[geos-commits] r3801 - in branches/3.3: . include/geos/operation/overlay/snap src/operation/overlay/snap tests/unit/capi
svn_geos at osgeo.org svn_geos at osgeo.org
Thu May 30 13:27:16 PDT 2013
Author: strk
Date: 2013-05-30 13:27:16 -0700 (Thu, 30 May 2013)
New Revision: 3801
   branches/3.3/NEWS
   branches/3.3/include/geos/operation/overlay/snap/LineStringSnapper.h
   branches/3.3/src/operation/overlay/snap/LineStringSnapper.cpp
   branches/3.3/tests/unit/capi/GEOSSnapTest.cpp
Improve snap algorithm reducing likelyhood of invalid output
 - Snap input vertices to closest snap point (#629)
 - Do not snap segments to external points (#501)
 - Never snap multiple vertices to the same snap point
Work funded by Tuscany Region - SITA. Contract "Support to the use
of GFOSS (Geographic Free and Open Source Software) Desktop tools"
(CIG Z3B06FA6D7).
Modified: branches/3.3/NEWS
--- branches/3.3/NEWS	2013-05-30 20:16:22 UTC (rev 3800)
+++ branches/3.3/NEWS	2013-05-30 20:27:16 UTC (rev 3801)
@@ -5,6 +5,7 @@
     - Fix area boundary return from GEOSPointOnSurface (#623)
     - Speedup GEOSWKBReader_read (#621)
     - Fix RobustLineIntersector handling of invalid intersection points (#622)
+    - Reduce likelyhood of invalid output from snap operation (#629, #501)
 Changes in 3.3.8
 2013-02-28
Modified: branches/3.3/include/geos/operation/overlay/snap/LineStringSnapper.h
--- branches/3.3/include/geos/operation/overlay/snap/LineStringSnapper.h	2013-05-30 20:16:22 UTC (rev 3800)
+++ branches/3.3/include/geos/operation/overlay/snap/LineStringSnapper.h	2013-05-30 20:27:16 UTC (rev 3801)
@@ -147,6 +147,11 @@
 			geom::CoordinateList::iterator from,
 			geom::CoordinateList::iterator too_far);
+	geom::CoordinateList::iterator findVertexToSnap(
+			const geom::Coordinate& snapPt,
+			geom::CoordinateList::iterator from,
+			geom::CoordinateList::iterator too_far);
     // Declare type as noncopyable
     LineStringSnapper(const LineStringSnapper& other);
     LineStringSnapper& operator=(const LineStringSnapper& rhs);
Modified: branches/3.3/src/operation/overlay/snap/LineStringSnapper.cpp
--- branches/3.3/src/operation/overlay/snap/LineStringSnapper.cpp	2013-05-30 20:16:22 UTC (rev 3800)
+++ branches/3.3/src/operation/overlay/snap/LineStringSnapper.cpp	2013-05-30 20:27:16 UTC (rev 3801)
@@ -16,6 +16,9 @@
  * Last port: operation/overlay/snap/LineStringSnapper.java r320 (JTS-1.12)
+ * NOTE: algorithm changed to improve output quality by reducing
+ *       probability of self-intersections
 #include <geos/operation/overlay/snap/LineStringSnapper.h>
@@ -34,6 +37,7 @@
 #if GEOS_DEBUG
 #include <iostream>
+#include <iomanip>
 using std::cerr;
 using std::endl;
 #endif
@@ -59,6 +63,53 @@
 /*private*/
+CoordinateList::iterator
+LineStringSnapper::findVertexToSnap(
+			const Coordinate& snapPt,
+			CoordinateList::iterator from,
+			CoordinateList::iterator too_far)
+	double minDist = snapTolerance; // make sure the first closer then
+	                                // snapTolerance is accepted
+	CoordinateList::iterator match=too_far;
+	for ( ; from != too_far; ++from)
+    Coordinate& c0 = *from;
+#if GEOS_DEBUG
+cerr << " Checking vertex " << c0 << endl;
+#endif
+		double dist = c0.distance(snapPt);
+		if ( dist >= minDist) {
+#if GEOS_DEBUG
+cerr << "   snap point distance " << dist
+     << " not smaller than tolerance "
+     << snapTolerance << " or previous closest "
+     << minDist << endl;
+#endif
+      continue;
+#if GEOS_DEBUG
+    cerr << "   snap point distance " << dist << " within tolerance "
+         << snapTolerance << " and closer than previous candidate "
+#endif
+    if ( dist == 0.0 ) return from; // can't find any closer
+    match = from;
+    minDist = dist;
+	return match;
+/*private*/
+#if 0 // changed to start looping from snap points
 void
 LineStringSnapper::snapVertices(geom::CoordinateList& srcCoords,
 			const geom::Coordinate::ConstVect& snapPts)
@@ -66,7 +117,7 @@
   if ( srcCoords.empty() ) return;
 #if GEOS_DEBUG
-cerr << "Snapping vertices of: " << srcCoords << endl;
+cerr << "Snapping vertices of: " << std::setprecision(15) << srcCoords << endl;
 #endif
 	using geom::CoordinateList;
@@ -98,6 +149,18 @@
 		assert(*found);
 		const Coordinate& snapPt = *(*found);
+#if 1
+    // Check if closest vertex for found snap is ourselves ?
