[geos-commits] r4318 - trunk/src/algorithm
Sandro Santilli strk at kbt.io
Thu Dec 29 09:57:51 PST 2016
Author: strk
Date: 2016-12-29 09:57:51 -0800 (Thu, 29 Dec 2016)
New Revision: 4318
   trunk/src/algorithm/MinimumDiameter.cpp
Drop trailing blanks
Modified: trunk/src/algorithm/MinimumDiameter.cpp
--- trunk/src/algorithm/MinimumDiameter.cpp	2016-12-24 15:52:47 UTC (rev 4317)
+++ trunk/src/algorithm/MinimumDiameter.cpp	2016-12-29 17:57:51 UTC (rev 4318)
@@ -8,7 +8,7 @@
  * This is free software; you can redistribute and/or modify it under
  * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
+ * by the Free Software Foundation.
  * See the COPYING file for more information.
@@ -16,7 +16,7 @@
  * Last port: algorithm/MinimumDiameter.java r966
  * TODO:
  * 	- avoid heap allocation for LineSegment and Coordinate
@@ -49,7 +49,7 @@
  * by two parallel lines.
  * This can be thought of as the smallest hole that the geometry can be
  * moved through, with a single rotation.
  * The first step in the algorithm is computing the convex hull of the Geometry.
  * If the input Geometry is known to be convex, a hint can be supplied to
  * avoid this computation.
@@ -268,7 +268,7 @@
 	if (maxPerpDistance < minWidth) {
 		minPtIndex = maxIndex;
 		minWidth = maxPerpDistance;
-		delete minWidthPt;
+		delete minWidthPt;
 		minWidthPt = new Coordinate(pts->getAt(minPtIndex));
 		delete minBaseSeg;
 		minBaseSeg = new LineSegment(*seg);
More information about the geos-commits mailing list
