[geos-commits] r3931 - trunk/tests/xmltester
svn_geos at osgeo.org svn_geos at osgeo.org
Wed Aug 28 05:46:04 PDT 2013
Author: mloskot
Date: 2013-08-28 05:46:04 -0700 (Wed, 28 Aug 2013)
New Revision: 3931
   trunk/tests/xmltester/XMLTester.cpp
Untabify
Modified: trunk/tests/xmltester/XMLTester.cpp
--- trunk/tests/xmltester/XMLTester.cpp	2013-08-28 12:35:13 UTC (rev 3930)
+++ trunk/tests/xmltester/XMLTester.cpp	2013-08-28 12:46:04 UTC (rev 3931)
@@ -154,361 +154,361 @@
 std::string
 normalize_filename(const std::string& str)
-	std::string newstring;
+    std::string newstring;
-	std::string::size_type last_slash = str.find_last_of('/', str.size());
-	if ( last_slash == std::string::npos ) newstring = str;
-	else newstring = str.substr(last_slash+1);
-	for (std::string::iterator i=newstring.begin(), e=newstring.end(); i!=e; ++i)
-		if ( *i == '.' ) *i = '_';
+    std::string::size_type last_slash = str.find_last_of('/', str.size());
+    if ( last_slash == std::string::npos ) newstring = str;
+    else newstring = str.substr(last_slash+1);
+    for (std::string::iterator i=newstring.begin(), e=newstring.end(); i!=e; ++i)
+        if ( *i == '.' ) *i = '_';
-	tolower(newstring);
+    tolower(newstring);
-	return newstring;
+    return newstring;
 /* Could be an XMLTester class private but oh well.. */
 static int
 checkBufferSuccess(geom::Geometry const& gRes, geom::Geometry const& gRealRes, double dist)
-	int success = 1;
-	do
+    int success = 1;
+    do
-		if ( gRes.getGeometryTypeId() != gRealRes.getGeometryTypeId() )
-			std::cerr << "Expected result is of type "
-				<< gRes.getGeometryType()
-				<< "; obtained result is of type "
-				<< gRealRes.getGeometryType()
-				<< std::endl;
-			success=0;
-			break;
+        if ( gRes.getGeometryTypeId() != gRealRes.getGeometryTypeId() )
+            std::cerr << "Expected result is of type "
+                << gRes.getGeometryType()
+                << "; obtained result is of type "
+                << gRealRes.getGeometryType()
+                << std::endl;
+            success=0;
+            break;
-		// Is a buffer always an area ?
-		if ( gRes.getDimension() != 2 )
-			std::cerr << "Don't know how to validate "
-				<< "result of buffer operation "
-				<< "when expected result is not an "
-				<< "areal type."
-				<< std::endl;
+        // Is a buffer always an area ?
+        if ( gRes.getDimension() != 2 )
+            std::cerr << "Don't know how to validate "
+                << "result of buffer operation "
+                << "when expected result is not an "
+                << "areal type."
+                << std::endl;
-		geos::xmltester::BufferResultMatcher matcher;
-		if ( ! matcher.isBufferResultMatch(gRealRes,
-						   gRes,
-						   dist) )
+        geos::xmltester::BufferResultMatcher matcher;
+        if ( ! matcher.isBufferResultMatch(gRealRes,
+                           gRes,
+                           dist) )
 std::cerr << "BufferResultMatcher FAILED" << std::endl;
-			success=0;
-			break;
+            success=0;
+            break;
-	while (0);
+    while (0);
-	return success;
+    return success;
 static int
 checkSingleSidedBufferSuccess(geom::Geometry& gRes,
-		geom::Geometry& gRealRes, double dist)
+        geom::Geometry& gRealRes, double dist)
-	int success = 1;
-	do
+    int success = 1;
+    do
-				<< std::endl;
-			success=0;
-			break;
+                << std::endl;
+            success=0;
+            break;
-		geos::xmltester::SingleSidedBufferResultMatcher matcher;
-						   gRes,
-						   dist) )
+        geos::xmltester::SingleSidedBufferResultMatcher matcher;
+                           gRes,
+                           dist) )
 std::cerr << "SingleSidedBufferResultMatcher FAILED" << std::endl;
-			success=0;
-			break;
+            success=0;
+            break;
-	while (0);
+    while (0);
-	return success;
+    return success;
 XMLTester::XMLTester()
-	gA(0),
-	gB(0),
-	gT(0),
-	pm(0),
-	factory(0),
-	wktreader(0),
-	wktwriter(0),
-	wkbreader(0),
-	wkbwriter(0),
-	test_predicates(0),
-	failed(0),
-	succeeded(0),
-	caseCount(0),
-	testCount(0),
-	testFileCount(0),
-	totalTestCount(0),
-	curr_file(NULL),
-	testValidOutput(false),
-	testValidInput(false),
-	sqlOutput(false),
-	HEXWKB_output(false)
+    gA(0),
+    gB(0),
+    gT(0),
+    pm(0),
+    factory(0),
+    wktreader(0),
+    wktwriter(0),
+    wkbreader(0),
+    wkbwriter(0),
+    test_predicates(0),
+    failed(0),
+    succeeded(0),
+    caseCount(0),
+    testCount(0),
+    testFileCount(0),
+    totalTestCount(0),
+    curr_file(NULL),
+    testValidOutput(false),
+    testValidInput(false),
+    sqlOutput(false),
+    HEXWKB_output(false)
-	setVerbosityLevel(0);
+    setVerbosityLevel(0);
 int
 XMLTester::setVerbosityLevel(int value)
-	int old_value=verbose;
+    int old_value=verbose;
-	verbose=value;
+    verbose=value;
-	return old_value;
+    return old_value;
 /*private*/
 void
 XMLTester::printTest(bool success, const std::string& expected_result, const std::string& actual_result)
-	if ( sqlOutput )
-		std::cout << "INSERT INTO \"" << normalize_filename(*curr_file) << "\" VALUES ("
-		          << caseCount << ", "
-		          << testCount << ", "
-		          << "'" << opSignature << "', "
-		          << "'" << curr_case_desc << "', ";
+    if ( sqlOutput )
+        std::cout << "INSERT INTO \"" << normalize_filename(*curr_file) << "\" VALUES ("
+                  << caseCount << ", "
+                  << testCount << ", "
+                  << "'" << opSignature << "', "
+                  << "'" << curr_case_desc << "', ";
-		std::string geomOut;
+        std::string geomOut;
-		if ( gA ) {
-			std::cout << "'" << printGeom(gA) << "', ";
-		} else {
-			std::cout << "NULL, ";
+        if ( gA ) {
+            std::cout << "'" << printGeom(gA) << "', ";
+        } else {
+            std::cout << "NULL, ";
-		if ( gB ) {
-			std::cout << "'" << printGeom(gB) << "', ";
-		} else {
+        if ( gB ) {
+            std::cout << "'" << printGeom(gB) << "', ";
+        } else {
-		std::cout << "'" << expected_result << "', "
-		          << "'" << actual_result << "', ";
+        std::cout << "'" << expected_result << "', "
+                  << "'" << actual_result << "', ";
-		if ( success ) std::cout << "'t'";
-		else std::cout << "'f'";
+        if ( success ) std::cout << "'t'";
+        else std::cout << "'f'";
-		std::cout << ");" << std::endl;
+        std::cout << ");" << std::endl;
-	else
-		std::cout << *curr_file <<":";
-		std::cout << " case" << caseCount << ":";
-		std::cout << " test" << testCount << ": "
-			<< opSignature;
-		std::cout << ": " << (success?"ok.":"failed.")<<std::endl;
+    else
+        std::cout << *curr_file <<":";
+        std::cout << " case" << caseCount << ":";
+        std::cout << " test" << testCount << ": "
+            << opSignature;
+        std::cout << ": " << (success?"ok.":"failed.")<<std::endl;
-		std::cout << "\tDescription: " << curr_case_desc << std::endl;
