[geos-commits] r3524 - in branches/3.3: .
include/geos/noding/snapround src/noding/snapround
tests/unit/operation/buffer
svn_geos at osgeo.org
Wed Nov 30 04:49:58 EST 2011
Author: strk
Date: 2011-11-30 01:49:58 -0800 (Wed, 30 Nov 2011)
New Revision: 3524
branches/3.3/NEWS
branches/3.3/include/geos/noding/snapround/MCIndexSnapRounder.h
branches/3.3/src/noding/snapround/MCIndexSnapRounder.cpp
branches/3.3/tests/unit/operation/buffer/BufferOpTest.cpp
Fix MCIndexSnapRounder use of provided precision model.
Fixes bug #473 (RightmostEdgeFinder assertion failure).
Includes regression test.
Modified: branches/3.3/NEWS
--- branches/3.3/NEWS 2011-11-30 09:45:49 UTC (rev 3523)
+++ branches/3.3/NEWS 2011-11-30 09:49:58 UTC (rev 3524)
@@ -7,6 +7,7 @@
- Fix noding of self-intersecting lines through UnaryUnion (#482)
- Fix handling of collapsed edges skipping in BufferOp (#494)
- Print up to 18 digits of precision for TopologyException points
+ - Fix noding with reduced precision in Buffer operation (#473)
Changes in 3.3.1
2011-09-27
Modified: branches/3.3/include/geos/noding/snapround/MCIndexSnapRounder.h
--- branches/3.3/include/geos/noding/snapround/MCIndexSnapRounder.h 2011-11-30 09:45:49 UTC (rev 3523)
+++ branches/3.3/include/geos/noding/snapround/MCIndexSnapRounder.h 2011-11-30 09:49:58 UTC (rev 3524)
@@ -13,7 +13,7 @@
- * Last port: noding/snapround/MCIndexSnapRounder.java r320 (JTS-1.12)
+ * Last port: noding/snapround/MCIndexSnapRounder.java r480 (JTS-1.12)
@@ -81,7 +81,9 @@
pm(nPm),
scaleFactor(nPm.getScale()),
pointSnapper(0)
+ li.setPrecisionModel(&pm);
std::vector<SegmentString*>* getNodedSubstrings() const {
return NodedSegmentString::getNodedSubstrings(*nodedSegStrings);
Modified: branches/3.3/src/noding/snapround/MCIndexSnapRounder.cpp
--- branches/3.3/src/noding/snapround/MCIndexSnapRounder.cpp 2011-11-30 09:45:49 UTC (rev 3523)
+++ branches/3.3/src/noding/snapround/MCIndexSnapRounder.cpp 2011-11-30 09:49:58 UTC (rev 3524)
@@ -13,7 +13,7 @@
Modified: branches/3.3/tests/unit/operation/buffer/BufferOpTest.cpp
--- branches/3.3/tests/unit/operation/buffer/BufferOpTest.cpp 2011-11-30 09:45:49 UTC (rev 3523)
+++ branches/3.3/tests/unit/operation/buffer/BufferOpTest.cpp 2011-11-30 09:49:58 UTC (rev 3524)
@@ -270,5 +270,49 @@
ensure(gBuffer->getNumPoints() >= std::size_t(5));
+ // Test for ticket #473
+ template<>
+ template<>
+ void object::test<10>()
+ using geos::operation::buffer::BufferOp;
+ using geos::operation::buffer::BufferParameters;
+ std::string wkt0("\
+MULTILINESTRING( \
+ (-22720.6801580484 130376.223341197, \
+ -22620.6136206117 130339.222540348, \
+ -22620.6133224902 130339.333510463), \
+ (-22720.3807106115 130487.193473695, \
+ -22620.3154956134 130450.192663993, \
+ -22620.3151974850 130450.303634126), \
+ (-22620.6133224902 130339.333510463, -22620.6127262471 130339.555450692), \
+ (-22620.1376011539 130450.303157004, -22620.3151974850 130450.303634126), \
+ (-22620.3151974850 130450.303634126, -22620.3146012281 130450.525574392), \
+ (-21480.3713729115 130150.471377565, \
+ -21481.6134583498 130150.918429232, \
+ -21482.5899891895 130151.031891269, \
+ -21480.9946803241 130149.807142948), \
+ (-21477.6185334698 130150.464355720,\
+ -21478.0611246018 130151.020338484, \
+ -21377.8977465929 130114.034129489) \
+ GeomPtr g0(wktreader.read(wkt0));
+ BufferParameters params(8, BufferParameters::CAP_SQUARE,
+ BufferParameters::JOIN_MITRE,
+ 1.0);
+ const double distance = 5.0;
+ BufferOp op(g0.get(), params);
+ GeomPtr gBuffer(op.getResultGeometry(distance));
+ // We're basically only interested an rough sense of a
+ // meaningful result.
+ ensure_equals(gBuffer->getNumPoints(), std::size_t(46));
+ ensure_equals(int(gBuffer->getArea()), 3520);
} // namespace tut
More information about the geos-commits
