[geos-commits] r3650 - in trunk: doc examples include include/geos include/geos/algorithm include/geos/algorithm/distance include/geos/algorithm/locate include/geos/geom include/geos/geom/prep include/geos/geom/util include/geos/geomgraph include/geos/geomgraph/index include/geos/index/bintree include/geos/index/chain include/geos/index/intervalrtree include/geos/index/quadtree include/geos/index/strtree include/geos/index/sweepline include/geos/io include/geos/noding include/geos/noding/snapround include/geos/operation include/geos/operation/buffer include/geos/operation/distance include/geos/operation/linemerge include/geos/operation/overlay include/geos/operation/overlay/snap include/geos/operation/overlay/validate include/geos/operation/polygonize include/geos/operation/relate include/geos/operation/union include/geos/operation/valid include/geos/planargraph include/geos/precision include/geos/simplify include/geos/util src/algorithm src/algorithm/locate src/geom src/geom/prep src/geom/util src/geomgraph src/geomgraph/index src/index/bintree src/index/chain src/index/intervalrtree src/index/quadtree src/index/strtree src/index/sweepline src/io src/noding src/noding/snapround src/operation src/operation/buffer src/operation/distance src/operation/linemerge src/operation/overlay src/operation/overlay/validate src/operation/polygonize src/operation/relate src/operation/valid src/planargraph src/planargraph/algorithm src/precision src/simplify src/util tests/bigtest tests/xmltester
svn_geos at osgeo.org svn_geos at osgeo.org
Tue May 29 01:42:25 PDT 2012
Author: strk
Date: 2012-05-29 01:42:24 -0700 (Tue, 29 May 2012)
New Revision: 3650
   trunk/doc/example.cpp
   trunk/examples/CPCLException.cpp
   trunk/examples/CoordinateSequencesExample.cpp
   trunk/examples/CustomCoordinateSequenceExample.cpp
   trunk/examples/CustomCoordinateSequenceExample.h
   trunk/examples/CustomPointCoordinateSequence.cpp
   trunk/include/acconfig.h
   trunk/include/geos/algorithm/CentralEndpointIntersector.h
   trunk/include/geos/algorithm/CentroidArea.h
   trunk/include/geos/algorithm/CentroidLine.h
   trunk/include/geos/algorithm/CentroidPoint.h
   trunk/include/geos/algorithm/ConvexHull.h
   trunk/include/geos/algorithm/InteriorPointArea.h
   trunk/include/geos/algorithm/InteriorPointLine.h
   trunk/include/geos/algorithm/InteriorPointPoint.h
   trunk/include/geos/algorithm/LineIntersector.h
   trunk/include/geos/algorithm/MCPointInRing.h
   trunk/include/geos/algorithm/MinimumDiameter.h
   trunk/include/geos/algorithm/NotRepresentableException.h
   trunk/include/geos/algorithm/PointInRing.h
   trunk/include/geos/algorithm/PointLocator.h
   trunk/include/geos/algorithm/RayCrossingCounter.h
   trunk/include/geos/algorithm/RobustDeterminant.h
   trunk/include/geos/algorithm/SIRtreePointInRing.h
   trunk/include/geos/algorithm/SimplePointInRing.h
   trunk/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
   trunk/include/geos/algorithm/distance/DistanceToPoint.h
   trunk/include/geos/algorithm/distance/PointPairDistance.h
   trunk/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
   trunk/include/geos/algorithm/locate/PointOnGeometryLocator.h
   trunk/include/geos/algorithm/locate/SimplePointInAreaLocator.h
   trunk/include/geos/geom/CoordinateArraySequence.h
   trunk/include/geos/geom/CoordinateFilter.h
   trunk/include/geos/geom/CoordinateList.h
   trunk/include/geos/geom/CoordinateSequence.h
   trunk/include/geos/geom/Dimension.h
   trunk/include/geos/geom/Envelope.h
   trunk/include/geos/geom/Geometry.h
   trunk/include/geos/geom/GeometryCollection.h
   trunk/include/geos/geom/GeometryComponentFilter.h
   trunk/include/geos/geom/GeometryFactory.h
   trunk/include/geos/geom/GeometryFilter.h
   trunk/include/geos/geom/GeometryList.h
   trunk/include/geos/geom/IntersectionMatrix.h
   trunk/include/geos/geom/LineSegment.h
   trunk/include/geos/geom/LineString.h
   trunk/include/geos/geom/LinearRing.h
   trunk/include/geos/geom/MultiLineString.h
   trunk/include/geos/geom/MultiPoint.h
   trunk/include/geos/geom/MultiPolygon.h
   trunk/include/geos/geom/Polygon.h
   trunk/include/geos/geom/PrecisionModel.h
   trunk/include/geos/geom/Triangle.h
   trunk/include/geos/geom/prep/AbstractPreparedPolygonContains.h
   trunk/include/geos/geom/prep/BasicPreparedGeometry.h
   trunk/include/geos/geom/prep/PreparedGeometry.h
   trunk/include/geos/geom/prep/PreparedGeometryFactory.h
   trunk/include/geos/geom/prep/PreparedLineString.h
   trunk/include/geos/geom/prep/PreparedPoint.h
   trunk/include/geos/geom/prep/PreparedPolygon.h
   trunk/include/geos/geom/prep/PreparedPolygonContains.h
   trunk/include/geos/geom/prep/PreparedPolygonContainsProperly.h
   trunk/include/geos/geom/prep/PreparedPolygonCovers.h
   trunk/include/geos/geom/prep/PreparedPolygonIntersects.h
   trunk/include/geos/geom/prep/PreparedPolygonPredicate.h
   trunk/include/geos/geom/util/ComponentCoordinateExtracter.h
   trunk/include/geos/geom/util/CoordinateOperation.h
   trunk/include/geos/geom/util/GeometryCombiner.h
   trunk/include/geos/geom/util/GeometryEditor.h
   trunk/include/geos/geom/util/GeometryEditorOperation.h
   trunk/include/geos/geom/util/GeometryTransformer.h
   trunk/include/geos/geom/util/LinearComponentExtracter.h
   trunk/include/geos/geom/util/PointExtracter.h
   trunk/include/geos/geom/util/PolygonExtracter.h
   trunk/include/geos/geom/util/ShortCircuitedGeometryVisitor.h
   trunk/include/geos/geomPrep.h
   trunk/include/geos/geomUtil.h
   trunk/include/geos/geomgraph.h
   trunk/include/geos/geomgraph/Depth.h
   trunk/include/geos/geomgraph/DirectedEdge.h
   trunk/include/geos/geomgraph/EdgeList.h
   trunk/include/geos/geomgraph/EdgeNodingValidator.h
   trunk/include/geos/geomgraph/GeometryGraph.h
   trunk/include/geos/geomgraph/Node.h
   trunk/include/geos/geomgraph/NodeFactory.h
   trunk/include/geos/geomgraph/NodeMap.h
   trunk/include/geos/geomgraph/Position.h
   trunk/include/geos/geomgraph/Quadrant.h
   trunk/include/geos/geomgraph/index/EdgeSetIntersector.h
   trunk/include/geos/geomgraph/index/MonotoneChain.h
   trunk/include/geos/geomgraph/index/MonotoneChainEdge.h
   trunk/include/geos/geomgraph/index/MonotoneChainIndexer.h
   trunk/include/geos/geomgraph/index/SegmentIntersector.h
   trunk/include/geos/geomgraph/index/SimpleEdgeSetIntersector.h
   trunk/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
   trunk/include/geos/geomgraph/index/SimpleSweepLineIntersector.h
   trunk/include/geos/geomgraph/index/SweepLineEvent.h
   trunk/include/geos/geomgraph/index/SweepLineEventObj.h
   trunk/include/geos/geomgraph/index/SweepLineSegment.h
   trunk/include/geos/index/bintree/Bintree.h
   trunk/include/geos/index/bintree/Interval.h
   trunk/include/geos/index/bintree/Key.h
   trunk/include/geos/index/bintree/Node.h
   trunk/include/geos/index/bintree/NodeBase.h
   trunk/include/geos/index/bintree/Root.h
   trunk/include/geos/index/chain/MonotoneChain.h
   trunk/include/geos/index/chain/MonotoneChainOverlapAction.h
   trunk/include/geos/index/chain/MonotoneChainSelectAction.h
   trunk/include/geos/index/intervalrtree/IntervalRTreeBranchNode.h
   trunk/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h
   trunk/include/geos/index/intervalrtree/IntervalRTreeNode.h
   trunk/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h
   trunk/include/geos/index/quadtree/DoubleBits.h
   trunk/include/geos/index/quadtree/IntervalSize.h
   trunk/include/geos/index/quadtree/Key.h
   trunk/include/geos/index/quadtree/Node.h
   trunk/include/geos/index/quadtree/NodeBase.h
   trunk/include/geos/index/quadtree/Quadtree.h
   trunk/include/geos/index/quadtree/Root.h
   trunk/include/geos/index/strtree/AbstractNode.h
   trunk/include/geos/index/strtree/AbstractSTRtree.h
   trunk/include/geos/index/strtree/Boundable.h
   trunk/include/geos/index/strtree/Interval.h
   trunk/include/geos/index/strtree/ItemBoundable.h
   trunk/include/geos/index/strtree/SIRtree.h
   trunk/include/geos/index/strtree/STRtree.h
   trunk/include/geos/index/sweepline/SweepLineEvent.h
   trunk/include/geos/index/sweepline/SweepLineIndex.h
   trunk/include/geos/index/sweepline/SweepLineInterval.h
   trunk/include/geos/index/sweepline/SweepLineOverlapAction.h
   trunk/include/geos/indexStrtree.h
   trunk/include/geos/indexSweepline.h
   trunk/include/geos/io.h
   trunk/include/geos/io/ByteOrderDataInStream.h
   trunk/include/geos/io/ByteOrderDataInStream.inl
   trunk/include/geos/io/ByteOrderValues.h
   trunk/include/geos/io/ParseException.h
   trunk/include/geos/io/StringTokenizer.h
   trunk/include/geos/io/WKBConstants.h
   trunk/include/geos/io/WKBReader.h
   trunk/include/geos/io/WKBWriter.h
   trunk/include/geos/io/WKTReader.h
   trunk/include/geos/io/WKTReader.inl
   trunk/include/geos/io/WKTWriter.h
   trunk/include/geos/io/Writer.h
   trunk/include/geos/noding/FastNodingValidator.h
   trunk/include/geos/noding/IntersectionAdder.h
   trunk/include/geos/noding/IntersectionFinderAdder.h
   trunk/include/geos/noding/IteratedNoder.h
   trunk/include/geos/noding/MCIndexNoder.h
   trunk/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
   trunk/include/geos/noding/NodableSegmentString.h
   trunk/include/geos/noding/NodedSegmentString.h
   trunk/include/geos/noding/NodingValidator.h
   trunk/include/geos/noding/Octant.h
   trunk/include/geos/noding/ScaledNoder.h
   trunk/include/geos/noding/SegmentIntersectionDetector.h
   trunk/include/geos/noding/SegmentIntersector.h
   trunk/include/geos/noding/SegmentNode.h
   trunk/include/geos/noding/SegmentNodeList.h
   trunk/include/geos/noding/SegmentSetMutualIntersector.h
   trunk/include/geos/noding/SegmentStringUtil.h
   trunk/include/geos/noding/SimpleNoder.h
   trunk/include/geos/noding/SingleInteriorIntersectionFinder.h
   trunk/include/geos/noding/SinglePassNoder.h
   trunk/include/geos/noding/snapround/HotPixel.h
   trunk/include/geos/noding/snapround/SimpleSnapRounder.h
   trunk/include/geos/operation/GeometryGraphOperation.h
   trunk/include/geos/operation/IsSimpleOp.h
   trunk/include/geos/operation/buffer/BufferBuilder.h
   trunk/include/geos/operation/buffer/BufferInputLineSimplifier.h
   trunk/include/geos/operation/buffer/BufferOp.h
   trunk/include/geos/operation/buffer/BufferSubgraph.h
   trunk/include/geos/operation/buffer/OffsetCurveSetBuilder.h
   trunk/include/geos/operation/buffer/RightmostEdgeFinder.h
   trunk/include/geos/operation/buffer/SubgraphDepthLocater.h
   trunk/include/geos/operation/distance/ConnectedElementLocationFilter.h
   trunk/include/geos/operation/distance/ConnectedElementPointFilter.h
   trunk/include/geos/operation/distance/DistanceOp.h
   trunk/include/geos/operation/distance/GeometryLocation.h
   trunk/include/geos/operation/linemerge/EdgeString.h
   trunk/include/geos/operation/linemerge/LineMergeDirectedEdge.h
   trunk/include/geos/operation/linemerge/LineMergeEdge.h
   trunk/include/geos/operation/linemerge/LineMergeGraph.h
   trunk/include/geos/operation/linemerge/LineMerger.h
   trunk/include/geos/operation/linemerge/LineSequencer.h
   trunk/include/geos/operation/overlay/EdgeSetNoder.h
   trunk/include/geos/operation/overlay/ElevationMatrix.h
   trunk/include/geos/operation/overlay/ElevationMatrixCell.h
   trunk/include/geos/operation/overlay/LineBuilder.h
   trunk/include/geos/operation/overlay/MaximalEdgeRing.h
   trunk/include/geos/operation/overlay/MinimalEdgeRing.h
   trunk/include/geos/operation/overlay/OverlayNodeFactory.h
   trunk/include/geos/operation/overlay/OverlayOp.h
   trunk/include/geos/operation/overlay/PointBuilder.h
   trunk/include/geos/operation/overlay/PolygonBuilder.h
   trunk/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h
   trunk/include/geos/operation/overlay/snap/SnapOverlayOp.h
   trunk/include/geos/operation/overlay/validate/FuzzyPointLocator.h
   trunk/include/geos/operation/overlay/validate/OffsetPointGenerator.h
   trunk/include/geos/operation/overlay/validate/OverlayResultValidator.h
   trunk/include/geos/operation/polygonize/EdgeRing.h
   trunk/include/geos/operation/polygonize/PolygonizeDirectedEdge.h
   trunk/include/geos/operation/polygonize/PolygonizeEdge.h
   trunk/include/geos/operation/polygonize/PolygonizeGraph.h
   trunk/include/geos/operation/polygonize/Polygonizer.h
   trunk/include/geos/operation/relate/EdgeEndBuilder.h
   trunk/include/geos/operation/relate/EdgeEndBundle.h
   trunk/include/geos/operation/relate/EdgeEndBundleStar.h
   trunk/include/geos/operation/relate/RelateComputer.h
   trunk/include/geos/operation/relate/RelateNodeFactory.h
   trunk/include/geos/operation/relate/RelateNodeGraph.h
   trunk/include/geos/operation/relate/RelateOp.h
   trunk/include/geos/operation/union/CascadedPolygonUnion.h
   trunk/include/geos/operation/valid/ConnectedInteriorTester.h
   trunk/include/geos/operation/valid/ConsistentAreaTester.h
   trunk/include/geos/operation/valid/IsValidOp.h
   trunk/include/geos/operation/valid/QuadtreeNestedRingTester.h
   trunk/include/geos/operation/valid/RepeatedPointTester.h
   trunk/include/geos/operation/valid/SimpleNestedRingTester.h
   trunk/include/geos/operation/valid/SweeplineNestedRingTester.h
   trunk/include/geos/operation/valid/TopologyValidationError.h
   trunk/include/geos/planargraph/DirectedEdge.h
   trunk/include/geos/planargraph/DirectedEdgeStar.h
   trunk/include/geos/planargraph/Edge.h
   trunk/include/geos/planargraph/GraphComponent.h
   trunk/include/geos/planargraph/Node.h
   trunk/include/geos/planargraph/NodeMap.h
   trunk/include/geos/planargraph/PlanarGraph.h
   trunk/include/geos/planargraph/Subgraph.h
   trunk/include/geos/precision/CommonBits.h
   trunk/include/geos/precision/CommonBitsOp.h
   trunk/include/geos/precision/CommonBitsRemover.h
   trunk/include/geos/precision/EnhancedPrecisionOp.h
   trunk/include/geos/precision/SimpleGeometryPrecisionReducer.h
   trunk/include/geos/profiler.h
   trunk/include/geos/simplify/DouglasPeuckerLineSimplifier.h
   trunk/include/geos/simplify/DouglasPeuckerSimplifier.h
   trunk/include/geos/simplify/LineSegmentIndex.h
   trunk/include/geos/simplify/TaggedLineSegment.h
   trunk/include/geos/simplify/TaggedLineString.h
   trunk/include/geos/simplify/TaggedLinesSimplifier.h
   trunk/include/geos/simplify/TopologyPreservingSimplifier.h
   trunk/include/geos/spatialIndex.h
   trunk/include/geos/unload.h
   trunk/include/geos/util/Assert.h
   trunk/include/geos/util/AssertionFailedException.h
   trunk/include/geos/util/CoordinateArrayFilter.h
   trunk/include/geos/util/GEOSException.h
   trunk/include/geos/util/GeometricShapeFactory.h
   trunk/include/geos/util/IllegalArgumentException.h
   trunk/include/geos/util/TopologyException.h
   trunk/include/geos/util/UniqueCoordinateArrayFilter.h
   trunk/include/geos/util/UnsupportedOperationException.h
   trunk/include/geos/util/math.h
   trunk/src/algorithm/CentroidArea.cpp
   trunk/src/algorithm/CentroidLine.cpp
   trunk/src/algorithm/CentroidPoint.cpp
   trunk/src/algorithm/ConvexHull.cpp
   trunk/src/algorithm/InteriorPointArea.cpp
   trunk/src/algorithm/InteriorPointLine.cpp
   trunk/src/algorithm/InteriorPointPoint.cpp
   trunk/src/algorithm/LineIntersector.cpp
   trunk/src/algorithm/MCPointInRing.cpp
   trunk/src/algorithm/MinimumDiameter.cpp
   trunk/src/algorithm/NotRepresentableException.cpp
   trunk/src/algorithm/PointLocator.cpp
   trunk/src/algorithm/RayCrossingCounter.cpp
   trunk/src/algorithm/SIRtreePointInRing.cpp
   trunk/src/algorithm/SimplePointInRing.cpp
   trunk/src/algorithm/locate/IndexedPointInAreaLocator.cpp
   trunk/src/algorithm/locate/PointOnGeometryLocator.cpp
   trunk/src/algorithm/locate/SimplePointInAreaLocator.cpp
   trunk/src/geom/CoordinateArraySequence.cpp
   trunk/src/geom/CoordinateSequence.cpp
   trunk/src/geom/CoordinateSequenceFactory.cpp
   trunk/src/geom/Dimension.cpp
   trunk/src/geom/Envelope.cpp
   trunk/src/geom/GeometryCollection.cpp
   trunk/src/geom/GeometryComponentFilter.cpp
   trunk/src/geom/GeometryFactory.cpp
   trunk/src/geom/GeometryList.cpp
   trunk/src/geom/IntersectionMatrix.cpp
   trunk/src/geom/LineSegment.cpp
   trunk/src/geom/LineString.cpp
   trunk/src/geom/LinearRing.cpp
   trunk/src/geom/Location.cpp
   trunk/src/geom/MultiLineString.cpp
   trunk/src/geom/MultiPoint.cpp
   trunk/src/geom/MultiPolygon.cpp
   trunk/src/geom/Polygon.cpp
   trunk/src/geom/PrecisionModel.cpp
   trunk/src/geom/Triangle.cpp
   trunk/src/geom/prep/AbstractPreparedPolygonContains.cpp
   trunk/src/geom/prep/BasicPreparedGeometry.cpp
   trunk/src/geom/prep/PreparedGeometry.cpp
   trunk/src/geom/prep/PreparedGeometryFactory.cpp
   trunk/src/geom/prep/PreparedLineString.cpp
   trunk/src/geom/prep/PreparedPoint.cpp
   trunk/src/geom/prep/PreparedPolygon.cpp
   trunk/src/geom/prep/PreparedPolygonContains.cpp
   trunk/src/geom/prep/PreparedPolygonContainsProperly.cpp
   trunk/src/geom/prep/PreparedPolygonCovers.cpp
   trunk/src/geom/prep/PreparedPolygonIntersects.cpp
   trunk/src/geom/prep/PreparedPolygonPredicate.cpp
   trunk/src/geom/util/ComponentCoordinateExtracter.cpp
   trunk/src/geom/util/CoordinateOperation.cpp
   trunk/src/geom/util/GeometryEditor.cpp
   trunk/src/geom/util/GeometryTransformer.cpp
   trunk/src/geomgraph/Depth.cpp
   trunk/src/geomgraph/EdgeList.cpp
   trunk/src/geomgraph/EdgeNodingValidator.cpp
   trunk/src/geomgraph/Label.cpp
   trunk/src/geomgraph/NodeFactory.cpp
   trunk/src/geomgraph/Position.cpp
   trunk/src/geomgraph/Quadrant.cpp
   trunk/src/geomgraph/index/MonotoneChainEdge.cpp
   trunk/src/geomgraph/index/MonotoneChainIndexer.cpp
   trunk/src/geomgraph/index/SegmentIntersector.cpp
   trunk/src/geomgraph/index/SimpleEdgeSetIntersector.cpp
   trunk/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp
   trunk/src/geomgraph/index/SimpleSweepLineIntersector.cpp
   trunk/src/geomgraph/index/SweepLineEvent.cpp
   trunk/src/geomgraph/index/SweepLineSegment.cpp
   trunk/src/index/bintree/Bintree.cpp
   trunk/src/index/bintree/Interval.cpp
   trunk/src/index/bintree/Key.cpp
   trunk/src/index/bintree/Node.cpp
   trunk/src/index/bintree/NodeBase.cpp
   trunk/src/index/bintree/Root.cpp
   trunk/src/index/chain/MonotoneChain.cpp
   trunk/src/index/chain/MonotoneChainOverlapAction.cpp
   trunk/src/index/chain/MonotoneChainSelectAction.cpp
   trunk/src/index/intervalrtree/IntervalRTreeBranchNode.cpp
   trunk/src/index/intervalrtree/IntervalRTreeLeafNode.cpp
   trunk/src/index/intervalrtree/IntervalRTreeNode.cpp
   trunk/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
   trunk/src/index/quadtree/DoubleBits.cpp
   trunk/src/index/quadtree/IntervalSize.cpp
   trunk/src/index/quadtree/Key.cpp
   trunk/src/index/quadtree/Node.cpp
   trunk/src/index/quadtree/NodeBase.cpp
   trunk/src/index/quadtree/Quadtree.cpp
   trunk/src/index/quadtree/Root.cpp
   trunk/src/index/strtree/AbstractNode.cpp
   trunk/src/index/strtree/AbstractSTRtree.cpp
   trunk/src/index/strtree/Interval.cpp
   trunk/src/index/strtree/ItemBoundable.cpp
   trunk/src/index/strtree/SIRtree.cpp
   trunk/src/index/strtree/STRtree.cpp
   trunk/src/index/sweepline/SweepLineEvent.cpp
   trunk/src/index/sweepline/SweepLineIndex.cpp
   trunk/src/index/sweepline/SweepLineInterval.cpp
   trunk/src/io/ByteOrderValues.cpp
   trunk/src/io/ParseException.cpp
   trunk/src/io/StringTokenizer.cpp
   trunk/src/io/Unload.cpp
   trunk/src/io/WKTReader.cpp
   trunk/src/io/Writer.cpp
   trunk/src/noding/FastNodingValidator.cpp
   trunk/src/noding/IntersectionAdder.cpp
   trunk/src/noding/IntersectionFinderAdder.cpp
   trunk/src/noding/MCIndexNoder.cpp
   trunk/src/noding/NodedSegmentString.cpp
   trunk/src/noding/NodingValidator.cpp
   trunk/src/noding/Octant.cpp
   trunk/src/noding/ScaledNoder.cpp
   trunk/src/noding/SegmentIntersectionDetector.cpp
   trunk/src/noding/SegmentNode.cpp
   trunk/src/noding/SegmentNodeList.cpp
   trunk/src/noding/SegmentStringUtil.cpp
   trunk/src/noding/SimpleNoder.cpp
   trunk/src/noding/SingleInteriorIntersectionFinder.cpp
   trunk/src/noding/snapround/HotPixel.cpp
   trunk/src/noding/snapround/SimpleSnapRounder.cpp
   trunk/src/operation/GeometryGraphOperation.cpp
   trunk/src/operation/buffer/BufferSubgraph.cpp
   trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp
   trunk/src/operation/buffer/RightmostEdgeFinder.cpp
   trunk/src/operation/buffer/SubgraphDepthLocater.cpp
   trunk/src/operation/distance/ConnectedElementLocationFilter.cpp
   trunk/src/operation/distance/ConnectedElementPointFilter.cpp
   trunk/src/operation/distance/DistanceOp.cpp
   trunk/src/operation/distance/GeometryLocation.cpp
   trunk/src/operation/linemerge/EdgeString.cpp
   trunk/src/operation/linemerge/LineMergeDirectedEdge.cpp
   trunk/src/operation/linemerge/LineMergeEdge.cpp
   trunk/src/operation/linemerge/LineMergeGraph.cpp
   trunk/src/operation/linemerge/LineMerger.cpp
   trunk/src/operation/linemerge/LineSequencer.cpp
   trunk/src/operation/overlay/EdgeSetNoder.cpp
   trunk/src/operation/overlay/ElevationMatrix.cpp
   trunk/src/operation/overlay/ElevationMatrixCell.cpp
   trunk/src/operation/overlay/MaximalEdgeRing.cpp
   trunk/src/operation/overlay/MinimalEdgeRing.cpp
   trunk/src/operation/overlay/OverlayNodeFactory.cpp
   trunk/src/operation/overlay/validate/FuzzyPointLocator.cpp
   trunk/src/operation/overlay/validate/OverlayResultValidator.cpp
   trunk/src/operation/polygonize/EdgeRing.cpp
   trunk/src/operation/polygonize/PolygonizeDirectedEdge.cpp
   trunk/src/operation/polygonize/PolygonizeEdge.cpp
   trunk/src/operation/polygonize/PolygonizeGraph.cpp
   trunk/src/operation/polygonize/Polygonizer.cpp
   trunk/src/operation/relate/EdgeEndBundleStar.cpp
   trunk/src/operation/relate/RelateNodeFactory.cpp
   trunk/src/operation/relate/RelateNodeGraph.cpp
   trunk/src/operation/relate/RelateOp.cpp
   trunk/src/operation/valid/ConnectedInteriorTester.cpp
   trunk/src/operation/valid/ConsistentAreaTester.cpp
   trunk/src/operation/valid/IndexedNestedRingTester.h
   trunk/src/operation/valid/QuadtreeNestedRingTester.cpp
   trunk/src/operation/valid/RepeatedPointTester.cpp
   trunk/src/operation/valid/SimpleNestedRingTester.cpp
   trunk/src/operation/valid/SweeplineNestedRingTester.cpp
   trunk/src/operation/valid/TopologyValidationError.cpp
   trunk/src/planargraph/DirectedEdge.cpp
   trunk/src/planargraph/DirectedEdgeStar.cpp
   trunk/src/planargraph/Edge.cpp
   trunk/src/planargraph/Node.cpp
   trunk/src/planargraph/NodeMap.cpp
   trunk/src/planargraph/PlanarGraph.cpp
   trunk/src/planargraph/Subgraph.cpp
   trunk/src/planargraph/algorithm/ConnectedSubgraphFinder.cpp
   trunk/src/precision/CommonBits.cpp
   trunk/src/precision/CommonBitsOp.cpp
   trunk/src/precision/CommonBitsRemover.cpp
   trunk/src/precision/EnhancedPrecisionOp.cpp
   trunk/src/precision/SimpleGeometryPrecisionReducer.cpp
   trunk/src/simplify/DouglasPeuckerLineSimplifier.cpp
   trunk/src/simplify/DouglasPeuckerSimplifier.cpp
   trunk/src/simplify/LineSegmentIndex.cpp
   trunk/src/simplify/TaggedLineSegment.cpp
   trunk/src/simplify/TaggedLineString.cpp
   trunk/src/simplify/TaggedLineStringSimplifier.cpp
   trunk/src/simplify/TaggedLinesSimplifier.cpp
   trunk/src/util/Assert.cpp
   trunk/src/util/Profiler.cpp
   trunk/tests/bigtest/GeometryTestFactory.cpp
   trunk/tests/bigtest/TestSweepLineSpeed.cpp
   trunk/tests/bigtest/bigtest.h
   trunk/tests/xmltester/CTS.cpp
   trunk/tests/xmltester/SimpleWKTTester.cpp
   trunk/tests/xmltester/Stackwalker.h
Drop embedded RCS logs
Modified: trunk/doc/example.cpp
--- trunk/doc/example.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/doc/example.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -1116,114 +1116,3 @@
 	exit(0);
- * $Log$
- * Revision 1.46  2006/04/09 11:07:54  mloskot
- * Small fixes in doc/example.cpp.
- * Revision 1.45  2006/04/04 08:16:46  strk
- * Changed GEOSException hierarchy to be derived from std::runtime_exception.
- * Removed the GEOSException::toString redundant method (use ::what() instead)
- * Revision 1.44  2006/03/28 15:19:22  strk
- * Added macros for sections skip (useful in debugging)
- * Revision 1.43  2006/03/15 18:44:51  strk
- * Bug #60 - Missing <cmath> header in some files
- * Revision 1.42  2006/03/06 21:27:39  strk
- * Cascading fixed after Unload definition moved to geos::io namespace
- * Revision 1.41  2006/03/06 19:40:46  strk
- * geos::util namespace. New GeometryCollection::iterator interface, many cleanups.
- * Revision 1.40  2006/03/06 15:23:14  strk
- * geos::io namespace
- * Revision 1.39  2006/03/03 10:46:21  strk
- * Removed 'using namespace' from headers, added missing headers in .cpp files, removed useless includes in headers (bug#46)
- * Revision 1.38  2006/02/19 19:46:49  strk
- * Packages <-> namespaces mapping for most GEOS internal code (uncomplete, but working). Dir-level libs for index/ subdirs.
- * Revision 1.37  2006/02/09 15:52:47  strk
- * GEOSException derived from std::exception; always thrown and cought by const ref.
- * Revision 1.36  2006/01/31 19:07:33  strk
- * - Renamed DefaultCoordinateSequence to CoordinateArraySequence.
- * - Moved GetNumGeometries() and GetGeometryN() interfaces
- *   from GeometryCollection to Geometry class.
- * - Added getAt(int pos, Coordinate &to) funtion to CoordinateSequence class.
- * - Reworked automake scripts to produce a static lib for each subdir and
- *   then link all subsystem's libs togheter
- * - Moved C-API in it's own top-level dir capi/
- * - Moved source/bigtest and source/test to tests/bigtest and test/xmltester
- * - Fixed PointLocator handling of LinearRings
- * - Changed CoordinateArrayFilter to reduce memory copies
- * - Changed UniqueCoordinateArrayFilter to reduce memory copies
- * - Added CGAlgorithms::isPointInRing() version working with
- *   Coordinate::ConstVect type (faster!)
- * - Ported JTS-1.7 version of ConvexHull with big attention to
- *   memory usage optimizations.
- * - Improved XMLTester output and user interface
- * - geos::geom::util namespace used for geom/util stuff
- * - Improved memory use in geos::geom::util::PolygonExtractor
- * - New ShortCircuitedGeometryVisitor class
- * - New operation/predicate package
- * Revision 1.35  2005/11/30 11:27:07  strk
- * catch std::exception by ref
- * Revision 1.34  2005/11/30 11:25:12  strk
- * includes cleanup
- * Revision 1.33  2005/09/27 16:20:43  strk
- * Reverted previous change, fixed the bug by turning WKBReader.factory
- * into a reference rather then a real object. ABI still breaks, but API
- * at least is safe (we didn't release any WKB-aware package so breaking
- * ABI is not a big deal at this stage).
- * Revision 1.32  2005/09/27 16:00:26  strk
- * Fixed bug in WKBReader destroying the GeometryFactory used in Geometry
- * construction. Changed it's definition to *require* a GeometryFactory
- * pointer parameter.
- * Revision 1.31  2005/09/26 08:17:19  strk
- * Removed memory leak from WKB tester
- * Revision 1.30  2005/09/03 21:26:42  strk
- * Reworked WKB I/O to avoid use of templates and make better use of STL
- * Revision 1.29  2005/07/11 12:17:26  strk
- * Commented out useless include
- * Revision 1.28  2005/04/29 16:36:28  strk
- * Made WKBReader use global_factory, for having WKB reads produce
- * same context of input geoms.
- * Revision 1.27  2005/04/29 15:34:20  strk
- * Typedef'ed biostringstream, preferred parameter for
- * WKB parser templates.
- * Added << operator for biostringstream.
- * Typedef'ed WKBWriter and WKBReader to be parametrized by
- * biostringstream.
- * Added WKBtest in doc/example.cpp
- * Revision 1.26  2004/12/08 13:54:43  strk
- * gcc warnings checked and fixed, general cleanups.
- * Revision 1.25  2004/10/13 10:03:02  strk
- * Added missing linemerge and polygonize operation.
- * Bug fixes and leaks removal from the newly added modules and
- * planargraph (used by them).
- * Some comments and indentation changes.
- * Revision 1.24  2004/07/22 16:58:01  strk
- * runtime version extractor functions split. geos::version() is now
- * geos::geosversion() and geos::jtsport()
- * Revision 1.23  2004/07/17 09:19:32  strk
- * added GEOS version report
Modified: trunk/examples/CPCLException.cpp
--- trunk/examples/CPCLException.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/examples/CPCLException.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -10,48 +10,6 @@
  * by the Free Software Foundation.
  * See the COPYING file for more information.
- * $Log$
- * Revision 1.7  2006/04/04 08:16:46  strk
- * Revision 1.6  2006/01/31 19:07:33  strk
- * Revision 1.5  2004/07/08 19:34:49  strk
- * Mirrored JTS interface of CoordinateSequence, factory and
- * default implementations.
- * Added CoordinateArraySequenceFactory::instance() function.
- * Revision 1.4  2004/07/02 13:28:26  strk
- * Fixed all #include lines to reflect headers layout change.
- * Added client application build tips in README.
- * Revision 1.3  2003/11/07 01:23:42  pramsey
- * Add standard CVS headers licence notices and copyrights to all cpp and h
- * files.
Modified: trunk/examples/CoordinateSequencesExample.cpp
--- trunk/examples/CoordinateSequencesExample.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/examples/CoordinateSequencesExample.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -13,45 +13,6 @@
- * $Log$
- * Revision 1.3  2006/02/09 15:52:47  strk
- * Revision 1.2  2006/01/31 19:07:33  strk
- * Revision 1.1  2004/07/08 19:41:27  strk
- * renamed to reflect JTS API.
- * Revision 1.5  2004/07/02 13:28:26  strk
- * Revision 1.4  2003/11/07 01:23:42  pramsey
- * files.
