[geos-commits] r3433 - in trunk/tests/unit: . operation operation/polygonize
svn_geos at osgeo.org svn_geos at osgeo.org
Wed Jul 20 04:46:21 EDT 2011
Author: strk
Date: 2011-07-20 01:46:21 -0700 (Wed, 20 Jul 2011)
New Revision: 3433
Added:
   trunk/tests/unit/operation/polygonize/
   trunk/tests/unit/operation/polygonize/PolygonizeTest.cpp
   trunk/tests/unit/Makefile.am
Port JTS unit test for Polygonizer class (very light..)
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am	2011-07-07 08:33:03 UTC (rev 3432)
+++ trunk/tests/unit/Makefile.am	2011-07-20 08:46:21 UTC (rev 3433)
@@ -85,6 +85,7 @@
 	operation/overlay/validate/OverlayResultValidatorTest.cpp \
 	operation/overlay/snap/GeometrySnapperTest.cpp \
 	operation/overlay/snap/LineStringSnapperTest.cpp \
+	operation/polygonize/PolygonizeTest.cpp \
 	operation/sharedpaths/SharedPathsOpTest.cpp \
 	operation/union/CascadedPolygonUnionTest.cpp \
 	operation/union/UnaryUnionOpTest.cpp \
Added: trunk/tests/unit/operation/polygonize/PolygonizeTest.cpp
--- trunk/tests/unit/operation/polygonize/PolygonizeTest.cpp	                        (rev 0)
+++ trunk/tests/unit/operation/polygonize/PolygonizeTest.cpp	2011-07-20 08:46:21 UTC (rev 3433)
@@ -0,0 +1,190 @@
+// $Id$
+// Test Suite for geos::operation::polygonize::Polygonizer class.
+// Port of junit/operation/polygonize/PolygonizeTest.java
+// tut
+#include <tut.hpp>
+// geos
+#include <geos/operation/polygonize/Polygonizer.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/Point.h>
+#include <geos/io/WKTReader.h>
+#include <geos/io/WKTWriter.h>
+// std
+#include <memory>
+#include <string>
+#include <vector>
+#include <iostream>
+namespace tut
+    // Test Group
+    // Common data used by tests
+    struct test_polygonizetest_data
+        geos::geom::GeometryFactory gf;
+        geos::io::WKTReader wktreader;
+        geos::io::WKTWriter wktwriter;
+        typedef geos::geom::Geometry::AutoPtr GeomPtr;
+        typedef geos::geom::Geometry Geom;
+        typedef geos::geom::Polygon Poly;
+        typedef geos::operation::polygonize::Polygonizer Polygonizer;
+        test_polygonizetest_data()
+          : gf(),
+            wktreader(&gf)
+          wktwriter.setTrim(true);
+        template <class T>
+        void delAll(T& cnt)
+          for (typename T::iterator i=cnt.begin(), e=cnt.end(); i!=e; ++i) {
+            delete *i;
+        void printAll(std::ostream& os, T& cnt)
+            os << **i;
+        GeomPtr readWKT(const std::string& inputWKT)
+            return GeomPtr(wktreader.read(inputWKT));
+        void readWKT(const char* const* inputWKT, std::vector<Geom*>& geoms)
+          for (const char* const* ptr=inputWKT; *ptr; ++ptr) {
+            geoms.push_back(readWKT(*ptr).release());
+        bool contains( T& cnt, const Geom* g)
+            const Geom* element = *i;
+            if (element->equalsExact(g)) {
+              return true;
+          return false;
+        template <class T, class S>
+        bool compare( T& ex, S& ob)
+          using std::cout;
+          using std::endl;
+          if ( ex.size() != ob.size() ) {
+            cout << "Expected " << ex.size() << " polygons, obtained "
+                 << ob.size() << endl;
+            return false;
+          for (typename T::iterator i=ex.begin(), e=ex.end(); i!=e; ++i) {
+            if ( ! contains(ob, *i) ) {
+              cout << "Expected " << wktwriter.write(*i)
+                   << " not found" << endl;
+              return false;
+          return true;
+        bool doTest(const char* const* inputWKT, const char* const* expectWKT)
+          using std::cout;
+          using std::endl;
+          std::vector<Geom*> inputGeoms, expectGeoms;
+          readWKT(inputWKT, inputGeoms);
+          readWKT(expectWKT, expectGeoms);
+          Polygonizer polygonizer;
+          polygonizer.add(&inputGeoms);
+          std::auto_ptr< std::vector<Poly*> > retGeoms;
+          retGeoms.reset( polygonizer.getPolygons() );
+          delAll(inputGeoms);
+          bool ok = compare(expectGeoms, *retGeoms);
+          if  ( ! ok ) {
+            cout << "OBTAINED(" << retGeoms->size() << "): ";
+            printAll(cout, *retGeoms);
+            cout << endl;
+            ensure( "not all expected geometries in the obtained set", 0 );
+          delAll(expectGeoms);
+          delAll(*retGeoms);
+          return ok;
+    typedef test_group<test_polygonizetest_data> group;
+    typedef group::object object;
+    group test_polygonizetest_group("geos::operation::polygonize::Polygonizer");
+    template<>
+    template<>
+    void object::test<1>()
+        static char const* const inp[] = {
+            "LINESTRING EMPTY",
+            NULL
+        static char const* const exp[] = {
+            NULL
+        doTest(inp, exp);
+    template<>
+    template<>
+    void object::test<2>()
+            "LINESTRING (100 180, 20 20, 160 20, 100 180)",
+            "LINESTRING (100 180, 80 60, 120 60, 100 180)",
+            NULL
+            "POLYGON ((100 180, 120 60, 80 60, 100 180))",
+            "POLYGON ((100 180, 160 20, 20 20, 100 180), (100 180, 80 60, 120 60, 100 180))",
+            NULL
+        doTest(inp, exp);
+} // namespace tut
More information about the geos-commits mailing list
