[geos-commits] r4016 - trunk/php/test
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Sep 22 07:13:11 PDT 2014
Author: strk
Date: 2014-09-22 07:13:11 -0700 (Mon, 22 Sep 2014)
New Revision: 4016
   trunk/php/test/test.php
Refactored PHP bindings tests
Patch by Benjamin Morel <benjamin.morel at gmail.com>
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php	2014-09-22 07:42:02 UTC (rev 4015)
+++ trunk/php/test/test.php	2014-09-22 14:13:11 UTC (rev 4016)
@@ -2151,7 +2151,6 @@
         } catch (Exception $e) {
             $this->assertContains('LITTLE (1) or BIG (0)', $e->getMessage());
     public function testWKBWriter_getsetIncludeSRID()
@@ -2165,230 +2164,79 @@
         $this->assertEquals(FALSE, $writer->getIncludeSRID());
-    public function testWKBWriter_write()
+     * @dataProvider providerWKBWriter_write
+     * @param integer $byteOrder       The byte order: 0 for BIG endian, 1 for LITTLE endian.
+     * @param integer $inputDimension  The input dimension: 2 or 3.
+     * @param integer $outputDimension The output dimension: 2 or 3.
+     * @param boolean $includeSrid     Whether to include the SRID in the output.
+     * @param string  $wkb             The expected HEX WKB output.
+    public function testWKBWriter_write($byteOrder, $inputDimension, $outputDimension, $includeSrid, $wkb)
-        $writer = new GEOSWKBWriter();
         $reader = new GEOSWKTReader();
+        $writer = new GEOSWKBWriter();
-        try {
-            $writer->write(1);
-            $this->assertTrue(FALSE); # this is just to fail if we get here
-        } catch (Exception $e) {
-            $this->assertContains('expects parameter 1', $e->getMessage());
+        $writer->setByteOrder($byteOrder);
+        $writer->setOutputDimension($outputDimension);
+        $writer->setIncludeSRID($includeSrid);
+        if ($inputDimension === 3) {
+            $g = $reader->read('POINT(6 7 8)');
+            $g->setSRID(53);
+        } else {
+            $g = $reader->read('POINT(6 7)');
+            $g->setSRID(43);
-        $g = $reader->read('POINT(6 7)');
-        $g->setSRID(43);
+        $this->assertSame(hex2bin($wkb), $writer->write($g));
+        $this->assertSame($wkb, $writer->writeHEX($g));
-        $writer->setOutputDimension(2); // 2D
+    public function providerWKBWriter_write()
+        return array(
+            // 2D input
+            array(1, 2, 2, false, '010100000000000000000018400000000000001C40'),        // 2D LITTLE endian
+            array(1, 2, 2, true, '01010000202B00000000000000000018400000000000001C40'), // 2D LITTLE endian + SRID
+            array(0, 2, 2, false, '00000000014018000000000000401C000000000000'),        // 2D BIG endian
+            array(0, 2, 2, true, '00200000010000002B4018000000000000401C000000000000'), // 2D BIG endian + SRID
+            array(1, 2, 3, false, '010100000000000000000018400000000000001C40'),        // 3D LITTLE endian
+            array(1, 2, 3, true, '01010000202B00000000000000000018400000000000001C40'), // 3D LITTLE endian + SRID
+            array(0, 2, 3, false, '00000000014018000000000000401C000000000000'),        // 3D BIG endian
+            array(0, 2, 3, true, '00200000010000002B4018000000000000401C000000000000'), // 3D BIG endian + SRID
-        // 2D LITTLE endian
-        $writer->setByteOrder(1);
-        $this->assertEquals(
-            hex2bin('010100000000000000000018400000000000001C40'),
-            $writer->write($g));
-        // 2D LITTLE endian + SRID
-        $writer->setIncludeSRID(TRUE);
-            hex2bin('01010000202B00000000000000000018400000000000001C40'),
-        $writer->setIncludeSRID(FALSE);
-        // 2D BIG endian
-        $writer->setByteOrder(0);
-        $this->assertEquals(hex2bin('00000000014018000000000000401C000000000000'),
-        // 2D BIG endian + SRID
-            hex2bin('00200000010000002B4018000000000000401C000000000000'),
-        $writer->setOutputDimension(3); // 3D
-        // 3D LITTLE endian (2D input)
-        // 3D LITTLE endian + SRID  (2D input)
-        // 3D BIG endian (2D input)
-        // 3D BIG endian + SRID (2D input)
-        $g = $reader->read('POINT(6 7 8)');
-        $g->setSRID(53);
-        // 2D LITTLE endian (3D input)
-        $this->assertEquals(hex2bin('010100000000000000000018400000000000001C40'),
-        // 2D LITTLE endian + SRID (3D input)
-            hex2bin('01010000203500000000000000000018400000000000001C40'),
-        // 2D BIG endian (3D input)
-        // 2D BIG endian + SRID (3D input)
-            hex2bin('0020000001000000354018000000000000401C000000000000'),
-        // 3D LITTLE endian (3D input)
-            hex2bin('010100008000000000000018400000000000001C400000000000002040'),
-        // 3D BIG endian (3D input)
-            hex2bin('00800000014018000000000000401C0000000000004020000000000000'),
-        // 3D BIG endian + SRID (3D input)
-            hex2bin('00A0000001000000354018000000000000401C0000000000004020000000000000'),
+            // 3D input