Modified: trunk/examples/CustomCoordinateSequenceExample.cpp
--- trunk/examples/CustomCoordinateSequenceExample.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/examples/CustomCoordinateSequenceExample.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -10,27 +10,6 @@
- * $Log$
- * Revision 1.3  2006/04/04 08:16:46  strk
- * Revision 1.2  2006/02/09 15:52:47  strk
- * Revision 1.6  2004/07/02 13:28:26  strk
- * Revision 1.5  2003/11/07 01:23:42  pramsey
- * files.
Modified: trunk/examples/CustomCoordinateSequenceExample.h
--- trunk/examples/CustomCoordinateSequenceExample.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/examples/CustomCoordinateSequenceExample.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -11,23 +11,6 @@
- * $Log$
- * Revision 1.2  2006/04/04 08:16:46  strk
- * Revision 1.8  2004/07/02 13:28:26  strk
- * Revision 1.7  2003/11/07 01:23:42  pramsey
- * files.
Modified: trunk/examples/CustomPointCoordinateSequence.cpp
--- trunk/examples/CustomPointCoordinateSequence.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/examples/CustomPointCoordinateSequence.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -10,26 +10,6 @@
- * $Log$
- * Revision 1.2  2005/01/28 09:47:51  strk
- * Replaced sprintf uses with ostringstream.
- * files.
Modified: trunk/include/acconfig.h
--- trunk/include/acconfig.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/acconfig.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -10,19 +10,6 @@
- * $Log$
- * Revision 1.4  2004/07/19 10:30:05  strk
- * acconfig.h moved one directory up
- * Revision 1.1  2004/07/02 13:20:42  strk
- * Header files moved under geos/ dir.
- * Revision 1.2  2003/11/07 01:23:42  pramsey
- * files.
Modified: trunk/include/geos/algorithm/CentralEndpointIntersector.h
--- trunk/include/geos/algorithm/CentralEndpointIntersector.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/CentralEndpointIntersector.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -155,8 +155,3 @@
 #endif
 #endif // GEOS_ALGORITHM_CENTRALENDPOINTINTERSECTOR_H
- * $Log$
Modified: trunk/include/geos/algorithm/CentroidArea.h
--- trunk/include/geos/algorithm/CentroidArea.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/CentroidArea.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -117,11 +117,3 @@
 #endif // GEOS_ALGORITHM_CENTROIDAREA_H
- * $Log$
- * Revision 1.1  2006/03/09 16:46:48  strk
- * geos::geom namespace definition, first pass at headers split
Modified: trunk/include/geos/algorithm/CentroidLine.h
--- trunk/include/geos/algorithm/CentroidLine.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/CentroidLine.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -74,11 +74,3 @@
 #endif // GEOS_ALGORITHM_CENTROIDLINE_H
- * $Log$
Modified: trunk/include/geos/algorithm/CentroidPoint.h
--- trunk/include/geos/algorithm/CentroidPoint.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/CentroidPoint.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -69,11 +69,3 @@
 } // namespace geos
 #endif // GEOS_ALGORITHM_CENTROIDPOINT_H
- * $Log$
Modified: trunk/include/geos/algorithm/ConvexHull.h
--- trunk/include/geos/algorithm/ConvexHull.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/ConvexHull.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -190,14 +190,3 @@
 #endif
 #endif // GEOS_ALGORITHM_CONVEXHULL_H
- * $Log$
- * Revision 1.2  2006/03/24 09:52:41  strk
- * USE_INLINE => GEOS_INLINE
Modified: trunk/include/geos/algorithm/InteriorPointArea.h
--- trunk/include/geos/algorithm/InteriorPointArea.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/InteriorPointArea.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -94,10 +94,3 @@
 #endif // GEOS_ALGORITHM_INTERIORPOINTAREA_H
- * $Log$
Modified: trunk/include/geos/algorithm/InteriorPointLine.h
--- trunk/include/geos/algorithm/InteriorPointLine.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/InteriorPointLine.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -83,10 +83,3 @@
 #endif // GEOS_ALGORITHM_INTERIORPOINTLINE_H
- * $Log$
Modified: trunk/include/geos/algorithm/InteriorPointPoint.h
--- trunk/include/geos/algorithm/InteriorPointPoint.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/InteriorPointPoint.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -74,10 +74,3 @@
 #endif // GEOS_ALGORITHM_INTERIORPOINTPOINT_H
- * $Log$
Modified: trunk/include/geos/algorithm/LineIntersector.h
--- trunk/include/geos/algorithm/LineIntersector.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/LineIntersector.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -364,16 +364,3 @@
 #endif // GEOS_ALGORITHM_LINEINTERSECTOR_H
- * $Log$
- * Revision 1.3  2006/04/20 14:16:25  strk
- * Added some more doxygen comments
- * Revision 1.2  2006/04/06 21:31:40  strk
- * Const correctness for debugging function
Modified: trunk/include/geos/algorithm/MCPointInRing.h
--- trunk/include/geos/algorithm/MCPointInRing.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/MCPointInRing.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -83,19 +83,3 @@
 #endif // GEOS_ALGORITHM_MCPOINTINRING_H
- * $Log$
- * Revision 1.4  2006/03/29 11:52:00  strk
- * const correctness, useless heap allocations removal
- * Revision 1.3  2006/03/22 18:12:31  strk
- * indexChain.h header split.
- * Revision 1.2  2006/03/22 16:01:33  strk
- * indexBintree.h header split, classes renamed to match JTS
Modified: trunk/include/geos/algorithm/MinimumDiameter.h
--- trunk/include/geos/algorithm/MinimumDiameter.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/MinimumDiameter.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -133,10 +133,3 @@
 #endif // GEOS_ALGORITHM_MINIMUMDIAMETER_H
- * $Log$
Modified: trunk/include/geos/algorithm/NotRepresentableException.h
--- trunk/include/geos/algorithm/NotRepresentableException.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/NotRepresentableException.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -44,10 +44,3 @@
 #endif
- * $Log$
Modified: trunk/include/geos/algorithm/PointInRing.h
--- trunk/include/geos/algorithm/PointInRing.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/PointInRing.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -40,10 +40,3 @@
 #endif
- * $Log$
Modified: trunk/include/geos/algorithm/PointLocator.h
--- trunk/include/geos/algorithm/PointLocator.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/PointLocator.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -107,10 +107,3 @@
 #endif // GEOS_ALGORITHM_POINTLOCATOR_H
- * $Log$
Modified: trunk/include/geos/algorithm/RayCrossingCounter.h
--- trunk/include/geos/algorithm/RayCrossingCounter.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/RayCrossingCounter.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -152,7 +152,3 @@
 } // geos
 #endif // GEOS_ALGORITHM_RAYCROSSINGCOUNTER_H
- * $Log$
Modified: trunk/include/geos/algorithm/RobustDeterminant.h
--- trunk/include/geos/algorithm/RobustDeterminant.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/RobustDeterminant.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -68,11 +68,3 @@
 #endif // GEOS_ALGORITHM_ROBUSTDETERMINANT_H
- * $Log$
Modified: trunk/include/geos/algorithm/SIRtreePointInRing.h
--- trunk/include/geos/algorithm/SIRtreePointInRing.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/SIRtreePointInRing.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -58,13 +58,3 @@
 #endif // GEOS_ALGORITHM_SIRTREEPOINTINRING_H
- * $Log$
- * Revision 1.2  2006/03/21 11:12:23  strk
- * Cleanups: headers inclusion and Log section
Modified: trunk/include/geos/algorithm/SimplePointInRing.h
--- trunk/include/geos/algorithm/SimplePointInRing.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/SimplePointInRing.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -46,10 +46,3 @@
 #endif // GEOS_ALGORITHM_SIMPLEPOINTINRING_H
- * $Log$
Modified: trunk/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
--- trunk/include/geos/algorithm/distance/DiscreteHausdorffDistance.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/distance/DiscreteHausdorffDistance.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -256,7 +256,3 @@
 #endif // GEOS_ALGORITHM_DISTANCE_DISCRETEHAUSDORFFDISTANCE_H
- * $Log$
Modified: trunk/include/geos/algorithm/distance/DistanceToPoint.h
--- trunk/include/geos/algorithm/distance/DistanceToPoint.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/distance/DistanceToPoint.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -74,7 +74,3 @@
 #endif // GEOS_ALGORITHM_DISTANCE_DISTANCETOPOINT_H
- * $Log$
Modified: trunk/include/geos/algorithm/distance/PointPairDistance.h
--- trunk/include/geos/algorithm/distance/PointPairDistance.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/distance/PointPairDistance.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -153,7 +153,3 @@
 #endif // GEOS_ALGORITHM_DISTANCE_POINTPAIRDISTANCE_H
- * $Log$
Modified: trunk/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
--- trunk/include/geos/algorithm/locate/IndexedPointInAreaLocator.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/locate/IndexedPointInAreaLocator.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -124,7 +124,3 @@
 } // geos
 #endif // GEOS_ALGORITHM_LOCATE_INDEXEDPOINTINAREALOCATOR_H
- * $Log$
Modified: trunk/include/geos/algorithm/locate/PointOnGeometryLocator.h
--- trunk/include/geos/algorithm/locate/PointOnGeometryLocator.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/locate/PointOnGeometryLocator.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -54,7 +54,3 @@
 } // geos
 #endif // GEOS_ALGORITHM_LOCATE_POINTONGEOMETRYLOCATOR_H
- * $Log$
Modified: trunk/include/geos/algorithm/locate/SimplePointInAreaLocator.h
--- trunk/include/geos/algorithm/locate/SimplePointInAreaLocator.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/algorithm/locate/SimplePointInAreaLocator.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -79,11 +79,3 @@
 #endif // GEOS_ALGORITHM_LOCATE_SIMPLEPOINTINAREALOCATOR_H
- * $Log$
Modified: trunk/include/geos/geom/CoordinateArraySequence.h
--- trunk/include/geos/geom/CoordinateArraySequence.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/CoordinateArraySequence.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -129,24 +129,4 @@
 } // namespace geos.geom
 } // namespace geos
-//#ifdef GEOS_INLINE
-//# include "geos/geom/CoordinateArraySequence.inl"
-//#endif
 #endif // ndef GEOS_GEOM_COORDINATEARRAYSEQUENCE_H
- * $Log$
- * Revision 1.4  2006/06/12 10:10:39  strk
- * Fixed getGeometryN() to take size_t rather then int, changed unsigned int parameters to size_t.
- * Revision 1.3  2006/05/03 08:58:34  strk
- * added new non-static CoordinateSequence::removeRepeatedPoints() mutator.
- * Revision 1.1  2006/03/09 16:46:49  strk
Modified: trunk/include/geos/geom/CoordinateFilter.h
--- trunk/include/geos/geom/CoordinateFilter.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/CoordinateFilter.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -62,24 +62,4 @@
 } // namespace geos::geom
 } // namespace geos
-//# include "geos/geom/CoordinateFilter.inl"
-//#endif
 #endif // ndef GEOS_GEOM_COORDINATEFILTER_H
- * $Log$
- * Revision 1.4  2006/06/19 23:33:03  strk
- * Don't *require* CoordinateFilters to define both read-only and read-write methods.
- * Revision 1.3  2006/03/24 09:52:41  strk
- * Revision 1.2  2006/03/13 21:13:54  strk
- * Added comment about possible refactoring
Modified: trunk/include/geos/geom/CoordinateList.h
--- trunk/include/geos/geom/CoordinateList.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/CoordinateList.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -189,14 +189,3 @@
 #endif
 #endif // ndef GEOS_GEOM_COORDINATELIST_H
- * $Log$
- * Revision 1.2  2006/07/21 17:05:22  strk
- * added operator<< for CoordinateList class
- * Revision 1.1  2006/07/21 14:53:12  strk
- * CoordinateList class re-introduced, for list-based ops
- * (not strictly mapped to JTS version, not yet at least)
Modified: trunk/include/geos/geom/CoordinateSequence.h
--- trunk/include/geos/geom/CoordinateSequence.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/CoordinateSequence.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -396,43 +396,3 @@
 //#endif
 #endif // ndef GEOS_GEOM_COORDINATESEQUENCE_H
- * $Log$
- * Revision 1.12  2006/06/12 16:51:23  strk
- * Added equality and inequality operators and tests
- * Revision 1.11  2006/06/12 16:36:22  strk
- * indentation, notes about things to be fixed.
- * Revision 1.10  2006/06/12 15:06:30  strk
- * Added default ctor and copy ctor (protected)
- * Revision 1.9  2006/06/12 10:10:39  strk
- * Revision 1.8  2006/05/04 08:42:12  strk
- * Added note about the CoordinateSequence::toVector() method.
- * Revision 1.7  2006/05/03 19:47:27  strk
- * added operator<< for CoordinateSequence
- * Revision 1.6  2006/05/03 08:58:34  strk
- * Revision 1.5  2006/04/11 11:55:22  strk
- * Added CoordinateSequence::AutoPtr typedef
- * Revision 1.4  2006/04/04 09:53:45  strk
- * Fixed applyCoordinateFilter() templated function body
- * Revision 1.2  2006/03/20 17:27:03  strk
- * Bug #72 - Missing <vector> header
Modified: trunk/include/geos/geom/Dimension.h
--- trunk/include/geos/geom/Dimension.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/Dimension.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -68,19 +68,3 @@
 #endif
 #endif // ndef GEOS_GEOM_DIMENSION_H
- * $Log$
- * Revision 1.4  2006/05/04 15:49:39  strk
- * updated all Geometry::getDimension() methods to return Dimension::DimensionType (closes bug#93)
- * Revision 1.3  2006/04/07 05:44:32  mloskot
- * Added name for anonymous enum in Dimension class (bug). Added missing new-line at the end of source files. Removed CR from line ends.
Modified: trunk/include/geos/geom/Envelope.h
--- trunk/include/geos/geom/Envelope.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/Envelope.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -498,22 +498,3 @@
 #endif
 #endif // ndef GEOS_GEOM_ENVELOPE_H
- * $Log$
- * Revision 1.4  2006/04/10 18:15:09  strk
- * Changed Geometry::envelope member to be of type auto_ptr<Envelope>.
- * Changed computeEnvelopeInternal() signater to return auto_ptr<Envelope>
- * Revision 1.3  2006/04/05 14:04:25  strk
- * Fixed copy ctor to support "Null" Envelope copies.
- * Drop init(Envelope&) method.
- * Port info and various cleanups.
Modified: trunk/include/geos/geom/Geometry.h
--- trunk/include/geos/geom/Geometry.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/Geometry.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -890,67 +890,3 @@
 #endif
 #endif // ndef GEOS_GEOM_GEOMETRY_H
- * $Log$
- * Revision 1.14  2006/07/08 00:33:55  strk
- *         * configure.in: incremented CAPI minor version, to avoid                        falling behind any future version from the 2.2. branch.
- *         * source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
- *         source/geomgraph/EdgeRing.cpp,
- *         source/headers/geos/geom/Geometry.h,
- *         source/headers/geos/geom/GeometryFactory.h,
- *         source/headers/geos/geom/GeometryFactory.inl,
- *         source/headers/geos/geomgraph/EdgeRing.h:
- *         updated doxygen comments (sync with JTS head).
- *         * source/headers/geos/platform.h.in: include <inttypes.h>
- *         rather then <stdint.h>
- * Revision 1.13  2006/06/12 10:10:39  strk
- * Revision 1.12  2006/05/18 08:56:50  strk
- *         source/headers/geos/geom/Geometry.h: added
- *         covers() and isCoveredBy() predicates.
- *         * tests/unit/Makefile.am,
- *         tests/unit/geom/Geometry/coversTest.cpp:
- *         added test for covers() predicates.
- * Revision 1.11  2006/05/04 15:49:39  strk
- * Revision 1.10  2006/04/28 10:55:39  strk
- * Geometry constructors made protected, to ensure all constructions use GeometryFactory,
- * which has been made friend of all Geometry derivates. getNumPoints() changed to return
- * size_t.
- * Revision 1.9  2006/04/11 09:31:47  strk
- * Added Geometry::AutoPtr typedef
- * Revision 1.8  2006/04/10 18:15:09  strk
- * Revision 1.7  2006/04/07 09:54:30  strk
- * Geometry::getNumGeometries() changed to return 'unsigned int'
- * rather then 'int'
- * Revision 1.6  2006/03/31 16:53:53  strk
- * Added comment about possible NULL return from getCoordinate()
- * Revision 1.5  2006/03/24 09:52:41  strk
- * Revision 1.4  2006/03/23 15:10:29  strk
- * Dropped by-pointer TopologyException constructor, various small cleanups
- * Revision 1.3  2006/03/23 12:12:01  strk
- * Fixes to allow build with -DGEOS_INLINE
- * Revision 1.2  2006/03/20 12:03:25  strk
- * Added operator<< for Geometry, writing HEXWKB
Modified: trunk/include/geos/geom/GeometryCollection.h
--- trunk/include/geos/geom/GeometryCollection.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/GeometryCollection.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -204,35 +204,3 @@
 #endif
 #endif // ndef GEOS_GEOS_GEOMETRYCOLLECTION_H
- * $Log$
- * Revision 1.8  2006/06/12 10:10:39  strk
- * Revision 1.7  2006/05/04 15:49:39  strk
- * Revision 1.6  2006/04/28 10:55:39  strk
- * size_t.
- * Revision 1.5  2006/04/10 18:15:09  strk
- * Revision 1.4  2006/04/07 09:54:30  strk
- * Revision 1.2  2006/03/23 12:12:01  strk
Modified: trunk/include/geos/geom/GeometryComponentFilter.h
--- trunk/include/geos/geom/GeometryComponentFilter.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/GeometryComponentFilter.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -58,24 +58,4 @@
 } // namespace geos
-//# include "geos/geom/GeometryComponentFilter.inl"
-//#endif
 #endif // ndef GEOS_GEOM_GEOMETRYCOMPONENTFILTER_H
- * $Log$
- * Revision 1.4  2006/06/08 11:20:24  strk
- * Added missing virtual destructor to abstract classes.
- * Revision 1.3  2006/04/13 14:25:17  strk
- * TopologyPreservingSimplifier initial port
Modified: trunk/include/geos/geom/GeometryFactory.h
--- trunk/include/geos/geom/GeometryFactory.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/GeometryFactory.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -397,55 +397,3 @@
 #endif
 #endif // ndef GEOS_GEOM_GEOMETRYFACTORY_H
- * $Log$
- * Revision 1.11  2006/07/08 00:33:55  strk
- * Revision 1.10  2006/06/19 21:17:24  strk
- * port info and doxygen dox.
- * Revision 1.9  2006/04/28 11:56:52  strk
- * * source/geom/GeometryFactory.cpp, source/headers/geos/geom/GeometryFactory.h: added LineString copy constructor.
- * * source/geom/Polygon.cpp: fixed getBoundary method to always return a geometry composed by LineStrings (not LinearRings)
- * Revision 1.8  2006/04/12 11:39:34  strk
- * Removed Geometry.h and CoordinateSequence.h includes.
- * The former created a circular dependency.
- * Revision 1.7  2006/04/11 11:16:25  strk
- * Added LineString and LinearRing constructors by auto_ptr
- * Revision 1.6  2006/04/10 13:09:49  strk
- * Added GeometryFactory::defaultInstance()
- * Made Geometry::INTERNAL_GEOMETRY_FACTORY an alias for it
- * removed last deletion from Unload::Release class
- * Revision 1.5  2006/03/31 17:51:26  strk
- * A few assertion checking, comments cleanup, use of initialization lists
- * in constructors, handled NULL parameters.
- * Revision 1.4  2006/03/28 16:33:14  strk
- * Added note about args responsibility in GeometryFactory constructor
Modified: trunk/include/geos/geom/GeometryFilter.h
--- trunk/include/geos/geom/GeometryFilter.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/GeometryFilter.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -66,24 +66,4 @@
 } // namespace geos
-//# include "geos/geom/GeometryFilter.inl"
-//#endif
 #endif // ndef GEOS_GEOM_GEOMETRYFILTER_H
- * $Log$
- * Revision 1.4  2006/06/12 17:14:11  strk
- * added assert(0) version of filter_ro() and filter_rw() to allow implementations to only defined the required one.
- * Revision 1.3  2006/06/08 11:20:24  strk
Modified: trunk/include/geos/geom/GeometryList.h
--- trunk/include/geos/geom/GeometryList.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/GeometryList.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -81,15 +81,3 @@
 #endif
 #endif // GEOS_GEOM_GEOMETRYLIST_H
- * $Log$
- * Revision 1.2  2006/04/11 09:53:44  strk
- * Added missing duplicated include sentinel
- * Revision 1.1  2006/04/11 09:41:26  strk
- * Initial implementation of a GeometryList class, to be used to manage
- * lists of Geometry pointers.
Modified: trunk/include/geos/geom/IntersectionMatrix.h
--- trunk/include/geos/geom/IntersectionMatrix.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/IntersectionMatrix.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -378,30 +378,4 @@
 } // namespace geos
-//# include "geos/geom/IntersectionMatrix.inl"
-//#endif
 #endif // ndef GEOS_GEOM_INTERSECTIONMATRIX_H
- * $Log$
- * Revision 1.6  2006/05/17 17:41:10  strk
- * Added output operator + test
- * Revision 1.5  2006/05/17 17:24:17  strk
- * Added port info, fixed isCoveredBy() comment.
- * Revision 1.4  2006/05/17 17:20:10  strk
- * added isCovers() and isCoveredBy() public methods to IntersectionMatrix and associated tests.
- * Revision 1.3  2006/04/09 01:46:13  mloskot
- * [SORRY] Added comments for doxygen based on JTS docs. Added row/col dimension consts. Added asserts in functions to check if given row/col is in range.
Modified: trunk/include/geos/geom/LineSegment.h
--- trunk/include/geos/geom/LineSegment.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/LineSegment.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -382,32 +382,3 @@
 #endif
 #endif // ndef GEOS_GEOM_LINESEGMENT_H
- * $Log$
- * Revision 1.8  2006/07/21 14:49:58  strk
- * Fixed typo in comment
- * Revision 1.7  2006/06/12 10:10:39  strk
- * Revision 1.6  2006/04/12 17:19:56  strk
- * Ported TaggedLineStringSimplifier class, made LineSegment class
- * polymorphic to fix derivation of TaggedLineSegment
- * Revision 1.5  2006/03/28 09:14:12  strk
- * Headers inclusion fix.
- * Revision 1.4  2006/03/24 09:52:41  strk
- * Revision 1.3  2006/03/16 13:28:22  strk
- * obsoleted getCoordinate(), replaced by operator[]
- * Revision 1.2  2006/03/13 22:33:09  strk
- * Added missing forward declarations
Modified: trunk/include/geos/geom/LineString.h
--- trunk/include/geos/geom/LineString.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/LineString.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -227,44 +227,3 @@
 #endif
 #endif // ndef GEOS_GEOS_LINESTRING_H
- * $Log$
- * Revision 1.10  2006/06/12 10:49:43  strk
- * unsigned int => size_t
- * Revision 1.9  2006/05/04 15:49:39  strk
- * Revision 1.8  2006/04/28 10:55:39  strk
- * size_t.
- * Revision 1.6  2006/04/10 18:15:09  strk
- * Revision 1.5  2006/04/10 17:35:44  strk
- * Changed LineString::points and Point::coordinates to be wrapped
- * in an auto_ptr<>. This should close bugs #86 and #89
- * Revision 1.4  2006/04/05 10:25:21  strk
- * Fixed LineString constructor to ensure deletion of CoordinateSequence
- * argument on exception throw
- * Revision 1.3  2006/03/31 16:55:17  strk
- * Added many assertions checking in LineString implementation.
- * Changed ::getCoordinate() to return NULL on empty geom.
- * Changed ::get{Start,End}Point() to return NULL on empty geom.
Modified: trunk/include/geos/geom/LinearRing.h
--- trunk/include/geos/geom/LinearRing.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/LinearRing.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -126,25 +126,4 @@
 } // namespace geos
-//# include "geos/geom/LinearRing.inl"
-//#endif
 #endif // ndef GEOS_GEOS_LINEARRING_H
- * $Log$
- * Revision 1.4  2006/04/11 11:16:25  strk
- * Revision 1.3  2006/04/10 17:35:44  strk
Modified: trunk/include/geos/geom/MultiLineString.h
--- trunk/include/geos/geom/MultiLineString.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/MultiLineString.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -129,24 +129,3 @@
 #endif
 #endif // ndef GEOS_GEOS_MULTILINESTRING_H
- * $Log$
- * Revision 1.5  2006/05/04 15:49:39  strk
- * Revision 1.4  2006/04/28 10:55:39  strk
- * size_t.
Modified: trunk/include/geos/geom/MultiPoint.h
--- trunk/include/geos/geom/MultiPoint.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/MultiPoint.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -120,26 +120,4 @@
 } // namespace geos
-//# include "geos/geom/MultiPoint.inl"
-//#endif
 #endif // ndef GEOS_GEOS_MULTIPOINT_H
- * $Log$
- * Revision 1.3  2006/04/28 10:55:39  strk
- * size_t.
Modified: trunk/include/geos/geom/MultiPolygon.h
--- trunk/include/geos/geom/MultiPolygon.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/MultiPolygon.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -129,21 +129,3 @@
 #endif
 #endif // ndef GEOS_GEOS_MULTIPOLYGON_H
- * $Log$
- * size_t.
Modified: trunk/include/geos/geom/Polygon.h
--- trunk/include/geos/geom/Polygon.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/Polygon.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -193,31 +193,3 @@
 } // namespace geos
 #endif // ndef GEOS_GEOM_POLYGON_H
- * $Log$
- * Revision 1.7  2006/06/08 17:58:57  strk
- * Polygon::getNumInteriorRing() return size_t, Polygon::interiorRingN() takes size_t.
- * Revision 1.6  2006/05/04 15:49:39  strk
- * Revision 1.5  2006/04/28 10:55:39  strk
- * size_t.
- * Revision 1.2  2006/03/15 09:12:45  strk
- * isSimple doc
Modified: trunk/include/geos/geom/PrecisionModel.h
--- trunk/include/geos/geom/PrecisionModel.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/PrecisionModel.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -330,28 +330,3 @@
 #endif
 #endif // ndef GEOS_GEOM_PRECISIONMODEL_H
- * $Log$
- * Revision 1.6  2006/04/06 12:34:07  strk
- * Port info, more debugging lines, doxygen comments
- * Revision 1.5  2006/04/03 14:07:32  strk
- * Commented out obsoleted toInternal() method
- * Revision 1.4  2006/03/28 08:57:37  strk
- * Comments cleanup, system headers included after project headers
- * Revision 1.2  2006/03/22 16:58:35  strk
- * Removed (almost) all inclusions of geom.h.
- * Removed obsoleted .cpp files.
- * Fixed a bug in WKTReader not using the provided CoordinateSequence
- * implementation, optimized out some memory allocations.
Modified: trunk/include/geos/geom/Triangle.h
--- trunk/include/geos/geom/Triangle.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/Triangle.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -58,13 +58,3 @@
 //#endif
 #endif // ndef GEOS_GEOM_TRIANGLE_H
- * $Log$
Modified: trunk/include/geos/geom/prep/AbstractPreparedPolygonContains.h
--- trunk/include/geos/geom/prep/AbstractPreparedPolygonContains.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/prep/AbstractPreparedPolygonContains.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -135,7 +135,3 @@
 } // geos
 #endif // GEOS_GEOM_PREP_ABSTRACTPREPAREDPOLYGONCONTAINS_H
- * $Log$
Modified: trunk/include/geos/geom/prep/BasicPreparedGeometry.h
--- trunk/include/geos/geom/prep/BasicPreparedGeometry.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/prep/BasicPreparedGeometry.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -180,7 +180,3 @@
 } // namespace geos
 #endif // GEOS_GEOM_PREP_BASICPREPAREDGEOMETRY_H
- * $Log$
Modified: trunk/include/geos/geom/prep/PreparedGeometry.h
--- trunk/include/geos/geom/prep/PreparedGeometry.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/prep/PreparedGeometry.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -200,7 +200,3 @@
 #endif // ndef GEOS_GEOM_PREP_PREPAREDGEOMETRY_H
- * $Log$
Modified: trunk/include/geos/geom/prep/PreparedGeometryFactory.h
--- trunk/include/geos/geom/prep/PreparedGeometryFactory.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/prep/PreparedGeometryFactory.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -90,7 +90,3 @@
 } // namespace geos
 #endif // GEOS_GEOM_PREP_PREPAREDGEOMETRYFACTORY_H
- * $Log$
Modified: trunk/include/geos/geom/prep/PreparedLineString.h
--- trunk/include/geos/geom/prep/PreparedLineString.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/prep/PreparedLineString.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -67,8 +67,3 @@
 } // namespace geos
 #endif // GEOS_GEOM_PREP_PREPAREDLINESTRING_H
- * $Log$
Modified: trunk/include/geos/geom/prep/PreparedPoint.h
--- trunk/include/geos/geom/prep/PreparedPoint.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/prep/PreparedPoint.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -57,7 +57,3 @@
 } // namespace geos
 #endif // GEOS_GEOM_PREP_PREPAREDPOINT_H
- * $Log$
Modified: trunk/include/geos/geom/prep/PreparedPolygon.h
--- trunk/include/geos/geom/prep/PreparedPolygon.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/prep/PreparedPolygon.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -73,7 +73,3 @@
 } // namespace geos
 #endif // GEOS_GEOM_PREP_PREPAREDPOLYGON_H
- * $Log$
Modified: trunk/include/geos/geom/prep/PreparedPolygonContains.h
--- trunk/include/geos/geom/prep/PreparedPolygonContains.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/prep/PreparedPolygonContains.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -104,7 +104,3 @@
 } // geos
 #endif // GEOS_GEOM_PREP_PREPAREDPOLYGONCONTAINS_H
- * $Log$
Modified: trunk/include/geos/geom/prep/PreparedPolygonContainsProperly.h
--- trunk/include/geos/geom/prep/PreparedPolygonContainsProperly.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/prep/PreparedPolygonContainsProperly.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -102,7 +102,3 @@
 } // geos
 #endif // GEOS_GEOM_PREP_PREPAREDPOLYGONCONTAINSPROPERLY_H
- * $Log$
Modified: trunk/include/geos/geom/prep/PreparedPolygonCovers.h
--- trunk/include/geos/geom/prep/PreparedPolygonCovers.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/prep/PreparedPolygonCovers.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -107,7 +107,3 @@
 } // geos
 #endif // GEOS_GEOM_PREP_PREPAREDPOLYGONCOVERS_H
- * $Log$
Modified: trunk/include/geos/geom/prep/PreparedPolygonIntersects.h
--- trunk/include/geos/geom/prep/PreparedPolygonIntersects.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/prep/PreparedPolygonIntersects.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -90,7 +90,3 @@
 } // geos
 #endif // GEOS_GEOM_PREP_PREPAREDPOLYGONINTERSECTS_H
- * $Log$
Modified: trunk/include/geos/geom/prep/PreparedPolygonPredicate.h
--- trunk/include/geos/geom/prep/PreparedPolygonPredicate.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/prep/PreparedPolygonPredicate.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -142,7 +142,4 @@
 } // namespace geos
 #endif // GEOS_GEOM_PREP_PREPAREDPOLYGONPREDICATE_H
- * $Log$
Modified: trunk/include/geos/geom/util/ComponentCoordinateExtracter.h
--- trunk/include/geos/geom/util/ComponentCoordinateExtracter.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/util/ComponentCoordinateExtracter.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -98,8 +98,3 @@
 } // namespace geos
 #endif //GEOS_GEOM_UTIL_COMPONENTCOORDINATEEXTRACTER_H
- * $Log$
Modified: trunk/include/geos/geom/util/CoordinateOperation.h
--- trunk/include/geos/geom/util/CoordinateOperation.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/util/CoordinateOperation.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -69,21 +69,4 @@
 } // namespace geos
-//# include "geos/geom/util/CoordinateOperation.inl"
-//#endif
 #endif
- * $Log$
Modified: trunk/include/geos/geom/util/GeometryCombiner.h
--- trunk/include/geos/geom/util/GeometryCombiner.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/util/GeometryCombiner.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -116,8 +116,3 @@
 } // namespace geos
 #endif
- * $Log$
Modified: trunk/include/geos/geom/util/GeometryEditor.h
--- trunk/include/geos/geom/util/GeometryEditor.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/util/GeometryEditor.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -125,18 +125,4 @@
 } // namespace geos
-//# include "geos/geom/util/GeometryEditor.inl"
-//#endif
 #endif
- * $Log$
Modified: trunk/include/geos/geom/util/GeometryEditorOperation.h
--- trunk/include/geos/geom/util/GeometryEditorOperation.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/util/GeometryEditorOperation.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -60,21 +60,4 @@
 } // namespace geos
-//# include "geos/geom/util/GeometryEditorOperation.inl"
-//#endif
 #endif
- * $Log$
Modified: trunk/include/geos/geom/util/GeometryTransformer.h
--- trunk/include/geos/geom/util/GeometryTransformer.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/util/GeometryTransformer.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -188,24 +188,4 @@
 } // namespace geos
-//# include "geos/geom/util/GeometryTransformer.inl"
-//#endif
 #endif // GEOS_GEOM_UTIL_GEOMETRYTRANSFORMER_H
- * $Log$
- * Revision 1.4  2006/06/19 21:20:22  strk
- * updated port info
- * Revision 1.2  2006/04/11 12:56:06  strk
- * used typedef for auto_ptr<CoordinateSequence>
- * Revision 1.1  2006/04/11 12:21:49  strk
- * GeometryTransformer class ported
Modified: trunk/include/geos/geom/util/LinearComponentExtracter.h
--- trunk/include/geos/geom/util/LinearComponentExtracter.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/util/LinearComponentExtracter.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -84,10 +84,3 @@
 } // namespace geos
 #endif
- * $Log$
Modified: trunk/include/geos/geom/util/PointExtracter.h
--- trunk/include/geos/geom/util/PointExtracter.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/util/PointExtracter.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -79,10 +79,3 @@
 } // namespace geos
 #endif
- * $Log$
Modified: trunk/include/geos/geom/util/PolygonExtracter.h
--- trunk/include/geos/geom/util/PolygonExtracter.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/util/PolygonExtracter.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -85,10 +85,3 @@
 } // namespace geos
 #endif
- * $Log$
Modified: trunk/include/geos/geom/util/ShortCircuitedGeometryVisitor.h
--- trunk/include/geos/geom/util/ShortCircuitedGeometryVisitor.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geom/util/ShortCircuitedGeometryVisitor.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -65,21 +65,4 @@
 } // namespace geos
-//# include "geos/geom/util/ShortCircuitedGeometryVisitor.inl"
-//#endif
 #endif
- * $Log$
Modified: trunk/include/geos/geomPrep.h
--- trunk/include/geos/geomPrep.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomPrep.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -36,8 +36,3 @@
 } // namespace geos
 #endif //GEOS_GEOMPREP_H
- * $Log$
Modified: trunk/include/geos/geomUtil.h
--- trunk/include/geos/geomUtil.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomUtil.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -37,10 +37,3 @@
 } // namespace geos
 #endif
- * $Log$
- * Revision 1.9  2006/03/09 16:46:48  strk
Modified: trunk/include/geos/geomgraph/Depth.h
--- trunk/include/geos/geomgraph/Depth.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/Depth.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -62,19 +62,4 @@
 } // namespace geos.geomgraph
 } // namespace geos
-//# include "geos/geomgraph/Depth.inl"
-//#endif
 #endif // ifndef GEOS_GEOMGRAPH_DEPTH_H
- * $Log$
Modified: trunk/include/geos/geomgraph/DirectedEdge.h
--- trunk/include/geos/geomgraph/DirectedEdge.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/DirectedEdge.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -189,23 +189,3 @@
 #endif
 #endif // ifndef GEOS_GEOMGRAPH_DIRECTEDEDGE_H
- * $Log$
- * Revision 1.5  2006/06/14 14:32:20  strk
- * EdgeEnd::getEdge() made non-virtual and inlined.