+        std::cout << "\tDescription: " << curr_case_desc << std::endl;
-		if ( gA ) {
-			std::cout << "\tGeometry A: ";
-			printGeom(std::cout, gA);
-			std::cout << std::endl;
+        if ( gA ) {
+            std::cout << "\tGeometry A: ";
+            printGeom(std::cout, gA);
+            std::cout << std::endl;
-		if ( gB ) {
-			std::cout << "\tGeometry B: ";
-			printGeom(std::cout, gB);
+        if ( gB ) {
+            std::cout << "\tGeometry B: ";
+            printGeom(std::cout, gB);
-		std::cout << "\tExpected result: "<<expected_result<<std::endl;
-		std::cout << "\tObtained result: "<<actual_result<<std::endl;
-		std::cout <<std::endl;
+        std::cout << "\tExpected result: "<<expected_result<<std::endl;
+        std::cout << "\tObtained result: "<<actual_result<<std::endl;
+        std::cout <<std::endl;
 void
 XMLTester::run(const std::string &source)
-	curr_file=&source;
+    curr_file=&source;
-	if ( sqlOutput )
-		std::cout << "CREATE TABLE \"" << normalize_filename(*curr_file) << "\""
-		          << "( caseno integer, testno integer, "
-			  << " operation varchar, description varchar, "
-			  << " a geometry, b geometry, expected geometry, "
-			  << " obtained geometry, result bool )"
+    if ( sqlOutput )
+        std::cout << "CREATE TABLE \"" << normalize_filename(*curr_file) << "\""
+                  << "( caseno integer, testno integer, "
+              << " operation varchar, description varchar, "
+              << " a geometry, b geometry, expected geometry, "
+              << " obtained geometry, result bool )"
-			  // NOTE: qgis 0.7.4 require oids for proper operations.
-			  //       The 'WITH OIDS' parameter is supported back to
-			  //       PostgreSQL 7.2, so if you run an older version
-			  //       rebuild with the next line commented out.
-			  << " WITH OIDS"
+              // NOTE: qgis 0.7.4 require oids for proper operations.
+              //       The 'WITH OIDS' parameter is supported back to
+              //       PostgreSQL 7.2, so if you run an older version
+              //       rebuild with the next line commented out.
+              << " WITH OIDS"
-			  << ";" << std::endl;
+              << ";" << std::endl;
-	++testFileCount;
+    ++testFileCount;
-	caseCount=0;
+    caseCount=0;
-	if ( ! xml.LoadFile(source.c_str()) )
-		std::stringstream err;
-		err << "Could not load " << source << ": " << xml.ErrorDesc();
-		throw runtime_error(err.str());
+    if ( ! xml.LoadFile(source.c_str()) )
+        std::stringstream err;
+        err << "Could not load " << source << ": " << xml.ErrorDesc();
+        throw runtime_error(err.str());
-	//dump_to_stdout(&xml);
+    //dump_to_stdout(&xml);
-	const TiXmlNode* node = xml.FirstChild("run");
+    const TiXmlNode* node = xml.FirstChild("run");
-	if ( ! node )
-	  throw(runtime_error("Document has no childs"));
+    if ( ! node )
+      throw(runtime_error("Document has no childs"));
-	parseRun(node);
+    parseRun(node);
 void
 XMLTester::resultSummary(std::ostream &os) const
-	os<<"Files: "<<testFileCount<<std::endl;
-	os<<"Tests: "<<totalTestCount<<std::endl;
-	os<<"Failed: "<<failed<<std::endl;
-	os<<"Succeeded: "<<succeeded<<std::endl;
+    os<<"Files: "<<testFileCount<<std::endl;
+    os<<"Tests: "<<totalTestCount<<std::endl;
+    os<<"Failed: "<<failed<<std::endl;
+    os<<"Succeeded: "<<succeeded<<std::endl;
 void
 XMLTester::resetCounters()
-	testFileCount=totalTestCount=failed=succeeded=0;
+    testFileCount=totalTestCount=failed=succeeded=0;
 void
 XMLTester::parseRun(const TiXmlNode* node)
-	using geos::geom::PrecisionModel;
+    using geos::geom::PrecisionModel;
-	assert(node);
+    assert(node);
-	//dump_to_stdout(node);
+    //dump_to_stdout(node);
-	// Look for precisionModel element
-	const TiXmlElement* el = node->FirstChildElement("precisionModel");
-	if ( el ) parsePrecisionModel(el);
-	else pm.reset(new PrecisionModel());
+    // Look for precisionModel element
+    const TiXmlElement* el = node->FirstChildElement("precisionModel");
+    if ( el ) parsePrecisionModel(el);
+    else pm.reset(new PrecisionModel());
-	if (verbose > 1)
-		std::cerr << *curr_file <<": run: Precision Model: " << pm->toString() <<std::endl;
+    if (verbose > 1)
+        std::cerr << *curr_file <<": run: Precision Model: " << pm->toString() <<std::endl;
-	factory.reset(new geom::GeometryFactory(pm.get()));
-	wktreader.reset(new io::WKTReader(factory.get()));
-	wktwriter.reset(new io::WKTWriter());
-	wkbreader.reset(new io::WKBReader(*factory));
-	wkbwriter.reset(new io::WKBWriter());
+    factory.reset(new geom::GeometryFactory(pm.get()));
+    wktreader.reset(new io::WKTReader(factory.get()));
+    wktwriter.reset(new io::WKTWriter());
+    wkbreader.reset(new io::WKBReader(*factory));
+    wkbwriter.reset(new io::WKBWriter());
-	const TiXmlNode* casenode;
-	for ( casenode = node->FirstChild("case");
-	      casenode;
-	      casenode = casenode->NextSibling("case") )
-		try {
-			parseCase(casenode);
-		} catch (const std::exception& exc) {
-			std::cerr<<exc.what()<<std::endl;
+    const TiXmlNode* casenode;
+    for ( casenode = node->FirstChild("case");
+          casenode;
+          casenode = casenode->NextSibling("case") )
+        try {
+            parseCase(casenode);
+        } catch (const std::exception& exc) {
+            std::cerr<<exc.what()<<std::endl;
 void
 XMLTester::parsePrecisionModel(const TiXmlElement* el)
-	//dump_to_stdout(el);
+    //dump_to_stdout(el);
-	/* This does not seem to work... */
-	std::string type;
-	const char* typeStr = el->Attribute("type");
-	if ( typeStr ) type = typeStr;
+    /* This does not seem to work... */
+    std::string type;
+    const char* typeStr = el->Attribute("type");
+    if ( typeStr ) type = typeStr;
-	const char* scaleStr = el->Attribute("scale");
+    const char* scaleStr = el->Attribute("scale");
-	if ( ! scaleStr ) {
-		if ( type == "FLOATING_SINGLE" )
-			pm.reset(new PrecisionModel(PrecisionModel::FLOATING_SINGLE));
-		else
-			pm.reset(new PrecisionModel());
-	} else {
+    if ( ! scaleStr ) {
+        if ( type == "FLOATING_SINGLE" )
+            pm.reset(new PrecisionModel(PrecisionModel::FLOATING_SINGLE));
+        else
+            pm.reset(new PrecisionModel());
+    } else {
-		char* stopstring;
+        char* stopstring;
-		double scale = std::strtod(scaleStr, &stopstring);
-		double offsetX = 0;
-		double offsetY = 2;
+        double scale = std::strtod(scaleStr, &stopstring);
+        double offsetX = 0;
+        double offsetY = 2;
-		if ( ! el->QueryDoubleAttribute("offsetx", &offsetX) )
-		{} // std::cerr << "No offsetx" << std::endl;
+        if ( ! el->QueryDoubleAttribute("offsetx", &offsetX) )
+        {} // std::cerr << "No offsetx" << std::endl;
-		if ( ! el->QueryDoubleAttribute("offsety", &offsetY) )
-		{} // std::cerr << "No offsety" << std::endl;
+        if ( ! el->QueryDoubleAttribute("offsety", &offsetY) )
+        {} // std::cerr << "No offsety" << std::endl;
-		// NOTE: PrecisionModel discards offsets anyway...
