[geos-commits] r3948 - branches/3.3
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Sep 10 00:09:02 PDT 2013
Author: strk
Date: 2013-09-10 00:09:02 -0700 (Tue, 10 Sep 2013)
New Revision: 3948
   branches/3.3/COPYING
Fix FSF address in license file (#662)
Modified: branches/3.3/COPYING
--- branches/3.3/COPYING	2013-09-10 07:08:20 UTC (rev 3947)
+++ branches/3.3/COPYING	2013-09-10 07:09:02 UTC (rev 3948)
@@ -1,8 +1,8 @@
-		  GNU LESSER GENERAL PUBLIC LICENSE
-		       Version 2.1, February 1999
+                  GNU LESSER GENERAL PUBLIC LICENSE
+                       Version 2.1, February 1999
  Copyright (C) 1991, 1999 Free Software Foundation, Inc.
-     59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
+ 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
  Everyone is permitted to copy and distribute verbatim copies
  of this license document, but changing it is not allowed.
@@ -10,7 +10,7 @@
  as the successor of the GNU Library Public License, version 2, hence
  the version number 2.1.]
-			    Preamble
+                            Preamble
   The licenses for most software are designed to take away your
 freedom to share and change it.  By contrast, the GNU General Public
@@ -112,7 +112,7 @@
 former contains code derived from the library, whereas the latter must
 be combined with the library in order to run.
    TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
   0. This License Agreement applies to any software library or other
@@ -146,7 +146,7 @@
 on the Library (independent of the use of the Library in a tool for
 writing it).  Whether that is true depends on what the Library does
 and what the program that uses the Library does.
   1. You may copy and distribute verbatim copies of the Library's
 complete source code as you receive it, in any medium, provided that
 you conspicuously and appropriately publish on each copy an
@@ -432,7 +432,7 @@
 of all derivatives of our free software and of promoting the sharing
 and reuse of software generally.
-			    NO WARRANTY
+                            NO WARRANTY
   15. BECAUSE THE LIBRARY IS LICENSED FREE OF CHARGE, THERE IS NO
 WARRANTY FOR THE LIBRARY, TO THE EXTENT PERMITTED BY APPLICABLE LAW.
@@ -455,7 +455,7 @@
 SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH
 DAMAGES.
-		     END OF TERMS AND CONDITIONS
+                     END OF TERMS AND CONDITIONS
            How to Apply These Terms to Your New Libraries
@@ -485,7 +485,7 @@
     You should have received a copy of the GNU Lesser General Public
     License along with this library; if not, write to the Free Software
-    Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
+    Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
 Also add information on how to contact you by electronic and paper mail.
@@ -500,5 +500,3 @@
   Ty Coon, President of Vice
 That's all there is to it!
More information about the geos-commits mailing list
