[geos-commits] r3529 - in trunk/tests/unit: . noding/snapround
svn_geos at osgeo.org svn_geos at osgeo.org
Wed Dec 7 06:17:59 EST 2011
Author: strk
Date: 2011-12-07 03:17:58 -0800 (Wed, 07 Dec 2011)
New Revision: 3529
Added:
   trunk/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp
   trunk/tests/unit/Makefile.am
Add a simple test for MCIndexSnapRounderTest
The test would fail before the fix in r3528
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am	2011-12-06 17:26:46 UTC (rev 3528)
+++ trunk/tests/unit/Makefile.am	2011-12-07 11:17:58 UTC (rev 3529)
@@ -77,6 +77,7 @@
 	noding/SegmentNodeTest.cpp \
 	noding/SegmentPointComparatorTest.cpp \
 	noding/snapround/HotPixelTest.cpp \
+	noding/snapround/MCIndexSnapRounderTest.cpp \
 	operation/buffer/BufferOpTest.cpp \
 	operation/buffer/BufferParametersTest.cpp \
 	operation/distance/DistanceOpTest.cpp \
Added: trunk/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp
--- trunk/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp	                        (rev 0)
+++ trunk/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp	2011-12-07 11:17:58 UTC (rev 3529)
@@ -0,0 +1,145 @@
+// Test Suite for geos::noding::snapround::MCIndexSnapRounder class.
+#include <tut.hpp>
+// geos
+#include <geos/noding/SegmentNode.h>
+#include <geos/noding/Noder.h>
+#include <geos/noding/NodedSegmentString.h>
+#include <geos/noding/SegmentString.h>
+#include <geos/noding/snapround/MCIndexSnapRounder.h>
+#include <geos/io/WKTWriter.h>
+#include <geos/io/WKBWriter.h>
+#include <geos/io/WKTReader.h>
+#include <geos/io/WKBReader.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/CoordinateArraySequenceFactory.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/MultiLineString.h>
+// std
+#include <memory>
+#include <fstream>
+#include <string>
+#include <iomanip>
+#include <iostream>
+namespace tut
+    // Test Group
+    // Common data used by all tests
+    struct test_mcidxsnprndr_data
+      typedef geos::noding::SegmentString SegmentString;
+      typedef geos::noding::NodedSegmentString NodedSegmentString;
+      typedef geos::noding::snapround::MCIndexSnapRounder MCIndexSnapRounder;
+      typedef geos::noding::Noder Noder;
+      typedef geos::io::WKTReader WKTReader;
+      typedef geos::io::WKBReader WKBReader;
+      typedef geos::io::WKTWriter WKTWriter;
+      typedef geos::io::WKBWriter WKBWriter;
+      typedef geos::geom::Geometry Geometry;
+      typedef geos::geom::PrecisionModel PrecisionModel;
+      typedef geos::geom::CoordinateSequence CoordinateSequence;
+      typedef std::auto_ptr<CoordinateSequence> CoordSeqPtr;
+      typedef std::auto_ptr<Geometry> GeomPtr;
+      typedef std::vector<SegmentString*> SegStrVct;
+      typedef std::vector<Geometry*> GeomVct;
+      const geos::geom::GeometryFactory gf_;
+      test_mcidxsnprndr_data()
+            : gf_()
+      GeomPtr getGeometry(SegStrVct& vct)
+        GeomVct *lines = new GeomVct;
+        for (SegStrVct::size_type i=0, n=vct.size(); i<n; ++i)
+          SegmentString* ss = vct[i];
+          lines->push_back( gf_.createLineString(*(ss->getCoordinates())) );
+        return GeomPtr(gf_.createMultiLineString(lines));
+      void getSegmentStrings(const Geometry& g, SegStrVct& vct)
+        CoordSeqPtr s ( g.getCoordinates() );
+        vct.push_back( new NodedSegmentString(s.release(), 0) );
+      GeomPtr readGeometry(const std::string& wkt)
+        GeomPtr g;
+        if ( wkt[0] == '0' || wkt[0] == '1' ) {
+          WKBReader r;
+          std::istringstream is(wkt);
+          g.reset( r.readHEX(is) );
+        } else {
+          WKTReader r;
+          g.reset( r.read(wkt) );
+        return g;
+      void getSegmentStrings(const std::string& wkt, SegStrVct& vct)
+        GeomPtr g = readGeometry(wkt);
+        getSegmentStrings(*g, vct);
+      void freeSegmentStrings(SegStrVct& vct)
+          delete vct[i];
+    typedef test_group<test_mcidxsnprndr_data> group;
+    typedef group::object object;
+    group test_mcidxsnprndr_group(
+      "geos::noding::snapround::MCIndexSnapRounder"
+    // Test Cases
+    // This test would fail before fix in r3528
+    template<>
+    template<>
+    void object::test<1>()
+      std::string wkt0("LINESTRING(99739.70596 -2239218.0625,99739.85604 -2239218.21258,99739.85605 -2239218.21258, 99739.85605 -2239218.21258,99739.86851 -2239218.21258,99739.86851 -2239218.20012, 99739.86851 -2239218.20012,99739.86851 -2239218.04, 99739.95848 -2239218.11015,99739.86851 -2239218.20012, 99739.86851 -2239218.20012,99739.85605 -2239218.21258, 99739.85605 -2239218.21258,99739.80901 -2239218.25961, 99739.80901 -2239218.25961,99739.68863 -2239218.38, 99739.86204 -2239218.31264,99739.80901 -2239218.25961, 99739.80901 -2239218.25961,99739.66841 -2239218.11901)");
+      SegStrVct nodable;
+      getSegmentStrings(wkt0, nodable);
+      ensure_equals( nodable.size(), 1u );
+      PrecisionModel pm(1e-5);
+      MCIndexSnapRounder noder(pm);
+      noder.computeNodes(&nodable);
+      std::auto_ptr<SegStrVct> noded ( noder.getNodedSubstrings() );
+      ensure_equals( "1e-5", noded->size(), 178u );
+      freeSegmentStrings(*noded);
+      freeSegmentStrings(nodable);
+} // namespace tut
More information about the geos-commits mailing list
