[geos-commits] r3636 - in trunk: capi include/geos/util src/util tests/unit/capi
svn_geos at osgeo.org svn_geos at osgeo.org
Wed May 23 19:03:35 EDT 2012
Author: mloskot
Date: 2012-05-23 16:03:34 -0700 (Wed, 23 May 2012)
New Revision: 3636
   trunk/capi/geos_c.h.in
   trunk/capi/geos_ts_c.cpp
   trunk/include/geos/util/CustomAllocators.h
   trunk/src/util/CustomAllocators.cpp
   trunk/tests/unit/capi/GEOSCustomAllocatorTest.cpp
Renamed Freer to Deallocator
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in	2012-05-23 22:57:51 UTC (rev 3635)
+++ trunk/capi/geos_c.h.in	2012-05-23 23:03:34 UTC (rev 3636)
@@ -138,7 +138,7 @@
 typedef void (*GEOSQueryCallback)(void *item, void *userdata);
 typedef void * (*GEOSAllocator) (size_t size);
-typedef void   (*GEOSFreer)    (void *ptr);
+typedef void   (*GEOSDeallocator) (void *ptr);
@@ -152,7 +152,7 @@
 	GEOSMessageHandler error_function);
 extern void GEOS_DLL finishGEOS(void);
 extern GEOSAllocator GEOS_DLL GEOS_setAllocator(GEOSAllocator nf);
-extern GEOSFreer GEOS_DLL GEOS_setFreer(GEOSFreer nf);
+extern GEOSDeallocator GEOS_DLL GEOS_setDeallocator(GEOSDeallocator nf);
 extern GEOSContextHandle_t GEOS_DLL initGEOS_r(
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp	2012-05-23 22:57:51 UTC (rev 3635)
+++ trunk/capi/geos_ts_c.cpp	2012-05-23 23:03:34 UTC (rev 3636)
@@ -159,10 +159,10 @@
 // --- Custom memory allocators -------------------------------- {
 using geos::util::CustomAllocators::GEOSAllocator;
-using geos::util::CustomAllocators::GEOSFreer;
+using geos::util::CustomAllocators::GEOSDeallocator;
 GEOSAllocator geos_alloc = std::malloc;
-GEOSFreer geos_free = std::free;
+GEOSDeallocator geos_free = std::free;
 GEOSAllocator
@@ -173,12 +173,12 @@
   return of;
-GEOSFreer
-GEOS_setFreer(GEOSFreer nf)
+GEOSDeallocator
+GEOS_setDeallocator(GEOSDeallocator nf)
-  GEOSFreer of = geos_free;
+  GEOSDeallocator of = geos_free;
   geos_free = nf;
-  geos::util::CustomAllocators::setFreer(geos_free);
+  geos::util::CustomAllocators::setDeallocator(geos_free);
   return of;
Modified: trunk/include/geos/util/CustomAllocators.h
--- trunk/include/geos/util/CustomAllocators.h	2012-05-23 22:57:51 UTC (rev 3635)
+++ trunk/include/geos/util/CustomAllocators.h	2012-05-23 23:03:34 UTC (rev 3636)
@@ -21,8 +21,8 @@
   typedef void * (*GEOSAllocator) (std::size_t size);
   GEOSAllocator setAllocator(GEOSAllocator nf);
-  typedef void   (*GEOSFreer)    (void *ptr);
-  GEOSFreer setFreer(GEOSFreer nf);
+  typedef void   (*GEOSDeallocator)    (void *ptr);
+  GEOSDeallocator setDeallocator(GEOSDeallocator nf);
Modified: trunk/src/util/CustomAllocators.cpp
--- trunk/src/util/CustomAllocators.cpp	2012-05-23 22:57:51 UTC (rev 3635)
+++ trunk/src/util/CustomAllocators.cpp	2012-05-23 23:03:34 UTC (rev 3636)
@@ -23,7 +23,7 @@
 namespace CustomAllocators {
 GEOSAllocator
@@ -33,10 +33,10 @@
   return of;
-GEOSFreer
-setFreer(GEOSFreer nf)
+GEOSDeallocator
+setDeallocator(GEOSDeallocator nf)
   geos_free = nf;
   return of;
Modified: trunk/tests/unit/capi/GEOSCustomAllocatorTest.cpp
--- trunk/tests/unit/capi/GEOSCustomAllocatorTest.cpp	2012-05-23 22:57:51 UTC (rev 3635)
+++ trunk/tests/unit/capi/GEOSCustomAllocatorTest.cpp	2012-05-23 23:03:34 UTC (rev 3636)
@@ -52,7 +52,7 @@
         test_capicustomallocators_data()
             GEOS_setAllocator(t_alloc);
-            GEOS_setFreer(t_free);
+            GEOS_setDeallocator(t_free);
         ~test_capicustomallocators_data()
More information about the geos-commits mailing list