- * Revision 1.4  2006/05/04 13:38:13  strk
- * doxygen comments cleanup
- * Revision 1.2  2006/03/15 15:27:23  strk
- * cleanups
Modified: trunk/include/geos/geomgraph/EdgeList.h
--- trunk/include/geos/geomgraph/EdgeList.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/EdgeList.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -128,17 +128,3 @@
 #endif
 #endif // ifndef GEOS_GEOMGRAPH_EDGELIST_H
- * $Log$
- * Revision 1.2  2006/03/14 11:03:15  strk
- * Added operator<< for Edge and EdgeList
Modified: trunk/include/geos/geomgraph/EdgeNodingValidator.h
--- trunk/include/geos/geomgraph/EdgeNodingValidator.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/EdgeNodingValidator.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -117,14 +117,3 @@
 //#endif
 #endif // ifndef GEOS_GEOMGRAPH_EDGENODINGVALIDATOR_H
- * $Log$
Modified: trunk/include/geos/geomgraph/GeometryGraph.h
--- trunk/include/geos/geomgraph/GeometryGraph.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/GeometryGraph.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -247,20 +247,3 @@
 #endif
 #endif // ifndef GEOS_GEOMGRAPH_GEOMETRYGRAPH_H
- * $Log$
- * Revision 1.4  2006/06/13 22:00:26  strk
- * Changed GeometryGraph::lineEdgeMap set comparison function to be pointer-based. Should be safe and much faster. Available tests all succeed.
- * Revision 1.3  2006/03/29 15:23:49  strk
- * Moved GeometryGraph inlines from .h to .inl file
Modified: trunk/include/geos/geomgraph/Node.h
--- trunk/include/geos/geomgraph/Node.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/Node.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -199,27 +199,3 @@
 #endif
 #endif // ifndef GEOS_GEOMGRAPH_NODE_H
- * $Log$
- * Revision 1.6  2006/06/01 11:49:36  strk
- * Reduced installed headers form geomgraph namespace
- * Revision 1.5  2006/04/27 15:15:06  strk
- * Z check removed from invariant tester to avoid aborts due to differences in FP computations.
- * Revision 1.4  2006/04/07 16:01:51  strk
- * Port info, doxygen comments, testInvariant(), many assertionss, handling of
- * the NULL EdgeEndStar member
- * Revision 1.2  2006/03/15 16:27:54  strk
- * operator<< for Node class
Modified: trunk/include/geos/geomgraph/NodeFactory.h
--- trunk/include/geos/geomgraph/NodeFactory.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/NodeFactory.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -50,22 +50,4 @@
 } // namespace geos
-//# include "geos/geomgraph/NodeFactory.inl"
-//#endif
 #endif // ifndef GEOS_GEOMGRAPH_NODEFACTORY_H
- * $Log$
Modified: trunk/include/geos/geomgraph/NodeMap.h
--- trunk/include/geos/geomgraph/NodeMap.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/NodeMap.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -117,26 +117,8 @@
 } // namespace geos
-//# include "geos/geomgraph/NodeMap.inl"
-//#endif
 #ifdef _MSC_VER
 #pragma warning(pop)
 #endif
 #endif // ifndef GEOS_GEOMGRAPH_NODEMAP_H
- * $Log$
- * Revision 1.3  2006/05/04 12:54:26  strk
- * Added invariant tester for NodeMap class, fixed comment about ownership of NodeFactory
Modified: trunk/include/geos/geomgraph/Position.h
--- trunk/include/geos/geomgraph/Position.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/Position.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -64,19 +64,5 @@
 } // namespace geos
-//# include "geos/geomgraph/Position.inl"
-//#endif
 #endif // ifndef GEOS_GEOMGRAPH_POSITION_H
- * $Log$
Modified: trunk/include/geos/geomgraph/Quadrant.h
--- trunk/include/geos/geomgraph/Quadrant.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/Quadrant.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -99,19 +99,5 @@
 } // namespace geos
-//# include "geos/geomgraph/Quadrant.inl"
-//#endif
 #endif // ifndef GEOS_GEOMGRAPH_QUADRANT_H
- * $Log$
Modified: trunk/include/geos/geomgraph/index/EdgeSetIntersector.h
--- trunk/include/geos/geomgraph/index/EdgeSetIntersector.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/index/EdgeSetIntersector.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -66,10 +66,3 @@
 #endif
- * $Log$
- * Revision 1.1  2006/03/14 12:55:55  strk
- * Headers split: geomgraphindex.h, nodingSnapround.h
Modified: trunk/include/geos/geomgraph/index/MonotoneChain.h
--- trunk/include/geos/geomgraph/index/MonotoneChain.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/index/MonotoneChain.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -69,10 +69,3 @@
 #endif
- * $Log$
Modified: trunk/include/geos/geomgraph/index/MonotoneChainEdge.h
--- trunk/include/geos/geomgraph/index/MonotoneChainEdge.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/index/MonotoneChainEdge.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -84,10 +84,3 @@
 #endif
- * $Log$
Modified: trunk/include/geos/geomgraph/index/MonotoneChainIndexer.h
--- trunk/include/geos/geomgraph/index/MonotoneChainIndexer.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/index/MonotoneChainIndexer.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -51,10 +51,3 @@
 #endif // GEOS_GEOMGRAPH_INDEX_MONOTONECHAININDEXER_H
- * $Log$
Modified: trunk/include/geos/geomgraph/index/SegmentIntersector.h
--- trunk/include/geos/geomgraph/index/SegmentIntersector.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/index/SegmentIntersector.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -135,10 +135,3 @@
 #endif
- * $Log$
Modified: trunk/include/geos/geomgraph/index/SimpleEdgeSetIntersector.h
--- trunk/include/geos/geomgraph/index/SimpleEdgeSetIntersector.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/index/SimpleEdgeSetIntersector.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -60,10 +60,3 @@
 #endif // GEOS_GEOMGRAPH_INDEX_SIMPLEEDGESETINTERSECTOR_H
- * $Log$
Modified: trunk/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
--- trunk/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -98,10 +98,3 @@
 #endif // GEOS_GEOMGRAPH_INDEX_SIMPLEMCSWEEPLINEINTERSECTOR_H
- * $Log$
Modified: trunk/include/geos/geomgraph/index/SimpleSweepLineIntersector.h
--- trunk/include/geos/geomgraph/index/SimpleSweepLineIntersector.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/index/SimpleSweepLineIntersector.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -95,10 +95,3 @@
 #endif // GEOS_GEOMGRAPH_INDEX_SIMPLESWEEPLINEINTERSECTOR_H
- * $Log$
Modified: trunk/include/geos/geomgraph/index/SweepLineEvent.h
--- trunk/include/geos/geomgraph/index/SweepLineEvent.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/index/SweepLineEvent.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -105,13 +105,3 @@
 #endif
- * $Log$
- * Revision 1.2  2006/03/15 17:17:42  strk
- * Revision 1.1  2006/03/14 12:55:56  strk
Modified: trunk/include/geos/geomgraph/index/SweepLineEventObj.h
--- trunk/include/geos/geomgraph/index/SweepLineEventObj.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/index/SweepLineEventObj.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -38,10 +38,3 @@
 #endif
- * $Log$
Modified: trunk/include/geos/geomgraph/index/SweepLineSegment.h
--- trunk/include/geos/geomgraph/index/SweepLineSegment.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph/index/SweepLineSegment.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -58,10 +58,3 @@
 #endif
- * $Log$
Modified: trunk/include/geos/geomgraph.h
--- trunk/include/geos/geomgraph.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/geomgraph.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -76,27 +76,3 @@
 //#include <geos/geomgraph/TopologyLocation.h>
 #endif // ifndef GEOS_GEOMGRAPH_H
- * $Log$
- * Revision 1.42  2006/06/01 11:49:35  strk
- * Revision 1.41  2006/03/09 16:46:48  strk
- * Revision 1.40  2006/03/06 19:40:46  strk
- * Revision 1.38  2006/03/02 14:34:30  strk
- * GeometryGraphOperation::li made a non-static member, and not more a pointer
- * Revision 1.37  2006/02/28 14:34:05  strk
- * Added many assertions and debugging output hunting for a bug in BufferOp
Modified: trunk/include/geos/index/bintree/Bintree.h
--- trunk/include/geos/index/bintree/Bintree.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/bintree/Bintree.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -128,10 +128,3 @@
 #endif // GEOS_IDX_BINTREE_BINTREE_H
- * $Log$
- * Revision 1.1  2006/03/22 16:01:33  strk
Modified: trunk/include/geos/index/bintree/Interval.h
--- trunk/include/geos/index/bintree/Interval.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/bintree/Interval.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -64,10 +64,3 @@
 #endif // GEOS_IDX_BINTREE_INTERVAL_H
- * $Log$
Modified: trunk/include/geos/index/bintree/Key.h
--- trunk/include/geos/index/bintree/Key.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/bintree/Key.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -72,10 +72,3 @@
 #endif // GEOS_IDX_BINTREE_KEY_H
- * $Log$
Modified: trunk/include/geos/index/bintree/Node.h
--- trunk/include/geos/index/bintree/Node.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/bintree/Node.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -75,10 +75,3 @@
 #endif // GEOS_IDX_BINTREE_NODE_H
- * $Log$
Modified: trunk/include/geos/index/bintree/NodeBase.h
--- trunk/include/geos/index/bintree/NodeBase.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/bintree/NodeBase.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -78,10 +78,3 @@
 #endif // GEOS_IDX_BINTREE_NODEBASE_H
- * $Log$
Modified: trunk/include/geos/index/bintree/Root.h
--- trunk/include/geos/index/bintree/Root.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/bintree/Root.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -74,10 +74,3 @@
 #endif // GEOS_IDX_BINTREE_ROOT_H
- * $Log$
Modified: trunk/include/geos/index/chain/MonotoneChain.h
--- trunk/include/geos/index/chain/MonotoneChain.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/chain/MonotoneChain.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -177,10 +177,3 @@
 #endif // GEOS_IDX_CHAIN_MONOTONECHAIN_H
- * $Log$
- * Revision 1.1  2006/03/22 18:12:31  strk
Modified: trunk/include/geos/index/chain/MonotoneChainOverlapAction.h
--- trunk/include/geos/index/chain/MonotoneChainOverlapAction.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/chain/MonotoneChainOverlapAction.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -87,10 +87,3 @@
 #endif // GEOS_IDX_CHAIN_MONOTONECHAINOVERLAPACTION_H
- * $Log$
Modified: trunk/include/geos/index/chain/MonotoneChainSelectAction.h
--- trunk/include/geos/index/chain/MonotoneChainSelectAction.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/chain/MonotoneChainSelectAction.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -77,10 +77,3 @@
 #endif // GEOS_IDX_CHAIN_MONOTONECHAINSELECTACTION_H
- * $Log$
Modified: trunk/include/geos/index/intervalrtree/IntervalRTreeBranchNode.h
--- trunk/include/geos/index/intervalrtree/IntervalRTreeBranchNode.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/intervalrtree/IntervalRTreeBranchNode.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -67,7 +67,4 @@
 } // geos
 #endif // GEOS_INDEX_INTERVALRTREE_INTERVALRTREEBRANCHNODE_H
- * $Log$
Modified: trunk/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h
--- trunk/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -60,7 +60,3 @@
 } // geos
 #endif // GEOS_INDEX_INTERVALRTREE_INTERVALRTREELEAFNODE_H
- * $Log$
Modified: trunk/include/geos/index/intervalrtree/IntervalRTreeNode.h
--- trunk/include/geos/index/intervalrtree/IntervalRTreeNode.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/intervalrtree/IntervalRTreeNode.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -107,7 +107,4 @@
 } // geos
 #endif // GEOS_INDEX_INTERVALRTREE_INTERVALRTREENODE_H
- * $Log$
Modified: trunk/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h
--- trunk/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -91,7 +91,4 @@
 } // geos
 #endif // GEOS_INDEX_INTERVALRTREE_SORTEDPACKEDINTERVALRTREE_H
- * $Log$
Modified: trunk/include/geos/index/quadtree/DoubleBits.h
--- trunk/include/geos/index/quadtree/DoubleBits.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/quadtree/DoubleBits.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -100,14 +100,3 @@
 } // namespace geos
 #endif // GEOS_IDX_QUADTREE_DOUBLEBITS_H
- * $Log$
- * Revision 1.2  2006/05/23 14:29:33  strk
- * * source/headers/geos/index/quadtree/DoubleBits.h, source/index/quadtree/DoubleBits.cpp: const correctness and documentation.
- * Revision 1.1  2006/03/22 12:22:50  strk
- * indexQuadtree.h split
Modified: trunk/include/geos/index/quadtree/IntervalSize.h
--- trunk/include/geos/index/quadtree/IntervalSize.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/quadtree/IntervalSize.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -62,11 +62,3 @@
 } // namespace geos
 #endif // GEOS_IDX_QUADTREE_INTERVALSIZE_H
- * $Log$
Modified: trunk/include/geos/index/quadtree/Key.h
--- trunk/include/geos/index/quadtree/Key.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/quadtree/Key.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -87,11 +87,3 @@
 } // namespace geos
 #endif // GEOS_IDX_QUADTREE_KEY_H
- * $Log$
Modified: trunk/include/geos/index/quadtree/Node.h
--- trunk/include/geos/index/quadtree/Node.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/quadtree/Node.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -135,11 +135,3 @@
 #endif
 #endif // GEOS_IDX_QUADTREE_NODE_H
- * $Log$
Modified: trunk/include/geos/index/quadtree/NodeBase.h
--- trunk/include/geos/index/quadtree/NodeBase.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/quadtree/NodeBase.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -156,11 +156,3 @@
 #endif
 #endif // GEOS_IDX_QUADTREE_NODEBASE_H
- * $Log$
Modified: trunk/include/geos/index/quadtree/Quadtree.h
--- trunk/include/geos/index/quadtree/Quadtree.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/quadtree/Quadtree.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -193,14 +193,3 @@
 #endif
 #endif // GEOS_IDX_QUADTREE_QUADTREE_H
- * $Log$
- * Revision 1.2  2006/04/03 08:29:30  strk
- * Added port info, cleaned up log message, minor assertion checking.
Modified: trunk/include/geos/index/quadtree/Root.h
--- trunk/include/geos/index/quadtree/Root.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/quadtree/Root.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -85,14 +85,3 @@
 } // namespace geos
 #endif // GEOS_IDX_QUADTREE_ROOT_H
- * $Log$
- * Revision 1.2  2006/06/12 17:15:29  strk
- * Removed unused parameters warning
Modified: trunk/include/geos/index/strtree/AbstractNode.h
--- trunk/include/geos/index/strtree/AbstractNode.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/strtree/AbstractNode.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -94,11 +94,3 @@
 #endif
 #endif // GEOS_INDEX_STRTREE_ABSTRACTNODE_H
- * $Log$
- * Revision 1.1  2006/03/21 10:47:34  strk
- * indexStrtree.h split
Modified: trunk/include/geos/index/strtree/AbstractSTRtree.h
--- trunk/include/geos/index/strtree/AbstractSTRtree.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/strtree/AbstractSTRtree.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -318,17 +318,3 @@
 } // namespace geos
 #endif // GEOS_INDEX_STRTREE_ABSTRACTSTRTREE_H
- * $Log$
- * Revision 1.3  2006/06/12 10:49:43  strk
- * Revision 1.2  2006/06/08 11:20:24  strk
Modified: trunk/include/geos/index/strtree/Boundable.h
--- trunk/include/geos/index/strtree/Boundable.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/strtree/Boundable.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -47,11 +47,3 @@
 } // namespace geos
 #endif // GEOS_INDEX_STRTREE_BOUNDABLE_H
- * $Log$
Modified: trunk/include/geos/index/strtree/Interval.h
--- trunk/include/geos/index/strtree/Interval.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/strtree/Interval.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -44,11 +44,3 @@
 } // namespace geos
 #endif // GEOS_INDEX_STRTREE_INTERVAL_H
- * $Log$
Modified: trunk/include/geos/index/strtree/ItemBoundable.h
--- trunk/include/geos/index/strtree/ItemBoundable.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/strtree/ItemBoundable.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -50,11 +50,3 @@
 } // namespace geos
 #endif // GEOS_INDEX_STRTREE_ITEMBOUNDABLE_H
- * $Log$
Modified: trunk/include/geos/index/strtree/SIRtree.h
--- trunk/include/geos/index/strtree/SIRtree.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/strtree/SIRtree.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -108,14 +108,3 @@
 } // namespace geos
 #endif // GEOS_INDEX_STRTREE_SIRTREE_H
- * $Log$
- * Revision 1.2  2006/06/12 10:49:43  strk
Modified: trunk/include/geos/index/strtree/STRtree.h
--- trunk/include/geos/index/strtree/STRtree.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/strtree/STRtree.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -152,17 +152,3 @@
 #endif
 #endif // GEOS_INDEX_STRTREE_STRTREE_H
- * $Log$
- * Revision 1.2  2006/04/03 08:43:09  strk
- * Added port info, minor cleanups
Modified: trunk/include/geos/index/sweepline/SweepLineEvent.h
--- trunk/include/geos/index/sweepline/SweepLineEvent.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/sweepline/SweepLineEvent.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -94,11 +94,3 @@
 } // namespace geos
 #endif // GEOS_INDEX_SWEEPLINE_SWEEPLINEEVENT_H
- * $Log$
- * Revision 1.1  2006/03/21 10:01:30  strk
- * indexSweepline.h header split
Modified: trunk/include/geos/index/sweepline/SweepLineIndex.h
--- trunk/include/geos/index/sweepline/SweepLineIndex.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/sweepline/SweepLineIndex.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -87,11 +87,3 @@
 #endif
 #endif // GEOS_INDEX_SWEEPLINE_SWEEPLINEINDEX_H
- * $Log$
Modified: trunk/include/geos/index/sweepline/SweepLineInterval.h
--- trunk/include/geos/index/sweepline/SweepLineInterval.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/sweepline/SweepLineInterval.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -37,11 +37,3 @@
 } // namespace geos
 #endif // GEOS_INDEX_SWEEPLINE_SWEEPLINEINTERVAL_H
- * $Log$
Modified: trunk/include/geos/index/sweepline/SweepLineOverlapAction.h
--- trunk/include/geos/index/sweepline/SweepLineOverlapAction.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/index/sweepline/SweepLineOverlapAction.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -43,14 +43,3 @@
 } // namespace geos
 #endif // GEOS_INDEX_SWEEPLINE_SWEEPLINEOVERLAPACTION_H
- * $Log$
Modified: trunk/include/geos/indexStrtree.h
--- trunk/include/geos/indexStrtree.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/indexStrtree.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -35,16 +35,3 @@
 #include <geos/index/strtree/STRtree.h>
 #endif // GEOS_INDEXSTRTREE_H
- * $Log$
- * Revision 1.17  2006/06/01 10:28:46  strk
- * Reduced number of installed headers for the geos::index namespace
- * Revision 1.16  2006/03/21 10:47:34  strk
- * Revision 1.15  2006/03/09 16:46:48  strk
Modified: trunk/include/geos/indexSweepline.h
--- trunk/include/geos/indexSweepline.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/indexSweepline.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -35,17 +35,3 @@
 #include <geos/index/sweepline/SweepLineOverlapAction.h>
 #endif
- * $Log$
- * Revision 1.8  2006/06/05 19:42:33  strk
- * Fixed noinst_geos_HEADERS => noinst_HEADERS.
- * Revision 1.7  2006/06/01 10:28:46  strk
- * Revision 1.6  2006/03/21 10:01:30  strk
Modified: trunk/include/geos/io/ByteOrderDataInStream.h
--- trunk/include/geos/io/ByteOrderDataInStream.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/io/ByteOrderDataInStream.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -80,14 +80,3 @@
 #endif
 #endif // #ifndef GEOS_IO_BYTEORDERDATAINSTREAM_H
- * $Log$
- * Revision 1.2  2006/03/28 11:26:13  strk
- * ByteOrderDataInStream inlines moved to .inl file, updated
- * implementation files includes.
- * Revision 1.1  2006/03/20 18:18:14  strk
- * io.h header split
Modified: trunk/include/geos/io/ByteOrderDataInStream.inl
--- trunk/include/geos/io/ByteOrderDataInStream.inl	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/io/ByteOrderDataInStream.inl	2012-05-29 08:42:24 UTC (rev 3650)
@@ -95,11 +95,3 @@
 } // namespace geos
 #endif // #ifndef GEOS_IO_BYTEORDERDATAINSTREAM_INL
- * $Log$
- * Revision 1.1  2006/03/28 11:26:13  strk
Modified: trunk/include/geos/io/ByteOrderValues.h
--- trunk/include/geos/io/ByteOrderValues.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/io/ByteOrderValues.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -59,10 +59,3 @@
 } // namespace geos
 #endif // #ifndef GEOS_IO_BYTEORDERVALUES_H
- * $Log$
Modified: trunk/include/geos/io/ParseException.h
--- trunk/include/geos/io/ParseException.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/io/ParseException.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -54,14 +54,3 @@
 } // namespace geos
 #endif // #ifndef GEOS_IO_PARSEEXCEPTION_H
- * $Log$
- * Changed GEOSException hierarchy to be derived from std::runtime_exception.
- * Removed the GEOSException::toString redundant method (use ::what() instead)
Modified: trunk/include/geos/io/StringTokenizer.h
--- trunk/include/geos/io/StringTokenizer.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/io/StringTokenizer.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -66,10 +66,3 @@
 #endif
 #endif // #ifndef GEOS_IO_STRINGTOKENIZER_H
- * $Log$
Modified: trunk/include/geos/io/WKBConstants.h
--- trunk/include/geos/io/WKBConstants.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/io/WKBConstants.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -45,14 +45,3 @@
 } // namespace geos
 #endif // #ifndef GEOS_IO_WKBCONSTANTS_H
- * $Log$
- * Revision 1.2  2006/05/23 09:24:37  strk
- * * source/io/ByteOrderValues.cpp: changed ENDIAN_BIG and ENDIAN_LITTLE values to match WKBConstants::XDR and WKBConstants::NDR respectively.
- * * source/headers/geos/io/WKBConstants.h: added comments about meaning of XDR/NDR.
Modified: trunk/include/geos/io/WKBReader.h
--- trunk/include/geos/io/WKBReader.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/io/WKBReader.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -170,16 +170,3 @@
 #endif
 #endif // #ifndef GEOS_IO_WKBREADER_H
- * $Log$
- * Revision 1.3  2006/06/01 11:49:36  strk
- * Revision 1.2  2006/04/12 10:57:19  strk
- * Added WKBReader default ctor using default GeometryFactory instance
Modified: trunk/include/geos/io/WKBWriter.h
--- trunk/include/geos/io/WKBWriter.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/io/WKBWriter.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -203,14 +203,3 @@
 } // namespace geos
 #endif // #ifndef GEOS_IO_WKBWRITER_H
- * $Log$
Modified: trunk/include/geos/io/WKTReader.h
--- trunk/include/geos/io/WKTReader.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/io/WKTReader.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -115,30 +115,3 @@
 #endif
 #endif // #ifndef GEOS_IO_WKTREADER_H
- * $Log$
- * Revision 1.6  2006/04/10 13:40:14  strk
- * Added default ctor for WKTReader (using GeometryFactory's default instance)
- * Revision 1.5  2006/04/10 12:05:35  strk
- * Added inline-replicator implementation files to make sure
- * functions in .inl files are still available out-of-line.
- * A side effect is this should fix MingW build.
- * Revision 1.4  2006/03/30 09:26:36  strk
- * minor cleanup
- * Revision 1.1  2006/03/20 18:18:15  strk
Modified: trunk/include/geos/io/WKTReader.inl
--- trunk/include/geos/io/WKTReader.inl	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/io/WKTReader.inl	2012-05-29 08:42:24 UTC (rev 3650)
@@ -63,27 +63,3 @@
 } // namespace geos
 #endif // #ifndef GEOS_IO_WKTREADER_INL
- * $Log$
- * Revision 1.5  2006/06/13 22:50:17  strk
- * * source/headers/geos/io/WKTReader.inl: added missing include for GEOS_DEBUG set case, use stderr for debugging output.
- * Revision 1.4  2006/04/10 13:40:14  strk
- * Revision 1.3  2006/04/10 12:05:35  strk
Modified: trunk/include/geos/io/WKTWriter.h
--- trunk/include/geos/io/WKTWriter.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/io/WKTWriter.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -272,19 +272,3 @@
 #endif
 #endif // #ifndef GEOS_IO_WKTWRITER_H
- * $Log$
- * Revision 1.3  2006/06/12 16:55:53  strk
- * fixed compiler warnings, fixed some methods to omit unused parameters.
Modified: trunk/include/geos/io/Writer.h
--- trunk/include/geos/io/Writer.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/io/Writer.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -50,10 +50,3 @@
 #endif
 #endif // #ifndef GEOS_IO_WRITER_H
- * $Log$
Modified: trunk/include/geos/io.h
--- trunk/include/geos/io.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/io.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -64,17 +64,3 @@
 using namespace geos::io;
 #endif
- * $Log$
- * Revision 1.29  2006/07/21 16:45:28  mloskot
- * Wrapped FIXME message with #warning directive to shout about potential headers removal in future.
- * Revision 1.28  2006/06/01 11:49:36  strk
- * Revision 1.27  2006/03/20 18:18:14  strk
Modified: trunk/include/geos/noding/FastNodingValidator.h
--- trunk/include/geos/noding/FastNodingValidator.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/FastNodingValidator.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -119,7 +119,3 @@
 } // namespace geos
 #endif // GEOS_NODING_FASTNODINGVALIDATOR_H
- * $Log$
Modified: trunk/include/geos/noding/IntersectionAdder.h
--- trunk/include/geos/noding/IntersectionAdder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/IntersectionAdder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -179,19 +179,4 @@
 } // namespace geos.noding
 } // namespace geos
-//# include "geos/noding/IntersectionAdder.inl"
-//#endif
 #endif // GEOS_NODING_INTERSECTIONADDER_H
- * $Log$
Modified: trunk/include/geos/noding/IntersectionFinderAdder.h
--- trunk/include/geos/noding/IntersectionFinderAdder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/IntersectionFinderAdder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -107,25 +107,4 @@
 } // namespace geos
-//# include "geos/noding/IntersectionFinderAdder.inl"
-//#endif
 #endif // GEOS_NODING_INTERSECTIONFINDERADDER_H
- * $Log$
- * Revision 1.4  2006/05/03 15:06:30  strk
- * Better doxygen comment
- * Revision 1.2  2006/03/14 12:55:56  strk
Modified: trunk/include/geos/noding/IteratedNoder.h
--- trunk/include/geos/noding/IteratedNoder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/IteratedNoder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -114,19 +114,4 @@
 } // namespace geos
-//# include "geos/noding/IteratedNoder.inl"
-//#endif
 #endif // GEOS_NODING_ITERATEDNODER_H
- * $Log$
Modified: trunk/include/geos/noding/MCIndexNoder.h
--- trunk/include/geos/noding/MCIndexNoder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/MCIndexNoder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -127,20 +127,3 @@
 #endif
 #endif // GEOS_NODING_MCINDEXNODER_H
- * $Log$
Modified: trunk/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
--- trunk/include/geos/noding/MCIndexSegmentSetMutualIntersector.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/MCIndexSegmentSetMutualIntersector.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -129,7 +129,3 @@
 } // namespace geos
 #endif // GEOS_NODING_MCINDEXSEGMENTSETMUTUALINTERSECTOR_H
- * $Log$
Modified: trunk/include/geos/noding/NodableSegmentString.h
--- trunk/include/geos/noding/NodableSegmentString.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/NodableSegmentString.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -57,7 +57,3 @@
 } // namespace geos
 #endif // GEOS_NODING_NODABLESEGMENTSTRING_H
- * $Log$
Modified: trunk/include/geos/noding/NodedSegmentString.h
--- trunk/include/geos/noding/NodedSegmentString.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/NodedSegmentString.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -214,7 +214,3 @@
 #endif
 #endif // GEOS_NODING_NODEDSEGMENTSTRING_H
- * $Log$
Modified: trunk/include/geos/noding/NodingValidator.h
--- trunk/include/geos/noding/NodingValidator.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/NodingValidator.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -110,19 +110,4 @@
 } // namespace geos
-//# include "geos/noding/NodingValidator.inl"
-//#endif
 #endif // GEOS_NODING_NODINGVALIDATOR_H
- * $Log$
- * Revision 1.2  2006/03/24 09:52:41  strk
- * USE_INLINE => GEOS_INLINE
- * geos::geom namespace definition, first pass at headers split
Modified: trunk/include/geos/noding/Octant.h
--- trunk/include/geos/noding/Octant.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/Octant.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -73,19 +73,4 @@
 } // namespace geos
-//# include "geos/noding/Octant.inl"
-//#endif
 #endif
- * $Log$
Modified: trunk/include/geos/noding/ScaledNoder.h
--- trunk/include/geos/noding/ScaledNoder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/ScaledNoder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -128,38 +128,4 @@
 #endif
-//# include "geos/noding/ScaledNoder.inl"
-//#endif
 #endif // GEOS_NODING_SCALEDNODER_H
- * $Log$
- * Revision 1.8  2006/06/19 23:33:03  strk
- * Revision 1.7  2006/05/04 06:36:00  strk
- * Extended definition to take new CoordinateSequence tracking into account
- * Revision 1.6  2006/05/03 15:04:33  strk
- * removed reduntant port info
- * Revision 1.5  2006/05/03 15:00:42  strk
- * Fixed scale() function to remove repeated points *after* rounding. Added brief doxygen class description.
- * Revision 1.4  2006/05/03 09:14:22  strk
- * * source/operation/buffer/OffsetCurveSetBuilder.cpp: used auto_ptr to protect leaks of CoordinateSequence
- * * source/noding/ScaledNoder.cpp, source/headers/geos/noding/ScaledNoder.h: ported JTS bugfix in scale method.
- * Revision 1.2  2006/03/13 21:19:51  strk
- * Fixed bug in ScaledNoder scaling mechanism (hugly code, due to CoordinateSequence visitor pattern design). Tests are still failing so this possibly needs some other fix. Streamlined includes by implementation file.
Modified: trunk/include/geos/noding/SegmentIntersectionDetector.h
--- trunk/include/geos/noding/SegmentIntersectionDetector.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/SegmentIntersectionDetector.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -169,8 +169,3 @@
 } // namespace geos
 #endif // GEOS_GEOM_PREP_SEGMENTINTERSECTIONDETECTOR_H
- * $Log$
Modified: trunk/include/geos/noding/SegmentIntersector.h
--- trunk/include/geos/noding/SegmentIntersector.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/SegmentIntersector.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -86,20 +86,4 @@
 } // namespace geos
-//# include "geos/noding/SegmentIntersector.inl"
-//#endif
 #endif // GEOS_NODING_SEGMENTINTERSECTOR_H
- * $Log$
Modified: trunk/include/geos/noding/SegmentNode.h
--- trunk/include/geos/noding/SegmentNode.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/SegmentNode.h	2012-05-29 08:42:24 UTC (rev 3650)
 } // namespace geos
-//# include "geos/noding/SegmentNode.inl"
-//#endif
 #endif // GEOS_NODING_SEGMENTNODE_H
- * $Log$
Modified: trunk/include/geos/noding/SegmentNodeList.h
--- trunk/include/geos/noding/SegmentNodeList.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/SegmentNodeList.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -191,25 +191,4 @@
 #endif
-//# include "geos/noding/SegmentNodeList.inl"
-//#endif
 #endif
- * $Log$
- * Revision 1.4  2006/06/12 11:29:23  strk
- * Revision 1.3  2006/05/04 07:41:56  strk
- * const-correct size() method for SegmentNodeList
Modified: trunk/include/geos/noding/SegmentSetMutualIntersector.h
--- trunk/include/geos/noding/SegmentSetMutualIntersector.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/SegmentSetMutualIntersector.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -79,7 +79,3 @@
 } // geos
 #endif // GEOS_NODING_SEGMENTSETMUTUALINTERSECTOR_H
- * $Log$
Modified: trunk/include/geos/noding/SegmentStringUtil.h
--- trunk/include/geos/noding/SegmentStringUtil.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/SegmentStringUtil.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -73,7 +73,3 @@
 } // geos
 #endif // GEOS_NODING_SEGMENTSTRINGUTIL_H
- * $Log$
Modified: trunk/include/geos/noding/SimpleNoder.h
--- trunk/include/geos/noding/SimpleNoder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/SimpleNoder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -69,22 +69,4 @@
 } // namespace geos
-//# include "geos/noding/SimpleNoder.inl"
-//#endif
 #endif // GEOS_NODING_SIMPLENODER_H
- * $Log$
- * Revision 1.2  2006/03/15 09:51:49  strk
- * streamlined header usage
Modified: trunk/include/geos/noding/SingleInteriorIntersectionFinder.h
--- trunk/include/geos/noding/SingleInteriorIntersectionFinder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/SingleInteriorIntersectionFinder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -121,7 +121,3 @@
 } // namespace geos
 #endif // GEOS_NODING_SINGLEINTERIORINTERSECTIONFINDER_H
- * $Log$
Modified: trunk/include/geos/noding/SinglePassNoder.h
--- trunk/include/geos/noding/SinglePassNoder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/SinglePassNoder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -93,19 +93,4 @@
 } // namespace geos
-//# include "geos/noding/SinglePassNoder.inl"
-//#endif
 #endif // GEOS_NODING_SINGLEPASSNODER_H
- * $Log$
Modified: trunk/include/geos/noding/snapround/HotPixel.h
--- trunk/include/geos/noding/snapround/HotPixel.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/snapround/HotPixel.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -211,17 +211,3 @@
 #endif
 #endif // GEOS_NODING_SNAPROUND_HOTPIXEL_H
- * $Log$
- * Revision 1.3  2006/05/03 17:50:49  strk
- * Doxygen comments
Modified: trunk/include/geos/noding/snapround/SimpleSnapRounder.h
--- trunk/include/geos/noding/snapround/SimpleSnapRounder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/noding/snapround/SimpleSnapRounder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -143,22 +143,4 @@
 } // namespace geos::noding
 } // namespace geos
-//# include "geos/noding/snapround/SimpleSnapRounder.inl"
-//#endif
 #endif // GEOS_NODING_SNAPROUND_SIMPLESNAPROUNDER_H
- * $Log$
- * Revision 1.3  2006/05/03 15:02:49  strk
- * moved some implementations from header to .cpp file (taken out of inline)
Modified: trunk/include/geos/operation/GeometryGraphOperation.h
--- trunk/include/geos/operation/GeometryGraphOperation.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/GeometryGraphOperation.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -88,17 +88,3 @@
 #endif
 #endif
- * $Log$
- * Revision 1.2  2006/04/03 15:54:33  strk
- * - getArgGeometry() parameter type changed from 'int' to 'unsigned int'
- * - Added port informations
- * - minor assertions checking
- * - minor cleanups
Modified: trunk/include/geos/operation/IsSimpleOp.h
--- trunk/include/geos/operation/IsSimpleOp.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/IsSimpleOp.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -217,14 +217,3 @@
 #endif
 #endif
- * $Log$
- * Revision 1.2  2006/03/15 18:59:33  strk
- * Bug #62: 'struct' CoordinateLessThen in forward declaration
Modified: trunk/include/geos/operation/buffer/BufferBuilder.h
--- trunk/include/geos/operation/buffer/BufferBuilder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/buffer/BufferBuilder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -231,14 +231,3 @@
 #endif
 #endif // ndef GEOS_OP_BUFFER_BUFFERBUILDER_H
- * $Log$
- * Revision 1.2  2006/03/14 16:08:21  strk
- * changed buildSubgraphs signature to use refs rather then pointers, made it const-correct. Reduced heap allocations in createSubgraphs()
- * Revision 1.1  2006/03/14 00:19:40  strk
- * opBuffer.h split, streamlined headers in some (not all) files in operation/buffer/
Modified: trunk/include/geos/operation/buffer/BufferInputLineSimplifier.h
--- trunk/include/geos/operation/buffer/BufferInputLineSimplifier.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/buffer/BufferInputLineSimplifier.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -184,7 +184,3 @@
 #endif // ndef GEOS_OP_BUFFER_BUFFERINPUTLINESIMPLIFIER_H
- * $Log$
Modified: trunk/include/geos/operation/buffer/BufferOp.h
--- trunk/include/geos/operation/buffer/BufferOp.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/buffer/BufferOp.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -272,10 +272,3 @@
 #endif // ndef GEOS_OP_BUFFER_BUFFEROP_H
- * $Log$
Modified: trunk/include/geos/operation/buffer/BufferSubgraph.h
--- trunk/include/geos/operation/buffer/BufferSubgraph.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/buffer/BufferSubgraph.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -196,16 +196,3 @@
 #endif // ndef GEOS_OP_BUFFER_BUFFERSUBGRAPH_H
- * $Log$
- * Revision 1.3  2006/03/15 11:45:06  strk
- * Revision 1.2  2006/03/14 14:16:52  strk
- * operator<< for BufferSubgraph, more debugging calls
Modified: trunk/include/geos/operation/buffer/OffsetCurveSetBuilder.h
--- trunk/include/geos/operation/buffer/OffsetCurveSetBuilder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/buffer/OffsetCurveSetBuilder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -213,13 +213,3 @@
 #endif // ndef GEOS_OP_BUFFER_OFFSETCURVESETBUILDER_H
- * $Log$
- * Revision 1.2  2006/05/04 10:15:20  strk
Modified: trunk/include/geos/operation/buffer/RightmostEdgeFinder.h
--- trunk/include/geos/operation/buffer/RightmostEdgeFinder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/buffer/RightmostEdgeFinder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -108,17 +108,3 @@
 #endif // ndef GEOS_OP_BUFFER_RIGHTMOSTEDGEFINDER_H
- * $Log$
- * Revision 1.3  2006/05/04 12:19:59  strk
- * Added note about findEdge() only scanning for forward DirectedEdges
- * Revision 1.2  2006/04/05 09:20:25  strk
- * Added port informations and many assertion checking.