+            array(1, 3, 2, false, '010100000000000000000018400000000000001C40'),                        // 2D LITTLE endian
+            array(1, 3, 2, true, '01010000203500000000000000000018400000000000001C40'),                 // 2D LITTLE endian + SRID
+            array(0, 3, 2, false, '00000000014018000000000000401C000000000000'),                        // 2D BIG endian
+            array(0, 3, 2, true, '0020000001000000354018000000000000401C000000000000'),                 // 2D BIG endian + SRID
+            array(1, 3, 3, false, '010100008000000000000018400000000000001C400000000000002040'),        // 3D LITTLE endian
+            array(1, 3, 3, true, '01010000A03500000000000000000018400000000000001C400000000000002040'), // 3D LITTLE endian + SRID
+            array(0, 3, 3, false, '00800000014018000000000000401C0000000000004020000000000000'),        // 3D BIG endian
+            array(0, 3, 3, true, '00A0000001000000354018000000000000401C0000000000004020000000000000'), // 3D BIG endian + SRID
-    public function testWKBWriter_writeHEX()
+     * @expectedException \Exception
+     * @expectedExceptionMessage expects parameter 1
+    public function testInvalidWriteThrowsException()
-        $reader = new GEOSWKTReader();
+        $writer->write(1);
-        try {
-            $writer->writeHEX(1);
-        $g->setSRID(43);
-            '010100000000000000000018400000000000001C40',
-            $writer->writeHEX($g));
-            '01010000202B00000000000000000018400000000000001C40',
-        // 2D BIG endian
-        $this->assertEquals('00000000014018000000000000401C000000000000',
-            '00200000010000002B4018000000000000401C000000000000',
-        $g->setSRID(53);
-        $this->assertEquals('010100000000000000000018400000000000001C40',
-            '01010000203500000000000000000018400000000000001C40',
-            '0020000001000000354018000000000000401C000000000000',
-            '010100008000000000000018400000000000001C400000000000002040',
-            '00800000014018000000000000401C0000000000004020000000000000',
-          '00A0000001000000354018000000000000401C0000000000004020000000000000',
+    public function testInvalidWriteHEXThrowsException()
+        $writer->writeHEX(1);
     public function testWKBReader__construct()
@@ -2397,7 +2245,14 @@
         $this->assertNotNull($reader);
-    public function testWKBReader_read()
+     * @dataProvider providerWKBReader_read
+     * @param string  $wkb  The WKB to read.
+     * @param boolean $is3D Whether the geometry is 3D (true) or 2D (false).
+     * @param integer $srid The expected result SRID.
+    public function testWKBReader_read($wkb, $is3D, $srid)
         $reader = new GEOSWKBReader();
@@ -2405,114 +2260,29 @@
         $writer->setTrim(TRUE);
-        $g = $reader->read(hex2bin(
-        $this->assertEquals('POINT (6 7)', $writer->write($g));
-        $this->assertEquals(0, $g->getSRID());
+        $wkt = $is3D ? 'POINT Z (6 7 8)' : 'POINT (6 7)';
-        // 2D BIG endian
-            '00000000014018000000000000401C000000000000'
+        $g = $reader->read(hex2bin($wkb));
+        $this->assertSame($wkt, $writer->write($g));
+        $this->assertSame($srid, $g->getSRID());
-        $this->assertEquals(43, $g->getSRID());
-        $this->assertEquals('POINT Z (6 7 8)', $writer->write($g));
-        // 3D BIG endian
-        $this->assertEquals(53, $g->getSRID());
+        $g = $reader->readHEX($wkb);
-    public function testWKBReader_readHEX()
+    public function providerWKBReader_read()
-        $reader = new GEOSWKBReader();
-        $writer = new GEOSWKTWriter();
-        $writer->setTrim(TRUE);
-        $g = $reader->readHEX(
+        return array(
+            array('010100000000000000000018400000000000001C40',                         false,  0), // 2D LITTLE endian,
+            array('00000000014018000000000000401C000000000000',                         false,  0), // 2D BIG endian,
+            array('01010000202B00000000000000000018400000000000001C40',                 false, 43), // 2D LITTLE endian + SRID
+            array('00200000010000002B4018000000000000401C000000000000',                 false, 43), // 2D BIG endian + SRID,
+            array('010100008000000000000018400000000000001C400000000000002040',         true,   0), // 3D LITTLE endian
+            array('01010000A03500000000000000000018400000000000001C400000000000002040', true,  53), // 3D LITTLE endian + SRID
+            array('00800000014018000000000000401C0000000000004020000000000000',         true,   0), // 3D BIG endian
+            array('00A0000001000000354018000000000000401C0000000000004020000000000000', true,  53), // 3D BIG endian + SRID
-        // 2D BIG endian
-        // 3D BIG endian
     public function testGEOSRelateMatch()
@@ -2522,5 +2292,4 @@
         $this->assertTrue(GEOSRelateMatch('0FFFFFFF2', 'TFFFFFFF2'));
         $this->assertFalse(GEOSRelateMatch('0FFFFFFF2', '0FFFFFFFF'));
More information about the geos-commits mailing list