-		pm.reset(new PrecisionModel(scale, offsetX, offsetY));
+        // NOTE: PrecisionModel discards offsets anyway...
+        pm.reset(new PrecisionModel(scale, offsetX, offsetY));
 bool
 XMLTester::testValid(const geom::Geometry* g, const std::string& label)
-	operation::valid::IsValidOp ivo(g);
-	bool valid = ivo.isValid();
-	if ( ! valid )
-		operation::valid::TopologyValidationError *err = ivo.getValidationError();
-		std::cerr << *curr_file << ":"
-			  << " case" << caseCount << ":"
-			  << " test" << testCount << ": "
-			  << opSignature << ": "
-			  << " invalid geometry (" << label
-			  << "): " << err->toString() << std::endl;
-	return valid;
+    operation::valid::IsValidOp ivo(g);
+    bool valid = ivo.isValid();
+    if ( ! valid )
+        operation::valid::TopologyValidationError *err = ivo.getValidationError();
+        std::cerr << *curr_file << ":"
+              << " case" << caseCount << ":"
+              << " test" << testCount << ": "
+              << opSignature << ": "
+              << " invalid geometry (" << label
+              << "): " << err->toString() << std::endl;
+    return valid;
@@ -517,916 +517,916 @@
 geom::Geometry *
 XMLTester::parseGeometry(const std::string &in, const char* label)
-	if ( ( ! wkbreader.get() ) || ( ! wktreader.get() ) )
-		throw(runtime_error("No precision model specified"));
+    if ( ( ! wkbreader.get() ) || ( ! wktreader.get() ) )
+        throw(runtime_error("No precision model specified"));
-	std::stringstream is(in, std::ios_base::in);
-	char first_char;
+    std::stringstream is(in, std::ios_base::in);
+    char first_char;
-	// Remove leading spaces
-	while (is.get(first_char) && std::isspace(first_char));
-	is.unget();
+    // Remove leading spaces
+    while (is.get(first_char) && std::isspace(first_char));
+    is.unget();
-	geom::Geometry* ret;
+    geom::Geometry* ret;
-	switch (first_char)
-		case '0':
-		case '1':
-		case '2':
-		case '3':
-		case '4':
-		case '5':
-		case '6':
-		case '7':
-		case '8':
-		case '9':
-		case 'A':
-		case 'B':
-		case 'C':
-		case 'D':
-		case 'E':
-		case 'F':
-			ret = wkbreader->readHEX(is);
-			break;
-		default:
-			ret = wktreader->read(in);
-			break;
+    switch (first_char)
+        case '0':
+        case '1':
+        case '2':
+        case '3':
+        case '4':
+        case '5':
+        case '6':
+        case '7':
+        case '8':
+        case '9':
+        case 'A':
+        case 'B':
+        case 'C':
+        case 'D':
+        case 'E':
+        case 'F':
+            ret = wkbreader->readHEX(is);
+            break;
+        default:
+            ret = wktreader->read(in);
+            break;
-	if ( testValidInput ) testValid(ret, std::string(label));
+    if ( testValidInput ) testValid(ret, std::string(label));
-	//ret->normalize();
+    //ret->normalize();
-	return ret;
+    return ret;
 std::string
 XMLTester::trimBlanks(const std::string &in)
-	std::string out;
-	std::string::size_type pos = in.find_first_not_of(" \t\n\r");
-	if (pos!=std::string::npos) out=in.substr(pos);
-	pos = out.find_last_not_of(" \t\n\r");
-	if (pos!=std::string::npos) out=out.substr(0, pos+1);
-	return out;
+    std::string out;
+    std::string::size_type pos = in.find_first_not_of(" \t\n\r");
+    if (pos!=std::string::npos) out=in.substr(pos);
+    pos = out.find_last_not_of(" \t\n\r");
+    if (pos!=std::string::npos) out=out.substr(0, pos+1);
+    return out;
 void
 XMLTester::parseCase(const TiXmlNode* node)
-	assert(node);
+    assert(node);
-	std::string geomAin;
-	std::string geomBin;
-	std::string thrownException;
+    std::string geomAin;
+    std::string geomBin;
+    std::string thrownException;
-	gA=NULL;
-	gB=NULL;
+    gA=NULL;
+    gB=NULL;
-	curr_case_desc.clear();
-	const TiXmlNode* txt = node->FirstChild("desc");
-	if ( txt ) {
-		txt = txt->FirstChild();
-		if ( txt ) curr_case_desc = trimBlanks(txt->Value());
+    curr_case_desc.clear();
+    const TiXmlNode* txt = node->FirstChild("desc");
+    if ( txt ) {
+        txt = txt->FirstChild();
+        if ( txt ) curr_case_desc = trimBlanks(txt->Value());
-	//std::cerr << "Desc: " << curr_case_desc << std::endl;
+    //std::cerr << "Desc: " << curr_case_desc << std::endl;
-	try {
-		const TiXmlNode *el = node->FirstChild("a");
-		geomAin = el->FirstChild()->Value();
-		geomAin = trimBlanks(geomAin);
-		gA = parseGeometry(geomAin, "Geometry A");
+    try {
+        const TiXmlNode *el = node->FirstChild("a");
+        geomAin = el->FirstChild()->Value();
+        geomAin = trimBlanks(geomAin);
+        gA = parseGeometry(geomAin, "Geometry A");
-		if ( 0 != (el = node->FirstChild("b")) )
-			geomBin = el->FirstChild()->Value();
-			geomBin = trimBlanks(geomBin);
-			gB = parseGeometry(geomBin, "Geometry B");
-	catch (const std::exception &e) {
-		thrownException = e.what();
-	catch (...) {
-		thrownException = "Unknown exception";
+        if ( 0 != (el = node->FirstChild("b")) )
+            geomBin = el->FirstChild()->Value();
+            geomBin = trimBlanks(geomBin);
+            gB = parseGeometry(geomBin, "Geometry B");
+    catch (const std::exception &e) {
+        thrownException = e.what();
+    catch (...) {
+        thrownException = "Unknown exception";
 //std::cerr << "A: " << geomAin << std::endl;
 //std::cerr << "B: " << geomBin << std::endl;
-	if ( thrownException != "" )
-		std::cout << " skipped ("<<thrownException<<")."<<std::endl;
-		return;
+    if ( thrownException != "" )
+        std::cout << " skipped ("<<thrownException<<")."<<std::endl;
+        return;
-	++caseCount;
-	testCount=0;
+    ++caseCount;
+    testCount=0;
-	const TiXmlNode* testnode;
-	for ( testnode = node->FirstChild("test");