- * Fixed bug in getRightmostSide() method ( a "testing-only" corner case )
Modified: trunk/include/geos/operation/buffer/SubgraphDepthLocater.h
--- trunk/include/geos/operation/buffer/SubgraphDepthLocater.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/buffer/SubgraphDepthLocater.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -121,13 +121,3 @@
 #endif // ndef GEOS_OP_BUFFER_SUBGRAPHDEPTHLOCATER_H
- * $Log$
- * Revision 1.2  2006/03/15 15:50:11  strk
- * const correctness, cleanups
Modified: trunk/include/geos/operation/distance/ConnectedElementLocationFilter.h
--- trunk/include/geos/operation/distance/ConnectedElementLocationFilter.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/distance/ConnectedElementLocationFilter.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -79,10 +79,3 @@
 #endif // GEOS_OP_DISTANCE_CONNECTEDELEMENTLOCATIONFILTER_H
- * $Log$
- * Revision 1.1  2006/03/21 17:55:01  strk
- * opDistance.h header split
Modified: trunk/include/geos/operation/distance/ConnectedElementPointFilter.h
--- trunk/include/geos/operation/distance/ConnectedElementPointFilter.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/distance/ConnectedElementPointFilter.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -74,13 +74,3 @@
 #endif // GEOS_OP_DISTANCE_CONNECTEDELEMENTPOINTFILTER_H
- * $Log$
Modified: trunk/include/geos/operation/distance/DistanceOp.h
--- trunk/include/geos/operation/distance/DistanceOp.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/distance/DistanceOp.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -279,10 +279,3 @@
 #endif // GEOS_OP_DISTANCE_DISTANCEOP_H
- * $Log$
Modified: trunk/include/geos/operation/distance/GeometryLocation.h
--- trunk/include/geos/operation/distance/GeometryLocation.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/distance/GeometryLocation.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -117,10 +117,3 @@
 #endif // GEOS_OP_DISTANCE_GEOMETRYLOCATION_H
- * $Log$
Modified: trunk/include/geos/operation/linemerge/EdgeString.h
--- trunk/include/geos/operation/linemerge/EdgeString.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/linemerge/EdgeString.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -88,10 +88,3 @@
 #endif
 #endif // GEOS_OP_LINEMERGE_EDGESTRING_H
- * $Log$
- * Revision 1.1  2006/03/22 10:13:53  strk
- * opLinemerge.h split
Modified: trunk/include/geos/operation/linemerge/LineMergeDirectedEdge.h
--- trunk/include/geos/operation/linemerge/LineMergeDirectedEdge.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/linemerge/LineMergeDirectedEdge.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -77,10 +77,3 @@
 } // namespace geos
 #endif // GEOS_OP_LINEMERGE_LINEMERGEDIRECTEDEDGE_H
- * $Log$
Modified: trunk/include/geos/operation/linemerge/LineMergeEdge.h
--- trunk/include/geos/operation/linemerge/LineMergeEdge.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/linemerge/LineMergeEdge.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -62,10 +62,3 @@
 } // namespace geos
 #endif // GEOS_OP_LINEMERGE_LINEMERGEEDGE_H
- * $Log$
Modified: trunk/include/geos/operation/linemerge/LineMergeGraph.h
--- trunk/include/geos/operation/linemerge/LineMergeGraph.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/linemerge/LineMergeGraph.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -91,10 +91,3 @@
 #endif
 #endif // GEOS_OP_LINEMERGE_LINEMERGEGRAPH_H
- * $Log$
Modified: trunk/include/geos/operation/linemerge/LineMerger.h
--- trunk/include/geos/operation/linemerge/LineMerger.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/linemerge/LineMerger.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -143,10 +143,3 @@
 #endif
 #endif // GEOS_OP_LINEMERGE_LINEMERGER_H
- * $Log$
Modified: trunk/include/geos/operation/linemerge/LineSequencer.h
--- trunk/include/geos/operation/linemerge/LineSequencer.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/linemerge/LineSequencer.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -293,10 +293,3 @@
 #endif
 #endif // GEOS_OP_LINEMERGE_LINESEQUENCER_H
- * $Log$
Modified: trunk/include/geos/operation/overlay/EdgeSetNoder.h
--- trunk/include/geos/operation/overlay/EdgeSetNoder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/overlay/EdgeSetNoder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -69,11 +69,3 @@
 } // namespace geos
 #endif // ndef GEOS_OP_OVERLAY_EDGESETNODER_H
- * $Log$
- * Revision 1.1  2006/03/17 13:24:59  strk
- * opOverlay.h header splitted. Reduced header inclusions in operation/overlay implementation files. ElevationMatrixFilter code moved from own file to ElevationMatrix.cpp (ideally a class-private).
Modified: trunk/include/geos/operation/overlay/ElevationMatrix.h
--- trunk/include/geos/operation/overlay/ElevationMatrix.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/overlay/ElevationMatrix.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -112,11 +112,3 @@
 #endif
 #endif // ndef GEOS_OP_OVERLAY_ELEVATIONMATRIX_H
- * $Log$
Modified: trunk/include/geos/operation/overlay/ElevationMatrixCell.h
--- trunk/include/geos/operation/overlay/ElevationMatrixCell.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/overlay/ElevationMatrixCell.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -63,11 +63,3 @@
 #endif
 #endif // ndef GEOS_OP_OVERLAY_ELEVATIONMATRIXCELL_H
- * $Log$
Modified: trunk/include/geos/operation/overlay/LineBuilder.h
--- trunk/include/geos/operation/overlay/LineBuilder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/overlay/LineBuilder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -138,14 +138,3 @@
 #endif
 #endif // ndef GEOS_OP_OVERLAY_LINEBUILDER_H
- * $Log$
- * Revision 1.2  2006/06/05 15:36:34  strk
- * Given OverlayOp funx code enum a name and renamed values to have a lowercase prefix. Drop all of noding headers from installed header set.
Modified: trunk/include/geos/operation/overlay/MaximalEdgeRing.h
--- trunk/include/geos/operation/overlay/MaximalEdgeRing.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/overlay/MaximalEdgeRing.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -105,15 +105,3 @@
 } // namespace geos
 #endif // ndef GEOS_OP_OVERLAY_MAXIMALEDGERING_H
- * $Log$
- * Revision 1.2  2006/03/27 16:02:34  strk
- * Added INL file for MinimalEdgeRing, added many debugging blocks,
- * fixed memory leak in ConnectedInteriorTester (bug #59)
Modified: trunk/include/geos/operation/overlay/MinimalEdgeRing.h
--- trunk/include/geos/operation/overlay/MinimalEdgeRing.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/overlay/MinimalEdgeRing.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -79,15 +79,3 @@
 #endif
 #endif // ndef GEOS_OP_OVERLAY_MINIMALEDGERING_H
- * $Log$
Modified: trunk/include/geos/operation/overlay/OverlayNodeFactory.h
--- trunk/include/geos/operation/overlay/OverlayNodeFactory.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/overlay/OverlayNodeFactory.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -56,11 +56,3 @@
 } // namespace geos
 #endif // ndef GEOS_OP_OVERLAY_OVERLAYNODEFACTORY_H
- * $Log$
Modified: trunk/include/geos/operation/overlay/OverlayOp.h
--- trunk/include/geos/operation/overlay/OverlayOp.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/overlay/OverlayOp.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -359,26 +359,3 @@
 #endif
 #endif // ndef GEOS_OP_OVERLAY_OVERLAYOP_H
- * $Log$
- * Revision 1.6  2006/07/05 20:19:29  strk
- * added checks for obviously wrong result of difference and intersection ops
- * Revision 1.5  2006/06/05 15:36:34  strk
- * Revision 1.4  2006/05/24 15:17:44  strk
- * Reduced number of installed headers in geos/operation/ subdir
- * Revision 1.3  2006/04/14 15:04:36  strk
- * fixed missing namespace qualification in overlay::overlayOp
- * Revision 1.2  2006/04/14 14:35:47  strk
- * Added overlayOp() adapter for use in templates expecting binary ops
Modified: trunk/include/geos/operation/overlay/PointBuilder.h
--- trunk/include/geos/operation/overlay/PointBuilder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/overlay/PointBuilder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -104,14 +104,3 @@
 } // namespace geos
 #endif // ndef GEOS_OP_OVERLAY_POINTBUILDER_H
- * $Log$
Modified: trunk/include/geos/operation/overlay/PolygonBuilder.h
--- trunk/include/geos/operation/overlay/PolygonBuilder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/overlay/PolygonBuilder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -210,18 +210,3 @@
 #endif
 #endif // ndef GEOS_OP_OVERLAY_POLYGONBUILDER_H
- * $Log$
- * Revision 1.3  2006/06/13 23:26:46  strk
- * cleanups
- * Revision 1.2  2006/03/20 12:33:45  strk
- * Simplified some privat methods to use refs instead of pointers, added
- * debugging section for failiures of holes/shells associations
Modified: trunk/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h
--- trunk/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -112,8 +112,3 @@
 } // namespace geos
 #endif // ndef GEOS_OP_OVERLAY_SNAP_SNAPIFNEEDEDOVERLAYOP_H
- * $Log$
Modified: trunk/include/geos/operation/overlay/snap/SnapOverlayOp.h
--- trunk/include/geos/operation/overlay/snap/SnapOverlayOp.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/overlay/snap/SnapOverlayOp.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -139,8 +139,3 @@
 #endif
 #endif // ndef GEOS_OP_OVERLAY_SNAP_SNAPOVERLAYOP_H
- * $Log$
Modified: trunk/include/geos/operation/overlay/validate/FuzzyPointLocator.h
--- trunk/include/geos/operation/overlay/validate/FuzzyPointLocator.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/overlay/validate/FuzzyPointLocator.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -97,8 +97,3 @@
 #endif
 #endif // ndef GEOS_OP_OVERLAY_FUZZYPOINTLOCATOR_H
- * $Log$
Modified: trunk/include/geos/operation/overlay/validate/OffsetPointGenerator.h
--- trunk/include/geos/operation/overlay/validate/OffsetPointGenerator.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/overlay/validate/OffsetPointGenerator.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -87,8 +87,3 @@
 #endif
 #endif // ndef GEOS_OP_OVERLAY_OFFSETPOINTGENERATOR_H
- * $Log$
Modified: trunk/include/geos/operation/overlay/validate/OverlayResultValidator.h
--- trunk/include/geos/operation/overlay/validate/OverlayResultValidator.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/overlay/validate/OverlayResultValidator.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -131,8 +131,3 @@
 #endif
 #endif // ndef GEOS_OP_OVERLAY_OVERLAYRESULTVALIDATOR_H
- * $Log$
Modified: trunk/include/geos/operation/polygonize/EdgeRing.h
--- trunk/include/geos/operation/polygonize/EdgeRing.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/polygonize/EdgeRing.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -209,14 +209,3 @@
 #endif
 #endif // GEOS_OP_POLYGONIZE_EDGERING_H
- * $Log$
- * Revision 1.2  2006/05/02 14:32:49  strk
- * Added port info for polygonize/EdgeRing class, polygonize/EdgeRing.h header
- * not installed.
- * Revision 1.1  2006/03/22 11:19:06  strk
- * opPolygonize.h headers split.
Modified: trunk/include/geos/operation/polygonize/PolygonizeDirectedEdge.h
--- trunk/include/geos/operation/polygonize/PolygonizeDirectedEdge.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/polygonize/PolygonizeDirectedEdge.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -121,10 +121,3 @@
 } // namespace geos
 #endif // GEOS_OP_POLYGONIZE_POLYGONIZEDIRECTEDEDGE_H
- * $Log$
Modified: trunk/include/geos/operation/polygonize/PolygonizeEdge.h
--- trunk/include/geos/operation/polygonize/PolygonizeEdge.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/polygonize/PolygonizeEdge.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -59,10 +59,3 @@
 } // namespace geos
 #endif // GEOS_OP_POLYGONIZE_POLYGONIZEEDGE_H
- * $Log$
Modified: trunk/include/geos/operation/polygonize/PolygonizeGraph.h
--- trunk/include/geos/operation/polygonize/PolygonizeGraph.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/polygonize/PolygonizeGraph.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -226,10 +226,3 @@
 #endif
 #endif // GEOS_OP_POLYGONIZE_POLYGONIZEGRAPH_H
- * $Log$
Modified: trunk/include/geos/operation/polygonize/Polygonizer.h
--- trunk/include/geos/operation/polygonize/Polygonizer.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/polygonize/Polygonizer.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -224,13 +224,3 @@
 #endif
 #endif // GEOS_OP_POLYGONIZE_POLYGONIZER_H
- * $Log$
Modified: trunk/include/geos/operation/relate/EdgeEndBuilder.h
--- trunk/include/geos/operation/relate/EdgeEndBuilder.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/relate/EdgeEndBuilder.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -70,11 +70,3 @@
 } // namespace geos
 #endif // GEOS_OP_RELATE_EDGEENDBUILDER_H
- * $Log$
- * Revision 1.1  2006/03/21 13:11:29  strk
- * opRelate.h header split
Modified: trunk/include/geos/operation/relate/EdgeEndBundle.h
--- trunk/include/geos/operation/relate/EdgeEndBundle.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/relate/EdgeEndBundle.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -106,11 +106,3 @@
 } // namespace geos
 #endif // GEOS_OP_RELATE_EDGEENDBUNDLE_H
- * $Log$
Modified: trunk/include/geos/operation/relate/EdgeEndBundleStar.h
--- trunk/include/geos/operation/relate/EdgeEndBundleStar.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/relate/EdgeEndBundleStar.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -66,11 +66,3 @@
 } // namespace geos
 #endif // GEOS_OP_RELATE_EDGEENDBUNDLESTAR_H
- * $Log$
Modified: trunk/include/geos/operation/relate/RelateComputer.h
--- trunk/include/geos/operation/relate/RelateComputer.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/relate/RelateComputer.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -167,11 +167,3 @@
 #endif
 #endif // GEOS_OP_RELATE_RELATECOMPUTER_H
- * $Log$
Modified: trunk/include/geos/operation/relate/RelateNodeFactory.h
--- trunk/include/geos/operation/relate/RelateNodeFactory.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/relate/RelateNodeFactory.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -55,11 +55,3 @@
 } // namespace geos
 #endif // GEOS_OP_RELATE_RELATENODEFACTORY_H
- * $Log$
Modified: trunk/include/geos/operation/relate/RelateNodeGraph.h
--- trunk/include/geos/operation/relate/RelateNodeGraph.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/relate/RelateNodeGraph.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -96,11 +96,3 @@
 } // namespace geos
 #endif // GEOS_OP_RELATE_RELATENODEGRAPH_H
- * $Log$
Modified: trunk/include/geos/operation/relate/RelateOp.h
--- trunk/include/geos/operation/relate/RelateOp.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/relate/RelateOp.h	2012-05-29 08:42:24 UTC (rev 3650)
 } // namespace geos
 #endif // GEOS_OP_RELATE_RELATEOP_H
- * $Log$
Modified: trunk/include/geos/operation/union/CascadedPolygonUnion.h
--- trunk/include/geos/operation/union/CascadedPolygonUnion.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/union/CascadedPolygonUnion.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -241,9 +241,3 @@
 } // namespace geos
 #endif
- * $Log$
Modified: trunk/include/geos/operation/valid/ConnectedInteriorTester.h
--- trunk/include/geos/operation/valid/ConnectedInteriorTester.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/valid/ConnectedInteriorTester.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -146,17 +146,3 @@
 #endif
 #endif // GEOS_OP_CONNECTEDINTERIORTESTER_H
- * $Log$
- * Revision 1.3  2006/04/06 12:48:36  strk
- * Added private vector to keep track of allocated MaximalEdgeRings objects
- * Revision 1.2  2006/03/27 14:20:46  strk
- * Added paranoid assertion checking and a note in header about responsibility of return from buildMaximalEdgeRings()
- * Revision 1.1  2006/03/20 16:57:44  strk
- * spatialindex.h and opValid.h headers split
Modified: trunk/include/geos/operation/valid/ConsistentAreaTester.h
--- trunk/include/geos/operation/valid/ConsistentAreaTester.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/valid/ConsistentAreaTester.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -151,15 +151,3 @@
 } // namespace geos
 #endif // GEOS_OP_CONSISTENTAREATESTER_H
- * $Log$
- * Revision 1.2  2006/03/27 10:37:58  strk
- * Reduced heap allocations and probability of error by making LineIntersector
- * and RelateNodeGraph part of ConsistentAreaTester class .
Modified: trunk/include/geos/operation/valid/IsValidOp.h
--- trunk/include/geos/operation/valid/IsValidOp.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/valid/IsValidOp.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -276,14 +276,3 @@
 } // namespace geos
 #endif // GEOS_OP_ISVALIDOP_H
- * $Log$
- * Revision 1.2  2006/03/29 13:53:59  strk
- * EdgeRing equipped with Invariant testing function and lots of exceptional assertions. Removed useless heap allocations, and pointers usages.
Modified: trunk/include/geos/operation/valid/QuadtreeNestedRingTester.h
--- trunk/include/geos/operation/valid/QuadtreeNestedRingTester.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/valid/QuadtreeNestedRingTester.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -101,14 +101,3 @@
 #endif
 #endif // GEOS_OP_QUADTREENESTEDRINGTESTER_H
- * $Log$
- * Revision 1.2  2006/03/29 11:48:53  strk
- * Removed useless heap allocations in construction, enforced const correctness
Modified: trunk/include/geos/operation/valid/RepeatedPointTester.h
--- trunk/include/geos/operation/valid/RepeatedPointTester.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/valid/RepeatedPointTester.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -66,11 +66,3 @@
 } // namespace geos
 #endif // GEOS_OP_REPEATEDPOINTTESTER_H
- * $Log$
Modified: trunk/include/geos/operation/valid/SimpleNestedRingTester.h
--- trunk/include/geos/operation/valid/SimpleNestedRingTester.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/valid/SimpleNestedRingTester.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -93,11 +93,3 @@
 #endif
 #endif // GEOS_OP_SIMPLENESTEDRINGTESTER_H
- * $Log$
Modified: trunk/include/geos/operation/valid/SweeplineNestedRingTester.h
--- trunk/include/geos/operation/valid/SweeplineNestedRingTester.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/valid/SweeplineNestedRingTester.h	2012-05-29 08:42:24 UTC (rev 3650)
 #endif
 #endif // GEOS_OP_SWEEPLINENESTEDRINGTESTER_H
- * $Log$
- * Revision 1.2  2006/06/01 10:28:47  strk
Modified: trunk/include/geos/operation/valid/TopologyValidationError.h
--- trunk/include/geos/operation/valid/TopologyValidationError.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/operation/valid/TopologyValidationError.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -75,11 +75,3 @@
 } // namespace geos
 #endif // GEOS_OP_TOPOLOGYVALIDATIONERROR_H
- * $Log$
Modified: trunk/include/geos/planargraph/DirectedEdge.h
--- trunk/include/geos/planargraph/DirectedEdge.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/planargraph/DirectedEdge.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -235,14 +235,3 @@
 } // namespace geos
 #endif // GEOS_PLANARGRAPH_DIRECTEDEDGE_H
- * $Log$
- * Revision 1.2  2006/06/12 15:46:08  strk
- * provided a memory friendly version of toEdges() method.
- * Revision 1.1  2006/03/21 21:42:54  strk
- * planargraph.h header split, planargraph:: classes renamed to match JTS symbols
Modified: trunk/include/geos/planargraph/DirectedEdgeStar.h
--- trunk/include/geos/planargraph/DirectedEdgeStar.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/planargraph/DirectedEdgeStar.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -140,14 +140,3 @@
 #endif
 #endif // GEOS_PLANARGRAPH_DIRECTEDEDGESTAR_H
- * $Log$
- * unsigned int => size_t
Modified: trunk/include/geos/planargraph/Edge.h
--- trunk/include/geos/planargraph/Edge.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/planargraph/Edge.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -147,11 +147,3 @@
 #endif
 #endif // GEOS_PLANARGRAPH_EDGE_H
- * $Log$
Modified: trunk/include/geos/planargraph/GraphComponent.h
--- trunk/include/geos/planargraph/GraphComponent.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/planargraph/GraphComponent.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -160,11 +160,3 @@
 } // namespace geos
 #endif // GEOS_PLANARGRAPH_GRAPHCOMPONENT_H
- * $Log$
Modified: trunk/include/geos/planargraph/Node.h
--- trunk/include/geos/planargraph/Node.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/planargraph/Node.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -137,17 +137,3 @@
 } // namespace geos
 #endif // GEOS_PLANARGRAPH_NODE_H
- * $Log$
- * Revision 1.3  2006/06/12 16:57:26  strk
- * Added note about ownership of return from getEdgesBetween()
Modified: trunk/include/geos/planargraph/NodeMap.h
--- trunk/include/geos/planargraph/NodeMap.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/planargraph/NodeMap.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -125,11 +125,3 @@
 #endif
 #endif // GEOS_PLANARGRAPH_NODEMAP_H
- * $Log$
Modified: trunk/include/geos/planargraph/PlanarGraph.h
--- trunk/include/geos/planargraph/PlanarGraph.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/planargraph/PlanarGraph.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -252,14 +252,3 @@
 #endif
 #endif // GEOS_PLANARGRAPH_PLANARGRAPH_H
- * $Log$
Modified: trunk/include/geos/planargraph/Subgraph.h
--- trunk/include/geos/planargraph/Subgraph.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/planargraph/Subgraph.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -154,11 +154,3 @@
 #endif
 #endif // GEOS_PLANARGRAPH_SUBGRAPH_H
- * $Log$
Modified: trunk/include/geos/precision/CommonBits.h
--- trunk/include/geos/precision/CommonBits.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/precision/CommonBits.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -96,10 +96,3 @@
 } // namespace geos
 #endif // GEOS_PRECISION_COMMONBITS_H
- * $Log$
- * Revision 1.1  2006/03/23 09:17:19  strk
- * precision.h header split, minor optimizations
Modified: trunk/include/geos/precision/CommonBitsOp.h
--- trunk/include/geos/precision/CommonBitsOp.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/precision/CommonBitsOp.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -172,16 +172,3 @@
 #endif
 #endif // GEOS_PRECISION_COMMONBITSOP_H
- * $Log$
- * Revision 1.3  2006/04/13 23:23:52  strk
- * fixed bug in binary ops failing to consistently reduce operands.
- * Revision 1.2  2006/04/06 14:36:52  strk
- * Cleanup in geos::precision namespace (leaks plugged, auto_ptr use, ...)
Modified: trunk/include/geos/precision/CommonBitsRemover.h
--- trunk/include/geos/precision/CommonBitsRemover.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/precision/CommonBitsRemover.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -90,16 +90,3 @@
 } // namespace geos
 #endif // GEOS_PRECISION_COMMONBITSREMOVER_H
- * $Log$
- * Revision 1.3  2006/04/07 08:30:30  strk
- * made addCommonBits/removeCommonBits interface consistent, doxygen comments
Modified: trunk/include/geos/precision/EnhancedPrecisionOp.h
--- trunk/include/geos/precision/EnhancedPrecisionOp.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/precision/EnhancedPrecisionOp.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -109,13 +109,3 @@
 } // namespace geos
 #endif // GEOS_PRECISION_ENHANCEDPRECISIONOP_H
- * $Log$
Modified: trunk/include/geos/precision/SimpleGeometryPrecisionReducer.h
--- trunk/include/geos/precision/SimpleGeometryPrecisionReducer.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/precision/SimpleGeometryPrecisionReducer.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -87,13 +87,3 @@
 } // namespace geos
 #endif // GEOS_PRECISION_SIMPLEGEOMETRYPRECISIONREDUCER_H
- * $Log$
- * Revision 1.2  2006/04/03 13:56:55  strk
- * Made externally-owned PrecisionModel  const
Modified: trunk/include/geos/profiler.h
--- trunk/include/geos/profiler.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/profiler.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -188,33 +188,3 @@
 #endif
 #endif // ndef GEOS_PROFILER_H
- * $Log$
- * Revision 1.8  2006/06/12 11:29:23  strk
- * Revision 1.7  2006/03/06 19:40:47  strk
- * geos::util namespace. New GeometryCollection::iterator interface, many cleanups.
- * Revision 1.6  2006/03/03 10:46:21  strk
- * Removed 'using namespace' from headers, added missing headers in .cpp files, removed useless includes in headers (bug#46)
- * Revision 1.5  2005/02/01 14:18:04  strk
- * Made profiler start/stop inline
- * Revision 1.4  2004/12/03 16:21:07  frank
- * dont try for sys/time.h with MSVC
- * Revision 1.3  2004/11/30 16:44:16  strk
- * Added gettimeofday implementation for win32, curtesy of Wu Yongwei.
- * Revision 1.2  2004/11/04 08:49:13  strk
- * Unlinked new documentation.
- * Revision 1.1  2004/11/01 16:43:04  strk
- * Added Profiler code.
- * Temporarly patched a bug in DoubleBits (must check drawbacks).
- * Various cleanups and speedups.
Modified: trunk/include/geos/simplify/DouglasPeuckerLineSimplifier.h
--- trunk/include/geos/simplify/DouglasPeuckerLineSimplifier.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/simplify/DouglasPeuckerLineSimplifier.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -100,19 +100,3 @@
 #endif
 #endif // GEOS_SIMPLIFY_DOUBGLASPEUCKERLINESIMPLIFIER_H
- * $Log$
- * Revision 1.4  2006/07/10 10:16:06  strk
- * changed vector<bool> to vector<short int> (see bug#101)
- * Revision 1.3  2006/06/12 11:29:23  strk
- * Revision 1.2  2006/04/13 10:39:12  strk
- * Initial implementation of TaggedLinesSimplifier class
- * Revision 1.1  2006/04/03 10:16:11  strk
- * DouglasPeuckerLineSimplifier class port
Modified: trunk/include/geos/simplify/DouglasPeuckerSimplifier.h
--- trunk/include/geos/simplify/DouglasPeuckerSimplifier.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/simplify/DouglasPeuckerSimplifier.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -84,13 +84,3 @@
 } // namespace geos
 #endif // GEOS_SIMPLIFY_DOUBGLASPEUCKERSIMPLIFIER_H
- * $Log$
- * Revision 1.1  2006/04/11 16:04:34  strk
- * geos::simplify::DouglasPeukerSimplifier class + unit test
Modified: trunk/include/geos/simplify/LineSegmentIndex.h
--- trunk/include/geos/simplify/LineSegmentIndex.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/simplify/LineSegmentIndex.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -87,13 +87,3 @@
 #endif
 #endif // GEOS_SIMPLIFY_LINESEGMENTINDEX_H
- * $Log$
- * Revision 1.2  2006/04/13 09:28:09  mloskot
- * Removed definition of copy ctor and assignment operator for LineSegmentString class.
- * Revision 1.1  2006/04/12 15:20:37  strk
- * LineSegmentIndex class
Modified: trunk/include/geos/simplify/TaggedLineSegment.h
--- trunk/include/geos/simplify/TaggedLineSegment.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/simplify/TaggedLineSegment.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -84,14 +84,3 @@
 } // namespace geos
 #endif // GEOS_SIMPLIFY_TAGGEDLINESEGMENT_H
- * $Log$
- * Revision 1.2  2006/04/12 17:19:57  strk
- * Ported TaggedLineStringSimplifier class, made LineSegment class
- * polymorphic to fix derivation of TaggedLineSegment
- * Revision 1.1  2006/04/12 14:22:12  strk
- * Initial implementation of TaggedLineSegment and TaggedLineString classes
Modified: trunk/include/geos/simplify/TaggedLineString.h
--- trunk/include/geos/simplify/TaggedLineString.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/simplify/TaggedLineString.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -129,31 +129,3 @@
 #endif
 #endif // GEOS_SIMPLIFY_TAGGEDLINESTRING_H
- * $Log$
- * Revision 1.7  2006/06/12 11:29:23  strk
- * Revision 1.6  2006/04/13 21:52:34  strk
- * Many debugging lines and assertions added. Fixed bug in TaggedLineString class.
- * Revision 1.5  2006/04/13 16:04:10  strk
- * Made TopologyPreservingSimplifier implementation successfully build
- * Revision 1.4  2006/04/13 09:21:45  mloskot
- * Removed definition of copy ctor and assignment operator for TaggedLineString class.
- * According to following rule: Declaring, but not defining, private copy operations has
- * the effect of "turning off" copying for the class.
- * Revision 1.3  2006/04/12 17:19:57  strk
- * Revision 1.2  2006/04/12 15:20:37  strk
Modified: trunk/include/geos/simplify/TaggedLinesSimplifier.h
--- trunk/include/geos/simplify/TaggedLinesSimplifier.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/simplify/TaggedLinesSimplifier.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -120,25 +120,3 @@
 #endif
 #endif // GEOS_SIMPLIFY_TAGGEDLINESSIMPLIFIER_H
- * $Log$
- * Revision 1.4  2006/05/24 15:32:11  strk
- * * source/headers/geos/simplify/TaggedLinesSimplifier.h: added LineSegmentIndex.h include so that every use of the templated simplify() function get all the required definitions.
- * Revision 1.3  2006/05/24 11:41:23  strk
- *         * source/headers/geos/simplify/TaggedLinesSimplifier.h,
- *         source/simplify/TaggedLinesSimplifier.cpp,
- *         source/simplify/TopologyPreservingSimplifier.cpp:
- *         fixed bug in TopologyPreservingSimplifier failing to
- *         detect intersections, refactored TaggedLinesSimplifier
- *         class to more closely match JTS and use templated
- *         functions.
- * Revision 1.2  2006/04/13 14:25:17  strk
- * TopologyPreservingSimplifier initial port
- * Revision 1.1  2006/04/13 10:39:12  strk
Modified: trunk/include/geos/simplify/TopologyPreservingSimplifier.h
--- trunk/include/geos/simplify/TopologyPreservingSimplifier.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/simplify/TopologyPreservingSimplifier.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -96,13 +96,3 @@
 #endif
 #endif // GEOS_SIMPLIFY_TOPOLOGYPRESERVINGSIMPLIFIER_H
- * $Log$
- * Revision 1.3  2006/04/13 16:04:10  strk
Modified: trunk/include/geos/spatialIndex.h
--- trunk/include/geos/spatialIndex.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/spatialIndex.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -28,11 +28,3 @@
 #include <geos/index/ItemVisitor.h>
 #endif // GEOS_INDEX_H
- * $Log$
- * Revision 1.9  2006/03/20 16:57:43  strk
Modified: trunk/include/geos/unload.h
--- trunk/include/geos/unload.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/unload.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -10,22 +10,6 @@
  * by the Free Software Foundation.
  * See the COPYING file for more information.
- * $Log$
- * Revision 1.3  2006/03/06 19:43:20  strk
- * Fixed Unload class definition namespace (geos::io)
- * Revision 1.2  2006/03/01 10:39:58  strk
- * ctor and dtor made private and inlined
- * Revision 1.1  2004/07/02 13:20:42  strk
- * Header files moved under geos/ dir.
- * Revision 1.2  2003/11/07 01:23:42  pramsey
- * Add standard CVS headers licence notices and copyrights to all cpp and h
- * files.
