[geos-commits] r3483 - trunk/tests/unit/linearref
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Sep 23 08:14:39 EDT 2011
Author: strk
Date: 2011-09-23 05:14:39 -0700 (Fri, 23 Sep 2011)
New Revision: 3483
   trunk/tests/unit/linearref/LengthIndexedLineTest.cpp
Port updates to the LenghtIndexedLineTest testcase (see #323)
Note that the test fails if the library isn't also fixed
Modified: trunk/tests/unit/linearref/LengthIndexedLineTest.cpp
--- trunk/tests/unit/linearref/LengthIndexedLineTest.cpp	2011-09-23 01:03:54 UTC (rev 3482)
+++ trunk/tests/unit/linearref/LengthIndexedLineTest.cpp	2011-09-23 12:14:39 UTC (rev 3483)
@@ -1,12 +1,13 @@
-// Ported from JTS junit/linearref/AbstractIndexedLineTest.java rev. 1.10
-// and  junit/linearref/LengthIndexedLineTest.java rev. 1.10
+// Ported from JTS junit/linearref/AbstractIndexedLineTestCase.java r466
+// and  junit/linearref/LengthIndexedLineTestCase.java r466
 #include <tut.hpp>
 #include <utility.h>
 // geos
 #include <geos/platform.h>
 #include <geos/io/WKTReader.h>
+#include <geos/io/WKTWriter.h>
 #include <geos/geom/PrecisionModel.h>
 #include <geos/geom/GeometryFactory.h>
 #include <geos/geom/Geometry.h> // required for use in auto_ptr
@@ -35,22 +36,26 @@
 struct test_lengthindexedline_data
     test_lengthindexedline_data()
-        : pm(), gf(&pm), reader(&gf)
+        : pm(), gf(&pm), reader(&gf), writer()
+      writer.setTrim(true);
     PrecisionModel pm;
     GeometryFactory gf;
     geos::io::WKTReader reader;
+    geos::io::WKTWriter writer;
     void checkExpected(Geometry* result, string const& expected)
         GeomPtr subLine(reader.read(expected));
-        ensure_equals_geometry(subLine.get(), result);
+        checkExpected(result, subLine.get());
     void checkExpected(Geometry* result, const Geometry* expected)
-        ensure_equals_geometry(expected, result);
+      bool isEqual = result->equalsExact(expected, 1.0e-5);
+      ensure_equals("Expect: "+writer.write(expected)+" Obtained: "+writer.write(result), isEqual, true);
     void runIndicesOfThenExtract(string const& inputStr, string const& subLineStr)
@@ -138,7 +143,7 @@
 group test_lengthindexedline_group("geos::linearref::LocationIndexedLine");
-//1 - testML
+// testML
 template<>
 template<>
 void object::test<1>()
@@ -147,19 +152,19 @@
                             "MULTILINESTRING ((1 1, 10 10), (20 20, 25 25))");
-//2 - testPartOfSegmentNoVertex
+// testPartOfSegmentNoVertex
 template<>
 template<>
-void object::test<2>()
+void object::test<2>()
     runIndicesOfThenExtract("LINESTRING (0 0, 10 10, 20 20)",
                             "LINESTRING (1 1, 9 9)");
-//3 - testPartOfSegmentContainingVertex()
+// testPartOfSegmentContainingVertex()
 template<>
 template<>
-void object::test<3>()
+void object::test<3>()
                             "LINESTRING (5 5, 10 10, 15 15)");
@@ -170,10 +175,10 @@
  * @throws Exception
-// 4 - testPartOfSegmentContainingDuplicateCoords
+// testPartOfSegmentContainingDuplicateCoords
 template<>
 template<>
-void object::test<4>()
+void object::test<4>()
     runIndicesOfThenExtract("LINESTRING (0 0, 10 10, 10 10, 20 20)",
                             "LINESTRING (5 5, 10 10, 10 10, 15 15)");
@@ -184,76 +189,76 @@
  * This requires that the correct vertex for (0,0) is selected.
