.23916625976562,153.12939453125 -4.25555610656738,153.131622314453 -4.26027870178223,153.134429931641 -4.27138900756836,153.132171630859 -4.37861061096191,153.130798339844 -4.39083385467529,153.128021240234 -4.39500045776367,153.121337890625 -4.40194416046143,153.108856201172 -4.40999984741211,153.092468261719 -4.42083358764648,153.080810546875 -4.43000030517578,153.066375732422 -4.44277763366699,153.063018798828 -4.44638824462891,153.0546875 -4.45861148834229,153.04052734375 -4.48527717590332,153.039154052734 -4.49749946594238,153.039703369141 -4.50361156463623,153.041076660156 -4.5091667175293,153.043304443359 -4.51388931274414,153.046630859375 -4.51722240447998,153.059692382812 -4.52555561065674,153.066375732422 -4.53222274780273,153.077453613281 -4.54861068725586,153.079406738281 -4.58916664123535,153.077453613281 -4.600555419921
 88,152.980255126953 -4.7605562210083,152.974670410156 -4.76666641235352,152.910247802734 -4.82333374023438,152.891662597656 -4.82250022888184,152.743560791016 -4.67305564880371,152.735504150391 -4.66083335876465,152.733306884766 -4.6561107635498,152.693023681641 -4.55833339691162,152.681365966797 -4.5222225189209,152.664978027344 -4.4688892364502,152.662750244141 -4.4572229385376,152.666381835938 -4.45388889312744,152.678588867188 -4.44555473327637,152.681365966797 -4.44138813018799,152.692199707031 -4.39361190795898,152.69775390625 -4.36499977111816,152.69775390625 -4.35805511474609,152.694427490234 -4.19138813018799,152.693572998047 -4.18527698516846,152.691650390625 -4.18055534362793,152.603302001953 -4.00611114501953,152.581909179688 -3.96583318710327,152.538726806641 -3.90009546279907,152.512176513672 -3.8687310218811,152.491577148438 -3.85225462913513,152.374969482422 -3.7277774810791,152.359954833984 -3.70472240447998,152.357177734375 -3.69361114501953,152.35662841796
 9 -3.6875,152.358001708984 -3.66166639328003,152.355224609375 -3.65055561065674,152.349700927734 -3.64249992370605,152.289428710938 -3.57944440841675,152.282470703125 -3.57277774810791,152.190521240234 -3.50888919830322,152.182464599609 -3.50361156463623,152.156372070312 -3.48861122131348,152.151641845703 -3.48638868331909,152.146087646484 -3.4850001335144,152.136657714844 -3.48916673660278,152.131072998047 -3.49055576324463,152.124969482422 -3.49000024795532,151.984405517578 -3.46444463729858,151.956359863281 -3.45833349227905,151.934967041016 -3.44555521011353,151.758331298828 -3.32444477081299,151.708862304688 -3.28055572509766,151.688293457031 -3.25305557250977,151.620513916016 -3.17722225189209,151.6171875 -3.17388916015625,151.608306884766 -3.16916656494141,151.574676513672 -3.1594443321228,151.532745361328 -3.14499998092651,151.493011474609 -3.13000011444092,151.483581542969 -3.12583303451538,151.462188720703 -3.11305570602417,151.455535888672 -3.1061110496521,151.452
 758789062 -3.10194444656372,151.450531005859 -3.09722232818604,151.449981689453 -3.08416652679443,151.448577880859 -3.07888889312744,151.44384765625 -3.06972217559814,151.438293457031 -3.06361103057861,151.417205810547 -3.05055570602417,151.369689941406 -3.02250003814697,151.281372070312 -2.97416639328003,151.237457275391 -2.95361137390137,151.214965820312 -2.94194412231445,151.150543212891 -2.89527797698975,151.122467041016 -2.86861085891724,151.119689941406 -2.86444473266602,151.113586425781 -2.8502779006958,151.110778808594 -2.84611082077026,151.106628417969 -2.84333324432373,151.004425048828 -2.78916692733765,150.999694824219 -2.78722238540649,150.930541992188 -2.76861095428467,150.923583984375 -2.76861095428467,150.903045654297 -2.77138900756836,150.876342773438 -2.77611112594604,150.861907958984 -2.78249979019165,150.832458496094 -2.78722238540649,150.819427490234 -2.7877779006958,150.754425048828 -2.77083349227905,150.750274658203 -2.76805543899536,150.729675292969 -2
 .74055576324463,150.730529785156 -2.7344446182251,150.733856201172 -2.7311110496521,150.747467041016 -2.71749973297119,150.752471923828 -2.71527767181396,150.763305664062 -2.7180552482605,150.824401855469 -2.71527767181396,150.874969482422 -2.71250009536743,150.88720703125 -2.71111106872559,150.891357421875 -2.70833349227905,150.894989013672 -2.70499992370605,150.896942138672 -2.70027780532837,150.885650634766 -2.6851110458374,150.884307861328 -2.67811107635498,150.876983642578 -2.65594434738159,150.875640869141 -2.65294456481934,150.873641967773 -2.65094447135925,150.867797851562 -2.64844417572021,150.861633300781 -2.64977788925171,150.856292724609 -2.65261125564575,150.853134155273 -2.65344452857971,150.838012695312 -2.64277791976929,150.831909179688 -2.64222240447998,150.822204589844 -2.6380558013916,150.792755126953 -2.61666631698608,150.805816650391 -2.56666660308838,150.807739257812 -2.56333351135254,150.811370849609 -2.55999994277954,150.817474365234 -2.559166431427,1
 50.834686279297 -2.57083368301392,150.838012695312 -2.57416677474976,150.906524658203 -2.63594436645508,150.964691162109 -2.68722200393677,150.968841552734 -2.69000005722046,151.086639404297 -2.75027799606323,151.190246582031 -2.82611131668091,151.280822753906 -2.87083339691162,151.311370849609 -2.86999988555908,151.419128417969 -2.89805555343628,151.427185058594 -2.9036111831665,151.464416503906 -2.93499994277954,151.598022460938 -3.02750015258789,151.641937255859 -3.04805564880371,151.717742919922 -3.11555576324463,151.72607421875 -3.12805557250977,151.815246582031 -3.19777774810791,151.820526123047 -3.1991662979126,151.825531005859 -3.1972222328186,151.833587646484 -3.19166660308838,151.855529785156 -3.18611097335815,151.861907958984 -3.18694448471069,151.921905517578 -3.20333337783813,151.948852539062 -3.21083354949951,152.055816650391 -3.24777793884277,152.054412841797 -3.26000022888184,152.054412841797 -3.27361106872559,152.057739257812 -3.28388929367065,152.1647033691
 41 -3.41111087799072,152.204406738281 -3.45444440841675,152.210510253906 -3.46055555343628,152.238006591797 -3.47833299636841,152.252471923828 -3.4844446182251,152.277191162109 -3.49472236633301,152.306640625 -3.50638914108276,152.327178955078 -3.51999998092651,152.355224609375 -3.54000043869019,152.361907958984 -3.54666709899902,152.367462158203 -3.55499982833862,152.392211914062 -3.59861087799072,152.411926269531 -3.63361120223999,152.488006591797 -3.64916658401489,152.493011474609 -3.64861106872559,152.496917724609 -3.65138864517212,152.503051757812 -3.6588888168335,152.511383056641 -3.67111110687256,152.553314208984 -3.74583339691162,152.556640625 -3.756667137146,152.555816650391 -3.76944446563721,152.549713134766 -3.78388929367065,152.546356201172 -3.79416704177856,152.549133300781 -3.79833364486694,152.573852539062 -3.8216667175293,152.577758789062 -3.82444477081299,152.582733154297 -3.82638883590698,152.603302001953 -3.83305549621582,152.659423828125 -3.84277772903442
 )),((149.6640625 -10.3398141860962,149.639434814453 -10.3413887023926,149.572204589844 -10.3413887023926,149.566925048828 -10.3413887023926,149.536651611328 -10.361665725708,149.335784912109 -10.307222366333,149.224975585938 -10.2761116027832,149.186645507812 -10.2600002288818,149.176361083984 -10.2563896179199,149.161102294922 -10.2511119842529,149.139984130859 -10.2449989318848,149.093292236328 -10.2341651916504,149.049407958984 -10.2424983978271,149.03857421875 -10.2449989318848,148.993835449219 -10.2605571746826,148.981628417969 -10.268611907959,148.934967041016 -10.2672233581543,148.79443359375 -10.2391662597656,148.723297119141 -10.1869449615479,148.680267333984 -10.1494445800781,148.677459716797 -10.1533336639404,148.642486572266 -10.1863880157471,148.637481689453 -10.1883344650269,148.468292236328 -10.2038879394531,148.462738037109 -10.2038879394531,148.4033203125 -10.2005558013916,148.372467041016 -10.1919441223145,148.3369140625 -10.1797218322754,148.332733154297 -
 10.176944732666,148.327178955078 -10.1688899993896,148.322479248047 -10.1599998474121,148.314971923828 -10.1405563354492,148.312194824219 -10.1363887786865,148.3046875 -10.130277633667,148.157562255859 -10.0737085342407,148.154418945312 -10.0791664123535,148.150543212891 -10.0952777862549,148.148315429688 -10.0999984741211,148.115509033203 -10.1216659545898,148.10302734375 -10.1297206878662,148.0888671875 -10.1358337402344,148.083312988281 -10.1372222900391,148.055236816406 -10.1433334350586,147.999694824219 -10.1519451141357,147.952453613281 -10.1458339691162,147.940795898438 -10.1211109161377,147.923034667969 -10.0980548858643,147.872192382812 -10.0475006103516,147.86328125 -10.0427780151367,147.857727050781 -10.0427780151367,147.781097412109 -10.0508327484131,147.775543212891 -10.0522232055664,147.766082763672 -10.0561103820801,147.619964599609 -9.9908332824707,147.612457275391 -9.98472213745117,147.601348876953 -9.97527694702148,147.574127197266 -9.94833374023438,147.510
 25390625 -9.87861061096191,147.504150390625 -9.87138748168945,147.501373291016 -9.86722183227539,147.499389648438 -9.85583305358887,147.501373291016 -9.85111045837402,147.503601074219 -9.83944320678711,147.503601074219 -9.8125,147.499389648438 -9.79638862609863,147.490509033203 -9.77138900756836,147.48828125 -9.76666641235352,147.386932373047 -9.63555717468262,147.316375732422 -9.55527877807617,147.296600341797 -9.53412532806396,147.248565673828 -9.50583457946777,147.12939453125 -9.44361114501953,147.080001831055 -9.43415546417236,147.099975585938 -9.44972229003906,147.102752685547 -9.45388793945312,147.102752685547 -9.48361015319824,147.101348876953 -9.48888778686523,147.09912109375 -9.49110984802246,147.094421386719 -9.49305534362793,147.0888671875 -9.49166679382324,147.062194824219 -9.47333335876465,147.055236816406 -9.46666526794434,147.008026123047 -9.39833450317383,147.001922607422 -9.3841667175293,146.926635742188 -9.28277778625488,146.91748046875 -9.28750038146973,14
 6.911376953125 -9.28694534301758,146.901092529297 -9.28333282470703,146.896942138672 -9.28083419799805,146.893585205078 -9.27722358703613,146.891662597656 -9.27250099182129,146.888885498047 -9.1833324432373,146.905044555664 -9.13727760314941,146.905868530273 -9.13410949707031,146.907043457031 -9.13127708435059,146.909881591797 -9.13077735900879,146.915374755859 -9.13361072540283,146.918548583984 -9.13444423675537,146.969696044922 -9.09138870239258,146.977172851562 -9.07444381713867,146.981353759766 -9.05944442749023,146.981048583984 -9.05097389221191,146.974395751953 -9.03388977050781,146.972473144531 -9.02916717529297,146.969116210938 -9.02833366394043,146.951080322266 -9.03388977050781,146.94580078125 -9.04194450378418,146.944427490234 -9.04722213745117,146.94580078125 -9.05277824401855,146.951904296875 -9.06027793884277,146.954681396484 -9.06833267211914,146.953308105469 -9.07361030578613,146.925262451172 -9.09999847412109,146.91748046875 -9.10610961914062,146.84460449218
 8 -9.09577751159668,146.840911865234 -9.09627723693848,146.83757019043 -9.09544467926025,146.630523681641 -9.0302791595459,146.621612548828 -9.02555656433105,146.586639404297 -8.99916648864746,146.578308105469 -8.9869441986084,146.55859375 -8.9416675567627,146.545532226562 -8.90250015258789,146.546081542969 -8.89777946472168,146.555816650391 -8.85972213745117,146.559143066406 -8.85638809204102,146.567474365234 -8.8075008392334,146.541351318359 -8.76361274719238,146.517486572266 -8.72500038146973,146.441345214844 -8.62472152709961,146.431915283203 -8.61388778686523,146.419982910156 -8.60499954223633,146.403594970703 -8.59444427490234,146.379104614258 -8.58470821380615,146.372192382812 -8.57805633544922,146.351623535156 -8.55777740478516,146.318572998047 -8.50889015197754,146.275543212891 -8.44305610656738,146.269439697266 -8.42888832092285,146.268035888672 -8.42361068725586,146.263305664062 -8.38750076293945,146.264709472656 -8.37527656555176,146.264709472656 -8.3686103820800
 8,146.262481689453 -8.35972213745117,146.243286132812 -8.29472351074219,146.238555908203 -8.28583335876465,146.229675292969 -8.27444458007812,146.218566894531 -8.26472282409668,146.111083984375 -8.16388893127441,146.110229492188 -8.13472366333008,146.089691162109 -8.09111022949219,145.998016357422 -8.05444526672363,145.987731933594 -8.05111122131348,145.930816650391 -8.04111099243164,145.918579101562 -8.03972244262695,145.898590087891 -8.03888893127441,145.880798339844 -8.04166793823242,145.835510253906 -8.02805709838867,145.797760009766 -8.00777816772461,145.786376953125 -7.99888896942139,145.718292236328 -7.96777820587158,145.649993896484 -7.9597225189209,145.630798339844 -7.94472217559814,145.616912841797 -7.93777751922607,145.528045654297 -7.93777751922607,145.502471923828 -7.9399995803833,145.484130859375 -7.94861030578613,145.465515136719 -7.95083332061768,145.443572998047 -7.94944381713867,145.432739257812 -7.94805526733398,145.422485351562 -7.94472217559814,145.24411
 0107422 -7.86861038208008,145.19807434082 -7.82955169677734,145.182723999023 -7.81383991241455,145.168106079102 -7.81822443008423,145.162994384766 -7.82626342773438,145.164459228516 -7.83649444580078,145.161529541016 -7.84489870071411,145.155685424805 -7.84599494934082,145.044967651367 -7.82041692733765,144.995513916016 -7.81555557250977,144.879669189453 -7.78250026702881,144.844696044922 -7.75722312927246,144.838562011719 -7.74972152709961,144.840515136719 -7.74499988555908,144.850250244141 -7.74111080169678,144.871337890625 -7.70777797698975,144.873565673828 -7.7030553817749,144.874114990234 -7.69694423675537,144.874114990234 -7.6899995803833,144.862457275391 -7.61055564880371,144.844696044922 -7.60777759552002,144.833862304688 -7.67722225189209,144.831085205078 -7.68111133575439,144.824127197266 -7.68805503845215,144.819427490234 -7.6899995803833,144.787750244141 -7.69138813018799,144.783599853516 -7.69138813018799,144.599395751953 -7.6602783203125,144.588287353516 -7.657
 50026702881,144.584411621094 -7.65472221374512,144.552185058594 -7.6119441986084,144.547210693359 -7.60305500030518,144.547210693359 -7.5963888168335,144.545806884766 -7.57472229003906,144.536376953125 -7.52694511413574,144.534973144531 -7.52166652679443,144.530822753906 -7.51222229003906,144.525268554688 -7.5038890838623,144.520538330078 -7.50194454193115,144.514984130859 -7.50194454193115,144.51025390625 -7.5038890838623,144.508880615234 -7.50944519042969,144.508331298828 -7.61472225189209,144.508331298828 -7.62138843536377,144.424682617188 -7.53305530548096,144.418579101562 -7.52583312988281,144.410247802734 -7.52027797698975,144.406921386719 -7.51944446563721,144.412200927734 -7.56583309173584,144.435516357422 -7.68000030517578,144.467742919922 -7.74305534362793,144.395812988281 -7.75583362579346,144.378021240234 -7.75333404541016,144.363006591797 -7.74777793884277,144.358856201172 -7.74499988555908,144.356628417969 -7.74027729034424,144.354125976562 -7.72944450378418,14
 4.354125976562 -7.72277736663818,144.356628417969 -7.70499992370605,144.359680175781 -7.69416618347168,144.360229492188 -7.68249988555908,144.319122314453 -7.62083339691162,144.315795898438 -7.61749935150146,144.310791015625 -7.61666584014893,144.260803222656 -7.63777828216553,144.250549316406 -7.65472221374512,144.243560791016 -7.66694450378418,144.255249023438 -7.73416614532471,144.263031005859 -7.74027729034424,144.272491455078 -7.76749992370605,144.271911621094 -7.77361106872559,144.268310546875 -7.77694511413574,144.224395751953 -7.79333305358887,144.219116210938 -7.79472255706787,144.213012695312 -7.79527759552002,144.147216796875 -7.77888870239258,144.121612548828 -7.77166652679443,143.911926269531 -7.69694423675537,143.899719238281 -7.68861103057861,143.848037719727 -7.63533353805542,143.838531494141 -7.62833404541016,143.829193115234 -7.61733341217041,143.822525024414 -7.60766696929932,143.812713623047 -7.58883380889893,143.810211181641 -7.58316707611084,143.8065490
 72266 -7.57049989700317,143.773040771484 -7.51555633544922,143.768310546875 -7.506667137146,143.758605957031 -7.50250053405762,143.664825439453 -7.46764850616455,143.691345214844 -7.51222229003906,143.755126953125 -7.58950042724609,143.839416503906 -7.71527767181396,143.845520019531 -7.73611068725586,143.852447509766 -7.77027797698975,143.85302734375 -7.78305530548096,143.851898193359 -7.79527759552002,143.85302734375 -7.80749988555908,143.854400634766 -7.81305503845215,143.896362304688 -7.88027763366699,143.901641845703 -7.88833332061768,143.9580078125 -7.97862243652344,143.957183837891 -7.98472213745117,143.955230712891 -7.9894437789917,143.893585205078 -8.03694534301758,143.889434814453 -8.03972244262695,143.884704589844 -8.04166793823242,143.847747802734 -8.04583358764648,143.833862304688 -8.04583358764648,143.755249023438 -8.04111099243164,143.750274658203 -8.03888893127441,143.743560791016 -8.03222274780273,143.738006591797 -8.02416801452637,143.724395751953 -8.0105571
 7468262,143.719421386719 -8.00833511352539,143.661376953125 -7.99138832092285,143.631896972656 -7.98666667938232,143.618835449219 -7.98611068725586,143.597473144531 -7.99222183227539,143.588562011719 -7.99694442749023,143.568908691406 -8.0041675567627,143.56575012207 -8.00483322143555,143.546081542969 -8.00638961791992,143.501647949219 -7.9961109161377,143.485778808594 -7.99138832092285,143.481628417969 -7.98888874053955,143.474975585938 -7.98194408416748,143.473571777344 -7.97305583953857,143.460510253906 -7.93861103057861,143.454406738281 -7.92416667938232,143.444122314453 -7.91333389282227,143.439971923828 -7.91055583953857,143.435241699219 -7.90861129760742,143.424133300781 -7.90722274780273,143.362457275391 -7.8997220993042,143.358306884766 -7.90250015258789,143.356903076172 -7.90805530548096,143.356903076172 -7.91333389282227,143.360504150391 -7.91694450378418,143.446624755859 -7.98055553436279,143.538635253906 -8.05216693878174,143.541458129883 -8.05333423614502,143.5
 43975830078 -8.05500030517578,143.547958374023 -8.05900001525879,143.628295898438 -8.19361114501953,143.630523681641 -8.19833374023438,143.632446289062 -8.20999908447266,143.631896972656 -8.21611022949219,143.629669189453 -8.22749900817871,143.625518798828 -8.2369441986084,143.622192382812 -8.24055480957031,143.611907958984 -8.24388885498047,143.56884765625 -8.24722099304199,143.554962158203 -8.24722099304199,143.512481689453 -8.2458324432373,143.469421386719 -8.24527740478516,143.382446289062 -8.25,143.373565673828 -8.25055694580078,143.338562011719 -8.2538890838623,143.234954833984 -8.27500152587891,143.178039550781 -8.28666687011719,143.080810546875 -8.30833435058594,143.069976806641 -8.31083297729492,143.049407958984 -8.31777763366699,143.034149169922 -8.32305526733398,143.023864746094 -8.3266658782959,143 -8.33666610717773,142.991058349609 -8.34138870239258,142.979949951172 -8.34416580200195,142.973297119141 -8.34416580200195,142.967193603516 -8.3436107635498,142.961639
 404297 -8.34222221374512,142.94580078125 -8.33749961853027,142.941070556641 -8.33527755737305,142.908874511719 -8.31916618347168,142.882171630859 -8.30500030517578,142.865509033203 -8.29416656494141,142.845794677734 -8.28666687011719,142.799987792969 -8.27500152587891,142.776641845703 -8.27083396911621,142.696350097656 -8.26749992370605,142.654693603516 -8.27361106872559,142.638031005859 -8.27777862548828,142.595794677734 -8.29000091552734,142.575256347656 -8.29666709899902,142.565521240234 -8.30083274841309,142.548309326172 -8.31083297729492,142.540802001953 -8.31694412231445,142.533874511719 -8.32388877868652,142.529968261719 -8.3266658782959,142.521087646484 -8.33138847351074,142.511383056641 -8.33527755737305,142.505828857422 -8.33666610717773,142.485229492188 -8.33666610717773,142.466918945312 -8.33611106872559,142.442749023438 -8.33277702331543,142.437469482422 -8.33138847351074,142.427764892578 -8.32722282409668,142.419708251953 -8.32194519042969,142.411926269531 -8.3
 1583404541016,142.403213500977 -8.28638935089111,142.396194458008 -8.26155567169189,142.395050048828 -8.25055599212646,142.394195556641 -8.23922157287598,142.39453125 -8.23155498504639,142.394195556641 -8.2278881072998,142.386657714844 -8.19361114501953,142.383880615234 -8.18972206115723,142.379943847656 -8.18694496154785,142.338562011719 -8.16638946533203,142.327758789062 -8.16388893127441,142.316925048828 -8.16388893127441,142.221618652344 -8.1733341217041,142.2119140625 -8.17722320556641,142.140808105469 -8.22222137451172,142.13720703125 -8.22555541992188,142.13525390625 -8.23027801513672,142.135803222656 -8.23638725280762,142.144714355469 -8.23916625976562,142.155822753906 -8.24055480957031,142.163879394531 -8.23638725280762,142.172210693359 -8.23083305358887,142.182464599609 -8.22083282470703,142.186645507812 -8.21805572509766,142.195526123047 -8.21333312988281,142.223571777344 -8.20027732849121,142.228302001953 -8.19833374023438,142.309143066406 -8.18083381652832,142.3
 14147949219 -8.18000030517578,142.324401855469 -8.1833324432373,142.338012695312 -8.19027709960938,142.355224609375 -8.19916725158691,142.361358642578 -8.20638847351074,142.374572753906 -8.26111125946045,142.377410888672 -8.2746114730835,142.377075195312 -8.28644466400146,142.377410888672 -8.29327774047852,142.382446289062 -8.31916618347168,142.388031005859 -8.32722282409668,142.408599853516 -8.34749984741211,142.439422607422 -8.37138748168945,142.44970703125 -8.37472152709961,142.466918945312 -8.37805557250977,142.473022460938 -8.37888717651367,142.486633300781 -8.37888717651367,142.493011474609 -8.37805557250977,142.512756347656 -8.37194442749023,142.522491455078 -8.36805534362793,142.5263671875 -8.36527633666992,142.540252685547 -8.35166549682617,142.548309326172 -8.34611129760742,142.556640625 -8.34083366394043,142.590240478516 -8.3266658782959,142.619689941406 -8.31500053405762,142.635528564453 -8.31027793884277,142.641662597656 -8.31083297729492,142.734680175781 -8.322
 50022888184,142.771636962891 -8.33194351196289,142.776641845703 -8.33388900756836,142.783325195312 -8.34083366394043,142.788879394531 -8.3488883972168,142.799133300781 -8.35916519165039,142.807464599609 -8.36444473266602,142.906097412109 -8.42361068725586,142.917205810547 -8.42611122131348,142.9580078125 -8.43166732788086,143.01025390625 -8.44111061096191,143.04443359375 -8.44777870178223,143.049987792969 -8.44916725158691,143.086364746094 -8.45999908447266,143.096618652344 -8.4636116027832,143.110229492188 -8.47027778625488,143.213012695312 -8.5494441986084,143.220520019531 -8.55555534362793,143.239135742188 -8.57138824462891,143.246063232422 -8.57805633544922,143.249389648438 -8.58138847351074,143.281646728516 -8.61861038208008,143.374664306641 -8.741943359375,143.392761230469 -8.77027893066406,143.395263671875 -8.7813892364502,143.406921386719 -8.96194458007812,143.405548095703 -8.96749877929688,143.403045654297 -8.97138786315918,143.384429931641 -8.99388885498047,143.367
 1875 -9.01083374023438,143.363006591797 -9.01361274719238,143.331634521484 -9.02833366394043,143.321899414062 -9.03250122070312,143.316650390625 -9.03388977050781,143.310241699219 -9.03305625915527,143.299407958984 -9.02361106872559,143.289154052734 -9.02027893066406,143.283050537109 -9.01972198486328,143.269989013672 -9.02027893066406,143.248016357422 -9.02555656433105,143.232177734375 -9.0302791595459,143.174133300781 -9.04861068725586,143.047210693359 -9.09000015258789,143.04248046875 -9.09194374084473,143.039154052734 -9.09527778625488,143.030822753906 -9.10750007629395,143.023864746094 -9.11416625976562,142.902770996094 -9.19750022888184,142.842468261719 -9.2327766418457,142.807464599609 -9.25222396850586,142.797760009766 -9.25638961791992,142.788299560547 -9.26027870178223,142.769134521484 -9.2672233581543,142.752471923828 -9.27138900756836,142.723846435547 -9.28333282470703,142.66552734375 -9.32055473327637,142.654693603516 -9.32999992370605,142.638885498047 -9.334722
 5189209,142.625244140625 -9.3347225189209,142.582733154297 -9.33083343505859,142.571624755859 -9.32805633544922,142.543029785156 -9.30916595458984,142.532470703125 -9.29888916015625,142.5244140625 -9.28694534301758,142.521087646484 -9.28333282470703,142.517486572266 -9.28000068664551,142.497741699219 -9.26527786254883,142.477172851562 -9.25166702270508,142.425811767578 -9.22805595397949,142.2099609375 -9.16500091552734,142.203033447266 -9.16500091552734,142.054412841797 -9.18722152709961,141.944702148438 -9.20694351196289,141.721343994141 -9.21444511413574,141.615783691406 -9.23611068725586,141.608856201172 -9.23611068725586,141.522491455078 -9.22111129760742,141.509429931641 -9.21388816833496,141.501922607422 -9.20777702331543,141.495788574219 -9.20027732849121,141.48828125 -9.19416618347168,141.460784912109 -9.17388916015625,141.448577880859 -9.16583442687988,141.429412841797 -9.15750122070312,141.388305664062 -9.14416694641113,141.375244140625 -9.14333343505859,141.323028
 564453 -9.14999961853027,141.312194824219 -9.15277862548828,141.307464599609 -9.15500068664551,141.294982910156 -9.16305541992188,141.284698486328 -9.17305564880371,141.266387939453 -9.18888854980469,141.226623535156 -9.21722221374512,141.213592529297 -9.22472190856934,141.176361083984 -9.23388862609863,141.160797119141 -9.23749923706055,141.122467041016 -9.23194313049316,141.117462158203 -9.22999954223633,141.109405517578 -9.22472190856934,141.090789794922 -9.20916557312012,141.033874511719 -9.15694427490234,141.013305664062 -9.13666725158691,141.007019042969 -9.12846755981445,141.006134033203 -6.90478563308716,141.006134033203 -6.89328384399414,140.998565673828 -6.89388942718506,140.990509033203 -6.89944458007812,140.983581542969 -6.9061107635498,140.978851318359 -6.90694427490234,140.949401855469 -6.9036111831665,140.902770996094 -6.85583305358887,140.875244140625 -6.79611110687256,140.871063232422 -6.7863883972168,140.859405517578 -6.72861099243164,140.858856201172 -6.67
 83332824707,140.863006591797 -6.63138866424561,140.891082763672 -6.60333347320557,140.895263671875 -6.60055541992188,140.898040771484 -6.59666728973389,140.947204589844 -6.5,140.951354980469 -6.48361110687256,140.950805664062 -6.47749996185303,140.948577880859 -6.47277736663818,140.94580078125 -6.4686107635498,140.928039550781 -6.45083332061768,140.932189941406 -6.43444442749023,140.963592529297 -6.3386116027832,140.967742919922 -6.33583354949951,140.973297119141 -6.33444499969482,140.985504150391 -6.33305549621582,141.006134033203 -6.33292484283447,141.006103515625 -6,141.006103515625 -4.90555477142334,141.006103515625 -2.61388921737671,141.002471923828 -2.60708522796631,141.029968261719 -2.59277772903442,141.034698486328 -2.59083318710327,141.039428710938 -2.59000015258789,141.046356201172 -2.59000015258789,141.199127197266 -2.61805534362793,141.204681396484 -2.61944437026978,141.214141845703 -2.62222194671631,141.270538330078 -2.64555549621582,141.273864746094 -2.65583324
 432373,141.278045654297 -2.6652774810791,141.284149169922 -2.67277765274048,141.345794677734 -2.70777797698975,141.369689941406 -2.7180552482605,141.380798339844 -2.72083330154419,141.410797119141 -2.72499990463257,141.426635742188 -2.72972202301025,141.436370849609 -2.73388910293579,141.568572998047 -2.79388904571533,141.608856201172 -2.8125,141.704132080078 -2.86250019073486,141.840515136719 -2.93694448471069,141.881622314453 -2.96444463729858,141.889984130859 -2.96999979019165,141.894714355469 -2.9719443321228,141.913879394531 -2.9719443321228,141.931091308594 -2.9686107635498,141.935791015625 -2.96638870239258,141.962463378906 -2.95888900756836,141.973571777344 -2.95611095428467,141.991912841797 -2.95416688919067,142.003601074219 -2.95611095428467,142.011932373047 -2.96166658401489,142.066070556641 -3.00833368301392,142.076904296875 -3.01777791976929,142.077758789062 -3.02055549621582,142.124969482422 -3.05944442749023,142.252471923828 -3.10472249984741,142.551910400391
 -3.21833324432373,142.663604736328 -3.24777793884277,142.946624755859 -3.33249998092651,142.992462158203 -3.34833335876465,143.032745361328 -3.36277770996094,143.041076660156 -3.36416673660278,143.073181152344 -3.36020636558533,143.087738037109 -3.35583353042603,143.093841552734 -3.35500001907349,143.106079101562 -3.35388898849487,143.123840332031 -3.35388898849487,143.172760009766 -3.35722255706787,143.194702148438 -3.3600001335144,143.209686279297 -3.3652777671814,143.2138671875 -3.36805534362793,143.229400634766 -3.37972211837769,143.23828125 -3.38444471359253,143.255554199219 -3.3880558013916,143.336364746094 -3.40166664123535,143.346069335938 -3.40166664123535,143.370788574219 -3.40166664123535,143.384429931641 -3.40305519104004,143.408325195312 -3.40638875961304,143.442749023438 -3.41194438934326,143.516082763672 -3.43444442749023,143.520812988281 -3.43666648864746,143.529144287109 -3.44194412231445,143.536651611328 -3.44805526733398,143.569427490234 -3.47555541992188,
 143.598846435547 -3.51444482803345,143.602172851562 -3.5247220993042,143.605804443359 -3.54194450378418,143.609130859375 -3.54527807235718,143.61328125 -3.54805564880371,143.648864746094 -3.56722259521484,143.731079101562 -3.60416698455811,143.768310546875 -3.61083364486694,143.790802001953 -3.61083364486694,143.794982910156 -3.61222219467163,143.798858642578 -3.61500024795532,143.949127197266 -3.73333311080933,143.955230712891 -3.73944425582886,143.9580078125 -3.74361133575439,143.964691162109 -3.7572226524353,143.966064453125 -3.76277780532837,143.976348876953 -3.77972221374512,143.981903076172 -3.78805589675903,143.988861083984 -3.79500007629395,143.993011474609 -3.79777812957764,144.016937255859 -3.81055545806885,144.243011474609 -3.87277746200562,144.249114990234 -3.87361097335815,144.253875732422 -3.87138891220093,144.255249023438 -3.86611127853394,144.253875732422 -3.86194467544556,144.253875732422 -3.85500001907349,144.258026123047 -3.84555530548096,144.275268554688
 -3.809166431427,144.278594970703 -3.80583333969116,144.284973144531 -3.80527782440186,144.338287353516 -3.80249977111816,144.375244140625 -3.80249977111816,144.511657714844 -3.82083368301392,144.515808105469 -3.82361125946045,144.532196044922 -3.84611082077026,144.534973144531 -3.8502779006958,144.549987792969 -3.87611103057861,144.552185058594 -3.88111114501953,144.547210693359 -3.8938889503479,144.545257568359 -3.90416669845581,144.54248046875 -3.93444442749023,144.543853759766 -3.95361137390137,144.547210693359 -3.96388912200928,144.551361083984 -3.9719443321228,144.571350097656 -3.99194431304932,144.591064453125 -4.00611114501953,144.608306884766 -4.0130558013916,144.613861083984 -4.01444530487061,144.653594970703 -4.0130558013916,144.673309326172 -4.01361179351807,144.678863525391 -4.01500034332275,144.729675292969 -4.0313892364502,144.766662597656 -4.04638862609863,144.850250244141 -4.09305572509766,144.858306884766 -4.09833335876465,144.876342773438 -4.11361122131348,
 144.978302001953 -4.22277736663818,144.981628417969 -4.22638893127441,144.986633300781 -4.23499965667725,144.991333007812 -4.24388885498047,144.994689941406 -4.25277805328369,144.996063232422 -4.26250076293945,145.004974365234 -4.28166675567627,145.033050537109 -4.33555603027344,145.036651611328 -4.33888912200928,145.054962158203 -4.35194396972656,145.089965820312 -4.37166595458984,145.094696044922 -4.37388896942139,145.157196044922 -4.38277721405029,145.228576660156 -4.3880558013916,145.253051757812 -4.37861061096191,145.293579101562 -4.37666606903076,145.305236816406 -4.37722206115723,145.333862304688 -4.38944435119629,145.338012695312 -4.39222240447998,145.451080322266 -4.49416637420654,145.459411621094 -4.50444507598877,145.527191162109 -4.59249973297119,145.614135742188 -4.70027828216553,145.620513916016 -4.70777797698975,145.675811767578 -4.76194477081299,145.679412841797 -4.76527786254883,145.69384765625 -4.77694511413574,145.735504150391 -4.80277729034424,145.7808227
 53906 -4.92777729034424,145.813598632812 -5.06555557250977,145.813598632812 -5.07250022888184,145.786926269531 -5.23138904571533,145.765808105469 -5.26361179351807,145.738861083984 -5.30527782440186,145.724395751953 -5.41222190856934,145.723846435547 -5.42527770996094,145.725250244141 -5.430832862854,145.734130859375 -5.4491662979126,145.747741699219 -5.46972179412842,145.754699707031 -5.47638893127441,145.766387939453 -5.48527717590332,145.782745361328 -5.4894437789917,145.787750244141 -5.48999977111816,145.793029785156 -5.48999977111816,145.872467041016 -5.48611068725586,145.930816650391 -5.47722244262695,145.935516357422 -5.47638893127441,145.963592529297 -5.47305583953857,145.976623535156 -5.47638893127441,146.082183837891 -5.51250076293945,146.174682617188 -5.55138874053955,146.194702148438 -5.55888843536377,146.289154052734 -5.58888912200928,146.376342773438 -5.59916687011719,146.439971923828 -5.59861087799072,146.445526123047 -5.59861087799072,146.465240478516 -5.6047
 2202301025,146.47021484375 -5.60666751861572,146.474090576172 -5.60944557189941,146.531188964844 -5.65468120574951,146.580535888672 -5.69472217559814,146.605224609375 -5.71777820587158,146.640808105469 -5.74388885498047,146.653045654297 -5.75194454193115,146.662750244141 -5.75611114501953,146.688873291016 -5.76416683197021,146.714691162109 -5.76972198486328,146.770782470703 -5.79138946533203,146.775787353516 -5.79361248016357,146.783843994141 -5.79889011383057,146.786071777344 -5.80388927459717,146.796310424805 -5.83441781997681,146.875213623047 -5.82555675506592,146.894958496094 -5.82888984680176,146.923004150391 -5.84194564819336,146.930511474609 -5.84805679321289,146.946319580078 -5.86638927459717,146.953826904297 -5.88611221313477,146.956604003906 -5.89027881622314,146.962707519531 -5.897780418396,146.992156982422 -5.91611289978027,147.014129638672 -5.92833518981934,147.041625976562 -5.94222354888916,147.046325683594 -5.94416904449463,147.102722167969 -5.96611404418945,1
 47.112152099609 -5.96667003631592,147.228820800781 -5.97223472595215,147.234924316406 -5.97140216827393,147.24658203125 -5.96251487731934,147.269683837891 -5.93807125091553,147.274658203125 -5.93612670898438,147.284942626953 -5.93529415130615,147.423278808594 -5.96058177947998,147.466613769531 -5.97085952758789,147.476867675781 -5.97419261932373,147.484375 -5.98030376434326,147.573303222656 -6.05527782440186,147.590515136719 -6.07222270965576,147.641937255859 -6.13694477081299,147.786651611328 -6.30249977111816,147.826354980469 -6.3372220993042,147.830261230469 -6.34694480895996,147.850250244141 -6.41166687011719,147.863861083984 -6.45916652679443,147.866638183594 -6.47000026702881,147.869964599609 -6.65472221374512,147.869415283203 -6.66083335876465,147.866058349609 -6.67083358764648,147.845520019531 -6.69138813018799,147.838562011719 -6.69805526733398,147.819427490234 -6.71305561065674,147.810516357422 -6.71777820587158,147.770812988281 -6.72611141204834,147.759155273438 -