+    CoordinateList::iterator vertpos = findVertexToSnap(snapPt, srcCoords.begin(), srcCoords.end());
+    if ( vertpos != it ) {
+#if GEOS_DEBUG
+cerr << " Snap found but it has a vertex point closer than this one" << endl;
+      continue;
+#endif
+#endif
 #if GEOS_DEBUG
 cerr << " found snap point " << snapPt << endl;
@@ -117,15 +180,88 @@
+#endif
+#if 1
 /*private*/
+void
+LineStringSnapper::snapVertices(geom::CoordinateList& srcCoords,
+			const geom::Coordinate::ConstVect& snapPts)
+  // nothing to do if there are no source coords..
+  if ( srcCoords.empty() ) return;
+#if GEOS_DEBUG
+cerr << "Snapping vertices of: " << srcCoords << endl;
+#endif
+	for ( Coordinate::ConstVect::const_iterator
+			it=snapPts.begin(), end=snapPts.end();
+			it != end;
+			++it)
+		assert(*it);
+		const Coordinate& snapPt = *(*it);
+#if GEOS_DEBUG
+cerr << "Checking for a vertex to snap to snapPt " << snapPt << endl;
+#endif
+		CoordinateList::iterator too_far = srcCoords.end();
+    if ( isClosed ) --too_far;
+			findVertexToSnap(snapPt, srcCoords.begin(), too_far);
+		if ( vertpos == too_far)
+#if GEOS_DEBUG
+cerr << " No vertex to snap" << endl;
+#endif
+			continue;
+#if 0
+    // Check if closest snap for found vertex is ourselves ?
+    Coordinate::ConstVect::const_iterator snappos =
+        findSnapForVertex(*vertpos, snapPts);
+    if ( snappos != it ) {
+#if GEOS_DEBUG
+cerr << " Vertex found but it has a snap point closer than this one" << endl;
+      continue;
+#endif
+#endif
+#if GEOS_DEBUG
+cerr << " Vertex to be snapped found, snapping" << endl;
+#endif
+    *vertpos = snapPt;
+    // keep final closing point in synch (rings only)
+    if (vertpos == srcCoords.begin() && isClosed)
+      vertpos = srcCoords.end(); --vertpos;
+#if GEOS_DEBUG
+cerr << " After vertex snapping, srcCoors are: " << srcCoords << endl;
+#endif
+#endif
+/*private*/
 LineStringSnapper::findSnapForVertex(const Coordinate& pt,
 			const Coordinate::ConstVect& snapPts)
+	Coordinate::ConstVect::const_iterator end = snapPts.end();
+	Coordinate::ConstVect::const_iterator candidate = end;
+	double minDist;
 	// TODO: use std::find_if
-	Coordinate::ConstVect::const_iterator end=snapPts.end();
 			it=snapPts.begin();
 			it != end;
@@ -134,14 +270,12 @@
 		assert(*it);
-		// shouldn't we look for *all* segments to be snapped rather then a single one?
 		if ( snapPt.equals2D(pt) )
 #if GEOS_DEBUG
 cerr << " points are equal, returning not-found " << endl;
 #endif
 			return end;
-			//continue;
 		double dist = snapPt.distance(pt);
@@ -151,18 +285,20 @@
 		if ( dist < snapTolerance )
-#if GEOS_DEBUG
-cerr << " snap point within tolerance, returning iterator to it" << endl;
-#endif
-			return it;
+      if ( candidate == end || dist < minDist ) {
+        minDist = dist;
+        candidate = it;
 #if GEOS_DEBUG
+  if ( candidate == end ) {
 cerr << " no snap point within distance, returning not-found" << endl;
 #endif
-	return end;
+	return candidate;
@@ -191,8 +327,6 @@
 cerr << "Checking for a segment to snap to snapPt " << snapPt << endl;
 #endif
-		// rather then a single one?
