[geos-commits] r3981 - in trunk: . src/algorithm src/geom src/io src/operation/buffer
svn_geos at osgeo.org svn_geos at osgeo.org
Wed May 7 10:32:22 PDT 2014
Author: mloskot
Date: 2014-05-07 10:32:22 -0700 (Wed, 07 May 2014)
New Revision: 3981
   trunk/nmake.opt
   trunk/src/algorithm/LineIntersector.cpp
   trunk/src/geom/LineSegment.cpp
   trunk/src/io/WKTWriter.cpp
   trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp
Apply minimal changes to enable building with Visual Studio 2013 (Ticket #691)
Modified: trunk/nmake.opt
--- trunk/nmake.opt	2014-03-29 10:44:53 UTC (rev 3980)
+++ trunk/nmake.opt	2014-05-07 17:32:22 UTC (rev 3981)
@@ -123,6 +123,9 @@
 !ELSEIF "$(_NMAKE_VER)" == "11.00.61030.0"
 GEOS_MSVC = 11.0
 GEOS_MSC = 1700
+!ELSEIF "$(_NMAKE_VER)" == "12.00.21005.1"
+GEOS_MSVC = 12.0
+GEOS_MSC = 1800
 !ELSE
 GEOS_MSVC = 0.0
 GEOS_MSC = 0
Modified: trunk/src/algorithm/LineIntersector.cpp
--- trunk/src/algorithm/LineIntersector.cpp	2014-03-29 10:44:53 UTC (rev 3980)
+++ trunk/src/algorithm/LineIntersector.cpp	2014-05-07 17:32:22 UTC (rev 3981)
@@ -29,6 +29,7 @@
 //#include <geos/util/Assert.h> // changed to TopologyException
 //#include <geos/util/TopologyException.h> // we don't throw anymore
+#include <algorithm> // for max()
 #include <string>
 #include <cmath> // for fabs()
 #include <cassert>
@@ -125,7 +126,7 @@
 		// <FIX>
 		// hack to ensure that non-endpoints always have a non-zero distance
 		if (dist == 0.0 && !(p==p0)) {
-			dist=max(pdx,pdy);
+			dist=(std::max)(pdx,pdy);
 	assert(!(dist == 0.0 && !(p==p0))); // Bad distance calculation
Modified: trunk/src/geom/LineSegment.cpp
--- trunk/src/geom/LineSegment.cpp	2014-03-29 10:44:53 UTC (rev 3980)
+++ trunk/src/geom/LineSegment.cpp	2014-05-07 17:32:22 UTC (rev 3981)
@@ -32,6 +32,7 @@
 #include <geos/profiler.h>
 #include <geos/inline.h>
 #include <sstream>
 #include <cmath>
@@ -168,10 +169,10 @@
 	int orient1 = algorithm::CGAlgorithms::orientationIndex(p0, p1, seg.p1);
 	// this handles the case where the points are L or collinear
 	if (orient0 >= 0 && orient1 >= 0)
-		return max(orient0, orient1);
+		return (std::max)(orient0, orient1);
 	// this handles the case where the points are R or collinear
 	if (orient0 <= 0 && orient1 <= 0)
 	// points lie on opposite sides ==> indeterminate orientation
 	return 0;
Modified: trunk/src/io/WKTWriter.cpp
--- trunk/src/io/WKTWriter.cpp	2014-03-29 10:44:53 UTC (rev 3980)
+++ trunk/src/io/WKTWriter.cpp	2014-05-07 17:32:22 UTC (rev 3981)
@@ -33,6 +33,7 @@
 #include <geos/geom/PrecisionModel.h>
 #include <geos/util/IllegalArgumentException.h>
+#include <algorithm> // for min
 #include <typeinfo>
 #include <cstdio> // should avoid this
 #include <string>
@@ -179,7 +180,7 @@
 WKTWriter::appendGeometryTaggedText(const Geometry *geometry, int level,
 		Writer *writer)
-  outputDimension = min( defaultOutputDimension,
+  outputDimension = (std::min)( defaultOutputDimension,
                          geometry->getCoordinateDimension() );
   indent(level, writer);
Modified: trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp
--- trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp	2014-03-29 10:44:53 UTC (rev 3980)
+++ trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp	2014-05-07 17:32:22 UTC (rev 3981)
@@ -37,6 +37,7 @@
 #include <geos/geomgraph/Label.h>
 #include <geos/noding/NodedSegmentString.h>
 #include <cmath>
 #include <cassert>
 #include <memory>
More information about the geos-commits mailing list
