[geos-commits] r3526 - branches/3.3/tests/xmltester/tests/safe
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Dec 2 04:44:40 EST 2011
Author: strk
Date: 2011-12-02 01:44:40 -0800 (Fri, 02 Dec 2011)
New Revision: 3526
   branches/3.3/tests/xmltester/tests/safe/buffer-1.01.xml
Add <resultMatcher> tag to make the test runnable with JTS
Modified: branches/3.3/tests/xmltester/tests/safe/buffer-1.01.xml
--- branches/3.3/tests/xmltester/tests/safe/buffer-1.01.xml	2011-12-02 09:42:02 UTC (rev 3525)
+++ branches/3.3/tests/xmltester/tests/safe/buffer-1.01.xml	2011-12-02 09:44:40 UTC (rev 3526)
@@ -1,5 +1,6 @@
 <run>
 <precisionModel type="FLOATING"/>
+<resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
 <case>
   <desc>GEOS 3.3.1 produces rectangle buffer, GEOS 3.2.0 fine (#494)</desc>
More information about the geos-commits mailing list