-//5 - testLoopWithStartSubLine
+// testLoopWithStartSubLine
 template<>
 template<>
-void object::test<5>()
+void object::test<5>()
     runIndicesOfThenExtract("LINESTRING (0 0, 0 10, 10 10, 10 0, 0 0)",
                             "LINESTRING (0 0, 0 10, 10 10)");
-//6 - testLoopWithEndingSubLine()
+// testLoopWithEndingSubLine()
 template<>
 template<>
-void object::test<6>()
+void object::test<6>()
                             "LINESTRING (10 10, 10 0, 0 0)");
 // test a subline equal to the parent loop
-//7 - testLoopWithIdenticalSubLine()
+// testLoopWithIdenticalSubLine()
 template<>
 template<>
-void object::test<7>()
+void object::test<7>()
                             "LINESTRING (0 0, 0 10, 10 10, 10 0, 0 0)");
 // test a zero-length subline equal to the start point
-//8 - testZeroLenSubLineAtStart()
+// testZeroLenSubLineAtStart()
 template<>
 template<>
-void object::test<8>()
+void object::test<8>()
                             "LINESTRING (0 0, 0 0)");
 // test a zero-length subline equal to a mid point
-//9 - testZeroLenSubLineAtMidVertex()
+// testZeroLenSubLineAtMidVertex()
 template<>
 template<>
-void object::test<9>()
+void object::test<9>()
                             "LINESTRING (10 10, 10 10)");
-//10 - testIndexOfAfterSquare()
+// testIndexOfAfterSquare()
 template<>
 template<>
-void object::test<10>()
+void object::test<10>()
     runIndexOfAfterTest("LINESTRING (0 0, 0 10, 10 10, 10 0, 0 0)",
                         "POINT (0 0)");
-//11 - testIndexOfAfterRibbon()
+// testIndexOfAfterRibbon()
 template<>
 template<>
-void object::test<11>()
+void object::test<11>()
     runIndexOfAfterTest("LINESTRING (0 0, 0 60, 50 60, 50 20, -20 20)",
                         "POINT (0 20)");
-//12 -  testOffsetStartPoint()
+// testOffsetStartPoint()
 template<>
 template<>
-void object::test<12>()
+void object::test<12>()
     runOffsetTest("LINESTRING (0 0, 10 10, 10 10, 20 20)", "POINT(0 0)", 1.0, "POINT (-0.7071067811865475 0.7071067811865475)");
     runOffsetTest("LINESTRING (0 0, 10 10, 10 10, 20 20)", "POINT(0 0)", -1.0, "POINT (0.7071067811865475 -0.7071067811865475)");
@@ -261,79 +266,89 @@
     runOffsetTest("LINESTRING (0 0, 10 10, 10 10, 20 20)", "POINT(10 10)", -5.0, "POINT (13.535533905932738 6.464466094067262)");
-//13 - testExtractLineBeyondRange()
+// testExtractLineBothIndicesAtEndpointXXX()
 template<>
 template<>
-void object::test<13>()
+void object::test<13>()
+  checkExtractLine(
+    "MULTILINESTRING ((0 0, 10 0), (20 0, 25 0, 30 0))",
+    -10, 10, "LINESTRING (10 0, 10 0)"
+// testExtractLineBeyondRange()
+template<> template<>
+void object::test<14>()
     checkExtractLine("LINESTRING (0 0, 10 10)", -100, 100, "LINESTRING (0 0, 10 10)");
-//14 - testExtractLineReverse()
+// testExtractLineReverse()
 template<>
 template<>
-void object::test<14>()
+void object::test<15>()
     checkExtractLine("LINESTRING (0 0, 10 0)", 9, 1, "LINESTRING (9 0, 1 0)");
-//15 - testExtractLineReverseMulti()
+// testExtractLineReverseMulti()
 template<>
 template<>
-void object::test<15>()
+void object::test<16>()
     checkExtractLine("MULTILINESTRING ((0 0, 10 0), (20 0, 25 0, 30 0))",
                      19, 1, "MULTILINESTRING ((29 0, 25 0, 20 0), (10 0, 1 0))");
-//16 - testExtractLineNegative()
+// testExtractLineNegative()
 template<>
 template<>
-void object::test<16>()
+void object::test<17>()
     checkExtractLine("LINESTRING (0 0, 10 0)", -9, -1, "LINESTRING (1 0, 9 0)");
-//17 - testExtractLineNegativeReverse()
+// testExtractLineNegativeReverse()
 template<>
 template<>
-void object::test<17>()
+void object::test<18>()
     checkExtractLine("LINESTRING (0 0, 10 0)", -1, -9, "LINESTRING (9 0, 1 0)");