 #include <geos/export.h>
Modified: trunk/include/geos/util/Assert.h
--- trunk/include/geos/util/Assert.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/util/Assert.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -60,13 +60,3 @@
 #endif // GEOS_UTIL_ASSERT_H
- * $Log$
- * Revision 1.2  2006/03/14 17:46:26  strk
- * Removed unrequired include
- * Revision 1.1  2006/03/09 16:46:49  strk
Modified: trunk/include/geos/util/AssertionFailedException.h
--- trunk/include/geos/util/AssertionFailedException.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/util/AssertionFailedException.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -49,10 +49,3 @@
 #endif // GEOS_UTIL_ASSERTIONFAILEDEXCEPTION_H
- * $Log$
Modified: trunk/include/geos/util/CoordinateArrayFilter.h
--- trunk/include/geos/util/CoordinateArrayFilter.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/util/CoordinateArrayFilter.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -60,13 +60,3 @@
 } // namespace geos
 #endif // GEOS_UTIL_COORDINATEARRAYFILTER_H
- * $Log$
- * Revision 1.2  2006/06/19 23:33:03  strk
- * Don't *require* CoordinateFilters to define both read-only and read-write methods.
Modified: trunk/include/geos/util/GEOSException.h
--- trunk/include/geos/util/GEOSException.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/util/GEOSException.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -74,20 +74,3 @@
 #endif
 #endif // GEOS_UTIL_GEOSEXCEPTION_H
- * $Log$
- * Revision 1.4  2006/05/22 15:08:01  strk
- * Print colon after exception name (as it has always been)
- * Revision 1.3  2006/04/05 09:34:20  strk
- * GEOSException derived from std::exception again, hopefully the correct way now
- * Revision 1.2  2006/04/04 08:16:46  strk
Modified: trunk/include/geos/util/GeometricShapeFactory.h
--- trunk/include/geos/util/GeometricShapeFactory.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/util/GeometricShapeFactory.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -198,10 +198,3 @@
 #endif
 #endif // GEOS_UTIL_GEOMETRICSHAPEFACTORY_H
- * $Log$
Modified: trunk/include/geos/util/IllegalArgumentException.h
--- trunk/include/geos/util/IllegalArgumentException.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/util/IllegalArgumentException.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -51,14 +51,3 @@
 #endif // GEOS_UTIL_ILLEGALARGUMENTEXCEPTION_H
- * $Log$
Modified: trunk/include/geos/util/TopologyException.h
--- trunk/include/geos/util/TopologyException.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/util/TopologyException.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -61,16 +61,3 @@
 #endif // GEOS_UTIL_TOPOLOGYEXCEPTION_H
- * $Log$
- * Revision 1.3  2006/03/23 15:10:29  strk
- * Dropped by-pointer TopologyException constructor, various small cleanups
- * Revision 1.2  2006/03/22 11:19:06  strk
Modified: trunk/include/geos/util/UniqueCoordinateArrayFilter.h
--- trunk/include/geos/util/UniqueCoordinateArrayFilter.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/util/UniqueCoordinateArrayFilter.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -89,19 +89,3 @@
 #endif
 #endif // GEOS_UTIL_UNIQUECOORDINATEARRAYFILTER_H
- * $Log$
- * Revision 1.4  2006/06/19 23:33:03  strk
- * Revision 1.3  2006/06/12 10:10:39  strk
- * Fixed getGeometryN() to take size_t rather then int, changed unsigned int parameters to size_t.
- * Revision 1.2  2006/04/10 09:21:23  mloskot
- * Added new test for UniqueCoordinateArrayFilter class. Small fixes related to signed/unsigned comparison.
Modified: trunk/include/geos/util/UnsupportedOperationException.h
--- trunk/include/geos/util/UnsupportedOperationException.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/util/UnsupportedOperationException.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -53,10 +53,3 @@
 #endif // GEOS_UTIL_UNSUPPORTEDOPERATIONEXCEPTION_H
- * $Log$
Modified: trunk/include/geos/util/math.h
--- trunk/include/geos/util/math.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/include/geos/util/math.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -39,19 +39,3 @@
 }} // namespace geos::util
 #endif // GEOS_UTIL_MATH_H
- * $Log$
- * Revision 1.4  2006/05/04 14:05:31  strk
- * * source/headers/geos/util/math.h: provided an util::round() method being an inline proxy to call appropriate default rounding function for the whole GEOS codebase. Currently pointing at util::java_math_round() being the last being used.
- * Revision 1.3  2006/04/07 12:37:53  mloskot
- * Added java_math_round() function for Asymmetric Arithmetic Rounding. Small fixes in Unit Tests.
- * Revision 1.2  2006/04/06 21:30:36  strk
- * Added missing rint_vc() forward declaration
Modified: trunk/src/algorithm/CentroidArea.cpp
--- trunk/src/algorithm/CentroidArea.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/CentroidArea.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -148,22 +148,3 @@
 } // namespace geos.algorithm
 } //namespace geos
- * $Log$
- * Revision 1.24  2006/06/08 17:58:57  strk
- * Polygon::getNumInteriorRing() return size_t, Polygon::interiorRingN() takes size_t.
- * Revision 1.23  2006/04/07 09:54:28  strk
- * Geometry::getNumGeometries() changed to return 'unsigned int'
- * rather then 'int'
- * Revision 1.22  2006/03/21 11:12:23  strk
- * Cleanups: headers inclusion and Log section
- * Revision 1.21  2006/03/09 16:46:45  strk
Modified: trunk/src/algorithm/CentroidLine.cpp
--- trunk/src/algorithm/CentroidLine.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/CentroidLine.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -85,14 +85,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.16  2006/03/21 11:12:23  strk
- * Revision 1.15  2006/03/09 16:46:45  strk
Modified: trunk/src/algorithm/CentroidPoint.cpp
--- trunk/src/algorithm/CentroidPoint.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/CentroidPoint.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -68,16 +68,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.12  2006/04/07 09:54:29  strk
- * Revision 1.11  2006/03/21 11:12:23  strk
- * Revision 1.10  2006/03/09 16:46:45  strk
Modified: trunk/src/algorithm/ConvexHull.cpp
--- trunk/src/algorithm/ConvexHull.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/ConvexHull.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -513,63 +513,6 @@
-// * @param  vertices  the vertices of a linear ring, which may or may not be
-// *      flattened (i.e. vertices collinear)
-// * @return a newly allocated CoordinateSequence
-//CoordinateSequence*
-//ConvexHull::cleanRing(const CoordinateSequence *original)
-//	Assert::equals(original->getAt(0),original->getAt(original->getSize()-1));
-//	size_t npts=original->getSize();
-//	vector<Coordinate> *newPts=new vector<Coordinate>;
-//	newPts->reserve(npts);
-//	const Coordinate *previousDistinctCoordinate=NULL;
-//	for(size_t i=0; i<npts-1; ++i)
-//		const Coordinate &currentCoordinate=original->getAt(i);
-//		const Coordinate &nextCoordinate=original->getAt(i+1);
-//		// skip repeated points (shouldn't this have been already done elsewhere?)
-//		if (currentCoordinate==nextCoordinate) continue;
-//		// skip collinear point
-//		if (previousDistinctCoordinate!=NULL &&
-//			isBetween(*previousDistinctCoordinate, currentCoordinate, nextCoordinate))
-//			continue;
-//		newPts->push_back(currentCoordinate);
-//		previousDistinctCoordinate=¤tCoordinate;
-//	newPts->push_back(original->getAt(npts-1));
-//	CoordinateSequence *cleanedRing=geomFactory->getCoordinateSequenceFactory()->create(newPts);
-//	return cleanedRing;
 } // namespace geos
- * $Log$
- * Revision 1.22  2006/06/12 10:49:43  strk
- * Revision 1.21  2006/03/24 09:52:41  strk
- * Revision 1.20  2006/03/21 11:12:23  strk
- * Revision 1.19  2006/03/09 16:46:45  strk
Modified: trunk/src/algorithm/InteriorPointArea.cpp
--- trunk/src/algorithm/InteriorPointArea.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/InteriorPointArea.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -154,17 +154,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.22  2006/04/07 09:54:29  strk
- * Revision 1.21  2006/03/21 11:12:23  strk
- * Revision 1.20  2006/03/09 16:46:45  strk
Modified: trunk/src/algorithm/InteriorPointLine.cpp
--- trunk/src/algorithm/InteriorPointLine.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/InteriorPointLine.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -152,12 +152,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.18  2006/03/21 11:12:23  strk
- * Revision 1.17  2006/03/09 16:46:45  strk
Modified: trunk/src/algorithm/InteriorPointPoint.cpp
--- trunk/src/algorithm/InteriorPointPoint.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/InteriorPointPoint.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -85,12 +85,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.14  2006/03/21 11:12:23  strk
- * Revision 1.13  2006/03/09 16:46:45  strk
Modified: trunk/src/algorithm/LineIntersector.cpp
--- trunk/src/algorithm/LineIntersector.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/LineIntersector.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -855,28 +855,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.42  2006/04/12 11:57:11  strk
- * Fixed debugging line
- * Revision 1.41  2006/04/07 09:12:57  strk
- * kept isInSegmentEnvelopes() check even when not debugging
- * Revision 1.40  2006/04/06 21:31:40  strk
- * Const correctness for debugging function
- * Revision 1.39  2006/04/04 12:39:08  strk
- * Changed NotRepresentableCoordinate exception handler to throw
- * a TopologyException. This allows further handling.
- * Revision 1.38  2006/03/21 11:12:23  strk
- * Revision 1.37  2006/03/16 10:38:14  strk
- * Bug #63 - Remove unreferenced local variable warning
- * Revision 1.36  2006/03/09 16:46:45  strk
Modified: trunk/src/algorithm/MCPointInRing.cpp
--- trunk/src/algorithm/MCPointInRing.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/MCPointInRing.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -178,21 +178,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.27  2006/03/29 11:52:00  strk
- * const correctness, useless heap allocations removal
- * Revision 1.26  2006/03/22 18:12:31  strk
- * indexChain.h header split.
- * Revision 1.25  2006/03/22 16:01:33  strk
- * indexBintree.h header split, classes renamed to match JTS
- * Revision 1.24  2006/03/21 11:12:23  strk
- * Revision 1.23  2006/03/09 16:46:45  strk
Modified: trunk/src/algorithm/MinimumDiameter.cpp
--- trunk/src/algorithm/MinimumDiameter.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/MinimumDiameter.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -278,12 +278,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.15  2006/03/21 11:12:23  strk
- * Revision 1.14  2006/03/09 16:46:45  strk
Modified: trunk/src/algorithm/NotRepresentableException.cpp
--- trunk/src/algorithm/NotRepresentableException.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/NotRepresentableException.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -38,16 +38,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.17  2006/04/04 08:16:46  strk
Modified: trunk/src/algorithm/PointLocator.cpp
--- trunk/src/algorithm/PointLocator.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/PointLocator.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -166,19 +166,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.31  2006/06/12 10:49:43  strk
- * Revision 1.30  2006/04/07 09:54:29  strk
- * Revision 1.29  2006/03/21 11:12:23  strk
- * Revision 1.28  2006/03/09 16:46:46  strk
Modified: trunk/src/algorithm/RayCrossingCounter.cpp
--- trunk/src/algorithm/RayCrossingCounter.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/RayCrossingCounter.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -177,8 +177,3 @@
 } // geos::algorithm
 } // geos
- * $Log$
Modified: trunk/src/algorithm/SIRtreePointInRing.cpp
--- trunk/src/algorithm/SIRtreePointInRing.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/SIRtreePointInRing.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -116,13 +116,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.17  2006/03/21 11:12:23  strk
- * Revision 1.16  2006/03/09 16:46:46  strk
Modified: trunk/src/algorithm/SimplePointInRing.cpp
--- trunk/src/algorithm/SimplePointInRing.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/SimplePointInRing.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -40,16 +40,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.17  2006/03/09 16:46:46  strk
- * Revision 1.16  2006/02/19 19:46:49  strk
- * Packages <-> namespaces mapping for most GEOS internal code (uncomplete, but working). Dir-level libs for index/ subdirs.
Modified: trunk/src/algorithm/locate/IndexedPointInAreaLocator.cpp
--- trunk/src/algorithm/locate/IndexedPointInAreaLocator.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/locate/IndexedPointInAreaLocator.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -145,8 +145,3 @@
 } // geos::algorithm::locate
 } // geos
- * $Log$
Modified: trunk/src/algorithm/locate/PointOnGeometryLocator.cpp
--- trunk/src/algorithm/locate/PointOnGeometryLocator.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/locate/PointOnGeometryLocator.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -22,8 +22,3 @@
 } // geos
- * $Log$
Modified: trunk/src/algorithm/locate/SimplePointInAreaLocator.cpp
--- trunk/src/algorithm/locate/SimplePointInAreaLocator.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/algorithm/locate/SimplePointInAreaLocator.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -94,17 +94,3 @@
 } // namespace geos.algorithm.locate
 } // namespace geos
- * $Log$
- * Revision 1.22  2006/06/12 11:29:23  strk
- * Revision 1.20  2006/03/09 16:46:46  strk
Modified: trunk/src/geom/CoordinateArraySequence.cpp
--- trunk/src/geom/CoordinateArraySequence.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/CoordinateArraySequence.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -287,26 +287,3 @@
 } // namespace geos::geom
 } //namespace geos
- * $Log$
- * Revision 1.10  2006/06/12 15:07:47  strk
- * explicitly invoked CoordinateSequence (copy) ctor - suggested by GCC warning.
- * Revision 1.9  2006/06/12 10:10:39  strk
- * Revision 1.8  2006/05/03 08:58:34  strk
- * added new non-static CoordinateSequence::removeRepeatedPoints() mutator.
- * Revision 1.7  2006/03/27 09:00:50  strk
- * Bug #79 - Small fix in CoordinateArraySequence::toString()
- * Revision 1.6  2006/03/22 16:58:34  strk
- * Removed (almost) all inclusions of geom.h.
- * Removed obsoleted .cpp files.
- * Fixed a bug in WKTReader not using the provided CoordinateSequence
- * implementation, optimized out some memory allocations.
Modified: trunk/src/geom/CoordinateSequence.cpp
--- trunk/src/geom/CoordinateSequence.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/CoordinateSequence.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -295,20 +295,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.21  2006/06/12 16:51:23  strk
- * Added equality and inequality operators and tests
- * Revision 1.20  2006/06/12 16:36:22  strk
- * indentation, notes about things to be fixed.
- * Revision 1.19  2006/06/12 10:10:39  strk
- * Revision 1.18  2006/05/03 19:47:27  strk
- * added operator<< for CoordinateSequence
Modified: trunk/src/geom/CoordinateSequenceFactory.cpp
--- trunk/src/geom/CoordinateSequenceFactory.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/CoordinateSequenceFactory.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -26,11 +26,3 @@
- * $Log$
- * Revision 1.4  2006/04/03 10:56:58  strk
- * Removed implementation files build spec for fully-inlined classes
Modified: trunk/src/geom/Dimension.cpp
--- trunk/src/geom/Dimension.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/Dimension.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -84,38 +84,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.15  2006/03/22 16:58:34  strk
- * Revision 1.14  2006/03/09 16:46:47  strk
- * Revision 1.13  2006/03/06 19:40:46  strk
- * Revision 1.12  2006/03/03 10:46:21  strk
- * Revision 1.11  2006/02/09 15:52:47  strk
- * GEOSException derived from std::exception; always thrown and cought by const ref.
- * Revision 1.10  2005/01/28 09:47:51  strk
- * Replaced sprintf uses with ostringstream.
- * Revision 1.9  2004/07/02 13:28:26  strk
- * Fixed all #include lines to reflect headers layout change.
- * Added client application build tips in README.
- * Revision 1.8  2003/11/07 01:23:42  pramsey
- * files.
Modified: trunk/src/geom/Envelope.cpp
--- trunk/src/geom/Envelope.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/Envelope.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -482,96 +482,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.30  2006/06/12 10:49:43  strk
- * Revision 1.29  2006/04/05 14:04:25  strk
- * Fixed copy ctor to support "Null" Envelope copies.
- * Drop init(Envelope&) method.
- * Port info and various cleanups.
- * Revision 1.28  2006/03/24 09:52:41  strk
- * Revision 1.27  2006/03/15 18:44:52  strk
- * Bug #60 - Missing <cmath> header in some files
- * Revision 1.26  2006/03/09 16:46:47  strk
- * Revision 1.25  2006/03/03 10:46:21  strk
- * Revision 1.24  2006/02/23 23:17:52  strk
- * - Coordinate::nullCoordinate made private
- * - Simplified Coordinate inline definitions
- * - LMGeometryComponentFilter definition moved to LineMerger.cpp file
- * - Misc cleanups
- * Revision 1.23  2006/02/08 17:18:28  strk
- * - New WKTWriter::toLineString and ::toPoint convenience methods
- * - New IsValidOp::setSelfTouchingRingFormingHoleValid method
- * - New Envelope::centre()
- * - New Envelope::intersection(Envelope)
- * - New Envelope::expandBy(distance, [ydistance])
- * - New LineString::reverse()
- * - New MultiLineString::reverse()
- * - New Geometry::buffer(distance, quadSeg, endCapStyle)
- * - Obsoleted toInternalGeometry/fromInternalGeometry
- * - More const-correctness in Buffer "package"
- * Revision 1.22  2006/01/15 21:22:02  strk
- * Added Envelope constructor by string (accepting what's returned by ::toString)
- * Revision 1.21  2005/11/08 10:03:28  strk
- * Set library version to 2.2.0.
- * Cleaned up Doxygen warnings.
- * Inlined more Envelope methods.
- * Dropped deprecated Envelope::overlaps methods.
- * Revision 1.20  2005/02/15 17:15:13  strk
- * Inlined most Envelope methods, reserved() memory for some vectors when
- * the usage was known a priori.
- * Revision 1.19  2005/02/01 16:06:53  strk
- * Small optimizations.
- * Revision 1.18  2005/01/28 09:47:51  strk
- * Revision 1.17  2004/11/08 10:58:08  strk
- * Optimized the ::intersect function to avoid nested function calls.
- * Revision 1.16  2004/11/01 16:43:04  strk
- * Revision 1.15  2004/09/16 09:48:06  strk
- * Added Envelope::equals
- * Revision 1.14  2004/07/21 09:55:24  strk
- * CoordinateSequence::atLeastNCoordinatesOrNothing definition fix.
- * Documentation fixes.
- * Revision 1.13  2004/07/19 13:19:30  strk
- * Revision 1.12  2004/07/02 13:28:26  strk
- * Revision 1.11  2004/03/18 10:42:44  ybychkov
- * "IO" and "Util" upgraded to JTS 1.4
- * "Geometry" partially upgraded.
- * Revision 1.10  2003/11/07 01:23:42  pramsey
- * files.
Modified: trunk/src/geom/GeometryCollection.cpp
--- trunk/src/geom/GeometryCollection.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/GeometryCollection.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -360,139 +360,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.60  2006/06/12 10:10:39  strk
- * Revision 1.59  2006/05/04 15:49:38  strk
- * updated all Geometry::getDimension() methods to return Dimension::DimensionType (closes bug#93)
- * Revision 1.58  2006/04/28 10:55:39  strk
- * Geometry constructors made protected, to ensure all constructions use GeometryFactory,
- * which has been made friend of all Geometry derivates. getNumPoints() changed to return
- * size_t.
- * Revision 1.57  2006/04/10 18:15:09  strk
- * Changed Geometry::envelope member to be of type auto_ptr<Envelope>.
- * Changed computeEnvelopeInternal() signater to return auto_ptr<Envelope>
- * Revision 1.56  2006/04/07 09:54:30  strk
- * Revision 1.55  2006/03/24 09:52:41  strk
- * USE_INLINE => GEOS_INLINE
- * Revision 1.54  2006/03/09 16:46:47  strk
- * geos::geom namespace definition, first pass at headers split
- * Revision 1.53  2006/03/06 19:40:46  strk
- * Revision 1.52  2006/03/03 10:46:21  strk
- * Revision 1.51  2006/02/09 15:52:47  strk
- * Revision 1.50  2006/01/31 19:07:33  strk
- * - Renamed DefaultCoordinateSequence to CoordinateArraySequence.
- * - Moved GetNumGeometries() and GetGeometryN() interfaces
- *   from GeometryCollection to Geometry class.
- * - Added getAt(int pos, Coordinate &to) funtion to CoordinateSequence class.
- * - Reworked automake scripts to produce a static lib for each subdir and
- *   then link all subsystem's libs togheter
- * - Moved C-API in it's own top-level dir capi/
- * - Moved source/bigtest and source/test to tests/bigtest and test/xmltester
- * - Fixed PointLocator handling of LinearRings
- * - Changed CoordinateArrayFilter to reduce memory copies
- * - Changed UniqueCoordinateArrayFilter to reduce memory copies
- * - Added CGAlgorithms::isPointInRing() version working with
- *   Coordinate::ConstVect type (faster!)
- * - Ported JTS-1.7 version of ConvexHull with big attention to
- *   memory usage optimizations.
- * - Improved XMLTester output and user interface
- * - geos::geom::util namespace used for geom/util stuff
- * - Improved memory use in geos::geom::util::PolygonExtractor
- * - New ShortCircuitedGeometryVisitor class
- * - New operation/predicate package
- * Revision 1.49  2005/12/08 14:14:07  strk
- * ElevationMatrixFilter used for both elevation and Matrix fill,
- * thus removing CoordinateSequence copy in ElevetaionMatrix::add(Geometry *).
- * Changed CoordinateFilter::filter_rw to be a const method: updated
- * all apply_rw() methods to take a const CoordinateFilter.
- * Revision 1.48  2005/11/25 09:57:51  strk
- * Fixed bug in getCoordinates() [ introduced by previous commit ]
- * Revision 1.47  2005/11/24 23:09:15  strk
- * CoordinateSequence indexes switched from int to the more
- * the correct unsigned int. Optimizations here and there
- * to avoid calling getSize() in loops.
- * Update of all callers is not complete yet.
- * Revision 1.46  2005/11/21 16:03:20  strk
- * Coordinate interface change:
- *         Removed setCoordinate call, use assignment operator
- *         instead. Provided a compile-time switch to
- *         make copy ctor and assignment operators non-inline
- *         to allow for more accurate profiling.
- * Coordinate copies removal:
- *         NodeFactory::createNode() takes now a Coordinate reference
- *         rather then real value. This brings coordinate copies
- *         in the testLeaksBig.xml test from 654818 to 645991
- *         (tested in 2.1 branch). In the head branch Coordinate
- *         copies are 222198.
- *         Removed useless coordinate copies in ConvexHull
- *         operations
- * STL containers heap allocations reduction:
- *         Converted many containers element from
- *         pointers to real objects.
- *         Made some use of .reserve() or size
- *         initialization when final container size is known
- *         in advance.
- * Stateless classes allocations reduction:
- *         Provided ::instance() function for
- *         NodeFactories, to avoid allocating
- *         more then one (they are all
- *         stateless).
- * HCoordinate improvements:
- *         Changed HCoordinate constructor by HCoordinates
- *         take reference rather then real objects.
- *         Changed HCoordinate::intersection to avoid
- *         a new allocation but rather return into a provided
- *         storage. LineIntersector changed to reflect
- *         the above change.
- * Revision 1.45  2005/06/23 14:22:32  strk
- * Inlined and added missing ::clone() for Geometry subclasses
- * Revision 1.44  2004/12/08 14:32:54  strk
- * cleanups
- * Revision 1.43  2004/07/27 16:35:46  strk
- * Geometry::getEnvelopeInternal() changed to return a const Envelope *.
- * This should reduce object copies as once computed the envelope of a
- * geometry remains the same.
- * Revision 1.42  2004/07/22 08:45:50  strk
- * Documentation updates, memory leaks fixed.
- * Revision 1.41  2004/07/22 07:04:49  strk
- * Documented missing geometry functions.
- * Revision 1.40  2004/07/08 19:34:49  strk
- * Mirrored JTS interface of CoordinateSequence, factory and
- * default implementations.
- * Added CoordinateArraySequenceFactory::instance() function.
Modified: trunk/src/geom/GeometryComponentFilter.cpp
--- trunk/src/geom/GeometryComponentFilter.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/GeometryComponentFilter.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -37,17 +37,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.12  2006/04/13 14:25:17  strk
- * Revision 1.11  2006/03/22 16:58:34  strk
Modified: trunk/src/geom/GeometryFactory.cpp
--- trunk/src/geom/GeometryFactory.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/GeometryFactory.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -731,73 +731,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.71  2006/07/08 00:33:54  strk
- *         * configure.in: incremented CAPI minor version, to avoid                        falling behind any future version from the 2.2. branch.
- *         * source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
- *         source/geomgraph/EdgeRing.cpp,
- *         source/headers/geos/geom/Geometry.h,
- *         source/headers/geos/geom/GeometryFactory.h,
- *         source/headers/geos/geom/GeometryFactory.inl,
- *         source/headers/geos/geomgraph/EdgeRing.h:
- *         updated doxygen comments (sync with JTS head).
- *         * source/headers/geos/platform.h.in: include <inttypes.h>
- *         rather then <stdint.h>
- * Revision 1.70  2006/06/19 21:17:23  strk
- * port info and doxygen dox.
- * Revision 1.69  2006/06/12 10:10:39  strk
- * Revision 1.68  2006/04/28 11:56:52  strk
- * * source/geom/GeometryFactory.cpp, source/headers/geos/geom/GeometryFactory.h: added LineString copy constructor.
- * * source/geom/Polygon.cpp: fixed getBoundary method to always return a geometry composed by LineStrings (not LinearRings)
- * Revision 1.67  2006/04/11 11:16:25  strk
- * Added LineString and LinearRing constructors by auto_ptr
- * Revision 1.66  2006/04/10 13:09:47  strk
- * Added GeometryFactory::defaultInstance()
- * Made Geometry::INTERNAL_GEOMETRY_FACTORY an alias for it
- * removed last deletion from Unload::Release class
- * Revision 1.65  2006/04/06 12:33:04  strk
- * More debugging lines
- * Revision 1.64  2006/03/31 17:51:24  strk
- * A few assertion checking, comments cleanup, use of initialization lists
- * in constructors, handled NULL parameters.
- * Revision 1.63  2006/03/24 09:52:41  strk
- * Revision 1.62  2006/03/20 10:11:50  strk
- * Bug #67 - Debugging helpers in GeometryFactory class
- * Revision 1.61  2006/03/09 16:46:47  strk
- * Revision 1.60  2006/03/06 19:40:46  strk
- * Revision 1.59  2006/03/03 10:46:21  strk
- * Revision 1.58  2006/03/01 18:37:08  strk
- * Geometry::createPointFromInternalCoord dropped (it's a duplication of GeometryFactory::createPointFromInternalCoord).
- * Fixed bugs in InteriorPoint* and getCentroid() inserted by previous commits.
- * Revision 1.57  2006/02/23 23:17:52  strk
- * - Misc cleanups
- * Revision 1.56  2006/02/09 15:52:47  strk
Modified: trunk/src/geom/GeometryList.cpp
--- trunk/src/geom/GeometryList.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/GeometryList.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -78,12 +78,3 @@
 } // namespace geos.geom
 } // namespace geos
- * $Log$
- * Revision 1.1  2006/04/11 09:41:26  strk
- * Initial implementation of a GeometryList class, to be used to manage
- * lists of Geometry pointers.
Modified: trunk/src/geom/IntersectionMatrix.cpp
--- trunk/src/geom/IntersectionMatrix.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/IntersectionMatrix.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -435,85 +435,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.26  2006/06/12 10:10:39  strk
- * Revision 1.25  2006/05/17 17:41:10  strk
- * Added output operator + test
- * Revision 1.24  2006/05/17 17:24:17  strk
- * Added port info, fixed isCoveredBy() comment.
- * Revision 1.23  2006/05/17 17:20:10  strk
- * added isCovers() and isCoveredBy() public methods to IntersectionMatrix and associated tests.
- * Revision 1.22  2006/04/09 01:41:48  mloskot
- * Added comments for doxygen based on JTS docs. Added row/col dimension consts. Added asserts in functions to check if given row/col is in range.
- * Revision 1.21  2006/03/22 16:58:34  strk
- * Revision 1.20  2006/03/13 21:54:56  strk
- * Streamlined headers inclusion.
- * Revision 1.19  2006/03/09 16:46:47  strk
- * Revision 1.18  2006/03/06 19:40:46  strk
- * Revision 1.17  2006/03/03 10:46:21  strk
- * Revision 1.16  2006/03/02 11:00:26  strk
- * Changed IntersectionMatrix funx taking strings to take const string& instead
- * Revision 1.15  2006/02/09 15:52:47  strk
- * Revision 1.14  2006/01/31 19:07:33  strk
- * Revision 1.13  2005/11/09 08:57:07  strk
- * IntersectionMatrix made a concrete and final type.
- * Cleanups in class definition.
- * Revision 1.12  2005/01/28 09:47:51  strk
- * Revision 1.11  2004/07/02 13:28:26  strk
- * files.
Modified: trunk/src/geom/LineSegment.cpp
--- trunk/src/geom/LineSegment.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/LineSegment.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -315,165 +315,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.36  2006/04/10 12:05:35  strk
- * Added inline-replicator implementation files to make sure
- * functions in .inl files are still available out-of-line.
- * A side effect is this should fix MingW build.
- * Revision 1.35  2006/03/24 09:52:41  strk
- * Revision 1.34  2006/03/22 18:12:31  strk
- * Revision 1.33  2006/03/22 16:58:34  strk
- * Revision 1.32  2006/03/16 13:28:21  strk
- * obsoleted getCoordinate(), replaced by operator[]
- * Revision 1.31  2006/03/15 18:44:52  strk
- * Revision 1.30  2006/03/13 21:54:56  strk
- * Revision 1.29  2006/03/09 16:46:47  strk
- * Revision 1.28  2006/03/06 19:40:46  strk
- * Revision 1.27  2006/03/03 10:46:21  strk
- * Revision 1.26  2006/03/01 17:16:38  strk
- * LineSegment class made final and optionally (compile-time) inlined.
- * Reduced heap allocations in Centroid{Area,Line,Point} and InteriorPoint{Area,Line,Point}.
- * Revision 1.25  2006/02/23 23:17:52  strk
- * - Misc cleanups
- * Revision 1.24  2006/02/19 19:46:49  strk
- * Revision 1.23  2006/01/31 19:07:33  strk
- * Revision 1.22  2005/11/21 16:03:20  strk
- *         operations
- *         in advance.
- *         stateless).
- * Revision 1.21  2005/06/24 11:09:42  strk
- * Dropped RobustLineIntersector, made LineIntersector a concrete class.
- * Added LineIntersector::hasIntersection(Coordinate&,Coordinate&,Coordinate&)
- * to avoid computing intersection point (Z) when it's not necessary.
- * Revision 1.20  2005/05/23 15:04:10  strk
- * Fixed bug in ::reverse()
- * Revision 1.19  2005/02/15 17:15:13  strk
- * Revision 1.18  2005/02/01 13:44:59  strk
- * More profiling labels.
- * Revision 1.17  2005/01/28 09:47:51  strk
- * Revision 1.16  2004/07/21 09:55:24  strk
- * Revision 1.15  2004/07/08 19:34:49  strk
- * Revision 1.14  2004/07/02 13:28:26  strk
- * Revision 1.13  2004/05/14 13:42:46  strk
- * DistanceOp bug removed, cascading errors fixed.
- * Revision 1.12  2004/04/05 06:35:14  ybychkov
- * "operation/distance" upgraded to JTS 1.4
- * Revision 1.11  2004/03/29 06:59:24  ybychkov
- * "noding/snapround" package ported (JTS 1.4);
- * "operation", "operation/valid", "operation/relate" and "operation/overlay" upgraded to JTS 1.4;
- * "geom" partially upgraded.
- * files.
- * Revision 1.9  2003/10/11 01:56:08  strk
- * Code base padded with 'const' keywords ;)
Modified: trunk/src/geom/LineString.cpp
--- trunk/src/geom/LineString.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/LineString.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -422,42 +422,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.71  2006/06/12 10:49:43  strk
- * Revision 1.70  2006/06/12 10:10:39  strk
- * Revision 1.69  2006/05/04 15:49:39  strk
- * Revision 1.68  2006/04/28 10:55:39  strk
- * size_t.
- * Revision 1.66  2006/04/10 18:15:09  strk
- * Revision 1.65  2006/04/10 17:35:44  strk
- * Changed LineString::points and Point::coordinates to be wrapped
- * in an auto_ptr<>. This should close bugs #86 and #89
- * Revision 1.64  2006/04/05 10:25:20  strk
- * Fixed LineString constructor to ensure deletion of CoordinateSequence
- * argument on exception throw
- * Revision 1.63  2006/03/31 16:55:17  strk
- * Added many assertions checking in LineString implementation.
- * Changed ::getCoordinate() to return NULL on empty geom.
- * Changed ::get{Start,End}Point() to return NULL on empty geom.
Modified: trunk/src/geom/LinearRing.cpp
--- trunk/src/geom/LinearRing.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/LinearRing.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -134,116 +134,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.33  2006/06/12 10:10:39  strk
- * Revision 1.32  2006/04/11 11:16:25  strk
- * Revision 1.31  2006/04/10 17:35:44  strk
- * Revision 1.30  2006/03/09 16:46:47  strk
- * Revision 1.29  2006/03/06 19:40:46  strk
- * Revision 1.28  2006/03/03 10:46:21  strk
- * Revision 1.27  2006/02/09 15:52:47  strk
- * Revision 1.26  2006/01/31 19:07:33  strk
- * Revision 1.25  2005/06/23 14:22:33  strk
- * Revision 1.24  2004/12/16 16:27:24  strk
- * Fixed LinearRing::clone() to return LinearRing instead of LineString
- * Revision 1.23  2004/12/03 22:52:56  strk
- * enforced const return of CoordinateSequence::toVector() method to derivate classes.
- * Revision 1.22  2004/07/08 19:34:49  strk
- * Revision 1.21  2004/07/06 17:58:22  strk
- * Removed deprecated Geometry constructors based on PrecisionModel and
- * SRID specification. Removed SimpleGeometryPrecisionReducer capability
- * of changing Geometry's factory. Reverted Geometry::factory member
- * to be a reference to external factory.
- * Revision 1.20  2004/07/05 10:50:20  strk
- * deep-dopy construction taken out of Geometry and implemented only
- * in GeometryFactory.
- * Deep-copy geometry construction takes care of cleaning up copies
- * on exception.
- * Implemented clone() method for CoordinateSequence
- * Changed createMultiPoint(CoordinateSequence) signature to reflect
- * copy semantic (by-ref instead of by-pointer).
- * Cleaned up documentation.
- * Revision 1.19  2004/07/02 13:28:26  strk
- * Revision 1.18  2004/07/01 14:12:44  strk
- * Geometry constructors come now in two flavors:
- * 	- deep-copy args (pass-by-reference)
- * 	- take-ownership of args (pass-by-pointer)
- * Same functionality is available through GeometryFactory,
- * including buildGeometry().
- * Revision 1.17  2004/06/28 21:11:43  strk
- * Moved getGeometryTypeId() definitions from geom.h to each geometry module.
- * Added holes argument check in Polygon.cpp.
- * Revision 1.16  2004/04/20 13:24:15  strk
- * More leaks removed.
- * Revision 1.15  2004/04/20 08:52:01  strk
- * GeometryFactory and Geometry const correctness.
