[geos-commits] r3633 - in trunk: src/util tests/unit/capi
svn_geos at osgeo.org svn_geos at osgeo.org
Wed May 16 12:47:18 EDT 2012
Author: strk
Date: 2012-05-16 09:47:18 -0700 (Wed, 16 May 2012)
New Revision: 3633
   trunk/src/util/CustomAllocators.cpp
   trunk/tests/unit/capi/GEOSCustomAllocatorTest.cpp
Fix CustomAllocators to really use the custom allocators
Improve the unit test for it
Modified: trunk/src/util/CustomAllocators.cpp
--- trunk/src/util/CustomAllocators.cpp	2012-05-16 12:20:53 UTC (rev 3632)
+++ trunk/src/util/CustomAllocators.cpp	2012-05-16 16:47:18 UTC (rev 3633)
@@ -45,15 +45,14 @@
 void*
 operator new (std::size_t size, const std::nothrow_t&) throw () {
         //std::cout << "...new(" << size << ") called" << std::endl;
-        return std::malloc(size);
+        return geos::util::CustomAllocators::geos_alloc(size);
 void operator delete (void *ptr) throw () {
         //std::cout << "...delete(" << ptr << ") called" << std::endl;
-        if ( ptr ) std::free(ptr);
+        if ( ptr ) geos::util::CustomAllocators::geos_free(ptr);
Modified: trunk/tests/unit/capi/GEOSCustomAllocatorTest.cpp
--- trunk/tests/unit/capi/GEOSCustomAllocatorTest.cpp	2012-05-16 12:20:53 UTC (rev 3632)
+++ trunk/tests/unit/capi/GEOSCustomAllocatorTest.cpp	2012-05-16 16:47:18 UTC (rev 3633)
@@ -20,6 +20,7 @@
     struct test_capicustomallocators_data
         static int alloc_count;
+        static int dealloc_count;
         static void notice(const char *fmt, ...)
@@ -44,7 +45,7 @@
         static void t_free(void *ptr)
             //notice("t_free(%p)", ptr);
-            --alloc_count;
+            ++dealloc_count;
             std::free(ptr);
@@ -52,8 +53,6 @@
             GEOS_setAllocator(t_alloc);
             GEOS_setFreer(t_free);
-            alloc_count = 0;
         ~test_capicustomallocators_data()
@@ -63,6 +62,7 @@
     int test_capicustomallocators_data::alloc_count = 0;
+    int test_capicustomallocators_data::dealloc_count = 0;
     typedef test_group<test_capicustomallocators_data> group;
     typedef group::object object;
@@ -78,12 +78,15 @@
     template<>
     void object::test<1>()
-        alloc_count = 0;
+        alloc_count = dealloc_count = 0;
         initGEOS(notice, notice);
+        notice("%d allocs, %d deallocs after initGEOS", alloc_count, dealloc_count);
         finishGEOS();
+        notice("%d allocs, %d deallocs after finishGEOS", alloc_count, dealloc_count);
-        ensure_equals(alloc_count, 0);
+        ensure(alloc_count > 0);
+        ensure_equals(alloc_count, dealloc_count);
     /// WKTReader
@@ -91,18 +94,45 @@
     template<>
     void object::test<2>()
-        alloc_count = 0;
+        int tmpcount = 0;
+        ensure("initGEOS didn't alloc", alloc_count > tmpcount);
+        tmpcount = alloc_count;
         GEOSWKTReader* reader = GEOSWKTReader_create();
+        ensure("GEOSWKTReader_create didn't alloc", alloc_count > tmpcount);
+        notice("%d allocs, %d deallocs after GEOSWKTReader_create", alloc_count, dealloc_count);
         GEOSGeometry* g = GEOSWKTReader_read(reader, "POINT(0 0)");
+        ensure("GEOSWKTReader_read didn't alloc", alloc_count > tmpcount);
+        notice("%d allocs, %d deallocs after GEOSWKTReader_read", alloc_count, dealloc_count);
+        tmpcount = dealloc_count;
         GEOSGeom_destroy(g);
+        ensure("GEOSGeom_destroy didn't dealloc", dealloc_count > tmpcount);
+        notice("%d allocs, %d deallocs after GEOSGeom_destroy", alloc_count, dealloc_count);
         GEOSWKTReader_destroy(reader);
+        ensure("GEOSWKTReader_destroy didn't dealloc", dealloc_count > tmpcount);
+        notice("%d allocs, %d deallocs after GEOSWKTReader_destroy", alloc_count, dealloc_count);
         finishGEOS();
+        ensure("finishGEOS didn't dealloc", dealloc_count > tmpcount);
More information about the geos-commits mailing list
