[geos-commits] r3988 - in trunk: include/geos/geom/prep src/geom/prep
svn_geos at osgeo.org
Fri Jun 20 00:48:30 PDT 2014
Author: strk
Date: 2014-06-20 00:48:30 -0700 (Fri, 20 Jun 2014)
New Revision: 3988
trunk/include/geos/geom/prep/PreparedPoint.h
trunk/src/geom/prep/PreparedPoint.cpp
Fix PreparedPoint::intersects signature to match the upper virtual
Thanks Mikhail Veltishchev for pointing out
See https://github.com/libgeos/libgeos/pull/33
Modified: trunk/include/geos/geom/prep/PreparedPoint.h
--- trunk/include/geos/geom/prep/PreparedPoint.h 2014-06-20 07:39:23 UTC (rev 3987)
+++ trunk/include/geos/geom/prep/PreparedPoint.h 2014-06-20 07:48:30 UTC (rev 3988)
@@ -48,7 +48,7 @@
* The optimization here is that computing topology for the test
* geometry is avoided. This can be significant for large geometries.
- bool intersects(const geom::Geometry* g);
+ bool intersects(const geom::Geometry* g) const;
Modified: trunk/src/geom/prep/PreparedPoint.cpp
--- trunk/src/geom/prep/PreparedPoint.cpp 2014-06-20 07:39:23 UTC (rev 3987)
+++ trunk/src/geom/prep/PreparedPoint.cpp 2014-06-20 07:48:30 UTC (rev 3988)
@@ -24,7 +24,7 @@
namespace prep { // geos.geom.prep
bool
-PreparedPoint::intersects(const geom::Geometry* g)
+PreparedPoint::intersects(const geom::Geometry* g) const
if (! envelopesIntersect( g)) return false;
More information about the geos-commits