- * Memory leaks removed from SimpleGeometryPrecisionReducer
- * and GeometryFactory.
- * Revision 1.14  2004/04/01 10:44:33  ybychkov
- * All "geom" classes from JTS 1.3 upgraded to JTS 1.4
- * Revision 1.13  2003/11/07 01:23:42  pramsey
- * files.
- * Revision 1.12  2003/10/11 03:23:22  strk
- * fixed spurious typos
Modified: trunk/src/geom/Location.cpp
--- trunk/src/geom/Location.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/Location.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -47,13 +47,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/geom/MultiLineString.cpp
--- trunk/src/geom/MultiLineString.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/MultiLineString.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -122,143 +122,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.34  2006/06/12 10:10:39  strk
- * Revision 1.33  2006/05/04 15:49:39  strk
- * Revision 1.32  2006/04/28 10:55:39  strk
- * size_t.
- * Revision 1.31  2006/03/24 09:52:41  strk
- * Revision 1.30  2006/03/23 12:12:00  strk
- * Fixes to allow build with -DGEOS_INLINE
- * Revision 1.27  2006/02/23 11:54:20  strk
- * - MCIndexPointSnapper
- * - MCIndexSnapRounder
- * - SnapRounding BufferOp
- * - ScaledNoder
- * - GEOSException hierarchy cleanups
- * - SpatialIndex memory-friendly query interface
- * - GeometryGraph::getBoundaryNodes memory-friendly
- * - NodeMap::getBoundaryNodes memory-friendly
- * - Cleanups in geomgraph::Edge
- * - Added an XML test for snaprounding buffer (shows leaks, working on it)
- * Revision 1.26  2006/02/19 19:46:49  strk
- * Revision 1.25  2006/02/08 17:18:28  strk
- * Revision 1.24  2006/01/31 19:07:33  strk
- * Revision 1.23  2004/09/12 03:51:27  pramsey
- * Casting changes to allow OS/X compilation.
- * Revision 1.22  2004/07/22 08:45:50  strk
- * Revision 1.21  2004/07/08 19:34:49  strk
- * Revision 1.20  2004/07/06 17:58:22  strk
- * Revision 1.19  2004/07/05 10:50:20  strk
- * on exception.
- * Revision 1.18  2004/07/02 13:28:26  strk
- * Revision 1.17  2004/07/01 14:12:44  strk
- * Revision 1.16  2004/06/28 21:11:43  strk
- * Revision 1.15  2004/05/07 13:04:57  strk
- * leak removed in MultiLineString::getBoundary()
- * Revision 1.14  2004/05/07 09:05:13  strk
- * Some const correctness added. Fixed bug in GeometryFactory::createMultiPoint
- * to handle NULL CoordinateSequence.
- * Revision 1.13  2004/04/20 08:52:01  strk
- * Revision 1.12  2004/04/01 10:44:33  ybychkov
- * Revision 1.11  2003/11/07 01:23:42  pramsey
- * files.
Modified: trunk/src/geom/MultiPoint.cpp
--- trunk/src/geom/MultiPoint.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/MultiPoint.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -78,135 +78,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.34  2006/05/04 15:49:39  strk
- * Revision 1.33  2006/04/28 10:55:39  strk
- * size_t.
- * Revision 1.32  2006/03/22 16:58:34  strk
- * Revision 1.31  2006/03/09 16:46:47  strk
- * Revision 1.30  2006/03/03 10:46:21  strk
- * Revision 1.29  2006/02/19 19:46:49  strk
- * Revision 1.28  2006/02/08 17:18:28  strk
- * Revision 1.27  2006/01/31 19:07:33  strk
- * Revision 1.26  2005/11/10 10:47:09  strk
- * Renamed MultiPoint::getCoordinate(int) to MultiPoint::getCoordinateN(int)
- * to avoid hiding of Geometry::getCoordinate().
- * Revision 1.25  2004/09/13 12:39:14  strk
- * Made Point and MultiPoint subject to Validity tests.
- * Revision 1.24  2004/09/12 03:51:27  pramsey
- * Revision 1.23  2004/07/22 08:45:50  strk
- * on exception.
- * Revision 1.16  2004/05/07 09:05:13  strk
- * Revision 1.13  2004/03/31 07:50:37  ybychkov
- * "geom" partially upgraded to JTS 1.4
- * Revision 1.12  2003/11/07 01:23:42  pramsey
- * files.
Modified: trunk/src/geom/MultiPolygon.cpp
--- trunk/src/geom/MultiPolygon.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/MultiPolygon.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -110,91 +110,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.32  2006/05/04 15:49:39  strk
- * Revision 1.31  2006/04/28 10:55:39  strk
- * size_t.
- * Revision 1.30  2006/04/07 09:54:30  strk
- * Revision 1.29  2006/03/24 09:52:41  strk
- * Revision 1.28  2006/03/23 12:12:00  strk
- * Revision 1.27  2006/03/22 16:58:34  strk
- * Revision 1.23  2004/12/08 14:33:20  strk
- * Checked inner polys getBoundary return for the single LineString case.
- * on exception.
Modified: trunk/src/geom/Polygon.cpp
--- trunk/src/geom/Polygon.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/Polygon.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -507,236 +507,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.68  2006/06/19 22:52:50  strk
- * optimized loops
- * Revision 1.67  2006/06/12 10:10:39  strk
- * Revision 1.66  2006/06/08 17:58:57  strk
- * Revision 1.65  2006/05/04 15:49:39  strk
- * Revision 1.64  2006/04/28 11:56:52  strk
- * Revision 1.63  2006/04/28 10:55:39  strk
- * size_t.
- * Revision 1.62  2006/04/10 18:15:09  strk
- * Revision 1.61  2006/03/15 09:13:36  strk
- * updated port info
- * Revision 1.60  2006/03/10 10:34:58  strk
- * Added missing <algorithm> include (#54)
- * Revision 1.59  2006/03/09 16:46:47  strk
- * Revision 1.58  2006/03/06 19:40:46  strk
- * Revision 1.57  2006/03/06 13:27:57  strk
- * Cleaned up equalsExact
- * Revision 1.56  2006/03/03 10:46:21  strk
- * Revision 1.55  2006/02/19 19:46:49  strk
- * Revision 1.54  2006/02/09 15:52:47  strk
- * Revision 1.53  2006/02/02 02:20:15  strk
- * Fixed bug in isRectangle() failing to detect rectangles.
- * Revision 1.52  2006/02/01 22:21:29  strk
- * - Added rectangle-based optimizations of intersects() and contains() ops
- * - Inlined all planarGraphComponent class
- * Revision 1.51  2006/01/31 19:07:33  strk
- * Revision 1.50  2005/12/08 14:14:07  strk
- * Revision 1.49  2005/11/24 23:09:15  strk
- * Revision 1.48  2005/11/21 16:03:20  strk
- *         operations
- *         in advance.
- *         stateless).
- * Revision 1.47  2005/06/23 14:22:33  strk
- * Revision 1.46  2004/12/30 10:14:51  strk
- * never return LinearRing or MultiLinearRing from getBoundary
- * Revision 1.45  2004/12/08 13:54:43  strk
- * gcc warnings checked and fixed, general cleanups.
- * Revision 1.44  2004/11/12 18:12:05  strk
- * Changed ::getBoundary() to return LineString if polygon has no holes.
- * (has required to pass OGC conformance test T20)
- * Revision 1.42  2004/07/22 07:04:49  strk
- * Revision 1.41  2004/07/13 08:33:52  strk
- * Added missing virtual destructor to virtual classes.
- * Fixed implicit unsigned int -> int casts
- * Revision 1.39  2004/07/06 17:58:22  strk
- * Revision 1.38  2004/07/05 10:50:20  strk
- * on exception.
- * Revision 1.37  2004/07/02 13:28:26  strk
- * Revision 1.36  2004/07/01 14:12:44  strk
- * Revision 1.35  2004/06/28 21:58:24  strk
- * Constructors speedup.
- * Revision 1.34  2004/06/28 21:11:43  strk
- * Revision 1.33  2004/06/15 20:30:47  strk
- * updated to respect deep-copy GeometryCollection interface
- * Revision 1.32  2004/04/20 13:24:15  strk
- * Revision 1.31  2004/04/20 08:52:01  strk
- * Revision 1.30  2004/04/01 10:44:33  ybychkov
- * Revision 1.29  2004/03/31 07:50:37  ybychkov
- * Revision 1.28  2004/02/27 17:43:45  strk
- * memory leak fix in Polygon::getArea() - reported by 'Manuel  Prieto Villegas' <mprieto at dap.es>
- * Revision 1.27  2003/11/07 01:23:42  pramsey
- * files.
- * Revision 1.26  2003/10/31 16:36:04  strk
- * Re-introduced clone() method. Copy constructor could not really
- * replace it.
- * Revision 1.25  2003/10/17 05:51:21  ybychkov
- * Fixed a small memory leak.
- * Revision 1.24  2003/10/16 08:50:00  strk
- * Memory leak fixes. Improved performance by mean of more calls to
- * new getCoordinatesRO() when applicable.
Modified: trunk/src/geom/PrecisionModel.cpp
--- trunk/src/geom/PrecisionModel.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/PrecisionModel.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -233,71 +233,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.46  2006/05/04 14:05:31  strk
- * Revision 1.45  2006/04/21 17:04:09  strk
- * Fixed constructor by type to always initialize scale factor
- * Revision 1.44  2006/04/07 12:37:51  mloskot
- * Revision 1.43  2006/04/06 12:36:52  strk
- * removed spurious lines from previous commi
- * Revision 1.42  2006/04/06 12:34:07  strk
- * Port info, more debugging lines, doxygen comments
- * Revision 1.41  2006/03/24 09:52:41  strk
- * Revision 1.40  2006/03/22 16:58:34  strk
- * Revision 1.39  2006/03/15 18:44:52  strk
- * Revision 1.38  2006/03/09 16:46:47  strk
- * Revision 1.37  2006/03/06 19:40:46  strk
- * Revision 1.36  2006/03/03 10:46:21  strk
- * Revision 1.35  2006/02/28 14:34:03  strk
- * Added many assertions and debugging output hunting for a bug in BufferOp
- * Revision 1.34  2006/02/27 09:05:32  strk
- * Doxygen comments, a few inlines and general cleanups
- * Revision 1.33  2006/02/24 16:20:14  strk
- * Added Mateusz implementation of round() in a new math.cpp file
- * named sym_round(). Changed use of rint_vc to sym_round in PrecisionModel.
- * Moved rint_vc to math.cpp (geos::util namespace), to be renamed
- * to something more meaningful
- * Revision 1.32  2006/02/23 23:17:52  strk
- * - Misc cleanups
- * Revision 1.31  2006/02/09 15:52:47  strk
- * Revision 1.30  2005/09/26 12:23:51  strk
- * Initializzation lists in PrecisionModel ctors
- * Revision 1.29  2005/01/28 09:47:51  strk
Modified: trunk/src/geom/Triangle.cpp
--- trunk/src/geom/Triangle.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/Triangle.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -35,16 +35,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.7  2006/03/22 16:58:34  strk
- * Revision 1.6  2006/03/13 21:54:56  strk
Modified: trunk/src/geom/prep/AbstractPreparedPolygonContains.cpp
--- trunk/src/geom/prep/AbstractPreparedPolygonContains.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/prep/AbstractPreparedPolygonContains.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -191,8 +191,3 @@
 } // geos::geom::prep
 } // geos::geom
 } // geos
- * $Log$
Modified: trunk/src/geom/prep/BasicPreparedGeometry.cpp
--- trunk/src/geom/prep/BasicPreparedGeometry.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/prep/BasicPreparedGeometry.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -154,8 +154,3 @@
 } // namespace geos.geom.prep
 } // namespace geos
- * $Log$
Modified: trunk/src/geom/prep/PreparedGeometry.cpp
--- trunk/src/geom/prep/PreparedGeometry.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/prep/PreparedGeometry.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -26,8 +26,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/geom/prep/PreparedGeometryFactory.cpp
--- trunk/src/geom/prep/PreparedGeometryFactory.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/prep/PreparedGeometryFactory.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -75,8 +75,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/geom/prep/PreparedLineString.cpp
--- trunk/src/geom/prep/PreparedLineString.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/prep/PreparedLineString.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -68,9 +68,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/geom/prep/PreparedPoint.cpp
--- trunk/src/geom/prep/PreparedPoint.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/prep/PreparedPoint.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -35,8 +35,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/geom/prep/PreparedPolygon.cpp
--- trunk/src/geom/prep/PreparedPolygon.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/prep/PreparedPolygon.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -147,9 +147,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/geom/prep/PreparedPolygonContains.cpp
--- trunk/src/geom/prep/PreparedPolygonContains.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/prep/PreparedPolygonContains.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -49,8 +49,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/geom/prep/PreparedPolygonContainsProperly.cpp
--- trunk/src/geom/prep/PreparedPolygonContainsProperly.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/prep/PreparedPolygonContainsProperly.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -85,8 +85,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/geom/prep/PreparedPolygonCovers.cpp
--- trunk/src/geom/prep/PreparedPolygonCovers.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/prep/PreparedPolygonCovers.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -46,8 +46,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/geom/prep/PreparedPolygonIntersects.cpp
--- trunk/src/geom/prep/PreparedPolygonIntersects.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/prep/PreparedPolygonIntersects.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -82,8 +82,3 @@
 } // geos::geom
 } // geos
- * $Log$
Modified: trunk/src/geom/prep/PreparedPolygonPredicate.cpp
--- trunk/src/geom/prep/PreparedPolygonPredicate.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/prep/PreparedPolygonPredicate.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -139,8 +139,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/geom/util/ComponentCoordinateExtracter.cpp
--- trunk/src/geom/util/ComponentCoordinateExtracter.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/util/ComponentCoordinateExtracter.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -23,8 +23,3 @@
 } // namespace geos.geom.util
 } // namespace geos
- * $Log$
Modified: trunk/src/geom/util/CoordinateOperation.cpp
--- trunk/src/geom/util/CoordinateOperation.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/util/CoordinateOperation.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -57,11 +57,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.1  2006/03/09 16:46:47  strk
Modified: trunk/src/geom/util/GeometryEditor.cpp
--- trunk/src/geom/util/GeometryEditor.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/util/GeometryEditor.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -181,94 +181,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.18  2006/06/08 17:58:57  strk
- * Revision 1.17  2006/04/07 09:54:30  strk
- * Revision 1.16  2006/03/09 16:46:47  strk
- * Revision 1.15  2006/03/06 19:40:46  strk
- * Revision 1.14  2006/03/03 10:46:21  strk
- * Revision 1.13  2006/01/31 19:07:34  strk
- * Revision 1.12  2004/12/22 09:42:45  strk
- * Fixed a premature Geometry destruction, Avoided CoordinateSequence copies
- * when possible.
- * Revision 1.11  2004/12/08 13:54:43  strk
- * Revision 1.10  2004/07/08 19:34:49  strk
- * Revision 1.8  2004/07/01 14:12:44  strk
- * Revision 1.7  2004/06/15 20:20:45  strk
- * Revision 1.6  2004/05/05 12:20:22  strk
- * Memory leak plugged in editGeometryCollection
- * Revision 1.5  2004/05/03 17:15:38  strk
- * leaks on exception fixed.
- * Revision 1.4  2004/04/20 10:14:20  strk
- * Memory leaks removed.
- * Revision 1.3  2004/04/20 08:52:01  strk
- * Revision 1.2  2004/04/14 11:05:07  strk
- * Added support for LinearRing in GeometryEditor
- * Revision 1.1  2004/04/04 06:29:11  ybychkov
- * "planargraph" and "geom/utill" upgraded to JTS 1.4
Modified: trunk/src/geom/util/GeometryTransformer.cpp
--- trunk/src/geom/util/GeometryTransformer.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geom/util/GeometryTransformer.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -385,17 +385,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.3  2006/06/19 21:20:22  strk
- * Revision 1.2  2006/04/11 16:04:34  strk
- * Revision 1.1  2006/04/11 12:21:48  strk
- * GeometryTransformer class ported
Modified: trunk/src/geomgraph/Depth.cpp
--- trunk/src/geomgraph/Depth.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geomgraph/Depth.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -173,37 +173,3 @@
 } // namespace geos.geomgraph
 } // namespace geos
- * $Log$
- * Revision 1.7  2006/03/15 17:16:29  strk
- * streamlined headers inclusion
- * Revision 1.5  2006/02/19 19:46:49  strk
- * Revision 1.4  2005/11/14 18:14:03  strk
- * Reduced heap allocations made by TopologyLocation and Label objects.
- * Enforced const-correctness on GraphComponent.
- * Cleanups.
- * Revision 1.3  2005/01/28 09:47:51  strk
- * Revision 1.2  2004/07/02 13:28:26  strk
- * Revision 1.1  2004/03/19 09:48:45  ybychkov
- * "geomgraph" and "geomgraph/indexl" upgraded to JTS 1.4
- * files.
Modified: trunk/src/geomgraph/EdgeList.cpp
--- trunk/src/geomgraph/EdgeList.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geomgraph/EdgeList.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -154,69 +154,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.17  2006/03/22 12:22:49  strk
- * indexQuadtree.h split
- * Revision 1.16  2006/03/14 11:03:14  strk
- * Added operator<< for Edge and EdgeList
- * Revision 1.15  2006/03/03 10:46:21  strk
- * Revision 1.14  2006/03/02 12:12:00  strk
- * Renamed DEBUG macros to GEOS_DEBUG, all wrapped in #ifndef block to allow global override (bug#43)
- * Revision 1.13  2006/02/28 14:34:04  strk
- * Revision 1.12  2006/02/23 11:54:20  strk
- * - ScaledNoder
- * Revision 1.11  2006/02/20 10:14:18  strk
- * - namespaces geos::index::*
- * - Doxygen documentation cleanup
- * Revision 1.10  2006/02/19 19:46:49  strk
- * Revision 1.9  2006/01/31 19:07:34  strk
- * Revision 1.8  2005/12/07 19:18:23  strk
- * Changed PlanarGraph::addEdges and EdgeList::addAll to take
- * a const vector by reference rather then a non-const vector by
- * pointer.
- * Optimized polygon vector allocations in OverlayOp::computeOverlay.
Modified: trunk/src/geomgraph/EdgeNodingValidator.cpp
--- trunk/src/geomgraph/EdgeNodingValidator.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geomgraph/EdgeNodingValidator.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -60,42 +60,3 @@
 } // namespace geos
- * $Log$
- * unsigned int => size_t
- * Revision 1.6  2006/02/19 19:46:49  strk
- * Revision 1.5  2006/02/18 21:08:09  strk
- * - new CoordinateSequence::applyCoordinateFilter method (slow but useful)
- * - SegmentString::getCoordinates() doesn't return a clone anymore.
- * - SegmentString::getCoordinatesRO() obsoleted.
- * - SegmentString constructor does not promises constness of passed
- *   CoordinateSequence anymore.
- * - NEW ScaledNoder class
- * - Stubs for MCIndexPointSnapper and  MCIndexSnapRounder
- * - Simplified internal interaces of OffsetCurveBuilder and OffsetCurveSetBuilder
- * Revision 1.4  2006/02/15 17:19:18  strk
- * NodingValidator synced with JTS-1.7, added CoordinateSequence::operator[]
- * and size() to easy port maintainance.
- * Revision 1.3  2004/07/02 13:28:26  strk
- * Revision 1.2  2004/03/31 07:50:37  ybychkov
Modified: trunk/src/geomgraph/Label.cpp
--- trunk/src/geomgraph/Label.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geomgraph/Label.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -275,23 +275,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.10  2006/04/06 09:01:37  strk
- * Doxygen comments, port info, operator<<, assertion checking
- * Revision 1.9  2006/04/03 17:05:22  strk
- * Assertion checking, port info, cleanups
- * Revision 1.8  2006/03/14 12:55:55  strk
- * Headers split: geomgraphindex.h, nodingSnapround.h
- * Revision 1.7  2006/03/03 10:46:21  strk
Modified: trunk/src/geomgraph/NodeFactory.cpp
--- trunk/src/geomgraph/NodeFactory.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geomgraph/NodeFactory.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -41,64 +41,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.5  2006/03/15 17:16:29  strk
- * Revision 1.4  2006/02/19 19:46:49  strk
- * Revision 1.3  2005/11/21 16:03:20  strk
- *         operations
- *         in advance.
- *         stateless).
- * Revision 1.7  2003/11/07 01:23:42  pramsey
- * files.
Modified: trunk/src/geomgraph/Position.cpp
--- trunk/src/geomgraph/Position.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geomgraph/Position.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -45,35 +45,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.6  2006/03/09 16:01:59  strk
- * Fixed debugging lines
- * Revision 1.5  2006/03/02 12:12:00  strk
- * Revision 1.3  2005/05/20 16:15:41  strk
- * Code cleanups
- * Revision 1.5  2003/11/07 01:23:42  pramsey
- * files.
Modified: trunk/src/geomgraph/Quadrant.cpp
--- trunk/src/geomgraph/Quadrant.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geomgraph/Quadrant.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -126,45 +126,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.10  2006/03/15 17:16:29  strk
- * Revision 1.9  2006/03/09 16:46:47  strk
- * Revision 1.8  2006/03/06 19:40:46  strk
- * geos::util namespace. New GeometryCollection::iterator interface, many cleanups.
- * Removed 'using namespace' from headers, added missing headers in .cpp files, removed useless includes in headers (bug#46)
- * Revision 1.5  2006/02/09 15:52:47  strk
- * Revision 1.4  2005/02/05 05:44:47  strk
- * Changed geomgraph nodeMap to use Coordinate pointers as keys, reduces
- * lots of other Coordinate copies.
- * files.
Modified: trunk/src/geomgraph/index/MonotoneChainEdge.cpp
--- trunk/src/geomgraph/index/MonotoneChainEdge.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geomgraph/index/MonotoneChainEdge.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -168,82 +168,3 @@
 } // namespace geos.geomgraph.index
 } // namespace geos
- * $Log$
- * Revision 1.13  2006/06/12 11:29:23  strk
- * Revision 1.12  2006/03/15 17:16:31  strk
- * Revision 1.11  2006/03/09 16:46:47  strk
- * Revision 1.10  2006/03/03 10:46:21  strk
- * Revision 1.9  2006/02/28 14:34:04  strk
- * Revision 1.8  2006/02/19 19:46:49  strk
- * Revision 1.7  2006/01/31 19:07:34  strk
- * Revision 1.6  2005/11/15 10:04:37  strk
- * Reduced heap allocations (vectors, mostly).
- * Enforced const-correctness, changed some interfaces
- * to use references rather then pointers when appropriate.
- * Revision 1.5  2004/11/23 19:53:06  strk
- * Had LineIntersector compute Z by interpolation.
- * Revision 1.4  2004/10/20 17:32:14  strk
- * Initial approach to 2.5d intersection()
- * Revision 1.3  2004/07/08 19:34:49  strk
- * Revision 1.1  2004/04/14 06:04:26  ybychkov
- * "geomgraph/index" committ problem fixed.
- * Revision 1.17  2004/03/19 09:49:29  ybychkov
- * Revision 1.16  2003/11/07 01:23:42  pramsey
- * files.
- * Revision 1.15  2003/10/15 16:39:03  strk
- * Made Edge::getCoordinates() return a 'const' value. Adapted code set.
Modified: trunk/src/geomgraph/index/MonotoneChainIndexer.cpp
--- trunk/src/geomgraph/index/MonotoneChainIndexer.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geomgraph/index/MonotoneChainIndexer.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -64,69 +64,3 @@
 } // namespage geos
- * $Log$
- * Revision 1.9  2006/03/15 17:16:31  strk
- * Revision 1.8  2006/03/09 16:46:47  strk
- * Revision 1.5  2006/01/31 19:07:34  strk
- * Revision 1.4  2005/11/15 10:04:37  strk
- * Revision 1.10  2004/03/19 09:49:29  ybychkov
- * Revision 1.9  2003/11/07 01:23:42  pramsey
- * files.
- * Revision 1.8  2003/10/15 16:39:03  strk
Modified: trunk/src/geomgraph/index/SegmentIntersector.cpp
--- trunk/src/geomgraph/index/SegmentIntersector.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geomgraph/index/SegmentIntersector.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -222,141 +222,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.18  2006/03/23 13:31:58  strk
- * Fixed to allow build with GEOS_DEBUG
- * Revision 1.17  2006/03/15 17:16:31  strk
- * Revision 1.13  2006/02/23 11:54:20  strk
- * - ScaledNoder
- * Revision 1.12  2006/02/19 19:46:49  strk
- * Revision 1.11  2006/01/31 19:07:34  strk
- * Revision 1.10  2005/11/21 16:03:20  strk
- *         operations
- *         in advance.
- *         stateless).
- * Revision 1.9  2005/11/15 10:04:37  strk
- * Revision 1.8  2005/04/06 11:09:41  strk
- * Applied patch from Jon Schlueter (math.h => cmath; ieeefp.h in "C" block)
- * Revision 1.7  2004/11/23 19:53:06  strk
- * Revision 1.6  2004/11/17 08:41:42  strk
- * Fixed a bug in Z computation and removed debugging output by default.
- * Revision 1.5  2004/11/17 08:13:16  strk
- * Indentation changes.
- * Some Z_COMPUTATION activated by default.
- * Revision 1.18  2004/03/19 09:49:29  ybychkov
- * Revision 1.17  2003/11/07 01:23:42  pramsey
- * files.
- * Revision 1.16  2003/10/15 16:39:03  strk
Modified: trunk/src/geomgraph/index/SimpleEdgeSetIntersector.cpp
--- trunk/src/geomgraph/index/SimpleEdgeSetIntersector.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geomgraph/index/SimpleEdgeSetIntersector.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -98,73 +98,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.10  2006/06/12 11:29:23  strk
- * Revision 1.4  2005/11/24 23:09:15  strk
- * Revision 1.2  2004/07/02 13:28:27  strk
- * Revision 1.6  2004/03/19 09:49:29  ybychkov
- * files.
- * Revision 1.4  2003/10/15 16:39:03  strk
Modified: trunk/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp
--- trunk/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -165,59 +165,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.9  2006/02/19 19:46:49  strk
- * Revision 1.8  2005/11/15 10:04:37  strk
- * Revision 1.7  2005/11/03 21:28:06  strk
- * Fixed constructors broke by previous commit
- * Revision 1.6  2005/11/03 19:51:28  strk
- * Indentation changes, small vector memory allocation optimization.
- * Revision 1.5  2005/10/27 14:05:19  strk
- * Added a SweepLineEventLessThen functor to be used by sort algorithm.
- * Revision 1.4  2004/11/22 11:34:49  strk
- * More debugging lines and comments/indentation cleanups
- * Revision 1.3  2004/10/20 17:32:14  strk
- * files.
Modified: trunk/src/geomgraph/index/SimpleSweepLineIntersector.cpp
--- trunk/src/geomgraph/index/SimpleSweepLineIntersector.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geomgraph/index/SimpleSweepLineIntersector.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -160,79 +160,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.11  2006/03/10 10:37:00  strk
- * Added missing <algorithm> include (#55)
- * Revision 1.10  2006/03/09 16:46:47  strk
- * Revision 1.9  2006/03/03 10:46:21  strk
- * Revision 1.5  2005/11/03 21:28:06  strk
- * Revision 1.4  2005/11/03 19:51:28  strk
- * Revision 1.7  2004/03/19 09:49:29  ybychkov
- * Revision 1.6  2003/11/07 01:23:42  pramsey
- * Add standard CVS headers licence notices and copyrights to all cpp and h
- * files.
- * Revision 1.5  2003/10/15 16:39:03  strk
Modified: trunk/src/geomgraph/index/SweepLineEvent.cpp
--- trunk/src/geomgraph/index/SweepLineEvent.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geomgraph/index/SweepLineEvent.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -77,56 +77,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.10  2006/03/15 17:16:31  strk
- * Revision 1.8  2006/03/02 14:53:40  strk
- * SweepLineEvent::DELETE=>DELETE_EVENT, INSERT=>INSERT_EVENT (#45)
- * Revision 1.7  2006/02/19 19:46:49  strk
- * Revision 1.6  2005/11/07 12:31:24  strk
- * Changed EdgeIntersectionList to use a set<> rathern then a vector<>, and
- * to avoid dynamic allocation of initial header.
- * Inlined short SweepLineEvent methods.
- * Revision 1.5  2005/11/04 15:42:52  strk
- * Fixed bug in SweepLineEventLessThen functor
- * (didn't conform to strict weak ordering).
- * Note: this was introduced by previous commit.
- * Revision 1.4  2005/10/27 14:05:20  strk
- * Revision 1.13  2004/03/19 09:49:29  ybychkov
- * files.
- * Revision 1.11  2003/10/15 15:30:32  strk
- * Declared a SweepLineEventOBJ from which MonotoneChain and
- * SweepLineSegment derive to abstract SweepLineEvent object
- * previously done on void * pointers.
- * No more compiler warnings...
Modified: trunk/src/geomgraph/index/SweepLineSegment.cpp
--- trunk/src/geomgraph/index/SweepLineSegment.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/geomgraph/index/SweepLineSegment.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -65,43 +65,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.6  2006/03/15 17:16:31  strk
- * Revision 1.5  2006/03/09 16:46:47  strk
- * Revision 1.3  2005/11/15 10:04:37  strk
- * files.
- * Revision 1.8  2003/10/15 15:30:32  strk
Modified: trunk/src/index/bintree/Bintree.cpp
--- trunk/src/index/bintree/Bintree.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/bintree/Bintree.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -150,11 +150,3 @@
 } // namespace geos.index.bintree
 } // namespace geos
- * $Log$
- * Revision 1.13  2006/03/22 16:01:33  strk
Modified: trunk/src/index/bintree/Interval.cpp
--- trunk/src/index/bintree/Interval.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/bintree/Interval.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -109,11 +109,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.3  2006/03/22 16:01:33  strk
Modified: trunk/src/index/bintree/Key.cpp
--- trunk/src/index/bintree/Key.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/bintree/Key.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -96,13 +96,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.11  2006/03/22 16:01:33  strk
- * Revision 1.10  2006/03/22 12:22:50  strk
Modified: trunk/src/index/bintree/Node.cpp
--- trunk/src/index/bintree/Node.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/bintree/Node.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -162,11 +162,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/index/bintree/NodeBase.cpp
--- trunk/src/index/bintree/NodeBase.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/bintree/NodeBase.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -135,14 +135,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.12  2006/03/22 18:12:31  strk
Modified: trunk/src/index/bintree/Root.cpp
--- trunk/src/index/bintree/Root.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/bintree/Root.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -86,27 +86,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.10  2006/03/22 16:01:33  strk
- * Revision 1.9  2006/03/22 12:22:50  strk
- * Revision 1.8  2006/02/20 10:14:18  strk
- * Revision 1.7  2004/07/02 13:28:27  strk
- * files.
Modified: trunk/src/index/chain/MonotoneChain.cpp
--- trunk/src/index/chain/MonotoneChain.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/chain/MonotoneChain.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -174,11 +174,3 @@
 } // namespace geos.index.chain
 } // namespace geos
- * $Log$
- * Revision 1.1  2006/03/22 18:12:32  strk
Modified: trunk/src/index/chain/MonotoneChainOverlapAction.cpp
--- trunk/src/index/chain/MonotoneChainOverlapAction.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/chain/MonotoneChainOverlapAction.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -40,11 +40,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.11  2006/03/22 18:12:32  strk
Modified: trunk/src/index/chain/MonotoneChainSelectAction.cpp
--- trunk/src/index/chain/MonotoneChainSelectAction.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/chain/MonotoneChainSelectAction.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -38,11 +38,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/index/intervalrtree/IntervalRTreeBranchNode.cpp
--- trunk/src/index/intervalrtree/IntervalRTreeBranchNode.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/intervalrtree/IntervalRTreeBranchNode.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -49,8 +49,3 @@
 } // geos::intervalrtree
 } // geos::index
 } // geos
- * $Log$
Modified: trunk/src/index/intervalrtree/IntervalRTreeLeafNode.cpp
--- trunk/src/index/intervalrtree/IntervalRTreeLeafNode.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/intervalrtree/IntervalRTreeLeafNode.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -42,8 +42,3 @@
 } // geos::index
 } // geos
- * $Log$
Modified: trunk/src/index/intervalrtree/IntervalRTreeNode.cpp
--- trunk/src/index/intervalrtree/IntervalRTreeNode.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/intervalrtree/IntervalRTreeNode.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -33,8 +33,3 @@
 } // geos::index
 } // geos
- * $Log$
Modified: trunk/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
--- trunk/src/index/intervalrtree/SortedPackedIntervalRTree.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/intervalrtree/SortedPackedIntervalRTree.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -145,8 +145,3 @@
 } // geos::index
 } // geos
- * $Log$
Modified: trunk/src/index/quadtree/DoubleBits.cpp
--- trunk/src/index/quadtree/DoubleBits.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/quadtree/DoubleBits.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -177,17 +177,3 @@
 } // namespace geos.index.quadtree
 } // namespace geos
- * $Log$
- * Revision 1.25  2006/05/24 16:29:11  strk
- * * source/index/quadtree/DoubleBits.cpp: handled negative or zero values in getExponent().
- * Revision 1.24  2006/05/23 14:29:33  strk
- * * source/headers/geos/index/quadtree/DoubleBits.h, source/index/quadtree/DoubleBits.cpp: const correctness and documentation.
- * Revision 1.23  2006/03/22 12:22:50  strk
Modified: trunk/src/index/quadtree/IntervalSize.cpp
--- trunk/src/index/quadtree/IntervalSize.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/quadtree/IntervalSize.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -45,30 +45,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.9  2006/03/15 18:44:52  strk
- * Revision 1.8  2006/03/03 10:46:21  strk
- * Revision 1.7  2006/02/20 10:14:18  strk
- * Revision 1.6  2004/07/02 13:28:27  strk
- * files.
Modified: trunk/src/index/quadtree/Key.cpp
--- trunk/src/index/quadtree/Key.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/quadtree/Key.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -127,13 +127,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.1  2006/03/22 14:28:52  strk
- * Filenames renamed to match class names (matching JTS)
- * Revision 1.13  2006/03/22 12:22:50  strk
Modified: trunk/src/index/quadtree/Node.cpp
--- trunk/src/index/quadtree/Node.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/quadtree/Node.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -206,17 +206,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.2  2006/03/23 13:31:58  strk
- * Revision 1.1  2006/03/22 14:28:53  strk
- * Revision 1.17  2006/03/22 12:22:50  strk
Modified: trunk/src/index/quadtree/NodeBase.cpp
--- trunk/src/index/quadtree/NodeBase.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/quadtree/NodeBase.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -271,17 +271,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.19  2006/03/22 12:22:50  strk
Modified: trunk/src/index/quadtree/Quadtree.cpp
--- trunk/src/index/quadtree/Quadtree.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/quadtree/Quadtree.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -164,29 +164,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.25  2006/04/03 08:29:30  strk
- * Added port info, cleaned up log message, minor assertion checking.
