[geos-commits] r4049 - in trunk: . capi tests/unit/capi
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Apr 10 00:37:17 PDT 2015
Author: strk
Date: 2015-04-10 00:37:17 -0700 (Fri, 10 Apr 2015)
New Revision: 4049
Added:
   trunk/tests/unit/capi/GEOSisClosedTest.cpp
   trunk/NEWS
   trunk/capi/geos_ts_c.cpp
Support for MultiLineString->isClosed() in C API
Includes tests for GEOSisClosed() in C API
Patch by Benjamin Morel <benjamin.morel at gmail.com>
Modified: trunk/NEWS
--- trunk/NEWS	2015-03-02 11:22:29 UTC (rev 4048)
+++ trunk/NEWS	2015-04-10 07:37:17 UTC (rev 4049)
@@ -11,6 +11,7 @@
 - Improvements:
   - Speed-up intersection and difference between geometries
     with small bounding box overlap.
+  - CAPI: add MULTILINESTRING support for GEOSisClosed (Benjamin Morel)
 Changes in 3.4.2
 2013-08-25
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp	2015-03-02 11:22:29 UTC (rev 4048)
+++ trunk/capi/geos_ts_c.cpp	2015-04-10 07:37:17 UTC (rev 4049)
@@ -2574,7 +2574,7 @@
- * Call only on LINESTRING
+ * Call only on LINESTRING or MULTILINESTRING
  * return 2 on exception, 1 on true, 0 on false
 char
@@ -2595,13 +2595,20 @@
     try
     	using geos::geom::LineString;
+    	using geos::geom::MultiLineString;
     	const LineString *ls = dynamic_cast<const LineString *>(g1);
-    	if ( ! ls )
-    		handle->ERROR_MESSAGE("Argument is not a LineString");
-    		return 2;
+    	if ( ls ) {
+    	    return ls->isClosed();
-    	return ls->isClosed();
+    	const MultiLineString *mls = dynamic_cast<const MultiLineString *>(g1);
+    	if ( mls ) {
+    	    return mls->isClosed();
+        handle->ERROR_MESSAGE("Argument is not a LineString or MultiLineString");
+        return 2;
     catch (const std::exception &e)
Added: trunk/tests/unit/capi/GEOSisClosedTest.cpp
--- trunk/tests/unit/capi/GEOSisClosedTest.cpp	                        (rev 0)
+++ trunk/tests/unit/capi/GEOSisClosedTest.cpp	2015-04-10 07:37:17 UTC (rev 4049)
@@ -0,0 +1,95 @@
+// Test Suite for C-API GEOSisClosed
+#include <tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cctype>
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <cstring>
+namespace tut
+    // Test Group
+    // Common data used in test cases.
+    struct test_capiisclosed_data
+        GEOSGeometry* geom_;
+        static void notice(const char *fmt, ...)
+            std::fprintf( stdout, "NOTICE: ");
+            va_list ap;
+            va_start(ap, fmt);
+            std::vfprintf(stdout, fmt, ap);
+            va_end(ap);
+            std::fprintf(stdout, "\n");
+        test_capiisclosed_data() : geom_(0)
+            initGEOS(notice, notice);
+        ~test_capiisclosed_data()
+            GEOSGeom_destroy(geom_);
+            finishGEOS();
+    typedef test_group<test_capiisclosed_data> group;
+    typedef group::object object;
+    group test_capiisclosed_group("capi::GEOSisClosed");
+    // Test Cases
+    template<>
+    template<>
+    void object::test<1>()
+        geom_ = GEOSGeomFromWKT("LINESTRING(0 0, 1 0, 1 1)");
+        int r = GEOSisClosed(geom_);
+        ensure_equals(r, 0);
+    template<>
+    template<>
+    void object::test<2>()
+        geom_ = GEOSGeomFromWKT("LINESTRING(0 0, 0 1, 1 1, 0 0)");
+        ensure_equals(r, 1);
+    template<>
+    template<>
+    void object::test<3>()
+        geom_ = GEOSGeomFromWKT("MULTILINESTRING ((1 1, 1 2, 2 2, 1 1), (0 0, 0 1, 1 1))");
+    template<>
+    template<>
+    void object::test<4>()
+        geom_ = GEOSGeomFromWKT("MULTILINESTRING ((1 1, 1 2, 2 2, 1 1), (0 0, 0 1, 1 1, 0 0))");
+} // namespace tut
More information about the geos-commits mailing list