 6.72805595397949,147.568023681641 -6.75194454193115,147.416381835938 -6.73499965667725,147.305541992188 -6.74583339691162,147.219696044922 -6.74638843536377,147.199981689453 -6.74583339691162,147.188873291016 -6.74305534362793,147.180816650391 -6.74027729034424,147.174682617188 -6.73555564880371,147.166381835938 -6.72333335876465,147.160247802734 -6.71722221374512,147.149993896484 -6.71388912200928,147.0888671875 -6.71444511413574,146.971069335938 -6.74305534362793,146.961364746094 -6.74722194671631,146.948577880859 -6.79805564880371,146.944976806641 -6.81527709960938,146.943023681641 -6.84027767181396,146.941650390625 -6.90444469451904,146.944976806641 -6.95388889312744,146.946350097656 -6.95944499969482,146.948577880859 -6.96416664123535,146.955230712891 -6.97111129760742,147.0244140625 -7.03694438934326,147.037475585938 -7.04444408416748,147.130798339844 -7.20361137390137,147.140258789062 -7.22111129760742,147.144439697266 -7.23083305358887,147.146362304688 -7.24916648864
 746,147.145812988281 -7.26194477081299,147.141662597656 -7.27166652679443,147.140258789062 -7.27694511413574,147.137481689453 -7.29472255706787,147.139709472656 -7.32527828216553,147.1533203125 -7.38305473327637,147.154693603516 -7.38861179351807,147.178588867188 -7.46388912200928,147.210784912109 -7.49027729034424,147.216369628906 -7.49166679382324,147.297210693359 -7.5038890838623,147.303314208984 -7.50472259521484,147.320526123047 -7.50527858734131,147.332183837891 -7.50333404541016,147.3369140625 -7.50527858734131,147.418579101562 -7.56722259521484,147.457733154297 -7.5977783203125,147.641357421875 -7.77555561065674,147.666656494141 -7.79111099243164,147.670806884766 -7.79388904571533,147.693298339844 -7.82583332061768,147.696075439453 -7.83527755737305,147.701629638672 -7.87055492401123,147.701629638672 -7.8841667175293,147.700805664062 -7.89027786254883,147.701629638672 -7.90333366394043,147.703033447266 -7.90861129760742,147.710510253906 -7.92166614532471,147.71524047
 8516 -7.92916679382324,147.718566894531 -7.93249988555908,147.731628417969 -7.9399995803833,147.741333007812 -7.94388866424561,147.756927490234 -7.94861030578613,147.776916503906 -7.93638801574707,147.782470703125 -7.93527698516846,147.804412841797 -7.93527698516846,147.854949951172 -7.93527698516846,147.866638183594 -7.93722152709961,147.876342773438 -7.94111061096191,147.888031005859 -7.94999980926514,147.911926269531 -7.96722221374512,147.935791015625 -7.98277759552002,147.939422607422 -7.98472213745117,147.974395751953 -7.99610900878906,147.979675292969 -8.03694534301758,147.982452392578 -8.04777908325195,147.985229492188 -8.05194473266602,147.9921875 -8.0586109161377,148.004425048828 -8.06666564941406,148.009979248047 -8.06666564941406,148.0263671875 -8.06277847290039,148.114685058594 -8.05527877807617,148.13525390625 -8.06611061096191,148.194976806641 -8.25194549560547,148.19970703125 -8.26749992370605,148.205810546875 -8.29527854919434,148.206634521484 -8.301389694213
 87,148.207183837891 -8.31083297729492,148.207183837891 -8.32055473327637,148.206634521484 -8.34000015258789,148.210784912109 -8.39305686950684,148.220245361328 -8.51027870178223,148.222198486328 -8.53388977050781,148.230529785156 -8.55972290039062,148.235229492188 -8.56861114501953,148.2421875 -8.57527732849121,148.271087646484 -8.59444427490234,148.300537109375 -8.61138916015625,148.318298339844 -8.60861015319824,148.327178955078 -8.60638809204102,148.331359863281 -8.60638809204102,148.347198486328 -8.61138916015625,148.351898193359 -8.61333274841309,148.376617431641 -8.62944412231445,148.443023681641 -8.67500114440918,148.44580078125 -8.67888832092285,148.478576660156 -8.73305511474609,148.479949951172 -8.73861122131348,148.479949951172 -8.75889015197754,148.489685058594 -8.84027671813965,148.494415283203 -8.86666488647461,148.530822753906 -8.99305534362793,148.534698486328 -9.00277900695801,148.536926269531 -9.00750160217285,148.5888671875 -9.07027816772461,148.6041259765
 62 -9.08250045776367,148.614410400391 -9.0858325958252,148.695251464844 -9.10222244262695,148.719970703125 -9.10472106933594,148.725250244141 -9.10472106933594,148.753601074219 -9.10416603088379,148.782196044922 -9.10138893127441,148.842468261719 -9.09055519104004,149.067199707031 -9.04111099243164,149.071350097656 -9.03861236572266,149.137756347656 -9.00666809082031,149.221343994141 -8.99860954284668,149.255828857422 -8.99777793884277,149.259979248047 -8.99916648864746,149.309967041016 -9.01694488525391,149.314697265625 -9.01889038085938,149.316650390625 -9.02166748046875,149.322204589844 -9.03777885437012,149.338012695312 -9.12972068786621,149.328308105469 -9.15277862548828,149.325531005859 -9.15694427490234,149.316070556641 -9.16777801513672,149.311920166016 -9.17055511474609,149.291351318359 -9.18388938903809,149.181640625 -9.34916687011719,149.1796875 -9.35361099243164,149.178863525391 -9.35972213745117,149.178863525391 -9.37333297729492,149.181091308594 -9.385000228881
 84,149.184417724609 -9.39500045776367,149.208312988281 -9.45249938964844,149.219970703125 -9.47472190856934,149.227752685547 -9.48749923706055,149.231079101562 -9.49110984802246,149.234405517578 -9.49444389343262,149.243286132812 -9.49916648864746,149.266662597656 -9.51000022888184,149.271636962891 -9.5119457244873,149.2783203125 -9.5119457244873,149.28857421875 -9.50861167907715,149.301635742188 -9.50777816772461,149.307189941406 -9.5091667175293,149.348846435547 -9.52194595336914,149.437469482422 -9.57138824462891,149.439422607422 -9.59111022949219,149.440795898438 -9.59638786315918,149.444122314453 -9.59972190856934,149.454406738281 -9.60305404663086,149.662200927734 -9.60722160339355,149.739410400391 -9.60166549682617,149.746337890625 -9.60166549682617,149.758026123047 -9.6038875579834,149.764984130859 -9.60916519165039,149.771087646484 -9.61666488647461,149.775268554688 -9.61944389343262,149.780548095703 -9.6208324432373,149.874389648438 -9.6422233581543,149.88079833984
 4 -9.64305686950684,149.9033203125 -9.64361190795898,149.910247802734 -9.64361190795898,149.94580078125 -9.6422233581543,149.956634521484 -9.63972282409668,149.960784912109 -9.6369457244873,149.982727050781 -9.63138771057129,150.008880615234 -9.63138771057129,150.049133300781 -9.67944526672363,150.051361083984 -9.68416595458984,150.053314208984 -9.68888854980469,150.056915283203 -9.70999908447266,150.056915283203 -9.71527671813965,150.055541992188 -9.72055435180664,150.051910400391 -9.72416687011719,149.988861083984 -9.75111198425293,149.926635742188 -9.76944541931152,149.863586425781 -9.78222274780273,149.857452392578 -9.78277778625488,149.852752685547 -9.78222274780273,149.841644287109 -9.77944564819336,149.835510253906 -9.77888870239258,149.808013916016 -9.7813892364502,149.769714355469 -9.7902774810791,149.764984130859 -9.79222297668457,149.739410400391 -9.80777740478516,149.727172851562 -9.81583404541016,149.720245361328 -9.82277679443359,149.717468261719 -9.82666587829
 59,149.716369628906 -9.83222198486328,149.717468261719 -9.83749961853027,149.721069335938 -9.84749984741211,149.723022460938 -9.85249900817871,149.76220703125 -9.90166664123535,149.873840332031 -10.0169448852539,149.914154052734 -10.0488891601562,149.926635742188 -10.0569438934326,149.935516357422 -10.0616655349731,149.982727050781 -10.081111907959,149.98828125 -10.0825004577637,149.994415283203 -10.0819444656372,150.003326416016 -10.0772228240967,150.013610839844 -10.0736103057861,150.019714355469 -10.073055267334,150.184143066406 -10.0933322906494,150.189147949219 -10.0952777862549,150.236358642578 -10.1283321380615,150.259704589844 -10.1527786254883,150.29052734375 -10.1830558776855,150.298583984375 -10.1883344650269,150.308319091797 -10.1924991607666,150.352752685547 -10.1999988555908,150.382171630859 -10.2047214508057,150.400268554688 -10.2072219848633,150.579681396484 -10.2411098480225,150.61328125 -10.2755565643311,150.618011474609 -10.2775001525879,150.63525390625 -1
 0.280834197998,150.641357421875 -10.2813892364502,150.647491455078 -10.280834197998,150.775543212891 -10.2613906860352,150.780548095703 -10.2591667175293,150.803588867188 -10.2486095428467,150.815521240234 -10.2397212982178,150.81884765625 -10.2363872528076,150.824981689453 -10.2316665649414,150.829681396484 -10.2294454574585,150.844116210938 -10.2247219085693,150.862731933594 -10.2227764129639,150.869415283203 -10.2227764129639,150.877746582031 -10.2283334732056,150.878295898438 -10.2316665649414,150.870788574219 -10.2377777099609,150.861907958984 -10.2424983978271,150.727752685547 -10.3125,150.641937255859 -10.3494434356689,150.636383056641 -10.3508319854736,150.631072998047 -10.3508319854736,150.602172851562 -10.3502769470215,150.596069335938 -10.3494434356689,150.547485351562 -10.3355560302734,150.496063232422 -10.3186111450195,150.438568115234 -10.3036117553711,150.421905517578 -10.3011112213135,150.415802001953 -10.3002777099609,150.406372070312 -10.3044452667236,150.3
 69110107422 -10.3219451904297,150.358306884766 -10.3313884735107,150.356353759766 -10.3361110687256,150.348571777344 -10.3758316040039,150.346618652344 -10.3875007629395,150.352172851562 -10.3952789306641,150.356903076172 -10.3975009918213,150.568572998047 -10.4627780914307,150.6494140625 -10.4755554199219,150.657745361328 -10.4811115264893,150.663299560547 -10.4891662597656,150.689971923828 -10.5502777099609,150.691925048828 -10.5550003051758,150.691345214844 -10.5611114501953,150.688568115234 -10.5652770996094,150.680267333984 -10.5774993896484,150.675537109375 -10.5794448852539,150.568023681641 -10.6219444274902,150.556365966797 -10.6238880157471,150.522766113281 -10.6191654205322,150.492736816406 -10.6191654205322,150.481628417969 -10.6219444274902,150.477447509766 -10.6244430541992,150.47412109375 -10.6277770996094,150.44384765625 -10.6588897705078,150.428314208984 -10.6877784729004,150.424133300781 -10.6905555725098,150.369964599609 -10.6872215270996,150.268585205078 -
 10.6886119842529,150.209686279297 -10.7005558013916,150.113006591797 -10.6674995422363,150.099975585938 -10.6575012207031,150.059417724609 -10.6258316040039,150.028045654297 -10.5894432067871,150.016937255859 -10.5733337402344,150.013031005859 -10.5705547332764,150.007476806641 -10.5691661834717,149.91552734375 -10.5577774047852,149.898590087891 -10.5597229003906,149.896362304688 -10.5625,149.893585205078 -10.5633344650269,149.888305664062 -10.5619449615479,149.862182617188 -10.5544452667236,149.852752685547 -10.5502777099609,149.850524902344 -10.5469455718994,149.875244140625 -10.5100002288818,149.878570556641 -10.5066680908203,149.883331298828 -10.5044460296631,149.901916503906 -10.5025005340576,149.942474365234 -10.5025005340576,149.964416503906 -10.5025005340576,149.968292236328 -10.5052795410156,149.971069335938 -10.5094451904297,149.97802734375 -10.5161113739014,149.989685058594 -10.5180568695068,150.016937255859 -10.5113906860352,150.022491455078 -10.5100002288818,150
 .031372070312 -10.5052795410156,150.039703369141 -10.5,150.078857421875 -10.4627780914307,150.064422607422 -10.4561100006104,149.990234375 -10.4372215270996,149.866363525391 -10.3980560302734,149.806091308594 -10.3677768707275,149.785522460938 -10.3583335876465,149.758026123047 -10.3461112976074,149.747741699219 -10.3427772521973,149.723846435547 -10.3394432067871,149.683868408203 -10.3380546569824,149.6640625 -10.3398141860962)),((152.004425048828 -2.67000007629395,151.972747802734 -2.66888904571533,151.961090087891 -2.66805553436279,151.957733154297 -2.66472196578979,151.955535888672 -2.65999984741211,151.953582763672 -2.64833354949951,151.954406738281 -2.64222240447998,151.958312988281 -2.63249969482422,151.972747802734 -2.60583353042603,151.979675292969 -2.59888887405396,151.983856201172 -2.59611082077026,151.995239257812 -2.59555530548096,152.000823974609 -2.5969443321228,152.010528564453 -2.60111141204834,152.018585205078 -2.60638904571533,152.022216796875 -2.610000133
 5144,152.035247802734 -2.63111114501953,152.037200927734 -2.63583326339722,152.038024902344 -2.64222240447998,152.029693603516 -2.66111087799072,152.026916503906 -2.6652774810791,152.022216796875 -2.66750001907349,152.004425048828 -2.67000007629395)),((151.959136962891 -2.84611082077026,151.946624755859 -2.84472227096558,151.941345214844 -2.84333324432373,151.937194824219 -2.8405556678772,151.931640625 -2.83249998092651,151.921905517578 -2.80777788162231,151.920806884766 -2.80222225189209,151.928863525391 -2.7186107635498,151.9296875 -2.71250009536743,151.932464599609 -2.70833349227905,151.939147949219 -2.70833349227905,151.944702148438 -2.70972204208374,151.985778808594 -2.72499990463257,151.989959716797 -2.72749996185303,151.996612548828 -2.7344446182251,152.006378173828 -2.74555540084839,152.009155273438 -2.74944448471069,152.009704589844 -2.75583362579346,152.011932373047 -2.79055595397949,152.011932373047 -2.81805562973022,152.009704589844 -2.82277774810791,152.00219726
 5625 -2.82888889312744,151.959136962891 -2.84611082077026)),((152.063873291016 -3.00222253799438,152.059143066406 -3,152.035247802734 -2.98277759552002,152.0283203125 -2.97555541992188,151.960510253906 -2.88722229003906,151.959686279297 -2.8808331489563,151.959686279297 -2.86861085891724,151.960510253906 -2.86250019073486,151.963287353516 -2.85833358764648,151.973571777344 -2.84805536270142,151.978302001953 -2.84611082077026,151.984954833984 -2.84611082077026,152.072204589844 -2.92138910293579,152.078857421875 -2.9283332824707,152.083862304688 -2.93694448471069,152.087188720703 -2.9472222328186,152.089141845703 -2.95888900756836,152.088562011719 -2.96527767181396,152.086639404297 -2.96999979019165,152.073577880859 -2.99805545806885,152.069976806641 -3.00138902664185,152.063873291016 -3.00222253799438)),((150.773590087891 -2.98555564880371,150.768035888672 -2.9844446182251,150.766082763672 -2.97944402694702,150.773040771484 -2.97249984741211,150.788024902344 -2.96027803421021
 ,150.795532226562 -2.95416688919067,150.870788574219 -2.91249990463257,150.879119873047 -2.9088888168335,150.903045654297 -2.90833330154419,150.908599853516 -2.90833330154419,150.913299560547 -2.91027784347534,150.941345214844 -2.9219446182251,151.021087646484 -2.96305561065674,151.023590087891 -2.96722221374512,151.021636962891 -2.9719443321228,151.003875732422 -2.98166656494141,150.999114990234 -2.98361110687256,150.992736816406 -2.9844446182251,150.882446289062 -2.9686107635498,150.872192382812 -2.96527767181396,150.855804443359 -2.9622220993042,150.838012695312 -2.95972204208374,150.831909179688 -2.96027803421021,150.773590087891 -2.98555564880371)),((152.640808105469 -3.23000001907349,152.636108398438 -3.2277774810791,152.605224609375 -3.20388889312744,152.577178955078 -3.17722225189209,152.538879394531 -3.1061110496521,152.537475585938 -3.10055589675903,152.537475585938 -3.09499979019165,152.539428710938 -3.09027767181396,152.553863525391 -3.07055568695068,152.55801391
 6016 -3.06777811050415,152.590240478516 -3.05194425582886,152.599700927734 -3.04805564880371,152.606079101562 -3.04722261428833,152.640258789062 -3.04305553436279,152.644989013672 -3.04527807235718,152.648590087891 -3.04861116409302,152.667755126953 -3.12944412231445,152.668853759766 -3.14861106872559,152.668853759766 -3.15527772903442,152.667755126953 -3.16083335876465,152.654693603516 -3.21638870239258,152.6533203125 -3.22166633605957,152.646362304688 -3.22861099243164,152.640808105469 -3.23000001907349)),((153.343292236328 -3.41666650772095,153.265258789062 -3.40722227096558,153.262481689453 -3.40444421768188,153.263885498047 -3.39888906478882,153.269989013672 -3.39277791976929,153.301635742188 -3.36944437026978,153.333587646484 -3.37138891220093,153.337188720703 -3.375,153.346069335938 -3.38666677474976,153.348022460938 -3.39138889312744,153.347473144531 -3.39750003814697,153.345245361328 -3.41194438934326,153.343292236328 -3.41666650772095)),((154.818572998047 -3.530277
 72903442,154.795257568359 -3.44138860702515,154.794708251953 -3.43249988555908,154.796081542969 -3.4283332824707,154.799407958984 -3.42500019073486,154.825531005859 -3.4713888168335,154.830261230469 -3.48027753829956,154.833862304688 -3.50416707992554,154.833038330078 -3.51027822494507,154.818572998047 -3.53027772903442)),((153.242462158203 -3.49944448471069,153.237182617188 -3.49805545806885,153.211090087891 -3.48861122131348,153.206909179688 -3.48583316802979,153.192474365234 -3.47277736663818,153.19384765625 -3.4686107635498,153.197204589844 -3.46527767181396,153.220520019531 -3.44888877868652,153.22412109375 -3.4466667175293,153.22802734375 -3.44555521011353,153.233581542969 -3.4466667175293,153.239959716797 -3.45444440841675,153.255554199219 -3.47972202301025,153.259704589844 -3.48916673660278,153.26025390625 -3.49527788162231,153.258331298828 -3.49888896942139,153.242462158203 -3.49944448471069)),((153.639434814453 -4.14083385467529,153.634429931641 -4.13861179351807,1
 53.588012695312 -4.10583305358887,153.585235595703 -4.10194396972656,153.584411621094 -4.09583377838135,153.585235595703 -4.08944416046143,153.587188720703 -4.0847225189209,153.602172851562 -4.05888843536377,153.629669189453 -4.0313892364502,153.633880615234 -4.0286111831665,153.653045654297 -4.02055549621582,153.658599853516 -4.01916694641113,153.662750244141 -4.02194499969482,153.664703369141 -4.02666664123535,153.671630859375 -4.08000087738037,153.672210693359 -4.08611106872559,153.671630859375 -4.10472202301025,153.670257568359 -4.10999965667725,153.650268554688 -4.1380558013916,153.645538330078 -4.14027786254883,153.639434814453 -4.14083385467529)),((145.057739257812 -4.13527774810791,145.050811767578 -4.13527774810791,145.041351318359 -4.13249969482422,145.037200927734 -4.13000011444092,145.031646728516 -4.12166595458984,145.027770996094 -4.11222171783447,145.0263671875 -4.10666656494141,145.022216796875 -4.07666683197021,145.0263671875 -4.06694507598877,145.0316467285
 16 -4.05888843536377,145.036651611328 -4.05666637420654,145.06884765625 -4.04500007629395,145.079132080078 -4.04777812957764,145.095520019531 -4.05888843536377,145.101623535156 -4.06638813018799,145.107177734375 -4.07527828216553,145.110504150391 -4.09222221374512,145.109954833984 -4.09833335876465,145.094696044922 -4.12444400787354,145.092193603516 -4.12833309173584,145.088012695312 -4.13138866424561,145.083312988281 -4.13333320617676,145.057739257812 -4.13527774810791)),((150.74609375 -6.13554954528809,150.729675292969 -6.14666748046875,150.724975585938 -6.14861106872559,150.707183837891 -6.15555572509766,150.668853759766 -6.16833305358887,150.663879394531 -6.16916656494141,150.661102294922 -6.16499996185303,150.659149169922 -6.15333366394043,150.657196044922 -6.14861106872559,150.652191162109 -6.14666748046875,150.63525390625 -6.14861106872559,150.509704589844 -6.23499965667725,150.484954833984 -6.25833415985107,150.480255126953 -6.26722240447998,150.473571777344 -6.27388
 954162598,150.468566894531 -6.2761116027832,150.406372070312 -6.29305553436279,150.400268554688 -6.29361152648926,150.222747802734 -6.28833293914795,150.211639404297 -6.2761116027832,150.188293457031 -6.25833415985107,150.184143066406 -6.25555610656738,150.180816650391 -6.25500011444092,150.170532226562 -6.25694465637207,150.080810546875 -6.28000068664551,150.038879394531 -6.29916667938232,150.018310546875 -6.32361125946045,150.016387939453 -6.30388832092285,150.014434814453 -6.29916667938232,150.010803222656 -6.29583358764648,149.98828125 -6.27722263336182,149.984130859375 -6.2747220993042,149.978576660156 -6.27333354949951,149.972473144531 -6.27388954162598,149.894989013672 -6.29249954223633,149.889709472656 -6.29249954223633,149.847198486328 -6.29249954223633,149.844421386719 -6.29249954223633,149.842193603516 -6.29249954223633,149.686645507812 -6.30527782440186,149.634704589844 -6.30805492401123,149.609405517578 -6.29249954223633,149.605224609375 -6.28972244262695,149.57
 4981689453 -6.26500034332275,149.571624755859 -6.26166725158691,149.555236816406 -6.22694492340088,149.539428710938 -6.19777774810791,149.510803222656 -6.15277767181396,149.489410400391 -6.12611103057861,149.482452392578 -6.11944389343262,149.467468261719 -6.10972213745117,149.444976806641 -6.09805583953857,149.341339111328 -6.06083297729492,149.335784912109 -6.05944442749023,149.311920166016 -6.05722236633301,149.289978027344 -6.06277751922607,149.163879394531 -6.11250019073486,149.138580322266 -6.14861106872559,149.131072998047 -6.15472221374512,149.119415283203 -6.15694427490234,149.069427490234 -6.16416645050049,149.063018798828 -6.16499996185303,149.056915283203 -6.16416645050049,149.052185058594 -6.16222190856934,149.049407958984 -6.15805530548096,149.048034667969 -6.15277767181396,149.048034667969 -6.14583396911621,149.050262451172 -6.14111137390137,149.054962158203 -6.13916683197021,149.061096191406 -6.13833332061768,149.067199707031 -6.14583396911621,149.07135009765
 6 -6.14861106872559,149.075531005859 -6.14583396911621,149.079681396484 -6.13638877868652,149.078857421875 -6.11944389343262,149.071899414062 -6.09277820587158,149.055541992188 -6.04444408416748,149.039978027344 -6.03694438934326,148.983032226562 -6.01972198486328,148.942474365234 -6.00833415985107,148.920654296875 -6.00002384185791,148.882995605469 -5.98166465759277,148.878814697266 -5.94748497009277,148.876068115234 -5.9436616897583,148.764434814453 -5.86499118804932,148.704650878906 -5.84858131408691,148.699554443359 -5.84745788574219,148.589721679688 -5.82837104797363,148.528045654297 -5.82837104797363,148.401672363281 -5.78336238861084,148.391967773438 -5.77940940856934,148.3876953125 -5.77660369873047,148.366607666016 -5.75592136383057,148.359771728516 -5.74921321868896,148.339324951172 -5.7143726348877,148.330780029297 -5.69515228271484,148.323089599609 -5.67537689208984,148.321655273438 -5.66980838775635,148.316467285156 -5.62802600860596,148.354675292969 -5.50166702
 270508,148.358001708984 -5.49277782440186,148.359954833984 -5.48805522918701,148.370239257812 -5.4777774810791,148.378570556641 -5.47249984741211,148.428588867188 -5.45111179351807,148.450531005859 -5.45527839660645,148.504699707031 -5.48333263397217,148.511657714844 -5.48999977111816,148.519714355469 -5.50250053405762,148.618286132812 -5.50500011444092,148.883605957031 -5.49694442749023,148.961639404297 -5.47361087799072,148.973297119141 -5.47166633605957,148.985778808594 -5.47305583953857,149.000823974609 -5.47833347320557,149.122192382812 -5.52416706085205,149.126892089844 -5.5261116027832,149.189147949219 -5.55833339691162,149.209686279297 -5.57194519042969,149.2138671875 -5.57472229003906,149.216064453125 -5.57944488525391,149.220764160156 -5.60611152648926,149.270812988281 -5.59444427490234,149.310516357422 -5.58611106872559,149.425537109375 -5.56722259521484,149.549133300781 -5.53861141204834,149.566925048828 -5.52888870239258,149.581909179688 -5.52333354949951,149.61
 1358642578 -5.51861095428467,149.668304443359 -5.51944446563721,149.680541992188 -5.55416679382324,149.680541992188 -5.561110496521,149.685516357422 -5.56305503845215,149.692199707031 -5.56305503845215,149.710784912109 -5.5625,149.875244140625 -5.5363883972168,149.880798339844 -5.53499984741211,149.887481689453 -5.53166675567627,149.916381835938 -5.51194477081299,149.928588867188 -5.50361156463623,149.956085205078 -5.47638893127441,149.964416503906 -5.46416664123535,149.981353759766 -5.4333324432373,149.984130859375 -5.42249965667725,149.983581542969 -5.41638851165771,149.981353759766 -5.41166687011719,149.97802734375 -5.40833377838135,149.973297119141 -5.4061107635498,149.954132080078 -5.40472221374512,149.950531005859 -5.40138912200928,149.923034667969 -5.36055564880371,149.917755126953 -5.35222244262695,149.918304443359 -5.34611129760742,149.928588867188 -5.31527709960938,149.934692382812 -5.30722236633301,150.002777099609 -5.16944408416748,150.015533447266 -5.05749988555
 908,150.019714355469 -5.04777812957764,150.029968261719 -5.03083324432373,150.034149169922 -5.02805614471436,150.0888671875 -5.00777816772461,150.095794677734 -5.00777816772461,150.121337890625 -5.00972270965576,150.126617431641 -5.01111125946045,150.154693603516 -5.02388954162598,150.181640625 -5.03888893127441,150.19384765625 -5.04722213745117,150.199401855469 -5.05527782440186,150.203582763672 -5.0649995803833,150.204956054688 -5.07055568695068,150.203582763672 -5.07583332061768,150.184143066406 -5.09833335876465,150.180816650391 -5.10194396972656,150.164428710938 -5.11277770996094,150.154693603516 -5.11694431304932,150.132720947266 -5.12222194671631,150.101348876953 -5.13194370269775,150.091644287109 -5.13583374023438,150.082733154297 -5.14138889312744,150.072479248047 -5.15166664123535,150.064422607422 -5.16388893127441,150.061645507812 -5.17472171783447,150.04248046875 -5.3086109161377,150.062194824219 -5.36388874053955,150.121337890625 -5.51250076293945,150.1232910156
 25 -5.51722240447998,150.143859863281 -5.5377779006958,150.164428710938 -5.55138874053955,150.178863525391 -5.55749988555908,150.184143066406 -5.55888843536377,150.282196044922 -5.57055568695068,150.291076660156 -5.57055568695068,150.296630859375 -5.569167137146,150.300811767578 -5.56638813018799,150.306915283203 -5.55888843536377,150.318023681641 -5.54194450378418,150.319976806641 -5.53722190856934,150.323303222656 -5.53361129760742,150.326904296875 -5.53027820587158,150.345245361328 -5.51472282409668,150.412475585938 -5.45861148834229,150.422760009766 -5.45527839660645,150.488555908203 -5.44694423675537,150.511108398438 -5.4505558013916,150.574127197266 -5.47638893127441,150.578308105469 -5.47916698455811,150.595520019531 -5.4961109161377,150.601623535156 -5.51722240447998,150.611083984375 -5.54194450378418,150.61328125 -5.54666709899902,150.616058349609 -5.55083274841309,150.624114990234 -5.55611038208008,150.644134521484 -5.55694389343262,150.677917480469 -5.551299095153
 81,150.693298339844 -5.54749965667725,150.698852539062 -5.54611110687256,150.914154052734 -5.4908332824707,150.924407958984 -5.48722171783447,150.979125976562 -5.44499969482422,151.003051757812 -5.42111110687256,151.011383056641 -5.4088888168335,151.015533447266 -5.39944458007812,151.018859863281 -5.38916683197021,151.023040771484 -5.37277698516846,151.023040771484 -5.3658332824707,151.018310546875 -5.34333324432373,151.018310546875 -5.33666706085205,151.018859863281 -5.33027839660645,151.0244140625 -5.28805541992188,151.028594970703 -5.27166652679443,151.038879394531 -5.24111080169678,151.046936035156 -5.22194480895996,151.066070556641 -5.18583297729492,151.071075439453 -5.17694473266602,151.084686279297 -5.1563892364502,151.096923828125 -5.14277839660645,151.26220703125 -4.98638820648193,151.266387939453 -4.98388862609863,151.357452392578 -4.94749927520752,151.441070556641 -4.93666648864746,151.513610839844 -4.93805503845215,151.604675292969 -4.96805572509766,151.608856201
 172 -4.97083377838135,151.614959716797 -4.97000026702881,151.641082763672 -4.95499992370605,151.648590087891 -4.94888877868652,151.654144287109 -4.94083309173584,151.676086425781 -4.90805530548096,151.684417724609 -4.88890266418457,151.687744140625 -4.86499977111816,151.682189941406 -4.81444454193115,151.658325195312 -4.61638832092285,151.630798339844 -4.50638961791992,151.62744140625 -4.49749946594238,151.598022460938 -4.43805503845215,151.592468261719 -4.43000030517578,151.588287353516 -4.42722225189209,151.547210693359 -4.35999965667725,151.501373291016 -4.23916625976562,151.5 -4.23388862609863,151.5 -4.22694492340088,151.503326416016 -4.21666622161865,151.508331298828 -4.20777797698975,151.511657714844 -4.20444488525391,151.536926269531 -4.18194389343262,151.783050537109 -4.20583343505859,151.841918945312 -4.22472190856934,151.852172851562 -4.22833347320557,151.857727050781 -4.23638820648193,151.859680175781 -4.24111080169678,151.861083984375 -4.24666690826416,151.863861
 083984 -4.27138900756836,151.869964599609 -4.28555583953857,151.878295898438 -4.29805564880371,151.884429931641 -4.30555534362793,151.895263671875 -4.3149995803833,151.904144287109 -4.32000064849854,151.9638671875 -4.33555603027344,151.969421386719 -4.33694458007812,151.974975585938 -4.33694458007812,151.984405517578 -4.33277797698975,151.991912841797 -4.32666683197021,152.138580322266 -4.20444488525391,152.141357421875 -4.20027828216553,152.145538330078 -4.19083309173584,152.150817871094 -4.17555522918701,152.153594970703 -4.16472244262695,152.153594970703 -4.15777778625488,152.156372070312 -4.15388870239258,152.161926269531 -4.14833354949951,152.166076660156 -4.14555549621582,152.171356201172 -4.14416694641113,152.177764892578 -4.14500045776367,152.185241699219 -4.14888954162598,152.214691162109 -4.16611099243164,152.235229492188 -4.2072229385376,152.239410400391 -4.21666622161865,152.2421875 -4.2344446182251,152.2421875 -4.24111080169678,152.240783691406 -4.24666690826416
 ,152.238006591797 -4.24805545806885,152.226898193359 -4.25083351135254,152.202453613281 -4.24666690826416,152.198303222656 -4.24388885498047,152.195526123047 -4.23999977111816,152.194122314453 -4.2344446182251,152.194122314453 -4.22749996185303,152.192749023438 -4.22222232818604,152.189971923828 -4.21805572509766,152.186645507812 -4.21472263336182,152.181640625 -4.21527767181396,152.176910400391 -4.21749973297119,152.172760009766 -4.22694492340088,152.16943359375 -4.24388885498047,152.170806884766 -4.28222274780273,152.171356201172 -4.28833293914795,152.172210693359 -4.29333305358887,152.174133300781 -4.29666709899902,152.1796875 -4.30472183227539,152.186645507812 -4.31166648864746,152.190521240234 -4.31444454193115,152.195526123047 -4.31638813018799,152.263885498047 -4.33500003814697,152.286651611328 -4.33972263336182,152.305236816406 -4.34166717529297,152.355804443359 -4.34305572509766,152.401641845703 -4.61083316802979,152.403045654297 -4.62305545806885,152.405242919922 -
 4.66888904571533,152.405822753906 -4.68888854980469,152.394989013672 -4.76111125946045,152.389434814453 -4.78305530548096,152.386108398438 -4.79333305358887,152.336090087891 -4.87527751922607,152.333312988281 -4.87916660308838,152.294128417969 -4.92916679382324,152.268035888672 -4.95777797698975,152.241333007812 -4.9844446182251,152.233306884766 -4.98999977111816,152.161102294922 -5.00694465637207,152.157196044922 -5.00694465637207,152.123565673828 -4.99944400787354,152.112457275391 -4.99666690826416,152.088562011719 -4.98638820648193,152.083038330078 -4.98499965667725,152.050262451172 -4.97972202301025,151.996612548828 -4.97277736663818,151.990509033203 -4.97222232818604,151.984954833984 -4.97361087799072,151.978302001953 -4.98027801513672,151.974975585938 -4.98388862609863,151.970794677734 -4.993332862854,151.968017578125 -5.0041675567627,151.966644287109 -5.02333354949951,151.964691162109 -5.10472202301025,151.969970703125 -5.14833354949951,151.97412109375 -5.157777786254
 88,151.979675292969 -5.16583347320557,151.993286132812 -5.17555522918701,152.069427490234 -5.23499965667725,152.07275390625 -5.23833274841309,152.118011474609 -5.29222202301025,152.124114990234 -5.29972171783447,152.129669189453 -5.30777740478516,152.144134521484 -5.34138870239258,152.145538330078 -5.34666728973389,152.147491455078 -5.36388874053955,152.144134521484 -5.37416648864746,152.131072998047 -5.40222263336182,152.123565673828 -5.41638851165771,152.096069335938 -5.4572229385376,151.972747802734 -5.53111171722412,151.968566894531 -5.53361129760742,151.841918945312 -5.59722232818604,151.825531005859 -5.60111141204834,151.818572998047 -5.60111141204834,151.808319091797 -5.5977783203125,151.779418945312 -5.58555603027344,151.771362304688 -5.58000087738037,151.759155273438 -5.55138874053955,151.752777099609 -5.54388904571533,151.748565673828 -5.54111099243164,151.705535888672 -5.53111171722412,151.699401855469 -5.53027820587158,151.491638183594 -5.52833366394043,151.47329
 7119141 -5.53027820587158,151.467742919922 -5.53166675567627,151.459411621094 -5.53583335876465,151.454132080078 -5.54111099243164,151.44384765625 -5.58555603027344,151.444427490234 -5.59166717529297,151.402770996094 -5.75137805938721,151.384704589844 -5.80720043182373,151.317779541016 -5.84993076324463,151.165649414062 -5.95807075500488,151.003051757812 -6.02250003814697,150.940795898438 -6.0286111831665,150.855804443359 -6.04083347320557,150.811920166016 -6.07638931274414,150.812744140625 -6.08944416046143,150.793304443359 -6.11805534362793,150.775543212891 -6.13916683197021,150.771636962891 -6.14166736602783,150.74609375 -6.13554954528809)),((154.153869628906 -4.44222164154053,154.128570556641 -4.3841667175293,154.126617431641 -4.37944412231445,154.128021240234 -4.37388896942139,154.132720947266 -4.37166595458984,154.140808105469 -4.37055492401123,154.150543212891 -4.37444400787354,154.152770996094 -4.37944412231445,154.1533203125 -4.3855562210083,154.155242919922 -4.4380
 5503845215,154.153869628906 -4.44222164154053)),((145.951354980469 -4.76444530487061,145.944427490234 -4.76444530487061,145.93359375 -4.76194477081299,145.918579101562 -4.75638961791992,145.898590087891 -4.74194431304932,145.891662597656 -4.73527717590332,145.875244140625 -4.69694423675537,145.873840332031 -4.69138813018799,145.872467041016 -4.67249965667725,145.873840332031 -4.66694450378418,145.892486572266 -4.6094446182251,145.8994140625 -4.59583377838135,145.904693603516 -4.58777809143066,145.914978027344 -4.57750034332275,145.966369628906 -4.53305530548096,145.970520019531 -4.53027820587158,145.975250244141 -4.52833366394043,145.981628417969 -4.52750015258789,146.011657714844 -4.5494441986084,146.026916503906 -4.56166648864746,146.053588867188 -4.5963888168335,146.055541992188 -4.60138893127441,146.054138183594 -4.66138935089111,146.04052734375 -4.70916652679443,146.037750244141 -4.71333408355713,146.027465820312 -4.72361087799072,146.019989013672 -4.72972202301025,145.
