[geos-commits] r3477 - in branches/3.2: . capi
source/headers/geos/linearref source/linearref
svn_geos at osgeo.org
Wed Sep 21 04:56:30 EDT 2011
Author: strk
Date: 2011-09-21 01:56:30 -0700 (Wed, 21 Sep 2011)
New Revision: 3477
branches/3.2/NEWS
branches/3.2/capi/geos_ts_c.cpp
branches/3.2/source/headers/geos/linearref/LengthIndexOfPoint.h
branches/3.2/source/headers/geos/linearref/LinearIterator.h
branches/3.2/source/linearref/LinearIterator.cpp
branches/3.2/source/linearref/LinearLocation.cpp
Fix LinearReferencing functions segfault (#353)
Modified: branches/3.2/NEWS
--- branches/3.2/NEWS 2011-09-21 08:39:40 UTC (rev 3476)
+++ branches/3.2/NEWS 2011-09-21 08:56:30 UTC (rev 3477)
@@ -6,6 +6,7 @@
- DistanceOp segfaults on MULTIPOLYGON with EMPTY elements (#367)
- RobustDeterminant is not robust (#450)
- Fix out-of-place build for python binding (#332)
+ - Fix LinearReferencing functions segfault (#353)
Changes in 3.2.2
Modified: branches/3.2/capi/geos_ts_c.cpp
--- branches/3.2/capi/geos_ts_c.cpp 2011-09-21 08:39:40 UTC (rev 3476)
+++ branches/3.2/capi/geos_ts_c.cpp 2011-09-21 08:56:30 UTC (rev 3477)
@@ -4403,36 +4403,52 @@
const Geometry *g,
const Geometry *p)
+ if ( 0 == extHandle ) return -1.0;
+ GEOSContextHandleInternal_t *handle =
+ reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if ( handle->initialized == 0 ) return -1.0;
const geos::geom::Point* point = dynamic_cast<const geos::geom::Point*>(p);
if (!point) {
- if ( 0 == extHandle )
- return -1.0;
- GEOSContextHandleInternal_t *handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
- if ( 0 == handle->initialized )
- return -1.0;
handle->ERROR_MESSAGE("third argument of GEOSProject_r must be Point*");
return -1.0;
const geos::geom::Coordinate* inputPt = p->getCoordinate();
- return geos::linearref::LengthIndexedLine(g).project(*inputPt);
+ try {
+ return geos::linearref::LengthIndexedLine(g).project(*inputPt);
+ } catch (const std::exception &e) {
+ handle->ERROR_MESSAGE("%s", e.what());
+ return -1.0;
+ } catch (...) {
+ handle->ERROR_MESSAGE("Unknown exception thrown");
+ return -1.0;
Geometry*
GEOSInterpolate_r(GEOSContextHandle_t extHandle, const Geometry *g, double d)
- geos::linearref::LengthIndexedLine lil(g);
- geos::geom::Coordinate coord = lil.extractPoint(d);
- const GeometryFactory *gf = handle->geomFactory;
- Geometry* point = gf->createPoint(coord);
- return point;
+ if ( 0 == extHandle ) return 0;
+ if ( handle->initialized == 0 ) return 0;
+ try {
+ geos::linearref::LengthIndexedLine lil(g);
+ geos::geom::Coordinate coord = lil.extractPoint(d);
+ const GeometryFactory *gf = handle->geomFactory;
+ Geometry* point = gf->createPoint(coord);
+ return point;
+ return 0;
+ } catch (...) {
+ return 0;
Modified: branches/3.2/source/headers/geos/linearref/LengthIndexOfPoint.h
--- branches/3.2/source/headers/geos/linearref/LengthIndexOfPoint.h 2011-09-21 08:39:40 UTC (rev 3476)
+++ branches/3.2/source/headers/geos/linearref/LengthIndexOfPoint.h 2011-09-21 08:56:30 UTC (rev 3477)
@@ -34,6 +34,15 @@
namespace linearref // geos::linearref
+ * \brief
+ * Computes the length index of the point
+ * on a linear Geometry nearest a given Coordinate.