- * Revision 1.24  2006/03/23 13:31:58  strk
- * Revision 1.22  2006/03/20 16:57:44  strk
- * spatialindex.h and opValid.h headers split
- * Revision 1.21  2006/03/03 10:46:21  strk
- * Revision 1.20  2006/03/02 12:12:00  strk
- * Revision 1.19  2006/03/01 13:49:45  strk
- * Fixed debug lines (bug#36)
Modified: trunk/src/index/quadtree/Root.cpp
--- trunk/src/index/quadtree/Root.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/quadtree/Root.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -143,14 +143,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.16  2006/03/22 12:22:50  strk
Modified: trunk/src/index/strtree/AbstractNode.cpp
--- trunk/src/index/strtree/AbstractNode.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/strtree/AbstractNode.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -68,14 +68,3 @@
 } // namespace geos.index.strtree
 } // namespace geos
- * $Log$
- * Revision 1.13  2006/03/21 10:47:34  strk
- * indexStrtree.h split
- * Revision 1.12  2006/03/06 19:40:47  strk
Modified: trunk/src/index/strtree/AbstractSTRtree.cpp
--- trunk/src/index/strtree/AbstractSTRtree.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/strtree/AbstractSTRtree.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -394,117 +394,3 @@
 } // namespace geos
- * $Log$
- * unsigned int => std::size_t
- * Revision 1.29  2006/03/21 10:47:34  strk
- * - ScaledNoder
- * Revision 1.26  2006/02/20 21:04:37  strk
- * - namespace geos::index
- * - SpatialIndex interface synced
- * Revision 1.25  2006/02/20 10:14:18  strk
- * Revision 1.24  2005/02/15 17:15:13  strk
- * Revision 1.23  2005/01/31 15:41:03  strk
- * Revision 1.22  2004/12/08 13:54:43  strk
- * Revision 1.21  2004/11/08 15:58:13  strk
- * More performance tuning.
- * Revision 1.20  2004/11/04 19:08:07  strk
- * Cleanups, initializers list, profiling.
- * Revision 1.19  2004/11/01 16:43:04  strk
- * Added Profiler code.
- * Temporarly patched a bug in DoubleBits (must check drawbacks).
- * Various cleanups and speedups.
- * Revision 1.18  2004/07/27 16:35:46  strk
- * Revision 1.17  2004/07/13 08:33:52  strk
- * Revision 1.16  2004/07/02 13:28:27  strk
- * Revision 1.15  2004/05/06 15:00:59  strk
- * Boundable destructor made virtual.
- * Added vector <AbstractNode *> *nodes member in AbstractSTRTree,
- * used to keep track of created node to cleanly delete them at
- * destruction time.
- * Revision 1.14  2004/05/06 08:59:19  strk
- * memory leak fixed
- * Revision 1.13  2004/05/05 17:42:06  strk
- * AbstractNode destructor made virtual. AbstractNode::bounds made protected.
- * SIRAbstractNode and STRAbstractNode destructors added to get rid of
- * AbstractNode::bounds in the right way (is a void * casted to appropriate
- * Class in the subClasses).
- * Revision 1.12  2004/05/03 22:56:44  strk
- * leaks fixed, exception specification omitted.
- * Revision 1.11  2004/05/03 16:29:21  strk
- * Added sortBoundables(const vector<Boundable *>) pure virtual in AbstractSTRtree,
- * implemented in SIRtree and STRtree. Comparator funx made static in STRtree.cpp
- * and SIRtree.cpp.
- * Revision 1.10  2004/05/03 13:17:55  strk
- * Fixed comparator function to express StrictWeakOrdering.
- * Revision 1.9  2004/04/28 14:58:47  strk
- * Made AbstractSTRtree::query use dynamic_cast<> to simulate java's
- * instanceof. Previous typeid(*) use missed to catch an STRAbstractNode
- * as a class derived from AbstractNode. Still have to check if this
- * is the correct semantic with Martin, but at least lots of SIGABORT
- * are no more raised.
- * Revision 1.8  2004/04/26 12:37:19  strk
- * Some leaks fixed.
- * Revision 1.7  2004/04/14 12:28:43  strk
- * shouldNeverReachHere exceptions made more verbose
- * Revision 1.6  2004/03/25 02:23:55  ybychkov
- * All "index/" packages upgraded to JTS 1.4
- * files.
Modified: trunk/src/index/strtree/Interval.cpp
--- trunk/src/index/strtree/Interval.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/strtree/Interval.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -71,29 +71,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.11  2006/03/21 10:47:34  strk
- * Revision 1.10  2006/03/06 19:40:47  strk
- * files.
Modified: trunk/src/index/strtree/ItemBoundable.cpp
--- trunk/src/index/strtree/ItemBoundable.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/strtree/ItemBoundable.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -41,34 +41,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.9  2006/03/21 10:47:34  strk
- * Revision 1.7  2004/07/27 16:35:46  strk
- * Revision 1.5  2004/05/06 15:00:59  strk
- * Revision 1.4  2003/11/07 01:23:42  pramsey
- * files.
Modified: trunk/src/index/strtree/SIRtree.cpp
--- trunk/src/index/strtree/SIRtree.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/strtree/SIRtree.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -144,64 +144,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.21  2006/06/12 10:49:43  strk
- * Revision 1.20  2006/03/21 10:47:34  strk
- * Revision 1.19  2006/03/06 19:40:47  strk
- * Revision 1.18  2006/03/03 10:46:21  strk
- * Revision 1.17  2006/02/23 11:54:20  strk
- * - ScaledNoder
- * Revision 1.16  2006/02/20 10:14:18  strk
- * Revision 1.15  2005/02/15 17:15:13  strk
- * Revision 1.14  2004/12/08 13:54:43  strk
- * Revision 1.13  2004/11/04 19:08:07  strk
- * Revision 1.12  2004/07/27 16:35:46  strk
- * Revision 1.11  2004/07/13 08:33:53  strk
- * Revision 1.10  2004/07/02 13:28:27  strk
- * Revision 1.9  2004/05/06 15:00:59  strk
Modified: trunk/src/index/strtree/STRtree.cpp
--- trunk/src/index/strtree/STRtree.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/strtree/STRtree.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -252,31 +252,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.33  2006/06/12 10:49:43  strk
- * Revision 1.32  2006/04/03 10:44:19  strk
- * Added missing headers
- * Revision 1.31  2006/04/03 08:43:09  strk
- * Added port info, minor cleanups
- * Revision 1.30  2006/03/21 10:47:34  strk
- * Revision 1.29  2006/03/20 16:57:44  strk
- * Revision 1.28  2006/03/15 18:44:52  strk
- * Revision 1.27  2006/03/06 19:40:47  strk
- * Revision 1.26  2006/03/03 10:46:21  strk
Modified: trunk/src/index/sweepline/SweepLineEvent.cpp
--- trunk/src/index/sweepline/SweepLineEvent.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/sweepline/SweepLineEvent.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -104,26 +104,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.1  2006/03/21 10:01:30  strk
- * indexSweepline.h header split
- * Revision 1.8  2006/03/02 14:53:44  strk
- * files.
Modified: trunk/src/index/sweepline/SweepLineIndex.cpp
--- trunk/src/index/sweepline/SweepLineIndex.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/sweepline/SweepLineIndex.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -113,17 +113,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.9  2006/03/21 10:01:30  strk
Modified: trunk/src/index/sweepline/SweepLineInterval.cpp
--- trunk/src/index/sweepline/SweepLineInterval.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/index/sweepline/SweepLineInterval.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -48,23 +48,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.8  2006/03/21 10:01:30  strk
- * files.
Modified: trunk/src/io/ByteOrderValues.cpp
--- trunk/src/io/ByteOrderValues.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/io/ByteOrderValues.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -155,44 +155,3 @@
 } // namespace geos.io
 } // namespace geos
- * $Log$
- * Revision 1.9  2006/05/23 12:33:41  strk
- * * source/io/ByteOrderValues.cpp: fixed bug in putLong() also affecting putDouble()
- * Revision 1.8  2006/05/23 09:24:35  strk
- * * source/io/ByteOrderValues.cpp: changed ENDIAN_BIG and ENDIAN_LITTLE values to match WKBConstants::XDR and WKBConstants::NDR respectively.
- * * source/headers/geos/io/WKBConstants.h: added comments about meaning of XDR/NDR.
- * Revision 1.7  2006/03/20 18:18:15  strk
- * io.h header split
- * Revision 1.6  2006/03/06 15:23:14  strk
- * geos::io namespace
- * Revision 1.5  2006/03/03 10:46:21  strk
- * Revision 1.4  2006/01/21 16:08:30  strk
- * Fixed integer conversion bug (ported from JTS-1.7).
- * Added last port information.
- * Revision 1.3  2005/04/29 17:40:36  strk
- * Updated Doxygen documentation and some Copyright headers.
- * Revision 1.2  2005/04/29 15:34:21  strk
- * Typedef'ed biostringstream, preferred parameter for
- * WKB parser templates.
- * Added << operator for biostringstream.
- * Typedef'ed WKBWriter and WKBReader to be parametrized by
- * biostringstream.
- * Added WKBtest in doc/example.cpp
- * Revision 1.1  2005/04/20 17:22:47  strk
- * Added initial implementation of WKBReaderT and ByteOrderDataInStreamT
- * class templates and ByteOrderValues class.
- * Work is unfinished as WKBReader requires new interface of CoordinateSequence
- * taking higher dimensions into account.
Modified: trunk/src/io/ParseException.cpp
--- trunk/src/io/ParseException.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/io/ParseException.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -60,38 +60,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.15  2006/04/04 08:16:46  strk
- * Changed GEOSException hierarchy to be derived from std::runtime_exception.
- * Removed the GEOSException::toString redundant method (use ::what() instead)
- * Revision 1.14  2006/03/20 18:18:15  strk
- * Revision 1.13  2006/03/06 15:23:14  strk
- * Revision 1.12  2006/03/03 10:46:21  strk
- * Revision 1.11  2006/02/09 15:52:47  strk
- * GEOSException derived from std::exception; always thrown and cought by const ref.
- * Revision 1.10  2005/01/28 10:01:09  strk
- * substituted sprintf calls with use of ostringstream
- * Revision 1.9  2004/07/02 13:28:27  strk
- * Fixed all #include lines to reflect headers layout change.
- * Added client application build tips in README.
- * Revision 1.8  2004/05/17 12:36:39  strk
- * ParseException message made more readable
- * files.
Modified: trunk/src/io/StringTokenizer.cpp
--- trunk/src/io/StringTokenizer.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/io/StringTokenizer.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -152,10 +152,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.16  2006/04/26 16:35:40  strk
- * Had WKTReader accept correct form for MultiPoint
Modified: trunk/src/io/Unload.cpp
--- trunk/src/io/Unload.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/io/Unload.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -29,126 +29,3 @@
 } //namespace geos
- * $Log$
- * Revision 1.26  2006/04/10 13:09:49  strk
- * Revision 1.25  2006/03/20 16:57:44  strk
- * Revision 1.24  2006/03/17 16:48:55  strk
- * LineIntersector and PointLocator made complete components of RelateComputer
- * (were statics const pointers before). Reduced inclusions from opRelate.h
- * and opValid.h, updated .cpp files to allow build.
- * Revision 1.23  2006/03/06 19:40:47  strk
- * Revision 1.22  2006/03/06 15:23:14  strk
- * Revision 1.20  2006/03/02 14:34:43  strk
- * GeometryGraphOperation::li made a non-static member, and not more a pointer
- * Revision 1.19  2006/03/01 10:39:59  strk
- * ctor and dtor made private and inlined
- * Revision 1.18  2006/02/23 11:54:20  strk
- * - ScaledNoder
- * Revision 1.17  2006/02/20 10:14:18  strk
- * Revision 1.16  2006/02/19 19:46:49  strk
- * Packages <-> namespaces mapping for most GEOS internal code (uncomplete, but working). Dir-level libs for index/ subdirs.
- * Revision 1.15  2006/01/31 19:07:34  strk
- * Revision 1.14  2004/12/08 14:30:53  strk
- * Added default profiler instance cleanup
- * Revision 1.13  2004/10/13 10:03:02  strk
- * Added missing linemerge and polygonize operation.
- * Bug fixes and leaks removal from the newly added modules and
- * planargraph (used by them).
- * Some comments and indentation changes.
- * Revision 1.12  2004/07/08 19:34:49  strk
- * Revision 1.11  2004/07/02 13:28:27  strk
- * Revision 1.10  2004/05/05 10:54:48  strk
- * Removed some private static heap explicit allocation, less cleanup done by
- * the unloader.
- * Revision 1.9  2004/04/16 08:52:52  strk
- * Unload::Release final delete (static heap allocations should be gone now)
- * Revision 1.8  2004/04/16 07:42:06  strk
- * PrecisionModel::Type made an enum instead of a Type.
- * Revision 1.7  2004/04/15 15:11:38  strk
- * Commented out deletion that seems to cause segfaults
- * Revision 1.6  2004/04/15 14:00:31  strk
- * Added new cleanup to Unload::Release
- * Revision 1.5  2004/04/01 10:44:34  ybychkov
- * Revision 1.4  2004/03/29 06:59:25  ybychkov
- * Revision 1.3  2004/03/19 09:48:46  ybychkov
- * Revision 1.2  2003/11/07 01:23:42  pramsey
- * files.
Modified: trunk/src/io/WKTReader.cpp
--- trunk/src/io/WKTReader.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/io/WKTReader.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -457,24 +457,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.42  2006/04/26 16:35:40  strk
- * Revision 1.41  2006/04/10 12:05:35  strk
- * Revision 1.40  2006/03/24 09:52:41  strk
- * USE_INLINE => GEOS_INLINE
- * Revision 1.39  2006/03/22 16:58:35  strk
- * Removed (almost) all inclusions of geom.h.
- * Removed obsoleted .cpp files.
- * Fixed a bug in WKTReader not using the provided CoordinateSequence
- * implementation, optimized out some memory allocations.
Modified: trunk/src/io/Writer.cpp
--- trunk/src/io/Writer.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/io/Writer.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -48,28 +48,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.12  2006/06/01 11:49:36  strk
- * Reduced installed headers form geomgraph namespace
- * Revision 1.11  2006/03/20 18:18:15  strk
- * Revision 1.10  2006/03/06 15:23:14  strk
- * Revision 1.8  2004/07/02 13:28:27  strk
- * files.
Modified: trunk/src/noding/FastNodingValidator.cpp
--- trunk/src/noding/FastNodingValidator.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/noding/FastNodingValidator.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -76,7 +76,3 @@
 } // namespace geos.noding
 } // namespace geos
- * $Log$
Modified: trunk/src/noding/IntersectionAdder.cpp
--- trunk/src/noding/IntersectionAdder.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/noding/IntersectionAdder.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -110,16 +110,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.3  2006/03/15 09:51:12  strk
- * streamlined headers usage
- * Revision 1.2  2006/02/19 19:46:49  strk
- * Revision 1.1  2006/02/16 08:19:07  strk
- * Missed from last commit
Modified: trunk/src/noding/IntersectionFinderAdder.cpp
--- trunk/src/noding/IntersectionFinderAdder.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/noding/IntersectionFinderAdder.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -65,18 +65,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.1  2006/02/14 13:28:26  strk
- * New SnapRounding code ported from JTS-1.7 (not complete yet).
- * Buffer op optimized by using new snaprounding code.
- * Leaks fixed in XMLTester.
Modified: trunk/src/noding/MCIndexNoder.cpp
--- trunk/src/noding/MCIndexNoder.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/noding/MCIndexNoder.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -157,75 +157,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.15  2006/03/24 09:52:41  strk
- * Revision 1.14  2006/03/22 18:12:32  strk
- * indexChain.h header split.
- * Revision 1.13  2006/03/15 09:51:12  strk
- * Revision 1.12  2006/03/14 12:55:56  strk
- * Revision 1.11  2006/03/03 10:46:21  strk
- * Revision 1.10  2006/03/02 12:12:00  strk
- * Revision 1.9  2006/02/28 14:34:05  strk
- * Revision 1.8  2006/02/23 23:17:52  strk
- * - Coordinate::nullCoordinate made private
- * - Simplified Coordinate inline definitions
- * - LMGeometryComponentFilter definition moved to LineMerger.cpp file
- * - Misc cleanups
- * Revision 1.7  2006/02/23 20:05:21  strk
- * Fixed bug in MCIndexNoder constructor making memory checker go crazy, more
- * doxygen-friendly comments, miscellaneous cleanups
- * Revision 1.6  2006/02/23 11:54:20  strk
- * - ScaledNoder
- * Revision 1.5  2006/02/21 16:53:49  strk
- * MCIndexPointSnapper, MCIndexSnapRounder
- * Revision 1.4  2006/02/20 10:14:18  strk
- * Revision 1.3  2006/02/19 19:46:49  strk
- * Revision 1.2  2006/02/18 21:08:09  strk
Modified: trunk/src/noding/NodedSegmentString.cpp
--- trunk/src/noding/NodedSegmentString.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/noding/NodedSegmentString.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -180,8 +180,3 @@
 } // geos::noding
 } // geos
- * $Log$
Modified: trunk/src/noding/NodingValidator.cpp
--- trunk/src/noding/NodingValidator.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/noding/NodingValidator.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -206,92 +206,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.16  2006/03/15 09:51:12  strk
- * Revision 1.15  2006/03/06 19:40:47  strk
- * Revision 1.13  2006/02/19 19:46:49  strk
- * Revision 1.12  2006/02/18 21:08:09  strk
- * Revision 1.11  2006/02/16 08:41:40  strk
- * Fixed include: "util.h" => "geos/util.h"
- * Revision 1.10  2006/02/15 17:19:18  strk
- * Revision 1.9  2006/02/14 13:28:26  strk
- * Revision 1.8  2006/02/09 15:52:47  strk
- * - Renamed DefaultCoordinateSequence to CoordinateArraySequence.
- * - Moved GetNumGeometries() and GetGeometryN() interfaces
- *   from GeometryCollection to Geometry class.
- * - Added getAt(int pos, Coordinate &to) funtion to CoordinateSequence class.
- * - Reworked automake scripts to produce a static lib for each subdir and
- *   then link all subsystem's libs togheter
- * - Moved C-API in it's own top-level dir capi/
- * - Moved source/bigtest and source/test to tests/bigtest and test/xmltester
- * - Fixed PointLocator handling of LinearRings
- * - Changed CoordinateArrayFilter to reduce memory copies
- * - Changed UniqueCoordinateArrayFilter to reduce memory copies
- * - Added CGAlgorithms::isPointInRing() version working with
- *   Coordinate::ConstVect type (faster!)
- * - Ported JTS-1.7 version of ConvexHull with big attention to
- *   memory usage optimizations.
- * - Improved XMLTester output and user interface
- * - geos::geom::util namespace used for geom/util stuff
- * - Improved memory use in geos::geom::util::PolygonExtractor
- * - New ShortCircuitedGeometryVisitor class
- * - New operation/predicate package
- * Revision 1.6  2005/11/25 11:31:21  strk
- * Removed all CoordinateSequence::getSize() calls embedded in for loops.
- * Revision 1.5  2005/06/24 11:09:43  strk
- * Revision 1.4  2004/11/01 16:43:04  strk
- * Mirrored JTS interface of CoordinateSequence, factory and
- * default implementations.
- * Added CoordinateArraySequenceFactory::instance() function.
- * Revision 1.1  2004/03/26 07:48:30  ybychkov
- * "noding" package ported (JTS 1.4)
Modified: trunk/src/noding/Octant.cpp
--- trunk/src/noding/Octant.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/noding/Octant.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -93,27 +93,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.6  2006/03/20 11:42:28  strk
- * Added missing <cmath> include
- * Revision 1.5  2006/03/15 09:51:12  strk
- * Revision 1.4  2006/03/06 19:40:47  strk
- * Revision 1.3  2006/03/03 10:46:21  strk
Modified: trunk/src/noding/ScaledNoder.cpp
--- trunk/src/noding/ScaledNoder.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/noding/ScaledNoder.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -228,66 +228,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.14  2006/06/19 23:33:03  strk
- * Don't *require* CoordinateFilters to define both read-only and read-write methods.
- * Revision 1.13  2006/05/04 14:05:31  strk
- * * source/headers/geos/util/math.h: provided an util::round() method being an inline proxy to call appropriate default rounding function for the whole GEOS codebase. Currently pointing at util::java_math_round() being the last being used.
- * Revision 1.12  2006/05/04 08:30:02  strk
- * removed use of SegmentString::setCoordinates() [dropped]
- * Revision 1.11  2006/05/03 20:05:18  strk
- * Added SQL debugging output
- * Revision 1.10  2006/05/03 15:40:14  strk
- * test SegmentString invariant before and after scaling
- * Revision 1.9  2006/05/03 15:12:35  strk
- * Oops, uninitialized value fix
- * Revision 1.8  2006/05/03 15:00:43  strk
- * Fixed scale() function to remove repeated points *after* rounding. Added brief doxygen class description.
- * Revision 1.7  2006/05/03 09:14:22  strk
- * * source/operation/buffer/OffsetCurveSetBuilder.cpp: used auto_ptr to protect leaks of CoordinateSequence
- * * source/noding/ScaledNoder.cpp, source/headers/geos/noding/ScaledNoder.h: ported JTS bugfix in scale method.
- * Revision 1.6  2006/05/02 16:22:18  strk
- * * source/noding/ScaledNoder.cpp: use java_math_round instead of sym_round.
- * Revision 1.4  2006/03/13 21:19:51  strk
- * Fixed bug in ScaledNoder scaling mechanism (hugly code, due to CoordinateSequence visitor pattern design). Tests are still failing so this possibly needs some other fix. Streamlined includes by implementation file.
- * Revision 1.3  2006/02/23 11:54:20  strk
- * - ScaledNoder
- * Revision 1.1  2006/02/18 21:08:09  strk
Modified: trunk/src/noding/SegmentIntersectionDetector.cpp
--- trunk/src/noding/SegmentIntersectionDetector.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/noding/SegmentIntersectionDetector.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -82,8 +82,3 @@
 } // geos::noding
 } // geos
- * $Log$
Modified: trunk/src/noding/SegmentNode.cpp
--- trunk/src/noding/SegmentNode.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/noding/SegmentNode.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -103,65 +103,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.15  2006/03/15 09:51:12  strk
- * Revision 1.13  2006/03/02 12:12:00  strk
- * Revision 1.12  2006/02/28 17:44:27  strk
- * Added a check in SegmentNode::addSplitEdge to prevent attempts
- * to build SegmentString with less then 2 points.
- * This is a temporary fix for the buffer.xml assertion failure, temporary
- * as Martin Davis review would really be needed there.
- * Revision 1.11  2006/02/28 14:34:05  strk
- * Revision 1.9  2006/02/15 14:59:07  strk
- * JTS-1.7 sync for:
- * noding/SegmentNode.cpp
- * noding/SegmentNodeList.cpp
- * noding/SegmentString.cpp
- * Revision 1.8  2006/02/14 13:28:26  strk
- * Revision 1.7  2005/02/22 18:21:46  strk
- * Changed SegmentNode to contain a *real* Coordinate (not a pointer) to reduce
- * construction costs.
- * Revision 1.6  2005/01/28 09:47:51  strk
- * Replaced sprintf uses with ostringstream.
- * Revision 1.5  2004/11/01 16:43:04  strk
- * Revision 1.4  2004/07/02 13:28:27  strk
- * Revision 1.3  2004/06/15 07:40:30  strk
- * Added missing <stdio.h> include
- * Revision 1.2  2004/05/03 12:09:22  strk
- * newline added at end of file
Modified: trunk/src/noding/SegmentNodeList.cpp
--- trunk/src/noding/SegmentNodeList.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/noding/SegmentNodeList.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -305,40 +305,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.33  2006/06/12 11:29:23  strk
- * Revision 1.32  2006/05/05 10:19:06  strk
- * droppped SegmentString::getContext(), new name is getData() to reflect change in JTS
- * Revision 1.31  2006/05/04 08:35:15  strk
- * noding/SegmentNodeList.cpp: cleanups, changed output operator to be more similar to JTS
- * Revision 1.30  2006/03/15 09:51:12  strk
- * Revision 1.29  2006/03/09 15:39:25  strk
- * Revision 1.28  2006/03/06 19:40:47  strk
- * Revision 1.27  2006/03/03 10:46:21  strk
- * Revision 1.26  2006/03/02 12:12:00  strk
- * Revision 1.25  2006/03/01 16:01:47  strk
- * Fixed const correctness of operator<<(ostream&, SegmentNodeList&) [bug#37]
- * Revision 1.24  2006/02/28 17:44:27  strk
Modified: trunk/src/noding/SegmentStringUtil.cpp
--- trunk/src/noding/SegmentStringUtil.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/noding/SegmentStringUtil.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -20,8 +20,3 @@
 } // geos::noding
 } // geos
- * $Log$
Modified: trunk/src/noding/SimpleNoder.cpp
--- trunk/src/noding/SimpleNoder.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/noding/SimpleNoder.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -67,71 +67,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.10  2006/03/15 09:51:12  strk
- * Revision 1.9  2006/02/23 20:05:21  strk
- * Revision 1.7  2006/02/18 21:08:09  strk
- * Revision 1.6  2006/02/14 13:28:26  strk
- * Revision 1.4  2005/11/25 11:31:21  strk
Modified: trunk/src/noding/SingleInteriorIntersectionFinder.cpp
--- trunk/src/noding/SingleInteriorIntersectionFinder.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/noding/SingleInteriorIntersectionFinder.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -67,7 +67,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/noding/snapround/HotPixel.cpp
--- trunk/src/noding/snapround/HotPixel.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/noding/snapround/HotPixel.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -190,40 +190,3 @@
 } // namespace geos.noding.snapround
 } // namespace geos
- * $Log$
- * Revision 1.8  2006/05/03 17:51:24  strk
- * system headers included after package headers
- * Revision 1.7  2006/03/24 09:52:41  strk
- * Revision 1.6  2006/03/14 12:55:56  strk
- * Revision 1.4  2006/02/21 16:53:49  strk
Modified: trunk/src/noding/snapround/SimpleSnapRounder.cpp
--- trunk/src/noding/snapround/SimpleSnapRounder.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/noding/snapround/SimpleSnapRounder.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -223,51 +223,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.11  2006/05/05 15:40:39  strk
- * Had nodind validation error throw an exception for SimpleSnapRounder
- * and MCIndexSnapRounder
- * Revision 1.10  2006/05/03 17:54:58  strk
- * Uncommented correctness checker
- * Revision 1.9  2006/05/03 15:49:16  strk
- * fixed bug in SimpleSnapRounder::computeSnaps, trying to access out-of-bound vector element.
- * Revision 1.8  2006/05/03 15:02:49  strk
- * moved some implementations from header to .cpp file (taken out of inline)
- * Revision 1.7  2006/03/15 09:51:13  strk
- * Revision 1.6  2006/03/03 10:46:21  strk
- * Revision 1.3  2006/02/18 21:08:09  strk
- * Revision 1.2  2006/02/15 17:19:18  strk
Modified: trunk/src/operation/GeometryGraphOperation.cpp
--- trunk/src/operation/GeometryGraphOperation.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/GeometryGraphOperation.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -118,26 +118,3 @@
 } // namespace geos.operation
 } // namespace geos
- * $Log$
- * Revision 1.23  2006/04/03 15:54:34  strk
- * - getArgGeometry() parameter type changed from 'int' to 'unsigned int'
- * - Added port informations
- * - minor assertions checking
- * - minor cleanups
- * Revision 1.22  2006/03/21 21:42:54  strk
- * planargraph.h header split, planargraph:: classes renamed to match JTS symbols
- * Revision 1.21  2006/03/02 14:34:43  strk
- * Revision 1.20  2006/02/27 09:05:33  strk
- * Revision 1.19  2006/02/19 19:46:49  strk
Modified: trunk/src/operation/buffer/BufferSubgraph.cpp
--- trunk/src/operation/buffer/BufferSubgraph.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/buffer/BufferSubgraph.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -356,17 +356,3 @@
 } // namespace geos.operation.buffer
 } // namespace geos
- * $Log$
- * Revision 1.34  2006/06/12 11:29:23  strk
- * Revision 1.33  2006/05/04 12:33:32  strk
- * Added some comments about RightmostEdgeFinder only considering forward DirectedEdge
- * Revision 1.32  2006/03/22 11:18:39  strk
- * Changed back 'unable to find edge to compute depths' from assertion to TopologyException
Modified: trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp
--- trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -379,24 +379,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.36  2006/06/12 11:29:23  strk
- * Revision 1.35  2006/06/09 07:42:13  strk
- * * source/geomgraph/GeometryGraph.cpp, source/operation/buffer/OffsetCurveSetBuilder.cpp, source/operation/overlay/OverlayOp.cpp, source/operation/valid/RepeatedPointTester.cpp: Fixed warning after Polygon ring accessor methods changed to work with size_t. Small optimizations in loops.
- * Revision 1.34  2006/05/03 09:14:22  strk
- * Revision 1.33  2006/03/27 17:04:18  strk
- * Cleanups and explicit initializations
Modified: trunk/src/operation/buffer/RightmostEdgeFinder.cpp
--- trunk/src/operation/buffer/RightmostEdgeFinder.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/buffer/RightmostEdgeFinder.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -257,94 +257,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.22  2006/06/12 11:29:23  strk
- * Revision 1.21  2006/05/03 15:05:36  strk
- * Assertions checking
- * Revision 1.20  2006/04/05 09:20:25  strk
- * Added port informations and many assertion checking.
- * Fixed bug in getRightmostSide() method ( a "testing-only" corner case )
- * Revision 1.19  2006/03/14 00:19:40  strk
- * opBuffer.h split, streamlined headers in some (not all) files in operation/buffer/
- * Revision 1.18  2006/03/09 16:46:49  strk
- * geos::geom namespace definition, first pass at headers split
- * Revision 1.17  2006/03/06 19:40:47  strk
- * Revision 1.16  2006/03/03 10:46:21  strk
- * Revision 1.15  2006/02/23 23:17:52  strk
- * - Misc cleanups
- * Revision 1.14  2006/02/19 19:46:49  strk
- * Revision 1.12  2005/11/25 11:31:21  strk
- * Revision 1.11  2005/05/19 10:29:28  strk
- * Removed some CGAlgorithms instances substituting them with direct calls
- * to the static functions. Interfaces accepting CGAlgorithms pointers kept
- * for backward compatibility but modified to make the argument optional.
- * Fixed a small memory leak in OffsetCurveBuilder::getRingCurve.
- * Inlined some smaller functions encountered during bug hunting.
- * Updated Copyright notices in the touched files.
- * Revision 1.10  2005/02/22 17:10:47  strk
- * Reduced CoordinateSequence::getSize() calls.
- * Revision 1.9  2004/07/08 19:34:49  strk
- * Revision 1.8  2004/07/02 13:28:28  strk
- * Revision 1.7  2004/04/10 08:40:01  ybychkov
- * "operation/buffer" upgraded to JTS 1.4
- * files.
Modified: trunk/src/operation/buffer/SubgraphDepthLocater.cpp
--- trunk/src/operation/buffer/SubgraphDepthLocater.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/buffer/SubgraphDepthLocater.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -357,126 +357,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.29  2006/06/12 11:29:23  strk
- * Revision 1.28  2006/03/20 10:13:15  strk
- * Bug #71 - Missing <algorithm>
- * Revision 1.27  2006/03/17 13:24:59  strk
- * opOverlay.h header splitted. Reduced header inclusions in operation/overlay implementation files. ElevationMatrixFilter code moved from own file to ElevationMatrix.cpp (ideally a class-private).
- * Revision 1.26  2006/03/15 18:57:39  strk
- * small cleanup
- * Revision 1.25  2006/03/15 15:50:12  strk
- * const correctness, cleanups
- * Revision 1.24  2006/03/15 12:52:56  strk
- * DepthSegment class moved inside SubgraphDepthLocator implementaion
- * as it was private to this file in JTS. Also, changed to reduce
- * copies of LineSegment copies.
- * Revision 1.23  2006/03/14 00:19:40  strk
- * Revision 1.22  2006/03/09 16:46:49  strk
- * Revision 1.20  2006/03/02 12:12:01  strk
- * Revision 1.19  2006/03/02 09:46:04  strk
- * cleaned up debugging lines
- * Revision 1.18  2006/03/01 17:16:39  strk
- * LineSegment class made final and optionally (compile-time) inlined.
- * Reduced heap allocations in Centroid{Area,Line,Point} and InteriorPoint{Area,Line,Point}.
- * Revision 1.17  2006/02/19 19:46:49  strk
- * Revision 1.16  2006/01/31 19:07:34  strk
- * Revision 1.15  2005/11/08 20:12:44  strk
- * Memory overhead reductions in buffer operations.
- * Revision 1.14  2005/07/11 10:27:14  strk
- * Fixed initializzazion lists
- * Revision 1.13  2005/06/30 18:31:48  strk
- * Ported SubgraphDepthLocator optimizations from JTS code
- * Revision 1.12  2005/06/28 21:13:43  strk
- * Fixed a bug introduced by LineSegment skip - made LineSegment skip a compile-time optione
- * Revision 1.11  2005/06/27 21:58:31  strk
- * Bugfix in DepthSegmentLT as suggested by Graeme Hiebert
- * Revision 1.10  2005/06/27 21:24:54  strk
- * Fixed bug just-introduced with optimization.