 994415283203 -4.74555492401123,145.961639404297 -4.76111125946045,145.951354980469 -4.76444530487061)),((159.513305664062 -4.58166694641113,159.511383056641 -4.57666683197021,159.515533447266 -4.53972244262695,159.518859863281 -4.5363883972168,159.522216796875 -4.55083274841309,159.523040771484 -4.56388854980469,159.519714355469 -4.57388973236084,159.516937255859 -4.57805633544922,159.513305664062 -4.58166694641113)),((149.552459716797 -4.72083377838135,149.546356201172 -4.72027778625488,149.475799560547 -4.71138954162598,149.470245361328 -4.71000003814697,149.465515136719 -4.70777797698975,149.461364746094 -4.70527839660645,149.457733154297 -4.70166683197021,149.455810546875 -4.69694423675537,149.454406738281 -4.68472194671631,149.455810546875 -4.67916679382324,149.468017578125 -4.66416645050049,149.506652832031 -4.64777851104736,149.512756347656 -4.64694499969482,149.518859863281 -4.64777851104736,149.529968261719 -4.65055561065674,149.540252685547 -4.65388870239258,149.54
 3579101562 -4.65722274780273,149.549133300781 -4.66555595397949,149.559967041016 -4.68194389343262,149.563293457031 -4.69222164154053,149.564147949219 -4.70527839660645,149.562744140625 -4.71055603027344,149.560516357422 -4.71527767181396,149.557189941406 -4.7188892364502,149.552459716797 -4.72083377838135)),((146.240509033203 -4.85805511474609,146.234405517578 -4.85750007629395,146.215789794922 -4.85138893127441,146.2119140625 -4.84861087799072,146.201629638672 -4.83833312988281,146.199401855469 -4.83361148834229,146.198028564453 -4.82805633544922,146.200256347656 -4.81638813018799,146.202178955078 -4.81166648864746,146.215789794922 -4.79111099243164,146.219970703125 -4.78833293914795,146.232177734375 -4.78833293914795,146.238555908203 -4.79055595397949,146.241333007812 -4.79333305358887,146.256927490234 -4.81166648864746,146.262481689453 -4.81972217559814,146.263885498047 -4.82527828216553,146.263885498047 -4.83083343505859,146.261932373047 -4.83555603027344,146.2508239746
 09 -4.85472202301025,146.246612548828 -4.85750007629395,146.240509033203 -4.85805511474609)),((149.152191162109 -4.92361068725586,149.133026123047 -4.91555595397949,149.128845214844 -4.9127779006958,149.122741699219 -4.90527820587158,149.118560791016 -4.89555549621582,149.118011474609 -4.88944435119629,149.119415283203 -4.8841667175293,149.122192382812 -4.88138866424561,149.156921386719 -4.86694431304932,149.161926269531 -4.86638832092285,149.165802001953 -4.86777782440186,149.175537109375 -4.87805557250977,149.178314208984 -4.88194370269775,149.181640625 -4.89222240447998,149.178863525391 -4.89638900756836,149.156921386719 -4.92305564880371,149.152191162109 -4.92361068725586)),((154.63720703125 -5.45861148834229,154.618011474609 -5.43138885498047,154.5869140625 -5.34472274780273,154.565795898438 -5.27666664123535,154.5302734375 -5.13388919830322,154.532196044922 -5.12222194671631,154.541076660156 -5.10388851165771,154.546630859375 -5.09555530548096,154.558319091797 -5.08000
 087738037,154.598846435547 -5.03083324432373,154.605529785156 -5.02388954162598,154.620513916016 -5.01861095428467,154.63916015625 -5.01638889312744,154.646087646484 -5.01638889312744,154.6513671875 -5.01777839660645,154.658874511719 -5.02388954162598,154.665802001953 -5.03083324432373,154.671356201172 -5.03888893127441,154.726898193359 -5.19722175598145,154.728302001953 -5.20277786254883,154.728302001953 -5.21638870239258,154.69384765625 -5.41833305358887,154.692474365234 -5.42388916015625,154.687194824219 -5.43194389343262,154.675537109375 -5.44083309173584,154.63720703125 -5.45861148834229)),((147.135528564453 -5.45111179351807,147.121887207031 -5.44444370269775,147.009979248047 -5.35499954223633,147.008026123047 -5.3502779006958,147.002471923828 -5.30388832092285,147.008026123047 -5.25888919830322,147.009979248047 -5.24722194671631,147.013610839844 -5.23833274841309,147.017761230469 -5.23555564880371,147.109405517578 -5.19333267211914,147.121063232422 -5.19111061096191,1
 47.128570556641 -5.19194412231445,147.134979248047 -5.19527721405029,147.191070556641 -5.248610496521,147.211639404297 -5.26916694641113,147.228851318359 -5.36388874053955,147.229949951172 -5.42111110687256,147.224670410156 -5.42944431304932,147.220520019531 -5.43194389343262,147.158874511719 -5.44833278656006,147.1533203125 -5.44972133636475,147.135528564453 -5.45111179351807)),((147.596618652344 -5.36305522918701,147.591918945312 -5.36111068725586,147.567199707031 -5.33916664123535,147.563873291016 -5.33583354949951,147.561645507812 -5.33111190795898,147.560516357422 -5.31888961791992,147.561645507812 -5.31333351135254,147.563873291016 -5.3086109161377,147.57080078125 -5.30166625976562,147.583038330078 -5.29361152648926,147.591918945312 -5.2902774810791,147.602172851562 -5.28805541992188,147.609130859375 -5.28805541992188,147.620788574219 -5.2902774810791,147.625518798828 -5.29222202301025,147.628845214844 -5.29555511474609,147.640533447266 -5.31666660308838,147.6427612304
 69 -5.3216667175293,147.643310546875 -5.32777786254883,147.642761230469 -5.33388900756836,147.640533447266 -5.3386116027832,147.626892089844 -5.35222244262695,147.602172851562 -5.3619441986084,147.596618652344 -5.36305522918701)),((148.114685058594 -5.4688892364502,148.087463378906 -5.45527839660645,148.079132080078 -5.44972133636475,148.077178955078 -5.44499969482422,148.073028564453 -5.43000030517578,148.071624755859 -5.4244441986084,148.072204589844 -5.41833305358887,148.084686279297 -5.38972282409668,148.090789794922 -5.38222217559814,148.099700927734 -5.3774995803833,148.117462158203 -5.3841667175293,148.122192382812 -5.38638877868652,148.136657714844 -5.39944458007812,148.139434814453 -5.40333366394043,148.143585205078 -5.41305541992188,148.144989013672 -5.41833305358887,148.145538330078 -5.43833255767822,148.143585205078 -5.44972133636475,148.138031005859 -5.45805549621582,148.133880615234 -5.46083354949951,148.125793457031 -5.4661111831665,148.120788574219 -5.4683332
 4432373,148.114685058594 -5.4688892364502)),((155.404083251953 -6,155.41552734375 -6.07638931274414,155.418853759766 -6.08666706085205,155.428588867188 -6.11111068725586,155.430541992188 -6.1158332824707,155.432739257812 -6.12083339691162,155.477172851562 -6.16916656494141,155.490783691406 -6.18277740478516,155.499114990234 -6.18805503845215,155.562744140625 -6.21749973297119,155.577178955078 -6.22361087799072,155.582733154297 -6.22500038146973,155.5888671875 -6.22416687011719,155.614959716797 -6.22000026702881,155.767761230469 -6.35583305358887,155.772491455078 -6.35777759552002,155.795257568359 -6.36250019073486,155.809692382812 -6.36861038208008,155.813598632812 -6.37138843536377,155.832733154297 -6.39861106872559,155.909698486328 -6.51222229003906,155.917755126953 -6.52444458007812,155.921905517578 -6.53416633605957,155.965789794922 -6.70555591583252,155.967193603516 -6.71111106872559,155.967742919922 -6.71722221374512,155.966644287109 -6.72277736663818,155.948028564453
 -6.77583312988281,155.940521240234 -6.78861141204834,155.918579101562 -6.80777740478516,155.913024902344 -6.80916595458984,155.909698486328 -6.80555534362793,155.908874511719 -6.7994441986084,155.890533447266 -6.77972221374512,155.860778808594 -6.77500057220459,155.854675292969 -6.77444458007812,155.848571777344 -6.77500057220459,155.823852539062 -6.77777767181396,155.816375732422 -6.78055572509766,155.775268554688 -6.81444454193115,155.748565673828 -6.84249973297119,155.742462158203 -6.84999942779541,155.719696044922 -6.875,155.713012695312 -6.88194370269775,155.707458496094 -6.88333320617676,155.69384765625 -6.88333320617676,155.623840332031 -6.868332862854,155.558868408203 -6.85249996185303,155.4921875 -6.83027839660645,155.47802734375 -6.82416725158691,155.444976806641 -6.80916595458984,155.342742919922 -6.74361133575439,155.3388671875 -6.74111080169678,155.335235595703 -6.73750019073486,155.239959716797 -6.62249946594238,155.192749023438 -6.56055545806885,155.2016296386
 72 -6.53472232818604,155.207183837891 -6.53472232818604,155.2099609375 -6.53055572509766,155.216064453125 -6.51638889312744,155.224975585938 -6.47749996185303,155.232452392578 -6.44416618347168,155.233306884766 -6.43805503845215,155.233306884766 -6.4244441986084,155.230529785156 -6.36305522918701,155.226348876953 -6.34694480895996,155.218841552734 -6.32916736602783,155.214141845703 -6.32027816772461,155.204406738281 -6.3086109161377,155.190795898438 -6.29500007629395,155.187194824219 -6.29166698455811,155.174987792969 -6.28333282470703,155.127746582031 -6.2761116027832,155.101623535156 -6.27722263336182,155.063293457031 -6.25694561004639,154.994110107422 -6.21666622161865,154.981628417969 -6.20861148834229,154.972198486328 -6.19777774810791,154.969970703125 -6.19277763366699,154.888580322266 -6.07916736602783,154.880249023438 -6.07361125946045,154.823577880859 -6.02805614471436,154.755645751953 -5.95617389678955,154.746643066406 -5.94450378417969,154.744384765625 -5.93978023
 529053,154.700469970703 -5.78020095825195,154.698577880859 -5.76851844787598,154.699432373047 -5.7623987197876,154.71826171875 -5.6700611114502,154.753601074219 -5.51805591583252,154.79052734375 -5.47916698455811,154.794128417969 -5.48250007629395,154.882446289062 -5.54333305358887,154.920806884766 -5.54999923706055,154.961090087891 -5.54666709899902,154.967468261719 -5.54611110687256,155.073577880859 -5.56166648864746,155.162353515625 -5.73234081268311,155.216064453125 -5.86872386932373,155.268798828125 -5.88423919677734,155.277679443359 -5.88895511627197,155.365020751953 -5.95777797698975,155.371643066406 -5.96472263336182,155.400543212891 -5.99583339691162,155.404083251953 -6)),((147.990478515625 -5.85603713989258,147.983520507812 -5.82075119018555,147.982116699219 -5.81519317626953,147.974609375 -5.79546737670898,147.972381591797 -5.79074478149414,147.968475341797 -5.78796863555908,147.945220947266 -5.77992534637451,147.93359375 -5.7777099609375,147.927490234375 -5.77854
 824066162,147.922790527344 -5.78049659729004,147.865112304688 -5.74775314331055,147.802154541016 -5.67277145385742,147.793273925781 -5.66138458251953,147.769958496094 -5.62221908569336,147.766052246094 -5.61277484893799,147.765228271484 -5.60666275024414,147.761108398438 -5.52833366394043,147.761932373047 -5.5222225189209,147.7802734375 -5.49416637420654,147.783874511719 -5.4908332824707,147.814697265625 -5.48472213745117,147.841918945312 -5.48999977111816,147.852172851562 -5.49361133575439,148.008605957031 -5.57611179351807,148.020812988281 -5.58416652679443,148.040802001953 -5.59861087799072,148.044128417969 -5.60194396972656,148.065307617188 -5.62758445739746,148.074279785156 -5.64482402801514,148.078460693359 -5.65427875518799,148.080444335938 -5.66595458984375,148.078552246094 -5.69124603271484,148.076629638672 -5.70347595214844,148.072540283203 -5.72654151916504,148.067840576172 -5.74905109405518,148.061492919922 -5.77711772918701,148.057586669922 -5.78656482696533,148
 .017150878906 -5.84463882446289,148.000762939453 -5.85269927978516,147.990478515625 -5.85603713989258)),((149.048034667969 -6.09555530548096,149.043304443359 -6.09333324432373,149.043853759766 -6.0886116027832,149.045257568359 -6.0872220993042,149.054138183594 -6.08388900756836,149.058319091797 -6.08666706085205,149.057739257812 -6.09138870239258,149.053588867188 -6.09416675567627,149.048034667969 -6.09555530548096)),((143.994415283203 -7.82583332061768,143.984680175781 -7.8230562210083,143.943572998047 -7.80277729034424,143.934692382812 -7.79805564880371,143.923583984375 -7.78861141204834,143.91748046875 -7.78111171722412,143.914703369141 -7.77694511413574,143.877746582031 -7.7186107635498,143.875793457031 -7.71388912200928,143.877166748047 -7.7097225189209,143.88134765625 -7.70694446563721,143.886657714844 -7.70833396911621,143.959411621094 -7.74222183227539,143.966918945312 -7.74833297729492,143.979125976562 -7.76333427429199,144.000549316406 -7.78999996185303,144.0080261
 23047 -7.80277729034424,144.009429931641 -7.80833339691162,144.008605957031 -7.81416606903076,144.006652832031 -7.819167137146,143.999694824219 -7.82444477081299,143.994415283203 -7.82583332061768)),((145.193572998047 -7.86722183227539,145.186645507812 -7.86722183227539,145.182464599609 -7.86444473266602,145.180541992188 -7.86111068725586,145.177764892578 -7.83666706085205,145.178314208984 -7.83055591583252,145.182464599609 -7.82777786254883,145.185241699219 -7.83055591583252,145.191345214844 -7.84083366394043,145.197479248047 -7.85499954223633,145.198852539062 -7.86055564880371,145.197479248047 -7.86444473266602,145.193572998047 -7.86722183227539)),((143.727752685547 -8.10222244262695,143.697479248047 -8.08444404602051,143.683319091797 -8.07833290100098,143.661376953125 -8.07277679443359,143.618011474609 -8.07222175598145,143.599700927734 -8.07416725158691,143.588562011719 -8.0716667175293,143.582458496094 -8.06416702270508,143.569427490234 -8.04305648803711,143.56607055664
 1 -8.03277778625488,143.565246582031 -8.02000045776367,143.568023681641 -8.01583480834961,143.574127197266 -8.01388931274414,143.629669189453 -8.00638961791992,143.635803222656 -8.00583457946777,143.642761230469 -8.00583457946777,143.651092529297 -8.00833511352539,143.66943359375 -8.0172233581543,143.682464599609 -8.02472305297852,143.697479248047 -8.03694534301758,143.707733154297 -8.04722213745117,143.731079101562 -8.0716667175293,143.737182617188 -8.07888793945312,143.739959716797 -8.08305549621582,143.741333007812 -8.0886116027832,143.739410400391 -8.09333229064941,143.733306884766 -8.10083198547363,143.727752685547 -8.10222244262695)),((143.66552734375 -8.17611122131348,143.654968261719 -8.17250061035156,143.625518798828 -8.15416717529297,143.621612548828 -8.15166664123535,143.618835449219 -8.14750099182129,143.607727050781 -8.13055419921875,143.604949951172 -8.11972045898438,143.604400634766 -8.11361122131348,143.604949951172 -8.10888862609863,143.609130859375 -8.10610
 961914062,143.636657714844 -8.09249877929688,143.642211914062 -8.09055519104004,143.654968261719 -8.0897216796875,143.679138183594 -8.09333229064941,143.688568115234 -8.09722137451172,143.700256347656 -8.10610961914062,143.707183837891 -8.11277770996094,143.710510253906 -8.11638832092285,143.716064453125 -8.12444305419922,143.718841552734 -8.13527870178223,143.719421386719 -8.15500068664551,143.7119140625 -8.16111183166504,143.702453613281 -8.1652774810791,143.683319091797 -8.1733341217041,143.677764892578 -8.17472267150879,143.66552734375 -8.17611122131348)),((143.685791015625 -8.24722099304199,143.659973144531 -8.241943359375,143.654418945312 -8.24055480957031,143.650268554688 -8.23777770996094,143.648315429688 -8.23305511474609,143.648864746094 -8.22694396972656,143.651641845703 -8.19972229003906,143.666656494141 -8.19305610656738,143.726898193359 -8.17388916015625,143.733306884766 -8.17472267150879,143.737182617188 -8.17722320556641,143.755828857422 -8.20527839660645,143
 .756378173828 -8.20861053466797,143.755249023438 -8.21388816833496,143.752471923828 -8.21805572509766,143.7421875 -8.22833251953125,143.734680175781 -8.23444366455078,143.718841552734 -8.23916625976562,143.697479248047 -8.24527740478516,143.685791015625 -8.24722099304199)),((143.687194824219 -8.43972206115723,143.680541992188 -8.43972206115723,143.670257568359 -8.43638801574707,143.651641845703 -8.42749977111816,143.630523681641 -8.40722274780273,143.610504150391 -8.38611221313477,143.584411621094 -8.3577766418457,143.607177734375 -8.33277702331543,143.612731933594 -8.33388900756836,143.653045654297 -8.34222221374512,143.658599853516 -8.3436107635498,143.66552734375 -8.34749984741211,143.672210693359 -8.35444450378418,143.677764892578 -8.36249923706055,143.692199707031 -8.39583396911621,143.694976806641 -8.40666770935059,143.698303222656 -8.42361068725586,143.698303222656 -8.43027877807617,143.696929931641 -8.43555641174316,143.692749023438 -8.43833351135254,143.687194824219
  -8.43972206115723)),((143.57275390625 -8.49388885498047,143.559143066406 -8.49388885498047,143.509155273438 -8.48250007629395,143.498016357422 -8.47972106933594,143.493286132812 -8.4777774810791,143.354949951172 -8.41805648803711,143.318572998047 -8.39305686950684,143.315795898438 -8.38888931274414,143.314422607422 -8.38361167907715,143.314422607422 -8.37666511535645,143.319427490234 -8.36916542053223,143.326904296875 -8.3630542755127,143.331634521484 -8.36111068725586,143.339141845703 -8.35833358764648,143.342742919922 -8.3577766418457,143.356353759766 -8.3577766418457,143.494689941406 -8.3630542755127,143.573577880859 -8.37194442749023,143.578308105469 -8.37388801574707,143.581085205078 -8.37805557250977,143.616058349609 -8.46277809143066,143.616058349609 -8.4688892364502,143.613861083984 -8.47360992431641,143.610504150391 -8.47694396972656,143.583862304688 -8.49138832092285,143.578857421875 -8.49333190917969,143.57275390625 -8.49388885498047)),((143.632446289062 -8.73444
 366455078,143.60107421875 -8.6924991607666,143.585784912109 -8.67972183227539,143.487731933594 -8.62888717651367,143.3671875 -8.54472351074219,143.278869628906 -8.51027870178223,143.269989013672 -8.50555610656738,143.252777099609 -8.49527740478516,143.240509033203 -8.48722076416016,143.182189941406 -8.42972183227539,143.180816650391 -8.42416763305664,143.18359375 -8.42000007629395,143.211639404297 -8.4152774810791,143.217742919922 -8.41611099243164,143.227447509766 -8.42611122131348,143.233032226562 -8.43444442749023,143.251373291016 -8.45666694641113,143.261657714844 -8.46694374084473,143.274688720703 -8.47444343566895,143.324676513672 -8.48583221435547,143.371337890625 -8.49388885498047,143.422760009766 -8.51083374023438,143.467193603516 -8.52777862548828,143.644134521484 -8.66472244262695,143.647491455078 -8.66805648803711,143.651641845703 -8.67777824401855,143.653045654297 -8.68305587768555,143.653594970703 -8.68916702270508,143.653045654297 -8.7005558013916,143.64135742
 1875 -8.72972106933594,143.638031005859 -8.73305511474609,143.632446289062 -8.73444366455078)),((151.144439697266 -8.8305549621582,151.094970703125 -8.7711124420166,151.10107421875 -8.63888931274414,151.05859375 -8.55166625976562,151.052459716797 -8.55222320556641,151.034698486328 -8.55222320556641,151.029144287109 -8.55083274841309,151.003051757812 -8.54277801513672,150.999694824219 -8.53944396972656,150.997741699219 -8.53472328186035,150.996917724609 -8.52861213684082,150.997741699219 -8.52250099182129,151.024993896484 -8.46694374084473,151.033325195312 -8.45472145080566,151.054412841797 -8.43499946594238,151.062744140625 -8.42972183227539,151.076354980469 -8.42611122131348,151.118286132812 -8.42000007629395,151.124969482422 -8.42000007629395,151.124969482422 -8.42555618286133,151.123840332031 -8.62472152709961,151.103302001953 -8.72916603088379,151.102447509766 -8.741943359375,151.103851318359 -8.7541675567627,151.107177734375 -8.76444625854492,151.144439697266 -8.8305549
 621582)),((152.835510253906 -9.23555564880371,152.829956054688 -9.22333335876465,152.679962158203 -9.09055519104004,152.6533203125 -9.06972122192383,152.649139404297 -9.06694412231445,152.573028564453 -9.02027893066406,152.563598632812 -9.01611137390137,152.556640625 -9.01611137390137,152.540252685547 -9.02027893066406,152.499694824219 -9.02500152587891,152.497741699219 -9.02166748046875,152.5244140625 -8.99305534362793,152.527770996094 -8.98972129821777,152.532470703125 -8.98777770996094,152.619689941406 -8.96138954162598,152.625793457031 -8.96055603027344,152.647216796875 -8.96138954162598,152.8046875 -8.96944427490234,152.810241699219 -8.97083282470703,152.814971923828 -8.97277641296387,152.93359375 -9.04388999938965,152.937744140625 -9.04666709899902,152.952758789062 -9.05888938903809,153.017761230469 -9.11777687072754,153.020538330078 -9.12166595458984,153.019989013672 -9.12638854980469,153.002777099609 -9.16500091552734,152.997192382812 -9.17305564880371,152.9930114746
 09 -9.17583274841309,152.98828125 -9.17777824401855,152.982177734375 -9.17722320556641,152.835510253906 -9.23555564880371)),((150.334411621094 -9.52666664123535,150.310241699219 -9.5261116027832,150.193023681641 -9.45388793945312,150.180816650391 -9.44555473327637,150.173858642578 -9.43888854980469,150.110778808594 -9.37277603149414,150.108306884766 -9.36861038208008,150.103302001953 -9.33694458007812,150.102752685547 -9.33083343505859,150.104125976562 -9.31861114501953,150.106903076172 -9.30777740478516,150.123291015625 -9.2630558013916,150.126068115234 -9.26027870178223,150.143859863281 -9.24555397033691,150.189147949219 -9.21111106872559,150.198028564453 -9.20777702331543,150.206909179688 -9.2055549621582,150.2138671875 -9.2055549621582,150.232177734375 -9.20777702331543,150.326904296875 -9.26916694641113,150.330810546875 -9.27194595336914,150.333038330078 -9.27666664123535,150.376892089844 -9.38333320617676,150.37744140625 -9.38944435119629,150.363006591797 -9.4874992370
 6055,150.344696044922 -9.51666641235352,150.339141845703 -9.52472305297852,150.334411621094 -9.52666664123535)),((150.846923828125 -9.71805572509766,150.844116210938 -9.68555641174316,150.801635742188 -9.65861129760742,150.763305664062 -9.66250038146973,150.691345214844 -9.66333389282227,150.661102294922 -9.66333389282227,150.654968261719 -9.66250038146973,150.622741699219 -9.65388870239258,150.514434814453 -9.62333297729492,150.490509033203 -9.58361053466797,150.427459716797 -9.44083404541016,150.423309326172 -9.43138885498047,150.419982910156 -9.41472244262695,150.419982910156 -9.4011116027832,150.421905517578 -9.38944435119629,150.426086425781 -9.37666511535645,150.435791015625 -9.35916519165039,150.442474365234 -9.35499954223633,150.473571777344 -9.33888816833496,150.478851318359 -9.33749961853027,150.481628417969 -9.33694458007812,150.487731933594 -9.33749961853027,150.498840332031 -9.34027671813965,150.505554199219 -9.34222221374512,150.5302734375 -9.35166549682617,150
 .571350097656 -9.37055397033691,150.598022460938 -9.38500022888184,150.618011474609 -9.39777946472168,150.624969482422 -9.40444564819336,150.63525390625 -9.42194557189941,150.639434814453 -9.42472267150879,150.666656494141 -9.43833351135254,150.676910400391 -9.4416675567627,150.683044433594 -9.44083404541016,150.731903076172 -9.42805671691895,150.7421875 -9.42472267150879,150.746063232422 -9.42138862609863,150.748291015625 -9.41805648803711,150.754974365234 -9.40444564819336,150.760528564453 -9.40444564819336,150.765258789062 -9.4063892364502,150.777770996094 -9.41472244262695,150.804412841797 -9.43277740478516,150.828308105469 -9.45638847351074,150.885803222656 -9.52083396911621,150.888031005859 -9.52555656433105,150.931915283203 -9.64166831970215,150.932464599609 -9.64777946472168,150.930541992188 -9.65916633605957,150.921630859375 -9.67083358764648,150.906646728516 -9.68277740478516,150.901092529297 -9.68138885498047,150.896362304688 -9.67416763305664,150.893585205078 -9.
 67194557189941,150.888580322266 -9.67138862609863,150.876892089844 -9.67749977111816,150.873565673828 -9.68083381652832,150.846923828125 -9.71805572509766)),((151.229125976562 -10.2011108398438,151.19775390625 -10.1727771759033,151.190246582031 -10.1669454574585,151.148315429688 -10.1472234725952,151.143585205078 -10.1452789306641,151.086639404297 -10.1269435882568,151.075805664062 -10.1244430541992,151.025817871094 -10.1141662597656,151.001647949219 -10.1108322143555,150.994964599609 -10.1108322143555,150.983306884766 -10.1127777099609,150.970245361328 -10.1122207641602,150.958587646484 -10.1102771759033,150.94970703125 -10.1055545806885,150.91552734375 -10.0041675567627,150.877746582031 -9.92666625976562,150.826904296875 -9.83888816833496,150.762481689453 -9.80500030517578,150.758605957031 -9.80249977111816,150.750274658203 -9.74833297729492,150.748840332031 -9.73083305358887,150.757202148438 -9.71194458007812,150.759979248047 -9.70777702331543,150.763885498047 -9.70499992
 370605,150.769439697266 -9.70666694641113,150.788024902344 -9.71944427490234,150.803039550781 -9.73138809204102,150.821624755859 -9.74694442749023,150.900268554688 -9.81916618347168,150.931915283203 -9.8488883972168,150.938873291016 -9.85583305358887,150.962738037109 -9.89361190795898,151.030548095703 -9.98527717590332,151.039428710938 -9.99694442749023,151.059967041016 -10.0169448852539,151.073028564453 -10.0244445800781,151.111358642578 -10.0447244644165,151.116058349609 -10.046667098999,151.122467041016 -10.0475006103516,151.136657714844 -10.041389465332,151.147216796875 -10.0325012207031,151.149139404297 -10.0277786254883,151.149719238281 -10.0219459533691,151.147766113281 -10.0169448852539,151.143585205078 -10.0088901519775,151.140808105469 -10.0050010681152,151.136657714844 -10.0022239685059,151.134704589844 -9.99749946594238,151.134704589844 -9.9908332824707,151.138031005859 -9.98749923706055,151.184143066406 -9.94472312927246,151.192199707031 -9.93944358825684,151.20
 0531005859 -9.93666648864746,151.26416015625 -9.91972160339355,151.281372070312 -9.9233341217041,151.284149169922 -9.92722320556641,151.298583984375 -9.95083236694336,151.299133300781 -9.96249961853027,151.296356201172 -9.97305488586426,151.271087646484 -10.0616655349731,151.252471923828 -10.0974998474121,151.246337890625 -10.1047210693359,151.243560791016 -10.1088886260986,151.234130859375 -10.1330547332764,151.221618652344 -10.1708335876465,151.221618652344 -10.1816673278809,151.222473144531 -10.1877784729004,151.223846435547 -10.1930561065674,151.229125976562 -10.2011108398438)),((150.880523681641 -10.6527786254883,150.856353759766 -10.6494445800781,150.794128417969 -10.6394443511963,150.785247802734 -10.6347236633301,150.769439697266 -10.6111106872559,150.767486572266 -10.6075000762939,150.788024902344 -10.5463886260986,150.790802001953 -10.5422229766846,150.794708251953 -10.539722442627,150.798858642578 -10.5383338928223,150.868835449219 -10.5383338928223,150.8749694824
 22 -10.5388889312744,150.892211914062 -10.547779083252,150.900268554688 -10.5530548095703,150.904418945312 -10.5625,150.894989013672 -10.6466665267944,150.892211914062 -10.6508331298828,150.880523681641 -10.6527786254883)),((150.927185058594 -10.6838893890381,150.923034667969 -10.6825008392334,150.920257568359 -10.6783332824707,150.911926269531 -10.65944480896,150.909973144531 -10.6547222137451,150.909149169922 -10.6419448852539,150.909973144531 -10.6358337402344,150.91943359375 -10.6130542755127,150.922210693359 -10.6088886260986,150.9296875 -10.6030540466309,150.934692382812 -10.6008319854736,150.94970703125 -10.59694480896,151.016082763672 -10.5908336639404,151.064147949219 -10.5922222137451,151.066925048828 -10.5947227478027,151.06884765625 -10.5980548858643,151.069702148438 -10.6111106872559,151.063293457031 -10.6438903808594,151.049133300781 -10.6702785491943,151.042205810547 -10.676944732666,151.036651611328 -10.6783332824707,151.031372070312 -10.676944732666,151.0099
 79248047 -10.6683330535889,151.008026123047 -10.6636123657227,151.003875732422 -10.6472234725952,151.001647949219 -10.6427783966064,150.994110107422 -10.6366672515869,150.988861083984 -10.6352787017822,150.941345214844 -10.6347236633301,150.936096191406 -10.6347236633301,150.929138183594 -10.6547222137451,150.927185058594 -10.6838893890381)),((152.744415283203 -10.7166652679443,152.702453613281 -10.7066669464111,152.686920166016 -10.7019443511963,152.573852539062 -10.6569442749023,152.564971923828 -10.6522235870361,152.544982910156 -10.6380558013916,152.541656494141 -10.6338901519775,152.540802001953 -10.6305541992188,152.542205810547 -10.6277770996094,152.555236816406 -10.6230554580688,152.562194824219 -10.6230554580688,152.573852539062 -10.6252765655518,152.614959716797 -10.6386127471924,152.690246582031 -10.6627788543701,152.693023681641 -10.6627788543701,152.759429931641 -10.6372222900391,152.784973144531 -10.6211109161377,152.790252685547 -10.6197204589844,152.814971923
 828 -10.6291656494141,152.870513916016 -10.6580562591553,152.873291015625 -10.6622219085693,152.873840332031 -10.6683330535889,152.873291015625 -10.6730556488037,152.870513916016 -10.676944732666,152.863586425781 -10.6825008392334,152.844970703125 -10.6952781677246,152.814971923828 -10.6966667175293,152.744415283203 -10.7166652679443)),((153.210510253906 -11.2858333587646,153.181640625 -11.2522239685059,153.143859863281 -11.2247219085693,153.13916015625 -11.2227764129639,153.120513916016 -11.2166652679443,153.114959716797 -11.2152767181396,153.106079101562 -11.2147216796875,153.093292236328 -11.2019443511963,153.091064453125 -11.1972217559814,153.093841552734 -11.1930561065674,153.102172851562 -11.1888885498047,153.112457275391 -11.1844444274902,153.123840332031 -11.1849994659424,153.12939453125 -11.1863880157471,153.198028564453 -11.2172222137451,153.2138671875 -11.2247219085693,153.222747802734 -11.2294454574585,153.251373291016 -11.2469444274902,153.250579833984 -11.25,15
 3.25 -11.2522239685059,153.241058349609 -11.2688903808594,153.210510253906 -11.2858333587646)),((154.112182617188 -11.4397220611572,154.106628417969 -11.4397220611572,154.062744140625 -11.4330558776855,154.058013916016 -11.4308338165283,154.006652832031 -11.3872222900391,154.003326416016 -11.3838901519775,154.021087646484 -11.3488883972168,154.089691162109 -11.3152770996094,154.153869628906 -11.3141670227051,154.225250244141 -11.3194446563721,154.268310546875 -11.338888168335,154.276641845703 -11.344165802002,154.286376953125 -11.3605556488037,154.288299560547 -11.3649997711182,154.297760009766 -11.3919448852539,154.289703369141 -11.4108333587646,154.285522460938 -11.4136123657227,154.266387939453 -11.421667098999,154.263031005859 -11.4180555343628,154.26025390625 -11.4075012207031,154.256103515625 -11.4047222137451,154.250549316406 -11.4033336639404,154.190246582031 -11.3994445800781,154.137481689453 -11.3986110687256,154.134704589844 -11.4027786254883,154.112182617188 -11.
 4397220611572)),((153.566070556641 -11.6424999237061,153.522216796875 -11.602222442627,153.479125976562 -11.5733337402344,153.421356201172 -11.5686111450195,153.376068115234 -11.5672225952148,153.3671875 -11.557222366333,153.364410400391 -11.5530548095703,153.363861083984 -11.5472221374512,153.376068115234 -11.5269451141357,153.382446289062 -11.5197219848633,153.38720703125 -11.5108337402344,153.388580322266 -11.5055561065674,153.387756347656 -11.5008344650269,153.384429931641 -11.4974994659424,153.325531005859 -11.4752769470215,153.276916503906 -11.4624996185303,153.271911621094 -11.4605560302734,153.268585205078 -11.4572219848633,153.190521240234 -11.3730554580688,153.188293457031 -11.3683319091797,153.187194824219 -11.3536109924316,153.187194824219 -11.3497219085693,153.198028564453 -11.3241672515869,153.200805664062 -11.3199996948242,153.220520019531 -11.3274993896484,153.291931152344 -11.3569431304932,153.398040771484 -11.4047222137451,153.413879394531 -11.4161109924316
 ,153.426910400391 -11.4302787780762,153.437744140625 -11.4397220611572,153.507751464844 -11.4724998474121,153.559143066406 -11.491943359375,153.570251464844 -11.494722366333,153.576354980469 -11.4955539703369,153.645538330078 -11.5150012969971,153.686645507812 -11.5269451141357,153.751098632812 -11.5644445419312,153.754425048828 -11.5680561065674,153.7763671875 -11.5974998474121,153.777770996094 -11.6027765274048,153.7763671875 -11.6080551147461,153.7744140625 -11.6130542755127,153.770812988281 -11.6163883209229,153.676361083984 -11.6283321380615,153.670257568359 -11.6277770996094,153.605804443359 -11.6174983978271,153.598846435547 -11.6174983978271,153.582458496094 -11.6283321380615,153.566070556641 -11.6424999237061)))
+  </a>
+<test>
+  <op name='buffer' arg1='A' arg2='0.0' arg3='1'>
+ MULTIPOLYGON(((144.520538330078 -1.12083339691162,144.516387939453 -1.12083339691162,144.514434814453 -1.11611104011536,144.514984130859 -1.10305547714233,144.517211914062 -1.09833335876465,144.521362304688 -1.09972214698792,144.522491455078 -1.10527777671814,144.523315429688 -1.11138892173767,144.522491455078 -1.11611104011536,144.520538330078 -1.12083339691162)),((149.731903076172 -1.60333347320557,149.715515136719 -1.57861113548279,149.7099609375 -1.57027792930603,149.703308105469 -1.56361126899719,149.699127197266 -1.56083345413208,149.681915283203 -1.55722236633301,149.680541992188 -1.56277775764465,149.681915283203 -1.57527780532837,149.681365966797 -1.5813889503479,149.678588867188 -1.58555555343628,149.673034667969 -1.58694458007812,149.663299560547 -1.58277773857117,149.659423828125 -1.58000016212463,149.558013916016 -1.50055575370789,149.533325195312 -1.469722032547,149.530548095703 -1.46555542945862,149.527770996094 -1.45444440841675,149.528594970703 -1.448333263
 39722,149.542755126953 -1.41472220420837,149.544982910156 -1.41000008583069,149.564147949219 -1.37027788162231,149.579956054688 -1.35527777671814,149.622467041016 -1.35944437980652,149.627166748047 -1.36138892173767,149.663299560547 -1.38666677474976,149.710784912109 -1.42166662216187,149.716918945312 -1.42916655540466,149.719696044922 -1.43333315849304,149.790252685547 -1.57666683197021,149.790802001953 -1.5813889503479,149.731903076172 -1.60333347320557)),((144.517761230469 -1.39833331108093,144.506103515625 -1.38944435119629,144.503326416016 -1.38555550575256,144.505554199219 -1.38055562973022,144.516387939453 -1.38194441795349,144.519989013672 -1.38555550575256,144.521911621094 -1.39555549621582,144.517761230469 -1.39833331108093)),((142.818298339844 -1.73333311080933,142.813598632812 -1.73277759552002,142.812194824219 -1.72722220420837,142.812744140625 -1.72111105918884,142.818298339844 -1.69972205162048,142.821075439453 -1.69583320617676,142.832183837891 -1.69361114501
 953,142.863006591797 -1.69444441795349,142.866363525391 -1.69777774810791,142.866912841797 -1.70944428443909,142.864410400391 -1.71361112594604,142.859405517578 -1.71555542945862,142.852752685547 -1.70861101150513,142.847198486328 -1.70722222328186,142.841644287109 -1.70861101150513,142.837463378906 -1.71138882637024,142.818298339844 -1.73333311080933)),((147.391937255859 -1.96083331108093,147.399993896484 -1.96638870239258,147.430816650391 -1.9902777671814,147.434417724609 -1.99361109733582,147.44580078125 -2.00944471359253,147.448028564453 -2.01416683197021,147.447204589844 -2.0188889503479,147.439697265625 -2.06083345413208,147.437744140625 -2.06555557250977,147.426086425781 -2.06777811050415,147.275268554688 -2.1211109161377,147.255554199219 -2.14916658401489,147.239135742188 -2.16694450378418,147.22802734375 -2.17638874053955,147.212188720703 -2.18805551528931,147.207458496094 -2.19027757644653,147.201904296875 -2.19166660308838,146.980529785156 -2.1991662979126,146.893
 035888672 -2.18944406509399,146.8388671875 -2.18194437026978,146.798309326172 -2.16888904571533,146.793579101562 -2.16694450378418,146.726348876953 -2.16083335876465,146.571624755859 -2.23472213745117,146.568023681641 -2.23666667938232,146.563293457031 -2.23472213745117,146.5283203125 -2.20111131668091,146.524993896484 -2.19083309173584,146.518035888672 -2.1497220993042,146.518859863281 -2.14361143112183,146.578308105469 -2.00194454193115,146.580535888672 -1.99722218513489,146.583862304688 -1.99361109733582,146.638580322266 -1.97861099243164,146.844970703125 -1.95055556297302,146.857177734375 -1.94916653633118,146.869689941406 -1.94916653633118,147.093566894531 -1.96638870239258,147.099975585938 -1.96694445610046,147.118286132812 -1.96888875961304,147.164428710938 -1.98333311080933,147.203308105469 -2.003333568573,147.300811767578 -2.02527761459351,147.417755126953 -2.05055570602417,147.419982910156 -2.04583358764648,147.422760009766 -2.03472232818604,147.422760009766 -2.029
 16669845581,147.420532226562 -2.01083374023438,147.418579101562 -2.00583362579346,147.391937255859 -1.96083331108093)),((147.756927490234 -2.35249996185303,147.766662597656 -2.32388925552368,147.795532226562 -2.26500034332275,147.815246582031 -2.24361133575439,147.832458496094 -2.24555540084839,147.877746582031 -2.28944444656372,147.879119873047 -2.29361152648926,147.856353759766 -2.3313889503479,147.848297119141 -2.33666658401489,147.829132080078 -2.34555530548096,147.824127197266 -2.34777784347534,147.81884765625 -2.34916639328003,147.812469482422 -2.34972190856934,147.756927490234 -2.35249996185303)),((150.367736816406 -2.68666648864746,150.356353759766 -2.66805553436279,150.347473144531 -2.66333341598511,150.341064453125 -2.66249990463257,150.273315429688 -2.67277765274048,150.257476806641 -2.6777777671814,150.242462158203 -2.68305540084839,150.190521240234 -2.68583297729492,150.184143066406 -2.68527746200562,150.109405517578 -2.625,149.972473144531 -2.50111150741577,149
 .965789794922 -2.4941668510437,149.949127197266 -2.47638845443726,149.948577880859 -2.47166633605957,149.951354980469 -2.46749973297119,149.960784912109 -2.46000003814697,150.079956054688 -2.41416645050049,150.189697265625 -2.37722206115723,150.206085205078 -2.37444448471069,150.216369628906 -2.37777757644653,150.248016357422 -2.39000034332275,150.417205810547 -2.46055555343628,150.443298339844 -2.47583293914795,150.446075439453 -2.47972202301025,150.467193603516 -2.54472255706787,150.468017578125 -2.55777788162231,150.459686279297 -2.64833354949951,150.458312988281 -2.6536111831665,150.448852539062 -2.66472196578979,150.443298339844 -2.66611099243164,150.41943359375 -2.66249990463257,150.406921386719 -2.66388893127441,150.4013671875 -2.6652774810791,150.371887207031 -2.68388891220093,150.367736816406 -2.68666648864746)),((152.659423828125 -3.84277772903442,152.670837402344 -3.85989284515381,152.701080322266 -3.88305521011353,152.739685058594 -3.89611101150513,152.7697143554
 69 -3.90027761459351,152.919128417969 -4.0041675567627,152.989685058594 -4.07583332061768,153.006927490234 -4.09361171722412,153.118560791016 -4.23916625976562,153.12939453125 -4.25555610656738,153.131622314453 -4.26027870178223,153.134429931641 -4.27138900756836,153.132171630859 -4.37861061096191,153.130798339844 -4.39083385467529,153.128021240234 -4.39500045776367,153.121337890625 -4.40194416046143,153.108856201172 -4.40999984741211,153.092468261719 -4.42083358764648,153.080810546875 -4.43000030517578,153.066375732422 -4.44277763366699,153.063018798828 -4.44638824462891,153.0546875 -4.45861148834229,153.04052734375 -4.48527717590332,153.039154052734 -4.49749946594238,153.039703369141 -4.50361156463623,153.041076660156 -4.5091667175293,153.043304443359 -4.51388931274414,153.046630859375 -4.51722240447998,153.059692382812 -4.52555561065674,153.066375732422 -4.53222274780273,153.077453613281 -4.54861068725586,153.079406738281 -4.58916664123535,153.077453613281 -4.600555419921
 88,152.980255126953 -4.7605562210083,152.974670410156 -4.76666641235352,152.910247802734 -4.82333374023438,152.891662597656 -4.82250022888184,152.743560791016 -4.67305564880371,152.735504150391 -4.66083335876465,152.733306884766 -4.6561107635498,152.693023681641 -4.55833339691162,152.681365966797 -4.5222225189209,152.664978027344 -4.4688892364502,152.662750244141 -4.4572229385376,152.666381835938 -4.45388889312744,152.678588867188 -4.44555473327637,152.681365966797 -4.44138813018799,152.692199707031 -4.39361190795898,152.69775390625 -4.36499977111816,152.69775390625 -4.35805511474609,152.694427490234 -4.19138813018799,152.693572998047 -4.18527698516846,152.691650390625 -4.18055534362793,152.603302001953 -4.00611114501953,152.581909179688 -3.96583318710327,152.538726806641 -3.90009546279907,152.512176513672 -3.8687310218811,152.491577148438 -3.85225462913513,152.374969482422 -3.7277774810791,152.359954833984 -3.70472240447998,152.357177734375 -3.69361114501953,152.35662841796
 9 -3.6875,152.358001708984 -3.66166639328003,152.355224609375 -3.65055561065674,152.349700927734 -3.64249992370605,152.289428710938 -3.57944440841675,152.282470703125 -3.57277774810791,152.190521240234 -3.50888919830322,152.182464599609 -3.50361156463623,152.156372070312 -3.48861122131348,152.151641845703 -3.48638868331909,152.146087646484 -3.4850001335144,152.136657714844 -3.48916673660278,152.131072998047 -3.49055576324463,152.124969482422 -3.49000024795532,151.984405517578 -3.46444463729858,151.956359863281 -3.45833349227905,151.934967041016 -3.44555521011353,151.758331298828 -3.32444477081299,151.708862304688 -3.28055572509766,151.688293457031 -3.25305557250977,151.620513916016 -3.17722225189209,151.6171875 -3.17388916015625,151.608306884766 -3.16916656494141,151.574676513672 -3.1594443321228,151.532745361328 -3.14499998092651,151.493011474609 -3.13000011444092,151.483581542969 -3.12583303451538,151.462188720703 -3.11305570602417,151.455535888672 -3.1061110496521,151.452
 758789062 -3.10194444656372,151.450531005859 -3.09722232818604,151.449981689453 -3.08416652679443,151.448577880859 -3.07888889312744,151.44384765625 -3.06972217559814,151.438293457031 -3.06361103057861,151.417205810547 -3.05055570602417,151.369689941406 -3.02250003814697,151.281372070312 -2.97416639328003,151.237457275391 -2.95361137390137,151.214965820312 -2.94194412231445,151.150543212891 -2.89527797698975,151.122467041016 -2.86861085891724,151.119689941406 -2.86444473266602,151.113586425781 -2.8502779006958,151.110778808594 -2.84611082077026,151.106628417969 -2.84333324432373,151.004425048828 -2.78916692733765,150.999694824219 -2.78722238540649,150.930541992188 -2.76861095428467,150.923583984375 -2.76861095428467,150.903045654297 -2.77138900756836,150.876342773438 -2.77611112594604,150.861907958984 -2.78249979019165,150.832458496094 -2.78722238540649,150.819427490234 -2.7877779006958,150.754425048828 -2.77083349227905,150.750274658203 -2.76805543899536,150.729675292969 -2
 .74055576324463,150.730529785156 -2.7344446182251,150.733856201172 -2.7311110496521,150.747467041016 -2.71749973297119,150.752471923828 -2.71527767181396,150.763305664062 -2.7180552482605,150.824401855469 -2.71527767181396,150.874969482422 -2.71250009536743,150.88720703125 -2.71111106872559,150.891357421875 -2.70833349227905,150.894989013672 -2.70499992370605,150.896942138672 -2.70027780532837,150.885650634766 -2.6851110458374,150.884307861328 -2.67811107635498,150.876983642578 -2.65594434738159,150.875640869141 -2.65294456481934,150.873641967773 -2.65094447135925,150.867797851562 -2.64844417572021,150.861633300781 -2.64977788925171,150.856292724609 -2.65261125564575,150.853134155273 -2.65344452857971,150.838012695312 -2.64277791976929,150.831909179688 -2.64222240447998,150.822204589844 -2.6380558013916,150.792755126953 -2.61666631698608,150.805816650391 -2.56666660308838,150.807739257812 -2.56333351135254,150.811370849609 -2.55999994277954,150.817474365234 -2.559166431427,1