+ * The nearest point is not necessarily unique; this class
+ * always computes the nearest point closest to
+ * the start of the geometry.
class LengthIndexOfPoint
@@ -53,17 +62,17 @@
LengthIndexOfPoint(const geom::Geometry *linearGeom);
- * Find the nearest location along a linear {@link Geometry} to a given point.
+ * Find the nearest location along a linear Geometry to a given point.
* @param inputPt the coordinate to locate
* @return the location of the nearest point
double indexOf(const geom::Coordinate& inputPt) const;
- * Finds the nearest index along the linear {@link Geometry}
- * to a given {@link Coordinate}
- * after the specified minimum index.
+ /** \brief
+ * Finds the nearest index along the linear Geometry
+ * to a given Coordinate after the specified minimum index.
* If possible the location returned will be strictly greater than the
* <code>minLocation</code>.
* If this is not possible, the
Modified: branches/3.2/source/headers/geos/linearref/LinearIterator.h
--- branches/3.2/source/headers/geos/linearref/LinearIterator.h 2011-09-21 08:39:40 UTC (rev 3476)
+++ branches/3.2/source/headers/geos/linearref/LinearIterator.h 2011-09-21 08:56:30 UTC (rev 3477)
@@ -31,11 +31,11 @@
namespace geos { namespace linearref
+/** \brief
* An iterator over the components and coordinates of a linear geometry
- * ({@link LineString}s and {@link MultiLineString}s.
+ * (LineString or MultiLineString).
- * The standard usage pattern for a {@link LinearIterator} is:
+ * The standard usage pattern for a LinearIterator is:
* <pre>
* for (LinearIterator it = new LinearIterator(...); it.hasNext(); it.next()) {
@@ -52,7 +52,7 @@
public:
- * Creates an iterator initialized to the start of a linear {@link Geometry}
+ * Creates an iterator initialized to the start of a linear Geometry
* @param linear the linear geometry to iterate over
@@ -142,7 +142,8 @@
const unsigned int numLines;
- * Invariant: currentLine <> null if the iterator is pointing at a valid coordinate
+ * Invariant: currentLine <> null if the iterator is pointing
+ * at a valid coordinate
void loadCurrentLine();
Modified: branches/3.2/source/linearref/LinearIterator.cpp
--- branches/3.2/source/linearref/LinearIterator.cpp 2011-09-21 08:39:40 UTC (rev 3476)
+++ branches/3.2/source/linearref/LinearIterator.cpp 2011-09-21 08:56:30 UTC (rev 3477)
@@ -23,6 +23,7 @@
#include <geos/linearref/LinearIterator.h>
#include <geos/linearref/LinearLocation.h>
#include <geos/linearref/LengthLocationMap.h>
+#include <geos/util/IllegalArgumentException.h>
using namespace geos::geom;
@@ -74,6 +75,9 @@
return;
currentLine = dynamic_cast<const LineString *> (linear->getGeometryN(componentIndex));
+ if ( ! currentLine ) {
+ throw util::IllegalArgumentException("LinearIterator only supports lineal geometry components");
bool LinearIterator::hasNext() const
Modified: branches/3.2/source/linearref/LinearLocation.cpp
--- branches/3.2/source/linearref/LinearLocation.cpp 2011-09-21 08:39:40 UTC (rev 3476)
+++ branches/3.2/source/linearref/LinearLocation.cpp 2011-09-21 08:56:30 UTC (rev 3477)
@@ -22,6 +22,7 @@
#include <geos/linearref/LengthIndexedLine.h>
using namespace std;
@@ -201,6 +202,9 @@
LinearLocation::getCoordinate(const Geometry* linearGeom) const
const LineString* lineComp = dynamic_cast<const LineString *> (linearGeom->getGeometryN(componentIndex));
+ if ( ! lineComp ) {
+ throw util::IllegalArgumentException("LinearLocation::getCoordinate only works with LineString geometries");
Coordinate p0 = lineComp->getCoordinateN(segmentIndex);
if (segmentIndex >= lineComp->getNumPoints() - 1)
return p0;
More information about the geos-commits