 		CoordinateList::iterator too_far = srcCoords.end(); --too_far;
 		CoordinateList::iterator segpos =
 			findSegmentToSnap(snapPt, srcCoords.begin(), too_far);
@@ -203,12 +337,113 @@
 #endif
 			continue;
+    /* Check if the snap point falls outside of the segment */
+    // If the snap point is outside, this means that an endpoint
+    // was not snap where it should have been
+    // so what we should do is re-snap the endpoint to this
+    // snapPt and then snap the closest between this and
+    // previous (for pf < 0.0) or next (for pf > 1.0) segment
+    // to the old endpoint.
+    //     --strk May 2013
+    // TODO: simplify this code, make more readable
+    CoordinateList::iterator to = segpos; ++to;
+    LineSegment seg(*segpos, *to);
+    double pf = seg.projectionFactor(snapPt);
+    if ( pf > 1.0 ) {
 #if GEOS_DEBUG
-cerr << " Segment to be snapped found, inserting point" << endl;
+      cerr << " Segment to be snapped is closer on his end point" << endl;
 #endif
-		// insert must happen one-past first point (before next point)
-		++segpos;
-		srcCoords.insert(segpos, snapPt);
+      Coordinate newSnapPt = seg.p1;
+      *to = seg.p1 = snapPt;
+      // now snap from-to (segpos) or to-next (segpos++) to newSnapPt
+      if ( to == too_far ) {
+        if ( isClosed ) {
+#if GEOS_DEBUG
+          cerr << " His end point is the last one, but is closed " << endl;
+#endif
+          *(srcCoords.begin()) = snapPt; // sync to start point
+          to = srcCoords.begin();
+        } else {
+#if GEOS_DEBUG
+          cerr << " His end point is the last one, inserting " << newSnapPt << " before it" << endl;
+#endif
+          srcCoords.insert(to, newSnapPt);
+          continue;
+      ++to;
+      LineSegment nextSeg(seg.p1, *to);
+      if ( nextSeg.distance(newSnapPt) < seg.distance(newSnapPt) ) {
+#if GEOS_DEBUG
+        cerr << " Next segment closer, inserting " << newSnapPt << " into " << nextSeg << endl;
+#endif
+        // insert into next segment
+      } else {
+#if GEOS_DEBUG
+        cerr << " This segment closer, inserting " << newSnapPt << " into " << seg << endl;
+#endif
+        // insert must happen one-past first point (before next point)
+        ++segpos;
+        srcCoords.insert(segpos, newSnapPt);
+    else if ( pf < 0.0 ) {
+#if GEOS_DEBUG
+      cerr << " Segment to be snapped is closer on his start point" << endl;
+#endif
+      Coordinate newSnapPt = seg.p0;
+      *segpos = seg.p0 = snapPt;
+      // now snap prev-from (--segpos) or from-to (segpos) to newSnapPt
+      if ( segpos == srcCoords.begin() ) {
+        if ( isClosed ) {
+#if GEOS_DEBUG
+          cerr << " His start point is the first one, but is closed " << endl;
+#endif
+          segpos = srcCoords.end(); --segpos;
+          *segpos = snapPt; // sync to end point
+        } else {
+#if GEOS_DEBUG
+          cerr << " His start point is the first one, inserting " << newSnapPt << " before it" << endl;
+#endif
+          ++segpos;
+          continue;
+#if GEOS_DEBUG
+cerr << " Before seg-snapping, srcCoors are: " << srcCoords << endl;
+#endif
+      --segpos;
+      LineSegment prevSeg(*segpos, seg.p0);
+      if ( prevSeg.distance(newSnapPt) < seg.distance(newSnapPt) ) {
+#if GEOS_DEBUG
+        cerr << " Prev segment closer, inserting " << newSnapPt << " into " << prevSeg << endl;
+#endif