 50.834686279297 -2.57083368301392,150.838012695312 -2.57416677474976,150.906524658203 -2.63594436645508,150.964691162109 -2.68722200393677,150.968841552734 -2.69000005722046,151.086639404297 -2.75027799606323,151.190246582031 -2.82611131668091,151.280822753906 -2.87083339691162,151.311370849609 -2.86999988555908,151.419128417969 -2.89805555343628,151.427185058594 -2.9036111831665,151.464416503906 -2.93499994277954,151.598022460938 -3.02750015258789,151.641937255859 -3.04805564880371,151.717742919922 -3.11555576324463,151.72607421875 -3.12805557250977,151.815246582031 -3.19777774810791,151.820526123047 -3.1991662979126,151.825531005859 -3.1972222328186,151.833587646484 -3.19166660308838,151.855529785156 -3.18611097335815,151.861907958984 -3.18694448471069,151.921905517578 -3.20333337783813,151.948852539062 -3.21083354949951,152.055816650391 -3.24777793884277,152.054412841797 -3.26000022888184,152.054412841797 -3.27361106872559,152.057739257812 -3.28388929367065,152.1647033691
 41 -3.41111087799072,152.204406738281 -3.45444440841675,152.210510253906 -3.46055555343628,152.238006591797 -3.47833299636841,152.252471923828 -3.4844446182251,152.277191162109 -3.49472236633301,152.306640625 -3.50638914108276,152.327178955078 -3.51999998092651,152.355224609375 -3.54000043869019,152.361907958984 -3.54666709899902,152.367462158203 -3.55499982833862,152.392211914062 -3.59861087799072,152.411926269531 -3.63361120223999,152.488006591797 -3.64916658401489,152.493011474609 -3.64861106872559,152.496917724609 -3.65138864517212,152.503051757812 -3.6588888168335,152.511383056641 -3.67111110687256,152.553314208984 -3.74583339691162,152.556640625 -3.756667137146,152.555816650391 -3.76944446563721,152.549713134766 -3.78388929367065,152.546356201172 -3.79416704177856,152.549133300781 -3.79833364486694,152.573852539062 -3.8216667175293,152.577758789062 -3.82444477081299,152.582733154297 -3.82638883590698,152.603302001953 -3.83305549621582,152.659423828125 -3.84277772903442
 )),((149.6640625 -10.3398141860962,149.639434814453 -10.3413887023926,149.572204589844 -10.3413887023926,149.566925048828 -10.3413887023926,149.536651611328 -10.361665725708,149.335784912109 -10.307222366333,149.224975585938 -10.2761116027832,149.186645507812 -10.2600002288818,149.176361083984 -10.2563896179199,149.161102294922 -10.2511119842529,149.139984130859 -10.2449989318848,149.093292236328 -10.2341651916504,149.049407958984 -10.2424983978271,149.03857421875 -10.2449989318848,148.993835449219 -10.2605571746826,148.981628417969 -10.268611907959,148.934967041016 -10.2672233581543,148.79443359375 -10.2391662597656,148.723297119141 -10.1869449615479,148.680267333984 -10.1494445800781,148.677459716797 -10.1533336639404,148.642486572266 -10.1863880157471,148.637481689453 -10.1883344650269,148.468292236328 -10.2038879394531,148.462738037109 -10.2038879394531,148.4033203125 -10.2005558013916,148.372467041016 -10.1919441223145,148.3369140625 -10.1797218322754,148.332733154297 -
 10.176944732666,148.327178955078 -10.1688899993896,148.322479248047 -10.1599998474121,148.314971923828 -10.1405563354492,148.312194824219 -10.1363887786865,148.3046875 -10.130277633667,148.157562255859 -10.0737085342407,148.154418945312 -10.0791664123535,148.150543212891 -10.0952777862549,148.148315429688 -10.0999984741211,148.115509033203 -10.1216659545898,148.10302734375 -10.1297206878662,148.0888671875 -10.1358337402344,148.083312988281 -10.1372222900391,148.055236816406 -10.1433334350586,147.999694824219 -10.1519451141357,147.952453613281 -10.1458339691162,147.940795898438 -10.1211109161377,147.923034667969 -10.0980548858643,147.872192382812 -10.0475006103516,147.86328125 -10.0427780151367,147.857727050781 -10.0427780151367,147.781097412109 -10.0508327484131,147.775543212891 -10.0522232055664,147.766082763672 -10.0561103820801,147.619964599609 -9.9908332824707,147.612457275391 -9.98472213745117,147.601348876953 -9.97527694702148,147.574127197266 -9.94833374023438,147.510
 25390625 -9.87861061096191,147.504150390625 -9.87138748168945,147.501373291016 -9.86722183227539,147.499389648438 -9.85583305358887,147.501373291016 -9.85111045837402,147.503601074219 -9.83944320678711,147.503601074219 -9.8125,147.499389648438 -9.79638862609863,147.490509033203 -9.77138900756836,147.48828125 -9.76666641235352,147.386932373047 -9.63555717468262,147.316375732422 -9.55527877807617,147.296600341797 -9.53412532806396,147.248565673828 -9.50583457946777,147.12939453125 -9.44361114501953,147.080001831055 -9.43415546417236,147.099975585938 -9.44972229003906,147.102752685547 -9.45388793945312,147.102752685547 -9.48361015319824,147.101348876953 -9.48888778686523,147.09912109375 -9.49110984802246,147.094421386719 -9.49305534362793,147.0888671875 -9.49166679382324,147.062194824219 -9.47333335876465,147.055236816406 -9.46666526794434,147.008026123047 -9.39833450317383,147.001922607422 -9.3841667175293,146.926635742188 -9.28277778625488,146.91748046875 -9.28750038146973,14
 6.911376953125 -9.28694534301758,146.901092529297 -9.28333282470703,146.896942138672 -9.28083419799805,146.893585205078 -9.27722358703613,146.891662597656 -9.27250099182129,146.888885498047 -9.1833324432373,146.905044555664 -9.13727760314941,146.905868530273 -9.13410949707031,146.907043457031 -9.13127708435059,146.909881591797 -9.13077735900879,146.915374755859 -9.13361072540283,146.918548583984 -9.13444423675537,146.969696044922 -9.09138870239258,146.977172851562 -9.07444381713867,146.981353759766 -9.05944442749023,146.981048583984 -9.05097389221191,146.974395751953 -9.03388977050781,146.972473144531 -9.02916717529297,146.969116210938 -9.02833366394043,146.951080322266 -9.03388977050781,146.94580078125 -9.04194450378418,146.944427490234 -9.04722213745117,146.94580078125 -9.05277824401855,146.951904296875 -9.06027793884277,146.954681396484 -9.06833267211914,146.953308105469 -9.07361030578613,146.925262451172 -9.09999847412109,146.91748046875 -9.10610961914062,146.84460449218
 8 -9.09577751159668,146.840911865234 -9.09627723693848,146.83757019043 -9.09544467926025,146.630523681641 -9.0302791595459,146.621612548828 -9.02555656433105,146.586639404297 -8.99916648864746,146.578308105469 -8.9869441986084,146.55859375 -8.9416675567627,146.545532226562 -8.90250015258789,146.546081542969 -8.89777946472168,146.555816650391 -8.85972213745117,146.559143066406 -8.85638809204102,146.567474365234 -8.8075008392334,146.541351318359 -8.76361274719238,146.517486572266 -8.72500038146973,146.441345214844 -8.62472152709961,146.431915283203 -8.61388778686523,146.419982910156 -8.60499954223633,146.403594970703 -8.59444427490234,146.379104614258 -8.58470821380615,146.372192382812 -8.57805633544922,146.351623535156 -8.55777740478516,146.318572998047 -8.50889015197754,146.275543212891 -8.44305610656738,146.269439697266 -8.42888832092285,146.268035888672 -8.42361068725586,146.263305664062 -8.38750076293945,146.264709472656 -8.37527656555176,146.264709472656 -8.3686103820800
 8,146.262481689453 -8.35972213745117,146.243286132812 -8.29472351074219,146.238555908203 -8.28583335876465,146.229675292969 -8.27444458007812,146.218566894531 -8.26472282409668,146.111083984375 -8.16388893127441,146.110229492188 -8.13472366333008,146.089691162109 -8.09111022949219,145.998016357422 -8.05444526672363,145.987731933594 -8.05111122131348,145.930816650391 -8.04111099243164,145.918579101562 -8.03972244262695,145.898590087891 -8.03888893127441,145.880798339844 -8.04166793823242,145.835510253906 -8.02805709838867,145.797760009766 -8.00777816772461,145.786376953125 -7.99888896942139,145.718292236328 -7.96777820587158,145.649993896484 -7.9597225189209,145.630798339844 -7.94472217559814,145.616912841797 -7.93777751922607,145.528045654297 -7.93777751922607,145.502471923828 -7.9399995803833,145.484130859375 -7.94861030578613,145.465515136719 -7.95083332061768,145.443572998047 -7.94944381713867,145.432739257812 -7.94805526733398,145.422485351562 -7.94472217559814,145.24411
 0107422 -7.86861038208008,145.19807434082 -7.82955169677734,145.182723999023 -7.81383991241455,145.168106079102 -7.81822443008423,145.162994384766 -7.82626342773438,145.164459228516 -7.83649444580078,145.161529541016 -7.84489870071411,145.155685424805 -7.84599494934082,145.044967651367 -7.82041692733765,144.995513916016 -7.81555557250977,144.879669189453 -7.78250026702881,144.844696044922 -7.75722312927246,144.838562011719 -7.74972152709961,144.840515136719 -7.74499988555908,144.850250244141 -7.74111080169678,144.871337890625 -7.70777797698975,144.873565673828 -7.7030553817749,144.874114990234 -7.69694423675537,144.874114990234 -7.6899995803833,144.862457275391 -7.61055564880371,144.844696044922 -7.60777759552002,144.833862304688 -7.67722225189209,144.831085205078 -7.68111133575439,144.824127197266 -7.68805503845215,144.819427490234 -7.6899995803833,144.787750244141 -7.69138813018799,144.783599853516 -7.69138813018799,144.599395751953 -7.6602783203125,144.588287353516 -7.657
 50026702881,144.584411621094 -7.65472221374512,144.552185058594 -7.6119441986084,144.547210693359 -7.60305500030518,144.547210693359 -7.5963888168335,144.545806884766 -7.57472229003906,144.536376953125 -7.52694511413574,144.534973144531 -7.52166652679443,144.530822753906 -7.51222229003906,144.525268554688 -7.5038890838623,144.520538330078 -7.50194454193115,144.514984130859 -7.50194454193115,144.51025390625 -7.5038890838623,144.508880615234 -7.50944519042969,144.508331298828 -7.61472225189209,144.508331298828 -7.62138843536377,144.424682617188 -7.53305530548096,144.418579101562 -7.52583312988281,144.410247802734 -7.52027797698975,144.406921386719 -7.51944446563721,144.412200927734 -7.56583309173584,144.435516357422 -7.68000030517578,144.467742919922 -7.74305534362793,144.395812988281 -7.75583362579346,144.378021240234 -7.75333404541016,144.363006591797 -7.74777793884277,144.358856201172 -7.74499988555908,144.356628417969 -7.74027729034424,144.354125976562 -7.72944450378418,14
 4.354125976562 -7.72277736663818,144.356628417969 -7.70499992370605,144.359680175781 -7.69416618347168,144.360229492188 -7.68249988555908,144.319122314453 -7.62083339691162,144.315795898438 -7.61749935150146,144.310791015625 -7.61666584014893,144.260803222656 -7.63777828216553,144.250549316406 -7.65472221374512,144.243560791016 -7.66694450378418,144.255249023438 -7.73416614532471,144.263031005859 -7.74027729034424,144.272491455078 -7.76749992370605,144.271911621094 -7.77361106872559,144.268310546875 -7.77694511413574,144.224395751953 -7.79333305358887,144.219116210938 -7.79472255706787,144.213012695312 -7.79527759552002,144.147216796875 -7.77888870239258,144.121612548828 -7.77166652679443,143.911926269531 -7.69694423675537,143.899719238281 -7.68861103057861,143.848037719727 -7.63533353805542,143.838531494141 -7.62833404541016,143.829193115234 -7.61733341217041,143.822525024414 -7.60766696929932,143.812713623047 -7.58883380889893,143.810211181641 -7.58316707611084,143.8065490
 72266 -7.57049989700317,143.773040771484 -7.51555633544922,143.768310546875 -7.506667137146,143.758605957031 -7.50250053405762,143.664825439453 -7.46764850616455,143.691345214844 -7.51222229003906,143.755126953125 -7.58950042724609,143.839416503906 -7.71527767181396,143.845520019531 -7.73611068725586,143.852447509766 -7.77027797698975,143.85302734375 -7.78305530548096,143.851898193359 -7.79527759552002,143.85302734375 -7.80749988555908,143.854400634766 -7.81305503845215,143.896362304688 -7.88027763366699,143.901641845703 -7.88833332061768,143.9580078125 -7.97862243652344,143.957183837891 -7.98472213745117,143.955230712891 -7.9894437789917,143.893585205078 -8.03694534301758,143.889434814453 -8.03972244262695,143.884704589844 -8.04166793823242,143.847747802734 -8.04583358764648,143.833862304688 -8.04583358764648,143.755249023438 -8.04111099243164,143.750274658203 -8.03888893127441,143.743560791016 -8.03222274780273,143.738006591797 -8.02416801452637,143.724395751953 -8.0105571
 7468262,143.719421386719 -8.00833511352539,143.661376953125 -7.99138832092285,143.631896972656 -7.98666667938232,143.618835449219 -7.98611068725586,143.597473144531 -7.99222183227539,143.588562011719 -7.99694442749023,143.568908691406 -8.0041675567627,143.56575012207 -8.00483322143555,143.546081542969 -8.00638961791992,143.501647949219 -7.9961109161377,143.485778808594 -7.99138832092285,143.481628417969 -7.98888874053955,143.474975585938 -7.98194408416748,143.473571777344 -7.97305583953857,143.460510253906 -7.93861103057861,143.454406738281 -7.92416667938232,143.444122314453 -7.91333389282227,143.439971923828 -7.91055583953857,143.435241699219 -7.90861129760742,143.424133300781 -7.90722274780273,143.362457275391 -7.8997220993042,143.358306884766 -7.90250015258789,143.356903076172 -7.90805530548096,143.356903076172 -7.91333389282227,143.360504150391 -7.91694450378418,143.446624755859 -7.98055553436279,143.538635253906 -8.05216693878174,143.541458129883 -8.05333423614502,143.5
 43975830078 -8.05500030517578,143.547958374023 -8.05900001525879,143.628295898438 -8.19361114501953,143.630523681641 -8.19833374023438,143.632446289062 -8.20999908447266,143.631896972656 -8.21611022949219,143.629669189453 -8.22749900817871,143.625518798828 -8.2369441986084,143.622192382812 -8.24055480957031,143.611907958984 -8.24388885498047,143.56884765625 -8.24722099304199,143.554962158203 -8.24722099304199,143.512481689453 -8.2458324432373,143.469421386719 -8.24527740478516,143.382446289062 -8.25,143.373565673828 -8.25055694580078,143.338562011719 -8.2538890838623,143.234954833984 -8.27500152587891,143.178039550781 -8.28666687011719,143.080810546875 -8.30833435058594,143.069976806641 -8.31083297729492,143.049407958984 -8.31777763366699,143.034149169922 -8.32305526733398,143.023864746094 -8.3266658782959,143 -8.33666610717773,142.991058349609 -8.34138870239258,142.979949951172 -8.34416580200195,142.973297119141 -8.34416580200195,142.967193603516 -8.3436107635498,142.961639
 404297 -8.34222221374512,142.94580078125 -8.33749961853027,142.941070556641 -8.33527755737305,142.908874511719 -8.31916618347168,142.882171630859 -8.30500030517578,142.865509033203 -8.29416656494141,142.845794677734 -8.28666687011719,142.799987792969 -8.27500152587891,142.776641845703 -8.27083396911621,142.696350097656 -8.26749992370605,142.654693603516 -8.27361106872559,142.638031005859 -8.27777862548828,142.595794677734 -8.29000091552734,142.575256347656 -8.29666709899902,142.565521240234 -8.30083274841309,142.548309326172 -8.31083297729492,142.540802001953 -8.31694412231445,142.533874511719 -8.32388877868652,142.529968261719 -8.3266658782959,142.521087646484 -8.33138847351074,142.511383056641 -8.33527755737305,142.505828857422 -8.33666610717773,142.485229492188 -8.33666610717773,142.466918945312 -8.33611106872559,142.442749023438 -8.33277702331543,142.437469482422 -8.33138847351074,142.427764892578 -8.32722282409668,142.419708251953 -8.32194519042969,142.411926269531 -8.3
 1583404541016,142.403213500977 -8.28638935089111,142.396194458008 -8.26155567169189,142.395050048828 -8.25055599212646,142.394195556641 -8.23922157287598,142.39453125 -8.23155498504639,142.394195556641 -8.2278881072998,142.386657714844 -8.19361114501953,142.383880615234 -8.18972206115723,142.379943847656 -8.18694496154785,142.338562011719 -8.16638946533203,142.327758789062 -8.16388893127441,142.316925048828 -8.16388893127441,142.221618652344 -8.1733341217041,142.2119140625 -8.17722320556641,142.140808105469 -8.22222137451172,142.13720703125 -8.22555541992188,142.13525390625 -8.23027801513672,142.135803222656 -8.23638725280762,142.144714355469 -8.23916625976562,142.155822753906 -8.24055480957031,142.163879394531 -8.23638725280762,142.172210693359 -8.23083305358887,142.182464599609 -8.22083282470703,142.186645507812 -8.21805572509766,142.195526123047 -8.21333312988281,142.223571777344 -8.20027732849121,142.228302001953 -8.19833374023438,142.309143066406 -8.18083381652832,142.3
 14147949219 -8.18000030517578,142.324401855469 -8.1833324432373,142.338012695312 -8.19027709960938,142.355224609375 -8.19916725158691,142.361358642578 -8.20638847351074,142.374572753906 -8.26111125946045,142.377410888672 -8.2746114730835,142.377075195312 -8.28644466400146,142.377410888672 -8.29327774047852,142.382446289062 -8.31916618347168,142.388031005859 -8.32722282409668,142.408599853516 -8.34749984741211,142.439422607422 -8.37138748168945,142.44970703125 -8.37472152709961,142.466918945312 -8.37805557250977,142.473022460938 -8.37888717651367,142.486633300781 -8.37888717651367,142.493011474609 -8.37805557250977,142.512756347656 -8.37194442749023,142.522491455078 -8.36805534362793,142.5263671875 -8.36527633666992,142.540252685547 -8.35166549682617,142.548309326172 -8.34611129760742,142.556640625 -8.34083366394043,142.590240478516 -8.3266658782959,142.619689941406 -8.31500053405762,142.635528564453 -8.31027793884277,142.641662597656 -8.31083297729492,142.734680175781 -8.322
 50022888184,142.771636962891 -8.33194351196289,142.776641845703 -8.33388900756836,142.783325195312 -8.34083366394043,142.788879394531 -8.3488883972168,142.799133300781 -8.35916519165039,142.807464599609 -8.36444473266602,142.906097412109 -8.42361068725586,142.917205810547 -8.42611122131348,142.9580078125 -8.43166732788086,143.01025390625 -8.44111061096191,143.04443359375 -8.44777870178223,143.049987792969 -8.44916725158691,143.086364746094 -8.45999908447266,143.096618652344 -8.4636116027832,143.110229492188 -8.47027778625488,143.213012695312 -8.5494441986084,143.220520019531 -8.55555534362793,143.239135742188 -8.57138824462891,143.246063232422 -8.57805633544922,143.249389648438 -8.58138847351074,143.281646728516 -8.61861038208008,143.374664306641 -8.741943359375,143.392761230469 -8.77027893066406,143.395263671875 -8.7813892364502,143.406921386719 -8.96194458007812,143.405548095703 -8.96749877929688,143.403045654297 -8.97138786315918,143.384429931641 -8.99388885498047,143.367
 1875 -9.01083374023438,143.363006591797 -9.01361274719238,143.331634521484 -9.02833366394043,143.321899414062 -9.03250122070312,143.316650390625 -9.03388977050781,143.310241699219 -9.03305625915527,143.299407958984 -9.02361106872559,143.289154052734 -9.02027893066406,143.283050537109 -9.01972198486328,143.269989013672 -9.02027893066406,143.248016357422 -9.02555656433105,143.232177734375 -9.0302791595459,143.174133300781 -9.04861068725586,143.047210693359 -9.09000015258789,143.04248046875 -9.09194374084473,143.039154052734 -9.09527778625488,143.030822753906 -9.10750007629395,143.023864746094 -9.11416625976562,142.902770996094 -9.19750022888184,142.842468261719 -9.2327766418457,142.807464599609 -9.25222396850586,142.797760009766 -9.25638961791992,142.788299560547 -9.26027870178223,142.769134521484 -9.2672233581543,142.752471923828 -9.27138900756836,142.723846435547 -9.28333282470703,142.66552734375 -9.32055473327637,142.654693603516 -9.32999992370605,142.638885498047 -9.334722
 5189209,142.625244140625 -9.3347225189209,142.582733154297 -9.33083343505859,142.571624755859 -9.32805633544922,142.543029785156 -9.30916595458984,142.532470703125 -9.29888916015625,142.5244140625 -9.28694534301758,142.521087646484 -9.28333282470703,142.517486572266 -9.28000068664551,142.497741699219 -9.26527786254883,142.477172851562 -9.25166702270508,142.425811767578 -9.22805595397949,142.2099609375 -9.16500091552734,142.203033447266 -9.16500091552734,142.054412841797 -9.18722152709961,141.944702148438 -9.20694351196289,141.721343994141 -9.21444511413574,141.615783691406 -9.23611068725586,141.608856201172 -9.23611068725586,141.522491455078 -9.22111129760742,141.509429931641 -9.21388816833496,141.501922607422 -9.20777702331543,141.495788574219 -9.20027732849121,141.48828125 -9.19416618347168,141.460784912109 -9.17388916015625,141.448577880859 -9.16583442687988,141.429412841797 -9.15750122070312,141.388305664062 -9.14416694641113,141.375244140625 -9.14333343505859,141.323028
 564453 -9.14999961853027,141.312194824219 -9.15277862548828,141.307464599609 -9.15500068664551,141.294982910156 -9.16305541992188,141.284698486328 -9.17305564880371,141.266387939453 -9.18888854980469,141.226623535156 -9.21722221374512,141.213592529297 -9.22472190856934,141.176361083984 -9.23388862609863,141.160797119141 -9.23749923706055,141.122467041016 -9.23194313049316,141.117462158203 -9.22999954223633,141.109405517578 -9.22472190856934,141.090789794922 -9.20916557312012,141.033874511719 -9.15694427490234,141.013305664062 -9.13666725158691,141.007019042969 -9.12846755981445,141.006134033203 -6.90478563308716,141.006134033203 -6.89328384399414,140.998565673828 -6.89388942718506,140.990509033203 -6.89944458007812,140.983581542969 -6.9061107635498,140.978851318359 -6.90694427490234,140.949401855469 -6.9036111831665,140.902770996094 -6.85583305358887,140.875244140625 -6.79611110687256,140.871063232422 -6.7863883972168,140.859405517578 -6.72861099243164,140.858856201172 -6.67
 83332824707,140.863006591797 -6.63138866424561,140.891082763672 -6.60333347320557,140.895263671875 -6.60055541992188,140.898040771484 -6.59666728973389,140.947204589844 -6.5,140.951354980469 -6.48361110687256,140.950805664062 -6.47749996185303,140.948577880859 -6.47277736663818,140.94580078125 -6.4686107635498,140.928039550781 -6.45083332061768,140.932189941406 -6.43444442749023,140.963592529297 -6.3386116027832,140.967742919922 -6.33583354949951,140.973297119141 -6.33444499969482,140.985504150391 -6.33305549621582,141.006134033203 -6.33292484283447,141.006103515625 -6,141.006103515625 -4.90555477142334,141.006103515625 -2.61388921737671,141.002471923828 -2.60708522796631,141.029968261719 -2.59277772903442,141.034698486328 -2.59083318710327,141.039428710938 -2.59000015258789,141.046356201172 -2.59000015258789,141.199127197266 -2.61805534362793,141.204681396484 -2.61944437026978,141.214141845703 -2.62222194671631,141.270538330078 -2.64555549621582,141.273864746094 -2.65583324
 432373,141.278045654297 -2.6652774810791,141.284149169922 -2.67277765274048,141.345794677734 -2.70777797698975,141.369689941406 -2.7180552482605,141.380798339844 -2.72083330154419,141.410797119141 -2.72499990463257,141.426635742188 -2.72972202301025,141.436370849609 -2.73388910293579,141.568572998047 -2.79388904571533,141.608856201172 -2.8125,141.704132080078 -2.86250019073486,141.840515136719 -2.93694448471069,141.881622314453 -2.96444463729858,141.889984130859 -2.96999979019165,141.894714355469 -2.9719443321228,141.913879394531 -2.9719443321228,141.931091308594 -2.9686107635498,141.935791015625 -2.96638870239258,141.962463378906 -2.95888900756836,141.973571777344 -2.95611095428467,141.991912841797 -2.95416688919067,142.003601074219 -2.95611095428467,142.011932373047 -2.96166658401489,142.066070556641 -3.00833368301392,142.076904296875 -3.01777791976929,142.077758789062 -3.02055549621582,142.124969482422 -3.05944442749023,142.252471923828 -3.10472249984741,142.551910400391
 -3.21833324432373,142.663604736328 -3.24777793884277,142.946624755859 -3.33249998092651,142.992462158203 -3.34833335876465,143.032745361328 -3.36277770996094,143.041076660156 -3.36416673660278,143.073181152344 -3.36020636558533,143.087738037109 -3.35583353042603,143.093841552734 -3.35500001907349,143.106079101562 -3.35388898849487,143.123840332031 -3.35388898849487,143.172760009766 -3.35722255706787,143.194702148438 -3.3600001335144,143.209686279297 -3.3652777671814,143.2138671875 -3.36805534362793,143.229400634766 -3.37972211837769,143.23828125 -3.38444471359253,143.255554199219 -3.3880558013916,143.336364746094 -3.40166664123535,143.346069335938 -3.40166664123535,143.370788574219 -3.40166664123535,143.384429931641 -3.40305519104004,143.408325195312 -3.40638875961304,143.442749023438 -3.41194438934326,143.516082763672 -3.43444442749023,143.520812988281 -3.43666648864746,143.529144287109 -3.44194412231445,143.536651611328 -3.44805526733398,143.569427490234 -3.47555541992188,
 143.598846435547 -3.51444482803345,143.602172851562 -3.5247220993042,143.605804443359 -3.54194450378418,143.609130859375 -3.54527807235718,143.61328125 -3.54805564880371,143.648864746094 -3.56722259521484,143.731079101562 -3.60416698455811,143.768310546875 -3.61083364486694,143.790802001953 -3.61083364486694,143.794982910156 -3.61222219467163,143.798858642578 -3.61500024795532,143.949127197266 -3.73333311080933,143.955230712891 -3.73944425582886,143.9580078125 -3.74361133575439,143.964691162109 -3.7572226524353,143.966064453125 -3.76277780532837,143.976348876953 -3.77972221374512,143.981903076172 -3.78805589675903,143.988861083984 -3.79500007629395,143.993011474609 -3.79777812957764,144.016937255859 -3.81055545806885,144.243011474609 -3.87277746200562,144.249114990234 -3.87361097335815,144.253875732422 -3.87138891220093,144.255249023438 -3.86611127853394,144.253875732422 -3.86194467544556,144.253875732422 -3.85500001907349,144.258026123047 -3.84555530548096,144.275268554688
 -3.809166431427,144.278594970703 -3.80583333969116,144.284973144531 -3.80527782440186,144.338287353516 -3.80249977111816,144.375244140625 -3.80249977111816,144.511657714844 -3.82083368301392,144.515808105469 -3.82361125946045,144.532196044922 -3.84611082077026,144.534973144531 -3.8502779006958,144.549987792969 -3.87611103057861,144.552185058594 -3.88111114501953,144.547210693359 -3.8938889503479,144.545257568359 -3.90416669845581,144.54248046875 -3.93444442749023,144.543853759766 -3.95361137390137,144.547210693359 -3.96388912200928,144.551361083984 -3.9719443321228,144.571350097656 -3.99194431304932,144.591064453125 -4.00611114501953,144.608306884766 -4.0130558013916,144.613861083984 -4.01444530487061,144.653594970703 -4.0130558013916,144.673309326172 -4.01361179351807,144.678863525391 -4.01500034332275,144.729675292969 -4.0313892364502,144.766662597656 -4.04638862609863,144.850250244141 -4.09305572509766,144.858306884766 -4.09833335876465,144.876342773438 -4.11361122131348,
 144.978302001953 -4.22277736663818,144.981628417969 -4.22638893127441,144.986633300781 -4.23499965667725,144.991333007812 -4.24388885498047,144.994689941406 -4.25277805328369,144.996063232422 -4.26250076293945,145.004974365234 -4.28166675567627,145.033050537109 -4.33555603027344,145.036651611328 -4.33888912200928,145.054962158203 -4.35194396972656,145.089965820312 -4.37166595458984,145.094696044922 -4.37388896942139,145.157196044922 -4.38277721405029,145.228576660156 -4.3880558013916,145.253051757812 -4.37861061096191,145.293579101562 -4.37666606903076,145.305236816406 -4.37722206115723,145.333862304688 -4.38944435119629,145.338012695312 -4.39222240447998,145.451080322266 -4.49416637420654,145.459411621094 -4.50444507598877,145.527191162109 -4.59249973297119,145.614135742188 -4.70027828216553,145.620513916016 -4.70777797698975,145.675811767578 -4.76194477081299,145.679412841797 -4.76527786254883,145.69384765625 -4.77694511413574,145.735504150391 -4.80277729034424,145.7808227
 53906 -4.92777729034424,145.813598632812 -5.06555557250977,145.813598632812 -5.07250022888184,145.786926269531 -5.23138904571533,145.765808105469 -5.26361179351807,145.738861083984 -5.30527782440186,145.724395751953 -5.41222190856934,145.723846435547 -5.42527770996094,145.725250244141 -5.430832862854,145.734130859375 -5.4491662979126,145.747741699219 -5.46972179412842,145.754699707031 -5.47638893127441,145.766387939453 -5.48527717590332,145.782745361328 -5.4894437789917,145.787750244141 -5.48999977111816,145.793029785156 -5.48999977111816,145.872467041016 -5.48611068725586,145.930816650391 -5.47722244262695,145.935516357422 -5.47638893127441,145.963592529297 -5.47305583953857,145.976623535156 -5.47638893127441,146.082183837891 -5.51250076293945,146.174682617188 -5.55138874053955,146.194702148438 -5.55888843536377,146.289154052734 -5.58888912200928,146.376342773438 -5.59916687011719,146.439971923828 -5.59861087799072,146.445526123047 -5.59861087799072,146.465240478516 -5.6047
 2202301025,146.47021484375 -5.60666751861572,146.474090576172 -5.60944557189941,146.531188964844 -5.65468120574951,146.580535888672 -5.69472217559814,146.605224609375 -5.71777820587158,146.640808105469 -5.74388885498047,146.653045654297 -5.75194454193115,146.662750244141 -5.75611114501953,146.688873291016 -5.76416683197021,146.714691162109 -5.76972198486328,146.770782470703 -5.79138946533203,146.775787353516 -5.79361248016357,146.783843994141 -5.79889011383057,146.786071777344 -5.80388927459717,146.796310424805 -5.83441781997681,146.875213623047 -5.82555675506592,146.894958496094 -5.82888984680176,146.923004150391 -5.84194564819336,146.930511474609 -5.84805679321289,146.946319580078 -5.86638927459717,146.953826904297 -5.88611221313477,146.956604003906 -5.89027881622314,146.962707519531 -5.897780418396,146.992156982422 -5.91611289978027,147.014129638672 -5.92833518981934,147.041625976562 -5.94222354888916,147.046325683594 -5.94416904449463,147.102722167969 -5.96611404418945,1
 47.112152099609 -5.96667003631592,147.228820800781 -5.97223472595215,147.234924316406 -5.97140216827393,147.24658203125 -5.96251487731934,147.269683837891 -5.93807125091553,147.274658203125 -5.93612670898438,147.284942626953 -5.93529415130615,147.423278808594 -5.96058177947998,147.466613769531 -5.97085952758789,147.476867675781 -5.97419261932373,147.484375 -5.98030376434326,147.573303222656 -6.05527782440186,147.590515136719 -6.07222270965576,147.641937255859 -6.13694477081299,147.786651611328 -6.30249977111816,147.826354980469 -6.3372220993042,147.830261230469 -6.34694480895996,147.850250244141 -6.41166687011719,147.863861083984 -6.45916652679443,147.866638183594 -6.47000026702881,147.869964599609 -6.65472221374512,147.869415283203 -6.66083335876465,147.866058349609 -6.67083358764648,147.845520019531 -6.69138813018799,147.838562011719 -6.69805526733398,147.819427490234 -6.71305561065674,147.810516357422 -6.71777820587158,147.770812988281 -6.72611141204834,147.759155273438 -
 6.72805595397949,147.568023681641 -6.75194454193115,147.416381835938 -6.73499965667725,147.305541992188 -6.74583339691162,147.219696044922 -6.74638843536377,147.199981689453 -6.74583339691162,147.188873291016 -6.74305534362793,147.180816650391 -6.74027729034424,147.174682617188 -6.73555564880371,147.166381835938 -6.72333335876465,147.160247802734 -6.71722221374512,147.149993896484 -6.71388912200928,147.0888671875 -6.71444511413574,146.971069335938 -6.74305534362793,146.961364746094 -6.74722194671631,146.948577880859 -6.79805564880371,146.944976806641 -6.81527709960938,146.943023681641 -6.84027767181396,146.941650390625 -6.90444469451904,146.944976806641 -6.95388889312744,146.946350097656 -6.95944499969482,146.948577880859 -6.96416664123535,146.955230712891 -6.97111129760742,147.0244140625 -7.03694438934326,147.037475585938 -7.04444408416748,147.130798339844 -7.20361137390137,147.140258789062 -7.22111129760742,147.144439697266 -7.23083305358887,147.146362304688 -7.24916648864
 746,147.145812988281 -7.26194477081299,147.141662597656 -7.27166652679443,147.140258789062 -7.27694511413574,147.137481689453 -7.29472255706787,147.139709472656 -7.32527828216553,147.1533203125 -7.38305473327637,147.154693603516 -7.38861179351807,147.178588867188 -7.46388912200928,147.210784912109 -7.49027729034424,147.216369628906 -7.49166679382324,147.297210693359 -7.5038890838623,147.303314208984 -7.50472259521484,147.320526123047 -7.50527858734131,147.332183837891 -7.50333404541016,147.3369140625 -7.50527858734131,147.418579101562 -7.56722259521484,147.457733154297 -7.5977783203125,147.641357421875 -7.77555561065674,147.666656494141 -7.79111099243164,147.670806884766 -7.79388904571533,147.693298339844 -7.82583332061768,147.696075439453 -7.83527755737305,147.701629638672 -7.87055492401123,147.701629638672 -7.8841667175293,147.700805664062 -7.89027786254883,147.701629638672 -7.90333366394043,147.703033447266 -7.90861129760742,147.710510253906 -7.92166614532471,147.71524047
 8516 -7.92916679382324,147.718566894531 -7.93249988555908,147.731628417969 -7.9399995803833,147.741333007812 -7.94388866424561,147.756927490234 -7.94861030578613,147.776916503906 -7.93638801574707,147.782470703125 -7.93527698516846,147.804412841797 -7.93527698516846,147.854949951172 -7.93527698516846,147.866638183594 -7.93722152709961,147.876342773438 -7.94111061096191,147.888031005859 -7.94999980926514,147.911926269531 -7.96722221374512,147.935791015625 -7.98277759552002,147.939422607422 -7.98472213745117,147.974395751953 -7.99610900878906,147.979675292969 -8.03694534301758,147.982452392578 -8.04777908325195,147.985229492188 -8.05194473266602,147.9921875 -8.0586109161377,148.004425048828 -8.06666564941406,148.009979248047 -8.06666564941406,148.0263671875 -8.06277847290039,148.114685058594 -8.05527877807617,148.13525390625 -8.06611061096191,148.194976806641 -8.25194549560547,148.19970703125 -8.26749992370605,148.205810546875 -8.29527854919434,148.206634521484 -8.301389694213
 87,148.207183837891 -8.31083297729492,148.207183837891 -8.32055473327637,148.206634521484 -8.34000015258789,148.210784912109 -8.39305686950684,148.220245361328 -8.51027870178223,148.222198486328 -8.53388977050781,148.230529785156 -8.55972290039062,148.235229492188 -8.56861114501953,148.2421875 -8.57527732849121,148.271087646484 -8.59444427490234,148.300537109375 -8.61138916015625,148.318298339844 -8.60861015319824,148.327178955078 -8.60638809204102,148.331359863281 -8.60638809204102,148.347198486328 -8.61138916015625,148.351898193359 -8.61333274841309,148.376617431641 -8.62944412231445,148.443023681641 -8.67500114440918,148.44580078125 -8.67888832092285,148.478576660156 -8.73305511474609,148.479949951172 -8.73861122131348,148.479949951172 -8.75889015197754,148.489685058594 -8.84027671813965,148.494415283203 -8.86666488647461,148.530822753906 -8.99305534362793,148.534698486328 -9.00277900695801,148.536926269531 -9.00750160217285,148.5888671875 -9.07027816772461,148.6041259765
 62 -9.08250045776367,148.614410400391 -9.0858325958252,148.695251464844 -9.10222244262695,148.719970703125 -9.10472106933594,148.725250244141 -9.10472106933594,148.753601074219 -9.10416603088379,148.782196044922 -9.10138893127441,148.842468261719 -9.09055519104004,149.067199707031 -9.04111099243164,149.071350097656 -9.03861236572266,149.137756347656 -9.00666809082031,149.221343994141 -8.99860954284668,149.255828857422 -8.99777793884277,149.259979248047 -8.99916648864746,149.309967041016 -9.01694488525391,149.314697265625 -9.01889038085938,149.316650390625 -9.02166748046875,149.322204589844 -9.03777885437012,149.338012695312 -9.12972068786621,149.328308105469 -9.15277862548828,149.325531005859 -9.15694427490234,149.316070556641 -9.16777801513672,149.311920166016 -9.17055511474609,149.291351318359 -9.18388938903809,149.181640625 -9.34916687011719,149.1796875 -9.35361099243164,149.178863525391 -9.35972213745117,149.178863525391 -9.37333297729492,149.181091308594 -9.385000228881
 84,149.184417724609 -9.39500045776367,149.208312988281 -9.45249938964844,149.219970703125 -9.47472190856934,149.227752685547 -9.48749923706055,149.231079101562 -9.49110984802246,149.234405517578 -9.49444389343262,149.243286132812 -9.49916648864746,149.266662597656 -9.51000022888184,149.271636962891 -9.5119457244873,149.2783203125 -9.5119457244873,149.28857421875 -9.50861167907715,149.301635742188 -9.50777816772461,149.307189941406 -9.5091667175293,149.348846435547 -9.52194595336914,149.437469482422 -9.57138824462891,149.439422607422 -9.59111022949219,149.440795898438 -9.59638786315918,149.444122314453 -9.59972190856934,149.454406738281 -9.60305404663086,149.662200927734 -9.60722160339355,149.739410400391 -9.60166549682617,149.746337890625 -9.60166549682617,149.758026123047 -9.6038875579834,149.764984130859 -9.60916519165039,149.771087646484 -9.61666488647461,149.775268554688 -9.61944389343262,149.780548095703 -9.6208324432373,149.874389648438 -9.6422233581543,149.88079833984
 4 -9.64305686950684,149.9033203125 -9.64361190795898,149.910247802734 -9.64361190795898,149.94580078125 -9.6422233581543,149.956634521484 -9.63972282409668,149.960784912109 -9.6369457244873,149.982727050781 -9.63138771057129,150.008880615234 -9.63138771057129,150.049133300781 -9.67944526672363,150.051361083984 -9.68416595458984,150.053314208984 -9.68888854980469,150.056915283203 -9.70999908447266,150.056915283203 -9.71527671813965,150.055541992188 -9.72055435180664,150.051910400391 -9.72416687011719,149.988861083984 -9.75111198425293,149.926635742188 -9.76944541931152,149.863586425781 -9.78222274780273,149.857452392578 -9.78277778625488,149.852752685547 -9.78222274780273,149.841644287109 -9.77944564819336,149.835510253906 -9.77888870239258,149.808013916016 -9.7813892364502,149.769714355469 -9.7902774810791,149.764984130859 -9.79222297668457,149.739410400391 -9.80777740478516,149.727172851562 -9.81583404541016,149.720245361328 -9.82277679443359,149.717468261719 -9.82666587829
 59,149.716369628906 -9.83222198486328,149.717468261719 -9.83749961853027,149.721069335938 -9.84749984741211,149.723022460938 -9.85249900817871,149.76220703125 -9.90166664123535,149.873840332031 -10.0169448852539,149.914154052734 -10.0488891601562,149.926635742188 -10.0569438934326,149.935516357422 -10.0616655349731,149.982727050781 -10.081111907959,149.98828125 -10.0825004577637,149.994415283203 -10.0819444656372,150.003326416016 -10.0772228240967,150.013610839844 -10.0736103057861,150.019714355469 -10.073055267334,150.184143066406 -10.0933322906494,150.189147949219 -10.0952777862549,150.236358642578 -10.1283321380615,150.259704589844 -10.1527786254883,150.29052734375 -10.1830558776855,150.298583984375 -10.1883344650269,150.308319091797 -10.1924991607666,150.352752685547 -10.1999988555908,150.382171630859 -10.2047214508057,150.400268554688 -10.2072219848633,150.579681396484 -10.2411098480225,150.61328125 -10.2755565643311,150.618011474609 -10.2775001525879,150.63525390625 -1
 0.280834197998,150.641357421875 -10.2813892364502,150.647491455078 -10.280834197998,150.775543212891 -10.2613906860352,150.780548095703 -10.2591667175293,150.803588867188 -10.2486095428467,150.815521240234 -10.2397212982178,150.81884765625 -10.2363872528076,150.824981689453 -10.2316665649414,150.829681396484 -10.2294454574585,150.844116210938 -10.2247219085693,150.862731933594 -10.2227764129639,150.869415283203 -10.2227764129639,150.877746582031 -10.2283334732056,150.878295898438 -10.2316665649414,150.870788574219 -10.2377777099609,150.861907958984 -10.2424983978271,150.727752685547 -10.3125,150.641937255859 -10.3494434356689,150.636383056641 -10.3508319854736,150.631072998047 -10.3508319854736,150.602172851562 -10.3502769470215,150.596069335938 -10.3494434356689,150.547485351562 -10.3355560302734,150.496063232422 -10.3186111450195,150.438568115234 -10.3036117553711,150.421905517578 -10.3011112213135,150.415802001953 -10.3002777099609,150.406372070312 -10.3044452667236,150.3
 69110107422 -10.3219451904297,150.358306884766 -10.3313884735107,150.356353759766 -10.3361110687256,150.348571777344 -10.3758316040039,150.346618652344 -10.3875007629395,150.352172851562 -10.3952789306641,150.356903076172 -10.3975009918213,150.568572998047 -10.4627780914307,150.6494140625 -10.4755554199219,150.657745361328 -10.4811115264893,150.663299560547 -10.4891662597656,150.689971923828 -10.5502777099609,150.691925048828 -10.5550003051758,150.691345214844 -10.5611114501953,150.688568115234 -10.5652770996094,150.680267333984 -10.5774993896484,150.675537109375 -10.5794448852539,150.568023681641 -10.6219444274902,150.556365966797 -10.6238880157471,150.522766113281 -10.6191654205322,150.492736816406 -10.6191654205322,150.481628417969 -10.6219444274902,150.477447509766 -10.6244430541992,150.47412109375 -10.6277770996094,150.44384765625 -10.6588897705078,150.428314208984 -10.6877784729004,150.424133300781 -10.6905555725098,150.369964599609 -10.6872215270996,150.268585205078 -
 10.6886119842529,150.209686279297 -10.7005558013916,150.113006591797 -10.6674995422363,150.099975585938 -10.6575012207031,150.059417724609 -10.6258316040039,150.028045654297 -10.5894432067871,150.016937255859 -10.5733337402344,150.013031005859 -10.5705547332764,150.007476806641 -10.5691661834717,149.91552734375 -10.5577774047852,149.898590087891 -10.5597229003906,149.896362304688 -10.5625,149.893585205078 -10.5633344650269,149.888305664062 -10.5619449615479,149.862182617188 -10.5544452667236,149.852752685547 -10.5502777099609,149.850524902344 -10.5469455718994,149.875244140625 -10.5100002288818,149.878570556641 -10.5066680908203,149.883331298828 -10.5044460296631,149.901916503906 -10.5025005340576,149.942474365234 -10.5025005340576,149.964416503906 -10.5025005340576,149.968292236328 -10.5052795410156,149.971069335938 -10.5094451904297,149.97802734375 -10.5161113739014,149.989685058594 -10.5180568695068,150.016937255859 -10.5113906860352,150.022491455078 -10.5100002288818,150
 .031372070312 -10.5052795410156,150.039703369141 -10.5,150.078857421875 -10.4627780914307,150.064422607422 -10.4561100006104,149.990234375 -10.4372215270996,149.866363525391 -10.3980560302734,149.806091308594 -10.3677768707275,149.785522460938 -10.3583335876465,149.758026123047 -10.3461112976074,149.747741699219 -10.3427772521973,149.723846435547 -10.3394432067871,149.683868408203 -10.3380546569824,149.6640625 -10.3398141860962)),((152.004425048828 -2.67000007629395,151.972747802734 -2.66888904571533,151.961090087891 -2.66805553436279,151.957733154297 -2.66472196578979,151.955535888672 -2.65999984741211,151.953582763672 -2.64833354949951,151.954406738281 -2.64222240447998,151.958312988281 -2.63249969482422,151.972747802734 -2.60583353042603,151.979675292969 -2.59888887405396,151.983856201172 -2.59611082077026,151.995239257812 -2.59555530548096,152.000823974609 -2.5969443321228,152.010528564453 -2.60111141204834,152.018585205078 -2.60638904571533,152.022216796875 -2.610000133
 5144,152.035247802734 -2.63111114501953,152.037200927734 -2.63583326339722,152.038024902344 -2.64222240447998,152.029693603516 -2.66111087799072,152.026916503906 -2.6652774810791,152.022216796875 -2.66750001907349,152.004425048828 -2.67000007629395)),((151.959136962891 -2.84611082077026,151.946624755859 -2.84472227096558,151.941345214844 -2.84333324432373,151.937194824219 -2.8405556678772,151.931640625 -2.83249998092651,151.921905517578 -2.80777788162231,151.920806884766 -2.80222225189209,151.928863525391 -2.7186107635498,151.9296875 -2.71250009536743,151.932464599609 -2.70833349227905,151.939147949219 -2.70833349227905,151.944702148438 -2.70972204208374,151.985778808594 -2.72499990463257,151.989959716797 -2.72749996185303,151.996612548828 -2.7344446182251,152.006378173828 -2.74555540084839,152.009155273438 -2.74944448471069,152.009704589844 -2.75583362579346,152.011932373047 -2.79055595397949,152.011932373047 -2.81805562973022,152.009704589844 -2.82277774810791,152.00219726
 5625 -2.82888889312744,151.959136962891 -2.84611082077026)),((152.063873291016 -3.00222253799438,152.059143066406 -3,152.035247802734 -2.98277759552002,152.0283203125 -2.97555541992188,151.960510253906 -2.88722229003906,151.959686279297 -2.8808331489563,151.959686279297 -2.86861085891724,151.960510253906 -2.86250019073486,151.963287353516 -2.85833358764648,151.973571777344 -2.84805536270142,151.978302001953 -2.84611082077026,151.984954833984 -2.84611082077026,152.072204589844 -2.92138910293579,152.078857421875 -2.9283332824707,152.083862304688 -2.93694448471069,152.087188720703 -2.9472222328186,152.089141845703 -2.95888900756836,152.088562011719 -2.96527767181396,152.086639404297 -2.96999979019165,152.073577880859 -2.99805545806885,152.069976806641 -3.00138902664185,152.063873291016 -3.00222253799438)),((150.773590087891 -2.98555564880371,150.768035888672 -2.9844446182251,150.766082763672 -2.97944402694702,150.773040771484 -2.97249984741211,150.788024902344 -2.96027803421021
