[geos-commits] r3818 - in trunk: src/operation/buffer tests/unit tests/unit/operation/buffer
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Jun 11 08:29:53 PDT 2013
Author: mloskot
Date: 2013-06-11 08:29:53 -0700 (Tue, 11 Jun 2013)
New Revision: 3818
Removed:
   trunk/tests/unit/operation/buffer/BufferBuilderTest.cpp
   trunk/src/operation/buffer/OffsetCurveBuilder.cpp
   trunk/tests/unit/Makefile.am
Revert r3817 as partial or incorrect fix. See ticket #633 for details.
Modified: trunk/src/operation/buffer/OffsetCurveBuilder.cpp
--- trunk/src/operation/buffer/OffsetCurveBuilder.cpp	2013-06-11 14:19:38 UTC (rev 3817)
+++ trunk/src/operation/buffer/OffsetCurveBuilder.cpp	2013-06-11 15:29:53 UTC (rev 3818)
@@ -145,7 +145,7 @@
     const CoordinateSequence& simp2 = *simp2_;
     int n2 = simp2.size() - 1;
-    segGen->initSideSegments(simp2[n2], simp2[n2-1], Position::RIGHT);
+    segGen->initSideSegments(simp2[n2], simp2[n2-1], Position::LEFT);
     segGen->addFirstSegment();
     for (int i = n2-2; i >= 0; --i) {
       segGen->addNextSegment(simp2[i], true);
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am	2013-06-11 14:19:38 UTC (rev 3817)
+++ trunk/tests/unit/Makefile.am	2013-06-11 15:29:53 UTC (rev 3818)
@@ -80,7 +80,6 @@
 	noding/SegmentPointComparatorTest.cpp \
 	noding/snapround/HotPixelTest.cpp \
 	noding/snapround/MCIndexSnapRounderTest.cpp \
-	operation/buffer/BufferBuilderTest.cpp \
 	operation/buffer/BufferOpTest.cpp \
 	operation/buffer/BufferParametersTest.cpp \
 	operation/distance/DistanceOpTest.cpp \
Deleted: trunk/tests/unit/operation/buffer/BufferBuilderTest.cpp
--- trunk/tests/unit/operation/buffer/BufferBuilderTest.cpp	2013-06-11 14:19:38 UTC (rev 3817)
+++ trunk/tests/unit/operation/buffer/BufferBuilderTest.cpp	2013-06-11 15:29:53 UTC (rev 3818)
@@ -1,119 +0,0 @@
-// Test Suite for geos::operation::buffer::BufferBuilder class.
-// tut
-#include <tut.hpp>
-// geos
-#include <geos/operation/buffer/BufferBuilder.h>
-#include <geos/operation/buffer/BufferParameters.h>
-#include <geos/platform.h>
-#include <geos/geom/Coordinate.h>
-#include <geos/geom/GeometryFactory.h>
-#include <geos/geom/Geometry.h>
-#include <geos/algorithm/PointLocator.h>
-#include <geos/io/WKTReader.h>
-#include <geos/geom/CoordinateSequence.h>
-// std
-#include <memory>
-#include <string>
-#include <vector>
-namespace tut
-    // Test Group
-    // Common data used by tests
-    struct test_bufferbuilder_data
-        geos::geom::GeometryFactory gf;
-        geos::io::WKTReader wktreader;
-        int const default_quadrant_segments;
-        typedef geos::geom::Geometry::AutoPtr GeomPtr;
-        typedef std::auto_ptr<geos::geom::CoordinateSequence> CSPtr;
-        test_bufferbuilder_data()
-            : gf(), wktreader(&gf), default_quadrant_segments(geos::operation::buffer::BufferParameters::DEFAULT_QUADRANT_SEGMENTS)
-            ensure_equals(default_quadrant_segments, int(8));
-    private:
-        // noncopyable
-        test_bufferbuilder_data(test_bufferbuilder_data const& other);
-        test_bufferbuilder_data& operator=(test_bufferbuilder_data const& rhs);
-    typedef test_group<test_bufferbuilder_data> group;
-    typedef group::object object;
-    group test_bufferbuilder_group("geos::operation::buffer::BufferBuilder");
-    // Test Cases
-    // Left-side offset curve
-    template<>
-    template<>
-    void object::test<1>()
-        using geos::operation::buffer::BufferBuilder;
-        using geos::operation::buffer::BufferParameters;
-        std::string wkt0("LINESTRING ("
-            "665.7317504882812500 133.0762634277343700,"
-            "1774.4752197265625000 19.9391822814941410,"
-            "756.2413940429687500 466.8306579589843700,"
-            "626.1337890625000000 1898.0147705078125000,"
-            "433.8007202148437500 404.6052856445312500)");
-        GeomPtr g0(wktreader.read(wkt0));
-        double const distance = 57.164000837203;
-        bool const leftSide = true;
-        BufferParameters params;
-        params.setJoinStyle(BufferParameters::JOIN_MITRE);
-        params.setMitreLimit(5.57F); // somewhere between 5.5 and 5.6
-        params.setSingleSided(true);
-        BufferBuilder builder(params);
-        GeomPtr gBuffer(builder.bufferLineSingleSided(g0.get(), distance, leftSide ));
-        ensure_equals(gBuffer->getGeometryTypeId(), geos::geom::GEOS_LINESTRING);
-        // Left-side offset curve expected with 5 vertices
-        ensure_equals(gBuffer->getNumPoints(), std::size_t(5));
-    // Right-side offset curve
-    template<>
-    template<>
-    void object::test<2>()
-        bool const leftSide = false;
-        GeomPtr gBuffer(builder.bufferLineSingleSided(g0.get(), distance, leftSide));
-} // namespace tut
More information about the geos-commits mailing list
