[geos-commits] r3494 - in trunk: . capi cmake include src tests tests/bigtest tests/unit tests/xmltester tools
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Oct 4 11:43:23 EDT 2011
Author: hobu
Date: 2011-10-04 08:43:22 -0700 (Tue, 04 Oct 2011)
New Revision: 3494
   trunk/
   trunk/capi/
   trunk/cmake/
   trunk/include/
   trunk/src/
   trunk/tests/
   trunk/tests/bigtest/
   trunk/tests/unit/
   trunk/tests/xmltester/
   trunk/tools/
propsets to svn:ignore CMake build junk
Property changes on: trunk
___________________________________________________________________
Modified: svn:ignore
   - aclocal.m4
autom4te.cache
config.guess
config.log
config.status
config.sub
configure
depcomp
install-sh
libtool
ltmain.sh
missing
mkinstalldirs
Makefile
Makefile.in
py-compile
tags
ID
*.swp
.gdb*
   + aclocal.m4
autom4te.cache
config.guess
config.log
config.status
config.sub
configure
depcomp
install-sh
libtool
ltmain.sh
missing
mkinstalldirs
Makefile
Makefile.in
py-compile
tags
ID
*.swp
.gdb*
CMakeFiles
*.cmake
cmake_install.*
CMakeCache.txt
Property changes on: trunk/capi
   - .deps
.libs
*.lo
*.la
*.obj
geos_c.h
geostest
Makefile
Makefile.in
test.out
testrunner
   + .deps
.libs
*.lo
*.la
*.obj
geos_c.h
geostest
Makefile
Makefile.in
test.out
testrunner
CTestTestfile.cmake
CMakeFiles
cmake_install.cmake
Property changes on: trunk/cmake
Added: svn:ignore
   + cmake_uninstall.cmake
Property changes on: trunk/include
   - Makefile.in
Makefile
config.h
stamp-h.in
stamp-h1
stamp-h2
config.h.in
   + Makefile.in
Makefile
config.h
stamp-h.in
stamp-h1
stamp-h2
CTestTestfile.cmake
CMakeFiles
cmake_install.cmake
config.h.in
Property changes on: trunk/src
   - .libs
.deps
Makefile
Makefile.in
*.dll
*.exp
*.exe
*.ilk
*.la
*.lib
*.lo
*.manifest
*.obj
*.pdb
tags
TAGS
ID
   + .libs
.deps
Makefile
Makefile.in
*.dll
*.exp
*.exe
*.ilk
*.la
*.lib
*.lo
*.manifest
*.obj
*.pdb
tags
TAGS
ID
CTestTestfile.cmake
CMakeFiles
cmake_install.cmake
Property changes on: trunk/tests
   - Makefile
Makefile.in
   + Makefile
Makefile.in
CTestTestfile.cmake
CMakeFiles
cmake_install.cmake
Property changes on: trunk/tests/bigtest
   - bug234
TestSweepLineSpeed
Makefile
Makefile.in
.deps
.libs
   + bug234
CTestTestfile.cmake
CMakeFiles
cmake_install.cmake
TestSweepLineSpeed
Makefile
Makefile.in
.deps
.libs
Property changes on: trunk/tests/unit
   - geostest
threadtest
badthreadtest
.deps
.libs
.gdb*
Makefile
Makefile.in
geos_unit
   + geostest
threadtest
badthreadtest
.deps
.libs
.gdb*
Makefile
Makefile.in
CTestTestfile.cmake
CMakeFiles
cmake_install.cmake
geos_unit
Property changes on: trunk/tests/xmltester
   - .deps
.libs
Makefile
Makefile.in
CTS
CTS.exe
testrunner
SimpleWKTTester
SimpleWKTTester.exe
XMLTester
XMLTester.exe
   + .deps
.libs
Makefile
Makefile.in
CTS
CTS.exe
testrunner
SimpleWKTTester
SimpleWKTTester.exe
XMLTester
XMLTester.exe
CTestTestfile.cmake
CMakeFiles
cmake_install.cmake
Property changes on: trunk/tools
   - Makefile
.cvsignore
geos-config
Makefile.in
   + Makefile
.cvsignore
geos-config
Makefile.in
CTestTestfile.cmake
CMakeFiles
cmake_install.cmake
More information about the geos-commits mailing list