-	      testnode;
-	      testnode = testnode->NextSibling("test") )
-		parseTest(testnode);
+    const TiXmlNode* testnode;
+    for ( testnode = node->FirstChild("test");
+          testnode;
+          testnode = testnode->NextSibling("test") )
+        parseTest(testnode);
-	totalTestCount+=testCount;
-	delete gA;
-	delete gB;
+    totalTestCount+=testCount;
+    delete gA;
+    delete gB;
 /*private*/
 void
 XMLTester::printGeom(std::ostream& os, const geom::Geometry *g)
-	os << printGeom(g);
+    os << printGeom(g);
 std::string
 XMLTester::printGeom(const geom::Geometry *g)
-	if ( HEXWKB_output )
-		std::stringstream s(std::ios_base::binary|std::ios_base::in|std::ios_base::out);
-		wkbwriter->write(*g, s);
-		std::stringstream s2;
-		wkbreader->printHEX(s, s2);
-		return s2.str();
-	else
-		return wktwriter->write(g);
+    if ( HEXWKB_output )
+        std::stringstream s(std::ios_base::binary|std::ios_base::in|std::ios_base::out);
+        wkbwriter->write(*g, s);
+        std::stringstream s2;
+        wkbreader->printHEX(s, s2);
+        return s2.str();
+    else
+        return wktwriter->write(g);
 void
 XMLTester::parseTest(const TiXmlNode* node)
-	using namespace operation::overlay;
+    using namespace operation::overlay;
-	typedef std::auto_ptr< geom::Geometry > GeomAutoPtr;
+    typedef std::auto_ptr< geom::Geometry > GeomAutoPtr;
-	int success=0; // no success by default
-	std::string opName;
-	std::string opArg1;
-	std::string opArg2;
-	std::string opArg3;
-	std::string opArg4;
-	std::string opRes;
+    int success=0; // no success by default
+    std::string opName;
+    std::string opArg1;
+    std::string opArg2;
+    std::string opArg3;
+    std::string opArg4;
+    std::string opRes;
-	++testCount;
+    ++testCount;
-	const TiXmlNode* opnode = node->FirstChild("op");
-	if ( ! opnode ) throw(runtime_error("case has no op"));
+    const TiXmlNode* opnode = node->FirstChild("op");
+    if ( ! opnode ) throw(runtime_error("case has no op"));
-	//dump_to_stdout(opnode);
+    //dump_to_stdout(opnode);
-	const TiXmlElement* opel = opnode->ToElement();
+    const TiXmlElement* opel = opnode->ToElement();
-	const char* tmp = opel->Attribute("name");
-	if ( tmp ) opName = tmp;
+    const char* tmp = opel->Attribute("name");
+    if ( tmp ) opName = tmp;
-	tmp = opel->Attribute("arg1");
-	if ( tmp ) opArg1 = tmp;
+    tmp = opel->Attribute("arg1");
+    if ( tmp ) opArg1 = tmp;
-	tmp = opel->Attribute("arg2");
-	if ( tmp ) opArg2 = tmp;
+    tmp = opel->Attribute("arg2");
+    if ( tmp ) opArg2 = tmp;
-	tmp = opel->Attribute("arg3");
-	if ( tmp ) opArg3 = tmp;
+    tmp = opel->Attribute("arg3");
+    if ( tmp ) opArg3 = tmp;
-	tmp = opel->Attribute("arg4");
-	if ( tmp ) opArg4 = tmp;
+    tmp = opel->Attribute("arg4");
+    if ( tmp ) opArg4 = tmp;
-	const TiXmlNode* resnode = opnode->FirstChild();
-	if ( ! resnode )
-		std::stringstream tmp;
-		tmp << "op of test " << testCount
-		    << " of case " << caseCount
-		    << " has no expected result child";
-		throw(runtime_error(tmp.str()));
-	opRes = resnode->Value();
+    const TiXmlNode* resnode = opnode->FirstChild();
+    if ( ! resnode )
+        std::stringstream tmp;
+        tmp << "op of test " << testCount
+            << " of case " << caseCount
+            << " has no expected result child";
+        throw(runtime_error(tmp.str()));
+    opRes = resnode->Value();
-	// trim blanks
-	opRes=trimBlanks(opRes);
-	opName=trimBlanks(opName);
-	tolower(opName);
+    // trim blanks
+    opRes=trimBlanks(opRes);
+    opName=trimBlanks(opName);
+    tolower(opName);
-	std::string opSig="";
+    std::string opSig="";
-	if ( opArg1 != "" ) opSig=opArg1;
-	if ( opArg2 != "" ) {
-		if ( opSig != "" ) opSig += ", ";
-		opSig += opArg2;
-	if ( opArg3 != "" ) {
-		opSig += opArg3;
-	if ( opArg4 != "" ) {
-		opSig += opArg4;
+    if ( opArg1 != "" ) opSig=opArg1;
+    if ( opArg2 != "" ) {
+        if ( opSig != "" ) opSig += ", ";
+        opSig += opArg2;
+    if ( opArg3 != "" ) {
+        opSig += opArg3;
+    if ( opArg4 != "" ) {
+        opSig += opArg4;
-	opSignature = opName + "(" + opSig + ")";
+    opSignature = opName + "(" + opSig + ")";
-	std::string actual_result="NONE";
+    std::string actual_result="NONE";
-	// expected_result will be modified by specific tests
-	// if needed (geometry normalization, for example)
-	std::string expected_result=opRes;
+    // expected_result will be modified by specific tests
+    // if needed (geometry normalization, for example)
+    std::string expected_result=opRes;
-	try
+    try
-		util::Profile profile("op");
+        util::Profile profile("op");
-		if (opName=="relate")
-			std::auto_ptr<geom::IntersectionMatrix> im(gA->relate(gB));
-			assert(im.get());
+        if (opName=="relate")
+            std::auto_ptr<geom::IntersectionMatrix> im(gA->relate(gB));
+            assert(im.get());
-			if (im->matches(opArg3)) actual_result="true";
-			else actual_result="false";
+            if (im->matches(opArg3)) actual_result="true";
+            else actual_result="false";
-			if (actual_result==opRes) success=1;
+            if (actual_result==opRes) success=1;
-		else if (opName=="isvalid")
-			geom::Geometry *gT=gA;
-			if ( ( opArg1 == "B" || opArg1 == "b" ) && gB ) {
-				gT=gB;
+        else if (opName=="isvalid")
+            geom::Geometry *gT=gA;
+            if ( ( opArg1 == "B" || opArg1 == "b" ) && gB ) {
+                gT=gB;
-			if (gT->isValid()) actual_result="true";
+            if (gT->isValid()) actual_result="true";
-		else if (opName=="intersection")
+        else if (opName=="intersection")
-			GeomAutoPtr gRes(parseGeometry(opRes, "expected"));
-			gRes->normalize();
