[geos-commits] r3542 - in trunk: macros tools
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Dec 12 04:59:00 EST 2011
Author: strk
Date: 2011-12-12 01:59:00 -0800 (Mon, 12 Dec 2011)
New Revision: 3542
   trunk/macros/geos.m4
   trunk/tools/geos-config.in
Add --clibs to geos-config and GEOS_C_LIBS to geos.m4 (#497)
Modified: trunk/macros/geos.m4
--- trunk/macros/geos.m4	2011-12-12 09:57:21 UTC (rev 3541)
+++ trunk/macros/geos.m4	2011-12-12 09:59:00 UTC (rev 3542)
@@ -1,7 +1,7 @@
 dnl
 dnl GEOS_INIT (MINIMUM_VERSION)
 dnl
-dnl Test for GEOS: define HAVE_GEOS, GEOS_LIBS, GEOS_CFLAGS, GEOS_VERSION
+dnl Test for GEOS: define HAVE_GEOS, GEOS_LIBS, GEOS_C_LIBS, GEOS_CFLAGS, GEOS_VERSION
 dnl
 dnl Call as GEOS_INIT or GEOS_INIT(minimum version) in configure.in. Test
 dnl HAVE_GEOS (yes|no) afterwards. If yes, all other vars above can be
@@ -16,6 +16,8 @@
 AC_DEFUN([GEOS_INIT],[
 	AC_SUBST(GEOS_LIBS)
 	AC_SUBST(GEOS_CFLAGS)
+	AC_SUBST(GEOS_C_LIBS)
+	AC_SUBST(GEOS_C_CFLAGS)
 	AC_SUBST(HAVE_GEOS)
 	AC_SUBST(GEOS_VERSION)
@@ -75,6 +77,7 @@
           AC_MSG_RESULT(yes)
           HAVE_GEOS="yes"
           GEOS_LIBS="`$GEOS_CONFIG --libs`"
+          GEOS_C_LIBS="`$GEOS_CONFIG --ldflags` -lgeos_c"
           GEOS_CFLAGS="`$GEOS_CONFIG --cflags`"
           GEOS_VERSION="`$GEOS_CONFIG --version`"
         else
Modified: trunk/tools/geos-config.in
--- trunk/tools/geos-config.in	2011-12-12 09:57:21 UTC (rev 3541)
+++ trunk/tools/geos-config.in	2011-12-12 09:59:00 UTC (rev 3542)
@@ -11,6 +11,7 @@
      [--prefix]
      [--version]
      [--libs]
+     [--clibs]
      [--cflags]
      [--ldflags]
      [--includes]
@@ -39,6 +40,9 @@
     --libs)
       echo -L${libdir} -lgeos
+    --clibs)
+      echo -L${libdir} -lgeos_c
     --ldflags)
       echo -L${libdir}
More information about the geos-commits mailing list