 ,150.795532226562 -2.95416688919067,150.870788574219 -2.91249990463257,150.879119873047 -2.9088888168335,150.903045654297 -2.90833330154419,150.908599853516 -2.90833330154419,150.913299560547 -2.91027784347534,150.941345214844 -2.9219446182251,151.021087646484 -2.96305561065674,151.023590087891 -2.96722221374512,151.021636962891 -2.9719443321228,151.003875732422 -2.98166656494141,150.999114990234 -2.98361110687256,150.992736816406 -2.9844446182251,150.882446289062 -2.9686107635498,150.872192382812 -2.96527767181396,150.855804443359 -2.9622220993042,150.838012695312 -2.95972204208374,150.831909179688 -2.96027803421021,150.773590087891 -2.98555564880371)),((152.640808105469 -3.23000001907349,152.636108398438 -3.2277774810791,152.605224609375 -3.20388889312744,152.577178955078 -3.17722225189209,152.538879394531 -3.1061110496521,152.537475585938 -3.10055589675903,152.537475585938 -3.09499979019165,152.539428710938 -3.09027767181396,152.553863525391 -3.07055568695068,152.55801391
 6016 -3.06777811050415,152.590240478516 -3.05194425582886,152.599700927734 -3.04805564880371,152.606079101562 -3.04722261428833,152.640258789062 -3.04305553436279,152.644989013672 -3.04527807235718,152.648590087891 -3.04861116409302,152.667755126953 -3.12944412231445,152.668853759766 -3.14861106872559,152.668853759766 -3.15527772903442,152.667755126953 -3.16083335876465,152.654693603516 -3.21638870239258,152.6533203125 -3.22166633605957,152.646362304688 -3.22861099243164,152.640808105469 -3.23000001907349)),((153.343292236328 -3.41666650772095,153.265258789062 -3.40722227096558,153.262481689453 -3.40444421768188,153.263885498047 -3.39888906478882,153.269989013672 -3.39277791976929,153.301635742188 -3.36944437026978,153.333587646484 -3.37138891220093,153.337188720703 -3.375,153.346069335938 -3.38666677474976,153.348022460938 -3.39138889312744,153.347473144531 -3.39750003814697,153.345245361328 -3.41194438934326,153.343292236328 -3.41666650772095)),((154.818572998047 -3.530277
 72903442,154.795257568359 -3.44138860702515,154.794708251953 -3.43249988555908,154.796081542969 -3.4283332824707,154.799407958984 -3.42500019073486,154.825531005859 -3.4713888168335,154.830261230469 -3.48027753829956,154.833862304688 -3.50416707992554,154.833038330078 -3.51027822494507,154.818572998047 -3.53027772903442)),((153.242462158203 -3.49944448471069,153.237182617188 -3.49805545806885,153.211090087891 -3.48861122131348,153.206909179688 -3.48583316802979,153.192474365234 -3.47277736663818,153.19384765625 -3.4686107635498,153.197204589844 -3.46527767181396,153.220520019531 -3.44888877868652,153.22412109375 -3.4466667175293,153.22802734375 -3.44555521011353,153.233581542969 -3.4466667175293,153.239959716797 -3.45444440841675,153.255554199219 -3.47972202301025,153.259704589844 -3.48916673660278,153.26025390625 -3.49527788162231,153.258331298828 -3.49888896942139,153.242462158203 -3.49944448471069)),((153.639434814453 -4.14083385467529,153.634429931641 -4.13861179351807,1
 53.588012695312 -4.10583305358887,153.585235595703 -4.10194396972656,153.584411621094 -4.09583377838135,153.585235595703 -4.08944416046143,153.587188720703 -4.0847225189209,153.602172851562 -4.05888843536377,153.629669189453 -4.0313892364502,153.633880615234 -4.0286111831665,153.653045654297 -4.02055549621582,153.658599853516 -4.01916694641113,153.662750244141 -4.02194499969482,153.664703369141 -4.02666664123535,153.671630859375 -4.08000087738037,153.672210693359 -4.08611106872559,153.671630859375 -4.10472202301025,153.670257568359 -4.10999965667725,153.650268554688 -4.1380558013916,153.645538330078 -4.14027786254883,153.639434814453 -4.14083385467529)),((145.057739257812 -4.13527774810791,145.050811767578 -4.13527774810791,145.041351318359 -4.13249969482422,145.037200927734 -4.13000011444092,145.031646728516 -4.12166595458984,145.027770996094 -4.11222171783447,145.0263671875 -4.10666656494141,145.022216796875 -4.07666683197021,145.0263671875 -4.06694507598877,145.0316467285
 16 -4.05888843536377,145.036651611328 -4.05666637420654,145.06884765625 -4.04500007629395,145.079132080078 -4.04777812957764,145.095520019531 -4.05888843536377,145.101623535156 -4.06638813018799,145.107177734375 -4.07527828216553,145.110504150391 -4.09222221374512,145.109954833984 -4.09833335876465,145.094696044922 -4.12444400787354,145.092193603516 -4.12833309173584,145.088012695312 -4.13138866424561,145.083312988281 -4.13333320617676,145.057739257812 -4.13527774810791)),((150.74609375 -6.13554954528809,150.729675292969 -6.14666748046875,150.724975585938 -6.14861106872559,150.707183837891 -6.15555572509766,150.668853759766 -6.16833305358887,150.663879394531 -6.16916656494141,150.661102294922 -6.16499996185303,150.659149169922 -6.15333366394043,150.657196044922 -6.14861106872559,150.652191162109 -6.14666748046875,150.63525390625 -6.14861106872559,150.509704589844 -6.23499965667725,150.484954833984 -6.25833415985107,150.480255126953 -6.26722240447998,150.473571777344 -6.27388
 954162598,150.468566894531 -6.2761116027832,150.406372070312 -6.29305553436279,150.400268554688 -6.29361152648926,150.222747802734 -6.28833293914795,150.211639404297 -6.2761116027832,150.188293457031 -6.25833415985107,150.184143066406 -6.25555610656738,150.180816650391 -6.25500011444092,150.170532226562 -6.25694465637207,150.080810546875 -6.28000068664551,150.038879394531 -6.29916667938232,150.018310546875 -6.32361125946045,150.016387939453 -6.30388832092285,150.014434814453 -6.29916667938232,150.010803222656 -6.29583358764648,149.98828125 -6.27722263336182,149.984130859375 -6.2747220993042,149.978576660156 -6.27333354949951,149.972473144531 -6.27388954162598,149.894989013672 -6.29249954223633,149.889709472656 -6.29249954223633,149.847198486328 -6.29249954223633,149.844421386719 -6.29249954223633,149.842193603516 -6.29249954223633,149.686645507812 -6.30527782440186,149.634704589844 -6.30805492401123,149.609405517578 -6.29249954223633,149.605224609375 -6.28972244262695,149.57
 4981689453 -6.26500034332275,149.571624755859 -6.26166725158691,149.555236816406 -6.22694492340088,149.539428710938 -6.19777774810791,149.510803222656 -6.15277767181396,149.489410400391 -6.12611103057861,149.482452392578 -6.11944389343262,149.467468261719 -6.10972213745117,149.444976806641 -6.09805583953857,149.341339111328 -6.06083297729492,149.335784912109 -6.05944442749023,149.311920166016 -6.05722236633301,149.289978027344 -6.06277751922607,149.163879394531 -6.11250019073486,149.138580322266 -6.14861106872559,149.131072998047 -6.15472221374512,149.119415283203 -6.15694427490234,149.069427490234 -6.16416645050049,149.063018798828 -6.16499996185303,149.056915283203 -6.16416645050049,149.052185058594 -6.16222190856934,149.049407958984 -6.15805530548096,149.048034667969 -6.15277767181396,149.048034667969 -6.14583396911621,149.050262451172 -6.14111137390137,149.054962158203 -6.13916683197021,149.061096191406 -6.13833332061768,149.067199707031 -6.14583396911621,149.07135009765
 6 -6.14861106872559,149.075531005859 -6.14583396911621,149.079681396484 -6.13638877868652,149.078857421875 -6.11944389343262,149.071899414062 -6.09277820587158,149.055541992188 -6.04444408416748,149.039978027344 -6.03694438934326,148.983032226562 -6.01972198486328,148.942474365234 -6.00833415985107,148.920654296875 -6.00002384185791,148.882995605469 -5.98166465759277,148.878814697266 -5.94748497009277,148.876068115234 -5.9436616897583,148.764434814453 -5.86499118804932,148.704650878906 -5.84858131408691,148.699554443359 -5.84745788574219,148.589721679688 -5.82837104797363,148.528045654297 -5.82837104797363,148.401672363281 -5.78336238861084,148.391967773438 -5.77940940856934,148.3876953125 -5.77660369873047,148.366607666016 -5.75592136383057,148.359771728516 -5.74921321868896,148.339324951172 -5.7143726348877,148.330780029297 -5.69515228271484,148.323089599609 -5.67537689208984,148.321655273438 -5.66980838775635,148.316467285156 -5.62802600860596,148.354675292969 -5.50166702
 270508,148.358001708984 -5.49277782440186,148.359954833984 -5.48805522918701,148.370239257812 -5.4777774810791,148.378570556641 -5.47249984741211,148.428588867188 -5.45111179351807,148.450531005859 -5.45527839660645,148.504699707031 -5.48333263397217,148.511657714844 -5.48999977111816,148.519714355469 -5.50250053405762,148.618286132812 -5.50500011444092,148.883605957031 -5.49694442749023,148.961639404297 -5.47361087799072,148.973297119141 -5.47166633605957,148.985778808594 -5.47305583953857,149.000823974609 -5.47833347320557,149.122192382812 -5.52416706085205,149.126892089844 -5.5261116027832,149.189147949219 -5.55833339691162,149.209686279297 -5.57194519042969,149.2138671875 -5.57472229003906,149.216064453125 -5.57944488525391,149.220764160156 -5.60611152648926,149.270812988281 -5.59444427490234,149.310516357422 -5.58611106872559,149.425537109375 -5.56722259521484,149.549133300781 -5.53861141204834,149.566925048828 -5.52888870239258,149.581909179688 -5.52333354949951,149.61
 1358642578 -5.51861095428467,149.668304443359 -5.51944446563721,149.680541992188 -5.55416679382324,149.680541992188 -5.561110496521,149.685516357422 -5.56305503845215,149.692199707031 -5.56305503845215,149.710784912109 -5.5625,149.875244140625 -5.5363883972168,149.880798339844 -5.53499984741211,149.887481689453 -5.53166675567627,149.916381835938 -5.51194477081299,149.928588867188 -5.50361156463623,149.956085205078 -5.47638893127441,149.964416503906 -5.46416664123535,149.981353759766 -5.4333324432373,149.984130859375 -5.42249965667725,149.983581542969 -5.41638851165771,149.981353759766 -5.41166687011719,149.97802734375 -5.40833377838135,149.973297119141 -5.4061107635498,149.954132080078 -5.40472221374512,149.950531005859 -5.40138912200928,149.923034667969 -5.36055564880371,149.917755126953 -5.35222244262695,149.918304443359 -5.34611129760742,149.928588867188 -5.31527709960938,149.934692382812 -5.30722236633301,150.002777099609 -5.16944408416748,150.015533447266 -5.05749988555
 908,150.019714355469 -5.04777812957764,150.029968261719 -5.03083324432373,150.034149169922 -5.02805614471436,150.0888671875 -5.00777816772461,150.095794677734 -5.00777816772461,150.121337890625 -5.00972270965576,150.126617431641 -5.01111125946045,150.154693603516 -5.02388954162598,150.181640625 -5.03888893127441,150.19384765625 -5.04722213745117,150.199401855469 -5.05527782440186,150.203582763672 -5.0649995803833,150.204956054688 -5.07055568695068,150.203582763672 -5.07583332061768,150.184143066406 -5.09833335876465,150.180816650391 -5.10194396972656,150.164428710938 -5.11277770996094,150.154693603516 -5.11694431304932,150.132720947266 -5.12222194671631,150.101348876953 -5.13194370269775,150.091644287109 -5.13583374023438,150.082733154297 -5.14138889312744,150.072479248047 -5.15166664123535,150.064422607422 -5.16388893127441,150.061645507812 -5.17472171783447,150.04248046875 -5.3086109161377,150.062194824219 -5.36388874053955,150.121337890625 -5.51250076293945,150.1232910156
 25 -5.51722240447998,150.143859863281 -5.5377779006958,150.164428710938 -5.55138874053955,150.178863525391 -5.55749988555908,150.184143066406 -5.55888843536377,150.282196044922 -5.57055568695068,150.291076660156 -5.57055568695068,150.296630859375 -5.569167137146,150.300811767578 -5.56638813018799,150.306915283203 -5.55888843536377,150.318023681641 -5.54194450378418,150.319976806641 -5.53722190856934,150.323303222656 -5.53361129760742,150.326904296875 -5.53027820587158,150.345245361328 -5.51472282409668,150.412475585938 -5.45861148834229,150.422760009766 -5.45527839660645,150.488555908203 -5.44694423675537,150.511108398438 -5.4505558013916,150.574127197266 -5.47638893127441,150.578308105469 -5.47916698455811,150.595520019531 -5.4961109161377,150.601623535156 -5.51722240447998,150.611083984375 -5.54194450378418,150.61328125 -5.54666709899902,150.616058349609 -5.55083274841309,150.624114990234 -5.55611038208008,150.644134521484 -5.55694389343262,150.677917480469 -5.551299095153
 81,150.693298339844 -5.54749965667725,150.698852539062 -5.54611110687256,150.914154052734 -5.4908332824707,150.924407958984 -5.48722171783447,150.979125976562 -5.44499969482422,151.003051757812 -5.42111110687256,151.011383056641 -5.4088888168335,151.015533447266 -5.39944458007812,151.018859863281 -5.38916683197021,151.023040771484 -5.37277698516846,151.023040771484 -5.3658332824707,151.018310546875 -5.34333324432373,151.018310546875 -5.33666706085205,151.018859863281 -5.33027839660645,151.0244140625 -5.28805541992188,151.028594970703 -5.27166652679443,151.038879394531 -5.24111080169678,151.046936035156 -5.22194480895996,151.066070556641 -5.18583297729492,151.071075439453 -5.17694473266602,151.084686279297 -5.1563892364502,151.096923828125 -5.14277839660645,151.26220703125 -4.98638820648193,151.266387939453 -4.98388862609863,151.357452392578 -4.94749927520752,151.441070556641 -4.93666648864746,151.513610839844 -4.93805503845215,151.604675292969 -4.96805572509766,151.608856201
 172 -4.97083377838135,151.614959716797 -4.97000026702881,151.641082763672 -4.95499992370605,151.648590087891 -4.94888877868652,151.654144287109 -4.94083309173584,151.676086425781 -4.90805530548096,151.684417724609 -4.88890266418457,151.687744140625 -4.86499977111816,151.682189941406 -4.81444454193115,151.658325195312 -4.61638832092285,151.630798339844 -4.50638961791992,151.62744140625 -4.49749946594238,151.598022460938 -4.43805503845215,151.592468261719 -4.43000030517578,151.588287353516 -4.42722225189209,151.547210693359 -4.35999965667725,151.501373291016 -4.23916625976562,151.5 -4.23388862609863,151.5 -4.22694492340088,151.503326416016 -4.21666622161865,151.508331298828 -4.20777797698975,151.511657714844 -4.20444488525391,151.536926269531 -4.18194389343262,151.783050537109 -4.20583343505859,151.841918945312 -4.22472190856934,151.852172851562 -4.22833347320557,151.857727050781 -4.23638820648193,151.859680175781 -4.24111080169678,151.861083984375 -4.24666690826416,151.863861
 083984 -4.27138900756836,151.869964599609 -4.28555583953857,151.878295898438 -4.29805564880371,151.884429931641 -4.30555534362793,151.895263671875 -4.3149995803833,151.904144287109 -4.32000064849854,151.9638671875 -4.33555603027344,151.969421386719 -4.33694458007812,151.974975585938 -4.33694458007812,151.984405517578 -4.33277797698975,151.991912841797 -4.32666683197021,152.138580322266 -4.20444488525391,152.141357421875 -4.20027828216553,152.145538330078 -4.19083309173584,152.150817871094 -4.17555522918701,152.153594970703 -4.16472244262695,152.153594970703 -4.15777778625488,152.156372070312 -4.15388870239258,152.161926269531 -4.14833354949951,152.166076660156 -4.14555549621582,152.171356201172 -4.14416694641113,152.177764892578 -4.14500045776367,152.185241699219 -4.14888954162598,152.214691162109 -4.16611099243164,152.235229492188 -4.2072229385376,152.239410400391 -4.21666622161865,152.2421875 -4.2344446182251,152.2421875 -4.24111080169678,152.240783691406 -4.24666690826416
 ,152.238006591797 -4.24805545806885,152.226898193359 -4.25083351135254,152.202453613281 -4.24666690826416,152.198303222656 -4.24388885498047,152.195526123047 -4.23999977111816,152.194122314453 -4.2344446182251,152.194122314453 -4.22749996185303,152.192749023438 -4.22222232818604,152.189971923828 -4.21805572509766,152.186645507812 -4.21472263336182,152.181640625 -4.21527767181396,152.176910400391 -4.21749973297119,152.172760009766 -4.22694492340088,152.16943359375 -4.24388885498047,152.170806884766 -4.28222274780273,152.171356201172 -4.28833293914795,152.172210693359 -4.29333305358887,152.174133300781 -4.29666709899902,152.1796875 -4.30472183227539,152.186645507812 -4.31166648864746,152.190521240234 -4.31444454193115,152.195526123047 -4.31638813018799,152.263885498047 -4.33500003814697,152.286651611328 -4.33972263336182,152.305236816406 -4.34166717529297,152.355804443359 -4.34305572509766,152.401641845703 -4.61083316802979,152.403045654297 -4.62305545806885,152.405242919922 -
 4.66888904571533,152.405822753906 -4.68888854980469,152.394989013672 -4.76111125946045,152.389434814453 -4.78305530548096,152.386108398438 -4.79333305358887,152.336090087891 -4.87527751922607,152.333312988281 -4.87916660308838,152.294128417969 -4.92916679382324,152.268035888672 -4.95777797698975,152.241333007812 -4.9844446182251,152.233306884766 -4.98999977111816,152.161102294922 -5.00694465637207,152.157196044922 -5.00694465637207,152.123565673828 -4.99944400787354,152.112457275391 -4.99666690826416,152.088562011719 -4.98638820648193,152.083038330078 -4.98499965667725,152.050262451172 -4.97972202301025,151.996612548828 -4.97277736663818,151.990509033203 -4.97222232818604,151.984954833984 -4.97361087799072,151.978302001953 -4.98027801513672,151.974975585938 -4.98388862609863,151.970794677734 -4.993332862854,151.968017578125 -5.0041675567627,151.966644287109 -5.02333354949951,151.964691162109 -5.10472202301025,151.969970703125 -5.14833354949951,151.97412109375 -5.157777786254
 88,151.979675292969 -5.16583347320557,151.993286132812 -5.17555522918701,152.069427490234 -5.23499965667725,152.07275390625 -5.23833274841309,152.118011474609 -5.29222202301025,152.124114990234 -5.29972171783447,152.129669189453 -5.30777740478516,152.144134521484 -5.34138870239258,152.145538330078 -5.34666728973389,152.147491455078 -5.36388874053955,152.144134521484 -5.37416648864746,152.131072998047 -5.40222263336182,152.123565673828 -5.41638851165771,152.096069335938 -5.4572229385376,151.972747802734 -5.53111171722412,151.968566894531 -5.53361129760742,151.841918945312 -5.59722232818604,151.825531005859 -5.60111141204834,151.818572998047 -5.60111141204834,151.808319091797 -5.5977783203125,151.779418945312 -5.58555603027344,151.771362304688 -5.58000087738037,151.759155273438 -5.55138874053955,151.752777099609 -5.54388904571533,151.748565673828 -5.54111099243164,151.705535888672 -5.53111171722412,151.699401855469 -5.53027820587158,151.491638183594 -5.52833366394043,151.47329
 7119141 -5.53027820587158,151.467742919922 -5.53166675567627,151.459411621094 -5.53583335876465,151.454132080078 -5.54111099243164,151.44384765625 -5.58555603027344,151.444427490234 -5.59166717529297,151.402770996094 -5.75137805938721,151.384704589844 -5.80720043182373,151.317779541016 -5.84993076324463,151.165649414062 -5.95807075500488,151.003051757812 -6.02250003814697,150.940795898438 -6.0286111831665,150.855804443359 -6.04083347320557,150.811920166016 -6.07638931274414,150.812744140625 -6.08944416046143,150.793304443359 -6.11805534362793,150.775543212891 -6.13916683197021,150.771636962891 -6.14166736602783,150.74609375 -6.13554954528809)),((154.153869628906 -4.44222164154053,154.128570556641 -4.3841667175293,154.126617431641 -4.37944412231445,154.128021240234 -4.37388896942139,154.132720947266 -4.37166595458984,154.140808105469 -4.37055492401123,154.150543212891 -4.37444400787354,154.152770996094 -4.37944412231445,154.1533203125 -4.3855562210083,154.155242919922 -4.4380
 5503845215,154.153869628906 -4.44222164154053)),((145.951354980469 -4.76444530487061,145.944427490234 -4.76444530487061,145.93359375 -4.76194477081299,145.918579101562 -4.75638961791992,145.898590087891 -4.74194431304932,145.891662597656 -4.73527717590332,145.875244140625 -4.69694423675537,145.873840332031 -4.69138813018799,145.872467041016 -4.67249965667725,145.873840332031 -4.66694450378418,145.892486572266 -4.6094446182251,145.8994140625 -4.59583377838135,145.904693603516 -4.58777809143066,145.914978027344 -4.57750034332275,145.966369628906 -4.53305530548096,145.970520019531 -4.53027820587158,145.975250244141 -4.52833366394043,145.981628417969 -4.52750015258789,146.011657714844 -4.5494441986084,146.026916503906 -4.56166648864746,146.053588867188 -4.5963888168335,146.055541992188 -4.60138893127441,146.054138183594 -4.66138935089111,146.04052734375 -4.70916652679443,146.037750244141 -4.71333408355713,146.027465820312 -4.72361087799072,146.019989013672 -4.72972202301025,145.
 994415283203 -4.74555492401123,145.961639404297 -4.76111125946045,145.951354980469 -4.76444530487061)),((159.513305664062 -4.58166694641113,159.511383056641 -4.57666683197021,159.515533447266 -4.53972244262695,159.518859863281 -4.5363883972168,159.522216796875 -4.55083274841309,159.523040771484 -4.56388854980469,159.519714355469 -4.57388973236084,159.516937255859 -4.57805633544922,159.513305664062 -4.58166694641113)),((149.552459716797 -4.72083377838135,149.546356201172 -4.72027778625488,149.475799560547 -4.71138954162598,149.470245361328 -4.71000003814697,149.465515136719 -4.70777797698975,149.461364746094 -4.70527839660645,149.457733154297 -4.70166683197021,149.455810546875 -4.69694423675537,149.454406738281 -4.68472194671631,149.455810546875 -4.67916679382324,149.468017578125 -4.66416645050049,149.506652832031 -4.64777851104736,149.512756347656 -4.64694499969482,149.518859863281 -4.64777851104736,149.529968261719 -4.65055561065674,149.540252685547 -4.65388870239258,149.54
 3579101562 -4.65722274780273,149.549133300781 -4.66555595397949,149.559967041016 -4.68194389343262,149.563293457031 -4.69222164154053,149.564147949219 -4.70527839660645,149.562744140625 -4.71055603027344,149.560516357422 -4.71527767181396,149.557189941406 -4.7188892364502,149.552459716797 -4.72083377838135)),((146.240509033203 -4.85805511474609,146.234405517578 -4.85750007629395,146.215789794922 -4.85138893127441,146.2119140625 -4.84861087799072,146.201629638672 -4.83833312988281,146.199401855469 -4.83361148834229,146.198028564453 -4.82805633544922,146.200256347656 -4.81638813018799,146.202178955078 -4.81166648864746,146.215789794922 -4.79111099243164,146.219970703125 -4.78833293914795,146.232177734375 -4.78833293914795,146.238555908203 -4.79055595397949,146.241333007812 -4.79333305358887,146.256927490234 -4.81166648864746,146.262481689453 -4.81972217559814,146.263885498047 -4.82527828216553,146.263885498047 -4.83083343505859,146.261932373047 -4.83555603027344,146.2508239746
 09 -4.85472202301025,146.246612548828 -4.85750007629395,146.240509033203 -4.85805511474609)),((149.152191162109 -4.92361068725586,149.133026123047 -4.91555595397949,149.128845214844 -4.9127779006958,149.122741699219 -4.90527820587158,149.118560791016 -4.89555549621582,149.118011474609 -4.88944435119629,149.119415283203 -4.8841667175293,149.122192382812 -4.88138866424561,149.156921386719 -4.86694431304932,149.161926269531 -4.86638832092285,149.165802001953 -4.86777782440186,149.175537109375 -4.87805557250977,149.178314208984 -4.88194370269775,149.181640625 -4.89222240447998,149.178863525391 -4.89638900756836,149.156921386719 -4.92305564880371,149.152191162109 -4.92361068725586)),((154.63720703125 -5.45861148834229,154.618011474609 -5.43138885498047,154.5869140625 -5.34472274780273,154.565795898438 -5.27666664123535,154.5302734375 -5.13388919830322,154.532196044922 -5.12222194671631,154.541076660156 -5.10388851165771,154.546630859375 -5.09555530548096,154.558319091797 -5.08000
 087738037,154.598846435547 -5.03083324432373,154.605529785156 -5.02388954162598,154.620513916016 -5.01861095428467,154.63916015625 -5.01638889312744,154.646087646484 -5.01638889312744,154.6513671875 -5.01777839660645,154.658874511719 -5.02388954162598,154.665802001953 -5.03083324432373,154.671356201172 -5.03888893127441,154.726898193359 -5.19722175598145,154.728302001953 -5.20277786254883,154.728302001953 -5.21638870239258,154.69384765625 -5.41833305358887,154.692474365234 -5.42388916015625,154.687194824219 -5.43194389343262,154.675537109375 -5.44083309173584,154.63720703125 -5.45861148834229)),((147.135528564453 -5.45111179351807,147.121887207031 -5.44444370269775,147.009979248047 -5.35499954223633,147.008026123047 -5.3502779006958,147.002471923828 -5.30388832092285,147.008026123047 -5.25888919830322,147.009979248047 -5.24722194671631,147.013610839844 -5.23833274841309,147.017761230469 -5.23555564880371,147.109405517578 -5.19333267211914,147.121063232422 -5.19111061096191,1
 47.128570556641 -5.19194412231445,147.134979248047 -5.19527721405029,147.191070556641 -5.248610496521,147.211639404297 -5.26916694641113,147.228851318359 -5.36388874053955,147.229949951172 -5.42111110687256,147.224670410156 -5.42944431304932,147.220520019531 -5.43194389343262,147.158874511719 -5.44833278656006,147.1533203125 -5.44972133636475,147.135528564453 -5.45111179351807)),((147.596618652344 -5.36305522918701,147.591918945312 -5.36111068725586,147.567199707031 -5.33916664123535,147.563873291016 -5.33583354949951,147.561645507812 -5.33111190795898,147.560516357422 -5.31888961791992,147.561645507812 -5.31333351135254,147.563873291016 -5.3086109161377,147.57080078125 -5.30166625976562,147.583038330078 -5.29361152648926,147.591918945312 -5.2902774810791,147.602172851562 -5.28805541992188,147.609130859375 -5.28805541992188,147.620788574219 -5.2902774810791,147.625518798828 -5.29222202301025,147.628845214844 -5.29555511474609,147.640533447266 -5.31666660308838,147.6427612304
 69 -5.3216667175293,147.643310546875 -5.32777786254883,147.642761230469 -5.33388900756836,147.640533447266 -5.3386116027832,147.626892089844 -5.35222244262695,147.602172851562 -5.3619441986084,147.596618652344 -5.36305522918701)),((148.114685058594 -5.4688892364502,148.087463378906 -5.45527839660645,148.079132080078 -5.44972133636475,148.077178955078 -5.44499969482422,148.073028564453 -5.43000030517578,148.071624755859 -5.4244441986084,148.072204589844 -5.41833305358887,148.084686279297 -5.38972282409668,148.090789794922 -5.38222217559814,148.099700927734 -5.3774995803833,148.117462158203 -5.3841667175293,148.122192382812 -5.38638877868652,148.136657714844 -5.39944458007812,148.139434814453 -5.40333366394043,148.143585205078 -5.41305541992188,148.144989013672 -5.41833305358887,148.145538330078 -5.43833255767822,148.143585205078 -5.44972133636475,148.138031005859 -5.45805549621582,148.133880615234 -5.46083354949951,148.125793457031 -5.4661111831665,148.120788574219 -5.4683332
 4432373,148.114685058594 -5.4688892364502)),((155.404083251953 -6,155.41552734375 -6.07638931274414,155.418853759766 -6.08666706085205,155.428588867188 -6.11111068725586,155.430541992188 -6.1158332824707,155.432739257812 -6.12083339691162,155.477172851562 -6.16916656494141,155.490783691406 -6.18277740478516,155.499114990234 -6.18805503845215,155.562744140625 -6.21749973297119,155.577178955078 -6.22361087799072,155.582733154297 -6.22500038146973,155.5888671875 -6.22416687011719,155.614959716797 -6.22000026702881,155.767761230469 -6.35583305358887,155.772491455078 -6.35777759552002,155.795257568359 -6.36250019073486,155.809692382812 -6.36861038208008,155.813598632812 -6.37138843536377,155.832733154297 -6.39861106872559,155.909698486328 -6.51222229003906,155.917755126953 -6.52444458007812,155.921905517578 -6.53416633605957,155.965789794922 -6.70555591583252,155.967193603516 -6.71111106872559,155.967742919922 -6.71722221374512,155.966644287109 -6.72277736663818,155.948028564453
 -6.77583312988281,155.940521240234 -6.78861141204834,155.918579101562 -6.80777740478516,155.913024902344 -6.80916595458984,155.909698486328 -6.80555534362793,155.908874511719 -6.7994441986084,155.890533447266 -6.77972221374512,155.860778808594 -6.77500057220459,155.854675292969 -6.77444458007812,155.848571777344 -6.77500057220459,155.823852539062 -6.77777767181396,155.816375732422 -6.78055572509766,155.775268554688 -6.81444454193115,155.748565673828 -6.84249973297119,155.742462158203 -6.84999942779541,155.719696044922 -6.875,155.713012695312 -6.88194370269775,155.707458496094 -6.88333320617676,155.69384765625 -6.88333320617676,155.623840332031 -6.868332862854,155.558868408203 -6.85249996185303,155.4921875 -6.83027839660645,155.47802734375 -6.82416725158691,155.444976806641 -6.80916595458984,155.342742919922 -6.74361133575439,155.3388671875 -6.74111080169678,155.335235595703 -6.73750019073486,155.239959716797 -6.62249946594238,155.192749023438 -6.56055545806885,155.2016296386
 72 -6.53472232818604,155.207183837891 -6.53472232818604,155.2099609375 -6.53055572509766,155.216064453125 -6.51638889312744,155.224975585938 -6.47749996185303,155.232452392578 -6.44416618347168,155.233306884766 -6.43805503845215,155.233306884766 -6.4244441986084,155.230529785156 -6.36305522918701,155.226348876953 -6.34694480895996,155.218841552734 -6.32916736602783,155.214141845703 -6.32027816772461,155.204406738281 -6.3086109161377,155.190795898438 -6.29500007629395,155.187194824219 -6.29166698455811,155.174987792969 -6.28333282470703,155.127746582031 -6.2761116027832,155.101623535156 -6.27722263336182,155.063293457031 -6.25694561004639,154.994110107422 -6.21666622161865,154.981628417969 -6.20861148834229,154.972198486328 -6.19777774810791,154.969970703125 -6.19277763366699,154.888580322266 -6.07916736602783,154.880249023438 -6.07361125946045,154.823577880859 -6.02805614471436,154.755645751953 -5.95617389678955,154.746643066406 -5.94450378417969,154.744384765625 -5.93978023
 529053,154.700469970703 -5.78020095825195,154.698577880859 -5.76851844787598,154.699432373047 -5.7623987197876,154.71826171875 -5.6700611114502,154.753601074219 -5.51805591583252,154.79052734375 -5.47916698455811,154.794128417969 -5.48250007629395,154.882446289062 -5.54333305358887,154.920806884766 -5.54999923706055,154.961090087891 -5.54666709899902,154.967468261719 -5.54611110687256,155.073577880859 -5.56166648864746,155.162353515625 -5.73234081268311,155.216064453125 -5.86872386932373,155.268798828125 -5.88423919677734,155.277679443359 -5.88895511627197,155.365020751953 -5.95777797698975,155.371643066406 -5.96472263336182,155.400543212891 -5.99583339691162,155.404083251953 -6)),((147.990478515625 -5.85603713989258,147.983520507812 -5.82075119018555,147.982116699219 -5.81519317626953,147.974609375 -5.79546737670898,147.972381591797 -5.79074478149414,147.968475341797 -5.78796863555908,147.945220947266 -5.77992534637451,147.93359375 -5.7777099609375,147.927490234375 -5.77854
 824066162,147.922790527344 -5.78049659729004,147.865112304688 -5.74775314331055,147.802154541016 -5.67277145385742,147.793273925781 -5.66138458251953,147.769958496094 -5.62221908569336,147.766052246094 -5.61277484893799,147.765228271484 -5.60666275024414,147.761108398438 -5.52833366394043,147.761932373047 -5.5222225189209,147.7802734375 -5.49416637420654,147.783874511719 -5.4908332824707,147.814697265625 -5.48472213745117,147.841918945312 -5.48999977111816,147.852172851562 -5.49361133575439,148.008605957031 -5.57611179351807,148.020812988281 -5.58416652679443,148.040802001953 -5.59861087799072,148.044128417969 -5.60194396972656,148.065307617188 -5.62758445739746,148.074279785156 -5.64482402801514,148.078460693359 -5.65427875518799,148.080444335938 -5.66595458984375,148.078552246094 -5.69124603271484,148.076629638672 -5.70347595214844,148.072540283203 -5.72654151916504,148.067840576172 -5.74905109405518,148.061492919922 -5.77711772918701,148.057586669922 -5.78656482696533,148
 .017150878906 -5.84463882446289,148.000762939453 -5.85269927978516,147.990478515625 -5.85603713989258)),((149.048034667969 -6.09555530548096,149.043304443359 -6.09333324432373,149.043853759766 -6.0886116027832,149.045257568359 -6.0872220993042,149.054138183594 -6.08388900756836,149.058319091797 -6.08666706085205,149.057739257812 -6.09138870239258,149.053588867188 -6.09416675567627,149.048034667969 -6.09555530548096)),((143.994415283203 -7.82583332061768,143.984680175781 -7.8230562210083,143.943572998047 -7.80277729034424,143.934692382812 -7.79805564880371,143.923583984375 -7.78861141204834,143.91748046875 -7.78111171722412,143.914703369141 -7.77694511413574,143.877746582031 -7.7186107635498,143.875793457031 -7.71388912200928,143.877166748047 -7.7097225189209,143.88134765625 -7.70694446563721,143.886657714844 -7.70833396911621,143.959411621094 -7.74222183227539,143.966918945312 -7.74833297729492,143.979125976562 -7.76333427429199,144.000549316406 -7.78999996185303,144.0080261
 23047 -7.80277729034424,144.009429931641 -7.80833339691162,144.008605957031 -7.81416606903076,144.006652832031 -7.819167137146,143.999694824219 -7.82444477081299,143.994415283203 -7.82583332061768)),((145.193572998047 -7.86722183227539,145.186645507812 -7.86722183227539,145.182464599609 -7.86444473266602,145.180541992188 -7.86111068725586,145.177764892578 -7.83666706085205,145.178314208984 -7.83055591583252,145.182464599609 -7.82777786254883,145.185241699219 -7.83055591583252,145.191345214844 -7.84083366394043,145.197479248047 -7.85499954223633,145.198852539062 -7.86055564880371,145.197479248047 -7.86444473266602,145.193572998047 -7.86722183227539)),((143.727752685547 -8.10222244262695,143.697479248047 -8.08444404602051,143.683319091797 -8.07833290100098,143.661376953125 -8.07277679443359,143.618011474609 -8.07222175598145,143.599700927734 -8.07416725158691,143.588562011719 -8.0716667175293,143.582458496094 -8.06416702270508,143.569427490234 -8.04305648803711,143.56607055664
 1 -8.03277778625488,143.565246582031 -8.02000045776367,143.568023681641 -8.01583480834961,143.574127197266 -8.01388931274414,143.629669189453 -8.00638961791992,143.635803222656 -8.00583457946777,143.642761230469 -8.00583457946777,143.651092529297 -8.00833511352539,143.66943359375 -8.0172233581543,143.682464599609 -8.02472305297852,143.697479248047 -8.03694534301758,143.707733154297 -8.04722213745117,143.731079101562 -8.0716667175293,143.737182617188 -8.07888793945312,143.739959716797 -8.08305549621582,143.741333007812 -8.0886116027832,143.739410400391 -8.09333229064941,143.733306884766 -8.10083198547363,143.727752685547 -8.10222244262695)),((143.66552734375 -8.17611122131348,143.654968261719 -8.17250061035156,143.625518798828 -8.15416717529297,143.621612548828 -8.15166664123535,143.618835449219 -8.14750099182129,143.607727050781 -8.13055419921875,143.604949951172 -8.11972045898438,143.604400634766 -8.11361122131348,143.604949951172 -8.10888862609863,143.609130859375 -8.10610
 961914062,143.636657714844 -8.09249877929688,143.642211914062 -8.09055519104004,143.654968261719 -8.0897216796875,143.679138183594 -8.09333229064941,143.688568115234 -8.09722137451172,143.700256347656 -8.10610961914062,143.707183837891 -8.11277770996094,143.710510253906 -8.11638832092285,143.716064453125 -8.12444305419922,143.718841552734 -8.13527870178223,143.719421386719 -8.15500068664551,143.7119140625 -8.16111183166504,143.702453613281 -8.1652774810791,143.683319091797 -8.1733341217041,143.677764892578 -8.17472267150879,143.66552734375 -8.17611122131348)),((143.685791015625 -8.24722099304199,143.659973144531 -8.241943359375,143.654418945312 -8.24055480957031,143.650268554688 -8.23777770996094,143.648315429688 -8.23305511474609,143.648864746094 -8.22694396972656,143.651641845703 -8.19972229003906,143.666656494141 -8.19305610656738,143.726898193359 -8.17388916015625,143.733306884766 -8.17472267150879,143.737182617188 -8.17722320556641,143.755828857422 -8.20527839660645,143
 .756378173828 -8.20861053466797,143.755249023438 -8.21388816833496,143.752471923828 -8.21805572509766,143.7421875 -8.22833251953125,143.734680175781 -8.23444366455078,143.718841552734 -8.23916625976562,143.697479248047 -8.24527740478516,143.685791015625 -8.24722099304199)),((143.687194824219 -8.43972206115723,143.680541992188 -8.43972206115723,143.670257568359 -8.43638801574707,143.651641845703 -8.42749977111816,143.630523681641 -8.40722274780273,143.610504150391 -8.38611221313477,143.584411621094 -8.3577766418457,143.607177734375 -8.33277702331543,143.612731933594 -8.33388900756836,143.653045654297 -8.34222221374512,143.658599853516 -8.3436107635498,143.66552734375 -8.34749984741211,143.672210693359 -8.35444450378418,143.677764892578 -8.36249923706055,143.692199707031 -8.39583396911621,143.694976806641 -8.40666770935059,143.698303222656 -8.42361068725586,143.698303222656 -8.43027877807617,143.696929931641 -8.43555641174316,143.692749023438 -8.43833351135254,143.687194824219
  -8.43972206115723)),((143.57275390625 -8.49388885498047,143.559143066406 -8.49388885498047,143.509155273438 -8.48250007629395,143.498016357422 -8.47972106933594,143.493286132812 -8.4777774810791,143.354949951172 -8.41805648803711,143.318572998047 -8.39305686950684,143.315795898438 -8.38888931274414,143.314422607422 -8.38361167907715,143.314422607422 -8.37666511535645,143.319427490234 -8.36916542053223,143.326904296875 -8.3630542755127,143.331634521484 -8.36111068725586,143.339141845703 -8.35833358764648,143.342742919922 -8.3577766418457,143.356353759766 -8.3577766418457,143.494689941406 -8.3630542755127,143.573577880859 -8.37194442749023,143.578308105469 -8.37388801574707,143.581085205078 -8.37805557250977,143.616058349609 -8.46277809143066,143.616058349609 -8.4688892364502,143.613861083984 -8.47360992431641,143.610504150391 -8.47694396972656,143.583862304688 -8.49138832092285,143.578857421875 -8.49333190917969,143.57275390625 -8.49388885498047)),((143.632446289062 -8.73444
 366455078,143.60107421875 -8.6924991607666,143.585784912109 -8.67972183227539,143.487731933594 -8.62888717651367,143.3671875 -8.54472351074219,143.278869628906 -8.51027870178223,143.269989013672 -8.50555610656738,143.252777099609 -8.49527740478516,143.240509033203 -8.48722076416016,143.182189941406 -8.42972183227539,143.180816650391 -8.42416763305664,143.18359375 -8.42000007629395,143.211639404297 -8.4152774810791,143.217742919922 -8.41611099243164,143.227447509766 -8.42611122131348,143.233032226562 -8.43444442749023,143.251373291016 -8.45666694641113,143.261657714844 -8.46694374084473,143.274688720703 -8.47444343566895,143.324676513672 -8.48583221435547,143.371337890625 -8.49388885498047,143.422760009766 -8.51083374023438,143.467193603516 -8.52777862548828,143.644134521484 -8.66472244262695,143.647491455078 -8.66805648803711,143.651641845703 -8.67777824401855,143.653045654297 -8.68305587768555,143.653594970703 -8.68916702270508,143.653045654297 -8.7005558013916,143.64135742
 1875 -8.72972106933594,143.638031005859 -8.73305511474609,143.632446289062 -8.73444366455078)),((151.144439697266 -8.8305549621582,151.094970703125 -8.7711124420166,151.10107421875 -8.63888931274414,151.05859375 -8.55166625976562,151.052459716797 -8.55222320556641,151.034698486328 -8.55222320556641,151.029144287109 -8.55083274841309,151.003051757812 -8.54277801513672,150.999694824219 -8.53944396972656,150.997741699219 -8.53472328186035,150.996917724609 -8.52861213684082,150.997741699219 -8.52250099182129,151.024993896484 -8.46694374084473,151.033325195312 -8.45472145080566,151.054412841797 -8.43499946594238,151.062744140625 -8.42972183227539,151.076354980469 -8.42611122131348,151.118286132812 -8.42000007629395,151.124969482422 -8.42000007629395,151.124969482422 -8.42555618286133,151.123840332031 -8.62472152709961,151.103302001953 -8.72916603088379,151.102447509766 -8.741943359375,151.103851318359 -8.7541675567627,151.107177734375 -8.76444625854492,151.144439697266 -8.8305549
 621582)),((152.835510253906 -9.23555564880371,152.829956054688 -9.22333335876465,152.679962158203 -9.09055519104004,152.6533203125 -9.06972122192383,152.649139404297 -9.06694412231445,152.573028564453 -9.02027893066406,152.563598632812 -9.01611137390137,152.556640625 -9.01611137390137,152.540252685547 -9.02027893066406,152.499694824219 -9.02500152587891,152.497741699219 -9.02166748046875,152.5244140625 -8.99305534362793,152.527770996094 -8.98972129821777,152.532470703125 -8.98777770996094,152.619689941406 -8.96138954162598,152.625793457031 -8.96055603027344,152.647216796875 -8.96138954162598,152.8046875 -8.96944427490234,152.810241699219 -8.97083282470703,152.814971923828 -8.97277641296387,152.93359375 -9.04388999938965,152.937744140625 -9.04666709899902,152.952758789062 -9.05888938903809,153.017761230469 -9.11777687072754,153.020538330078 -9.12166595458984,153.019989013672 -9.12638854980469,153.002777099609 -9.16500091552734,152.997192382812 -9.17305564880371,152.9930114746
 09 -9.17583274841309,152.98828125 -9.17777824401855,152.982177734375 -9.17722320556641,152.835510253906 -9.23555564880371)),((150.334411621094 -9.52666664123535,150.310241699219 -9.5261116027832,150.193023681641 -9.45388793945312,150.180816650391 -9.44555473327637,150.173858642578 -9.43888854980469,150.110778808594 -9.37277603149414,150.108306884766 -9.36861038208008,150.103302001953 -9.33694458007812,150.102752685547 -9.33083343505859,150.104125976562 -9.31861114501953,150.106903076172 -9.30777740478516,150.123291015625 -9.2630558013916,150.126068115234 -9.26027870178223,150.143859863281 -9.24555397033691,150.189147949219 -9.21111106872559,150.198028564453 -9.20777702331543,150.206909179688 -9.2055549621582,150.2138671875 -9.2055549621582,150.232177734375 -9.20777702331543,150.326904296875 -9.26916694641113,150.330810546875 -9.27194595336914,150.333038330078 -9.27666664123535,150.376892089844 -9.38333320617676,150.37744140625 -9.38944435119629,150.363006591797 -9.4874992370
 6055,150.344696044922 -9.51666641235352,150.339141845703 -9.52472305297852,150.334411621094 -9.52666664123535)),((150.846923828125 -9.71805572509766,150.844116210938 -9.68555641174316,150.801635742188 -9.65861129760742,150.763305664062 -9.66250038146973,150.691345214844 -9.66333389282227,150.661102294922 -9.66333389282227,150.654968261719 -9.66250038146973,150.622741699219 -9.65388870239258,150.514434814453 -9.62333297729492,150.490509033203 -9.58361053466797,150.427459716797 -9.44083404541016,150.423309326172 -9.43138885498047,150.419982910156 -9.41472244262695,150.419982910156 -9.4011116027832,150.421905517578 -9.38944435119629,150.426086425781 -9.37666511535645,150.435791015625 -9.35916519165039,150.442474365234 -9.35499954223633,150.473571777344 -9.33888816833496,150.478851318359 -9.33749961853027,150.481628417969 -9.33694458007812,150.487731933594 -9.33749961853027,150.498840332031 -9.34027671813965,150.505554199219 -9.34222221374512,150.5302734375 -9.35166549682617,150
 .571350097656 -9.37055397033691,150.598022460938 -9.38500022888184,150.618011474609 -9.39777946472168,150.624969482422 -9.40444564819336,150.63525390625 -9.42194557189941,150.639434814453 -9.42472267150879,150.666656494141 -9.43833351135254,150.676910400391 -9.4416675567627,150.683044433594 -9.44083404541016,150.731903076172 -9.42805671691895,150.7421875 -9.42472267150879,150.746063232422 -9.42138862609863,150.748291015625 -9.41805648803711,150.754974365234 -9.40444564819336,150.760528564453 -9.40444564819336,150.765258789062 -9.4063892364502,150.777770996094 -9.41472244262695,150.804412841797 -9.43277740478516,150.828308105469 -9.45638847351074,150.885803222656 -9.52083396911621,150.888031005859 -9.52555656433105,150.931915283203 -9.64166831970215,150.932464599609 -9.64777946472168,150.930541992188 -9.65916633605957,150.921630859375 -9.67083358764648,150.906646728516 -9.68277740478516,150.901092529297 -9.68138885498047,150.896362304688 -9.67416763305664,150.893585205078 -9.