+            GeomAutoPtr gRes(parseGeometry(opRes, "expected"));
+            gRes->normalize();
 #ifndef USE_BINARYOP
-			GeomAutoPtr gRealRes(gA->intersection(gB));
+            GeomAutoPtr gRealRes(gA->intersection(gB));
 #else
-			GeomAutoPtr gRealRes = BinaryOp(gA, gB, overlayOp(OverlayOp::opINTERSECTION));
+            GeomAutoPtr gRealRes = BinaryOp(gA, gB, overlayOp(OverlayOp::opINTERSECTION));
 #endif
-			gRealRes->normalize();
+            gRealRes->normalize();
-			if (gRes->compareTo(gRealRes.get())==0) success=1;
+            if (gRes->compareTo(gRealRes.get())==0) success=1;
-			actual_result=printGeom(gRealRes.get());
-			expected_result=printGeom(gRes.get());
+            actual_result=printGeom(gRealRes.get());
+            expected_result=printGeom(gRes.get());
-			if ( testValidOutput )
-				success &= int(testValid(gRealRes.get(), "result"));
+            if ( testValidOutput )
+                success &= int(testValid(gRealRes.get(), "result"));
-		else if (opName=="union")
+        else if (opName=="union")
-			GeomAutoPtr gRealRes;
-			if ( gB ) {
+            GeomAutoPtr gRealRes;
+            if ( gB ) {
-				gRealRes.reset(gA->Union(gB));
+                gRealRes.reset(gA->Union(gB));
 #else
-				gRealRes = BinaryOp(gA, gB, overlayOp(OverlayOp::opUNION));
+                gRealRes = BinaryOp(gA, gB, overlayOp(OverlayOp::opUNION));
 #endif
-			} else {
-				gRealRes = gA->Union();
+            } else {
+                gRealRes = gA->Union();
-			if (gRes->equals(gRealRes.get())) success=1;
+            if (gRes->equals(gRealRes.get())) success=1;
-		else if (opName=="difference")
+        else if (opName=="difference")
-			GeomAutoPtr gRealRes(gA->difference(gB));
+            GeomAutoPtr gRealRes(gA->difference(gB));
 #else
-			GeomAutoPtr gRealRes = BinaryOp(gA, gB, overlayOp(OverlayOp::opDIFFERENCE));
+            GeomAutoPtr gRealRes = BinaryOp(gA, gB, overlayOp(OverlayOp::opDIFFERENCE));
 #endif
-		else if (opName=="symdifference")
+        else if (opName=="symdifference")
-			GeomAutoPtr gRealRes(gA->symDifference(gB));
+            GeomAutoPtr gRealRes(gA->symDifference(gB));
 #else
-			GeomAutoPtr gRealRes = BinaryOp(gA, gB, overlayOp(OverlayOp::opSYMDIFFERENCE));
+            GeomAutoPtr gRealRes = BinaryOp(gA, gB, overlayOp(OverlayOp::opSYMDIFFERENCE));
 #endif
-		else if (opName=="intersects")
-			geom::Geometry *g1 = opArg1 == "B" ? gB : gA;
-			geom::Geometry *g2 = opArg2 == "B" ? gB : gA;
+        else if (opName=="intersects")
+            geom::Geometry *g1 = opArg1 == "B" ? gB : gA;
+            geom::Geometry *g2 = opArg2 == "B" ? gB : gA;
-			if (g1->intersects(g2)) actual_result="true";
+            if (g1->intersects(g2)) actual_result="true";
-		else if (opName=="contains")
+        else if (opName=="contains")
-			if (g1->contains(g2)) actual_result="true";
+            if (g1->contains(g2)) actual_result="true";
-		else if (opName=="within")
+        else if (opName=="within")
-			if (g1->within(g2)) actual_result="true";
+            if (g1->within(g2)) actual_result="true";
-		else if (opName=="covers")
+        else if (opName=="covers")
-			if (g1->covers(g2)) actual_result="true";
+            if (g1->covers(g2)) actual_result="true";
-		else if (opName=="coveredby")
+        else if (opName=="coveredby")
-			if (g1->coveredBy(g2)) actual_result="true";
+            if (g1->coveredBy(g2)) actual_result="true";
-		else if (opName=="getboundary")
-			if ( ( opArg1 == "B" || opArg1 == "b" ) && gB ) gT=gB;
+        else if (opName=="getboundary")
+            if ( ( opArg1 == "B" || opArg1 == "b" ) && gB ) gT=gB;
-			GeomAutoPtr gRealRes(gT->getBoundary());
+            GeomAutoPtr gRealRes(gT->getBoundary());
-		else if (opName=="getcentroid")
+        else if (opName=="getcentroid")
-			GeomAutoPtr gRealRes(gT->getCentroid());
+            GeomAutoPtr gRealRes(gT->getCentroid());
-			if ( gRealRes.get() ) gRealRes->normalize();
-			else gRealRes.reset(factory->createPoint());
+            if ( gRealRes.get() ) gRealRes->normalize();
+            else gRealRes.reset(factory->createPoint());
-		else if (opName=="issimple")
+        else if (opName=="issimple")
-			if (gT->isSimple()) actual_result="true";
+            if (gT->isSimple()) actual_result="true";
-		else if (opName=="convexhull")
+        else if (opName=="convexhull")
-			GeomAutoPtr gRealRes(gT->convexHull());
+            GeomAutoPtr gRealRes(gT->convexHull());
-		else if (opName=="buffer")
-			using namespace operation::buffer;
+        else if (opName=="buffer")
+            using namespace operation::buffer;
-			profile.start();
+            profile.start();
-			double dist = std::atof(opArg2.c_str());
+            double dist = std::atof(opArg2.c_str());
-			BufferParameters params;
-		params.setQuadrantSegments(std::atoi(opArg3.c_str()));
+            BufferParameters params;
+        params.setQuadrantSegments(std::atoi(opArg3.c_str()));
-			BufferOp op(gT, params);
-			gRealRes.reset(op.getResultGeometry(dist));
+            BufferOp op(gT, params);
+            gRealRes.reset(op.getResultGeometry(dist));
-			profile.stop();
+            profile.stop();
-			// Validate the buffer operation
-			success = checkBufferSuccess(*gRes, *gRealRes, dist);
+            // Validate the buffer operation
+            success = checkBufferSuccess(*gRes, *gRealRes, dist);
-		else if (opName=="buffersinglesided")
+        else if (opName=="buffersinglesided")
-			profile.start();
+            profile.start();
-			BufferParameters params ;
-			params.setJoinStyle( BufferParameters::JOIN_ROUND ) ;
-		params.setQuadrantSegments( std::atoi(opArg3.c_str()));
-			bool leftSide = true ;
-			if ( opArg4 == "right" )