+        // insert into prev segment
+      } else {
+#if GEOS_DEBUG
+#endif
+    else {
+      assert(pf != 0.0);
+#if GEOS_DEBUG
+cerr << " Segment to be snapped found, projection factor is " << pf << ", inserting point" << endl;
+#endif
+      ++segpos;
+      srcCoords.insert(segpos, snapPt);
 #if GEOS_DEBUG
@@ -226,8 +461,8 @@
 	LineSegment seg;
-	double minDist = snapTolerance+1; // make sure the first closer then
-	                                  // snapTolerance is accepted
@@ -267,30 +502,27 @@
 		double dist = seg.distance(snapPt);
-		if ( dist < snapTolerance ) {
-      if ( dist < minDist ) {
 #if GEOS_DEBUG
-cerr << "   snap point distance " << dist << " within tolerance "
-     << snapTolerance << " and closer than previous candidate " << minDist
-     << endl;
 #endif
-        match = from;
-        minDist = dist;
-#if GEOS_DEBUG
-      else {
-     << snapTolerance << " but not closer than previous candidate " << minDist
-     << endl;
-#endif
+      continue;
 #if GEOS_DEBUG
-    else {
-cerr << "   snap point distance " << dist << " bigger than tolerance "
-     << snapTolerance << endl;
 #endif
+    match = from;
+    minDist = dist;
 	return match;
Modified: branches/3.3/tests/unit/capi/GEOSSnapTest.cpp
--- branches/3.3/tests/unit/capi/GEOSSnapTest.cpp	2013-05-30 20:16:22 UTC (rev 3800)
+++ branches/3.3/tests/unit/capi/GEOSSnapTest.cpp	2013-05-30 20:27:16 UTC (rev 3801)
@@ -134,5 +134,88 @@
         ensure_equals(out, "LINESTRING (0 0, 9 0)");
+    /// See http://trac.osgeo.org/geos/ticket/501
+    template<>
+    template<>
+    void object::test<5>()
+        geom1_ = GEOSGeomFromWKT("LINESTRING(0 0, 10 0)");
+        geom2_ = GEOSGeomFromWKT("LINESTRING(0 0, 9 0, 10 0, 11 0)");
+        geom3_ = GEOSSnap(geom1_, geom2_, 2);
+        char* wkt_c = GEOSWKTWriter_write(w_, geom3_);
+        std::string out(wkt_c);
+        free(wkt_c);
+        //ensure_equals(out, "LINESTRING (0 0, 9 0, 10 0)");
+        ensure_equals(out, "LINESTRING (0 0, 9 0, 10 0, 11 0)");
+    /// Test snapping of equidistant segments to outlyers snap point
+    template<>
+    template<>
+    void object::test<6>()
+        geom1_ = GEOSGeomFromWKT("LINESTRING(0 3,4 1,0 1)");
+        geom2_ = GEOSGeomFromWKT("MULTIPOINT(5 0,4 1)");
+        free(wkt_c);
+        ensure_equals(out, "LINESTRING (0 3, 4 1, 5 0, 0 1)");
+        //ensure_equals(out, "LINESTRING (0 3, 4 1, 0 1)");
+    /// Same as the above but with the snap points order reversed
+    template<>
+    template<>
+    void object::test<7>()
+        geom2_ = GEOSGeomFromWKT("MULTIPOINT(4 1,5 0)");
+        free(wkt_c);
+    /// Test snapping of closed ring to outlyers snap point
+    template<>
+    template<>
+    void object::test<8>()
+        geom1_ = GEOSGeomFromWKT("LINESTRING(0 0,10 0,10 10,0 10,0 0)");
+        geom2_ = GEOSGeomFromWKT("MULTIPOINT(0 0,-1 0)");
+        geom3_ = GEOSSnap(geom1_, geom2_, 3);
+        free(wkt_c);
+        ensure_equals(out, "LINESTRING (-1 0, 0 0, 10 0, 10 10, 0 10, -1 0)");
+    template<>
+    template<>
+    void object::test<9>()
+        geom1_ = GEOSGeomFromWKT("LINESTRING(0 2,5 2,9 2,5 0)");
+        geom2_ = GEOSGeomFromWKT("POINT(5 0)");
+        free(wkt_c);
+        ensure_equals(out, "LINESTRING (0 2, 5 2, 9 2, 5 0)");
 } // namespace tut
More information about the geos-commits mailing list