 67194557189941,150.888580322266 -9.67138862609863,150.876892089844 -9.67749977111816,150.873565673828 -9.68083381652832,150.846923828125 -9.71805572509766)),((151.229125976562 -10.2011108398438,151.19775390625 -10.1727771759033,151.190246582031 -10.1669454574585,151.148315429688 -10.1472234725952,151.143585205078 -10.1452789306641,151.086639404297 -10.1269435882568,151.075805664062 -10.1244430541992,151.025817871094 -10.1141662597656,151.001647949219 -10.1108322143555,150.994964599609 -10.1108322143555,150.983306884766 -10.1127777099609,150.970245361328 -10.1122207641602,150.958587646484 -10.1102771759033,150.94970703125 -10.1055545806885,150.91552734375 -10.0041675567627,150.877746582031 -9.92666625976562,150.826904296875 -9.83888816833496,150.762481689453 -9.80500030517578,150.758605957031 -9.80249977111816,150.750274658203 -9.74833297729492,150.748840332031 -9.73083305358887,150.757202148438 -9.71194458007812,150.759979248047 -9.70777702331543,150.763885498047 -9.70499992
 370605,150.769439697266 -9.70666694641113,150.788024902344 -9.71944427490234,150.803039550781 -9.73138809204102,150.821624755859 -9.74694442749023,150.900268554688 -9.81916618347168,150.931915283203 -9.8488883972168,150.938873291016 -9.85583305358887,150.962738037109 -9.89361190795898,151.030548095703 -9.98527717590332,151.039428710938 -9.99694442749023,151.059967041016 -10.0169448852539,151.073028564453 -10.0244445800781,151.111358642578 -10.0447244644165,151.116058349609 -10.046667098999,151.122467041016 -10.0475006103516,151.136657714844 -10.041389465332,151.147216796875 -10.0325012207031,151.149139404297 -10.0277786254883,151.149719238281 -10.0219459533691,151.147766113281 -10.0169448852539,151.143585205078 -10.0088901519775,151.140808105469 -10.0050010681152,151.136657714844 -10.0022239685059,151.134704589844 -9.99749946594238,151.134704589844 -9.9908332824707,151.138031005859 -9.98749923706055,151.184143066406 -9.94472312927246,151.192199707031 -9.93944358825684,151.20
 0531005859 -9.93666648864746,151.26416015625 -9.91972160339355,151.281372070312 -9.9233341217041,151.284149169922 -9.92722320556641,151.298583984375 -9.95083236694336,151.299133300781 -9.96249961853027,151.296356201172 -9.97305488586426,151.271087646484 -10.0616655349731,151.252471923828 -10.0974998474121,151.246337890625 -10.1047210693359,151.243560791016 -10.1088886260986,151.234130859375 -10.1330547332764,151.221618652344 -10.1708335876465,151.221618652344 -10.1816673278809,151.222473144531 -10.1877784729004,151.223846435547 -10.1930561065674,151.229125976562 -10.2011108398438)),((150.880523681641 -10.6527786254883,150.856353759766 -10.6494445800781,150.794128417969 -10.6394443511963,150.785247802734 -10.6347236633301,150.769439697266 -10.6111106872559,150.767486572266 -10.6075000762939,150.788024902344 -10.5463886260986,150.790802001953 -10.5422229766846,150.794708251953 -10.539722442627,150.798858642578 -10.5383338928223,150.868835449219 -10.5383338928223,150.8749694824
 22 -10.5388889312744,150.892211914062 -10.547779083252,150.900268554688 -10.5530548095703,150.904418945312 -10.5625,150.894989013672 -10.6466665267944,150.892211914062 -10.6508331298828,150.880523681641 -10.6527786254883)),((150.927185058594 -10.6838893890381,150.923034667969 -10.6825008392334,150.920257568359 -10.6783332824707,150.911926269531 -10.65944480896,150.909973144531 -10.6547222137451,150.909149169922 -10.6419448852539,150.909973144531 -10.6358337402344,150.91943359375 -10.6130542755127,150.922210693359 -10.6088886260986,150.9296875 -10.6030540466309,150.934692382812 -10.6008319854736,150.94970703125 -10.59694480896,151.016082763672 -10.5908336639404,151.064147949219 -10.5922222137451,151.066925048828 -10.5947227478027,151.06884765625 -10.5980548858643,151.069702148438 -10.6111106872559,151.063293457031 -10.6438903808594,151.049133300781 -10.6702785491943,151.042205810547 -10.676944732666,151.036651611328 -10.6783332824707,151.031372070312 -10.676944732666,151.0099
 79248047 -10.6683330535889,151.008026123047 -10.6636123657227,151.003875732422 -10.6472234725952,151.001647949219 -10.6427783966064,150.994110107422 -10.6366672515869,150.988861083984 -10.6352787017822,150.941345214844 -10.6347236633301,150.936096191406 -10.6347236633301,150.929138183594 -10.6547222137451,150.927185058594 -10.6838893890381)),((152.744415283203 -10.7166652679443,152.702453613281 -10.7066669464111,152.686920166016 -10.7019443511963,152.573852539062 -10.6569442749023,152.564971923828 -10.6522235870361,152.544982910156 -10.6380558013916,152.541656494141 -10.6338901519775,152.540802001953 -10.6305541992188,152.542205810547 -10.6277770996094,152.555236816406 -10.6230554580688,152.562194824219 -10.6230554580688,152.573852539062 -10.6252765655518,152.614959716797 -10.6386127471924,152.690246582031 -10.6627788543701,152.693023681641 -10.6627788543701,152.759429931641 -10.6372222900391,152.784973144531 -10.6211109161377,152.790252685547 -10.6197204589844,152.814971923
 828 -10.6291656494141,152.870513916016 -10.6580562591553,152.873291015625 -10.6622219085693,152.873840332031 -10.6683330535889,152.873291015625 -10.6730556488037,152.870513916016 -10.676944732666,152.863586425781 -10.6825008392334,152.844970703125 -10.6952781677246,152.814971923828 -10.6966667175293,152.744415283203 -10.7166652679443)),((153.210510253906 -11.2858333587646,153.181640625 -11.2522239685059,153.143859863281 -11.2247219085693,153.13916015625 -11.2227764129639,153.120513916016 -11.2166652679443,153.114959716797 -11.2152767181396,153.106079101562 -11.2147216796875,153.093292236328 -11.2019443511963,153.091064453125 -11.1972217559814,153.093841552734 -11.1930561065674,153.102172851562 -11.1888885498047,153.112457275391 -11.1844444274902,153.123840332031 -11.1849994659424,153.12939453125 -11.1863880157471,153.198028564453 -11.2172222137451,153.2138671875 -11.2247219085693,153.222747802734 -11.2294454574585,153.251373291016 -11.2469444274902,153.250579833984 -11.25,15
 3.25 -11.2522239685059,153.241058349609 -11.2688903808594,153.210510253906 -11.2858333587646)),((154.112182617188 -11.4397220611572,154.106628417969 -11.4397220611572,154.062744140625 -11.4330558776855,154.058013916016 -11.4308338165283,154.006652832031 -11.3872222900391,154.003326416016 -11.3838901519775,154.021087646484 -11.3488883972168,154.089691162109 -11.3152770996094,154.153869628906 -11.3141670227051,154.225250244141 -11.3194446563721,154.268310546875 -11.338888168335,154.276641845703 -11.344165802002,154.286376953125 -11.3605556488037,154.288299560547 -11.3649997711182,154.297760009766 -11.3919448852539,154.289703369141 -11.4108333587646,154.285522460938 -11.4136123657227,154.266387939453 -11.421667098999,154.263031005859 -11.4180555343628,154.26025390625 -11.4075012207031,154.256103515625 -11.4047222137451,154.250549316406 -11.4033336639404,154.190246582031 -11.3994445800781,154.137481689453 -11.3986110687256,154.134704589844 -11.4027786254883,154.112182617188 -11.
 4397220611572)),((153.566070556641 -11.6424999237061,153.522216796875 -11.602222442627,153.479125976562 -11.5733337402344,153.421356201172 -11.5686111450195,153.376068115234 -11.5672225952148,153.3671875 -11.557222366333,153.364410400391 -11.5530548095703,153.363861083984 -11.5472221374512,153.376068115234 -11.5269451141357,153.382446289062 -11.5197219848633,153.38720703125 -11.5108337402344,153.388580322266 -11.5055561065674,153.387756347656 -11.5008344650269,153.384429931641 -11.4974994659424,153.325531005859 -11.4752769470215,153.276916503906 -11.4624996185303,153.271911621094 -11.4605560302734,153.268585205078 -11.4572219848633,153.190521240234 -11.3730554580688,153.188293457031 -11.3683319091797,153.187194824219 -11.3536109924316,153.187194824219 -11.3497219085693,153.198028564453 -11.3241672515869,153.200805664062 -11.3199996948242,153.220520019531 -11.3274993896484,153.291931152344 -11.3569431304932,153.398040771484 -11.4047222137451,153.413879394531 -11.4161109924316
 ,153.426910400391 -11.4302787780762,153.437744140625 -11.4397220611572,153.507751464844 -11.4724998474121,153.559143066406 -11.491943359375,153.570251464844 -11.494722366333,153.576354980469 -11.4955539703369,153.645538330078 -11.5150012969971,153.686645507812 -11.5269451141357,153.751098632812 -11.5644445419312,153.754425048828 -11.5680561065674,153.7763671875 -11.5974998474121,153.777770996094 -11.6027765274048,153.7763671875 -11.6080551147461,153.7744140625 -11.6130542755127,153.770812988281 -11.6163883209229,153.676361083984 -11.6283321380615,153.670257568359 -11.6277770996094,153.605804443359 -11.6174983978271,153.598846435547 -11.6174983978271,153.582458496094 -11.6283321380615,153.566070556641 -11.6424999237061)))
+  </op>
+</test>
+</case>
+</run>
Copied: trunk/tests/xmltester/tests/ticket/bug275.xml (from rev 3289, trunk/tests/xmltester/tests/bug275.xml)
--- trunk/tests/xmltester/tests/ticket/bug275.xml	                        (rev 0)
+++ trunk/tests/xmltester/tests/ticket/bug275.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -0,0 +1,31 @@
+<run>
+  <desc>
+http://trac.osgeo.org/geos/ticket/275
+  </desc>
+  <precisionModel type="FLOATING" />
+<case>
+  <desc>
+  </desc>
+  <a>
+MULTIPOLYGON (((97.4196581300587923 1391.7094503287939915, 1097.3929445351700451 1659.6432199333848985, 2097.6867783781326580 1391.5243492190379584, 2829.5979618286305595 659.3760732813996128, 3097.3929252677053228 -340.6343946513263745, 2829.3203546600025220 -1340.5704802618731719, 2566.4316545475776365 -1603.3983692935935323, 2589.9586987092807249 -1691.2539814346002913, 2550.3216026895242976 -1839.1041048139375107, 2582.0225141513105882 -1957.4828931887502677, 2523.0465473393464890 -2177.4688367911371643, 2361.9813735858801920 -2338.4967531528800464, 2141.9817920466971373 -2397.4218256316030420, 1921.9931199150225893 -2338.4560374338593647, 1915.5094890288899023 -2331.9715065100085667, 1790.8032356108271870 -2365.3730474120334293, 1773.3588004956532131 -2360.6972390794344392, 1755.9014460409671301 -2365.3730474120334293, 1535.9127739092928095 -2306.4072592142892972, 1470.0174606543544087 -2240.5027985744332000, 1267.8188705444704283 -2294.6600223925997852, 1145.5500718010
 853234 -2750.7342254735290226, 779.4928666591022193 -3116.7067547270667092, 279.4938285436001593 -3250.6273710942414255, -220.4804154644647269 -3116.6142190040254718, -276.8825358097809044 -3060.2042690896628301, -317.8708072633123720 -3042.4487397531365787, -317.0081043084857697 -3040.4572078632113517, -353.9188796380849453 -3025.9673133506230442, -481.8759722620623052 -2952.0780561800302166, -597.3916747239470624 -2859.9435764086629206, -697.8857092860117746 -2751.6218846962374300, -781.1133376604859677 -2629.5325659449085833, -845.2155017965442312 -2496.4027329581699632, -881.7734250743712892 -2377.8616075414415718, -883.2163026251768088 -2378.2274205979942963, -915.6765245378969666 -2250.1944686487954641, -958.6488338256679071 -2176.6893024190303549, -958.3104527203266798 -2176.4914793507796276, -961.3773376604859777 -2171.9925659449086197, -1025.4795017965443549 -2038.8627329581699996, -1069.0243497161841333 -1897.6661108397263433, -1091.0392188351402183 -1751.556612805
 9626863, -1091.0323623564322588 -1603.7978911310922285, -1089.6762878232161711 -1594.8034867385058533, -1104.6051239273215288 -1541.4387753320572756, -1142.1697554404233870 -1500.9481685832554376, -1144.1735018958338514 -1502.8286850026515822, -1237.9475018958337387 -1402.9096850026517131, -1235.9437554404232742 -1401.0291685832553412, -1283.8694719642787732 -1349.3704336840412452, -1284.3641704239839783 -1349.7723644815778243, -1285.2860836559341351 -1348.6376690100614724, -1338.3270735958196838 -1329.0603190321844522, -1337.4416005745254097 -1326.6613035542172838, -1425.0218796380850108 -1292.2803133506229187, -1552.9789722620623706 -1218.3910561800300911, -1668.4946747239471279 -1126.2565764086627951, -1679.3254791566805579 -1114.5821415641194108, -1680.0605373265407252 -1115.3491207030931491, -1702.7503708819851909 -1093.6036172334481762, -1770.9343685341837045 -1058.4171540195427497, -1770.1722772833329600 -1056.9403807575390601, -1874.5379722620623397 -996.674056180030
 1066, -1895.7478836933294133 -979.7571858838782646, -1896.7182978644157174 -981.0996960943623435, -2746.6499049371641377 -366.7388744659292570, -2763.2967822031337164 -362.2768436281256186, -2790.5987539714260492 -334.9710818839997160, -2790.5987539714260492 -334.9710818839996023, -2842.3952978644156246 -297.5306960943622698, -2841.4248836933293205 -296.1881858838783614, -2935.7306747239472315 -220.9705764086628506, -3036.2247092860116027 -112.6488846962375874, -3086.2207836436286925 -39.3080148699587753, -3129.2862482014747911 3.7634279033554208, -3145.0472131318642823 62.5968530737783055, -3145.0472131318642823 62.5968530737785258, -3183.5545017965441730 142.5702670418300499, -3227.0993497161844061 283.7668891602737631, -3249.1142188351404911 429.8763871940373633, -3249.1132358283407484 451.0604139114426516, -3263.2299989295852356 503.7562690975839246, -3249.1083453730552719 556.4508704679574294, -3249.1073623564325317 577.6351088689078779, -3227.0789334334317573 723.74256
 31523476568, -3183.5209817488726003 864.9351434214565870, -3145.0063950996932363 944.9047260716176879, -3129.2399803399048324 1003.7367132380807107, -3086.1705453954227778 1046.8041554447745511, -3036.1675038980588397 1120.1406209104106892, -2935.6634168207938274 1228.4529856651729460, -2820.1391641855243506 1320.5767444414277634, -2801.7930339334729979 1331.1685093202834196, -2763.2166432025555878 1369.7431151977043555, -2710.5214060758321466 1383.8623258961499687, -2692.1752147154593331 1394.4541260546511694, -2554.6299030180371119 1448.4349291985654418, -2410.5755828783944708 1481.3133830416004457, -2322.0627096881689795 1487.9463092123467050, -2263.2300000000000182 1503.7100000000000364, -2204.3990753125572155 1487.9409523895812981, -2115.7029639281322488 1481.2860169705504632, -1971.6547489328795564 1448.3808253636827885, -1834.1194591345197296 1394.3744929749309449, -1815.7587157038797159 1383.7697470828661608, -1763.0830830785189391 1369.6505646428263390, -1724.513755
 0381382425 1331.0687426030108327, -1706.1692244587284222 1320.4733608833789731, -1685.0325693031700212 1303.6117095115282609, -1684.0647021355841844 1304.9506960943622289, -798.3848875647835257 664.7497975144585780, -668.7086314658160973 597.8301540195427606, -669.4687336638634179 596.3572351253640136, -653.9962840476707697 587.4207017476531973, -634.6270161446395832 659.6966464095463607, 97.4196581300587923 1391.7094503287939915)))
+  </a>
+  <b>
+POLYGON ((-3138.9918179090095691 39.9929298181513317, -3195.9318721744207323 131.7765582775780331, -3194.3605115562841092 132.7513874532058367, -3212.0423376604862824 158.6894340550911124, -3276.1445017965443185 291.8192670418299599, -3319.6893497161845517 433.0158891602736730, -3341.7042188351406367 579.1253871940372164, -3341.7041685876552037 580.2082322725017320, -3341.7842797495400191 580.2023206768839145, -3358.7842797495400191 810.5783206768840046, -3358.7041685876552037 810.5842322725018221, -3358.6973623564326772 957.2601088689078779, -3336.6689334334319028 1103.3675631523476568, -3293.1109817488727458 1244.5601434214565870, -3260.5234971247000431 1312.2230153808816340, -3296.6374455479131029 1414.0631037763496352, -3294.8380822260414789 1414.7011836840215437, -3328.7143497161841879 1524.5468891602736221, -3349.7012648829327190 1663.8340056869151340, -3350.1912493926529351 1663.7938778131951949, -3510.7782493926529241 3624.6538778131953222, -3510.2882648829327081 362
 4.6940056869152613, -3511.3162188351402619 3631.5163871940371791, -3511.3093623564318477 3779.2751088689078642, -3489.2809334334315281 3925.3825631523477568, -3445.7229817488723711 4066.5751434214562323, -3381.6084625862131361 4199.6990267427599974, -3298.3695038980586105 4321.7806209104110167, -3197.8654168207931434 4430.0929856651728187, -3082.3411641855241214 4522.2167444414280908, -2954.3772147154591039 4596.0941260546514968, -2816.8319030180368827 4650.0749291985657692, -2672.7775828783942416 4682.9533830416003184, -2592.0441774584969608 4689.0033359847420797, -2592.2292272141212379 4691.7359415891232857, 464.5127727858784965 4898.7359415891232857, 464.6978225415029442 4896.0033359847420797, 531.3099999999999454 4900.9950805664066138, 678.8370360718679422 4889.9260169705503358, 822.8852510671204072 4857.0208253636828886, 832.4966505855577452 4853.2466926456381771, 832.7155347673275401 4853.9304792686480141, 3440.9455347673278993 4019.0204792686481596, 3440.7266505855582
 182 4018.3366926456378678, 3568.6505408654807070 3968.1044929749309631, 3696.6007755412720144 3894.2033608833789913, 3812.1079268348321420 3802.0581609104569907, 3912.5919080161379497 3693.7271431733465761, 3995.8082053600896870 3571.6301008898981308, 4059.8980139174327633 3438.4943193843760127, 4103.4297576971002854 3297.2936566327280161, 4111.9568486815251163 3240.6649172772094971, 4114.5449810944692217 3241.0993479430067055, 4438.8449810944684941 1309.0733479430066382, 4436.2568486815243887 1308.6389172772094298, 4449.7310668223972243 1219.1561161070862909, 4449.7104973863315536 1071.3973957048663124, 4427.6685088490185080 925.2919864301782127, 4384.0974537747060822 784.1034492265001745, 4319.9705801376658201 650.9855167172314623, 4236.7202918527709699 528.9116481847523801, 4136.2061531259496405 420.6086113205509491, 4020.6733513123099328 328.4955743328730478, 3892.7025460983149969 254.6300689133272499, 3755.1522252283625676 200.6620310892940324, 3611.0948543776285078 167
 .7969465530077287, 3463.7482473934069276 156.7689236912091246, 3316.4036898899316839 167.8242957839195242, 3172.3524217021254117 200.7161186505198884, 3034.8121203619148218 254.7096866493769767, 2920.2486381949101997 320.8647580300017808, 2829.5979618286305595 659.3760732813996128, 2485.1041348942267177 1003.9814942180254320, 2264.2788423241918281 2319.5541328332446938, 409.7273757065412383 2913.2071331414008455, -1458.2438853899545848 2786.7096887882385090, -1390.0104079583070416 1953.5395283355223910, -1308.4375544520867152 1723.5068962236503012, -1310.2333181418257482 1722.8700927968927772, -1276.3402423028999237 1612.9336566327281162, -1254.3389331776024846 1466.8221161070862308, -1254.3595026136681554 1319.0633957048662523, -1256.0639743336037100 1307.7652980846462469, -1255.2787938929561733 1307.6972329071288641, -1257.2316394637061876 1285.1697643588329356, -1227.2802423028999783 1188.0186566327281525, -1205.2789331776025392 1041.9071161070862672, -1205.29049195638299
 35 958.8756534762312640, -1684.0647021355841844 1304.9506960943622289, -1685.0325693031700212 1303.6117095115282609, -1706.1692244587284222 1320.4733608833789731, -1724.5137550381382425 1331.0687426030108327, -1763.0830830785189391 1369.6505646428263390, -1815.7587157038797159 1383.7697470828661608, -1834.1194591345197296 1394.3744929749309449, -1971.6547489328795564 1448.3808253636827885, -2115.7029639281322488 1481.2860169705504632, -2204.3990753125572155 1487.9409523895812981, -2263.2300000000000182 1503.7100000000000364, -2322.0627096881689795 1487.9463092123467050, -2410.5755828783944708 1481.3133830416004457, -2554.6299030180371119 1448.4349291985654418, -2692.1752147154593331 1394.4541260546511694, -2710.5214060758321466 1383.8623258961499687, -2763.2166432025555878 1369.7431151977043555, -2801.7930339334729979 1331.1685093202834196, -2820.1391641855243506 1320.5767444414277634, -2935.6634168207938274 1228.4529856651729460, -3036.1675038980588397 1120.1406209104106892
 , -3086.1705453954227778 1046.8041554447745511, -3129.2399803399048324 1003.7367132380807107, -3145.0063950996932363 944.9047260716176879, -3183.5209817488726003 864.9351434214565870, -3227.0789334334317573 723.7425631523476568, -3249.1073623564325317 577.6351088689078779, -3249.1083453730552719 556.4508704679574294, -3263.2299989295852356 503.7562690975839246, -3249.1132358283407484 451.0604139114426516, -3249.1142188351404911 429.8763871940373633, -3227.0993497161844061 283.7668891602737631, -3183.5545017965441730 142.5702670418300499, -3145.0472131318642823 62.5968530737785258, -3145.0472131318642823 62.5968530737783055, -3138.9918179090095691 39.9929298181513317))
+  </b>
+<test>
+  <op name="isValid" arg1="A">true</op>
+</test>
+<test>
+  <op name="isValid" arg1="B">true</op>
+</test>
+<test>
+ <op name="union" arg1="A" arg2="B">
+	POLYGON ((-3511.3162188351402619 3631.5163871940371791, -3511.3093623564318477 3779.2751088689078642, -3489.2809334334315281 3925.3825631523477568, -3445.7229817488723711 4066.5751434214562323, -3381.6084625862131361 4199.6990267427599974, -3298.3695038980586105 4321.7806209104110167, -3197.8654168207931434 4430.0929856651728187, -3082.3411641855241214 4522.2167444414280908, -2954.3772147154591039 4596.0941260546514968, -2816.8319030180368827 4650.0749291985657692, -2672.7775828783942416 4682.9533830416003184, -2592.0441774584969608 4689.0033359847420797, -2592.2292272141212379 4691.7359415891232857, 464.5127727858784965 4898.7359415891232857, 464.6978225415029442 4896.0033359847420797, 531.3099999999999454 4900.9950805664066138, 678.8370360718679422 4889.9260169705503358, 822.8852510671204072 4857.0208253636828886, 832.4966505855577452 4853.2466926456381771, 832.7155347673275401 4853.9304792686480141, 3440.9455347673278993 4019.0204792686481596, 3440.7266505855582182 4018.
 3366926456378678, 3568.6505408654807070 3968.1044929749309631, 3696.6007755412720144 3894.2033608833789913, 3812.1079268348321420 3802.0581609104569907, 3912.5919080161379497 3693.7271431733465761, 3995.8082053600896870 3571.6301008898981308, 4059.8980139174327633 3438.4943193843760127, 4103.4297576971002854 3297.2936566327280161, 4111.9568486815251163 3240.6649172772094971, 4114.5449810944692217 3241.0993479430067055, 4438.8449810944684941 1309.0733479430066382, 4436.2568486815243887 1308.6389172772094298, 4449.7310668223972243 1219.1561161070862909, 4449.7104973863315536 1071.3973957048663124, 4427.6685088490185080 925.2919864301782127, 4384.0974537747060822 784.1034492265001745, 4319.9705801376658201 650.9855167172314623, 4236.7202918527709699 528.9116481847523801, 4136.2061531259496405 420.6086113205509491, 4020.6733513123099328 328.4955743328730478, 3892.7025460983149969 254.6300689133272499, 3755.1522252283625676 200.6620310892940324, 3611.0948543776285078 167.79694655
 30077287, 3463.7482473934069276 156.7689236912091246, 3316.4036898899316839 167.8242957839195242, 3172.3524217021254117 200.7161186505198884, 3034.8121203619148218 254.7096866493769767, 2920.2486381949101997 320.8647580300017808, 3097.3929252677053228 -340.6343946513263745, 2829.3203546600025220 -1340.5704802618731719, 2566.4316545475776365 -1603.3983692935935323, 2589.9586987092807249 -1691.2539814346002913, 2550.3216026895242976 -1839.1041048139375107, 2582.0225141513105882 -1957.4828931887502677, 2523.0465473393464890 -2177.4688367911371643, 2361.9813735858801920 -2338.4967531528800464, 2141.9817920466971373 -2397.4218256316030420, 1921.9931199150225893 -2338.4560374338593647, 1915.5094890288899023 -2331.9715065100085667, 1790.8032356108271870 -2365.3730474120334293, 1773.3588004956532131 -2360.6972390794344392, 1755.9014460409671301 -2365.3730474120334293, 1535.9127739092928095 -2306.4072592142892972, 1470.0174606543544087 -2240.5027985744332000, 1267.8188705444704283 -2
 294.6600223925997852, 1145.5500718010853234 -2750.7342254735290226, 779.4928666591022193 -3116.7067547270667092, 279.4938285436001593 -3250.6273710942414255, -220.4804154644647269 -3116.6142190040254718, -276.8825358097809044 -3060.2042690896628301, -317.8708072633123720 -3042.4487397531365787, -317.0081043084857697 -3040.4572078632113517, -353.9188796380849453 -3025.9673133506230442, -481.8759722620623052 -2952.0780561800302166, -597.3916747239470624 -2859.9435764086629206, -697.8857092860117746 -2751.6218846962374300, -781.1133376604859677 -2629.5325659449085833, -845.2155017965442312 -2496.4027329581699632, -881.7734250743712892 -2377.8616075414415718, -883.2163026251768088 -2378.2274205979942963, -915.6765245378969666 -2250.1944686487954641, -958.6488338256679071 -2176.6893024190303549, -958.3104527203266798 -2176.4914793507796276, -961.3773376604859777 -2171.9925659449086197, -1025.4795017965443549 -2038.8627329581699996, -1069.0243497161841333 -1897.6661108397263433, -
 1091.0392188351402183 -1751.5566128059626863, -1091.0323623564322588 -1603.7978911310922285, -1089.6762878232161711 -1594.8034867385058533, -1104.6051239273215288 -1541.4387753320572756, -1142.1697554404233870 -1500.9481685832554376, -1144.1735018958338514 -1502.8286850026515822, -1237.9475018958337387 -1402.9096850026517131, -1235.9437554404232742 -1401.0291685832553412, -1283.8694719642787732 -1349.3704336840412452, -1284.3641704239839783 -1349.7723644815778243, -1285.2860836559341351 -1348.6376690100614724, -1338.3270735958196838 -1329.0603190321844522, -1337.4416005745254097 -1326.6613035542172838, -1425.0218796380850108 -1292.2803133506229187, -1552.9789722620623706 -1218.3910561800300911, -1668.4946747239471279 -1126.2565764086627951, -1679.3254791566805579 -1114.5821415641194108, -1680.0605373265407252 -1115.3491207030931491, -1702.7503708819851909 -1093.6036172334481762, -1770.9343685341837045 -1058.4171540195427497, -1770.1722772833329600 -1056.9403807575390601, -18
 74.5379722620623397 -996.6740561800301066, -1895.7478836933294133 -979.7571858838782646, -1896.7182978644157174 -981.0996960943623435, -2746.6499049371641377 -366.7388744659292570, -2763.2967822031337164 -362.2768436281256186, -2790.5987539714260492 -334.9710818839997160, -2790.5987539714260492 -334.9710818839996023, -2842.3952978644156246 -297.5306960943622698, -2841.4248836933293205 -296.1881858838783614, -2935.7306747239472315 -220.9705764086628506, -3036.2247092860116027 -112.6488846962375874, -3086.2207836436286925 -39.3080148699587753, -3129.2862482014747911 3.7634279033554208, -3138.9918179090095691 39.9929298181513317, -3195.9318721744207323 131.7765582775780331, -3194.3605115562841092 132.7513874532058367, -3212.0423376604862824 158.6894340550911124, -3276.1445017965443185 291.8192670418299599, -3319.6893497161845517 433.0158891602736730, -3341.7042188351406367 579.1253871940372164, -3341.7041685876552037 580.2082322725017320, -3341.7842797495400191 580.202320676883
 9145, -3358.7842797495400191 810.5783206768840046, -3358.7041685876552037 810.5842322725018221, -3358.6973623564326772 957.2601088689078779, -3336.6689334334319028 1103.3675631523476568, -3293.1109817488727458 1244.5601434214565870, -3260.5234971247000431 1312.2230153808816340, -3296.6374455479131029 1414.0631037763496352, -3294.8380822260414789 1414.7011836840215437, -3328.7143497161841879 1524.5468891602736221, -3349.7012648829327190 1663.8340056869151340, -3350.1912493926529351 1663.7938778131951949, -3510.7782493926529241 3624.6538778131953222, -3510.2882648829327081 3624.6940056869152613, -3511.3162188351402619 3631.5163871940371791), (-1458.2438853899545848 2786.7096887882385090, -1390.0104079583070416 1953.5395283355223910, -1308.4375544520867152 1723.5068962236503012, -1310.2333181418257482 1722.8700927968927772, -1276.3402423028999237 1612.9336566327281162, -1254.3389331776024846 1466.8221161070862308, -1254.3595026136681554 1319.0633957048662523, -1256.063974333603
 7100 1307.7652980846462469, -1255.2787938929561733 1307.6972329071288641, -1257.2316394637061876 1285.1697643588329356, -1227.2802423028999783 1188.0186566327281525, -1205.2789331776025392 1041.9071161070862672, -1205.2904919563829935 958.8756534762312640, -798.3848875647835257 664.7497975144585780, -668.7086314658160973 597.8301540195427606, -669.4687336638634179 596.3572351253640136, -653.9962840476707697 587.4207017476531973, -634.6270161446395832 659.6966464095463607, 97.4196581300587923 1391.7094503287939915, 1097.3929445351700451 1659.6432199333848985, 2097.6867783781326580 1391.5243492190379584, 2485.1041348942267177 1003.9814942180254320, 2264.2788423241918281 2319.5541328332446938, 409.7273757065412383 2913.2071331414008455, -1458.2438853899545848 2786.7096887882385090))
+ </op>
+</test>
+</case>
+</run>
Copied: trunk/tests/xmltester/tests/ticket/bug344.xml (from rev 3289, trunk/tests/xmltester/tests/bug344.xml)
--- trunk/tests/xmltester/tests/ticket/bug344.xml	                        (rev 0)
+++ trunk/tests/xmltester/tests/ticket/bug344.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -0,0 +1,22 @@
+<run>
+  <desc>
+    http://trac.osgeo.org/geos/ticket/344
+    Buffer operation uses a huge amount of memory
+  </desc>
+<case>
+  <desc>
+  </desc>
+  <a>
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
 B67CC96BCA8740C0DC8882748CDD51C08D316601C98740C0334399FC85DD51C0D56D9A88C88740C0BF277BF07FDD51C046F5317AC98740C0ABD5B21078DD51C04A0856D5CB8740C0CC7FA37870DD51C0544843D7CF8740C07AC6BE6463DD51C068C81DDBD78740C0B6DB2E3457DD51C05E49F25CDF8740C0A219D5334EDD51C0B5F2DC8CE48740C0673D21E035DD51C0F6B6990AF18740C01D4421B800DD51C07ED470DB088840C0010200000015000000BF7E880D16E051C031A5E48BAC8440C05578865F20E051C0F42D1801BA8440C0E692AAED26E051C0907758F2C28440C08F06A6892DE051C0A924FC9CCC8440C099E7D20932E051C0B891B245D28440C0552E54FE35E051C06EE7B11CD78440C02AD1483A39E051C0C063D3A5DA8440C0CABF3B9E3BE051C0C576F700DD8440C0696677923EE051C0160DBED5DF8440C03E096CCE41E051C01B20E230E28440C07D8A2D4E46E051C091D442C9E48440C0A58A3D0F49E051C06DF82702E68440C086C77E164BE051C0B90501E8E68440C0C57652BA4FE051C0E2506452E88440C0CF296D1654E051C09B1430CBE88440C0D9F62CBE57E051C09B1430CBE88440C0E3337E865CE051C04EAB329DE78440C0573B2FBA61E051C02560CF32E68440C0F63D8FF664E051C0B5F2DC8CE48440C0ED7CE47B6BE051C0F3C011EEDF8
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
 018CF8540C047AE9B525EDD51C0A1C5ADDDD18540C091589C7B59DD51C098384DFAD68540C001020000000300000091589C7B59DD51C098384DFAD68540C0B2A0302853DD51C0A1585D3DDD8540C0BA9D222C4FDD51C022B53F06E18540C0010200000003000000BA9D222C4FDD51C022B53F06E18540C0D31C0F6C4BDD51C0686F3A13E48540C081AE22484ADD51C05B79C9FFE48540C001020000000500000081AE22484ADD51C05B79C9FFE48540C0CA69F40F47DD51C04EAB329DE78540C021F6F87340DD51C0109546CCEC8540C0E2BCEE633BDD51C01AEFD819F08540C0C5F1327939DD51C096DC723FF18540C001020000000E000000C5F1327939DD51C096DC723FF18540C037B0B03B38DD51C090BDDEFDF18540C06ECFE27B35DD51C06C6BFAA2F38540C08FA7E5072EDD51C0528D4DE1F78540C0F7C9518028DD51C074CD89E2FA8540C0E6BD20D827DD51C0EB45A3F1FA8540C000F8F1E123DD51C0798489F5FC8540C0070CEDF71FDD51C0F58590F3FE8540C0F42FEEAB17DD51C022E417B9028640C0FADB549316DD51C08D806500038640C08070F4E711DD51C098987851058640C0C3C716380FDD51C074EA6FAE068640C041C120440DDD51C09DAB9CAC078640C0C563F5FD0ADD51C02B7AF18F088640C001020000000D000000C563F5FD0ADD51C02B7AF18F
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
 C51C0EDF549496A8540C09A4EA1A90DDC51C0F1F9BC3D638540C0AF44A0FA07DC51C021054F21578540C0828DEBDFF5DB51C02018F66A368540C059A65F22DEDB51C02E84E6841A8540C034D8D479D4DB51C0D39FFD48118540C0DDC6B0D4C4DB51C0DD4C3BEB098540C09E769DB2BFDB51C067AC472B088540C00102000000020000009E769DB2BFDB51C067AC472B088540C0DC10E335AFDB51C0523AA28C028540C0010200000002000000FC694881AADB51C06D663E31FC8440C0438C7C03B8DB51C0D8F6D104E58440C0010200000002000000438C7C03B8DB51C0D8F6D104E58440C0257C4A29C3DB51C03615F3BDD08440C00102000000020000004F3860FC59DA51C04D4C1762F58540C010BA3AB654DA51C0465B9544F68540C0010200000002000000F5FD2F325CDA51C0EDD0555F028640C0CA4A38995DDA51C0B48E4F6D158640C00102000000090000003485CE6B6CDB51C0015361C7DA8340C012E62CA25CDB51C09FF0C80EE08340C0F637B23C59DB51C0B62C5F97E18340C0C1864C9E57DB51C008C3256CE48340C0BC6DF0CF56DB51C0BAD7EEC3E68340C05D37A5BC56DB51C0D5B0DF13EB8340C03E1B5EB557DB51C03E552A4DEF8340C0836DC4935DDB51C05A626534F28340C086E7A56263DB51C0FA9573CEF48340C00102000000020000003485CE6B6C
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
 02000000CCB6D3D688DA51C07522C154338740C0A290099D7CDA51C0B5E9BE524C8740C0010200000005000000A290099D7CDA51C0B5E9BE524C8740C086DFF2FD79DA51C053E34AE2518740C0940FE61B76DA51C002CCC694598740C08AFD0A3E72DA51C09ED38789618740C097DF0E7970DA51C0BAF42F49658740C0010200000003000000AD776E907FDA51C0E6C0BC11278740C069705B5B78DA51C02CB24236358740C07830BD5873DA51C00356B3733F8740C00102000000020000007830BD5873DA51C00356B3733F8740C0A88F1BD970DA51C05AA3795B448740C0010200000002000000A290099D7CDA51C0B5E9BE524C8740C046B1811978DA51C006FB0A2D468740C001020000000200000046B1811978DA51C006FB0A2D468740C07830BD5873DA51C00356B3733F8740C00102000000020000002123FB7B84DA51C095DD825B2D8740C046B1811978DA51C006FB0A2D468740C00102000000020000001EAA84822DDA51C0EAB298D87C8740C0B82EEBB424DA51C00FD4298F6E8740C00102000000020000009DD7D8252ADA51C05BB97251888740C02BB4BD2720DA51C0925F9A7D798740C001020000000200000076B28AED24DA51C0162296838F8740C07AD33E671CDA51C064607880828740C001020000000200000059BD6834DED951C04A8CAF87408640C03
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