-				leftSide = false ;
+            BufferParameters params ;
+            params.setJoinStyle( BufferParameters::JOIN_ROUND ) ;
+        params.setQuadrantSegments( std::atoi(opArg3.c_str()));
+            bool leftSide = true ;
+            if ( opArg4 == "right" )
+                leftSide = false ;
-			BufferBuilder bufBuilder( params ) ;
-			gRealRes.reset( bufBuilder.bufferLineSingleSided(
-			                             gT, dist, leftSide ) ) ;
+            BufferBuilder bufBuilder( params ) ;
+            gRealRes.reset( bufBuilder.bufferLineSingleSided(
+                                         gT, dist, leftSide ) ) ;
-			profile.stop();
+            profile.stop();
-			// Validate the single sided buffer operation
-			success = checkSingleSidedBufferSuccess(*gRes,
-					*gRealRes, dist);
+            // Validate the single sided buffer operation
+            success = checkSingleSidedBufferSuccess(*gRes,
+                    *gRealRes, dist);
-		else if (opName=="buffermitredjoin")
+        else if (opName=="buffermitredjoin")
-			profile.start();
+            profile.start();
-			params.setJoinStyle(BufferParameters::JOIN_MITRE);
+            params.setJoinStyle(BufferParameters::JOIN_MITRE);
-			profile.stop();
+            profile.stop();
-		else if (opName=="getinteriorpoint")
+        else if (opName=="getinteriorpoint")
-			GeomAutoPtr gRealRes(gT->getInteriorPoint());
+            GeomAutoPtr gRealRes(gT->getInteriorPoint());
-		else if (opName=="iswithindistance")
-			double dist=std::atof(opArg3.c_str());
-			if (gA->isWithinDistance(gB, dist)) {
-				actual_result="true";
-			} else {
-				actual_result="false";
+        else if (opName=="iswithindistance")
+            double dist=std::atof(opArg3.c_str());
+            if (gA->isWithinDistance(gB, dist)) {
+                actual_result="true";
+            } else {
+                actual_result="false";
-		else if (opName=="polygonize")
+        else if (opName=="polygonize")
-			GeomAutoPtr gRes(wktreader->read(opRes));
+            GeomAutoPtr gRes(wktreader->read(opRes));
-			Polygonizer plgnzr;
-			plgnzr.add(gA);
+            Polygonizer plgnzr;
+            plgnzr.add(gA);
             std::vector<geos::geom::Polygon *>*polys = plgnzr.getPolygons();
-			std::vector<geom::Geometry *>*newgeoms = new std::vector<geom::Geometry *>;
-			for (unsigned int i=0; i<polys->size(); i++)
-				newgeoms->push_back((*polys)[i]);
-			delete polys;
+            std::vector<geom::Geometry *>*newgeoms = new std::vector<geom::Geometry *>;
+            for (unsigned int i=0; i<polys->size(); i++)
+                newgeoms->push_back((*polys)[i]);
+            delete polys;
-			GeomAutoPtr gRealRes(factory->createGeometryCollection(newgeoms));
+            GeomAutoPtr gRealRes(factory->createGeometryCollection(newgeoms));
-		else if (opName=="linemerge")
+        else if (opName=="linemerge")
-			LineMerger merger;
-			merger.add(gT);
-			std::auto_ptr< std::vector<geom::LineString *> > lines ( merger.getMergedLineStrings() );
-			std::vector<geom::Geometry *>*newgeoms = new std::vector<geom::Geometry *>(lines->begin(),
-					lines->end());
+            LineMerger merger;
+            merger.add(gT);
+            std::auto_ptr< std::vector<geom::LineString *> > lines ( merger.getMergedLineStrings() );
+            std::vector<geom::Geometry *>*newgeoms = new std::vector<geom::Geometry *>(lines->begin(),
+                    lines->end());
-		else if (opName=="areatest")
-			char* rest;
-			double toleratedDiff = std::strtod(opRes.c_str(), &rest);
-			int validOut = 1;
+        else if (opName=="areatest")
+            char* rest;
+            double toleratedDiff = std::strtod(opRes.c_str(), &rest);
+            int validOut = 1;
-			if ( rest == opRes.c_str() )
-				throw std::runtime_error("malformed testcase: missing tolerated area difference in 'areatest' op");
+            if ( rest == opRes.c_str() )
+                throw std::runtime_error("malformed testcase: missing tolerated area difference in 'areatest' op");
-			if ( verbose > 1 )
-		std::cerr << "Running intersection for areatest" << std::endl;
+            if ( verbose > 1 )
+        std::cerr << "Running intersection for areatest" << std::endl;
-			GeomAutoPtr gI(gA->intersection(gB));
+            GeomAutoPtr gI(gA->intersection(gB));
 #else
-			GeomAutoPtr gI = BinaryOp(gA, gB,
-					overlayOp(OverlayOp::opINTERSECTION));
+            GeomAutoPtr gI = BinaryOp(gA, gB,
+                    overlayOp(OverlayOp::opINTERSECTION));
 #endif
-				validOut &= int(testValid(gI.get(), "areatest intersection"));
+                validOut &= int(testValid(gI.get(), "areatest intersection"));
-		std::cerr << "Running difference(A,B) for areatest" << std::endl;
+        std::cerr << "Running difference(A,B) for areatest" << std::endl;
-			GeomAutoPtr gDab(gA->difference(gB));
+            GeomAutoPtr gDab(gA->difference(gB));
 #else
-			GeomAutoPtr gDab = BinaryOp(gA, gB,
-					overlayOp(OverlayOp::opDIFFERENCE));
+            GeomAutoPtr gDab = BinaryOp(gA, gB,
+                    overlayOp(OverlayOp::opDIFFERENCE));
 #endif
-				validOut &= int(testValid(gI.get(), "areatest difference(a,b)"));
+                validOut &= int(testValid(gI.get(), "areatest difference(a,b)"));
-		std::cerr << "Running difference(B,A) for areatest" << std::endl;
+        std::cerr << "Running difference(B,A) for areatest" << std::endl;
-			GeomAutoPtr gDba(gB->difference(gA));
+            GeomAutoPtr gDba(gB->difference(gA));
 #else
-			GeomAutoPtr gDba = BinaryOp(gB, gA,
+            GeomAutoPtr gDba = BinaryOp(gB, gA,
 #endif
-				validOut &= int(testValid(gI.get(), "areatest difference(b,a)"));
