[geos-commits] r3610 - in branches/3.3/tests/xmltester: . tests/ticket
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Apr 10 11:32:29 EDT 2012
Author: strk
Date: 2012-04-10 08:32:29 -0700 (Tue, 10 Apr 2012)
New Revision: 3610
Added:
   branches/3.3/tests/xmltester/tests/ticket/bug527.xml
   branches/3.3/tests/xmltester/Makefile.am
Add test for bug #527
Modified: branches/3.3/tests/xmltester/Makefile.am
--- branches/3.3/tests/xmltester/Makefile.am	2012-04-10 15:16:39 UTC (rev 3609)
+++ branches/3.3/tests/xmltester/Makefile.am	2012-04-10 15:32:29 UTC (rev 3610)
@@ -34,6 +34,7 @@
 	$(srcdir)/tests/ticket/bug398.xml \
 	$(srcdir)/tests/ticket/bug434.xml \
 	$(srcdir)/tests/ticket/bug488.xml \
+	$(srcdir)/tests/ticket/bug527.xml \
 	$(srcdir)/tests/general/TestBoundary.xml \
 	$(srcdir)/tests/general/TestBuffer.xml \
 	$(srcdir)/tests/general/TestBufferMitredJoin.xml \
Added: branches/3.3/tests/xmltester/tests/ticket/bug527.xml
--- branches/3.3/tests/xmltester/tests/ticket/bug527.xml	                        (rev 0)
+++ branches/3.3/tests/xmltester/tests/ticket/bug527.xml	2012-04-10 15:32:29 UTC (rev 3610)
@@ -0,0 +1,27 @@
+<run>
+  <precisionModel type="FLOATING" />
+  <case>
+    <desc>
+Bogus noding
+http://trac.osgeo.org/geos/ticket/527
+    </desc>
+    <a>
+LINESTRING(
+ 1725063 4819121,
+ 1725064.14183882 4819094.70208557,
+ 1725064.13656044 4819094.70235069,
+ 1725064.14210362 4819094.70227252,
+ 1725064.13656043 4819094.70235069,
+ 1725063 4819121
+    </a>
+    <test>
+      <op name='union' arg1='A' >
+MULTILINESTRING ((1725064.1365604456514120 4819094.7023506900295615, 1725064.1365604463499039 4819094.7023506900295615), (1725064.1418305356055498 4819094.7022763714194298, 1725064.1418388199526817 4819094.7020855704322457, 1725064.1365604465827346 4819094.7023506900295615), (1725064.1418305356055498 4819094.7022763714194298, 1725064.1421036201063544 4819094.7022725204005837), (1725064.1365604465827346 4819094.7023506900295615, 1725064.1418305356055498 4819094.7022763714194298), (1725064.1365604465827346 4819094.7023506900295615, 1725064.1365604463499039 4819094.7023506900295615), (1725064.1365604440215975 4819094.7023506900295615, 1725064.1365604400634766 4819094.7023506900295615), (1725064.1365604456514120 4819094.7023506900295615, 1725064.1365604440215975 4819094.7023506900295615), (1725063.0000000000000000 4819121.0000000000000000, 1725064.1418305356055498 4819094.7022763714194298), (1725064.1365604400634766 4819094.7023506900295615, 1725064.1365604300517589 4819094.7023
 506900295615, 1725063.0000000000000000 4819121.0000000000000000))
+      </op>
+    </test>
+  </case>
+</run>
More information about the geos-commits mailing list