 C0E8A38CB800E151C0713F3B3B748440C049CF3EA0FDE051C0DDB3AED1728440C0742C4A64FAE051C025F0E258728440C035AB88E4F5E051C095777A4A738440C0246E0498E8E051C05CEA7B687A8440C002A72D64E4E051C04F4AF7297D8440C08EE733A0DEE051C059A48977808440C04FAE2990D9E051C082D54796828440C046FB0E34D5E051C0AB20AB00848440C0DFB023C4CBE051C056A64EF6858440C0400AE8CFC8E051C00F6A1A6F868440C001892650C4E051C05BD3179D878440C09768DA0FC2E051C0137D3ECA888440C04BF1A77CBEE051C065B7E0568B8440C0AC787EACBBE051C0DB519CA38E8440C00DD242B8B8E051C09D6FFA69928440C0037B4CA4B4E051C088A47103998440C08FBB52E0AEE051C035F74663A38440C0915ACDDFA9E051C0BAA29410AC8440C0F2F510E8A7E051C03057F5A8AE8440C0523530A8A5E051C0ED2DE57CB18440C0E8E6D143A3E051C062E24515B48440C013FC2598A0E051C01FB935E9B68440C03E2B1F389DE051C04D17BDAEBA8440C09F0E1AB09AE051C0E7E9B70ABD8440C00068DEBB97E051C0A4C0A7DEBF8440C02BF3FBA394E051C03D93A23AC28440C056F4E21F91E051C0FA69920EC58440C04DCBFE2F8DE051C028E2BE1FC88440C00EC0064488E051C03222AC21CC8440C09AD2FA5B82E051C0D107CBD8D08
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
 BE56DDE51C0153D4BEBCA8440C0094268F36EDE51C038F988F3CB8440C08B93B1906FDE51C0CCE039A5CD8440C07FB7E5C86FDE51C0A22D420CCF8440C0D9D138D46FDE51C0EF963F3AD08440C03EC857A76FDE51C0302471A0D18440C0976F7D586FDE51C07C8D6ECED28440C001020000000B0000009518BAC873DE51C0F994AD3FD38440C03C71941774DE51C03B281719D38440C0232C2AE274DE51C000862F5DD28440C08EC5DBEF75DE51C0AD31E884D08440C01CD94B0977DE51C0A3337A7FCD8440C09F9DC20078DE51C0B8E45D9AC78440C0FEBC040278DE51C09A6F8E84C78440C093C1F63878DE51C0724408D9C38440C03AA7A32D78DE51C03E99DAADC08440C09F9DC20078DE51C0AAB129FCBE8440C02EE57CB177DE51C05EAA8889BC8440C001020000000D000000028BB26D87DE51C0E21E4B1FBA8440C050E3DEFC86DE51C012BD8C62B98440C0B0C33D3B85DE51C07ED5DBB0B78440C08237A45181DE51C0F7CF2E3AB48440C07DAEB6627FDE51C0108EFE3CB28440C0916A33A97CDE51C000A5468DAE8440C0684DE2627BDE51C0A24621C9AC8440C04AF2B7987ADE51C0DEC02ED4AB8440C0BCDE477F79DE51C0857B65DEAA8440C093C1F63878DE51C04AD97D22AA8440C082CF6ADC76DE51C044EE3378A98440C0658EE55D75DE51C0F193B42CA98440
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
 000019F55A1A89DE51C0248C5539A38440C013F06B2489DE51C0E28222CCA38440C0228B34F18EDE51C07DAC85FEAE8440C001020000000200000019F55A1A89DE51C0248C5539A38440C00E677E3587DE51C0DC97D821A38440C0010200000004000000A9BEF38B92DE51C027874F3A918440C06876DD5B91DE51C05725917D908440C04BA8853790DE51C063015D45908440C0ED04453D8EDE51C0159227A4908440C00102000000030000009A6B877599DE51C07F40B15FC18440C0466D2C7299DE51C0B9C2BB5CC48440C0F9BB77D498DE51C08333F8FBC58440C0010200000002000000250BF379A0DE51C0675F79909E8440C008EF062C94DE51C09B16612FB98440C0010200000005000000A3073E06ABDE51C00E5F7017AB8440C0691206AFA7DE51C0816E79F6A68440C0283D1DD9A6DE51C0C3D3D0ABA68440C06FA76384A6DE51C0C201E3CFA68440C0F2B62D25A6DE51C00A52842FA78440C001020000000500000091E1C2CB9DDE51C010A7DDF98F8440C091E1C2CB9DDE51C0B06A5A73918440C0DA232FC69BDE51C0EF192E17968440C0A5106D6C9BDE51C0CB57B89B968440C0224CF6749ADE51C02A8E03AF968440C0010200000004000000028BB26D87DE51C0E21E4B1FBA8440C07D6F78E68ADE51C0EB3E5B62C08440C055BA601594DE51C0EDB8E177D38
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
 C48340C01760C4E3C7DE51C000529B38B98340C025068195C3DE51C081F8AF62A78340C001020000000200000025068195C3DE51C081F8AF62A78340C0384FD081C0DE51C05EF1796A9A8340C0010200000002000000384FD081C0DE51C05EF1796A9A8340C027EA16CBBEDE51C0144438C1928340C0010200000002000000C1429C3D86DE51C0713381C75C8340C0E3F2695F8ADE51C00DB8F8252C8340C00102000000020000006DE525FF93DE51C0A25AE95A208340C0A9BEF38B92DE51C08FD25BF22E8340C0010200000002000000A9BEF38B92DE51C08FD25BF22E8340C04BD6975B90DE51C07682A21E478340C00102000000020000004BD6975B90DE51C07682A21E478340C046DA7C128EDE51C09EE7F461628340C0010200000002000000361FD7868ADE51C09B4A500D458340C04BD6975B90DE51C07682A21E478340C00102000000020000004BD6975B90DE51C07682A21E478340C0118B187698DE51C07BA933524A8340C0010200000002000000261EABEF57DF51C0342F87DD778440C008E8BE9C59DF51C07D2F74DB748440C001020000000600000008E8BE9C59DF51C07D2F74DB748440C04F1EBBB05ADF51C08FA09D78738440C084BBB3765BDF51C090D4E70F728440C01E38C2FD5BDF51C014D3E011708440C08944A1655DDF51C067DC2FFA658440C07
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
 000000DC7AF25597DE51C05646239F578340C00CEB217596DE51C0F247AC20618340C07E4ADFB595DE51C025EDA1D8658340C0010200000002000000E3F2695F8ADE51C00DB8F8252C8340C0A9BEF38B92DE51C08FD25BF22E8340C0010200000002000000A9BEF38B92DE51C08FD25BF22E8340C0643B84969ADE51C01CC98A86318340C0010200000003000000DD15B0D3FEDE51C07DA367C4168440C0170BE82A02DF51C074F629221E8440C0CEC87B3004DF51C0D739611D228440C0010200000003000000CEC87B3004DF51C0D739611D228440C0BB0CFFE906DF51C0E544BB0A298440C0FCB0396208DF51C0C1E7E2CA348440C0010200000002000000FCB0396208DF51C0C1E7E2CA348440C0ADD96F920BDF51C09DCFCA074E8440C0010200000017000000EA1A779414DF51C05EDBDB2DC98340C009B3BFA211DF51C04701A260C68340C03B0785F70BDF51C05AD427B9C38340C06028BBF40ADF51C0C0FBF4E9C28340C05A12FB5F09DF51C01A4D2EC6C08340C0AA3418D904DF51C0054B1A48BC8340C040B50B1703DF51C053927538BA8340C0E211CB1C01DF51C0F5616298B88340C0129C9F87FFDE51C0785A2327B88340C07EE59C33FDDE51C0785A2327B88340C05DA8FC6BF9DE51C0DD7BB8E4B88340C09485AFAFF5DE51C09525DF11BA8340C0315981C6F1D
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
 A8340C0010200000002000000813D26521ADE51C0416326512F8540C0B9347EE115DE51C016687748318540C0010200000003000000B9347EE115DE51C016687748318540C03BB13D6917DE51C00B6712503C8540C0D7ACE93015DE51C0C088C78F428540C0010200000003000000D7ACE93015DE51C0C088C78F428540C09299661511DE51C0F015DD7A4D8540C02FFA0AD20CDE51C01607E11B548540C0010200000007000000B6DF354305DE51C0BD06D8A2608540C0D591239D01DE51C05BA1FE69598540C0A7D13F1CFFDD51C04654F2FB488540C01E47BDF1FFDD51C017940E7B468540C0DDE40176FFDD51C05B05D616438540C02A2389B9FFDD51C02063EE5A428540C0E9A9C42BFFDD51C0FF147DF43C8540C0010200000002000000094E7D20F9DD51C00384C5973F8540C0E9A9C42BFFDD51C0FF147DF43C8540C0010200000004000000E9A9C42BFFDD51C0FF147DF43C8540C0CEB1721E04DE51C06BA395D63A8540C05672045F07DE51C0166BB8C83D8540C0AC32F8A00CDE51C07CC6CF903B8540C001020000000600000020F2F16412DE51C006D5AB6D2F8540C088A130830CDE51C09F03CB11328540C0A159C8120CDE51C039DCFDE0328540C0A1E69AB80BDE51C06E5F515B348540C0122CB3AD0BDE51C0FD5BB862358540C0AC32F8A00CDE51C07CC6CF90
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
 2260634D1B8540C001020000000200000025523F14F1D951C0B3F96EA9398540C0C05B2041F1D951C023D4B1EF2F8540C0010200000002000000C05B2041F1D951C023D4B1EF2F8540C0FC17AD48F1D951C05B5B785E2A8540C001020000000500000076E8AA2F01DA51C0E4FE7E8C148440C041D8840F00DA51C001182A5A148440C048F71851FFD951C07F81C586138440C0AD7A0ACAFED951C0E5AECA2A118440C0FBB8910DFFD951C0EF5B08CD098440C0010200000002000000FBB8910DFFD951C0EF5B08CD098440C095C2723AFFD951C089E30A39008440C001020000000200000095C2723AFFD951C089E30A39008440C09535A094FFD951C03460353BF78340C00102000000020000009535A094FFD951C03460353BF78340C0FA2BBF67FFD951C0F1A375AFEE8340C0010200000002000000FA2BBF67FFD951C0F1A375AFEE8340C09535A094FFD951C0F07A1FFDE58340C00102000000020000009535A094FFD951C0F07A1FFDE58340C09535A094FFD951C0DC5CA1B4DC8340C00102000000020000009535A094FFD951C0DC5CA1B4DC8340C0303F81C1FFD951C01D99A2B7D38340C0010200000002000000303F81C1FFD951C01D99A2B7D38340C0E27327D8FFD951C0C815CDB9CA8340C0010200000002000000E27327D8FFD951C0C815CDB9CA8340C095A8CDE
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
 D951C0238D6555DF8440C0010200000002000000713ED065C5D951C0238D6555DF8440C00C48B192C5D951C0F4DB7CC8008540C00102000000030000000C48B192C5D951C0F4DB7CC8008540C00CBBDEECC5D951C0C0817F00088540C0EE7321FBC5D951C035FC5D8E0D8540C0010200000002000000717D0EE2B9D951C0F16261889C8540C0D700005BB9D951C0C022BF7E888540C0010200000002000000D700005BB9D951C0C022BF7E888540C054AFB6BDB8D951C0E113460E6C8540C001020000000300000054AFB6BDB8D951C0E113460E6C8540C0E3AEB9FEB8D951C0727D699B2C8540C0A1ED3D01B9D951C0BB325EA91D8540C0010200000002000000EE7321FBC5D951C035FC5D8E0D8540C0EE7321FBC5D951C0DEFFC709138540C0010200000002000000EE7321FBC5D951C0DEFFC709138540C00CBBDEECC5D951C02B5899DF1F8540C00102000000020000000CBBDEECC5D951C02B5899DF1F8540C00CBBDEECC5D951C036F22F38398540C00102000000030000000CBBDEECC5D951C036F22F38398540C01EE1B4E0C5D951C0B39597FC4F8540C00CBBDEECC5D951C0B17504CB6C8540C00102000000020000000CBBDEECC5D951C0B17504CB6C8540C00CBBDEECC5D951C040E6B974828540C00102000000020000000CBBDEECC5D951C040E6B974828540C08
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
 0006C19BA23ADD951C012C7702B738440C054EEF439ADD951C0F646AD307D8440C001020000000200000054EEF439ADD951C0F646AD307D8440C0D10FD9F6ACD951C01D160F94808440C0010200000002000000D10FD9F6ACD951C01D160F94808440C01FDB32E0ACD951C0CF19AC938E8440C00102000000020000001FDB32E0ACD951C0CF19AC938E8440C0D10FD9F6ACD951C02FCF392E998440C0010200000002000000D10FD9F6ACD951C02FCF392E998440C01FDB32E0ACD951C0E53EDE509D8440C00102000000020000001FDB32E0ACD951C0E53EDE509D8440C01FDB32E0ACD951C06924F895BD8440C00102000000020000001FDB32E0ACD951C06924F895BD8440C06C19BA23ADD951C006C2A96ADD8440C00102000000020000006C19BA23ADD951C006C2A96ADD8440C054EEF439ADD951C0FACCFEE5FF8440C001020000000200000054EEF439ADD951C0FACCFEE5FF8440C054EEF439ADD951C0EB5795D8108540C001020000000200000054EEF439ADD951C0EB5795D8108540C08ABC9B5DADD951C0D35A87591E8540C00102000000040000008BC22E8A9ED951C0BE011C31698440C02687F4809ED951C005C24EB16A8440C0D49AE61DA7D951C0EA1FE978718440C06C19BA23ADD951C012C7702B738440C00102000000030000001FDB32E0ACD951C0E53E
 DE509D8440C0CF5F8D58B0D951C027D2472A9D8440C03CF71E2EB9D951C038995D9C9D8440C00102000000020000003CF71E2EB9D951C038995D9C9D8440C059130B7CC5D951C09DE8047E9E8440C001020000000200000059130B7CC5D951C09DE8047E9E8440C017838769DFD951C06759411DA08440C001020000000200000017838769DFD951C06759411DA08440C0FA6AFDE3F3D951C013FFC1D19F8440C00102000000020000008ABC9B5DADD951C0D35A87591E8540C0F887D283A7D951C0B541DC8B1E8540C001020000000200000081FCB67155DA51C0F230A30EE18440C01FF301814EDA51C04523449EC98440C0010200000002000000BA97457243DA51C0B2D073B0A38440C01F189BB143DA51C0C388D8BB9A8440C001020000000200000004A1061D3EDA51C02C7299E4918440C045D5AF743EDA51C0695F2F03848440C0010200000002000000D4A304583FDA51C0626534F2798440C0B0E42A163FDA51C0DAD2591C848440C00102000000020000003CE6F2D544DA51C0863B17467A8440C0DDAFA7C244DA51C0036674F6848440C0010200000002000000A174D8333ADA51C08627AA6D798440C0AD2292D739DA51C0BD772F52838440C0010200000002000000FC72C17435DA51C0B0D46993798440C07FDEAF5D35DA51C088500020828440C001020000000
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
 00002000000C3B178FB3DDA51C0BCD86AC5ED8440C0D40561133EDA51C0AF1B00BBE48440C0010200000002000000EE8DC64645DA51C0B6E7E8A7EE8440C0FA21DB9E45DA51C0799274CDE48440C0010200000002000000BB568C04E4D951C03FD0C07E3E8440C038C02731E3D951C0E8A562635E8440C0010200000002000000838D4699E8D951C0CE9FDBF0608440C029424530E9D951C097E13FDD408440C001020000000200000086D91544EED951C04B53A97E4A8440C051532690EDD951C06EA5D766638440C00102000000020000007C04A33781DA51C0D3646B22D88340C076A0F3BF81DA51C02DC25E72ED8340C001020000000500000076A0F3BF81DA51C02DC25E72ED8340C0B1FDBF4582DA51C008CFDFDFFB8340C00B8B40AB82DA51C0E150AEDF028440C08173EBDA83DA51C0DBB05C250E8440C02D55B31886DA51C0CF1F894D1A8440C00102000000070000002D55B31886DA51C0CF1F894D1A8440C067F1626188DA51C011D61066248440C067D7BD1589DA51C00FF8B2A3278440C0E92807B389DA51C0675F1ED72B8440C0D1E39C7D8ADA51C0E7734930308440C0EE2422FC8BDA51C0E76D11BD318440C0E2BB838E8CDA51C0F75C01E0338440C0010200000005000000B2BE81C98DDA51C06BC317DCC58340C0AA6BA3F08FDA51C03D5464BECD8340C01B
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
 86DA51C00399F8FE618440C008347D1B87DA51C08EA559EA6A8440C031DEA00788DA51C05E58480A768440C00102000000020000004ED1915C7EDA51C08B9EA575658440C0DD71D41B7FDA51C0BCB0355B798440C001020000000400000045D95BCA79DA51C0F239C148798440C003EACDA879DA51C03BE702F2808440C0D82725A971DA51C035FCB847808440C08A5CCBBF71DA51C0844314387E8440C00102000000020000008A5CCBBF71DA51C0844314387E8440C04D158C4A6ADA51C0A2009BBD7D8440C00102000000020000007EF32C5272DA51C003E4F0EE6D8440C08A5CCBBF71DA51C0844314387E8440C0010200000004000000D3799E897ADA51C0431ABA7E668440C0F211E79777DA51C0D0C5F0225D8440C0E1AC2DE175DA51C074733B45588440C05FEB522374DA51C0752387E3548440C001020000000200000031DEA00788DA51C05E58480A768440C0DD71D41B7FDA51C0BCB0355B798440C0010200000002000000DD71D41B7FDA51C0BCB0355B798440C045D95BCA79DA51C0F239C148798440C001020000000200000045D95BCA79DA51C0F239C148798440C017331D9576DA51C0753282D7788440C00102000000050000009FA97C748FDB51C0337C5578E18440C0B4D3C55C88DB51C0F7C54A71FA8440C0CC18309287DB51C01A828879FB8440C0756
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
 00005546C8E5E4D851C0A5CF5845C98540C03F6F2A52E1D851C08DD31055F88540C083B57B03DDD851C0E61E12BEF78540C0B3B27DC8DBD851C0C0F11021098640C0010200000002000000FC034070F0D851C0F900930A198640C064B0E254EBD851C04D8F5CED178640C001020000000200000064B0E254EBD851C04D8F5CED178640C0E98601A6E7D851C071F5AD20178640C0010200000002000000B239BD41EAD851C0B8342328238640C064B0E254EBD851C04D8F5CED178640C00102000000020000002D0ABB28FAD851C0871AE0DD258640C032112510E5D851C056D5CBEF348640C001020000000200000032112510E5D851C056D5CBEF348640C0E4FD13B7E5D851C08A7DB89A2B8640C00102000000020000007555455D10D951C0695DFE9EB38640C0D014F02117D951C06E08443E9E8640C001020000000400000057A7148527D851C06B7EFCA5458840C06D640DCD2BD851C0325294F0298840C0F817416326D851C0FE5EAF55278840C09AD3C0EA23D851C075392520268840C0010200000002000000FAF25DA516D851C0C8C2C6AB628840C01926AEBE15D851C090D0E000448840C00102000000020000001926AEBE15D851C090D0E000448840C078488CF914D851C0BA4C4D82378840C0010200000002000000663F9CD120D851C07E7F9422438840C08CC5C
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
 C303DABD851C0FB952941DA8540C0010200000002000000F0B5B1239FD851C00490DAC4C98540C0F80B2C369CD851C07989FBD9D98540C001020000000200000026E5EE737CE051C0930B8453D58440C0E6632DF477E051C0E487A5DCD88440C0010200000002000000E7ABE46377E051C0E0748181D68440C0F05EFFBF7BE051C0D51AEF33D38440C0010200000044000000F05EFFBF7BE051C0D51AEF33D38440C023F02CE68CE051C041A08E22C68440C06C802D0A96E051C02D060FD3BE8440C0753348669AE051C0DC89ED49BB8440C074B10EEC9DE051C01F717E79B78440C048F8DEDFA0E051C0CEF45CF0B38440C0524FD5F3A4E051C00BF1A375AF8440C02720DC53A8E051C049EDEAFAAA8440C0C6F4296CABE051C0CF256607A68440C09BC530CCAEE051C007F5E3E59F8440C0A592F073B2E051C040C461C4998440C044392C68B5E051C0C6FCDCD0948440C01952EA37B8E051C004F92356908440C0B89C01E4BAE051C0D69A9C908C8440C016B36F38BDE051C0194EE3288A8440C0EBB188BCC0E051C05C77F354878440C0C0F858B0C3E051C0332C90EA858440C0C9AB730CC8E051C00AE12C80848440C0D3307C44CCE051C0753BFBCA838440C0A75DA7ECCFE051C099733ADA828440C0B1B49D00D4E051C005CE0825828440C0F0355F80D8E051C0DC82A5BA
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
 078440C081D2AB5C03DF51C0508A56EE058440C001020000000300000081D2AB5C03DF51C0508A56EE058440C064A82FF001DF51C015BA5C0E058440C0781F9100FFDE51C09415C3D5018440C0010200000002000000781F9100FFDE51C09415C3D5018440C090F1CDDBFDDE51C053B6A393008440C001020000000200000090F1CDDBFDDE51C053B6A393008440C00AE18739F7DE51C02F75EB90F68340C00102000000020000000AE18739F7DE51C02F75EB90F68340C0F06C8FDEF0DE51C0DAC3036FED8340C0010200000002000000F06C8FDEF0DE51C0DAC3036FED8340C0292504ABEADE51C07FDF1A33E48340C0010200000003000000292504ABEADE51C07FDF1A33E48340C08AF72D84E6DE51C041649126DE8340C0FC451A26E4DE51C066EABF18DB8340C0010200000003000000FC451A26E4DE51C066EABF18DB8340C0B6CA02DCE2DE51C0A37E726FD98340C0F952D389DFDE51C0B699AF37D68340C0010200000003000000F952D389DFDE51C0B699AF37D68340C0A2EE0390DADE51C0B2028DE3D18340C044937A05D8DE51C0EF3A1BF2CF8340C001020000000200000044937A05D8DE51C0EF3A1BF2CF8340C05BF4A9BECEDE51C0CFC4CFDAC88340C00102000000030000005BF4A9BECEDE51C0CFC4CFDAC88340C0855FEAE7CDDE51C09A55E938C88340C01
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
 826AE8440C0B1ADFAB7A6DB51C0C60556C49F8440C0F4328AE596DB51C014B18861878440C00C8684398BDB51C02A937593738440C0D7A0D4038BDB51C09C2045F8728440C00288163488DB51C0B5E44C6E6F8440C0CDC243BD85DB51C01B26BFEA6D8440C0C323963982DB51C0CEBCC1BC6C8440C0EE7D05C47FDB51C02159C0046E8440C0010200000003000000B33742507FDB51C0C83C974E908440C016A6EF3584DB51C0FAC1AF47978440C0366156838BDB51C090D2B6ABA18440C0010200000002000000366156838BDB51C090D2B6ABA18440C094F36A2599DB51C0B977C36CB88440C001020000000200000054A5D2F47EDB51C09BE21698BA8440C0366156838BDB51C090D2B6ABA18440C0010200000003000000366156838BDB51C090D2B6ABA18440C05544978194DB51C07AC7293A928440C0AD86C43D96DB51C099EC44EE8E8440C00102000000050000004B32BCA310DB51C0D078C7CE808540C0B4942C2721DB51C0943DF83F768540C0381BE1A334DB51C0BD29F6E16A8540C0E2EA00883BDB51C048759549688540C068ED11C53FDB51C0D763C7EB668540C001020000000A00000068ED11C53FDB51C0D763C7EB668540C0C0E4EBD742DB51C0436271EE658540C01F7D38ED4EDB51C06D0F3114668540C0F4C308E151DB51C08451FF0F668540C0614AC9
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
 69708640C09F16CD1484D551C080A378F06E8640C0BC71F7DE84D551C06EAE505A6E8640C0DFBA078D85D551C027BAD3426E8640C0010200000002000000C3D265D6F7D551C0D3BEB9BF7A8640C02E2D3421F7D551C03D32B154728640C00102000000020000002E2D3421F7D551C03D32B154728640C09F443AF2F6D551C0807566CC6E8640C00102000000040000002E2D3421F7D551C03D32B154728640C0C9E88024ECD551C0650113B8758640C0AB7015D5ECD551C0AE9AE7887C8640C063D8BC05EDD551C0D16A92697E8640C0010200000008000000AF10B11CFCD551C02967DE605E8640C05BE443F5FBD551C0481630815B8640C02087776FFBD551C0FB08579B5A8640C09D352ED2FAD551C06D0CF093598640C0683C11C4F9D551C085F29947598640C063658FABECD551C0BF88111D5D8640C0E1A018B4EBD551C01DE736E15E8640C07B905495ECD551C060A3F66C678640C00102000000060000007B905495ECD551C060A3F66C678640C0513C1D7EEDD551C0A70705A5688640C02087776FFBD551C0CD936B0A648640C06D382C0DFCD551C0567DAEB6628640C0BA76B350FCD551C0635FB2F1608640C0AF10B11CFCD551C02967DE605E8640C0010200000002000000577E744504D651C0CBF44BC45B8640C0AF10B11CFCD551C02967DE605E8640C00102000
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
 B8540C01B39C1ED3FD751C0817DCFA33D8540C00102000000030000009709754735D751C0AC10A0F0238540C0C779A46634D751C029D9A0E52F8540C092C5A28E33D751C0BE2B27463B8540C001020000000300000092C5A28E33D751C0BE2B27463B8540C08DDA58E432D751C0128F1F85468540C0C9B08A3732D751C094E645DC528540C0010200000003000000893D59D622D751C0F53691F4C48440C0B5A679C729D751C030D978B0C58440C0F1C4628A28D751C0E8C2A3E8DC8440C0010200000003000000BECE97280CD751C02FFDA60B0C8540C08466D7BD15D751C014DCFE4B088540C06AD6BE2525D751C0184B47EF0A8540C0010200000002000000D6BA1E9617D751C0C5DF9B4B168540C0DB8B683B26D751C0DBB9D518198540C001020000000200000071AA5A7718D751C00ED8D5E4298540C0281DF68C0ED751C0194C0D7E2C8540C0010200000003000000DC34119175D851C072D014F0218540C0A6214F3775D851C00A7AB9991B8540C0F4797BC674D851C0233EC10F188540C0010200000002000000F4797BC674D851C0233EC10F188540C0EE601FF873D851C09B5775560B8540C0010200000002000000EE601FF873D851C09B5775560B8540C03C2F151B73D851C05418004FFF8440C00102000000020000003C2F151B73D851C05418004FFF8440C084
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
 E31096D751C05D84CE10338540C0D0C3BFBE8CD751C0703DAF1D318540C0BCDE477F79D751C0D66AB4C12E8540C0BCDE477F79D751C0831035762E8540C09016670C73D751C0CB1E57D92D8540C0B6042A2D6DD751C0A22F18B72C8540C0F651FCCE65D751C043893B832B8540C0010200000002000000F651FCCE65D751C043893B832B8540C0E6DBCC3255D751C01BBAD91F288540C00102000000040000006947BB1B55D751C00F4E9F78298540C02C5F3C284DD751C0B079B020288540C0D310FA3E41D751C06A013510268540C09709754735D751C0AC10A0F0238540C00102000000030000009709754735D751C0AC10A0F0238540C0AB3E575B31D751C07773A72A238540C02E5915E126D751C0F5C8D57E218540C00102000000020000002E5915E126D751C0F5C8D57E218540C089EFC4AC17D751C085A39A481F8540C0010200000002000000003219332ED851C013A4ADA5DB8440C060DE889320D851C004E44BA8E08440C001020000000600000060DE889320D851C004E44BA8E08440C04EA6C0B80AD851C06B065D67E88440C0FB3F87F9F2D751C0A3D2E352F08440C024DEF071DCD751C057D4BBD3F88440C02AF1CA3FC4D751C0BE384C8F018540C04AC851CAB5D751C0741882D2068540C001020000000400000071B66FA4A2D751C078634161508540C0666
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
 DDBFEF0CED851C032E9EFA5F08440C0134548DDCED851C08FABEC16DC8440C00102000000030000003FAE68CED5D851C0E71890BDDE8440C021DAD836D6D851C0D704076AE78440C003C12D69D6D851C077894567F48440C001020000000200000003C12D69D6D851C077894567F48440C074A785DCD6D851C04D277E31008540C0010200000002000000EC3026FDBDD851C0B642FDD3B28440C09F1738EAB2D851C0851156BEC28440C001020000000200000065BE28E6C5D851C0FD0571D4C08440C0A088450CBBD851C03B8A73D4D18440C0010200000002000000D43950F1C9D851C0275591C0D58440C0DE70C4FFC2D851C0DB368C82E08440C0010200000002000000A5F21BCBE0D851C0446B459BE38440C084AB1741DFD851C0211DBBE8F18440C001020000000200000084AB1741DFD851C0211DBBE8F18440C0A0B1E54BDED851C015973ECFFA8440C0010200000002000000A0B1E54BDED851C015973ECFFA8440C0355D4F74DDD851C0FC85C377078540C00102000000040000007ACC9B1EEFD851C0C7BDF90D138540C0D5CA845FEAD851C033DC80CF0F8540C0C2C073EFE1D851C095F661180B8540C0355D4F74DDD851C0FC85C377078540C0010200000002000000355D4F74DDD851C0FC85C377078540C03C1D7EEDCFD851C0FDD3B25A058540C00102000000
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
 E64416C41BD951C0247ABE0B008440C0E014B1E31AD951C0749C363EEE8340C0010200000003000000E014B1E31AD951C0749C363EEE8340C07B1E92101BD951C0A6CDDD53DE8340C0C8CF46AE1BD951C0DC5CA1B4DC8340C0010200000003000000037B4CA434D951C058868263E08340C0D22FB6B52AD951C06468869EDE8340C0167C58B52AD951C0077A7A9EDE8340C0010200000002000000167C58B52AD951C0077A7A9EDE8340C0C8CF46AE1BD951C0DC5CA1B4DC8340C0010200000002000000C8CF46AE1BD951C0DC5CA1B4DC8340C024415D4917D951C060556243DC8340C00102000000020000009949D40B3ED951C032CDCF68068440C06DACC43C2BD951C00AFE6D05038440C00102000000020000006DACC43C2BD951C00AFE6D05038440C0E64416C41BD951C0247ABE0B008440C00102000000020000003453B5383ED951C0351F7CCD178440C0A2BF86962BD951C02536C41D148440C0010200000002000000A2BF86962BD951C02536C41D148440C0211510A41CD951C09DFCCC0F128440C00102000000020000002E51627C3DD951C05D7B551D288440C0F0FD0DDA2BD951C05D818D90268440C0010200000002000000F0FD0DDA2BD951C05D818D90268440C0CDE506431DD951C0C466DBC4248440C001020000000200000034E087DE3DD951C01E262BD
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
 440C0E2ADF36F97D651C0FD6662BA108540C0010200000002000000E2ADF36F97D651C0FD6662BA108540C076C6527F98D651C0EED75361228540C00102000000030000001059A48977D651C0EC67B114C98440C09DF0B7E287D651C023F77475C78440C091EF52EA92D651C04863FE1BC58440C001020000000900000082412D6148DB51C023AC7C85BB8440C03986B6523EDB51C0CB8058DBB98440C05D59582632DB51C02E652A0EB18440C0268A90BA1DDB51C03AD3DFA69A8440C0E02BBAF51ADB51C04717409D978440C00366193D12DB51C0A0DDC60B8E8440C023F3C81F0CDB51C018D2E1218C8440C0DAD2591C04DB51C0ACEDDC6A8C8440C083458F29E9DA51C09A0F632D998440C001020000000600000083458F29E9DA51C09A0F632D998440C0FCB26AC6D8DA51C054724EECA18440C05B0BB3D0CEDA51C0F0A1E991AB8440C02E6E4848C9DA51C0FA57A027AF8440C02C706880C1DA51C0B201C754B08440C01FA22CD7B6DA51C082F3F3F0AF8440C0010200000002000000C49E2C6B51D751C057DF0A72618540C0F525659C50D751C0A0617B77758540C0010200000002000000F525659C50D751C0A0617B77758540C0C0E72C584FD751C04B523EA99B8540C001020000000A0000008BD761F1C0D651C04C546F0D6C8540C0B4363234C3D651C04B7C49BE6D
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
 B3ED951C032CDCF68068440C03453B5383ED951C0351F7CCD178440C00102000000020000003453B5383ED951C0351F7CCD178440C02E51627C3DD951C05D7B551D288440C00102000000030000002E51627C3DD951C05D7B551D288440C04C981F6E3DD951C0389F3A56298440C034E087DE3DD951C01E262BD0388440C001020000000300000034E087DE3DD951C01E262BD0388440C0E6875B4F3ED951C03E71A5434C8440C0630564543ED951C0A96917D34C8440C0010200000002000000630564543ED951C0A96917D34C8440C01B0E4B033FD951C0D0BFB8AF5E8440C00102000000030000001B0E4B033FD951C0D0BFB8AF5E8440C051210D5D3FD951C01E801EB4688440C0868D57C540D951C01FA97466718440C0010200000002000000868D57C540D951C01FA97466718440C06ED5BF3541D951C0F28AF1AB838440C00102000000020000006ED5BF3541D951C0F28AF1AB838440C0BBA0191F41D951C0307F85CC958440C0010200000002000000BBA0191F41D951C0307F85CC958440C0F06EC04241D951C03BA01111A38440C0010200000002000000F06EC04241D951C03BA01111A38440C056AAFA4B41D951C0CFAF9C73A68440C001020000000200000056AAFA4B41D951C0CFAF9C73A68440C0976B764941D951C05107C3CAB28440C00102000000020000
 00976B764941D951C05107C3CAB28440C06DECC84741D951C0D5ACD804BD8440C00102000000020000006DECC84741D951C0D5ACD804BD8440C0DF5FF36041D951C06BA97290C68440C0010200000002000000DF5FF36041D951C06BA97290C68440C056AAFA4B41D951C0A8188CB6CF8440C001020000000200000056AAFA4B41D951C0A8188CB6CF8440C008DFA06241D951C091894AD9D88440C001020000000200000008DFA06241D951C091894AD9D88440C0A9BF5E6141D951C0B986BE60DC8440C001020000000F00000060C20D9DC3D851C085A4051ECE8240C06F43311ECAD851C05CB68C8AEE8240C048CB3791CFD851C08EC81C70028340C0525040C9D3D851C0B99E32480B8340C074684760E2D851C08F876302238340C049CF9959F0D851C00E2C47C8408340C006161B4EF4D851C0232823D3468340C08DD6AC8EF7D851C0C62066E54D8340C062D5C512FBD851C0C9271A5A538340C0842C0B26FED851C0B6549401568340C028BBF48A02D951C091BAF836588340C07FF1B16007D951C0EB05FA9F578340C01FF7ADD609D951C075EF3C4C568340C0EE6CD96B0BD951C05E15037F538340C0BE897CF20BD951C0E3EB21D04F8340C001020000000A000000BE897CF20BD951C0E3EB21D04F8340C0122F4FE70AD951C0745C8DEC4A8340C04F67DDF508D951C
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
 0C0659934FCDDDC51C08923B48AA38540C00992D2C7D7DC51C003FFA556A98540C01C23D923D4DC51C0E90C8CBCAC8540C06958E773C9DC51C06D14FEB1B58540C0C0401020C3DC51C0E8DB82A5BA8540C01771F03BBCDC51C0F21B70A7BE8540C06478EC67B1DC51C06CE3F49AC38540C0B1091F00A7DC51C0BE5F1624C78540C09D5B32D89EDC51C09F6E4507C98540C0546F0D6C95DC51C057321180C98540C0010200000002000000AA5093CFE1DC51C0793AFCDA9F8540C06437D840DFDC51C0969A98897D8540C0010200000002000000F40478C116DC51C06FE6A1009B8440C05AED067621DC51C002D0CDA3878440C00102000000020000005AED067621DC51C002D0CDA3878440C09A46EE4424DC51C0DBD8918F828440C0010200000002000000507A956B40DC51C0ECF42801D68440C06D09AF134DDC51C0F7764B72C08440C00102000000020000006D09AF134DDC51C0F7764B72C08440C0B76E394D55DC51C0DBDC989EB08440C0010200000002000000B76E394D55DC51C0DBDC989EB08440C05BB8077C59DC51C062218491A88440C00102000000020000005BB8077C59DC51C062218491A88440C02B1D07B966DC51C0E60D8BAC908440C00102000000020000002B1D07B966DC51C0E60D8BAC908440C02AC187B773DC51C0CED9A788788440C00102000000
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
 D29DC51C0068200193A8540C0010200000004000000336C94F51BDE51C0D56AFE4E498540C0EC600ECC1BDE51C050076811408540C0EC600ECC1BDE51C0FA5D7DE13A8540C0813D26521ADE51C0416326512F8540C0010200000005000000813D26521ADE51C0416326512F8540C0E251CF2717DE51C04F6DBAAF148540C078CF262C16DE51C08856DDD90D8540C00D67237C14DE51C0A747AEF60B8540C0A3A2FB8312DE51C012A27C410B8540C00102000000020000004FD7C9CFFCDB51C040B2CA96F68440C0C253234FEDDB51C0C1768B1B128540C0010200000002000000638DC415E1D951C0DEACC1FBAA8540C0F5B814FCDBD951C0377CC15DAC8540C0010200000006000000F5B814FCDBD951C0377CC15DAC8540C0CEFDD5E3BED951C0D896A6ADB68540C07BA6F2D1BDD951C03E4EE2BDB48540C0C78D113FB5D951C0B41CE8A1B68540C04F7FAC96AAD951C031AE5D7FB78540C0D168BCBEA0D951C05B5B1DA5B78540C00102000000030000006DCBDB6C07DA51C0D9CF6229928540C0744694F606DA51C0F22C9CFFB28540C03E92921E06DA51C01DC7B4DBD38540C00102000000020000003E92921E06DA51C01DC7B4DBD38540C03F671C3405DA51C0BDB90908F78540C00102000000020000000DF159E814DA51C00A0F3FA4848540C0B491EBA614DA51C0485C
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
 0002000000E59189A592DB51C004CCD7C0B18540C0AAB0636D9DDB51C06B1382B0AE8540C00102000000020000007F0E982C93DB51C07D75FAE6A38540C0ED7D4F519ADB51C013FFC1D19F8540C0010200000002000000A0D4A8D175DB51C08BEA63F4928540C0F7EAE3A16FDB51C03185BD3F948540C0010200000002000000D0F643C769DB51C078222D3AFE8540C07797D58569DB51C0D2F4238FF18540C0010200000002000000DFBA078D85DB51C051AA33AD038640C0E25F5F468CDB51C05E448078028640C0010200000002000000AA3418D984DB51C0F680D481078640C068565B5686DB51C07B91BF6A1B8640C0010200000002000000C48C3A84BBDB51C01723B7CB238640C01DD59FB3BBDB51C0C8DE9C5B328640C00102000000020000005436ACA9ACDB51C0DD71D41BFF8540C0306EFEBAAEDB51C0C2621E43118640C001020000000200000054C37E4FACDB51C0A453573ECB8540C012802491A2DB51C09D5C9DADCD8540C0010200000002000000A1D80A9A96DB51C0E9ED748CD08540C012802491A2DB51C09D5C9DADCD8540C00102000000020000000E66136058DB51C024DB5438DD8540C0C19AB97658DB51C032DAF4B1CC8540C00102000000030000007C5E961B31DB51C07A98AC40E38740C08F238C5539DB51C0C2397E03EE8740C04D1421753BDB5
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
 88640C0DD24068195DD51C0C3E62D686B8640C0010200000002000000DD24068195DD51C0C3E62D686B8640C04F289F7994DD51C07DFE2037688640C00102000000020000004F289F7994DD51C07DFE2037688640C0D45AE21291DD51C0234E82925D8640C0010200000005000000D45AE21291DD51C0234E82925D8640C081ECF5EE8FDD51C09C48D51B5A8640C0FA5C120C8CDD51C05B0E4F0A4E8640C0B9FDF2C98ADD51C0570163224A8640C016AC27A982DD51C0B7A7F5C8308640C001020000000200000016AC27A982DD51C0B7A7F5C8308640C043E158BC7DDD51C0CA3DB896248640C001020000000200000043E158BC7DDD51C0CA3DB896248640C0268C66657BDD51C05062C6CA1E8640C0010200000002000000268C66657BDD51C05062C6CA1E8640C0154152FA78DD51C0171A3ED8188640C0010200000002000000154152FA78DD51C0171A3ED8188640C05A1AAEC472DD51C0A8397991098640C00102000000020000005A1AAEC472DD51C0A8397991098640C077E2282F68DD51C0039FD5B8ED8540C001020000000200000077E2282F68DD51C0039FD5B8ED8540C07FABD09B65DD51C0E49E5335E68540C0010200000002000000A03F23C78CDD51C0CD7A8C4D868640C0829CE6D399DD51C04BB3D4D5788640C00102000000020000004F289F7994DD51C0
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
 EF8403C68640C0F97BCE82F5DD51C07A8CF2CCCB8640C078EBA122F3DD51C0793E03EACD8640C06468869EDEDD51C0A53D6F74DF8640C044E68013C0DD51C0647F34F7EB8640C0B3FC0AE3B8DD51C0FD0978E3EE8640C0010200000005000000E3F1FE89DBDD51C0BD9580F33D8640C0BC202235EDDD51C029D9A0E52F8640C0C04AF4E8FCDD51C00BD12170248640C0CF47BEB70EDE51C02444F982168640C0FB5D335420DE51C0029F1F46088640C0010200000002000000FB5D335420DE51C0029F1F46088640C0C9B3267131DE51C0EBD511D1F98540C001020000000200000066930DB537DE51C09040CDDAB78540C01826530523DE51C0CF3A996EC88540C00102000000020000001826530523DE51C0CF3A996EC88540C09E16725B11DE51C09852F245D68540C00102000000020000009E16725B11DE51C09852F245D68540C03CA583F5FFDD51C008D79244E58540C0010200000002000000665AACF24EDE51C0B9B4D084DC8540C03763E2A04EDE51C0B41776BDD98540C00102000000020000003763E2A04EDE51C0B41776BDD98540C0C1D9F7F24CDE51C04B22FB20CB8540C0010200000002000000C1D9F7F24CDE51C04B22FB20CB8540C0C7F88B344CDE51C0785D64A7C48540C0010200000002000000C7F88B344CDE51C0785D64A7C48540C0FDB561B94ADE5
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
 934DE51C0A1624106978540C00102000000020000002138D32934DE51C0A1624106978540C0F88491031BDE51C02B72E371AC8540C0010200000002000000F88491031BDE51C02B72E371AC8540C0723DC04909DE51C0D051FD39BB8540C0010200000002000000723DC04909DE51C0D051FD39BB8540C06412E456F7DD51C046B3B27DC88540C00102000000020000006203D836FBDD51C0C8F03389D58540C02F562F1A0DDE51C01DAACE0FC88540C00102000000020000002F562F1A0DDE51C01DAACE0FC88540C0619FA5D01EDE51C0C57B69E5B98540C0010200000002000000619FA5D01EDE51C0C57B69E5B98540C0D99942E735DE51C027C75345A78540C0010200000002000000D99942E735DE51C027C75345A78540C09673CEF437DE51C0A63627E5A48540C001020000000200000088B36CF73CDE51C095DAE621AE8540C07B8C4D863EDE51C035BB4967BB8540C00102000000020000007B8C4D863EDE51C035BB4967BB8540C09E17DD3040DE51C0A05AD82EC88540C0010200000002000000AEEF68884FDE51C090CD9F80378540C047D6D0BC52DE51C036B6323C518540C0010200000003000000938D075B6CDE51C09C1551137D8540C0432CAC657CDE51C0757A3947788540C0D85B14877DDE51C0ECAA9BE6788540C0010200000002000000942012746ADE
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
 456ADA51C069D086B2A68440C06C651DE967DA51C08F6CAE9AE78440C01488E82164DA51C0FBCE8A03438540C00102000000030000000B0A83328DDA51C08BAE66F8AA8440C0602EF36789DA51C0DAAA24B20F8540C039317FE085DA51C021414C1D3F8540C0010200000004000000C866A26362DA51C00DF2C4BD438540C05044752964DA51C0DA99F8591B8540C09D7F603365DA51C03A1D6DC1F78440C09C20A0B165DA51C001CC6BDBE68440C00102000000040000009C20A0B165DA51C001CC6BDBE68440C04E69B3A066DA51C01465259CCC8440C0000EEBD767DA51C04A35A26AAA8440C042FD78F967DA51C08D4A45BEA68440C001020000000500000083458F29E9DA51C09A0F632D998440C07130E58DDDDA51C039C082EAD58440C0FC259820D9DA51C0BB65E2B1FA8440C03E46D49FD8DA51C0B747CA71028540C0F04C6892D8DA51C0B35A05D6168540C0010200000003000000DFFB1BB4D7DA51C0E89BD953178540C0029EB470D9DA51C064A021D2258540C0E5428AA6D8DA51C01FB9DA2F448540C0010200000004000000E5428AA6D8DA51C01FB9DA2F448540C02BA798DED9DA51C081F91A38568540C09F437463D5DA51C0AC74D256808540C041722145D3DA51C085831843948540C0010200000004000000D8D30E7FCDDA51C0EDE6F39BD38540C0EB138
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
 8540C00102000000050000003930140B57DA51C03D597BE9378540C0E58A411658DA51C007D0EFFB378540C0975D8B7159DA51C0E3699EC8388540C0D7B90E7A5BDA51C042107BFC398540C0C866A26362DA51C00DF2C4BD438540C0010200000002000000E712584A60DA51C0856863DB588440C0F31FD26F5FDA51C0D6CD2099698440C0010200000003000000F31FD26F5FDA51C0D6CD2099698440C09462EC295EDA51C03B43273A818440C0D7B672405CDA51C0E0BE6955A68440C0010200000004000000D7B672405CDA51C0E0BE6955A68440C0900D49D25ADA51C099F38C7DC98440C0B4A1AC295ADA51C0223C35F2D48440C081FCB67155DA51C0F230A30EE18440C001020000000200000081FCB67155DA51C0F230A30EE18440C0B15879B853DA51C0FCFAC67CE58440C0010200000002000000B15879B853DA51C0FCFAC67CE58440C04FF6E0FF58DA51C0E29B5C42F48440C00102000000030000004FF6E0FF58DA51C0E29B5C42F48440C0A95B87B457DA51C0755EBE501B8540C03930140B57DA51C03D597BE9378540C0010200000002000000D3307C444CDA51C0DF86BDF5068540C09BBD7D6745DA51C03800D182068540C00102000000020000009BBD7D6745DA51C03800D182068540C032BA72AC41DA51C0CD63833B068540C0010200000003000000C61