+                validOut &= int(testValid(gI.get(), "areatest difference(b,a)"));
-		std::cerr << "Running symdifference for areatest" << std::endl;
+        std::cerr << "Running symdifference for areatest" << std::endl;
-			GeomAutoPtr gSD(gA->symDifference(gB));
+            GeomAutoPtr gSD(gA->symDifference(gB));
 #else
-			GeomAutoPtr gSD = BinaryOp(gA, gB,
-					overlayOp(OverlayOp::opSYMDIFFERENCE));
+            GeomAutoPtr gSD = BinaryOp(gA, gB,
+                    overlayOp(OverlayOp::opSYMDIFFERENCE));
 #endif
-				validOut &= int(testValid(gI.get(), "areatest symdifference"));
+                validOut &= int(testValid(gI.get(), "areatest symdifference"));
-		std::cerr << "Running union for areatest" << std::endl;
+        std::cerr << "Running union for areatest" << std::endl;
-			GeomAutoPtr gU(gA->Union(gB));
+            GeomAutoPtr gU(gA->Union(gB));
 #else
-			GeomAutoPtr gU = BinaryOp(gA, gB,
-					overlayOp(OverlayOp::opUNION));
+            GeomAutoPtr gU = BinaryOp(gA, gB,
+                    overlayOp(OverlayOp::opUNION));
 #endif
-			double areaA = gA->getArea();
-			double areaB = gB->getArea();
-			double areaI = gI->getArea();
-			double areaDab = gDab->getArea();
-			double areaDba = gDba->getArea();
-			double areaSD = gSD->getArea();
-			double areaU = gU->getArea();
+            double areaA = gA->getArea();
+            double areaB = gB->getArea();
+            double areaI = gI->getArea();
+            double areaDab = gDab->getArea();
+            double areaDba = gDba->getArea();
+            double areaSD = gSD->getArea();
+            double areaU = gU->getArea();
-			double maxdiff = 0;
-			std::string maxdiffop;
+            double maxdiff = 0;
+            std::string maxdiffop;
-			// @ : symdifference
-			// - : difference
-			// + : union
-			// ^ : intersection
-			// A == ( A ^ B ) + ( A - B )
-			double diff = std::fabs ( areaA - areaI - areaDab );
-			if ( diff > maxdiff ) {
-				maxdiffop = "A == ( A ^ B ) + ( A - B )";
-				maxdiff = diff;
+            // @ : symdifference
+            // - : difference
+            // + : union
+            // ^ : intersection
+            // A == ( A ^ B ) + ( A - B )
+            double diff = std::fabs ( areaA - areaI - areaDab );
+            if ( diff > maxdiff ) {
+                maxdiffop = "A == ( A ^ B ) + ( A - B )";
+                maxdiff = diff;
-			// B == ( A ^ B ) + ( B - A )
-			diff = std::fabs ( areaB - areaI - areaDba );
-				maxdiffop = "B == ( A ^ B ) + ( B - A )";
-				maxdiff = diff;
+            // B == ( A ^ B ) + ( B - A )
+            diff = std::fabs ( areaB - areaI - areaDba );
+                maxdiffop = "B == ( A ^ B ) + ( B - A )";
+                maxdiff = diff;
-			//  ( A @ B ) == ( A - B ) + ( B - A )
-			diff = std::fabs ( areaDab + areaDba - areaSD );
-				maxdiffop = "( A @ B ) == ( A - B ) + ( B - A )";
-				maxdiff = diff;
+            //  ( A @ B ) == ( A - B ) + ( B - A )
+            diff = std::fabs ( areaDab + areaDba - areaSD );
+                maxdiffop = "( A @ B ) == ( A - B ) + ( B - A )";
+                maxdiff = diff;
-			//  ( A u B ) == ( A ^ B ) + ( A @ B )
-			diff = std::fabs ( areaI + areaSD - areaU );
-				maxdiffop = "( A u B ) == ( A ^ B ) + ( A @ B )";
-				maxdiff = diff;
+            //  ( A u B ) == ( A ^ B ) + ( A @ B )
+            diff = std::fabs ( areaI + areaSD - areaU );
+                maxdiffop = "( A u B ) == ( A ^ B ) + ( A @ B )";
+                maxdiff = diff;
-			if ( maxdiff <= toleratedDiff )
-				success = 1 && validOut;
+            if ( maxdiff <= toleratedDiff )
+                success = 1 && validOut;
-			tmp << maxdiffop << ": " << maxdiff;
-			actual_result=tmp.str();
-			expected_result=opRes;
+            tmp << maxdiffop << ": " << maxdiff;
+            actual_result=tmp.str();
+            expected_result=opRes;
-		else if (opName=="distance")
-			char* rest;
-			double distE = std::strtod(opRes.c_str(), &rest);
-				throw std::runtime_error("malformed testcase: missing expected result in 'distance' op");
+        else if (opName=="distance")
+            char* rest;
+            double distE = std::strtod(opRes.c_str(), &rest);
+                throw std::runtime_error("malformed testcase: missing expected result in 'distance' op");
-			double distO = g1->distance(g2);
-			std::stringstream ss; ss << distO;
-			actual_result = ss.str();
+            double distO = g1->distance(g2);
+            std::stringstream ss; ss << distO;
+            actual_result = ss.str();
-			// TODO: Use a tolerance ?
-			success = ( distO == distE ) ? 1 : 0;
+            // TODO: Use a tolerance ?
+            success = ( distO == distE ) ? 1 : 0;
-		else
-			std::cerr << *curr_file << ":";
-			std::cerr << " case" << caseCount << ":";
-			std::cerr << " test" << testCount << ": "
-					  << opName << "(" << opSig << ")";
-			std::cerr << ": skipped (unrecognized)." << std::endl;
-			return;
+        else
+            std::cerr << *curr_file << ":";
+            std::cerr << " case" << caseCount << ":";
+            std::cerr << " test" << testCount << ": "
+                      << opName << "(" << opSig << ")";
+            std::cerr << ": skipped (unrecognized)." << std::endl;
+            return;
-		std::cerr<<"EXCEPTION on case "<<caseCount
-			<<" test "<<testCount<<": "<<e.what()
-			<<std::endl;
-		actual_result = e.what();
-	catch (...)
-		std::cerr << "Unknown EXEPTION on case "
-		          << caseCount
-		          << std::endl;
-		actual_result = "Unknown exception thrown";
+        std::cerr<<"EXCEPTION on case "<<caseCount
+            <<" test "<<testCount<<": "<<e.what()
+            <<std::endl;
+        actual_result = e.what();
+    catch (...)
