[geos-commits] r3739 - in branches/3.3: . src/algorithm tests/unit/capi
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Jan 11 06:25:48 PST 2013
Author: strk
Date: 2013-01-11 06:25:46 -0800 (Fri, 11 Jan 2013)
New Revision: 3739
   branches/3.3/NEWS
   branches/3.3/src/algorithm/InteriorPointLine.cpp
   branches/3.3/tests/unit/capi/GEOSPointOnSurfaceTest.cpp
Fix GEOSPointOnSurface with zero-length linestring (#609)
Modified: branches/3.3/NEWS
--- branches/3.3/NEWS	2012-12-06 17:44:57 UTC (rev 3738)
+++ branches/3.3/NEWS	2013-01-11 14:25:46 UTC (rev 3739)
@@ -5,6 +5,7 @@
     - Fix abort in RightmostEdgeFinder (#605)
     - Do not force precision reduction below 6 significant digits
       while trying to obtain a valid Buffer output (#605)
+    - Fix GEOSPointOnSurface with zero-length linestring (#609)
 Changes in 3.3.6
 2012-11-15 -- that's Post-GIS day !
Modified: branches/3.3/src/algorithm/InteriorPointLine.cpp
--- branches/3.3/src/algorithm/InteriorPointLine.cpp	2012-12-06 17:44:57 UTC (rev 3738)
+++ branches/3.3/src/algorithm/InteriorPointLine.cpp	2013-01-11 14:25:46 UTC (rev 3739)
@@ -48,8 +48,8 @@
 		std::cerr << "Centroid: " << centroid << std::endl;
 #endif
 		addInterior(g);
-		if (!hasInterior) addEndpoints(g);
+	if (!hasInterior) addEndpoints(g);
 InteriorPointLine::~InteriorPointLine()
@@ -119,8 +119,11 @@
 void
 InteriorPointLine::addEndpoints(const CoordinateSequence *pts)
-	add(pts->getAt(0));
-	add(pts->getAt(pts->getSize()-1));
+  size_t npts = pts->size();
+  if ( npts ) {
+    add(pts->getAt(0));
+    if ( npts > 1 ) add(pts->getAt(npts-1));
 /*private*/
Modified: branches/3.3/tests/unit/capi/GEOSPointOnSurfaceTest.cpp
--- branches/3.3/tests/unit/capi/GEOSPointOnSurfaceTest.cpp	2012-12-06 17:44:57 UTC (rev 3738)
+++ branches/3.3/tests/unit/capi/GEOSPointOnSurfaceTest.cpp	2013-01-11 14:25:46 UTC (rev 3739)
@@ -167,7 +167,25 @@
         wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
         ensure_equals(std::string(wkt_), std::string( "POINT EMPTY"));
+    // Single point linestring -- see http://trac.osgeo.org/geos/ticket/609
+    template<>
+    template<>
+    void object::test<6>()
+        geom1_ = GEOSGeomFromWKT("LINESTRING(0 0, 0 0)");
+        ensure( 0 != geom1_ );
+        geom2_ = GEOSPointOnSurface(geom1_);
+        ensure( 0 != geom2_ );
+        wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
+        ensure_equals(std::string(wkt_), std::string( "POINT (0 0)"));
 } // namespace tut
More information about the geos-commits mailing list
