[geos-commits] r3861 - in trunk: . tools
svn_geos at osgeo.org svn_geos at osgeo.org
Sat Aug 3 08:37:46 PDT 2013
Author: mloskot
Date: 2013-08-03 08:37:46 -0700 (Sat, 03 Aug 2013)
New Revision: 3861
Added:
   trunk/tools/geos_svn_revision_cmake.h.in
   trunk/CMakeLists.txt
Add geos_svn_revision.h generator to CMake config
Patch from David Burken attached to #643
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt	2013-08-02 22:38:59 UTC (rev 3860)
+++ trunk/CMakeLists.txt	2013-08-03 15:37:46 UTC (rev 3861)
@@ -237,20 +237,46 @@
 # Setup checks and generate config headers
+#  MACRO: GET_SVN_REVISION
+#  DESCRIPTION:
+#      MACRO FOR GETTING THE SVN revision for this build
+MACRO (GET_SVN_REVISION)
+   FIND_PACKAGE(Subversion)
+   IF(SUBVERSION_FOUND)
+      Subversion_WC_INFO(${PROJECT_SOURCE_DIR} Project)
+      # MESSAGE("Current revision is ${Project_WC_REVISION}")
+      # Subversion_WC_LOG(${PROJECT_SOURCE_DIR} Project)
+      # MESSAGE("Last changed log is ${Project_LAST_CHANGED_LOG}")
+   ENDIF()
+ENDMACRO(GET_SVN_REVISION)
 # Determine SVN/Git revision
-message(STATUS "Generating revision header ${CMAKE_SOURCE_DIR}/geos_svn_revision.h")
-find_program(SH sh)
-if(SH)
-  execute_process(COMMAND ${SH} -c
-    "cd ${CMAKE_SOURCE_DIR} && ${CMAKE_SOURCE_DIR}/tools/svn_repo_revision.sh")
+GET_SVN_REVISION()
+if ( NOT ${Project_WC_REVISION} EQUAL 0 )
+   set( GEOS_SVN_REVISION ${Project_WC_REVISION} )
+   configure_file (
+      "${PROJECT_SOURCE_DIR}/tools/geos_svn_revision_cmake.h.in"
+      "${PROJECT_SOURCE_DIR}/geos_svn_revision.h" )
+      # "${geos_BINARY_DIR}/include/geos_svn_revision.h" )
+else()
+   message(STATUS "Generating revision header ${CMAKE_SOURCE_DIR}/geos_svn_revision.h")
+   find_program(SH sh)
+   if(SH)
+      execute_process(COMMAND ${SH} -c
+      "cd ${CMAKE_SOURCE_DIR} && ${CMAKE_SOURCE_DIR}/tools/svn_repo_revision.sh")
-  file(RENAME "${CMAKE_SOURCE_DIR}/geos_svn_revision.h"
-    "${CMAKE_BINARY_DIR}/geos_svn_revision.h")
-else()
-  message("*** sh-compatible command not found, cannot create geos_svn_revision.h")
-  message("*** Check SVN revision and create revision header manually:")
-  message("*** echo '#define GEOS_SVN_REVISION XYZ' > ${CMAKE_SOURCE_DIR}/geos_svn_revision.h")
+      file(RENAME "${CMAKE_SOURCE_DIR}/geos_svn_revision.h"
+      "${CMAKE_BINARY_DIR}/geos_svn_revision.h")
+   else()
+      message("*** sh-compatible command not found, cannot create geos_svn_revision.h")
+      message("*** Check SVN revision and create revision header manually:")
+      message("*** echo '#define GEOS_SVN_REVISION XYZ' > ${CMAKE_SOURCE_DIR}/geos_svn_revision.h")
+   endif()
 endif()
+# End: Determine SVN/Git revision
 if(EXISTS ${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h)
   message(STATUS "Disabling existing ${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h")
Added: trunk/tools/geos_svn_revision_cmake.h.in
--- trunk/tools/geos_svn_revision_cmake.h.in	                        (rev 0)
+++ trunk/tools/geos_svn_revision_cmake.h.in	2013-08-03 15:37:46 UTC (rev 3861)
@@ -0,0 +1 @@
+#define GEOS_SVN_REVISION @GEOS_SVN_REVISION@
More information about the geos-commits mailing list