+        std::cerr << "Unknown EXEPTION on case "
+                  << caseCount
+                  << std::endl;
+        actual_result = "Unknown exception thrown";
-	if ( success ) ++succeeded;
-	else ++failed;
+    if ( success ) ++succeeded;
+    else ++failed;
-	if ((!success && verbose) || verbose > 1)
-		printTest(!!success, expected_result, actual_result);
+    if ((!success && verbose) || verbose > 1)
+        printTest(!!success, expected_result, actual_result);
-	if (test_predicates && gB && gA) {
-		runPredicates(gA, gB);
+    if (test_predicates && gB && gA) {
+        runPredicates(gA, gB);
 void
 XMLTester::runPredicates(const geom::Geometry *gA, const geom::Geometry *gB)
-	std::cout << "\t    Equals:\tAB=" << (gA->equals(gB)?"T":"F") << ", BA=" << (gB->equals(gA)?"T":"F") << std::endl;
-	std::cout << "\t  Disjoint:\tAB=" << (gA->disjoint(gB)?"T":"F") << ", BA=" << (gB->disjoint(gA)?"T":"F") << std::endl;
-	std::cout << "\tIntersects:\tAB=" << (gA->intersects(gB)?"T":"F") << ", BA=" << (gB->intersects(gA)?"T":"F") << std::endl;
-	std::cout << "\t   Touches:\tAB=" << (gA->touches(gB)?"T":"F") << ", BA=" << (gB->touches(gA)?"T":"F") << std::endl;
-	std::cout << "\t   Crosses:\tAB=" << (gA->crosses(gB)?"T":"F") << ", BA=" << (gB->crosses(gA)?"T":"F") << std::endl;
-	std::cout << "\t    Within:\tAB=" << (gA->within(gB)?"T":"F") << ", BA=" << (gB->within(gA)?"T":"F") << std::endl;
-	std::cout << "\t  Contains:\tAB=" << (gA->contains(gB)?"T":"F") << ", BA=" << (gB->contains(gA)?"T":"F") << std::endl;
-	std::cout << "\t  Overlaps:\tAB=" << (gA->overlaps(gB)?"T":"F") << ", BA=" << (gB->overlaps(gA)?"T":"F") << std::endl;
+    std::cout << "\t    Equals:\tAB=" << (gA->equals(gB)?"T":"F") << ", BA=" << (gB->equals(gA)?"T":"F") << std::endl;
+    std::cout << "\t  Disjoint:\tAB=" << (gA->disjoint(gB)?"T":"F") << ", BA=" << (gB->disjoint(gA)?"T":"F") << std::endl;
+    std::cout << "\tIntersects:\tAB=" << (gA->intersects(gB)?"T":"F") << ", BA=" << (gB->intersects(gA)?"T":"F") << std::endl;
+    std::cout << "\t   Touches:\tAB=" << (gA->touches(gB)?"T":"F") << ", BA=" << (gB->touches(gA)?"T":"F") << std::endl;
+    std::cout << "\t   Crosses:\tAB=" << (gA->crosses(gB)?"T":"F") << ", BA=" << (gB->crosses(gA)?"T":"F") << std::endl;
+    std::cout << "\t    Within:\tAB=" << (gA->within(gB)?"T":"F") << ", BA=" << (gB->within(gA)?"T":"F") << std::endl;
+    std::cout << "\t  Contains:\tAB=" << (gA->contains(gB)?"T":"F") << ", BA=" << (gB->contains(gA)?"T":"F") << std::endl;
+    std::cout << "\t  Overlaps:\tAB=" << (gA->overlaps(gB)?"T":"F") << ", BA=" << (gB->overlaps(gA)?"T":"F") << std::endl;
 XMLTester::~XMLTester()
@@ -1437,14 +1437,14 @@
 static void
 usage(char *me, int exitcode, std::ostream &os)
-	os << "Usage: " << me << " [options] <test> [<test> ...]" << std::endl;
-	os << "Options: " << std::endl;
-	os << " -v                  Verbose mode "
-	   << "(multiple -v increment verbosity)" << std::endl
-	   << "--test-valid-output  Test output validity" << std::endl
-	   << "--test-valid-input   Test input validity" << std::endl
-	   << "--sql-output         Produce SQL output" << std::endl
-	   << "--wkb-output         Print Geometries as HEXWKB" << std::endl;
+    os << "Usage: " << me << " [options] <test> [<test> ...]" << std::endl;
+    os << "Options: " << std::endl;
+    os << " -v                  Verbose mode "
+       << "(multiple -v increment verbosity)" << std::endl
+       << "--test-valid-output  Test output validity" << std::endl
+       << "--test-valid-input   Test input validity" << std::endl
+       << "--sql-output         Produce SQL output" << std::endl
+       << "--wkb-output         Print Geometries as HEXWKB" << std::endl;
     std::exit(exitcode);
@@ -1452,70 +1452,70 @@
 int
 main(int argC, char* argV[])
-	int verbose=0;
-	bool sql_output=false;
+    int verbose=0;
+    bool sql_output=false;
 #if defined(_MSC_VER) && defined(GEOS_TEST_USE_STACKWALKER)
-	InitAllocCheck();
+    InitAllocCheck();
 #endif
-	if ( argC < 2 ) usage(argV[0], 1, std::cerr);
+    if ( argC < 2 ) usage(argV[0], 1, std::cerr);
-	XMLTester tester;
-	tester.setVerbosityLevel(verbose);
+    XMLTester tester;
+    tester.setVerbosityLevel(verbose);
-	for (int i=1; i<argC; ++i)
-		// increment verbosity level
-		if ( ! std::strcmp(argV[i], "-v" ) )
-			++verbose;
-			continue;
-		if ( ! std::strcmp(argV[i], "--test-valid-output" ) )
-			tester.testOutputValidity(true);
-			continue;
-		if ( ! std::strcmp(argV[i], "--sql-output" ) )
-			sql_output = true;
-			tester.setSQLOutput(sql_output);
-			continue;
-		if ( ! std::strcmp(argV[i], "--wkb-output" ) )
-			tester.setHEXWKBOutput(sql_output);
-			continue;
-		if ( ! std::strcmp(argV[i], "--test-valid-input" ) )
-			tester.testInputValidity(true);
-			continue;
+    for (int i=1; i<argC; ++i)
+        // increment verbosity level
+        if ( ! std::strcmp(argV[i], "-v" ) )
+            ++verbose;
+            continue;
+        if ( ! std::strcmp(argV[i], "--test-valid-output" ) )
+            tester.testOutputValidity(true);
+            continue;
+        if ( ! std::strcmp(argV[i], "--sql-output" ) )
+            sql_output = true;
+            tester.setSQLOutput(sql_output);
+            continue;
+        if ( ! std::strcmp(argV[i], "--wkb-output" ) )
+            tester.setHEXWKBOutput(sql_output);
+            continue;
+        if ( ! std::strcmp(argV[i], "--test-valid-input" ) )
+            tester.testInputValidity(true);
+            continue;
-		std::string source = argV[i];
+        std::string source = argV[i];
-		try {
-			tester.run(source);
+        try {
+            tester.run(source);
-	if ( ! sql_output ) tester.resultSummary(std::cout);
-	else tester.resultSummary(std::cerr);
+    if ( ! sql_output ) tester.resultSummary(std::cout);
+    else tester.resultSummary(std::cerr);
-	io::Unload::Release();
+    io::Unload::Release();
-	return tester.getFailuresCount();
+    return tester.getFailuresCount();
-	DeInitAllocCheck();
+    DeInitAllocCheck();
 #endif
More information about the geos-commits mailing list
