[geos-commits] r3339 - trunk/src/algorithm
svn_geos at osgeo.org svn_geos at osgeo.org
Tue May 10 05:51:05 EDT 2011
Author: strk
Date: 2011-05-10 02:51:05 -0700 (Tue, 10 May 2011)
New Revision: 3339
   trunk/src/algorithm/HCoordinate.cpp
Drop STORE_INTERMEDIATE_COMPUTATION_VALUES macro and protected non-unrolled computation, that is all paranoia aimed at making floats stored to match java IEEE. Since we get no failures in testsuite (our and postgis') I think it makes sense to have the code as close as possible to the JTS one.
Modified: trunk/src/algorithm/HCoordinate.cpp
--- trunk/src/algorithm/HCoordinate.cpp	2011-05-10 09:50:44 UTC (rev 3338)
+++ trunk/src/algorithm/HCoordinate.cpp	2011-05-10 09:51:05 UTC (rev 3339)
@@ -34,9 +34,6 @@
 #define GEOS_DEBUG 0
 #endif
-// Define to make -ffloat-store be effective for this class
-#define STORE_INTERMEDIATE_COMPUTATION_VALUES 1
 using namespace std;
 using namespace geos::geom;
@@ -58,12 +55,6 @@
 	     << " q2: " << q2 << endl;
 #endif
-#if 0 // NOTE: unrolled computation is intentionally turned off
-      //       as it makes the algorithm less stable numerically
-      //       In particular the first case in TestBufferMitredJoin.xml
-      //       would fail with unrolled computation on and no input
-      //       simplification in operation/buffer/OffsetCurveBuilder.cpp
 	// unrolled computation
 	double px = p1.y - p2.y;
@@ -87,20 +78,6 @@
 	ret = Coordinate(xInt, yInt);
-#else
-	HCoordinate hc1p1(p1);
-	HCoordinate hc1p2(p2);
-	HCoordinate l1(hc1p1, hc1p2);
-	HCoordinate hc2q1(q1);
-	HCoordinate hc2q2(q2);
-	HCoordinate l2(hc2q1, hc2q2);
-	HCoordinate intHCoord(l1, l2);
-	intHCoord.getCoordinate(ret);
-#endif
 /*public*/
@@ -159,8 +136,6 @@
 /*public*/
-#ifndef STORE_INTERMEDIATE_COMPUTATION_VALUES
 HCoordinate::HCoordinate(const HCoordinate &p1, const HCoordinate &p2)
 	x( p1.y*p2.w - p2.y*p1.w ),
@@ -169,46 +144,12 @@
-#else // def STORE_INTERMEDIATE_COMPUTATION_VALUES
-HCoordinate::HCoordinate(const HCoordinate &p1, const HCoordinate &p2)
-        double xf1 = p1.y*p2.w;
-        double xf2 = p2.y*p1.w;
-        x = xf1 - xf2;
-        double yf1 = p2.x*p1.w;
-        double yf2 = p1.x*p2.w;
-        y = yf1 - yf2;
-        double wf1 = p1.x*p2.y;
-        double wf2 = p2.x*p1.y;
-        w = wf1 - wf2;
-#if GEOS_DEBUG
-        cerr
-             << " xf1: " << xf1 << endl
-             << " xf2: " << xf2 << endl
-             << " yf1: " << yf1 << endl
-             << " yf2: " << yf2 << endl
-             << " wf1: " << wf1 << endl
-             << " wf2: " << wf2 << endl
-             << "   x: " << x << endl
-             << "   y: " << y << endl
-             << "   w: " << w << endl;
-#endif // def GEOS_DEBUG
-#endif // def STORE_INTERMEDIATE_COMPUTATION_VALUES
 /*public*/
 double
 HCoordinate::getX() const
 	double a = x/w;
-	//if (std::fabs(a) > std::numeric_limits<double>::max())
-	if ( !FINITE(a) )
+	if ( !FINITE(a) ) {
 		throw NotRepresentableException();
 	return a;
@@ -219,10 +160,7 @@
 HCoordinate::getY() const
 	double a = y/w;
-	if ( !FINITE(a) )
 	return a;
More information about the geos-commits mailing list