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
 00ED139BEAA4D851C0EBC0DE69D78540C0370C303DABD851C0FB952941DA8540C0010200000002000000370C303DABD851C0FB952941DA8540C09B801596AED851C0D71533C2DB8540C001020000000200000057DDD90D91D851C0EE2AFFB5178640C0446CB07092D851C02F36AD14028640C00102000000020000007062A30799D851C0B2CA96F6178640C0DAF8B8DB9AD851C06BB0BA1F018640C0010200000004000000954B3ED1D0D851C09DA85B2CFB8540C0DAC29899BED851C029D25856F58540C0F0DE5163C2D851C05ED0E748D38540C0295E656DD3D851C0EA44DD62D98540C0010200000003000000CCFFF51BB7D851C02FD2D567188640C03C253152B9D851C0B792C2610E8640C0187D6022B9D851C0F273E899038640C0010200000003000000552646E0D9D851C046651E543D8640C0DF3DF669CBD851C02FB9F6AA3A8640C05DE96B4CBED851C0E9E45652388640C0010200000002000000BCD28D0BE2D851C079019B18378640C032112510E5D851C056D5CBEF348640C0010200000003000000C105346CEFD851C06F449CF3F88540C04F8CD1DFF0D851C0A810D951E68540C066F6798CF2D851C0005E55ACD08540C0010200000005000000B20639390DD951C0D852F64CE58540C02FF76E980DD951C0CA98CCC2E88540C09F50F4650ED951C0298128F3E
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
 9247A8640C00102000000020000007773A72AA3D951C011AAD4EC818640C0DC24ABC7A2D951C08C88BDAB798640C00102000000020000003FADFDF8A6D951C0EDA5DF74818640C0283D1DD9A6D951C0DA9BCE04798640C00102000000020000009DA62AC8AAD951C0CF58EA0F838640C05BB79CA6AAD951C04B299E69788640C00102000000020000009FC321C08ED951C0E038DF3E618640C03A5AD5928ED951C0503349D16F8640C0010200000002000000FB65E6B889D951C0C27B58B9618640C0D1E638B789D951C044FB58C16F8640C00102000000020000005B71BBE188D951C0BC7669C3618640C0A8F7F99488D951C0A8EAD44B428640C0010200000002000000AC8B80AF8DD951C0D86E7143428640C02F0E78AA8DD951C0E66BE058618640C0010200000002000000887C3C99A4D951C0EBDF9AE0408640C011D3742CA5D951C02BE6D65A4E8640C0010200000002000000AED7F4A0A0D951C00E6EC6C4418640C0A85C3C17A1D951C078978BF84E8640C001020000000200000074FC61959CD951C0381B86EA418640C092E45E059DD951C0318969954F8640C001020000000600000059B043EB97D951C033FCA71B288640C0423EE8D9ACD951C0CEEE7F36288640C02387E354C6D951C06823D74D298640C06671B504CFD951C0E0450488278640C061D74004E6D9
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
 670F8FDB51C0A1B48185DD8740C029F27FA28DDB51C0DB0539DED38740C001020000000200000029F27FA28DDB51C0DB0539DED38740C08EBD288B8CDB51C0B8BFC469D28740C00102000000020000008EBD288B8CDB51C0B8BFC469D28740C04583143C85DB51C0EDDD7AA8C88740C00102000000020000008EBD288B8CDB51C0B8BFC469D28740C06792A2DF88DB51C007FC2B75DA8740C00102000000040000008F5ABCB351DB51C031B19EFFC38640C08604E7E761DB51C0FCFF3861C28640C00EE2B9AD63DB51C097C4FE57C28640C0A0A0B9F369DB51C00852CEBCC18640C0010200000002000000A0A0B9F369DB51C00852CEBCC18640C0DB1DADC582DB51C07484C256BF8640C0010200000002000000DB1DADC582DB51C07484C256BF8640C0D41E40D09BDB51C064DD89A3BC8640C0010200000004000000D41E40D09BDB51C064DD89A3BC8640C004E04499B2DB51C0D684FE53BB8640C08DB2237ABEDB51C0E8DB82A5BA8640C0B3F1BB44D0DB51C07782FDD7B98640C0010200000004000000B3F1BB44D0DB51C07782FDD7B98640C0450CE0D2D6DB51C03C6A4C88B98640C07BE9375DE0DB51C0D700005BB98640C09016C2C5E5DB51C036DB2626B98640C00102000000050000009016C2C5E5DB51C036DB2626B98640C02145532CEDDB51C060FEAFDFB88640C
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
 D5D8840C0A8E49CD843D951C00549449D5E8840C0
+  </a>
+<test>
+  <op name='buffer' arg1='A' arg2='0.005' arg3='1'>
+    GEOMETRYCOLLECTION EMPTY
+  </op>
+</test>
+</case>
+</run>
Copied: trunk/tests/xmltester/tests/ticket/bug350.xml (from rev 3289, trunk/tests/xmltester/tests/bug350.xml)
--- trunk/tests/xmltester/tests/ticket/bug350.xml	                        (rev 0)
+++ trunk/tests/xmltester/tests/ticket/bug350.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -0,0 +1,29 @@
+<run>
+  <precisionModel type="FLOATING" />
+<case>
+  <desc>
+http://trac.osgeo.org/geos/ticket/350
+TopologyException: found non-noded intersection between LINESTRING (-322379 830.734, -336712 -2708) and LINESTRING (-332496 -1667.09, -322379 830.734) at -332496 -1667.09
+  </desc>
+  <a>
+01060000000100000001030000000100000007000000000000005C3613C1000000000028A54000000000208D14C1000000000028A5C000000000A83F15C100000000C0A6D040981124BD63B414C1B82DC4EB7C969940CA5EE746E76814C120462E0E5B4A8A40323BFF843F4B14C1C77B5B2D590C9AC0000000005C3613C1000000000028A540
+  </a>
+  <b>
+01060000000100000001030000000100000005000000EF2CF4FC0ED315C1F4792E801F82B6C0477F50A83BA313C12242DCE0BE81B2C0203301B73FCE13C14FB2744AB1EBD24029062D840ECE15C161DDB50E8D6BD140EF2CF4FC0ED315C1F4792E801F82B6C0
+  </b>
+<test>
+ <op name="union" arg1="A" arg2="B">
+POLYGON ((-314775 2708, -322378.6881546058 830.7344192302963, -321742.91436957236 -4737.74561859717, -357571.7470252057 -5762.123049645208, -357251.62907800317 17838.204022852125, -324495.928715514 19374.77016942418, -322378.6881546058 830.7344192302967, -314775 2708))
+ </op>
+</test>
+<test>
+ <op name="difference" arg1="A" arg2="B">
+POLYGON ((-314775 2708, -322378.6881546058 830.7344192302963, -322378.6881546058 830.7344192302967, -314775 2708))
+ </op>
+</test>
+</case>
+</run>
Copied: trunk/tests/xmltester/tests/ticket/bug356.xml (from rev 3289, trunk/tests/xmltester/tests/bug356.xml)
--- trunk/tests/xmltester/tests/ticket/bug356.xml	                        (rev 0)
+++ trunk/tests/xmltester/tests/ticket/bug356.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -0,0 +1,25 @@
+<run>
+  <desc>
+http://trac.osgeo.org/geos/ticket/356
+  </desc>
+  <resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
+<case>
+  <desc>
+multilinestring buffer artifacts
+  </desc>
+  <a>
+MULTILINESTRING((1676339.95971128 4847443.67952346, 1676340.19 4847443.54, 1676338.44 4847440.65, 1676335.37 4847442.52, 1676337.12 4847445.4, 1676339.95971128 4847443.67952346))
+  </a>
+<test>
+  <op name='buffer' arg1='A' arg2='1.0' arg3='8'>
+POLYGON ((1676334.370908338 4847442.47738721, 1676334.381771572 4847442.672985536, 1676334.430559768 4847442.86271278, 1676334.515400594 4847443.039287834, 1676336.265400594 4847445.919287834, 1676336.383019845 4847446.075914382, 1676336.528914198 4847446.206608688, 1676336.697486246 4847446.306356514, 1676336.882268526 4847446.371330916, 1676337.07617165 4847446.399039078, 1676337.2717563 4847446.388417942, 1676337.461518643 4847446.339875002, 1676337.638178226 4847446.255272662, 1676340.477889498 4847444.534796128, 1676340.477889507 4847444.534796122, 1676340.708178227 4847444.395272662, 1676340.865054944 4847444.277767458, 1676340.995997551 4847444.13191887, 1676341.095975523 4847443.963330074, 1676341.16114793 4847443.778477878, 1676341.189010992 4847443.584463894, 1676341.178494273 4847443.388741704, 1676341.130001801 4847443.19883052, 1676341.04539655 4847443.022026312, 1676339.29539655 4847440.132026312, 1676339.177687757 4847439.974857962, 1676339.031535752 4847439.8
 43721232, 1676338.862575756 4847439.743672394, 1676338.6773224 4847439.678569058, 1676338.482918545 4847439.650921426, 1676338.286859869 4847439.661795518, 1676338.096705855 4847439.710772058, 1676337.91978832 4847439.795962644, 1676334.84978832 4847441.665962642, 1676334.693269131 4847441.783769514, 1676334.56272065 4847441.92983049, 1676334.463152898 4847442.098540236, 1676334.398386959 4847442.283424222, 1676334.370908338 4847442.47738721),
+(1676338.816753609 4847443.202781668, 1676337.455985112 4847444.027221212, 1676336.743325995 4847442.854387922, 1676338.10393518 4847442.025612946, 1676338.816753609 4847443.202781668))
+  </op>
+</test>
+</case>
+</run>
Copied: trunk/tests/xmltester/tests/ticket/bug358.xml (from rev 3289, trunk/tests/xmltester/tests/bug358.xml)
--- trunk/tests/xmltester/tests/ticket/bug358.xml	                        (rev 0)
+++ trunk/tests/xmltester/tests/ticket/bug358.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -0,0 +1,26 @@
+<run>
+  <desc>
+http://trac.osgeo.org/geos/ticket/358
+  </desc>
+<case>
+  <desc>
+Invalid result from union
+  </desc>
+  <a>
+010300000001000000D60500000AD7A3306B4D39418FC2F598DE4B52410AD7A3B0794D39418FC2F5F8DC4B52410AD7A3B08E4D39418FC2F5B8DB4B52410AD7A3B0A34D39418FC2F5F8D94B52410AD7A330B24D39418FC2F558DA4B52410AD7A3B0C34D39418FC2F518DB4B52410AD7A3B0D24D39418FC2F578DA4B52410AD7A3B0E54D39418FC2F558D84B52410AD7A3B0F34D39418FC2F5F8D64B52410AD7A330044E39418FC2F5F8D34B52410AD7A330134E39418FC2F5F8D14B52410AD7A330334E39418FC2F598D04B52410AD7A3304D4E39418FC2F578CD4B52410AD7A3B05D4E39418FC2F558CA4B52410AD7A3306E4E39418FC2F518C84B52410AD7A330844E39418FC2F578C54B52410AD7A3309C4E39418FC2F5B8C24B52410AD7A330C74E39418FC2F5D8BB4B52410AD7A3B0DE4E39418FC2F578B74B52410AD7A3B0F04E39418FC2F598B34B52410AD7A330FF4E39418FC2F518B14B52410AD7A3B0154F39418FC2F558AD4B52410AD7A3B01F4F39418FC2F5F8AB4B52410AD7A3B0374F39418FC2F5B8A84B52410AD7A3B04F4F39418FC2F5B8A64B52410AD7A3B0774F39418FC2F578A44B52410AD7A3B0AA4F39418FC2F5F8A34B52410AD7A3B0C54F39418FC2F558A24B52410AD7A330DD4F39418FC2F5389C4B52410AD7A330055039418FC2F5188F4B52410AD
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
 47C4D524190E4F2AF4F5039412E6EA3D9784D5241D0D556AC4F503941D8F0F4D6784D524118B7D1F04F503941E04F8DD3784D5241907571BB50503941EA73B5B1784D5241042B87C6505039416C787AB5784D5241042B8746675039416C787A95744D52419075713B67503941EA73B591744D52414CC807BD67503941E0BE0E7C744D5241E43FA4CF6750394108CE1975744D5241905CFED36750394152962176744D5241905CFE536F50394152962176724D5241E43FA44F6F50394108CE1975724D5241480C021B70503941923A0129724D5241240681357050394134A2B407724D5241BCB88D467050394162A1D608724D5241DCD781C37C503941C6FEB24B664D5241C46D34C0845039414C158C6E5F4D5241B47BF2B084503941D8A3706D5F4D5241448B6CC7845039410EBE30515F4D524168DE71DA84503941482EFF515F4D524168DE71DA88503941482EFF71594D5241448B6CC7885039410EBE3071594D524190C2F5E888503941703D0A47594D524178BE9FDA8850394100DE0235594D5241F44A59E688503941CCCCCC34594D5241F44A596687503941CCCCCCF4534D524178BE9F5A8750394100DE02F5534D5241480C021B875039414E4013A5534D5241C030999A865039414CC80775534D5241ECE236AA86503941A4703D72534D5241ECE2362A7F503941A470
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
 410E4FAF7C134D52416891ED2CE0523941B0E1E979134D5241A401BC85E0523941E6D0229B134D5241504013F1E052394172F90FAD134D5241042B87E6E0523941FEF675B0134D5241A49BC440F25239410A46250D174D5241F4B0504BF25239418048BF09174D52417C832F2CF3523941840D4F2F174D5241809543CBF3523941ECC03937174D5241645DDCC6F35239413E0AD73B174D52411C5A641B0F533941CC5D4BDC184D52418004C51F0F5339417A14AED7184D5241BC7493081053394112F241E3184D524100B37B82105339417C6132DD184D5241B8FC8784105339418A4160E1184D52416C2BF6A720533941D6E76A63184D5241A4B437C81F533941ECE2365E184D5241C84B37C91F533941E04F8D5B184D5241444772E91E53394168226C50184D5241A8A44EF01D533941849ECD26184D52411895D4491D533941DCB584E8174D5241F4285C0F1D533941703D0A9F174D52411895D4491D53394104C58F55174D5241A8A44EF01D5339415EDC4617174D5241444772E91E5339417A58A8ED164D524140A4DFFE1F53394188F4DBDF164D5241F4285C0F20533941703D0ADF164D52412406815520533941022B87E2164D5241489D805620533941F697DDDF164D5241489D80D635533941F697DD5F174D5241240681D535533941022B8762174D524118265335365
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
 1D54394144FAED4B194D52419CC420901D5439411AC05B40194D524110C7BA881D54394128ED0D3E194D524104C58FB131543941865AD330154D5241388941604154394144696F90114D5241287E8C294F5439414E6210A00D4D5241ACADD82F4F543941D8A370A10D4D52416C9A774C4F543941C898BB960D4D5241B09465884F543941A223B98C0D4D52414C3789814F543941304CA68A0D4D524104098AEF5C5439416C567DC20A4D524110C7BAE86B5439410EE02DA8034D524130772D016F54394194658803FF4C5241F4285C0F6F5439412E211F04FF4C524130772D316F543941E4839ED9FE4C5241A8F1D2AD6F543941907EFBAAFE4C5241A80A46A56F54394134EF38A9FE4C5241043411C67854394102BC05E2FB4C5241081B9ECE785439415E4BC8E3FB4C5241D83D79F8785439419CC420D4FB4C524140E8D9CC79543941E61DA7B0FB4C52415427A0C9795439410022FDAEFB4C52412831084C855439411C5A644BFA4C524114F2414F8554394104560E4DFA4C52414CEA047485543941D478E946FA4C5241FCCBEE9986543941CC5D4B38FA4C52414C158CAA8654394152B81E39FA4C524178BE9FAA86543941D0D55638FA4C5241341136EC9854394112A5BD51FA4C5241086822EC9854394194878552FA4C5241FC65F78499543941764F1E5AFA4C5241A4B43
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
 1F4FDD4C8B0543941F6065F8C5A4C524188635DBCB0543941C64B378D5A4C52418CB96BA9B05439411E166A755A4C524144AD693EB05439411C9E5E4D5A4C5241C84B3749B05439413E9B554B5A4C52417858A8759A543941CA32C40D534C52414060E5709E543941840D4F174B4C5241D000DEA298543941B6A6799B4A4C5241941804A68E543941666666C6494C52410C022BA7805439411895D459494C524194B20C81775439411895D459494C5241941804166F54394190A0F80D4B4C5241585BB1FF695439413C4ED1894C4C5241D8F0F4FA69543941CCCCCC884C4C5241B8F3FDE469543941DE2406914C4C5241C017266363543941DA1B7C314E4C5241905CFED362543941D42B65494E4C5241941804D6625439416ADE714A4E4C5241808CB9DB585439411A51DA7B4F4C5241345EBAD95854394116FBCB7A4F4C5241F0C9C3C2585439415405A37E4F4C5241703D0AB7585439417E1D387F4F4C5241D066D5B758543941EC2FBB7F4F4C5241686FF00536543941C2F528DC524C5241DCD7811327543941849ECD5A544C52418CDB68A01954394148BF7DC5564C52412C1895E410543941780B2494594C5241B0E1E9650E54394196438B585B4C524194A982610E543941545227585B4C52410868225C0E543941B2BFEC5E5B4C5241647FD94D0E54394114D044645B4C
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
 E0BE0EC8884C524114AE47711D533941E2E995C6884C524108CE196149533941A4DFBEB6914C52410C24281E5F533941B29DEF4F934C5241FC87F41B5F533941CEAACF51934C524174E09C515F53394148E17A54934C5241EC2FBBF75F5339417EFB3A70934C52415CFE431A605339410A46257D934C52414060E520605339411A51DA7B934C524188A7577A6F53394150FC1863984C52410044FA8D855339413480B7409B4C5241EC0434E19C5339415C2041859D4C524144696FE09C53394112A5BD859D4C524170AC8BEB9C533941842F4C869D4C5241E86A2B369D5339418026C2929D4C5241D4E76A3B9D533941C6DCB5909D4C52413C4ED1B1B75339416E3480CBA14C524150D191ACB753394196218ECDA14C52414C621008B853394162A1D6DCA14C5241482EFF11B853394104E78CE0A14C5241F48E5314B85339416EA301E0A14C524128C286F7C353394130BB270FA54C52418C6CE7BBCC5339411804561AA64C5241FCCBEEB9CC53394164CC5D1BA64C52416007CE49CD5339418AFD6533A64C5241BC529681CD53394114D04448A64C5241A879C789CD53394166D5E746A64C5241A4923AD1D85339410E2DB281AA4C5241B86B09C9D85339412ACB1083AA4C524138894100D953394110E9B797AA4C52417C1D3827D9533941EA95B2C8AA4C524138894100D9533
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
 533941DA8AFD49D24C524138F8C2C4B45339417C3F354AD24C5241A8C64B77A95339414850FC70D34C5241D834EFF88753394190317775DC4C5241C876BE6F805339418E06F0C2DE4C524100BC05D27B53394180D93D39E24C5241186A4D4379533941E63FA46BE54C524194B20C01785339413C4ED1E1E84C5241943A016D7D533941164850C8ED4C5241F4DBD7718B533941903177D1F14C52419031776D8B533941B0506BD2F14C5241CC5D4BC88B5339418CDB68F4F14C5241B49DEFE78B53394130992A1CF24C5241D49AE6ED8B533941721B0D1CF24C52412063EE3A8D5339411C0DE08DF64C5241F875E07C8E533941B840826EFA4C524138B4C8C69653394134A2B46FFD4C5241F41FD2BF9C533941CAC34209FF4C524148BF7DBD9C5339416007CE09FF4C524170CE88229D5339412EB29D2FFF4C5241B8627F499D53394176029A60FF4C524148E17A449D5339418E06F066FF4C52416419E2489D5339416EC5FE66FF4C52416007CED99C533941CAA14592014D524140CF66D59C533941ECE23692014D524174E09CD19C53394122DBF996014D5241D83D79D89C533941782D2197014D524180B740A29B533941BEC11706054D524128C286D7A45339414C158C06074D52415CD3BCD3A4533941789CA207074D524174E09CF1A45339412E90A00C074D524198BB966
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
 C5241E43FA45F1C52394128A08930F24C5241B8DA8ABD3A523941F6285CBBF24C524130FF21BD3A523941865AD3BCF24C524190E4F22F3B523941DE718AC2F24C524100BC05323B5239416619E2C0F24C5241B4EA73156D523941D24D62A8F64C5241401361136D5239414CA60AAAF64C524144696F406D523941F01648ACF64C524114143F766D523941A60A46B5F64C52419487857A6D523941FAA067B3F64C5241CC32C491825239415AF5B9B6F94C5241443EE87995523941C8073D53FB4C5241780B247895523941DCB58454FB4C52411CEBE28695523941EE7C3F55FB4C5241DC4603889552394192CB7F54FB4C52419075716BC7523941F44A59FEFF4C5241D019516AC7523941BE9F1AFFFF4C5241E0BE0E7CC7523941B615FBFFFF4C524198BB96F0C7523941FC187313004D524130E6AEF5C75239418638D611004D5241BCE3149DDA523941CEAACFC1034D524124B9FC97DA523941448B6CC3034D524194A982A1DA52394100DE02C5034D5241BCC117A6DA5239410AF9A0C3034D5241107A362BF6523941A0F83176094D5241F87E6A2C285339415EDC466B0E4D5241F80FE98766533941780B2428144D52414CC807ED83533941E4F21F1A164D5241B415FB5B8F53394172F90FD1164D52417CAEB6D298533941AA6054AE154D52419C779C729B533941D40968E6
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
 EA1F64C5241CCEEC94389533941B27BF2A0F64C5241F063CC3D8953394104560EA1F64C524104560EFD87533941A01A2F59F24C52411851DA1B7A533941168C4A5AEE4C5241388941207A533941F46C5659EE4C524140CF66C5795339411AE25837EE4C52419CA223B979533941D656EC27EE4C5241B47BF2B079533941B6847C28EE4C524110363C0D7453394198DD930FE94C524140CF661574533941B8AF030FE94C5241A067B3FA73533941228E75EDE84C5241CCEEC90374533941705F07E2E84C5241CCCCCCFC73533941AE69DEE1E84C52416CE7FB49755339417A58A84DE54C52416C09F950755339413C4ED14DE54C52414803785B755339412E90A040E54C52413C4ED15175533941780B2440E54C5241C4F528EC77533941ECC039FFE14C5241141DC9F57753394134A2B4FFE14C5241BC490C0278533941164850F0E14C52416C9A77FC775339411A51DAEFE14C52412C6519C27C533941E63FA45BDE4C5241C486A7C77C533941E2361A5CDE4C524114FBCBCE7C533941782D2153DE4C524140575B217D5339415A423E34DE4C524170AC8B1B7D533941BC270F33DE4C524104A392EA84533941388941D0DB4C52411CC05BF084533941D8A370D1DB4C5241E4F21F0285533941A857CACADB4C5241E43FA4FF845339417C3F35CADB4C5241DC8AFDD5A6533941DE
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
 43941D022DBF5A04B524100917E6BAE543941501E16C6964B524128A08960AE54394164EE5AC6964B52419C33A244AE5439413A234AA3964B52411CC9E54FAE543941B4C876A2964B5241B025E463A4543941460378338E4B5241E81DA758A4543941CC5D4B348E4B52412C90A048A454394130992A208E4B5241CCEEC9E3A3543941FC3A70FA8D4B5241E8482EEFA35439411AC05BF88D4B524138F8C2649C543941FC87F4638B4B5241D42B65599C543941DE0209668B4B5241E0E00B239C5439417CD0B3518B4B5241A401BC259C54394172F90F518B4B52412C87160986543941BEC1177E854B524188855A836F543941903177157E4B52415839B4786F54394192ED7C177E4B524130992A486F543941182653057E4B524140355E4A6F5439415E29CB047E4B5241E00B932966543941C68F31A37B4B5241D46F5F27665439417E8CB9A37B4B52410C24281E66543941827346A07B4B5241B8F3FD24655439419EEFA7767B4B5241C09F1AFF6354394196D409687B4B5241DC1B7CB15754394196D409687B4B5241D49AE69D57543941708104697B4B5241F063CC9D57543941E2361A687B4B5241F8A0672348543941240681817B4B5241DCD781234854394142AD69827B4B5241EC04341147543941E0BE0E907B4B5241A813D0F4465439415E29CB947B4B5241F0D24DF2
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
 64B52410AD7A3303E5039418FC2F578784B52410AD7A3B02A5039418FC2F5D87A4B52410AD7A3B0145039418FC2F5587E4B52410AD7A3B00B5039418FC2F538814B52410AD7A330FC4F39418FC2F598864B52410AD7A330F04F39418FC2F5388D4B52410AD7A330E24F39418FC2F5B8934B52410AD7A330D54F39418FC2F598974B52410AD7A3B0C24F39418FC2F5589A4B52410AD7A330AA4F39418FC2F5989D4B52410AD7A3B0894F39418FC2F5789F4B52410AD7A3305D4F39418FC2F598A14B52410AD7A3B02D4F39418FC2F5D8A44B52410AD7A330124F39418FC2F518A84B52410AD7A330FC4E39418FC2F578AB4B52410AD7A3B0E24E39418FC2F598AD4B52410AD7A330D84E39418FC2F558B14B52410AD7A3B0C44E39418FC2F538B54B52410AD7A330AB4E39418FC2F578BA4B52410AD7A3B08B4E39418FC2F5B8BE4B52410AD7A3B06A4E39418FC2F518C24B52410AD7A3305B4E39418FC2F578C34B52410AD7A3303F4E39418FC2F518C74B52410AD7A3302F4E39418FC2F558C84B52410AD7A3B0234E39418FC2F578C64B52410AD7A3301B4E39418FC2F5D8C14B52410AD7A330184E39418FC2F518BE4B52410AD7A3B0144E39418FC2F5F8B84B52410AD7A330F74D39418FC2F558B94B52410AD7A3B0FC4D39418FC2F5D8BF4B52410AD7A330F94D39418FC2F5
 98C44B52410AD7A3B0E74D39418FC2F5B8C74B52410AD7A3B0D64D39418FC2F5D8CA4B52410AD7A330BC4D39418FC2F558CC4B52410AD7A3B0A74D39418FC2F518CE4B52410AD7A3308B4D39418FC2F538D04B52410AD7A3B0754D39418FC2F5F8D14B52410AD7A330614D39418FC2F578D54B52410AD7A330484D39418FC2F5F8D84B52410AD7A330314D39418FC2F518DC4B52410AD7A3B0444D39418FC2F5B8E34B52410AD7A3306B4D39418FC2F598DE4B5241
+  </a>
+  <b>
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
 F1543941CE19514E534C5241BCC117C6DF543941923A01E1524C524170F085F9C6543941C8BAB8BD504C524130992AC8B05439417EFB3ADC4D4C5241984C155CA1543941D85F76534A4C52418CB96B59A15439417C832F544A4C52414CA60AC6A0543941BC96903B4A4C52419C8026A2A0543941A679C7394A4C52414CEA04A4A0543941D24D62384A4C5241F4FDD4B88F5439416ABC74CF484C52410022FDB68F543941D044D8D0484C5241946588538F5439411EC9E5CB484C5241B8FC87548F5439413C4ED1C9484C5241E8B7AF03815439418026C25A484C5241C420B00281543941D044D85C484C5241043411C6805439411895D459484C5241A835CDCB765439411895D459484C524188F4DB077654394198DD9363484C524124E4838E75543941ACADD877484C52410CB5A6897554394186A75776484C52419031776D6C543941AA60544E4A4C5241AC6054726C543941D066D54F4A4C524150AF94456C543941840D4F574A4C52412CB29D2F6C5439419465885F4A4C5241B047E12A6C54394126E4835E4A4C52416CC5FE0267543941244A7BDF4B4C5241BCE314CD6054394190C2F56C4D4C52410881953357543941A857CA924E4C524140575B9134543941EA73B5ED514C52419C802692345439415A8638EE514C5241787AA58C34543941DCF97EEE514C524134113
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
 174D52415C2041F182533941CAA14512174D5241F441CF168F53394152499DD4174D524174F90F198F533941AED85FD2174D52416CC5FE928F533941B20C71D8174D52418C06F0569053394132C4B1CE174D5241
+  </b>
+<test>
+ <op name="union" arg1="A" arg2="B">
+ 010300000007000000020300000AD7A330314D39418FC2F518DC4B52410AD7A3B0444D39418FC2F5B8E34B52410AD7A3306B4D39418FC2F598DE4B52410AD7A3B0794D39418FC2F5F8DC4B52410AD7A3B08E4D39418FC2F5B8DB4B52410AD7A3B0A34D39418FC2F5F8D94B52410AD7A330B24D39418FC2F558DA4B52410AD7A3B0C34D39418FC2F518DB4B52410AD7A3B0D24D39418FC2F578DA4B52410AD7A3B0E54D39418FC2F558D84B52410AD7A3B0F34D39418FC2F5F8D64B52410AD7A330044E39418FC2F5F8D34B52410AD7A330134E39418FC2F5F8D14B52410AD7A330334E39418FC2F598D04B52410AD7A3304D4E39418FC2F578CD4B52410AD7A3B05D4E39418FC2F558CA4B52410AD7A3306E4E39418FC2F518C84B52410AD7A330844E39418FC2F578C54B52410AD7A3309C4E39418FC2F5B8C24B52410AD7A330C74E39418FC2F5D8BB4B52410AD7A3B0DE4E39418FC2F578B74B52410AD7A3B0F04E39418FC2F598B34B52410AD7A330FF4E39418FC2F518B14B52410AD7A3B0154F39418FC2F558AD4B52410AD7A3B01F4F39418FC2F5F8AB4B52410AD7A3B0374F39418FC2F5B8A84B52410AD7A3B04F4F39418FC2F5B8A64B52410AD7A3B0774F39418FC2F578A44B52410AD7A3B0AA4F39418FC2F5F8A34B52410AD7A3B0C54F39418FC2F558A24B52410A
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
 544C52418838D6E5035539413E575B6D544C524110E9B73F0355394176E09C51544C524108CE1931035539416619E250544C524174D712320355394138894150544C5241F853E315FA54394130DD2472534C524144D8F014FA5439415C6DC572534C5241148C4A7AF954394174B5156B534C52419487857AF9543941FCCBEE69534C52414082E247F1543941CE19514E534C5241BCC117C6DF543941923A01E1524C524170F085F9C6543941C8BAB8BD504C524130992AC8B05439417EFB3ADC4D4C5241984C155CA1543941D85F76534A4C52418CB96B59A15439417C832F544A4C52414CA60AC6A0543941BC96903B4A4C52419C8026A2A0543941A679C7394A4C52414CEA04A4A0543941D24D62384A4C5241AEAFC51E9E543941E8329D024A4C52413C7958589F54394152B81EB9454C524104098A4F9F543941FE65F7B8454C5241148C4A5A9F5439418E7571AB454C5241F0D24D429F54394114AE478D454C5241D44D62509F543941C6DCB58C454C5241A01A2F8D9A54394176711B353E4C5241C09F1A7F9A543941C442AD353E4C5241043411769A543941F44A592A3E4C5241105839849A543941287E8C293E4C5241686FF0F594543941D200DE02384C5241FC87F43B8C543941029A084B2E4C52411895D47987543941B6847CA4284C5241D4E76A6B87543941EE7C3
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
 E9EC543941EE7C3F5D324B5241C09F1AEFEC543941FC3A7056324B5241C07D1DC8EC543941228E7525324B52419CA22359EC54394144FAEDFB314B5241285305B3EB5439417C832FE0314B5241C09F1AEFEA543941FC3A70D6314B5241A05E292BEA5439417C832FE0314B5241280F0B85E954394144FAEDFB314B524104341116E9543941228E7525324B5241006F81F4E8543941789CA24F324B5241F41FD2EFE85439412A3A924F324B524118D9CEF7E6543941CC7F48773B4B5241DC2406C1E2543941CEF7536F3E4B5241F44A59A6DA5439411C0DE019424B5241FC87F49BCC543941BAB88D6A454B524148E17A84C15439411AC05BE4474B5241A4BDC187C1543941A60A46E5474B5241D85F766FC154394186C954E9474B52415839B448C154394162C3D3F7474B5241BC529641C1543941FEB27BF6474B5241ACD85F86B8543941061214D74A4B5241004D848DB8543941D6C56DD84A4B5241A80A4645B85439416ABC74F34A4B52417A4EAB43B854394159FD76F54A4B5241A150AA44B8543941697C36F44A4B52414B0D4445B8543941C44375F34A4B5241DD478747B85439419C8B9CF24A4B524129CA4AFACB543941E4D53DEE3F4B52415CFD7DC5CC5439414A3CA4903B4B5241F596172FCB5439417E6FD763384B5241C263E44FD4543941B1A20AC42E4B5241F59
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
 F596173FC9513941E4D53D966B4B5241F5961787A5513941170971DA6F4B52418F30B13482513941170971CC764B52410AD7A330645139418FC2F5387D4B52410AD7A3B0525139418FC2F5B8814B52410AD7A3B0425139418FC2F5B8844B52410AD7A330325139418FC2F5B8884B52410AD7A3B0275139418FC2F5988A4B52410AD7A330195139418FC2F5188B4B52410AD7A3300E5139418FC2F598894B52410AD7A3B0075139418FC2F578864B52410AD7A3B0035139418FC2F538824B52410AD7A3B0FC5039418FC2F5187E4B52410AD7A330F55039418FC2F5B87C4B52410AD7A330E25039418FC2F5187A4B52410AD7A3B0CB5039418FC2F5F8764B52410AD7A3B0B85039418FC2F558764B52410AD7A3309C5039418FC2F538764B52410AD7A3307F5039418FC2F578764B52410AD7A3306C5039418FC2F538764B52410AD7A3303E5039418FC2F578784B52410AD7A3B02A5039418FC2F5D87A4B52410AD7A3B0145039418FC2F5587E4B52410AD7A3B00B5039418FC2F538814B52410AD7A330FC4F39418FC2F598864B52410AD7A330F04F39418FC2F5388D4B52410AD7A330E24F39418FC2F5B8934B52410AD7A330D54F39418FC2F598974B52410AD7A3B0C24F39418FC2F5589A4B52410AD7A330AA4F39418FC2F5989D4B52410AD7A3B0894F39418FC2F5789F4B5
 2410AD7A3305D4F39418FC2F598A14B52410AD7A3B02D4F39418FC2F5D8A44B52410AD7A330124F39418FC2F518A84B52410AD7A330FC4E39418FC2F578AB4B52410AD7A3B0E24E39418FC2F598AD4B52410AD7A330D84E39418FC2F558B14B52410AD7A3B0C44E39418FC2F538B54B52410AD7A330AB4E39418FC2F578BA4B52410AD7A3B08B4E39418FC2F5B8BE4B52410AD7A3B06A4E39418FC2F518C24B52410AD7A3305B4E39418FC2F578C34B52410AD7A3303F4E39418FC2F518C74B52410AD7A3302F4E39418FC2F558C84B52410AD7A3B0234E39418FC2F578C64B52410AD7A3301B4E39418FC2F5D8C14B52410AD7A330184E39418FC2F518BE4B52410AD7A3B0144E39418FC2F5F8B84B52410AD7A330F74D39418FC2F558B94B52410AD7A3B0FC4D39418FC2F5D8BF4B52410AD7A330F94D39418FC2F598C44B52410AD7A3B0E74D39418FC2F5B8C74B52410AD7A3B0D64D39418FC2F5D8CA4B52410AD7A330BC4D39418FC2F558CC4B52410AD7A3B0A74D39418FC2F518CE4B52410AD7A3308B4D39418FC2F538D04B52410AD7A3B0754D39418FC2F5F8D14B52410AD7A330614D39418FC2F578D54B52410AD7A330484D39418FC2F5F8D84B52410AD7A330314D39418FC2F518DC4B52412F000000C0EC9ECCF7523941226C78366A4C524140A4DFCEF75239415E
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
 134113624704C5241D0B359F5015339410A682224704C524100917EFB0153394142F1631C704C5241C854C1F801533941B27BF218704C5241F4B050FB01533941D634EF18704C5241A42C438C01533941E8FBA9156C4C52417CD0B3890153394132E6AE156C4C52416C787A6501533941780B24E86B4C5241900F7AF6005339419A779CBE6B4C5241DC4603A800533941240681B16B4C5241746891AD00533941244A7BAF6B4C524190ED7C6FF8523941BAB88D466A4C5241B459F569F8523941BC7493486A4C5241F0D24D12F8523941FCCBEE396A4C5241C0EC9ECCF7523941226C78366A4C524128000000E02D907090533941D066D5CB174D524190C2F5489B5339417A36AB7E164D52411CEBE2469B5339412CF6977D164D5241FC5C6DD59B533941A679C765164D5241D8C56D449C5339413889413C164D524120B072489C533941A2D63437164D524160C3D34B9C533941B81E8537164D524134EF38559F5339416EA30128144D52413C4ED1519F533941585BB127144D5241F085C9749F533941A6BDC1FB134D52411C7C61729F533941A223B9F8134D52419C33A2749F533941C6DCB5F8134D52414894F6069F53394178E926790F4D5241E43FA44F9F5339417EFB3A74124D5241C0CAA1C5AB5339417A58A845114D52415CFE435AB8533941AED85F1A0F4D5241CC32
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
 96BF9835139418638D6C1044D524104000000A8C64B27735139419A081BA62C4C52412497FF109E5139419CA223852E4C5241D0B359D59A51394196B20C612E4C5241A8C64B27735139419A081BA62C4C5241
+ </op>
+</test>
+</case>
+</run>
Copied: trunk/tests/xmltester/tests/ticket/bug360.xml (from rev 3289, trunk/tests/xmltester/tests/bug360.xml)
--- trunk/tests/xmltester/tests/ticket/bug360.xml	                        (rev 0)
+++ trunk/tests/xmltester/tests/ticket/bug360.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -0,0 +1,22 @@
+<run>
+  <desc>
+http://trac.osgeo.org/geos/ticket/360
+  </desc>
+  <precisionModel type="FLOATING" />
+<case>
+  <desc>
+Exception on CascadedUnion (JTS works!)
+  </desc>
+  <a>
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
 124A21B12F11D5241010300000001000000060000009C8CC751B8483A4118E57CB8FD1D52413551951AB9483A41DAABCF0F001E52417E74A8A5BA483A41C45FD389FF1D52415374A8A5BA483A41C45FD389FF1D52417E74A8A5BA483A41B95FD389FF1D52419C8CC751B8483A4118E57CB8FD1D5241</a>
+<test>
+ <op name="union" arg1="A">
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
+ </op>
+</test>
+</case>
+</run>
Copied: trunk/tests/xmltester/tests/ticket/bug366.xml (from rev 3289, trunk/tests/xmltester/tests/bug366.xml)
--- trunk/tests/xmltester/tests/ticket/bug366.xml	                        (rev 0)
+++ trunk/tests/xmltester/tests/ticket/bug366.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -0,0 +1,23 @@
+<run>
+  <desc>
+    http://trac.osgeo.org/geos/ticket/366
+    Unable to find edge to compute depths at at -200016 249553
+  </desc>
+  <resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
+<case>
+  <desc>
+  </desc>
+  <a>
+010600000001000000010300000001000000430000000DD099A7C7BD05C10000000010770E41EBB1C54FEDCA05C1CCA26DE993F10D41AB1E6C42C2EF05C1D7671DD628780D41A75458319C6806C183FA179D57DB0D41FD31ACF35E0807C1F904B274BC300E41C5606C75B9B507C169C3D67252650E41643B759A4E6908C17C28D55402770E41253271484F6908C1D1B5CF70FF760E4196E03414516908C14FCABE34ED760E41105F5B3A5B6908C11996CABFCB760E414D3086B56B6908C142DC48EAAC760E41186E91E3816908C1186E91E391760E414A097E7F826908C1C9B79A6391760E414B097E7F826908C1C8B79A6391760E414F097E7F826908C1C5B79A6391760E4142DC48EA9C6908C14D3086B57B760E411996CABFBB6908C1105F5B3A6B760E414FCABE34DD6908C196E0341461760E4100000000006A08C10A25EBA65D760E41B13541CB226A08C196E0341461760E41E7693540446A08C1105F5B3A6B760E41BE23B715636A08C14D3086B57B760E41B1F681807D6A08C1C5B79A6391760E41B5F681807D6A08C1C8B79A6391760E41B6F681807D6A08C1C9B79A6391760E41E8916E1C7E6A08C1186E91E391760E41B3CF794A946A08C142DC48EAAC760E41F0A0A4C5A46A08C11996CABFCB760E416A1FCBEBAE6A08C14FCABE34ED760E415D4D7BFBB06A08C10
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
 C114E940F9C7430F411530CCF5BF5406C19BAF9406E8630F4166203B26D81106C14D0D57E70F8F0F410EFB351CDE0006C1F3284448F9980F41BEEB2AF1DCF105C12DEF4FF6E67C0F41EBB1C54FEDCA05C1365D92168CFC0E410DD099A7C7BD05C10000000010770E41
+  </a>
+<test>
+  <op name='buffer' arg1='A' arg2='1'>
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
 780D41E99D0A581A090BC13FE1EC9691F10D4163B25DA61A090BC1446CB02093F10D411F9B894E40160BC188CF42370F770E41
+  </op>
+</test>
+</case>
+</run>
Copied: trunk/tests/xmltester/tests/ticket/bug398.xml (from rev 3289, trunk/tests/xmltester/tests/bug398.xml)
--- trunk/tests/xmltester/tests/ticket/bug398.xml	                        (rev 0)
+++ trunk/tests/xmltester/tests/ticket/bug398.xml	2011-04-20 15:55:53 UTC (rev 3290)
@@ -0,0 +1,48 @@
+<run>
+  <desc>
+http://trac.osgeo.org/geos/ticket/398
+  </desc>
+<case>
+  <desc><![CDATA[
+Assertion `shellCount <= 1' failed.
+  ]]></desc>
+  <a>
+MULTIPOLYGON (((60.0 6.5105151320986412,
+44.0044859469790026 11.6931320480208569, 0.0 25.9507790663861222,
+0.0 26.8608278557796467, 0.0 29.8387923019253307, 60.0 10.3985283676378408,
+60.0 7.8021345594223774, 60.0000000000000000 6.6570998796460161, 60.0
+6.5105151320986412)), ((43.3161197496508308 0.0,
+0.0 0.0, 0.0 14.0346133423735822, 0.0 17.9226661292310787,
+0.0 21.5874865260243638, 34.0258524396557860
+6.8981402622972743, 55.3161197496508308 0.0,
+50.0044466166182886 0.0, 43.3161197496508308
+0.0)), ((13.4455725323347899 36.0,
+60.0 36.0, 60.0 16.7944518298098018, 60.0 16.3644011555093201,
+60.0 14.0439960304547569, 2.9187843276549756
+36.0, 11.8945390820010992 36.0, 13.4455725323347899 36.0)))
+  </a>
+  <b>
+POLYGON ((50.0044466166182886 0.0,
+0.0 21.5874865260243638, 0.0
+35.7392139719321804, 60.0 13.1838946818537934,
+60.0 0.0, 50.0044466166182886 0.0))
+  </b>
+<test>
+MULTIPOLYGON (((0.0 0.0, 0.0 14.0346133423735822, 0.0 17.9226661292310787,
+0.0 21.5874865260243638, 0.0 25.9507790663861222, 0.0 26.8608278557796467,
+0.0 29.8387923019253307, 0.0 35.7392139719321804, 60.0 13.1838946818537934,
+60.0 10.3985283676378408, 60.0 7.8021345594223774, 60.0 6.6570998796460161,
+60.0 6.5105151320986412, 60.0 0.0, 55.3161197496508308 0.0,
+50.0044466166182886 0.0, 43.3161197496508308 0.0, 0.0 0.0)),
+((2.9187843276549756 36.0, 11.8945390820010992 36.0, 13.4455725323347899
+36.0, 60.0 36.0, 60.0 16.7944518298098018, 60.0 16.3644011555093201,
+60.0 14.0439960304547569, 2.9187843276549756 36.0)))'
+ </op>
+</test>
+</case>
+</run>
More information about the geos-commits mailing list