- * Revision 1.9  2005/06/27 21:21:21  strk
- * Reduced Coordinate copies due to LineSegment overuse
- * Revision 1.8  2005/05/23 15:13:00  strk
- * Added debugging output
- * Revision 1.7  2005/05/20 16:15:41  strk
- * Code cleanups
- * Revision 1.6  2005/05/19 10:29:28  strk
- * Revision 1.5  2004/07/08 19:34:49  strk
- * Revision 1.4  2004/07/02 13:28:28  strk
- * Revision 1.3  2004/05/05 12:29:44  strk
- * memleak fixed in ::getDepth
- * Revision 1.2  2004/05/03 22:56:44  strk
- * Revision 1.1  2004/04/10 08:40:01  ybychkov
Modified: trunk/src/operation/distance/ConnectedElementLocationFilter.cpp
--- trunk/src/operation/distance/ConnectedElementLocationFilter.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/distance/ConnectedElementLocationFilter.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -67,17 +67,3 @@
 } // namespace geos.operation.distance
 } // namespace geos
- * $Log$
- * Revision 1.7  2006/03/21 17:55:01  strk
- * opDistance.h header split
Modified: trunk/src/operation/distance/ConnectedElementPointFilter.cpp
--- trunk/src/operation/distance/ConnectedElementPointFilter.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/distance/ConnectedElementPointFilter.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -56,11 +56,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.11  2006/03/21 17:55:01  strk
Modified: trunk/src/operation/distance/DistanceOp.cpp
--- trunk/src/operation/distance/DistanceOp.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/distance/DistanceOp.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -628,22 +628,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.24  2006/06/12 11:29:24  strk
- * Revision 1.23  2006/03/24 09:52:41  strk
- * Revision 1.22  2006/03/23 12:12:01  strk
- * Fixes to allow build with -DGEOS_INLINE
- * Revision 1.21  2006/03/21 17:55:01  strk
- * Revision 1.20  2006/03/03 10:46:21  strk
Modified: trunk/src/operation/distance/GeometryLocation.cpp
--- trunk/src/operation/distance/GeometryLocation.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/distance/GeometryLocation.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -79,11 +79,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.6  2006/03/21 17:55:01  strk
Modified: trunk/src/operation/linemerge/EdgeString.cpp
--- trunk/src/operation/linemerge/EdgeString.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/linemerge/EdgeString.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -100,11 +100,3 @@
 } // namespace geos.operation.linemerge
 } // namespace geos
- * $Log$
- * Revision 1.10  2006/03/22 10:13:54  strk
- * opLinemerge.h split
Modified: trunk/src/operation/linemerge/LineMergeDirectedEdge.cpp
--- trunk/src/operation/linemerge/LineMergeDirectedEdge.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/linemerge/LineMergeDirectedEdge.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -65,14 +65,3 @@
 } //namespace geos
- * $Log$
- * Revision 1.8  2006/03/22 10:13:54  strk
- * Revision 1.7  2006/03/21 21:42:54  strk
Modified: trunk/src/operation/linemerge/LineMergeEdge.cpp
--- trunk/src/operation/linemerge/LineMergeEdge.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/linemerge/LineMergeEdge.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -45,11 +45,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.6  2006/03/22 10:13:54  strk
Modified: trunk/src/operation/linemerge/LineMergeGraph.cpp
--- trunk/src/operation/linemerge/LineMergeGraph.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/linemerge/LineMergeGraph.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -127,14 +127,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.15  2006/03/22 10:13:54  strk
- * Revision 1.14  2006/03/21 21:42:54  strk
Modified: trunk/src/operation/linemerge/LineMerger.cpp
--- trunk/src/operation/linemerge/LineMerger.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/linemerge/LineMerger.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -234,18 +234,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.15  2006/06/12 11:29:24  strk
- * Revision 1.14  2006/03/22 10:13:54  strk
- * Revision 1.13  2006/03/21 21:42:54  strk
Modified: trunk/src/operation/linemerge/LineSequencer.cpp
--- trunk/src/operation/linemerge/LineSequencer.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/linemerge/LineSequencer.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -450,22 +450,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.10  2006/06/12 10:49:43  strk
- * Revision 1.9  2006/03/24 11:04:44  strk
- * Changed assert() with Assert::isTrue in addReverseSubpath
- * Revision 1.8  2006/03/24 10:44:07  strk
- * Fixed to build with -DNDEBUG
- * Revision 1.7  2006/03/22 10:13:54  strk
- * Revision 1.6  2006/03/21 21:42:54  strk
Modified: trunk/src/operation/overlay/EdgeSetNoder.cpp
--- trunk/src/operation/overlay/EdgeSetNoder.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/overlay/EdgeSetNoder.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -59,32 +59,3 @@
 } // namespace geos.operation.overlay
 } // namespace geos
- * $Log$
- * Revision 1.11  2006/03/17 13:24:59  strk
- * Revision 1.10  2006/03/09 16:46:49  strk
- * Revision 1.9  2006/03/03 10:46:22  strk
- * Revision 1.7  2005/11/16 15:49:54  strk
- * Reduced gratuitous heap allocations.
- * Revision 1.6  2004/07/02 13:28:28  strk
- * files.
Modified: trunk/src/operation/overlay/ElevationMatrix.cpp
--- trunk/src/operation/overlay/ElevationMatrix.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/overlay/ElevationMatrix.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -244,35 +244,3 @@
 } // namespace geos;
- * $Log$
- * Revision 1.14  2006/03/17 13:24:59  strk
- * Revision 1.13  2006/03/09 16:46:49  strk
- * Revision 1.11  2006/03/03 10:46:22  strk
- * Revision 1.10  2006/03/02 12:12:01  strk
- * Revision 1.7  2005/12/11 10:41:56  strk
- * Fixed premature initialization of average Z value in ElevationMatrixFilter
Modified: trunk/src/operation/overlay/ElevationMatrixCell.cpp
--- trunk/src/operation/overlay/ElevationMatrixCell.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/overlay/ElevationMatrixCell.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -89,30 +89,3 @@
- * $Log$
- * Revision 1.6  2006/03/17 13:24:59  strk
- * Revision 1.5  2006/03/03 10:46:22  strk
- * Revision 1.3  2004/11/29 16:05:33  strk
- * Fixed a bug in LineIntersector::interpolateZ causing NaN values
- * to come out.
- * Handled dimensional collapses in ElevationMatrix.
- * Added ISNAN macro and changed ISNAN/FINITE macros to avoid
- * dispendious isnan() and finite() calls.
- * Revision 1.2  2004/11/26 09:22:50  strk
- * Added FINITE(x) macro and its use.
- * Made input geoms average Z computation optional in OverlayOp.
- * Revision 1.1  2004/11/23 16:22:49  strk
- * Added ElevationMatrix class and components to do post-processing draping of overlayed geometries.
Modified: trunk/src/operation/overlay/MaximalEdgeRing.cpp
--- trunk/src/operation/overlay/MaximalEdgeRing.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/overlay/MaximalEdgeRing.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -140,22 +140,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.19  2006/03/27 16:02:34  strk
- * Added INL file for MinimalEdgeRing, added many debugging blocks,
- * fixed memory leak in ConnectedInteriorTester (bug #59)
- * Revision 1.18  2006/03/17 13:24:59  strk
- * Revision 1.17  2006/03/14 17:08:04  strk
- * comments cleanup, integrity checks
- * Revision 1.16  2006/03/09 18:18:39  strk
- * Added memory-friendly MaximalEdgeRing::buildMinimalRings() implementation.
- * Applied patch to IsValid operation from JTS-1.7.1
Modified: trunk/src/operation/overlay/MinimalEdgeRing.cpp
--- trunk/src/operation/overlay/MinimalEdgeRing.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/overlay/MinimalEdgeRing.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -52,17 +52,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.14  2006/03/27 16:02:34  strk
- * Revision 1.13  2006/03/17 13:24:59  strk
Modified: trunk/src/operation/overlay/OverlayNodeFactory.cpp
--- trunk/src/operation/overlay/OverlayNodeFactory.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/overlay/OverlayNodeFactory.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -44,60 +44,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.10  2006/03/17 13:24:59  strk
- * Revision 1.8  2005/11/21 16:03:20  strk
- * Coordinate interface change:
- *         Removed setCoordinate call, use assignment operator
- *         instead. Provided a compile-time switch to
- *         make copy ctor and assignment operators non-inline
- *         to allow for more accurate profiling.
- * Coordinate copies removal:
- *         NodeFactory::createNode() takes now a Coordinate reference
- *         rather then real value. This brings coordinate copies
- *         in the testLeaksBig.xml test from 654818 to 645991
- *         (tested in 2.1 branch). In the head branch Coordinate
- *         copies are 222198.
- *         Removed useless coordinate copies in ConvexHull
- *         operations
- * STL containers heap allocations reduction:
- *         Converted many containers element from
- *         pointers to real objects.
- *         Made some use of .reserve() or size
- *         initialization when final container size is known
- *         in advance.
- * Stateless classes allocations reduction:
- *         Provided ::instance() function for
- *         NodeFactories, to avoid allocating
- *         more then one (they are all
- *         stateless).
- * HCoordinate improvements:
- *         Changed HCoordinate constructor by HCoordinates
- *         take reference rather then real objects.
- *         Changed HCoordinate::intersection to avoid
- *         a new allocation but rather return into a provided
- *         storage. LineIntersector changed to reflect
- *         the above change.
- * Revision 1.7  2004/07/02 13:28:29  strk
- * files.
Modified: trunk/src/operation/overlay/validate/FuzzyPointLocator.cpp
--- trunk/src/operation/overlay/validate/FuzzyPointLocator.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/overlay/validate/FuzzyPointLocator.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -150,7 +150,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/operation/overlay/validate/OverlayResultValidator.cpp
--- trunk/src/operation/overlay/validate/OverlayResultValidator.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/overlay/validate/OverlayResultValidator.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -247,7 +247,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/operation/polygonize/EdgeRing.cpp
--- trunk/src/operation/polygonize/EdgeRing.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/polygonize/EdgeRing.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -268,17 +268,3 @@
 } // namespace geos.operation.polygonize
 } // namespace geos
- * $Log$
- * Revision 1.2  2006/05/02 14:32:49  strk
- * Added port info for polygonize/EdgeRing class, polygonize/EdgeRing.h header
- * not installed.
- * Revision 1.1  2006/05/02 14:22:30  strk
- * * source/operation/polygonize/: polygonizeEdgeRing.cpp renamed to EdgeRing.cpp, to follow JTS naming.
- * Revision 1.16  2006/03/22 11:19:06  strk
- * opPolygonize.h headers split.
Modified: trunk/src/operation/polygonize/PolygonizeDirectedEdge.cpp
--- trunk/src/operation/polygonize/PolygonizeDirectedEdge.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/polygonize/PolygonizeDirectedEdge.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -110,11 +110,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.7  2006/03/22 11:19:06  strk
Modified: trunk/src/operation/polygonize/PolygonizeEdge.cpp
--- trunk/src/operation/polygonize/PolygonizeEdge.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/polygonize/PolygonizeEdge.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -38,10 +38,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.5  2006/03/22 11:19:06  strk
Modified: trunk/src/operation/polygonize/PolygonizeGraph.cpp
--- trunk/src/operation/polygonize/PolygonizeGraph.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/polygonize/PolygonizeGraph.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -481,126 +481,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.18  2006/03/22 11:19:06  strk
- * Revision 1.17  2006/03/21 21:42:54  strk
- * Revision 1.16  2006/03/06 19:40:47  strk
- * Revision 1.15  2006/03/03 10:46:22  strk
- * Revision 1.13  2006/01/31 19:07:34  strk
- * Revision 1.12  2005/12/09 11:36:38  strk
- * Small leak plugged in CAPI::GEOSHasZ() and in
- * invalid input to PolygonizeGraph (again)
- * Revision 1.11  2005/12/09 10:03:46  strk
- * Fixed a bug making PolygonizeGraph choking on invalid LineStrings.
- * Minor optimizations in Polygonizer loops.
- *         operations
- *         in advance.
- *         stateless).
- * Revision 1.9  2005/11/15 12:14:05  strk
- * Reduced heap allocations, made use of references when appropriate,
- * small optimizations here and there.
- * Revision 1.8  2004/12/14 10:35:44  strk
- * Comments cleanup. PolygonizeGraph keeps track of generated CoordinateSequence
- * for delayed destruction.
- * Revision 1.7  2004/12/08 13:54:44  strk
- * gcc warnings checked and fixed, general cleanups.
- * Revision 1.6  2004/10/26 16:09:21  strk
- * Some more intentation and envelope equality check fix.
- * Revision 1.5  2004/10/19 19:51:14  strk
- * Fixed many leaks and bugs in Polygonizer.
- * Output still bogus.
- * Revision 1.4  2004/10/13 10:03:02  strk
- * Revision 1.3  2004/07/08 19:34:50  strk
- * Revision 1.2  2004/07/02 13:28:29  strk
- * Revision 1.1  2004/04/08 04:53:56  ybychkov
- * "operation/polygonize" ported from JTS 1.4
Modified: trunk/src/operation/polygonize/Polygonizer.cpp
--- trunk/src/operation/polygonize/Polygonizer.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/polygonize/Polygonizer.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -312,49 +312,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.13  2006/03/22 11:19:06  strk
- * Revision 1.12  2006/03/03 10:46:22  strk
- * Revision 1.11  2006/03/02 12:12:01  strk
- * Renamed DEBUG macros to GEOS_DEBUG, all wrapped in #ifndef block to allow global override (bug#43)
- * Revision 1.10  2006/02/19 19:46:49  strk
- * Revision 1.9  2005/12/09 10:32:28  strk
- * Cleaned up debugging line left over from previous commit
- * Revision 1.8  2005/12/09 10:03:46  strk
- * Revision 1.7  2005/06/17 15:08:06  strk
- * Polygonizer segfault fix
- * Revision 1.6  2004/12/08 13:54:44  strk
- * Revision 1.5  2004/10/27 13:57:07  strk
- * Added some debugging lines (disabled by default)
- * Revision 1.4  2004/10/26 16:09:21  strk
- * Revision 1.3  2004/10/19 19:51:14  strk
Modified: trunk/src/operation/relate/EdgeEndBundleStar.cpp
--- trunk/src/operation/relate/EdgeEndBundleStar.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/relate/EdgeEndBundleStar.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -80,16 +80,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.13  2006/03/21 13:11:29  strk
- * opRelate.h header split
- * Revision 1.12  2006/03/20 16:57:44  strk
- * Revision 1.11  2006/02/19 19:46:50  strk
Modified: trunk/src/operation/relate/RelateNodeFactory.cpp
--- trunk/src/operation/relate/RelateNodeFactory.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/relate/RelateNodeFactory.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -46,15 +46,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.10  2006/03/21 13:11:29  strk
- * Revision 1.9  2006/03/20 16:57:44  strk
- * Revision 1.8  2006/02/19 19:46:50  strk
Modified: trunk/src/operation/relate/RelateNodeGraph.cpp
--- trunk/src/operation/relate/RelateNodeGraph.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/relate/RelateNodeGraph.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -149,18 +149,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.19  2006/03/21 13:11:29  strk
- * Revision 1.18  2006/03/20 16:57:44  strk
- * Revision 1.17  2006/03/03 10:46:22  strk
- * Removed 'using namespace' from headers, added missing headers in .cpp files, removed useless includes in headers (bug#46)
- * Revision 1.16  2006/02/19 19:46:50  strk
Modified: trunk/src/operation/relate/RelateOp.cpp
--- trunk/src/operation/relate/RelateOp.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/relate/RelateOp.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -78,18 +78,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.18  2006/03/17 16:48:55  strk
- * Revision 1.17  2006/02/19 19:46:50  strk
Modified: trunk/src/operation/valid/ConnectedInteriorTester.cpp
--- trunk/src/operation/valid/ConnectedInteriorTester.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/valid/ConnectedInteriorTester.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -354,33 +354,3 @@
 } // namespace geos.operation.valid
 } // namespace geos
- * $Log$
- * Revision 1.29  2006/06/12 11:29:24  strk
- * unsigned int => size_t
- * Revision 1.28  2006/04/06 12:45:28  strk
- * Delayed deletion of newly allocated MaximalEdgeRings.
- * Existing 'valid' operation tests don't should instability with
- * this patch.
- * Revision 1.27  2006/03/29 13:53:59  strk
- * EdgeRing equipped with Invariant testing function and lots of exceptional assertions. Removed useless heap allocations, and pointers usages.
- * Revision 1.26  2006/03/27 16:02:34  strk
- * Revision 1.25  2006/03/27 14:20:46  strk
- * Added paranoid assertion checking and a note in header about responsibility of return from buildMaximalEdgeRings()
- * Revision 1.24  2006/03/20 16:57:44  strk
- * Revision 1.23  2006/03/17 16:48:55  strk
Modified: trunk/src/operation/valid/ConsistentAreaTester.cpp
--- trunk/src/operation/valid/ConsistentAreaTester.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/valid/ConsistentAreaTester.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -125,24 +125,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.17  2006/03/27 10:37:59  strk
- * Reduced heap allocations and probability of error by making LineIntersector
- * and RelateNodeGraph part of ConsistentAreaTester class .
- * Revision 1.16  2006/03/21 13:11:29  strk
- * Revision 1.15  2006/03/20 16:57:44  strk
- * Revision 1.14  2006/03/17 16:48:55  strk
Modified: trunk/src/operation/valid/IndexedNestedRingTester.h
--- trunk/src/operation/valid/IndexedNestedRingTester.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/valid/IndexedNestedRingTester.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -105,8 +105,3 @@
 } // namespace geos
 #endif // GEOS_OP_VALID_OFFSETCURVEVERTEXLIST_H
- * $Log$
Modified: trunk/src/operation/valid/QuadtreeNestedRingTester.cpp
--- trunk/src/operation/valid/QuadtreeNestedRingTester.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/valid/QuadtreeNestedRingTester.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -130,24 +130,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.25  2006/06/12 11:29:24  strk
- * Revision 1.24  2006/03/29 11:48:53  strk
- * Removed useless heap allocations in construction, enforced const correctness
- * indexQuadtree.h split
- * Revision 1.21  2006/03/17 16:48:55  strk
Modified: trunk/src/operation/valid/RepeatedPointTester.cpp
--- trunk/src/operation/valid/RepeatedPointTester.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/valid/RepeatedPointTester.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -149,71 +149,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.20  2006/06/09 07:42:13  strk
- * Revision 1.19  2006/04/07 09:54:30  strk
- * Geometry::getNumGeometries() changed to return 'unsigned int'
- * rather then 'int'
- * Revision 1.17  2006/03/09 16:46:49  strk
- * geos::util namespace. New GeometryCollection::iterator interface, many cleanups.
- * Revision 1.15  2006/02/19 19:46:50  strk
- * Revision 1.14  2006/02/09 15:52:47  strk
- * Revision 1.11  2004/07/08 19:34:50  strk
- * Revision 1.10  2004/07/02 13:28:29  strk
- * Revision 1.9  2003/11/07 01:23:42  pramsey
- * files.
- * Revision 1.8  2003/10/16 17:33:20  strk
- * dropped useless string() cast
Modified: trunk/src/operation/valid/SimpleNestedRingTester.cpp
--- trunk/src/operation/valid/SimpleNestedRingTester.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/valid/SimpleNestedRingTester.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -69,71 +69,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.16  2006/06/12 11:29:24  strk
- * Revision 1.14  2006/03/17 16:48:56  strk
- * Revision 1.13  2006/03/06 19:40:47  strk
- * Revision 1.12  2006/02/19 19:46:50  strk
- * Revision 1.11  2006/01/31 19:07:34  strk
- * Revision 1.10  2005/11/04 11:04:09  strk
- * Ported revision 1.38 of IsValidOp.java (adding closed Ring checks).
- * Changed NestedRingTester classes to use Coorinate pointers
- * rather then actual objects, to speedup NULL tests.
- * Added JTS port revision when applicable.
- * Revision 1.9  2004/07/08 19:34:50  strk
- * Revision 1.8  2004/07/02 13:28:29  strk
- * Revision 1.7  2004/03/29 06:59:25  ybychkov
- * "noding/snapround" package ported (JTS 1.4);
- * "operation", "operation/valid", "operation/relate" and "operation/overlay" upgraded to JTS 1.4;
- * "geom" partially upgraded.
- * Revision 1.6  2003/11/07 01:23:43  pramsey
- * Add standard CVS headers licence notices and copyrights to all cpp and h
- * files.
Modified: trunk/src/operation/valid/SweeplineNestedRingTester.cpp
--- trunk/src/operation/valid/SweeplineNestedRingTester.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/valid/SweeplineNestedRingTester.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -103,16 +103,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.18  2006/06/12 11:29:24  strk
- * Revision 1.17  2006/04/09 04:09:43  mloskot
- * Removed redundant semicolon reported by g++ -pedantic.
- * Revision 1.16  2006/03/21 10:01:30  strk
Modified: trunk/src/operation/valid/TopologyValidationError.cpp
--- trunk/src/operation/valid/TopologyValidationError.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/operation/valid/TopologyValidationError.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -87,55 +87,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.16  2006/03/27 10:36:51  strk
- * added missing space in exception message
- * Revision 1.14  2006/03/03 10:46:22  strk
- * Revision 1.13  2006/03/01 10:48:55  strk
- * Changed static TopologyValidationError::errMsg[] from 'string' to 'const char*'
- * to reduce dynamic memory allocations.
- * Revision 1.12  2006/02/23 23:17:52  strk
- * - Misc cleanups
- * Revision 1.10  2006/01/20 19:11:09  strk
- * Updated last port info
- * Revision 1.9  2005/11/04 11:04:09  strk
- * Revision 1.8  2004/11/05 11:41:57  strk
- * Made IsValidOp handle IllegalArgumentException throw from GeometryGraph
- * as a sign of invalidity (just for Polygon geometries).
- * Removed leaks generated by this specific exception.
- * Revision 1.7  2004/09/13 10:14:47  strk
- * Added INVALID_COORDINATE code num and error message.
- * Revision 1.6  2004/07/02 13:28:29  strk
- * Revision 1.5  2003/11/07 01:23:43  pramsey
- * files.
Modified: trunk/src/planargraph/DirectedEdge.cpp
--- trunk/src/planargraph/DirectedEdge.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/planargraph/DirectedEdge.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -182,13 +182,3 @@
 } // namespace planargraph
 } // namespace geos
- * $Log$
- * Revision 1.2  2006/06/12 15:46:09  strk
- * provided a memory friendly version of toEdges() method.
- * Revision 1.1  2006/03/21 21:42:54  strk
Modified: trunk/src/planargraph/DirectedEdgeStar.cpp
--- trunk/src/planargraph/DirectedEdgeStar.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/planargraph/DirectedEdgeStar.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -179,10 +179,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/planargraph/Edge.cpp
--- trunk/src/planargraph/Edge.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/planargraph/Edge.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -89,10 +89,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/planargraph/Node.cpp
--- trunk/src/planargraph/Node.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/planargraph/Node.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -61,13 +61,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.2  2006/06/12 15:47:08  strk
- * implemented missing getEdgesBetween() method (untested).
Modified: trunk/src/planargraph/NodeMap.cpp
--- trunk/src/planargraph/NodeMap.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/planargraph/NodeMap.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -90,10 +90,3 @@
 } //namespace planargraph
 } //namespace geos
- * $Log$
Modified: trunk/src/planargraph/PlanarGraph.cpp
--- trunk/src/planargraph/PlanarGraph.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/planargraph/PlanarGraph.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -149,13 +149,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.4  2006/06/12 10:49:43  strk
- * Revision 1.3  2006/03/21 21:42:54  strk
Modified: trunk/src/planargraph/Subgraph.cpp
--- trunk/src/planargraph/Subgraph.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/planargraph/Subgraph.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -43,10 +43,3 @@
 } // namespace geos
- * $Log$
Modified: trunk/src/planargraph/algorithm/ConnectedSubgraphFinder.cpp
--- trunk/src/planargraph/algorithm/ConnectedSubgraphFinder.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/planargraph/algorithm/ConnectedSubgraphFinder.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -95,10 +95,3 @@
 } // namespace geos.planargraph.algorithm
 } // namespace geos
- * $Log$
- * Revision 1.5  2006/03/21 21:42:54  strk
Modified: trunk/src/precision/CommonBits.cpp
--- trunk/src/precision/CommonBits.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/precision/CommonBits.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -94,29 +94,5 @@
 	return (double)commonBits;
-//* A representation of the Double bits formatted for easy readability
-//String toString(int64 bits)
-//double x = Double.int64BitsToDouble(bits);
-//String numStr = int64.toBinaryString(bits);
-//String padStr = "0000000000000000000000000000000000000000000000000000000000000000" + numStr;
-//String bitStr = padStr.substring(padStr.length() - 64);
-//String str = bitStr.substring(0, 1) + "  "
-//+ bitStr.substring(1, 12) + "(exp) "
-//+ bitStr.substring(12)
-//+ " [ " + x + " ]";
-//return str;
 } // namespace geos.precision
 } // namespace geos
- * $Log$
- * Revision 1.4  2006/03/23 09:17:19  strk
- * precision.h header split, minor optimizations
Modified: trunk/src/precision/CommonBitsOp.cpp
--- trunk/src/precision/CommonBitsOp.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/precision/CommonBitsOp.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -169,23 +169,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.10  2006/04/13 23:28:26  strk
- * "always build before commit" (forgot a closing paren)
- * Revision 1.9  2006/04/13 23:23:52  strk
- * fixed bug in binary ops failing to consistently reduce operands.
- * Revision 1.8  2006/04/07 08:27:12  strk
- * debugging blocks
- * Revision 1.7  2006/04/06 14:36:51  strk
- * Cleanup in geos::precision namespace (leaks plugged, auto_ptr use, ...)
- * Revision 1.6  2006/03/23 09:17:19  strk
Modified: trunk/src/precision/CommonBitsRemover.cpp
--- trunk/src/precision/CommonBitsRemover.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/precision/CommonBitsRemover.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -182,22 +182,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.9  2006/04/07 08:28:25  strk
- * debugging lines, assertions
- * Revision 1.8  2006/04/06 14:36:51  strk
- * Revision 1.7  2006/03/23 09:17:19  strk
- * Revision 1.6  2006/03/06 19:40:47  strk
- * Revision 1.5  2006/03/02 16:21:26  strk
- * geos::precision namespace added
Modified: trunk/src/precision/EnhancedPrecisionOp.cpp
--- trunk/src/precision/EnhancedPrecisionOp.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/precision/EnhancedPrecisionOp.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -246,16 +246,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.9  2006/04/07 08:31:37  strk
- * Debugging lines
Modified: trunk/src/precision/SimpleGeometryPrecisionReducer.cpp
--- trunk/src/precision/SimpleGeometryPrecisionReducer.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/precision/SimpleGeometryPrecisionReducer.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -174,13 +174,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.14  2006/04/03 13:56:54  strk
- * Made externally-owned PrecisionModel  const
- * Revision 1.13  2006/03/23 09:17:19  strk
Modified: trunk/src/simplify/DouglasPeuckerLineSimplifier.cpp
--- trunk/src/simplify/DouglasPeuckerLineSimplifier.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/simplify/DouglasPeuckerLineSimplifier.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -115,16 +115,3 @@
 } // namespace geos::simplify
 } // namespace geos
- * $Log$
- * Revision 1.3  2006/06/12 11:29:24  strk
- * Revision 1.2  2006/06/03 22:29:39  hobu
- * Use a fully qualified namespace for LineSegment because we're inside of geos::simplify at the time
- * Revision 1.1  2006/04/03 10:16:11  strk
- * DouglasPeuckerLineSimplifier class port
Modified: trunk/src/simplify/DouglasPeuckerSimplifier.cpp
--- trunk/src/simplify/DouglasPeuckerSimplifier.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/simplify/DouglasPeuckerSimplifier.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -192,13 +192,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.2  2006/04/13 16:44:49  strk
- * Fixed a bug in DPTransformer handling of MultiPolygons
- * Revision 1.1  2006/04/11 16:04:34  strk
- * geos::simplify::DouglasPeukerSimplifier class + unit test
Modified: trunk/src/simplify/LineSegmentIndex.cpp
--- trunk/src/simplify/LineSegmentIndex.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/simplify/LineSegmentIndex.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -170,19 +170,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.4  2006/06/12 17:18:56  strk
- * LineSegmentIndex: explicitly initialized parent class in constructors.
- * Revision 1.2  2006/04/13 09:28:09  mloskot
- * Removed definition of copy ctor and assignment operator for LineSegmentString class.
- * Revision 1.1  2006/04/12 15:20:37  strk
- * LineSegmentIndex class
Modified: trunk/src/simplify/TaggedLineSegment.cpp
--- trunk/src/simplify/TaggedLineSegment.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/simplify/TaggedLineSegment.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -73,14 +73,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.2  2006/04/12 17:19:57  strk
- * Ported TaggedLineStringSimplifier class, made LineSegment class
- * polymorphic to fix derivation of TaggedLineSegment
- * Revision 1.1  2006/04/12 14:22:12  strk
- * Initial implementation of TaggedLineSegment and TaggedLineString classes
Modified: trunk/src/simplify/TaggedLineString.cpp
--- trunk/src/simplify/TaggedLineString.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/simplify/TaggedLineString.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -248,24 +248,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.5  2006/06/12 11:29:24  strk
- * Revision 1.4  2006/04/13 21:52:35  strk
- * Many debugging lines and assertions added. Fixed bug in TaggedLineString class.
- * Revision 1.3  2006/04/13 09:21:46  mloskot
- * Removed definition of copy ctor and assignment operator for TaggedLineString class.
- * According to following rule: Declaring, but not defining, private copy operations has
- * the effect of "turning off" copying for the class.
- * Revision 1.2  2006/04/12 15:20:37  strk
Modified: trunk/src/simplify/TaggedLineStringSimplifier.cpp
--- trunk/src/simplify/TaggedLineStringSimplifier.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/simplify/TaggedLineStringSimplifier.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -347,14 +347,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.2  2006/04/13 21:52:35  strk
- * Revision 1.1  2006/04/12 17:19:57  strk
Modified: trunk/src/simplify/TaggedLinesSimplifier.cpp
--- trunk/src/simplify/TaggedLinesSimplifier.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/simplify/TaggedLinesSimplifier.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -65,22 +65,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.3  2006/05/24 11:41:23  strk
- *         * source/headers/geos/simplify/TaggedLinesSimplifier.h,
- *         source/simplify/TaggedLinesSimplifier.cpp,
- *         source/simplify/TopologyPreservingSimplifier.cpp:
- *         fixed bug in TopologyPreservingSimplifier failing to
- *         detect intersections, refactored TaggedLinesSimplifier
- *         class to more closely match JTS and use templated
- *         functions.
- * Revision 1.2  2006/04/13 14:25:17  strk
- * TopologyPreservingSimplifier initial port
- * Revision 1.1  2006/04/13 10:39:12  strk
- * Initial implementation of TaggedLinesSimplifier class
Modified: trunk/src/util/Assert.cpp
--- trunk/src/util/Assert.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/util/Assert.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -54,41 +54,3 @@
 } // namespace geos.util
 } // namespace geos
- * $Log$
- * Revision 1.14  2006/03/09 16:46:49  strk
- * Revision 1.11  2006/02/23 11:54:21  strk
- * - MCIndexPointSnapper
- * - MCIndexSnapRounder
- * - SnapRounding BufferOp
- * - ScaledNoder
- * - GEOSException hierarchy cleanups
- * - SpatialIndex memory-friendly query interface
- * - GeometryGraph::getBoundaryNodes memory-friendly
- * - NodeMap::getBoundaryNodes memory-friendly
- * - Cleanups in geomgraph::Edge
- * - Added an XML test for snaprounding buffer (shows leaks, working on it)
- * Revision 1.10  2006/02/09 15:52:47  strk
- * Revision 1.9  2004/07/02 13:28:29  strk
- * Revision 1.8  2003/11/07 01:23:43  pramsey
- * files.
Modified: trunk/src/util/Profiler.cpp
--- trunk/src/util/Profiler.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/src/util/Profiler.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -167,39 +167,3 @@
 } // namespace geos
- * $Log$
- * Revision 1.10  2006/06/12 11:29:24  strk
- * Revision 1.9  2006/03/07 14:18:34  strk
- * Profiler singleton implemented with a function-static Profiler instance
- * Revision 1.8  2006/03/06 19:40:48  strk
- * Revision 1.7  2006/03/03 10:46:22  strk
- * Revision 1.6  2005/02/01 14:18:04  strk
- * Made profiler start/stop inline
- * Revision 1.5  2005/02/01 13:44:59  strk
- * More profiling labels.
- * Revision 1.4  2004/12/03 22:52:56  strk
- * enforced const return of CoordinateSequence::toVector() method to derivate classes.
- * Revision 1.3  2004/11/08 12:15:35  strk
- * Added number of gathered timings in output.
- * Revision 1.2  2004/11/08 11:19:39  strk
- * Profiler::get() always return a Profile (new if not existant).
- * Revision 1.1  2004/11/01 16:43:04  strk
- * Added Profiler code.
- * Temporarly patched a bug in DoubleBits (must check drawbacks).
- * Various cleanups and speedups.
Modified: trunk/tests/bigtest/GeometryTestFactory.cpp
--- trunk/tests/bigtest/GeometryTestFactory.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/tests/bigtest/GeometryTestFactory.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -130,53 +130,3 @@
 	CoordinateSequence *pts=createSineStar(basex, basey, size, armLen, nArms, nPts);
 	return fact->createPolygon(fact->createLinearRing(pts),NULL);
- * $Log$
- * Revision 1.1  2006/01/31 19:07:35  strk
- * Revision 1.13  2005/04/06 11:09:41  strk
- * Applied patch from Jon Schlueter (math.h => cmath; ieeefp.h in "C" block)
- * Revision 1.12  2004/12/08 13:54:43  strk
- * Revision 1.11  2004/07/19 10:35:23  strk
- * bigtest.h moved to local dir
- * Revision 1.10  2004/07/08 19:34:49  strk
- * Revision 1.9  2004/07/02 13:28:26  strk
- * Revision 1.8  2003/11/07 01:23:42  pramsey
- * files.
Modified: trunk/tests/bigtest/TestSweepLineSpeed.cpp
--- trunk/tests/bigtest/TestSweepLineSpeed.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/tests/bigtest/TestSweepLineSpeed.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -11,44 +11,6 @@
  * See the COPYING file for more information.
- * $Log$
- * Revision 1.2  2006/06/12 16:57:51  strk
- * Removed unused parameter warnings
- * Revision 1.13  2004/07/19 10:35:23  strk
- * Revision 1.12  2004/07/02 13:28:26  strk
- * Revision 1.11  2003/11/07 01:23:42  pramsey
- * files.
Modified: trunk/tests/bigtest/bigtest.h
--- trunk/tests/bigtest/bigtest.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/tests/bigtest/bigtest.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -11,45 +11,6 @@
- * $Log$
- * Revision 1.1  2004/07/19 10:35:23  strk
- * Revision 1.2  2004/07/08 19:34:49  strk
- * Added DefaultCoordinateSequenceFactory::instance() function.
- * Revision 1.1  2004/07/02 13:20:42  strk
- * Header files moved under geos/ dir.
- * Revision 1.4  2003/11/07 01:23:42  pramsey
- * files.
Modified: trunk/tests/xmltester/CTS.cpp
--- trunk/tests/xmltester/CTS.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/tests/xmltester/CTS.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -11,41 +11,7 @@
- * $Log$
- * Revision 1.2  2006/02/09 15:52:47  strk
- * Revision 1.7  2003/11/07 01:23:43  pramsey
- * files.
Modified: trunk/tests/xmltester/SimpleWKTTester.cpp
--- trunk/tests/xmltester/SimpleWKTTester.cpp	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/tests/xmltester/SimpleWKTTester.cpp	2012-05-29 08:42:24 UTC (rev 3650)
@@ -65,17 +65,3 @@
 	return 0;
- * $Log$
- * Revision 1.7  2006/06/12 16:59:04  strk
- * Revision 1.6  2006/06/09 08:28:38  strk
- * Removed compiler warning
- * Revision 1.5  2006/03/09 16:46:49  strk
Modified: trunk/tests/xmltester/Stackwalker.h
--- trunk/tests/xmltester/Stackwalker.h	2012-05-28 12:29:47 UTC (rev 3649)
+++ trunk/tests/xmltester/Stackwalker.h	2012-05-29 08:42:24 UTC (rev 3650)
@@ -10,38 +10,6 @@
  * by the Free Software Foundation.
- * $Log$
- * Revision 1.3  2004/03/17 02:00:33  ybychkov
- * "Algorithm" upgraded to JTS 1.4
- * Revision 1.2  2003/11/07 01:23:43  pramsey
- * files.
More information about the geos-commits mailing list