-//18 - testExtractLineIndexAtEndpoint()
+// testExtractLineIndexAtEndpoint()
 template<>
 template<>
-void object::test<18>()
+void object::test<19>()
                      10, -1, "LINESTRING (20 0, 25 0, 29 0)");
-//19 - testExtractLineBothIndicesAtEndpoint()
+// testExtractLineBothIndicesAtEndpoint()
 template<>
 template<>
-void object::test<19>()
+void object::test<20>()
-                     10, 10, "LINESTRING (20 0, 20 0)");
+                     10, 10, "LINESTRING (10 0, 10 0)");
-//20 - testExtractLineBothIndicesAtEndpointNegative()
+// testExtractLineBothIndicesAtEndpointNegative()
 template<>
 template<>
-void object::test<20>()
+void object::test<21>()
-                     -10, 10, "LINESTRING (20 0, 20 0)");
+                     -10, 10, "LINESTRING (10 0, 10 0)");
-//21 - testExtractPointBeyondRange()
+// testExtractPointBeyondRange()
 template<>
 template<>
-void object::test<21>()
+void object::test<22>()
     GeomPtr linearGeom(reader.read("LINESTRING (0 0, 10 10)"));
     LengthIndexedLine indexedLine(linearGeom.get());
@@ -344,10 +359,10 @@
     ensure(pt2 == Coordinate(0, 0));
-//22 - testProjectPointWithDuplicateCoords()
+// testProjectPointWithDuplicateCoords()
 template<>
 template<>
-void object::test<22>()
+void object::test<23>()
     GeomPtr linearGeom(reader.read("LINESTRING (0 0, 10 0, 10 0, 20 0)"));
@@ -359,10 +374,10 @@
  * Tests that z values are interpolated
-//23 - testComputeZ()
+// testComputeZ()
 template<>
 template<>
-void object::test<23>()
+void object::test<24>()
     GeomPtr linearGeom(reader.read("LINESTRING (0 0 0, 10 10 10)"));
@@ -376,10 +391,10 @@
  * Tests that if the input does not have Z ordinates, neither does the output.
-//24 - testComputeZNaN()
+// testComputeZNaN()
 template<>
 template<>
-void object::test<24>()
+void object::test<25>()
     GeomPtr linearGeom(reader.read("LINESTRING (0 0, 10 10 10)"));
@@ -388,6 +403,74 @@
     Coordinate projPt = indexedLine.extractPoint(projIndex);
     ensure(0 != ISNAN(projPt.z));
+ * From GEOS Ticket #323
+// testProjectExtractPoint()
+template<>
+template<>
+void object::test<26>()
+  GeomPtr linearGeom(reader.read("MULTILINESTRING ((0 2, 0 0), (-1 1, 1 1))"));
+  LengthIndexedLine indexedLine(linearGeom.get());
+  double index = indexedLine.project(Coordinate(1, 0));
+  Coordinate pt = indexedLine.extractPoint(index);
+  ensure_equals(pt, Coordinate(0, 0));
+ * Tests that leading and trailing zero-length sublines are trimmed in
+ * the computed result, and that zero-length extracts return the lowest
+ * extracted zero-length line
+// testExtractLineIndexAtEndpointWithZeroLenComponents()
+void object::test<27>()
+  checkExtractLine(
+    "MULTILINESTRING ((0 0, 10 0), (10 0, 10 0), (20 0, 25 0, 30 0))",
+    10, -1, "LINESTRING (20 0, 25 0, 29 0)");
+  checkExtractLine(
+    5, 10, "LINESTRING (5 0, 10 0)");
+  checkExtractLine(
+    "MULTILINESTRING ((0 0,10 0),(10 0,10 0),(10 0,10 0),(20 0,25 0,30 0))",
+  checkExtractLine(
+    "MULTILINESTRING((0 0,10 0),(10 0,10 0),(10 0,10 0),(10 0,10 0),(20 0,25 0,30 0))",
+    10, -10, "LINESTRING (10 0, 10 0)");
+#if 0
+template<>
+template<>
+void object::test<28>()
+"MULTILINESTRING ((0 -2, 0 2),(-2 0, 2 0))"
+  double projIndex = indexedLine.project(Coordinate(2, 1.9));
+  ensure_equals(projIndex, 8);
+  Coordinate projPt = indexedLine.extractPoint(projIndex);
+  ensure_equals(projPt, Coordinate(2, 0));
+  projIndex = indexedLine.project(Coordinate(2, 2.1));
+  ensure_equals(projIndex, 4);
+  projPt = indexedLine.extractPoint(projIndex);
+  ensure_equals(projPt, Coordinate(0, 2));
+#endif
 } // namespace tut
More information about the geos-commits mailing list
